[PATCH v2] usb: gadget: usbhs: Add Renesas USBHS device driver
From: Vitaliy Vasylskyy vitaliy.vasylskyy@globallogic.com
Add UDC driver for Renesas USBHS controller found in R-Car Gen3 SoCs. This is mostly ported from the Linux kernel, with additional porting glue. The code has been synchronized with 1b4861e32e46 ("Linux 6.9.3") and cleaned up and ported to DM since the original implementation by Vitaliy.
Signed-off-by: Vitaliy Vasylskyy vitaliy.vasylskyy@globallogic.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Note that the driver does have a few checkpatch warnings in it, those also partly come from Linux. --- Cc: Jonas Karlman jonas@kwiboo.se Cc: Lukasz Majewski lukma@denx.de Cc: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Miquel Raynal miquel.raynal@bootlin.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Vitaliy Vasylskyy vitaliy.vasylskyy@globallogic.com --- V2: Drop CONFIG_USB_RENESAS_USBHS_UDC check --- drivers/usb/gadget/Kconfig | 9 + drivers/usb/gadget/Makefile | 1 + drivers/usb/gadget/rcar/Makefile | 8 + drivers/usb/gadget/rcar/common.c | 478 +++++++++++ drivers/usb/gadget/rcar/common.h | 328 +++++++ drivers/usb/gadget/rcar/fifo.c | 1067 +++++++++++++++++++++++ drivers/usb/gadget/rcar/fifo.h | 114 +++ drivers/usb/gadget/rcar/mod.c | 345 ++++++++ drivers/usb/gadget/rcar/mod.h | 161 ++++ drivers/usb/gadget/rcar/mod_gadget.c | 1136 +++++++++++++++++++++++++ drivers/usb/gadget/rcar/pipe.c | 849 ++++++++++++++++++ drivers/usb/gadget/rcar/pipe.h | 114 +++ drivers/usb/gadget/rcar/renesas_usb.h | 125 +++ 13 files changed, 4735 insertions(+) create mode 100644 drivers/usb/gadget/rcar/Makefile create mode 100644 drivers/usb/gadget/rcar/common.c create mode 100644 drivers/usb/gadget/rcar/common.h create mode 100644 drivers/usb/gadget/rcar/fifo.c create mode 100644 drivers/usb/gadget/rcar/fifo.h create mode 100644 drivers/usb/gadget/rcar/mod.c create mode 100644 drivers/usb/gadget/rcar/mod.h create mode 100644 drivers/usb/gadget/rcar/mod_gadget.c create mode 100644 drivers/usb/gadget/rcar/pipe.c create mode 100644 drivers/usb/gadget/rcar/pipe.h create mode 100644 drivers/usb/gadget/rcar/renesas_usb.h
diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 4621a6fd5e6..5fb73890c78 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -114,6 +114,15 @@ config USB_GADGET_DWC2_OTG driver to operate in Peripheral mode. This option requires USB_GADGET to be enabled.
+config USB_RENESAS_USBHS + bool "Renesas RCar USB2.0 HS controller (gadget mode)" + select USB_GADGET_DUALSPEED + help + The Renesas Rcar USB 2.0 high-speed gadget controller + integrated into Salvator and Kingfisher boards. Select this + option if you want the driver to operate in Peripheral mode. + This option requires USB_GADGET to be enabled. + if USB_GADGET_DWC2_OTG
config USB_GADGET_DWC2_OTG_PHY diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 6abcce0d9c7..da76b6524de 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -21,6 +21,7 @@ obj-$(CONFIG_USB_GADGET_BCM_UDC_OTG_PHY) += bcm_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_DWC2_OTG) += dwc2_udc_otg.o obj-$(CONFIG_USB_GADGET_DWC2_OTG_PHY) += dwc2_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_MAX3420) += max3420_udc.o +obj-$(CONFIG_USB_RENESAS_USBHS) += rcar/ ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o diff --git a/drivers/usb/gadget/rcar/Makefile b/drivers/usb/gadget/rcar/Makefile new file mode 100644 index 00000000000..676f39c8e24 --- /dev/null +++ b/drivers/usb/gadget/rcar/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-$(CONFIG_USB_RENESAS_USBHS) += \ + common.o \ + fifo.o \ + mod.o \ + mod_gadget.o \ + pipe.o diff --git a/drivers/usb/gadget/rcar/common.c b/drivers/usb/gadget/rcar/common.c new file mode 100644 index 00000000000..2ba022a3f2c --- /dev/null +++ b/drivers/usb/gadget/rcar/common.c @@ -0,0 +1,478 @@ +// SPDX-License-Identifier: GPL-1.0+ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Copyright (C) 2019 Renesas Electronics Corporation + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ + +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <errno.h> +#include <generic-phy.h> +#include <linux/err.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <usb.h> + +#include "common.h" + +/* + * image of renesas_usbhs + * + * ex) gadget case + + * mod.c + * mod_gadget.c + * mod_host.c pipe.c fifo.c + * + * +-------+ +-----------+ + * | pipe0 |------>| fifo pio | + * +------------+ +-------+ +-----------+ + * | mod_gadget |=====> | pipe1 |--+ + * +------------+ +-------+ | +-----------+ + * | pipe2 | | +-| fifo dma0 | + * +------------+ +-------+ | | +-----------+ + * | mod_host | | pipe3 |<-|--+ + * +------------+ +-------+ | +-----------+ + * | .... | +--->| fifo dma1 | + * | .... | +-----------+ + */ + +/* + * common functions + */ +u16 usbhs_read(struct usbhs_priv *priv, u32 reg) +{ + return ioread16(priv->base + reg); +} + +void usbhs_write(struct usbhs_priv *priv, u32 reg, u16 data) +{ + iowrite16(data, priv->base + reg); +} + +void usbhs_bset(struct usbhs_priv *priv, u32 reg, u16 mask, u16 data) +{ + u16 val = usbhs_read(priv, reg); + + val &= ~mask; + val |= data & mask; + + usbhs_write(priv, reg, val); +} + +/* + * syscfg functions + */ +static void usbhs_sys_clock_ctrl(struct usbhs_priv *priv, int enable) +{ + usbhs_bset(priv, SYSCFG, SCKE, enable ? SCKE : 0); +} + +void usbhs_sys_host_ctrl(struct usbhs_priv *priv, int enable) +{ + u16 mask = DCFM | DRPD | DPRPU | HSE | USBE; + u16 val = DCFM | DRPD | HSE | USBE; + + /* + * if enable + * + * - select Host mode + * - D+ Line/D- Line Pull-down + */ + usbhs_bset(priv, SYSCFG, mask, enable ? val : 0); +} + +void usbhs_sys_function_ctrl(struct usbhs_priv *priv, int enable) +{ + u16 mask = DCFM | DRPD | DPRPU | HSE | USBE; + u16 val = HSE | USBE; + + /* + * if enable + * + * - select Function mode + * - D+ Line Pull-up is disabled + * When D+ Line Pull-up is enabled, + * calling usbhs_sys_function_pullup(,1) + */ + usbhs_bset(priv, SYSCFG, mask, enable ? val : 0); +} + +void usbhs_sys_function_pullup(struct usbhs_priv *priv, int enable) +{ + usbhs_bset(priv, SYSCFG, DPRPU, enable ? DPRPU : 0); +} + +void usbhs_sys_set_test_mode(struct usbhs_priv *priv, u16 mode) +{ + usbhs_write(priv, TESTMODE, mode); +} + +/* + * frame functions + */ +int usbhs_frame_get_num(struct usbhs_priv *priv) +{ + return usbhs_read(priv, FRMNUM) & FRNM_MASK; +} + +/* + * usb request functions + */ +void usbhs_usbreq_get_val(struct usbhs_priv *priv, struct usb_ctrlrequest *req) +{ + u16 val; + + val = usbhs_read(priv, USBREQ); + req->bRequest = (val >> 8) & 0xFF; + req->bRequestType = (val >> 0) & 0xFF; + + req->wValue = cpu_to_le16(usbhs_read(priv, USBVAL)); + req->wIndex = cpu_to_le16(usbhs_read(priv, USBINDX)); + req->wLength = cpu_to_le16(usbhs_read(priv, USBLENG)); +} + +void usbhs_usbreq_set_val(struct usbhs_priv *priv, struct usb_ctrlrequest *req) +{ + usbhs_write(priv, USBREQ, (req->bRequest << 8) | req->bRequestType); + usbhs_write(priv, USBVAL, le16_to_cpu(req->wValue)); + usbhs_write(priv, USBINDX, le16_to_cpu(req->wIndex)); + usbhs_write(priv, USBLENG, le16_to_cpu(req->wLength)); + + usbhs_bset(priv, DCPCTR, SUREQ, SUREQ); +} + +/* + * bus/vbus functions + */ +void usbhs_bus_send_sof_enable(struct usbhs_priv *priv) +{ + u16 status = usbhs_read(priv, DVSTCTR) & (USBRST | UACT); + + if (status != USBRST) { + struct device *dev = usbhs_priv_to_dev(priv); + dev_err(dev, "usbhs should be reset\n"); + } + + usbhs_bset(priv, DVSTCTR, (USBRST | UACT), UACT); +} + +void usbhs_bus_send_reset(struct usbhs_priv *priv) +{ + usbhs_bset(priv, DVSTCTR, (USBRST | UACT), USBRST); +} + +int usbhs_bus_get_speed(struct usbhs_priv *priv) +{ + u16 dvstctr = usbhs_read(priv, DVSTCTR); + + switch (RHST & dvstctr) { + case RHST_LOW_SPEED: + return USB_SPEED_LOW; + case RHST_FULL_SPEED: + return USB_SPEED_FULL; + case RHST_HIGH_SPEED: + return USB_SPEED_HIGH; + } + + return USB_SPEED_UNKNOWN; +} + +static void usbhsc_bus_init(struct usbhs_priv *priv) +{ + usbhs_write(priv, DVSTCTR, 0); +} + +/* + * device configuration + */ +int usbhs_set_device_config(struct usbhs_priv *priv, int devnum, + u16 upphub, u16 hubport, u16 speed) +{ + struct device *dev = usbhs_priv_to_dev(priv); + u16 usbspd = 0; + u32 reg = DEVADD0 + (2 * devnum); + + if (devnum > 10) { + dev_err(dev, "cannot set speed to unknown device %d\n", devnum); + return -EIO; + } + + if (upphub > 0xA) { + dev_err(dev, "unsupported hub number %d\n", upphub); + return -EIO; + } + + switch (speed) { + case USB_SPEED_LOW: + usbspd = USBSPD_SPEED_LOW; + break; + case USB_SPEED_FULL: + usbspd = USBSPD_SPEED_FULL; + break; + case USB_SPEED_HIGH: + usbspd = USBSPD_SPEED_HIGH; + break; + default: + dev_err(dev, "unsupported speed %d\n", speed); + return -EIO; + } + + usbhs_write(priv, reg, UPPHUB(upphub) | + HUBPORT(hubport)| + USBSPD(usbspd)); + + return 0; +} + +/* + * interrupt functions + */ +void usbhs_xxxsts_clear(struct usbhs_priv *priv, u16 sts_reg, u16 bit) +{ + u16 pipe_mask = (u16)GENMASK(usbhs_get_dparam(priv, pipe_size), 0); + + usbhs_write(priv, sts_reg, ~(1 << bit) & pipe_mask); +} + +/* + * local functions + */ +static void usbhsc_set_buswait(struct usbhs_priv *priv) +{ + int wait = usbhs_get_dparam(priv, buswait_bwait); + + /* set bus wait if platform have */ + if (wait) + usbhs_bset(priv, BUSWAIT, 0x000F, wait); +} + +/* + * platform default param + */ + +/* commonly used on newer SH-Mobile and R-Car SoCs */ +static struct renesas_usbhs_driver_pipe_config usbhsc_new_pipe[] = { + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_CONTROL, 64, 0x00, false), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_ISOC, 1024, 0x08, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_ISOC, 1024, 0x28, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x48, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x58, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x68, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_INT, 64, 0x04, false), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_INT, 64, 0x05, false), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_INT, 64, 0x06, false), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x78, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x88, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x98, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0xa8, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0xb8, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0xc8, true), + RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0xd8, true), +}; + +#define LPSTS 0x102 +#define LPSTS_SUSPM BIT(14) + +#define UGCTRL2 0x184 +#define UGCTRL2_RESERVED_3 BIT(0) +#define UGCTRL2_USB0SEL_EHCI 0x10 +#define UGCTRL2_USB0SEL_HSUSB 0x20 +#define UGCTRL2_USB0SEL_OTG 0x30 +#define UGCTRL2_USB0SEL_MASK 0x30 +#define UGCTRL2_VBUSSEL BIT(10) + +struct usbhs_priv_otg_data { + void __iomem *base; + void __iomem *phybase; + + struct platform_device usbhs_dev; + struct usbhs_priv usbhs_priv; + + struct phy phy; +}; + +static int usbhs_rcar3_power_ctrl(struct usbhs_priv *priv, bool enable) +{ + if (enable) { + writel(UGCTRL2_USB0SEL_OTG | UGCTRL2_VBUSSEL | UGCTRL2_RESERVED_3, + priv->base + UGCTRL2); + + usbhs_bset(priv, LPSTS, LPSTS_SUSPM, LPSTS_SUSPM); + /* The controller on R-Car Gen3 needs to wait up to 90 usec */ + udelay(90); + + usbhs_sys_clock_ctrl(priv, enable); + } else { + usbhs_sys_clock_ctrl(priv, enable); + + usbhs_bset(priv, LPSTS, LPSTS_SUSPM, 0); + } + + return 0; +} + +void usbhsc_hotplug(struct usbhs_priv *priv) +{ + int ret; + + ret = usbhs_mod_change(priv, USBHS_GADGET); + if (ret < 0) + return; + + usbhs_rcar3_power_ctrl(priv, true); + + /* bus init */ + usbhsc_set_buswait(priv); + usbhsc_bus_init(priv); + + /* module start */ + usbhs_mod_call(priv, start, priv); +} + +#define USB2_OBINTSTA 0x604 +#define USB2_OBINT_SESSVLDCHG BIT(12) +#define USB2_OBINT_IDDIGCHG BIT(11) + +static int usbhs_udc_otg_gadget_handle_interrupts(struct udevice *dev) +{ + struct usbhs_priv_otg_data *priv = dev_get_priv(dev); + const u32 status = readl(priv->phybase + USB2_OBINTSTA); + + /* We don't have a good way to forward IRQ to PHY yet */ + if (status & (USB2_OBINT_SESSVLDCHG | USB2_OBINT_IDDIGCHG)) { + writel(USB2_OBINT_SESSVLDCHG | USB2_OBINT_IDDIGCHG, + priv->phybase + USB2_OBINTSTA); + generic_phy_set_mode(&priv->phy, PHY_MODE_USB_OTG, 0); + } + + usbhs_interrupt(0, &priv->usbhs_priv); + + return 0; +} + +static int usbhs_probe(struct usbhs_priv *priv) +{ + int ret; + + priv->dparam.type = USBHS_TYPE_RCAR_GEN3; + priv->dparam.pio_dma_border = 64; + priv->dparam.pipe_configs = usbhsc_new_pipe; + priv->dparam.pipe_size = ARRAY_SIZE(usbhsc_new_pipe); + + /* call pipe and module init */ + ret = usbhs_pipe_probe(priv); + if (ret < 0) + return ret; + + ret = usbhs_fifo_probe(priv); + if (ret < 0) + goto probe_end_pipe_exit; + + ret = usbhs_mod_probe(priv); + if (ret < 0) + goto probe_end_fifo_exit; + + usbhs_sys_clock_ctrl(priv, 0); + + usbhs_rcar3_power_ctrl(priv, true); + usbhs_mod_autonomy_mode(priv); + usbhsc_hotplug(priv); + + return ret; + +probe_end_fifo_exit: + usbhs_fifo_remove(priv); +probe_end_pipe_exit: + usbhs_pipe_remove(priv); + return ret; +} + +static int usbhs_udc_otg_probe(struct udevice *dev) +{ + struct usbhs_priv_otg_data *priv = dev_get_priv(dev); + struct usb_gadget *gadget; + struct clk_bulk clk_bulk; + int ret = -EINVAL; + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -EINVAL; + + ret = clk_get_bulk(dev, &clk_bulk); + if (ret) + return ret; + + ret = clk_enable_bulk(&clk_bulk); + if (ret) + return ret; + + clrsetbits_le32(priv->base + UGCTRL2, UGCTRL2_USB0SEL_MASK, UGCTRL2_USB0SEL_EHCI); + clrsetbits_le16(priv->base + LPSTS, LPSTS_SUSPM, LPSTS_SUSPM); + + ret = generic_setup_phy(dev, &priv->phy, 0, PHY_MODE_USB_OTG, 1); + if (ret) + goto err_clk; + + priv->phybase = dev_read_addr_ptr(priv->phy.dev); + + priv->usbhs_priv.pdev = &priv->usbhs_dev; + priv->usbhs_priv.base = priv->base; + priv->usbhs_dev.dev.driver_data = &priv->usbhs_priv; + ret = usbhs_probe(&priv->usbhs_priv); + if (ret < 0) + goto err_phy; + + gadget = usbhsg_get_gadget(&priv->usbhs_priv); + gadget->is_dualspeed = 1; + gadget->is_otg = 0; + gadget->is_a_peripheral = 0; + gadget->b_hnp_enable = 0; + gadget->a_hnp_support = 0; + gadget->a_alt_hnp_support = 0; + + return usb_add_gadget_udc((struct device *)dev, gadget); + +err_phy: + generic_shutdown_phy(&priv->phy); +err_clk: + clk_disable_bulk(&clk_bulk); + return ret; +} + +static int usbhs_udc_otg_remove(struct udevice *dev) +{ + struct usbhs_priv_otg_data *priv = dev_get_priv(dev); + + usbhs_rcar3_power_ctrl(&priv->usbhs_priv, false); + usbhs_mod_remove(&priv->usbhs_priv); + usbhs_fifo_remove(&priv->usbhs_priv); + usbhs_pipe_remove(&priv->usbhs_priv); + + generic_shutdown_phy(&priv->phy); + + return dm_scan_fdt_dev(dev); +} + +static const struct udevice_id usbhs_udc_otg_ids[] = { + { .compatible = "renesas,rcar-gen3-usbhs" }, + {}, +}; + +static const struct usb_gadget_generic_ops usbhs_udc_otg_ops = { + .handle_interrupts = usbhs_udc_otg_gadget_handle_interrupts, +}; + +U_BOOT_DRIVER(usbhs_udc_otg) = { + .name = "usbhs-udc-otg", + .id = UCLASS_USB_GADGET_GENERIC, + .ops = &usbhs_udc_otg_ops, + .of_match = usbhs_udc_otg_ids, + .probe = usbhs_udc_otg_probe, + .remove = usbhs_udc_otg_remove, + .priv_auto = sizeof(struct usbhs_priv_otg_data), +}; diff --git a/drivers/usb/gadget/rcar/common.h b/drivers/usb/gadget/rcar/common.h new file mode 100644 index 00000000000..544cfd77cdf --- /dev/null +++ b/drivers/usb/gadget/rcar/common.h @@ -0,0 +1,328 @@ +/* SPDX-License-Identifier: GPL-1.0+ */ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Copyright (C) 2019 Renesas Electronics Corporation + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ +#ifndef RENESAS_USB_DRIVER_H +#define RENESAS_USB_DRIVER_H + +#include <dm/device.h> +#include <dm/device_compat.h> +#include <linux/bug.h> +#include <linux/delay.h> +#include <linux/io.h> +#include "renesas_usb.h" + +struct usbhs_priv; + +#include "mod.h" +#include "pipe.h" + +/* + * + * register define + * + */ +#define SYSCFG 0x0000 +#define BUSWAIT 0x0002 +#define DVSTCTR 0x0008 +#define TESTMODE 0x000C +#define CFIFO 0x0014 +#define CFIFOSEL 0x0020 +#define CFIFOCTR 0x0022 +#define D0FIFO 0x0100 +#define D0FIFOSEL 0x0028 +#define D0FIFOCTR 0x002A +#define D1FIFO 0x0120 +#define D1FIFOSEL 0x002C +#define D1FIFOCTR 0x002E +#define INTENB0 0x0030 +#define INTENB1 0x0032 +#define BRDYENB 0x0036 +#define NRDYENB 0x0038 +#define BEMPENB 0x003A +#define INTSTS0 0x0040 +#define INTSTS1 0x0042 +#define BRDYSTS 0x0046 +#define NRDYSTS 0x0048 +#define BEMPSTS 0x004A +#define FRMNUM 0x004C +#define USBREQ 0x0054 /* USB request type register */ +#define USBVAL 0x0056 /* USB request value register */ +#define USBINDX 0x0058 /* USB request index register */ +#define USBLENG 0x005A /* USB request length register */ +#define DCPCFG 0x005C +#define DCPMAXP 0x005E +#define DCPCTR 0x0060 +#define PIPESEL 0x0064 +#define PIPECFG 0x0068 +#define PIPEBUF 0x006A +#define PIPEMAXP 0x006C +#define PIPEPERI 0x006E +#define PIPEnCTR 0x0070 +#define PIPE1TRE 0x0090 +#define PIPE1TRN 0x0092 +#define PIPE2TRE 0x0094 +#define PIPE2TRN 0x0096 +#define PIPE3TRE 0x0098 +#define PIPE3TRN 0x009A +#define PIPE4TRE 0x009C +#define PIPE4TRN 0x009E +#define PIPE5TRE 0x00A0 +#define PIPE5TRN 0x00A2 +#define PIPEBTRE 0x00A4 +#define PIPEBTRN 0x00A6 +#define PIPECTRE 0x00A8 +#define PIPECTRN 0x00AA +#define PIPEDTRE 0x00AC +#define PIPEDTRN 0x00AE +#define PIPEETRE 0x00B0 +#define PIPEETRN 0x00B2 +#define PIPEFTRE 0x00B4 +#define PIPEFTRN 0x00B6 +#define PIPE9TRE 0x00B8 +#define PIPE9TRN 0x00BA +#define PIPEATRE 0x00BC +#define PIPEATRN 0x00BE +#define DEVADD0 0x00D0 /* Device address n configuration */ +#define DEVADD1 0x00D2 +#define DEVADD2 0x00D4 +#define DEVADD3 0x00D6 +#define DEVADD4 0x00D8 +#define DEVADD5 0x00DA +#define DEVADD6 0x00DC +#define DEVADD7 0x00DE +#define DEVADD8 0x00E0 +#define DEVADD9 0x00E2 +#define DEVADDA 0x00E4 +#define D2FIFOSEL 0x00F0 /* for R-Car Gen2 */ +#define D2FIFOCTR 0x00F2 /* for R-Car Gen2 */ +#define D3FIFOSEL 0x00F4 /* for R-Car Gen2 */ +#define D3FIFOCTR 0x00F6 /* for R-Car Gen2 */ +#define SUSPMODE 0x0102 /* for RZ/A */ + +/* SYSCFG */ +#define SCKE (1 << 10) /* USB Module Clock Enable */ +#define CNEN (1 << 8) /* Single-ended receiver operation Enable */ +#define HSE (1 << 7) /* High-Speed Operation Enable */ +#define DCFM (1 << 6) /* Controller Function Select */ +#define DRPD (1 << 5) /* D+ Line/D- Line Resistance Control */ +#define DPRPU (1 << 4) /* D+ Line Resistance Control */ +#define USBE (1 << 0) /* USB Module Operation Enable */ +#define UCKSEL (1 << 2) /* Clock Select for RZ/A1 */ +#define UPLLE (1 << 1) /* USB PLL Enable for RZ/A1 */ + +/* DVSTCTR */ +#define EXTLP (1 << 10) /* Controls the EXTLP pin output state */ +#define PWEN (1 << 9) /* Controls the PWEN pin output state */ +#define USBRST (1 << 6) /* Bus Reset Output */ +#define UACT (1 << 4) /* USB Bus Enable */ +#define RHST (0x7) /* Reset Handshake */ +#define RHST_LOW_SPEED 1 /* Low-speed connection */ +#define RHST_FULL_SPEED 2 /* Full-speed connection */ +#define RHST_HIGH_SPEED 3 /* High-speed connection */ + +/* CFIFOSEL */ +#define DREQE (1 << 12) /* DMA Transfer Request Enable */ +#define MBW_32 (0x2 << 10) /* CFIFO Port Access Bit Width */ + +/* CFIFOCTR */ +#define BVAL (1 << 15) /* Buffer Memory Enable Flag */ +#define BCLR (1 << 14) /* CPU buffer clear */ +#define FRDY (1 << 13) /* FIFO Port Ready */ +#define DTLN_MASK (0x0FFF) /* Receive Data Length */ + +/* INTENB0 */ +#define VBSE (1 << 15) /* Enable IRQ VBUS_0 and VBUSIN_0 */ +#define RSME (1 << 14) /* Enable IRQ Resume */ +#define SOFE (1 << 13) /* Enable IRQ Frame Number Update */ +#define DVSE (1 << 12) /* Enable IRQ Device State Transition */ +#define CTRE (1 << 11) /* Enable IRQ Control Stage Transition */ +#define BEMPE (1 << 10) /* Enable IRQ Buffer Empty */ +#define NRDYE (1 << 9) /* Enable IRQ Buffer Not Ready Response */ +#define BRDYE (1 << 8) /* Enable IRQ Buffer Ready */ + +/* INTENB1 */ +#define BCHGE (1 << 14) /* USB Bus Change Interrupt Enable */ +#define DTCHE (1 << 12) /* Disconnection Detect Interrupt Enable */ +#define ATTCHE (1 << 11) /* Connection Detect Interrupt Enable */ +#define EOFERRE (1 << 6) /* EOF Error Detect Interrupt Enable */ +#define SIGNE (1 << 5) /* Setup Transaction Error Interrupt Enable */ +#define SACKE (1 << 4) /* Setup Transaction ACK Interrupt Enable */ + +/* INTSTS0 */ +#define VBINT (1 << 15) /* VBUS0_0 and VBUS1_0 Interrupt Status */ +#define DVST (1 << 12) /* Device State Transition Interrupt Status */ +#define CTRT (1 << 11) /* Control Stage Interrupt Status */ +#define BEMP (1 << 10) /* Buffer Empty Interrupt Status */ +#define BRDY (1 << 8) /* Buffer Ready Interrupt Status */ +#define VBSTS (1 << 7) /* VBUS_0 and VBUSIN_0 Input Status */ +#define VALID (1 << 3) /* USB Request Receive */ + +#define DVSQ_MASK (0x7 << 4) /* Device State */ +#define POWER_STATE (0 << 4) +#define DEFAULT_STATE (1 << 4) +#define ADDRESS_STATE (2 << 4) +#define CONFIGURATION_STATE (3 << 4) +#define SUSPENDED_STATE (4 << 4) + +#define CTSQ_MASK (0x7) /* Control Transfer Stage */ +#define IDLE_SETUP_STAGE 0 /* Idle stage or setup stage */ +#define READ_DATA_STAGE 1 /* Control read data stage */ +#define READ_STATUS_STAGE 2 /* Control read status stage */ +#define WRITE_DATA_STAGE 3 /* Control write data stage */ +#define WRITE_STATUS_STAGE 4 /* Control write status stage */ +#define NODATA_STATUS_STAGE 5 /* Control write NoData status stage */ +#define SEQUENCE_ERROR 6 /* Control transfer sequence error */ + +/* INTSTS1 */ +#define OVRCR (1 << 15) /* OVRCR Interrupt Status */ +#define BCHG (1 << 14) /* USB Bus Change Interrupt Status */ +#define DTCH (1 << 12) /* USB Disconnection Detect Interrupt Status */ +#define ATTCH (1 << 11) /* ATTCH Interrupt Status */ +#define EOFERR (1 << 6) /* EOF Error Detect Interrupt Status */ +#define SIGN (1 << 5) /* Setup Transaction Error Interrupt Status */ +#define SACK (1 << 4) /* Setup Transaction ACK Response Interrupt Status */ + +/* PIPECFG */ +/* DCPCFG */ +#define TYPE_NONE (0 << 14) /* Transfer Type */ +#define TYPE_BULK (1 << 14) +#define TYPE_INT (2 << 14) +#define TYPE_ISO (3 << 14) +#define BFRE (1 << 10) /* BRDY Interrupt Operation Spec. */ +#define DBLB (1 << 9) /* Double Buffer Mode */ +#define SHTNAK (1 << 7) /* Pipe Disable in Transfer End */ +#define DIR_OUT (1 << 4) /* Transfer Direction */ + +/* PIPEMAXP */ +/* DCPMAXP */ +#define DEVSEL_MASK (0xF << 12) /* Device Select */ +#define DCP_MAXP_MASK (0x7F) +#define PIPE_MAXP_MASK (0x7FF) + +/* PIPEBUF */ +#define BUFSIZE_SHIFT 10 +#define BUFSIZE_MASK (0x1F << BUFSIZE_SHIFT) +#define BUFNMB_MASK (0xFF) + +/* PIPEnCTR */ +/* DCPCTR */ +#define BSTS (1 << 15) /* Buffer Status */ +#define SUREQ (1 << 14) /* Sending SETUP Token */ +#define INBUFM (1 << 14) /* (PIPEnCTR) Transfer Buffer Monitor */ +#define CSSTS (1 << 12) /* CSSTS Status */ +#define ACLRM (1 << 9) /* Buffer Auto-Clear Mode */ +#define SQCLR (1 << 8) /* Toggle Bit Clear */ +#define SQSET (1 << 7) /* Toggle Bit Set */ +#define SQMON (1 << 6) /* Toggle Bit Check */ +#define PBUSY (1 << 5) /* Pipe Busy */ +#define PID_MASK (0x3) /* Response PID */ +#define PID_NAK 0 +#define PID_BUF 1 +#define PID_STALL10 2 +#define PID_STALL11 3 + +#define CCPL (1 << 2) /* Control Transfer End Enable */ + +/* PIPEnTRE */ +#define TRENB (1 << 9) /* Transaction Counter Enable */ +#define TRCLR (1 << 8) /* Transaction Counter Clear */ + +/* FRMNUM */ +#define FRNM_MASK (0x7FF) + +/* DEVADDn */ +#define UPPHUB(x) (((x) & 0xF) << 11) /* HUB Register */ +#define HUBPORT(x) (((x) & 0x7) << 8) /* HUB Port for Target Device */ +#define USBSPD(x) (((x) & 0x3) << 6) /* Device Transfer Rate */ +#define USBSPD_SPEED_LOW 0x1 +#define USBSPD_SPEED_FULL 0x2 +#define USBSPD_SPEED_HIGH 0x3 + +/* SUSPMODE */ +#define SUSPM (1 << 14) /* SuspendM Control */ + +/* + * struct + */ +struct usbhs_priv { + void __iomem *base; + struct renesas_usbhs_driver_param dparam; + struct platform_device *pdev; + + /* + * module control + */ + struct usbhs_mod_info mod_info; + + /* + * pipe control + */ + struct usbhs_pipe_info pipe_info; + + /* + * fifo control + */ + struct usbhs_fifo_info fifo_info; +}; + +/* + * common + */ +u16 usbhs_read(struct usbhs_priv *priv, u32 reg); +void usbhs_write(struct usbhs_priv *priv, u32 reg, u16 data); +void usbhs_bset(struct usbhs_priv *priv, u32 reg, u16 mask, u16 data); + +#define usbhs_lock(p, f) spin_lock_irqsave(usbhs_priv_to_lock(p), f) +#define usbhs_unlock(p, f) spin_unlock_irqrestore(usbhs_priv_to_lock(p), f) + +/* + * sysconfig + */ +void usbhs_sys_host_ctrl(struct usbhs_priv *priv, int enable); +void usbhs_sys_function_ctrl(struct usbhs_priv *priv, int enable); +void usbhs_sys_function_pullup(struct usbhs_priv *priv, int enable); +void usbhs_sys_set_test_mode(struct usbhs_priv *priv, u16 mode); + +/* + * usb request + */ +void usbhs_usbreq_get_val(struct usbhs_priv *priv, struct usb_ctrlrequest *req); +void usbhs_usbreq_set_val(struct usbhs_priv *priv, struct usb_ctrlrequest *req); + +/* + * bus + */ +void usbhs_bus_send_sof_enable(struct usbhs_priv *priv); +void usbhs_bus_send_reset(struct usbhs_priv *priv); +int usbhs_bus_get_speed(struct usbhs_priv *priv); +int usbhs_vbus_ctrl(struct usbhs_priv *priv, int enable); +void usbhsc_hotplug(struct usbhs_priv *priv); + +/* + * frame + */ +int usbhs_frame_get_num(struct usbhs_priv *priv); + +/* + * device config + */ +int usbhs_set_device_config(struct usbhs_priv *priv, int devnum, u16 upphub, + u16 hubport, u16 speed); + +/* + * interrupt functions + */ +void usbhs_xxxsts_clear(struct usbhs_priv *priv, u16 sts_reg, u16 bit); + +/* + * data + */ +#define usbhs_get_dparam(priv, param) (priv->dparam.param) +#define usbhs_priv_to_dev(priv) (&priv->pdev->dev) + +#endif /* RENESAS_USB_DRIVER_H */ diff --git a/drivers/usb/gadget/rcar/fifo.c b/drivers/usb/gadget/rcar/fifo.c new file mode 100644 index 00000000000..6016b2987d5 --- /dev/null +++ b/drivers/usb/gadget/rcar/fifo.c @@ -0,0 +1,1067 @@ +// SPDX-License-Identifier: GPL-1.0+ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Copyright (C) 2019 Renesas Electronics Corporation + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ +#include <linux/delay.h> +#include <linux/io.h> +#include "common.h" +#include "pipe.h" + +#define usbhsf_get_cfifo(p) (&((p)->fifo_info.cfifo)) + +#define usbhsf_fifo_is_busy(f) ((f)->pipe) /* see usbhs_pipe_select_fifo */ + +/* + * packet initialize + */ +void usbhs_pkt_init(struct usbhs_pkt *pkt) +{ + INIT_LIST_HEAD(&pkt->node); +} + +/* + * packet control function + */ +static int usbhsf_null_handle(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pkt->pipe); + struct device *dev = usbhs_priv_to_dev(priv); + + dev_err(dev, "null handler\n"); + + return -EINVAL; +} + +static const struct usbhs_pkt_handle usbhsf_null_handler = { + .prepare = usbhsf_null_handle, + .try_run = usbhsf_null_handle, +}; + +void usbhs_pkt_push(struct usbhs_pipe *pipe, struct usbhs_pkt *pkt, + void (*done)(struct usbhs_priv *priv, + struct usbhs_pkt *pkt), + void *buf, int len, int zero, int sequence) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct device *dev = usbhs_priv_to_dev(priv); + unsigned long flags; + + if (!done) { + dev_err(dev, "no done function\n"); + return; + } + + /******************** spin lock ********************/ + usbhs_lock(priv, flags); + + if (!pipe->handler) { + dev_err(dev, "no handler function\n"); + pipe->handler = &usbhsf_null_handler; + } + + list_move_tail(&pkt->node, &pipe->list); + + /* + * each pkt must hold own handler. + * because handler might be changed by its situation. + * dma handler -> pio handler. + */ + pkt->pipe = pipe; + pkt->buf = buf; + pkt->handler = pipe->handler; + pkt->length = len; + pkt->zero = zero; + pkt->actual = 0; + pkt->done = done; + pkt->sequence = sequence; + + usbhs_unlock(priv, flags); + /******************** spin unlock ******************/ +} + +static void __usbhsf_pkt_del(struct usbhs_pkt *pkt) +{ + list_del_init(&pkt->node); +} + +struct usbhs_pkt *__usbhsf_pkt_get(struct usbhs_pipe *pipe) +{ + return list_first_entry_or_null(&pipe->list, struct usbhs_pkt, node); +} + +static void usbhsf_fifo_unselect(struct usbhs_pipe *pipe, + struct usbhs_fifo *fifo); +static struct dma_chan *usbhsf_dma_chan_get(struct usbhs_fifo *fifo, + struct usbhs_pkt *pkt); +#define usbhsf_dma_map(p) __usbhsf_dma_map_ctrl(p, 1) +#define usbhsf_dma_unmap(p) __usbhsf_dma_map_ctrl(p, 0) +static int __usbhsf_dma_map_ctrl(struct usbhs_pkt *pkt, int map); +static void usbhsf_tx_irq_ctrl(struct usbhs_pipe *pipe, int enable); +static void usbhsf_rx_irq_ctrl(struct usbhs_pipe *pipe, int enable); +struct usbhs_pkt *usbhs_pkt_pop(struct usbhs_pipe *pipe, struct usbhs_pkt *pkt) +{ + struct usbhs_fifo *fifo = usbhs_pipe_to_fifo(pipe); + unsigned long flags; + + /******************** spin lock ********************/ + usbhs_lock(priv, flags); + + usbhs_pipe_disable(pipe); + + if (!pkt) + pkt = __usbhsf_pkt_get(pipe); + + if (pkt) { + struct dma_chan *chan = NULL; + + if (fifo) + chan = usbhsf_dma_chan_get(fifo, pkt); + if (chan) + usbhsf_dma_unmap(pkt); + + usbhs_pipe_clear_without_sequence(pipe, 0, 0); + usbhs_pipe_running(pipe, 0); + + __usbhsf_pkt_del(pkt); + } + + if (fifo) + usbhsf_fifo_unselect(pipe, fifo); + + usbhs_unlock(priv, flags); + /******************** spin unlock ******************/ + + return pkt; +} + +enum { + USBHSF_PKT_PREPARE, + USBHSF_PKT_TRY_RUN, + USBHSF_PKT_DMA_DONE, +}; + +static int usbhsf_pkt_handler(struct usbhs_pipe *pipe, int type) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct usbhs_pkt *pkt; + struct device *dev = usbhs_priv_to_dev(priv); + int (*func)(struct usbhs_pkt *pkt, int *is_done); + unsigned long flags; + int ret = 0; + int is_done = 0; + + /******************** spin lock ********************/ + usbhs_lock(priv, flags); + + pkt = __usbhsf_pkt_get(pipe); + if (!pkt) { + ret = -EINVAL; + goto __usbhs_pkt_handler_end; + } + + switch (type) { + case USBHSF_PKT_PREPARE: + func = pkt->handler->prepare; + break; + case USBHSF_PKT_TRY_RUN: + func = pkt->handler->try_run; + break; + case USBHSF_PKT_DMA_DONE: + func = pkt->handler->dma_done; + break; + default: + dev_err(dev, "unknown pkt handler\n"); + goto __usbhs_pkt_handler_end; + } + + if (likely(func)) + ret = func(pkt, &is_done); + + if (is_done) + __usbhsf_pkt_del(pkt); + +__usbhs_pkt_handler_end: + usbhs_unlock(priv, flags); + /******************** spin unlock ******************/ + + if (is_done) { + pkt->done(priv, pkt); + usbhs_pkt_start(pipe); + } + + return ret; +} + +void usbhs_pkt_start(struct usbhs_pipe *pipe) +{ + usbhsf_pkt_handler(pipe, USBHSF_PKT_PREPARE); +} + +/* + * irq enable/disable function + */ +#define usbhsf_irq_empty_ctrl(p, e) usbhsf_irq_callback_ctrl(p, irq_bempsts, e) +#define usbhsf_irq_ready_ctrl(p, e) usbhsf_irq_callback_ctrl(p, irq_brdysts, e) +#define usbhsf_irq_callback_ctrl(pipe, status, enable) \ + ({ \ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); \ + struct usbhs_mod *mod = usbhs_mod_get_current(priv); \ + u16 status = (1 << usbhs_pipe_number(pipe)); \ + if (!mod) \ + return; \ + if (enable) \ + mod->status |= status; \ + else \ + mod->status &= ~status; \ + usbhs_irq_callback_update(priv, mod); \ + }) + +static void usbhsf_tx_irq_ctrl(struct usbhs_pipe *pipe, int enable) +{ + /* + * And DCP pipe can NOT use "ready interrupt" for "send" + * it should use "empty" interrupt. + * see + * "Operation" - "Interrupt Function" - "BRDY Interrupt" + * + * on the other hand, normal pipe can use "ready interrupt" for "send" + * even though it is single/double buffer + */ + if (usbhs_pipe_is_dcp(pipe)) + usbhsf_irq_empty_ctrl(pipe, enable); + else + usbhsf_irq_ready_ctrl(pipe, enable); +} + +static void usbhsf_rx_irq_ctrl(struct usbhs_pipe *pipe, int enable) +{ + usbhsf_irq_ready_ctrl(pipe, enable); +} + +/* + * FIFO ctrl + */ +static void usbhsf_send_terminator(struct usbhs_pipe *pipe, + struct usbhs_fifo *fifo) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + + usbhs_bset(priv, fifo->ctr, BVAL, BVAL); +} + +static int usbhsf_fifo_barrier(struct usbhs_priv *priv, + struct usbhs_fifo *fifo) +{ + /* The FIFO port is accessible */ + if (usbhs_read(priv, fifo->ctr) & FRDY) + return 0; + + return -EBUSY; +} + +static void usbhsf_fifo_clear(struct usbhs_pipe *pipe, + struct usbhs_fifo *fifo) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + int ret = 0; + + if (!usbhs_pipe_is_dcp(pipe)) { + /* + * This driver checks the pipe condition first to avoid -EBUSY + * from usbhsf_fifo_barrier() if the pipe is RX direction and + * empty. + */ + if (usbhs_pipe_is_dir_in(pipe)) + ret = usbhs_pipe_is_accessible(pipe); + if (!ret) + ret = usbhsf_fifo_barrier(priv, fifo); + } + + /* + * if non-DCP pipe, this driver should set BCLR when + * usbhsf_fifo_barrier() returns 0. + */ + if (!ret) + usbhs_write(priv, fifo->ctr, BCLR); +} + +static int usbhsf_fifo_rcv_len(struct usbhs_priv *priv, + struct usbhs_fifo *fifo) +{ + return usbhs_read(priv, fifo->ctr) & DTLN_MASK; +} + +static void usbhsf_fifo_unselect(struct usbhs_pipe *pipe, + struct usbhs_fifo *fifo) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + + usbhs_pipe_select_fifo(pipe, NULL); + usbhs_write(priv, fifo->sel, 0); +} + +static int usbhsf_fifo_select(struct usbhs_pipe *pipe, + struct usbhs_fifo *fifo, + int write) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct device *dev = usbhs_priv_to_dev(priv); + int timeout = 1024; + u16 mask = ((1 << 5) | 0xF); /* mask of ISEL | CURPIPE */ + u16 base = usbhs_pipe_number(pipe); /* CURPIPE */ + + if (usbhs_pipe_is_busy(pipe) || + usbhsf_fifo_is_busy(fifo)) + return -EBUSY; + + if (usbhs_pipe_is_dcp(pipe)) { + base |= (1 == write) << 5; /* ISEL */ + + if (usbhs_mod_is_host(priv)) + usbhs_dcp_dir_for_host(pipe, write); + } + + /* "base" will be used below */ + usbhs_write(priv, fifo->sel, base | MBW_32); + + /* check ISEL and CURPIPE value */ + while (timeout--) { + if (base == (mask & usbhs_read(priv, fifo->sel))) { + usbhs_pipe_select_fifo(pipe, fifo); + return 0; + } + udelay(10); + } + + dev_err(dev, "fifo select error\n"); + + return -EIO; +} + +/* + * DCP status stage + */ +static int usbhs_dcp_dir_switch_to_write(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct usbhs_fifo *fifo = usbhsf_get_cfifo(priv); /* CFIFO */ + struct device *dev = usbhs_priv_to_dev(priv); + int ret; + + usbhs_pipe_disable(pipe); + + ret = usbhsf_fifo_select(pipe, fifo, 1); + if (ret < 0) { + dev_err(dev, "%s() failed\n", __func__); + return ret; + } + + usbhs_pipe_sequence_data1(pipe); /* DATA1 */ + + usbhsf_fifo_clear(pipe, fifo); + usbhsf_send_terminator(pipe, fifo); + + usbhsf_fifo_unselect(pipe, fifo); + + usbhsf_tx_irq_ctrl(pipe, 1); + usbhs_pipe_enable(pipe); + + return ret; +} + +static int usbhs_dcp_dir_switch_to_read(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct usbhs_fifo *fifo = usbhsf_get_cfifo(priv); /* CFIFO */ + struct device *dev = usbhs_priv_to_dev(priv); + int ret; + + usbhs_pipe_disable(pipe); + + ret = usbhsf_fifo_select(pipe, fifo, 0); + if (ret < 0) { + dev_err(dev, "%s() fail\n", __func__); + return ret; + } + + usbhs_pipe_sequence_data1(pipe); /* DATA1 */ + usbhsf_fifo_clear(pipe, fifo); + + usbhsf_fifo_unselect(pipe, fifo); + + usbhsf_rx_irq_ctrl(pipe, 1); + usbhs_pipe_enable(pipe); + + return ret; + +} + +static int usbhs_dcp_dir_switch_done(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + + if (pkt->handler == &usbhs_dcp_status_stage_in_handler) + usbhsf_tx_irq_ctrl(pipe, 0); + else + usbhsf_rx_irq_ctrl(pipe, 0); + + pkt->actual = pkt->length; + *is_done = 1; + + return 0; +} + +const struct usbhs_pkt_handle usbhs_dcp_status_stage_in_handler = { + .prepare = usbhs_dcp_dir_switch_to_write, + .try_run = usbhs_dcp_dir_switch_done, +}; + +const struct usbhs_pkt_handle usbhs_dcp_status_stage_out_handler = { + .prepare = usbhs_dcp_dir_switch_to_read, + .try_run = usbhs_dcp_dir_switch_done, +}; + +/* + * DCP data stage (push) + */ +static int usbhsf_dcp_data_stage_try_push(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + + usbhs_pipe_sequence_data1(pipe); /* DATA1 */ + + /* + * change handler to PIO push + */ + pkt->handler = &usbhs_fifo_pio_push_handler; + + return pkt->handler->prepare(pkt, is_done); +} + +const struct usbhs_pkt_handle usbhs_dcp_data_stage_out_handler = { + .prepare = usbhsf_dcp_data_stage_try_push, +}; + +/* + * DCP data stage (pop) + */ +static int usbhsf_dcp_data_stage_prepare_pop(struct usbhs_pkt *pkt, + int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct usbhs_fifo *fifo = usbhsf_get_cfifo(priv); + + if (usbhs_pipe_is_busy(pipe)) + return 0; + + /* + * prepare pop for DCP should + * - change DCP direction, + * - clear fifo + * - DATA1 + */ + usbhs_pipe_disable(pipe); + + usbhs_pipe_sequence_data1(pipe); /* DATA1 */ + + usbhsf_fifo_select(pipe, fifo, 0); + usbhsf_fifo_clear(pipe, fifo); + usbhsf_fifo_unselect(pipe, fifo); + + /* + * change handler to PIO pop + */ + pkt->handler = &usbhs_fifo_pio_pop_handler; + + return pkt->handler->prepare(pkt, is_done); +} + +const struct usbhs_pkt_handle usbhs_dcp_data_stage_in_handler = { + .prepare = usbhsf_dcp_data_stage_prepare_pop, +}; + +/* + * PIO push handler + */ +static int usbhsf_pio_try_push(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct device *dev = usbhs_priv_to_dev(priv); + struct usbhs_fifo *fifo = usbhsf_get_cfifo(priv); /* CFIFO */ + void __iomem *addr = priv->base + fifo->port; + u8 *buf; + int maxp = usbhs_pipe_get_maxpacket(pipe); + int total_len; + int i, ret, len; + int is_short; + + usbhs_pipe_data_sequence(pipe, pkt->sequence); + pkt->sequence = -1; /* -1 sequence will be ignored */ + + usbhs_pipe_set_trans_count_if_bulk(pipe, pkt->length); + + ret = usbhsf_fifo_select(pipe, fifo, 1); + if (ret < 0) + return 0; + + ret = usbhs_pipe_is_accessible(pipe); + if (ret < 0) { + /* inaccessible pipe is not an error */ + ret = 0; + goto usbhs_fifo_write_busy; + } + + ret = usbhsf_fifo_barrier(priv, fifo); + if (ret < 0) + goto usbhs_fifo_write_busy; + + buf = pkt->buf + pkt->actual; + len = pkt->length - pkt->actual; + len = min(len, maxp); + total_len = len; + is_short = total_len < maxp; + + /* + * FIXME + * + * 32-bit access only + */ + if (len >= 4 && !((unsigned long)buf & 0x03)) { + iowrite32_rep(addr, buf, len / 4); + len %= 4; + buf += total_len - len; + } + + /* the rest operation */ + if (usbhs_get_dparam(priv, cfifo_byte_addr)) { + for (i = 0; i < len; i++) + iowrite8(buf[i], addr + (i & 0x03)); + } else { + for (i = 0; i < len; i++) + iowrite8(buf[i], addr + (0x03 - (i & 0x03))); + } + + /* + * variable update + */ + pkt->actual += total_len; + + if (pkt->actual < pkt->length) + *is_done = 0; /* there are remainder data */ + else if (is_short) + *is_done = 1; /* short packet */ + else + *is_done = !pkt->zero; /* send zero packet ? */ + + /* + * pipe/irq handling + */ + if (is_short) + usbhsf_send_terminator(pipe, fifo); + + usbhsf_tx_irq_ctrl(pipe, !*is_done); + usbhs_pipe_running(pipe, !*is_done); + usbhs_pipe_enable(pipe); + + dev_dbg(dev, " send %d (%d/ %d/ %d/ %d)\n", + usbhs_pipe_number(pipe), + pkt->length, pkt->actual, *is_done, pkt->zero); + + usbhsf_fifo_unselect(pipe, fifo); + + return 0; + +usbhs_fifo_write_busy: + usbhsf_fifo_unselect(pipe, fifo); + + /* + * pipe is busy. + * retry in interrupt + */ + usbhsf_tx_irq_ctrl(pipe, 1); + usbhs_pipe_running(pipe, 1); + + return ret; +} + +static int usbhsf_pio_prepare_push(struct usbhs_pkt *pkt, int *is_done) +{ + if (usbhs_pipe_is_running(pkt->pipe)) + return 0; + + return usbhsf_pio_try_push(pkt, is_done); +} + +const struct usbhs_pkt_handle usbhs_fifo_pio_push_handler = { + .prepare = usbhsf_pio_prepare_push, + .try_run = usbhsf_pio_try_push, +}; + +/* + * PIO pop handler + */ +static int usbhsf_prepare_pop(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct usbhs_fifo *fifo = usbhsf_get_cfifo(priv); + + if (usbhs_pipe_is_busy(pipe)) + return 0; + + if (usbhs_pipe_is_running(pipe)) + return 0; + + /* + * pipe enable to prepare packet receive + */ + usbhs_pipe_data_sequence(pipe, pkt->sequence); + pkt->sequence = -1; /* -1 sequence will be ignored */ + + if (usbhs_pipe_is_dcp(pipe)) + usbhsf_fifo_clear(pipe, fifo); + + usbhs_pipe_set_trans_count_if_bulk(pipe, pkt->length); + usbhs_pipe_enable(pipe); + usbhs_pipe_running(pipe, 1); + usbhsf_rx_irq_ctrl(pipe, 1); + + return 0; +} + +static int usbhsf_pio_try_pop(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct device *dev = usbhs_priv_to_dev(priv); + struct usbhs_fifo *fifo = usbhsf_get_cfifo(priv); /* CFIFO */ + void __iomem *addr = priv->base + fifo->port; + u8 *buf; + u32 data = 0; + int maxp = usbhs_pipe_get_maxpacket(pipe); + int rcv_len, len; + int i, ret; + int total_len = 0; + + ret = usbhsf_fifo_select(pipe, fifo, 0); + if (ret < 0) + return 0; + + ret = usbhsf_fifo_barrier(priv, fifo); + if (ret < 0) + goto usbhs_fifo_read_busy; + + rcv_len = usbhsf_fifo_rcv_len(priv, fifo); + + buf = pkt->buf + pkt->actual; + len = pkt->length - pkt->actual; + len = min(len, rcv_len); + total_len = len; + + /* + * update actual length first here to decide disable pipe. + * if this pipe keeps BUF status and all data were popped, + * then, next interrupt/token will be issued again + */ + pkt->actual += total_len; + + if ((pkt->actual == pkt->length) || /* receive all data */ + (total_len < maxp)) { /* short packet */ + *is_done = 1; + usbhsf_rx_irq_ctrl(pipe, 0); + usbhs_pipe_running(pipe, 0); + /* + * If function mode, since this controller is possible to enter + * Control Write status stage at this timing, this driver + * should not disable the pipe. If such a case happens, this + * controller is not able to complete the status stage. + */ + if (!usbhs_mod_is_host(priv) && !usbhs_pipe_is_dcp(pipe)) + usbhs_pipe_disable(pipe); /* disable pipe first */ + } + + /* + * Buffer clear if Zero-Length packet + * + * see + * "Operation" - "FIFO Buffer Memory" - "FIFO Port Function" + */ + if (0 == rcv_len) { + pkt->zero = 1; + usbhsf_fifo_clear(pipe, fifo); + goto usbhs_fifo_read_end; + } + + /* + * FIXME + * + * 32-bit access only + */ + if (len >= 4 && !((unsigned long)buf & 0x03)) { + ioread32_rep(addr, buf, len / 4); + len %= 4; + buf += total_len - len; + } + + /* the rest operation */ + for (i = 0; i < len; i++) { + if (!(i & 0x03)) + data = ioread32(addr); + + buf[i] = (data >> ((i & 0x03) * 8)) & 0xff; + } + +usbhs_fifo_read_end: + dev_dbg(dev, " recv %d (%d/ %d/ %d/ %d)\n", + usbhs_pipe_number(pipe), + pkt->length, pkt->actual, *is_done, pkt->zero); + +usbhs_fifo_read_busy: + usbhsf_fifo_unselect(pipe, fifo); + + return ret; +} + +const struct usbhs_pkt_handle usbhs_fifo_pio_pop_handler = { + .prepare = usbhsf_prepare_pop, + .try_run = usbhsf_pio_try_pop, +}; + +/* + * DCP ctrol statge handler + */ +static int usbhsf_ctrl_stage_end(struct usbhs_pkt *pkt, int *is_done) +{ + usbhs_dcp_control_transfer_done(pkt->pipe); + + *is_done = 1; + + return 0; +} + +const struct usbhs_pkt_handle usbhs_ctrl_stage_end_handler = { + .prepare = usbhsf_ctrl_stage_end, + .try_run = usbhsf_ctrl_stage_end, +}; + +/* + * DMA fifo functions + */ +static struct dma_chan *usbhsf_dma_chan_get(struct usbhs_fifo *fifo, + struct usbhs_pkt *pkt) +{ + if (&usbhs_fifo_dma_push_handler == pkt->handler) + return fifo->tx_chan; + + if (&usbhs_fifo_dma_pop_handler == pkt->handler) + return fifo->rx_chan; + + return NULL; +} + +#define usbhsf_dma_start(p, f) __usbhsf_dma_ctrl(p, f, DREQE) +#define usbhsf_dma_stop(p, f) __usbhsf_dma_ctrl(p, f, 0) +static void __usbhsf_dma_ctrl(struct usbhs_pipe *pipe, + struct usbhs_fifo *fifo, + u16 dreqe) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + + usbhs_bset(priv, fifo->sel, DREQE, dreqe); +} + +static int __usbhsf_dma_map_ctrl(struct usbhs_pkt *pkt, int map) +{ + struct usbhs_pipe *pipe = pkt->pipe; + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct usbhs_pipe_info *info = usbhs_priv_to_pipeinfo(priv); + + return info->dma_map_ctrl(pkt, map); +} + +/* + * DMA push handler + */ +static int usbhsf_dma_prepare_push(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + + if (usbhs_pipe_is_busy(pipe)) + return 0; + + /* + * change handler to PIO + */ + pkt->handler = &usbhs_fifo_pio_push_handler; + + return pkt->handler->prepare(pkt, is_done); +} + +static int usbhsf_dma_push_done(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + int is_short = pkt->trans % usbhs_pipe_get_maxpacket(pipe); + + pkt->actual += pkt->trans; + + if (pkt->actual < pkt->length) + *is_done = 0; /* there are remainder data */ + else if (is_short) + *is_done = 1; /* short packet */ + else + *is_done = !pkt->zero; /* send zero packet? */ + + usbhs_pipe_running(pipe, !*is_done); + + usbhsf_dma_stop(pipe, pipe->fifo); + usbhsf_dma_unmap(pkt); + usbhsf_fifo_unselect(pipe, pipe->fifo); + + if (!*is_done) { + /* change handler to PIO */ + pkt->handler = &usbhs_fifo_pio_push_handler; + return pkt->handler->try_run(pkt, is_done); + } + + return 0; +} + +const struct usbhs_pkt_handle usbhs_fifo_dma_push_handler = { + .prepare = usbhsf_dma_prepare_push, + .dma_done = usbhsf_dma_push_done, +}; + +/* + * DMA pop handler + */ + +static int usbhsf_dma_prepare_pop_with_rx_irq(struct usbhs_pkt *pkt, + int *is_done) +{ + return usbhsf_prepare_pop(pkt, is_done); +} + +static int usbhsf_dma_prepare_pop(struct usbhs_pkt *pkt, int *is_done) +{ + return usbhsf_dma_prepare_pop_with_rx_irq(pkt, is_done); +} + +static int usbhsf_dma_try_pop_with_rx_irq(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + + if (usbhs_pipe_is_busy(pipe)) + return 0; + + /* + * change handler to PIO + */ + pkt->handler = &usbhs_fifo_pio_pop_handler; + + return pkt->handler->try_run(pkt, is_done); +} + +static int usbhsf_dma_try_pop(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pkt->pipe); + + BUG_ON(usbhs_get_dparam(priv, has_usb_dmac)); + + return usbhsf_dma_try_pop_with_rx_irq(pkt, is_done); +} + +static int usbhsf_dma_pop_done_with_rx_irq(struct usbhs_pkt *pkt, int *is_done) +{ + struct usbhs_pipe *pipe = pkt->pipe; + int maxp = usbhs_pipe_get_maxpacket(pipe); + + usbhsf_dma_stop(pipe, pipe->fifo); + usbhsf_dma_unmap(pkt); + usbhsf_fifo_unselect(pipe, pipe->fifo); + + pkt->actual += pkt->trans; + + if ((pkt->actual == pkt->length) || /* receive all data */ + (pkt->trans < maxp)) { /* short packet */ + *is_done = 1; + usbhs_pipe_running(pipe, 0); + } else { + /* re-enable */ + usbhs_pipe_running(pipe, 0); + usbhsf_prepare_pop(pkt, is_done); + } + + return 0; +} + +static int usbhsf_dma_pop_done(struct usbhs_pkt *pkt, int *is_done) +{ + return usbhsf_dma_pop_done_with_rx_irq(pkt, is_done); +} + +const struct usbhs_pkt_handle usbhs_fifo_dma_pop_handler = { + .prepare = usbhsf_dma_prepare_pop, + .try_run = usbhsf_dma_try_pop, + .dma_done = usbhsf_dma_pop_done +}; + +/* + * irq functions + */ +static int usbhsf_irq_empty(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state) +{ + struct usbhs_pipe *pipe; + struct device *dev = usbhs_priv_to_dev(priv); + int i, ret; + + if (!irq_state->bempsts) { + dev_err(dev, "debug %s !!\n", __func__); + return -EIO; + } + + dev_dbg(dev, "irq empty [0x%04x]\n", irq_state->bempsts); + + /* + * search interrupted "pipe" + * not "uep". + */ + usbhs_for_each_pipe_with_dcp(pipe, priv, i) { + if (!(irq_state->bempsts & (1 << i))) + continue; + + ret = usbhsf_pkt_handler(pipe, USBHSF_PKT_TRY_RUN); + if (ret < 0) + dev_err(dev, "irq_empty run_error %d : %d\n", i, ret); + } + + return 0; +} + +static int usbhsf_irq_ready(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state) +{ + struct usbhs_pipe *pipe; + struct device *dev = usbhs_priv_to_dev(priv); + int i, ret; + + if (!irq_state->brdysts) { + dev_err(dev, "debug %s !!\n", __func__); + return -EIO; + } + + dev_dbg(dev, "irq ready [0x%04x]\n", irq_state->brdysts); + + /* + * search interrupted "pipe" + * not "uep". + */ + usbhs_for_each_pipe_with_dcp(pipe, priv, i) { + if (!(irq_state->brdysts & (1 << i))) + continue; + + ret = usbhsf_pkt_handler(pipe, USBHSF_PKT_TRY_RUN); + if (ret < 0) + dev_err(dev, "irq_ready run_error %d : %d\n", i, ret); + } + + return 0; +} + +void usbhs_fifo_clear_dcp(struct usbhs_pipe *pipe) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct usbhs_fifo *fifo = usbhsf_get_cfifo(priv); /* CFIFO */ + + /* clear DCP FIFO of transmission */ + if (usbhsf_fifo_select(pipe, fifo, 1) < 0) + return; + usbhsf_fifo_clear(pipe, fifo); + usbhsf_fifo_unselect(pipe, fifo); + + /* clear DCP FIFO of reception */ + if (usbhsf_fifo_select(pipe, fifo, 0) < 0) + return; + usbhsf_fifo_clear(pipe, fifo); + usbhsf_fifo_unselect(pipe, fifo); +} + +/* + * fifo init + */ +void usbhs_fifo_init(struct usbhs_priv *priv) +{ + struct usbhs_mod *mod = usbhs_mod_get_current(priv); + struct usbhs_fifo *cfifo = usbhsf_get_cfifo(priv); + struct usbhs_fifo *dfifo; + int i; + + mod->irq_empty = usbhsf_irq_empty; + mod->irq_ready = usbhsf_irq_ready; + mod->irq_bempsts = 0; + mod->irq_brdysts = 0; + + cfifo->pipe = NULL; + usbhs_for_each_dfifo(priv, dfifo, i) + dfifo->pipe = NULL; +} + +void usbhs_fifo_quit(struct usbhs_priv *priv) +{ + struct usbhs_mod *mod = usbhs_mod_get_current(priv); + + mod->irq_empty = NULL; + mod->irq_ready = NULL; + mod->irq_bempsts = 0; + mod->irq_brdysts = 0; +} + +#define __USBHS_DFIFO_INIT(priv, fifo, channel, fifo_port) \ +do { \ + fifo = usbhsf_get_dnfifo(priv, channel); \ + fifo->name = "D"#channel"FIFO"; \ + fifo->port = fifo_port; \ + fifo->sel = D##channel##FIFOSEL; \ + fifo->ctr = D##channel##FIFOCTR; \ + fifo->tx_slave.shdma_slave.slave_id = \ + usbhs_get_dparam(priv, d##channel##_tx_id); \ + fifo->rx_slave.shdma_slave.slave_id = \ + usbhs_get_dparam(priv, d##channel##_rx_id); \ +} while (0) + +#define USBHS_DFIFO_INIT(priv, fifo, channel) \ + __USBHS_DFIFO_INIT(priv, fifo, channel, D##channel##FIFO) +#define USBHS_DFIFO_INIT_NO_PORT(priv, fifo, channel) \ + __USBHS_DFIFO_INIT(priv, fifo, channel, 0) + +int usbhs_fifo_probe(struct usbhs_priv *priv) +{ + struct usbhs_fifo *fifo; + + /* CFIFO */ + fifo = usbhsf_get_cfifo(priv); + fifo->name = "CFIFO"; + fifo->port = CFIFO; + fifo->sel = CFIFOSEL; + fifo->ctr = CFIFOCTR; + + /* DFIFO */ + USBHS_DFIFO_INIT(priv, fifo, 0); + USBHS_DFIFO_INIT(priv, fifo, 1); + USBHS_DFIFO_INIT_NO_PORT(priv, fifo, 2); + USBHS_DFIFO_INIT_NO_PORT(priv, fifo, 3); + + return 0; +} + +void usbhs_fifo_remove(struct usbhs_priv *priv) +{ +} diff --git a/drivers/usb/gadget/rcar/fifo.h b/drivers/usb/gadget/rcar/fifo.h new file mode 100644 index 00000000000..86746ca9bdd --- /dev/null +++ b/drivers/usb/gadget/rcar/fifo.h @@ -0,0 +1,114 @@ +/* SPDX-License-Identifier: GPL-1.0+ */ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ +#ifndef RENESAS_USB_FIFO_H +#define RENESAS_USB_FIFO_H + +#include <dma.h> +#include "pipe.h" + +/* + * Drivers, using this library are expected to embed struct shdma_dev, + * struct shdma_chan, struct shdma_desc, and struct shdma_slave + * in their respective device, channel, descriptor and slave objects. + */ + +struct shdma_slave { + int slave_id; +}; + +/* Used by slave DMA clients to request DMA to/from a specific peripheral */ +struct sh_dmae_slave { + struct shdma_slave shdma_slave; /* Set by the platform */ +}; + +struct usbhs_fifo { + char *name; + u32 port; /* xFIFO */ + u32 sel; /* xFIFOSEL */ + u32 ctr; /* xFIFOCTR */ + + struct usbhs_pipe *pipe; + + struct dma_chan *tx_chan; + struct dma_chan *rx_chan; + + struct sh_dmae_slave tx_slave; + struct sh_dmae_slave rx_slave; +}; + +#define USBHS_MAX_NUM_DFIFO 4 +struct usbhs_fifo_info { + struct usbhs_fifo cfifo; + struct usbhs_fifo dfifo[USBHS_MAX_NUM_DFIFO]; +}; +#define usbhsf_get_dnfifo(p, n) (&((p)->fifo_info.dfifo[n])) +#define usbhs_for_each_dfifo(priv, dfifo, i) \ + for ((i) = 0; \ + ((i) < USBHS_MAX_NUM_DFIFO) && \ + ((dfifo) = usbhsf_get_dnfifo(priv, (i))); \ + (i)++) + +struct usbhs_pkt_handle; +struct usbhs_pkt { + struct list_head node; + struct usbhs_pipe *pipe; + const struct usbhs_pkt_handle *handler; + void (*done)(struct usbhs_priv *priv, + struct usbhs_pkt *pkt); + struct work_struct work; + dma_addr_t dma; + const struct dmaengine_result *dma_result; + void *buf; + int length; + int trans; + int actual; + int zero; + int sequence; +}; + +struct usbhs_pkt_handle { + int (*prepare)(struct usbhs_pkt *pkt, int *is_done); + int (*try_run)(struct usbhs_pkt *pkt, int *is_done); + int (*dma_done)(struct usbhs_pkt *pkt, int *is_done); +}; + +/* + * fifo + */ +int usbhs_fifo_probe(struct usbhs_priv *priv); +void usbhs_fifo_remove(struct usbhs_priv *priv); +void usbhs_fifo_init(struct usbhs_priv *priv); +void usbhs_fifo_quit(struct usbhs_priv *priv); +void usbhs_fifo_clear_dcp(struct usbhs_pipe *pipe); + +/* + * packet info + */ +extern const struct usbhs_pkt_handle usbhs_fifo_pio_push_handler; +extern const struct usbhs_pkt_handle usbhs_fifo_pio_pop_handler; +extern const struct usbhs_pkt_handle usbhs_ctrl_stage_end_handler; + +extern const struct usbhs_pkt_handle usbhs_fifo_dma_push_handler; +extern const struct usbhs_pkt_handle usbhs_fifo_dma_pop_handler; + +extern const struct usbhs_pkt_handle usbhs_dcp_status_stage_in_handler; +extern const struct usbhs_pkt_handle usbhs_dcp_status_stage_out_handler; + +extern const struct usbhs_pkt_handle usbhs_dcp_data_stage_in_handler; +extern const struct usbhs_pkt_handle usbhs_dcp_data_stage_out_handler; + +void usbhs_pkt_init(struct usbhs_pkt *pkt); +void usbhs_pkt_push(struct usbhs_pipe *pipe, struct usbhs_pkt *pkt, + void (*done)(struct usbhs_priv *priv, + struct usbhs_pkt *pkt), + void *buf, int len, int zero, int sequence); +struct usbhs_pkt *usbhs_pkt_pop(struct usbhs_pipe *pipe, struct usbhs_pkt *pkt); +void usbhs_pkt_start(struct usbhs_pipe *pipe); +struct usbhs_pkt *__usbhsf_pkt_get(struct usbhs_pipe *pipe); + +#endif /* RENESAS_USB_FIFO_H */ diff --git a/drivers/usb/gadget/rcar/mod.c b/drivers/usb/gadget/rcar/mod.c new file mode 100644 index 00000000000..f5f8d169e17 --- /dev/null +++ b/drivers/usb/gadget/rcar/mod.c @@ -0,0 +1,345 @@ +// SPDX-License-Identifier: GPL-1.0+ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Copyright (C) 2019 Renesas Electronics Corporation + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ +#include "common.h" +#include "mod.h" + +/* + * autonomy + * + * these functions are used if platform doesn't have external phy. + * -> there is no "notify_hotplug" callback from platform + * -> call "notify_hotplug" by itself + * -> use own interrupt to connect/disconnect + * -> it mean module clock is always ON + * ~~~~~~~~~~~~~~~~~~~~~~~~~ + */ +static int usbhsm_autonomy_irq_vbus(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state) +{ + usbhsc_hotplug(priv); + + return 0; +} + +void usbhs_mod_autonomy_mode(struct usbhs_priv *priv) +{ + struct usbhs_mod_info *info = usbhs_priv_to_modinfo(priv); + + info->irq_vbus = usbhsm_autonomy_irq_vbus; + + usbhs_irq_callback_update(priv, NULL); +} + +/* + * host / gadget functions + * + * renesas_usbhs host/gadget can register itself by below functions. + * these functions are called when probe + * + */ +void usbhs_mod_register(struct usbhs_priv *priv, struct usbhs_mod *mod, int id) +{ + struct usbhs_mod_info *info = usbhs_priv_to_modinfo(priv); + + info->mod[id] = mod; + mod->priv = priv; +} + +struct usbhs_mod *usbhs_mod_get(struct usbhs_priv *priv, int id) +{ + struct usbhs_mod_info *info = usbhs_priv_to_modinfo(priv); + struct usbhs_mod *ret = NULL; + + switch (id) { + case USBHS_HOST: + case USBHS_GADGET: + ret = info->mod[id]; + break; + } + + return ret; +} + +int usbhs_mod_is_host(struct usbhs_priv *priv) +{ + struct usbhs_mod *mod = usbhs_mod_get_current(priv); + struct usbhs_mod_info *info = usbhs_priv_to_modinfo(priv); + + if (!mod) + return -EINVAL; + + return info->mod[USBHS_HOST] == mod; +} + +struct usbhs_mod *usbhs_mod_get_current(struct usbhs_priv *priv) +{ + struct usbhs_mod_info *info = usbhs_priv_to_modinfo(priv); + + return info->curt; +} + +int usbhs_mod_change(struct usbhs_priv *priv, int id) +{ + struct usbhs_mod_info *info = usbhs_priv_to_modinfo(priv); + struct usbhs_mod *mod = NULL; + int ret = 0; + + /* id < 0 mean no current */ + switch (id) { + case USBHS_HOST: + case USBHS_GADGET: + mod = info->mod[id]; + break; + default: + ret = -EINVAL; + } + info->curt = mod; + + return ret; +} + +irqreturn_t usbhs_interrupt(int irq, void *data); +int usbhs_mod_probe(struct usbhs_priv *priv) +{ + int ret; + + /* + * install host/gadget driver + */ + ret = usbhs_mod_host_probe(priv); + if (ret < 0) + return ret; + + ret = usbhs_mod_gadget_probe(priv); + if (ret < 0) + goto mod_init_host_err; + + return ret; + +mod_init_host_err: + usbhs_mod_host_remove(priv); + + return ret; +} + +void usbhs_mod_remove(struct usbhs_priv *priv) +{ + usbhs_mod_host_remove(priv); + usbhs_mod_gadget_remove(priv); +} + +/* + * status functions + */ +int usbhs_status_get_device_state(struct usbhs_irq_state *irq_state) +{ + return (int)irq_state->intsts0 & DVSQ_MASK; +} + +int usbhs_status_get_ctrl_stage(struct usbhs_irq_state *irq_state) +{ + /* + * return value + * + * IDLE_SETUP_STAGE + * READ_DATA_STAGE + * READ_STATUS_STAGE + * WRITE_DATA_STAGE + * WRITE_STATUS_STAGE + * NODATA_STATUS_STAGE + * SEQUENCE_ERROR + */ + return (int)irq_state->intsts0 & CTSQ_MASK; +} + +static int usbhs_status_get_each_irq(struct usbhs_priv *priv, + struct usbhs_irq_state *state) +{ + struct usbhs_mod *mod = usbhs_mod_get_current(priv); + u16 intenb0, intenb1; + unsigned long flags; + + /******************** spin lock ********************/ + usbhs_lock(priv, flags); + state->intsts0 = usbhs_read(priv, INTSTS0); + intenb0 = usbhs_read(priv, INTENB0); + + if (usbhs_mod_is_host(priv)) { + state->intsts1 = usbhs_read(priv, INTSTS1); + intenb1 = usbhs_read(priv, INTENB1); + } else { + state->intsts1 = intenb1 = 0; + } + + /* mask */ + if (mod) { + state->brdysts = usbhs_read(priv, BRDYSTS); + state->nrdysts = usbhs_read(priv, NRDYSTS); + state->bempsts = usbhs_read(priv, BEMPSTS); + + state->bempsts &= mod->irq_bempsts; + state->brdysts &= mod->irq_brdysts; + } + usbhs_unlock(priv, flags); + /******************** spin unlock ******************/ + + return 0; +} + +/* + * interrupt + */ +#define INTSTS0_MAGIC 0xF800 /* acknowledge magical interrupt sources */ +#define INTSTS1_MAGIC 0xA870 /* acknowledge magical interrupt sources */ +irqreturn_t usbhs_interrupt(int irq, void *data) +{ + struct usbhs_priv *priv = data; + struct usbhs_irq_state irq_state; + + if (usbhs_status_get_each_irq(priv, &irq_state) < 0) + return IRQ_NONE; + + /* + * clear interrupt + * + * The hardware is _very_ picky to clear interrupt bit. + * Especially INTSTS0_MAGIC, INTSTS1_MAGIC value. + * + * see + * "Operation" + * - "Control Transfer (DCP)" + * - Function :: VALID bit should 0 + */ + usbhs_write(priv, INTSTS0, ~irq_state.intsts0 & INTSTS0_MAGIC); + if (usbhs_mod_is_host(priv)) + usbhs_write(priv, INTSTS1, ~irq_state.intsts1 & INTSTS1_MAGIC); + + /* + * The driver should not clear the xxxSTS after the line of + * "call irq callback