[PATCH] ufs: core: remove link_startup_again logic
The link_startup_again logic was added in Linux to handle device that were set in LinkDown state, which should not be the case since U-boot doesn't set LinkDown state are init, and Linux sets the device active in ufshcd_init() for the first link startup.
While it worked to far, it breaks link startup for Qualcomm Controllers v5, let's just remove the logic.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/ufs/ufs.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index be64bf971f1..28c244b70e5 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -456,9 +456,7 @@ static int ufshcd_link_startup(struct ufs_hba *hba) { int ret; int retries = DME_LINKSTARTUP_RETRIES; - bool link_startup_again = true;
-link_startup: do { ufshcd_ops_link_startup_notify(hba, PRE_CHANGE);
@@ -484,12 +482,6 @@ link_startup: /* failed to get the link up... retire */ goto out;
- if (link_startup_again) { - link_startup_again = false; - retries = DME_LINKSTARTUP_RETRIES; - goto link_startup; - } - /* Mark that link is up in PWM-G1, 1-lane, SLOW-AUTO mode */ ufshcd_init_pwr_info(hba);
--- base-commit: 7e52d6ccfb76e2afc2d183b357abe2a2e2f948cf change-id: 20240528-topic-sm8x50-ufs-core-link-startup-again-bc2cf907c164
Hi Neil,
s/are/at ?
I don't see any repercussions ATM, but will need to get a wider opinion with different controllers before acking.
goto link_startup;
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-ufs (u-boot-ufs-next)
[1/1] ufs: core: remove link_startup_again logic https://source.denx.de/u-boot/custodians/u-boot-ufs/-/commit/67e291d147cd40c...
Neha Malcom Francis
Neil Armstrong
