[PATCH 0/4] Convert CONFIG_SYS_MIPS_TIMER_FREQ to Kconfig
This removes CONFIG_SYS_HZ and converts CONFIG_SYS_MIPS_TIMER_FREQ to Kconfig. The series only applies on u-boot-mips/next (based on u-boot/next and the Mediatek MT7621 series).
Daniel Schwierzeck (4): MIPS: remove deprecated TARGET_VCT option MIPS: remove CONFIG_SYS_MHZ MIPS: mscc: remove unused CPU_CLOCK_RATE MIPS: convert CONFIG_SYS_MIPS_TIMER_FREQ to Kconfig
arch/mips/Kconfig | 26 +++++++++++++------ arch/mips/mach-jz47xx/include/mach/jz4780.h | 2 +- arch/mips/mach-jz47xx/jz4780/pll.c | 6 +---- board/imgtec/ci20/ci20.c | 4 --- configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/ap152_defconfig | 1 + configs/bcm968380gerg_ram_defconfig | 1 + configs/boston32r2_defconfig | 1 + configs/boston32r2el_defconfig | 1 + configs/boston32r6_defconfig | 1 + configs/boston32r6el_defconfig | 1 + configs/boston64r2_defconfig | 1 + configs/boston64r2el_defconfig | 1 + configs/boston64r6_defconfig | 1 + configs/boston64r6el_defconfig | 1 + configs/ci20_mmc_defconfig | 1 + configs/comtrend_ar5315u_ram_defconfig | 1 + configs/comtrend_ar5387un_ram_defconfig | 1 + configs/comtrend_ct5361_ram_defconfig | 1 + configs/comtrend_vr3032u_ram_defconfig | 1 + configs/comtrend_wap5813n_ram_defconfig | 1 + .../gardena-smart-gateway-mt7688_defconfig | 1 + configs/huawei_hg556a_ram_defconfig | 1 + configs/imgtec_xilfpga_defconfig | 1 + configs/linkit-smart-7688_defconfig | 1 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/mscc_jr2_defconfig | 1 + configs/mscc_luton_defconfig | 1 + configs/mscc_ocelot_defconfig | 1 + configs/mscc_serval_defconfig | 1 + configs/mscc_servalt_defconfig | 1 + configs/mt7620_mt7530_rfb_defconfig | 1 + configs/mt7620_rfb_defconfig | 1 + configs/mt7621_nand_rfb_defconfig | 1 + configs/mt7621_rfb_defconfig | 1 + configs/mt7628_rfb_defconfig | 1 + configs/netgear_cg3100d_ram_defconfig | 1 + configs/netgear_dgnd3700v2_ram_defconfig | 1 + configs/pic32mzdask_defconfig | 1 + configs/sagem_f@st1704_ram_defconfig | 1 + configs/sfr_nb4-ser_ram_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/vocore2_defconfig | 1 + include/configs/ap121.h | 3 --- include/configs/ap143.h | 3 --- include/configs/ap152.h | 3 --- include/configs/bmips_bcm3380.h | 3 --- include/configs/bmips_bcm6318.h | 3 --- include/configs/bmips_bcm63268.h | 3 --- include/configs/bmips_bcm6328.h | 3 --- include/configs/bmips_bcm6338.h | 3 --- include/configs/bmips_bcm6348.h | 3 --- include/configs/bmips_bcm6358.h | 3 --- include/configs/bmips_bcm6362.h | 3 --- include/configs/bmips_bcm6368.h | 3 --- include/configs/bmips_bcm6838.h | 3 --- include/configs/boston.h | 1 - include/configs/ci20.h | 4 --- .../configs/gardena-smart-gateway-mt7688.h | 3 --- include/configs/imgtec_xilfpga.h | 2 -- include/configs/linkit-smart-7688.h | 3 --- include/configs/malta.h | 2 -- include/configs/mt7620.h | 2 -- include/configs/mt7621.h | 2 -- include/configs/mt7628.h | 2 -- include/configs/pic32mzdask.h | 2 -- include/configs/tplink_wdr4300.h | 3 --- include/configs/vcoreiii.h | 7 ----- include/configs/vocore2.h | 3 --- scripts/config_whitelist.txt | 2 -- 74 files changed, 63 insertions(+), 95 deletions(-)
This board has been removed a long time ago.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com ---
arch/mips/Kconfig | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 2e0793a7a7..8bef63cbb7 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -39,14 +39,6 @@ config TARGET_MALTA select SWAP_IO_SPACE imply CMD_DM
-config TARGET_VCT - bool "Support vct" - select ROM_EXCEPTION_VECTORS - select SUPPORTS_BIG_ENDIAN - select SUPPORTS_CPU_MIPS32_R1 - select SUPPORTS_CPU_MIPS32_R2 - select SYS_MIPS_CACHE_INIT_RAM_LOAD - config ARCH_ATH79 bool "Support QCA/Atheros ath79" select DM
Thanks, Stefan
-config TARGET_VCT
Viele Grüße, Stefan Roese
Resolve all uses of CONFIG_SYS_MHZ with the currently defined value. Remove code which depends on CONFIG_SYS_MHZ but where no board configs actually use that code.
