[U-Boot] [PATCHv2] OMAP3: Add Corscience Tricorder board
Tricorder is a board which is very similar to the Devkit8000. It is designed as a base platform for further medical devices.
www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html
Signed-off-by: Thomas Weber weber@corscience.de --- Sorry for the long time between V1 and V2.
Changes from V1: - Reworked after comments from Tom and Igor. Thanks. - Changed authorship/derived from - Fix ubifs environment part - Replaced whitespaces with tabs MAINTAINERS | 1 + board/corscience/tricorder/Makefile | 46 ++++ board/corscience/tricorder/tricorder.c | 105 +++++++++ board/corscience/tricorder/tricorder.h | 375 ++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/tricorder.h | 320 +++++++++++++++++++++++++++ 6 files changed, 848 insertions(+), 0 deletions(-) create mode 100644 board/corscience/tricorder/Makefile create mode 100644 board/corscience/tricorder/tricorder.c create mode 100644 board/corscience/tricorder/tricorder.h create mode 100644 include/configs/tricorder.h
diff --git a/MAINTAINERS b/MAINTAINERS index 8c4fe2d..61caa96 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -903,6 +903,7 @@ Stephen Warren swarren@nvidia.com Thomas Weber weber@corscience.de
devkit8000 ARM ARMV7 (OMAP3530 SoC) + tricorder ARM ARMV7 (OMAP3503 SoC)
Lei Wen leiwen@marvell.com
diff --git a/board/corscience/tricorder/Makefile b/board/corscience/tricorder/Makefile new file mode 100644 index 0000000..16ef3a3 --- /dev/null +++ b/board/corscience/tricorder/Makefile @@ -0,0 +1,46 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2012 +# Thomas Weber weber@corscience.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := tricorder.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/corscience/tricorder/tricorder.c b/board/corscience/tricorder/tricorder.c new file mode 100644 index 0000000..435711a --- /dev/null +++ b/board/corscience/tricorder/tricorder.c @@ -0,0 +1,105 @@ +/* + * (C) Copyright 2012 + * Corscience GmbH & Co. KG, <www.corscience.de> + * Thomas Weber weber@corscience.de + * Sunil Kumar sunilsaini05@gmail.com + * Shashi Ranjan shashiranjanmca05@gmail.com + * + * Derived from Devkit8000 code by + * Frederik Kriewitz frederik@kriewitz.eu + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <twl4030.h> +#include <asm/io.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mem.h> +#include "tricorder.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +/* + * Routine: misc_init_r + * Description: Configure board specific parts + */ +int misc_init_r(void) +{ + twl4030_power_init(); +#ifdef CONFIG_TWL4030_LED + twl4030_led_init(TWL4030_LED_LEDEN_LEDAON | TWL4030_LED_LEDEN_LEDBON); +#endif + + dieid_num_r(); + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_TRICORDER(); +} + +#if defined(CONFIG_GENERIC_MMC) && !(defined(CONFIG_SPL_BUILD)) +int board_mmc_init(bd_t *bis) +{ + return omap_mmc_init(0); +} +#endif + +/* + * Routine: get_board_mem_timings + * Description: If we use SPL then there is no x-loader nor config header + * so we have to setup the DDR timings ourself on the first bank. This + * provides the timing values back to the function that configures + * the memory. We have either one or two banks of 128MB DDR. + */ +void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, + u32 *mr) +{ + /* General SDRC config */ + *mcfg = MICRON_V_MCFG_165(128 << 20); + *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + + /* AC timings */ + *ctrla = MICRON_V_ACTIMA_165; + *ctrlb = MICRON_V_ACTIMB_165; + *mr = MICRON_V_MR_165; +} diff --git a/board/corscience/tricorder/tricorder.h b/board/corscience/tricorder/tricorder.h new file mode 100644 index 0000000..cae8c75 --- /dev/null +++ b/board/corscience/tricorder/tricorder.h @@ -0,0 +1,375 @@ +/* + * (C) Copyright 2008 + * Dirk Behme dirk.behme@gmail.com + * + * (C) Copyright 2012 + * Corscience GmbH & Co. KG, <www.corscience.de> + * Thomas Weber weber@corscience.