[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 1811a928c6c7604d6d05a84b4d552a7c31b4994e:
Move most CONFIG_HAVE_BLOCK_DEVICE to Kconfig (2018-02-08 19:09:03 -0500)
git://git.denx.de/u-boot-fsl-qoriq.git
for you to fetch changes up to ee3556bcafbb05e59aabdc31368984e76acaabc4:
drivers/ddr/fsl: Dual-license DDR driver (2018-02-09 08:36:40 -0800)
---------------------------------------------------------------- Hou Zhiqiang (1): ARMv8: ls1046a: Enable PCIe and E1000 in lpuart defconfig
Lukas Auer (1): crypto/fsl: instantiate all rng state handles
Rajat Srivastava (1): armv8: ls1088a: qspi: Enable XIP mode above 16 MB addresses
Sriram Dash (1): armv8: Remove dependency of SERDES for LSCH2 and LSCH3
Vinitha Pillai-B57223 (1): armv8: ls1012ardb: Add distro secure boot support
York Sun (1): drivers/ddr/fsl: Dual-license DDR driver
Zhao Qiang (1): PowerPC: phy: enable all phylib drivers when use phylib and tsec enet
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 14 +++++-- arch/powerpc/include/asm/config.h | 4 +- configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 13 +++--- configs/ls1046aqds_lpuart_defconfig | 7 ++++ configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088aqds_qspi_defconfig | 1 + configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_qspi_defconfig | 1 + drivers/crypto/fsl/jobdesc.c | 35 ++++++++-------- drivers/crypto/fsl/jobdesc.h | 2 +- drivers/crypto/fsl/jr.c | 57 ++++++++++++++++----------- drivers/crypto/fsl/jr.h | 2 + drivers/ddr/fsl/arm_ddr_gen3.c | 2 +- drivers/ddr/fsl/ctrl_regs.c | 2 +- drivers/ddr/fsl/ddr1_dimm_params.c | 2 +- drivers/ddr/fsl/ddr2_dimm_params.c | 2 +- drivers/ddr/fsl/ddr3_dimm_params.c | 2 +- drivers/ddr/fsl/ddr4_dimm_params.c | 2 +- drivers/ddr/fsl/fsl_ddr_gen4.c | 2 +- drivers/ddr/fsl/fsl_mmdc.c | 2 +- drivers/ddr/fsl/interactive.c | 2 +- drivers/ddr/fsl/lc_common_dimm_params.c | 2 +- drivers/ddr/fsl/main.c | 2 +- drivers/ddr/fsl/mpc85xx_ddr_gen1.c | 2 +- drivers/ddr/fsl/mpc85xx_ddr_gen2.c | 2 +- drivers/ddr/fsl/mpc85xx_ddr_gen3.c | 2 +- drivers/ddr/fsl/mpc86xx_ddr.c | 2 +- drivers/ddr/fsl/options.c | 2 +- drivers/ddr/fsl/util.c | 2 +- include/common_timing_params.h | 2 +- include/configs/ls1012ardb.h | 20 +++++++++- include/fsl_ddr.h | 2 +- include/fsl_ddr_dimm_params.h | 2 +- include/fsl_ddrc_version.h | 2 +- include/fsl_immap.h | 2 +- include/fsl_mmdc.h | 2 +- include/fsl_sec.h | 3 ++ 37 files changed, 129 insertions(+), 78 deletions(-)
Thanks.
York
On Mon, Feb 12, 2018 at 05:06:35PM +0000, York Sun wrote:
Tom,
York Sun
