[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 3fea95369850987de15a2a0ac009d05e13b90246:
Merge branch 'master' of git://git.denx.de/u-boot-video (2017-04-14 22:05:17 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git
for you to fetch changes up to e0dfec863e2ca5088dd797a5b6853d4c0df9002c:
powerpc/board/t1024rdb: enable board-level reset when issuing reset command (2017-04-17 09:03:30 -0700)
---------------------------------------------------------------- Ashish kumar (1): armv8: fsl-lsch3: Instantiate TZASC configuration in 2 groups
Ruchika Gupta (4): arm: ls1043ardb: Add SD secure boot target arm: ls1043ardb: Add NAND secure boot target arm: ls1046ardb: Add SD secure boot target powerpc: e6500: Lock/unlock 1 cache instead of L1 as init_ram
Santan Kumar (1): armv8: ls2080a: Add serdes2 protocol 0x51 support
Shengzhou Liu (2): arm64/ls1046a: Enable ERRATUM_A008850 for ls1046a SoC powerpc/board/t1024rdb: enable board-level reset when issuing reset command
Sumit Garg (3): armv8: ls1043ardb: SPL size reduction armv8: ls1046ardb: SPL size reduction armv8: LS1046AQDS: Add NOR Secure Boot Target
Thomas Schaefer (1): drivers: ddr: fsl: fix unused-const-variable warnings
VINITHA PILLAI (1): powerpc: T1042RDB: SECURE BOOT: Remove CONFIG_CMD_BLOB from SPL compilation
Vinitha Pillai-B57223 (6): armv8: fsl-layerscape: SECURE BOOT: Add header address of PPA in kconfig armv8: LS1043ARDB: Enable PPA in Secure boot defconfig armv8: SECURE_BOOT: Enable chain of trust on LS1046A platform armv8: LS1046ARDB: Add QSPI Secure Boot target armv8: SECURE_BOOT: Enable chain of trust on LS1012A platform armv8: LS1012ARDB: Add QSPI Secure Boot target
Yangbo Lu (1): armv8/fsl-layerscape: fdt: avoid incorrect fixing with CONFIG_SYS_CLK_FREQ
York Sun (3): armv8: ls2080a: Drop macro CONFIG_LS2080A armv8: ls1043a: Drop macro CONFIG_LS1043A armv7: ls1021a: Drop macro CONFIG_LS102XA
tang yuantian (1): armv8: ls1046aqds: enable ppa in default config
arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 23 +++++++ arch/arm/cpu/armv8/fsl-layerscape/Makefile | 4 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 6 +- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 4 +- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 26 ++++---- arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 20 +++++- arch/arm/dts/Makefile | 2 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 13 ++-- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 2 +- .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 2 +- arch/arm/include/asm/arch-ls102xa/config.h | 2 +- arch/arm/include/asm/config.h | 2 +- arch/arm/include/asm/fsl_secure_boot.h | 53 ++++++++++------ arch/powerpc/cpu/mpc85xx/start.S | 6 +- arch/powerpc/include/asm/fsl_secure_boot.h | 2 +- board/freescale/common/arm_sleep.c | 6 +- board/freescale/common/fsl_chain_of_trust.c | 2 +- board/freescale/common/fsl_validate.c | 6 +- board/freescale/ls1012ardb/MAINTAINERS | 4 ++ board/freescale/ls1012ardb/ls1012ardb.c | 5 ++ board/freescale/ls1043aqds/Makefile | 2 + board/freescale/ls1043ardb/MAINTAINERS | 2 + board/freescale/ls1043ardb/Makefile | 4 +- board/freescale/ls1043ardb/ls1043ardb.c | 18 +++--- board/freescale/ls1046aqds/MAINTAINERS | 4 ++ board/freescale/ls1046aqds/Makefile | 2 + board/freescale/ls1046aqds/ls1046aqds.c | 19 ++++++ board/freescale/ls1046ardb/Kconfig | 2 +- board/freescale/ls1046ardb/MAINTAINERS | 10 +++ board/freescale/ls1046ardb/Makefile | 4 +- board/freescale/ls1046ardb/ls1046ardb.c | 35 ++++++++--- board/freescale/t102xrdb/t102xrdb.c | 7 +++ configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 48 +++++++++++++++ configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 57 +++++++++++++++++ configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 57 +++++++++++++++++ configs/ls1043ardb_sdcard_defconfig | 1 - configs/ls1046aqds_SECURE_BOOT_defconfig | 39 ++++++++++++ configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_qspi_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_sdcard_qspi_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 37 +++++++++++ configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 45 ++++++++++++++ configs/ls2080a_emu_defconfig | 2 +- configs/ls2080a_simu_defconfig | 2 +- configs/ls2080aqds_SECURE_BOOT_defconfig | 1 - configs/ls2080aqds_defconfig | 1 - configs/ls2080aqds_nand_defconfig | 2 +- configs/ls2080aqds_qspi_defconfig | 2 +- configs/ls2080ardb_SECURE_BOOT_defconfig | 1 - configs/ls2080ardb_defconfig | 1 - configs/ls2080ardb_nand_defconfig | 2 +- drivers/crypto/fsl/jobdesc.c | 4 +- drivers/crypto/fsl/jr.c | 21 ++++--- drivers/ddr/fsl/options.c | 72 +++++++++++----------- drivers/i2c/mxc_i2c.c | 2 +- drivers/net/fm/Makefile | 2 +- drivers/net/ldpaa_eth/Makefile | 2 +- drivers/qe/qe.c | 6 +- drivers/usb/common/fsl-errata.c | 2 +- include/config_fsl_chain_trust.h | 9 +-- include/configs/ls1012a_common.h | 2 - include/configs/ls1012ardb.h | 3 + include/configs/ls1021aiot.h | 2 - include/configs/ls1021aqds.h | 2 - include/configs/ls1021atwr.h | 2 - include/configs/ls1043a_common.h | 72 ++++++++++++++++++++-- include/configs/ls1043ardb.h | 16 ++++- include/configs/ls1046a_common.h | 48 ++++++++++++++- include/configs/ls1046ardb.h | 17 ++++- include/fsl_errata.h | 4 +- include/linux/immap_qe.h | 2 +- include/linux/usb/xhci-fsl.h | 6 +- include/tsec.h | 2 +- include/usb/ehci-ci.h | 2 +- scripts/config_whitelist.txt | 3 - 82 files changed, 740 insertions(+), 172 deletions(-) create mode 100644 configs/ls1012ardb_qspi_SECURE_BOOT_defconfig create mode 100644 configs/ls1043ardb_nand_SECURE_BOOT_defconfig create mode 100644 configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig create mode 100644 configs/ls1046aqds_SECURE_BOOT_defconfig create mode 100644 configs/ls1046ardb_qspi_SECURE_BOOT_defconfig create mode 100644 configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig
York
On Tue, Apr 18, 2017 at 08:32:48AM -0700, York Sun wrote:
Tom,
York Sun
