[PATCH v2] tee: optee: Change printing during optee_probe
Right now the error messages when optee has a version mismatch or shared memory is not configured are done with a debug(). That's not very convenient since you have to enable debugging to figure out what's going on, although this is an actual error.
So let's switch the debug() -> dev_err() and report those explicitly.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com --- drivers/tee/optee/core.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/tee/optee/core.c b/drivers/tee/optee/core.c index b898c32edc0b..73dbb22ba097 100644 --- a/drivers/tee/optee/core.c +++ b/drivers/tee/optee/core.c @@ -624,14 +624,14 @@ static int optee_probe(struct udevice *dev) u32 sec_caps;
if (!is_optee_api(pdata->invoke_fn)) { - debug("%s: OP-TEE api uid mismatch\n", __func__); + dev_err(dev, "OP-TEE api uid mismatch\n"); return -ENOENT; }
print_os_revision(dev, pdata->invoke_fn);
if (!api_revision_is_compatible(pdata->invoke_fn)) { - debug("%s: OP-TEE api revision mismatch\n", __func__); + dev_err(dev, "OP-TEE api revision mismatch\n"); return -ENOENT; }
@@ -642,7 +642,7 @@ static int optee_probe(struct udevice *dev) */ if (!exchange_capabilities(pdata->invoke_fn, &sec_caps) || !(sec_caps & OPTEE_SMC_SEC_CAP_DYNAMIC_SHM)) { - debug("%s: OP-TEE capabilities mismatch\n", __func__); + dev_err(dev, "OP-TEE capabilities mismatch\n"); return -ENOENT; }
Hi Ilias,
On Wed, 10 Mar 2021 at 06:35, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
The code that probes the device should report the error. If you put errors in a device driver it bloats the code and also it makes it impossible for the caller to suppress the error, e.g. if it is OK for the device to not probe.
On Thu, Mar 11, 2021 at 09:45:46PM -0700, Simon Glass wrote:
Hi Ilias,
I am notr sure I am following here. This gets called from the core dm code. Is there a callback in that, so we can register a specific print per device? If not now how do you expect the core to habdle each specific driver error code and print a message that makes sense?
Well in the op-tee case it's an explicit node you need to add in the DTB. So i am not really sure this applies here.
Thanks /Ilias
Hi Ilias,
On Thu, 11 Mar 2021 at 22:07, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Ilias,
Well, who probes the device? Somewhere there is a call to uclass_first_device(...) or similar, and that should receive the error-return value.
I'm not sure, but you might be thinking of the 'bind' step. For probe it is OK for devices to fail to probe.
Ilias Apalodimas
