[U-Boot] [PATCH] arm: rmobile: r8a7794: Enable SMP mode of Auxiliary Control Register
R8a7794 uses ARM SoC of CA7 base. If we want to use dcache on CA7, we need to enable SMP bit of Auxiliary Control Register.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S b/arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S index d47546a..fc839ea 100644 --- a/arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S +++ b/arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S @@ -40,7 +40,7 @@ do_lowlevel_init: and r1, r1, #0x7F00 lsrs r1, r1, #8 cmp r1, #0x4C /* 0x4C is ID of r8a7794 */ - beq _exit_init_l2_a15 + beq _enable_actlr_smp
/* surpress wfe if ca15 */ tst r4, #4 @@ -64,6 +64,14 @@ do_lowlevel_init: orrne r0, r0, #0x20 /* L2CTLR[5] */ #endif mcrne p15, 1, r0, c9, c0, 2 + + b _exit_init_l2_a15 + +_enable_actlr_smp: /* R8A7794 only (CA7) */ + mrc p15, 0, r0, c1, c0, 1 + orr r0, r0, #0x40 + mcr p15, 0, r0, c1, c0, 1 + _exit_init_l2_a15: ldr r3, =(CONFIG_SYS_INIT_SP_ADDR) sub sp, r3, #4
Nobuhiro Iwamatsu
