[PATCH v3 00/12] phy: atheros: dt bindings and cleanup
This patch series superseeds the following two:
From Vladimir Oltean
https://patchwork.ozlabs.org/cover/1031360/
From me:
https://patchwork.ozlabs.org/cover/1184507/
Although the first is marked as accepted into u-boot-net I guess it was removed due to broken boards ("DT as ABI", RGMII delay was fixed and thus breaks the board).
After disussing with Vladimir, I've integrated his patches with this series. Also the first one Address packet drops at low traffic rate due to SmartEEE feature was dropped because it will likely be fixed by making u-boot support the eee-broken-X device tree properties. Apart from that, only the subject was changed and a note about possible board breakage was added the patch which changes the delay behaviour.
For all of those, who will test this patchset, the device tree binding needs the phydev->node property, which needs to be set in every network driver. If the device tree binding is not working for you have a look at the ar803x_of_init: found PHY node: phy@0 output. In the case above "phy@0" is the phy node in the device tree. If instead the node of your network device is displayed, you have to set the phydev->node property in your network device driver.
For the fsl_enetc driver this patchset will add it: https://patchwork.ozlabs.org/cover/1188043/
changes since v2: - rebased onto latest master, esp. #include <dm/device_compat.h>
changes since v1: - pull all Vladimirs Oltan's patches and rebase mine onto them - fix the CLK_25M settings for the AR8035 - add two new patches "fix AR8021 PHY ID mask" and "use defines for PHY IDs" - use the new kernel device tree binding for the AR803x PHYs: https://patchwork.ozlabs.org/patch/1188293/ - add debugging output
Michael Walle (7): phy: atheros: fix AR8021 PHY ID mask phy: atheros: use defines for PHY IDs phy: atheros: introduce debug read and write functions phy: atheros: move delay config to common function phy: atheros: add device tree bindings and config phy: atheros: ar8035: remove static clock config phy: atheros: consolidate {ar8031|ar8035}_config()
Vladimir Oltean (5): phy: atheros: Make RGMII Tx delays actually configurable for AR8035 phy: atheros: Use common functions for RGMII internal delays phy: atheros: Clarify the configuration of the CLK_25M output pin phy: atheros: Explicitly disable RGMII delays phy: atheros: Clarify the intention of ar8021_config
doc/device-tree-bindings/net/phy/atheros.txt | 35 ++ drivers/net/phy/atheros.c | 350 ++++++++++++++++--- include/dt-bindings/net/qca-ar803x.h | 13 + 3 files changed, 345 insertions(+), 53 deletions(-) create mode 100644 doc/device-tree-bindings/net/phy/atheros.txt create mode 100644 include/dt-bindings/net/qca-ar803x.h
Delete the extraneous write to debug reg 5 that enables Tx delay
When the driver was originally introduced in commit "6027384a phylib: Add Atheros AR8035 GETH PHY support", the Tx delay was being unconditionally enabled.
Then during "2ec4d10b phy: atheros: add support for RGMII_ID, RGMII_TXID and RGMII_RXID", the author did not notice that code for enabling Tx delay code was already. Therefore, the if condition for Tx delay has always been useless for this PHY since this commit introduced it.
Prior to this patch, every AR8035 PHY in U-boot had Tx delay enabled. After this patch, only those who define the interface as RGMII_TXID or RGMII_ID will. This is to be expected, but will nonetheless break the setups of those who didn't know they rely on Tx delay implicitly.
