[Patch] net: dwc_eth_qos - works with fixed-phy
Let the EQoS in imx8mp handle fixed-phy too. Without that patch it lost track to the node to scan speed and duplex. Patch was created by Marek Vasut, just tested by me.
Signed-off-by: Elmar Psilog <epsi at gmx.de> --- drivers/net/dwc_eth_qos.c 1 file changed
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index afc47b56ff..10915d8e47 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -785,9 +785,21 @@ static int eqos_start(struct udevice *dev) */ if (!eqos->phy) { int addr = -1; - addr = eqos_get_phy_addr(eqos, dev); - eqos->phy = phy_connect(eqos->mii, addr, dev, - eqos->config->interface(dev)); + ofnode fixed_node; + + if (IS_ENABLED(CONFIG_PHY_FIXED)) { + fixed_node = ofnode_find_subnode(dev_ofnode(dev), + "fixed-link"); + if (ofnode_valid(fixed_node)) { + eqos->phy = fixed_phy_create(dev_ofnode(dev)); + eqos->phy_of_node = fixed_node; + } + } + if (!eqos->phy) { + addr = eqos_get_phy_addr(eqos, dev); + eqos->phy = phy_connect(eqos->mii, addr, dev, eqos->config->interface(dev)); + } + if (!eqos->phy) { pr_err("phy_connect() failed"); goto err_stop_resets;
If you were to use 'git format-patch' and 'git send-email', those tools would generate the correct Subject and diffstat etc. for you. Also have a look at scripts/checkpatch.pl to validate whether a patch is correct.
+CC Ramon the network maintainer .
Am 16.02.23 um 02:39 schrieb Marek Vasut:
New attempt: used script to check and fix and used git format-patch.
Also base is latest trunk, not v2023.1 as before.
Hope this fits your needs, otherwise I afraid I need detailed instruction.
-- drivers/net/dwc_eth_qos.c | 18 +++++++++++++++--- 1 file changed, 15 insertions(+), 3 deletions(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 112deb546d..d04362d6c6 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -788,9 +788,21 @@ static int eqos_start(struct udevice *dev) */ if (!eqos->phy) { int addr = -1; - addr = eqos_get_phy_addr(eqos, dev); - eqos->phy = phy_connect(eqos->mii, addr, dev, - eqos->config->interface(dev)); + ofnode fixed_node; + + if (IS_ENABLED(CONFIG_PHY_FIXED)) { + fixed_node = ofnode_find_subnode(dev_ofnode(dev), "fixed-link"); + if (ofnode_valid(fixed_node)) { + eqos->phy = fixed_phy_create(dev_ofnode(dev)); + eqos->phy_of_node = fixed_node; + } + } + + if (!eqos->phy) { + addr = eqos_get_phy_addr(eqos, dev); + eqos->phy = phy_connect(eqos->mii, addr, dev, eqos->config->interface(dev)); + } + if (!eqos->phy) { pr_err("phy_connect() failed"); goto err_stop_resets;
Basically the process is documented at length here:
https://u-boot.readthedocs.io/en/latest/develop/sending_patches.html
which is very much identical to even lengthier Linux patch submission guidelines:
https://www.kernel.org/doc/html/latest/process/submitting-patches.html
If you use git send-email , that will do most of the work for you, including correct formatting etc. The invocation is something like:
$ git send-email --annotate --to=u-boot@lists.denx.de --cc=additional-person@to.copy --cc=one@more.person -1 <commit ID>
Note that you do have to configure SMTP access in git-config for that to work.
You had the patch right very much the first time, except for a few style issues, like [Patch] instead of [PATCH] in the subject, patch itself was malformed likely due to copy-paste, and the checkpatch issues had to be addressed . When sending a new revision, include changelog in the patch below the --- below diffstat, and also make sure the Subjects reads [PATCH v2], git send-email -v2 does that for you (and -v3 does v3 etc.). You're almost there, no worries.
Wait for Ramon to review this patch and then send V2 if needed.
ofnode fixed_node;
fixed_node =
"fixed-link");
eqos->phy =
if (!eqos->phy) {
Okay by me, please send a fresh V2 so we can apply it easily.
Subject: [PATCH] dwc_eth_qos: Revert regression handling fixed phy
In imx8mp operation on eqos with fixed phy I get without that patch: ERROR: no/invalid <fixed-link< property! --- drivers/net/dwc_eth_qos.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 67d80d987f..8ca8adead9 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -801,8 +801,10 @@ static int eqos_start(struct udevice *dev) if (IS_ENABLED(CONFIG_PHY_FIXED)) { fixed_node = ofnode_find_subnode(dev_ofnode(dev), "fixed-link"); - if (ofnode_valid(fixed_node)) + if (ofnode_valid(fixed_node)) { eqos->phy = fixed_phy_create(dev_ofnode(dev)); + eqos->phy_of_node = fixed_node; + } }
if (!eqos->phy) {
Which commit is being reverted here ?
True. I just checked the mails last year and my confusion grows.
It was right here at the bottom: https://lists.denx.de/pipermail/u-boot/2023-February/509156.html
But already in PATCH_v2 it seems that line was dropped, my fault.
Elmar Psilog
Nicole Battenfeld
Ramon Fried