functions" because each "if" statement is + * possible to call the callback function for avoiding any side effects. + */ + if (irq_state.intsts0 & BRDY) + usbhs_write(priv, BRDYSTS, ~irq_state.brdysts); + usbhs_write(priv, NRDYSTS, ~irq_state.nrdysts); + if (irq_state.intsts0 & BEMP) + usbhs_write(priv, BEMPSTS, ~irq_state.bempsts); + + /* + * call irq callback functions + * see also + * usbhs_irq_setting_update + */ + + /* INTSTS0 */ + if (irq_state.intsts0 & VBINT) + usbhs_mod_info_call(priv, irq_vbus, priv, &irq_state); + + if (irq_state.intsts0 & DVST) + usbhs_mod_call(priv, irq_dev_state, priv, &irq_state); + + if (irq_state.intsts0 & CTRT) + usbhs_mod_call(priv, irq_ctrl_stage, priv, &irq_state); + + if (irq_state.intsts0 & BEMP) + usbhs_mod_call(priv, irq_empty, priv, &irq_state); + + if (irq_state.intsts0 & BRDY) + usbhs_mod_call(priv, irq_ready, priv, &irq_state); + + if (usbhs_mod_is_host(priv)) { + /* INTSTS1 */ + if (irq_state.intsts1 & ATTCH) + usbhs_mod_call(priv, irq_attch, priv, &irq_state); + + if (irq_state.intsts1 & DTCH) + usbhs_mod_call(priv, irq_dtch, priv, &irq_state); + + if (irq_state.intsts1 & SIGN) + usbhs_mod_call(priv, irq_sign, priv, &irq_state); + + if (irq_state.intsts1 & SACK) + usbhs_mod_call(priv, irq_sack, priv, &irq_state); + } + return IRQ_HANDLED; +} + +void usbhs_irq_callback_update(struct usbhs_priv *priv, struct usbhs_mod *mod) +{ + u16 intenb0 = 0; + u16 intenb1 = 0; + struct usbhs_mod_info *info = usbhs_priv_to_modinfo(priv); + + /* + * BEMPENB/BRDYENB are picky. + * below method is required + * + * - clear INTSTS0 + * - update BEMPENB/BRDYENB + * - update INTSTS0 + */ + usbhs_write(priv, INTENB0, 0); + if (usbhs_mod_is_host(priv)) + usbhs_write(priv, INTENB1, 0); + + usbhs_write(priv, BEMPENB, 0); + usbhs_write(priv, BRDYENB, 0); + + /* + * see also + * usbhs_interrupt + */ + + if (info->irq_vbus) + intenb0 |= VBSE; + + if (mod) { + /* + * INTSTS0 + */ + if (mod->irq_ctrl_stage) + intenb0 |= CTRE; + + if (mod->irq_dev_state) + intenb0 |= DVSE; + + if (mod->irq_empty && mod->irq_bempsts) { + usbhs_write(priv, BEMPENB, mod->irq_bempsts); + intenb0 |= BEMPE; + } + + if (mod->irq_ready && mod->irq_brdysts) { + usbhs_write(priv, BRDYENB, mod->irq_brdysts); + intenb0 |= BRDYE; + } + + if (usbhs_mod_is_host(priv)) { + /* + * INTSTS1 + */ + if (mod->irq_attch) + intenb1 |= ATTCHE; + + if (mod->irq_dtch) + intenb1 |= DTCHE; + + if (mod->irq_sign) + intenb1 |= SIGNE; + + if (mod->irq_sack) + intenb1 |= SACKE; + } + } + + if (intenb0) + usbhs_write(priv, INTENB0, intenb0); + + if (usbhs_mod_is_host(priv) && intenb1) + usbhs_write(priv, INTENB1, intenb1); +} diff --git a/drivers/usb/gadget/rcar/mod.h b/drivers/usb/gadget/rcar/mod.h new file mode 100644 index 00000000000..b670e950a28 --- /dev/null +++ b/drivers/usb/gadget/rcar/mod.h @@ -0,0 +1,161 @@ +/* SPDX-License-Identifier: GPL-1.0+ */ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Copyright (C) 2019 Renesas Electronics Corporation + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ +#ifndef RENESAS_USB_MOD_H +#define RENESAS_USB_MOD_H + +#include "common.h" + +/* + * struct + */ +struct usbhs_irq_state { + u16 intsts0; + u16 intsts1; + u16 brdysts; + u16 nrdysts; + u16 bempsts; +}; + +struct usbhs_mod { + char *name; + + /* + * entry point from common.c + */ + int (*start)(struct usbhs_priv *priv); + int (*stop)(struct usbhs_priv *priv); + + /* + * INTSTS0 + */ + + /* DVST (DVSQ) */ + int (*irq_dev_state)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); + + /* CTRT (CTSQ) */ + int (*irq_ctrl_stage)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); + + /* BEMP / BEMPSTS */ + int (*irq_empty)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); + u16 irq_bempsts; + + /* BRDY / BRDYSTS */ + int (*irq_ready)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); + u16 irq_brdysts; + + /* + * INTSTS1 + */ + + /* ATTCHE */ + int (*irq_attch)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); + + /* DTCHE */ + int (*irq_dtch)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); + + /* SIGN */ + int (*irq_sign)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); + + /* SACK */ + int (*irq_sack)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); + + struct usbhs_priv *priv; +}; + +struct usbhs_mod_info { + struct usbhs_mod *mod[USBHS_MAX]; + struct usbhs_mod *curt; /* current mod */ + + /* + * INTSTS0 :: VBINT + * + * This function will be used as autonomy mode (runtime_pwctrl == 0) + * when the platform doesn't have own get_vbus function. + * + * This callback cannot be member of "struct usbhs_mod" because it + * will be used even though host/gadget has not been selected. + */ + int (*irq_vbus)(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state); +}; + +/* + * for host/gadget module + */ +struct usbhs_mod *usbhs_mod_get(struct usbhs_priv *priv, int id); +struct usbhs_mod *usbhs_mod_get_current(struct usbhs_priv *priv); +void usbhs_mod_register(struct usbhs_priv *priv, struct usbhs_mod *usb, int id); +int usbhs_mod_is_host(struct usbhs_priv *priv); +int usbhs_mod_change(struct usbhs_priv *priv, int id); +int usbhs_mod_probe(struct usbhs_priv *priv); +void usbhs_mod_remove(struct usbhs_priv *priv); + +void usbhs_mod_autonomy_mode(struct usbhs_priv *priv); +void usbhs_mod_non_autonomy_mode(struct usbhs_priv *priv); + +/* + * status functions + */ +int usbhs_status_get_device_state(struct usbhs_irq_state *irq_state); +int usbhs_status_get_ctrl_stage(struct usbhs_irq_state *irq_state); + +/* + * callback functions + */ +void usbhs_irq_callback_update(struct usbhs_priv *priv, struct usbhs_mod *mod); + +irqreturn_t usbhs_interrupt(int irq, void *data); + +#define usbhs_mod_call(priv, func, param...) \ + ({ \ + struct usbhs_mod *mod; \ + mod = usbhs_mod_get_current(priv); \ + !mod ? -ENODEV : \ + !mod->func ? 0 : \ + mod->func(param); \ + }) + +#define usbhs_priv_to_modinfo(priv) (&priv->mod_info) +#define usbhs_mod_info_call(priv, func, param...) \ +({ \ + struct usbhs_mod_info *info; \ + info = usbhs_priv_to_modinfo(priv); \ + !info->func ? 0 : \ + info->func(param); \ +}) + +/* + * host / gadget control + */ +#if defined(CONFIG_USB_RENESAS_USBHS_HCD) || \ + defined(CONFIG_USB_RENESAS_USBHS_HCD_MODULE) +extern int usbhs_mod_host_probe(struct usbhs_priv *priv); +extern int usbhs_mod_host_remove(struct usbhs_priv *priv); +#else +static inline int usbhs_mod_host_probe(struct usbhs_priv *priv) +{ + return 0; +} +static inline void usbhs_mod_host_remove(struct usbhs_priv *priv) +{ +} +#endif + +extern int usbhs_mod_gadget_probe(struct usbhs_priv *priv); +extern void usbhs_mod_gadget_remove(struct usbhs_priv *priv); + +#endif /* RENESAS_USB_MOD_H */ diff --git a/drivers/usb/gadget/rcar/mod_gadget.c b/drivers/usb/gadget/rcar/mod_gadget.c new file mode 100644 index 00000000000..bd9855eb4fa --- /dev/null +++ b/drivers/usb/gadget/rcar/mod_gadget.c @@ -0,0 +1,1136 @@ +// SPDX-License-Identifier: GPL-1.0+ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Copyright (C) 2019 Renesas Electronics Corporation + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ +#include <linux/delay.h> +#include <linux/dma-mapping.h> +#include <linux/io.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <linux/usb/otg.h> +#include "common.h" + +/* + * struct + */ +struct usbhsg_request { + struct usb_request req; + struct usbhs_pkt pkt; +}; + +#define EP_NAME_SIZE 8 +struct usbhsg_gpriv; +struct usbhsg_uep { + struct usb_ep ep; + struct usbhs_pipe *pipe; + spinlock_t lock; /* protect the pipe */ + + char ep_name[EP_NAME_SIZE]; + + struct usbhsg_gpriv *gpriv; +}; + +struct usbhsg_gpriv { + struct usb_gadget gadget; + struct usbhs_mod mod; + + struct usbhsg_uep *uep; + int uep_size; + + struct usb_gadget_driver *driver; + bool vbus_active; + + u32 status; +#define USBHSG_STATUS_STARTED (1 << 0) +#define USBHSG_STATUS_REGISTERD (1 << 1) +#define USBHSG_STATUS_WEDGE (1 << 2) +#define USBHSG_STATUS_SELF_POWERED (1 << 3) +#define USBHSG_STATUS_SOFT_CONNECT (1 << 4) +}; + +struct usbhsg_recip_handle { + char *name; + int (*device)(struct usbhs_priv *priv, struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl); + int (*interface)(struct usbhs_priv *priv, struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl); + int (*endpoint)(struct usbhs_priv *priv, struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl); +}; + +/* + * macro + */ +#define usbhsg_priv_to_gpriv(priv) \ + container_of( \ + usbhs_mod_get(priv, USBHS_GADGET), \ + struct usbhsg_gpriv, mod) + +#define __usbhsg_for_each_uep(start, pos, g, i) \ + for ((i) = start; \ + ((i) < (g)->uep_size) && ((pos) = (g)->uep + (i)); \ + (i)++) + +#define usbhsg_for_each_uep(pos, gpriv, i) \ + __usbhsg_for_each_uep(1, pos, gpriv, i) + +#define usbhsg_for_each_uep_with_dcp(pos, gpriv, i) \ + __usbhsg_for_each_uep(0, pos, gpriv, i) + +#define usbhsg_gadget_to_gpriv(g)\ + container_of(g, struct usbhsg_gpriv, gadget) + +#define usbhsg_req_to_ureq(r)\ + container_of(r, struct usbhsg_request, req) + +#define usbhsg_ep_to_uep(e) container_of(e, struct usbhsg_uep, ep) +#define usbhsg_gpriv_to_dev(gp) usbhs_priv_to_dev((gp)->mod.priv) +#define usbhsg_gpriv_to_priv(gp) ((gp)->mod.priv) +#define usbhsg_gpriv_to_dcp(gp) ((gp)->uep) +#define usbhsg_gpriv_to_nth_uep(gp, i) ((gp)->uep + i) +#define usbhsg_uep_to_gpriv(u) ((u)->gpriv) +#define usbhsg_uep_to_pipe(u) ((u)->pipe) +#define usbhsg_pipe_to_uep(p) ((p)->mod_private) +#define usbhsg_is_dcp(u) ((u) == usbhsg_gpriv_to_dcp((u)->gpriv)) + +#define usbhsg_ureq_to_pkt(u) (&(u)->pkt) +#define usbhsg_pkt_to_ureq(i) \ + container_of(i, struct usbhsg_request, pkt) + +#define usbhsg_is_not_connected(gp) ((gp)->gadget.speed == USB_SPEED_UNKNOWN) + +/* status */ +#define usbhsg_status_init(gp) do {(gp)->status = 0; } while (0) +#define usbhsg_status_set(gp, b) (gp->status |= b) +#define usbhsg_status_clr(gp, b) (gp->status &= ~b) +#define usbhsg_status_has(gp, b) (gp->status & b) + +/* + * queue push/pop + */ +static void __usbhsg_queue_pop(struct usbhsg_uep *uep, + struct usbhsg_request *ureq, + int status) +{ + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep); + struct device *dev = usbhsg_gpriv_to_dev(gpriv); + + if (pipe) + dev_dbg(dev, "pipe %d : queue pop\n", usbhs_pipe_number(pipe)); + + ureq->req.status = status; + spin_unlock(usbhs_priv_to_lock(priv)); + usb_gadget_giveback_request(&uep->ep, &ureq->req); + spin_lock(usbhs_priv_to_lock(priv)); +} + +static void usbhsg_queue_pop(struct usbhsg_uep *uep, + struct usbhsg_request *ureq, + int status) +{ + unsigned long flags; + + usbhs_lock(priv, flags); + __usbhsg_queue_pop(uep, ureq, status); + usbhs_unlock(priv, flags); +} + +static void usbhsg_queue_done(struct usbhs_priv *priv, struct usbhs_pkt *pkt) +{ + struct usbhs_pipe *pipe = pkt->pipe; + struct usbhsg_uep *uep = usbhsg_pipe_to_uep(pipe); + struct usbhsg_request *ureq = usbhsg_pkt_to_ureq(pkt); + unsigned long flags; + + ureq->req.actual = pkt->actual; + + usbhs_lock(priv, flags); + if (uep) + __usbhsg_queue_pop(uep, ureq, 0); + usbhs_unlock(priv, flags); +} + +static void usbhsg_queue_push(struct usbhsg_uep *uep, + struct usbhsg_request *ureq) +{ + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + struct device *dev = usbhsg_gpriv_to_dev(gpriv); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep); + struct usbhs_pkt *pkt = usbhsg_ureq_to_pkt(ureq); + struct usb_request *req = &ureq->req; + + req->actual = 0; + req->status = -EINPROGRESS; + usbhs_pkt_push(pipe, pkt, usbhsg_queue_done, + req->buf, req->length, req->zero, -1); + usbhs_pkt_start(pipe); + + dev_dbg(dev, "pipe %d : queue push (%d)\n", + usbhs_pipe_number(pipe), + req->length); +} + +/* + * dma map/unmap + */ +static int usbhsg_dma_map_ctrl(struct usbhs_pkt *pkt, int map) +{ + return -1; +} + +/* + * USB_TYPE_STANDARD / clear feature functions + */ +static int usbhsg_recip_handler_std_control_done(struct usbhs_priv *priv, + struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + struct usbhsg_uep *dcp = usbhsg_gpriv_to_dcp(gpriv); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(dcp); + + usbhs_dcp_control_transfer_done(pipe); + + return 0; +} + +static int usbhsg_recip_handler_std_clear_endpoint(struct usbhs_priv *priv, + struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl) +{ + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep); + + if (!usbhsg_status_has(gpriv, USBHSG_STATUS_WEDGE)) { + usbhs_pipe_disable(pipe); + usbhs_pipe_sequence_data0(pipe); + usbhs_pipe_enable(pipe); + } + + usbhsg_recip_handler_std_control_done(priv, uep, ctrl); + + usbhs_pkt_start(pipe); + + return 0; +} + +static struct usbhsg_recip_handle req_clear_feature = { + .name = "clear feature", + .device = usbhsg_recip_handler_std_control_done, + .interface = usbhsg_recip_handler_std_control_done, + .endpoint = usbhsg_recip_handler_std_clear_endpoint, +}; + +/* + * USB_TYPE_STANDARD / set feature functions + */ +static int usbhsg_recip_handler_std_set_device(struct usbhs_priv *priv, + struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl) +{ + switch (le16_to_cpu(ctrl->wValue)) { + case USB_DEVICE_TEST_MODE: + usbhsg_recip_handler_std_control_done(priv, uep, ctrl); + udelay(100); + usbhs_sys_set_test_mode(priv, le16_to_cpu(ctrl->wIndex) >> 8); + break; + default: + usbhsg_recip_handler_std_control_done(priv, uep, ctrl); + break; + } + + return 0; +} + +static int usbhsg_recip_handler_std_set_endpoint(struct usbhs_priv *priv, + struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl) +{ + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep); + + usbhs_pipe_stall(pipe); + + usbhsg_recip_handler_std_control_done(priv, uep, ctrl); + + return 0; +} + +static struct usbhsg_recip_handle req_set_feature = { + .name = "set feature", + .device = usbhsg_recip_handler_std_set_device, + .interface = usbhsg_recip_handler_std_control_done, + .endpoint = usbhsg_recip_handler_std_set_endpoint, +}; + +/* + * USB_TYPE_STANDARD / get status functions + */ +static void __usbhsg_recip_send_complete(struct usb_ep *ep, + struct usb_request *req) +{ + struct usbhsg_request *ureq = usbhsg_req_to_ureq(req); + + /* free allocated recip-buffer/usb_request */ + kfree(ureq->pkt.buf); + usb_ep_free_request(ep, req); +} + +static void __usbhsg_recip_send_status(struct usbhsg_gpriv *gpriv, + unsigned short status) +{ + struct usbhsg_uep *dcp = usbhsg_gpriv_to_dcp(gpriv); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(dcp); + struct device *dev = usbhsg_gpriv_to_dev(gpriv); + struct usb_request *req; + __le16 *buf; + + /* alloc new usb_request for recip */ + req = usb_ep_alloc_request(&dcp->ep, GFP_ATOMIC); + if (!req) { + dev_err(dev, "recip request allocation fail\n"); + return; + } + + /* alloc recip data buffer */ + buf = kmalloc(sizeof(*buf), GFP_ATOMIC); + if (!buf) { + usb_ep_free_request(&dcp->ep, req); + return; + } + + /* recip data is status */ + *buf = cpu_to_le16(status); + + /* allocated usb_request/buffer will be freed */ + req->complete = __usbhsg_recip_send_complete; + req->buf = buf; + req->length = sizeof(*buf); + req->zero = 0; + + /* push packet */ + pipe->handler = &usbhs_fifo_pio_push_handler; + usbhsg_queue_push(dcp, usbhsg_req_to_ureq(req)); +} + +static int usbhsg_recip_handler_std_get_device(struct usbhs_priv *priv, + struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl) +{ + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + unsigned short status = 0; + + if (usbhsg_status_has(gpriv, USBHSG_STATUS_SELF_POWERED)) + status = 1 << USB_DEVICE_SELF_POWERED; + + __usbhsg_recip_send_status(gpriv, status); + + return 0; +} + +static int usbhsg_recip_handler_std_get_interface(struct usbhs_priv *priv, + struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl) +{ + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + unsigned short status = 0; + + __usbhsg_recip_send_status(gpriv, status); + + return 0; +} + +static int usbhsg_recip_handler_std_get_endpoint(struct usbhs_priv *priv, + struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl) +{ + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep); + unsigned short status = 0; + + if (usbhs_pipe_is_stall(pipe)) + status = 1 << USB_ENDPOINT_HALT; + + __usbhsg_recip_send_status(gpriv, status); + + return 0; +} + +static struct usbhsg_recip_handle req_get_status = { + .name = "get status", + .device = usbhsg_recip_handler_std_get_device, + .interface = usbhsg_recip_handler_std_get_interface, + .endpoint = usbhsg_recip_handler_std_get_endpoint, +}; + +/* + * USB_TYPE handler + */ +static int usbhsg_recip_run_handle(struct usbhs_priv *priv, + struct usbhsg_recip_handle *handler, + struct usb_ctrlrequest *ctrl) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + struct device *dev = usbhsg_gpriv_to_dev(gpriv); + struct usbhsg_uep *uep; + struct usbhs_pipe *pipe; + int recip = ctrl->bRequestType & USB_RECIP_MASK; + int nth = le16_to_cpu(ctrl->wIndex) & USB_ENDPOINT_NUMBER_MASK; + int ret = 0; + int (*func)(struct usbhs_priv *priv, struct usbhsg_uep *uep, + struct usb_ctrlrequest *ctrl); + char *msg; + + uep = usbhsg_gpriv_to_nth_uep(gpriv, nth); + pipe = usbhsg_uep_to_pipe(uep); + if (!pipe) { + dev_err(dev, "wrong recip request\n"); + return -EINVAL; + } + + switch (recip) { + case USB_RECIP_DEVICE: + msg = "DEVICE"; + func = handler->device; + break; + case USB_RECIP_INTERFACE: + msg = "INTERFACE"; + func = handler->interface; + break; + case USB_RECIP_ENDPOINT: + msg = "ENDPOINT"; + func = handler->endpoint; + break; + default: + dev_warn(dev, "unsupported RECIP(%d)\n", recip); + func = NULL; + ret = -EINVAL; + } + + if (func) { + dev_dbg(dev, "%s (pipe %d :%s)\n", handler->name, nth, msg); + ret = func(priv, uep, ctrl); + } + + return ret; +} + +/* + * irq functions + * + * it will be called from usbhs_interrupt + */ +static int usbhsg_irq_dev_state(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + struct device *dev = usbhsg_gpriv_to_dev(gpriv); + int state = usbhs_status_get_device_state(irq_state); + + gpriv->gadget.speed = usbhs_bus_get_speed(priv); + + dev_dbg(dev, "state = %x : speed : %d\n", state, gpriv->gadget.speed); + + if (gpriv->gadget.speed != USB_SPEED_UNKNOWN && + (state & SUSPENDED_STATE)) { + if (gpriv->driver && gpriv->driver->suspend) + gpriv->driver->suspend(&gpriv->gadget); + usb_gadget_set_state(&gpriv->gadget, USB_STATE_SUSPENDED); + } + + return 0; +} + +static int usbhsg_irq_ctrl_stage(struct usbhs_priv *priv, + struct usbhs_irq_state *irq_state) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + struct usbhsg_uep *dcp = usbhsg_gpriv_to_dcp(gpriv); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(dcp); + struct device *dev = usbhsg_gpriv_to_dev(gpriv); + struct usb_ctrlrequest ctrl; + struct usbhsg_recip_handle *recip_handler = NULL; + int stage = usbhs_status_get_ctrl_stage(irq_state); + int ret = 0; + + dev_dbg(dev, "stage = %d\n", stage); + + /* + * see Manual + * + * "Operation" + * - "Interrupt Function" + * - "Control Transfer Stage Transition Interrupt" + * - Fig. "Control Transfer Stage Transitions" + */ + + switch (stage) { + case READ_DATA_STAGE: + pipe->handler = &usbhs_fifo_pio_push_handler; + break; + case WRITE_DATA_STAGE: + pipe->handler = &usbhs_fifo_pio_pop_handler; + break; + case NODATA_STATUS_STAGE: + pipe->handler = &usbhs_ctrl_stage_end_handler; + break; + case READ_STATUS_STAGE: + case WRITE_STATUS_STAGE: + usbhs_dcp_control_transfer_done(pipe); + fallthrough; + default: + return ret; + } + + /* + * get usb request + */ + usbhs_usbreq_get_val(priv, &ctrl); + + switch (ctrl.bRequestType & USB_TYPE_MASK) { + case USB_TYPE_STANDARD: + switch (ctrl.bRequest) { + case USB_REQ_CLEAR_FEATURE: + recip_handler = &req_clear_feature; + break; + case USB_REQ_SET_FEATURE: + recip_handler = &req_set_feature; + break; + case USB_REQ_GET_STATUS: + recip_handler = &req_get_status; + break; + } + } + + /* + * setup stage / run recip + */ + if (recip_handler) + ret = usbhsg_recip_run_handle(priv, recip_handler, &ctrl); + else + ret = gpriv->driver->setup(&gpriv->gadget, &ctrl); + + if (ret < 0) + usbhs_pipe_stall(pipe); + + return ret; +} + +/* + * + * usb_dcp_ops + * + */ +static int usbhsg_pipe_disable(struct usbhsg_uep *uep) +{ + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep); + struct usbhs_pkt *pkt; + + while (1) { + pkt = usbhs_pkt_pop(pipe, NULL); + if (!pkt) + break; + + usbhsg_queue_pop(uep, usbhsg_pkt_to_ureq(pkt), -ESHUTDOWN); + } + + usbhs_pipe_disable(pipe); + + return 0; +} + +/* + * + * usb_ep_ops + * + */ +static int usbhsg_ep_enable(struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc) +{ + struct usbhsg_uep *uep = usbhsg_ep_to_uep(ep); + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + struct usbhs_priv *priv = usbhsg_gpriv_to_priv(gpriv); + struct usbhs_pipe *pipe; + int ret = -EIO; + unsigned long flags; + + usbhs_lock(priv, flags); + + /* + * if it already have pipe, + * nothing to do + */ + if (uep->pipe) { + usbhs_pipe_clear(uep->pipe); + usbhs_pipe_sequence_data0(uep->pipe); + ret = 0; + goto usbhsg_ep_enable_end; + } + + pipe = usbhs_pipe_malloc(priv, + usb_endpoint_type(desc), + usb_endpoint_dir_in(desc)); + if (pipe) { + uep->pipe = pipe; + pipe->mod_private = uep; + + /* set epnum / maxp */ + usbhs_pipe_config_update(pipe, 0, + usb_endpoint_num(desc), + usb_endpoint_maxp(desc)); + + /* + * usbhs_fifo_dma_push/pop_handler try to + * use dmaengine if possible. + * It will use pio handler if impossible. + */ + if (usb_endpoint_dir_in(desc)) { + pipe->handler = &usbhs_fifo_dma_push_handler; + } else { + pipe->handler = &usbhs_fifo_dma_pop_handler; + usbhs_xxxsts_clear(priv, BRDYSTS, + usbhs_pipe_number(pipe)); + } + + ret = 0; + } + +usbhsg_ep_enable_end: + usbhs_unlock(priv, flags); + + return ret; +} + +static int usbhsg_ep_disable(struct usb_ep *ep) +{ + struct usbhsg_uep *uep = usbhsg_ep_to_uep(ep); + struct usbhs_pipe *pipe; + unsigned long flags; + + spin_lock_irqsave(&uep->lock, flags); + pipe = usbhsg_uep_to_pipe(uep); + if (!pipe) + goto out; + + usbhsg_pipe_disable(uep); + usbhs_pipe_free(pipe); + + uep->pipe->mod_private = NULL; + uep->pipe = NULL; + +out: + spin_unlock_irqrestore(&uep->lock, flags); + + return 0; +} + +static struct usb_request *usbhsg_ep_alloc_request(struct usb_ep *ep, + gfp_t gfp_flags) +{ + struct usbhsg_request *ureq; + + ureq = kzalloc(sizeof *ureq, gfp_flags); + if (!ureq) + return NULL; + + usbhs_pkt_init(usbhsg_ureq_to_pkt(ureq)); + + return &ureq->req; +} + +static void usbhsg_ep_free_request(struct usb_ep *ep, + struct usb_request *req) +{ + struct usbhsg_request *ureq = usbhsg_req_to_ureq(req); + + WARN_ON(!list_empty(&ureq->pkt.node)); + kfree(ureq); +} + +static int usbhsg_ep_queue(struct usb_ep *ep, struct usb_request *req, + gfp_t gfp_flags) +{ + struct usbhsg_uep *uep = usbhsg_ep_to_uep(ep); + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + struct usbhsg_request *ureq = usbhsg_req_to_ureq(req); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep); + + /* param check */ + if (usbhsg_is_not_connected(gpriv) || + unlikely(!gpriv->driver) || + unlikely(!pipe)) + return -ESHUTDOWN; + + usbhsg_queue_push(uep, ureq); + + return 0; +} + +static int usbhsg_ep_dequeue(struct usb_ep *ep, struct usb_request *req) +{ + struct usbhsg_uep *uep = usbhsg_ep_to_uep(ep); + struct usbhsg_request *ureq = usbhsg_req_to_ureq(req); + struct usbhs_pipe *pipe; + unsigned long flags; + + spin_lock_irqsave(&uep->lock, flags); + pipe = usbhsg_uep_to_pipe(uep); + if (pipe) + usbhs_pkt_pop(pipe, usbhsg_ureq_to_pkt(ureq)); + + /* + * To dequeue a request, this driver should call the usbhsg_queue_pop() + * even if the pipe is NULL. + */ + usbhsg_queue_pop(uep, ureq, -ECONNRESET); + spin_unlock_irqrestore(&uep->lock, flags); + + return 0; +} + +bool usbhs_pipe_contains_transmittable_data(struct usbhs_pipe *pipe); +static int __usbhsg_ep_set_halt_wedge(struct usb_ep *ep, int halt, int wedge) +{ + struct usbhsg_uep *uep = usbhsg_ep_to_uep(ep); + struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep); + struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep); + struct device *dev = usbhsg_gpriv_to_dev(gpriv); + unsigned long flags; + int ret = 0; + + dev_dbg(dev, "set halt %d (pipe %d)\n", + halt, usbhs_pipe_number(pipe)); + + /******************** spin lock ********************/ + usbhs_lock(priv, flags); + + /* + * According to usb_ep_set_halt()'s description, this function should + * return -EAGAIN if the IN endpoint has any queue or data. Note + * that the usbhs_pipe_is_dir_in() returns false if the pipe is an + * IN endpoint in the gadget mode. + */ + if (!usbhs_pipe_is_dir_in(pipe) && (__usbhsf_pkt_get(pipe) || + usbhs_pipe_contains_transmittable_data(pipe))) { + ret = -EAGAIN; + goto out; + } + + if (halt) + usbhs_pipe_stall(pipe); + else + usbhs_pipe_disable(pipe); + + if (halt && wedge) + usbhsg_status_set(gpriv, USBHSG_STATUS_WEDGE); + else + usbhsg_status_clr(gpriv, USBHSG_STATUS_WEDGE); + +out: + usbhs_unlock(priv, flags); + /******************** spin unlock ******************/ + + return ret; +} + +static int usbhsg_ep_set_halt(struct usb_ep *ep, int value) +{ + return __usbhsg_ep_set_halt_wedge(ep, value, 0); +} + +static int usbhsg_ep_set_wedge(struct usb_ep *ep) +{ + return __usbhsg_ep_set_halt_wedge(ep, 1, 1); +} + +static const struct usb_ep_ops usbhsg_ep_ops = { + .enable = usbhsg_ep_enable, + .disable = usbhsg_ep_disable, + + .alloc_request = usbhsg_ep_alloc_request, + .free_request = usbhsg_ep_free_request, + + .queue = usbhsg_ep_queue, + .dequeue = usbhsg_ep_dequeue, + + .set_halt = usbhsg_ep_set_halt, + .set_wedge = usbhsg_ep_set_wedge, +}; + +/* + * pullup control + */ +static int usbhsg_can_pullup(struct usbhs_priv *priv) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + + return gpriv->driver && + usbhsg_status_has(gpriv, USBHSG_STATUS_SOFT_CONNECT); +} + +static void usbhsg_update_pullup(struct usbhs_priv *priv) +{ + if (usbhsg_can_pullup(priv)) + usbhs_sys_function_pullup(priv, 1); + else + usbhs_sys_function_pullup(priv, 0); +} + +/* + * usb module start/end + */ +static int usbhsg_try_start(struct usbhs_priv *priv, u32 status) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + struct usbhsg_uep *dcp = usbhsg_gpriv_to_dcp(gpriv); + struct usbhs_mod *mod = usbhs_mod_get_current(priv); + struct device *dev = usbhs_priv_to_dev(priv); + unsigned long flags; + int ret = 0; + + /******************** spin lock ********************/ + usbhs_lock(priv, flags); + + usbhsg_status_set(gpriv, status); + if (!