[U-Boot] [PATCH 08/12] macb: Fix return values of macb_eth_initialize()
macb: Return 1 from macb_eth_initialize() upon successful initialization and 0 in case of failure
Signed-off-by: Matthias Kaehlcke matthias@kaehlcke.net --- drivers/net/macb.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index c184353..e2a0724 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -500,7 +500,7 @@ int macb_eth_initialize(int id, void *regs, unsigned int phy_addr) macb = malloc(sizeof(struct macb_device)); if (!macb) { printf("Error: Failed to allocate memory for MACB%d\n", id); - return -1; + return 0; } memset(macb, 0, sizeof(struct macb_device));
@@ -542,7 +542,7 @@ int macb_eth_initialize(int id, void *regs, unsigned int phy_addr)
eth_register(netdev);
- return 0; + return 1; }
#endif
return -1;
}return 0;
this is an error path thus the current code is correct -mike
Matthias Kaehlcke
Mike Frysinger