arch/mips/mach-jz47xx/include/mach/jz4780.h | 2 +- arch/mips/mach-jz47xx/jz4780/pll.c | 6 +----- board/imgtec/ci20/ci20.c | 4 ---- include/configs/ap121.h | 3 +-- include/configs/ap143.h | 3 +-- include/configs/ap152.h | 3 +-- include/configs/ci20.h | 3 +-- include/configs/malta.h | 3 +-- include/configs/tplink_wdr4300.h | 3 +-- scripts/config_whitelist.txt | 1 - 10 files changed, 8 insertions(+), 23 deletions(-)
diff --git a/arch/mips/mach-jz47xx/include/mach/jz4780.h b/arch/mips/mach-jz47xx/include/mach/jz4780.h index 4422e503ed..880445dac3 100644 --- a/arch/mips/mach-jz47xx/include/mach/jz4780.h +++ b/arch/mips/mach-jz47xx/include/mach/jz4780.h @@ -60,7 +60,7 @@
/* PLL setup */ #define JZ4780_SYS_EXTAL 48000000 -#define JZ4780_SYS_MEM_SPEED (CONFIG_SYS_MHZ * 1000000) +#define JZ4780_SYS_MEM_SPEED (1200 * 1000000) #define JZ4780_SYS_MEM_DIV 3 #define JZ4780_SYS_AUDIO_SPEED (768 * 1000000)
diff --git a/arch/mips/mach-jz47xx/jz4780/pll.c b/arch/mips/mach-jz47xx/jz4780/pll.c index 323c634fb3..4519b478cc 100644 --- a/arch/mips/mach-jz47xx/jz4780/pll.c +++ b/arch/mips/mach-jz47xx/jz4780/pll.c @@ -399,11 +399,7 @@ static void cpu_mux_select(int pll) ((2 - 1) << CPM_CPCCR_L2DIV_BIT) | ((1 - 1) << CPM_CPCCR_CDIV_BIT);
- if (CONFIG_SYS_MHZ >= 1000) - clk_ctrl |= (12 - 1) << CPM_CPCCR_PDIV_BIT; - else - clk_ctrl |= (6 - 1) << CPM_CPCCR_PDIV_BIT; - + clk_ctrl |= (12 - 1) << CPM_CPCCR_PDIV_BIT; clrsetbits_le32(cpm_regs + CPM_CPCCR, 0x00ffffff, clk_ctrl);
while (readl(cpm_regs + CPM_CPCSR) & (CPM_CPCSR_CDIV_BUSY | diff --git a/board/imgtec/ci20/ci20.c b/board/imgtec/ci20/ci20.c index 7cbe49abd9..89f5e7ad79 100644 --- a/board/imgtec/ci20/ci20.c +++ b/board/imgtec/ci20/ci20.c @@ -350,10 +350,6 @@ static const struct jz4780_ddr_config H5TQ2G83CFR_48_config = { .pulldn = 0x0e, };
-#if (CONFIG_SYS_MHZ != 1200) -#error No DDR configuration for CPU speed -#endif - const struct jz4780_ddr_config *jz4780_get_ddr_config(void) { const int board_revision = ci20_revision(); diff --git a/include/configs/ap121.h b/include/configs/ap121.h index 099aac5421..61cc073a8a 100644 --- a/include/configs/ap121.h +++ b/include/configs/ap121.h @@ -6,8 +6,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_MHZ 200 -#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) +#define CONFIG_SYS_MIPS_TIMER_FREQ 200000000
#define CONFIG_SYS_SDRAM_BASE 0x80000000
diff --git a/include/configs/ap143.h b/include/configs/ap143.h index 60b9e779fa..579b9b4f2c 100644 --- a/include/configs/ap143.h +++ b/include/configs/ap143.h @@ -6,8 +6,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_MHZ 325 -#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) +#define CONFIG_SYS_MIPS_TIMER_FREQ 325000000
diff --git a/include/configs/ap152.h b/include/configs/ap152.h index d165ead7bb..283762fd22 100644 --- a/include/configs/ap152.h +++ b/include/configs/ap152.h @@ -6,8 +6,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_MHZ 375 -#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) +#define CONFIG_SYS_MIPS_TIMER_FREQ 375000000
diff --git a/include/configs/ci20.h b/include/configs/ci20.h index 192da015e1..7e8a9fcb80 100644 --- a/include/configs/ci20.h +++ b/include/configs/ci20.h @@ -10,8 +10,7 @@ #define __CONFIG_CI20_H__
/* Ingenic JZ4780 clock configuration. */ -#define CONFIG_SYS_MHZ 1200 -#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) +#define CONFIG_SYS_MIPS_TIMER_FREQ 1200000000
/* Memory configuration */ #define CONFIG_SYS_MONITOR_LEN (512 * 1024) diff --git a/include/configs/malta.h b/include/configs/malta.h index c8b230ab21..717867d12a 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -18,8 +18,7 @@ /* * CPU Configuration */ -#define CONFIG_SYS_MHZ 250 /* arbitrary value */ -#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) +#define CONFIG_SYS_MIPS_TIMER_FREQ 250000000
/* * Memory map diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index f5466fd509..1400a211e3 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -6,8 +6,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_MHZ 280 -#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) +#define CONFIG_SYS_MIPS_TIMER_FREQ 280000000
#define CONFIG_SYS_SDRAM_BASE 0xa0000000
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index f4ae48d265..5f4972ab95 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1024,7 +1024,6 @@ CONFIG_SYS_MEMORY_SIZE CONFIG_SYS_MEM_RESERVE_SECURE CONFIG_SYS_MEM_SIZE CONFIG_SYS_MFD -CONFIG_SYS_MHZ CONFIG_SYS_MIPS_TIMER_FREQ CONFIG_SYS_MMC_CD_PIN CONFIG_SYS_MMC_CLK_OD
Thanks, Stefan
- else
- CPU Configuration
- Memory map
CPU_CLOCK_RATE is just used once for CONFIG_SYS_MIPS_TIMER_FREQ which is migrated to Kconfig in the next patch.
