[U-Boot] [PATCH 3/5] msm7x30: Add support for Qualcomm msm7630 soc
From: Mohamed Haneef mohamed.haneef@lntinfotech.com
*Support for Qualcomm msm7630 soc
Signed-off-by: Mohamed Haneef mohamed.haneef@lntinfotech.com --- arch/arm/cpu/armv7/msm7630/Makefile | 59 +++ arch/arm/cpu/armv7/msm7630/acpuclock.c | 328 +++++++++++++ arch/arm/cpu/armv7/msm7630/board.c | 58 +++ arch/arm/cpu/armv7/msm7630/config.mk | 1 + arch/arm/cpu/armv7/msm7630/gpio.c | 229 +++++++++ arch/arm/cpu/armv7/msm7630/lowlevel_init.S | 626 +++++++++++++++++++++++++ arch/arm/cpu/armv7/msm7630/timer.c | 148 ++++++ arch/arm/include/asm/arch-msm7630/adm.h | 28 ++ arch/arm/include/asm/arch-msm7630/gpio.h | 47 ++ arch/arm/include/asm/arch-msm7630/gpio_hw.h | 168 +++++++ arch/arm/include/asm/arch-msm7630/iomap.h | 96 ++++ arch/arm/include/asm/arch-msm7630/proc_comm.h | 42 ++ arch/arm/include/asm/arch-msm7630/sys_proto.h | 29 ++ 13 files changed, 1859 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/armv7/msm7630/Makefile create mode 100644 arch/arm/cpu/armv7/msm7630/acpuclock.c create mode 100644 arch/arm/cpu/armv7/msm7630/board.c create mode 100644 arch/arm/cpu/armv7/msm7630/config.mk create mode 100644 arch/arm/cpu/armv7/msm7630/gpio.c create mode 100644 arch/arm/cpu/armv7/msm7630/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/msm7630/timer.c create mode 100644 arch/arm/include/asm/arch-msm7630/adm.h create mode 100644 arch/arm/include/asm/arch-msm7630/gpio.h create mode 100644 arch/arm/include/asm/arch-msm7630/gpio_hw.h create mode 100644 arch/arm/include/asm/arch-msm7630/iomap.h create mode 100644 arch/arm/include/asm/arch-msm7630/proc_comm.h create mode 100644 arch/arm/include/asm/arch-msm7630/sys_proto.h
diff --git a/arch/arm/cpu/armv7/msm7630/Makefile b/arch/arm/cpu/armv7/msm7630/Makefile new file mode 100644 index 0000000..d9dfade --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/Makefile @@ -0,0 +1,59 @@ +# +# (C) Copyright 2012 +# LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> +# +# (C) Copyright 2010,2011 Nvidia Corporation. +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# The AVP is ARMv4T architecture so we must use special compiler +# flags for any startup files it might use. +#CFLAGS_arch/arm/cpu/armv7/tegra2/ap20.o += -march=armv4t +#CFLAGS_arch/arm/cpu/armv7/tegra2/clock.o += -march=armv4t + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS-y := lowlevel_init.o +COBJS-y := board.o +COBJS-y += timer.o +COBJS-y += acpuclock.o +COBJS-y += gpio.o + + SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) + OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/msm7630/acpuclock.c b/arch/arm/cpu/armv7/msm7630/acpuclock.c new file mode 100644 index 0000000..035ce04 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/acpuclock.c @@ -0,0 +1,328 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <asm/arch/iomap.h> +#include <asm/io.h> +#include <common.h> +#include <asm/arch/mmc.h> +#include <asm/arch/proc_comm.h> +#define ACPU_806MHZ 42 +#define ACPU_1024MHZ 53 +#define ACPU_1200MHZ 125 +#define ACPU_1400MHZ 73 + +/* Macros to select PLL2 with divide by 1 */ +#define ACPU_SRC_SEL 3 +#define ACPU_SRC_DIV 0 + +#define BIT(n) (1 << (n)) +#define VREG_CONFIG (BIT(7) | BIT(6)) +#define VREG_DATA (VREG_CONFIG | (VREF_SEL << 5)) +#define VREF_SEL 1 /* 0: 0.625V (50mV step), 1: 0.3125V (25mV step). */ +#define V_STEP (25 * (2 - VREF_SEL)) /* Minimum voltage step size. */ +#define MV(mv) ((mv) / (!((mv) % V_STEP))) +/* mv = (750mV + (raw * 25mV)) * (2 - VREF_SEL) */ +#define VDD_RAW(mv) (((MV(mv) / V_STEP) - 30) | VREG_DATA) + + +/* enum for SDC CLK IDs */ +enum { + SDC1_CLK = 19, + SDC1_PCLK = 20, + SDC2_CLK = 21, + SDC2_PCLK = 22, + SDC3_CLK = 23, + SDC3_PCLK = 24, + SDC4_CLK = 25, + SDC4_PCLK = 26 +}; + +/* Zero'th entry is dummy */ +static uint8_t sdc_clk[] = {0, SDC1_CLK, SDC2_CLK, SDC3_CLK, SDC4_CLK}; +static uint8_t sdc_pclk[] = {0, SDC1_PCLK, SDC2_PCLK, SDC3_PCLK, SDC4_PCLK}; + +void spm_init(void) +{ + writel(0x05, MSM_SAW_BASE + 0x10); /* MSM_SPM_REG_SAW_CFG */ + writel(0x18, MSM_SAW_BASE + 0x14); /* MSM_SPM_REG_SAW_SPM_CTL */ + writel(0x00006666, MSM_SAW_BASE + 0x18); + /* MSM_SPM_REG_SAW_SPM_SLP_TMR_DLY */ + writel(0xFF000666, MSM_SAW_BASE + 0x1C); + /* MSM_SPM_REG_SAW_SPM_WAKE_TMR_DLY */ + writel(0x01, MSM_SAW_BASE + 0x24); /* MSM_SPM_REG_SAW_SLP_CLK_EN */ + writel(0x03, MSM_SAW_BASE + 0x28); + /* MSM_SPM_REG_SAW_SLP_HSFS_PRECLMP_EN */ + writel(0x00, MSM_SAW_BASE + 0x2C); + /* MSM_SPM_REG_SAW_SLP_HSFS_POSTCLMP_EN */ + writel(0x01, MSM_SAW_BASE + 0x30); /* MSM_SPM_REG_SAW_SLP_CLMP_EN */ + writel(0x00, MSM_SAW_BASE + 0x34); /* MSM_SPM_REG_SAW_SLP_RST_EN */ + writel(0x00, MSM_SAW_BASE + 0x38); /* MSM_SPM_REG_SAW_SPM_MPM_CFG */ +} + +/* Configures msmc2 voltage. vlevel is in mV */ +void msmc2_config(unsigned vlevel) +{ + unsigned val; + val = readl(MSM_SAW_BASE + 0x08); /* MSM_SPM_REG_SAW_VCTL */ + val &= ~0xFF; + val |= VDD_RAW(vlevel); + writel(val, MSM_SAW_BASE + 0x08); /* MSM_SPM_REG_SAW_VCTL */ + /* Wait for PMIC state to return to idle and for VDD to stabilize */ + while (((readl(MSM_SAW_BASE + 0x0C) >> 20) & 0x3) != 0) + ; + udelay(160); +} + +void enable_pll(unsigned num) +{ + unsigned reg_val; + reg_val = readl(PLL_ENA_REG); + reg_val |= (1 << num); + writel(reg_val, PLL_ENA_REG); + /* Wait until PLL is enabled */ + while ((readl(PLL2_STATUS_BASE_REG) & (1 << 16)) == 0) + ; +} + +void acpu_clock_init(void) +{ + unsigned clk, reg_clksel, reg_clkctl, src_sel; + /* Fixing msmc2 voltage */ + spm_init(); + clk = readl(PLL2_L_VAL_ADDR) & 0xFF; + if (clk == ACPU_806MHZ) + msmc2_config(1100); + else if (clk == ACPU_1024MHZ || clk == ACPU_1200MHZ) + msmc2_config(1200); + else if (clk == ACPU_1400MHZ) + msmc2_config(1250); + /* Enable pll 2 */ + enable_pll(2); + reg_clksel = readl(SCSS_CLK_SEL); + /* CLK_SEL_SRC1NO */ + src_sel = reg_clksel & 1; + /* Program clock source and divider. */ + reg_clkctl = readl(SCSS_CLK_CTL); + reg_clkctl &= ~(0xFF << (8 * src_sel)); + reg_clkctl |= ACPU_SRC_SEL << (4 + 8 * src_sel); + reg_clkctl |= ACPU_SRC_DIV << (0 + 8 * src_sel); + writel(reg_clkctl, SCSS_CLK_CTL); + /* Toggle clock source. */ + reg_clksel ^= 1; + /* Program clock source selection. */ + writel(reg_clksel, SCSS_CLK_SEL); +} + +void hsusb_clock_init(void) +{ + int val = 0; + unsigned sh2_own_row2; + unsigned sh2_own_row2_hsusb_mask = (1 << 11); + + sh2_own_row2 = readl(SH2_OWN_ROW2_BASE_REG); + if (sh2_own_row2 & sh2_own_row2_hsusb_mask) { + /* USB local clock control enabled */ + /* Set value in MD register */ + val = 0x5DF; + writel(val, SH2_USBH_MD_REG); + /* Set value in NS register */ + val = 1 << 8; + val = val | readl(SH2_USBH_NS_REG); + writel(val, SH2_USBH_NS_REG); + val = 1 << 11; + val = val | readl(SH2_USBH_NS_REG); + writel(val, SH2_USBH_NS_REG); + val = 1 << 9; + val = val | readl(SH2_USBH_NS_REG); + writel(val, SH2_USBH_NS_REG); + val = 1 << 13; + val = val | readl(SH2_USBH_NS_REG); + writel(val, SH2_USBH_NS_REG); + /* Enable USBH_P_CLK */ + val = 1 << 25; + val = val | readl(SH2_GLBL_CLK_ENA_SC); + writel(val, SH2_GLBL_CLK_ENA_SC); + } else + /* USB local clock control not enabled; use proc comm */ + usb_clock_init(); + +} + +void adm_enable_clock(void) +{ + unsigned int val = 0; + + /* Enable ADM_CLK */ + val = 1 << 5; + val = val | readl(SH2_GLBL_CLK_ENA_SC); + writel(val, SH2_GLBL_CLK_ENA_SC); +} + +void mdp_lcdc_clock_init(void) +{ + unsigned int val = 0; + unsigned sh2_own_apps2; + unsigned sh2_own_apps2_lcdc_mask = (1 << 3); + + sh2_own_apps2 = readl(SH2_OWN_APPS2_BASE_REG); + if (sh2_own_apps2 & sh2_own_apps2_lcdc_mask) { + /* MDP local clock control enabled */ + /* Select clock source and divider */ + val = 0x29; + val = val | readl(SH2_MDP_NS_REG); + writel(val, SH2_MDP_NS_REG); + + /* Enable MDP source clock(root) */ + val = 1 << 11; + val = val | readl(SH2_MDP_NS_REG); + writel(val, SH2_MDP_NS_REG); + + /* Enable graphics clock(branch) */ + val = 1 << 9; + val = val | readl(SH2_MDP_NS_REG); + writel(val, SH2_MDP_NS_REG); + + /* Enable MDP_P_CLK */ + val = 1 << 6; + val = val | readl(SH2_GLBL_CLK_ENA_2_SC); + writel(val, SH2_GLBL_CLK_ENA_2_SC); + + /* Enable AXI_MDP_CLK */ + val = 1 << 29; + val = val | readl(SH2_GLBL_CLK_ENA_2_SC); + writel(val, SH2_GLBL_CLK_ENA_2_SC); + + /* LCDC local clock control enabled */ + /* Set value in MD register */ + val = 0x1FFF9; + writel(val, SH2_MDP_LCDC_MD_REG); + + /* Set MDP_LCDC_N_VAL in NS register */ + val = 0xFFFA << 16; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Set clock source */ + val = 1; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Set divider */ + val = 3 << 3; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Set MN counter mode */ + val = 2 << 5; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Enable MN counter */ + val = 1 << 8; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Enable mdp_lcdc_src(root) clock */ + val = 1 << 11; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Enable mdp_lcdc_pclk(branch) clock */ + val = 1 << 9; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Enable mdp_lcdc_pad_pclk(branch) clock */ + val = 1 << 12; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + } else { + /* MDP local clock control not enabled; use proc comm */ + mdp_clock_init(122880000); + /* LCDC local clock control not enabled; use proc comm */ + lcdc_clock_init(27648000); + } +} + +void mddi_pmdh_clock_init(void) +{ + unsigned int val = 0; + unsigned sh2_own_row1; + unsigned sh2_own_row1_pmdh_mask = (1 << 19); + + sh2_own_row1 = readl(SH2_OWN_ROW1_BASE_REG); + if (sh2_own_row1 & sh2_own_row1_pmdh_mask) { + /* Select clock source and divider */ + val = 1; + val |= (1 << 3); + val = val | readl(SH2_PMDH_NS_REG); + writel(val, SH2_PMDH_NS_REG); + + /* Enable PMDH_SRC (root) signal */ + val = 1 << 11; + val = val | readl(SH2_PMDH_NS_REG); + writel(val, SH2_PMDH_NS_REG); + + /* Enable PMDH_P_CLK */ + val = 1 << 4; + val = val | readl(SH2_GLBL_CLK_ENA_2_SC); + writel(val, SH2_GLBL_CLK_ENA_2_SC); + } else + /* MDDI local clock control not enabled; use proc comm */ + mddi_clock_init(0, 480000000); +} + +void ce_clock_init(void) +{ + unsigned int val = 0; + + /* Enable CE_CLK */ + val = 1 << 6; + val = val | readl(SH2_GLBL_CLK_ENA_SC); + writel(val, SH2_GLBL_CLK_ENA_SC); +} + +#ifdef CONFIG_QC_MMC +/* Configure MMC clock */ +void clock_config_mmc(uint32_t interface, uint32_t freq) +{ + uint32_t reg = 0; + + if (mmc_clock_set_rate(sdc_clk[interface], freq) < 0) + printf("Failure setting clock rate for MCLK - " + "clk_rate: %d\n!", freq); + + /* enable clock */ + if (mmc_clock_enable_disable(sdc_clk[interface], MMC_CLK_ENABLE) < 0) + printf("Failure enabling MMC Clock!\n"); + + reg |= MMC_BOOT_MCI_CLK_ENABLE; + reg |= MMC_BOOT_MCI_CLK_ENA_FLOW; + reg |= MMC_BOOT_MCI_CLK_IN_FEEDBACK; + writel(reg, MMC_BOOT_MCI_CLK); +} + +/* Intialize MMC clock */ +void clock_init_mmc(uint32_t interface) +{ + if (mmc_clock_enable_disable(sdc_pclk[interface], MMC_CLK_ENABLE) < 0) + printf("Failure enabling PCLK!