[PATCH v1 0/7] clk : rockchip: update rk3568 and rk3588 clk driver
Elaine Zhang (5): rockchip: dts: rk3568: Resync from kernel-4.19 clk: rockchip: rk3568: add i2s3 clk clk: rockchip: rk3568: support dclk_vop select more parent clks clk: rockchip: rk3588: support aclk_top_root set 750M clk: rockchip: rk3588: fix up the frac pll calculation
Guochun Huang (1): clk: rk3588: Add 742.5M parameter for PLL
Wyon Bi (1): clk: rockchip: rk3588: Avoid re-setting the pll rate of dclk_vop's parent
.../include/asm/arch-rockchip/cru_rk3568.h | 36 +++ drivers/clk/rockchip/clk_pll.c | 102 ++++++-- drivers/clk/rockchip/clk_rk3568.c | 228 +++++++++++++++++- drivers/clk/rockchip/clk_rk3588.c | 35 ++- include/dt-bindings/clock/rk3568-cru.h | 7 + 5 files changed, 373 insertions(+), 35 deletions(-)
Resync from kernel-4.19: (a6cf6aca12c0 drivers: rkflash: Ajudst the dll strategy)
Change-Id: I7b7134946b76dbd8963cfaafdc5b56750622855e Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- include/dt-bindings/clock/rk3568-cru.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/dt-bindings/clock/rk3568-cru.h b/include/dt-bindings/clock/rk3568-cru.h index c1942422a438..251445cf7632 100644 --- a/include/dt-bindings/clock/rk3568-cru.h +++ b/include/dt-bindings/clock/rk3568-cru.h @@ -478,6 +478,13 @@ #define CPLL_50M 415 #define CPLL_25M 416 #define CPLL_100M 417 +#define SCLK_DDRCLK 418 +#define I2S1_MCLKOUT 419 +#define I2S3_MCLKOUT 420 +#define I2S1_MCLK_RX_IOE 421 +#define I2S1_MCLK_TX_IOE 422 +#define I2S2_MCLK_IOE 423 +#define I2S3_MCLK_IOE 424
#define PCLK_CORE_PVTM 450
Hi Elaine,
bindings should be synced from mainline linux, not vendor kernel.
This is the only missing clock that is defined in mainline linux.
These are missing in mainline linux, please upstream to linux.
Regards, Jonas
From: Elaine Zhang zhangqing@rock-chips.com Date: Tue, 10 Oct 2023 16:51:49 +0800
Linux 4.19 is ancient; why are you not synching from 6.5 or a 6.6 release candidate?
-- 2.17.1
Change-Id: If20fe16260d2b584d4216d1dbabffcb25478fb1d Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- .../include/asm/arch-rockchip/cru_rk3568.h | 36 +++ drivers/clk/rockchip/clk_rk3568.c | 218 ++++++++++++++++++ 2 files changed, 254 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3568.h b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h index 9c7ddd751f72..0306ce57e369 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3568.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h @@ -211,6 +211,31 @@ enum { ACLK_PERIMID_SEL_100M, ACLK_PERIMID_SEL_24M,
