[U-Boot] [PATCH v2 00/14] sunxi: convert musb to the device model and enable usb_ether
This serie aims at fixing an issue we had to carry out of tree patches for for a few years.
The issue is this: a significant number of Allwinner boards don't have an Ethernet connection, while an Ethernet connection is pretty useful for example during development to do some PXE/NFS boot.
However, we needed to have DM_ETH enabled for the boards that use our Ethernet controller drivers that rely on it. It meant having to use the newly introduced DM_ETH support in the usb_ether gadget, but our musb peripheral wasn't converted to the device model, and therefore not usable with it.
The other alternative was to use the old-style usb_ether driver, which worked fine but were disabling the Ethernet controller driver.
Thus, none were good, upstreamable solution.
Fix this properly by adding support for the musb in peripheral mode in the device model. While we're doing so, I also took the occasion to move a number of configuration options to Kconfig, and rework the dependencies between them to ease the selection of related options while trying to avoid as much as possible the combinations that are not valid.
This was tested on a Sinlinx SinA33 that is wired as a peripheral-only mUSB.
Let me know what you think, Maxime
Changes from v1: - Rebased on v2017.09 - Added some help on a number of options introduced - Added the various tags collected
Maxime Ripard (14): usb: gadget: Move USBNET_DEVADDR option out of g_dnl usb: gadget: Document USBNET_DEVADDR usb: gadget: Move USBNET_HOST_ADDR to Kconfig usb: gadget: Convert USB_ETHER to Kconfig usb: gadget: usb_ether: Move the interfaces to Kconfig usb: gadget: Make g_dnl USB settings common usb: gadget: usb_ether: Move settings to common sunxi: provide default USB gadget setup sunxi: imply USB_GADGET cmd: fastboot: Rework fastboot dependency musb: sunxi: switch to the device model sunxi: Register usb_ether sunxi: Imply USB_ETHER sunxi: sina33: Sync the device tree with the kernel
arch/arm/Kconfig | 4 +- arch/arm/dts/axp223.dtsi | 58 ++- arch/arm/dts/axp22x.dtsi | 10 +- arch/arm/dts/sun8i-a23-a33.dtsi | 446 ++++++--------- arch/arm/dts/sun8i-a33-sinlinx-sina33.dts | 43 +- arch/arm/dts/sun8i-a33.dtsi | 477 +++++++++++++--- arch/arm/include/asm/arch-sunxi/usb_phy.h | 7 +- board/samsung/common/gadget.c | 4 +- board/siemens/common/factoryset.c | 4 +- board/sunxi/board.c | 3 +- cmd/fastboot/Kconfig | 4 +- configs/A13-OLinuXino_defconfig | 5 +- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 5 +- configs/A20-OLinuXino-Lime2_defconfig | 5 +- configs/CHIP_defconfig | 5 +- configs/CHIP_pro_defconfig | 5 +- configs/Cubietruck_defconfig | 5 +- configs/Nintendo_NES_Classic_Edition_defconfig | 5 +- configs/Sinlinx_SinA33_defconfig | 5 +- configs/am335x_baltos_defconfig | 8 +- configs/am335x_boneblack_defconfig | 10 +- configs/am335x_boneblack_vboot_defconfig | 9 +- configs/am335x_evm_defconfig | 9 +- configs/am335x_evm_nor_defconfig | 9 +- configs/am335x_evm_norboot_defconfig | 10 +- configs/am335x_evm_spiboot_defconfig | 9 +- configs/am335x_evm_usbspl_defconfig | 9 +- configs/am335x_hs_evm_defconfig | 7 +- configs/am43xx_evm_defconfig | 6 +- configs/am43xx_evm_ethboot_defconfig | 6 +- configs/am43xx_evm_qspiboot_defconfig | 6 +- configs/am43xx_evm_usbhost_boot_defconfig | 6 +- configs/am43xx_hs_evm_defconfig | 6 +- configs/am57xx_evm_defconfig | 8 +- configs/am57xx_evm_nodt_defconfig | 9 +- configs/am57xx_hs_evm_defconfig | 8 +- configs/apalis-tk1_defconfig | 6 +- configs/apalis_imx6_defconfig | 6 +- configs/apalis_imx6_nospl_com_defconfig | 6 +- configs/apalis_imx6_nospl_it_defconfig | 6 +- configs/apalis_t30_defconfig | 6 +- configs/bcm11130_defconfig | 6 +- configs/bcm11130_nand_defconfig | 6 +- configs/bcm23550_w1d_defconfig | 9 +- configs/bcm28155_ap_defconfig | 9 +- configs/bcm28155_w1d_defconfig | 6 +- configs/beaver_defconfig | 6 +- configs/birdland_bav335a_defconfig | 9 +- configs/birdland_bav335b_defconfig | 9 +- configs/cei-tk1-som_defconfig | 6 +- configs/cgtqmx6eval_defconfig | 9 +- configs/chromebit_mickey_defconfig | 7 +- configs/chromebook_jerry_defconfig | 7 +- configs/chromebook_minnie_defconfig | 7 +- configs/colibri_imx6_defconfig | 6 +- configs/colibri_imx6_nospl_defconfig | 6 +- configs/colibri_imx7_defconfig | 6 +- configs/colibri_t20_defconfig | 6 +- configs/colibri_t30_defconfig | 6 +- configs/colibri_vf_defconfig | 6 +- configs/corvus_defconfig | 6 +- configs/dalmore_defconfig | 6 +- configs/dms-ba16-1g_defconfig | 6 +- configs/dms-ba16_defconfig | 6 +- configs/dra7xx_evm_defconfig | 8 +- configs/dra7xx_hs_evm_defconfig | 8 +- configs/draco_defconfig | 7 +- configs/e2220-1170_defconfig | 6 +- configs/edison_defconfig | 6 +- configs/etamin_defconfig | 7 +- configs/evb-rk3036_defconfig | 7 +- configs/evb-rk3229_defconfig | 7 +- configs/evb-rk3288_defconfig | 7 +- configs/evb-rk3328_defconfig | 6 +- configs/fennec-rk3288_defconfig | 7 +- configs/firefly-rk3288_defconfig | 7 +- configs/gwventana_emmc_defconfig | 8 +- configs/gwventana_gw5904_defconfig | 8 +- configs/gwventana_nand_defconfig | 8 +- configs/jetson-tk1_defconfig | 6 +- configs/kc1_defconfig | 9 +- configs/kylin-rk3036_defconfig | 7 +- configs/ma5d4evk_defconfig | 7 +- configs/miqi-rk3288_defconfig | 7 +- configs/mx6qsabrelite_defconfig | 11 +- configs/mx6sabreauto_defconfig | 6 +- configs/mx6sabresd_defconfig | 6 +- configs/mx7dsabresd_defconfig | 6 +- configs/mx7dsabresd_secure_defconfig | 6 +- configs/nitrogen6dl2g_defconfig | 11 +- configs/nitrogen6dl_defconfig | 11 +- configs/nitrogen6q2g_defconfig | 11 +- configs/nitrogen6q_defconfig | 11 +- configs/nitrogen6s1g_defconfig | 11 +- configs/nitrogen6s_defconfig | 11 +- configs/novena_defconfig | 2 +- configs/nyan-big_defconfig | 6 +- configs/odroid-xu3_defconfig | 6 +- configs/odroid_defconfig | 6 +- configs/omap3_beagle_defconfig | 10 +- configs/omap3_evm_defconfig | 7 +- configs/omap3_logic_defconfig | 9 +- configs/omap5_uevm_defconfig | 6 +- configs/opos6uldev_defconfig | 6 +- configs/origen_defconfig | 6 +- configs/p2371-0000_defconfig | 6 +- configs/p2371-2180_defconfig | 6 +- configs/p2571_defconfig | 6 +- configs/parrot_r16_defconfig | 5 +- configs/pcm051_rev1_defconfig | 1 +- configs/pcm051_rev3_defconfig | 1 +- configs/phycore-rk3288_defconfig | 7 +- configs/pico-imx6ul_defconfig | 6 +- configs/pico-imx7d_defconfig | 6 +- configs/popmetal-rk3288_defconfig | 7 +- configs/pxm2_defconfig | 8 +- configs/rastaban_defconfig | 8 +- configs/rock2_defconfig | 7 +- configs/rut_defconfig | 7 +- configs/s5p_goni_defconfig | 6 +- configs/s5pc210_universal_defconfig | 6 +- configs/sama5d2_ptc_nandflash_defconfig | 2 +- configs/sama5d2_ptc_spiflash_defconfig | 2 +- configs/sansa_fuze_plus_defconfig | 2 +- configs/smartweb_defconfig | 6 +- configs/sniper_defconfig | 9 +- configs/socfpga_arria5_defconfig | 6 +- configs/socfpga_cyclone5_defconfig | 6 +- configs/socfpga_de0_nano_soc_defconfig | 6 +- configs/socfpga_de10_nano_defconfig | 6 +- configs/socfpga_mcvevk_defconfig | 6 +- configs/socfpga_sockit_defconfig | 6 +- configs/socfpga_socrates_defconfig | 6 +- configs/socfpga_vining_fpga_defconfig | 6 +- configs/taurus_defconfig | 6 +- configs/tbs2910_defconfig | 6 +- configs/thuban_defconfig | 7 +- configs/tinker-rk3288_defconfig | 7 +- configs/topic_miami_defconfig | 6 +- configs/topic_miamilite_defconfig | 6 +- configs/topic_miamiplus_defconfig | 6 +- configs/trats2_defconfig | 6 +- configs/trats_defconfig | 6 +- configs/venice2_defconfig | 6 +- configs/vinco_defconfig | 2 +- configs/warp7_defconfig | 9 +- configs/warp7_secure_defconfig | 9 +- configs/warp_defconfig | 6 +- configs/xfi3_defconfig | 2 +- configs/xilinx_zynqmp_ep_defconfig | 6 +- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 6 +- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 6 +- configs/xilinx_zynqmp_zcu102_revA_defconfig | 6 +- configs/xilinx_zynqmp_zcu102_revB_defconfig | 6 +- configs/zynq_microzed_defconfig | 6 +- configs/zynq_picozed_defconfig | 6 +- configs/zynq_z_turn_defconfig | 6 +- configs/zynq_zc702_defconfig | 6 +- configs/zynq_zc706_defconfig | 6 +- configs/zynq_zed_defconfig | 6 +- configs/zynq_zybo_defconfig | 6 +- doc/README.android-fastboot | 8 +- drivers/usb/gadget/Kconfig | 78 ++- drivers/usb/gadget/ether.c | 16 +- drivers/usb/gadget/g_dnl.c | 12 +- drivers/usb/musb-new/sunxi.c | 56 +-- include/configs/am335x_evm.h | 6 +- include/configs/am3517_evm.h | 5 +- include/configs/am43xx_evm.h | 6 +- include/configs/baltos.h | 6 +- include/configs/gw_ventana.h | 2 +- include/configs/h2200.h | 2 +- include/configs/ma5d4evk.h | 3 +- include/configs/nitrogen6x.h | 2 +- include/configs/novena.h | 2 +- include/configs/odroid_xu3.h | 2 +- include/configs/omap3_beagle.h | 1 +- include/configs/omap3_evm.h | 1 +- include/configs/omap3_logic.h | 1 +- include/configs/pcm051.h | 5 +- include/configs/sama5d2_ptc.h | 3 +- include/configs/sansa_fuze_plus.h | 2 +- include/configs/siemens-am33x-common.h | 6 +- include/configs/tao3530.h | 2 +- include/configs/vinco.h | 3 +- include/configs/warp7.h | 4 +- include/configs/xfi3.h | 2 +- include/dt-bindings/clock/sun8i-a23-a33-ccu.h | 127 ++++- include/dt-bindings/reset/sun8i-a23-a33-ccu.h | 87 +++- scripts/config_whitelist.txt | 5 +- 190 files changed, 1509 insertions(+), 999 deletions(-) create mode 100644 arch/arm/dts/axp223.dtsi create mode 100644 include/dt-bindings/clock/sun8i-a23-a33-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-a23-a33-ccu.h
base-commit: c98ac3487e413c71e5d36322ef3324b21c6f60f9
The USBNET_DEVADDR has nothing to do with the USB download gadget, but rather with the USB Ethernet gadget. Move it out of the if statement.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- drivers/usb/gadget/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 225b66bc95ff..d52626908846 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -119,10 +119,10 @@ config G_DNL_VENDOR_NUM config G_DNL_PRODUCT_NUM hex "Product ID of USB device"
+endif # USB_GADGET_DOWNLOAD + config USBNET_DEVADDR string "USB Gadget Ethernet device mac address" default "de:ad:be:ef:00:01"
-endif # USB_GADGET_DOWNLOAD - endif # USB_GADGET
- config USBNET_DEVADDR string "USB Gadget Ethernet device mac address" default "de:ad:be:ef:00:01"
Acked-by: Łukasz Majewski lukma@denx.de
Add an help about the USBNET_DEVADDR Kconfig option to make it clearer what it's about.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- drivers/usb/gadget/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index d52626908846..6dc9d177f5ad 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -124,5 +124,8 @@ endif # USB_GADGET_DOWNLOAD config USBNET_DEVADDR string "USB Gadget Ethernet device mac address" default "de:ad:be:ef:00:01" + help + Ethernet MAC address of the device-side (ie. local board's) MAC + address of the usb_ether interface
endif # USB_GADGET
On 12 September 2017 at 13:01, Maxime Ripard maxime.ripard@free-electrons.com wrote:
help
endif # USB_GADGET
While the USB Ethernet device address is already defined in Kconfig, the host address isn't. Convert it.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/warp7_defconfig | 1 + configs/warp7_secure_defconfig | 1 + drivers/usb/gadget/Kconfig | 7 +++++++ include/configs/am335x_evm.h | 1 - include/configs/baltos.h | 1 - include/configs/h2200.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/warp7.h | 1 - scripts/config_whitelist.txt | 1 - 14 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index eb8338f0f10d..be057acf8634 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -63,5 +63,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index b8526fc15ed3..719d16b145eb 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -42,6 +42,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_LZO=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index c5e7425a7797..c9eab68c8299 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -35,6 +35,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_LZO=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 38370ee8d8f5..b1da71d4c7ed 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -74,6 +74,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_SYS_CONSOLE_BG_COL=0xff CONFIG_SYS_CONSOLE_FG_COL=0x00 diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 5acfe22b0a6d..940c4144d406 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -70,3 +70,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 99fe800317c2..f430f30bbbe5 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -38,4 +38,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OF_LIBFDT=y diff --git a/configs/warp7_secure_defconfig b/configs/warp7_secure_defconfig index 8beda72cd882..96e2c9e5cfde 100644 --- a/configs/warp7_secure_defconfig +++ b/configs/warp7_secure_defconfig @@ -36,4 +36,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OF_LIBFDT=y diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 6dc9d177f5ad..510efd67b9a4 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -128,4 +128,11 @@ config USBNET_DEVADDR Ethernet MAC address of the device-side (ie. local board's) MAC address of the usb_ether interface
+config USBNET_HOST_ADDR + string "USB Gadget Ethernet host mac address" + default "de:ad:be:ef:00:00" + help + Ethernet MAC address of the host-side (ie. remote device's) MAC + address of the usb_ether interface + endif # USB_GADGET diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 415ce46e0d8d..7c025c7e46c8 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -266,7 +266,6 @@ #ifdef CONFIG_USB_MUSB_GADGET #define CONFIG_USB_ETHER #define CONFIG_USB_ETH_RNDIS -#define CONFIG_USBNET_HOST_ADDR "de:ad:be:af:00:00" #endif /* CONFIG_USB_MUSB_GADGET */
/* diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 185c749d7868..535fdd4373b0 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -286,7 +286,6 @@ #ifdef CONFIG_USB_MUSB_GADGET #define CONFIG_USB_ETHER #define CONFIG_USB_ETH_RNDIS -#define CONFIG_USBNET_HOST_ADDR "de:ad:be:af:00:00" #endif /* CONFIG_USB_MUSB_GADGET */
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 870014ddf475..e956e89a89d5 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -127,7 +127,6 @@ #define CONFIG_USB_ETH_SUBSET
#define CONFIG_USBNET_DEV_ADDR "de:ad:be:ef:00:01" -#define CONFIG_USBNET_HOST_ADDR "de:ad:be:ef:00:02" #define CONFIG_EXTRA_ENV_SETTINGS \ "stdin=serial\0" \ "stdout=serial\0" \ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 2314a2d2ef35..2bcd77e9efc8 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -181,7 +181,6 @@ #ifdef CONFIG_USB_MUSB_GADGET #define CONFIG_USB_ETHER #define CONFIG_USB_ETH_RNDIS -#define CONFIG_USBNET_HOST_ADDR "de:ad:be:af:00:00" #endif /* CONFIG_USB_MUSB_GADGET */
/* USB DRACO ID as default */ diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 75ae8a3e3338..9ce425156677 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -139,7 +139,6 @@ #define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC #define CONFIG_USB_ETH_RNDIS -#define CONFIG_USBNET_HOST_ADDR "de:ad:be:af:00:00" #define CONFIG_USBNET_DEV_ADDR "de:ad:be:af:00:01"
#endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 9ce0c3f039ff..784e83c7c8a1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4983,7 +4983,6 @@ CONFIG_USBD_SERIAL_OUT_PKTSIZE CONFIG_USBD_VENDORID CONFIG_USBID_ADDR CONFIG_USBNET_DEV_ADDR -CONFIG_USBNET_HOST_ADDR CONFIG_USBNET_MANUFACTURER CONFIG_USBTTY CONFIG_USB_AM35X
- string "USB Gadget Ethernet host mac address"
- default "de:ad:be:ef:00:00"
- help
Reviewed-by: Łukasz Majewski lukma@denx.de
The USB Ethernet gadget option has not yet been moved to Kconfig, let's deal with that.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 1 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/draco_defconfig | 1 + configs/etamin_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/ma5d4evk_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/sama5d2_ptc_nandflash_defconfig | 1 + configs/sama5d2_ptc_spiflash_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/thuban_defconfig | 1 + configs/vinco_defconfig | 1 + configs/warp7_defconfig | 1 + configs/warp7_secure_defconfig | 1 + configs/xfi3_defconfig | 1 + drivers/usb/gadget/Kconfig | 14 ++++++++++++++ include/configs/am335x_evm.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/baltos.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/h2200.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/pcm051.h | 1 - include/configs/sama5d2_ptc.h | 1 - include/configs/sansa_fuze_plus.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/tao3530.h | 2 -- include/configs/vinco.h | 1 - include/configs/warp7.h | 1 - include/configs/xfi3.h | 1 - scripts/config_whitelist.txt | 1 - 60 files changed, 53 insertions(+), 21 deletions(-)
diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index be057acf8634..2f075091b27a 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -63,6 +63,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 719d16b145eb..a3dd9b03b538 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -42,6 +42,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 0a239bb73399..7d52382c24dc 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -52,4 +52,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_LZO=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 00c1af43449d..69b2cf3e1f61 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -54,6 +54,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_RSA=y CONFIG_LZO=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 9f08edff4ca5..708df4284093 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -41,6 +41,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index c9eab68c8299..3f6f2798adce 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -35,6 +35,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 501fb2b90f4d..427ca371815c 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -39,6 +39,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index 7c351382d96c..a4e9e8f1b27b 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -45,6 +45,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index acdd56b43558..552150732398 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -58,5 +58,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_RSA=y CONFIG_LZO=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index f5a2c1b52621..e38030bf5913 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -70,3 +70,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_USB_ETHER=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 148d4218c090..33ca6858abfd 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -70,3 +70,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_USB_ETHER=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 74aa2ef56621..35d9e1ac27dc 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -68,6 +68,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Gateworks" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 7bbdd500a78c..ca7eb5ac573e 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -72,6 +72,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Gateworks" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index aaedf93eeac9..cb9655574888 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -71,6 +71,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Gateworks" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index 0d8c109fbcf1..0655505a1321 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -52,6 +52,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="AriesEmbedded" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 57aba7e6d09a..bab0d0c79f0d 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -54,5 +54,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 50e6b70bc9a0..0d19b85a30f3 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -51,5 +51,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 61e5ea4e21ef..a20580eb77bb 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -51,5 +51,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 9dbb7181ee23..940c74a5ece2 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -52,5 +52,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 5478390fd8c3..83772cb2efcf 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -52,5 +52,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 01881686429b..862b41a3f8c9 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -51,5 +51,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 51f1f91be854..e5376313b9bd 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -51,5 +51,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 2921525f9fb0..786ab2854f70 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -48,6 +48,7 @@ CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y +CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index cf888f3491aa..8896b84ebc9a 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -52,6 +52,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="TI" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_MCS7830=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 962ffa072996..8db95f167a1a 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -56,6 +56,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0x5678 +CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_BCH=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 8d0a4d48e415..3bf115e6f8c8 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -49,4 +49,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="TI" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 +CONFIG_USB_ETHER=y CONFIG_BCH=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 1683f88b690b..9b325d43ba79 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -60,5 +60,6 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index d082bb4af204..14211ec6835e 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -60,5 +60,6 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index b1da71d4c7ed..b6624f0be16c 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -74,6 +74,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_SYS_CONSOLE_BG_COL=0xff diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 940c4144d406..ed5f2f841b2a 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -70,4 +70,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 6ec8ff35710e..1b787906baf9 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -75,6 +75,7 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_SYS_CONSOLE_BG_COL=0xff CONFIG_SYS_CONSOLE_FG_COL=0x00 diff --git a/configs/sama5d2_ptc_nandflash_defconfig b/configs/sama5d2_ptc_nandflash_defconfig index bca3ac2fcbfc..6672a5ce11f7 100644 --- a/configs/sama5d2_ptc_nandflash_defconfig +++ b/configs/sama5d2_ptc_nandflash_defconfig @@ -30,3 +30,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_USB_ETHER=y diff --git a/configs/sama5d2_ptc_spiflash_defconfig b/configs/sama5d2_ptc_spiflash_defconfig index e4fb49f6627d..9a23a808f1b3 100644 --- a/configs/sama5d2_ptc_spiflash_defconfig +++ b/configs/sama5d2_ptc_spiflash_defconfig @@ -31,3 +31,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_USB_ETHER=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index f6ce09c366b4..c6d50ccb8e15 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -32,4 +32,5 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y +CONFIG_USB_ETHER=y CONFIG_OF_LIBFDT=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index c30e924fb56f..eb9124ce23ec 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -70,3 +70,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_USB_ETHER=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 2cd4466a08e5..08aa8c52a254 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -32,5 +32,6 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index f430f30bbbe5..8a3717facdbd 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -38,5 +38,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OF_LIBFDT=y diff --git a/configs/warp7_secure_defconfig b/configs/warp7_secure_defconfig index 96e2c9e5cfde..83a06079fdc5 100644 --- a/configs/warp7_secure_defconfig +++ b/configs/warp7_secure_defconfig @@ -36,5 +36,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OF_LIBFDT=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index de80da69c68b..6cc78452829c 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -31,4 +31,5 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y +CONFIG_USB_ETHER=y CONFIG_OF_LIBFDT=y diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 510efd67b9a4..ae3a37b3a935 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -121,6 +121,18 @@ config G_DNL_PRODUCT_NUM
+config USB_ETHER + bool "USB Ethernet Gadget" + help + Creates an Ethernet network device through a USB peripheral + controller. This will create a network interface on both the device + (U-Boot) and the host (remote device) that can be used just like any + other nework interface. + It will bind on the peripheral USB controller, ignoring the USB hosts + controllers in the system. + +if USB_ETHER + config USBNET_DEVADDR string "USB Gadget Ethernet device mac address" default "de:ad:be:ef:00:01" @@ -135,4 +147,6 @@ config USBNET_HOST_ADDR Ethernet MAC address of the host-side (ie. remote device's) MAC address of the usb_ether interface
+endif # USB_ETHER + endif # USB_GADGET diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 7c025c7e46c8..9238c4bb769c 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -264,7 +264,6 @@ #define CONFIG_AM335X_USB1_MODE MUSB_HOST
#ifdef CONFIG_USB_MUSB_GADGET -#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_RNDIS #endif /* CONFIG_USB_MUSB_GADGET */
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 5435ca8f4ea4..d09672770134 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -80,7 +80,6 @@ #endif /* CONFIG_USB_MUSB_HOST */
diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 535fdd4373b0..380a78918f29 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -284,7 +284,6 @@ #define CONFIG_AM335X_USB1_MODE MUSB_OTG
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 9c26059a068e..f4b7a061ba12 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -146,7 +146,6 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USBD_HS -#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC #define CONFIG_NETCONSOLE
diff --git a/include/configs/h2200.h b/include/configs/h2200.h index e956e89a89d5..24ff53f6f1e9 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -123,7 +123,6 @@ "bootm ; "
#define CONFIG_USB_GADGET_PXA2XX -#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_SUBSET
#define CONFIG_USBNET_DEV_ADDR "de:ad:be:ef:00:01" diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 50b21c9d97a0..2ad4952f5eeb 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -97,7 +97,6 @@ #ifdef CONFIG_CMD_USB
/* USB device */ -#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "AriesEmbedded" #define CONFIG_USB_FUNCTION_MASS_STORAGE diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index d32d8f871a99..ca37f584f042 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -19,7 +19,6 @@
#define CONFIG_MISC_INIT_R #define CONFIG_USBD_HS -#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC #define CONFIG_NETCONSOLE
diff --git a/include/configs/novena.h b/include/configs/novena.h index be8c6911e63a..9068ee2182e3 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -129,7 +129,6 @@ #define CONFIG_MXC_USB_FLAGS 0 /* Gadget part */ #define CONFIG_USBD_HS -#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC #define CONFIG_NETCONSOLE #endif diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index ee22f4fc1bb5..ff6e86e80e9e 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -46,7 +46,6 @@ #define CONFIG_USB_MUSB_OMAP2PLUS #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_TWL4030_USB 1 -#define CONFIG_USB_ETHER
/* USB EHCI */
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index af99e8b5cb48..178e61e1b6f7 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -82,7 +82,6 @@ #define CONFIG_USB_OMAP3 #define CONFIG_USB_MUSB_OMAP2PLUS #define CONFIG_USB_MUSB_PIO_ONLY -#define CONFIG_USB_ETHER
/* USB EHCI */ #define CONFIG_SYS_USB_FAT_BOOT_PARTITION 1 diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 5fba35668b2d..092bb73a8464 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -57,7 +57,6 @@ /* USB */ #define CONFIG_USB_MUSB_OMAP2PLUS #define CONFIG_USB_MUSB_PIO_ONLY -#define CONFIG_USB_ETHER
/* TWL4030 */ #define CONFIG_TWL4030_USB diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index f678b2944dd0..309bbd6bd36f 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -134,7 +134,6 @@ #define CONFIG_AM335X_USB1_MODE MUSB_HOST
diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index b04781893d48..a1a0602cdd0c 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -60,7 +60,6 @@ #endif
/* USB device */ -#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D2_PTC"
diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index 250917b1dc05..9e33ca42270c 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -39,7 +39,6 @@ #define CONFIG_EHCI_MXS_PORT0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
-#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC #define CONFIG_NETCONSOLE #endif diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 2bcd77e9efc8..0600984f95aa 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -179,7 +179,6 @@ #define CONFIG_AM335X_USB1_MODE MUSB_HOST
diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 11b909b7dd88..1a4b78674f01 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -215,8 +215,6 @@ /* USB EHCI */ #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 162
-#define CONFIG_USB_ETHER - /* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_NAND_SIMPLE diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 490dc446d6d2..3b3ec6c8f2ad 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -64,7 +64,6 @@ #endif
/* USB device */ -#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "L+G VInCo"
diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 9ce425156677..05ae3542a9ad 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -136,7 +136,6 @@ #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M #define DFU_DEFAULT_POLL_TIMEOUT 300
-#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_DEV_ADDR "de:ad:be:af:00:01" diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index 73f431681db3..7bbfd75c0cb8 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -39,7 +39,6 @@ #define CONFIG_EHCI_MXS_PORT0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
-#define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC #define CONFIG_NETCONSOLE #endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 784e83c7c8a1..e9e716e7c80e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -5013,7 +5013,6 @@ CONFIG_USB_EHCI_TEGRA CONFIG_USB_EHCI_TXFIFO_THRESH CONFIG_USB_EHCI_VCT CONFIG_USB_EHCI_VF -CONFIG_USB_ETHER CONFIG_USB_ETH_CDC CONFIG_USB_ETH_QMULT CONFIG_USB_ETH_RNDIS
+config USB_ETHER
help
+if USB_ETHER
+endif # USB_ETHER
/* USB EHCI */
We need to select an interface for the usb_ether gadget, and they haven't been converted to Kconfig yet. Add a choice to make sure we have an option selected, and convert all the users.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/gwventana_emmc_defconfig | 1 +- configs/gwventana_gw5904_defconfig | 1 +- configs/gwventana_nand_defconfig | 1 +- configs/mx6qsabrelite_defconfig | 1 +- configs/nitrogen6dl2g_defconfig | 1 +- configs/nitrogen6dl_defconfig | 1 +- configs/nitrogen6q2g_defconfig | 1 +- configs/nitrogen6q_defconfig | 1 +- configs/nitrogen6s1g_defconfig | 1 +- configs/nitrogen6s_defconfig | 1 +- configs/novena_defconfig | 1 +- configs/sansa_fuze_plus_defconfig | 1 +- configs/warp7_defconfig | 1 +- configs/warp7_secure_defconfig | 1 +- configs/xfi3_defconfig | 1 +- drivers/usb/gadget/Kconfig | 28 +++++++++++++++++++++++++++- include/configs/am335x_evm.h | 4 +---- include/configs/am3517_evm.h | 4 +---- include/configs/baltos.h | 4 +---- include/configs/gw_ventana.h | 1 +- include/configs/ma5d4evk.h | 1 +- include/configs/nitrogen6x.h | 1 +- include/configs/novena.h | 1 +- include/configs/pcm051.h | 4 +---- include/configs/sama5d2_ptc.h | 1 +- include/configs/sansa_fuze_plus.h | 1 +- include/configs/siemens-am33x-common.h | 4 +---- include/configs/vinco.h | 1 +- include/configs/warp7.h | 2 +-- include/configs/xfi3.h | 1 +- scripts/config_whitelist.txt | 2 +-- 31 files changed, 43 insertions(+), 32 deletions(-)
diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 35d9e1ac27dc..03d732d8f11e 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -69,6 +69,7 @@ CONFIG_G_DNL_MANUFACTURER="Gateworks" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index ca7eb5ac573e..51aa13dbaca3 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -73,6 +73,7 @@ CONFIG_G_DNL_MANUFACTURER="Gateworks" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index cb9655574888..4b2e1a752935 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -72,6 +72,7 @@ CONFIG_G_DNL_MANUFACTURER="Gateworks" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index bab0d0c79f0d..f716c8fd7f77 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -55,5 +55,6 @@ CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 0d19b85a30f3..fd4a46558129 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -52,5 +52,6 @@ CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index a20580eb77bb..30046e3f3a07 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -52,5 +52,6 @@ CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 940c74a5ece2..f9160c208fe7 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -53,5 +53,6 @@ CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 83772cb2efcf..8bca0e04439e 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -53,5 +53,6 @@ CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 862b41a3f8c9..668fbaa37010 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -52,5 +52,6 @@ CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index e5376313b9bd..99106c9a1f5a 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -52,5 +52,6 @@ CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 786ab2854f70..a7056ff13771 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -49,6 +49,7 @@ CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index c6d50ccb8e15..b5443dda98a9 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -33,4 +33,5 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_OF_LIBFDT=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 8a3717facdbd..32cf7a4da4b4 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -39,5 +39,6 @@ CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OF_LIBFDT=y diff --git a/configs/warp7_secure_defconfig b/configs/warp7_secure_defconfig index 83a06079fdc5..99764dbd0bb1 100644 --- a/configs/warp7_secure_defconfig +++ b/configs/warp7_secure_defconfig @@ -37,5 +37,6 @@ CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OF_LIBFDT=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 6cc78452829c..91768a4a7106 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -32,4 +32,5 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_OF_LIBFDT=y diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index ae3a37b3a935..1201276be837 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -133,6 +133,34 @@ config USB_ETHER
if USB_ETHER