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Acked-by: Joe Hershberger joe.hershberger@ni.com --- drivers/net/phy/atheros.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 3783d155e7..537c1a9125 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -63,10 +63,6 @@ static int ar8035_config(struct phy_device *phydev) regval = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); phy_write(phydev, MDIO_DEVAD_NONE, 0xe, (regval|0x0018));
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); - regval = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, (regval|0x0100)); - if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) { /* select debug reg 5 */
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Acked-by: Joe Hershberger joe.hershberger@ni.com --- drivers/net/phy/atheros.c | 69 +++++++++++++++++++++++---------------- 1 file changed, 41 insertions(+), 28 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 537c1a9125..c0c2b4db39 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -12,16 +12,45 @@ #define AR803x_PHY_DEBUG_DATA_REG 0x1e
#define AR803x_DEBUG_REG_5 0x5 -#define AR803x_RGMII_TX_CLK_DLY 0x100 +#define AR803x_RGMII_TX_CLK_DLY BIT(8)
#define AR803x_DEBUG_REG_0 0x0 -#define AR803x_RGMII_RX_CLK_DLY 0x8000 +#define AR803x_RGMII_RX_CLK_DLY BIT(15) + +static void ar803x_enable_rx_delay(struct phy_device *phydev, bool on) +{ + int regval; + + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_0); + regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); + if (on) + regval |= AR803x_RGMII_RX_CLK_DLY; + else + regval &= ~AR803x_RGMII_RX_CLK_DLY; + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, regval); +} + +static void ar803x_enable_tx_delay(struct phy_device *phydev, bool on) +{ + int regval; + + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_5); + regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); + if (on) + regval |= AR803x_RGMII_TX_CLK_DLY; + else + regval &= ~AR803x_RGMII_TX_CLK_DLY; + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, regval); +}
static int ar8021_config(struct phy_device *phydev) { phy_write(phydev, MDIO_DEVAD_NONE, 0x00, 0x1200); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x3D47); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_5); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, 0x3D47);
phydev->supported = phydev->drv->features; return 0; @@ -30,20 +59,12 @@ static int ar8021_config(struct phy_device *phydev) static int ar8031_config(struct phy_device *phydev) { if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || - phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, - AR803x_DEBUG_REG_5); - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, - AR803x_RGMII_TX_CLK_DLY); - } + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + ar803x_enable_tx_delay(phydev, true);
if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || - phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, - AR803x_DEBUG_REG_0); - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, - AR803x_RGMII_RX_CLK_DLY); - } + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + ar803x_enable_rx_delay(phydev, true);
@@ -64,20 +85,12 @@ static int ar8035_config(struct phy_device *phydev) phy_write(phydev, MDIO_DEVAD_NONE, 0xe, (regval|0x0018));
if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || - (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) { - /* select debug reg 5 */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1D, 0x5); - /* enable tx delay */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1E, 0x0100); - } + (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) + ar803x_enable_tx_delay(phydev, true);
if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || - (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID)) { - /* select debug reg 0 */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1D, 0x0); - /* enable rx delay */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1E, 0x8000); - } + (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID)) + ar803x_enable_rx_delay(phydev, true);
Also take the opportunity to use the phy_read_mmd and phy_write_mmd convenience functions.
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Acked-by: Joe Hershberger joe.hershberger@ni.com --- drivers/net/phy/atheros.c | 19 ++++++++++++++----- 1 file changed, 14 insertions(+), 5 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index c0c2b4db39..1da18eb5d4 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -17,6 +17,15 @@ #define AR803x_DEBUG_REG_0 0x0 #define AR803x_RGMII_RX_CLK_DLY BIT(15)
+/* CLK_25M register is at MMD 7, address 0x8016 */ +#define AR803x_CLK_25M_SEL_REG 0x8016 +/* AR8035: Select frequency on CLK_25M pin through bits 4:3 */ +#define AR8035_CLK_25M_FREQ_25M (0 | 0) +#define AR8035_CLK_25M_FREQ_50M (0 | BIT(3)) +#define AR8035_CLK_25M_FREQ_62M (BIT(4) | 0) +#define AR8035_CLK_25M_FREQ_125M (BIT(4) | BIT(3)) +#define AR8035_CLK_25M_MASK GENMASK(4, 3) + static void ar803x_enable_rx_delay(struct phy_device *phydev, bool on) { int regval; @@ -78,11 +87,11 @@ static int ar8035_config(struct phy_device *phydev) { int regval;
- phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x0007); - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016); - phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007); - regval = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, (regval|0x0018)); + /* Configure CLK_25M output clock at 125 MHz */ + regval = phy_read_mmd(phydev, MDIO_MMD_AN, AR803x_CLK_25M_SEL_REG); + regval &= ~AR8035_CLK_25M_MASK; /* No surprises */ + regval |= AR8035_CLK_25M_FREQ_125M; + phy_write_mmd(phydev, MDIO_MMD_AN, AR803x_CLK_25M_SEL_REG, regval);
To eliminate any doubts about the out-of-reset value of the PHY, that the driver previously relied on.
