[U-Boot] [PATCH 2/8] sun8i: Add CCI-400 definitions
Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index 65c0441..76da00f 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -18,6 +18,9 @@ #define SUNXI_SRAM_D_BASE 0x00010000 /* 4 kiB */ #define SUNXI_SRAM_B_BASE 0x00020000 /* 64 kiB (secure) */
+#define SUN8I_CPUXCFG_BASE 0x01700000 +#define SUN8I_CCI400_BASE 0x01790000 + #define SUNXI_SRAMC_BASE 0x01c00000 #define SUNXI_DRAMC_BASE 0x01c01000 #define SUNXI_DMA_BASE 0x01c02000 @@ -168,6 +171,10 @@ #define SUNXI_SS_BOND_ID_A31 4 #define SUNXI_SS_BOND_ID_A31S 5
+#define CCI400_DVM_MESSAGE_REQ_EN 0x00000002 +#define CCI400_SNOOP_REQ_EN 0x00000001 +#define CCI400_SHAORD_NON_SHAREABLE 0x00000002 + #ifndef __ASSEMBLY__ void sunxi_board_init(void); void sunxi_reset(void);
On Tue, May 17, 2016 at 10:38 AM, tpearson@raptorengineering.com wrote:
A commit message would be nice.
Please use SUNXI_ prefix. We can potentially add A80 support later on using the same macro names.
_SHA_ORD_ would be better as the original name is "Shareable Override Register".
CCI-400 is a standard IP block from ARM. Please move the definitions to a separate, shared header, preferably under arch/arm/include/asm/.
ChenYu
#ifndef __ASSEMBLY__ void sunxi_board_init(void); void sunxi_reset(void); -- 2.8.0.rc3
Chen-Yu Tsai
