[U-Boot] [PATCH 1/3] mx53_smd: add spi nor support
Add spi nor support to mx53 smd, including iomux, configs, etc. To test spi nor on mx53 smd: MX53SMD U-Boot > sf probe 0:21249 JEDEC ID: 0x202016 m25p32 (4096 Kbytes) SF: Detected m25p32 with page size 0 Bytes, total 4 MiB
Here, 21249 is integer of hex 0x5301. 0x01 is cs and 0x53 is active gpio number.
Signed-off-by: Terry Lv r65388@freescale.com --- board/freescale/mx53smd/mx53smd.c | 63 +++++++++++++++++++++++++++++++++++++ include/configs/mx53smd.h | 17 ++++++++++ 2 files changed, 80 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mx53smd/mx53smd.c b/board/freescale/mx53smd/mx53smd.c index 87fa7fa..abb1e9b 100644 --- a/board/freescale/mx53smd/mx53smd.c +++ b/board/freescale/mx53smd/mx53smd.c @@ -127,6 +127,65 @@ static void setup_iomux_fec(void) PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); }
+#ifdef CONFIG_MXC_SPI +static void setup_iomux_spi(u8 bus, u8 ss) +{ + switch (bus) { + case 0: + /* SCLK */ + mxc_request_iomux(MX53_PIN_EIM_D16, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX53_PIN_EIM_D16, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH); + mxc_iomux_set_input(MX53_ECSPI1_IPP_CSPI_CLK_IN_SELECT_INPUT, + 0x3); + + /* MISO */ + mxc_request_iomux(MX53_PIN_EIM_D17, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX53_PIN_EIM_D17, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH); + mxc_iomux_set_input(MX53_ECSPI1_IPP_IND_MISO_SELECT_INPUT, + 0x3); + + /* MOSI */ + mxc_request_iomux(MX53_PIN_EIM_D18, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX53_PIN_EIM_D18, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH); + mxc_iomux_set_input(MX53_ECSPI1_IPP_IND_MOSI_SELECT_INPUT, + 0x3); + + if (0 == ss) { + mxc_request_iomux(MX53_PIN_EIM_EB2, + IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX53_PIN_EIM_EB2, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH); + mxc_iomux_set_input( + MX53_ECSPI1_IPP_IND_SS_B_1_SELECT_INPUT, + 0x3); + + mxc_request_iomux(MX53_PIN_EIM_EB2, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX53_PIN_EIM_EB2, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH); + } else if (1 == ss){ + mxc_request_iomux(MX53_PIN_EIM_D19, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX53_PIN_EIM_D19, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH); + mxc_iomux_set_input( + MX53_ECSPI1_IPP_IND_SS_B_2_SELECT_INPUT, + 0x2); + + mxc_request_iomux(MX53_PIN_EIM_D19, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX53_PIN_EIM_D19, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH); + } + break; + case 1: + case 2: + default: + break; + } +} +#endif + #ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[1] = { {MMC_SDHC1_BASE_ADDR, 1}, @@ -203,6 +262,10 @@ int board_early_init_f(void) { setup_iomux_uart(); setup_iomux_fec(); +#if defined(CONFIG_MXC_SPI) && defined(CONFIG_SPI_FLASH) \ + && defined(CONFIG_SPI_FLASH_BUS) && defined(CONFIG_SPI_FLASH_CS) + setup_iomux_spi(CONFIG_SPI_FLASH_BUS, CONFIG_SPI_FLASH_CS); +#endif
return 0; } diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index 48b32dd..e830c1b 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -65,6 +65,23 @@ #define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
+/* SPI Configs*/ +#define CONFIG_CMD_SPI +#define CONFIG_MXC_SPI +#define CONFIG_SPI_VER_2_3 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR +#define CONFIG_CSPI3_BASE_ADDR CSPI3_BASE_ADDR + +/* SPI Flash Configs */ +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO 1 +#define CONFIG_SF_DEFAULT_SPEED 25000000 +#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) +#define CONFIG_SPI_FLASH_BUS 0 +#define CONFIG_SPI_FLASH_CS 1 + /* Eth Configs */ #define CONFIG_HAS_ETH1 #define CONFIG_MII
In mxc_spi, we used to use soc config, e.g. CONFIG_MX35, CONFIG_MX51. In this way, we can't exlain the difference of spi in each soc and we need to modify the driver for each new soc. Thus, now it use spi version config which can be found in reference manual to diff. And new soc just need to add spi version config in config files to enable it. it would be eaiser than before.