If bisecting shows that this commit breaks your board you probably have a wrong PHY interface mode. You probably want the PHY_INTERFACE_MODE_RGMII_RXID or PHY_INTERFACE_MODE_RGMII_ID mode.
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Acked-by: Joe Hershberger joe.hershberger@ni.com --- drivers/net/phy/atheros.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 1da18eb5d4..3e59c3f391 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -70,10 +70,14 @@ static int ar8031_config(struct phy_device *phydev) if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) ar803x_enable_tx_delay(phydev, true); + else + ar803x_enable_tx_delay(phydev, false);
if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) ar803x_enable_rx_delay(phydev, true); + else + ar803x_enable_rx_delay(phydev, false);
@@ -96,10 +100,14 @@ static int ar8035_config(struct phy_device *phydev) if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) ar803x_enable_tx_delay(phydev, true); + else + ar803x_enable_tx_delay(phydev, false);
if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID)) ar803x_enable_rx_delay(phydev, true); + else + ar803x_enable_rx_delay(phydev, false);
Debug register 5 contains TX_CLK DELAY at bit 8 and reserved values at the other bit positions, just like the other PHYs in the family do. Therefore, it is not necessary to hardcode the reserved values, but instead simply follow the read-modify-write procedure from the common function.
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Acked-by: Joe Hershberger joe.hershberger@ni.com --- drivers/net/phy/atheros.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 3e59c3f391..3cc162828c 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -56,10 +56,10 @@ static void ar803x_enable_tx_delay(struct phy_device *phydev, bool on)
static int ar8021_config(struct phy_device *phydev) { - phy_write(phydev, MDIO_DEVAD_NONE, 0x00, 0x1200); - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, - AR803x_DEBUG_REG_5); - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, 0x3D47); + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, + BMCR_ANENABLE | BMCR_ANRESTART); + + ar803x_enable_tx_delay(phydev, true);
The upper bits are all the OUI.
Signed-off-by: Michael Walle michael@walle.cc --- drivers/net/phy/atheros.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 3cc162828c..01953a1390 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -120,7 +120,7 @@ static int ar8035_config(struct phy_device *phydev) static struct phy_driver AR8021_driver = { .name = "AR8021", .uid = 0x4dd040, - .mask = 0x4ffff0, + .mask = 0xfffffff0, .features = PHY_GBIT_FEATURES, .config = ar8021_config, .startup = genphy_startup,
Signed-off-by: Michael Walle michael@walle.cc --- drivers/net/phy/atheros.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 01953a1390..5ff5875d3d 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -26,6 +26,10 @@ #define AR8035_CLK_25M_FREQ_125M (BIT(4) | BIT(3)) #define AR8035_CLK_25M_MASK GENMASK(4, 3)
+#define AR8021_PHY_ID 0x004dd040 +#define AR8031_PHY_ID 0x004dd074 +#define AR8035_PHY_ID 0x004dd072 + static void ar803x_enable_rx_delay(struct phy_device *phydev, bool on) { int regval; @@ -119,7 +123,7 @@ static int ar8035_config(struct phy_device *phydev)
static struct phy_driver AR8021_driver = { .name = "AR8021", - .uid = 0x4dd040, + .uid = AR8021_PHY_ID, .mask = 0xfffffff0, .features = PHY_GBIT_FEATURES, .config = ar8021_config, @@ -129,7 +133,7 @@ static struct phy_driver AR8021_driver = {
static struct phy_driver AR8031_driver = { .name = "AR8031/AR8033", - .uid = 0x4dd074, + .uid = AR8031_PHY_ID, .mask = 0xffffffef, .features = PHY_GBIT_FEATURES, .config = ar8031_config, @@ -139,7 +143,7 @@ static struct phy_driver AR8031_driver = {
static struct phy_driver AR8035_driver = { .name = "AR8035", - .uid = 0x4dd072, + .uid = AR8035_PHY_ID, .mask = 0xffffffef, .features = PHY_GBIT_FEATURES, .config = ar8035_config,
Provide functions to read and write the Atheros debug registers.
