[U-Boot] Please pull u-boot-samsung/master
Dear Tom,
The following changes since commit b91b8f74fe9ded18344c3d03080a4abc07254502: Wolfgang Denk (1): Merge branch 'master' of /home/wd/git/u-boot/custodians
git://git.denx.de/u-boot-samsung master
Minkyu Kang (2): s3c64xx: move s3c64xx header files to asm-arm/arch-s3c64xx s5pc1xx: serial: fix the error check logic
Seunghyeon Rhee (1): S3C6400/SMDK6400: fix stack_setup in start.S
kevin.morfitt@fearnside-systems.co.uk (3): Move s3c24x0 header files to asm-arm/arch-s3c24x0/ Clean-up of s3c24x0 header files Add a unified s3c24x0 header file
board/mpl/vcma9/vcma9.c | 2 +- board/mpl/vcma9/vcma9.h | 16 +- board/samsung/smdk2400/smdk2400.c | 2 +- board/samsung/smdk2410/smdk2410.c | 2 +- board/samsung/smdk6400/lowlevel_init.S | 2 +- board/samsung/smdk6400/smdk6400.c | 2 +- board/sbc2410x/sbc2410x.c | 2 +- board/trab/cmd_trab.c | 2 +- board/trab/rs485.c | 2 +- board/trab/rs485.h | 2 +- board/trab/trab.c | 2 +- board/trab/trab_fkt.c | 2 +- board/trab/tsc2000.c | 2 +- board/trab/vfd.c | 2 +- cpu/arm1176/cpu.c | 2 +- cpu/arm1176/s3c64xx/cpu_init.S | 2 +- cpu/arm1176/s3c64xx/reset.S | 2 +- cpu/arm1176/s3c64xx/speed.c | 2 +- cpu/arm1176/s3c64xx/timer.c | 2 +- cpu/arm1176/start.S | 9 +- cpu/arm920t/s3c24x0/interrupts.c | 6 +- cpu/arm920t/s3c24x0/speed.c | 13 +- cpu/arm920t/s3c24x0/timer.c | 15 +- cpu/arm920t/s3c24x0/usb.c | 17 +- cpu/arm920t/s3c24x0/usb_ohci.c | 11 +- cpu/arm920t/start.S | 4 +- drivers/i2c/s3c24x0_i2c.c | 6 +- drivers/mtd/nand/s3c2410_nand.c | 2 +- drivers/mtd/nand/s3c64xx.c | 2 +- drivers/net/smc911x.c | 6 + drivers/rtc/s3c24x0_rtc.c | 6 +- drivers/serial/s3c64xx.c | 2 +- drivers/serial/serial_s3c24x0.c | 6 +- drivers/serial/serial_s5pc1xx.c | 24 +- drivers/usb/host/ohci-hcd.c | 3 +- drivers/usb/host/s3c64xx-hcd.c | 2 +- include/{ => asm-arm/arch-s3c24x0}/s3c2400.h | 18 +- include/{ => asm-arm/arch-s3c24x0}/s3c2410.h | 19 +- include/asm-arm/arch-s3c24x0/s3c24x0.h | 652 +++++++++++++++++++++++++ include/asm-arm/arch-s3c24x0/s3c24x0_cpu.h | 27 + include/{ => asm-arm/arch-s3c64xx}/s3c6400.h | 0 include/{ => asm-arm/arch-s3c64xx}/s3c64x0.h | 0 include/common.h | 5 +- include/configs/VCMA9.h | 7 +- include/configs/sbc2410x.h | 7 +- include/configs/smdk2400.h | 7 +- include/configs/smdk2410.h | 7 +- include/configs/smdk6400.h | 2 - include/configs/trab.h | 9 +- include/s3c24x0.h | 656 -------------------------- 50 files changed, 816 insertions(+), 786 deletions(-) rename include/{ => asm-arm/arch-s3c24x0}/s3c2400.h (98%) rename include/{ => asm-arm/arch-s3c24x0}/s3c2410.h (98%) create mode 100644 include/asm-arm/arch-s3c24x0/s3c24x0.h create mode 100644 include/asm-arm/arch-s3c24x0/s3c24x0_cpu.h rename include/{ => asm-arm/arch-s3c64xx}/s3c6400.h (100%) rename include/{ => asm-arm/arch-s3c64xx}/s3c64x0.h (100%) delete mode 100644 include/s3c24x0.h
Minkyu Kang wrote:
Dear Tom,
These have been pushed to arm/next
Thanks Tom
Minkyu Kang
Tom