include/configs/vcoreiii.h | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 78a62a8b02..5c5036b8be 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -13,11 +13,9 @@ #define CONFIG_SYS_INIT_SP_OFFSET 0x400000
#if defined(CONFIG_SOC_LUTON) || defined(CONFIG_SOC_SERVAL) -#define CPU_CLOCK_RATE 416666666 /* Clock for the MIPS core */ #define CONFIG_SYS_MIPS_TIMER_FREQ 208333333 #else -#define CPU_CLOCK_RATE 500000000 /* Clock for the MIPS core */ -#define CONFIG_SYS_MIPS_TIMER_FREQ (CPU_CLOCK_RATE / 2) +#define CONFIG_SYS_MIPS_TIMER_FREQ 250000000 #endif #define CONFIG_SYS_NS16550_CLK CONFIG_SYS_MIPS_TIMER_FREQ
Thanks, Stefan
This converts the following to Kconfig: CONFIG_SYS_MIPS_TIMER_REQ
arch/mips/Kconfig | 18 ++++++++++++++++++ configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/ap152_defconfig | 1 + configs/bcm968380gerg_ram_defconfig | 1 + configs/boston32r2_defconfig | 1 + configs/boston32r2el_defconfig | 1 + configs/boston32r6_defconfig | 1 + configs/boston32r6el_defconfig | 1 + configs/boston64r2_defconfig | 1 + configs/boston64r2el_defconfig | 1 + configs/boston64r6_defconfig | 1 + configs/boston64r6el_defconfig | 1 + configs/ci20_mmc_defconfig | 1 + configs/comtrend_ar5315u_ram_defconfig | 1 + configs/comtrend_ar5387un_ram_defconfig | 1 + configs/comtrend_ct5361_ram_defconfig | 1 + configs/comtrend_vr3032u_ram_defconfig | 1 + configs/comtrend_wap5813n_ram_defconfig | 1 + configs/gardena-smart-gateway-mt7688_defconfig | 1 + configs/huawei_hg556a_ram_defconfig | 1 + configs/imgtec_xilfpga_defconfig | 1 + configs/linkit-smart-7688_defconfig | 1 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/mscc_jr2_defconfig | 1 + configs/mscc_luton_defconfig | 1 + configs/mscc_ocelot_defconfig | 1 + configs/mscc_serval_defconfig | 1 + configs/mscc_servalt_defconfig | 1 + configs/mt7620_mt7530_rfb_defconfig | 1 + configs/mt7620_rfb_defconfig | 1 + configs/mt7621_nand_rfb_defconfig | 1 + configs/mt7621_rfb_defconfig | 1 + configs/mt7628_rfb_defconfig | 1 + configs/netgear_cg3100d_ram_defconfig | 1 + configs/netgear_dgnd3700v2_ram_defconfig | 1 + configs/pic32mzdask_defconfig | 1 + configs/sagem_f@st1704_ram_defconfig | 1 + configs/sfr_nb4-ser_ram_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/vocore2_defconfig | 1 + include/configs/ap121.h | 2 -- include/configs/ap143.h | 2 -- include/configs/ap152.h | 2 -- include/configs/bmips_bcm3380.h | 3 --- include/configs/bmips_bcm6318.h | 3 --- include/configs/bmips_bcm63268.h | 3 --- include/configs/bmips_bcm6328.h | 3 --- include/configs/bmips_bcm6338.h | 3 --- include/configs/bmips_bcm6348.h | 3 --- include/configs/bmips_bcm6358.h | 3 --- include/configs/bmips_bcm6362.h | 3 --- include/configs/bmips_bcm6368.h | 3 --- include/configs/bmips_bcm6838.h | 3 --- include/configs/boston.h | 1 - include/configs/ci20.h | 3 --- include/configs/gardena-smart-gateway-mt7688.h | 3 --- include/configs/imgtec_xilfpga.h | 2 -- include/configs/linkit-smart-7688.h | 3 --- include/configs/malta.h | 1 - include/configs/mt7620.h | 2 -- include/configs/mt7621.h | 2 -- include/configs/mt7628.h | 2 -- include/configs/pic32mzdask.h | 2 -- include/configs/tplink_wdr4300.h | 2 -- include/configs/vcoreiii.h | 5 ----- include/configs/vocore2.h | 3 --- scripts/config_whitelist.txt | 1 - 71 files changed, 61 insertions(+), 68 deletions(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 8bef63cbb7..9af0133f10 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -14,6 +14,7 @@ choice
config TARGET_MALTA bool "Support malta" + select HAS_FIXED_TIMER_FREQUENCY select BOARD_EARLY_INIT_R select DM select DM_SERIAL @@ -41,17 +42,20 @@ config TARGET_MALTA
config ARCH_ATH79 bool "Support QCA/Atheros ath79" + select HAS_FIXED_TIMER_FREQUENCY select DM select OF_CONTROL imply CMD_DM
config ARCH_MSCC bool "Support MSCC VCore-III" + select HAS_FIXED_TIMER_FREQUENCY select OF_CONTROL select DM
config ARCH_BMIPS bool "Support BMIPS SoCs" + select HAS_FIXED_TIMER_FREQUENCY select CLK select CPU select DM @@ -62,6 +66,7 @@ config ARCH_BMIPS
config ARCH_MTMIPS bool "Support MediaTek MIPS platforms" + select HAS_FIXED_TIMER_FREQUENCY select CLK imply CMD_DM select DISPLAY_CPUINFO @@ -88,6 +93,7 @@ config ARCH_MTMIPS config ARCH_JZ47XX bool "Support Ingenic JZ47xx" select SUPPORT_SPL + select HAS_FIXED_TIMER_FREQUENCY select OF_CONTROL select DM
@@ -116,12 +122,14 @@ config ARCH_OCTEON
config MACH_PIC32 bool "Support Microchip PIC32" + select HAS_FIXED_TIMER_FREQUENCY select DM select OF_CONTROL imply CMD_DM
config TARGET_BOSTON bool "Support Boston" + select HAS_FIXED_TIMER_FREQUENCY select DM imply DM_EVENT select DM_SERIAL @@ -143,6 +151,7 @@ config TARGET_BOSTON
config TARGET_XILFPGA bool "Support Imagination Xilfpga" + select HAS_FIXED_TIMER_FREQUENCY select DM select DM_ETH select DM_GPIO @@ -246,6 +255,12 @@ config ROM_EXCEPTION_VECTORS Disable this, if the U-Boot image is booted from DRAM (e.g. by SPL). In that case the image size will be reduced by 0x500 bytes.