\n"); +} +#endif diff --git a/arch/arm/cpu/armv7/msm7630/board.c b/arch/arm/cpu/armv7/msm7630/board.c new file mode 100644 index 0000000..8dd61b4 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/board.c @@ -0,0 +1,58 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/arch/iomap.h> +#include <asm/arch/sys_proto.h> + + +DECLARE_GLOBAL_DATA_PTR; + +void set_vector_base(unsigned long addr) +{ + __asm__ volatile ("mcr p15, 0, %0, c12, c0, 0" : : "r" (addr)); +} + +int dram_init(void) +{ + /* We do not initialise DRAM here. We just query the size */ + gd->ram_size = PHYS_SDRAM_1_SIZE; + /* Now check it dynamically */ + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + +} + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init() +{ + __cpu_early_init(); + return 0; +} +#endif diff --git a/arch/arm/cpu/armv7/msm7630/config.mk b/arch/arm/cpu/armv7/msm7630/config.mk new file mode 100644 index 0000000..935a147 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/config.mk @@ -0,0 +1 @@ +PLATFORM_CPPFLAGS += -march=armv7-a diff --git a/arch/arm/cpu/armv7/msm7630/gpio.c b/arch/arm/cpu/armv7/msm7630/gpio.c new file mode 100644 index 0000000..daa6d66 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/gpio.c @@ -0,0 +1,229 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/iomap.h> +#include <asm/arch/gpio.h> +#include <asm/arch/proc_comm.h> +#include <asm/arch/gpio_hw.h> + +struct gpioregs { + unsigned out; + unsigned in; + unsigned int_status; + unsigned int_clear; + unsigned int_en; + unsigned int_edge; + unsigned int_pos; + unsigned oe; +}; + +static struct gpioregs GPIO_REGS[] = { + { + .out = GPIO_OUT_0, + .in = GPIO_IN_0, + .int_status = GPIO_INT_STATUS_0, + .int_clear = GPIO_INT_CLEAR_0, + .int_en = GPIO_INT_EN_0, + .int_edge = GPIO_INT_EDGE_0, + .int_pos = GPIO_INT_POS_0, + .oe = GPIO_OE_0, + }, + { + .out = GPIO_OUT_1, + .in = GPIO_IN_1, + .int_status = GPIO_INT_STATUS_1, + .int_clear = GPIO_INT_CLEAR_1, + .int_en = GPIO_INT_EN_1, + .int_edge = GPIO_INT_EDGE_1, + .int_pos = GPIO_INT_POS_1, + .oe = GPIO_OE_1, + }, + { + .out = GPIO_OUT_2, + .in = GPIO_IN_2, + .int_status = GPIO_INT_STATUS_2, + .int_clear = GPIO_INT_CLEAR_2, + .int_en = GPIO_INT_EN_2, + .int_edge = GPIO_INT_EDGE_2, + .int_pos = GPIO_INT_POS_2, + .oe = GPIO_OE_2, + }, + { + .out = GPIO_OUT_3, + .in = GPIO_IN_3, + .int_status = GPIO_INT_STATUS_3, + .int_clear = GPIO_INT_CLEAR_3, + .int_en = GPIO_INT_EN_3, + .int_edge = GPIO_INT_EDGE_3, + .int_pos = GPIO_INT_POS_3, + .oe = GPIO_OE_3, + }, + { + .out = GPIO_OUT_4, + .in = GPIO_IN_4, + .int_status = GPIO_INT_STATUS_4, + .int_clear = GPIO_INT_CLEAR_4, + .int_en = GPIO_INT_EN_4, + .int_edge = GPIO_INT_EDGE_4, + .int_pos = GPIO_INT_POS_4, + .oe = GPIO_OE_4, + }, + { + .out = GPIO_OUT_5, + .in = GPIO_IN_5, + .int_status = GPIO_INT_STATUS_5, + .int_clear = GPIO_INT_CLEAR_5, + .int_en = GPIO_INT_EN_5, + .int_edge = GPIO_INT_EDGE_5, + .int_pos = GPIO_INT_POS_5, + .oe = GPIO_OE_5, + }, + { + .out = GPIO_OUT_6, + .in = GPIO_IN_6, + .int_status = GPIO_INT_STATUS_6, + .int_clear = GPIO_INT_CLEAR_6, + .int_en = GPIO_INT_EN_6, + .int_edge = GPIO_INT_EDGE_6, + .int_pos = GPIO_INT_POS_6, + .oe = GPIO_OE_6, + }, + { + .out = GPIO_OUT_7, + .in = GPIO_IN_7, + .int_status = GPIO_INT_STATUS_7, + .int_clear = GPIO_INT_CLEAR_7, + .int_en = GPIO_INT_EN_7, + .int_edge = GPIO_INT_EDGE_7, + .int_pos = GPIO_INT_POS_7, + .oe = GPIO_OE_7, + }, +}; + +static struct gpioregs *find_gpio(unsigned n, unsigned *bit) +{ + if (n > 150) { + *bit = 1 << (n - 151); + return GPIO_REGS + 7; + } + if (n > 133) { + *bit = 1 << (n - 134); + return GPIO_REGS + 6; + } + if (n > 106) { + *bit = 1 << (n - 107); + return GPIO_REGS + 5; + } + if (n > 94) { + *bit = 1 << (n - 95); + return GPIO_REGS + 4; + } + if (n > 67) { + *bit = 1 << (n - 68); + return GPIO_REGS + 3; + } + if (n > 43) { + *bit = 1 << (n - 44); + return GPIO_REGS + 2; + } + if (n > 15) { + *bit = 1 << (n - 16); + return GPIO_REGS + 1; + } + *bit = 1 << n; + return GPIO_REGS + 0; +} + +int gpio_config(unsigned n, unsigned flags) +{ + struct gpioregs *r; + unsigned b; + unsigned v; + + r = find_gpio(n, &b); + if (!r) + return -1; + + v = readl(r->oe); + if (flags & GPIO_OUTPUT) + writel(v | b, r->oe); + else + writel(v & (~b), r->oe); + return 0; +} + +void gpio_set(unsigned n, unsigned on) +{ + struct gpioregs *r; + unsigned b; + unsigned v; + + r = find_gpio(n, &b); + if (r == 0) + return; + + v = readl(r->out); + if (on) + writel(v | b, r->out); + else + writel(v & (~b), r->out); +} + +int gpio_get(unsigned n) +{ + struct gpioregs *r; + unsigned b; + + r = find_gpio(n, &b); + if (r == 0) + return 0; + return (readl(r->in) & b) ? 1 : 0; +} + +void platform_config_interleaved_mode_gpios(void) +{ + /* configure EB2_CS1 through GPIO86 */ + writel(GPIO_ALT_FUNC_PAGE_REG, 0x56); + writel(GPIO_ALT_FUNC_CFG_REG, 0x04); + /* configure the EBI2_BUSY1_N through GPIO115 */ + writel(GPIO_ALT_FUNC_PAGE_REG, 0x73); + writel(GPIO_ALT_FUNC_CFG_REG, 0x08); +} + +/* Enables all gpios passed in table*/ +int platform_gpios_enable(const struct msm_gpio *table, int size) +{ + int rc; + int i; + const struct msm_gpio *g; + for (i = 0; i < size; i++) { + g = table + i; + /* Enable gpio */ + rc = gpio_tlmm_config(g->gpio_cfg, GPIO_ENABLE); + if (rc) + goto err; + } + return 0; +err: + return rc; +} + diff --git a/arch/arm/cpu/armv7/msm7630/lowlevel_init.S b/arch/arm/cpu/armv7/msm7630/lowlevel_init.S new file mode 100644 index 0000000..d8d5b46 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/lowlevel_init.S @@ -0,0 +1,626 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <config.h> +#include <version.h> + +.text +.code 32 + +#define DSB .byte 0x4f, 0xf0, 0x7f, 0xf5 +#define ISB .byte 0x6f, 0xf0, 0x7f, 0xf5 + +/* + ; LVT Ring Osc counter + ; used to determine sense amp settings + ; Clobbers registers r0, r4, r5, r6, r7, r9, r10, r11 +*/ +.equ CLK_CTL_BASE, 0xA8600000 +.equ A_GLBL_CLK_ENA, 0x0000 +.equ A_PRPH_WEB_NS_REG,0x0080 +.equ A_MSM_CLK_RINGOSC,0x00D0 +.equ A_TCXO_CNT, 0x00D4 +.equ A_TCXO_CNT_DONE, 0x00D8 +.equ A_RINGOSC_CNT, 0x00DC +.equ A_MISC_CLK_CTL, 0x0108 +.equ CLK_TEST, 0xA8600114 +.equ SPSS_CSR_BASE, 0xAC100000 +.equ A_SCRINGOSC, 0x0510 + +//;; Number of TCXO cycles to count ring oscillations +.equ TCXO_CNT_VAL, 0x100 + +//; Halcyon addresses +.equ TCSR_CONF_FUSE_1, 0xAB600060 //; TCSR_CONF_FUSE_1 register +.equ TCSR_CONF_FUSE_4, 0xAB60006C //; TCSR_CONF_FUSE_4 register + +//; SCORPION_L1_ACC (1:0) Fuses bit location +.equ L1_ACC_BIT_0, 12 //;12th bit of TCSR_CONF_FUSE_4 +.equ L1_ACC_BIT_1, 13 //;13th bit of TCSR_CONF_FUSE_4 +//; SCORPION_L2_ACC (2:0) Fuses bit location +.equ L2_ACC_BIT_0, 25 //;25th bit of TCSR_CONF_FUSE_1 +.equ L2_ACC_BIT_1, 10 //;10th bit of TCSR_CONF_FUSE_4 +.equ L2_ACC_BIT_2, 11 //;11th bit of TCSR_CONF_FUSE_4 + +//; CP15: PVR2F0 values according to SCORPION_L1_ACC (1:0) +.equ PVR2F0_00, 0x00000000 +.equ PVR2F0_01, 0x04000000 +.equ PVR2F0_10, 0x08000000 +.equ PVR2F0_11, 0x0C000000 + +//; CP15: PVR2F1 values according to SCORPION_L1_ACC (1:0) +.equ PVR2F1_00, 0x00000008 +.equ PVR2F1_01, 0x00000008 +.equ PVR2F1_10, 0x00000208 +.equ PVR2F1_11, 0x00000208 + +//; CP15: PVR0F2 values according to SCORPION_L1_ACC (1:0) +.equ PVR0F2_00, 0x00000000 +.equ PVR0F2_01, 0x00000000 +.equ PVR0F2_10, 0x00000200 +.equ PVR0F2_11, 0x00000200 + +//; CP15: PVR0F0 values according to SCORPION_L1_ACC (1:0) +.equ PVR0F0_00, 0x7F000000 +.equ PVR0F0_01, 0x7F000400 +.equ PVR0F0_10, 0x7F000000 +.equ PVR0F0_11, 0x7F000400 + +//; CP15: L2VR3F1 values according to SCORPION_L2_ACC (2:0) +.equ L2VR3F1_000, 0x00FFFF60 +.equ L2VR3F1_001, 0x00FFFF40 +.equ L2VR3F1_010, 0x00FFFC60 +.equ L2VR3F1_011, 0x00FFFC40 +.equ L2VR3F1_100, 0x00FCFF60 +.equ L2VR3F1_101, 0x00FCFF40 +.equ L2VR3F1_110, 0x00FCFC60 +.equ L2VR3F1_111, 0x00FCFC40 + + + + +_TEXT_BASE: + .word CONFIG_SYS_TEXT_BASE @ sdram load addr from config file + +.global invalidate_dcache +invalidate_dcache: + mov pc, lr + + .align 5 +.globl lowlevel_init +lowlevel_init: + mov pc, lr @ back to arch calling code + +.global reset_cpu +reset_cpu: +_loop_forever: + b _loop_forever + +.globl SET_SA +SET_SA: + + //;-------------------------------------------------------------------- + //; Fuse bits used to determine sense amp settings + //;-------------------------------------------------------------------- + + //; Reading L1_ACC + ldr r4, = 0x0 + + //; Read L1_ACC_BIT_0 + ldr r1, =TCSR_CONF_FUSE_4 + ldr r2, =L1_ACC_BIT_0 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + orr r4, r3, r4 + + //; Read L1_ACC_BIT_1 + ldr r1, =TCSR_CONF_FUSE_4 + ldr r2, =L1_ACC_BIT_1 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + mov r3, r3, LSL #1 + orr r4, r3, r4 + +l1_ck_0: + //; if L1_[1:0] == 00 + ldr r5, = 0x0 + cmp r4, r5 + bne l1_ck_1 + ldr r0, =PVR0F0_00 + ldr r1, =PVR0F2_00 + ldr r2, =PVR2F0_00 + ldr r3, =PVR2F1_00 + b WRITE_L1_SA_SETTINGS + +l1_ck_1: + //; if L1_[1:0] == 01 + ldr r1, = 0x01 + cmp r4, r1 + bne l1_ck_2 + ldr r0, =PVR0F0_01 + ldr r1, =PVR0F2_01 + ldr r2, =PVR2F0_01 + ldr r3, =PVR2F1_01 + b WRITE_L1_SA_SETTINGS + +l1_ck_2: + //; if L1_[2:0] == 10 + ldr r1, = 0x02 + cmp r4, r1 + bne l1_ck_3 + ldr r0, =PVR0F0_10 + ldr r1, =PVR0F2_10 + ldr r2, =PVR2F0_10 + ldr r3, =PVR2F1_10 + b WRITE_L1_SA_SETTINGS + +l1_ck_3: + //; if L1_[2:0] == 11 + ldr r1, = 0x03 + cmp r4, r1 + ldr r0, =PVR0F0_11 + ldr r1, =PVR0F2_11 + ldr r2, =PVR2F0_11 + ldr r3, =PVR2F1_11 + b WRITE_L1_SA_SETTINGS + + +WRITE_L1_SA_SETTINGS: + + //;WCP15_PVR0F0 r0 + mcr p15, 0x0, r0, c15, c15, 0x0 //; write R0 to PVR0F0 + + //;WCP15_PVR0F2 r1 + mcr p15, 0x0, r1, c15, c15, 0x2 //; write R1 to PVR0F2 + + //;WCP15_PVR2F0 r2 + mcr p15, 0x2, r2, c15, c15, 0x0 //; write R2 to PVR2F0 + + // Disable predecode repair cache on certain Scorpion revisions + // (Raptor V2 and earlier, or Halcyon V1) + mrc p15, 0, r1, c0, c0, 0 //; MIDR + BIC r2, r1, #0xf0 //; check for Halcyon V1 + ldr r4, =0x511f0000 + cmp r2, r4 + bne PVR2F1 + +DPRC: + mrc p15, 0, r1, c15, c15, 2 //; PVR0F2 + orr r1, r1, #0x10 //; enable bit 4 + mcr p15, 0, r1, c15, c15, 2 //; disable predecode repair cache + +PVR2F1: + //;WCP15_PVR2F1 r3 + mcr p15, 0x2, r3, c15, c15, 0x1 //; write R3 to PVR2F1 + + //; Reading L2_ACC + ldr r4, = 0x0 + + //; Read L2_ACC_BIT_0 + ldr r1, =TCSR_CONF_FUSE_1 + ldr r2, =L2_ACC_BIT_0 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + orr r4, r3, r4 + + //; Read L2_ACC_BIT_1 + ldr r1, =TCSR_CONF_FUSE_4 + ldr r2, =L2_ACC_BIT_1 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + mov r3, r3, LSL #1 + orr r4, r3, r4 + + //; Read L2_ACC_BIT_2 + ldr r1, =TCSR_CONF_FUSE_4 + ldr r2, =L2_ACC_BIT_2 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + mov r3, r3, LSL #2 + orr r4, r3, r4 + +l2_ck_0: + //; if L2_[2:0] == 000 + ldr r5, = 0x0 + cmp r4, r5 + bne l2_ck_1 + ldr r0, =L2VR3F1_000 + b WRITE_L2_SA_SETTINGS + +l2_ck_1: + //; if L2_[2:0] == 001 + ldr r5, = 0x1 + cmp r4, r5 + bne l2_ck_2 + ldr r0, =L2VR3F1_001 + b WRITE_L2_SA_SETTINGS + +l2_ck_2: + //; if L2_[2:0] == 010 + ldr r5, = 0x2 + cmp r4, r5 + bne l2_ck_3 + ldr r0, =L2VR3F1_010 + b WRITE_L2_SA_SETTINGS + +l2_ck_3: + //; if L2_[2:0] == 011 + ldr r5, = 0x3 + cmp r4, r5 + bne l2_ck_4 + ldr r0, =L2VR3F1_011 + b WRITE_L2_SA_SETTINGS + +l2_ck_4: + //; if L2_[2:0] == 100 + ldr r5, = 0x4 + cmp r4, r5 + bne l2_ck_5 + ldr r0, =L2VR3F1_100 + b WRITE_L2_SA_SETTINGS + +l2_ck_5: + //; if L2_[2:0] == 101 + ldr r5, = 0x5 + cmp r4, r5 + bne l2_ck_6 + ldr r0, =L2VR3F1_101 + b WRITE_L2_SA_SETTINGS + +l2_ck_6: + //; if L2_[2:0] == 110 + ldr r5, = 0x6 + cmp r4, r5 + bne l2_ck_7 + ldr r0, =L2VR3F1_110 + b WRITE_L2_SA_SETTINGS + +l2_ck_7: + //; if L2_[2:0] == 111 + ldr r5, = 0x7 + cmp r4, r5 + ldr r0, =L2VR3F1_111 + b WRITE_L2_SA_SETTINGS + +WRITE_L2_SA_SETTINGS: + //;WCP15_L2VR3F1 r0 + mcr p15, 0x3, r0, c15, c15, 0x1 //;write r0 to L2VR3F1 + DSB + ISB + + ldr r0, =0 //;make sure the registers we touched + ldr r1, =0 //;are cleared when we return + ldr r2, =0 + ldr r3, =0 + ldr r4, =0 + ldr r5, =0 + + mrs r0, cpsr + orr r0, r0, #(1<<7) + msr cpsr_c, r0 + + //; routine complete + pop {r5-r12,pc} + +.ltorg + +.globl __cpu_early_init +__cpu_early_init: + + //; Zero out r0 for use throughout this code. All other GPRs + //; (r1-r3) are set throughout this code to help establish + //; a consistent startup state for any code that follows. + //; Users should add code at the end of this routine to establish + //; their own stack address (r13), add translation page tables, enable + //; the caches, etc. + push {r5-r12,r14} + mov r0, #0x0 + + + //; Remove hardcoded cache settings. appsbl_handler.s calls Set_SA + //; API to dynamically configure cache for slow/nominal/fast parts + + //; DCIALL to invalidate L2 cache bank (needs to be run 4 times, + //; once per bank) + //; This must be done early in code (prior to enabling the caches) + mov r1, #0x2 + mcr p15, 0, r1, c9, c0, 6 //; DCIALL bank D ([15:14] == 2'b00) + orr r1, r1, #0x00004000 + mcr p15, 0, r1, c9, c0, 6 //; DCIALL bank C ([15:14] == 2'b01) + add r1, r1, #0x00004000 + mcr p15, 0, r1, c9, c0, 6 //; DCIALL bank B ([15:14] == 2'b10) + add r1, r1, #0x00004000 + mcr p15, 0, r1, c9, c0, 6 //; DCIALL bank A ([15:14] == 2'b11) + + //; Initialize the BPCR - setup Global History Mask (GHRM) to all 1's + //; and have all address bits (AM) participate. + //; Different settings can be used to improve performance + // movW r1, #0x01FF +.word 0xe30011ff // hardcoded movW instruction due to lack of compiler support + // movT r1, #0x01FF +.word 0xe34011ff // hardcoded movT instruction due to lack of compiler support + mcr p15, 7, r1, c15, c0, 2 //; WCP15_BPCR + + + //; Initialize all I$ Victim Registers to 0 for startup + mcr p15, 0, r0, c9, c1, 0 //; WCP15_ICVIC0 r0 + mcr p15, 0, r0, c9, c1, 1 //; WCP15_ICVIC1 r0 + mcr p15, 0, r0, c9, c1, 2 //; WCP15_ICVIC2 r0 + mcr p15, 0, r0, c9, c1, 3 //; WCP15_ICVIC3 r0 + mcr p15, 0, r0, c9, c1, 4 //; WCP15_ICVIC4 r0 + mcr p15, 0, r0, c9, c1, 5 //; WCP15_ICVIC5 r0 + mcr p15, 0, r0, c9, c1, 6 //; WCP15_ICVIC5 r0 + mcr p15, 0, r0, c9, c1, 7 //; WCP15_ICVIC7 r0 + + //; Initialize all I$ Locked Victim Registers (Unlocked Floors) to 0 + mcr p15, 1, r0, c9, c1, 0 //; WCP15_ICFLOOR0 r0 + mcr p15, 1, r0, c9, c1, 1 //; WCP15_ICFLOOR1 r0 + mcr p15, 1, r0, c9, c1, 2 //; WCP15_ICFLOOR2 r0 + mcr p15, 1, r0, c9, c1, 3 //; WCP15_ICFLOOR3 r0 + mcr p15, 1, r0, c9, c1, 4 //; WCP15_ICFLOOR4 r0 + mcr p15, 1, r0, c9, c1, 5 //; WCP15_ICFLOOR5 r0 + mcr p15, 1, r0, c9, c1, 6 //; WCP15_ICFLOOR6 r0 + mcr p15, 1, r0, c9, c1, 7 //; WCP15_ICFLOOR7 r0 + + //; Initialize