+ /* CRU_CLK_SEL21_CON */ + I2S3_MCLKOUT_TX_SEL_SHIFT = 15, + I2S3_MCLKOUT_TX_SEL_MASK = 1 << I2S3_MCLKOUT_TX_SEL_SHIFT, + I2S3_MCLKOUT_TX_SEL_MCLK = 0, + I2S3_MCLKOUT_TX_SEL_12M, + CLK_I2S3_SEL_SHIFT = 10, + CLK_I2S3_SEL_MASK = 0x3 << CLK_I2S3_SEL_SHIFT, + CLK_I2S3_SEL_SRC = 0, + CLK_I2S3_SEL_FRAC, + CLK_I2S3_SEL_CLKIN, + CLK_I2S3_SEL_XIN12M, + CLK_I2S3_SRC_SEL_SHIFT = 8, + CLK_I2S3_SRC_SEL_MASK = 0x3 << CLK_I2S3_SRC_SEL_SHIFT, + CLK_I2S3_SRC_SEL_GPLL = 0, + CLK_I2S3_SRC_SEL_CPLL, + CLK_I2S3_SRC_SEL_NPLL, + CLK_I2S3_SRC_DIV_SHIFT = 0, + CLK_I2S3_SRC_DIV_MASK = 0x7f << CLK_I2S3_SRC_DIV_SHIFT, + + /* CRU_CLK_SEL22_CON */ + CLK_I2S3_FRAC_NUMERATOR_SHIFT = 16, + CLK_I2S3_FRAC_NUMERATOR_MASK = 0xffff << 16, + CLK_I2S3_FRAC_DENOMINATOR_SHIFT = 0, + CLK_I2S3_FRAC_DENOMINATOR_MASK = 0xffff, + /* CRU_CLK_SEL27_CON */ CLK_CRYPTO_PKA_SEL_SHIFT = 6, CLK_CRYPTO_PKA_SEL_MASK = 3 << CLK_CRYPTO_PKA_SEL_SHIFT, @@ -502,5 +527,16 @@ enum { /* CRU_CLK_SEL82_CON */ CPLL_100M_DIV_SHIFT = 0, CPLL_100M_DIV_MASK = 0x1f << CPLL_100M_DIV_SHIFT, + + /* GRF_SOC_CON2 */ + I2S3_MCLKOUT_SEL_SHIFT = 15, + I2S3_MCLKOUT_SEL_MASK = 0x1 << I2S3_MCLKOUT_SEL_SHIFT, + I2S3_MCLKOUT_SEL_RX = 0, + I2S3_MCLKOUT_SEL_TX, + I2S3_MCLK_IOE_SEL_SHIFT = 3, + I2S3_MCLK_IOE_SEL_MASK = 0x1 << I2S3_MCLK_IOE_SEL_SHIFT, + I2S3_MCLK_IOE_SEL_CLKIN = 0, + I2S3_MCLK_IOE_SEL_CLKOUT, + }; #endif diff --git a/drivers/clk/rockchip/clk_rk3568.c b/drivers/clk/rockchip/clk_rk3568.c index 599b7b130eb9..469014439be4 100644 --- a/drivers/clk/rockchip/clk_rk3568.c +++ b/drivers/clk/rockchip/clk_rk3568.c @@ -13,6 +13,7 @@ #include <asm/arch-rockchip/cru_rk3568.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/grf_rk3568.h> #include <asm/io.h> #include <dm/device-internal.h> #include <dm/lists.h> @@ -2326,6 +2327,170 @@ static ulong rk3568_uart_set_rate(struct rk3568_clk_priv *priv, return rk3568_uart_get_rate(priv, clk_id); }
+#ifndef CONFIG_SPL_BUILD +static ulong rk3568_i2s3_get_rate(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + struct rk3568_grf *grf = priv->grf; + u32 con, div, src, p_rate; + u32 reg, fracdiv, p_src; + unsigned long m, n; + + switch (clk_id) { + case I2S3_MCLKOUT_TX: + con = readl(&cru->clksel_con[21]); + src = (con & I2S3_MCLKOUT_TX_SEL_MASK) >> + I2S3_MCLKOUT_TX_SEL_SHIFT; + if (src == I2S3_MCLKOUT_TX_SEL_12M) + p_rate = 12000000; + else + p_rate = rk3568_i2s3_get_rate(priv, MCLK_I2S3_2CH_TX); + return p_rate; + case I2S3_MCLKOUT_RX: + con = readl(&cru->clksel_con[83]); + src = (con & I2S3_MCLKOUT_TX_SEL_MASK) >> + I2S3_MCLKOUT_TX_SEL_SHIFT; + if (src == I2S3_MCLKOUT_TX_SEL_12M) + p_rate = 12000000; + else + p_rate = rk3568_i2s3_get_rate(priv, MCLK_I2S3_2CH_RX); + return p_rate; + case I2S3_MCLKOUT: + con = readl(&grf->soc_con2); + src = (con & I2S3_MCLKOUT_SEL_MASK) + >> I2S3_MCLKOUT_SEL_SHIFT; + if (src == I2S3_MCLKOUT_SEL_RX) + p_rate = rk3568_i2s3_get_rate(priv, I2S3_MCLKOUT_RX); + else + p_rate = rk3568_i2s3_get_rate(priv, I2S3_MCLKOUT_TX); + return p_rate; + case MCLK_I2S3_2CH_RX: + reg = 83; + break; + case MCLK_I2S3_2CH_TX: + reg = 21; + break; + default: + return -ENOENT; + } + + con = readl(&cru->clksel_con[reg]); + src = (con & CLK_I2S3_SEL_MASK) >> CLK_I2S3_SEL_SHIFT; + div = (con & CLK_I2S3_SRC_DIV_MASK) >> CLK_I2S3_SRC_DIV_SHIFT; + p_src = (con & CLK_I2S3_SRC_SEL_MASK) >> CLK_I2S3_SRC_SEL_SHIFT; + if (p_src == CLK_I2S3_SRC_SEL_GPLL) + p_rate = priv->gpll_hz; + else if (p_src == CLK_I2S3_SRC_SEL_CPLL) + p_rate = priv->cpll_hz; + else + p_rate = priv->npll_hz; + if (src == CLK_I2S3_SEL_SRC) { + return DIV_TO_RATE(p_rate, div); + } else if (src == CLK_I2S3_SEL_FRAC) { + fracdiv = readl(&cru->clksel_con[reg + 1]); + n = fracdiv & CLK_I2S3_FRAC_NUMERATOR_MASK; + n >>= CLK_I2S3_FRAC_NUMERATOR_SHIFT; + m = fracdiv & CLK_I2S3_FRAC_DENOMINATOR_MASK; + m >>= CLK_I2S3_FRAC_DENOMINATOR_SHIFT; + return DIV_TO_RATE(p_rate, div) * n / m; + } else { + return OSC_HZ / 2; + } +} + +static ulong rk3568_i2s3_set_rate(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + struct rk3568_grf *grf = priv->grf; + u32 reg, con, clk_src, i2s_src, div; + unsigned long m = 0, n = 0, val; + + if (priv->gpll_hz % rate == 0) { + clk_src = CLK_I2S3_SRC_SEL_GPLL; + i2s_src = CLK_I2S3_SEL_SRC; + div = DIV_ROUND_UP(priv->gpll_hz, rate); + } else if (priv->cpll_hz % rate == 0) { + clk_src = CLK_I2S3_SRC_SEL_CPLL; + i2s_src = CLK_I2S3_SEL_SRC; + div = DIV_ROUND_UP(priv->gpll_hz, rate); + } else if (rate == OSC_HZ / 2) { + clk_src = CLK_I2S3_SRC_SEL_GPLL; + i2s_src = CLK_I2S3_SEL_XIN12M; + div = 1; + } else { + clk_src = CLK_I2S3_SRC_SEL_GPLL; + i2s_src = CLK_I2S3_SEL_FRAC; + div = 1; + rational_best_approximation(rate, priv->gpll_hz / div, + GENMASK(16 - 1, 0), + GENMASK(16 - 1, 0), + &m, &n); + } + + switch (clk_id) { + case I2S3_MCLKOUT_TX: + if (rate == 12000000) { + rk_clrsetreg(&cru->clksel_con[21], + I2S3_MCLKOUT_TX_SEL_MASK, + I2S3_MCLKOUT_TX_SEL_12M << + I2S3_MCLKOUT_TX_SEL_SHIFT); + } else { + rk3568_i2s3_set_rate(priv, MCLK_I2S3_2CH_TX, rate), + rk_clrsetreg(&cru->clksel_con[21], + I2S3_MCLKOUT_TX_SEL_MASK, + I2S3_MCLKOUT_TX_SEL_MCLK << + I2S3_MCLKOUT_TX_SEL_SHIFT); + } + return rk3568_i2s3_get_rate(priv, clk_id); + case I2S3_MCLKOUT_RX: + if (rate == 12000000) { + rk_clrsetreg(&cru->clksel_con[83], + I2S3_MCLKOUT_TX_SEL_MASK, + I2S3_MCLKOUT_TX_SEL_12M << + I2S3_MCLKOUT_TX_SEL_SHIFT); + } else { + rk3568_i2s3_set_rate(priv, MCLK_I2S3_2CH_RX, rate), + rk_clrsetreg(&cru->clksel_con[21], + I2S3_MCLKOUT_TX_SEL_MASK, + I2S3_MCLKOUT_TX_SEL_MCLK << + I2S3_MCLKOUT_TX_SEL_SHIFT); + } + return rk3568_i2s3_get_rate(priv, clk_id); + case I2S3_MCLKOUT: + con = readl(&grf->soc_con2); + clk_src = (con & I2S3_MCLKOUT_SEL_MASK) + >> I2S3_MCLKOUT_SEL_SHIFT; + if (clk_src == I2S3_MCLKOUT_SEL_RX) + rk3568_i2s3_set_rate(priv, I2S3_MCLKOUT_RX, rate); + else + rk3568_i2s3_set_rate(priv, I2S3_MCLKOUT_TX, rate); + return rk3568_i2s3_get_rate(priv, clk_id); + case MCLK_I2S3_2CH_RX: + reg = 83; + break; + case MCLK_I2S3_2CH_TX: + reg = 21; + break; + default: + return -ENOENT; + } + + rk_clrsetreg(&cru->clksel_con[reg], + CLK_I2S3_SEL_MASK | CLK_I2S3_SRC_SEL_MASK | + CLK_I2S3_SRC_DIV_MASK, + (clk_src << CLK_I2S3_SRC_SEL_SHIFT) | + (i2s_src << CLK_I2S3_SEL_SHIFT) | + ((div - 1) << CLK_I2S3_SRC_DIV_SHIFT)); + if (m && n) { + val = m << CLK_I2S3_FRAC_NUMERATOR_SHIFT | n; + writel(val, &cru->clksel_con[reg + 1]); + } + return rk3568_i2s3_get_rate(priv, clk_id); +} + +#endif + static ulong rk3568_clk_get_rate(struct clk *clk) { struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); @@ -2463,6 +2628,13 @@ static ulong rk3568_clk_get_rate(struct clk *clk) case TCLK_WDT_NS: rate = OSC_HZ; break; + case I2S3_MCLKOUT_RX: + case I2S3_MCLKOUT_TX: + case MCLK_I2S3_2CH_RX: + case MCLK_I2S3_2CH_TX: + case I2S3_MCLKOUT: + rate = rk3568_i2s3_get_rate(priv, clk->id); + break; #endif case SCLK_UART1: case SCLK_UART2: @@ -2648,6 +2820,13 @@ static ulong rk3568_clk_set_rate(struct clk *clk, ulong rate) case TCLK_WDT_NS: ret = OSC_HZ; break; + case I2S3_MCLKOUT_RX: + case I2S3_MCLKOUT_TX: + case MCLK_I2S3_2CH_RX: + case MCLK_I2S3_2CH_TX: + case I2S3_MCLKOUT: + ret = rk3568_i2s3_set_rate(priv, clk->id, rate); + break; #endif case SCLK_UART1: case SCLK_UART2: @@ -2824,6 +3003,42 @@ static int rk3568_rkvdec_set_parent(struct clk *clk, struct clk *parent) return 0; }
