[U-Boot] [PATCH] imx: ventana: relax phy reset times
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index dc8cd88..7052663 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -132,9 +132,9 @@ static void setup_iomux_enet(int gpio) /* toggle PHY_RST# */ gpio_request(gpio, "phy_rst#"); gpio_direction_output(gpio, 0); - mdelay(10); + mdelay(2); gpio_set_value(gpio, 1); - mdelay(100); + mdelay(15); }
#ifdef CONFIG_USB_EHCI_MX6
- mdelay(10);
- mdelay(2); gpio_set_value(gpio, 1);
- mdelay(100);
- mdelay(15);
Reviewed-by: Stefano Babic sbabic@denx.de
Tim, I have seen some warnings by compiling your new boards. Reason is that the new configs (emmc, nand) are missing from the MAINTAINERS file. Can you send a patch to fix this ? You can see the warnings if you run "buildman gw_ventana" - thanks !
Best regards, Stefano
mdelay(10);
mdelay(100);
mdelay(15);
Will do - thanks for the heads-up!
Please drop this patch... I'm still having reliability issues with the MV88E6176 phy reset. The datasheet doesn't give much details about the reset requirements so I'll leave them overly conservative.
Thanks,
Tim
Stefano Babic
Tim Harvey