all D$ Victim Registers to 0 + mcr p15, 2, r0, c9, c1, 0 //; WP15_DCVIC0 r0 + mcr p15, 2, r0, c9, c1, 1 //; WP15_DCVIC1 r0 + mcr p15, 2, r0, c9, c1, 2 //; WP15_DCVIC2 r0 + mcr p15, 2, r0, c9, c1, 3 //; WP15_DCVIC3 r0 + mcr p15, 2, r0, c9, c1, 4 //; WP15_DCVIC4 r0 + mcr p15, 2, r0, c9, c1, 5 //; WP15_DCVIC5 r0 + mcr p15, 2, r0, c9, c1, 6 //; WP15_DCVIC6 r0 + mcr p15, 2, r0, c9, c1, 7 //; WP15_DCVIC7 r0 + + //; Initialize all D$ Locked VDCtim Registers (Unlocked Floors) to 0 + mcr p15, 3, r0, c9, c1, 0 //; WCP15_DCFLOOR0 r0 + mcr p15, 3, r0, c9, c1, 1 //; WCP15_DCFLOOR1 r0 + mcr p15, 3, r0, c9, c1, 2 //; WCP15_DCFLOOR2 r0 + mcr p15, 3, r0, c9, c1, 3 //; WCP15_DCFLOOR3 r0 + mcr p15, 3, r0, c9, c1, 4 //; WCP15_DCFLOOR4 r0 + mcr p15, 3, r0, c9, c1, 5 //; WCP15_DCFLOOR5 r0 + mcr p15, 3, r0, c9, c1, 6 //; WCP15_DCFLOOR6 r0 + mcr p15, 3, r0, c9, c1, 7 //; WCP15_DCFLOOR7 r0 + + //; Initialize ASID to zero + mcr p15, 0, r0, c13, c0, 1 //; WCP15_CONTEXTIDR r0 + + //; ICIALL to invalidate entire I-Cache + mcr p15, 0, r0, c7, c5, 0 //; ICIALLU + + //; DCIALL to invalidate entire D-Cache + mcr p15, 0, r0, c9, c0, 6 //; DCIALL r0 + + //; Initialize ADFSR to zero + mcr p15, 0, r0, c5, c1, 0 //; ADFSR r0 + + //; Initialize EFSR to zero + mcr p15, 7, r0, c15, c0, 1 //; EFSR r0 + + //; The VBAR (Vector Base Address Register) should be initialized + //; early in your code. We are setting it to zero + mcr p15, 0, r0, c12, c0, 0 //; WCP15_VBAR r0 + + //; Ensure the mcr's above have completed their operation + //; before continuing + DSB + ISB + + //; Setup CCPR - Cache Coherency Policy Register + //; setup CCPR[L1ISHP, L2ISHP] both to 0b00 (no forcing) + //; setup CCPR[L1OSHP, L2OSHP] both to 0b10 (force non-cacheable) + movw r2, #0x88 + mcr p15, 0, r2, c10, c4, 2 + + //;------------------------------------------------------------------- + //; There are a number of registers that must be set prior to enabling + //; the MMU. The DCAR is one of these registers. We are setting + //; it to zero (no access) to easily detect improper setup in subsequent + //; code sequences + //;------------------------------------------------------------------- + //; Setup DACR (Domain Access Control Register) to zero + mcr p15, 0, r0, c3, c0, 0 //; WCP15_DACR r0 + + //; Setup DCLKCR to allow normal D-Cache line fills + mcr p15, 1, r0, c9, c0, 7 //; WCP15_DCLKCR r0 + + //; Setup the TLBLKCR + //; Victim = 6'b000000; Floor = 6'b000000; + //; IASIDCFG = + //;2'b00 (State-Machine); IALLCFG = 2'b01 (Flash); BNA = 1'b0; + mov r1, #0x02 + mcr p15, 0, r1, c10, c1, 3 //; WCP15_TLBLKCR r1 + + //;Make sure TLBLKCR is complete before continuing + ISB + + //; Invalidate the UTLB + mcr p15, 0, r0, c8, c7, 0 //; UTLBIALL + + //; Make sure UTLB request has been presented to macro before continuing + ISB + +SYSI2: + //; setup L2CR1 to some default Instruction and data prefetching values + //; Users may want specific settings for various performance + //; enhancements + //; In Halcyon we do not have broadcasting barriers. So we need to turn + // ; on bit 8 of L2CR1; which DBB:( Disable barrier broadcast ) + ldr r2, =0x133 + mcr p15, 3, r2, c15, c0, 3 //; WCP15_L2CR1 r0 + + + //; Enable Z bit to enable branch prediction (default is off) + mrc p15, 0, r2, c1, c0, 0 //; RCP15_SCTLR r2 + orr r2, r2, #0x00000800 + mcr p15, 0, r2, c1, c0, 0 //; WCP15_SCTLR r2 + + //; Make sure Link stack is initialized with branch and links to + //; sequential addresses + //; This aids in creating a predictable startup environment + bl SEQ1 +SEQ1: bl SEQ2 +SEQ2: bl SEQ3 +SEQ3: bl SEQ4 +SEQ4: bl SEQ5 +SEQ5: bl SEQ6 +SEQ6: bl SEQ7 +SEQ7: bl SEQ8 +SEQ8: + + //; REMOVE FOLLOWING THREE INSTRUCTIONS WHEN POWER COLLAPSE IS ENA + //;Make sure the DBGOSLSR[LOCK] bit is cleared to allow access to the + //;debug registers + //; Writing anything but the "secret code" to the DBGOSLAR clears the + //;DBGOSLSR[LOCK] bit + mcr p14, 0, r0, c1, c0, 4 //; WCP14_DBGOSLAR r0 + + + //; Read the DBGPRSR to clear the DBGPRSR[STICKYPD] + //; Any read to DBGPRSR clear the STICKYPD bit + //; ISB guarantees the read completes before attempting to + //; execute a CP14 instruction. + mrc p14, 0, r3, c1, c5, 4 //; RCP14_DBGPRSR r3 + ISB + + //; Initialize the Watchpoint Control Registers to zero (optional) + //;;; mcr p14, 0, r0, c0, c0, 7 ; WCP14_DBGWCR0 r0 + //;;; mcr p14, 0, r0, c0, c1, 7 ; WCP14_DBGWCR1 r0 + + + //;-------------------------------------------------------------------- + //; The saved Program Status Registers (SPSRs) should be setup + //; prior to any automatic mode switches. The following + //; code sets these registers up to a known state. Users will need to + //; customize these settings to meet their needs. + //;-------------------------------------------------------------------- + mov r2, #0x1f + mov r1, #0xd7 //;ABT mode + msr cpsr_c, r1 //;ABT mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xdb //;UND mode + msr cpsr_c, r1 //;UND mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xd1 //;FIQ mode + msr cpsr_c, r1 //;FIQ mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xd2 //;IRQ mode + msr cpsr_c, r1 //;IRQ mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xd6 //;Monitor mode + msr cpsr_c, r1 //;Monitor mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xd3 //;SVC mode + msr cpsr_c, r1 //;SVC mode + msr spsr_cxfs, r2 //;clear the spsr + + + //;-------------------------------------------------------------------- + //; Enabling Error reporting is something users may want to do at + //; some other point in time. We have chosen some default settings + //; that should be reviewed. Most of these registers come up in an + //; unpredictable state after reset. + //;-------------------------------------------------------------------- +//;Start of error and control setting + + //; setup L2CR0 with various L2/TCM control settings + //; enable out of order bus attributes and error reporting + //; this register comes up unpredictable after reset + // movw r1, #0x0F0F +.word 0xe3001f0f // hardcoded movw instruction due to lack of compiler support + // movT r1, #0xC005 +.word 0xe34c1005 // hardcoded movw instruction due to lack of compiler support + mcr p15, 3, r1, c15, c0, 1 //; WCP15_L2CR0 r1 + + //; setup L2CPUCR + //; mov r2, #0xFF + //; Enable I and D cache parity + //;L2CPUCR[7:5] = 3~Rh7 ~V enable parity error reporting for modified, + //;tag, and data parity errors + mov r2, #0xe0 + mcr p15, 3, r2, c15, c0, 2 //; WCP15_L2CPUCR r2 + + //; setup SPCR + //; enable all error reporting + //;(reset value is unpredicatble for most bits) + mov r3, #0x0F + mcr p15, 0, r3, c9, c7, 0 //; WCP15_SPCR r3 + + //; setup DMACHCRs (reset value unpredictable) + //; control setting and enable all error reporting + mov r1, #0x0F + + //; DMACHCR0 = 0000000F + mov r2, #0x00 //; channel 0 + mcr p15, 0, r2, c11, c0, 0 //; WCP15_DMASELR r2 + mcr p15, 0, r1, c11, c0, 2 //; WCP15_DMACHCR r1 + + //; DMACHCR1 = 0000000F + mov r2, #0x01 //; channel 1 + mcr p15, 0, r2, c11, c0, 0 //; WCP15_DMASELR r2 + mcr p15, 0, r1, c11, c0, 2 //; WCP15_DMACHCR r1 + + //; DMACHCR2 = 0000000F + mov r2, #0x02 //; channel 2 + mcr p15, 0, r2, c11, c0, 0 //; WCP15_DMASELR r2 + mcr p15, 0, r1, c11, c0, 2 //; WCP15_DMACHCR r1 + + //; DMACHCR3 = 0000000F + mov r2, #0x03 //; channel 3 + mcr p15, 0, r2, c11, c0, 0 //; WCP15_DMASELR r2 + mcr p15, 0, r1, c11, c0, 2 //; WCP15_DMACHCR r1 + + //; Set ACTLR (reset unpredictable) + //; Set AVIVT control, error reporting, etc. + //; mov r3, #0x07 + //; Enable I and D cache parity + //;ACTLR[2:0] = 3'h7 - enable parity error reporting from L2/I$/D$) + //;ACTLR[5:4] = 2'h3 - enable parity + //;ACTLR[19:18] =2'h3 - always generate and + //;check parity(when MMU disabled). + //;Value to be written #0xC0037 + // movw r3, #0x0037 +.word 0xe3003037 // hardcoded movw instruction due to lack of compiler support + // movT r3, #0x000C +.word 0xe340300c // hardcoded movw instruction due to lack of compiler support + mcr p15, 0, r3, c1, c0, 1 //; WCP15_ACTLR r3 + +//;End of error and control setting + + //;--------------------------------------------------------------------- + //; Unlock ETM and read StickyPD to halt the ETM clocks from running. + //; This is required for power saving whether the ETM is used or not. + //;--------------------------------------------------------------------- + + //;Clear ETMOSLSR[LOCK] bit + mov r1, #0x00000000 + mcr p14, 1, r1, c1, c0, 4 //; WCP14_ETMOSLAR r1 + + //;Clear ETMPDSR[STICKYPD] bit + mrc p14, 1, r2, c1, c5, 4 //; RCP14_ETMPDSR r2 + b SET_SA + + +.ltorg diff --git a/arch/arm/cpu/armv7/msm7630/timer.c b/arch/arm/cpu/armv7/msm7630/timer.c new file mode 100644 index 0000000..1c3f7ba --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/timer.c @@ -0,0 +1,148 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * (C) Copyright 2010,2011 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2008 + * Texas Instruments + * + * Richard Woodruff r-woodruff2@ti.com + * Syed Moahmmed Khasim khasim@ti.com + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * Alex Zuepke azu@sysgo.de + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/iomap.h> +#include <asm/io.h> +#include <config.h> +#include <common.h> +#include <asm/types.h> +#define TIMER_LOAD_VAL 0x21 + +#define GPT_ENABLE_CLR_ON_MATCH_EN 2 +#define GPT_ENABLE_EN 1 +#define DGT_ENABLE_CLR_ON_MATCH_EN 2 +#define DGT_ENABLE_EN 1 + +#define SPSS_TIMER_STATUS_DGT_EN (1 << 0) + + +#define READ_TIMER readl(GPT_COUNT_VAL) + +static ulong timestamp; +static ulong lastinc; +#define DGT_HZ 6750000 /* Uses LPXO/4 (27.0 MHz / 4) */ + + +/* nothing really to do with interrupts, just starts up a counter. */ +int timer_init(void) +{ + uint32_t val = 0; + + /* Disable timer */ + writel(0, DGT_ENABLE); + + /* Check for the hardware revision */ + val = readl(HW_REVISION_NUMBER); + val = (val >> 28) & 0x0F; + if (val >= 1) + writel(1, DGT_CLK_CTL); + return 0; +} + + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +/* delay x useconds AND perserve advance timstamp value */ +void __udelay(unsigned long usecs) +{ + unsigned int val; + usecs = (usecs * 33 + 1000 - 33) / 1000; + + writel(0, GPT_CLEAR); + writel(0, GPT_ENABLE); + do { + val = 0; + val = readl(GPT_COUNT_VAL); + } while (val != 0); + + writel(GPT_ENABLE_EN, GPT_ENABLE); + do { + val = 0; + val = readl(GPT_COUNT_VAL); + } while (val < usecs) ; + + writel(0, GPT_ENABLE); + writel(0, GPT_CLEAR); + +} + +void reset_timer_masked(void) +{ + /* reset time */ + lastinc = READ_TIMER; /* capure current decrementer value time */ + timestamp = 0; /* start "advancing" time stamp from 0 */ +} + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; /* current tick value */ + + if (lastinc <= now) { /* normal mode (non roll) */ + /* normal mode */ + timestamp += now - lastinc; + /* move stamp forward with absolute diff ticks */ + } else { /* we have overflow of the count down timer */ + timestamp += now + (TIMER_LOAD_VAL - lastinc); + } + lastinc = now; + + return timestamp; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return 19200000; +} diff --git a/arch/arm/include/asm/arch-msm7630/adm.h b/arch/arm/include/asm/arch-msm7630/adm.h new file mode 100644 index 0000000..0e8af85 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/adm.h @@ -0,0 +1,28 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __ADM_H +#define __ADM_H + +/* Channel #s and security domain */ +#define ADM_CHN 8 +#define ADM_SD 2 + +#endif diff --git a/arch/arm/include/asm/arch-msm7630/gpio.h b/arch/arm/include/asm/arch-msm7630/gpio.h new file mode 100644 index 0000000..af6ddaa --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/gpio.h @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __GPIO_H +#define __GPIO_H + +#ifndef GPIO_INPUT +#define GPIO_INPUT 0x0000 +#endif +#ifndef GPIO_OUTPUT +#define GPIO_OUTPUT 0x0001 +#endif + +#define GPIO_LEVEL 0x0000 +#define GPIO_EDGE 0x0010 + +#define GPIO_RISING 0x0020 +#define GPIO_FALLING 0x0040 + +#define GPIO_HIGH 0x0020 +#define GPIO_LOW 0x0040 + +#define GPIO_PULLUP 0x0100 +#define GPIO_PULLDOWN 0x0200 + +int gpio_config(unsigned nr, unsigned flags); +void gpio_set(unsigned nr, unsigned on); +int gpio_get(unsigned nr); + +#endif diff --git a/arch/arm/include/asm/arch-msm7630/gpio_hw.h b/arch/arm/include/asm/arch-msm7630/gpio_hw.h new file mode 100644 index 0000000..c8244d8 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/gpio_hw.h @@ -0,0 +1,168 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __GPIO_HW_H +#define __GPIO_HW_H + +#define MSM_GPIO1_BASE 0xAC001000 +#define MSM_GPIO2_BASE 0xAC101000 + +#define GPIO1_REG(off) (MSM_GPIO1_BASE + (off)) +#define GPIO2_REG(off) (MSM_GPIO2_BASE + 0x400 + (off)) + +/* output value */ +#define GPIO_OUT_0 GPIO1_REG(0x00) /* gpio 15-0 */ +#define GPIO_OUT_1 GPIO2_REG(0x00) /* gpio 43-16 */ +#define GPIO_OUT_2 GPIO1_REG(0x04) /* gpio 67-44 */ +#define GPIO_OUT_3 GPIO1_REG(0x08) /* gpio 94-68 */ +#define GPIO_OUT_4 GPIO1_REG(0x0C) /* gpio 106-95 */ +#define GPIO_OUT_5 GPIO1_REG(0x50) /* gpio 133-107 */ +#define GPIO_OUT_6 GPIO1_REG(0xC4) /* gpio 150-134 */ +#define GPIO_OUT_7 GPIO1_REG(0x214) /* gpio 181-151 */ + +/* same pin map as above, output enable */ +#define GPIO_OE_0 GPIO1_REG(0x10) +#define GPIO_OE_1 GPIO2_REG(0x08) +#define GPIO_OE_2 GPIO1_REG(0x14) +#define GPIO_OE_3 GPIO1_REG(0x18) +#define GPIO_OE_4 GPIO1_REG(0x1C) +#define GPIO_OE_5 GPIO1_REG(0x54) +#define GPIO_OE_6 GPIO1_REG(0xC8) +#define GPIO_OE_7 GPIO1_REG(0x218) + +/* same pin map as above, input read */ +#define GPIO_IN_0 GPIO1_REG(0x34) +#define GPIO_IN_1 GPIO2_REG(0x20) +#define GPIO_IN_2 GPIO1_REG(0x38) +#define GPIO_IN_3 GPIO1_REG(0x3C) +#define GPIO_IN_4 GPIO1_REG(0x40) +#define GPIO_IN_5 GPIO1_REG(0x44) +#define GPIO_IN_6 GPIO1_REG(0xCC) +#define GPIO_IN_7 GPIO1_REG(0x21C) + +/* same pin map as above, 1=edge 0=level interrup */ +#define GPIO_INT_EDGE_0 GPIO1_REG(0x60) +#define GPIO_INT_EDGE_1 GPIO2_REG(0x50) +#define GPIO_INT_EDGE_2 GPIO1_REG(0x64) +#define GPIO_INT_EDGE_3 GPIO1_REG(0x68) +#define GPIO_INT_EDGE_4 GPIO1_REG(0x6C) +#define GPIO_INT_EDGE_5 GPIO1_REG(0xC0) +#define GPIO_INT_EDGE_6 GPIO1_REG(0xD0) +#define GPIO_INT_EDGE_7 GPIO1_REG(0x240) + +/* same pin map as above, 1=positive 0=negative */ +#define GPIO_INT_POS_0 GPIO1_REG(0x70) +#define GPIO_INT_POS_1 GPIO2_REG(0x58) +#define GPIO_INT_POS_2 GPIO1_REG(0x74) +#define GPIO_INT_POS_3 GPIO1_REG(0x78) +#define GPIO_INT_POS_4 GPIO1_REG(0x7C) +#define GPIO_INT_POS_5 GPIO1_REG(0xBC) +#define GPIO_INT_POS_6 GPIO1_REG(0xD4) +#define GPIO_INT_POS_7 GPIO1_REG(0x228) + +/* same pin map as above, interrupt enable */ +#define GPIO_INT_EN_0 GPIO1_REG(0x80) +#define GPIO_INT_EN_1 GPIO2_REG(0x60) +#define GPIO_INT_EN_2 GPIO1_REG(0x84) +#define GPIO_INT_EN_3 GPIO1_REG(0x88) +#define GPIO_INT_EN_4 GPIO1_REG(0x8C) +#define GPIO_INT_EN_5 GPIO1_REG(0xB8) +#define GPIO_INT_EN_6 GPIO1_REG(0xD8) +#define GPIO_INT_EN_7 GPIO1_REG(0x22C) + +/* same pin map as above, write 1 to clear interrupt */ +#define GPIO_INT_CLEAR_0 GPIO1_REG(0x90) +#define GPIO_INT_CLEAR_1 GPIO2_REG(0x68) +#define GPIO_INT_CLEAR_2 GPIO1_REG(0x94) +#define GPIO_INT_CLEAR_3 GPIO1_REG(0x98) +#define GPIO_INT_CLEAR_4 GPIO1_REG(0x9C) +#define GPIO_INT_CLEAR_5 GPIO1_REG(0xB4) +#define GPIO_INT_CLEAR_6 GPIO1_REG(0xDC) +#define GPIO_INT_CLEAR_7 GPIO1_REG(0x230) + +/* same pin map as above, 1=interrupt pending */ +#define GPIO_INT_STATUS_0 GPIO1_REG(0xA0) +#define GPIO_INT_STATUS_1 GPIO2_REG(0x70) +#define GPIO_INT_STATUS_2 GPIO1_REG(0xA4) +#define GPIO_INT_STATUS_3 GPIO1_REG(0xA8) +#define GPIO_INT_STATUS_4 GPIO1_REG(0xAC) +#define GPIO_INT_STATUS_5 GPIO1_REG(0xB0) +#define GPIO_INT_STATUS_6 GPIO1_REG(0xE0) +#define GPIO_INT_STATUS_7 GPIO1_REG(0x234) + + +#define GPIO_OUT_VAL_REG_BASE 0xABC00000 +#define GPIO_ALT_FUNC_PAGE_REG (GPIO_OUT_VAL_REG_BASE + 0x20) +#define GPIO_ALT_FUNC_CFG_REG (GPIO_OUT_VAL_REG_BASE + 0x24) + + +/* GPIO TLMM: Pullup/Pulldown */ +#define GPIO_NO_PULL 0 +#define GPIO_PULL_DOWN 1 +#define GPIO_KEEPER 2 +#define GPIO_PULL_UP 3 + +/* GPIO TLMM: Drive Strength */ +#define GPIO_2MA 0 +#define GPIO_4MA 1 +#define GPIO_6MA 2 +#define GPIO_8MA 3 +#define GPIO_10MA 4 +#define GPIO_12MA 5 +#define GPIO_14MA 6 +#define GPIO_16MA 7 + +#define GPIO38_GPIO_CNTRL 0x175 + +/* GPIO TLMM: Status */ +#define GPIO_ENABLE 0 +#define GPIO_DISABLE 1 + +#define GPIO_CFG(gpio, func, dir, pull, drvstr) \ + ((((gpio) & 0x3FF) << 4) | \ + ((func) & 0xf) | \ + (((dir) & 0x1) << 14) | \ + (((pull) & 0x3) << 15) | \ + (((drvstr) & 0xF) << 17)) + +/** + * struct msm_gpio - GPIO pin description + * @gpio_cfg - configuration bitmap, as per gpio_tlmm_config() + * @label - textual label + * + * Usually, GPIO's are operated by sets. + * This struct accumulate all GPIO information in single source + * and facilitete group operations provided by msm_gpios_xxx() + */ +struct msm_gpio { + unsigned gpio_cfg; + const char *label; +}; + +/** + * extract GPIO pin from bit-field used for gpio_tlmm_config + */ +#define GPIO_PIN(gpio_cfg) (((gpio_cfg) >> 4) & 0x3ff) +#define GPIO_FUNC(gpio_cfg) (((gpio_cfg) >> 0) & 0xf) +#define GPIO_DIR(gpio_cfg) (((gpio_cfg) >> 14) & 0x1) +#define GPIO_PULL(gpio_cfg) (((gpio_cfg) >> 15) & 0x3) +#define GPIO_DRVSTR(gpio_cfg) (((gpio_cfg) >> 17) & 0xf) + +#endif diff --git a/arch/arm/include/asm/arch-msm7630/iomap.h b/arch/arm/include/asm/arch-msm7630/iomap.h new file mode 100644 index 0000000..186c6c2 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/iomap.h @@ -0,0 +1,96 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __IOMAP_H_ +#define __IOMAP_H_ + +#define MSM_UART1_BASE 0xACA00000 +#define MSM_UART2_BASE 0xACB00000 +#define MSM_UART3_BASE 0xACC00000 + +#define MSM_VIC_BASE 0xC0080000 +#define MSM_TMR_BASE 0xC0100000 + +#define MSM_GPT_BASE (MSM_TMR_BASE + 0x04) +#define MSM_DGT_BASE (MSM_TMR_BASE + 0x24) +#define SPSS_TIMER_STATUS (MSM_TMR_BASE + 0x88) + +#define GPT_REG(off) (MSM_GPT_BASE + (off)) +#define DGT_REG(off) (MSM_DGT_BASE + (off)) + +#define GPT_MATCH_VAL GPT_REG(0x0000) +#define GPT_COUNT_VAL GPT_REG(0x0004) +#define GPT_ENABLE GPT_REG(0x0008) +#define GPT_CLEAR GPT_REG(0x000C) + +#define DGT_MATCH_VAL DGT_REG(0x0000) +#define DGT_COUNT_VAL DGT_REG(0x0004) +#define DGT_ENABLE DGT_REG(0x0008) +#define DGT_CLEAR DGT_REG(0x000C) +#define DGT_CLK_CTL DGT_REG(0x0010) + +#define HW_REVISION_NUMBER 0xABC00270 + +#define MSM_CSR_BASE 0xC0100000 +#define MSM_GCC_BASE 0xC0182000 + +#define MSM_SDC1_BASE 0xA0400000 +#define MSM_SDC2_BASE 0xA0500000 +#define MSM_SDC3_BASE 0xA3000000 +#define MSM_SDC4_BASE 0xA3100000 + +#define MSM_SHARED_BASE 0x00100000 +#define MSM_CLK_CTL_BASE 0xAB800000 +#define MSM_CLK_CTL_SH2_BASE 0xABA01000 + +#define REG_BASE(off) (MSM_CLK_CTL_BASE + (off)) +#define REG_SH2_BASE(off) (MSM_CLK_CTL_SH2_BASE + (off)) + +#define SCSS_CLK_CTL 0xC0101004 +#define SCSS_CLK_SEL 0xC0101008 + +#define MSM_USB_BASE 0xA3600000 +#define MSM_CRYPTO_BASE 0xA8400000 + +#define SH2_USBH_MD_REG REG_SH2_BASE(0x2BC) +#define SH2_USBH_NS_REG REG_SH2_BASE(0x2C0) + +#define SH2_MDP_NS_REG REG_SH2_BASE(0x14C) +#define SH2_MDP_LCDC_MD_REG REG_SH2_BASE(0x38C) +#define SH2_MDP_LCDC_NS_REG REG_SH2_BASE(0x390) +#define SH2_MDP_VSYNC_REG REG_SH2_BASE(0x460) +#define SH2_PMDH_NS_REG REG_SH2_BASE(0x8C) + +#define SH2_GLBL_CLK_ENA_SC REG_SH2_BASE(0x3BC) +#define SH2_GLBL_CLK_ENA_2_SC REG_SH2_BASE(0x3C0) + +#define SH2_OWN_ROW1_BASE_REG REG_BASE(0x041C) +#define SH2_OWN_ROW2_BASE_REG REG_BASE(0x0424) +#define SH2_OWN_APPS2_BASE_REG REG_BASE(0x0414) + +#define MSM_ADM_BASE 0xAC200000 +#define MSM_ADM_SD_OFFSET 0x00100400 + +#define MSM_SAW_BASE 0xC0102000 + +#define PLL_ENA_REG REG_SH2_BASE(0x0264) +#define PLL2_STATUS_BASE_REG REG_BASE(0x0350) +#define PLL2_L_VAL_ADDR REG_BASE(0x033C) +#endif diff --git a/arch/arm/include/asm/arch-msm7630/proc_comm.h b/arch/arm/include/asm/arch-msm7630/proc_comm.h new file mode 100644 index 0000000..3df08b9 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/proc_comm.h @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __PROC_COMM_H_ +#define __PROC_COMM_H_ + +void usb_clock_init(void); +void lcdc_clock_init(unsigned rate); +void mdp_clock_init(unsigned rate); +void uart3_clock_init(void); +void uart2_clock_init(void); +void uart1_clock_init(void); +void mddi_clock_init(unsigned num, unsigned rate); +void reboot(unsigned reboot_reason); +int mmc_clock_enable_disable(unsigned id, unsigned enable); +int mmc_clock_set_rate(unsigned id, unsigned rate); +int mmc_clock_get_rate(unsigned id); +int gpio_tlmm_config(unsigned config, unsigned disable); +int vreg_set_level(unsigned id, unsigned mv); +int vreg_enable(unsigned id); +int vreg_disable(unsigned id); + +#endif + + diff --git a/arch/arm/include/asm/arch-msm7630/sys_proto.h b/arch/arm/include/asm/arch-msm7630/sys_proto.h new file mode 100644 index 0000000..c679d92 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/sys_proto.h @@ -0,0 +1,29 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef _SYS_PROTO_H_ +#define _SYS_PROTO_H_ + +void pll8_enable(void); +void clock_init(void); +void __cpu_early_init(void); + +#endif + -- 1.7.1
The contents of this e-mail and any attachment(s) may contain confidential or privileged information for the intended recipient(s). Unintended recipients are prohibited from taking action on the basis of information in this e-mail and using or disseminating the information, and must notify the sender and delete it from their system. L&T Infotech will not accept responsibility or liability for the accuracy or completeness of, or the presence of any virus or disabling code in this e-mail"
Hi Mohamed,
Le 16/02/2012 03:59, mohamed.haneef@lntinfotech.com a écrit :
+#define BIT(n) (1<< (n)) +#define VREG_CONFIG (BIT(7) | BIT(6))
BIT() is not used elsewhere. It would be simpler not to define it and to define VREG_CONFIG as (3 << 6).
Besides, isn't that rather a VREG_CONFIG_MASK?
Where is it used?
It says 'check it dynamically', but does not seem to. Any reason not to detect RAM size dynamically?
if (n> 150) {
*bit = 1<< (n - 151);
if (n> 133) {
*bit = 1<< (n - 134);
if (n> 106) {
*bit = 1<< (n - 107);
if (n> 94) {
*bit = 1<< (n - 95);
if (n> 67) {
*bit = 1<< (n - 68);
if (n> 43) {
*bit = 1<< (n - 44);
if (n> 15) {
*bit = 1<< (n - 16);
*bit = 1<< n;
struct gpioregs *r;
unsigned b;
unsigned v;
r = find_gpio(n,&b);
if (!r)
return -1;
v = readl(r->oe);
if (flags& GPIO_OUTPUT)
else
writel(v& (~b), r->oe);
struct gpioregs *r;
unsigned b;
unsigned v;
if (r == 0)
return;
v = readl(r->out);
if (on)
else
writel(v& (~b), r->out);
struct gpioregs *r;
unsigned b;
if (r == 0)
return (readl(r->in)& b) ? 1 : 0;
int rc;
int i;
for (i = 0; i< size; i++) {
g = table + i;
/* Enable gpio */
if (rc)
goto err;
+err:
return rc;
- (C) Copyright 2012
- LARSEN& TOUBRO INFOTECH LTD<www.lntinfotech.com>
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+#include<config.h> +#include<version.h>
+.text +.code 32
- ; LVT Ring Osc counter
- ; used to determine sense amp settings
- ; Clobbers registers r0, r4, r5, r6, r7, r9, r10, r11
+_TEXT_BASE:
mov pc, lr
.align 5
b _loop_forever
//; Reading L1_ACC
ldr r4, = 0x0
ldr r3, [r1]
mov r3, r3, LSR r2
and r3, r3, #1
orr r4, r3, r4
ldr r3, [r1]
mov r3, r3, LSR r2
and r3, r3, #1
mov r3, r3, LSL #1
orr r4, r3, r4
+l1_ck_0:
ldr r5, = 0x0
cmp r4, r5
bne l1_ck_1
ldr r0, =PVR0F0_00
ldr r1, =PVR0F2_00
ldr r2, =PVR2F0_00
ldr r3, =PVR2F1_00
+l1_ck_1:
ldr r1, = 0x01
cmp r4, r1
bne l1_ck_2
ldr r0, =PVR0F0_01
ldr r1, =PVR0F2_01
ldr r2, =PVR2F0_01
ldr r3, =PVR2F1_01
+l1_ck_2:
ldr r1, = 0x02
cmp r4, r1
bne l1_ck_3
ldr r0, =PVR0F0_10
ldr r1, =PVR0F2_10
ldr r2, =PVR2F0_10
ldr r3, =PVR2F1_10
+l1_ck_3:
ldr r1, = 0x03
cmp r4, r1
ldr r0, =PVR0F0_11
ldr r1, =PVR0F2_11
ldr r2, =PVR2F0_11
ldr r3, =PVR2F1_11
//;WCP15_PVR0F0 r0
//;WCP15_PVR0F2 r1
//;WCP15_PVR2F0 r2
ldr r4, =0x511f0000
cmp r2, r4
bne PVR2F1
+DPRC:
+PVR2F1:
//;WCP15_PVR2F1 r3
//; Reading L2_ACC
ldr r4, = 0x0
ldr r3, [r1]
mov r3, r3, LSR r2
and r3, r3, #1
orr r4, r3, r4
ldr r3, [r1]
mov r3, r3, LSR r2
and r3, r3, #1
mov r3, r3, LSL #1
orr r4, r3, r4
ldr r3, [r1]
mov r3, r3, LSR r2
and r3, r3, #1
mov r3, r3, LSL #2
orr r4, r3, r4
+l2_ck_0:
ldr r5, = 0x0
cmp r4, r5
bne l2_ck_1
+l2_ck_1:
ldr r5, = 0x1
cmp r4, r5
bne l2_ck_2
+l2_ck_2:
ldr r5, = 0x2
cmp r4, r5
bne l2_ck_3
+l2_ck_3:
ldr r5, = 0x3
cmp r4, r5
bne l2_ck_4
+l2_ck_4:
ldr r5, = 0x4
cmp r4, r5
bne l2_ck_5
+l2_ck_5:
ldr r5, = 0x5
cmp r4, r5
bne l2_ck_6
+l2_ck_6:
ldr r5, = 0x6
cmp r4, r5
bne l2_ck_7
+l2_ck_7:
ldr r5, = 0x7
cmp r4, r5
//;WCP15_L2VR3F1 r0
DSB
ISB
ldr r2, =0
ldr r3, =0
ldr r4, =0
ldr r5, =0
mrs r0, cpsr
orr r0, r0, #(1<<7)
msr cpsr_c, r0
pop {r5-r12,pc}
+.ltorg
push {r5-r12,r14}
mov r0, #0x0
//; once per bank)
mov r1, #0x2
// movW r1, #0x01FF
// movT r1, #0x01FF
DSB
ISB
movw r2, #0x88
//; code sequences
//; IASIDCFG =
mov r1, #0x02
ISB
ISB
+SYSI2:
//; enhancements
ldr r2, =0x133
bl SEQ1
//;debug registers
ISB
If that is optional, why do it?
mov r2, #0x1f
// movw r1, #0x0F0F
// movT r1, #0xC005
//; setup L2CPUCR
//; mov r2, #0xFF
mov r2, #0xe0
//; setup SPCR
mov r3, #0x0F
mov r1, #0x0F
//; mov r3, #0x07
// movw r3, #0x0037
// movT r3, #0x000C
mov r1, #0x00000000
b SET_SA
- (C) Copyright 2010,2011
- NVIDIA Corporation<www.nvidia.com>
- (C) Copyright 2008
- Texas Instruments
- Richard Woodruffr-woodruff2@ti.com
- Syed Moahmmed Khasimkhasim@ti.com
- (C) Copyright 2002
- Sysgo Real-Time Solutions, GmbH<www.elinos.com>
- Marius Groegermgroeger@sysgo.de
- Alex Zuepkeazu@sysgo.de
- Gary Jennejohn, DENX Software Engineering,garyj@denx.de
- project.