+static int __maybe_unused rk3568_i2s3_set_parent(struct clk *clk, + struct clk *parent) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3568_grf *grf = priv->grf; + + switch (clk->id) { + case I2S3_MCLK_IOE: + if (parent->id == I2S3_MCLKOUT) { + rk_clrsetreg(&grf->soc_con2, I2S3_MCLK_IOE_SEL_MASK, + I2S3_MCLK_IOE_SEL_CLKOUT << + I2S3_MCLK_IOE_SEL_SHIFT); + } else { + rk_clrsetreg(&grf->soc_con2, I2S3_MCLK_IOE_SEL_MASK, + I2S3_MCLK_IOE_SEL_CLKIN << + I2S3_MCLK_IOE_SEL_SHIFT); + } + break; + case I2S3_MCLKOUT: + if (parent->id == I2S3_MCLKOUT_RX) { + rk_clrsetreg(&grf->soc_con2, I2S3_MCLKOUT_SEL_MASK, + I2S3_MCLKOUT_SEL_RX << + I2S3_MCLKOUT_SEL_SHIFT); + } else { + rk_clrsetreg(&grf->soc_con2, I2S3_MCLKOUT_SEL_MASK, + I2S3_MCLKOUT_SEL_TX << + I2S3_MCLKOUT_SEL_SHIFT); + } + break; + default: + return -EINVAL; + } + + return 0; +} + static int rk3568_clk_set_parent(struct clk *clk, struct clk *parent) { switch (clk->id) { @@ -2848,6 +3063,9 @@ static int rk3568_clk_set_parent(struct clk *clk, struct clk *parent) case SCLK_GMAC1_RGMII_SPEED: case SCLK_GMAC1_RMII_SPEED: break; + case I2S3_MCLK_IOE: + case I2S3_MCLKOUT: + return rk3568_i2s3_set_parent(clk, parent); default: return -ENOENT; }
Hi Elaine,
Please add commit message, and remove the change id.
same for other patches.
Thanks,
- Kever
- /* CRU_CLK_SEL21_CON */
- I2S3_MCLKOUT_TX_SEL_SHIFT = 15,
- I2S3_MCLKOUT_TX_SEL_MASK = 1 << I2S3_MCLKOUT_TX_SEL_SHIFT,
- I2S3_MCLKOUT_TX_SEL_MCLK = 0,
- I2S3_MCLKOUT_TX_SEL_12M,
- CLK_I2S3_SEL_SHIFT = 10,
- CLK_I2S3_SEL_MASK = 0x3 << CLK_I2S3_SEL_SHIFT,
- CLK_I2S3_SEL_SRC = 0,
- CLK_I2S3_SEL_FRAC,
- CLK_I2S3_SEL_CLKIN,
- CLK_I2S3_SEL_XIN12M,
- CLK_I2S3_SRC_SEL_SHIFT = 8,
- CLK_I2S3_SRC_SEL_MASK = 0x3 << CLK_I2S3_SRC_SEL_SHIFT,
- CLK_I2S3_SRC_SEL_GPLL = 0,
- CLK_I2S3_SRC_SEL_CPLL,
- CLK_I2S3_SRC_SEL_NPLL,
- CLK_I2S3_SRC_DIV_SHIFT = 0,
- CLK_I2S3_SRC_DIV_MASK = 0x7f << CLK_I2S3_SRC_DIV_SHIFT,
- /* CRU_CLK_SEL22_CON */
- CLK_I2S3_FRAC_NUMERATOR_SHIFT = 16,
- CLK_I2S3_FRAC_NUMERATOR_MASK = 0xffff << 16,
- CLK_I2S3_FRAC_DENOMINATOR_SHIFT = 0,
- CLK_I2S3_FRAC_DENOMINATOR_MASK = 0xffff,
- /* CRU_CLK_SEL27_CON */ CLK_CRYPTO_PKA_SEL_SHIFT = 6, CLK_CRYPTO_PKA_SEL_MASK = 3 << CLK_CRYPTO_PKA_SEL_SHIFT,
- /* GRF_SOC_CON2 */
- I2S3_MCLKOUT_SEL_SHIFT = 15,
- I2S3_MCLKOUT_SEL_MASK = 0x1 << I2S3_MCLKOUT_SEL_SHIFT,
- I2S3_MCLKOUT_SEL_RX = 0,
- I2S3_MCLKOUT_SEL_TX,
- I2S3_MCLK_IOE_SEL_SHIFT = 3,
- I2S3_MCLK_IOE_SEL_MASK = 0x1 << I2S3_MCLK_IOE_SEL_SHIFT,
- I2S3_MCLK_IOE_SEL_CLKIN = 0,
- I2S3_MCLK_IOE_SEL_CLKOUT,
- }; #endif
- struct rk3568_cru *cru = priv->cru;
- struct rk3568_grf *grf = priv->grf;