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _TRICORDER_H_ +#define _TRICORDER_H_ + +const omap3_sysinfo sysinfo = { + DDR_STACKED, + "OMAP3 Tricorder", + "NAND", +}; + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_TRICORDER() \ + /* SDRC */\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) /*SDRC_D0*/\ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) /*SDRC_D1*/\ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) /*SDRC_D2*/\ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) /*SDRC_D3*/\ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) /*SDRC_D4*/\ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) /*SDRC_D5*/\ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) /*SDRC_D6*/\ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) /*SDRC_D7*/\ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) /*SDRC_D8*/\ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) /*SDRC_D9*/\ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) /*SDRC_D10*/\ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) /*SDRC_D11*/\ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) /*SDRC_D12*/\ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) /*SDRC_D13*/\ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) /*SDRC_D14*/\ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) /*SDRC_D15*/\ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) /*SDRC_D16*/\ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) /*SDRC_D17*/\ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) /*SDRC_D18*/\ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) /*SDRC_D19*/\ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) /*SDRC_D20*/\ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) /*SDRC_D21*/\ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) /*SDRC_D22*/\ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) /*SDRC_D23*/\ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) /*SDRC_D24*/\ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) /*SDRC_D25*/\ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) /*SDRC_D26*/\ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) /*SDRC_D27*/\ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) /*SDRC_D28*/\ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) /*SDRC_D29*/\ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) /*SDRC_D30*/\ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) /*SDRC_D31*/\ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) /*SDRC_CLK*/\ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) /*SDRC_DQS0*/\ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) /*SDRC_DQS1*/\ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) /*SDRC_DQS2*/\ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) /*SDRC_DQS3*/\ + /* GPMC */\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTD | DIS | M0)) /*GPMC_A1*/\ + MUX_VAL(CP(GPMC_A2), (IDIS | PTD | DIS | M0)) /*GPMC_A2*/\ + MUX_VAL(CP(GPMC_A3), (IDIS | PTD | DIS | M0)) /*GPMC_A3*/\ + MUX_VAL(CP(GPMC_A4), (IDIS | PTD | DIS | M0)) /*GPMC_A4*/\ + MUX_VAL(CP(GPMC_A5), (IDIS | PTD | DIS | M0)) /*GPMC_A5*/\ + MUX_VAL(CP(GPMC_A6), (IDIS | PTD | DIS | M0)) /*GPMC_A6*/\ + MUX_VAL(CP(GPMC_A7), (IDIS | PTD | DIS | M0)) /*GPMC_A7*/\ + MUX_VAL(CP(GPMC_A8), (IDIS | PTD | DIS | M0)) /*GPMC_A8*/\ + MUX_VAL(CP(GPMC_A9), (IDIS | PTD | DIS | M0)) /*GPMC_A9*/\ + MUX_VAL(CP(GPMC_A10), (IDIS | PTD | DIS | M0)) /*GPMC_A10*/\ + MUX_VAL(CP(GPMC_D0), (IEN | PTD | DIS | M0)) /*GPMC_D0*/\ + MUX_VAL(CP(GPMC_D1), (IEN | PTD | DIS | M0)) /*GPMC_D1*/\ + MUX_VAL(CP(GPMC_D2), (IEN | PTD | DIS | M0)) /*GPMC_D2*/\ + MUX_VAL(CP(GPMC_D3), (IEN | PTD | DIS | M0)) /*GPMC_D3*/\ + MUX_VAL(CP(GPMC_D4), (IEN | PTD | DIS | M0)) /*GPMC_D4*/\ + MUX_VAL(CP(GPMC_D5), (IEN | PTD | DIS | M0)) /*GPMC_D5*/\ + MUX_VAL(CP(GPMC_D6), (IEN | PTD | DIS | M0)) /*GPMC_D6*/\ + MUX_VAL(CP(GPMC_D7), (IEN | PTD | DIS | M0)) /*GPMC_D7*/\ + MUX_VAL(CP(GPMC_D8), (IEN | PTD | DIS | M0)) /*GPMC_D8*/\ + MUX_VAL(CP(GPMC_D9), (IEN | PTD | DIS | M0)) /*GPMC_D9*/\ + MUX_VAL(CP(GPMC_D10), (IEN | PTD | DIS | M0)) /*GPMC_D10*/\ + MUX_VAL(CP(GPMC_D11), (IEN | PTD | DIS | M0)) /*GPMC_D11*/\ + MUX_VAL(CP(GPMC_D12), (IEN | PTD | DIS | M0)) /*GPMC_D12*/\ + MUX_VAL(CP(GPMC_D13), (IEN | PTD | DIS | M0)) /*GPMC_D13*/\ + MUX_VAL(CP(GPMC_D14), (IEN | PTD | DIS | M0)) /*GPMC_D14*/\ + MUX_VAL(CP(GPMC_D15), (IEN | PTD | DIS | M0)) /*GPMC_D15*/\ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) /*GPMC_nCS0 NAND*/\ + MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0)) /*GPMC_nCS1*/\ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) /*GPMC_nCS2*/\ + MUX_VAL(CP(GPMC_NCS3), (IDIS | PTU | EN | M0)) /*GPMC_nCS3*/\ + MUX_VAL(CP(GPMC_NCS4), (IDIS | PTU | EN | M0)) /*GPMC_nCS4*/\ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0)) /*GPMC_nCS5*/\ + MUX_VAL(CP(GPMC_NCS6), (IDIS | PTU | EN | M0)) /*GPMC_nCS6*/\ + MUX_VAL(CP(GPMC_NCS7), (IDIS | PTU | EN | M0)) /*GPMC_nCS7*/\ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0)) /*GPMC_nBE1*/\ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M0)) /*GPMC_WAIT2*/\ + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M0)) /*GPMC_WAIT3*/\ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTD | DIS | M0)) /*GPMC_CLK*/\ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /*GPMC_nADV_ALE*/\ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /*GPMC_nOE*/\ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) /*GPMC_nWE*/\ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTD | DIS | M0)) /*GPMC_nBE0_CLE*/\ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) /*GPMC_nWP*/\ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) /*GPMC_WAIT0*/\ + MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M0)) /*GPMC_WAIT1*/\ + /* DSS */\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) /*DSS_PCLK*/\ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) /*DSS_HSYNC*/\ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) /*DSS_VSYNC*/\ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) /*DSS_ACBIAS*/\ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) /*DSS_DATA0*/\ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) /*DSS_DATA1*/\ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) /*DSS_DATA2*/\ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) /*DSS_DATA3*/\ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) /*DSS_DATA4*/\ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) /*DSS_DATA5*/\ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) /*DSS_DATA6*/\ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) /*DSS_DATA7*/\ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) /*DSS_DATA8*/\ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) /*DSS_DATA9*/\ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) /*DSS_DATA10*/\ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) /*DSS_DATA11*/\ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) /*DSS_DATA12*/\ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) /*DSS_DATA13*/\ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) /*DSS_DATA14*/\ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) /*DSS_DATA15*/\ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) /*DSS_DATA16*/\ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) /*DSS_DATA17*/\ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) /*DSS_DATA18*/\ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) /*DSS_DATA19*/\ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) /*DSS_DATA20*/\ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) /*DSS_DATA21*/\ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) /*DSS_DATA22*/\ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) /*DSS_DATA23*/\ + /* CAMERA */\ + MUX_VAL(CP(CAM_HS), (IEN | PTU | EN | M0)) /*CAM_HS */\ + MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M0)) /*CAM_VS */\ + MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) /*CAM_XCLKA*/\ + MUX_VAL(CP(CAM_PCLK), (IEN | PTU | EN | M0)) /*CAM_PCLK*/\ + MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4)) /*GPIO_98*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) /*CAM_D0*/\ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) /*CAM_D1*/\ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) /*CAM_D2*/\ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) /*CAM_D3*/\ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) /*CAM_D4*/\ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) /*CAM_D5*/\ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) /*CAM_D6*/\ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) /*CAM_D7*/\ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) /*CAM_D8*/\ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) /*CAM_D9*/\ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) /*CAM_D10*/\ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) /*CAM_D11*/\ + MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0)) /*CAM_XCLKB*/\ + MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M4)) /*GPIO_167*/\ + MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0)) /*CAM_STROBE*/\ + MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) /*CSI2_DX0*/\ + MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) /*CSI2_DY0*/\ + MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) /*CSI2_DX1*/\ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) /*CSI2_DY1*/\ + /* Audio Interface */\ + MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | DIS | M0)) /*McBSP2_FSX*/\ + MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | DIS | M0)) /*McBSP2_CLKX*/\ + MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | DIS | M0)) /*McBSP2_DR*/\ + MUX_VAL(CP(MCBSP2_DX), (IDIS | PTD | DIS | M0)) /*McBSP2_DX*/\ + /* MMC Slot */\ + MUX_VAL(CP(MMC1_CLK), (IDIS | PTU | EN | M0)) /*MMC1_CLK*/\ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | EN | M0)) /*MMC1_CMD*/\ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | EN | M0)) /*MMC1_DAT0*/\ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | EN | M0)) /*MMC1_DAT1*/\ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | EN | M0)) /*MMC1_DAT2*/\ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | EN | M0)) /*MMC1_DAT3*/\ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M0)) /*MMC1_DAT4*/\ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M0)) /*MMC1_DAT5*/\ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M0)) /*MMC1_DAT6*/\ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M0)) /*MMC1_DAT7*/\ + /* Expansion Header */\ + MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M4)) /*GPIO_130*/\ + MUX_VAL(CP(MMC2_CMD), (IEN | PTU | EN | M4)) /*GPIO_131*/\ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | EN | M4)) /*GPIO_132*/\ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | EN | M4)) /*GPIO_133*/\ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | EN | M4)) /*GPIO_134*/\ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | EN | M4)) /*GPIO_135*/\ + MUX_VAL(CP(MMC2_DAT4), (IEN | PTU | EN | M4)) /*GPIO_136*/\ + MUX_VAL(CP(MMC2_DAT5), (IEN | PTU | EN | M4)) /*GPIO_137*/\ + MUX_VAL(CP(MMC2_DAT6), (IEN | PTU | EN | M4)) /*GPIO_138*/\ + MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M4)) /*GPIO_139*/\ + MUX_VAL(CP(MCBSP3_DX), (IDIS | PTD | DIS | M4)) /*GPIO_140*/\ + MUX_VAL(CP(MCBSP3_DR), (IDIS | PTD | DIS | M4)) /*GPIO_141*/\ + MUX_VAL(CP(MCBSP3_CLKX), (IDIS | PTD | DIS | M4)) /*GPIO_142*/\ + MUX_VAL(CP(MCBSP3_FSX), (IDIS | PTD | DIS | M4)) /*GPIO_143*/\ + MUX_VAL(CP(UART2_CTS), (IDIS | PTD | DIS | M4)) /*GPIO_144*/\ + MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M4)) /*GPIO_145*/\ + MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M4)) /*GPIO_146*/\ + MUX_VAL(CP(UART2_RX), (IDIS | PTD | DIS | M4)) /*GPIO_147*/\ + MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) /*GPIO_148*/\ + MUX_VAL(CP(UART1_RTS), (IDIS | PTD | DIS | M4)) /*GPIO_149*/ \ + MUX_VAL(CP(UART1_CTS), (IDIS | PTD | DIS | M4)) /*GPIO_150*/ \ + MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0)) /*GPIO_151*/\ + MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M1)) /*GPIO_152*/\ + MUX_VAL(CP(MCBSP4_DR), (IEN | PTD | DIS | M1)) /*GPIO_153*/\ + MUX_VAL(CP(MCBSP4_DX), (IEN | PTD | DIS | M1)) /*GPIO_154*/\ + MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M1)) /*GPIO_155*/\ + MUX_VAL(CP(MCBSP1_CLKR), (IDIS | PTD | DIS | M4)) /*GPIO_156*/\ + MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M4)) /*GPIO_157*/\ + MUX_VAL(CP(MCBSP1_DX), (IDIS | PTD | DIS | M4)) /*GPIO_158*/\ + MUX_VAL(CP(MCBSP1_DR), (IDIS | PTD | DIS | M4)) /*GPIO_159*/\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) /*GPIO_160*/\ + MUX_VAL(CP(MCBSP1_FSX), (IDIS | PTD | DIS | M4)) /*GPIO_161*/\ + MUX_VAL(CP(MCBSP1_CLKX), (IDIS | PTD | DIS | M4)) /*GPIO_162*/\ + /* Serial Interface */\ + MUX_VAL(CP(UART3_CTS_RCTX), (IDIS | PTD | EN | M4)) /*GPIO_163 - LED2*/\ + MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTU | EN | M4)) /*GPIO_164 - LED3*/\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) /*UART3_RX_IRRX*/\ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) /*UART3_TX_IRTX*/\ + /* Host USB0 */\ + MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) /*HSUSB0_CLK*/\ + MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) /*HSUSB0_STP*/\ + MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) /*HSUSB0_DIR*/\ + MUX_VAL(CP(HSUSB0_NXT), (IEN | PTD | DIS | M0)) /*HSUSB0_NXT*/\ + MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA0*/\ + MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA1*/\ + MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA2*/\ + MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA3*/\ + MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA4*/\ + MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA5*/\ + MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA6*/\ + MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA7*/\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) /*I2C1_SCL*/\ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) /*I2C1_SDA*/\ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0)) /*I2C2_SCL*/\ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0)) /*I2C2_SDA*/\ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) /*I2C3_SCL*/\ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) /*I2C3_SDA*/\ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) /*I2C4_SCL*/\ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) /*I2C4_SDA*/\ + MUX_VAL(CP(HDQ_SIO), (IEN | PTU | EN | M0)) /*HDQ_SIO*/\ + MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M4)) /*GPIO_171*/\ + MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M4)) /*GPIO_172*/\ + MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0)) /*MCSPI1_SOMI*/\ + MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | DIS | M0)) /*MCSPI1_CS0*/\ + MUX_VAL(CP(MCSPI1_CS1), (IDIS | PTD | DIS | M0)) /*MCSPI1_CS1*/\ + MUX_VAL(CP(MCSPI1_CS2), (IDIS | PTD | DIS | M4)) /*GPIO_176*/\ + /* USB EHCI (port 2) */\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M0)) /*HSUSB2_DATA2*/\ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)) /*HSUSB2_DATA7*/\ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M0)) /*HSUSB2_DATA4*/\ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)) /*HSUSB2_DATA5*/\ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M0)) /*HSUSB2_DATA6*/\ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M0)) /*HSUSB2_DATA3*/\ + /*Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /*SYS_32K*/\ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) /*SYS_CLKREQ*/\ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) /*SYS_nIRQ*/\ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3*/\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4*/\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7 - BOOTMODE*/\ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/ \ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\ + MUX_VAL(CP(SYS_CLKOUT1), (IDIS | PTD | EN | M0)) /*SYS_CLKOUT1*/\ + MUX_VAL(CP(SYS_CLKOUT2), (IDIS | PTU | EN | M4)) /*GPIO_186 - LED1*/\ + MUX_VAL(CP(ETK_CLK_ES2), (IDIS | PTD | DIS | M4)) /*GPIO_12*/\ + MUX_VAL(CP(ETK_CTL_ES2), (IDIS | PTD | EN | M4)) /*GPIO_13*/\ + MUX_VAL(CP(ETK_D0_ES2), (IDIS | PTU | EN | M1)) /*SPI3_SIMO*/\ + MUX_VAL(CP(ETK_D1_ES2), (IDIS | PTU | EN | M1)) /*SPI3_SOMI*/\ + MUX_VAL(CP(ETK_D2_ES2), (IDIS | PTU | EN | M1)) /*SPI3_CS0*/\ + MUX_VAL(CP(ETK_D3_ES2), (IDIS | PTU | EN | M1)) /*SPI3_CLK*/\ + MUX_VAL(CP(ETK_D4_ES2), (IDIS | PTU | EN | M4)) /*GPIO_18*/\ + MUX_VAL(CP(ETK_D5_ES2), (IDIS | PTU | EN | M4)) /*GPIO_19*/\ + MUX_VAL(CP(ETK_D6_ES2), (IDIS | PTU | EN | M4)) /*GPIO_20*/\ + MUX_VAL(CP(ETK_D7_ES2), (IDIS | PTU | EN | M1)) /*SPI3_CS1*/\ + MUX_VAL(CP(ETK_D8_ES2), (IEN | PTU | DIS | M4)) /*MSECURE*/\ + MUX_VAL(CP(ETK_D9_ES2), (IEN | PTU | EN | M4)) /*GPIO_23*/\ + /*HSUSB2 */\ + MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTU | EN | M4)) /*GPIO_24*/\ + MUX_VAL(CP(ETK_D11_ES2), (IEN | PTU | EN | M4)) /*GPIO_25*/\ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTU | EN | M4)) /*GPIO_26*/\ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTU | EN | M4)) /*GPIO_27*/\ + MUX_VAL(CP(ETK_D14_ES2), (IEN | PTU | EN | M4)) /*GPIO_28*/\ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTU | EN | M4)) /*GPIO_29*/\ + /* */\ + MUX_VAL(CP(D2D_MCAD1), (IEN | PTD | EN | M0)) /*D2D_MCAD1*/\ + MUX_VAL(CP(D2D_MCAD2), (IEN | PTD | EN | M0)) /*D2D_MCAD2*/\ + MUX_VAL(CP(D2D_MCAD3), (IEN | PTD | EN | M0)) /*D2D_MCAD3*/\ + MUX_VAL(CP(D2D_MCAD4), (IEN | PTD | EN | M0)) /*D2D_MCAD4*/\ + MUX_VAL(CP(D2D_MCAD5), (IEN | PTD | EN | M0)) /*D2D_MCAD5*/\ + MUX_VAL(CP(D2D_MCAD6), (IEN | PTD | EN | M0)) /*D2D_MCAD6*/\ + MUX_VAL(CP(D2D_MCAD7), (IEN | PTD | EN | M0)) /*D2D_MCAD7*/\ + MUX_VAL(CP(D2D_MCAD8), (IEN | PTD | EN | M0)) /*D2D_MCAD8*/\ + MUX_VAL(CP(D2D_MCAD9), (IEN | PTD | EN | M0)) /*D2D_MCAD9*/\ + MUX_VAL(CP(D2D_MCAD10), (IEN | PTD | EN | M0)) /*D2D_MCAD10*/\ + MUX_VAL(CP(D2D_MCAD11), (IEN | PTD | EN | M0)) /*D2D_MCAD11*/\ + MUX_VAL(CP(D2D_MCAD12), (IEN | PTD | EN | M0)) /*D2D_MCAD12*/\ + MUX_VAL(CP(D2D_MCAD13), (IEN | PTD | EN | M0)) /*D2D_MCAD13*/\ + MUX_VAL(CP(D2D_MCAD14), (IEN | PTD | EN | M0)) /*D2D_MCAD14*/\ + MUX_VAL(CP(D2D_MCAD15), (IEN | PTD | EN | M0)) /*D2D_MCAD15*/\ + MUX_VAL(CP(D2D_MCAD16), (IEN | PTD | EN | M0)) /*D2D_MCAD16*/\ + MUX_VAL(CP(D2D_MCAD17), (IEN | PTD | EN | M0)) /*D2D_MCAD17*/\ + MUX_VAL(CP(D2D_MCAD18), (IEN | PTD | EN | M0)) /*D2D_MCAD18*/\ + MUX_VAL(CP(D2D_MCAD19), (IEN | PTD | EN | M0)) /*D2D_MCAD19*/\ + MUX_VAL(CP(D2D_MCAD20), (IEN | PTD | EN | M0)) /*D2D_MCAD20*/\ + MUX_VAL(CP(D2D_MCAD21), (IEN | PTD | EN | M0)) /*D2D_MCAD21*/\ + MUX_VAL(CP(D2D_MCAD22), (IEN | PTD | EN | M0)) /*D2D_MCAD22*/\ + MUX_VAL(CP(D2D_MCAD23), (IEN | PTD | EN | M0)) /*D2D_MCAD23*/\ + MUX_VAL(CP(D2D_MCAD24), (IEN | PTD | EN | M0)) /*D2D_MCAD24*/\ + MUX_VAL(CP(D2D_MCAD25), (IEN | PTD | EN | M0)) /*D2D_MCAD25*/\ + MUX_VAL(CP(D2D_MCAD26), (IEN | PTD | EN | M0)) /*D2D_MCAD26*/\ + MUX_VAL(CP(D2D_MCAD27), (IEN | PTD | EN | M0)) /*D2D_MCAD27*/\ + MUX_VAL(CP(D2D_MCAD28), (IEN | PTD | EN | M0)) /*D2D_MCAD28*/\ + MUX_VAL(CP(D2D_MCAD29), (IEN | PTD | EN | M0)) /*D2D_MCAD29*/\ + MUX_VAL(CP(D2D_MCAD30), (IEN | PTD | EN | M0)) /*D2D_MCAD30*/\ + MUX_VAL(CP(D2D_MCAD31), (IEN | PTD | EN | M0)) /*D2D_MCAD31*/\ + MUX_VAL(CP(D2D_MCAD32), (IEN | PTD | EN | M0)) /*D2D_MCAD32*/\ + MUX_VAL(CP(D2D_MCAD33), (IEN | PTD | EN | M0)) /*D2D_MCAD33*/\ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) /*D2D_MCAD34*/\ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) /*D2D_MCAD35*/\ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) /*D2D_MCAD36*/\ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) /*D2D_clk26mi*/\ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) /*D2D_nrespwron*/\ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) /*D2D_nreswarm */\ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) /*D2D_arm9nirq */\ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) /*D2D_uma2p6fiq*/\ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) /*D2D_spint*/\ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) /*D2D_frint*/\ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) /*D2D_dmareq0*/\ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) /*D2D_dmareq1*/\ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) /*D2D_dmareq2*/\ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) /*D2D_dmareq3*/\ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) /*D2D_n3gtrst*/\ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) /*D2D_n3gtdi*/\ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) /*D2D_n3gtdo*/\ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) /*D2D_n3gtms*/\ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) /*D2D_n3gtck*/\ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) /*D2D_n3grtck*/\ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) /*D2D_mstdby*/\ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) /*D2D_swakeup*/\ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) /*D2D_idlereq*/\ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) /*D2D_idleack*/\ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) /*D2D_mwrite*/\ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) /*D2D_swrite*/\ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) /*D2D_mread*/\ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) /*D2D_sread*/\ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) /*D2D_mbusflag*/\ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) /*D2D_sbusflag*/\ + MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /*sdrc_cke0*/\ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTD | DIS | M7)) /*sdrc_cke1*/ + +#endif diff --git a/boards.cfg b/boards.cfg index 2f90dbf..d7b41a4 100644 --- a/boards.cfg +++ b/boards.cfg @@ -213,6 +213,7 @@ omap3_evm_quick_mmc arm armv7 evm ti omap3_evm_quick_nand arm armv7 evm ti omap3 omap3_sdp3430 arm armv7 sdp3430 ti omap3 devkit8000 arm armv7 devkit8000 timll omap3 +tricorder arm armv7 tricorder corscience omap3 twister arm armv7 twister technexion omap3 omap4_panda arm armv7 panda ti omap4 omap4_sdp4430 arm armv7 sdp4430 ti omap4 diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h new file mode 100644 index 0000000..f87696b --- /dev/null +++ b/include/configs/tricorder.h @@ -0,0 +1,320 @@ +/* + * (C) Copyright 2006-2008 + * Texas Instruments. + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim x0khasim@ti.com + * + * (C) Copyright 2012 + * Corscience GmbH & Co. KG + * Thomas Weber weber@corscience.de + * + * Configuration settings for the Tricorder board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_OMAP /* in a TI OMAP core */ +#define CONFIG_OMAP34XX /* which is a 34XX */ + +#define CONFIG_MACH_TYPE MACH_TYPE_TRICORDER +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80100000 + +#define CONFIG_SDRC /* The chip has SDRC controller */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* Display CPU and Board information */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +#define CONFIG_OF_LIBFDT + +/* Size of malloc() pool */ +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ + /* Sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (512 << 10)) + +/* Hardware drivers */ + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +/* select