(usbhsg_status_has(gpriv, USBHSG_STATUS_STARTED) && + usbhsg_status_has(gpriv, USBHSG_STATUS_REGISTERD))) + ret = -1; /* not ready */ + + usbhs_unlock(priv, flags); + /******************** spin unlock ********************/ + + if (ret < 0) + return 0; /* not ready is not error */ + + /* + * enable interrupt and systems if ready + */ + dev_dbg(dev, "start gadget\n"); + + /* + * pipe initialize and enable DCP + */ + usbhs_fifo_init(priv); + usbhs_pipe_init(priv, + usbhsg_dma_map_ctrl); + + /* dcp init instead of usbhsg_ep_enable() */ + dcp->pipe = usbhs_dcp_malloc(priv); + dcp->pipe->mod_private = dcp; + usbhs_pipe_config_update(dcp->pipe, 0, 0, 64); + + /* + * system config enble + * - HI speed + * - function + * - usb module + */ + usbhs_sys_function_ctrl(priv, 1); + usbhsg_update_pullup(priv); + + /* + * enable irq callback + */ + mod->irq_dev_state = usbhsg_irq_dev_state; + mod->irq_ctrl_stage = usbhsg_irq_ctrl_stage; + usbhs_irq_callback_update(priv, mod); + + return 0; +} + +static int usbhsg_try_stop(struct usbhs_priv *priv, u32 status) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + struct usbhs_mod *mod = usbhs_mod_get_current(priv); + struct usbhsg_uep *uep; + struct device *dev = usbhs_priv_to_dev(priv); + unsigned long flags; + int ret = 0, i; + + /******************** spin lock ********************/ + usbhs_lock(priv, flags); + + usbhsg_status_clr(gpriv, status); + if (!usbhsg_status_has(gpriv, USBHSG_STATUS_STARTED) && + !usbhsg_status_has(gpriv, USBHSG_STATUS_REGISTERD)) + ret = -1; /* already done */ + + usbhs_unlock(priv, flags); + /******************** spin unlock ********************/ + + if (ret < 0) + return 0; /* already done is not error */ + + /* + * disable interrupt and systems if 1st try + */ + usbhs_fifo_quit(priv); + + /* disable all irq */ + mod->irq_dev_state = NULL; + mod->irq_ctrl_stage = NULL; + usbhs_irq_callback_update(priv, mod); + + gpriv->gadget.speed = USB_SPEED_UNKNOWN; + + /* disable sys */ + usbhs_sys_set_test_mode(priv, 0); + usbhs_sys_function_ctrl(priv, 0); + + /* disable all eps */ + usbhsg_for_each_uep_with_dcp(uep, gpriv, i) + usbhsg_ep_disable(&uep->ep); + + dev_dbg(dev, "stop gadget\n"); + + return 0; +} + +/* + * VBUS provided by the PHY + */ +static void usbhs_mod_phy_mode(struct usbhs_priv *priv) +{ + struct usbhs_mod_info *info = &priv->mod_info; + + info->irq_vbus = NULL; + + usbhs_irq_callback_update(priv, NULL); +} + +/* + * + * linux usb function + * + */ +static int usbhsg_gadget_start(struct usb_gadget *gadget, + struct usb_gadget_driver *driver) +{ + struct usbhsg_gpriv *gpriv = usbhsg_gadget_to_gpriv(gadget); + struct usbhs_priv *priv = usbhsg_gpriv_to_priv(gpriv); + + if (!driver || !driver->setup) + return -EINVAL; + + /* get vbus using phy versions */ + usbhs_mod_phy_mode(priv); + + /* first hook up the driver ... */ + gpriv->driver = driver; + + return usbhsg_try_start(priv, USBHSG_STATUS_REGISTERD); +} + +static int usbhsg_gadget_stop(struct usb_gadget *gadget) +{ + struct usbhsg_gpriv *gpriv = usbhsg_gadget_to_gpriv(gadget); + struct usbhs_priv *priv = usbhsg_gpriv_to_priv(gpriv); + + usbhsg_try_stop(priv, USBHSG_STATUS_REGISTERD); + + gpriv->driver = NULL; + + return 0; +} + +/* + * usb gadget ops + */ +static int usbhsg_get_frame(struct usb_gadget *gadget) +{ + struct usbhsg_gpriv *gpriv = usbhsg_gadget_to_gpriv(gadget); + struct usbhs_priv *priv = usbhsg_gpriv_to_priv(gpriv); + + return usbhs_frame_get_num(priv); +} + +static int usbhsg_pullup(struct usb_gadget *gadget, int is_on) +{ + struct usbhsg_gpriv *gpriv = usbhsg_gadget_to_gpriv(gadget); + struct usbhs_priv *priv = usbhsg_gpriv_to_priv(gpriv); + unsigned long flags; + + usbhs_lock(priv, flags); + if (is_on) + usbhsg_status_set(gpriv, USBHSG_STATUS_SOFT_CONNECT); + else + usbhsg_status_clr(gpriv, USBHSG_STATUS_SOFT_CONNECT); + usbhsg_update_pullup(priv); + usbhs_unlock(priv, flags); + + return 0; +} + +static int usbhsg_set_selfpowered(struct usb_gadget *gadget, int is_self) +{ + struct usbhsg_gpriv *gpriv = usbhsg_gadget_to_gpriv(gadget); + + if (is_self) + usbhsg_status_set(gpriv, USBHSG_STATUS_SELF_POWERED); + else + usbhsg_status_clr(gpriv, USBHSG_STATUS_SELF_POWERED); + + return 0; +} + +static int usbhsg_vbus_session(struct usb_gadget *gadget, int is_active) +{ + struct usbhsg_gpriv *gpriv = usbhsg_gadget_to_gpriv(gadget); + struct usbhs_priv *priv = usbhsg_gpriv_to_priv(gpriv); + + gpriv->vbus_active = !!is_active; + + usbhsc_hotplug(priv); + + return 0; +} + +static const struct usb_gadget_ops usbhsg_gadget_ops = { + .get_frame = usbhsg_get_frame, + .set_selfpowered = usbhsg_set_selfpowered, + .udc_start = usbhsg_gadget_start, + .udc_stop = usbhsg_gadget_stop, + .pullup = usbhsg_pullup, + .vbus_session = usbhsg_vbus_session, +}; + +static int usbhsg_start(struct usbhs_priv *priv) +{ + return usbhsg_try_start(priv, USBHSG_STATUS_STARTED); +} + +static int usbhsg_stop(struct usbhs_priv *priv) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + + /* cable disconnect */ + if (gpriv->driver && + gpriv->driver->disconnect) + gpriv->driver->disconnect(&gpriv->gadget); + + return usbhsg_try_stop(priv, USBHSG_STATUS_STARTED); +} + +int usbhs_mod_gadget_probe(struct usbhs_priv *priv) +{ + struct usbhsg_gpriv *gpriv; + struct usbhsg_uep *uep; + struct device *dev = usbhs_priv_to_dev(priv); + struct renesas_usbhs_driver_pipe_config *pipe_configs = + usbhs_get_dparam(priv, pipe_configs); + int pipe_size = usbhs_get_dparam(priv, pipe_size); + int i; + int ret; + + gpriv = kzalloc(sizeof(struct usbhsg_gpriv), GFP_KERNEL); + if (!gpriv) + return -ENOMEM; + + uep = kcalloc(pipe_size, sizeof(struct usbhsg_uep), GFP_KERNEL); + if (!uep) { + ret = -ENOMEM; + goto usbhs_mod_gadget_probe_err_gpriv; + } + + /* + * CAUTION + * + * There is no guarantee that it is possible to access usb module here. + * Don't accesses to it. + * The accesse will be enable after "usbhsg_start" + */ + + /* + * register itself + */ + usbhs_mod_register(priv, &gpriv->mod, USBHS_GADGET); + + /* init gpriv */ + gpriv->mod.name = "gadget"; + gpriv->mod.start = usbhsg_start; + gpriv->mod.stop = usbhsg_stop; + gpriv->uep = uep; + gpriv->uep_size = pipe_size; + usbhsg_status_init(gpriv); + + /* + * init gadget + */ + gpriv->gadget.dev.parent = dev; + gpriv->gadget.name = "renesas_usbhs_udc"; + gpriv->gadget.ops = &usbhsg_gadget_ops; + gpriv->gadget.max_speed = USB_SPEED_HIGH; + + INIT_LIST_HEAD(&gpriv->gadget.ep_list); + + /* + * init usb_ep + */ + usbhsg_for_each_uep_with_dcp(uep, gpriv, i) { + uep->gpriv = gpriv; + uep->pipe = NULL; + snprintf(uep->ep_name, EP_NAME_SIZE, "ep%d", i); + + uep->ep.name = uep->ep_name; + uep->ep.ops = &usbhsg_ep_ops; + INIT_LIST_HEAD(&uep->ep.ep_list); + spin_lock_init(&uep->lock); + + /* init DCP */ + if (usbhsg_is_dcp(uep)) { + gpriv->gadget.ep0 = &uep->ep; + usb_ep_set_maxpacket_limit(&uep->ep, 64); + uep->ep.caps.type_control = true; + } else { + /* init normal pipe */ + if (pipe_configs[i].type == USB_ENDPOINT_XFER_ISOC) + uep->ep.caps.type_iso = true; + if (pipe_configs[i].type == USB_ENDPOINT_XFER_BULK) + uep->ep.caps.type_bulk = true; + if (pipe_configs[i].type == USB_ENDPOINT_XFER_INT) + uep->ep.caps.type_int = true; + usb_ep_set_maxpacket_limit(&uep->ep, + pipe_configs[i].bufsize); + list_add_tail(&uep->ep.ep_list, &gpriv->gadget.ep_list); + } + uep->ep.caps.dir_in = true; + uep->ep.caps.dir_out = true; + } + + ret = usb_add_gadget_udc(dev, &gpriv->gadget); + if (ret) + goto err_add_udc; + + + dev_info(dev, "gadget probed\n"); + + return 0; + +err_add_udc: + kfree(gpriv->uep); + +usbhs_mod_gadget_probe_err_gpriv: + kfree(gpriv); + + return ret; +} + +void usbhs_mod_gadget_remove(struct usbhs_priv *priv) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + + usb_del_gadget_udc(&gpriv->gadget); + + kfree(gpriv->uep); + kfree(gpriv); +} + +struct usb_gadget *usbhsg_get_gadget(struct usbhs_priv *priv) +{ + struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv); + return &gpriv->gadget; +} diff --git a/drivers/usb/gadget/rcar/pipe.c b/drivers/usb/gadget/rcar/pipe.c new file mode 100644 index 00000000000..a2b24f38144 --- /dev/null +++ b/drivers/usb/gadget/rcar/pipe.c @@ -0,0 +1,849 @@ +// SPDX-License-Identifier: GPL-1.0+ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ +#include <linux/delay.h> +#include "common.h" +#include "pipe.h" + +/* + * macros + */ +#define usbhsp_addr_offset(p) ((usbhs_pipe_number(p) - 1) * 2) + +#define usbhsp_flags_set(p, f) ((p)->flags |= USBHS_PIPE_FLAGS_##f) +#define usbhsp_flags_clr(p, f) ((p)->flags &= ~USBHS_PIPE_FLAGS_##f) +#define usbhsp_flags_has(p, f) ((p)->flags & USBHS_PIPE_FLAGS_##f) +#define usbhsp_flags_init(p) do {(p)->flags = 0; } while (0) + +/* + * for debug + */ +static char *usbhsp_pipe_name[] = { + [USB_ENDPOINT_XFER_CONTROL] = "DCP", + [USB_ENDPOINT_XFER_BULK] = "BULK", + [USB_ENDPOINT_XFER_INT] = "INT", + [USB_ENDPOINT_XFER_ISOC] = "ISO", +}; + +char *usbhs_pipe_name(struct usbhs_pipe *pipe) +{ + return usbhsp_pipe_name[usbhs_pipe_type(pipe)]; +} + +static struct renesas_usbhs_driver_pipe_config +*usbhsp_get_pipe_config(struct usbhs_priv *priv, int pipe_num) +{ + struct renesas_usbhs_driver_pipe_config *pipe_configs = + usbhs_get_dparam(priv, pipe_configs); + + return &pipe_configs[pipe_num]; +} + +/* + * DCPCTR/PIPEnCTR functions + */ +static void usbhsp_pipectrl_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + int offset = usbhsp_addr_offset(pipe); + + if (usbhs_pipe_is_dcp(pipe)) + usbhs_bset(priv, DCPCTR, mask, val); + else + usbhs_bset(priv, PIPEnCTR + offset, mask, val); +} + +static u16 usbhsp_pipectrl_get(struct usbhs_pipe *pipe) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + int offset = usbhsp_addr_offset(pipe); + + if (usbhs_pipe_is_dcp(pipe)) + return usbhs_read(priv, DCPCTR); + else + return usbhs_read(priv, PIPEnCTR + offset); +} + +/* + * DCP/PIPE functions + */ +static void __usbhsp_pipe_xxx_set(struct usbhs_pipe *pipe, + u16 dcp_reg, u16 pipe_reg, + u16 mask, u16 val) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + + if (usbhs_pipe_is_dcp(pipe)) + usbhs_bset(priv, dcp_reg, mask, val); + else + usbhs_bset(priv, pipe_reg, mask, val); +} + +static u16 __usbhsp_pipe_xxx_get(struct usbhs_pipe *pipe, + u16 dcp_reg, u16 pipe_reg) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + + if (usbhs_pipe_is_dcp(pipe)) + return usbhs_read(priv, dcp_reg); + else + return usbhs_read(priv, pipe_reg); +} + +/* + * DCPCFG/PIPECFG functions + */ +static void usbhsp_pipe_cfg_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{ + __usbhsp_pipe_xxx_set(pipe, DCPCFG, PIPECFG, mask, val); +} + +static u16 usbhsp_pipe_cfg_get(struct usbhs_pipe *pipe) +{ + return __usbhsp_pipe_xxx_get(pipe, DCPCFG, PIPECFG); +} + +/* + * PIPEnTRN/PIPEnTRE functions + */ +static void usbhsp_pipe_trn_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct device *dev = usbhs_priv_to_dev(priv); + int num = usbhs_pipe_number(pipe); + u16 reg; + + /* + * It is impossible to calculate address, + * since PIPEnTRN addresses were mapped randomly. + */ +#define CASE_PIPExTRN(a) \ + case 0x ## a: \ + reg = PIPE ## a ## TRN; \ + break; + + switch (num) { + CASE_PIPExTRN(1); + CASE_PIPExTRN(2); + CASE_PIPExTRN(3); + CASE_PIPExTRN(4); + CASE_PIPExTRN(5); + CASE_PIPExTRN(B); + CASE_PIPExTRN(C); + CASE_PIPExTRN(D); + CASE_PIPExTRN(E); + CASE_PIPExTRN(F); + CASE_PIPExTRN(9); + CASE_PIPExTRN(A); + default: + dev_err(dev, "unknown pipe (%d)\n", num); + return; + } + __usbhsp_pipe_xxx_set(pipe, 0, reg, mask, val); +} + +static void usbhsp_pipe_tre_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct device *dev = usbhs_priv_to_dev(priv); + int num = usbhs_pipe_number(pipe); + u16 reg; + + /* + * It is impossible to calculate address, + * since PIPEnTRE addresses were mapped randomly. + */ +#define CASE_PIPExTRE(a) \ + case 0x ## a: \ + reg = PIPE ## a ## TRE; \ + break; + + switch (num) { + CASE_PIPExTRE(1); + CASE_PIPExTRE(2); + CASE_PIPExTRE(3); + CASE_PIPExTRE(4); + CASE_PIPExTRE(5); + CASE_PIPExTRE(B); + CASE_PIPExTRE(C); + CASE_PIPExTRE(D); + CASE_PIPExTRE(E); + CASE_PIPExTRE(F); + CASE_PIPExTRE(9); + CASE_PIPExTRE(A); + default: + dev_err(dev, "unknown pipe (%d)\n", num); + return; + } + + __usbhsp_pipe_xxx_set(pipe, 0, reg, mask, val); +} + +/* + * PIPEBUF + */ +static void usbhsp_pipe_buf_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{ + if (usbhs_pipe_is_dcp(pipe)) + return; + + __usbhsp_pipe_xxx_set(pipe, 0, PIPEBUF, mask, val); +} + +/* + * DCPMAXP/PIPEMAXP + */ +static void usbhsp_pipe_maxp_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{ + __usbhsp_pipe_xxx_set(pipe, DCPMAXP, PIPEMAXP, mask, val); +} + +/* + * pipe control functions + */ +static void usbhsp_pipe_select(struct usbhs_pipe *pipe) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + + /* + * On pipe, this is necessary before + * accesses to below registers. + * + * PIPESEL : usbhsp_pipe_select + * PIPECFG : usbhsp_pipe_cfg_xxx + * PIPEBUF : usbhsp_pipe_buf_xxx + * PIPEMAXP : usbhsp_pipe_maxp_xxx + * PIPEPERI + */ + + /* + * if pipe is dcp, no pipe is selected. + * it is no problem, because dcp have its register + */ + usbhs_write(priv, PIPESEL, 0xF & usbhs_pipe_number(pipe)); +} + +static int usbhsp_pipe_barrier(struct usbhs_pipe *pipe) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + int timeout = 1024; + u16 mask = usbhs_mod_is_host(priv) ? (CSSTS | PID_MASK) : PID_MASK; + + /* + * make sure.... + * + * Modify these bits when CSSTS = 0, PID = NAK, and no pipe number is + * specified by the CURPIPE bits. + * When changing the setting of this bit after changing + * the PID bits for the selected pipe from BUF to NAK, + * check that CSSTS = 0 and PBUSY = 0. + */ + + /* + * CURPIPE bit = 0 + * + * see also + * "Operation" + * - "Pipe Control" + * - "Pipe Control Registers Switching Procedure" + */ + usbhs_write(priv, CFIFOSEL, 0); + usbhs_pipe_disable(pipe); + + do { + if (!(usbhsp_pipectrl_get(pipe) & mask)) + return 0; + + udelay(10); + + } while (timeout--); + + return -EBUSY; +} + +int usbhs_pipe_is_accessible(struct usbhs_pipe *pipe) +{ + u16 val; + + val = usbhsp_pipectrl_get(pipe); + if (val & BSTS) + return 0; + + return -EBUSY; +} + +bool usbhs_pipe_contains_transmittable_data(struct usbhs_pipe *pipe) +{ + u16 val; + + /* Do not support for DCP pipe */ + if (usbhs_pipe_is_dcp(pipe)) + return false; + + val = usbhsp_pipectrl_get(pipe); + if (val & INBUFM) + return true; + + return false; +} + +/* + * PID ctrl + */ +static void __usbhsp_pid_try_nak_if_stall(struct usbhs_pipe *pipe) +{ + u16 pid = usbhsp_pipectrl_get(pipe); + + pid &= PID_MASK; + + /* + * see + * "Pipe n Control Register" - "PID" + */ + switch (pid) { + case PID_STALL11: + usbhsp_pipectrl_set(pipe, PID_MASK, PID_STALL10); + fallthrough; + case PID_STALL10: + usbhsp_pipectrl_set(pipe, PID_MASK, PID_NAK); + } +} + +void usbhs_pipe_disable(struct usbhs_pipe *pipe) +{ + int timeout = 1024; + u16 val; + + /* see "Pipe n Control Register" - "PID" */ + __usbhsp_pid_try_nak_if_stall(pipe); + + usbhsp_pipectrl_set(pipe, PID_MASK, PID_NAK); + + do { + val = usbhsp_pipectrl_get(pipe); + val &= PBUSY; + if (!val) + break; + + udelay(10); + } while (timeout--); +} + +void usbhs_pipe_enable(struct usbhs_pipe *pipe) +{ + /* see "Pipe n Control Register" - "PID" */ + __usbhsp_pid_try_nak_if_stall(pipe); + + usbhsp_pipectrl_set(pipe, PID_MASK, PID_BUF); +} + +void usbhs_pipe_stall(struct usbhs_pipe *pipe) +{ + u16 pid = usbhsp_pipectrl_get(pipe); + + pid &= PID_MASK; + + /* + * see + * "Pipe n Control Register" - "PID" + */ + switch (pid) { + case PID_NAK: + usbhsp_pipectrl_set(pipe, PID_MASK, PID_STALL10); + break; + case PID_BUF: + usbhsp_pipectrl_set(pipe, PID_MASK, PID_STALL11); + break; + } +} + +int usbhs_pipe_is_stall(struct usbhs_pipe *pipe) +{ + u16 pid = usbhsp_pipectrl_get(pipe) & PID_MASK; + + return (int)(pid == PID_STALL10 || pid == PID_STALL11); +} + +void usbhs_pipe_set_trans_count_if_bulk(struct usbhs_pipe *pipe, int len) +{ + if (!usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_BULK)) + return; + + /* + * clear and disable transfer counter for IN/OUT pipe + */ + usbhsp_pipe_tre_set(pipe, TRCLR | TRENB, TRCLR); + + /* + * Only IN direction bulk pipe can use transfer count. + * Without using this function, + * received data will break if it was large data size. + * see PIPEnTRN/PIPEnTRE for detail + */ + if (usbhs_pipe_is_dir_in(pipe)) { + int maxp = usbhs_pipe_get_maxpacket(pipe); + + usbhsp_pipe_trn_set(pipe, 0xffff, DIV_ROUND_UP(len, maxp)); + usbhsp_pipe_tre_set(pipe, TRENB, TRENB); /* enable */ + } +} + + +/* + * pipe setup + */ +static int usbhsp_setup_pipecfg(struct usbhs_pipe *pipe, int is_host, + int dir_in, u16 *pipecfg) +{ + u16 type = 0; + u16 bfre = 0; + u16 dblb = 0; + u16 cntmd = 0; + u16 dir = 0; + u16 epnum = 0; + u16 shtnak = 0; + static const u16 type_array[] = { + [USB_ENDPOINT_XFER_BULK] = TYPE_BULK, + [USB_ENDPOINT_XFER_INT] = TYPE_INT, + [USB_ENDPOINT_XFER_ISOC] = TYPE_ISO, + }; + + if (usbhs_pipe_is_dcp(pipe)) + return -EINVAL; + + /* + * PIPECFG + * + * see + * - "Register Descriptions" - "PIPECFG" register + * - "Features" - "Pipe configuration" + * - "Operation" - "Pipe Control" + */ + + /* TYPE */ + type = type_array[usbhs_pipe_type(pipe)]; + + /* BFRE */ + if (usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_ISOC) || + usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_BULK)) + bfre = 0; /* FIXME */ + + /* DBLB: see usbhs_pipe_config_update() */ + + /* CNTMD */ + if (usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_BULK)) + cntmd = 0; /* FIXME */ + + /* DIR */ + if (dir_in) + usbhsp_flags_set(pipe, IS_DIR_HOST); + + if (!!is_host ^ !!dir_in) + dir |= DIR_OUT; + + if (!dir) + usbhsp_flags_set(pipe, IS_DIR_IN); + + /* SHTNAK */ + if (usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_BULK) && + !dir) + shtnak = SHTNAK; + + /* EPNUM */ + epnum = 0; /* see usbhs_pipe_config_update() */ + *pipecfg = type | + bfre | + dblb | + cntmd | + dir | + shtnak | + epnum; + return 0; +} + +static u16 usbhsp_setup_pipebuff(struct usbhs_pipe *pipe) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + struct device *dev = usbhs_priv_to_dev(priv); + int pipe_num = usbhs_pipe_number(pipe); + u16 buff_size; + u16 bufnmb; + u16 bufnmb_cnt; + struct renesas_usbhs_driver_pipe_config *pipe_config = + usbhsp_get_pipe_config(priv, pipe_num); + + /* + * PIPEBUF + * + * see + * - "Register Descriptions" - "PIPEBUF" register + * - "Features" - "Pipe configuration" + * - "Operation" - "FIFO Buffer Memory" + * - "Operation" - "Pipe Control" + */ + buff_size = pipe_config->bufsize; + bufnmb = pipe_config->bufnum; + + /* change buff_size to register value */ + bufnmb_cnt = (buff_size / 64) - 1; + + dev_dbg(dev, "pipe : %d : buff_size 0x%x: bufnmb 0x%x\n", + pipe_num, buff_size, bufnmb); + + return (0x1f & bufnmb_cnt) << 10 | + (0xff & bufnmb) << 0; +} + +void usbhs_pipe_config_update(struct usbhs_pipe *pipe, u16 devsel, + u16 epnum, u16 maxp) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + int pipe_num = usbhs_pipe_number(pipe); + struct renesas_usbhs_driver_pipe_config *pipe_config = + usbhsp_get_pipe_config(priv, pipe_num); + u16 dblb = pipe_config->double_buf ? DBLB : 0; + + if (devsel > 0xA) { + struct device *dev = usbhs_priv_to_dev(priv); + + dev_err(dev, "devsel error %d\n", devsel); + + devsel = 0; + } + + usbhsp_pipe_barrier(pipe); + + pipe->maxp = maxp; + + usbhsp_pipe_select(pipe); + usbhsp_pipe_maxp_set(pipe, 0xFFFF, + (devsel << 12) | + maxp); + + if (!usbhs_pipe_is_dcp(pipe)) + usbhsp_pipe_cfg_set(pipe, 0x000F | DBLB, epnum | dblb); +} + +/* + * pipe control + */ +int usbhs_pipe_get_maxpacket(struct usbhs_pipe *pipe) +{ + /* + * see + * usbhs_pipe_config_update() + * usbhs_dcp_malloc() + */ + return pipe->maxp; +} + +int usbhs_pipe_is_dir_in(struct usbhs_pipe *pipe) +{ + return usbhsp_flags_has(pipe, IS_DIR_IN); +} + +int usbhs_pipe_is_dir_host(struct usbhs_pipe *pipe) +{ + return usbhsp_flags_has(pipe, IS_DIR_HOST); +} + +int usbhs_pipe_is_running(struct usbhs_pipe *pipe) +{ + return usbhsp_flags_has(pipe, IS_RUNNING); +} + +void usbhs_pipe_running(struct usbhs_pipe *pipe, int running) +{ + if (running) + usbhsp_flags_set(pipe, IS_RUNNING); + else + usbhsp_flags_clr(pipe, IS_RUNNING); +} + +void usbhs_pipe_data_sequence(struct usbhs_pipe *pipe, int sequence) +{ + u16 mask = (SQCLR | SQSET); + u16 val; + + /* + * sequence + * 0 : data0 + * 1 : data1 + * -1 : no change + */ + switch (sequence) { + case 0: + val = SQCLR; + break; + case 1: + val = SQSET; + break; + default: + return; + } + + usbhsp_pipectrl_set(pipe, mask, val); +} + +static int usbhs_pipe_get_data_sequence(struct usbhs_pipe *pipe) +{ + return !!(usbhsp_pipectrl_get(pipe) & SQMON); +} + +void usbhs_pipe_clear(struct usbhs_pipe *pipe) +{ + if (usbhs_pipe_is_dcp(pipe)) { + usbhs_fifo_clear_dcp(pipe); + } else { + usbhsp_pipectrl_set(pipe, ACLRM, ACLRM); + usbhsp_pipectrl_set(pipe, ACLRM, 0); + } +} + +/* Should call usbhsp_pipe_select() before */ +void usbhs_pipe_clear_without_sequence(struct usbhs_pipe *pipe, + int needs_bfre, int bfre_enable) +{ + int sequence; + + usbhsp_pipe_select(pipe); + sequence = usbhs_pipe_get_data_sequence(pipe); + if (needs_bfre) + usbhsp_pipe_cfg_set(pipe, BFRE, bfre_enable ? BFRE : 0); + usbhs_pipe_clear(pipe); + usbhs_pipe_data_sequence(pipe, sequence); +} + +void usbhs_pipe_config_change_bfre(struct usbhs_pipe *pipe, int enable) +{ + if (usbhs_pipe_is_dcp(pipe)) + return; + + usbhsp_pipe_select(pipe); + /* check if the driver needs to change the BFRE value */ + if (!(enable ^ !!(usbhsp_pipe_cfg_get(pipe) & BFRE))) + return; + + usbhs_pipe_clear_without_sequence(pipe, 1, enable); +} + +static struct usbhs_pipe *usbhsp_get_pipe(struct usbhs_priv *priv, u32 type) +{ + struct usbhs_pipe *pos, *pipe; + int i; + + /* + * find target pipe + */ + pipe = NULL; + usbhs_for_each_pipe_with_dcp(pos, priv, i) { + if (!usbhs_pipe_type_is(pos, type)) + continue; + if (usbhsp_flags_has(pos, IS_USED)) + continue; + + pipe = pos; + break; + } + + if (!pipe) + return NULL; + + /* + * initialize pipe flags + */ + usbhsp_flags_init(pipe); + usbhsp_flags_set(pipe, IS_USED); + + return pipe; +} + +static void usbhsp_put_pipe(struct usbhs_pipe *pipe) +{ + usbhsp_flags_init(pipe); +} + +void usbhs_pipe_init(struct usbhs_priv *priv, + int (*dma_map_ctrl)(struct usbhs_pkt *pkt, int map)) +{ + struct usbhs_pipe_info *info = usbhs_priv_to_pipeinfo(priv); + struct usbhs_pipe *pipe; + int i; + + usbhs_for_each_pipe_with_dcp(pipe, priv, i) { + usbhsp_flags_init(pipe); + pipe->fifo = NULL; + pipe->mod_private = NULL; + INIT_LIST_HEAD(&pipe->list); + + /* pipe force init */ + usbhs_pipe_clear(pipe); + } + + info->dma_map_ctrl = dma_map_ctrl; +} + +struct usbhs_pipe *usbhs_pipe_malloc(struct usbhs_priv *priv, + int endpoint_type, + int dir_in) +{ + struct device *dev = usbhs_priv_to_dev(priv); + struct usbhs_pipe *pipe; + int is_host = usbhs_mod_is_host(priv); + int ret; + u16 pipecfg, pipebuf; + + pipe = usbhsp_get_pipe(priv, endpoint_type); + if (!pipe) { + dev_err(dev, "can't get pipe (%s)\n", + usbhsp_pipe_name[endpoint_type]); + return NULL; + } + + INIT_LIST_HEAD(&pipe->list); + + usbhs_pipe_disable(pipe); + + /* make sure pipe is not busy */ + ret = usbhsp_pipe_barrier(pipe); + if (ret < 0) { + dev_err(dev, "pipe setup failed %d\n", usbhs_pipe_number(pipe)); + return NULL; + } + + if (usbhsp_setup_pipecfg(pipe, is_host, dir_in, &pipecfg)) { + dev_err(dev, "can't setup pipe\n"); + return NULL; + } + + pipebuf = usbhsp_setup_pipebuff(pipe); + + usbhsp_pipe_select(pipe); + usbhsp_pipe_cfg_set(pipe, 0xFFFF, pipecfg); + usbhsp_pipe_buf_set(pipe, 0xFFFF, pipebuf); + usbhs_pipe_clear(pipe); + + usbhs_pipe_sequence_data0(pipe); + + dev_dbg(dev, "enable pipe %d : %s (%s)\n", + usbhs_pipe_number(pipe), + usbhs_pipe_name(pipe), + usbhs_pipe_is_dir_in(pipe) ? "in" : "out"); + + /* + * epnum / maxp are still not set to this pipe. + * call usbhs_pipe_config_update() after this function !! + */ + + return pipe; +} + +void usbhs_pipe_free(struct usbhs_pipe *pipe) +{ + usbhsp_pipe_select(pipe); + usbhsp_pipe_cfg_set(pipe, 0xFFFF, 0); + usbhsp_put_pipe(pipe); +} + +void usbhs_pipe_select_fifo(struct usbhs_pipe *pipe, struct usbhs_fifo *fifo) +{ + if (pipe->fifo) + pipe->fifo->pipe = NULL; + + pipe->fifo = fifo; + + if (fifo) + fifo->pipe = pipe; +} + + +/* + * dcp control + */ +struct usbhs_pipe *usbhs_dcp_malloc(struct usbhs_priv *priv) +{ + struct usbhs_pipe *pipe; + + pipe = usbhsp_get_pipe(priv, USB_ENDPOINT_XFER_CONTROL); + if (!pipe) + return NULL; + + INIT_LIST_HEAD(&pipe->list); + + /* + * call usbhs_pipe_config_update() after this function !! + */ + + return pipe; +} + +void usbhs_dcp_control_transfer_done(struct usbhs_pipe *pipe) +{ + struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); + + WARN_ON(!usbhs_pipe_is_dcp(pipe)); + + usbhs_pipe_enable(pipe); + + if (!usbhs_mod_is_host(priv)) /* funconly */ + usbhsp_pipectrl_set(pipe, CCPL, CCPL); +} + +void usbhs_dcp_dir_for_host(struct usbhs_pipe *pipe, int dir_out) +{ + usbhsp_pipe_cfg_set(pipe, DIR_OUT, + dir_out ? DIR_OUT : 0); +} + +/* + * pipe module function + */ +int usbhs_pipe_probe(struct usbhs_priv *priv) +{ + struct usbhs_pipe_info *info = usbhs_priv_to_pipeinfo(priv); + struct usbhs_pipe *pipe; + struct device *dev = usbhs_priv_to_dev(priv); + struct renesas_usbhs_driver_pipe_config *pipe_configs = + usbhs_get_dparam(priv, pipe_configs); + int pipe_size = usbhs_get_dparam(priv, pipe_size); + int i; + + /* This driver expects 1st pipe is DCP */ + if (pipe_configs[0].type != USB_ENDPOINT_XFER_CONTROL) { + dev_err(dev, "1st PIPE is not DCP\n"); + return -EINVAL; + } + + info->pipe = kcalloc(pipe_size, sizeof(struct usbhs_pipe), + GFP_KERNEL); + if (!info->pipe) + return -ENOMEM; + + info->size = pipe_size; + + /* + * init pipe + */ + usbhs_for_each_pipe_with_dcp(pipe, priv, i) { + pipe->priv = priv; + + usbhs_pipe_type(pipe) = + pipe_configs[i].type & USB_ENDPOINT_XFERTYPE_MASK; + + dev_dbg(dev, "pipe %x\t: %s\n", + i, usbhsp_pipe_name[pipe_configs[i].type]); + } + + return 0; +} + +void usbhs_pipe_remove(struct usbhs_priv *priv) +{ + struct usbhs_pipe_info *info = usbhs_priv_to_pipeinfo(priv); + + kfree(info->pipe); +} diff --git a/drivers/usb/gadget/rcar/pipe.h b/drivers/usb/gadget/rcar/pipe.h new file mode 100644 index 00000000000..01c15178a28 --- /dev/null +++ b/drivers/usb/gadget/rcar/pipe.h @@ -0,0 +1,114 @@ +// SPDX-License-Identifier: GPL-1.0+ +/* + * Renesas USB driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + */ +#ifndef RENESAS_USB_PIPE_H +#define RENESAS_USB_PIPE_H + +#include "common.h" +#include "fifo.h" + +/* + * struct + */ +struct usbhs_pipe { + u32 pipe_type; /* USB_ENDPOINT_XFER_xxx */ + + struct usbhs_priv *priv; + struct usbhs_fifo *fifo; + struct list_head list; + + int maxp; + + u32 flags; +#define USBHS_PIPE_FLAGS_IS_USED (1 << 0) +#define USBHS_PIPE_FLAGS_IS_DIR_IN (1 << 1) +#define USBHS_PIPE_FLAGS_IS_DIR_HOST (1 << 2) +#define USBHS_PIPE_FLAGS_IS_RUNNING (1 << 3) + + const struct usbhs_pkt_handle *handler; + + void *mod_private; +}; + +struct usbhs_pipe_info { + struct usbhs_pipe *pipe; + int size; /* array size of "pipe" */ + + int (*dma_map_ctrl)(struct usbhs_pkt *pkt, int map); +}; + +/* + * pipe list + */ +#define __usbhs_for_each_pipe(start, pos, info, i) \ + for ((i) = start; \ + ((i) < (info)->size) && ((pos) = (info)->pipe + (i)); \ + (i)++) + +#define usbhs_for_each_pipe(pos, priv, i) \ + __usbhs_for_each_pipe(1, pos, &((priv)->pipe_info), i) + +#define usbhs_for_each_pipe_with_dcp(pos, priv, i) \ + __usbhs_for_each_pipe(0, pos, &((priv)->pipe_info), i) + +/* + * data + */ +#define usbhs_priv_to_pipeinfo(pr) (&(pr)->pipe_info) + +/* + * pipe control + */ +char *usbhs_pipe_name(struct usbhs_pipe *pipe); +struct usbhs_pipe +*usbhs_pipe_malloc(struct usbhs_priv *priv, int endpoint_type, int dir_in); +void usbhs_pipe_free(struct usbhs_pipe *pipe); +int usbhs_pipe_probe(struct usbhs_priv *priv); +void usbhs_pipe_remove(struct usbhs_priv *priv); +int usbhs_pipe_is_dir_in(struct usbhs_pipe *pipe); +int usbhs_pipe_is_dir_host(struct usbhs_pipe *pipe); +int usbhs_pipe_is_running(struct usbhs_pipe *pipe); +void usbhs_pipe_running(struct usbhs_pipe *pipe, int running); + +void usbhs_pipe_init(struct usbhs_priv *priv, + int (*dma_map_ctrl)(struct usbhs_pkt *pkt, int map)); +int usbhs_pipe_get_maxpacket(struct usbhs_pipe *pipe); +void usbhs_pipe_clear(struct usbhs_pipe *pipe); +void usbhs_pipe_clear_without_sequence(struct usbhs_pipe *pipe, + int needs_bfre, int bfre_enable); +int usbhs_pipe_is_accessible(struct usbhs_pipe *pipe); +void usbhs_pipe_enable(struct usbhs_pipe *pipe); +void usbhs_pipe_disable(struct usbhs_pipe *pipe); +void usbhs_pipe_stall(struct usbhs_pipe *pipe); +int usbhs_pipe_is_stall(struct usbhs_pipe *pipe); +void usbhs_pipe_set_trans_count_if_bulk(struct usbhs_pipe *pipe, int len); +void usbhs_pipe_select_fifo(struct usbhs_pipe *pipe, struct usbhs_fifo *fifo); +void usbhs_pipe_config_update(struct usbhs_pipe *pipe, u16 devsel, + u16 epnum, u16 maxp); +void usbhs_pipe_config_change_bfre(struct usbhs_pipe *pipe, int enable); + +#define usbhs_pipe_sequence_data0(pipe) usbhs_pipe_data_sequence(pipe, 0) +#define usbhs_pipe_sequence_data1(pipe) usbhs_pipe_data_sequence(pipe, 1) +void usbhs_pipe_data_sequence(struct usbhs_pipe *pipe, int data); + +#define usbhs_pipe_to_priv(p) ((p)->priv) +#define usbhs_pipe_number(p) (int)((p) - (p)->priv->pipe_info.pipe) +#define usbhs_pipe_is_dcp(p) ((p)->priv->pipe_info.pipe == (p)) +#define usbhs_pipe_to_fifo(p) ((p)->fifo) +#define usbhs_pipe_is_busy(p) usbhs_pipe_to_fifo(p) + +#define usbhs_pipe_type(p) ((p)->pipe_type) +#define usbhs_pipe_type_is(p, t) ((p)->pipe_type == t) + +/* + * dcp control + */ +struct usbhs_pipe *usbhs_dcp_malloc(struct usbhs_priv *priv); +void usbhs_dcp_control_transfer_done(struct usbhs_pipe *pipe); +void usbhs_dcp_dir_for_host(struct usbhs_pipe *pipe, int dir_out); + +#endif /* RENESAS_USB_PIPE_H */ diff --git a/drivers/usb/gadget/rcar/renesas_usb.h b/drivers/usb/gadget/rcar/renesas_usb.h new file mode 100644 index 00000000000..8155e3dcaf6 --- /dev/null +++ b/drivers/usb/gadget/rcar/renesas_usb.h @@ -0,0 +1,125 @@ +// SPDX-License-Identifier: GPL-1.0+ +/* + * Renesas USB + * + * Copyright (C) 2011 Renesas Solutions Corp. + * Kuninori Morimoto kuninori.morimoto.gx@renesas.com + * + * Ported to u-boot + * Copyright (C) 2016 GlobalLogic + */ +#ifndef RENESAS_USB_H +#define RENESAS_USB_H + +#include <linux/usb/ch9.h> +#include <linux/compat.h> + +struct platform_device { + const char *name; + struct device dev; +}; + +/* + * module type + * + * it will be return value from get_id + */ +enum { + USBHS_HOST = 0, + USBHS_GADGET, + USBHS_MAX, +}; + +/* + * parameters for renesas usbhs + * + * some register needs USB chip specific parameters. + * This struct show it to driver + */ + +struct renesas_usbhs_driver_pipe_config { + u8 type; /* USB_ENDPOINT_XFER_xxx */ + u16 bufsize; + u8 bufnum; + bool double_buf; +}; +#define RENESAS_USBHS_PIPE(_type, _size, _num, _double_buf) { \ + .type = (_type), \ + .bufsize = (_size), \ + .bufnum = (_num), \ + .double_buf = (_double_buf), \ + } + +struct renesas_usbhs_driver_param { + /* + * pipe settings + */ + struct renesas_usbhs_driver_pipe_config *pipe_configs; + int pipe_size; /* pipe_configs array size */ + + /* + * option: + * + * for BUSWAIT :: BWAIT + * see + * renesas_usbhs/common.c :: usbhsc_set_buswait() + * */ + int buswait_bwait; + + /* + * option: + * + * delay time from notify_hotplug callback + */ + int detection_delay; /* msec */ + + /* + * option: + * + * dma id for dmaengine + * The data transfer direction on D0FIFO/D1FIFO should be + * fixed for keeping consistency. + * So, the platform id settings will be.. + * .d0_tx_id = xx_TX, + * .d1_rx_id = xx_RX, + * or + * .d1_tx_id = xx_TX, + * .d0_rx_id = xx_RX, + */ + int d0_tx_id; + int d0_rx_id; + int d1_tx_id; + int d1_rx_id; + int d2_tx_id; + int d2_rx_id; + int d3_tx_id; + int d3_rx_id; + + /* + * option: + * + * pio <--> dma border. + */ + int pio_dma_border; /* default is 64byte */ + + uintptr_t type; + u32 enable_gpio; + + /* + * option: + */ + u32 has_otg:1; /* for controlling PWEN/EXTLP */ + u32 has_sudmac:1; /* for SUDMAC */ + u32 has_usb_dmac:1; /* for USB-DMAC */ + u32 cfifo_byte_addr:1; /* CFIFO is byte addressable */ +#define USBHS_USB_DMAC_XFER_SIZE 32 /* hardcode the xfer size */ + u32 multi_clks:1; + u32 has_new_pipe_configs:1; +}; + +#define USBHS_TYPE_RCAR_GEN3 2 + +struct usbhs_priv; +struct usb_gadget *usbhsg_get_gadget(struct usbhs_priv *priv); + +#endif /* RENESAS_USB_H */
Hi Marek,
Thank you for the patch.
