[U-Boot] [PATCH 5/6] 4xx: Enable USB on PLU405 boards
This patch enables the PCI-OHCI controller on PLU405 board.
Also the default CPU frequency is updated to 266 MHz and command line editing is enabled.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- include/configs/PLU405.h | 20 ++++++++++++++++---- 1 files changed, 16 insertions(+), 4 deletions(-)
diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 211d926..4d302ef 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -88,6 +88,7 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_PING #define CONFIG_CMD_EEPROM +#define CONFIG_CMD_USB
#define CONFIG_OF_LIBFDT #define CONFIG_OF_BOARD_SETUP @@ -150,6 +151,7 @@
#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
+#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */
@@ -192,7 +194,7 @@ #define PCI_HOST_AUTO 2 /* detected via arbiter enable */
#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_HOST PCI_HOST_HOST /* select pci host function */ +#define CONFIG_PCI_HOST PCI_HOST_FORCE /* select pci host function */ #define CONFIG_PCI_PNP /* do pci plug-and-play */ /* resource configuration */
@@ -208,7 +210,7 @@ #define CFG_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ #define CFG_PCI_PTM2LA 0xffc00000 /* point to flash */ #define CFG_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ -#define CFG_PCI_PTM2PCI 0x04000000 /* Host: use this pci address */ +#define CFG_PCI_PTM2PCI 0x08000000 /* Host: use this pci address */
/*----------------------------------------------------------------------- * IDE/ATA stuff @@ -406,7 +408,7 @@ * Default speed selection (cpu_plb_opb_ebc) in mhz. * This value will be set if iic boot eprom is disabled. */ -#if 0 +#if 1 #define PLLMR0_DEFAULT PLLMR0_266_133_66_33 #define PLLMR1_DEFAULT PLLMR1_266_133_66_33 #endif @@ -414,9 +416,19 @@ #define PLLMR0_DEFAULT PLLMR0_200_100_50_33 #define PLLMR1_DEFAULT PLLMR1_200_100_50_33 #endif -#if 1 +#if 0 #define PLLMR0_DEFAULT PLLMR0_133_66_66_33 #define PLLMR1_DEFAULT PLLMR1_133_66_66_33 #endif
+/* + * PCI OHCI controller + */ +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_PCI_OHCI 1 +#define CFG_OHCI_SWAP_REG_ACCESS 1 +#define CFG_USB_OHCI_MAX_ROOT_PORTS 15 +#define CFG_USB_OHCI_SLOT_NAME "ohci_pci" +#define CONFIG_USB_STORAGE 1 + #endif /* __CONFIG_H */
Matthias Fuchs
