[U-Boot] [PATCH] Tegra: Restore cp15 VBAR _start vector write for ARMv7
A start vector fix was added by AneeshV for OMAP4 (commit 0d479b53), and caused the old monilithic Tegra builds to hang due to an undefined instruction trap. Previously, the code needed to run on both the AVP (ARM7TDI) and A9, and the AVP doesn't have a CP15 register. I corrected this in commit 6d6c0bae w/#ifndef CONFIG_TEGRA, but now that we use SPL, and boot the AVP w/o any ARMv7 code, I can revert my change, and make Aneesh's change apply to Tegra.
Signed-off-by: Tom Warren twarren@nvidia.com --- arch/arm/cpu/armv7/start.S | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index c0e1849..7700315 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -251,12 +251,10 @@ ENTRY(c_runtime_cpu_setup) /* * Move vector table */ -#if !defined(CONFIG_TEGRA) /* Set vector address in CP15 VBAR register */ ldr r0, =_start add r0, r0, r9 mcr p15, 0, r0, c12, c0, 0 @Set VBAR -#endif /* !Tegra */
bx lr
Tom,
I applied your patch (and the one from Vincent [1]) but I still get no exception output (just hang) with the test case I posted earlier [2]. There must be still something wrong.
Marc
[1] http://u-boot.10912.n7.nabble.com/PATCH-armv7-do-not-relocate-start-twice- td149815.html [2] http://u-boot.10912.n7.nabble.com/unaligned-access-in-part-efi-c- td150763.html
- Move vector table
bx lr
Marc Dietrich
Tom Warren
