[U-Boot] [PATCH] env: Merge Rockchip, Sunxi, Zynq and ZynqMP
There is no reason to have the same Kconfig options for different SoCs separately. The patch is merging them together.
Patch is based on https://lists.denx.de/pipermail/u-boot/2018-July/335126.html
I have ENV_SECT_SIZE just for zynq/zynqmp because rockchip and sunxi have this in their configs. When they decide to move then can enable that option for them too. I expect when more platforms extend this we will have less constrain Kconfig setup.
--- env/Kconfig | 66 ++++++++++++++++--------------------------------------------- 1 file changed, 17 insertions(+), 49 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index b37dcd78eb75..0ded003d7d41 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -431,23 +431,37 @@ config ENV_EXT4_FILE It's a string of the EXT4 file name. This file use to store the environment (explicit path to the file)
-if ARCH_SUNXI +if ARCH_ROCKCHIP || ARCH_SUNXI || ARCH_ZYNQ || ARCH_ZYNQMP
config ENV_OFFSET hex "Environment Offset" depends on !ENV_IS_IN_UBI depends on !ENV_IS_NOWHERE + default 0x3f8000 if ARCH_ROCKCHIP default 0x88000 if ARCH_SUNXI + default 0xE0000 if ARCH_ZYNQ + default 0x1E00000 if ARCH_ZYNQMP help Offset from the start of the device (or partition)
config ENV_SIZE hex "Environment Size" - depends on !ENV_IS_NOWHERE - default 0x20000 if ARCH_SUNXI + default 0x8000 if ARCH_ROCKCHIP && !ENV_IS_NOWHERE + default 0x20000 if ARCH_SUNXI && !ENV_IS_NOWHERE + default 0x20000 if ARCH_ZYNQ + default 0x40000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP + default 0x8000 if ARCH_ZYNQMP help Size of the environment storage area
+config ENV_SECT_SIZE + hex "Environment Sector-Size" + depends on !ENV_IS_NOWHERE && (ARCH_ZYNQ || ARCH_ZYNQMP) + default 0x40000 if ARCH_ZYNQMP + default 0x20000 if ARCH_ZYNQ + help + Size of the sector containing the environment. + config ENV_UBI_PART string "UBI partition name" depends on ENV_IS_IN_UBI @@ -462,52 +476,6 @@ config ENV_UBI_VOLUME
endif
-if ARCH_ROCKCHIP - -config ENV_OFFSET - hex - depends on !ENV_IS_IN_UBI - depends on !ENV_IS_NOWHERE - default 0x3f8000 - help - Offset from the start of the device (or partition) - -config ENV_SIZE - hex - default 0x8000 - help - Size of the environment storage area - -endif - -if ARCH_ZYNQMP || ARCH_ZYNQ - -config ENV_OFFSET - hex "Environment Offset" - depends on !ENV_IS_NOWHERE - default 0x1E00000 if ARCH_ZYNQMP - default 0xE0000 if ARCH_ZYNQ - help - Offset from the start of the device (or partition) - -config ENV_SIZE - hex "Environment Size" - default 0x40000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP - default 0x8000 if ARCH_ZYNQMP - default 0x20000 if ARCH_ZYNQ - help - Size of the environment storage area. - -config ENV_SECT_SIZE - hex "Environment Sector-Size" - depends on !ENV_IS_NOWHERE - default 0x40000 if ARCH_ZYNQMP - default 0x20000 if ARCH_ZYNQ - help - Size of the sector containing the environment. - -endif - config USE_DEFAULT_ENV_FILE bool "Create default environment from file" help
Can we have a depends on instead? That would be more flexible.
- default 0x3f8000 if ARCH_ROCKCHIP default 0x88000 if ARCH_SUNXI
- default 0x1E00000 if ARCH_ZYNQMP help Offset from the start of the device (or partition)
- default 0x8000 if ARCH_ROCKCHIP && !ENV_IS_NOWHERE
- default 0x20000 if ARCH_SUNXI && !ENV_IS_NOWHERE
I'm not sure why you removed the depends on !ENV_IS_NOWHERE. Do you have a case where the environment is not store anywhere but still need a size?
Thanks! Maxime
In what sense? If depends is used below then the same 4 platforms will be listed on all options below. (I want to also add ZYNQMP_R5 there too) And changing this in one place seems to me better then on four.
yes, I had a compilation warning for that case.
in include/environment.h at line 145 it is written this #define ENV_SIZE (CONFIG_ENV_SIZE - ENV_HEADER_SIZE)
ENV_SIZE is also used in typedef struct environment_s some lines below. And this structure is used a lot.
How did you find out that this can't be used for ENV_IS_NOWHERE?
Thanks, Michal
For now I like the "if" method for now as we can't (or couldn't a while ago) globally migrate everyone over. I think trying to move everyone over again is something I should give another try.
I would have sworn that ENV_SIZE is used for ENV_IS_NOWHERE as that's how much space we have for environment when it's in memory as well.
Ack.
Argh, sorry for that I was abused by sunxi-common still having that: https://git.denx.de/?p=u-boot.git;a=blob;f=include/configs/sunxi-common.h#l1...
While i was convinced that we were relying solely on Kconfig. I'll send a subsequent patch, that one works for me.
Sorry, Maxime
Ack.
Ok. Can you please convert this to any official tag which I can include?
Thanks, Michal
Ack.
Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Maxime
Signed-off-by: Michal Simek michal.simek@xilinx.com Acked-by: Maxime Ripard maxime.ripard@bootlin.com
After doing a little work around the ENV_IS_NOWHERE parts and size-testing, applied to u-boot/master, thanks!
I expect you forget to push.
Thanks, Michal
Sadly the sync out to the public side of git.denx.de is lagging behind again.
Maxime Ripard
Michal Simek