- MA 02111-1307 USA
+#include<asm/arch/iomap.h> +#include<asm/io.h> +#include<config.h> +#include<common.h> +#include<asm/types.h> +#define TIMER_LOAD_VAL 0x21
+#define SPSS_TIMER_STATUS_DGT_EN (1<< 0)
uint32_t val = 0;
/* Disable timer */
val = (val>> 28)& 0x0F;
if (val>= 1)
unsigned int val;
do {
val = 0;
} while (val != 0);
do {
val = 0;
} while (val< usecs) ;
Why do you need a timer reset function?
/* reset time */
if (lastinc<= now) { /* normal mode (non roll) */
/* normal mode */
lastinc = now;
return timestamp;
- This function is derived from PowerPC code (read timebase as long long).
- On ARM it just returns the timer value.
- This function is derived from PowerPC code (timebase clock frequency).
- On ARM it returns the number of timer ticks per second.
return 19200000;
((((gpio)& 0x3FF)<< 4) | \
((func)& 0xf) | \
(((dir)& 0x1)<< 14) | \
(((pull)& 0x3)<< 15) | \
(((drvstr)& 0xF)<< 17))
- struct msm_gpio - GPIO pin description
- @gpio_cfg - configuration bitmap, as per gpio_tlmm_config()
- @label - textual label
- Usually, GPIO's are operated by sets.
- This struct accumulate all GPIO information in single source
- and facilitete group operations provided by msm_gpios_xxx()
+struct msm_gpio {
unsigned gpio_cfg;
const char *label;
- extract GPIO pin from bit-field used for gpio_tlmm_config
+#define GPIO_PIN(gpio_cfg) (((gpio_cfg)>> 4)& 0x3ff) +#define GPIO_FUNC(gpio_cfg) (((gpio_cfg)>> 0)& 0xf) +#define GPIO_DIR(gpio_cfg) (((gpio_cfg)>> 14)& 0x1) +#define GPIO_PULL(gpio_cfg) (((gpio_cfg)>> 15)& 0x3) +#define GPIO_DRVSTR(gpio_cfg) (((gpio_cfg)>> 17)& 0xf)
-- 1.7.1
Amicalement,
* Support for Qualcomm msm7630 SoC
Signed-off-by: Mohamed Haneef mohamed.haneef@lntinfotech.com ---
Changes for v2: - removed BIT() macro and replacing with (3 << 6) in the macro VERG_CONFIG - removed the unwanted comment line - removed Intitalize the Watchpoint Controll Register to zero, since optional - removed reset_timer_masked function since it is not used any where
arch/arm/cpu/armv7/msm7630/Makefile | 59 +++ arch/arm/cpu/armv7/msm7630/acpuclock.c | 327 +++++++++++++ arch/arm/cpu/armv7/msm7630/board.c | 57 +++ arch/arm/cpu/armv7/msm7630/config.mk | 1 + arch/arm/cpu/armv7/msm7630/gpio.c | 229 +++++++++ arch/arm/cpu/armv7/msm7630/lowlevel_init.S | 623 +++++++++++++++++++++++++ arch/arm/cpu/armv7/msm7630/timer.c | 142 ++++++ arch/arm/include/asm/arch-msm7630/adm.h | 28 ++ arch/arm/include/asm/arch-msm7630/gpio.h | 47 ++ arch/arm/include/asm/arch-msm7630/gpio_hw.h | 168 +++++++ arch/arm/include/asm/arch-msm7630/iomap.h | 96 ++++ arch/arm/include/asm/arch-msm7630/proc_comm.h | 42 ++ arch/arm/include/asm/arch-msm7630/sys_proto.h | 29 ++ 13 files changed, 1848 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/armv7/msm7630/Makefile create mode 100644 arch/arm/cpu/armv7/msm7630/acpuclock.c create mode 100644 arch/arm/cpu/armv7/msm7630/board.c create mode 100644 arch/arm/cpu/armv7/msm7630/config.mk create mode 100644 arch/arm/cpu/armv7/msm7630/gpio.c create mode 100644 arch/arm/cpu/armv7/msm7630/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/msm7630/timer.c create mode 100644 arch/arm/include/asm/arch-msm7630/adm.h create mode 100644 arch/arm/include/asm/arch-msm7630/gpio.h create mode 100644 arch/arm/include/asm/arch-msm7630/gpio_hw.h create mode 100644 arch/arm/include/asm/arch-msm7630/iomap.h create mode 100644 arch/arm/include/asm/arch-msm7630/proc_comm.h create mode 100644 arch/arm/include/asm/arch-msm7630/sys_proto.h
diff --git a/arch/arm/cpu/armv7/msm7630/Makefile b/arch/arm/cpu/armv7/msm7630/Makefile new file mode 100644 index 0000000..d9dfade --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/Makefile @@ -0,0 +1,59 @@ +# +# (C) Copyright 2012 +# LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> +# +# (C) Copyright 2010,2011 Nvidia Corporation. +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# The AVP is ARMv4T architecture so we must use special compiler +# flags for any startup files it might use. +#CFLAGS_arch/arm/cpu/armv7/tegra2/ap20.o += -march=armv4t +#CFLAGS_arch/arm/cpu/armv7/tegra2/clock.o += -march=armv4t + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS-y := lowlevel_init.o +COBJS-y := board.o +COBJS-y += timer.o +COBJS-y += acpuclock.o +COBJS-y += gpio.o + + SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) + OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/msm7630/acpuclock.c b/arch/arm/cpu/armv7/msm7630/acpuclock.c new file mode 100644 index 0000000..73570fc --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/acpuclock.c @@ -0,0 +1,327 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <asm/arch/iomap.h> +#include <asm/io.h> +#include <common.h> +#include <asm/arch/mmc.h> +#include <asm/arch/proc_comm.h> +#define ACPU_806MHZ 42 +#define ACPU_1024MHZ 53 +#define ACPU_1200MHZ 125 +#define ACPU_1400MHZ 73 + +/* Macros to select PLL2 with divide by 1 */ +#define ACPU_SRC_SEL 3 +#define ACPU_SRC_DIV 0 + +#define VREG_CONFIG (3 << 6) +#define VREG_DATA (VREG_CONFIG | (VREF_SEL << 5)) +#define VREF_SEL 1 /* 0: 0.625V (50mV step), 1: 0.3125V (25mV step). */ +#define V_STEP (25 * (2 - VREF_SEL)) /* Minimum voltage step size. */ +#define MV(mv) ((mv) / (!((mv) % V_STEP))) +/* mv = (750mV + (raw * 25mV)) * (2 - VREF_SEL) */ +#define VDD_RAW(mv) (((MV(mv) / V_STEP) - 30) | VREG_DATA) + + +/* enum for SDC CLK IDs */ +enum { + SDC1_CLK = 19, + SDC1_PCLK = 20, + SDC2_CLK = 21, + SDC2_PCLK = 22, + SDC3_CLK = 23, + SDC3_PCLK = 24, + SDC4_CLK = 25, + SDC4_PCLK = 26 +}; + +/* Zero'th entry is dummy */ +static uint8_t sdc_clk[] = {0, SDC1_CLK, SDC2_CLK, SDC3_CLK, SDC4_CLK}; +static uint8_t sdc_pclk[] = {0, SDC1_PCLK, SDC2_PCLK, SDC3_PCLK, SDC4_PCLK}; + +void spm_init(void) +{ + writel(0x05, MSM_SAW_BASE + 0x10); /* MSM_SPM_REG_SAW_CFG */ + writel(0x18, MSM_SAW_BASE + 0x14); /* MSM_SPM_REG_SAW_SPM_CTL */ + writel(0x00006666, MSM_SAW_BASE + 0x18); + /* MSM_SPM_REG_SAW_SPM_SLP_TMR_DLY */ + writel(0xFF000666, MSM_SAW_BASE + 0x1C); + /* MSM_SPM_REG_SAW_SPM_WAKE_TMR_DLY */ + writel(0x01, MSM_SAW_BASE + 0x24); /* MSM_SPM_REG_SAW_SLP_CLK_EN */ + writel(0x03, MSM_SAW_BASE + 0x28); + /* MSM_SPM_REG_SAW_SLP_HSFS_PRECLMP_EN */ + writel(0x00, MSM_SAW_BASE + 0x2C); + /* MSM_SPM_REG_SAW_SLP_HSFS_POSTCLMP_EN */ + writel(0x01, MSM_SAW_BASE + 0x30); /* MSM_SPM_REG_SAW_SLP_CLMP_EN */ + writel(0x00, MSM_SAW_BASE + 0x34); /* MSM_SPM_REG_SAW_SLP_RST_EN */ + writel(0x00, MSM_SAW_BASE + 0x38); /* MSM_SPM_REG_SAW_SPM_MPM_CFG */ +} + +/* Configures msmc2 voltage. vlevel is in mV */ +void msmc2_config(unsigned vlevel) +{ + unsigned val; + val = readl(MSM_SAW_BASE + 0x08); /* MSM_SPM_REG_SAW_VCTL */ + val &= ~0xFF; + val |= VDD_RAW(vlevel); + writel(val, MSM_SAW_BASE + 0x08); /* MSM_SPM_REG_SAW_VCTL */ + /* Wait for PMIC state to return to idle and for VDD to stabilize */ + while (((readl(MSM_SAW_BASE + 0x0C) >> 20) & 0x3) != 0) + ; + udelay(160); +} + +void enable_pll(unsigned num) +{ + unsigned reg_val; + reg_val = readl(PLL_ENA_REG); + reg_val |= (1 << num); + writel(reg_val, PLL_ENA_REG); + /* Wait until PLL is enabled */ + while ((readl(PLL2_STATUS_BASE_REG) & (1 << 16)) == 0) + ; +} + +void acpu_clock_init(void) +{ + unsigned clk, reg_clksel, reg_clkctl, src_sel; + /* Fixing msmc2 voltage */ + spm_init(); + clk = readl(PLL2_L_VAL_ADDR) & 0xFF; + if (clk == ACPU_806MHZ) + msmc2_config(1100); + else if (clk == ACPU_1024MHZ || clk == ACPU_1200MHZ) + msmc2_config(1200); + else if (clk == ACPU_1400MHZ) + msmc2_config(1250); + /* Enable pll 2 */ + enable_pll(2); + reg_clksel = readl(SCSS_CLK_SEL); + /* CLK_SEL_SRC1NO */ + src_sel = reg_clksel & 1; + /* Program clock source and divider. */ + reg_clkctl = readl(SCSS_CLK_CTL); + reg_clkctl &= ~(0xFF << (8 * src_sel)); + reg_clkctl |= ACPU_SRC_SEL << (4 + 8 * src_sel); + reg_clkctl |= ACPU_SRC_DIV << (0 + 8 * src_sel); + writel(reg_clkctl, SCSS_CLK_CTL); + /* Toggle clock source. */ + reg_clksel ^= 1; + /* Program clock source selection. */ + writel(reg_clksel, SCSS_CLK_SEL); +} + +void hsusb_clock_init(void) +{ + int val = 0; + unsigned sh2_own_row2; + unsigned sh2_own_row2_hsusb_mask = (1 << 11); + + sh2_own_row2 = readl(SH2_OWN_ROW2_BASE_REG); + if (sh2_own_row2 & sh2_own_row2_hsusb_mask) { + /* USB local clock control enabled */ + /* Set value in MD register */ + val = 0x5DF; + writel(val, SH2_USBH_MD_REG); + /* Set value in NS register */ + val = 1 << 8; + val = val | readl(SH2_USBH_NS_REG); + writel(val, SH2_USBH_NS_REG); + val = 1 << 11; + val = val | readl(SH2_USBH_NS_REG); + writel(val, SH2_USBH_NS_REG); + val = 1 << 9; + val = val | readl(SH2_USBH_NS_REG); + writel(val, SH2_USBH_NS_REG); + val = 1 << 13; + val = val | readl(SH2_USBH_NS_REG); + writel(val, SH2_USBH_NS_REG); + /* Enable USBH_P_CLK */ + val = 1 << 25; + val = val | readl(SH2_GLBL_CLK_ENA_SC); + writel(val, SH2_GLBL_CLK_ENA_SC); + } else + /* USB local clock control not enabled; use proc comm */ + usb_clock_init(); + +} + +void adm_enable_clock(void) +{ + unsigned int val = 0; + + /* Enable ADM_CLK */ + val = 1 << 5; + val = val | readl(SH2_GLBL_CLK_ENA_SC); + writel(val, SH2_GLBL_CLK_ENA_SC); +} + +void mdp_lcdc_clock_init(void) +{ + unsigned int val = 0; + unsigned sh2_own_apps2; + unsigned sh2_own_apps2_lcdc_mask = (1 << 3); + + sh2_own_apps2 = readl(SH2_OWN_APPS2_BASE_REG); + if (sh2_own_apps2 & sh2_own_apps2_lcdc_mask) { + /* MDP local clock control enabled */ + /* Select clock source and divider */ + val = 0x29; + val = val | readl(SH2_MDP_NS_REG); + writel(val, SH2_MDP_NS_REG); + + /* Enable MDP source clock(root) */ + val = 1 << 11; + val = val | readl(SH2_MDP_NS_REG); + writel(val, SH2_MDP_NS_REG); + + /* Enable graphics clock(branch) */ + val = 1 << 9; + val = val | readl(SH2_MDP_NS_REG); + writel(val, SH2_MDP_NS_REG); + + /* Enable MDP_P_CLK */ + val = 1 << 6; + val = val | readl(SH2_GLBL_CLK_ENA_2_SC); + writel(val, SH2_GLBL_CLK_ENA_2_SC); + + /* Enable AXI_MDP_CLK */ + val = 1 << 29; + val = val | readl(SH2_GLBL_CLK_ENA_2_SC); + writel(val, SH2_GLBL_CLK_ENA_2_SC); + + /* LCDC local clock control enabled */ + /* Set value in MD register */ + val = 0x1FFF9; + writel(val, SH2_MDP_LCDC_MD_REG); + + /* Set MDP_LCDC_N_VAL in NS register */ + val = 0xFFFA << 16; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Set clock source */ + val = 1; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Set divider */ + val = 3 << 3; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Set MN counter mode */ + val = 2 << 5; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Enable MN counter */ + val = 1 << 8; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Enable mdp_lcdc_src(root) clock */ + val = 1 << 11; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Enable mdp_lcdc_pclk(branch) clock */ + val = 1 << 9; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + + /* Enable mdp_lcdc_pad_pclk(branch) clock */ + val = 1 << 12; + val = val | readl(SH2_MDP_LCDC_NS_REG); + writel(val, SH2_MDP_LCDC_NS_REG); + } else { + /* MDP local clock control not enabled; use proc comm */ + mdp_clock_init(122880000); + /* LCDC local clock control not enabled; use proc comm */ + lcdc_clock_init(27648000); + } +} + +void mddi_pmdh_clock_init(void) +{ + unsigned int val = 0; + unsigned sh2_own_row1; + unsigned sh2_own_row1_pmdh_mask = (1 << 19); + + sh2_own_row1 = readl(SH2_OWN_ROW1_BASE_REG); + if (sh2_own_row1 & sh2_own_row1_pmdh_mask) { + /* Select clock source and divider */ + val = 1; + val |= (1 << 3); + val = val | readl(SH2_PMDH_NS_REG); + writel(val, SH2_PMDH_NS_REG); + + /* Enable PMDH_SRC (root) signal */ + val = 1 << 11; + val = val | readl(SH2_PMDH_NS_REG); + writel(val, SH2_PMDH_NS_REG); + + /* Enable PMDH_P_CLK */ + val = 1 << 4; + val = val | readl(SH2_GLBL_CLK_ENA_2_SC); + writel(val, SH2_GLBL_CLK_ENA_2_SC); + } else + /* MDDI local clock control not enabled; use proc comm */ + mddi_clock_init(0, 480000000); +} + +void ce_clock_init(void) +{ + unsigned int val = 0; + + /* Enable CE_CLK */ + val = 1 << 6; + val = val | readl(SH2_GLBL_CLK_ENA_SC); + writel(val, SH2_GLBL_CLK_ENA_SC); +} + +#ifdef CONFIG_QC_MMC +/* Configure MMC clock */ +void clock_config_mmc(uint32_t interface, uint32_t freq) +{ + uint32_t reg = 0; + + if (mmc_clock_set_rate(sdc_clk[interface], freq) < 0) + printf("Failure setting clock rate for MCLK - " + "clk_rate: %d\n!", freq); + + /* enable clock */ + if (mmc_clock_enable_disable(sdc_clk[interface], MMC_CLK_ENABLE) < 0) + printf("Failure enabling MMC Clock!