- u32 con, div, src, p_rate;
- u32 reg, fracdiv, p_src;
- unsigned long m, n;
- switch (clk_id) {
- case I2S3_MCLKOUT_TX:
p_rate = 12000000;
else
return p_rate;
- case I2S3_MCLKOUT_RX:
p_rate = 12000000;
else
return p_rate;
- case I2S3_MCLKOUT:
else
return p_rate;
- case MCLK_I2S3_2CH_RX:
reg = 83;
break;
- case MCLK_I2S3_2CH_TX:
reg = 21;
break;
- default:
return -ENOENT;
- con = readl(&cru->clksel_con[reg]);
- src = (con & CLK_I2S3_SEL_MASK) >> CLK_I2S3_SEL_SHIFT;
- div = (con & CLK_I2S3_SRC_DIV_MASK) >> CLK_I2S3_SRC_DIV_SHIFT;
- p_src = (con & CLK_I2S3_SRC_SEL_MASK) >> CLK_I2S3_SRC_SEL_SHIFT;
- if (p_src == CLK_I2S3_SRC_SEL_GPLL)
- else if (p_src == CLK_I2S3_SRC_SEL_CPLL)
- else
- if (src == CLK_I2S3_SEL_SRC) {
- } else if (src == CLK_I2S3_SEL_FRAC) {
- } else {
return OSC_HZ / 2;
- u32 reg, con, clk_src, i2s_src, div;
- unsigned long m = 0, n = 0, val;
- if (priv->gpll_hz % rate == 0) {
- } else if (priv->cpll_hz % rate == 0) {
- } else if (rate == OSC_HZ / 2) {
div = 1;
- } else {
div = 1;
GENMASK(16 - 1, 0),
GENMASK(16 - 1, 0),
&m, &n);
- switch (clk_id) {
} else {
} else {
else
reg = 83;
break;
reg = 21;
break;
- default:
return -ENOENT;
- rk_clrsetreg(&cru->clksel_con[reg],
- if (m && n) {
- return rk3568_i2s3_get_rate(priv, clk_id);
- static ulong rk3568_clk_get_rate(struct clk *clk) { struct rk3568_clk_priv *priv = dev_get_priv(clk->dev);
#endif case SCLK_UART1: case SCLK_UART2:break;
struct clk *parent)
- struct rk3568_clk_priv *priv = dev_get_priv(clk->dev);
- switch (clk->id) {
- case I2S3_MCLK_IOE:
} else {
break;
} else {
break;
- default:
return -EINVAL;
- static int rk3568_clk_set_parent(struct clk *clk, struct clk *parent) { switch (clk->id) {
default: return -ENOENT; }return rk3568_i2s3_set_parent(clk, parent);
Change-Id: Ib823620ff7940f8d62e78010817ca9b5f06995dd Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- drivers/clk/rockchip/clk_rk3568.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3568.c b/drivers/clk/rockchip/clk_rk3568.c index 469014439be4..7b9035acdb0f 100644 --- a/drivers/clk/rockchip/clk_rk3568.c +++ b/drivers/clk/rockchip/clk_rk3568.c @@ -1839,7 +1839,7 @@ static ulong rk3568_dclk_vop_set_clk(struct rk3568_clk_priv *priv, rockchip_pll_set_rate(&rk3568_pll_clks[VPLL], priv->cru, VPLL, div * rate); } else { - for (i = 0; i <= DCLK_VOP_SEL_CPLL; i++) { + for (i = sel; i <= DCLK_VOP_SEL_CPLL; i++) { switch (i) { case DCLK_VOP_SEL_GPLL: pll_rate = priv->gpll_hz; @@ -2964,9 +2964,15 @@ static int