Signed-off-by: Terry Lv r65388@freescale.com --- README | 4 ++- drivers/spi/mxc_spi.c | 59 ++++++++++++++++++++++++------------------------- 2 files changed, 32 insertions(+), 31 deletions(-) mode change 100644 => 100755 drivers/spi/mxc_spi.c
diff --git a/README b/README index 07f1d11..19268d9 100644 --- a/README +++ b/README @@ -1910,7 +1910,9 @@ The following options need to be configured: CONFIG_MXC_SPI
Enables the driver for the SPI controllers on i.MX and MXC - SoCs. Currently i.MX31/35/51 are supported. + SoCs. The board must also define the version of SPI controller + and SPI base addresses that will be used. + Currently i.MX31/35/51/53 are supported.
- FPGA Support: CONFIG_FPGA
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c old mode 100644 new mode 100755 index 2fa7486..2f48483 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -27,14 +27,12 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h>
-#ifdef CONFIG_MX27 -/* i.MX27 has a completely wrong register layout and register definitions in the - * datasheet, the correct one is in the Freescale's Linux driver */ +#if defined(CONFIG_SPI_VER_0_4) || defined(CONFIG_SPI_VER_0_0)
-#error "i.MX27 CSPI not supported due to drastic differences in register definitions" \ +#error "CSPI version not supported due to drastic differences in register definitions" \ "See linux mxc_spi driver from Freescale for details."
-#elif defined(CONFIG_MX31) +#elif defined(CONFIG_SPI_VER_0_5)
#define MXC_CSPICTRL_EN (1 << 0) #define MXC_CSPICTRL_MODE (1 << 1) @@ -54,13 +52,7 @@ #define MXC_CSPIPERIOD_32KHZ (1 << 15) #define MAX_SPI_BYTES 4
-static unsigned long spi_bases[] = { - 0x43fa4000, - 0x50010000, - 0x53f84000, -}; - -#elif defined(CONFIG_MX51) +#elif defined(CONFIG_SPI_VER_2_3)
#define MXC_CSPICTRL_EN (1 << 0) #define MXC_CSPICTRL_MODE (1 << 1) @@ -85,13 +77,7 @@ static unsigned long spi_bases[] = { #define MXC_CSPICON_PHA 0 #define MXC_CSPICON_SSPOL 12
-static unsigned long spi_bases[] = { - CSPI1_BASE_ADDR, - CSPI2_BASE_ADDR, - CSPI3_BASE_ADDR, -}; - -#elif defined(CONFIG_MX35) +#elif defined(CONFIG_SPI_VER_0_7)
#define MXC_CSPICTRL_EN (1 << 0) #define MXC_CSPICTRL_MODE (1 << 1) @@ -111,15 +97,28 @@ static unsigned long spi_bases[] = { #define MXC_CSPIPERIOD_32KHZ (1 << 15) #define MAX_SPI_BYTES 4
-static unsigned long spi_bases[] = { - 0x43fa4000, - 0x50010000, -}; - #else -#error "Unsupported architecture" +#error "Unsupported cspi version" #endif
+static unsigned long spi_bases[] = { +#ifdef CONFIG_CSPI1_BASE_ADDR + CONFIG_CSPI1_BASE_ADDR, +#endif +#ifdef CONFIG_CSPI2_BASE_ADDR + CONFIG_CSPI2_BASE_ADDR, +#endif +#ifdef CONFIG_CSPI3_BASE_ADDR + CONFIG_CSPI3_BASE_ADDR, +#endif +#ifdef CONFIG_CSPI4_BASE_ADDR + CONFIG_CSPI4_BASE_ADDR, +#endif +#ifdef CONFIG_CSPI5_BASE_ADDR + CONFIG_CSPI5_BASE_ADDR, +#endif +}; + #define OUT MXC_GPIO_DIRECTION_OUT
#define reg_read readl @@ -129,7 +128,7 @@ struct mxc_spi_slave { struct spi_slave slave; unsigned long base; u32 ctrl_reg; -#if defined(CONFIG_MX51) +#if defined(CONFIG_SPI_VER_2_3) u32 cfg_reg; #endif int gpio; @@ -167,7 +166,7 @@ u32 get_cspi_div(u32 div) return i; }
-#if defined(CONFIG_MX31) || defined(CONFIG_MX35) +#if defined(CONFIG_SPI_VER_0_5) || defined(CONFIG_SPI_VER_0_7) static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, unsigned int max_hz, unsigned int mode) { @@ -187,7 +186,7 @@ static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, MXC_CSPICTRL_BITCOUNT(MXC_CSPICTRL_MAXBITS) | MXC_CSPICTRL_DATARATE(div) | MXC_CSPICTRL_EN | -#ifdef CONFIG_MX35 +#ifdef CONFIG_SPI_VER_0_7 MXC_CSPICTRL_SSCTL | #endif MXC_CSPICTRL_MODE; @@ -204,7 +203,7 @@ static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, } #endif
