[PATCH 0/5] arm64: zynqmp: DT sync with Linux kernel
I found some differences between kernel and u-boot that's why do small sync up.
Thanks, Michal
Michal Simek (5): arm64: zynqmp: Sync #dma-cells property location arm64: zynqmp: Added GEM reset definitions arm64: zynqmp: Fix AMS device tree node arm64: zynqmp: Align gpio-key node names with dtschema arm64: zynqmp: Remove id from usb node name
arch/arm/dts/zynqmp-sm-k26-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu100-revC.dts | 2 +- arch/arm/dts/zynqmp-zcu102-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu106-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu111-revA.dts | 2 +- arch/arm/dts/zynqmp.dtsi | 56 ++++++++++++++++------------- 6 files changed, 36 insertions(+), 30 deletions(-)
Sync property location with Linux kernel done by Linux commit (1ff2d58e60c8093e9be935b1f191341c0cda957a).
Signed-off-by: Michal Simek michal.simek@amd.com ---
Link: https://lore.kernel.org/r/20220112151541.1328732-3-m.tretter@pengutronix.de --- arch/arm/dts/zynqmp.dtsi | 32 ++++++++++++++++---------------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index b210bc4b87ec..9434c48e4f59 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -280,10 +280,10 @@ interrupt-parent = <&gic>; interrupts = <0 124 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <128>; iommus = <&smmu 0x14e8>; power-domains = <&zynqmp_firmware PD_GDMA>; - #dma-cells = <1>; };
fpd_dma_chan2: dma-controller@fd510000 { @@ -293,10 +293,10 @@ interrupt-parent = <&gic>; interrupts = <0 125 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <128>; iommus = <&smmu 0x14e9>; power-domains = <&zynqmp_firmware PD_GDMA>; - #dma-cells = <1>; };
fpd_dma_chan3: dma-controller@fd520000 { @@ -306,10 +306,10 @@ interrupt-parent = <&gic>; interrupts = <0 126 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <128>; iommus = <&smmu 0x14ea>; power-domains = <&zynqmp_firmware PD_GDMA>; - #dma-cells = <1>; };
fpd_dma_chan4: dma-controller@fd530000 { @@ -319,10 +319,10 @@ interrupt-parent = <&gic>; interrupts = <0 127 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <128>; iommus = <&smmu 0x14eb>; power-domains = <&zynqmp_firmware PD_GDMA>; - #dma-cells = <1>; };
fpd_dma_chan5: dma-controller@fd540000 { @@ -332,10 +332,10 @@ interrupt-parent = <&gic>; interrupts = <0 128 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <128>; iommus = <&smmu 0x14ec>; power-domains = <&zynqmp_firmware PD_GDMA>; - #dma-cells = <1>; };
fpd_dma_chan6: dma-controller@fd550000 { @@ -345,10 +345,10 @@ interrupt-parent = <&gic>; interrupts = <0 129 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <128>; iommus = <&smmu 0x14ed>; power-domains = <&zynqmp_firmware PD_GDMA>; - #dma-cells = <1>; };
fpd_dma_chan7: dma-controller@fd560000 { @@ -358,10 +358,10 @@ interrupt-parent = <&gic>; interrupts = <0 130 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <128>; iommus = <&smmu 0x14ee>; power-domains = <&zynqmp_firmware PD_GDMA>; - #dma-cells = <1>; };
fpd_dma_chan8: dma-controller@fd570000 { @@ -371,10 +371,10 @@ interrupt-parent = <&gic>; interrupts = <0 131 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <128>; iommus = <&smmu 0x14ef>; power-domains = <&zynqmp_firmware PD_GDMA>; - #dma-cells = <1>; };
gic: interrupt-controller@f9010000 { @@ -411,10 +411,10 @@ interrupt-parent = <&gic>; interrupts = <0 77 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <64>; iommus = <&smmu 0x868>; power-domains = <&zynqmp_firmware PD_ADMA>; - #dma-cells = <1>; };