Signed-off-by: Michael Walle michael@walle.cc --- drivers/net/phy/atheros.c | 57 ++++++++++++++++++++++++++++----------- 1 file changed, 41 insertions(+), 16 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 5ff5875d3d..660dcd9491 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -30,32 +30,57 @@ #define AR8031_PHY_ID 0x004dd074 #define AR8035_PHY_ID 0x004dd072
-static void ar803x_enable_rx_delay(struct phy_device *phydev, bool on) +static int ar803x_debug_reg_read(struct phy_device *phydev, u16 reg) { - int regval; + int ret; + + ret = phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + reg); + if (ret < 0) + return ret; + + return phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); +} + +static int ar803x_debug_reg_mask(struct phy_device *phydev, u16 reg, + u16 clear, u16 set) +{ + int val; + + val = ar803x_debug_reg_read(phydev, reg); + if (val < 0) + return val; + + val &= 0xffff; + val &= ~clear; + val |= set; + + return phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, + val); +} + +static int ar803x_enable_rx_delay(struct phy_device *phydev, bool on) +{ + u16 clear = 0, set = 0;
- phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, - AR803x_DEBUG_REG_0); - regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); if (on) - regval |= AR803x_RGMII_RX_CLK_DLY; + set = AR803x_RGMII_RX_CLK_DLY; else - regval &= ~AR803x_RGMII_RX_CLK_DLY; - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, regval); + clear = AR803x_RGMII_RX_CLK_DLY; + + return ar803x_debug_reg_mask(phydev, AR803x_DEBUG_REG_0, clear, set); }
-static void ar803x_enable_tx_delay(struct phy_device *phydev, bool on) +static int ar803x_enable_tx_delay(struct phy_device *phydev, bool on) { - int regval; + u16 clear = 0, set = 0;
- phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, - AR803x_DEBUG_REG_5); - regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); if (on) - regval |= AR803x_RGMII_TX_CLK_DLY; + set = AR803x_RGMII_TX_CLK_DLY; else - regval &= ~AR803x_RGMII_TX_CLK_DLY; - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, regval); + clear = AR803x_RGMII_TX_CLK_DLY; + + return ar803x_debug_reg_mask(phydev, AR803x_DEBUG_REG_5, clear, set); }
Signed-off-by: Michael Walle michael@walle.cc --- drivers/net/phy/atheros.c | 38 ++++++++++++++++++++++---------------- 1 file changed, 22 insertions(+), 16 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 660dcd9491..22035c2496 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -94,19 +94,32 @@ static int ar8021_config(struct phy_device *phydev) return 0; }
-static int ar8031_config(struct phy_device *phydev) +static int ar803x_delay_config(struct phy_device *phydev) { + int ret; + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) - ar803x_enable_tx_delay(phydev, true); + ret = ar803x_enable_tx_delay(phydev, true); else - ar803x_enable_tx_delay(phydev, false); + ret = ar803x_enable_tx_delay(phydev, false);
if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) - ar803x_enable_rx_delay(phydev, true); + ret = ar803x_enable_rx_delay(phydev, true); else - ar803x_enable_rx_delay(phydev, false); + ret = ar803x_enable_rx_delay(phydev, false); + + return ret; +} + +static int ar8031_config(struct phy_device *phydev) +{ + int ret; + + ret = ar803x_delay_config(phydev); + if (ret < 0) + return ret;
@@ -118,6 +131,7 @@ static int ar8031_config(struct phy_device *phydev)
static int ar8035_config(struct phy_device *phydev) { + int ret; int regval;
/* Configure CLK_25M output clock at 125 MHz */ @@ -126,17 +140,9 @@ static int ar8035_config(struct phy_device *phydev) regval |= AR8035_CLK_25M_FREQ_125M; phy_write_mmd(phydev, MDIO_MMD_AN, AR803x_CLK_25M_SEL_REG, regval);
- if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || - (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) - ar803x_enable_tx_delay(phydev, true); - else - ar803x_enable_tx_delay(phydev, false); - - if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || - (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID)) - ar803x_enable_rx_delay(phydev, true); - else - ar803x_enable_rx_delay(phydev, false); + ret = ar803x_delay_config(phydev); + if (ret < 0) + return ret;
Add support for configuring the CLK_25M pin as well as the RGMII I/O voltage by the device tree.
By default the AT803x PHYs outputs the 25MHz clock of the XTAL input. But this output can also be changed by software to other frequencies. This commit introduces a generic way to configure this output.