-#if defined(CONFIG_MX51) +#if defined(CONFIG_SPI_VER_2_3) static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, unsigned int max_hz, unsigned int mode) { @@ -316,7 +315,7 @@ int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, MXC_CSPICTRL_BITCOUNT(bitlen - 1);
reg_write(®s->ctrl, mxcs->ctrl_reg | MXC_CSPICTRL_EN); -#ifdef CONFIG_MX51 +#ifdef CONFIG_SPI_VER_2_3 reg_write(®s->cfg, mxcs->cfg_reg); #endif
Hi Terry,
I agree with this series, that drops also all nasty adresses using the defines from ix-regs.h. However, I disagree that you move the decision which controller should be used into the board configuration file. This is a SOC propriety, not a board configuration option. A MX31 board cannot set CONFIG_SPI_VER_2_3 - it must use always the right one that belong to the SOC.
I thing that the version number should be moved into the corresponding imx-regs.hm selecting another name, CONFIG_ can then be misleading with the board configuration (only SPI_VER_*, maybe ?).
Best regards, Stefano Babic
Apply new mxc_spi version configs to other soc configs.
Signed-off-by: Terry Lv r65388@freescale.com --- arch/arm/include/asm/arch-mx31/imx-regs.h | 4 ++++ include/configs/efikamx.h | 4 ++++ include/configs/flea3.h | 3 +++ include/configs/imx31_litekit.h | 5 +++++ include/configs/imx31_phycore.h | 4 ++++ include/configs/mx31ads.h | 4 ++++ include/configs/mx31pdk.h | 4 ++++ include/configs/mx35pdk.h | 8 +++++++- include/configs/mx51evk.h | 4 ++++ include/configs/qong.h | 4 ++++ include/configs/tt01.h | 5 +++++ 11 files changed, 48 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h index 0147920..4f9c78c 100644 --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -24,6 +24,10 @@ #ifndef __ASM_ARCH_MX31_IMX_REGS_H #define __ASM_ARCH_MX31_IMX_REGS_H
+#define CSPI1_BASE_ADDR 0x43fa4000 +#define CSPI2_BASE_ADDR 0x50010000 +#define CSPI3_BASE_ADDR 0x53f84000 + #if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) #include <asm/types.h>
diff --git a/include/configs/efikamx.h b/include/configs/efikamx.h index a07c8b5..1fe558d 100644 --- a/include/configs/efikamx.h +++ b/include/configs/efikamx.h @@ -99,6 +99,10 @@
#define CONFIG_HARD_SPI #define CONFIG_MXC_SPI +#define CONFIG_SPI_VER_2_3 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR +#define CONFIG_CSPI3_BASE_ADDR CSPI3_BASE_ADDR #define CONFIG_DEFAULT_SPI_BUS 1 #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
diff --git a/include/configs/flea3.h b/include/configs/flea3.h index d88c578..0d85ed5 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -71,6 +71,9 @@ #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0xfe #define CONFIG_MXC_SPI +#define CONFIG_SPI_VER_0_7 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR #define CONFIG_MXC_GPIO
/* diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index 1455ea2..d213ed0 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -69,6 +69,11 @@
#define CONFIG_HARD_SPI 1 #define CONFIG_MXC_SPI 1 +#define CONFIG_SPI_VER_0_5 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR +#define CONFIG_CSPI3_BASE_ADDR CSPI3_BASE_ADDR + #define CONFIG_DEFAULT_SPI_BUS 1 #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 1b75197..f7c2e2d 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -213,6 +213,10 @@