+config SYS_MIPS_TIMER_FREQ + int "Fixed MIPS CPU timer frequency in Hz" + depends on HAS_FIXED_TIMER_FREQUENCY + help + Configures a fixed CPU timer frequency. + config MIPS_CM_BASE hex "MIPS CM GCR Base Address" depends on MIPS_CM @@ -427,6 +442,9 @@ config SUPPORTS_CPU_MIPS64_R6 config SUPPORTS_CPU_MIPS64_OCTEON bool
+config HAS_FIXED_TIMER_FREQUENCY + bool + config CPU_CAVIUM_OCTEON bool
diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig index e522a3f4c0..5450807f29 100644 --- a/configs/ap121_defconfig +++ b/configs/ap121_defconfig @@ -10,6 +10,7 @@ CONFIG_DEBUG_UART_CLOCK=25000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x81000000 CONFIG_ARCH_ATH79=y +CONFIG_SYS_MIPS_TIMER_FREQ=200000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MEMTEST_START=0x80100000 CONFIG_SYS_MEMTEST_END=0x83f00000 diff --git a/configs/ap143_defconfig b/configs/ap143_defconfig index 4bdcea3060..7cdc88d33b 100644 --- a/configs/ap143_defconfig +++ b/configs/ap143_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x81000000 CONFIG_ARCH_ATH79=y CONFIG_TARGET_AP143=y +CONFIG_SYS_MIPS_TIMER_FREQ=325000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MEMTEST_START=0x80100000 CONFIG_SYS_MEMTEST_END=0x83f00000 diff --git a/configs/ap152_defconfig b/configs/ap152_defconfig index adcc6c54a8..dce30d441a 100644 --- a/configs/ap152_defconfig +++ b/configs/ap152_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x81000000 CONFIG_ARCH_ATH79=y CONFIG_TARGET_AP152=y +CONFIG_SYS_MIPS_TIMER_FREQ=375000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MEMTEST_START=0x80100000 CONFIG_SYS_MEMTEST_END=0x83f00000 diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 0475535e99..510b966437 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="brcm,bcm968380gerg" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6838=y +CONFIG_SYS_MIPS_TIMER_FREQ=160000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 2be57d2d1e..f60ca172ec 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_TARGET_BOSTON=y +CONFIG_SYS_MIPS_TIMER_FREQ=30000000 # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 524564355f..fd5eac0e13 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="img,boston" CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_TARGET_BOSTON=y +CONFIG_SYS_MIPS_TIMER_FREQ=30000000 # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/boston32r6_defconfig b/configs/boston32r6_defconfig index 7bb4e692d6..63e2e97ea0 100644 --- a/configs/boston32r6_defconfig +++ b/configs/boston32r6_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS32_R6=y +CONFIG_SYS_MIPS_TIMER_FREQ=30000000 # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/boston32r6el_defconfig b/configs/boston32r6el_defconfig index 8ae2f235b1..ee1a6679b6 100644 --- a/configs/boston32r6el_defconfig +++ b/configs/boston32r6el_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS32_R6=y +CONFIG_SYS_MIPS_TIMER_FREQ=30000000 # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 4a41e6b5cc..19144585b9 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0xffffffff88000000 CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS64_R2=y +CONFIG_SYS_MIPS_TIMER_FREQ=30000000 # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index 0670ffabbb..fa62ad76a4 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0xffffffff88000000 CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS64_R2=y +CONFIG_SYS_MIPS_TIMER_FREQ=30000000 # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/boston64r6_defconfig b/configs/boston64r6_defconfig index bf7f709524..1111df5668 100644 --- a/configs/boston64r6_defconfig +++ b/configs/boston64r6_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0xffffffff88000000 CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS64_R6=y +CONFIG_SYS_MIPS_TIMER_FREQ=30000000 # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/boston64r6el_defconfig b/configs/boston64r6el_defconfig index e1d46d3060..5c6a1cb668 100644 --- a/configs/boston64r6el_defconfig +++ b/configs/boston64r6el_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0xffffffff88000000 CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_TARGET_BOSTON=y CONFIG_CPU_MIPS64_R6=y +CONFIG_SYS_MIPS_TIMER_FREQ=30000000 # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index 07848a5933..65d9045ec7 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_MMC=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x81000000 CONFIG_ARCH_JZ47XX=y +CONFIG_SYS_MIPS_TIMER_FREQ=1200000000 CONFIG_FIT=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS4,115200 rw rootwait root=/dev/mmcblk0p1" diff --git a/configs/comtrend_ar5315u_ram_defconfig b/configs/comtrend_ar5315u_ram_defconfig index 36eab571ea..75cef92acc 100644 --- a/configs/comtrend_ar5315u_ram_defconfig +++ b/configs/comtrend_ar5315u_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="comtrend,ar-5315u" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6318=y +CONFIG_SYS_MIPS_TIMER_FREQ=166500000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/comtrend_ar5387un_ram_defconfig b/configs/comtrend_ar5387un_ram_defconfig index 68969c0413..fc477b9872 100644 --- a/configs/comtrend_ar5387un_ram_defconfig +++ b/configs/comtrend_ar5387un_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="comtrend,ar-5387un" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6328=y +CONFIG_SYS_MIPS_TIMER_FREQ=160000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index cb2caf4543..9d6cf49fb5 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="comtrend,ct-5361" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6348=y +CONFIG_SYS_MIPS_TIMER_FREQ=128000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/comtrend_vr3032u_ram_defconfig b/configs/comtrend_vr3032u_ram_defconfig index 138d3c84ba..c3b9e2982e 100644 --- a/configs/comtrend_vr3032u_ram_defconfig +++ b/configs/comtrend_vr3032u_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="comtrend,vr-3032u" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM63268=y +CONFIG_SYS_MIPS_TIMER_FREQ=200000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index b7174ff5ee..46e01980e5 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="comtrend,wap-5813n" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6368=y +CONFIG_SYS_MIPS_TIMER_FREQ=200000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index b9ee281be9..af67a730d4 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7628=y +CONFIG_SYS_MIPS_TIMER_FREQ=290000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index 2b5a587141..4ad9c4d1a8 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="huawei,hg556a" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6358=y +CONFIG_SYS_MIPS_TIMER_FREQ=150000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/imgtec_xilfpga_defconfig b/configs/imgtec_xilfpga_defconfig index 51c7e500dc..01ec605814 100644 --- a/configs/imgtec_xilfpga_defconfig +++ b/configs/imgtec_xilfpga_defconfig @@ -6,6 +6,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_DEFAULT_DEVICE_TREE="nexys4ddr" CONFIG_SYS_LOAD_ADDR=0x80500000 CONFIG_TARGET_XILFPGA=y +CONFIG_SYS_MIPS_TIMER_FREQ=50000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index a129679e9d..0bdb4e612c 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7628=y CONFIG_BOARD_LINKIT_SMART_7688=y +CONFIG_SYS_MIPS_TIMER_FREQ=290000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index e55b4a4914..1954dd3263 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0xffffffff81000000 CONFIG_ENV_ADDR=0xFFFFFFFFBE3E0000 CONFIG_TARGET_MALTA=y CONFIG_CPU_MIPS64_R2=y +CONFIG_SYS_MIPS_TIMER_FREQ=250000000 # CONFIG_AUTOBOOT is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index 6c6492d3fe..e93bbdedf2 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_ADDR=0xFFFFFFFFBE3E0000 CONFIG_TARGET_MALTA=y CONFIG_BUILD_TARGET="u-boot-swap.bin" CONFIG_CPU_MIPS64_R2=y +CONFIG_SYS_MIPS_TIMER_FREQ=250000000 CONFIG_SYS_LITTLE_ENDIAN=y # CONFIG_AUTOBOOT is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 3aff68b018..0f993309c2 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_SYS_LOAD_ADDR=0x81000000 CONFIG_ENV_ADDR=0xBE3E0000 CONFIG_TARGET_MALTA=y +CONFIG_SYS_MIPS_TIMER_FREQ=250000000 # CONFIG_AUTOBOOT is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index e268fb6374..0a47eb4a4b 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0x81000000 CONFIG_ENV_ADDR=0xBE3E0000 CONFIG_TARGET_MALTA=y CONFIG_BUILD_TARGET="u-boot-swap.bin" +CONFIG_SYS_MIPS_TIMER_FREQ=250000000 CONFIG_SYS_LITTLE_ENDIAN=y # CONFIG_AUTOBOOT is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index b2e1a8e826..81d22b0051 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -13,6 +13,7 @@ CONFIG_ENV_OFFSET_REDUND=0x140000 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_ARCH_MSCC=y CONFIG_SOC_JR2=y +CONFIG_SYS_MIPS_TIMER_FREQ=250000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fc00000 diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index 8eebe7b314..3ccc625506 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_ARCH_MSCC=y CONFIG_SOC_LUTON=y CONFIG_DDRTYPE_MT47H128M8HQ=y +CONFIG_SYS_MIPS_TIMER_FREQ=208333333 CONFIG_MIPS_BOOT_FDT=y CONFIG_DEBUG_UART=y CONFIG_SYS_MEMTEST_START=0x80000000 diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index 6ba9311626..660fa56b3f 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x140000 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_ARCH_MSCC=y +CONFIG_SYS_MIPS_TIMER_FREQ=250000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fc00000 diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index 1b9096682f..4f06f5d098 