Also the PHY supports different RGMII I/O voltages: 1.5V, 1.8V and 2.5V. An internal LDO is able to provide 1.5V (default) and 1.8V. The 2.5V option needs an external supply voltage. This commit adds support to switch the internal LDO to 1.8V.
Signed-off-by: Michael Walle michael@walle.cc --- doc/device-tree-bindings/net/phy/atheros.txt | 35 +++ drivers/net/phy/atheros.c | 224 ++++++++++++++++++- include/dt-bindings/net/qca-ar803x.h | 13 ++ 3 files changed, 270 insertions(+), 2 deletions(-) create mode 100644 doc/device-tree-bindings/net/phy/atheros.txt create mode 100644 include/dt-bindings/net/qca-ar803x.h
diff --git a/doc/device-tree-bindings/net/phy/atheros.txt b/doc/device-tree-bindings/net/phy/atheros.txt new file mode 100644 index 0000000000..97e97b8c13 --- /dev/null +++ b/doc/device-tree-bindings/net/phy/atheros.txt @@ -0,0 +1,35 @@ +* Qualcomm Atheros PHY Device Tree binding + +Required properties: +- reg: PHY address + +Optional properties: +- qca,clk-out-frequency: Clock frequency of the CLK_25M pin in Hz. + Either 25000000, 50000000, 62500000 or 125000000. +- qca,clk-out-strength: Clock output buffer driver strength. + Supported values are defined in dt-bindings/net/qca-ar803x.h +- qca,keep-pll-enabled: Keep the PLL running if no link is present. + Don't go into hibernation mode. + Only supported on the AR8031/AR8033. +- vddio-supply: RGMII I/O voltage regulator + Only supported on the AR8031/AR8033. + +Optional subnodes: +- vddio-regulator: Initial data for the VDDIO regulator, as covered + doc/device-tree-bindings/regulator/regulator.txt + +Example: + #include <dt-bindings/net/qca-ar803x.h> + + ethernet-phy@0 { + reg = <0>; + qca-clk-out-frequency = <125000000>; + qca,keep-pll-enabled; + + vddio-supply = <&vddio>; + + vddio: vddio-regulator { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 22035c2496..3cd301c50e 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -4,21 +4,41 @@ * * Copyright 2011, 2013 Freescale Semiconductor, Inc. * author Andy Fleming + * Copyright (c) 2019 Michael Walle michael@walle.cc */ #include <common.h> #include <phy.h> +#include <dm/device_compat.h> +#include <linux/bitfield.h> +#include <dt-bindings/net/qca-ar803x.h>
#define AR803x_PHY_DEBUG_ADDR_REG 0x1d #define AR803x_PHY_DEBUG_DATA_REG 0x1e
+/* Debug registers */ +#define AR803x_DEBUG_REG_0 0x0 +#define AR803x_RGMII_RX_CLK_DLY BIT(15) + #define AR803x_DEBUG_REG_5 0x5 #define AR803x_RGMII_TX_CLK_DLY BIT(8)
-#define AR803x_DEBUG_REG_0 0x0 -#define AR803x_RGMII_RX_CLK_DLY BIT(15) +#define AR803x_DEBUG_REG_1F 0x1f +#define AR803x_PLL_ON BIT(2) +#define AR803x_RGMII_1V8 BIT(3)
/* CLK_25M register is at MMD 7, address 0x8016 */ #define AR803x_CLK_25M_SEL_REG 0x8016 + +#define AR803x_CLK_25M_MASK GENMASK(4, 2) +#define AR803x_CLK_25M_25MHZ_XTAL 0 +#define AR803x_CLK_25M_25MHZ_DSP 1 +#define AR803x_CLK_25M_50MHZ_PLL 2 +#define AR803x_CLK_25M_50MHZ_DSP 3 +#define AR803x_CLK_25M_62_5MHZ_PLL 4 +#define AR803x_CLK_25M_62_5MHZ_DSP 5 +#define AR803x_CLK_25M_125MHZ_PLL 6 +#define AR803x_CLK_25M_125MHZ_DSP 7 + /* AR8035: Select frequency on CLK_25M pin through bits 4:3 */ #define AR8035_CLK_25M_FREQ_25M (0 | 0) #define AR8035_CLK_25M_FREQ_50M (0 | BIT(3)) @@ -26,10 +46,23 @@ #define AR8035_CLK_25M_FREQ_125M (BIT(4) | BIT(3)) #define AR8035_CLK_25M_MASK GENMASK(4, 3)