rk3568_dclk_vop_set_parent(struct clk *clk, struct clk *parent) if (parent->id == PLL_VPLL) { rk_clrsetreg(&cru->clksel_con[con_id], DCLK0_VOP_SEL_MASK, DCLK_VOP_SEL_VPLL << DCLK0_VOP_SEL_SHIFT); - } else { + } else if (parent->id == PLL_HPLL) { rk_clrsetreg(&cru->clksel_con[con_id], DCLK0_VOP_SEL_MASK, DCLK_VOP_SEL_HPLL << DCLK0_VOP_SEL_SHIFT); + } else if (parent->id == PLL_CPLL) { + rk_clrsetreg(&cru->clksel_con[con_id], DCLK0_VOP_SEL_MASK, + DCLK_VOP_SEL_CPLL << DCLK0_VOP_SEL_SHIFT); + } else { + rk_clrsetreg(&cru->clksel_con[con_id], DCLK0_VOP_SEL_MASK, + DCLK_VOP_SEL_GPLL << DCLK0_VOP_SEL_SHIFT); }
Change-Id: I5a842a3103df9a566789e7635fb484e4bb0bf427 Signed-off-by: Guochun Huang hero.huang@rock-chips.com Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- drivers/clk/rockchip/clk_rk3588.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/clk/rockchip/clk_rk3588.c b/drivers/clk/rockchip/clk_rk3588.c index 119b1337bdf2..c86176264147 100644 --- a/drivers/clk/rockchip/clk_rk3588.c +++ b/drivers/clk/rockchip/clk_rk3588.c @@ -36,6 +36,7 @@ static struct rockchip_pll_rate_table rk3588_pll_rates[] = { RK3588_PLL_RATE(816000000, 2, 272, 2, 0), RK3588_PLL_RATE(786432000, 2, 262, 2, 9437), RK3588_PLL_RATE(786000000, 1, 131, 2, 0), + RK3588_PLL_RATE(742500000, 4, 495, 2, 0), RK3588_PLL_RATE(722534400, 8, 963, 2, 24850), RK3588_PLL_RATE(600000000, 2, 200, 2, 0), RK3588_PLL_RATE(594000000, 2, 198, 2, 0),
Change-Id: I78f00d37a645f37e28587d1c31f3179d5fa891e7 Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- drivers/clk/rockchip/clk_rk3588.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3588.c b/drivers/clk/rockchip/clk_rk3588.c index c86176264147..7ba037ad72ba 100644 --- a/drivers/clk/rockchip/clk_rk3588.c +++ b/drivers/clk/rockchip/clk_rk3588.c @@ -306,12 +306,18 @@ static ulong rk3588_top_set_clk(struct rk3588_clk_priv *priv,
switch (clk_id) { case ACLK_TOP_ROOT: - src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + if (!(priv->cpll_hz % rate)) { + src_clk = ACLK_TOP_ROOT_SRC_SEL_CPLL; + src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate); + } else { + src_clk = ACLK_TOP_ROOT_SRC_SEL_GPLL; + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + } assert(src_clk_div - 1 <= 31); rk_clrsetreg(&cru->clksel_con[8], ACLK_TOP_ROOT_DIV_MASK | ACLK_TOP_ROOT_SRC_SEL_MASK, - (ACLK_TOP_ROOT_SRC_SEL_GPLL << + (src_clk << ACLK_TOP_ROOT_SRC_SEL_SHIFT) | (src_clk_div - 1) << ACLK_TOP_ROOT_DIV_SHIFT); break;
Elaine Zhang
Jonas Karlman
Kever Yang
Mark Kettenis
