[PATCH] drivers: ram: rockchip: Fix dram channels calculation for rk3399
Only add the dram channel when we finally setup it successfully at the last step.
Signed-off-by: Han Pengfei pengphei@foxmail.com --- drivers/ram/rockchip/sdram_rk3399.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index c0a06dcaed..fd8ba45d68 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -2964,8 +2964,6 @@ static int sdram_init(struct dram_info *dram, if (cap_info->rank == 0) { clear_channel_params(params, 1); continue; - } else { - params->base.num_channels++; }
if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) { @@ -2991,6 +2989,8 @@ static int sdram_init(struct dram_info *dram, printf("no ddrconfig find, Cap not support!\n"); continue; } + + params->base.num_channels++; set_ddrconfig(chan, params, channel, cap_info->ddrconfig); set_cap_relate_config(chan, params, channel); }
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
} else {
set_ddrconfig(chan, params, channel, cap_info->ddrconfig); set_cap_relate_config(chan, params, channel); }params->base.num_channels++;
Kever Yang