+#define AR803x_CLK_25M_DR_MASK GENMASK(8, 7) +#define AR803x_CLK_25M_DR_FULL 0 +#define AR803x_CLK_25M_DR_HALF 1 +#define AR803x_CLK_25M_DR_QUARTER 2 + #define AR8021_PHY_ID 0x004dd040 #define AR8031_PHY_ID 0x004dd074 #define AR8035_PHY_ID 0x004dd072
+struct ar803x_priv { + int flags; +#define AR803x_FLAG_KEEP_PLL_ENABLED BIT(0) /* don't turn off internal PLL */ +#define AR803x_FLAG_RGMII_1V8 BIT(1) /* use 1.8V RGMII I/O voltage */ + u16 clk_25m_reg; + u16 clk_25m_mask; +}; + static int ar803x_debug_reg_read(struct phy_device *phydev, u16 reg) { int ret; @@ -113,14 +146,193 @@ static int ar803x_delay_config(struct phy_device *phydev) return ret; }
+static int ar803x_regs_config(struct phy_device *phydev) +{ + struct ar803x_priv *priv = phydev->priv; + u16 set = 0, clear = 0; + int val; + int ret; + + /* no configuration available */ + if (!priv) + return 0; + + /* + * Only supported on the AR8031, AR8035 has strappings for the PLL mode + * as well as the RGMII voltage. + */ + if (phydev->drv->uid == AR8031_PHY_ID) { + if (priv->flags & AR803x_FLAG_KEEP_PLL_ENABLED) + set |= AR803x_PLL_ON; + else + clear |= AR803x_PLL_ON; + + if (priv->flags & AR803x_FLAG_RGMII_1V8) + set |= AR803x_RGMII_1V8; + else + clear |= AR803x_RGMII_1V8; + + ret = ar803x_debug_reg_mask(phydev, AR803x_DEBUG_REG_1F, clear, + set); + if (ret < 0) + return ret; + } + + /* save the write access if the mask is empty */ + if (priv->clk_25m_mask) { + val = phy_read_mmd(phydev, MDIO_MMD_AN, AR803x_CLK_25M_SEL_REG); + if (val < 0) + return val; + val &= ~priv->clk_25m_mask; + val |= priv->clk_25m_reg; + ret = phy_write_mmd(phydev, MDIO_MMD_AN, + AR803x_CLK_25M_SEL_REG, val); + if (ret < 0) + return ret; + } + + return 0; +} + +static int ar803x_of_init(struct phy_device *phydev) +{ +#if defined(CONFIG_DM_ETH) + struct ar803x_priv *priv; + ofnode node, vddio_reg_node; + u32 strength, freq, min_uV, max_uV; + int sel; + + node = phy_get_ofnode(phydev); + if (!ofnode_valid(node)) + return -EINVAL; + + priv = malloc(sizeof(*priv)); + if (!priv) + return -ENOMEM; + memset(priv, 0, sizeof(*priv)); + + phydev->priv = priv; + + debug("%s: found PHY node: %s\n", __func__, ofnode_get_name(node)); + + if (ofnode_read_bool(node, "qca,keep-pll-enabled")) + priv->flags |= AR803x_FLAG_KEEP_PLL_ENABLED; + + /* + * We can't use the regulator framework because the regulator is + * a subnode of the PHY. So just read the two properties we are + * interested in. + */ + vddio_reg_node = ofnode_find_subnode(node, "vddio-regulator"); + if (ofnode_valid(vddio_reg_node)) { + min_uV = ofnode_read_u32_default(vddio_reg_node, + "regulator-min-microvolt", 0); + max_uV = ofnode_read_u32_default(vddio_reg_node, + "regulator-max-microvolt", 0); + + if (min_uV != max_uV) { + free(priv); + return -EINVAL; + } + + switch (min_uV) { + case 1500000: + break; + case 1800000: + priv->flags |= AR803x_FLAG_RGMII_1V8; + break; + default: + free(priv); + return -EINVAL; + } + } + + /* + * Get the CLK_25M frequency from the device tree. Only XTAL