[U-Boot] [PATCH 1/1] efi_selftest: simplify lib/efi_selftest/Makefile
We should not make anything in lib/efi_selftest if CONFIG_CMD_BOOTEFI_SELFTEST is not defined.
We can make that test in lib/Makefile
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/Makefile | 2 +- lib/efi_selftest/Makefile | 10 ++-------- 2 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/lib/Makefile b/lib/Makefile index f169644850..849098995c 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -8,7 +8,7 @@ ifndef CONFIG_SPL_BUILD obj-$(CONFIG_EFI) += efi/ obj-$(CONFIG_EFI_LOADER) += efi_driver/ obj-$(CONFIG_EFI_LOADER) += efi_loader/ -obj-$(CONFIG_EFI_LOADER) += efi_selftest/ +obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += efi_selftest/ obj-$(CONFIG_LZMA) += lzma/ obj-$(CONFIG_BZIP2) += bzip2/ obj-$(CONFIG_TIZEN) += tizen/ diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 2f55d9d66f..0acd790550 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -10,7 +10,7 @@ CFLAGS_REMOVE_efi_selftest_miniapp_exit.o := $(CFLAGS_NON_EFI) -Os CFLAGS_efi_selftest_miniapp_return.o := $(CFLAGS_EFI) -Os -ffreestanding CFLAGS_REMOVE_efi_selftest_miniapp_return.o := $(CFLAGS_NON_EFI) -Os
-obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += \ +obj-y += \ efi_selftest.o \ efi_selftest_bitblt.o \ efi_selftest_config_table.o \ @@ -37,20 +37,16 @@ efi_selftest_util.o \ efi_selftest_variables.o \ efi_selftest_watchdog.o
-ifeq ($(CONFIG_CMD_BOOTEFI_SELFTEST),y) obj-$(CONFIG_CPU_V7) += efi_selftest_unaligned.o -endif
ifeq ($(CONFIG_BLK)$(CONFIG_PARTITIONS),yy) -obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += efi_selftest_block_device.o +obj-y += efi_selftest_block_device.o endif
# TODO: As of v2018.01 the relocation code for the EFI application cannot # be built on x86_64. ifeq ($(CONFIG_X86_64)$(CONFIG_SANDBOX),)
-ifneq ($(CONFIG_CMD_BOOTEFI_SELFTEST),) - obj-y += \ efi_selftest_startimage_exit.o \ efi_selftest_startimage_return.o @@ -74,5 +70,3 @@ $(obj)/efi_selftest_startimage_exit.o: $(obj)/efi_miniapp_file_image_exit.h $(obj)/efi_selftest_startimage_return.o: $(obj)/efi_miniapp_file_image_return.h
endif - -endif