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_ARCH_MSCC=y CONFIG_SOC_SERVAL=y CONFIG_DDRTYPE_H5TQ1G63BFA=y +CONFIG_SYS_MIPS_TIMER_FREQ=208333333 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x87c00000 CONFIG_SYS_LITTLE_ENDIAN=y diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index ca358e666a..ad834f398c 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET_REDUND=0x140000 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_ARCH_MSCC=y CONFIG_SOC_SERVALT=y +CONFIG_SYS_MIPS_TIMER_FREQ=250000000 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fc00000 CONFIG_SYS_LITTLE_ENDIAN=y diff --git a/configs/mt7620_mt7530_rfb_defconfig b/configs/mt7620_mt7530_rfb_defconfig index 8c64bb740a..96f10926b1 100644 --- a/configs/mt7620_mt7530_rfb_defconfig +++ b/configs/mt7620_mt7530_rfb_defconfig @@ -16,6 +16,7 @@ CONFIG_DEBUG_UART_CLOCK=40000000 CONFIG_SYS_LOAD_ADDR=0x80010000 CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_MT7620_MT7530_RFB=y +CONFIG_SYS_MIPS_TIMER_FREQ=290000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig index 2aa6eb7e26..d96da91df3 100644 --- a/configs/mt7620_rfb_defconfig +++ b/configs/mt7620_rfb_defconfig @@ -15,6 +15,7 @@ CONFIG_DEBUG_UART_BASE=0xb0000c00 CONFIG_DEBUG_UART_CLOCK=40000000 CONFIG_SYS_LOAD_ADDR=0x80010000 CONFIG_ARCH_MTMIPS=y +CONFIG_SYS_MIPS_TIMER_FREQ=290000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/mt7621_nand_rfb_defconfig b/configs/mt7621_nand_rfb_defconfig index 0ad4849eb2..ee30f48fc3 100644 --- a/configs/mt7621_nand_rfb_defconfig +++ b/configs/mt7621_nand_rfb_defconfig @@ -15,6 +15,7 @@ CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7621=y CONFIG_MT7621_BOOT_FROM_NAND=y CONFIG_BOARD_MT7621_NAND_RFB=y +CONFIG_SYS_MIPS_TIMER_FREQ=440000000 # CONFIG_MIPS_CACHE_SETUP is not set # CONFIG_MIPS_CACHE_DISABLE is not set CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/mt7621_rfb_defconfig b/configs/mt7621_rfb_defconfig index fa66364817..9987cc5769 100644 --- a/configs/mt7621_rfb_defconfig +++ b/configs/mt7621_rfb_defconfig @@ -13,6 +13,7 @@ CONFIG_DEBUG_UART_CLOCK=50000000 CONFIG_SYS_LOAD_ADDR=0x83000000 CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7621=y +CONFIG_SYS_MIPS_TIMER_FREQ=440000000 # CONFIG_MIPS_CACHE_SETUP is not set # CONFIG_MIPS_CACHE_DISABLE is not set CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig index 14fc8b05e3..0e100fca49 100644 --- a/configs/mt7628_rfb_defconfig +++ b/configs/mt7628_rfb_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_LOAD_ADDR=0x80010000 CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7628=y CONFIG_BOARD_MT7628_RFB=y +CONFIG_SYS_MIPS_TIMER_FREQ=290000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/netgear_cg3100d_ram_defconfig b/configs/netgear_cg3100d_ram_defconfig index 4336116f57..860ef11384 100644 --- a/configs/netgear_cg3100d_ram_defconfig +++ b/configs/netgear_cg3100d_ram_defconfig @@ -7,6 +7,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="netgear,cg3100d" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y +CONFIG_SYS_MIPS_TIMER_FREQ=166500000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/netgear_dgnd3700v2_ram_defconfig b/configs/netgear_dgnd3700v2_ram_defconfig index 73de5ed15b..ff4ac67d6b 100644 --- a/configs/netgear_dgnd3700v2_ram_defconfig +++ b/configs/netgear_dgnd3700v2_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="netgear,dgnd3700v2" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6362=y +CONFIG_SYS_MIPS_TIMER_FREQ=200000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index a912ea638f..53c596dbcb 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -7,6 +7,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="pic32mzda_sk" CONFIG_SYS_LOAD_ADDR=0x88500000 CONFIG_MACH_PIC32=y +CONFIG_SYS_MIPS_TIMER_FREQ=100000000 # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_SYS_MEMTEST_START=0x88000000 diff --git a/configs/sagem_f@st1704_ram_defconfig b/configs/sagem_f@st1704_ram_defconfig index 875ae210de..1b989df466 100644 --- a/configs/sagem_f@st1704_ram_defconfig +++ b/configs/sagem_f@st1704_ram_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sagem,f@st1704" CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6338=y +CONFIG_SYS_MIPS_TIMER_FREQ=120000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index df008b797f..0f564befa7 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6358=y CONFIG_BOARD_SFR_NB4_SER=y +CONFIG_SYS_MIPS_TIMER_FREQ=150000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index 40dc2c158e..c6ecc38595 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tplink_wdr4300" CONFIG_SYS_LOAD_ADDR=0xa1000000 CONFIG_ARCH_ATH79=y CONFIG_BOARD_TPLINK_WDR4300=y +CONFIG_SYS_MIPS_TIMER_FREQ=280000000 CONFIG_SYS_MEMTEST_START=0x80100000 CONFIG_SYS_MEMTEST_END=0x83f00000 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/vocore2_defconfig b/configs/vocore2_defconfig index b362d549a2..98429a69a7 100644 --- a/configs/vocore2_defconfig +++ b/configs/vocore2_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_LOAD_ADDR=0x80100000 CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7628=y CONFIG_BOARD_VOCORE2=y +CONFIG_SYS_MIPS_TIMER_FREQ=290000000 CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/include/configs/ap121.h b/include/configs/ap121.h index 61cc073a8a..650140bb72 100644 --- a/include/configs/ap121.h +++ b/include/configs/ap121.h @@ -6,8 +6,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_MIPS_TIMER_FREQ 200000000 - #define CONFIG_SYS_SDRAM_BASE 0x80000000