+choice + prompt "USB Ethernet Gadget Model" + default USB_ETH_RNDIS + help + There is several models (protocols) to implement Ethernet over USB + devices. The main ones are Microsoft's RNDIS and USB's CDC-Ethernet + (also called CDC-ECM). RNDIS is obviously compatible with Windows, + while CDC-ECM is not. Most other operating systems support both, so + if inter-operability is a concern, RNDIS is to be preferred. + +config USB_ETH_CDC + bool "CDC-ECM Protocol" + help + CDC (Communications Device Class) is the standard for Ethernet over + USB devices. While there's several alternatives, the most widely used + protocol is ECM (Ethernet Control Model). However, compatibility with + Windows is not that great. + +config USB_ETH_RNDIS + bool "RNDIS Protocol" + help + The RNDIS (Remote Network Driver Interface Specification) is a + Microsoft proprietary protocol to create an Ethernet device over USB. + Windows obviously supports it, as well as all the major operating + systems, so it's the best option for compatibility. + +endchoice + config USBNET_DEVADDR string "USB Gadget Ethernet device mac address" default "de:ad:be:ef:00:01" diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 9238c4bb769c..96294679bf9b 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -263,10 +263,6 @@ #define CONFIG_AM335X_USB1 #define CONFIG_AM335X_USB1_MODE MUSB_HOST
-#ifdef CONFIG_USB_MUSB_GADGET -#define CONFIG_USB_ETH_RNDIS -#endif /* CONFIG_USB_MUSB_GADGET */ - /* * Disable MMC DM for SPL build and can be re-enabled after adding * DM support in SPL diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index d09672770134..38bd6e35e8cd 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -79,10 +79,6 @@
-#ifdef CONFIG_USB_MUSB_GADGET -#define CONFIG_USB_ETH_RNDIS -#endif /* CONFIG_USB_MUSB_GADGET */ - #endif /* CONFIG_USB_MUSB_AM35X */
/* I2C */ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 380a78918f29..44af4d3deec8 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -283,10 +283,6 @@ #define CONFIG_AM335X_USB1 #define CONFIG_AM335X_USB1_MODE MUSB_OTG
-#ifdef CONFIG_USB_MUSB_GADGET -#define CONFIG_USB_ETH_RNDIS -#endif /* CONFIG_USB_MUSB_GADGET */ - #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* disable host part of MUSB in SPL */ /* disable EFI partitions and partition UUID support */ diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index f4b7a061ba12..2795568e8c89 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -146,7 +146,6 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USBD_HS -#define CONFIG_USB_ETH_CDC #define CONFIG_NETCONSOLE
/* USB Mass Storage Gadget */ diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 2ad4952f5eeb..6d25d84c6eb6 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -97,7 +97,6 @@ #ifdef CONFIG_CMD_USB
/* USB device */ -#define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "AriesEmbedded" #define CONFIG_USB_FUNCTION_MASS_STORAGE #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1 * 1024 * 1024) diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index ca37f584f042..6068b70d2d69 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -19,7 +19,6 @@
#define CONFIG_MISC_INIT_R #define CONFIG_USBD_HS -#define CONFIG_USB_ETH_CDC #define CONFIG_NETCONSOLE
#define CONFIG_MXC_UART diff --git a/include/configs/novena.h b/include/configs/novena.h index 9068ee2182e3..4825d5bac19a 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -129,7 +129,6 @@ #define CONFIG_MXC_USB_FLAGS 0 /* Gadget part */ #define CONFIG_USBD_HS -#define CONFIG_USB_ETH_CDC #define CONFIG_NETCONSOLE #endif
diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 309bbd6bd36f..79f3f48df87e 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -133,10 +133,6 @@ #define CONFIG_AM335X_USB1 #define CONFIG_AM335X_USB1_MODE MUSB_HOST
-#ifdef CONFIG_USB_MUSB_GADGET -#define CONFIG_USB_ETH_RNDIS -#endif /* CONFIG_USB_MUSB_GADGET */ - #define CONFIG_PHY_SMSC
#endif /* ! __CONFIG_PCM051_H */ diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index a1a0602cdd0c..543592e3a574 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -60,7 +60,6 @@ #endif
/* USB device */ -#define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D2_PTC"
/* Ethernet Hardware */ diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index 9e33ca42270c..99200140fe5e 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -39,7 +39,6 @@ #define CONFIG_EHCI_MXS_PORT0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 0600984f95aa..1997c2dd5ae4 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -178,10 +178,6 @@ #define CONFIG_AM335X_USB1 #define CONFIG_AM335X_USB1_MODE MUSB_HOST
-#ifdef CONFIG_USB_MUSB_GADGET -#define CONFIG_USB_ETH_RNDIS -#endif /* CONFIG_USB_MUSB_GADGET */ - /* USB DRACO ID as default */ #define CONFIG_USBD_HS
diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 3b3ec6c8f2ad..f5aaaa2ffe91 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -64,7 +64,6 @@ #endif
/* USB device */ -#define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "L+G VInCo"
/* Ethernet Hardware */ diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 05ae3542a9ad..11f1bc3eab75 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -136,8 +136,6 @@ #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M #define DFU_DEFAULT_POLL_TIMEOUT 300
-#define CONFIG_USB_ETH_CDC -#define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_DEV_ADDR "de:ad:be:af:00:01"
#endif diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index 7bbfd75c0cb8..1e70a762e0d9 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -39,7 +39,6 @@ #define CONFIG_EHCI_MXS_PORT0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e9e716e7c80e..bbc3d4351bbd 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -5013,9 +5013,7 @@ CONFIG_USB_EHCI_TEGRA CONFIG_USB_EHCI_TXFIFO_THRESH CONFIG_USB_EHCI_VCT CONFIG_USB_EHCI_VF -CONFIG_USB_ETH_CDC CONFIG_USB_ETH_QMULT -CONFIG_USB_ETH_RNDIS CONFIG_USB_ETH_SUBSET CONFIG_USB_EXT2_BOOT CONFIG_USB_FAT_BOOT
if USB_ETHER
+choice
- prompt "USB Ethernet Gadget Model"
- default USB_ETH_RNDIS
- help
+config USB_ETH_CDC
- bool "CDC-ECM Protocol"
- help
- bool "RNDIS Protocol"
- help
+endchoice
- Disable MMC DM for SPL build and can be re-enabled after adding
- DM support in SPL
/* I2C */
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Lukasz Majewski lukma@denx.de Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/samsung/common/gadget.c | 4 +-- board/siemens/common/factoryset.c | 4 +-- configs/A13-OLinuXino_defconfig | 6 ++-- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 6 ++-- configs/A20-OLinuXino-Lime2_defconfig | 6 ++-- configs/CHIP_defconfig | 6 ++-- configs/CHIP_pro_defconfig | 6 ++-- configs/Cubietruck_defconfig | 6 ++-- configs/Nintendo_NES_Classic_Edition_defconfig | 6 ++-- configs/Sinlinx_SinA33_defconfig | 6 ++-- configs/am335x_baltos_defconfig | 6 ++-- configs/am335x_boneblack_defconfig | 6 ++-- configs/am335x_boneblack_vboot_defconfig | 6 ++-- configs/am335x_evm_defconfig | 6 ++-- configs/am335x_evm_nor_defconfig | 6 ++-- configs/am335x_evm_norboot_defconfig | 6 ++-- configs/am335x_evm_spiboot_defconfig | 6 ++-- configs/am335x_evm_usbspl_defconfig | 6 ++-- configs/am335x_hs_evm_defconfig | 6 ++-- configs/am43xx_evm_defconfig | 6 ++-- configs/am43xx_evm_ethboot_defconfig | 6 ++-- configs/am43xx_evm_qspiboot_defconfig | 6 ++-- configs/am43xx_evm_usbhost_boot_defconfig | 6 ++-- configs/am43xx_hs_evm_defconfig | 6 ++-- configs/am57xx_evm_defconfig | 6 ++-- configs/am57xx_evm_nodt_defconfig | 6 ++-- configs/am57xx_hs_evm_defconfig | 6 ++-- configs/apalis-tk1_defconfig | 6 ++-- configs/apalis_imx6_defconfig | 6 ++-- configs/apalis_imx6_nospl_com_defconfig | 6 ++-- configs/apalis_imx6_nospl_it_defconfig | 6 ++-- configs/apalis_t30_defconfig | 6 ++-- configs/bcm11130_defconfig | 6 ++-- configs/bcm11130_nand_defconfig | 6 ++-- configs/bcm23550_w1d_defconfig | 6 ++-- configs/bcm28155_ap_defconfig | 6 ++-- configs/bcm28155_w1d_defconfig | 6 ++-- configs/beaver_defconfig | 6 ++-- configs/birdland_bav335a_defconfig | 6 ++-- configs/birdland_bav335b_defconfig | 6 ++-- configs/cei-tk1-som_defconfig | 6 ++-- configs/cgtqmx6eval_defconfig | 6 ++-- configs/chromebit_mickey_defconfig | 6 ++-- configs/chromebook_jerry_defconfig | 6 ++-- configs/chromebook_minnie_defconfig | 6 ++-- configs/colibri_imx6_defconfig | 6 ++-- configs/colibri_imx6_nospl_defconfig | 6 ++-- configs/colibri_imx7_defconfig | 6 ++-- configs/colibri_t20_defconfig | 6 ++-- configs/colibri_t30_defconfig | 6 ++-- configs/colibri_vf_defconfig | 6 ++-- configs/corvus_defconfig | 6 ++-- configs/dalmore_defconfig | 6 ++-- configs/dms-ba16-1g_defconfig | 6 ++-- configs/dms-ba16_defconfig | 6 ++-- configs/dra7xx_evm_defconfig | 6 ++-- configs/dra7xx_hs_evm_defconfig | 6 ++-- configs/draco_defconfig | 6 ++-- configs/e2220-1170_defconfig | 6 ++-- configs/edison_defconfig | 6 ++-- configs/etamin_defconfig | 6 ++-- configs/evb-rk3036_defconfig | 6 ++-- configs/evb-rk3229_defconfig | 6 ++-- configs/evb-rk3288_defconfig | 6 ++-- configs/evb-rk3328_defconfig | 6 ++-- configs/fennec-rk3288_defconfig | 6 ++-- configs/firefly-rk3288_defconfig | 6 ++-- configs/gwventana_emmc_defconfig | 6 ++-- configs/gwventana_gw5904_defconfig | 6 ++-- configs/gwventana_nand_defconfig | 6 ++-- configs/jetson-tk1_defconfig | 6 ++-- configs/kc1_defconfig | 6 ++-- configs/kylin-rk3036_defconfig | 6 ++-- configs/ma5d4evk_defconfig | 6 ++-- configs/miqi-rk3288_defconfig | 6 ++-- configs/mx6qsabrelite_defconfig | 6 ++-- configs/mx6sabreauto_defconfig | 6 ++-- configs/mx6sabresd_defconfig | 6 ++-- configs/mx7dsabresd_defconfig | 6 ++-- configs/mx7dsabresd_secure_defconfig | 6 ++-- configs/nitrogen6dl2g_defconfig | 6 ++-- configs/nitrogen6dl_defconfig | 6 ++-- configs/nitrogen6q2g_defconfig | 6 ++-- configs/nitrogen6q_defconfig | 6 ++-- configs/nitrogen6s1g_defconfig | 6 ++-- configs/nitrogen6s_defconfig | 6 ++-- configs/nyan-big_defconfig | 6 ++-- configs/odroid-xu3_defconfig | 6 ++-- configs/odroid_defconfig | 6 ++-- configs/omap3_beagle_defconfig | 6 ++-- configs/omap3_evm_defconfig | 6 ++-- configs/omap3_logic_defconfig | 6 ++-- configs/omap5_uevm_defconfig | 6 ++-- configs/opos6uldev_defconfig | 6 ++-- configs/origen_defconfig | 6 ++-- configs/p2371-0000_defconfig | 6 ++-- configs/p2371-2180_defconfig | 6 ++-- configs/p2571_defconfig | 6 ++-- configs/parrot_r16_defconfig | 6 ++-- configs/phycore-rk3288_defconfig | 6 ++-- configs/pico-imx6ul_defconfig | 6 ++-- configs/pico-imx7d_defconfig | 6 ++-- configs/popmetal-rk3288_defconfig | 6 ++-- configs/pxm2_defconfig | 6 ++-- configs/rastaban_defconfig | 6 ++-- configs/rock2_defconfig | 6 ++-- configs/rut_defconfig | 6 ++-- configs/s5p_goni_defconfig | 6 ++-- configs/s5pc210_universal_defconfig | 6 ++-- configs/smartweb_defconfig | 6 ++-- configs/sniper_defconfig | 6 ++-- configs/socfpga_arria5_defconfig | 6 ++-- configs/socfpga_cyclone5_defconfig | 6 ++-- configs/socfpga_de0_nano_soc_defconfig | 6 ++-- configs/socfpga_de10_nano_defconfig | 6 ++-- configs/socfpga_mcvevk_defconfig | 6 ++-- configs/socfpga_sockit_defconfig | 6 ++-- configs/socfpga_socrates_defconfig | 6 ++-- configs/socfpga_vining_fpga_defconfig | 6 ++-- configs/taurus_defconfig | 6 ++-- configs/tbs2910_defconfig | 6 ++-- configs/thuban_defconfig | 6 ++-- configs/tinker-rk3288_defconfig | 6 ++-- configs/topic_miami_defconfig | 6 ++-- configs/topic_miamilite_defconfig | 6 ++-- configs/topic_miamiplus_defconfig | 6 ++-- configs/trats2_defconfig | 6 ++-- configs/trats_defconfig | 6 ++-- configs/venice2_defconfig | 6 ++-- configs/warp7_defconfig | 6 ++-- configs/warp7_secure_defconfig | 6 ++-- configs/warp_defconfig | 6 ++-- configs/xilinx_zynqmp_ep_defconfig | 6 ++-- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 6 ++-- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 6 ++-- configs/xilinx_zynqmp_zcu102_revA_defconfig | 6 ++-- configs/xilinx_zynqmp_zcu102_revB_defconfig | 6 ++-- configs/zynq_microzed_defconfig | 6 ++-- configs/zynq_picozed_defconfig | 6 ++-- configs/zynq_z_turn_defconfig | 6 ++-- configs/zynq_zc702_defconfig | 6 ++-- configs/zynq_zc706_defconfig | 6 ++-- configs/zynq_zed_defconfig | 6 ++-- configs/zynq_zybo_defconfig | 6 ++-- doc/README.android-fastboot | 8 ++--- drivers/usb/gadget/Kconfig | 25 ++++++++++------- drivers/usb/gadget/g_dnl.c | 12 ++++---- include/configs/am43xx_evm.h | 6 ++-- include/configs/odroid_xu3.h | 2 +- 149 files changed, 460 insertions(+), 453 deletions(-)
diff --git a/board/samsung/common/gadget.c b/board/samsung/common/gadget.c index 6a1e57f1645c..ef732befc44e 100644 --- a/board/samsung/common/gadget.c +++ b/board/samsung/common/gadget.c @@ -17,8 +17,8 @@ int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) put_unaligned(CONFIG_G_DNL_UMS_VENDOR_NUM, &dev->idVendor); put_unaligned(CONFIG_G_DNL_UMS_PRODUCT_NUM, &dev->idProduct); } else { - put_unaligned(CONFIG_G_DNL_VENDOR_NUM, &dev->idVendor); - put_unaligned(CONFIG_G_DNL_PRODUCT_NUM, &dev->idProduct); + put_unaligned(CONFIG_USB_GADGET_VENDOR_NUM, &dev->idVendor); + put_unaligned(CONFIG_USB_GADGET_PRODUCT_NUM, &dev->idProduct); } return 0; } diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index b4f027af2862..81bbb5758d0b 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -145,8 +145,8 @@ int factoryset_read_eeprom(int i2c_addr) unsigned char *cp, *cp1;
#if defined(CONFIG_USB_FUNCTION_DFU) - factory_dat.usb_vendor_id = CONFIG_G_DNL_VENDOR_NUM; - factory_dat.usb_product_id = CONFIG_G_DNL_PRODUCT_NUM; + factory_dat.usb_vendor_id = CONFIG_USB_GADGET_VENDOR_NUM; + factory_dat.usb_product_id = CONFIG_USB_GADGET_PRODUCT_NUM; #endif if (i2c_probe(i2c_addr)) goto err; diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index fbacce07cf0c..2574018d8213 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -32,7 +32,7 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 58aa988b2363..5663a824e71b 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -34,7 +34,7 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 6d7c58861373..63d013293690 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -33,7 +33,7 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 83228bd10f05..278039c05573 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -23,8 +23,8 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 3a748fc27e07..edbdefc69ddf 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -28,8 +28,8 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index f93ff0d6c463..2d1753645b0f 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -33,7 +33,7 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index d05375d0dbd5..99f7d30f150d 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -23,7 +23,7 @@ CONFIG_AXP_ELDO2_VOLT=1800 CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index af00e5434763..8c5fc7587909 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -28,7 +28,7 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 2f075091b27a..efcbc523749c 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -59,10 +59,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0403 -CONFIG_G_DNL_PRODUCT_NUM=0xbd00 CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_FAT_WRITE=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index a3dd9b03b538..85f220329e4e 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -38,10 +38,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_LZO=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 7d52382c24dc..9ba3f7c04d73 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -48,9 +48,9 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_LZO=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 69b2cf3e1f61..8aa3c0de8824 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -50,10 +50,10 @@ CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_RSA=y CONFIG_LZO=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 708df4284093..b745f2997334 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -37,10 +37,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 3f6f2798adce..9662b6684c1f 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -31,10 +31,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_LZO=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 427ca371815c..5e2c19066daa 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -35,10 +35,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index a4e9e8f1b27b..d6c21b8e85ee 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -41,10 +41,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 552150732398..683c102d0f1f 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -54,10 +54,10 @@ CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_RSA=y CONFIG_LZO=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 15c25d39f1ae..ce5d0eb29142 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -52,7 +52,7 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0403 -CONFIG_G_DNL_PRODUCT_NUM=0xbd00 diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 6c170888680c..7bcec25af36f 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -61,8 +61,8 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0403 -CONFIG_G_DNL_PRODUCT_NUM=0xbd00 CONFIG_OF_LIBFDT=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index fde41c5c7e1c..e72d435cfe06 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -52,9 +52,9 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0403 -CONFIG_G_DNL_PRODUCT_NUM=0xbd00 CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 0bed33572297..8109f98b4b7c 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -75,7 +75,7 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0403 -CONFIG_G_DNL_PRODUCT_NUM=0xbd00 diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index a4d23e10b60e..da7dbfb02b9e 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -63,7 +63,7 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0403 -CONFIG_G_DNL_PRODUCT_NUM=0xbd00 diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 3d455eb7d4e1..a9ee2e448f3c 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -72,7 +72,7 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index f96348699bad..ae7c3464e0cb 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -62,9 +62,9 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 01d77cbbd09e..1047f33237ef 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -75,7 +75,7 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index