lpd_dma_chan2: dma-controller@ffa90000 { @@ -424,10 +424,10 @@ interrupt-parent = <&gic>; interrupts = <0 78 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <64>; iommus = <&smmu 0x869>; power-domains = <&zynqmp_firmware PD_ADMA>; - #dma-cells = <1>; };
lpd_dma_chan3: dma-controller@ffaa0000 { @@ -437,10 +437,10 @@ interrupt-parent = <&gic>; interrupts = <0 79 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <64>; iommus = <&smmu 0x86a>; power-domains = <&zynqmp_firmware PD_ADMA>; - #dma-cells = <1>; };
lpd_dma_chan4: dma-controller@ffab0000 { @@ -450,10 +450,10 @@ interrupt-parent = <&gic>; interrupts = <0 80 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <64>; iommus = <&smmu 0x86b>; power-domains = <&zynqmp_firmware PD_ADMA>; - #dma-cells = <1>; };
lpd_dma_chan5: dma-controller@ffac0000 { @@ -463,10 +463,10 @@ interrupt-parent = <&gic>; interrupts = <0 81 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <64>; iommus = <&smmu 0x86c>; power-domains = <&zynqmp_firmware PD_ADMA>; - #dma-cells = <1>; };
lpd_dma_chan6: dma-controller@ffad0000 { @@ -476,10 +476,10 @@ interrupt-parent = <&gic>; interrupts = <0 82 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <64>; iommus = <&smmu 0x86d>; power-domains = <&zynqmp_firmware PD_ADMA>; - #dma-cells = <1>; };
lpd_dma_chan7: dma-controller@ffae0000 { @@ -489,10 +489,10 @@ interrupt-parent = <&gic>; interrupts = <0 83 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <64>; iommus = <&smmu 0x86e>; power-domains = <&zynqmp_firmware PD_ADMA>; - #dma-cells = <1>; };
lpd_dma_chan8: dma-controller@ffaf0000 { @@ -502,10 +502,10 @@ interrupt-parent = <&gic>; interrupts = <0 84 4>; clock-names = "clk_main", "clk_apb"; + #dma-cells = <1>; xlnx,bus-width = <64>; iommus = <&smmu 0x86f>; power-domains = <&zynqmp_firmware PD_ADMA>; - #dma-cells = <1>; };
mc: memory-controller@fd070000 {
The Cadence GEM/MACB driver now utilizes the platform-level reset on the ZynqMP platform. Add reset definitions to the ZynqMP platform device tree to allow this to be used. Linux upstream commit (e461bd6f43f4e568f7436a8b6bc21c4ce6914c36).
Signed-off-by: Robert Hancock robert.hancock@calian.com Signed-off-by: Michal Simek michal.simek@amd.com ---
https://lore.kernel.org/netdev/20220112181113.875567-4-robert.hancock@calian... --- arch/arm/dts/zynqmp.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 9434c48e4f59..e2eb27b3151e 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -540,6 +540,7 @@ iommus = <&smmu 0x874>; power-domains = <&zynqmp_firmware PD_ETH_0>; resets = <&zynqmp_reset ZYNQMP_RESET_GEM0>; + reset-names = "gem0_rst"; };
gem1: ethernet@ff0c0000 { @@ -554,6 +555,7 @@ iommus = <&smmu 0x875>; power-domains = <&zynqmp_firmware PD_ETH_1>; resets = <&zynqmp_reset ZYNQMP_RESET_GEM1>; + reset-names = "gem1_rst"; };
gem2: ethernet@ff0d0000 { @@ -568,6 +570,7 @@ iommus = <&smmu 0x876>; power-domains = <&zynqmp_firmware PD_ETH_2>; resets = <&zynqmp_reset ZYNQMP_RESET_GEM2>; + reset-names = "gem2_rst"; };
gem3: ethernet@ff0e0000 { @@ -582,6 +585,7 @@ iommus = <&smmu 0x877>; power-domains = <&zynqmp_firmware PD_ETH_3>; resets = <&zynqmp_reset ZYNQMP_RESET_GEM3>; + reset-names = "gem3_rst"; };
gpio: gpio@ff0a0000 {
Aligned node description with the Linux kernel. Node has been added by kernel commit (271c1fa01c2307cf74f4656390d6299991119c3e).