and PLL + * sources are supported right now. There is also the possibilty to use + * the DSP as frequency reference, this is used for synchronous + * ethernet. + */ + if (!ofnode_read_u32(node, "qca,clk-out-frequency", &freq)) { + switch (freq) { + case 25000000: + sel = AR803x_CLK_25M_25MHZ_XTAL; + break; + case 50000000: + sel = AR803x_CLK_25M_50MHZ_PLL; + break; + case 62500000: + sel = AR803x_CLK_25M_62_5MHZ_PLL; + break; + case 125000000: + sel = AR803x_CLK_25M_125MHZ_PLL; + break; + default: + dev_err(phydev->dev, + "invalid qca,clk-out-frequency\n"); + free(priv); + return -EINVAL; + } + + priv->clk_25m_mask |= AR803x_CLK_25M_MASK; + priv->clk_25m_reg |= FIELD_PREP(AR803x_CLK_25M_MASK, sel); + /* + * Fixup for the AR8035 which only has two bits. The two + * remaining bits map to the same frequencies. + */ + if (phydev->drv->uid == AR8035_PHY_ID) { + u16 clear = AR803x_CLK_25M_MASK & AR8035_CLK_25M_MASK; + + priv->clk_25m_mask &= ~clear; + priv->clk_25m_reg &= ~clear; + } + } + + if (phydev->drv->uid == AR8031_PHY_ID && + !ofnode_read_u32(node, "qca,clk-out-strength", &strength)) { + switch (strength) { + case AR803X_STRENGTH_FULL: + sel = AR803x_CLK_25M_DR_FULL; + break; + case AR803X_STRENGTH_HALF: + sel = AR803x_CLK_25M_DR_HALF; + break; + case AR803X_STRENGTH_QUARTER: + sel = AR803x_CLK_25M_DR_QUARTER; + break; + default: + dev_err(phydev->dev, + "invalid qca,clk-out-strength\n"); + free(priv); + return -EINVAL; + } + priv->clk_25m_mask |= AR803x_CLK_25M_DR_MASK; + priv->clk_25m_reg |= FIELD_PREP(AR803x_CLK_25M_DR_MASK, sel); + } + + debug("%s: flags=%x clk_25m_reg=%04x clk_25m_mask=%04x\n", __func__, + priv->flags, priv->clk_25m_reg, priv->clk_25m_mask); +#endif + + return 0; +} + static int ar8031_config(struct phy_device *phydev) { int ret;
+ ret = ar803x_of_init(phydev); + if (ret < 0) + return ret; + ret = ar803x_delay_config(phydev); if (ret < 0) return ret;
+ ret = ar803x_regs_config(phydev); + if (ret < 0) + return ret; + phydev->supported = phydev->drv->features;
genphy_config_aneg(phydev); @@ -134,6 +346,10 @@ static int ar8035_config(struct phy_device *phydev) int ret; int regval;
+ ret = ar803x_of_init(phydev); + if (ret < 0) + return ret; + /* Configure CLK_25M output clock at 125 MHz */ regval = phy_read_mmd(phydev, MDIO_MMD_AN, AR803x_CLK_25M_SEL_REG); regval &= ~AR8035_CLK_25M_MASK; /* No surprises */ @@ -144,6 +360,10 @@ static int ar8035_config(struct phy_device *phydev) if (ret < 0) return ret;
genphy_config_aneg(phydev); diff --git a/include/dt-bindings/net/qca-ar803x.h b/include/dt-bindings/net/qca-ar803x.h new file mode 100644 index 0000000000..9c046c7242 --- /dev/null +++ b/include/dt-bindings/net/qca-ar803x.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Device Tree constants for the Qualcomm Atheros AR803x PHYs + */ + +#ifndef _DT_BINDINGS_QCA_AR803X_H +#define _DT_BINDINGS_QCA_AR803X_H + +#define AR803X_STRENGTH_FULL 0 +#define AR803X_STRENGTH_HALF 1 +#define AR803X_STRENGTH_QUARTER 2 + +#endif
We can configure the clock output in the device tree. Disable the hardcoded one in here. This is highly board-specific and should have never been enabled in the PHY driver.