\n"); + + reg |= MMC_BOOT_MCI_CLK_ENABLE; + reg |= MMC_BOOT_MCI_CLK_ENA_FLOW; + reg |= MMC_BOOT_MCI_CLK_IN_FEEDBACK; + writel(reg, MMC_BOOT_MCI_CLK); +} + +/* Intialize MMC clock */ +void clock_init_mmc(uint32_t interface) +{ + if (mmc_clock_enable_disable(sdc_pclk[interface], MMC_CLK_ENABLE) < 0) + printf("Failure enabling PCLK!\n"); +} +#endif diff --git a/arch/arm/cpu/armv7/msm7630/board.c b/arch/arm/cpu/armv7/msm7630/board.c new file mode 100644 index 0000000..c7b8204 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/board.c @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/arch/iomap.h> +#include <asm/arch/sys_proto.h> + + +DECLARE_GLOBAL_DATA_PTR; + +void set_vector_base(unsigned long addr) +{ + __asm__ volatile ("mcr p15, 0, %0, c12, c0, 0" : : "r" (addr)); +} + +int dram_init(void) +{ + /* We do not initialise DRAM here. We just query the size */ + gd->ram_size = PHYS_SDRAM_1_SIZE; + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + +} + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init() +{ + __cpu_early_init(); + return 0; +} +#endif diff --git a/arch/arm/cpu/armv7/msm7630/config.mk b/arch/arm/cpu/armv7/msm7630/config.mk new file mode 100644 index 0000000..935a147 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/config.mk @@ -0,0 +1 @@ +PLATFORM_CPPFLAGS += -march=armv7-a diff --git a/arch/arm/cpu/armv7/msm7630/gpio.c b/arch/arm/cpu/armv7/msm7630/gpio.c new file mode 100644 index 0000000..daa6d66 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/gpio.c @@ -0,0 +1,229 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/iomap.h> +#include <asm/arch/gpio.h> +#include <asm/arch/proc_comm.h> +#include <asm/arch/gpio_hw.h> + +struct gpioregs { + unsigned out; + unsigned in; + unsigned int_status; + unsigned int_clear; + unsigned int_en; + unsigned int_edge; + unsigned int_pos; + unsigned oe; +}; + +static struct gpioregs GPIO_REGS[] = { + { + .out = GPIO_OUT_0, + .in = GPIO_IN_0, + .int_status = GPIO_INT_STATUS_0, + .int_clear = GPIO_INT_CLEAR_0, + .int_en = GPIO_INT_EN_0, + .int_edge = GPIO_INT_EDGE_0, + .int_pos = GPIO_INT_POS_0, + .oe = GPIO_OE_0, + }, + { + .out = GPIO_OUT_1, + .in = GPIO_IN_1, + .int_status = GPIO_INT_STATUS_1, + .int_clear = GPIO_INT_CLEAR_1, + .int_en = GPIO_INT_EN_1, + .int_edge = GPIO_INT_EDGE_1, + .int_pos = GPIO_INT_POS_1, + .oe = GPIO_OE_1, + }, + { + .out = GPIO_OUT_2, + .in = GPIO_IN_2, + .int_status = GPIO_INT_STATUS_2, + .int_clear = GPIO_INT_CLEAR_2, + .int_en = GPIO_INT_EN_2, + .int_edge = GPIO_INT_EDGE_2, + .int_pos = GPIO_INT_POS_2, + .oe = GPIO_OE_2, + }, + { + .out = GPIO_OUT_3, + .in = GPIO_IN_3, + .int_status = GPIO_INT_STATUS_3, + .int_clear = GPIO_INT_CLEAR_3, + .int_en = GPIO_INT_EN_3, + .int_edge = GPIO_INT_EDGE_3, + .int_pos = GPIO_INT_POS_3, + .oe = GPIO_OE_3, + }, + { + .out = GPIO_OUT_4, + .in = GPIO_IN_4, + .int_status = GPIO_INT_STATUS_4, + .int_clear = GPIO_INT_CLEAR_4, + .int_en = GPIO_INT_EN_4, + .int_edge = GPIO_INT_EDGE_4, + .int_pos = GPIO_INT_POS_4, + .oe = GPIO_OE_4, + }, + { + .out = GPIO_OUT_5, + .in = GPIO_IN_5, + .int_status = GPIO_INT_STATUS_5, + .int_clear = GPIO_INT_CLEAR_5, + .int_en = GPIO_INT_EN_5, + .int_edge = GPIO_INT_EDGE_5, + .int_pos = GPIO_INT_POS_5, + .oe = GPIO_OE_5, + }, + { + .out = GPIO_OUT_6, + .in = GPIO_IN_6, + .int_status = GPIO_INT_STATUS_6, + .int_clear = GPIO_INT_CLEAR_6, + .int_en = GPIO_INT_EN_6, + .int_edge = GPIO_INT_EDGE_6, + .int_pos = GPIO_INT_POS_6, + .oe = GPIO_OE_6, + }, + { + .out = GPIO_OUT_7, + .in = GPIO_IN_7, + .int_status = GPIO_INT_STATUS_7, + .int_clear = GPIO_INT_CLEAR_7, + .int_en = GPIO_INT_EN_7, + .int_edge = GPIO_INT_EDGE_7, + .int_pos = GPIO_INT_POS_7, + .oe = GPIO_OE_7, + }, +}; + +static struct gpioregs *find_gpio(unsigned n, unsigned *bit) +{ + if (n > 150) { + *bit = 1 << (n - 151); + return GPIO_REGS + 7; + } + if (n > 133) { + *bit = 1 << (n - 134); + return GPIO_REGS + 6; + } + if (n > 106) { + *bit = 1 << (n - 107); + return GPIO_REGS + 5; + } + if (n > 94) { + *bit = 1 << (n - 95); + return GPIO_REGS + 4; + } + if (n > 67) { + *bit = 1 << (n - 68); + return GPIO_REGS + 3; + } + if (n > 43) { + *bit = 1 << (n - 44); + return GPIO_REGS + 2; + } + if (n > 15) { + *bit = 1 << (n - 16); + return GPIO_REGS + 1; + } + *bit = 1 << n; + return GPIO_REGS + 0; +} + +int gpio_config(unsigned n, unsigned flags) +{ + struct gpioregs *r; + unsigned b; + unsigned v; + + r = find_gpio(n, &b); + if (!r) + return -1; + + v = readl(r->oe); + if (flags & GPIO_OUTPUT) + writel(v | b, r->oe); + else + writel(v & (~b), r->oe); + return 0; +} + +void gpio_set(unsigned n, unsigned on) +{ + struct gpioregs *r; + unsigned b; + unsigned v; + + r = find_gpio(n, &b); + if (r == 0) + return; + + v = readl(r->out); + if (on) + writel(v | b, r->out); + else + writel(v & (~b), r->out); +} + +int gpio_get(unsigned n) +{ + struct gpioregs *r; + unsigned b; + + r = find_gpio(n, &b); + if (r == 0) + return 0; + return (readl(r->in) & b) ? 1 : 0; +} + +void platform_config_interleaved_mode_gpios(void) +{ + /* configure EB2_CS1 through GPIO86 */ + writel(GPIO_ALT_FUNC_PAGE_REG, 0x56); + writel(GPIO_ALT_FUNC_CFG_REG, 0x04); + /* configure the EBI2_BUSY1_N through GPIO115 */ + writel(GPIO_ALT_FUNC_PAGE_REG, 0x73); + writel(GPIO_ALT_FUNC_CFG_REG, 0x08); +} + +/* Enables all gpios passed in table*/ +int platform_gpios_enable(const struct msm_gpio *table, int size) +{ + int rc; + int i; + const struct msm_gpio *g; + for (i = 0; i < size; i++) { + g = table + i; + /* Enable gpio */ + rc = gpio_tlmm_config(g->gpio_cfg, GPIO_ENABLE); + if (rc) + goto err; + } + return 0; +err: + return rc; +} + diff --git a/arch/arm/cpu/armv7/msm7630/lowlevel_init.S b/arch/arm/cpu/armv7/msm7630/lowlevel_init.S new file mode 100644 index 0000000..ef63770 --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/lowlevel_init.S @@ -0,0 +1,623 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <config.h> +#include <version.h> + +.text +.code 32 + +#define DSB .byte 0x4f, 0xf0, 0x7f, 0xf5 +#define ISB .byte 0x6f, 0xf0, 0x7f, 0xf5 + +/* + ; LVT Ring Osc counter + ; used to determine sense amp settings + ; Clobbers registers r0, r4, r5, r6, r7, r9, r10, r11 +*/ +.equ CLK_CTL_BASE, 0xA8600000 +.equ A_GLBL_CLK_ENA, 0x0000 +.equ A_PRPH_WEB_NS_REG,0x0080 +.equ A_MSM_CLK_RINGOSC,0x00D0 +.equ A_TCXO_CNT, 0x00D4 +.equ A_TCXO_CNT_DONE, 0x00D8 +.equ A_RINGOSC_CNT, 0x00DC +.equ A_MISC_CLK_CTL, 0x0108 +.equ CLK_TEST, 0xA8600114 +.equ SPSS_CSR_BASE, 0xAC100000 +.equ A_SCRINGOSC, 0x0510 + +//;; Number of TCXO cycles to count ring oscillations +.equ TCXO_CNT_VAL, 0x100 + +//; Halcyon addresses +.equ TCSR_CONF_FUSE_1, 0xAB600060 //; TCSR_CONF_FUSE_1 register +.equ TCSR_CONF_FUSE_4, 0xAB60006C //; TCSR_CONF_FUSE_4 register + +//; SCORPION_L1_ACC (1:0) Fuses bit location +.equ L1_ACC_BIT_0, 12 //;12th bit of TCSR_CONF_FUSE_4 +.equ L1_ACC_BIT_1, 13 //;13th bit of TCSR_CONF_FUSE_4 +//; SCORPION_L2_ACC (2:0) Fuses bit location +.equ L2_ACC_BIT_0, 25 //;25th bit of TCSR_CONF_FUSE_1 +.equ L2_ACC_BIT_1, 10 //;10th bit of TCSR_CONF_FUSE_4 +.equ L2_ACC_BIT_2, 11 //;11th bit of TCSR_CONF_FUSE_4 + +//; CP15: PVR2F0 values according to SCORPION_L1_ACC (1:0) +.equ PVR2F0_00, 0x00000000 +.equ PVR2F0_01, 0x04000000 +.equ PVR2F0_10, 0x08000000 +.equ PVR2F0_11, 0x0C000000 + +//; CP15: PVR2F1 values according to SCORPION_L1_ACC (1:0) +.equ PVR2F1_00, 0x00000008 +.equ PVR2F1_01, 0x00000008 +.equ PVR2F1_10, 0x00000208 +.equ PVR2F1_11, 0x00000208 + +//; CP15: PVR0F2 values according to SCORPION_L1_ACC (1:0) +.equ PVR0F2_00, 0x00000000 +.equ PVR0F2_01, 0x00000000 +.equ PVR0F2_10, 0x00000200 +.equ PVR0F2_11, 0x00000200 + +//; CP15: PVR0F0 values according to SCORPION_L1_ACC (1:0) +.equ PVR0F0_00, 0x7F000000 +.equ PVR0F0_01, 0x7F000400 +.equ PVR0F0_10, 0x7F000000 +.equ PVR0F0_11, 0x7F000400 + +//; CP15: L2VR3F1 values according to SCORPION_L2_ACC (2:0) +.equ L2VR3F1_000, 0x00FFFF60 +.equ L2VR3F1_001, 0x00FFFF40 +.equ L2VR3F1_010, 0x00FFFC60 +.equ L2VR3F1_011, 0x00FFFC40 +.equ L2VR3F1_100, 0x00FCFF60 +.equ L2VR3F1_101, 0x00FCFF40 +.equ L2VR3F1_110, 0x00FCFC60 +.equ L2VR3F1_111, 0x00FCFC40 + + + + +_TEXT_BASE: + .word CONFIG_SYS_TEXT_BASE @ sdram load addr from config file + +.global invalidate_dcache +invalidate_dcache: + mov pc, lr + + .align 5 +.globl lowlevel_init +lowlevel_init: + mov pc, lr @ back to arch calling code + +.global reset_cpu +reset_cpu: +_loop_forever: + b _loop_forever + +.globl SET_SA +SET_SA: + + //;-------------------------------------------------------------------- + //; Fuse bits used to determine sense amp settings + //;-------------------------------------------------------------------- + + //; Reading L1_ACC + ldr r4, = 0x0 + + //; Read L1_ACC_BIT_0 + ldr r1, =TCSR_CONF_FUSE_4 + ldr r2, =L1_ACC_BIT_0 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + orr r4, r3, r4 + + //; Read L1_ACC_BIT_1 + ldr r1, =TCSR_CONF_FUSE_4 + ldr r2, =L1_ACC_BIT_1 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + mov r3, r3, LSL #1 + orr r4, r3, r4 + +l1_ck_0: + //; if L1_[1:0] == 00 + ldr r5, = 0x0 + cmp r4, r5 + bne l1_ck_1 + ldr r0, =PVR0F0_00 + ldr r1, =PVR0F2_00 + ldr r2, =PVR2F0_00 + ldr r3, =PVR2F1_00 + b WRITE_L1_SA_SETTINGS + +l1_ck_1: + //; if L1_[1:0] == 01 + ldr r1, = 0x01 + cmp r4, r1 + bne l1_ck_2 + ldr r0, =PVR0F0_01 + ldr r1, =PVR0F2_01 + ldr r2, =PVR2F0_01 + ldr r3, =PVR2F1_01 + b WRITE_L1_SA_SETTINGS + +l1_ck_2: + //; if L1_[2:0] == 10 + ldr r1, = 0x02 + cmp r4, r1 + bne l1_ck_3 + ldr r0, =PVR0F0_10 + ldr r1, =PVR0F2_10 + ldr r2, =PVR2F0_10 + ldr r3, =PVR2F1_10 + b WRITE_L1_SA_SETTINGS + +l1_ck_3: + //; if L1_[2:0] == 11 + ldr r1, = 0x03 + cmp r4, r1 + ldr r0, =PVR0F0_11 + ldr r1, =PVR0F2_11 + ldr r2, =PVR2F0_11 + ldr r3, =PVR2F1_11 + b WRITE_L1_SA_SETTINGS + + +WRITE_L1_SA_SETTINGS: + + //;WCP15_PVR0F0 r0 + mcr p15, 0x0, r0, c15, c15, 0x0 //; write R0 to PVR0F0 + + //;WCP15_PVR0F2 r1 + mcr p15, 0x0, r1, c15, c15, 0x2 //; write R1 to PVR0F2 + + //;WCP15_PVR2F0 r2 + mcr p15, 0x2, r2, c15, c15, 0x0 //; write R2 to PVR2F0 + + // Disable predecode repair cache on certain Scorpion revisions + // (Raptor V2 and earlier, or Halcyon V1) + mrc p15, 0, r1, c0, c0, 0 //; MIDR + BIC r2, r1, #0xf0 //; check for Halcyon V1 + ldr r4, =0x511f0000 + cmp r2, r4 + bne PVR2F1 + +DPRC: + mrc p15, 0, r1, c15, c15, 2 //; PVR0F2 + orr r1, r1, #0x10 //; enable bit 4 + mcr p15, 0, r1, c15, c15, 2 //; disable predecode repair cache + +PVR2F1: + //;WCP15_PVR2F1 r3 + mcr p15, 0x2, r3, c15, c15, 0x1 //; write R3 to PVR2F1 + + //; Reading L2_ACC + ldr r4, = 0x0 + + //; Read L2_ACC_BIT_0 + ldr r1, =TCSR_CONF_FUSE_1 + ldr r2, =L2_ACC_BIT_0 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + orr r4, r3, r4 + + //; Read L2_ACC_BIT_1 + ldr r1, =TCSR_CONF_FUSE_4 + ldr r2, =L2_ACC_BIT_1 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + mov r3, r3, LSL #1 + orr r4, r3, r4 + + //; Read L2_ACC_BIT_2 + ldr r1, =TCSR_CONF_FUSE_4 + ldr r2, =L2_ACC_BIT_2 + ldr r3, [r1] + mov r3, r3, LSR r2 + and r3, r3, #1 + mov r3, r3, LSL #2 + orr r4, r3, r4 + +l2_ck_0: + //; if L2_[2:0] == 000 + ldr r5, = 0x0 + cmp r4, r5 + bne l2_ck_1 + ldr r0, =L2VR3F1_000 + b WRITE_L2_SA_SETTINGS + +l2_ck_1: + //; if L2_[2:0] == 001 + ldr r5, = 0x1 + cmp r4, r5 + bne l2_ck_2 + ldr r0, =L2VR3F1_001 + b WRITE_L2_SA_SETTINGS + +l2_ck_2: + //; if L2_[2:0] == 010 + ldr r5, = 0x2 + cmp r4, r5 + bne l2_ck_3 + ldr r0, =L2VR3F1_010 + b WRITE_L2_SA_SETTINGS + +l2_ck_3: + //; if L2_[2:0] == 011 + ldr r5, = 0x3 + cmp r4, r5 + bne l2_ck_4 + ldr r0, =L2VR3F1_011 + b WRITE_L2_SA_SETTINGS + +l2_ck_4: + //; if L2_[2:0] == 100 + ldr r5, = 0x4 + cmp r4, r5 + bne l2_ck_5 + ldr r0, =L2VR3F1_100 + b WRITE_L2_SA_SETTINGS + +l2_ck_5: + //; if L2_[2:0] == 101 + ldr r5, = 0x5 + cmp r4, r5 + bne l2_ck_6 + ldr r0, =L2VR3F1_101 + b WRITE_L2_SA_SETTINGS + +l2_ck_6: + //; if L2_[2:0] == 110 + ldr r5, = 0x6 + cmp r4, r5 + bne l2_ck_7 + ldr r0, =L2VR3F1_110 + b WRITE_L2_SA_SETTINGS + +l2_ck_7: + //; if L2_[2:0] == 111 + ldr r5, = 0x7 + cmp r4, r5 + ldr r0, =L2VR3F1_111 + b WRITE_L2_SA_SETTINGS + +WRITE_L2_SA_SETTINGS: + //;WCP15_L2VR3F1 r0 + mcr p15, 0x3, r0, c15, c15, 0x1 //;write r0 to L2VR3F1 + DSB + ISB + + ldr r0, =0 //;make sure the registers we touched + ldr r1, =0 //;are cleared when we return + ldr r2, =0 + ldr r3, =0 + ldr r4, =0 + ldr r5, =0 + + mrs r0, cpsr + orr r0, r0, #(1<<7) + msr cpsr_c, r0 + + //; routine complete + pop {r5-r12,pc} + +.ltorg + +.globl __cpu_early_init +__cpu_early_init: + + //; Zero out r0 for use throughout this code. All other GPRs + //; (r1-r3) are set throughout this code to help establish + //; a consistent startup state for any code that follows. + //; Users should add code at the end of this routine to establish + //; their own stack address (r13), add translation page tables, enable + //; the caches, etc. + push {r5-r12,r14} + mov r0, #0x0 + + + //; Remove hardcoded cache settings. appsbl_handler.s calls Set_SA + //; API to dynamically configure cache for slow/nominal/fast parts + + //; DCIALL to invalidate L2 cache bank (needs to be run 4 times, + //; once per bank) + //; This must be done early in code (prior to enabling the caches) + mov r1, #0x2 + mcr p15, 0, r1, c9, c0, 6 //; DCIALL bank D ([15:14] == 2'b00) + orr r1, r1, #0x00004000 + mcr p15, 0, r1, c9, c0, 6 //; DCIALL bank C ([15:14] == 2'b01) + add r1, r1, #0x00004000 + mcr p15, 0, r1, c9, c0, 6 //; DCIALL bank B ([15:14] == 2'b10) + add r1, r1, #0x00004000 + mcr p15, 0, r1, c9, c0, 6 //; DCIALL bank A ([15:14] == 2'b11) + + //; Initialize the BPCR - setup Global History Mask (GHRM) to all 1's + //; and have all address bits (AM) participate. + //; Different settings can be used to improve performance + // movW r1, #0x01FF +.word 0xe30011ff // hardcoded movW instruction due to lack of compiler support + // movT r1, #0x01FF +.word 0xe34011ff // hardcoded movT instruction due to lack of compiler support + mcr p15, 7, r1, c15, c0, 2 //; WCP15_BPCR + + + //; Initialize all I$ Victim Registers to 0 for startup + mcr p15, 0, r0, c9, c1, 0 //; WCP15_ICVIC0 r0 + mcr p15, 0, r0, c9, c1, 1 //; WCP15_ICVIC1 r0 + mcr p15, 0, r0, c9, c1, 2 //; WCP15_ICVIC2 r0 + mcr p15, 0, r0, c9, c1, 3 //; WCP15_ICVIC3 r0 + mcr p15, 0, r0, c9, c1, 4 //; WCP15_ICVIC4 r0 + mcr p15, 0, r0, c9, c1, 5 //; WCP15_ICVIC5 r0 + mcr p15, 0, r0, c9, c1, 6 //; WCP15_ICVIC5 r0 + mcr p15, 0, r0, c9, c1, 7 //; WCP15_ICVIC7 r0 + + //; Initialize all I$ Locked Victim Registers (Unlocked Floors) to 0 + mcr p15, 1, r0, c9, c1, 0 //; WCP15_ICFLOOR0 r0 + mcr p15, 1, r0, c9, c1, 1 //; WCP15_ICFLOOR1 r0 + mcr p15, 1, r0, c9, c1, 2 //; WCP15_ICFLOOR2 r0 + mcr p15, 1, r0, c9, c1, 3 //; WCP15_ICFLOOR3 r0 + mcr p15, 1, r0, c9, c1, 4 //; WCP15_ICFLOOR4 r0 + mcr p15, 1, r0, c9, c1, 5 //; WCP15_ICFLOOR5 r0 + mcr p15, 1, r0, c9, c1, 6 //; WCP15_ICFLOOR6 r0 + mcr p15, 1, r0, c9, c1, 7 //; WCP15_ICFLOOR7 r0 + + //; Initialize all D$ Victim Registers to 0 + mcr p15, 2, r0, c9, c1, 0 //; WP15_DCVIC0 r0 + mcr p15, 2, r0, c9, c1, 1 //; WP15_DCVIC1 r0 + mcr p15, 2, r0, c9, c1, 2 //; WP15_DCVIC2 r0 + mcr p15, 2, r0, c9, c1, 3 //; WP15_DCVIC3 r0 + mcr p15, 2, r0, c9, c1, 4 //; WP15_DCVIC4 r0 + mcr p15, 2, r0, c9, c1, 5 //; WP15_DCVIC5 r0 + mcr p15, 2, r0, c9, c1, 6 //; WP15_DCVIC6 r0 + mcr p15, 2, r0, c9, c1, 7 //; WP15_DCVIC7 r0 + + //; Initialize all D$ Locked VDCtim Registers (Unlocked Floors) to 0 + mcr p15, 3, r0, c9, c1, 0 //; WCP15_DCFLOOR0 r0 + mcr p15, 3, r0, c9, c1, 1 //; WCP15_DCFLOOR1 r0 + mcr p15, 3, r0, c9, c1, 2 //; WCP15_DCFLOOR2 r0 + mcr p15, 3, r0, c9, c1, 3 //; WCP15_DCFLOOR3 r0 + mcr p15, 3, r0, c9, c1, 4 //; WCP15_DCFLOOR4 r0 + mcr p15, 3, r0, c9, c1, 5 //; WCP15_DCFLOOR5 r0 + mcr p15, 3, r0, c9, c1, 6 //; WCP15_DCFLOOR6 r0 + mcr p15, 3, r0, c9, c1, 7 //; WCP15_DCFLOOR7 r0 + + //; Initialize ASID to zero + mcr p15, 0, r0, c13, c0, 1 //; WCP15_CONTEXTIDR r0 + + //; ICIALL to invalidate entire I-Cache + mcr p15, 0, r0, c7, c5, 0 //; ICIALLU + + //; DCIALL to invalidate entire D-Cache + mcr p15, 0, r0, c9, c0, 6 //; DCIALL r0 + + //; Initialize ADFSR to zero + mcr p15, 0, r0, c5, c1, 0 //; ADFSR r0 + + //; Initialize EFSR to zero + mcr p15, 7, r0, c15, c0, 1 //; EFSR r0 + + //; The VBAR (Vector Base Address Register) should be initialized + //; early in your code. We are setting it to zero + mcr p15, 0, r0, c12, c0, 0 //; WCP15_VBAR r0 + + //; Ensure the mcr's above have completed their operation + //; before continuing + DSB + ISB + + //; Setup CCPR - Cache Coherency Policy Register + //; setup CCPR[L1ISHP, L2ISHP] both to 0b00 (no forcing) + //; setup CCPR[L1OSHP, L2OSHP] both to 0b10 (force non-cacheable) + movw r2, #0x88 + mcr p15, 0, r2, c10, c4, 2 + + //;------------------------------------------------------------------- + //; There are a number of registers that must be set prior to enabling + //; the MMU. The DCAR is one of these registers. We are setting + //; it to zero (no access) to easily detect improper setup in subsequent + //; code sequences + //;------------------------------------------------------------------- + //; Setup DACR (Domain Access Control Register) to zero + mcr p15, 0, r0, c3, c0, 0 //; WCP15_DACR r0 + + //; Setup DCLKCR to allow normal D-Cache line fills + mcr p15, 1, r0, c9, c0, 7 //; WCP15_DCLKCR r0 + + //; Setup the TLBLKCR + //; Victim = 6'b000000; Floor = 6'b000000; + //; IASIDCFG = + //;2'b00 (State-Machine); IALLCFG = 2'b01 (Flash); BNA = 1'b0; + mov r1, #0x02 + mcr p15, 0, r1, c10, c1, 3 //; WCP15_TLBLKCR r1 + + //;Make sure TLBLKCR is complete before continuing + ISB + + //; Invalidate the UTLB + mcr p15, 0, r0, c8, c7, 0 //; UTLBIALL + + //; Make sure UTLB request has been presented to macro before continuing + ISB + +SYSI2: + //; setup L2CR1 to some default Instruction and data prefetching values + //; Users may want specific settings for various performance + //; enhancements + //; In Halcyon we do not have broadcasting barriers. So we need to turn + // ; on bit 8 of L2CR1; which DBB:( Disable barrier broadcast ) + ldr r2, =0x133 + mcr p15, 3, r2, c15, c0, 3 //; WCP15_L2CR1 r0 + + + //; Enable Z bit to enable branch prediction (default is off) + mrc p15, 0, r2, c1, c0, 0 //; RCP15_SCTLR r2 + orr r2, r2, #0x00000800 + mcr p15, 0, r2, c1, c0, 0 //; WCP15_SCTLR r2 + + //; Make sure Link stack is initialized with branch and links to + //; sequential addresses + //; This aids in creating a predictable startup environment + bl SEQ1 +SEQ1: bl SEQ2 +SEQ2: bl SEQ3 +SEQ3: bl SEQ4 +SEQ4: bl SEQ5 +SEQ5: bl SEQ6 +SEQ6: bl SEQ7 +SEQ7: bl SEQ8 +SEQ8: + + //; REMOVE FOLLOWING THREE INSTRUCTIONS WHEN POWER COLLAPSE IS ENA + //;Make sure the DBGOSLSR[LOCK] bit is cleared to allow access to the + //;debug registers + //; Writing anything but the "secret code" to the DBGOSLAR clears the + //;DBGOSLSR[LOCK] bit + mcr p14, 0, r0, c1, c0, 4 //; WCP14_DBGOSLAR r0 + + + //; Read the DBGPRSR to clear the DBGPRSR[STICKYPD] + //; Any read to DBGPRSR clear the STICKYPD bit + //; ISB guarantees the read completes before attempting to + //; execute a CP14 instruction. + mrc p14, 0, r3, c1, c5, 4 //; RCP14_DBGPRSR r3 + ISB + + + + //;-------------------------------------------------------------------- + //; The saved Program Status Registers (SPSRs) should be setup + //; prior to any automatic mode switches. The following + //; code sets these registers up to a known state. Users will need to + //; customize these settings to meet their needs. + //;-------------------------------------------------------------------- + mov r2, #0x1f + mov r1, #0xd7 //;ABT mode + msr cpsr_c, r1 //;ABT mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xdb //;UND mode + msr cpsr_c, r1 //;UND mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xd1 //;FIQ mode + msr cpsr_c, r1 //;FIQ mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xd2 //;IRQ mode + msr cpsr_c, r1 //;IRQ mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xd6 //;Monitor mode + msr cpsr_c, r1 //;Monitor mode + msr spsr_cxfs, r2 //;clear the spsr + mov r1, #0xd3 //;SVC mode + msr cpsr_c, r1 //;SVC mode + msr spsr_cxfs, r2 //;clear the spsr + + + //;-------------------------------------------------------------------- + //; Enabling Error reporting is something users may want to do at + //; some other point in time. We have chosen some default settings + //; that should be reviewed. Most of these registers come up in an + //; unpredictable state after reset. + //;-------------------------------------------------------------------- +//;Start of error and control setting + + //; setup L2CR0 with various L2/TCM control settings + //; enable out of order bus attributes and error reporting + //; this register comes up unpredictable after reset + // movw r1, #0x0F0F +.word 0xe3001f0f // hardcoded movw instruction due to lack of compiler support + // movT r1, #0xC005 +.word 0xe34c1005 // hardcoded movw instruction due to lack of compiler support + mcr p15, 3, r1, c15, c0, 1 //; WCP15_L2CR0 r1 + + //; setup L2CPUCR + //; mov r2, #0xFF + //; Enable I and D cache parity + //;L2CPUCR[7:5] = 3~Rh7 ~V enable parity error reporting for modified, + //;tag, and data parity errors + mov r2, #0xe0 + mcr p15, 3, r2, c15, c0, 2 //; WCP15_L2CPUCR r2 + + //; setup SPCR + //; enable all error reporting + //;(reset value is unpredicatble for most bits) + mov r3, #0x0F + mcr p15, 0, r3, c9, c7, 0 //; WCP15_SPCR r3 + + //; setup DMACHCRs (reset value unpredictable) + //; control setting and enable all error reporting + mov r1, #0x0F + + //; DMACHCR0 = 0000000F + mov r2, #0x00 //; channel 0 + mcr p15, 0, r2, c11, c0, 0 //; WCP15_DMASELR r2 + mcr p15, 0, r1, c11, c0, 2 //; WCP15_DMACHCR r1 + + //; DMACHCR1 = 0000000F + mov r2, #0x01 //; channel 1 + mcr p15, 0, r2, c11, c0, 0 //; WCP15_DMASELR r2 + mcr p15, 0, r1, c11, c0, 2 //; WCP15_DMACHCR r1 + + //; DMACHCR2 = 0000000F + mov r2, #0x02 //; channel 2 + mcr p15, 0, r2, c11, c0, 0 //; WCP15_DMASELR r2 + mcr p15, 0, r1, c11, c0, 2 //; WCP15_DMACHCR r1 + + //; DMACHCR3 = 0000000F + mov r2, #0x03 //; channel 3 + mcr p15, 0, r2, c11, c0, 0 //; WCP15_DMASELR r2 + mcr p15, 0, r1, c11, c0, 2 //; WCP15_DMACHCR r1 + + //; Set ACTLR (reset unpredictable) + //; Set AVIVT control, error reporting, etc. + //; mov r3, #0x07 + //; Enable I and D cache parity + //;ACTLR[2:0] = 3'h7 - enable parity error reporting from L2/I$/D$) + //;ACTLR[5:4] = 2'h3 - enable parity + //;ACTLR[19:18] =2'h3 - always generate and + //;check parity(when MMU disabled). + //;Value to be written #0xC0037 + // movw r3, #0x0037 +.word 0xe3003037 // hardcoded movw instruction due to lack of compiler support + // movT r3, #0x000C +.word 0xe340300c // hardcoded movw instruction due to lack of compiler support + mcr p15, 0, r3, c1, c0, 1 //; WCP15_ACTLR r3 + +//;End of error and control setting + + //;--------------------------------------------------------------------- + //; Unlock ETM and read StickyPD to halt the ETM clocks from running. + //; This is required for power saving whether the ETM is used or not. + //;--------------------------------------------------------------------- + + //;Clear ETMOSLSR[LOCK] bit + mov r1, #0x00000000 + mcr p14, 1, r1, c1, c0, 4 //; WCP14_ETMOSLAR r1 + + //;Clear ETMPDSR[STICKYPD] bit + mrc p14, 1, r2, c1, c5, 4 //; RCP14_ETMPDSR r2 + b SET_SA + + +.ltorg diff --git a/arch/arm/cpu/armv7/msm7630/timer.c b/arch/arm/cpu/armv7/msm7630/timer.c new file mode 100644 index 0000000..007314e --- /dev/null +++ b/arch/arm/cpu/armv7/msm7630/timer.c @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * (C) Copyright 2010,2011 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2008 + * Texas Instruments + * + * Richard Woodruff r-woodruff2@ti.com + * Syed Moahmmed Khasim khasim@ti.com + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * Alex Zuepke azu@sysgo.de + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/iomap.h> +#include <asm/io.h> +#include <config.h> +#include <common.h> +#include <asm/types.h> +#define TIMER_LOAD_VAL 0x21 + +#define GPT_ENABLE_CLR_ON_MATCH_EN 2 +#define