e6e3a9bfe932..84e010649115 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -47,9 +47,9 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0xffff CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0xffff CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index b2284acc34a3..1ab836389d6e 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -56,11 +56,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4000 CONFIG_USB_HOST_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/apalis_imx6_nospl_com_defconfig b/configs/apalis_imx6_nospl_com_defconfig index 239605dadfaa..3f4f8a500b26 100644 --- a/configs/apalis_imx6_nospl_com_defconfig +++ b/configs/apalis_imx6_nospl_com_defconfig @@ -45,11 +45,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4020 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4020 CONFIG_USB_HOST_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/apalis_imx6_nospl_it_defconfig b/configs/apalis_imx6_nospl_it_defconfig index 1bc05d7266d3..f88dd02a4f9e 100644 --- a/configs/apalis_imx6_nospl_it_defconfig +++ b/configs/apalis_imx6_nospl_it_defconfig @@ -45,11 +45,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4020 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4020 CONFIG_USB_HOST_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index e15e11ad929a..588c1842a3d3 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -40,9 +40,9 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4000 CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index cf3a7cd74d09..4d93975d69aa 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -27,9 +27,9 @@ CONFIG_MMC_SDHCI_KONA=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Broadcom Corporation" +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0d02 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" -CONFIG_G_DNL_VENDOR_NUM=0x18d1 -CONFIG_G_DNL_PRODUCT_NUM=0x0d02 diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 2ce917981ecb..555ff0538216 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -27,9 +27,9 @@ CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Broadcom Corporation" +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0d02 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" -CONFIG_G_DNL_VENDOR_NUM=0x18d1 -CONFIG_G_DNL_PRODUCT_NUM=0x0d02 diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index 70918654f5ca..49f7e40d15d9 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -34,11 +34,11 @@ CONFIG_MMC_SDHCI_KONA=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Broadcom Corporation" +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0d02 CONFIG_USB_GADGET_BCM_UDC_OTG_PHY=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" -CONFIG_G_DNL_VENDOR_NUM=0x18d1 -CONFIG_G_DNL_PRODUCT_NUM=0x0d02 CONFIG_OF_LIBFDT=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index db1ad401324f..9e17b60e54e4 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -35,11 +35,11 @@ CONFIG_MMC_SDHCI_KONA=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Broadcom Corporation" +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0d02 CONFIG_USB_GADGET_BCM_UDC_OTG_PHY=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" -CONFIG_G_DNL_VENDOR_NUM=0x18d1 -CONFIG_G_DNL_PRODUCT_NUM=0x0d02 CONFIG_OF_LIBFDT=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index 3684fae37005..8f8668ba5b74 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -29,9 +29,9 @@ CONFIG_BCM_SF2_ETH_GMAC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Broadcom Corporation" +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0d02 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" -CONFIG_G_DNL_VENDOR_NUM=0x18d1 -CONFIG_G_DNL_PRODUCT_NUM=0x0d02 diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 7fb88e452b99..ad26354b4df9 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -45,10 +45,10 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 44f4eac6f63b..41b77302155f 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -66,10 +66,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_FAT_WRITE=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 1dffd1a1950d..6ecf8d035478 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -66,10 +66,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_FAT_WRITE=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index 91b5647e6436..a4cd2701e14f 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -48,10 +48,10 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index fc336103cf2b..b17c30fcd2f6 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -57,11 +57,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Congatec" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Congatec" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index f40c0b9afa7d..fccff80780bc 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -75,11 +75,11 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index cdeabaa12aa6..18790b30898f 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -76,11 +76,11 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index c1e36fa8601d..fdb992d59252 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -75,11 +75,11 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 7d1e709d4c47..600387aed428 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -54,11 +54,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4000 CONFIG_USB_HOST_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/colibri_imx6_nospl_defconfig b/configs/colibri_imx6_nospl_defconfig index 6877993088f4..2e69195cc6c9 100644 --- a/configs/colibri_imx6_nospl_defconfig +++ b/configs/colibri_imx6_nospl_defconfig @@ -43,11 +43,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4000 CONFIG_USB_HOST_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index d0b6c6814631..56ae86799140 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -56,10 +56,10 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 0b5604c85158..786d50b458b3 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -47,11 +47,11 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4000 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 65fa90fa2909..1601aa6bc6bf 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -34,11 +34,11 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4000 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 1ffe86180974..c0d664ec2fcd 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -53,11 +53,11 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Toradex" -CONFIG_G_DNL_VENDOR_NUM=0x1b67 -CONFIG_G_DNL_PRODUCT_NUM=0x4000 CONFIG_VIDEO_FSL_DCU_FB=y CONFIG_SYS_CONSOLE_FG_COL=0x00 CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 705e00145700..066dc38535d0 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -49,9 +49,9 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 # CONFIG_EFI_LOADER is not set diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index ba3d478b1e7b..caf998be99cc 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -39,10 +39,10 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index 2342f34e7885..352ab04c8ba3 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -38,10 +38,10 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Advantech" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Advantech" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 08d96add3b93..8a38c8d8c4c9 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -37,10 +37,10 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Advantech" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Advantech" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index e4bb299275d9..4aca3a4a043a 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -90,7 +90,7 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index f55fc501aa48..4d126e09f6a6 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -92,7 +92,7 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 diff --git a/configs/draco_defconfig b/configs/draco_defconfig index e38030bf5913..de2961bfb9c7 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -66,8 +66,8 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_USB_ETHER=y diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index 41248189e3e4..267051228623 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -35,8 +35,8 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/edison_defconfig b/configs/edison_defconfig index d58700c204cb..d3b67c336f47 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -33,9 +33,9 @@ CONFIG_DM_PCI_COMPAT=y CONFIG_USB_DWC3_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Intel" -CONFIG_G_DNL_VENDOR_NUM=0x8087 -CONFIG_G_DNL_PRODUCT_NUM=0x0a99 +CONFIG_USB_GADGET_MANUFACTURER="Intel" +CONFIG_USB_GADGET_VENDOR_NUM=0x8087 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0a99 # CONFIG_USB_HOST_ETHER is not set CONFIG_FAT_WRITE=y CONFIG_SHA1=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 33ca6858abfd..70559892b6e3 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -66,8 +66,8 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_USB_ETHER=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index 5a53951314e2..9cce3351f80b 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -44,11 +44,11 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x310a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x310a CONFIG_SPL_TINY_MEMSET=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 5a658a149522..61fdacaa1340 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -44,9 +44,9 @@ CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_ERRNO_STR=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 5294ba9f5feb..0d91cdd53ff6 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -66,11 +66,11 @@ CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 7bec00178692..e3999556d8b2 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -47,8 +47,8 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x330a +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x330a CONFIG_USE_TINY_PRINTF=y CONFIG_ERRNO_STR=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 96a07defce64..51420e5b66db 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -69,11 +69,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 82da6016e654..eb42def73fc2 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -75,11 +75,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 03d732d8f11e..eeb795876f2c 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -63,11 +63,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Gateworks" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Gateworks" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 51aa13dbaca3..75a07c587400 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -67,11 +67,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Gateworks" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Gateworks" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 4b2e1a752935..1819b9f09d14 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -66,11 +66,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Gateworks" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Gateworks" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 1e3e4bed6af2..f40f6ae56f53 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -49,10 +49,10 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index d9c2efcf7cbe..d27a7f5abbe0 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -42,8 +42,8 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index a42f5e0efb40..0904eb14d4fc 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -44,11 +44,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x310a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x310a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index 0655505a1321..43ab70416331 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -47,11 +47,11 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="AriesEmbedded" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="AriesEmbedded" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index b0437e13a7a7..e607ecd7dd71 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -69,11 +69,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index f716c8fd7f77..92e0a578dfde 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -49,11 +49,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Boundary" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Boundary" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 828318931560..2e375c3068f8 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -48,11 +48,11 @@ CONFIG_PHYLIB=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 0e49e69c8cd5..d511fc98b906 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -48,11 +48,11 @@ CONFIG_PCI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 795c4f2b7124..26250fdb5e91 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -64,11 +64,11 @@ CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_ERRNO_STR=y diff --git a/configs/mx7dsabresd_secure_defconfig b/configs/mx7dsabresd_secure_defconfig index bd68831db7cc..970f8211ef2c 100644 --- a/configs/mx7dsabresd_secure_defconfig +++ b/configs/mx7dsabresd_secure_defconfig @@ -66,11 +66,11 @@ CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_ERRNO_STR=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index fd4a46558129..a5fdb48d2452 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -46,11 +46,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Boundary" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Boundary" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 30046e3f3a07..1803bdba888e 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -46,11 +46,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Boundary" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Boundary" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index f9160c208fe7..3c9b44023f82 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -47,11 +47,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Boundary" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Boundary" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 8bca0e04439e..82b05febae40 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -47,11 +47,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Boundary" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Boundary" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 668fbaa37010..3e4c20357c16 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -46,11 +46,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Boundary" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Boundary" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 99106c9a1f5a..107cbfc9bc55 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -46,11 +46,11 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Boundary" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Boundary" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 29d918d974e4..ba9d8f545ccc 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -65,11 +65,11 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index a5e47c84f248..ab7f8bde9dd7 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -43,10 +43,10 @@ CONFIG_USB_DWC3_GADGET=y CONFIG_USB_DWC3_PHY_SAMSUNG=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Samsung" +CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Samsung" -CONFIG_G_DNL_VENDOR_NUM=0x04e8 -CONFIG_G_DNL_PRODUCT_NUM=0x6601 CONFIG_USB_HOST_ETHER=y CONFIG_VIDEO_BRIDGE=y CONFIG_ERRNO_STR=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 0dc1a250c5d0..ddac08cb98fd 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -56,11 +56,11 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Samsung" +CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Samsung" -CONFIG_G_DNL_VENDOR_NUM=0x04e8 -CONFIG_G_DNL_PRODUCT_NUM=0x6601 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_ERRNO_STR=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 8896b84ebc9a..86967b07fb9c 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -48,10 +48,10 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="TI" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="TI" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 8db95f167a1a..5f6067e689d0 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -52,10 +52,10 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0x5678 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0x5678 CONFIG_USB_ETHER=y CONFIG_FAT_WRITE=y CONFIG_BCH=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 3bf115e6f8c8..b1693be7edd7 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -45,9 +45,9 @@ CONFIG_OMAP3_SPI=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="TI" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="TI" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_BCH=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 6e860ef5e32d..e2295759f0ef 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -49,10 +49,10 @@ CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0403 -CONFIG_G_DNL_PRODUCT_NUM=0xbd00 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_FAT_WRITE=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index a880c62eb6ac..0c2319272ac7 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -79,10 +79,10 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Armadeus Systems" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Armadeus Systems" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER is not set diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 298e7a494371..013eec185aaf 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -41,8 +41,8 @@ CONFIG_MMC_SDHCI_S5P=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Samsung" +CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Samsung" -CONFIG_G_DNL_VENDOR_NUM=0x04e8 -CONFIG_G_DNL_PRODUCT_NUM=0x6601 diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index e499b82d344f..e186526550ee 