On lun., sept. 09, 2024 at 01:06, Marek Vasut marek.vasut+renesas@mailbox.org wrote:
From: Vitaliy Vasylskyy vitaliy.vasylskyy@globallogic.com
Add UDC driver for Renesas USBHS controller found in R-Car Gen3 SoCs. This is mostly ported from the Linux kernel, with additional porting glue. The code has been synchronized with 1b4861e32e46 ("Linux 6.9.3") and cleaned up and ported to DM since the original implementation by Vitaliy.
Signed-off-by: Vitaliy Vasylskyy vitaliy.vasylskyy@globallogic.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org
I already did the comparison with the linux driver in v1: https://lore.kernel.org/r/all/87jzhcpi9z.fsf@baylibre.com/
The diff between v1 and v2 looks good to me as well, so
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
Note that the driver does have a few checkpatch warnings in it, those also partly come from Linux.
Cc: Jonas Karlman jonas@kwiboo.se Cc: Lukasz Majewski lukma@denx.de Cc: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Miquel Raynal miquel.raynal@bootlin.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Vitaliy Vasylskyy vitaliy.vasylskyy@globallogic.com
V2: Drop CONFIG_USB_RENESAS_USBHS_UDC check
drivers/usb/gadget/Kconfig | 9 + drivers/usb/gadget/Makefile | 1 + drivers/usb/gadget/rcar/Makefile | 8 + drivers/usb/gadget/rcar/common.c | 478 +++++++++++ drivers/usb/gadget/rcar/common.h | 328 +++++++ drivers/usb/gadget/rcar/fifo.c | 1067 +++++++++++++++++++++++ drivers/usb/gadget/rcar/fifo.h | 114 +++ drivers/usb/gadget/rcar/mod.c | 345 ++++++++ drivers/usb/gadget/rcar/mod.h | 161 ++++ drivers/usb/gadget/rcar/mod_gadget.c | 1136 +++++++++++++++++++++++++ drivers/usb/gadget/rcar/pipe.c | 849 ++++++++++++++++++ drivers/usb/gadget/rcar/pipe.h | 114 +++ drivers/usb/gadget/rcar/renesas_usb.h | 125 +++ 13 files changed, 4735 insertions(+) create mode 100644 drivers/usb/gadget/rcar/Makefile create mode 100644 drivers/usb/gadget/rcar/common.c create mode 100644 drivers/usb/gadget/rcar/common.h create mode 100644 drivers/usb/gadget/rcar/fifo.c create mode 100644 drivers/usb/gadget/rcar/fifo.h create mode 100644 drivers/usb/gadget/rcar/mod.c create mode 100644 drivers/usb/gadget/rcar/mod.h create mode 100644 drivers/usb/gadget/rcar/mod_gadget.c create mode 100644 drivers/usb/gadget/rcar/pipe.c create mode 100644 drivers/usb/gadget/rcar/pipe.h create mode 100644 drivers/usb/gadget/rcar/renesas_usb.h
diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 4621a6fd5e6..5fb73890c78 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -114,6 +114,15 @@ config USB_GADGET_DWC2_OTG driver to operate in Peripheral mode. This option requires USB_GADGET to be enabled.
+config USB_RENESAS_USBHS
- bool "Renesas RCar USB2.0 HS controller (gadget mode)"
- select USB_GADGET_DUALSPEED
- help
The Renesas Rcar USB 2.0 high-speed gadget controller
integrated into Salvator and Kingfisher boards. Select this
option if you want the driver to operate in Peripheral mode.
if USB_GADGET_DWC2_OTG
config USB_GADGET_DWC2_OTG_PHY diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 6abcce0d9c7..da76b6524de 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -21,6 +21,7 @@ obj-$(CONFIG_USB_GADGET_BCM_UDC_OTG_PHY) += bcm_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_DWC2_OTG) += dwc2_udc_otg.o obj-$(CONFIG_USB_GADGET_DWC2_OTG_PHY) += dwc2_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_MAX3420) += max3420_udc.o +obj-$(CONFIG_USB_RENESAS_USBHS) += rcar/ ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o diff --git a/drivers/usb/gadget/rcar/Makefile b/drivers/usb/gadget/rcar/Makefile new file mode 100644 index 00000000000..676f39c8e24 --- /dev/null +++ b/drivers/usb/gadget/rcar/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0
+obj-$(CONFIG_USB_RENESAS_USBHS) += \
- common.o \
- fifo.o \
- mod.o \
- mod_gadget.o \
- pipe.o
diff --git a/drivers/usb/gadget/rcar/common.c b/drivers/usb/gadget/rcar/common.c new file mode 100644 index 00000000000..2ba022a3f2c --- /dev/null +++ b/drivers/usb/gadget/rcar/common.c @@ -0,0 +1,478 @@ +// SPDX-License-Identifier: GPL-1.0+ +/*
- Renesas USB driver
- Copyright (C) 2011 Renesas Solutions Corp.
- Copyright (C) 2019 Renesas Electronics Corporation
- Kuninori Morimoto kuninori.morimoto.gx@renesas.com
+#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <errno.h> +#include <generic-phy.h> +#include <linux/err.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <usb.h>
image of renesas_usbhs
- ex) gadget case
- mod.c
- mod_gadget.c
- mod_host.c pipe.c fifo.c
| pipe0 |------>| fifo pio |
- | mod_gadget |=====> | pipe1 |--+
| pipe2 | | +-| fifo dma0 |
- | mod_host | | pipe3 |<-|--+
| .... | +--->| fifo dma1 |
common functions
+u16 usbhs_read(struct usbhs_priv *priv, u32 reg) +{
- return ioread16(priv->base + reg);
+void usbhs_write(struct usbhs_priv *priv, u32 reg, u16 data) +{
- iowrite16(data, priv->base + reg);
+void usbhs_bset(struct usbhs_priv *priv, u32 reg, u16 mask, u16 data) +{
- u16 val = usbhs_read(priv, reg);
- val &= ~mask;
- val |= data & mask;
- usbhs_write(priv, reg, val);
syscfg functions
+static void usbhs_sys_clock_ctrl(struct usbhs_priv *priv, int enable) +{
- usbhs_bset(priv, SYSCFG, SCKE, enable ? SCKE : 0);
+void usbhs_sys_host_ctrl(struct usbhs_priv *priv, int enable) +{
- u16 mask = DCFM | DRPD | DPRPU | HSE | USBE;
- u16 val = DCFM | DRPD | HSE | USBE;
* if enable
* - select Host mode
* - D+ Line/D- Line Pull-down
- usbhs_bset(priv, SYSCFG, mask, enable ? val : 0);
+void usbhs_sys_function_ctrl(struct usbhs_priv *priv, int enable) +{
- u16 val = HSE | USBE;
* if enable
* - select Function mode
* - D+ Line Pull-up is disabled
* When D+ Line Pull-up is enabled,
* calling usbhs_sys_function_pullup(,1)
+void usbhs_sys_function_pullup(struct usbhs_priv *priv, int enable) +{
- usbhs_bset(priv, SYSCFG, DPRPU, enable ? DPRPU : 0);
+void usbhs_sys_set_test_mode(struct usbhs_priv *priv, u16 mode) +{
- usbhs_write(priv, TESTMODE, mode);
frame functions
+int usbhs_frame_get_num(struct usbhs_priv *priv) +{
- return usbhs_read(priv, FRMNUM) & FRNM_MASK;
usb request functions
+void usbhs_usbreq_get_val(struct usbhs_priv *priv, struct usb_ctrlrequest *req) +{
- u16 val;
- val = usbhs_read(priv, USBREQ);
- req->bRequest = (val >> 8) & 0xFF;
- req->bRequestType = (val >> 0) & 0xFF;
- req->wValue = cpu_to_le16(usbhs_read(priv, USBVAL));
- req->wIndex = cpu_to_le16(usbhs_read(priv, USBINDX));
- req->wLength = cpu_to_le16(usbhs_read(priv, USBLENG));
+void usbhs_usbreq_set_val(struct usbhs_priv *priv, struct usb_ctrlrequest *req) +{
- usbhs_write(priv, USBREQ, (req->bRequest << 8) | req->bRequestType);
- usbhs_write(priv, USBVAL, le16_to_cpu(req->wValue));
- usbhs_write(priv, USBINDX, le16_to_cpu(req->wIndex));
- usbhs_write(priv, USBLENG, le16_to_cpu(req->wLength));
- usbhs_bset(priv, DCPCTR, SUREQ, SUREQ);
bus/vbus functions
+void usbhs_bus_send_sof_enable(struct usbhs_priv *priv) +{
- u16 status = usbhs_read(priv, DVSTCTR) & (USBRST | UACT);
- if (status != USBRST) {
dev_err(dev, "usbhs should be reset\n");
- usbhs_bset(priv, DVSTCTR, (USBRST | UACT), UACT);
+void usbhs_bus_send_reset(struct usbhs_priv *priv) +{
- usbhs_bset(priv, DVSTCTR, (USBRST | UACT), USBRST);
+int usbhs_bus_get_speed(struct usbhs_priv *priv) +{
- u16 dvstctr = usbhs_read(priv, DVSTCTR);
- switch (RHST & dvstctr) {
- case RHST_LOW_SPEED:
return USB_SPEED_LOW;
- case RHST_FULL_SPEED:
return USB_SPEED_FULL;
- case RHST_HIGH_SPEED:
return USB_SPEED_HIGH;
- return USB_SPEED_UNKNOWN;
+static void usbhsc_bus_init(struct usbhs_priv *priv) +{
- usbhs_write(priv, DVSTCTR, 0);
device configuration
+int usbhs_set_device_config(struct usbhs_priv *priv, int devnum,
u16 upphub, u16 hubport, u16 speed)
- struct device *dev = usbhs_priv_to_dev(priv);
- u16 usbspd = 0;
- u32 reg = DEVADD0 + (2 * devnum);
- if (devnum > 10) {
dev_err(dev, "cannot set speed to unknown device %d\n", devnum);
return -EIO;
- if (upphub > 0xA) {
dev_err(dev, "unsupported hub number %d\n", upphub);
return -EIO;
- switch (speed) {
- case USB_SPEED_LOW:
usbspd = USBSPD_SPEED_LOW;
break;
- case USB_SPEED_FULL:
usbspd = USBSPD_SPEED_FULL;
break;
- case USB_SPEED_HIGH:
usbspd = USBSPD_SPEED_HIGH;
break;
- default:
dev_err(dev, "unsupported speed %d\n", speed);
return -EIO;
- usbhs_write(priv, reg, UPPHUB(upphub) |
HUBPORT(hubport)|
USBSPD(usbspd));
interrupt functions
+void usbhs_xxxsts_clear(struct usbhs_priv *priv, u16 sts_reg, u16 bit) +{
- u16 pipe_mask = (u16)GENMASK(usbhs_get_dparam(priv, pipe_size), 0);
- usbhs_write(priv, sts_reg, ~(1 << bit) & pipe_mask);
local functions
+static void usbhsc_set_buswait(struct usbhs_priv *priv) +{
- int wait = usbhs_get_dparam(priv, buswait_bwait);
- /* set bus wait if platform have */
- if (wait)
usbhs_bset(priv, BUSWAIT, 0x000F, wait);
platform default param
+/* commonly used on newer SH-Mobile and R-Car SoCs */ +static struct renesas_usbhs_driver_pipe_config usbhsc_new_pipe[] = {
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_CONTROL, 64, 0x00, false),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_ISOC, 1024, 0x08, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_ISOC, 1024, 0x28, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x48, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x58, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x68, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_INT, 64, 0x04, false),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_INT, 64, 0x05, false),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_INT, 64, 0x06, false),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x78, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x88, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0x98, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0xa8, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0xb8, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0xc8, true),
- RENESAS_USBHS_PIPE(USB_ENDPOINT_XFER_BULK, 512, 0xd8, true),
+#define LPSTS 0x102 +#define LPSTS_SUSPM BIT(14)
+#define UGCTRL2 0x184 +#define UGCTRL2_RESERVED_3 BIT(0) +#define UGCTRL2_USB0SEL_EHCI 0x10 +#define UGCTRL2_USB0SEL_HSUSB 0x20 +#define UGCTRL2_USB0SEL_OTG 0x30 +#define UGCTRL2_USB0SEL_MASK 0x30 +#define UGCTRL2_VBUSSEL BIT(10)
+struct usbhs_priv_otg_data {
- void __iomem *base;
- void __iomem *phybase;
- struct platform_device usbhs_dev;
- struct usbhs_priv usbhs_priv;
- struct phy phy;
+static int usbhs_rcar3_power_ctrl(struct usbhs_priv *priv, bool enable) +{
- if (enable) {
writel(UGCTRL2_USB0SEL_OTG | UGCTRL2_VBUSSEL | UGCTRL2_RESERVED_3,
priv->base + UGCTRL2);
usbhs_bset(priv, LPSTS, LPSTS_SUSPM, LPSTS_SUSPM);
/* The controller on R-Car Gen3 needs to wait up to 90 usec */
udelay(90);
usbhs_sys_clock_ctrl(priv, enable);
- } else {
usbhs_bset(priv, LPSTS, LPSTS_SUSPM, 0);
+void usbhsc_hotplug(struct usbhs_priv *priv) +{
- int ret;
- ret = usbhs_mod_change(priv, USBHS_GADGET);
- if (ret < 0)
return;
- usbhs_rcar3_power_ctrl(priv, true);
- /* bus init */
- usbhsc_set_buswait(priv);
- usbhsc_bus_init(priv);
- /* module start */
- usbhs_mod_call(priv, start, priv);
+#define USB2_OBINTSTA 0x604 +#define USB2_OBINT_SESSVLDCHG BIT(12) +#define USB2_OBINT_IDDIGCHG BIT(11)
+static int usbhs_udc_otg_gadget_handle_interrupts(struct udevice *dev) +{
- struct usbhs_priv_otg_data *priv = dev_get_priv(dev);
- const u32 status = readl(priv->phybase + USB2_OBINTSTA);
- /* We don't have a good way to forward IRQ to PHY yet */
- if (status & (USB2_OBINT_SESSVLDCHG | USB2_OBINT_IDDIGCHG)) {
writel(USB2_OBINT_SESSVLDCHG | USB2_OBINT_IDDIGCHG,
generic_phy_set_mode(&priv->phy, PHY_MODE_USB_OTG, 0);
- usbhs_interrupt(0, &priv->usbhs_priv);
+static int usbhs_probe(struct usbhs_priv *priv) +{
- int ret;
- priv->dparam.type = USBHS_TYPE_RCAR_GEN3;
- priv->dparam.pio_dma_border = 64;
- priv->dparam.pipe_configs = usbhsc_new_pipe;
- priv->dparam.pipe_size = ARRAY_SIZE(usbhsc_new_pipe);
- /* call pipe and module init */
- ret = usbhs_pipe_probe(priv);
- if (ret < 0)
return ret;
- ret = usbhs_fifo_probe(priv);
- if (ret < 0)
goto probe_end_pipe_exit;
- ret = usbhs_mod_probe(priv);
- if (ret < 0)
goto probe_end_fifo_exit;
- usbhs_sys_clock_ctrl(priv, 0);
- usbhs_mod_autonomy_mode(priv);
- usbhsc_hotplug(priv);
- return ret;
+probe_end_fifo_exit:
- usbhs_fifo_remove(priv);
+probe_end_pipe_exit:
- usbhs_pipe_remove(priv);
- return ret;
+static int usbhs_udc_otg_probe(struct udevice *dev) +{
- struct usb_gadget *gadget;
- struct clk_bulk clk_bulk;
- int ret = -EINVAL;
- priv->base = dev_read_addr_ptr(dev);
- if (!priv->base)
return -EINVAL;
- ret = clk_get_bulk(dev, &clk_bulk);
- if (ret)
return ret;
- ret = clk_enable_bulk(&clk_bulk);
- if (ret)
return ret;
- clrsetbits_le32(priv->base + UGCTRL2, UGCTRL2_USB0SEL_MASK, UGCTRL2_USB0SEL_EHCI);
- clrsetbits_le16(priv->base + LPSTS, LPSTS_SUSPM, LPSTS_SUSPM);
- ret = generic_setup_phy(dev, &priv->phy, 0, PHY_MODE_USB_OTG, 1);
- if (ret)
goto err_clk;
- priv->phybase = dev_read_addr_ptr(priv->phy.dev);
- priv->usbhs_priv.pdev = &priv->usbhs_dev;
- priv->usbhs_priv.base = priv->base;
- priv->usbhs_dev.dev.driver_data = &priv->usbhs_priv;
- ret = usbhs_probe(&priv->usbhs_priv);
- if (ret < 0)
goto err_phy;
- gadget = usbhsg_get_gadget(&priv->usbhs_priv);
- gadget->is_dualspeed = 1;
- gadget->is_otg = 0;
- gadget->is_a_peripheral = 0;
- gadget->b_hnp_enable = 0;
- gadget->a_hnp_support = 0;
- gadget->a_alt_hnp_support = 0;
- return usb_add_gadget_udc((struct device *)dev, gadget);
+err_phy:
- generic_shutdown_phy(&priv->phy);
+err_clk:
- clk_disable_bulk(&clk_bulk);
- return ret;
+static int usbhs_udc_otg_remove(struct udevice *dev) +{
- usbhs_rcar3_power_ctrl(&priv->usbhs_priv, false);
- usbhs_mod_remove(&priv->usbhs_priv);
- usbhs_fifo_remove(&priv->usbhs_priv);
- usbhs_pipe_remove(&priv->usbhs_priv);
- return dm_scan_fdt_dev(dev);
+static const struct udevice_id usbhs_udc_otg_ids[] = {
- { .compatible = "renesas,rcar-gen3-usbhs" },
+static const struct usb_gadget_generic_ops usbhs_udc_otg_ops = {
- .handle_interrupts = usbhs_udc_otg_gadget_handle_interrupts,
+U_BOOT_DRIVER(usbhs_udc_otg) = {
- .name = "usbhs-udc-otg",
- .id = UCLASS_USB_GADGET_GENERIC,
- .ops = &usbhs_udc_otg_ops,
- .of_match = usbhs_udc_otg_ids,
- .probe = usbhs_udc_otg_probe,
- .remove = usbhs_udc_otg_remove,
- .priv_auto = sizeof(struct usbhs_priv_otg_data),
+}; diff --git a/drivers/usb/gadget/rcar/common.h b/drivers/usb/gadget/rcar/common.h new file mode 100644 index 00000000000..544cfd77cdf --- /dev/null +++ b/drivers/usb/gadget/rcar/common.h @@ -0,0 +1,328 @@ +/* SPDX-License-Identifier: GPL-1.0+ */ +/*
+#ifndef RENESAS_USB_DRIVER_H +#define RENESAS_USB_DRIVER_H
+#include <dm/device.h> +#include <dm/device_compat.h> +#include <linux/bug.h> +#include <linux/delay.h> +#include <linux/io.h> +#include "renesas_usb.h"
+struct usbhs_priv;
+#include "mod.h" +#include "pipe.h"
register define
+#define SYSCFG 0x0000 +#define BUSWAIT 0x0002 +#define DVSTCTR 0x0008 +#define TESTMODE 0x000C +#define CFIFO 0x0014 +#define CFIFOSEL 0x0020 +#define CFIFOCTR 0x0022 +#define D0FIFO 0x0100 +#define D0FIFOSEL 0x0028 +#define D0FIFOCTR 0x002A +#define D1FIFO 0x0120 +#define D1FIFOSEL 0x002C +#define D1FIFOCTR 0x002E +#define INTENB0 0x0030 +#define INTENB1 0x0032 +#define BRDYENB 0x0036 +#define NRDYENB 0x0038 +#define BEMPENB 0x003A +#define INTSTS0 0x0040 +#define INTSTS1 0x0042 +#define BRDYSTS 0x0046 +#define NRDYSTS 0x0048 +#define BEMPSTS 0x004A +#define FRMNUM 0x004C +#define USBREQ 0x0054 /* USB request type register */ +#define USBVAL 0x0056 /* USB request value register */ +#define USBINDX 0x0058 /* USB request index register */ +#define USBLENG 0x005A /* USB request length register */ +#define DCPCFG 0x005C +#define DCPMAXP 0x005E +#define DCPCTR 0x0060 +#define PIPESEL 0x0064 +#define PIPECFG 0x0068 +#define PIPEBUF 0x006A +#define PIPEMAXP 0x006C +#define PIPEPERI 0x006E +#define PIPEnCTR 0x0070 +#define PIPE1TRE 0x0090 +#define PIPE1TRN 0x0092 +#define PIPE2TRE 0x0094 +#define PIPE2TRN 0x0096 +#define PIPE3TRE 0x0098 +#define PIPE3TRN 0x009A +#define PIPE4TRE 0x009C +#define PIPE4TRN 0x009E +#define PIPE5TRE 0x00A0 +#define PIPE5TRN 0x00A2 +#define PIPEBTRE 0x00A4 +#define PIPEBTRN 0x00A6 +#define PIPECTRE 0x00A8 +#define PIPECTRN 0x00AA +#define PIPEDTRE 0x00AC +#define PIPEDTRN 0x00AE +#define PIPEETRE 0x00B0 +#define PIPEETRN 0x00B2 +#define PIPEFTRE 0x00B4 +#define PIPEFTRN 0x00B6 +#define PIPE9TRE 0x00B8 +#define PIPE9TRN 0x00BA +#define PIPEATRE 0x00BC +#define PIPEATRN 0x00BE +#define DEVADD0 0x00D0 /* Device address n configuration */ +#define DEVADD1 0x00D2 +#define DEVADD2 0x00D4 +#define DEVADD3 0x00D6 +#define DEVADD4 0x00D8 +#define DEVADD5 0x00DA +#define DEVADD6 0x00DC +#define DEVADD7 0x00DE +#define DEVADD8 0x00E0 +#define DEVADD9 0x00E2 +#define DEVADDA 0x00E4 +#define D2FIFOSEL 0x00F0 /* for R-Car Gen2 */ +#define D2FIFOCTR 0x00F2 /* for R-Car Gen2 */ +#define D3FIFOSEL 0x00F4 /* for R-Car Gen2 */ +#define D3FIFOCTR 0x00F6 /* for R-Car Gen2 */ +#define SUSPMODE 0x0102 /* for RZ/A */
+/* SYSCFG */ +#define SCKE (1 << 10) /* USB Module Clock Enable */ +#define CNEN (1 << 8) /* Single-ended receiver operation Enable */ +#define HSE (1 << 7) /* High-Speed Operation Enable */ +#define DCFM (1 << 6) /* Controller Function Select */ +#define DRPD (1 << 5) /* D+ Line/D- Line Resistance Control */ +#define DPRPU (1 << 4) /* D+ Line Resistance Control */ +#define USBE (1 << 0) /* USB Module Operation Enable */ +#define UCKSEL (1 << 2) /* Clock Select for RZ/A1 */ +#define UPLLE (1 << 1) /* USB PLL Enable for RZ/A1 */
+/* DVSTCTR */ +#define EXTLP (1 << 10) /* Controls the EXTLP pin output state */ +#define PWEN (1 << 9) /* Controls the PWEN pin output state */ +#define USBRST (1 << 6) /* Bus Reset Output */ +#define UACT (1 << 4) /* USB Bus Enable */ +#define RHST (0x7) /* Reset Handshake */ +#define RHST_LOW_SPEED 1 /* Low-speed connection */ +#define RHST_FULL_SPEED 2 /* Full-speed connection */ +#define RHST_HIGH_SPEED 3 /* High-speed connection */
+/* CFIFOSEL */ +#define DREQE (1 << 12) /* DMA Transfer Request Enable */ +#define MBW_32 (0x2 << 10) /* CFIFO Port Access Bit Width */
+/* CFIFOCTR */ +#define BVAL (1 << 15) /* Buffer Memory Enable Flag */ +#define BCLR (1 << 14) /* CPU buffer clear */ +#define FRDY (1 << 13) /* FIFO Port Ready */ +#define DTLN_MASK (0x0FFF) /* Receive Data Length */
+/* INTENB0 */ +#define VBSE (1 << 15) /* Enable IRQ VBUS_0 and VBUSIN_0 */ +#define RSME (1 << 14) /* Enable IRQ Resume */ +#define SOFE (1 << 13) /* Enable IRQ Frame Number Update */ +#define DVSE (1 << 12) /* Enable IRQ Device State Transition */ +#define CTRE (1 << 11) /* Enable IRQ Control Stage Transition */ +#define BEMPE (1 << 10) /* Enable IRQ Buffer Empty */ +#define NRDYE (1 << 9) /* Enable IRQ Buffer Not Ready Response */ +#define BRDYE (1 << 8) /* Enable IRQ Buffer Ready */
+/* INTENB1 */ +#define BCHGE (1 << 14) /* USB Bus Change Interrupt Enable */ +#define DTCHE (1 << 12) /* Disconnection Detect Interrupt Enable */ +#define ATTCHE (1 << 11) /* Connection Detect Interrupt Enable */ +#define EOFERRE (1 << 6) /* EOF Error Detect Interrupt Enable */ +#define SIGNE (1 << 5) /* Setup Transaction Error Interrupt Enable */ +#define SACKE (1 << 4) /* Setup Transaction ACK Interrupt Enable */
+/* INTSTS0 */ +#define VBINT (1 << 15) /* VBUS0_0 and VBUS1_0 Interrupt Status */ +#define DVST (1 << 12) /* Device State Transition Interrupt Status */ +#define CTRT (1 << 11) /* Control Stage Interrupt Status */ +#define BEMP (1 << 10) /* Buffer Empty Interrupt Status */ +#define BRDY (1 << 8) /* Buffer Ready Interrupt Status */ +#define VBSTS (1 << 7) /* VBUS_0 and VBUSIN_0 Input Status */ +#define VALID (1 << 3) /* USB Request Receive */
+#define DVSQ_MASK (0x7 << 4) /* Device State */ +#define POWER_STATE (0 << 4) +#define DEFAULT_STATE (1 << 4) +#define ADDRESS_STATE (2 << 4) +#define CONFIGURATION_STATE (3 << 4) +#define SUSPENDED_STATE (4 << 4)
+#define CTSQ_MASK (0x7) /* Control Transfer Stage */ +#define IDLE_SETUP_STAGE 0 /* Idle stage or setup stage */ +#define READ_DATA_STAGE 1 /* Control read data stage */ +#define READ_STATUS_STAGE 2 /* Control read status stage */ +#define WRITE_DATA_STAGE 3 /* Control write data stage */ +#define WRITE_STATUS_STAGE 4 /* Control write status stage */ +#define NODATA_STATUS_STAGE 5 /* Control write NoData status stage */ +#define SEQUENCE_ERROR 6 /* Control transfer sequence error */
+/* INTSTS1 */ +#define OVRCR (1 << 15) /* OVRCR Interrupt Status */ +#define BCHG (1 << 14) /* USB Bus Change Interrupt Status */ +#define DTCH (1 << 12) /* USB Disconnection Detect Interrupt Status */ +#define ATTCH (1 << 11) /* ATTCH Interrupt Status */ +#define EOFERR (1 << 6) /* EOF Error Detect Interrupt Status */ +#define SIGN (1 << 5) /* Setup Transaction Error Interrupt Status */ +#define SACK (1 << 4) /* Setup Transaction ACK Response Interrupt Status */
+/* PIPECFG */ +/* DCPCFG */ +#define TYPE_NONE (0 << 14) /* Transfer Type */ +#define TYPE_BULK (1 << 14) +#define TYPE_INT (2 << 14) +#define TYPE_ISO (3 << 14) +#define BFRE (1 << 10) /* BRDY Interrupt Operation Spec. */ +#define DBLB (1 << 9) /* Double Buffer Mode */ +#define SHTNAK (1 << 7) /* Pipe Disable in Transfer End */ +#define DIR_OUT (1 << 4) /* Transfer Direction */
+/* PIPEMAXP */ +/* DCPMAXP */ +#define DEVSEL_MASK (0xF << 12) /* Device Select */ +#define DCP_MAXP_MASK (0x7F) +#define PIPE_MAXP_MASK (0x7FF)
+/* PIPEBUF */ +#define BUFSIZE_SHIFT 10 +#define BUFSIZE_MASK (0x1F << BUFSIZE_SHIFT) +#define BUFNMB_MASK (0xFF)
+/* PIPEnCTR */ +/* DCPCTR */ +#define BSTS (1 << 15) /* Buffer Status */ +#define SUREQ (1 << 14) /* Sending SETUP Token */ +#define INBUFM (1 << 14) /* (PIPEnCTR) Transfer Buffer Monitor */ +#define CSSTS (1 << 12) /* CSSTS Status */ +#define ACLRM (1 << 9) /* Buffer Auto-Clear Mode */ +#define SQCLR (1 << 8) /* Toggle Bit Clear */ +#define SQSET (1 << 7) /* Toggle Bit Set */ +#define SQMON (1 << 6) /* Toggle Bit Check */ +#define PBUSY (1 << 5) /* Pipe Busy */ +#define PID_MASK (0x3) /* Response PID */ +#define PID_NAK 0 +#define PID_BUF 1 +#define PID_STALL10 2 +#define PID_STALL11 3
+#define CCPL (1 << 2) /* Control Transfer End Enable */
+/* PIPEnTRE */ +#define TRENB (1 << 9) /* Transaction Counter Enable */ +#define TRCLR (1 << 8) /* Transaction Counter Clear */
+/* FRMNUM */ +#define FRNM_MASK (0x7FF)
+/* DEVADDn */ +#define UPPHUB(x) (((x) & 0xF) << 11) /* HUB Register */ +#define HUBPORT(x) (((x) & 0x7) << 8) /* HUB Port for Target Device */ +#define USBSPD(x) (((x) & 0x3) << 6) /* Device Transfer Rate */ +#define USBSPD_SPEED_LOW 0x1 +#define USBSPD_SPEED_FULL 0x2 +#define USBSPD_SPEED_HIGH 0x3
+/* SUSPMODE */ +#define SUSPM (1 << 14) /* SuspendM Control */
struct
+struct usbhs_priv {
- struct renesas_usbhs_driver_param dparam;
- struct platform_device *pdev;
* module control
- struct usbhs_mod_info mod_info;
* pipe control
- struct usbhs_pipe_info pipe_info;
* fifo control
- struct usbhs_fifo_info fifo_info;
- common
+u16 usbhs_read(struct usbhs_priv *priv, u32 reg); +void usbhs_write(struct usbhs_priv *priv, u32 reg, u16 data); +void usbhs_bset(struct usbhs_priv *priv, u32 reg, u16 mask, u16 data);
+#define usbhs_lock(p, f) spin_lock_irqsave(usbhs_priv_to_lock(p), f) +#define usbhs_unlock(p, f) spin_unlock_irqrestore(usbhs_priv_to_lock(p), f)
- sysconfig
+void usbhs_sys_host_ctrl(struct usbhs_priv *priv, int enable); +void usbhs_sys_function_ctrl(struct usbhs_priv *priv, int enable); +void usbhs_sys_function_pullup(struct usbhs_priv *priv, int enable); +void usbhs_sys_set_test_mode(struct usbhs_priv *priv, u16 mode);
- usb request
+void usbhs_usbreq_get_val(struct usbhs_priv *priv, struct usb_ctrlrequest *req); +void usbhs_usbreq_set_val(struct usbhs_priv *priv, struct usb_ctrlrequest *req);
- bus
+void usbhs_bus_send_sof_enable(struct usbhs_priv *priv); +void usbhs_bus_send_reset(struct usbhs_priv *priv); +int usbhs_bus_get_speed(struct usbhs_priv *priv); +int usbhs_vbus_ctrl(struct usbhs_priv *priv, int enable); +void usbhsc_hotplug(struct usbhs_priv *priv);
- frame
+int usbhs_frame_get_num(struct usbhs_priv *priv);
- device config
+int usbhs_set_device_config(struct usbhs_priv *priv, int devnum, u16 upphub,
u16 hubport, u16 speed);
- interrupt functions
+void usbhs_xxxsts_clear(struct usbhs_priv *priv, u16 sts_reg, u16 bit);
- data
+#define usbhs_get_dparam(priv, param) (priv->dparam.param) +#define usbhs_priv_to_dev(priv) (&priv->pdev->dev)
+#endif /* RENESAS_USB_DRIVER_H */ diff --git a/drivers/usb/gadget/rcar/fifo.c b/drivers/usb/gadget/rcar/fifo.c new file mode 100644 index 00000000000..6016b2987d5 --- /dev/null +++ b/drivers/usb/gadget/rcar/fifo.c @@ -0,0 +1,1067 @@ +// SPDX-License-Identifier: GPL-1.0+ +/*
+#include <linux/delay.h> +#include <linux/io.h> +#include "common.h" +#include "pipe.h"
+#define usbhsf_get_cfifo(p) (&((p)->fifo_info.cfifo))
+#define usbhsf_fifo_is_busy(f) ((f)->pipe) /* see usbhs_pipe_select_fifo */
packet initialize
+void usbhs_pkt_init(struct usbhs_pkt *pkt) +{
- INIT_LIST_HEAD(&pkt->node);
packet control function
+static int usbhsf_null_handle(struct usbhs_pkt *pkt, int *is_done) +{
- struct usbhs_priv *priv = usbhs_pipe_to_priv(pkt->pipe);
- dev_err(dev, "null handler\n");
- return -EINVAL;
+static const struct usbhs_pkt_handle usbhsf_null_handler = {
- .prepare = usbhsf_null_handle,
- .try_run = usbhsf_null_handle,
+void usbhs_pkt_push(struct usbhs_pipe *pipe, struct usbhs_pkt *pkt,
void (*done)(struct usbhs_priv *priv,
struct usbhs_pkt *pkt),
void *buf, int len, int zero, int sequence)
- struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe);
- unsigned long flags;
- if (!done) {
dev_err(dev, "no done function\n");
return;
- /******************** spin lock ********************/
- usbhs_lock(priv, flags);
- if (!pipe->handler) {
dev_err(dev, "no handler function\n");
pipe->handler = &usbhsf_null_handler;
- list_move_tail(&pkt->node, &pipe->list);
* each pkt must hold own handler.
