[U-Boot] [PATCH] Exynos5250: Remove lowlevelinit
Since we use CONFIG_SKIP_LOWLEVEL_INIT for Exynos baords, we dont need to a lowlevel_init.S file.
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com --- board/samsung/smdk5250/lowlevel_init.S | 82 ---------------------------------- 1 file changed, 82 deletions(-) delete mode 100644 board/samsung/smdk5250/lowlevel_init.S
diff --git a/board/samsung/smdk5250/lowlevel_init.S b/board/samsung/smdk5250/lowlevel_init.S deleted file mode 100644 index 9003e2d..0000000 --- a/board/samsung/smdk5250/lowlevel_init.S +++ /dev/null @@ -1,82 +0,0 @@ -/* - * Lowlevel setup for SMDK5250 board based on S5PC520 - * - * Copyright (C) 2012 Samsung Electronics - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <config.h> -#include <version.h> -#include <asm/arch/cpu.h> - -_TEXT_BASE: - .word CONFIG_SYS_TEXT_BASE - - .globl lowlevel_init -lowlevel_init: - - /* use iRAM stack in bl2 */ - ldr sp, =CONFIG_IRAM_STACK - stmdb r13!, {ip,lr} - - /* check reset status */ - ldr r0, =(EXYNOS5_POWER_BASE + INFORM1_OFFSET) - ldr r1, [r0] - - /* AFTR wakeup reset */ - ldr r2, =S5P_CHECK_DIDLE - cmp r1, r2 - beq exit_wakeup - - /* LPA wakeup reset */ - ldr r2, =S5P_CHECK_LPA - cmp r1, r2 - beq exit_wakeup - - /* Sleep wakeup reset */ - ldr r2, =S5P_CHECK_SLEEP - cmp r1, r2 - beq wakeup_reset - - /* - * If U-boot is already running in RAM, no need to relocate U-Boot. - * Memory controller must be configured before relocating U-Boot - * in ram. - */ - ldr r0, =0x0ffffff /* r0 <- Mask Bits*/ - bic r1, pc, r0 /* pc <- current addr of code */ - /* r1 <- unmasked bits of pc */ - ldr r2, _TEXT_BASE /* r2 <- original base addr in ram */ - bic r2, r2, r0 /* r2 <- unmasked bits of r2*/ - cmp r1, r2 /* compare r1, r2 */ - beq 1f /* r0 == r1 then skip sdram init */ - - /* init system clock */ - bl system_clock_init - - /* Memory initialize */ - bl mem_ctrl_init - -1: - bl arch_cpu_init - bl tzpc_init - ldmia r13!, {ip,pc} - -wakeup_reset: - bl system_clock_init - bl mem_ctrl_init - bl arch_cpu_init - bl tzpc_init - -exit_wakeup: - /* Load return address and jump to kernel */ - ldr r0, =(EXYNOS5_POWER_BASE + INFORM0_OFFSET) - - /* r1 = physical address of exynos5_cpu_resume function*/ - ldr r1, [r0] - - /* Jump to kernel */ - mov pc, r1 - nop - nop
Hi Rajeshwari,
On Fri, 14 Feb 2014 13:52:48 +0530, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
Builds fine on my side, and as it just removes dead code, I've assigned this patch to myself and will include it in my next PR. Thanks!
Amicalement,
Hi Albert,
On Fri, Feb 14, 2014 at 3:11 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Rajeshwari,
Sure Thanx
Hi Rajeshwari,
- Lowlevel setup for SMDK5250 board based on S5PC520
- Copyright (C) 2012 Samsung Electronics
-_TEXT_BASE:
-lowlevel_init:
- ldr r1, [r0]
- cmp r1, r2
- beq exit_wakeup
- cmp r1, r2
- beq exit_wakeup
- cmp r1, r2
- beq wakeup_reset
* in ram.
- bl mem_ctrl_init
-1:
- bl arch_cpu_init
- bl tzpc_init
-wakeup_reset:
- bl mem_ctrl_init
- bl arch_cpu_init
- bl tzpc_init
-exit_wakeup:
- ldr r1, [r0]
- mov pc, r1
- nop
- nop
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Rajeshwari Birje
Rajeshwari Shinde