#define CONFIG_HARD_SPI #define CONFIG_MXC_SPI +#define CONFIG_SPI_VER_0_5 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR +#define CONFIG_CSPI3_BASE_ADDR CSPI3_BASE_ADDR #define CONFIG_CMD_SPI
#define CONFIG_S6E63D6 diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 7e011ae..eff70de 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -65,6 +65,10 @@
#define CONFIG_HARD_SPI 1 #define CONFIG_MXC_SPI 1 +#define CONFIG_SPI_VER_0_5 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR +#define CONFIG_CSPI3_BASE_ADDR CSPI3_BASE_ADDR #define CONFIG_DEFAULT_SPI_BUS 1 #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH) #define CONFIG_MXC_GPIO diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 4253c3e..8210f97 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -67,6 +67,10 @@
#define CONFIG_HARD_SPI #define CONFIG_MXC_SPI +#define CONFIG_SPI_VER_0_5 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR +#define CONFIG_CSPI3_BASE_ADDR CSPI3_BASE_ADDR #define CONFIG_DEFAULT_SPI_BUS 1 #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 32ed609..26eb1d5 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -62,9 +62,15 @@ #define CONFIG_SYS_I2C_MX35_PORT1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0xfe -#define CONFIG_MXC_SPI #define CONFIG_MXC_GPIO
+/* + * SPI Configs + */ +#define CONFIG_MXC_SPI +#define CONFIG_SPI_VER_0_7 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR
/* * PMIC Configs diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 7c7544f..0c23d04 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -68,6 +68,10 @@ #define CONFIG_CMD_SPI
/* PMIC Controller */ #define CONFIG_PMIC diff --git a/include/configs/qong.h b/include/configs/qong.h index 3346802..d2bc39d 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -56,6 +56,10 @@ #define CONFIG_HW_WATCHDOG
#define CONFIG_MXC_SPI +#define CONFIG_SPI_VER_0_5 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR +#define CONFIG_CSPI3_BASE_ADDR CSPI3_BASE_ADDR #define CONFIG_DEFAULT_SPI_BUS 1 #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH) #define CONFIG_RTC_MC13XXX diff --git a/include/configs/tt01.h b/include/configs/tt01.h index 6ef25cd..1de0f10 100644 --- a/include/configs/tt01.h +++ b/include/configs/tt01.h @@ -151,6 +151,11 @@ #define CONFIG_SYS_MX31_UART2
#define CONFIG_MXC_SPI +#define CONFIG_SPI_VER_0_5 1 +#define CONFIG_CSPI1_BASE_ADDR CSPI1_BASE_ADDR +#define CONFIG_CSPI2_BASE_ADDR CSPI2_BASE_ADDR +#define CONFIG_CSPI3_BASE_ADDR CSPI3_BASE_ADDR + #define CONFIG_MXC_GPIO
/* MC13783 connected to CSPI3 and SS0 */
These are not configurable. If a board is a MX5, they are fixed from imx-regs.h. See also my previous answer to Patch 2/3.
Hi Terry,
I think sf probe accepts also parameter in hex, such as sf probe 0x5301.
- switch (bus) {
- case 0:
/* SCLK */
0x3);
/* MISO */
0x3);
/* MOSI */
0x3);
if (0 == ss) {
IOMUX_CONFIG_ALT4);
0x3);
0x2);
Instead of this if-else, it can be more readable if you introduce a switch-case, printing in the default case an error message if the cs is not expected.
break;
- case 1:
- case 2:
- default:
break;
bus different as 1 is an error currently on this board. Insert a default case, with some message as "unsupported" or such like that.
Ok, this depends on your previous patchset. It must be merged firstly before applying this series. Can you mention it in the next changelog ?
There is also a CONFIG_SF_DEFAULT_CS, if you like to use it. You can set it to 0x5301 (better write as in your comment, (GPIO << 8) + CS) and sf probe will take it automatically.
Stefano Babic
Terry Lv