* because handler might be changed by its situation.
* dma handler -> pio handler.
- pkt->pipe = pipe;
- pkt->buf = buf;
- pkt->handler = pipe->handler;
- pkt->length = len;
- pkt->zero = zero;
- pkt->actual = 0;
- pkt->done = done;
- pkt->sequence = sequence;
- usbhs_unlock(priv, flags);
- /******************** spin unlock ******************/
+static void __usbhsf_pkt_del(struct usbhs_pkt *pkt) +{
- list_del_init(&pkt->node);
+struct usbhs_pkt *__usbhsf_pkt_get(struct usbhs_pipe *pipe) +{
- return list_first_entry_or_null(&pipe->list, struct usbhs_pkt, node);
+static void usbhsf_fifo_unselect(struct usbhs_pipe *pipe,
+static struct dma_chan *usbhsf_dma_chan_get(struct usbhs_fifo *fifo,
struct usbhs_pkt *pkt);
+#define usbhsf_dma_map(p) __usbhsf_dma_map_ctrl(p, 1) +#define usbhsf_dma_unmap(p) __usbhsf_dma_map_ctrl(p, 0) +static int __usbhsf_dma_map_ctrl(struct usbhs_pkt *pkt, int map); +static void usbhsf_tx_irq_ctrl(struct usbhs_pipe *pipe, int enable); +static void usbhsf_rx_irq_ctrl(struct usbhs_pipe *pipe, int enable); +struct usbhs_pkt *usbhs_pkt_pop(struct usbhs_pipe *pipe, struct usbhs_pkt *pkt) +{
- struct usbhs_fifo *fifo = usbhs_pipe_to_fifo(pipe);
- usbhs_pipe_disable(pipe);
- if (!pkt)
pkt = __usbhsf_pkt_get(pipe);
- if (pkt) {
struct dma_chan *chan = NULL;
if (fifo)
chan = usbhsf_dma_chan_get(fifo, pkt);
if (chan)
usbhsf_dma_unmap(pkt);
usbhs_pipe_clear_without_sequence(pipe, 0, 0);
usbhs_pipe_running(pipe, 0);
__usbhsf_pkt_del(pkt);
- if (fifo)
usbhsf_fifo_unselect(pipe, fifo);
- return pkt;
+enum {
- USBHSF_PKT_PREPARE,
- USBHSF_PKT_TRY_RUN,
- USBHSF_PKT_DMA_DONE,
+static int usbhsf_pkt_handler(struct usbhs_pipe *pipe, int type) +{
- struct usbhs_pkt *pkt;
- int (*func)(struct usbhs_pkt *pkt, int *is_done);
- int ret = 0;
- int is_done = 0;
- pkt = __usbhsf_pkt_get(pipe);
- if (!pkt) {
ret = -EINVAL;
goto __usbhs_pkt_handler_end;
- switch (type) {
- case USBHSF_PKT_PREPARE:
func = pkt->handler->prepare;
break;
- case USBHSF_PKT_TRY_RUN:
func = pkt->handler->try_run;
break;
- case USBHSF_PKT_DMA_DONE:
func = pkt->handler->dma_done;
break;
- default:
dev_err(dev, "unknown pkt handler\n");
- if (likely(func))
ret = func(pkt, &is_done);
- if (is_done)
+__usbhs_pkt_handler_end:
- if (is_done) {
pkt->done(priv, pkt);
usbhs_pkt_start(pipe);
- return ret;
+void usbhs_pkt_start(struct usbhs_pipe *pipe) +{
- usbhsf_pkt_handler(pipe, USBHSF_PKT_PREPARE);
irq enable/disable function
+#define usbhsf_irq_empty_ctrl(p, e) usbhsf_irq_callback_ctrl(p, irq_bempsts, e) +#define usbhsf_irq_ready_ctrl(p, e) usbhsf_irq_callback_ctrl(p, irq_brdysts, e) +#define usbhsf_irq_callback_ctrl(pipe, status, enable) \
struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe); \
struct usbhs_mod *mod = usbhs_mod_get_current(priv); \
u16 status = (1 << usbhs_pipe_number(pipe)); \
if (!mod) \
return; \
if (enable) \
mod->status |= status; \
else \
mod->status &= ~status; \
usbhs_irq_callback_update(priv, mod); \
+static void usbhsf_tx_irq_ctrl(struct usbhs_pipe *pipe, int enable) +{
* And DCP pipe can NOT use "ready interrupt" for "send"
* it should use "empty" interrupt.
* see
* "Operation" - "Interrupt Function" - "BRDY Interrupt"
* on the other hand, normal pipe can use "ready interrupt" for "send"
* even though it is single/double buffer
- if (usbhs_pipe_is_dcp(pipe))
usbhsf_irq_empty_ctrl(pipe, enable);
- else
usbhsf_irq_ready_ctrl(pipe, enable);
+static void usbhsf_rx_irq_ctrl(struct usbhs_pipe *pipe, int enable) +{
- usbhsf_irq_ready_ctrl(pipe, enable);
FIFO ctrl
+static void usbhsf_send_terminator(struct usbhs_pipe *pipe,
- usbhs_bset(priv, fifo->ctr, BVAL, BVAL);
+static int usbhsf_fifo_barrier(struct usbhs_priv *priv,
- /* The FIFO port is accessible */
- if (usbhs_read(priv, fifo->ctr) & FRDY)
- return -EBUSY;
+static void usbhsf_fifo_clear(struct usbhs_pipe *pipe,
- int ret = 0;
- if (!usbhs_pipe_is_dcp(pipe)) {
* This driver checks the pipe condition first to avoid -EBUSY
* from usbhsf_fifo_barrier() if the pipe is RX direction and
* empty.
ret = usbhs_pipe_is_accessible(pipe);
if (!ret)
ret = usbhsf_fifo_barrier(priv, fifo);
* if non-DCP pipe, this driver should set BCLR when
* usbhsf_fifo_barrier() returns 0.
- if (!ret)
usbhs_write(priv, fifo->ctr, BCLR);
+static int usbhsf_fifo_rcv_len(struct usbhs_priv *priv,
- return usbhs_read(priv, fifo->ctr) & DTLN_MASK;
- usbhs_pipe_select_fifo(pipe, NULL);
- usbhs_write(priv, fifo->sel, 0);
+static int usbhsf_fifo_select(struct usbhs_pipe *pipe,
int write)
- int timeout = 1024;
- u16 mask = ((1 << 5) | 0xF); /* mask of ISEL | CURPIPE */
- u16 base = usbhs_pipe_number(pipe); /* CURPIPE */
- if (usbhs_pipe_is_busy(pipe) ||
usbhsf_fifo_is_busy(fifo))
return -EBUSY;
- if (usbhs_pipe_is_dcp(pipe)) {
base |= (1 == write) << 5; /* ISEL */
if (usbhs_mod_is_host(priv))
usbhs_dcp_dir_for_host(pipe, write);
- /* "base" will be used below */
- usbhs_write(priv, fifo->sel, base | MBW_32);
- /* check ISEL and CURPIPE value */
- while (timeout--) {
if (base == (mask & usbhs_read(priv, fifo->sel))) {
usbhs_pipe_select_fifo(pipe, fifo);
udelay(10);
- dev_err(dev, "fifo select error\n");
- return -EIO;
DCP status stage
+static int usbhs_dcp_dir_switch_to_write(struct usbhs_pkt *pkt, int *is_done) +{
- struct usbhs_pipe *pipe = pkt->pipe;
- struct usbhs_fifo *fifo = usbhsf_get_cfifo(priv); /* CFIFO */
- int ret;
- ret = usbhsf_fifo_select(pipe, fifo, 1);
- if (ret < 0) {
dev_err(dev, "%s() failed\n", __func__);
return ret;
- usbhs_pipe_sequence_data1(pipe); /* DATA1 */
- usbhsf_fifo_clear(pipe, fifo);
- usbhsf_send_terminator(pipe, fifo);
- usbhsf_fifo_unselect(pipe, fifo);
- usbhsf_tx_irq_ctrl(pipe, 1);
- usbhs_pipe_enable(pipe);
- return ret;
+static int usbhs_dcp_dir_switch_to_read(struct usbhs_pkt *pkt, int *is_done) +{
- int ret;
- ret = usbhsf_fifo_select(pipe, fifo, 0);
- if (ret < 0) {
dev_err(dev, "%s() fail\n", __func__);
return ret;
- usbhsf_rx_irq_ctrl(pipe, 1);
- return ret;
+static int usbhs_dcp_dir_switch_done(struct usbhs_pkt *pkt, int *is_done) +{
- if (pkt->handler == &usbhs_dcp_status_stage_in_handler)
usbhsf_tx_irq_ctrl(pipe, 0);
- else
usbhsf_rx_irq_ctrl(pipe, 0);
- pkt->actual = pkt->length;
- *is_done = 1;
+const struct usbhs_pkt_handle usbhs_dcp_status_stage_in_handler = {
- .prepare = usbhs_dcp_dir_switch_to_write,
- .try_run = usbhs_dcp_dir_switch_done,
+const struct usbhs_pkt_handle usbhs_dcp_status_stage_out_handler = {
- .prepare = usbhs_dcp_dir_switch_to_read,
DCP data stage (push)
+static int usbhsf_dcp_data_stage_try_push(struct usbhs_pkt *pkt, int *is_done) +{
* change handler to PIO push
- pkt->handler = &usbhs_fifo_pio_push_handler;
- return pkt->handler->prepare(pkt, is_done);
+const struct usbhs_pkt_handle usbhs_dcp_data_stage_out_handler = {
- .prepare = usbhsf_dcp_data_stage_try_push,
DCP data stage (pop)
+static int usbhsf_dcp_data_stage_prepare_pop(struct usbhs_pkt *pkt,
int *is_done)
- if (usbhs_pipe_is_busy(pipe))
* prepare pop for DCP should
* - change DCP direction,
* - clear fifo
* - DATA1
- usbhsf_fifo_select(pipe, fifo, 0);
* change handler to PIO pop
- pkt->handler = &usbhs_fifo_pio_pop_handler;
+const struct usbhs_pkt_handle usbhs_dcp_data_stage_in_handler = {
- .prepare = usbhsf_dcp_data_stage_prepare_pop,
PIO push handler
+static int usbhsf_pio_try_push(struct usbhs_pkt *pkt, int *is_done) +{
- void __iomem *addr = priv->base + fifo->port;
- u8 *buf;
- int maxp = usbhs_pipe_get_maxpacket(pipe);
- int total_len;
- int i, ret, len;
- int is_short;
- usbhs_pipe_data_sequence(pipe, pkt->sequence);
- pkt->sequence = -1; /* -1 sequence will be ignored */
- usbhs_pipe_set_trans_count_if_bulk(pipe, pkt->length);
- if (ret < 0)
- ret = usbhs_pipe_is_accessible(pipe);
- if (ret < 0) {
/* inaccessible pipe is not an error */
ret = 0;
goto usbhs_fifo_write_busy;
- ret = usbhsf_fifo_barrier(priv, fifo);
- if (ret < 0)
- buf = pkt->buf + pkt->actual;
- len = pkt->length - pkt->actual;
- len = min(len, maxp);
- total_len = len;
- is_short = total_len < maxp;
* FIXME
* 32-bit access only
- if (len >= 4 && !((unsigned long)buf & 0x03)) {
iowrite32_rep(addr, buf, len / 4);
len %= 4;
buf += total_len - len;
- /* the rest operation */
- if (usbhs_get_dparam(priv, cfifo_byte_addr)) {
for (i = 0; i < len; i++)
iowrite8(buf[i], addr + (i & 0x03));
- } else {
iowrite8(buf[i], addr + (0x03 - (i & 0x03)));
* variable update
- pkt->actual += total_len;
- if (pkt->actual < pkt->length)
*is_done = 0; /* there are remainder data */
- else if (is_short)
*is_done = 1; /* short packet */
- else
*is_done = !pkt->zero; /* send zero packet ? */
* pipe/irq handling
- if (is_short)
- usbhsf_tx_irq_ctrl(pipe, !*is_done);
- usbhs_pipe_running(pipe, !*is_done);
- dev_dbg(dev, " send %d (%d/ %d/ %d/ %d)\n",
pkt->length, pkt->actual, *is_done, pkt->zero);
+usbhs_fifo_write_busy:
* pipe is busy.
* retry in interrupt
- usbhs_pipe_running(pipe, 1);
- return ret;
+static int usbhsf_pio_prepare_push(struct usbhs_pkt *pkt, int *is_done) +{
- if (usbhs_pipe_is_running(pkt->pipe))
- return usbhsf_pio_try_push(pkt, is_done);
+const struct usbhs_pkt_handle usbhs_fifo_pio_push_handler = {
- .prepare = usbhsf_pio_prepare_push,
- .try_run = usbhsf_pio_try_push,
PIO pop handler
+static int usbhsf_prepare_pop(struct usbhs_pkt *pkt, int *is_done) +{
- if (usbhs_pipe_is_running(pipe))
* pipe enable to prepare packet receive
+static int usbhsf_pio_try_pop(struct usbhs_pkt *pkt, int *is_done) +{
- u8 *buf;
- u32 data = 0;
- int rcv_len, len;
- int i, ret;
- int total_len = 0;
- if (ret < 0)
- if (ret < 0)
goto usbhs_fifo_read_busy;
- rcv_len = usbhsf_fifo_rcv_len(priv, fifo);
- len = min(len, rcv_len);
- total_len = len;
* update actual length first here to decide disable pipe.
* if this pipe keeps BUF status and all data were popped,
* then, next interrupt/token will be issued again
- if ((pkt->actual == pkt->length) || /* receive all data */
(total_len < maxp)) { /* short packet */
*is_done = 1;
* If function mode, since this controller is possible to enter
* Control Write status stage at this timing, this driver
* should not disable the pipe. If such a case happens, this
* controller is not able to complete the status stage.
if (!usbhs_mod_is_host(priv) && !usbhs_pipe_is_dcp(pipe))
usbhs_pipe_disable(pipe); /* disable pipe first */
* Buffer clear if Zero-Length packet
* see
* "Operation" - "FIFO Buffer Memory" - "FIFO Port Function"
- if (0 == rcv_len) {
pkt->zero = 1;
goto usbhs_fifo_read_end;
* FIXME
ioread32_rep(addr, buf, len / 4);
len %= 4;
- for (i = 0; i < len; i++) {
if (!(i & 0x03))
data = ioread32(addr);
buf[i] = (data >> ((i & 0x03) * 8)) & 0xff;
+usbhs_fifo_read_end:
- dev_dbg(dev, " recv %d (%d/ %d/ %d/ %d)\n",
+usbhs_fifo_read_busy:
- return ret;
+const struct usbhs_pkt_handle usbhs_fifo_pio_pop_handler = {
- .prepare = usbhsf_prepare_pop,
- .try_run = usbhsf_pio_try_pop,
DCP ctrol statge handler
+static int usbhsf_ctrl_stage_end(struct usbhs_pkt *pkt, int *is_done) +{
- usbhs_dcp_control_transfer_done(pkt->pipe);
- *is_done = 1;
+const struct usbhs_pkt_handle usbhs_ctrl_stage_end_handler = {
- .prepare = usbhsf_ctrl_stage_end,
- .try_run = usbhsf_ctrl_stage_end,
DMA fifo functions
- if (&usbhs_fifo_dma_push_handler == pkt->handler)
return fifo->tx_chan;
- if (&usbhs_fifo_dma_pop_handler == pkt->handler)
return fifo->rx_chan;
- return NULL;
+#define usbhsf_dma_start(p, f) __usbhsf_dma_ctrl(p, f, DREQE) +#define usbhsf_dma_stop(p, f) __usbhsf_dma_ctrl(p, f, 0) +static void __usbhsf_dma_ctrl(struct usbhs_pipe *pipe,
u16 dreqe)
- usbhs_bset(priv, fifo->sel, DREQE, dreqe);
+static int __usbhsf_dma_map_ctrl(struct usbhs_pkt *pkt, int map) +{
- struct usbhs_pipe_info *info = usbhs_priv_to_pipeinfo(priv);
- return info->dma_map_ctrl(pkt, map);
DMA push handler
+static int usbhsf_dma_prepare_push(struct usbhs_pkt *pkt, int *is_done) +{
+static int usbhsf_dma_push_done(struct usbhs_pkt *pkt, int *is_done) +{
- int is_short = pkt->trans % usbhs_pipe_get_maxpacket(pipe);
- pkt->actual += pkt->trans;
- else
*is_done = !pkt->zero; /* send zero packet? */
- usbhsf_dma_stop(pipe, pipe->fifo);
- usbhsf_dma_unmap(pkt);
- usbhsf_fifo_unselect(pipe, pipe->fifo);
- if (!*is_done) {
/* change handler to PIO */
return pkt->handler->try_run(pkt, is_done);
+const struct usbhs_pkt_handle usbhs_fifo_dma_push_handler = {
- .prepare = usbhsf_dma_prepare_push,
- .dma_done = usbhsf_dma_push_done,
DMA pop handler
+static int usbhsf_dma_prepare_pop_with_rx_irq(struct usbhs_pkt *pkt,
int *is_done)
- return usbhsf_prepare_pop(pkt, is_done);
+static int usbhsf_dma_prepare_pop(struct usbhs_pkt *pkt, int *is_done) +{
- return usbhsf_dma_prepare_pop_with_rx_irq(pkt, is_done);
+static int usbhsf_dma_try_pop_with_rx_irq(struct usbhs_pkt *pkt, int *is_done) +{
- return pkt->handler->try_run(pkt, is_done);
+static int usbhsf_dma_try_pop(struct usbhs_pkt *pkt, int *is_done) +{
- BUG_ON(usbhs_get_dparam(priv, has_usb_dmac));
- return usbhsf_dma_try_pop_with_rx_irq(pkt, is_done);
+static int usbhsf_dma_pop_done_with_rx_irq(struct usbhs_pkt *pkt, int *is_done) +{
(pkt->trans < maxp)) { /* short packet */
*is_done = 1;
- } else {
/* re-enable */
+static int usbhsf_dma_pop_done(struct usbhs_pkt *pkt, int *is_done) +{
- return usbhsf_dma_pop_done_with_rx_irq(pkt, is_done);
+const struct usbhs_pkt_handle usbhs_fifo_dma_pop_handler = {
- .prepare = usbhsf_dma_prepare_pop,
- .try_run = usbhsf_dma_try_pop,
- .dma_done = usbhsf_dma_pop_done
irq functions
+static int usbhsf_irq_empty(struct usbhs_priv *priv,
struct usbhs_irq_state *irq_state)
- struct usbhs_pipe *pipe;
- int i, ret;
- if (!irq_state->bempsts) {
dev_err(dev, "debug %s !!\n", __func__);
return -EIO;
- dev_dbg(dev, "irq empty [0x%04x]\n", irq_state->bempsts);
* search interrupted "pipe"
* not "uep".
- usbhs_for_each_pipe_with_dcp(pipe, priv, i) {
if (!(irq_state->bempsts & (1 << i)))
continue;
ret = usbhsf_pkt_handler(pipe, USBHSF_PKT_TRY_RUN);
if (ret < 0)
dev_err(dev, "irq_empty run_error %d : %d\n", i, ret);
+static int usbhsf_irq_ready(struct usbhs_priv *priv,
- int i, ret;
- if (!irq_state->brdysts) {
return -EIO;
- dev_dbg(dev, "irq ready [0x%04x]\n", irq_state->brdysts);
* not "uep".
if (!(irq_state->brdysts & (1 << i)))
continue;
if (ret < 0)
dev_err(dev, "irq_ready run_error %d : %d\n", i, ret);
+void usbhs_fifo_clear_dcp(struct usbhs_pipe *pipe) +{
- /* clear DCP FIFO of transmission */
- if (usbhsf_fifo_select(pipe, fifo, 1) < 0)
return;
- /* clear DCP FIFO of reception */
- if (usbhsf_fifo_select(pipe, fifo, 0) < 0)
return;
fifo init
+void usbhs_fifo_init(struct usbhs_priv *priv) +{
- struct usbhs_mod *mod = usbhs_mod_get_current(priv);
- struct usbhs_fifo *cfifo = usbhsf_get_cfifo(priv);
- struct usbhs_fifo *dfifo;
- int i;
- mod->irq_empty = usbhsf_irq_empty;
- mod->irq_ready = usbhsf_irq_ready;
- mod->irq_bempsts = 0;
- mod->irq_brdysts = 0;
- cfifo->pipe = NULL;
- usbhs_for_each_dfifo(priv, dfifo, i)
dfifo->pipe = NULL;
+void usbhs_fifo_quit(struct usbhs_priv *priv) +{
- mod->irq_empty = NULL;
- mod->irq_ready = NULL;
+#define __USBHS_DFIFO_INIT(priv, fifo, channel, fifo_port) \ +do { \
- fifo = usbhsf_get_dnfifo(priv, channel); \
- fifo->name = "D"#channel"FIFO"; \
- fifo->port = fifo_port; \
- fifo->sel = D##channel##FIFOSEL; \
- fifo->ctr = D##channel##FIFOCTR; \
- fifo->tx_slave.shdma_slave.slave_id = \
usbhs_get_dparam(priv, d##channel##_tx_id); \
- fifo->rx_slave.shdma_slave.slave_id = \
usbhs_get_dparam(priv, d##channel##_rx_id); \
+} while (0)
+#define USBHS_DFIFO_INIT(priv, fifo, channel) \
__USBHS_DFIFO_INIT(priv, fifo, channel, D##channel##FIFO)
+#define USBHS_DFIFO_INIT_NO_PORT(priv, fifo, channel) \
__USBHS_DFIFO_INIT(priv, fifo, channel, 0)
+int usbhs_fifo_probe(struct usbhs_priv *priv) +{
- struct usbhs_fifo *fifo;
- /* CFIFO */
- fifo = usbhsf_get_cfifo(priv);
- fifo->name = "CFIFO";
- fifo->port = CFIFO;
- fifo->sel = CFIFOSEL;
- fifo->ctr = CFIFOCTR;
- /* DFIFO */
- USBHS_DFIFO_INIT(priv, fifo, 0);
- USBHS_DFIFO_INIT(priv, fifo, 1);
- USBHS_DFIFO_INIT_NO_PORT(priv, fifo, 2);
- USBHS_DFIFO_INIT_NO_PORT(priv, fifo, 3);
+void usbhs_fifo_remove(struct usbhs_priv *priv) +{ +} diff --git a/drivers/usb/gadget/rcar/fifo.h b/drivers/usb/gadget/rcar/fifo.h new file mode 100644 index 00000000000..86746ca9bdd --- /dev/null +++ b/drivers/usb/gadget/rcar/fifo.h @@ -0,0 +1,114 @@ +/* SPDX-License-Identifier: GPL-1.0+ */ +/*
+#ifndef RENESAS_USB_FIFO_H +#define RENESAS_USB_FIFO_H
+#include <dma.h> +#include "pipe.h"
- Drivers, using this library are expected to embed struct shdma_dev,
- struct shdma_chan, struct shdma_desc, and struct shdma_slave
- in their respective device, channel, descriptor and slave objects.
+struct shdma_slave {
- int slave_id;
+/* Used by slave DMA clients to request DMA to/from a specific peripheral */ +struct sh_dmae_slave {
- struct shdma_slave shdma_slave; /* Set by the platform */
+struct usbhs_fifo {
- char *name;
- u32 port; /* xFIFO */
- u32 sel; /* xFIFOSEL */
- u32 ctr; /* xFIFOCTR */
- struct dma_chan *tx_chan;
- struct dma_chan *rx_chan;
- struct sh_dmae_slave tx_slave;
- struct sh_dmae_slave rx_slave;
+#define USBHS_MAX_NUM_DFIFO 4 +struct usbhs_fifo_info {
- struct usbhs_fifo cfifo;
- struct usbhs_fifo dfifo[USBHS_MAX_NUM_DFIFO];
+}; +#define usbhsf_get_dnfifo(p, n) (&((p)->fifo_info.dfifo[n])) +#define usbhs_for_each_dfifo(priv, dfifo, i) \
- for ((i) = 0; \
((i) < USBHS_MAX_NUM_DFIFO) && \
((dfifo) = usbhsf_get_dnfifo(priv, (i))); \
(i)++)
+struct usbhs_pkt_handle; +struct usbhs_pkt {
- struct list_head node;
- const struct usbhs_pkt_handle *handler;
- void (*done)(struct usbhs_priv *priv,
- struct work_struct work;
- dma_addr_t dma;
- const struct dmaengine_result *dma_result;
- void *buf;
- int length;
- int trans;
- int actual;
- int zero;
- int sequence;
+struct usbhs_pkt_handle {
- int (*prepare)(struct usbhs_pkt *pkt, int *is_done);
- int (*try_run)(struct usbhs_pkt *pkt, int *is_done);
- int (*dma_done)(struct usbhs_pkt *pkt, int *is_done);
- fifo
+int usbhs_fifo_probe(struct usbhs_priv *priv); +void usbhs_fifo_remove(struct usbhs_priv *priv); +void usbhs_fifo_init(struct usbhs_priv *priv); +void usbhs_fifo_quit(struct usbhs_priv *priv); +void usbhs_fifo_clear_dcp(struct usbhs_pipe *pipe);
- packet info
+extern const struct usbhs_pkt_handle usbhs_fifo_pio_push_handler; +extern const struct usbhs_pkt_handle usbhs_fifo_pio_pop_handler; +extern const struct usbhs_pkt_handle usbhs_ctrl_stage_end_handler;
+extern const struct usbhs_pkt_handle usbhs_fifo_dma_push_handler; +extern const struct usbhs_pkt_handle usbhs_fifo_dma_pop_handler;
+extern const struct usbhs_pkt_handle usbhs_dcp_status_stage_in_handler; +extern const struct usbhs_pkt_handle usbhs_dcp_status_stage_out_handler;
+extern const struct usbhs_pkt_handle usbhs_dcp_data_stage_in_handler; +extern const struct usbhs_pkt_handle usbhs_dcp_data_stage_out_handler;
+void usbhs_pkt_init(struct usbhs_pkt *pkt); +void usbhs_pkt_push(struct usbhs_pipe *pipe, struct usbhs_pkt *pkt,
void *buf, int len, int zero, int sequence);
+struct usbhs_pkt *usbhs_pkt_pop(struct usbhs_pipe *pipe, struct usbhs_pkt *pkt); +void usbhs_pkt_start(struct usbhs_pipe *pipe); +struct usbhs_pkt *__usbhsf_pkt_get(struct usbhs_pipe *pipe);
+#endif /* RENESAS_USB_FIFO_H */ diff --git a/drivers/usb/gadget/rcar/mod.c b/drivers/usb/gadget/rcar/mod.c new file mode 100644 index 00000000000..f5f8d169e17 --- /dev/null +++ b/drivers/usb/gadget/rcar/mod.c @@ -0,0 +1,345 @@ +// SPDX-License-Identifier: GPL-1.0+ +/*
+#include "common.h" +#include "mod.h"
autonomy
- these functions are used if platform doesn't have external phy.