GPT_ENABLE_EN 1 +#define DGT_ENABLE_CLR_ON_MATCH_EN 2 +#define DGT_ENABLE_EN 1 + +#define SPSS_TIMER_STATUS_DGT_EN (1 << 0) + + +#define READ_TIMER readl(GPT_COUNT_VAL) + +static ulong timestamp; +static ulong lastinc; +#define DGT_HZ 6750000 /* Uses LPXO/4 (27.0 MHz / 4) */ + + +/* nothing really to do with interrupts, just starts up a counter. */ +int timer_init(void) +{ + uint32_t val = 0; + + /* Disable timer */ + writel(0, DGT_ENABLE); + + /* Check for the hardware revision */ + val = readl(HW_REVISION_NUMBER); + val = (val >> 28) & 0x0F; + if (val >= 1) + writel(1, DGT_CLK_CTL); + return 0; +} + + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +/* delay x useconds AND perserve advance timstamp value */ +void __udelay(unsigned long usecs) +{ + unsigned int val; + usecs = (usecs * 33 + 1000 - 33) / 1000; + + writel(0, GPT_CLEAR); + writel(0, GPT_ENABLE); + do { + val = 0; + val = readl(GPT_COUNT_VAL); + } while (val != 0); + + writel(GPT_ENABLE_EN, GPT_ENABLE); + do { + val = 0; + val = readl(GPT_COUNT_VAL); + } while (val < usecs) ; + + writel(0, GPT_ENABLE); + writel(0, GPT_CLEAR); + +} + + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; /* current tick value */ + + if (lastinc <= now) { /* normal mode (non roll) */ + /* normal mode */ + timestamp += now - lastinc; + /* move stamp forward with absolute diff ticks */ + } else { /* we have overflow of the count down timer */ + timestamp += now + (TIMER_LOAD_VAL - lastinc); + } + lastinc = now; + + return timestamp; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return 19200000; +} diff --git a/arch/arm/include/asm/arch-msm7630/adm.h b/arch/arm/include/asm/arch-msm7630/adm.h new file mode 100644 index 0000000..0e8af85 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/adm.h @@ -0,0 +1,28 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __ADM_H +#define __ADM_H + +/* Channel #s and security domain */ +#define ADM_CHN 8 +#define ADM_SD 2 + +#endif diff --git a/arch/arm/include/asm/arch-msm7630/gpio.h b/arch/arm/include/asm/arch-msm7630/gpio.h new file mode 100644 index 0000000..af6ddaa --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/gpio.h @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __GPIO_H +#define __GPIO_H + +#ifndef GPIO_INPUT +#define GPIO_INPUT 0x0000 +#endif +#ifndef GPIO_OUTPUT +#define GPIO_OUTPUT 0x0001 +#endif + +#define GPIO_LEVEL 0x0000 +#define GPIO_EDGE 0x0010 + +#define GPIO_RISING 0x0020 +#define GPIO_FALLING 0x0040 + +#define GPIO_HIGH 0x0020 +#define GPIO_LOW 0x0040 + +#define GPIO_PULLUP 0x0100 +#define GPIO_PULLDOWN 0x0200 + +int gpio_config(unsigned nr, unsigned flags); +void gpio_set(unsigned nr, unsigned on); +int gpio_get(unsigned nr); + +#endif diff --git a/arch/arm/include/asm/arch-msm7630/gpio_hw.h b/arch/arm/include/asm/arch-msm7630/gpio_hw.h new file mode 100644 index 0000000..c8244d8 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/gpio_hw.h @@ -0,0 +1,168 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __GPIO_HW_H +#define __GPIO_HW_H + +#define MSM_GPIO1_BASE 0xAC001000 +#define MSM_GPIO2_BASE 0xAC101000 + +#define GPIO1_REG(off) (MSM_GPIO1_BASE + (off)) +#define GPIO2_REG(off) (MSM_GPIO2_BASE + 0x400 + (off)) + +/* output value */ +#define GPIO_OUT_0 GPIO1_REG(0x00) /* gpio 15-0 */ +#define GPIO_OUT_1 GPIO2_REG(0x00) /* gpio 43-16 */ +#define GPIO_OUT_2 GPIO1_REG(0x04) /* gpio 67-44 */ +#define GPIO_OUT_3 GPIO1_REG(0x08) /* gpio 94-68 */ +#define GPIO_OUT_4 GPIO1_REG(0x0C) /* gpio 106-95 */ +#define GPIO_OUT_5 GPIO1_REG(0x50) /* gpio 133-107 */ +#define GPIO_OUT_6 GPIO1_REG(0xC4) /* gpio 150-134 */ +#define GPIO_OUT_7 GPIO1_REG(0x214) /* gpio 181-151 */ + +/* same pin map as above, output enable */ +#define GPIO_OE_0 GPIO1_REG(0x10) +#define GPIO_OE_1 GPIO2_REG(0x08) +#define GPIO_OE_2 GPIO1_REG(0x14) +#define GPIO_OE_3 GPIO1_REG(0x18) +#define GPIO_OE_4 GPIO1_REG(0x1C) +#define GPIO_OE_5 GPIO1_REG(0x54) +#define GPIO_OE_6 GPIO1_REG(0xC8) +#define GPIO_OE_7 GPIO1_REG(0x218) + +/* same pin map as above, input read */ +#define GPIO_IN_0 GPIO1_REG(0x34) +#define GPIO_IN_1 GPIO2_REG(0x20) +#define GPIO_IN_2 GPIO1_REG(0x38) +#define GPIO_IN_3 GPIO1_REG(0x3C) +#define GPIO_IN_4 GPIO1_REG(0x40) +#define GPIO_IN_5 GPIO1_REG(0x44) +#define GPIO_IN_6 GPIO1_REG(0xCC) +#define GPIO_IN_7 GPIO1_REG(0x21C) + +/* same pin map as above, 1=edge 0=level interrup */ +#define GPIO_INT_EDGE_0 GPIO1_REG(0x60) +#define GPIO_INT_EDGE_1 GPIO2_REG(0x50) +#define GPIO_INT_EDGE_2 GPIO1_REG(0x64) +#define GPIO_INT_EDGE_3 GPIO1_REG(0x68) +#define GPIO_INT_EDGE_4 GPIO1_REG(0x6C) +#define GPIO_INT_EDGE_5 GPIO1_REG(0xC0) +#define GPIO_INT_EDGE_6 GPIO1_REG(0xD0) +#define GPIO_INT_EDGE_7 GPIO1_REG(0x240) + +/* same pin map as above, 1=positive 0=negative */ +#define GPIO_INT_POS_0 GPIO1_REG(0x70) +#define GPIO_INT_POS_1 GPIO2_REG(0x58) +#define GPIO_INT_POS_2 GPIO1_REG(0x74) +#define GPIO_INT_POS_3 GPIO1_REG(0x78) +#define GPIO_INT_POS_4 GPIO1_REG(0x7C) +#define GPIO_INT_POS_5 GPIO1_REG(0xBC) +#define GPIO_INT_POS_6 GPIO1_REG(0xD4) +#define GPIO_INT_POS_7 GPIO1_REG(0x228) + +/* same pin map as above, interrupt enable */ +#define GPIO_INT_EN_0 GPIO1_REG(0x80) +#define GPIO_INT_EN_1 GPIO2_REG(0x60) +#define GPIO_INT_EN_2 GPIO1_REG(0x84) +#define GPIO_INT_EN_3 GPIO1_REG(0x88) +#define GPIO_INT_EN_4 GPIO1_REG(0x8C) +#define GPIO_INT_EN_5 GPIO1_REG(0xB8) +#define GPIO_INT_EN_6 GPIO1_REG(0xD8) +#define GPIO_INT_EN_7 GPIO1_REG(0x22C) + +/* same pin map as above, write 1 to clear interrupt */ +#define GPIO_INT_CLEAR_0 GPIO1_REG(0x90) +#define GPIO_INT_CLEAR_1 GPIO2_REG(0x68) +#define GPIO_INT_CLEAR_2 GPIO1_REG(0x94) +#define GPIO_INT_CLEAR_3 GPIO1_REG(0x98) +#define GPIO_INT_CLEAR_4 GPIO1_REG(0x9C) +#define GPIO_INT_CLEAR_5 GPIO1_REG(0xB4) +#define GPIO_INT_CLEAR_6 GPIO1_REG(0xDC) +#define GPIO_INT_CLEAR_7 GPIO1_REG(0x230) + +/* same pin map as above, 1=interrupt pending */ +#define GPIO_INT_STATUS_0 GPIO1_REG(0xA0) +#define GPIO_INT_STATUS_1 GPIO2_REG(0x70) +#define GPIO_INT_STATUS_2 GPIO1_REG(0xA4) +#define GPIO_INT_STATUS_3 GPIO1_REG(0xA8) +#define GPIO_INT_STATUS_4 GPIO1_REG(0xAC) +#define GPIO_INT_STATUS_5 GPIO1_REG(0xB0) +#define GPIO_INT_STATUS_6 GPIO1_REG(0xE0) +#define GPIO_INT_STATUS_7 GPIO1_REG(0x234) + + +#define GPIO_OUT_VAL_REG_BASE 0xABC00000 +#define GPIO_ALT_FUNC_PAGE_REG (GPIO_OUT_VAL_REG_BASE + 0x20) +#define GPIO_ALT_FUNC_CFG_REG (GPIO_OUT_VAL_REG_BASE + 0x24) + + +/* GPIO TLMM: Pullup/Pulldown */ +#define GPIO_NO_PULL 0 +#define GPIO_PULL_DOWN 1 +#define GPIO_KEEPER 2 +#define GPIO_PULL_UP 3 + +/* GPIO TLMM: Drive Strength */ +#define GPIO_2MA 0 +#define GPIO_4MA 1 +#define GPIO_6MA 2 +#define GPIO_8MA 3 +#define GPIO_10MA 4 +#define GPIO_12MA 5 +#define GPIO_14MA 6 +#define GPIO_16MA 7 + +#define GPIO38_GPIO_CNTRL 0x175 + +/* GPIO TLMM: Status */ +#define GPIO_ENABLE 0 +#define GPIO_DISABLE 1 + +#define GPIO_CFG(gpio, func, dir, pull, drvstr) \ + ((((gpio) & 0x3FF) << 4) | \ + ((func) & 0xf) | \ + (((dir) & 0x1) << 14) | \ + (((pull) & 0x3) << 15) | \ + (((drvstr) & 0xF) << 17)) + +/** + * struct msm_gpio - GPIO pin description + * @gpio_cfg - configuration bitmap, as per gpio_tlmm_config() + * @label - textual label + * + * Usually, GPIO's are operated by sets. + * This struct accumulate all GPIO information in single source + * and facilitete group operations provided by msm_gpios_xxx() + */ +struct msm_gpio { + unsigned gpio_cfg; + const char *label; +}; + +/** + * extract GPIO pin from bit-field used for gpio_tlmm_config + */ +#define GPIO_PIN(gpio_cfg) (((gpio_cfg) >> 4) & 0x3ff) +#define GPIO_FUNC(gpio_cfg) (((gpio_cfg) >> 0) & 0xf) +#define GPIO_DIR(gpio_cfg) (((gpio_cfg) >> 14) & 0x1) +#define GPIO_PULL(gpio_cfg) (((gpio_cfg) >> 15) & 0x3) +#define GPIO_DRVSTR(gpio_cfg) (((gpio_cfg) >> 17) & 0xf) + +#endif diff --git a/arch/arm/include/asm/arch-msm7630/iomap.h b/arch/arm/include/asm/arch-msm7630/iomap.h new file mode 100644 index 0000000..186c6c2 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/iomap.h @@ -0,0 +1,96 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __IOMAP_H_ +#define __IOMAP_H_ + +#define MSM_UART1_BASE 0xACA00000 +#define MSM_UART2_BASE 0xACB00000 +#define MSM_UART3_BASE 0xACC00000 + +#define MSM_VIC_BASE 0xC0080000 +#define MSM_TMR_BASE 0xC0100000 + +#define MSM_GPT_BASE (MSM_TMR_BASE + 0x04) +#define MSM_DGT_BASE (MSM_TMR_BASE + 0x24) +#define SPSS_TIMER_STATUS (MSM_TMR_BASE + 0x88) + +#define GPT_REG(off) (MSM_GPT_BASE + (off)) +#define DGT_REG(off) (MSM_DGT_BASE + (off)) + +#define GPT_MATCH_VAL GPT_REG(0x0000) +#define GPT_COUNT_VAL GPT_REG(0x0004) +#define GPT_ENABLE GPT_REG(0x0008) +#define GPT_CLEAR GPT_REG(0x000C) + +#define DGT_MATCH_VAL DGT_REG(0x0000) +#define DGT_COUNT_VAL DGT_REG(0x0004) +#define DGT_ENABLE DGT_REG(0x0008) +#define DGT_CLEAR DGT_REG(0x000C) +#define DGT_CLK_CTL DGT_REG(0x0010) + +#define HW_REVISION_NUMBER 0xABC00270 + +#define MSM_CSR_BASE 0xC0100000 +#define MSM_GCC_BASE 0xC0182000 + +#define MSM_SDC1_BASE 0xA0400000 +#define MSM_SDC2_BASE 0xA0500000 +#define MSM_SDC3_BASE 0xA3000000 +#define MSM_SDC4_BASE 0xA3100000 + +#define MSM_SHARED_BASE 0x00100000 +#define MSM_CLK_CTL_BASE 0xAB800000 +#define MSM_CLK_CTL_SH2_BASE 0xABA01000 + +#define REG_BASE(off) (MSM_CLK_CTL_BASE + (off)) +#define REG_SH2_BASE(off) (MSM_CLK_CTL_SH2_BASE + (off)) + +#define SCSS_CLK_CTL 0xC0101004 +#define SCSS_CLK_SEL 0xC0101008 + +#define MSM_USB_BASE 0xA3600000 +#define MSM_CRYPTO_BASE 0xA8400000 + +#define SH2_USBH_MD_REG REG_SH2_BASE(0x2BC) +#define SH2_USBH_NS_REG REG_SH2_BASE(0x2C0) + +#define SH2_MDP_NS_REG REG_SH2_BASE(0x14C) +#define SH2_MDP_LCDC_MD_REG REG_SH2_BASE(0x38C) +#define SH2_MDP_LCDC_NS_REG REG_SH2_BASE(0x390) +#define SH2_MDP_VSYNC_REG REG_SH2_BASE(0x460) +#define SH2_PMDH_NS_REG REG_SH2_BASE(0x8C) + +#define SH2_GLBL_CLK_ENA_SC REG_SH2_BASE(0x3BC) +#define SH2_GLBL_CLK_ENA_2_SC REG_SH2_BASE(0x3C0) + +#define SH2_OWN_ROW1_BASE_REG REG_BASE(0x041C) +#define SH2_OWN_ROW2_BASE_REG REG_BASE(0x0424) +#define SH2_OWN_APPS2_BASE_REG REG_BASE(0x0414) + +#define MSM_ADM_BASE 0xAC200000 +#define MSM_ADM_SD_OFFSET 0x00100400 + +#define MSM_SAW_BASE 0xC0102000 + +#define PLL_ENA_REG REG_SH2_BASE(0x0264) +#define PLL2_STATUS_BASE_REG REG_BASE(0x0350) +#define PLL2_L_VAL_ADDR REG_BASE(0x033C) +#endif diff --git a/arch/arm/include/asm/arch-msm7630/proc_comm.h b/arch/arm/include/asm/arch-msm7630/proc_comm.h new file mode 100644 index 0000000..3df08b9 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/proc_comm.h @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __PROC_COMM_H_ +#define __PROC_COMM_H_ + +void usb_clock_init(void); +void lcdc_clock_init(unsigned rate); +void mdp_clock_init(unsigned rate); +void uart3_clock_init(void); +void uart2_clock_init(void); +void uart1_clock_init(void); +void mddi_clock_init(unsigned num, unsigned rate); +void reboot(unsigned reboot_reason); +int mmc_clock_enable_disable(unsigned id, unsigned enable); +int mmc_clock_set_rate(unsigned id, unsigned rate); +int mmc_clock_get_rate(unsigned id); +int gpio_tlmm_config(unsigned config, unsigned disable); +int vreg_set_level(unsigned id, unsigned mv); +int vreg_enable(unsigned id); +int vreg_disable(unsigned id); + +#endif + + diff --git a/arch/arm/include/asm/arch-msm7630/sys_proto.h b/arch/arm/include/asm/arch-msm7630/sys_proto.h new file mode 100644 index 0000000..c679d92 --- /dev/null +++ b/arch/arm/include/asm/arch-msm7630/sys_proto.h @@ -0,0 +1,29 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef _SYS_PROTO_H_ +#define _SYS_PROTO_H_ + +void pll8_enable(void); +void clock_init(void); +void __cpu_early_init(void); + +#endif + -- 1.7.1
The contents of this e-mail and any attachment(s) may contain confidential or privileged information for the intended recipient(s). Unintended recipients are prohibited from taking action on the basis of information in this e-mail and using or disseminating the information, and must notify the sender and delete it from their system. L&T Infotech will not accept responsibility or liability for the accuracy or completeness of, or the presence of any virus or disabling code in this e-mail"
Albert ARIBAUD
Mohamed Haneef