If bisecting shows that this commit breaks your board it probably depends on the clock output of your Atheros AR8035 PHY. Please have a look at doc/device-tree-bindings/net/phy/atheros.txt. You need to set "clk-out-frequency = <125000000>" because that value was the hardcoded value until this commit.
Signed-off-by: Michael Walle michael@walle.cc --- drivers/net/phy/atheros.c | 13 ------------- 1 file changed, 13 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 3cd301c50e..3142733105 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -38,12 +38,6 @@ #define AR803x_CLK_25M_62_5MHZ_DSP 5 #define AR803x_CLK_25M_125MHZ_PLL 6 #define AR803x_CLK_25M_125MHZ_DSP 7 - -/* AR8035: Select frequency on CLK_25M pin through bits 4:3 */ -#define AR8035_CLK_25M_FREQ_25M (0 | 0) -#define AR8035_CLK_25M_FREQ_50M (0 | BIT(3)) -#define AR8035_CLK_25M_FREQ_62M (BIT(4) | 0) -#define AR8035_CLK_25M_FREQ_125M (BIT(4) | BIT(3)) #define AR8035_CLK_25M_MASK GENMASK(4, 3)
#define AR803x_CLK_25M_DR_MASK GENMASK(8, 7) @@ -344,18 +338,11 @@ static int ar8031_config(struct phy_device *phydev) static int ar8035_config(struct phy_device *phydev) { int ret; - int regval;
ret = ar803x_of_init(phydev); if (ret < 0) return ret;
- /* Configure CLK_25M output clock at 125 MHz */ - regval = phy_read_mmd(phydev, MDIO_MMD_AN, AR803x_CLK_25M_SEL_REG); - regval &= ~AR8035_CLK_25M_MASK; /* No surprises */ - regval |= AR8035_CLK_25M_FREQ_125M; - phy_write_mmd(phydev, MDIO_MMD_AN, AR803x_CLK_25M_SEL_REG, regval); - ret = ar803x_delay_config(phydev); if (ret < 0) return ret;
The two functions are now exactly the same, remove one of them.
Signed-off-by: Michael Walle michael@walle.cc --- drivers/net/phy/atheros.c | 30 +++--------------------------- 1 file changed, 3 insertions(+), 27 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 3142733105..47ff9f8d44 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -311,31 +311,7 @@ static int ar803x_of_init(struct phy_device *phydev) return 0; }
-static int ar8031_config(struct phy_device *phydev) -{ - int ret; - - ret = ar803x_of_init(phydev); - if (ret < 0) - return ret; - - ret = ar803x_delay_config(phydev); - if (ret < 0) - return ret; - - ret = ar803x_regs_config(phydev); - if (ret < 0) - return ret; - - phydev->supported = phydev->drv->features; - - genphy_config_aneg(phydev); - genphy_restart_aneg(phydev); - - return 0; -} - -static int ar8035_config(struct phy_device *phydev) +static int ar803x_config(struct phy_device *phydev) { int ret;
@@ -374,7 +350,7 @@ static struct phy_driver AR8031_driver = { .uid = AR8031_PHY_ID, .mask = 0xffffffef, .features = PHY_GBIT_FEATURES, - .config = ar8031_config, + .config = ar803x_config, .startup = genphy_startup, .shutdown = genphy_shutdown, }; @@ -384,7 +360,7 @@ static struct phy_driver AR8035_driver = { .uid = AR8035_PHY_ID, .mask = 0xffffffef, .features = PHY_GBIT_FEATURES, - .config = ar8035_config, + .config = ar803x_config, .startup = genphy_startup, .shutdown = genphy_shutdown, };
Am 2020-05-06 21:14, schrieb Michael Walle:
This patch series superseeds the following two: From Vladimir Oltean https://patchwork.ozlabs.org/cover/1031360/ From me: https://patchwork.ozlabs.org/cover/1184507/
changes since v2:
changes since v1:
PHY IDs"
Oh I've actually forgot the "Acked-by:" from Joe from the v2 series.
All but the
were acked by Joe.
Tom, should I send a v4 where I drop that patch and could you pull this series?
-michael
changes since v2:
changes since v1:
All but the
were acked by Joe.
Yes please, sounds like a plan, thanks for the explanation!
Michael Walle
