[U-Boot] Uboot NAND sub system and it's commands
Hello All, I am using DM6446 (TI DaVinci) customized board. 1. I am not able to understand meaning of NAND Sub system U boot commands, e.g. nand write, nand read, nand erase etc. 2. I want to use the NAND sub system U boot command in Linux (ARM side of DM6446 core), is it possible ? may be some utiliy to export these commands or some paralle command which have similar functionality (such as writting on specific location of RAM (87000000) from nand(0X1000000)).?
Thanks in advance -swapnali Thanks and regards -swapnali
- I am not able to understand meaning of NAND Sub system U boot commands, e.g. nand write, nand read, nand erase etc.
"write", "read", and "erase" are fairly straightforward English words. Is there some particular aspect you find confusing?
- I want to use the NAND sub system U boot command in Linux (ARM side
No. U-boot does not remain active once Linux boots.
See nandwrite in the mtd-utils package.
-Scott
Thanks Scott for input Best regards -swapnali ----- Original Message ----- From: "Scott Wood" scottwood@freescale.com To: "Swapnali C. Patil" swapnali.patil@intelli-vision.com Cc: u-boot@lists.denx.de Sent: Wednesday, March 04, 2009 4:18 AM Subject: Re: [U-Boot] Uboot NAND sub system and it's commands
-Scott
Scott Wood
Swapnali C. Patil