#define CONFIG_SYS_INIT_RAM_ADDR 0xbd000000 diff --git a/include/configs/ap143.h b/include/configs/ap143.h index 579b9b4f2c..0eed8db23b 100644 --- a/include/configs/ap143.h +++ b/include/configs/ap143.h @@ -6,8 +6,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_MIPS_TIMER_FREQ 325000000 - #define CONFIG_SYS_SDRAM_BASE 0x80000000
#define CONFIG_SYS_INIT_RAM_ADDR 0xbd000000 diff --git a/include/configs/ap152.h b/include/configs/ap152.h index 283762fd22..7124711119 100644 --- a/include/configs/ap152.h +++ b/include/configs/ap152.h @@ -6,8 +6,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_MIPS_TIMER_FREQ 375000000 - #define CONFIG_SYS_SDRAM_BASE 0x80000000
#define CONFIG_SYS_INIT_RAM_ADDR 0xbd000000 diff --git a/include/configs/bmips_bcm3380.h b/include/configs/bmips_bcm3380.h index 66c23cd1d7..c328f41420 100644 --- a/include/configs/bmips_bcm3380.h +++ b/include/configs/bmips_bcm3380.h @@ -8,9 +8,6 @@
#include <linux/sizes.h>
-/* CPU */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 166500000 - /* RAM */ #define CONFIG_SYS_SDRAM_BASE 0x80000000
diff --git a/include/configs/bmips_bcm6318.h b/include/configs/bmips_bcm6318.h index 55c1d439d5..d16d50e5ec 100644 --- a/include/configs/bmips_bcm6318.h +++ b/include/configs/bmips_bcm6318.h @@ -8,9 +8,6 @@
diff --git a/include/configs/bmips_bcm63268.h b/include/configs/bmips_bcm63268.h index f046b7e662..f69c46b11c 100644 --- a/include/configs/bmips_bcm63268.h +++ b/include/configs/bmips_bcm63268.h @@ -8,9 +8,6 @@
-/* CPU */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 200000000 - /* RAM */ #define CONFIG_SYS_SDRAM_BASE 0x80000000
diff --git a/include/configs/bmips_bcm6328.h b/include/configs/bmips_bcm6328.h index 7e488072ed..acd021ecad 100644 --- a/include/configs/bmips_bcm6328.h +++ b/include/configs/bmips_bcm6328.h @@ -8,9 +8,6 @@
-/* CPU */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 160000000 - /* RAM */ #define CONFIG_SYS_SDRAM_BASE 0x80000000
diff --git a/include/configs/bmips_bcm6338.h b/include/configs/bmips_bcm6338.h index ddaa540513..c4d92db999 100644 --- a/include/configs/bmips_bcm6338.h +++ b/include/configs/bmips_bcm6338.h @@ -8,9 +8,6 @@
-/* CPU */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 120000000 - /* RAM */ #define CONFIG_SYS_SDRAM_BASE 0x80000000
diff --git a/include/configs/bmips_bcm6348.h b/include/configs/bmips_bcm6348.h index f704fe26ca..208a86a79d 100644 --- a/include/configs/bmips_bcm6348.h +++ b/include/configs/bmips_bcm6348.h @@ -8,9 +8,6 @@
-/* CPU */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 128000000 - /* RAM */ #define CONFIG_SYS_SDRAM_BASE 0x80000000
diff --git a/include/configs/bmips_bcm6358.h b/include/configs/bmips_bcm6358.h index 9aaa694cad..c098588db1 100644 --- a/include/configs/bmips_bcm6358.h +++ b/include/configs/bmips_bcm6358.h @@ -8,9 +8,6 @@
-/* CPU */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 150000000 - /* RAM */ #define CONFIG_SYS_SDRAM_BASE 0x80000000
diff --git a/include/configs/bmips_bcm6362.h b/include/configs/bmips_bcm6362.h index 34e542544c..6e707d341b 100644 --- a/include/configs/bmips_bcm6362.h +++ b/include/configs/bmips_bcm6362.h @@ -8,9 +8,6 @@
diff --git a/include/configs/bmips_bcm6368.h b/include/configs/bmips_bcm6368.h index 0319124a0e..d6ff1bcb35 100644 --- a/include/configs/bmips_bcm6368.h +++ b/include/configs/bmips_bcm6368.h @@ -8,9 +8,6 @@
diff --git a/include/configs/bmips_bcm6838.h b/include/configs/bmips_bcm6838.h index 481dfc20b3..a1c992b7a6 100644 --- a/include/configs/bmips_bcm6838.h +++ b/include/configs/bmips_bcm6838.h @@ -8,9 +8,6 @@
diff --git a/include/configs/boston.h b/include/configs/boston.h index 8b04492753..953112b5d9 100644 --- a/include/configs/boston.h +++ b/include/configs/boston.h @@ -13,7 +13,6 @@ /* * CPU */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 30000000
/* * PCI diff --git a/include/configs/ci20.h b/include/configs/ci20.h index 7e8a9fcb80..d094fb594f 100644 --- a/include/configs/ci20.h +++ b/include/configs/ci20.h @@ -9,9 +9,6 @@ #ifndef __CONFIG_CI20_H__ #define __CONFIG_CI20_H__