- -> there is no "notify_hotplug" callback from platform
- -> call "notify_hotplug" by itself
- -> use own interrupt to connect/disconnect
- -> it mean module clock is always ON
+static int usbhsm_autonomy_irq_vbus(struct usbhs_priv *priv,
+void usbhs_mod_autonomy_mode(struct usbhs_priv *priv) +{
- struct usbhs_mod_info *info = usbhs_priv_to_modinfo(priv);
- info->irq_vbus = usbhsm_autonomy_irq_vbus;
- usbhs_irq_callback_update(priv, NULL);
host / gadget functions
- renesas_usbhs host/gadget can register itself by below functions.
- these functions are called when probe
+void usbhs_mod_register(struct usbhs_priv *priv, struct usbhs_mod *mod, int id) +{
- info->mod[id] = mod;
- mod->priv = priv;
+struct usbhs_mod *usbhs_mod_get(struct usbhs_priv *priv, int id) +{
- struct usbhs_mod *ret = NULL;
- switch (id) {
- case USBHS_HOST:
- case USBHS_GADGET:
ret = info->mod[id];
break;
- return ret;
+int usbhs_mod_is_host(struct usbhs_priv *priv) +{
- if (!mod)
return -EINVAL;
- return info->mod[USBHS_HOST] == mod;
+struct usbhs_mod *usbhs_mod_get_current(struct usbhs_priv *priv) +{
- return info->curt;
+int usbhs_mod_change(struct usbhs_priv *priv, int id) +{
- struct usbhs_mod *mod = NULL;
- int ret = 0;
- /* id < 0 mean no current */
- switch (id) {
- case USBHS_HOST:
mod = info->mod[id];
break;
- default:
ret = -EINVAL;
- info->curt = mod;
- return ret;
+irqreturn_t usbhs_interrupt(int irq, void *data); +int usbhs_mod_probe(struct usbhs_priv *priv) +{
- int ret;
* install host/gadget driver
- ret = usbhs_mod_host_probe(priv);
- if (ret < 0)
return ret;
- ret = usbhs_mod_gadget_probe(priv);
- if (ret < 0)
goto mod_init_host_err;
- return ret;
+mod_init_host_err:
- usbhs_mod_host_remove(priv);
- return ret;
+void usbhs_mod_remove(struct usbhs_priv *priv) +{
- usbhs_mod_gadget_remove(priv);
status functions
+int usbhs_status_get_device_state(struct usbhs_irq_state *irq_state) +{
- return (int)irq_state->intsts0 & DVSQ_MASK;
+int usbhs_status_get_ctrl_stage(struct usbhs_irq_state *irq_state) +{
* return value
* IDLE_SETUP_STAGE
* READ_DATA_STAGE
* READ_STATUS_STAGE
* WRITE_DATA_STAGE
* WRITE_STATUS_STAGE
* NODATA_STATUS_STAGE
* SEQUENCE_ERROR
- return (int)irq_state->intsts0 & CTSQ_MASK;
+static int usbhs_status_get_each_irq(struct usbhs_priv *priv,
struct usbhs_irq_state *state)
- u16 intenb0, intenb1;
- state->intsts0 = usbhs_read(priv, INTSTS0);
- intenb0 = usbhs_read(priv, INTENB0);
- if (usbhs_mod_is_host(priv)) {
state->intsts1 = usbhs_read(priv, INTSTS1);
intenb1 = usbhs_read(priv, INTENB1);
- } else {
state->intsts1 = intenb1 = 0;
- /* mask */
- if (mod) {
state->brdysts = usbhs_read(priv, BRDYSTS);
state->nrdysts = usbhs_read(priv, NRDYSTS);
state->bempsts = usbhs_read(priv, BEMPSTS);
state->bempsts &= mod->irq_bempsts;
state->brdysts &= mod->irq_brdysts;
interrupt
+#define INTSTS0_MAGIC 0xF800 /* acknowledge magical interrupt sources */ +#define INTSTS1_MAGIC 0xA870 /* acknowledge magical interrupt sources */ +irqreturn_t usbhs_interrupt(int irq, void *data) +{
- struct usbhs_priv *priv = data;
- struct usbhs_irq_state irq_state;
- if (usbhs_status_get_each_irq(priv, &irq_state) < 0)
return IRQ_NONE;
* clear interrupt
* The hardware is _very_ picky to clear interrupt bit.
* Especially INTSTS0_MAGIC, INTSTS1_MAGIC value.
* see
* "Operation"
* - "Control Transfer (DCP)"
* - Function :: VALID bit should 0
- usbhs_write(priv, INTSTS0, ~irq_state.intsts0 & INTSTS0_MAGIC);
usbhs_write(priv, INTSTS1, ~irq_state.intsts1 & INTSTS1_MAGIC);
* The driver should not clear the xxxSTS after the line of
* "call irq callback functions" because each "if" statement is
* possible to call the callback function for avoiding any side effects.
- if (irq_state.intsts0 & BRDY)
usbhs_write(priv, BRDYSTS, ~irq_state.brdysts);
- usbhs_write(priv, NRDYSTS, ~irq_state.nrdysts);
- if (irq_state.intsts0 & BEMP)
usbhs_write(priv, BEMPSTS, ~irq_state.bempsts);
* call irq callback functions
* see also
* usbhs_irq_setting_update
- /* INTSTS0 */
- if (irq_state.intsts0 & VBINT)
usbhs_mod_info_call(priv, irq_vbus, priv, &irq_state);
- if (irq_state.intsts0 & DVST)
usbhs_mod_call(priv, irq_dev_state, priv, &irq_state);
- if (irq_state.intsts0 & CTRT)
usbhs_mod_call(priv, irq_ctrl_stage, priv, &irq_state);
usbhs_mod_call(priv, irq_empty, priv, &irq_state);
usbhs_mod_call(priv, irq_ready, priv, &irq_state);
/* INTSTS1 */
if (irq_state.intsts1 & ATTCH)
usbhs_mod_call(priv, irq_attch, priv, &irq_state);
if (irq_state.intsts1 & DTCH)
usbhs_mod_call(priv, irq_dtch, priv, &irq_state);
if (irq_state.intsts1 & SIGN)
usbhs_mod_call(priv, irq_sign, priv, &irq_state);
if (irq_state.intsts1 & SACK)
usbhs_mod_call(priv, irq_sack, priv, &irq_state);
- return IRQ_HANDLED;
+void usbhs_irq_callback_update(struct usbhs_priv *priv, struct usbhs_mod *mod) +{
- u16 intenb0 = 0;
- u16 intenb1 = 0;
* BEMPENB/BRDYENB are picky.
* below method is required
* - clear INTSTS0
* - update BEMPENB/BRDYENB
* - update INTSTS0
- usbhs_write(priv, INTENB0, 0);
usbhs_write(priv, INTENB1, 0);
- usbhs_write(priv, BEMPENB, 0);
- usbhs_write(priv, BRDYENB, 0);
* see also
* usbhs_interrupt
- if (info->irq_vbus)
intenb0 |= VBSE;
- if (mod) {
* INTSTS0
if (mod->irq_ctrl_stage)
intenb0 |= CTRE;
if (mod->irq_dev_state)
intenb0 |= DVSE;
if (mod->irq_empty && mod->irq_bempsts) {
usbhs_write(priv, BEMPENB, mod->irq_bempsts);
intenb0 |= BEMPE;
if (mod->irq_ready && mod->irq_brdysts) {
usbhs_write(priv, BRDYENB, mod->irq_brdysts);
intenb0 |= BRDYE;
* INTSTS1
if (mod->irq_attch)
intenb1 |= ATTCHE;
if (mod->irq_dtch)
intenb1 |= DTCHE;
if (mod->irq_sign)
intenb1 |= SIGNE;
if (mod->irq_sack)
intenb1 |= SACKE;
- if (intenb0)
usbhs_write(priv, INTENB0, intenb0);
- if (usbhs_mod_is_host(priv) && intenb1)
usbhs_write(priv, INTENB1, intenb1);
+} diff --git a/drivers/usb/gadget/rcar/mod.h b/drivers/usb/gadget/rcar/mod.h new file mode 100644 index 00000000000..b670e950a28 --- /dev/null +++ b/drivers/usb/gadget/rcar/mod.h @@ -0,0 +1,161 @@ +/* SPDX-License-Identifier: GPL-1.0+ */ +/*
+#ifndef RENESAS_USB_MOD_H +#define RENESAS_USB_MOD_H
- struct
+struct usbhs_irq_state {
- u16 intsts0;
- u16 intsts1;
- u16 brdysts;
- u16 nrdysts;
- u16 bempsts;
+struct usbhs_mod {
- char *name;
* entry point from common.c
- int (*start)(struct usbhs_priv *priv);
- int (*stop)(struct usbhs_priv *priv);
* INTSTS0
- /* DVST (DVSQ) */
- int (*irq_dev_state)(struct usbhs_priv *priv,
struct usbhs_irq_state *irq_state);
- /* CTRT (CTSQ) */
- int (*irq_ctrl_stage)(struct usbhs_priv *priv,
- /* BEMP / BEMPSTS */
- int (*irq_empty)(struct usbhs_priv *priv,
- u16 irq_bempsts;
- /* BRDY / BRDYSTS */
- int (*irq_ready)(struct usbhs_priv *priv,
- u16 irq_brdysts;
* INTSTS1
- /* ATTCHE */
- int (*irq_attch)(struct usbhs_priv *priv,
- /* DTCHE */
- int (*irq_dtch)(struct usbhs_priv *priv,
- /* SIGN */
- int (*irq_sign)(struct usbhs_priv *priv,
- /* SACK */
- int (*irq_sack)(struct usbhs_priv *priv,
- struct usbhs_priv *priv;
+struct usbhs_mod_info {
- struct usbhs_mod *mod[USBHS_MAX];
- struct usbhs_mod *curt; /* current mod */
* INTSTS0 :: VBINT
* This function will be used as autonomy mode (runtime_pwctrl == 0)
* when the platform doesn't have own get_vbus function.
* This callback cannot be member of "struct usbhs_mod" because it
* will be used even though host/gadget has not been selected.
- int (*irq_vbus)(struct usbhs_priv *priv,
for host/gadget module
+struct usbhs_mod *usbhs_mod_get(struct usbhs_priv *priv, int id); +struct usbhs_mod *usbhs_mod_get_current(struct usbhs_priv *priv); +void usbhs_mod_register(struct usbhs_priv *priv, struct usbhs_mod *usb, int id); +int usbhs_mod_is_host(struct usbhs_priv *priv); +int usbhs_mod_change(struct usbhs_priv *priv, int id); +int usbhs_mod_probe(struct usbhs_priv *priv); +void usbhs_mod_remove(struct usbhs_priv *priv);
+void usbhs_mod_autonomy_mode(struct usbhs_priv *priv); +void usbhs_mod_non_autonomy_mode(struct usbhs_priv *priv);
status functions
+int usbhs_status_get_device_state(struct usbhs_irq_state *irq_state); +int usbhs_status_get_ctrl_stage(struct usbhs_irq_state *irq_state);
callback functions
+void usbhs_irq_callback_update(struct usbhs_priv *priv, struct usbhs_mod *mod);
+#define usbhs_mod_call(priv, func, param...) \
struct usbhs_mod *mod; \
!mod ? -ENODEV : \
!mod->func ? 0 : \
mod->func(param); \
+#define usbhs_priv_to_modinfo(priv) (&priv->mod_info) +#define usbhs_mod_info_call(priv, func, param...) \ +({ \
- struct usbhs_mod_info *info; \
- info = usbhs_priv_to_modinfo(priv); \
- !info->func ? 0 : \
info->func(param); \
- host / gadget control
+#if defined(CONFIG_USB_RENESAS_USBHS_HCD) || \
- defined(CONFIG_USB_RENESAS_USBHS_HCD_MODULE)
+extern int usbhs_mod_host_probe(struct usbhs_priv *priv); +extern int usbhs_mod_host_remove(struct usbhs_priv *priv); +#else +static inline int usbhs_mod_host_probe(struct usbhs_priv *priv) +{
+} +static inline void usbhs_mod_host_remove(struct usbhs_priv *priv) +{ +} +#endif
+extern int usbhs_mod_gadget_probe(struct usbhs_priv *priv); +extern void usbhs_mod_gadget_remove(struct usbhs_priv *priv);
+#endif /* RENESAS_USB_MOD_H */ diff --git a/drivers/usb/gadget/rcar/mod_gadget.c b/drivers/usb/gadget/rcar/mod_gadget.c new file mode 100644 index 00000000000..bd9855eb4fa --- /dev/null +++ b/drivers/usb/gadget/rcar/mod_gadget.c @@ -0,0 +1,1136 @@ +// SPDX-License-Identifier: GPL-1.0+ +/*
+#include <linux/delay.h> +#include <linux/dma-mapping.h> +#include <linux/io.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <linux/usb/otg.h> +#include "common.h"
struct
+struct usbhsg_request {
- struct usb_request req;
- struct usbhs_pkt pkt;
+#define EP_NAME_SIZE 8 +struct usbhsg_gpriv; +struct usbhsg_uep {
- struct usb_ep ep;
- spinlock_t lock; /* protect the pipe */
- char ep_name[EP_NAME_SIZE];
- struct usbhsg_gpriv *gpriv;
+struct usbhsg_gpriv {
- struct usb_gadget gadget;
- struct usbhs_mod mod;
- struct usbhsg_uep *uep;
- int uep_size;
- struct usb_gadget_driver *driver;
- bool vbus_active;
- u32 status;
+#define USBHSG_STATUS_STARTED (1 << 0) +#define USBHSG_STATUS_REGISTERD (1 << 1) +#define USBHSG_STATUS_WEDGE (1 << 2) +#define USBHSG_STATUS_SELF_POWERED (1 << 3) +#define USBHSG_STATUS_SOFT_CONNECT (1 << 4) +};
+struct usbhsg_recip_handle {
- char *name;
- int (*device)(struct usbhs_priv *priv, struct usbhsg_uep *uep,
struct usb_ctrlrequest *ctrl);
- int (*interface)(struct usbhs_priv *priv, struct usbhsg_uep *uep,
- int (*endpoint)(struct usbhs_priv *priv, struct usbhsg_uep *uep,
macro
+#define usbhsg_priv_to_gpriv(priv) \
- container_of( \
usbhs_mod_get(priv, USBHS_GADGET), \
struct usbhsg_gpriv, mod)
+#define __usbhsg_for_each_uep(start, pos, g, i) \
- for ((i) = start; \
((i) < (g)->uep_size) && ((pos) = (g)->uep + (i)); \
(i)++)
+#define usbhsg_for_each_uep(pos, gpriv, i) \
- __usbhsg_for_each_uep(1, pos, gpriv, i)
+#define usbhsg_for_each_uep_with_dcp(pos, gpriv, i) \
- __usbhsg_for_each_uep(0, pos, gpriv, i)
+#define usbhsg_gadget_to_gpriv(g)\
- container_of(g, struct usbhsg_gpriv, gadget)
+#define usbhsg_req_to_ureq(r)\
- container_of(r, struct usbhsg_request, req)
+#define usbhsg_ep_to_uep(e) container_of(e, struct usbhsg_uep, ep) +#define usbhsg_gpriv_to_dev(gp) usbhs_priv_to_dev((gp)->mod.priv) +#define usbhsg_gpriv_to_priv(gp) ((gp)->mod.priv) +#define usbhsg_gpriv_to_dcp(gp) ((gp)->uep) +#define usbhsg_gpriv_to_nth_uep(gp, i) ((gp)->uep + i) +#define usbhsg_uep_to_gpriv(u) ((u)->gpriv) +#define usbhsg_uep_to_pipe(u) ((u)->pipe) +#define usbhsg_pipe_to_uep(p) ((p)->mod_private) +#define usbhsg_is_dcp(u) ((u) == usbhsg_gpriv_to_dcp((u)->gpriv))
+#define usbhsg_ureq_to_pkt(u) (&(u)->pkt) +#define usbhsg_pkt_to_ureq(i) \
- container_of(i, struct usbhsg_request, pkt)
+#define usbhsg_is_not_connected(gp) ((gp)->gadget.speed == USB_SPEED_UNKNOWN)
+/* status */ +#define usbhsg_status_init(gp) do {(gp)->status = 0; } while (0) +#define usbhsg_status_set(gp, b) (gp->status |= b) +#define usbhsg_status_clr(gp, b) (gp->status &= ~b) +#define usbhsg_status_has(gp, b) (gp->status & b)
queue push/pop
+static void __usbhsg_queue_pop(struct usbhsg_uep *uep,
struct usbhsg_request *ureq,
int status)
- struct usbhsg_gpriv *gpriv = usbhsg_uep_to_gpriv(uep);
- struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(uep);
- struct device *dev = usbhsg_gpriv_to_dev(gpriv);
- if (pipe)
dev_dbg(dev, "pipe %d : queue pop\n", usbhs_pipe_number(pipe));
- ureq->req.status = status;
- spin_unlock(usbhs_priv_to_lock(priv));
- usb_gadget_giveback_request(&uep->ep, &ureq->req);
- spin_lock(usbhs_priv_to_lock(priv));
+static void usbhsg_queue_pop(struct usbhsg_uep *uep,
int status)
- __usbhsg_queue_pop(uep, ureq, status);
+static void usbhsg_queue_done(struct usbhs_priv *priv, struct usbhs_pkt *pkt) +{
- struct usbhsg_uep *uep = usbhsg_pipe_to_uep(pipe);
- struct usbhsg_request *ureq = usbhsg_pkt_to_ureq(pkt);
- ureq->req.actual = pkt->actual;
- if (uep)
__usbhsg_queue_pop(uep, ureq, 0);
+static void usbhsg_queue_push(struct usbhsg_uep *uep,
struct usbhsg_request *ureq)
- struct usbhs_pkt *pkt = usbhsg_ureq_to_pkt(ureq);
- struct usb_request *req = &ureq->req;
- req->actual = 0;
- req->status = -EINPROGRESS;
- usbhs_pkt_push(pipe, pkt, usbhsg_queue_done,
req->buf, req->length, req->zero, -1);
- usbhs_pkt_start(pipe);
- dev_dbg(dev, "pipe %d : queue push (%d)\n",
usbhs_pipe_number(pipe),
req->length);
dma map/unmap
+static int usbhsg_dma_map_ctrl(struct usbhs_pkt *pkt, int map) +{
- return -1;
USB_TYPE_STANDARD / clear feature functions
+static int usbhsg_recip_handler_std_control_done(struct usbhs_priv *priv,
- struct usbhsg_gpriv *gpriv = usbhsg_priv_to_gpriv(priv);
- struct usbhsg_uep *dcp = usbhsg_gpriv_to_dcp(gpriv);
- struct usbhs_pipe *pipe = usbhsg_uep_to_pipe(dcp);
- usbhs_dcp_control_transfer_done(pipe);
+static int usbhsg_recip_handler_std_clear_endpoint(struct usbhs_priv *priv,
- if (!usbhsg_status_has(gpriv, USBHSG_STATUS_WEDGE)) {
usbhs_pipe_sequence_data0(pipe);
- usbhsg_recip_handler_std_control_done(priv, uep, ctrl);
+static struct usbhsg_recip_handle req_clear_feature = {
- .name = "clear feature",
- .device = usbhsg_recip_handler_std_control_done,
- .interface = usbhsg_recip_handler_std_control_done,
- .endpoint = usbhsg_recip_handler_std_clear_endpoint,
USB_TYPE_STANDARD / set feature functions
+static int usbhsg_recip_handler_std_set_device(struct usbhs_priv *priv,
- switch (le16_to_cpu(ctrl->wValue)) {
- case USB_DEVICE_TEST_MODE:
udelay(100);
usbhs_sys_set_test_mode(priv, le16_to_cpu(ctrl->wIndex) >> 8);
break;
- default:
break;
+static int usbhsg_recip_handler_std_set_endpoint(struct usbhs_priv *priv,
- usbhs_pipe_stall(pipe);
+static struct usbhsg_recip_handle req_set_feature = {
- .name = "set feature",
- .device = usbhsg_recip_handler_std_set_device,
- .endpoint = usbhsg_recip_handler_std_set_endpoint,
USB_TYPE_STANDARD / get status functions
+static void __usbhsg_recip_send_complete(struct usb_ep *ep,
struct usb_request *req)
- struct usbhsg_request *ureq = usbhsg_req_to_ureq(req);
- /* free allocated recip-buffer/usb_request */
- kfree(ureq->pkt.buf);
- usb_ep_free_request(ep, req);
+static void __usbhsg_recip_send_status(struct usbhsg_gpriv *gpriv,
unsigned short status)
- struct usb_request *req;
- __le16 *buf;
- /* alloc new usb_request for recip */
- req = usb_ep_alloc_request(&dcp->ep, GFP_ATOMIC);
- if (!req) {
dev_err(dev, "recip request allocation fail\n");
return;
- /* alloc recip data buffer */
- buf = kmalloc(sizeof(*buf), GFP_ATOMIC);
- if (!buf) {
usb_ep_free_request(&dcp->ep, req);
return;
- /* recip data is status */
- *buf = cpu_to_le16(status);
- /* allocated usb_request/buffer will be freed */
- req->complete = __usbhsg_recip_send_complete;
- req->buf = buf;
- req->length = sizeof(*buf);
- req->zero = 0;
- /* push packet */
- pipe->handler = &usbhs_fifo_pio_push_handler;
- usbhsg_queue_push(dcp, usbhsg_req_to_ureq(req));
+static int usbhsg_recip_handler_std_get_device(struct usbhs_priv *priv,
- unsigned short status = 0;
- if (usbhsg_status_has(gpriv, USBHSG_STATUS_SELF_POWERED))
status = 1 << USB_DEVICE_SELF_POWERED;
- __usbhsg_recip_send_status(gpriv, status);
+static int usbhsg_recip_handler_std_get_interface(struct usbhs_priv *priv,
+static int usbhsg_recip_handler_std_get_endpoint(struct usbhs_priv *priv,
- if (usbhs_pipe_is_stall(pipe))
status = 1 << USB_ENDPOINT_HALT;
+static struct usbhsg_recip_handle req_get_status = {
- .name = "get status",
- .device = usbhsg_recip_handler_std_get_device,
- .interface = usbhsg_recip_handler_std_get_interface,
- .endpoint = usbhsg_recip_handler_std_get_endpoint,
USB_TYPE handler
+static int usbhsg_recip_run_handle(struct usbhs_priv *priv,
struct usbhsg_recip_handle *handler,
- int recip = ctrl->bRequestType & USB_RECIP_MASK;
- int nth = le16_to_cpu(ctrl->wIndex) & USB_ENDPOINT_NUMBER_MASK;
- int ret = 0;
- int (*func)(struct usbhs_priv *priv, struct usbhsg_uep *uep,
- char *msg;
- uep = usbhsg_gpriv_to_nth_uep(gpriv, nth);
- pipe = usbhsg_uep_to_pipe(uep);
- if (!pipe) {
dev_err(dev, "wrong recip request\n");
return -EINVAL;
- switch (recip) {
- case USB_RECIP_DEVICE:
msg = "DEVICE";
func = handler->device;
break;
- case USB_RECIP_INTERFACE:
msg = "INTERFACE";
func = handler->interface;
break;
- case USB_RECIP_ENDPOINT:
msg = "ENDPOINT";
func = handler->endpoint;
break;
- default:
dev_warn(dev, "unsupported RECIP(%d)\n", recip);
func = NULL;
ret = -EINVAL;
- if (func) {
dev_dbg(dev, "%s (pipe %d :%s)\n", handler->name, nth, msg);
ret = func(priv, uep, ctrl);
- return ret;
irq functions
- it will be called from usbhs_interrupt
+static int usbhsg_irq_dev_state(struct usbhs_priv *priv,
- int state = usbhs_status_get_device_state(irq_state);
- gpriv->gadget.speed = usbhs_bus_get_speed(priv);
- dev_dbg(dev, "state = %x : speed : %d\n", state, gpriv->gadget.speed);
- if (gpriv->gadget.speed != USB_SPEED_UNKNOWN &&
(state & SUSPENDED_STATE)) {
if (gpriv->driver && gpriv->driver->suspend)
gpriv->driver->suspend(&gpriv->gadget);
usb_gadget_set_state(&gpriv->gadget, USB_STATE_SUSPENDED);
+static int usbhsg_irq_ctrl_stage(struct usbhs_priv *priv,
- struct usb_ctrlrequest ctrl;
- struct usbhsg_recip_handle *recip_handler = NULL;
- int stage = usbhs_status_get_ctrl_stage(irq_state);
- int ret = 0;
- dev_dbg(dev, "stage = %d\n", stage);
* see Manual
* "Operation"
* - "Interrupt Function"
* - "Control Transfer Stage Transition Interrupt"
* - Fig. "Control Transfer Stage Transitions"
- switch (stage) {
- case READ_DATA_STAGE:
break;
- case WRITE_DATA_STAGE:
pipe->handler = &usbhs_fifo_pio_pop_handler;
break;
- case NODATA_STATUS_STAGE:
pipe->handler = &usbhs_ctrl_stage_end_handler;
break;
- case READ_STATUS_STAGE:
- case WRITE_STATUS_STAGE:
fallthrough;
- default:
return ret;
* get usb request
- usbhs_usbreq_get_val(priv, &ctrl);
- switch (ctrl.bRequestType & USB_TYPE_MASK) {
- case USB_TYPE_STANDARD:
switch (ctrl.bRequest) {
case USB_REQ_CLEAR_FEATURE:
recip_handler = &req_clear_feature;
break;
case USB_REQ_SET_FEATURE:
recip_handler = &req_set_feature;
break;
case USB_REQ_GET_STATUS:
recip_handler = &req_get_status;
break;
* setup stage / run recip
- if (recip_handler)
ret = usbhsg_recip_run_handle(priv, recip_handler, &ctrl);
- else
ret = gpriv->driver->setup(&gpriv->gadget, &ctrl);
- if (ret < 0)
- return ret;
usb_dcp_ops
+static int usbhsg_pipe_disable(struct usbhsg_uep *uep) +{
- while (1) {
pkt = usbhs_pkt_pop(pipe, NULL);
if (!pkt)
break;
usbhsg_queue_pop(uep, usbhsg_pkt_to_ureq(pkt), -ESHUTDOWN);
usb_ep_ops
+static int usbhsg_ep_enable(struct usb_ep *ep,
const struct usb_endpoint_descriptor *desc)
- struct usbhsg_uep *uep = usbhsg_ep_to_uep(ep);
- struct usbhs_priv *priv = usbhsg_gpriv_to_priv(gpriv);
- int ret = -EIO;
* if it already have pipe,
* nothing to do
- if (uep->pipe) {
usbhs_pipe_clear(uep->pipe);
usbhs_pipe_sequence_data0(uep->pipe);
ret = 0;
goto usbhsg_ep_enable_end;
- pipe = usbhs_pipe_malloc(priv,
usb_endpoint_type(desc),
usb_endpoint_dir_in(desc));
- if (pipe) {
uep->pipe = pipe;
pipe->mod_private = uep;
/* set epnum / maxp */
usbhs_pipe_config_update(pipe, 0,
usb_endpoint_num(desc),
usb_endpoint_maxp(desc));
* usbhs_fifo_dma_push/pop_handler try to
* use dmaengine if possible.
* It will use pio handler if impossible.
if (usb_endpoint_dir_in(desc)) {
pipe->handler = &usbhs_fifo_dma_push_handler;
} else {
pipe->handler = &usbhs_fifo_dma_pop_handler;
usbhs_xxxsts_clear(priv, BRDYSTS,
ret = 0;
+usbhsg_ep_enable_end:
- return ret;
+static int usbhsg_ep_disable(struct usb_ep *ep) +{
- spin_lock_irqsave(&uep->lock, flags);
- if (!pipe)
goto out;
- usbhsg_pipe_disable(uep);
- usbhs_pipe_free(pipe);
- uep->pipe->mod_private = NULL;
- uep->pipe = NULL;
+out:
- spin_unlock_irqrestore(&uep->lock, flags);
+static struct usb_request *usbhsg_ep_alloc_request(struct usb_ep *ep,
gfp_t gfp_flags)
- struct usbhsg_request *ureq;
- ureq = kzalloc(sizeof *ureq, gfp_flags);
- if (!ureq)
return NULL;
- usbhs_pkt_init(usbhsg_ureq_to_pkt(ureq));
- return &ureq->req;
+static void usbhsg_ep_free_request(struct usb_ep *ep,
- WARN_ON(!list_empty(&ureq->pkt.node));
- kfree(ureq);
+static int usbhsg_ep_queue(struct usb_ep *ep, struct usb_request *req,
gfp_t gfp_flags)
- /* param check */
- if (usbhsg_is_not_connected(gpriv) ||
unlikely(!gpriv->driver) ||
unlikely(!pipe))
return -ESHUTDOWN;
- usbhsg_queue_push(uep, ureq);
+static int usbhsg_ep_dequeue(struct usb_ep *ep, struct usb_request *req) +{
- if (pipe)
usbhs_pkt_pop(pipe, usbhsg_ureq_to_pkt(ureq));
* To dequeue a request, this driver should call the usbhsg_queue_pop()
* even if the pipe is NULL.
- usbhsg_queue_pop(uep, ureq, -ECONNRESET);
+bool usbhs_pipe_contains_transmittable_data(struct usbhs_pipe *pipe); +static int __usbhsg_ep_set_halt_wedge(struct usb_ep *ep, int halt, int wedge) +{
- int ret = 0;
- dev_dbg(dev, "set halt %d (pipe %d)\n",
halt, usbhs_pipe_number(pipe));
* According to usb_ep_set_halt()'s description, this function should
* return -EAGAIN if the IN endpoint has any queue or data. Note
* that the usbhs_pipe_is_dir_in() returns false if the pipe is an
* IN endpoint in the gadget mode.
- if (!usbhs_pipe_is_dir_in(pipe) && (__usbhsf_pkt_get(pipe) ||
usbhs_pipe_contains_transmittable_data(pipe))) {
ret = -EAGAIN;
goto out;
- if (halt)
- else
- if (halt && wedge)
usbhsg_status_set(gpriv, USBHSG_STATUS_WEDGE);
- else
usbhsg_status_clr(gpriv, USBHSG_STATUS_WEDGE);
+out:
- return ret;
+static int usbhsg_ep_set_halt(struct usb_ep *ep, int value) +{
- return __usbhsg_ep_set_halt_wedge(ep, value, 0);
+static int usbhsg_ep_set_wedge(struct usb_ep *ep) +{
- return __usbhsg_ep_set_halt_wedge(ep, 1, 1);
+static const struct usb_ep_ops usbhsg_ep_ops = {
- .enable = usbhsg_ep_enable,
- .disable = usbhsg_ep_disable,
- .alloc_request = usbhsg_ep_alloc_request,
- .free_request = usbhsg_ep_free_request,
- .queue = usbhsg_ep_queue,
- .dequeue = usbhsg_ep_dequeue,
- .set_halt = usbhsg_ep_set_halt,
- .set_wedge = usbhsg_ep_set_wedge,
pullup control
+static int usbhsg_can_pullup(struct usbhs_priv *priv) +{
- return gpriv->driver &&
usbhsg_status_has(gpriv, USBHSG_STATUS_SOFT_CONNECT);
+static void usbhsg_update_pullup(struct usbhs_priv *priv) +{
- if (usbhsg_can_pullup(priv))
usbhs_sys_function_pullup(priv, 1);
- else
usbhs_sys_function_pullup(priv, 0);
usb module start/end
+static int usbhsg_try_start(struct usbhs_priv *priv, u32 status) +{
- struct device *dev = usbhs_priv_to_dev(priv);
- int ret = 0;
- usbhsg_status_set(gpriv, status);
- if (!(usbhsg_status_has(gpriv, USBHSG_STATUS_STARTED) &&
usbhsg_status_has(gpriv, USBHSG_STATUS_REGISTERD)))
ret = -1; /* not ready */
- /******************** spin unlock ********************/
- if (ret < 0)
return 0; /* not ready is not error */
* enable interrupt and systems if ready
- dev_dbg(dev, "start gadget\n");
* pipe initialize and enable DCP
- usbhs_fifo_init(priv);
- usbhs_pipe_init(priv,
usbhsg_dma_map_ctrl);
- /* dcp init instead of usbhsg_ep_enable() */
- dcp->pipe = usbhs_dcp_malloc(priv);
- dcp->pipe->mod_private = dcp;
- usbhs_pipe_config_update(dcp->pipe, 0, 0, 64);
* system config enble
* - HI speed
* - function
* - usb module
- usbhs_sys_function_ctrl(priv, 1);
- usbhsg_update_pullup(priv);
* enable irq callback
- mod->irq_dev_state = usbhsg_irq_dev_state;
- mod->irq_ctrl_stage = usbhsg_irq_ctrl_stage;
- usbhs_irq_callback_update(priv, mod);
+static int usbhsg_try_stop(struct usbhs_priv *priv, u32 status) +{
- int ret = 0, i;
- usbhsg_status_clr(gpriv, status);
- if (!usbhsg_status_has(gpriv, USBHSG_STATUS_STARTED) &&
!usbhsg_status_has(gpriv, USBHSG_STATUS_REGISTERD))
ret = -1; /* already done */
- if (ret < 0)
return 0; /* already done is not error */
* disable interrupt and systems if 1st try
- usbhs_fifo_quit(priv);
- /* disable all irq */
- mod->irq_dev_state = NULL;
- mod->irq_ctrl_stage = NULL;
- gpriv->gadget.speed = USB_SPEED_UNKNOWN;
- /* disable sys */
- usbhs_sys_set_test_mode(priv, 0);
- usbhs_sys_function_ctrl(priv, 0);
- /* disable all eps */
- usbhsg_for_each_uep_with_dcp(uep, gpriv, i)
usbhsg_ep_disable(&uep->ep);
- dev_dbg(dev, "stop gadget\n");
- VBUS provided by the PHY
+static void usbhs_mod_phy_mode(struct usbhs_priv *priv) +{
- struct usbhs_mod_info *info = &priv->mod_info;
- info->irq_vbus = NULL;
linux usb function
+static int usbhsg_gadget_start(struct usb_gadget *gadget,
struct usb_gadget_driver *driver)
- struct usbhsg_gpriv *gpriv = usbhsg_gadget_to_gpriv(gadget);
- if (!driver || !driver->setup)
return -EINVAL;
- /* get vbus using phy versions */
- usbhs_mod_phy_mode(priv);
- /* first hook up the driver ... */
- gpriv->driver = driver;
- return usbhsg_try_start(priv, USBHSG_STATUS_REGISTERD);
+static int usbhsg_gadget_stop(struct usb_gadget *gadget) +{
- usbhsg_try_stop(priv, USBHSG_STATUS_REGISTERD);
- gpriv->driver = NULL;
usb gadget ops
+static int usbhsg_get_frame(struct usb_gadget *gadget) +{
- return usbhs_frame_get_num(priv);
+static int usbhsg_pullup(struct usb_gadget *gadget, int is_on) +{
- if (is_on)
usbhsg_status_set(gpriv, USBHSG_STATUS_SOFT_CONNECT);
- else
usbhsg_status_clr(gpriv, USBHSG_STATUS_SOFT_CONNECT);
+static int usbhsg_set_selfpowered(struct usb_gadget *gadget, int is_self) +{
- if (is_self)
usbhsg_status_set(gpriv, USBHSG_STATUS_SELF_POWERED);
- else
usbhsg_status_clr(gpriv, USBHSG_STATUS_SELF_POWERED);
+static int usbhsg_vbus_session(struct usb_gadget *gadget, int is_active) +{
- gpriv->vbus_active = !!is_active;
+static const struct usb_gadget_ops usbhsg_gadget_ops = {
- .get_frame = usbhsg_get_frame,
- .set_selfpowered = usbhsg_set_selfpowered,
- .udc_start = usbhsg_gadget_start,
- .udc_stop = usbhsg_gadget_stop,
- .pullup = usbhsg_pullup,
- .vbus_session = usbhsg_vbus_session,
+static int usbhsg_start(struct usbhs_priv *priv) +{
- return usbhsg_try_start(priv, USBHSG_STATUS_STARTED);
+static int usbhsg_stop(struct usbhs_priv *priv) +{
- /* cable disconnect */
- if (gpriv->driver &&
gpriv->driver->disconnect)
gpriv->driver->disconnect(&gpriv->gadget);
- return usbhsg_try_stop(priv, USBHSG_STATUS_STARTED);
+int usbhs_mod_gadget_probe(struct usbhs_priv *priv) +{
- struct renesas_usbhs_driver_pipe_config *pipe_configs =
usbhs_get_dparam(priv, pipe_configs);
- int pipe_size = usbhs_get_dparam(priv, pipe_size);
- int i;
- int ret;
- gpriv = kzalloc(sizeof(struct usbhsg_gpriv), GFP_KERNEL);
- if (!gpriv)
return -ENOMEM;
- uep = kcalloc(pipe_size, sizeof(struct usbhsg_uep), GFP_KERNEL);
- if (!uep) {
ret = -ENOMEM;
goto usbhs_mod_gadget_probe_err_gpriv;
* CAUTION
* There is no guarantee that it is possible to access usb module here.