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -36,8 +36,8 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 3330d23e4089..6713564763d6 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -43,8 +43,8 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index 9259c1316e27..ae896bdde6ff 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -36,8 +36,8 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index 53825eba33c3..4b70fc5687eb 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -24,7 +24,7 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" +CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a +CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" -CONFIG_G_DNL_VENDOR_NUM=0x1f3a -CONFIG_G_DNL_PRODUCT_NUM=0x1010 diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 93ee353d0dc2..ba50ea9d8665 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -72,11 +72,11 @@ CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index abafc65f578c..c213493b12c0 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -32,9 +32,9 @@ CONFIG_PHY_MICREL=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_OF_LIBFDT=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 114c397d2e92..d34e6cecbbd9 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -28,9 +28,9 @@ CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_OF_LIBFDT=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 5e99f9c08922..a8d5cbf70940 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -69,11 +69,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index b6624f0be16c..384ad35aec9c 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -70,10 +70,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index ed5f2f841b2a..3c9c2b342359 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -66,9 +66,9 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index b41644ef5fb3..d0ffdc7b0e70 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -67,11 +67,11 @@ CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 1b787906baf9..1f472009321e 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -71,10 +71,10 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_USB_ETHER=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_SYS_CONSOLE_BG_COL=0xff diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 7d8792cb0580..eb6c2d70c0a6 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -35,9 +35,9 @@ CONFIG_DM_PMIC=y CONFIG_DM_PMIC_MAX8998=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Samsung" +CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Samsung" -CONFIG_G_DNL_VENDOR_NUM=0x04e8 -CONFIG_G_DNL_PRODUCT_NUM=0x6601 CONFIG_FAT_WRITE=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 16352ad7a061..e48e4b53835f 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -46,8 +46,8 @@ CONFIG_DM_PMIC_MAX8998=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Samsung" +CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Samsung" -CONFIG_G_DNL_VENDOR_NUM=0x04e8 -CONFIG_G_DNL_PRODUCT_NUM=0x6601 diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index accdd5da8818..583000e952d6 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -46,10 +46,10 @@ CONFIG_PHYLIB=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_MCS7830=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index f24153b56fd3..75371c47ce8e 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -43,8 +43,8 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index cf4fa20f2c1c..dc2182138c1d 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -64,9 +64,9 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="altera" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="altera" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 1cc6e161d969..9d465761440b 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -64,9 +64,9 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="altera" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="altera" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 0bb9121c262e..7a03e8240cd3 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -58,9 +58,9 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="terasic" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="terasic" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 16cff90369e7..c9f9e50ac85f 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -56,9 +56,9 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="terasic" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="terasic" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 0b4ad4118f24..d06db2548cde 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -58,9 +58,9 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="denx" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="denx" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index b22bf6f608c5..1d50140119a5 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -64,9 +64,9 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="terasic" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="terasic" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 335c9e8384e4..c088c3ed479a 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -64,9 +64,9 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="ebv" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="ebv" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 3bcedb6d1aee..1911735af1ac 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -81,9 +81,9 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="samtec" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="samtec" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 71a382a3e132..bde93e958325 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -53,8 +53,8 @@ CONFIG_PHYLIB=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_USE_TINY_PRINTF=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 20814ccea33b..81225e865abf 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -45,10 +45,10 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="TBS" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="TBS" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index eb9124ce23ec..d9030ec82766 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -66,8 +66,8 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" +CONFIG_USB_GADGET_VENDOR_NUM=0x0908 +CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Siemens AG" -CONFIG_G_DNL_VENDOR_NUM=0x0908 -CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_USB_ETHER=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 00e2d8195434..84fcd8979f20 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -72,11 +72,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Rockchip" -CONFIG_G_DNL_VENDOR_NUM=0x2207 -CONFIG_G_DNL_PRODUCT_NUM=0x320a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index 1080554cba37..a8028b6b18cd 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -46,8 +46,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index 1450fbc61aa0..568eb66d516d 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -47,8 +47,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index d3fc7ad63f32..94fa96221ce5 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -46,8 +46,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index bcc73d4fa266..a4cd8c875ca8 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -50,8 +50,8 @@ CONFIG_DM_PMIC_MAX77686=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Samsung" +CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Samsung" -CONFIG_G_DNL_VENDOR_NUM=0x04e8 -CONFIG_G_DNL_PRODUCT_NUM=0x6601 diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 3f0c59baadcf..5c567f660d04 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -49,8 +49,8 @@ CONFIG_PMIC_MAX8997=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Samsung" +CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Samsung" -CONFIG_G_DNL_VENDOR_NUM=0x04e8 -CONFIG_G_DNL_PRODUCT_NUM=0x6601 diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index f90936e7440e..5820897ae5b0 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -38,10 +38,10 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" +CONFIG_USB_GADGET_VENDOR_NUM=0x0955 +CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="NVIDIA" -CONFIG_G_DNL_VENDOR_NUM=0x0955 -CONFIG_G_DNL_PRODUCT_NUM=0x701a CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 32cf7a4da4b4..c91090cac08b 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -33,11 +33,11 @@ CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" diff --git a/configs/warp7_secure_defconfig b/configs/warp7_secure_defconfig index 99764dbd0bb1..5a2b39493a24 100644 --- a/configs/warp7_secure_defconfig +++ b/configs/warp7_secure_defconfig @@ -31,11 +31,11 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 8e58790269b8..3432a786ba78 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -30,9 +30,9 @@ CONFIG_DFU_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_OF_LIBFDT=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index c3ba5bf63242..03f529e6f4dd 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -85,8 +85,8 @@ CONFIG_USB_DWC3_GADGET=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 # CONFIG_REGEX is not set CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 588b15430bf6..92ac41a6f25c 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -77,7 +77,7 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03FD -CONFIG_G_DNL_PRODUCT_NUM=0x0300 +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 0a3ac9dbeadc..7a40b055a199 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -75,7 +75,7 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03FD -CONFIG_G_DNL_PRODUCT_NUM=0x0300 +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index ee0beda47a8e..670206800e04 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -80,7 +80,7 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03FD -CONFIG_G_DNL_PRODUCT_NUM=0x0300 +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index e47e4bf6e5e1..d878c18476ec 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -80,7 +80,7 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03FD -CONFIG_G_DNL_PRODUCT_NUM=0x0300 +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index ae248f51bc26..cb867010e261 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -53,8 +53,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03FD -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index 0afdd1147a90..39d76ba96553 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -42,8 +42,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/zynq_z_turn_defconfig b/configs/zynq_z_turn_defconfig index 3684b8531fa9..d21a8faa0f64 100644 --- a/configs/zynq_z_turn_defconfig +++ b/configs/zynq_z_turn_defconfig @@ -52,8 +52,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03FD -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 21852e55b6d4..a574a8991737 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -60,8 +60,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index dfafc9a9f6d5..d9718b06de2e 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -56,8 +56,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index bb512aff09d1..3a18c4aeb3a8 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -53,8 +53,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index fd31b4dc14f0..9edde2ace32c 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -58,8 +58,8 @@ CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Xilinx" -CONFIG_G_DNL_VENDOR_NUM=0x03fd -CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/doc/README.android-fastboot b/doc/README.android-fastboot index b8afa1576244..2c3ee7810a4f 100644 --- a/doc/README.android-fastboot +++ b/doc/README.android-fastboot @@ -34,11 +34,11 @@ The fastboot gadget relies on the USB download gadget, so the following options must be configured:
CONFIG_USB_GADGET_DOWNLOAD -CONFIG_G_DNL_VENDOR_NUM -CONFIG_G_DNL_PRODUCT_NUM -CONFIG_G_DNL_MANUFACTURER +CONFIG_USB_GADGET_VENDOR_NUM +CONFIG_USB_GADGET_PRODUCT_NUM +CONFIG_USB_GADGET_MANUFACTURER
-NOTE: The CONFIG_G_DNL_VENDOR_NUM must be one of the numbers supported by +NOTE: The CONFIG_USB_GADGET_VENDOR_NUM must be one of the numbers supported by the fastboot client. The list of vendor IDs supported can be found in the fastboot client source code (fastboot.c) mentioned above.
diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 1201276be837..7bbfde26d0be 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -36,6 +36,22 @@ menuconfig USB_GADGET
if USB_GADGET
+config USB_GADGET_MANUFACTURER + string "Vendor name of the USB device" + help + Vendor name of the USB device emulated, reported to the host device. + This is usually either the manufacturer of the device or the SoC. + +config USB_GADGET_VENDOR_NUM + hex "Vendor ID of the USB device" + Vendor ID of the USB device emulated, reported to the host device. + This is usually the board or SoC vendor's, unless you've registered + for one. + +config USB_GADGET_PRODUCT_NUM + hex "Product ID of the USB device" + Product ID of the USB device emulated, reported to the host device. + config USB_GADGET_ATMEL_USBA bool "Atmel USBA" select USB_GADGET_DUALSPEED @@ -110,15 +126,6 @@ config USB_FUNCTION_SDP allows to download images into memory and execute (jump to) them using the same protocol as implemented by the i.MX family's boot ROM.
-config G_DNL_MANUFACTURER - string "Vendor name of USB device" - -config G_DNL_VENDOR_NUM - hex "Vendor ID of USB device" - -config G_DNL_PRODUCT_NUM - hex "Product ID of USB device" - endif # USB_GADGET_DOWNLOAD
config USB_ETHER diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index 039331a5afd9..99d500a6af4e 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -26,9 +26,9 @@
/* * One needs to define the following: - * CONFIG_G_DNL_VENDOR_NUM - * CONFIG_G_DNL_PRODUCT_NUM - * CONFIG_G_DNL_MANUFACTURER + * CONFIG_USB_GADGET_VENDOR_NUM + * CONFIG_USB_GADGET_PRODUCT_NUM + * CONFIG_USB_GADGET_MANUFACTURER * at e.g. ./configs/<board>_defconfig */
@@ -46,7 +46,7 @@
static const char product[] = "USB download gadget"; static char g_dnl_serial[MAX_STRING_SERIAL]; -static const char manufacturer[] = CONFIG_G_DNL_MANUFACTURER; +static const char manufacturer[] = CONFIG_USB_GADGET_MANUFACTURER;
void g_dnl_set_serialnumber(char *s) { @@ -62,8 +62,8 @@ static struct usb_device_descriptor device_desc = { .bDeviceClass = USB_CLASS_PER_INTERFACE, .bDeviceSubClass = 0, /*0x02:CDC-modem , 0x00:CDC-serial*/
- .idVendor = __constant_cpu_to_le16(CONFIG_G_DNL_VENDOR_NUM), - .idProduct = __constant_cpu_to_le16(CONFIG_G_DNL_PRODUCT_NUM), + .idVendor = __constant_cpu_to_le16(CONFIG_USB_GADGET_VENDOR_NUM), + .idProduct = __constant_cpu_to_le16(CONFIG_USB_GADGET_PRODUCT_NUM), /* .iProduct = DYNAMIC */ /* .iSerialNumber = DYNAMIC */ .bNumConfigurations = 1, diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index b84f6e3480cb..6e76729ef41c 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -89,9 +89,9 @@
#undef CONFIG_USB_GADGET_DOWNLOAD #undef CONFIG_USB_GADGET_VBUS_DRAW -#undef CONFIG_G_DNL_MANUFACTURER -#undef CONFIG_G_DNL_VENDOR_NUM -#undef CONFIG_G_DNL_PRODUCT_NUM +#undef CONFIG_USB_GADGET_MANUFACTURER +#undef CONFIG_USB_GADGET_VENDOR_NUM +#undef CONFIG_USB_GADGET_PRODUCT_NUM #undef CONFIG_USB_GADGET_DUALSPEED #endif
diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 8bc7fbde9e36..13a45010bf5b 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -45,7 +45,7 @@ #define DFU_MANIFEST_POLL_TIMEOUT 25000
/* THOR */ -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM +#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_USB_GADGET_VENDOR_NUM #define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D #define CONFIG_USB_FUNCTION_THOR
The usb_ether gadget duplicates the USB settings for the manufacturer, product ID and vendor ID.
Make sure we use the common option so that we can expect a single VID/PID couple for a single device.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Lukasz Majewski lukma@denx.de Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/sama5d2_ptc_nandflash_defconfig | 1 + configs/sama5d2_ptc_spiflash_defconfig | 1 + configs/vinco_defconfig | 1 + drivers/usb/gadget/Kconfig | 2 ++ drivers/usb/gadget/ether.c | 16 ++++++++-------- include/configs/ma5d4evk.h | 1 - include/configs/sama5d2_ptc.h | 1 - include/configs/vinco.h | 1 - scripts/config_whitelist.txt | 1 - 9 files changed, 13 insertions(+), 12 deletions(-)
diff --git a/configs/sama5d2_ptc_nandflash_defconfig b/configs/sama5d2_ptc_nandflash_defconfig index 6672a5ce11f7..431056a50a8b 100644 --- a/configs/sama5d2_ptc_nandflash_defconfig +++ b/configs/sama5d2_ptc_nandflash_defconfig @@ -29,5 +29,6 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Atmel SAMA5D2_PTC" CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_USB_ETHER=y diff --git a/configs/sama5d2_ptc_spiflash_defconfig b/configs/sama5d2_ptc_spiflash_defconfig index 9a23a808f1b3..66bb671820a6 100644 --- a/configs/sama5d2_ptc_spiflash_defconfig +++ b/configs/sama5d2_ptc_spiflash_defconfig @@ -30,5 +30,6 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Atmel SAMA5D2_PTC" CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_USB_ETHER=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 08aa8c52a254..57ca8f949077 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -31,6 +31,7 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="L+G VInCo" CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 7bbfde26d0be..ef13bd2edb66 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -44,12 +44,14 @@ config USB_GADGET_MANUFACTURER
config USB_GADGET_VENDOR_NUM hex "Vendor ID of the USB device" + help Vendor ID of the USB device emulated, reported to the host device. This is usually the board or SoC vendor's, unless you've registered for one.
config USB_GADGET_PRODUCT_NUM hex "Product ID of the USB device" + help Product ID of the USB device emulated, reported to the host device.