-/* Ingenic JZ4780 clock configuration. */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 1200000000 - /* Memory configuration */ #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index d21a9b9383..e1079a5e68 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -6,9 +6,6 @@ #ifndef __CONFIG_GARDENA_SMART_GATEWAY_H #define __CONFIG_GARDENA_SMART_GATEWAY_H
-/* CPU */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 290000000 - /* RAM */ #define CONFIG_SYS_SDRAM_BASE 0x80000000
diff --git a/include/configs/imgtec_xilfpga.h b/include/configs/imgtec_xilfpga.h index 599b0c50de..1fc45f9060 100644 --- a/include/configs/imgtec_xilfpga.h +++ b/include/configs/imgtec_xilfpga.h @@ -15,8 +15,6 @@ /*-------------------------------------------- * CPU configuration */ -/* CPU Timer rate */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 50000000
/*---------------------------------------------------------------------- * Memory Layout diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index 2e077dd516..1f4e0b0f86 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -6,9 +6,6 @@ #ifndef __CONFIG_LINKIT_SMART_7688_H #define __CONFIG_LINKIT_SMART_7688_H
diff --git a/include/configs/malta.h b/include/configs/malta.h index 717867d12a..2e7c34e243 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -18,7 +18,6 @@ /* * CPU Configuration */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 250000000
/* * Memory map diff --git a/include/configs/mt7620.h b/include/configs/mt7620.h index 049d9a1b55..ee8d40ddce 100644 --- a/include/configs/mt7620.h +++ b/include/configs/mt7620.h @@ -8,8 +8,6 @@ #ifndef __CONFIG_MT7620_H #define __CONFIG_MT7620_H
-#define CONFIG_SYS_MIPS_TIMER_FREQ 290000000 - #define CONFIG_SYS_SDRAM_BASE 0x80000000
#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 diff --git a/include/configs/mt7621.h b/include/configs/mt7621.h index 1f68997080..554c435842 100644 --- a/include/configs/mt7621.h +++ b/include/configs/mt7621.h @@ -8,8 +8,6 @@ #ifndef __CONFIG_MT7621_H #define __CONFIG_MT7621_H
-#define CONFIG_SYS_MIPS_TIMER_FREQ 440000000 - #define CONFIG_SYS_SDRAM_BASE 0x80000000
#define CONFIG_VERY_BIG_RAM diff --git a/include/configs/mt7628.h b/include/configs/mt7628.h index 3680c0fe44..402e772729 100644 --- a/include/configs/mt7628.h +++ b/include/configs/mt7628.h @@ -8,8 +8,6 @@ #ifndef __CONFIG_MT7628_H #define __CONFIG_MT7628_H
#define CONFIG_SYS_INIT_SP_OFFSET 0x80000 diff --git a/include/configs/pic32mzdask.h b/include/configs/pic32mzdask.h index 0a07c9c29c..9d796f9f34 100644 --- a/include/configs/pic32mzdask.h +++ b/include/configs/pic32mzdask.h @@ -13,8 +13,6 @@ /*-------------------------------------------- * CPU configuration */ -/* CPU Timer rate */ -#define CONFIG_SYS_MIPS_TIMER_FREQ 100000000
/*---------------------------------------------------------------------- * Memory Layout diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index 1400a211e3..b14726ad23 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -6,8 +6,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_MIPS_TIMER_FREQ 280000000 - #define CONFIG_SYS_SDRAM_BASE 0xa0000000
#define CONFIG_SYS_INIT_RAM_ADDR 0xbd000000 diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 5c5036b8be..02ddc6fb6e 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -12,11 +12,6 @@
-#if defined(CONFIG_SOC_LUTON) || defined(CONFIG_SOC_SERVAL) -#define CONFIG_SYS_MIPS_TIMER_FREQ 208333333 -#else -#define CONFIG_SYS_MIPS_TIMER_FREQ 250000000 -#endif #define CONFIG_SYS_NS16550_CLK CONFIG_SYS_MIPS_TIMER_FREQ
#define CONFIG_SYS_SDRAM_BASE 0x80000000 diff --git a/include/configs/vocore2.h b/include/configs/vocore2.h index 6a7a0832c9..970c275839 100644 --- a/include/configs/vocore2.h +++ b/include/configs/vocore2.h @@ -6,9 +6,6 @@ #ifndef __VOCORE2_CONFIG_H__ #define __VOCORE2_CONFIG_H__
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 5f4972ab95..27bf0c4722 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1024,7 +1024,6 @@ CONFIG_SYS_MEMORY_SIZE CONFIG_SYS_MEM_RESERVE_SECURE CONFIG_SYS_MEM_SIZE CONFIG_SYS_MFD -CONFIG_SYS_MIPS_TIMER_FREQ CONFIG_SYS_MMC_CD_PIN CONFIG_SYS_MMC_CLK_OD CONFIG_SYS_MMC_MAX_BLK_COUNT
Thanks, Stefan
- select HAS_FIXED_TIMER_FREQUENCY select BOARD_EARLY_INIT_R select DM select DM_SERIAL
- select HAS_FIXED_TIMER_FREQUENCY select CLK imply CMD_DM select DISPLAY_CPUINFO
- select HAS_FIXED_TIMER_FREQUENCY select OF_CONTROL select DM
- select HAS_FIXED_TIMER_FREQUENCY select DM select DM_ETH select DM_GPIO
- int "Fixed MIPS CPU timer frequency in Hz"
- depends on HAS_FIXED_TIMER_FREQUENCY
- help
- config MIPS_CM_BASE hex "MIPS CM GCR Base Address" depends on MIPS_CM
- bool
- config CPU_CAVIUM_OCTEON bool
- CPU
- PCI
- CPU configuration
- Memory Layout
- CPU Configuration
- Memory map
- CPU configuration
- Memory Layout
Daniel Schwierzeck
Stefan Roese