* Don't accesses to it.
* The accesse will be enable after "usbhsg_start"
* register itself
- usbhs_mod_register(priv, &gpriv->mod, USBHS_GADGET);
- /* init gpriv */
- gpriv->mod.name = "gadget";
- gpriv->mod.start = usbhsg_start;
- gpriv->mod.stop = usbhsg_stop;
- gpriv->uep = uep;
- gpriv->uep_size = pipe_size;
- usbhsg_status_init(gpriv);
* init gadget
- gpriv->gadget.dev.parent = dev;
- gpriv->gadget.name = "renesas_usbhs_udc";
- gpriv->gadget.ops = &usbhsg_gadget_ops;
- gpriv->gadget.max_speed = USB_SPEED_HIGH;
- INIT_LIST_HEAD(&gpriv->gadget.ep_list);
* init usb_ep
- usbhsg_for_each_uep_with_dcp(uep, gpriv, i) {
uep->gpriv = gpriv;
uep->pipe = NULL;
snprintf(uep->ep_name, EP_NAME_SIZE, "ep%d", i);
uep->ep.name = uep->ep_name;
uep->ep.ops = &usbhsg_ep_ops;
INIT_LIST_HEAD(&uep->ep.ep_list);
spin_lock_init(&uep->lock);
/* init DCP */
if (usbhsg_is_dcp(uep)) {
gpriv->gadget.ep0 = &uep->ep;
usb_ep_set_maxpacket_limit(&uep->ep, 64);
uep->ep.caps.type_control = true;
} else {
/* init normal pipe */
if (pipe_configs[i].type == USB_ENDPOINT_XFER_ISOC)
uep->ep.caps.type_iso = true;
if (pipe_configs[i].type == USB_ENDPOINT_XFER_BULK)
uep->ep.caps.type_bulk = true;
if (pipe_configs[i].type == USB_ENDPOINT_XFER_INT)
uep->ep.caps.type_int = true;
pipe_configs[i].bufsize);
list_add_tail(&uep->ep.ep_list, &gpriv->gadget.ep_list);
uep->ep.caps.dir_in = true;
uep->ep.caps.dir_out = true;
- ret = usb_add_gadget_udc(dev, &gpriv->gadget);
- if (ret)
goto err_add_udc;
- dev_info(dev, "gadget probed\n");
+err_add_udc:
- kfree(gpriv->uep);
+usbhs_mod_gadget_probe_err_gpriv:
- kfree(gpriv);
- return ret;
+void usbhs_mod_gadget_remove(struct usbhs_priv *priv) +{
- usb_del_gadget_udc(&gpriv->gadget);
- kfree(gpriv);
+struct usb_gadget *usbhsg_get_gadget(struct usbhs_priv *priv) +{
- return &gpriv->gadget;
+} diff --git a/drivers/usb/gadget/rcar/pipe.c b/drivers/usb/gadget/rcar/pipe.c new file mode 100644 index 00000000000..a2b24f38144 --- /dev/null +++ b/drivers/usb/gadget/rcar/pipe.c @@ -0,0 +1,849 @@ +// SPDX-License-Identifier: GPL-1.0+ +/*
- Renesas USB driver
- Copyright (C) 2011 Renesas Solutions Corp.
- Kuninori Morimoto kuninori.morimoto.gx@renesas.com
+#include <linux/delay.h> +#include "common.h" +#include "pipe.h"
macros
+#define usbhsp_addr_offset(p) ((usbhs_pipe_number(p) - 1) * 2)
+#define usbhsp_flags_set(p, f) ((p)->flags |= USBHS_PIPE_FLAGS_##f) +#define usbhsp_flags_clr(p, f) ((p)->flags &= ~USBHS_PIPE_FLAGS_##f) +#define usbhsp_flags_has(p, f) ((p)->flags & USBHS_PIPE_FLAGS_##f) +#define usbhsp_flags_init(p) do {(p)->flags = 0; } while (0)
- for debug
+static char *usbhsp_pipe_name[] = {
- [USB_ENDPOINT_XFER_CONTROL] = "DCP",
- [USB_ENDPOINT_XFER_BULK] = "BULK",
- [USB_ENDPOINT_XFER_INT] = "INT",
- [USB_ENDPOINT_XFER_ISOC] = "ISO",
+char *usbhs_pipe_name(struct usbhs_pipe *pipe) +{
- return usbhsp_pipe_name[usbhs_pipe_type(pipe)];
+static struct renesas_usbhs_driver_pipe_config +*usbhsp_get_pipe_config(struct usbhs_priv *priv, int pipe_num) +{
- return &pipe_configs[pipe_num];
DCPCTR/PIPEnCTR functions
+static void usbhsp_pipectrl_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{
- int offset = usbhsp_addr_offset(pipe);
usbhs_bset(priv, DCPCTR, mask, val);
- else
usbhs_bset(priv, PIPEnCTR + offset, mask, val);
+static u16 usbhsp_pipectrl_get(struct usbhs_pipe *pipe) +{
return usbhs_read(priv, DCPCTR);
- else
return usbhs_read(priv, PIPEnCTR + offset);
DCP/PIPE functions
+static void __usbhsp_pipe_xxx_set(struct usbhs_pipe *pipe,
u16 dcp_reg, u16 pipe_reg,
u16 mask, u16 val)
usbhs_bset(priv, dcp_reg, mask, val);
- else
usbhs_bset(priv, pipe_reg, mask, val);
+static u16 __usbhsp_pipe_xxx_get(struct usbhs_pipe *pipe,
u16 dcp_reg, u16 pipe_reg)
return usbhs_read(priv, dcp_reg);
- else
return usbhs_read(priv, pipe_reg);
DCPCFG/PIPECFG functions
+static void usbhsp_pipe_cfg_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{
- __usbhsp_pipe_xxx_set(pipe, DCPCFG, PIPECFG, mask, val);
+static u16 usbhsp_pipe_cfg_get(struct usbhs_pipe *pipe) +{
- return __usbhsp_pipe_xxx_get(pipe, DCPCFG, PIPECFG);
PIPEnTRN/PIPEnTRE functions
+static void usbhsp_pipe_trn_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{
- int num = usbhs_pipe_number(pipe);
- u16 reg;
* It is impossible to calculate address,
* since PIPEnTRN addresses were mapped randomly.
+#define CASE_PIPExTRN(a) \
- case 0x ## a: \
reg = PIPE ## a ## TRN; \
break;
- switch (num) {
- CASE_PIPExTRN(1);
- CASE_PIPExTRN(2);
- CASE_PIPExTRN(3);
- CASE_PIPExTRN(4);
- CASE_PIPExTRN(5);
- CASE_PIPExTRN(B);
- CASE_PIPExTRN(C);
- CASE_PIPExTRN(D);
- CASE_PIPExTRN(E);
- CASE_PIPExTRN(F);
- CASE_PIPExTRN(9);
- CASE_PIPExTRN(A);
- default:
dev_err(dev, "unknown pipe (%d)\n", num);
return;
- __usbhsp_pipe_xxx_set(pipe, 0, reg, mask, val);
+static void usbhsp_pipe_tre_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{
- u16 reg;
* since PIPEnTRE addresses were mapped randomly.
+#define CASE_PIPExTRE(a) \
- case 0x ## a: \
reg = PIPE ## a ## TRE; \
break;
- switch (num) {
- CASE_PIPExTRE(1);
- CASE_PIPExTRE(2);
- CASE_PIPExTRE(3);
- CASE_PIPExTRE(4);
- CASE_PIPExTRE(5);
- CASE_PIPExTRE(B);
- CASE_PIPExTRE(C);
- CASE_PIPExTRE(D);
- CASE_PIPExTRE(E);
- CASE_PIPExTRE(F);
- CASE_PIPExTRE(9);
- CASE_PIPExTRE(A);
- default:
return;
PIPEBUF
+static void usbhsp_pipe_buf_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{
return;
- __usbhsp_pipe_xxx_set(pipe, 0, PIPEBUF, mask, val);
DCPMAXP/PIPEMAXP
+static void usbhsp_pipe_maxp_set(struct usbhs_pipe *pipe, u16 mask, u16 val) +{
- __usbhsp_pipe_xxx_set(pipe, DCPMAXP, PIPEMAXP, mask, val);
pipe control functions
+static void usbhsp_pipe_select(struct usbhs_pipe *pipe) +{
* On pipe, this is necessary before
* accesses to below registers.
* PIPESEL : usbhsp_pipe_select
* PIPECFG : usbhsp_pipe_cfg_xxx
* PIPEBUF : usbhsp_pipe_buf_xxx
* PIPEMAXP : usbhsp_pipe_maxp_xxx
* PIPEPERI
* if pipe is dcp, no pipe is selected.
* it is no problem, because dcp have its register
- usbhs_write(priv, PIPESEL, 0xF & usbhs_pipe_number(pipe));
+static int usbhsp_pipe_barrier(struct usbhs_pipe *pipe) +{
- u16 mask = usbhs_mod_is_host(priv) ? (CSSTS | PID_MASK) : PID_MASK;
* make sure....
* Modify these bits when CSSTS = 0, PID = NAK, and no pipe number is
* specified by the CURPIPE bits.
* When changing the setting of this bit after changing
* the PID bits for the selected pipe from BUF to NAK,
* check that CSSTS = 0 and PBUSY = 0.
* CURPIPE bit = 0
* see also
* "Operation"
* - "Pipe Control"
* - "Pipe Control Registers Switching Procedure"
- usbhs_write(priv, CFIFOSEL, 0);
- do {
if (!(usbhsp_pipectrl_get(pipe) & mask))
udelay(10);
- } while (timeout--);
- return -EBUSY;
+int usbhs_pipe_is_accessible(struct usbhs_pipe *pipe) +{
- u16 val;
- val = usbhsp_pipectrl_get(pipe);
- if (val & BSTS)
- return -EBUSY;
+bool usbhs_pipe_contains_transmittable_data(struct usbhs_pipe *pipe) +{
- u16 val;
- /* Do not support for DCP pipe */
return false;
- if (val & INBUFM)
return true;
- return false;
PID ctrl
+static void __usbhsp_pid_try_nak_if_stall(struct usbhs_pipe *pipe) +{
- u16 pid = usbhsp_pipectrl_get(pipe);
- pid &= PID_MASK;
* see
* "Pipe n Control Register" - "PID"
- switch (pid) {
- case PID_STALL11:
usbhsp_pipectrl_set(pipe, PID_MASK, PID_STALL10);
fallthrough;
- case PID_STALL10:
usbhsp_pipectrl_set(pipe, PID_MASK, PID_NAK);
+void usbhs_pipe_disable(struct usbhs_pipe *pipe) +{
- u16 val;
- /* see "Pipe n Control Register" - "PID" */
- __usbhsp_pid_try_nak_if_stall(pipe);
- usbhsp_pipectrl_set(pipe, PID_MASK, PID_NAK);
- do {
val &= PBUSY;
if (!val)
break;
udelay(10);
+void usbhs_pipe_enable(struct usbhs_pipe *pipe) +{
- usbhsp_pipectrl_set(pipe, PID_MASK, PID_BUF);
+void usbhs_pipe_stall(struct usbhs_pipe *pipe) +{
- pid &= PID_MASK;
* see
- switch (pid) {
- case PID_NAK:
break;
- case PID_BUF:
usbhsp_pipectrl_set(pipe, PID_MASK, PID_STALL11);
break;
+int usbhs_pipe_is_stall(struct usbhs_pipe *pipe) +{
- u16 pid = usbhsp_pipectrl_get(pipe) & PID_MASK;
- return (int)(pid == PID_STALL10 || pid == PID_STALL11);
+void usbhs_pipe_set_trans_count_if_bulk(struct usbhs_pipe *pipe, int len) +{
- if (!usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_BULK))
return;
* clear and disable transfer counter for IN/OUT pipe
- usbhsp_pipe_tre_set(pipe, TRCLR | TRENB, TRCLR);
* Only IN direction bulk pipe can use transfer count.
* Without using this function,
* received data will break if it was large data size.
* see PIPEnTRN/PIPEnTRE for detail
- if (usbhs_pipe_is_dir_in(pipe)) {
usbhsp_pipe_trn_set(pipe, 0xffff, DIV_ROUND_UP(len, maxp));
usbhsp_pipe_tre_set(pipe, TRENB, TRENB); /* enable */
pipe setup
+static int usbhsp_setup_pipecfg(struct usbhs_pipe *pipe, int is_host,
int dir_in, u16 *pipecfg)
- u16 type = 0;
- u16 bfre = 0;
- u16 dblb = 0;
- u16 cntmd = 0;
- u16 dir = 0;
- u16 epnum = 0;
- u16 shtnak = 0;
- static const u16 type_array[] = {
[USB_ENDPOINT_XFER_BULK] = TYPE_BULK,
[USB_ENDPOINT_XFER_INT] = TYPE_INT,
[USB_ENDPOINT_XFER_ISOC] = TYPE_ISO,
return -EINVAL;
* PIPECFG
* see
* - "Register Descriptions" - "PIPECFG" register
* - "Features" - "Pipe configuration"
* - "Operation" - "Pipe Control"
- /* TYPE */
- type = type_array[usbhs_pipe_type(pipe)];
- /* BFRE */
- if (usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_ISOC) ||
bfre = 0; /* FIXME */
- /* DBLB: see usbhs_pipe_config_update() */
- /* CNTMD */
- if (usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_BULK))
cntmd = 0; /* FIXME */
- /* DIR */
- if (dir_in)
usbhsp_flags_set(pipe, IS_DIR_HOST);
- if (!!is_host ^ !!dir_in)
dir |= DIR_OUT;
- if (!dir)
usbhsp_flags_set(pipe, IS_DIR_IN);
- /* SHTNAK */
- if (usbhs_pipe_type_is(pipe, USB_ENDPOINT_XFER_BULK) &&
!dir)
shtnak = SHTNAK;
- /* EPNUM */
- epnum = 0; /* see usbhs_pipe_config_update() */
- *pipecfg = type |
bfre |
dblb |
cntmd |
dir |
shtnak |
epnum;
+static u16 usbhsp_setup_pipebuff(struct usbhs_pipe *pipe) +{
- int pipe_num = usbhs_pipe_number(pipe);
- u16 buff_size;
- u16 bufnmb;
- u16 bufnmb_cnt;
- struct renesas_usbhs_driver_pipe_config *pipe_config =
usbhsp_get_pipe_config(priv, pipe_num);
* PIPEBUF
* see
* - "Register Descriptions" - "PIPEBUF" register
* - "Operation" - "FIFO Buffer Memory"
- buff_size = pipe_config->bufsize;
- bufnmb = pipe_config->bufnum;
- /* change buff_size to register value */
- bufnmb_cnt = (buff_size / 64) - 1;
- dev_dbg(dev, "pipe : %d : buff_size 0x%x: bufnmb 0x%x\n",
pipe_num, buff_size, bufnmb);
- return (0x1f & bufnmb_cnt) << 10 |
(0xff & bufnmb) << 0;
+void usbhs_pipe_config_update(struct usbhs_pipe *pipe, u16 devsel,
u16 epnum, u16 maxp)
- u16 dblb = pipe_config->double_buf ? DBLB : 0;
- if (devsel > 0xA) {
dev_err(dev, "devsel error %d\n", devsel);
devsel = 0;
- usbhsp_pipe_barrier(pipe);
- pipe->maxp = maxp;
- usbhsp_pipe_select(pipe);
- usbhsp_pipe_maxp_set(pipe, 0xFFFF,
(devsel << 12) |
maxp);
usbhsp_pipe_cfg_set(pipe, 0x000F | DBLB, epnum | dblb);
pipe control
+int usbhs_pipe_get_maxpacket(struct usbhs_pipe *pipe) +{
* see
* usbhs_pipe_config_update()
* usbhs_dcp_malloc()
- return pipe->maxp;
+int usbhs_pipe_is_dir_in(struct usbhs_pipe *pipe) +{
- return usbhsp_flags_has(pipe, IS_DIR_IN);
+int usbhs_pipe_is_dir_host(struct usbhs_pipe *pipe) +{
- return usbhsp_flags_has(pipe, IS_DIR_HOST);
+int usbhs_pipe_is_running(struct usbhs_pipe *pipe) +{
- return usbhsp_flags_has(pipe, IS_RUNNING);
+void usbhs_pipe_running(struct usbhs_pipe *pipe, int running) +{
- if (running)
usbhsp_flags_set(pipe, IS_RUNNING);
- else
usbhsp_flags_clr(pipe, IS_RUNNING);
+void usbhs_pipe_data_sequence(struct usbhs_pipe *pipe, int sequence) +{
- u16 mask = (SQCLR | SQSET);
- u16 val;
* sequence
* 0 : data0
* 1 : data1
* -1 : no change
- switch (sequence) {
- case 0:
val = SQCLR;
break;
- case 1:
val = SQSET;
break;
- default:
return;
- usbhsp_pipectrl_set(pipe, mask, val);
+static int usbhs_pipe_get_data_sequence(struct usbhs_pipe *pipe) +{
- return !!(usbhsp_pipectrl_get(pipe) & SQMON);
+void usbhs_pipe_clear(struct usbhs_pipe *pipe) +{
usbhs_fifo_clear_dcp(pipe);
- } else {
usbhsp_pipectrl_set(pipe, ACLRM, ACLRM);
usbhsp_pipectrl_set(pipe, ACLRM, 0);
+/* Should call usbhsp_pipe_select() before */ +void usbhs_pipe_clear_without_sequence(struct usbhs_pipe *pipe,
int needs_bfre, int bfre_enable)
- int sequence;
- sequence = usbhs_pipe_get_data_sequence(pipe);
- if (needs_bfre)
usbhsp_pipe_cfg_set(pipe, BFRE, bfre_enable ? BFRE : 0);
- usbhs_pipe_clear(pipe);
- usbhs_pipe_data_sequence(pipe, sequence);
+void usbhs_pipe_config_change_bfre(struct usbhs_pipe *pipe, int enable) +{
return;
- /* check if the driver needs to change the BFRE value */
- if (!(enable ^ !!(usbhsp_pipe_cfg_get(pipe) & BFRE)))
return;
- usbhs_pipe_clear_without_sequence(pipe, 1, enable);
+static struct usbhs_pipe *usbhsp_get_pipe(struct usbhs_priv *priv, u32 type) +{
- struct usbhs_pipe *pos, *pipe;
- int i;
* find target pipe
- pipe = NULL;
- usbhs_for_each_pipe_with_dcp(pos, priv, i) {
if (!usbhs_pipe_type_is(pos, type))
continue;
if (usbhsp_flags_has(pos, IS_USED))
continue;
pipe = pos;
break;
- if (!pipe)
return NULL;
* initialize pipe flags
- usbhsp_flags_init(pipe);
- usbhsp_flags_set(pipe, IS_USED);
- return pipe;
+static void usbhsp_put_pipe(struct usbhs_pipe *pipe) +{
+void usbhs_pipe_init(struct usbhs_priv *priv,
int (*dma_map_ctrl)(struct usbhs_pkt *pkt, int map))
- int i;
pipe->fifo = NULL;
INIT_LIST_HEAD(&pipe->list);
/* pipe force init */
- info->dma_map_ctrl = dma_map_ctrl;
+struct usbhs_pipe *usbhs_pipe_malloc(struct usbhs_priv *priv,
int endpoint_type,
int dir_in)
- int is_host = usbhs_mod_is_host(priv);
- int ret;
- u16 pipecfg, pipebuf;
- pipe = usbhsp_get_pipe(priv, endpoint_type);
- if (!pipe) {
dev_err(dev, "can't get pipe (%s)\n",
usbhsp_pipe_name[endpoint_type]);
return NULL;
- INIT_LIST_HEAD(&pipe->list);
- /* make sure pipe is not busy */
- ret = usbhsp_pipe_barrier(pipe);
- if (ret < 0) {
dev_err(dev, "pipe setup failed %d\n", usbhs_pipe_number(pipe));
return NULL;
- if (usbhsp_setup_pipecfg(pipe, is_host, dir_in, &pipecfg)) {
dev_err(dev, "can't setup pipe\n");
return NULL;
- pipebuf = usbhsp_setup_pipebuff(pipe);
- usbhsp_pipe_cfg_set(pipe, 0xFFFF, pipecfg);
- usbhsp_pipe_buf_set(pipe, 0xFFFF, pipebuf);
- usbhs_pipe_sequence_data0(pipe);
- dev_dbg(dev, "enable pipe %d : %s (%s)\n",
usbhs_pipe_name(pipe),
usbhs_pipe_is_dir_in(pipe) ? "in" : "out");
* epnum / maxp are still not set to this pipe.
* call usbhs_pipe_config_update() after this function !!
- return pipe;
+void usbhs_pipe_free(struct usbhs_pipe *pipe) +{
- usbhsp_pipe_cfg_set(pipe, 0xFFFF, 0);
- usbhsp_put_pipe(pipe);
+void usbhs_pipe_select_fifo(struct usbhs_pipe *pipe, struct usbhs_fifo *fifo) +{
- if (pipe->fifo)
pipe->fifo->pipe = NULL;
- pipe->fifo = fifo;
- if (fifo)
fifo->pipe = pipe;
dcp control
+struct usbhs_pipe *usbhs_dcp_malloc(struct usbhs_priv *priv) +{
- pipe = usbhsp_get_pipe(priv, USB_ENDPOINT_XFER_CONTROL);
- if (!pipe)
return NULL;
- return pipe;
+void usbhs_dcp_control_transfer_done(struct usbhs_pipe *pipe) +{
- struct usbhs_priv *priv = usbhs_pipe_to_priv(pipe);
- WARN_ON(!usbhs_pipe_is_dcp(pipe));
- if (!usbhs_mod_is_host(priv)) /* funconly */
usbhsp_pipectrl_set(pipe, CCPL, CCPL);
+void usbhs_dcp_dir_for_host(struct usbhs_pipe *pipe, int dir_out) +{
- usbhsp_pipe_cfg_set(pipe, DIR_OUT,
dir_out ? DIR_OUT : 0);
pipe module function
+int usbhs_pipe_probe(struct usbhs_priv *priv) +{
- int i;
- /* This driver expects 1st pipe is DCP */
- if (pipe_configs[0].type != USB_ENDPOINT_XFER_CONTROL) {
dev_err(dev, "1st PIPE is not DCP\n");
return -EINVAL;
- info->pipe = kcalloc(pipe_size, sizeof(struct usbhs_pipe),
GFP_KERNEL);
- if (!info->pipe)
return -ENOMEM;
- info->size = pipe_size;
* init pipe
pipe->priv = priv;
usbhs_pipe_type(pipe) =
pipe_configs[i].type & USB_ENDPOINT_XFERTYPE_MASK;
dev_dbg(dev, "pipe %x\t: %s\n",
i, usbhsp_pipe_name[pipe_configs[i].type]);
+void usbhs_pipe_remove(struct usbhs_priv *priv) +{
- kfree(info->pipe);
+} diff --git a/drivers/usb/gadget/rcar/pipe.h b/drivers/usb/gadget/rcar/pipe.h new file mode 100644 index 00000000000..01c15178a28 --- /dev/null +++ b/drivers/usb/gadget/rcar/pipe.h @@ -0,0 +1,114 @@ +// SPDX-License-Identifier: GPL-1.0+ +/*
+#ifndef RENESAS_USB_PIPE_H +#define RENESAS_USB_PIPE_H
+#include "common.h" +#include "fifo.h"
- struct
+struct usbhs_pipe {
- u32 pipe_type; /* USB_ENDPOINT_XFER_xxx */
- struct list_head list;
- int maxp;
- u32 flags;
+#define USBHS_PIPE_FLAGS_IS_USED (1 << 0) +#define USBHS_PIPE_FLAGS_IS_DIR_IN (1 << 1) +#define USBHS_PIPE_FLAGS_IS_DIR_HOST (1 << 2) +#define USBHS_PIPE_FLAGS_IS_RUNNING (1 << 3)
- void *mod_private;
+struct usbhs_pipe_info {
- int size; /* array size of "pipe" */
- int (*dma_map_ctrl)(struct usbhs_pkt *pkt, int map);
- pipe list
+#define __usbhs_for_each_pipe(start, pos, info, i) \
((i) < (info)->size) && ((pos) = (info)->pipe + (i)); \
(i)++)
+#define usbhs_for_each_pipe(pos, priv, i) \
- __usbhs_for_each_pipe(1, pos, &((priv)->pipe_info), i)
+#define usbhs_for_each_pipe_with_dcp(pos, priv, i) \
- __usbhs_for_each_pipe(0, pos, &((priv)->pipe_info), i)
- data
+#define usbhs_priv_to_pipeinfo(pr) (&(pr)->pipe_info)
- pipe control
+char *usbhs_pipe_name(struct usbhs_pipe *pipe); +struct usbhs_pipe +*usbhs_pipe_malloc(struct usbhs_priv *priv, int endpoint_type, int dir_in); +void usbhs_pipe_free(struct usbhs_pipe *pipe); +int usbhs_pipe_probe(struct usbhs_priv *priv); +void usbhs_pipe_remove(struct usbhs_priv *priv); +int usbhs_pipe_is_dir_in(struct usbhs_pipe *pipe); +int usbhs_pipe_is_dir_host(struct usbhs_pipe *pipe); +int usbhs_pipe_is_running(struct usbhs_pipe *pipe); +void usbhs_pipe_running(struct usbhs_pipe *pipe, int running);
int (*dma_map_ctrl)(struct usbhs_pkt *pkt, int map));
+int usbhs_pipe_get_maxpacket(struct usbhs_pipe *pipe); +void usbhs_pipe_clear(struct usbhs_pipe *pipe); +void usbhs_pipe_clear_without_sequence(struct usbhs_pipe *pipe,
int needs_bfre, int bfre_enable);
+int usbhs_pipe_is_accessible(struct usbhs_pipe *pipe); +void usbhs_pipe_enable(struct usbhs_pipe *pipe); +void usbhs_pipe_disable(struct usbhs_pipe *pipe); +void usbhs_pipe_stall(struct usbhs_pipe *pipe); +int usbhs_pipe_is_stall(struct usbhs_pipe *pipe); +void usbhs_pipe_set_trans_count_if_bulk(struct usbhs_pipe *pipe, int len); +void usbhs_pipe_select_fifo(struct usbhs_pipe *pipe, struct usbhs_fifo *fifo); +void usbhs_pipe_config_update(struct usbhs_pipe *pipe, u16 devsel,
u16 epnum, u16 maxp);
+void usbhs_pipe_config_change_bfre(struct usbhs_pipe *pipe, int enable);
+#define usbhs_pipe_sequence_data0(pipe) usbhs_pipe_data_sequence(pipe, 0) +#define usbhs_pipe_sequence_data1(pipe) usbhs_pipe_data_sequence(pipe, 1) +void usbhs_pipe_data_sequence(struct usbhs_pipe *pipe, int data);
+#define usbhs_pipe_to_priv(p) ((p)->priv) +#define usbhs_pipe_number(p) (int)((p) - (p)->priv->pipe_info.pipe) +#define usbhs_pipe_is_dcp(p) ((p)->priv->pipe_info.pipe == (p)) +#define usbhs_pipe_to_fifo(p) ((p)->fifo) +#define usbhs_pipe_is_busy(p) usbhs_pipe_to_fifo(p)
+#define usbhs_pipe_type(p) ((p)->pipe_type) +#define usbhs_pipe_type_is(p, t) ((p)->pipe_type == t)
- dcp control
+struct usbhs_pipe *usbhs_dcp_malloc(struct usbhs_priv *priv); +void usbhs_dcp_control_transfer_done(struct usbhs_pipe *pipe); +void usbhs_dcp_dir_for_host(struct usbhs_pipe *pipe, int dir_out);
+#endif /* RENESAS_USB_PIPE_H */ diff --git a/drivers/usb/gadget/rcar/renesas_usb.h b/drivers/usb/gadget/rcar/renesas_usb.h new file mode 100644 index 00000000000..8155e3dcaf6 --- /dev/null +++ b/drivers/usb/gadget/rcar/renesas_usb.h @@ -0,0 +1,125 @@ +// SPDX-License-Identifier: GPL-1.0+ +/*
- Renesas USB
- Ported to u-boot
- Copyright (C) 2016 GlobalLogic
+#ifndef RENESAS_USB_H +#define RENESAS_USB_H
+#include <linux/usb/ch9.h> +#include <linux/compat.h>
+struct platform_device {
- const char *name;
- struct device dev;
- module type
- it will be return value from get_id
+enum {
- USBHS_HOST = 0,
- USBHS_GADGET,
- USBHS_MAX,
- parameters for renesas usbhs
- some register needs USB chip specific parameters.
- This struct show it to driver
+struct renesas_usbhs_driver_pipe_config {
- u8 type; /* USB_ENDPOINT_XFER_xxx */
- u16 bufsize;
- u8 bufnum;
- bool double_buf;
+}; +#define RENESAS_USBHS_PIPE(_type, _size, _num, _double_buf) { \
.type = (_type), \
.bufsize = (_size), \
.bufnum = (_num), \
.double_buf = (_double_buf), \
+struct renesas_usbhs_driver_param {
* pipe settings
- struct renesas_usbhs_driver_pipe_config *pipe_configs;
- int pipe_size; /* pipe_configs array size */
* option:
* for BUSWAIT :: BWAIT
* see
* renesas_usbhs/common.c :: usbhsc_set_buswait()
- int buswait_bwait;
* option:
* delay time from notify_hotplug callback
- int detection_delay; /* msec */
* option:
* dma id for dmaengine
* The data transfer direction on D0FIFO/D1FIFO should be
* fixed for keeping consistency.
* So, the platform id settings will be..
* .d0_tx_id = xx_TX,
* .d1_rx_id = xx_RX,
* or
* .d1_tx_id = xx_TX,
* .d0_rx_id = xx_RX,
- int d0_tx_id;
- int d0_rx_id;
- int d1_tx_id;
- int d1_rx_id;
- int d2_tx_id;
- int d2_rx_id;
- int d3_tx_id;
- int d3_rx_id;
* option:
* pio <--> dma border.
- int pio_dma_border; /* default is 64byte */
- uintptr_t type;
- u32 enable_gpio;
* option:
- u32 has_otg:1; /* for controlling PWEN/EXTLP */
- u32 has_sudmac:1; /* for SUDMAC */
- u32 has_usb_dmac:1; /* for USB-DMAC */
- u32 cfifo_byte_addr:1; /* CFIFO is byte addressable */
+#define USBHS_USB_DMAC_XFER_SIZE 32 /* hardcode the xfer size */
- u32 multi_clks:1;
- u32 has_new_pipe_configs:1;
+#define USBHS_TYPE_RCAR_GEN3 2
+struct usbhs_priv; +struct usb_gadget *usbhsg_get_gadget(struct usbhs_priv *priv);
+#endif /* RENESAS_USB_H */
2.45.2
On Mon, 09 Sep 2024 01:06:24 +0200, Marek Vasut wrote:
Add UDC driver for Renesas USBHS controller found in R-Car Gen3 SoCs. This is mostly ported from the Linux kernel, with additional porting glue. The code has been synchronized with 1b4861e32e46 ("Linux 6.9.3") and cleaned up and ported to DM since the original implementation by Vitaliy.
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-dfu (u-boot-dfu-next)
[1/1] usb: gadget: usbhs: Add Renesas USBHS device driver https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/50bb758c1e3424d...
-- Mattijs
Mattijs Korpershoek