config USB_GADGET_ATMEL_USBA diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 2cf5c8d31e25..dbb578258f96 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -273,8 +273,8 @@ static inline int BITRATE(struct usb_gadget *g) * static ushort idProduct; */
-#if defined(CONFIG_USBNET_MANUFACTURER) -static char *iManufacturer = CONFIG_USBNET_MANUFACTURER; +#if defined(CONFIG_USB_GADGET_MANUFACTURER) +static char *iManufacturer = CONFIG_USB_GADGET_MANUFACTURER; #else static char *iManufacturer = "U-Boot"; #endif @@ -2073,11 +2073,11 @@ static int eth_bind(struct usb_gadget *gadget) * to choose the right configuration otherwise. */ if (rndis) { -#if defined(CONFIG_USB_RNDIS_VENDOR_ID) && defined(CONFIG_USB_RNDIS_PRODUCT_ID) +#if defined(CONFIG_USB_GADGET_VENDOR_NUM) && defined(CONFIG_USB_GADGET_PRODUCT_NUM) device_desc.idVendor = - __constant_cpu_to_le16(CONFIG_USB_RNDIS_VENDOR_ID); + __constant_cpu_to_le16(CONFIG_USB_GADGET_VENDOR_NUM); device_desc.idProduct = - __constant_cpu_to_le16(CONFIG_USB_RNDIS_PRODUCT_ID); + __constant_cpu_to_le16(CONFIG_USB_GADGET_PRODUCT_NUM); #else device_desc.idVendor = __constant_cpu_to_le16(RNDIS_VENDOR_NUM); @@ -2092,9 +2092,9 @@ static int eth_bind(struct usb_gadget *gadget) * supporting one submode of the "SAFE" variant of MDLM.) */ } else { -#if defined(CONFIG_USB_CDC_VENDOR_ID) && defined(CONFIG_USB_CDC_PRODUCT_ID) - device_desc.idVendor = cpu_to_le16(CONFIG_USB_CDC_VENDOR_ID); - device_desc.idProduct = cpu_to_le16(CONFIG_USB_CDC_PRODUCT_ID); +#if defined(CONFIG_USB_GADGET_VENDOR_NUM) && defined(CONFIG_USB_GADGET_PRODUCT_NUM) + device_desc.idVendor = cpu_to_le16(CONFIG_USB_GADGET_VENDOR_NUM); + device_desc.idProduct = cpu_to_le16(CONFIG_USB_GADGET_PRODUCT_NUM); #else if (!cdc) { device_desc.idVendor = diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 6d25d84c6eb6..3aeb7e6ef136 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -97,7 +97,6 @@ #ifdef CONFIG_CMD_USB
/* USB device */ -#define CONFIG_USBNET_MANUFACTURER "AriesEmbedded" #define CONFIG_USB_FUNCTION_MASS_STORAGE #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1 * 1024 * 1024) #define DFU_DEFAULT_POLL_TIMEOUT 300 diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index 543592e3a574..2328c7614ed7 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -60,7 +60,6 @@ #endif
/* USB device */ -#define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D2_PTC"
/* Ethernet Hardware */ #define CONFIG_MACB diff --git a/include/configs/vinco.h b/include/configs/vinco.h index f5aaaa2ffe91..0a23b93f669e 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -64,7 +64,6 @@ #endif
/* USB device */ -#define CONFIG_USBNET_MANUFACTURER "L+G VInCo"
/* Ethernet Hardware */ #define CONFIG_PHY_SMSC diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index bbc3d4351bbd..5cb6ce6612d1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4983,7 +4983,6 @@ CONFIG_USBD_SERIAL_OUT_PKTSIZE CONFIG_USBD_VENDORID CONFIG_USBID_ADDR CONFIG_USBNET_DEV_ADDR -CONFIG_USBNET_MANUFACTURER CONFIG_USBTTY CONFIG_USB_AM35X CONFIG_USB_ATMEL
All the Allwinner boards use the same manufacturer, VID and PID for the gadgets. Make them the defaults to remove some boilerplate from our defconfigs.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/A13-OLinuXino_defconfig | 3 --- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 3 --- configs/A20-OLinuXino-Lime2_defconfig | 3 --- configs/CHIP_defconfig | 3 --- configs/CHIP_pro_defconfig | 3 --- configs/Cubietruck_defconfig | 3 --- configs/Nintendo_NES_Classic_Edition_defconfig | 3 --- configs/Sinlinx_SinA33_defconfig | 3 --- configs/parrot_r16_defconfig | 3 --- drivers/usb/gadget/Kconfig | 3 +++ 10 files changed, 3 insertions(+), 27 deletions(-)
diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 2574018d8213..ae790164dff7 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -32,7 +32,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 5663a824e71b..b136af66b71f 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -34,7 +34,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 63d013293690..ebb435f30956 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -33,7 +33,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 278039c05573..7d50d0533dcd 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -23,8 +23,5 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index edbdefc69ddf..76daf477ec87 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -28,8 +28,5 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 2d1753645b0f..1b2989d364f6 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -33,7 +33,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index 99f7d30f150d..5986764a14b9 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -23,7 +23,4 @@ CONFIG_AXP_ELDO2_VOLT=1800 CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 8c5fc7587909..9299aedd6019 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -28,7 +28,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index 4b70fc5687eb..57db9587fe77 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -24,7 +24,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" -CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a -CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index ef13bd2edb66..32b9a7e9fe49 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -38,12 +38,14 @@ if USB_GADGET
config USB_GADGET_MANUFACTURER string "Vendor name of the USB device" + default "Allwinner Technology" if ARCH_SUNXI help Vendor name of the USB device emulated, reported to the host device. This is usually either the manufacturer of the device or the SoC.
config USB_GADGET_VENDOR_NUM hex "Vendor ID of the USB device" + default 0x1f3a if ARCH_SUNXI help Vendor ID of the USB device emulated, reported to the host device. This is usually the board or SoC vendor's, unless you've registered @@ -51,6 +53,7 @@ config USB_GADGET_VENDOR_NUM
config USB_GADGET_PRODUCT_NUM hex "Product ID of the USB device" + default 0x1010 if ARCH_SUNXI help Product ID of the USB device emulated, reported to the host device.
Reviewed-by: Łukasz Majewski lukma@denx.de
- default 0x1010 if ARCH_SUNXI help Product ID of the USB device emulated, reported to the host device.
A good number of our boards have USB_GADGET enabled. Imply it so that all the boards can benefit from it, and remove some boilerplate from our defconfigs.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/Kconfig | 1 + configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 1 - configs/CHIP_defconfig | 1 - configs/CHIP_pro_defconfig | 1 - configs/Cubietruck_defconfig | 1 - configs/Nintendo_NES_Classic_Edition_defconfig | 1 - configs/Sinlinx_SinA33_defconfig | 1 - configs/parrot_r16_defconfig | 1 - 10 files changed, 1 insertion(+), 9 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 53eae8953e0b..1eb59c591a54 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -705,6 +705,7 @@ config ARCH_SUNXI imply SPL_POWER_SUPPORT imply SPL_SERIAL_SUPPORT imply USB_FUNCTION_FASTBOOT + imply USB_GADGET
config TARGET_TS4600 bool "Support TS4600" diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index ae790164dff7..e55dbff44d36 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -31,5 +31,4 @@ CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index b136af66b71f..9491708d80c6 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -33,5 +33,4 @@ CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index ebb435f30956..2bb8ee8c9ebd 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -32,5 +32,4 @@ CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 7d50d0533dcd..b9f70d240c3c 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -22,6 +22,5 @@ CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 76daf477ec87..74f6eb10fc01 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -27,6 +27,5 @@ CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 1b2989d364f6..458e2a9d8b04 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -32,5 +32,4 @@ CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index 5986764a14b9..e031dd8f5d5f 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -22,5 +22,4 @@ CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_ELDO2_VOLT=1800 CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 9299aedd6019..143a9b4b6c10 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -27,5 +27,4 @@ CONFIG_DFU_RAM=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index 57db9587fe77..b36b9efec650 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -23,5 +23,4 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y
imply USB_GADGET
On Wed, Sep 13, 2017 at 3:01 AM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
This breaks builds using defconfigs where USB_MUSB_GADGET is not set. Perhaps a better solution would be to imply USB_GADGET from USB_MUSB_GADGET? Kconfig complains about recursive dependencies if I do
imply USB_GADGET if USB_MUSB_GADGET
under ARCH_SUNXI though.
ChenYu
Thanks, I just pushed a fix for it.
Maxime
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right.
That will also reduce the boilerplate in the defconfigs.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/Kconfig | 2 -- cmd/fastboot/Kconfig | 4 ++++ configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 1 - configs/CHIP_defconfig | 1 - configs/CHIP_pro_defconfig | 1 - configs/Cubietruck_defconfig | 1 - configs/Nintendo_NES_Classic_Edition_defconfig | 1 - configs/Sinlinx_SinA33_defconfig | 1 - configs/am335x_boneblack_defconfig | 2 -- configs/am335x_boneblack_vboot_defconfig | 2 -- configs/am335x_evm_defconfig | 2 -- configs/am335x_evm_nor_defconfig | 2 -- configs/am335x_evm_norboot_defconfig | 2 -- configs/am335x_evm_spiboot_defconfig | 2 -- configs/am335x_evm_usbspl_defconfig | 2 -- configs/am57xx_evm_defconfig | 2 -- configs/am57xx_evm_nodt_defconfig | 3 --- configs/am57xx_hs_evm_defconfig | 2 -- configs/bcm23550_w1d_defconfig | 3 --- configs/bcm28155_ap_defconfig | 3 --- configs/birdland_bav335a_defconfig | 3 --- configs/birdland_bav335b_defconfig | 3 --- configs/cgtqmx6eval_defconfig | 3 --- configs/chromebit_mickey_defconfig | 1 - configs/chromebook_jerry_defconfig | 1 - configs/chromebook_minnie_defconfig | 1 - configs/dra7xx_evm_defconfig | 2 -- configs/dra7xx_hs_evm_defconfig | 2 -- configs/evb-rk3036_defconfig | 1 - configs/evb-rk3229_defconfig | 1 - configs/evb-rk3288_defconfig | 1 - configs/fennec-rk3288_defconfig | 1 - configs/firefly-rk3288_defconfig | 1 - configs/kc1_defconfig | 3 --- configs/kylin-rk3036_defconfig | 1 - configs/miqi-rk3288_defconfig | 1 - configs/mx6qsabrelite_defconfig | 3 --- configs/nitrogen6dl2g_defconfig | 3 --- configs/nitrogen6dl_defconfig | 3 --- configs/nitrogen6q2g_defconfig | 3 --- configs/nitrogen6q_defconfig | 3 --- configs/nitrogen6s1g_defconfig | 3 --- configs/nitrogen6s_defconfig | 3 --- configs/omap3_beagle_defconfig | 3 --- configs/omap3_logic_defconfig | 2 -- configs/parrot_r16_defconfig | 1 - configs/phycore-rk3288_defconfig | 1 - configs/popmetal-rk3288_defconfig | 1 - configs/rock2_defconfig | 1 - configs/sniper_defconfig | 3 --- configs/tinker-rk3288_defconfig | 1 - 53 files changed, 4 insertions(+), 97 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 1eb59c591a54..519f42778a8d 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -693,7 +693,6 @@ config ARCH_SUNXI select USB_STORAGE if DISTRO_DEFAULTS select USB_KEYBOARD if DISTRO_DEFAULTS select USE_TINY_PRINTF - imply CMD_FASTBOOT imply FASTBOOT imply FAT_WRITE imply PRE_CONSOLE_BUFFER @@ -704,7 +703,6 @@ config ARCH_SUNXI imply SPL_MMC_SUPPORT if MMC imply SPL_POWER_SUPPORT imply SPL_SERIAL_SUPPORT - imply USB_FUNCTION_FASTBOOT imply USB_GADGET
config TARGET_TS4600 diff --git a/cmd/fastboot/Kconfig b/cmd/fastboot/Kconfig index fb0c5da94cdb..5c1186017206 100644 --- a/cmd/fastboot/Kconfig +++ b/cmd/fastboot/Kconfig @@ -8,6 +8,10 @@ if FASTBOOT
config USB_FUNCTION_FASTBOOT bool "Enable USB fastboot gadget" + default y + select USB_GADGET_DOWNLOAD + imply ANDROID_BOOT_IMAGE + imply CMD_FASTBOOT help This enables the USB part of the fastboot gadget.
diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index e55dbff44d36..ed8349000e22 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -31,4 +31,3 @@ CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 9491708d80c6..a04037ebe7cc 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -33,4 +33,3 @@ CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 2bb8ee8c9ebd..f9388a005bcd 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -32,4 +32,3 @@ CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index b9f70d240c3c..5acce42a60f9 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -22,5 +22,4 @@ CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 74f6eb10fc01..2303135449b2 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -27,5 +27,4 @@ CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 458e2a9d8b04..3dff02f342d7 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -32,4 +32,3 @@ CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index e031dd8f5d5f..26fcffa02f10 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -22,4 +22,3 @@ CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_ELDO2_VOLT=1800 CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 143a9b4b6c10..d726b404cc5e 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -27,4 +27,3 @@ CONFIG_DFU_RAM=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 85f220329e4e..e17329bc4fda 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -18,7 +18,6 @@ CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set @@ -41,7 +40,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_LZO=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 9ba3f7c04d73..4669a68d1471 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -21,7 +21,6 @@ CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set @@ -51,6 +50,5 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_LZO=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 8aa3c0de8824..e5363e78f07f 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00080000 @@ -53,7 +52,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_RSA=y CONFIG_LZO=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index b745f2997334..9d226bc8919f 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -14,7 +14,6 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00080000 @@ -40,7 +39,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 9662b6684c1f..e786565c2a17 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -12,7 +12,6 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MTDPARTS=y @@ -34,7 +33,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_LZO=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 5e2c19066daa..0ab48d9647c0 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set @@ -38,7 +37,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index d6c21b8e85ee..0674ab0570e8 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -18,7 +18,6 @@ CONFIG_SPL_USB_GADGET_SUPPORT=y CONFIG_SPL_USBETH_SUPPORT=y # CONFIG_SPL_YMODEM_SUPPORT is not set CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00080000 @@ -44,7 +43,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index a9ee2e448f3c..07afb9139a77 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -25,7 +25,6 @@ CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_USB_DEV=1 @@ -75,4 +74,3 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index ae7c3464e0cb..88b8bc104d08 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -15,8 +15,6 @@ CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_USB_DEV=1 @@ -65,6 +63,5 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 1047f33237ef..dd5e86212576 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -30,7 +30,6 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_USB_DEV=1 @@ -78,4 +77,3 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index 49f7e40d15d9..f7af02f61323 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -7,8 +7,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x80000000 CONFIG_FASTBOOT_BUF_SIZE=0x1D000000 CONFIG_FASTBOOT_FLASH=y @@ -40,5 +38,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0d02 CONFIG_USB_GADGET_BCM_UDC_OTG_PHY=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index 9e17b60e54e4..2d24200096e3 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -8,8 +8,6 @@ CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x80000000 CONFIG_FASTBOOT_BUF_SIZE=0x7FF00000 CONFIG_FASTBOOT_FLASH=y @@ -41,5 +39,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0d02 CONFIG_USB_GADGET_BCM_UDC_OTG_PHY=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 41b77302155f..828bbd16e6ed 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -24,8 +24,6 @@ CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -69,7 +67,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_FAT_WRITE=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 6ecf8d035478..d851575ac619 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -24,8 +24,6 @@ CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -69,7 +67,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_FAT_WRITE=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index b17c30fcd2f6..201a33138cf2 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -24,8 +24,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -61,7 +59,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Congatec" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index fccff80780bc..e061b2615255 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -79,7 +79,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 18790b30898f..2f6b4e5e3d30 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -80,7 +80,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index fdb992d59252..3b76cb47fb4d 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -79,7 +79,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 4aca3a4a043a..748948ec8156 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -25,7 +25,6 @@ CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_FLASH=y @@ -93,4 +92,3 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 4d126e09f6a6..d31653e9d1c5 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -30,7 +30,6 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_FLASH=y @@ -95,4 +94,3 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index 9cce3351f80b..f2c4d8c54303 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -48,7 +48,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x310a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_SPL_TINY_MEMSET=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 61fdacaa1340..2bc9f4a9765b 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -48,5 +48,4 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_ERRNO_STR=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 0d91cdd53ff6..d8dadd7ea97e 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -70,7 +70,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 51420e5b66db..adc3f7aa70a8 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -73,7 +73,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index eb42def73fc2..3e95f0fca2b3 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -79,7 +79,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index d27a7f5abbe0..87b3eec4623c 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -12,8 +12,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="kc1 # " CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2000000 CONFIG_FASTBOOT_FLASH=y @@ -45,5 +43,4 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index 0904eb14d4fc..5adf5779c728 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -48,7 +48,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x310a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index e607ecd7dd71..e5d1b759256a 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -73,7 +73,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 92e0a578dfde..3dfe25ebb5c0 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -10,8 +10,6 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -53,7 +51,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Boundary" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index a5fdb48d2452..32c6eea54618 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -10,8 +10,6 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -50,7 +48,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Boundary" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 1803bdba888e..8ce2515d3794 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -10,8 +10,6 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -50,7 +48,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Boundary" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 3c9b44023f82..1c149b5edf99 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -10,8 +10,6 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -51,7 +49,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Boundary" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 82b05febae40..29e59fd71ea0 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -10,8 +10,6 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -51,7 +49,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Boundary" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 3e4c20357c16..a06d6e12e358 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -10,8 +10,6 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -50,7 +48,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Boundary" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 107cbfc9bc55..a7a54bbb5e0f 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -10,8 +10,6 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -50,7 +48,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Boundary" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 86967b07fb9c..024e35647304 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -9,8 +9,6 @@ CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y @@ -51,7 +49,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="TI" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index b1693be7edd7..4380d6c84220 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP Logic # " CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -48,6 +47,5 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="TI" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_BCH=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index b36b9efec650..6be57e604e89 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -23,4 +23,3 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index ba50ea9d8665..f9a53fc920d0 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -76,7 +76,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index a8d5cbf70940..5e592e6b918b 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -73,7 +73,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index d0ffdc7b0e70..be28c6640c1f 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -71,7 +71,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 75371c47ce8e..21254a5ad32b 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -13,8 +13,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="sniper # " CONFIG_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2000000 CONFIG_FASTBOOT_FLASH=y @@ -46,5 +44,4 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 84fcd8979f20..816fc0189c1d 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -76,7 +76,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y
- default y
- select USB_GADGET_DOWNLOAD
- imply ANDROID_BOOT_IMAGE
- imply CMD_FASTBOOT help This enables the USB part of the fastboot gadget.
