[U-Boot] [PATCH V2 1/2] imx: spl: enable CONFIG_SPL_WATCHDOG_SUPPORT
This commit 4bdcbe60a142b08eefccb0e326a37ba81d3389e8 removes reset_cpu which breaks SPL build when DEBUG macro defined.
" arch/arm/lib/built-in.o: In function `do_reset': ~/uboot/arch/arm/lib/reset.c:45: undefined reference to `reset_cpu' scripts/Makefile.spl:244: recipe for target 'spl/u-boot-spl' failed " Enable CONFIG_SPL_WATCHDOG_SUPPORT to fix this issue.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Marek Vasut marex@denx.de Cc: Tim Harvey tharvey@gateworks.com --- include/configs/imx6_spl.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 43ce7fe..68d3fd7 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -34,6 +34,7 @@ #define CONFIG_SPL_SERIAL_SUPPORT #define CONFIG_SPL_I2C_SUPPORT #define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_WATCHDOG_SUPPORT
/* NAND support */ #if defined(CONFIG_SPL_NAND_SUPPORT)
With DEBUG macro enabled, SPL build failure: " arch/arm/cpu/armv7/built-in.o: In function `reset_misc': ~/uboot/arch/arm/cpu/armv7/mx6/soc.c:406: undefined reference to `lcdif_power_down' scripts/Makefile.spl:244: recipe for target 'spl/u-boot-spl' failed " Wrap VIDEO settings with ifndef CONFIG_SPL_BUILD
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Stefano Babic sbabic@denx.de --- include/configs/mx6ul_14x14_evk.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 5779632..a4f624c 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -243,6 +243,7 @@
#define CONFIG_IMX_THERMAL
+#ifndef CONFIG_SPL_BUILD #define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE @@ -259,5 +260,6 @@ #define CONFIG_VIDEO_BMP_LOGO #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR #endif +#endif
#endif
Hi Peng,
I've been carrying a local patch for the same, so
Acked-by: Eric Nelson eric@nelint.com
Why don't you implement dummy reset_cpu() {} instead ?
Best regards, Marek Vasut
Do you mean this, https://patchwork.ozlabs.org/patch/562232/?
Regards, Peng
On Monday, January 04, 2016 at 01:40:10 PM, Peng Fan wrote:
Hi Marek,
Yes, I'd prefer that, since I do not want to see watchdog support becoming mandatory part of the SPL build. Watchdog support should be optional.
Hi Marek,
Wait for Stefano's comments on this -:)
Regards, Peng.
Hi Marek, Peng,
Hi Marek,
Yes, enabling watchdog should be not be mandatory. Anyway, this happens only if CONFIG_IMX_WATCHDOG is set, else CONFIG_SPL_WATCHDOG_SUPPORT lets only to link reset_cpu() to the build. This is also what happens for all MX6 boards that do not enable the watchdog but need reset_cpu().
Adding another dummy function looks nasty to me, and Fabio sent some time ago patches to clean up this and drop empty reset_cpu() inside board files. We should not create this mess again.
Best regards, Stefano Babic
On Monday, January 04, 2016 at 01:57:59 PM, Stefano Babic wrote:
Hi Marek, Peng,
Hi Marek,
This is completely counter-intuitive and stupid. I suspect this behavior is required on iMX because iMXes reset through watchdog, yes ? In that case, add a comment explaining why we always select watchdog in SPL on i.MXes.
Fine
Eric Nelson
Peng Fan
Stefano Babic