serial console configuration */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} + +/* MMC */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_DOS_PARTITION + +/* I2C */ +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* TWL4030 */ +#define CONFIG_TWL4030_POWER +#define CONFIG_TWL4030_LED + +/* Board NAND Info */ +#define CONFIG_SYS_NO_FLASH /* no NOR flash */ +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:" \ + "512k(u-boot-spl)," \ + "1920k(u-boot)," \ + "128k(u-boot-env)," \ + "4m(kernel)," \ + "-(fs)" + +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ + /* to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access nand at */ + /* CS0 */ +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ + /* devices */ + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */ +#define CONFIG_CMD_UBI /* UBIFS commands */ + +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_FPGA /* FPGA configuration Support */ +#undef CONFIG_CMD_IMI /* iminfo */ +#undef CONFIG_CMD_JFFS2 /* JFFS2 Support */ + +/* needed for ubi */ +#define CONFIG_RBTREE +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_PARTITIONS + +/* Environment information */ +#define CONFIG_ENV_OVERWRITE /* allow to overwrite serial and ethaddr */ + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyO2,115200n8\0" \ + "vram=12M\0" \ + "lcdmode=800x600\0" \ + "defaultdisplay=lcd\0" \ + "kernelopts=rw rootwait\0" \ + "commonargs=" \ + "setenv bootargs console=${console} " \ + "vram=${vram} " \ + "omapfb.mode=lcd:${lcdmode} " \ + "omapdss.def_disp=${defaultdisplay}\0" \ + "mmcargs=" \ + "run commonargs; " \ + "setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p2 " \ + "${kernelopts}\0" \ + "nandargs=" \ + "run commonargs; " \ + "setenv bootargs ${bootargs} " \ + "omapfb.mode=lcd:${lcdmode} " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=ubi0:rootfs " \ + "rootfstype=ubifs " \ + "${kernelopts}\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "eraseenv=nand unlock 0x260000 0x20000; nand erase 0x260000 0x20000\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + "autoboot=if mmc init 0; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi\0" + + +#define CONFIG_BOOTCOMMAND "run autoboot" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "OMAP3 Tricorder # " +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0 + 0x07000000) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + 0x01000000) /* 16MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0 + 0x02000000) + +/* + * OMAP3 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* The stack sizes are set up in start.S using the settings below */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (128 << 20) /* at least 128 MiB */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* NAND and environment organization */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) + +/* SRAM config */ +#define CONFIG_SYS_SRAM_START 0x40200000 +#define CONFIG_SYS_SRAM_SIZE 0x10000 + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_NAND_SIMPLE + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ + +#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ +#define CONFIG_SPL_MAX_SIZE 0xB400 /* 45 K */ +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 /*CONFIG_SYS_SDRAM_BASE*/ +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 + +/* NAND boot config */ +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ + 10, 11, 12, 13} + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 3 + +#define CONFIG_SYS_NAND_ECCSTEPS (CONFIG_SYS_NAND_PAGE_SIZE / \ + CONFIG_SYS_NAND_ECCSIZE) +#define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ + CONFIG_SYS_NAND_ECCSTEPS) + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x200000 + +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 /* 1 MB */ + +#endif /* __CONFIG_H */
Applied to u-boot-ti/master, thanks!
Thomas Weber
