[U-Boot] [PATCH] omap3: omap3_logic: switch to using TI_COMMON_CMD_OPTION
Enable TI_COMMON_CMD_OPTIONS and remove similar options from the defconfig. Updated with savedefconfig
CMD_USB isn't enabled yet. I have some testing to do with musb.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/logicpd/omap3som/Kconfig b/board/logicpd/omap3som/Kconfig index 03d272a..68d40dc 100644 --- a/board/logicpd/omap3som/Kconfig +++ b/board/logicpd/omap3som/Kconfig @@ -9,4 +9,6 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "omap3_logic"
+source "board/ti/common/Kconfig" + endif diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 561bdfb..50450c9 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -1,11 +1,11 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_LOGIC=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-37xx-devkit" -CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y @@ -16,29 +16,14 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP Logic # " -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set -CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y -CONFIG_CMD_SPI=y -CONFIG_CMD_I2C=y +# CONFIG_CMD_USB is not set # CONFIG_CMD_FPGA is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y # CONFIG_BLK is not set CONFIG_DM_I2C=y
Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Tom Rini trini@konsulko.com
Adam Ford