Signed-off-by: Robert Hancock robert.hancock@calian.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Link: https://lore.kernel.org/r/20220120010246.3794962-2-robert.hancock@calian.com Signed-off-by: Michal Simek michal.simek@amd.com --- arch/arm/dts/zynqmp.dtsi | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index e2eb27b3151e..4e1113db1a7e 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -938,21 +938,23 @@ interrupt-names = "ams-irq"; reg = <0x0 0xffa50000 0x0 0x800>; reg-names = "ams-base"; - #address-cells = <2>; - #size-cells = <2>; + #address-cells = <1>; + #size-cells = <1>; #io-channel-cells = <1>; - ranges; + ranges = <0 0 0xffa50800 0x800>;
- ams_ps: ams_ps@ffa50800 { + ams_ps: ams_ps@0 { compatible = "xlnx,zynqmp-ams-ps"; status = "disabled"; - reg = <0x0 0xffa50800 0x0 0x400>; + reg = <0x0 0x400>; };
- ams_pl: ams_pl@ffa50c00 { + ams_pl: ams_pl@400 { compatible = "xlnx,zynqmp-ams-pl"; status = "disabled"; - reg = <0x0 0xffa50c00 0x0 0x400>; + reg = <0x400 0x400>; + #address-cells = <1>; + #size-cells = <0>; }; };
The node names should be generic and DT schema expects certain pattern (e.g. with key/button/switch). It is based on kernel commit (228e8a88b1915a2b467c83d8d0976605f1272fae).
Link: https://lore.kernel.org/r/20220616005333.18491-30-krzysztof.kozlowski@linaro... --- arch/arm/dts/zynqmp-sm-k26-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu100-revC.dts | 2 +- arch/arm/dts/zynqmp-zcu102-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu106-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu111-revA.dts | 2 +- 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/zynqmp-sm-k26-revA.dts b/arch/arm/dts/zynqmp-sm-k26-revA.dts index bae24aabdbd1..aafaaec3f1c4 100644 --- a/arch/arm/dts/zynqmp-sm-k26-revA.dts +++ b/arch/arm/dts/zynqmp-sm-k26-revA.dts @@ -53,7 +53,7 @@ gpio-keys { compatible = "gpio-keys"; autorepeat; - fwuen { + key-fwuen { label = "fwuen"; gpios = <&gpio 12 GPIO_ACTIVE_LOW>; linux,code = <BTN_MISC>; diff --git a/arch/arm/dts/zynqmp-zcu100-revC.dts b/arch/arm/dts/zynqmp-zcu100-revC.dts index 5e7bc7384fce..eea703ab67ea 100644 --- a/arch/arm/dts/zynqmp-zcu100-revC.dts +++ b/arch/arm/dts/zynqmp-zcu100-revC.dts @@ -49,7 +49,7 @@ gpio-keys { compatible = "gpio-keys"; autorepeat; - sw4 { + switch-4 { label = "sw4"; gpios = <&gpio 23 GPIO_ACTIVE_LOW>; linux,code = <KEY_POWER>; diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index 9d8e551ed277..d78bfb8987fc 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -47,7 +47,7 @@ gpio-keys { compatible = "gpio-keys"; autorepeat; - sw19 { + switch-19 { label = "sw19"; gpios = <&gpio 22 GPIO_ACTIVE_HIGH>; linux,code = <KEY_DOWN>; diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index 4858b4d1f5e9..266c24e41259 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -47,7 +47,7 @@ gpio-keys { compatible = "gpio-keys"; autorepeat; - sw19 { + switch-19 { label = "sw19"; gpios = <&gpio 22 GPIO_ACTIVE_HIGH>; linux,code = <KEY_DOWN>; diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index 2e95f22c3f08..8535cc089132 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -47,7 +47,7 @@ gpio-keys { compatible = "gpio-keys"; autorepeat; - sw19 { + switch-19 { label = "sw19"; gpios = <&gpio 22 GPIO_ACTIVE_HIGH>; linux,code = <KEY_DOWN>;
There is no reason to have number in usb node name. This is also sync up patch with upstream kernel.
arch/arm/dts/zynqmp.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 4e1113db1a7e..34504a8cbb92 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -846,7 +846,7 @@ power-domains = <&zynqmp_firmware PD_UART_1>; };
- usb0: usb0@ff9d0000 { + usb0: usb@ff9d0000 { #address-cells = <2>; #size-cells = <2>; status = "disabled"; @@ -879,7 +879,7 @@ }; };
- usb1: usb1@ff9e0000 { + usb1: usb@ff9e0000 { #address-cells = <2>; #size-cells = <2>; status = "disabled";
Thanks, Michal
Queue for next.
M
Michal Simek
