[PATCH] rockchip: make_fit_atf: generate signed conf when FIT_SIGN_KEY is set
Introduce the environment variable FIT_SIGN_KEY which when set is the name of the key that should be used to sign the binaries and configuration in the FIT image. Usage example (tested on RockPi4B):
mkdir keys openssl genpkey -algorithm RSA -out keys/dev.key \ -pkeyopt rsa_keygen_bits:2048 -pkeyopt rsa_keygen_pubexp:65537 openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt FIT_SIGN_KEY=dev TEE=.../tee.bin BL31=.../bl31.elf \ ../../git/arch/arm/mach-rockchip/make_fit_atf.py \ arch/arm/dts/rk3399-rock-pi-4b.dtb > u-boot.its cp spl/dts/dt-spl.dtb spl/u-boot-spl.dtb ./tools/mkimage -E -B 0x8 -p 0x0 -f u-boot.its -k keys \ -r -K spl/u-boot-spl.dtb u-boot.itb cat tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl-nodtb.bin \ spl/u-boot-spl.dtb > idbloader.img
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- arch/arm/mach-rockchip/make_fit_atf.py | 49 ++++++++++++++++++-------- 1 file changed, 34 insertions(+), 15 deletions(-)
diff --git a/arch/arm/mach-rockchip/make_fit_atf.py b/arch/arm/mach-rockchip/make_fit_atf.py index f3224d2555..e587760ccf 100755 --- a/arch/arm/mach-rockchip/make_fit_atf.py +++ b/arch/arm/mach-rockchip/make_fit_atf.py @@ -28,19 +28,6 @@ DT_HEADER = """ images { """
-DT_UBOOT = """ - uboot { - description = "U-Boot (64-bit)"; - data = /incbin/("u-boot-nodtb.bin"); - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <0x%08x>; - }; - -""" - DT_IMAGES_NODE_END = """ };
""" @@ -60,6 +47,7 @@ def append_bl31_node(file, atf_index, phy_addr, elf_entry): file.write('\t\t\tload = <0x%08x>;\n' % phy_addr) if atf_index == 1: file.write('\t\t\tentry = <0x%08x>;\n' % elf_entry) + append_hash_sig_nodes(file) file.write('\t\t};\n') file.write('\n')
@@ -75,6 +63,7 @@ def append_tee_node(file, atf_index, phy_addr, elf_entry): file.write('\t\t\tcompression = "none";\n') file.write('\t\t\tload = <0x%08x>;\n' % phy_addr) file.write('\t\t\tentry = <0x%08x>;\n' % elf_entry) + append_hash_sig_nodes(file) file.write('\t\t};\n') file.write('\n')
@@ -88,6 +77,7 @@ def append_fdt_node(file, dtbs): file.write('\t\t\tdata = /incbin/("%s");\n' % dtb) file.write('\t\t\ttype = "flat_dt";\n') file.write('\t\t\tcompression = "none";\n') + append_hash_sig_nodes(file) file.write('\t\t};\n') file.write('\n') cnt = cnt + 1 @@ -108,6 +98,13 @@ def append_conf_section(file, cnt, dtname, segments): if segments <= 1: file.write(';\n') file.write('\t\t\tfdt = "fdt_%d";\n' % cnt) + key_name = os.getenv('FIT_SIGN_KEY') + if key_name: + file.write('\t\t\tsignature {\n') + file.write('\t\t\t\tsign-images = "firmware","loadables","fdt";\n') + file.write('\t\t\t\talgo = "sha1,rsa2048";\n') + file.write('\t\t\t\tkey-name-hint = "dev";\n') + file.write('\t\t\t};\n') file.write('\t\t};\n') file.write('\n')
@@ -123,12 +120,34 @@ def append_conf_node(file, dtbs, segments): file.write('\t};\n') file.write('\n')
-def generate_atf_fit_dts_uboot(fit_file, uboot_file_name): +def generate_atf_fit_dts_uboot(file, uboot_file_name): segments = unpack_elf(uboot_file_name) if len(segments) != 1: raise ValueError("Invalid u-boot ELF image '%s'" % uboot_file_name) index, entry, p_paddr, data = segments[0] - fit_file.write(DT_UBOOT % p_paddr) + file.write('\n') + file.write('\t\tuboot {\n') + file.write('\t\t\tdescription = "U-Boot (64-bit)";\n') + file.write('\t\t\tdata = /incbin/("u-boot-nodtb.bin");\n') + file.write('\t\t\ttype = "standalone";\n') + file.write('\t\t\tos = "U-Boot";\n') + file.write('\t\t\tarch = "arm64";\n') + file.write('\t\t\tcompression = "none";\n') + file.write('\t\t\tload = <0x%08x>;\n' % p_paddr) + append_hash_sig_nodes(file) + file.write('\t\t};\n') + file.write('\n') + +def append_hash_sig_nodes(file): + key_name = os.getenv("FIT_SIGN_KEY") + if key_name: + file.write('\t\t\thash-1 {\n') + file.write('\t\t\t\talgo = "sha1";\n') + file.write('\t\t\t};\n') + file.write('\t\t\tsignature-1 {\n') + file.write('\t\t\t\talgo = "sha1,rsa2048";\n') + file.write('\t\t\t\tkey-name-hint = "%s";\n' % key_name) + file.write('\t\t\t};\n')
def generate_atf_fit_dts_bl31(fit_file, bl31_file_name, tee_file_name, dtbs_file_name): segments = unpack_elf(bl31_file_name)
Jerome Forissier