The device model was implemented so far using a hook that needed to be called from the board support, without DT support and only for the host.
Switch to probing both in peripheral and host mode through the DT.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/include/asm/arch-sunxi/usb_phy.h | 7 +--- board/sunxi/board.c | 1 +- drivers/usb/musb-new/sunxi.c | 56 +++++++++++------------- 3 files changed, 27 insertions(+), 37 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/usb_phy.h b/arch/arm/include/asm/arch-sunxi/usb_phy.h index cef6c985bc8d..5a9cacb6f4a3 100644 --- a/arch/arm/include/asm/arch-sunxi/usb_phy.h +++ b/arch/arm/include/asm/arch-sunxi/usb_phy.h @@ -19,10 +19,3 @@ void sunxi_usb_phy_power_off(int index); int sunxi_usb_phy_vbus_detect(int index); int sunxi_usb_phy_id_detect(int index); void sunxi_usb_phy_enable_squelch_detect(int index, int enable); - -/* Not really phy related, but we have to declare this somewhere ... */ -#if defined(CONFIG_USB_MUSB_HOST) || defined(CONFIG_USB_MUSB_GADGET) -void sunxi_musb_board_init(void); -#else -#define sunxi_musb_board_init() -#endif diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 70e01437c4f4..f9224360d758 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -736,7 +736,6 @@ int misc_init_r(void) if (ret) return ret; #endif - sunxi_musb_board_init();
return 0; } diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 5c1a902e42dc..7ee44ea91900 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -308,9 +308,6 @@ static struct musb_hdrc_platform_data musb_plat = { .platform_ops = &sunxi_musb_ops, };
-#ifdef CONFIG_USB_MUSB_HOST -static int musb_usb_remove(struct udevice *dev); - static int musb_usb_probe(struct udevice *dev) { struct musb_host_data *host = dev_get_priv(dev); @@ -319,16 +316,20 @@ static int musb_usb_probe(struct udevice *dev)
priv->desc_before_addr = true;
+#ifdef CONFIG_USB_MUSB_HOST host->host = musb_init_controller(&musb_plat, NULL, (void *)SUNXI_USB0_BASE); if (!host->host) return -EIO;
ret = musb_lowlevel_init(host); - if (ret == 0) - printf("MUSB OTG\n"); - else - musb_usb_remove(dev); + if (!ret) + printf("Allwinner mUSB OTG (Host)\n"); +#else + ret = musb_register(&musb_plat, NULL, (void *)SUNXI_USB0_BASE); + if (!ret) + printf("Allwinner mUSB OTG (Peripheral)\n"); +#endif
return ret; } @@ -352,30 +353,27 @@ static int musb_usb_remove(struct udevice *dev) return 0; }
-U_BOOT_DRIVER(usb_musb) = { - .name = "sunxi-musb", - .id = UCLASS_USB, - .probe = musb_usb_probe, - .remove = musb_usb_remove, - .ops = &musb_usb_ops, - .platdata_auto_alloc_size = sizeof(struct usb_platdata), - .priv_auto_alloc_size = sizeof(struct musb_host_data), +static const struct udevice_id sunxi_musb_ids[] = { + { .compatible = "allwinner,sun4i-a10-musb" }, + { .compatible = "allwinner,sun6i-a31-musb" }, + { .compatible = "allwinner,sun8i-a33-musb" }, + { .compatible = "allwinner,sun8i-h3-musb" }, + { } }; -#endif
-void sunxi_musb_board_init(void) -{ +U_BOOT_DRIVER(usb_musb) = { + .name = "sunxi-musb", #ifdef CONFIG_USB_MUSB_HOST - struct udevice *dev; - - /* - * Bind the driver directly for now as musb linux kernel support is - * still pending upstream so our dts files do not have the necessary - * nodes yet. TODO: Remove this as soon as the dts nodes are in place - * and bind by compatible instead. - */ - device_bind_driver(dm_root(), "sunxi-musb", "sunxi-musb", &dev); + .id = UCLASS_USB, #else - musb_register(&musb_plat, NULL, (void *)SUNXI_USB0_BASE); + .id = UCLASS_USB_DEV_GENERIC, #endif -} + .of_match = sunxi_musb_ids, + .probe = musb_usb_probe, + .remove = musb_usb_remove, +#ifdef CONFIG_USB_MUSB_HOST + .ops = &musb_usb_ops, +#endif + .platdata_auto_alloc_size = sizeof(struct usb_platdata), + .priv_auto_alloc_size = sizeof(struct musb_host_data), +};
return 0; }
- if (ret == 0)
- else
- if (!ret)
+#else
- ret = musb_register(&musb_plat, NULL, (void *)SUNXI_USB0_BASE);
- if (!ret)
- .id = UCLASS_USB,
- { .compatible = "allwinner,sun4i-a10-musb" },
- { .compatible = "allwinner,sun6i-a31-musb" },
- { .compatible = "allwinner,sun8i-a33-musb" },
- { .compatible = "allwinner,sun8i-h3-musb" },
-#endif
- .name = "sunxi-musb", #ifdef CONFIG_USB_MUSB_HOST
- .id = UCLASS_USB, #else
- .id = UCLASS_USB_DEV_GENERIC, #endif
- .of_match = sunxi_musb_ids,
Call the function to register the usb_ether gadget in the board.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/board.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index f9224360d758..610fa89056ef 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -737,6 +737,8 @@ int misc_init_r(void) return ret; #endif
+ usb_ether_init(); + return 0; }
- usb_ether_init();
- return 0; }
Now that we can enable the usb_ether gadget, do it. This will be especially useful for boards that don't have any ethernet controller, such as the ones based on the A13 or A33.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 519f42778a8d..bce5959ef687 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -703,6 +703,7 @@ config ARCH_SUNXI imply SPL_MMC_SUPPORT if MMC imply SPL_POWER_SUPPORT imply SPL_SERIAL_SUPPORT + imply USB_ETHER imply USB_GADGET
The kernel DT of the SinA33 has evolved quite a bit. Make sure we sync it and its upstream DTSI to be able to use the OTG. The DTs were taken from the 4.13 kernel release.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/dts/axp223.dtsi | 58 ++- arch/arm/dts/axp22x.dtsi | 10 +- arch/arm/dts/sun8i-a23-a33.dtsi | 446 +++++++----------- arch/arm/dts/sun8i-a33-sinlinx-sina33.dts | 43 ++- arch/arm/dts/sun8i-a33.dtsi | 477 +++++++++++++++---- include/dt-bindings/clock/sun8i-a23-a33-ccu.h | 127 +++++- include/dt-bindings/reset/sun8i-a23-a33-ccu.h | 87 +++- 7 files changed, 914 insertions(+), 334 deletions(-) create mode 100644 arch/arm/dts/axp223.dtsi create mode 100644 include/dt-bindings/clock/sun8i-a23-a33-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-a23-a33-ccu.h
diff --git a/arch/arm/dts/axp223.dtsi b/arch/arm/dts/axp223.dtsi new file mode 100644 index 000000000000..b91b6c1278c7 --- /dev/null +++ b/arch/arm/dts/axp223.dtsi @@ -0,0 +1,58 @@ +/* + * Copyright 2016 Free Electrons + * + * Quentin Schulz quentin.schulz@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/* + * AXP223 Integrated Power Management Chip + * http://www.x-powers.com/product/AXP22X.php + * http://dl.linux-sunxi.org/AXP/AXP223-en.pdf + * + * The AXP223 shares most of its logic with the AXP221 but it has some + * differences, for the VBUS driver for example. + */ + +#include "axp22x.dtsi" + +&usb_power_supply { + compatible = "x-powers,axp223-usb-power-supply"; +}; diff --git a/arch/arm/dts/axp22x.dtsi b/arch/arm/dts/axp22x.dtsi index 458b6681e3ec..87fb08e812ec 100644 --- a/arch/arm/dts/axp22x.dtsi +++ b/arch/arm/dts/axp22x.dtsi @@ -52,6 +52,16 @@ interrupt-controller; #interrupt-cells = <1>;
+ ac_power_supply: ac-power-supply { + compatible = "x-powers,axp221-ac-power-supply"; + status = "disabled"; + }; + + battery_power_supply: battery-power-supply { + compatible = "x-powers,axp221-battery-power-supply"; + status = "disabled"; + }; + regulators { /* Default work frequency for buck regulators */ x-powers,dcdc-freq = <3000>; diff --git a/arch/arm/dts/sun8i-a23-a33.dtsi b/arch/arm/dts/sun8i-a23-a33.dtsi index f97c38f097d1..ea50dda75adc 100644 --- a/arch/arm/dts/sun8i-a23-a33.dtsi +++ b/arch/arm/dts/sun8i-a23-a33.dtsi @@ -46,7 +46,8 @@
#include <dt-bindings/interrupt-controller/arm-gic.h>
-#include <dt-bindings/pinctrl/sun4i-a10.h> +#include <dt-bindings/clock/sun8i-a23-a33-ccu.h> +#include <dt-bindings/reset/sun8i-a23-a33-ccu.h>
/ { interrupt-parent = <&gic>; @@ -60,7 +61,9 @@ compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "de_be0-lcd0"; - clocks = <&pll6 0>; + clocks = <&ccu CLK_BUS_LCD>, <&ccu CLK_BUS_DE_BE>, + <&ccu CLK_LCD_CH0>, <&ccu CLK_DE_BE>, + <&ccu CLK_DRAM_DE_BE>, <&ccu CLK_DRC>; status = "disabled"; }; }; @@ -80,7 +83,7 @@ #address-cells = <1>; #size-cells = <0>;
- cpu@0 { + cpu0: cpu@0 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0>; @@ -102,151 +105,16 @@ #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24000000>; + clock-accuracy = <50000>; clock-output-names = "osc24M"; };
- osc32k: osc32k_clk { + ext_osc32k: ext_osc32k_clk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; - clock-output-names = "osc32k"; - }; - - pll1: clk@01c20000 { - #clock-cells = <0>; - compatible = "allwinner,sun8i-a23-pll1-clk"; - reg = <0x01c20000 0x4>; - clocks = <&osc24M>; - clock-output-names = "pll1"; - }; - - /* dummy clock until actually implemented */ - pll5: pll5_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <0>; - clock-output-names = "pll5"; - }; - - pll6: clk@01c20028 { - #clock-cells = <1>; - compatible = "allwinner,sun6i-a31-pll6-clk"; - reg = <0x01c20028 0x4>; - clocks = <&osc24M>; - clock-output-names = "pll6", "pll6x2"; - }; - - cpu: cpu_clk@01c20050 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-cpu-clk"; - reg = <0x01c20050 0x4>; - - /* - * PLL1 is listed twice here. - * While it looks suspicious, it's actually documented - * that way both in the datasheet and in the code from - * Allwinner. - */ - clocks = <&osc32k>, <&osc24M>, <&pll1>, <&pll1>; - clock-output-names = "cpu"; - }; - - axi: axi_clk@01c20050 { - #clock-cells = <0>; - compatible = "allwinner,sun8i-a23-axi-clk"; - reg = <0x01c20050 0x4>; - clocks = <&cpu>; - clock-output-names = "axi"; - }; - - ahb1: ahb1_clk@01c20054 { - #clock-cells = <0>; - compatible = "allwinner,sun6i-a31-ahb1-clk"; - reg = <0x01c20054 0x4>; - clocks = <&osc32k>, <&osc24M>, <&axi>, <&pll6 0>; - clock-output-names = "ahb1"; - }; - - apb1: apb1_clk@01c20054 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-apb0-clk"; - reg = <0x01c20054 0x4>; - clocks = <&ahb1>; - clock-output-names = "apb1"; - }; - - apb1_gates: clk@01c20068 { - #clock-cells = <1>; - compatible = "allwinner,sun8i-a23-apb1-gates-clk"; - reg = <0x01c20068 0x4>; - clocks = <&apb1>; - clock-indices = <0>, <5>, - <12>, <13>; - clock-output-names = "apb1_codec", "apb1_pio", - "apb1_daudio0", "apb1_daudio1"; - }; - - apb2: clk@01c20058 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-apb1-clk"; - reg = <0x01c20058 0x4>; - clocks = <&osc32k>, <&osc24M>, <&pll6 0>, <&pll6 0>; - clock-output-names = "apb2"; - }; - - apb2_gates: clk@01c2006c { - #clock-cells = <1>; - compatible = "allwinner,sun8i-a23-apb2-gates-clk"; - reg = <0x01c2006c 0x4>; - clocks = <&apb2>; - clock-indices = <0>, <1>, - <2>, <16>, - <17>, <18>, - <19>, <20>; - clock-output-names = "apb2_i2c0", "apb2_i2c1", - "apb2_i2c2", "apb2_uart0", - "apb2_uart1", "apb2_uart2", - "apb2_uart3", "apb2_uart4"; - }; - - mmc0_clk: clk@01c20088 { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c20088 0x4>; - clocks = <&osc24M>, <&pll6 0>; - clock-output-names = "mmc0", - "mmc0_output", - "mmc0_sample"; - }; - - mmc1_clk: clk@01c2008c { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c2008c 0x4>; - clocks = <&osc24M>, <&pll6 0>; - clock-output-names = "mmc1", - "mmc1_output", - "mmc1_sample"; - }; - - mmc2_clk: clk@01c20090 { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c20090 0x4>; - clocks = <&osc24M>, <&pll6 0>; - clock-output-names = "mmc2", - "mmc2_output", - "mmc2_sample"; - }; - - usb_clk: clk@01c200cc { - #clock-cells = <1>; - #reset-cells = <1>; - compatible = "allwinner,sun8i-a23-usb-clk"; - reg = <0x01c200cc 0x4>; - clocks = <&osc24M>; - clock-output-names = "usb_phy0", "usb_phy1", "usb_hsic", - "usb_hsic_12M", "usb_ohci0"; + clock-accuracy = <50000>; + clock-output-names = "ext-osc32k"; }; };
@@ -260,24 +128,23 @@ compatible = "allwinner,sun8i-a23-dma"; reg = <0x01c02000 0x1000>; interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ahb1_gates 6>; - resets = <&ahb1_rst 6>; + clocks = <&ccu CLK_BUS_DMA>; + resets = <&ccu RST_BUS_DMA>; #dma-cells = <1>; };
mmc0: mmc@01c0f000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun7i-a20-mmc"; reg = <0x01c0f000 0x1000>; - clocks = <&ahb1_gates 8>, - <&mmc0_clk 0>, - <&mmc0_clk 1>, - <&mmc0_clk 2>; + clocks = <&ccu CLK_BUS_MMC0>, + <&ccu CLK_MMC0>, + <&ccu CLK_MMC0_OUTPUT>, + <&ccu CLK_MMC0_SAMPLE>; clock-names = "ahb", "mmc", "output", "sample"; - resets = <&ahb1_rst 8>; + resets = <&ccu RST_BUS_MMC0>; reset-names = "ahb"; interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; @@ -286,18 +153,17 @@ };
mmc1: mmc@01c10000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun7i-a20-mmc"; reg = <0x01c10000 0x1000>; - clocks = <&ahb1_gates 9>, - <&mmc1_clk 0>, - <&mmc1_clk 1>, - <&mmc1_clk 2>; + clocks = <&ccu CLK_BUS_MMC1>, + <&ccu CLK_MMC1>, + <&ccu CLK_MMC1_OUTPUT>, + <&ccu CLK_MMC1_SAMPLE>; clock-names = "ahb", "mmc", "output", "sample"; - resets = <&ahb1_rst 9>; + resets = <&ccu RST_BUS_MMC1>; reset-names = "ahb"; interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; @@ -306,18 +172,17 @@ };
mmc2: mmc@01c11000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun7i-a20-mmc"; reg = <0x01c11000 0x1000>; - clocks = <&ahb1_gates 10>, - <&mmc2_clk 0>, - <&mmc2_clk 1>, - <&mmc2_clk 2>; + clocks = <&ccu CLK_BUS_MMC2>, + <&ccu CLK_MMC2>, + <&ccu CLK_MMC2_OUTPUT>, + <&ccu CLK_MMC2_SAMPLE>; clock-names = "ahb", "mmc", "output", "sample"; - resets = <&ahb1_rst 10>; + resets = <&ccu RST_BUS_MMC2>; reset-names = "ahb"; interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; @@ -325,12 +190,55 @@ #size-cells = <0>; };
+ nfc: nand@01c03000 { + compatible = "allwinner,sun4i-a10-nand"; + reg = <0x01c03000 0x1000>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_NAND>, <&ccu CLK_NAND>; + clock-names = "ahb", "mod"; + resets = <&ccu RST_BUS_NAND>; + reset-names = "ahb"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + usb_otg: usb@01c19000 { + /* compatible gets set in SoC specific dtsi file */ + reg = <0x01c19000 0x0400>; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@01c19400 { + /* + * compatible and address regions get set in + * SoC specific dtsi file + */ + clocks = <&ccu CLK_USB_PHY0>, + <&ccu CLK_USB_PHY1>; + clock-names = "usb0_phy", + "usb1_phy"; + resets = <&ccu RST_USB_PHY0>, + <&ccu RST_USB_PHY1>; + reset-names = "usb0_reset", + "usb1_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + ehci0: usb@01c1a000 { compatible = "allwinner,sun8i-a23-ehci", "generic-ehci"; reg = <0x01c1a000 0x100>; interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ahb1_gates 26>; - resets = <&ahb1_rst 26>; + clocks = <&ccu CLK_BUS_EHCI>; + resets = <&ccu RST_BUS_EHCI>; phys = <&usbphy 1>; phy-names = "usb"; status = "disabled"; @@ -340,101 +248,100 @@ compatible = "allwinner,sun8i-a23-ohci", "generic-ohci"; reg = <0x01c1a400 0x100>; interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ahb1_gates 29>, <&usb_clk 16>; - resets = <&ahb1_rst 29>; + clocks = <&ccu CLK_BUS_OHCI>, <&ccu CLK_USB_OHCI>; + resets = <&ccu RST_BUS_OHCI>; phys = <&usbphy 1>; phy-names = "usb"; status = "disabled"; };
+ ccu: clock@01c20000 { + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&rtc 0>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + pio: pinctrl@01c20800 { /* compatible gets set in SoC specific dtsi file */ reg = <0x01c20800 0x400>; /* interrupts get set in SoC specific dtsi file */ - clocks = <&apb1_gates 5>; + clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&rtc 0>; + clock-names = "apb", "hosc", "losc"; gpio-controller; interrupt-controller; #interrupt-cells = <3>; #gpio-cells = <3>;
uart0_pins_a: uart0@0 { - allwinner,pins = "PF2", "PF4"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PF2", "PF4"; + function = "uart0"; + }; + + uart1_pins_a: uart1@0 { + pins = "PG6", "PG7"; + function = "uart1"; + }; + + uart1_pins_cts_rts_a: uart1-cts-rts@0 { + pins = "PG8", "PG9"; + function = "uart1"; };
mmc0_pins_a: mmc0@0 { - allwinner,pins = "PF0", "PF1", "PF2", - "PF3", "PF4", "PF5"; - allwinner,function = "mmc0"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PF0", "PF1", "PF2", + "PF3", "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; };
mmc1_pins_a: mmc1@0 { - allwinner,pins = "PG0", "PG1", "PG2", - "PG3", "PG4", "PG5"; - allwinner,function = "mmc1"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PG0", "PG1", "PG2", + "PG3", "PG4", "PG5"; + function = "mmc1"; + drive-strength = <30>; + bias-pull-up; };
mmc2_8bit_pins: mmc2_8bit { - allwinner,pins = "PC5", "PC6", "PC8", - "PC9", "PC10", "PC11", - "PC12", "PC13", "PC14", - "PC15", "PC16"; - allwinner,function = "mmc2"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PC5", "PC6", "PC8", + "PC9", "PC10", "PC11", + "PC12", "PC13", "PC14", + "PC15", "PC16"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; };
pwm0_pins: pwm0 { - allwinner,pins = "PH0"; - allwinner,function = "pwm0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PH0"; + function = "pwm0"; };
i2c0_pins_a: i2c0@0 { - allwinner,pins = "PH2", "PH3"; - allwinner,function = "i2c0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PH2", "PH3"; + function = "i2c0"; };
i2c1_pins_a: i2c1@0 { - allwinner,pins = "PH4", "PH5"; - allwinner,function = "i2c1"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PH4", "PH5"; + function = "i2c1"; };
i2c2_pins_a: i2c2@0 { - allwinner,pins = "PE12", "PE13"; - allwinner,function = "i2c2"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PE12", "PE13"; + function = "i2c2"; }; - }; - - ahb1_rst: reset@01c202c0 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202c0 0xc>; - };
- apb1_rst: reset@01c202d0 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202d0 0x4>; - }; - - apb2_rst: reset@01c202d8 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202d8 0x4>; + lcd_rgb666_pins: lcd-rgb666@0 { + pins = "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", + "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", + "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", + "PD24", "PD25", "PD26", "PD27"; + function = "lcd0"; + }; };
timer@01c20c00 { @@ -472,8 +379,8 @@ interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&apb2_gates 16>; - resets = <&apb2_rst 16>; + clocks = <&ccu CLK_BUS_UART0>; + resets = <&ccu RST_BUS_UART0>; dmas = <&dma 6>, <&dma 6>; dma-names = "rx", "tx"; status = "disabled"; @@ -485,8 +392,8 @@ interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&apb2_gates 17>; - resets = <&apb2_rst 17>; + clocks = <&ccu CLK_BUS_UART1>; + resets = <&ccu RST_BUS_UART1>; dmas = <&dma 7>, <&dma 7>; dma-names = "rx", "tx"; status = "disabled"; @@ -498,8 +405,8 @@ interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&apb2_gates 18>; - resets = <&apb2_rst 18>; + clocks = <&ccu CLK_BUS_UART2>; + resets = <&ccu RST_BUS_UART2>; dmas = <&dma 8>, <&dma 8>; dma-names = "rx", "tx"; status = "disabled"; @@ -511,8 +418,8 @@ interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&apb2_gates 19>; - resets = <&apb2_rst 19>; + clocks = <&ccu CLK_BUS_UART3>; + resets = <&ccu RST_BUS_UART3>; dmas = <&dma 9>, <&dma 9>; dma-names = "rx", "tx"; status = "disabled"; @@ -524,8 +431,8 @@ interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&apb2_gates 20>; - resets = <&apb2_rst 20>; + clocks = <&ccu CLK_BUS_UART4>; + resets = <&ccu RST_BUS_UART4>; dmas = <&dma 10>, <&dma 10>; dma-names = "rx", "tx"; status = "disabled"; @@ -535,8 +442,8 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2ac00 0x400>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&apb2_gates 0>; - resets = <&apb2_rst 0>; + clocks = <&ccu CLK_BUS_I2C0>; + resets = <&ccu RST_BUS_I2C0>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -546,8 +453,8 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b000 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&apb2_gates 1>; - resets = <&apb2_rst 1>; + clocks = <&ccu CLK_BUS_I2C1>; + resets = <&ccu RST_BUS_I2C1>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -557,17 +464,44 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b400 0x400>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&apb2_gates 2>; - resets = <&apb2_rst 2>; + clocks = <&ccu CLK_BUS_I2C2>; + resets = <&ccu RST_BUS_I2C2>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
+ mali: gpu@1c40000 { + compatible = "allwinner,sun8i-a23-mali", + "allwinner,sun7i-a20-mali", "arm,mali-400"; + reg = <0x01c40000 0x10000>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gp", + "gpmmu", + "pp0", + "ppmmu0", + "pp1", + "ppmmu1", + "pmu"; + clocks = <&ccu CLK_BUS_GPU>, <&ccu CLK_GPU>; + clock-names = "bus", "core"; + resets = <&ccu RST_BUS_GPU>; + #cooling-cells = <2>; + + assigned-clocks = <&ccu CLK_GPU>; + assigned-clock-rates = <384000000>; + }; + gic: interrupt-controller@01c81000 { compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; reg = <0x01c81000 0x1000>, - <0x01c82000 0x1000>, + <0x01c82000 0x2000>, <0x01c84000 0x2000>, <0x01c86000 0x2000>; interrupt-controller; @@ -580,13 +514,16 @@ reg = <0x01f00000 0x54>; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + clock-output-names = "osc32k"; + clocks = <&ext_osc32k>; + #clock-cells = <1>; };
- nmi_intc: interrupt-controller@01f00c0c { - compatible = "allwinner,sun6i-a31-sc-nmi"; + nmi_intc: interrupt-controller@1f00c00 { + compatible = "allwinner,sun6i-a31-r-intc"; interrupt-controller; #interrupt-cells = <2>; - reg = <0x01f00c0c 0x38>; + reg = <0x01f00c00 0x400>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; };
@@ -632,6 +569,10 @@ compatible = "allwinner,sun6i-a31-clock-reset"; #reset-cells = <1>; }; + + codec_analog: codec-analog { + compatible = "allwinner,sun8i-a23-codec-analog"; + }; };
cpucfg@01f01c00 { @@ -654,7 +595,8 @@ compatible = "allwinner,sun8i-a23-r-pinctrl"; reg = <0x01f02c00 0x400>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&apb0_gates 0>; + clocks = <&apb0_gates 0>, <&osc24M>, <&rtc 0>; + clock-names = "apb", "hosc", "losc"; resets = <&apb0_rst 0>; gpio-controller; interrupt-controller; @@ -664,17 +606,15 @@ #gpio-cells = <3>;
r_rsb_pins: r_rsb { - allwinner,pins = "PL0", "PL1"; - allwinner,function = "s_rsb"; - allwinner,drive = <SUN4I_PINCTRL_20_MA>; - allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + pins = "PL0", "PL1"; + function = "s_rsb"; + drive-strength = <20>; + bias-pull-up; };
r_uart_pins_a: r_uart@0 { - allwinner,pins = "PL2", "PL3"; - allwinner,function = "s_uart"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PL2", "PL3"; + function = "s_uart"; }; };
diff --git a/arch/arm/dts/sun8i-a33-sinlinx-sina33.dts b/arch/arm/dts/sun8i-a33-sinlinx-sina33.dts index fef6abc0a703..b1bc88c46c67 100644 --- a/arch/arm/dts/sun8i-a33-sinlinx-sina33.dts +++ b/arch/arm/dts/sun8i-a33-sinlinx-sina33.dts @@ -61,6 +61,31 @@ chosen { stdout-path = "serial0:115200n8"; }; + + panel { + compatible = "netron-dy,e231732"; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + + panel_input: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon0_out_panel>; + }; + }; + }; +}; + +&de { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <®_dcdc3>; };
&ehci0 { @@ -207,12 +232,30 @@ regulator-name = "vcc-rtc"; };
+&tcon0 { + pinctrl-names = "default"; + pinctrl-0 = <&lcd_rgb666_pins>; + status = "okay"; +}; + +&tcon0_out { + tcon0_out_panel: endpoint@0 { + reg = <0>; + remote-endpoint = <&panel_input>; + }; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_b>; status = "okay"; };
+&usb_otg { + dr_mode = "peripheral"; + status = "okay"; +}; + &usbphy { status = "okay"; usb1_vbus-supply = <®_vcc5v0>; /* USB1 VBUS is always on */ diff --git a/arch/arm/dts/sun8i-a33.dtsi b/arch/arm/dts/sun8i-a33.dtsi index 001d8402ca18..22660919bd08 100644 --- a/arch/arm/dts/sun8i-a33.dtsi +++ b/arch/arm/dts/sun8i-a33.dtsi @@ -43,19 +43,137 @@ */
#include "sun8i-a23-a33.dtsi" +#include <dt-bindings/thermal/thermal.h>
/ { + cpu0_opp_table: opp_table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-120000000 { + opp-hz = /bits/ 64 <120000000>; + opp-microvolt = <1040000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-240000000 { + opp-hz = /bits/ 64 <240000000>; + opp-microvolt = <1040000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-312000000 { + opp-hz = /bits/ 64 <312000000>; + opp-microvolt = <1040000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <1040000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-480000000 { + opp-hz = /bits/ 64 <480000000>; + opp-microvolt = <1040000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-504000000 { + opp-hz = /bits/ 64 <504000000>; + opp-microvolt = <1040000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <1040000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-648000000 { + opp-hz = /bits/ 64 <648000000>; + opp-microvolt = <1040000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-720000000 { + opp-hz = /bits/ 64 <720000000>; + opp-microvolt = <1100000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1100000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-912000000 { + opp-hz = /bits/ 64 <912000000>; + opp-microvolt = <1200000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1200000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + }; + cpus { + cpu@0 { + clocks = <&ccu CLK_CPUX>; + clock-names = "cpu"; + operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; + }; + + cpu@1 { + operating-points-v2 = <&cpu0_opp_table>; + }; + cpu@2 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <2>; + operating-points-v2 = <&cpu0_opp_table>; };
cpu@3 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <3>; + operating-points-v2 = <&cpu0_opp_table>; + }; + }; + + de: display-engine { + compatible = "allwinner,sun8i-a33-display-engine"; + allwinner,pipelines = <&fe0>; + status = "disabled"; + }; + + iio-hwmon { + compatible = "iio-hwmon"; + io-channels = <&ths>; + }; + + mali_opp_table: gpu-opp-table { + compatible = "operating-points-v2"; + + opp-144000000 { + opp-hz = /bits/ 64 <144000000>; + }; + + opp-240000000 { + opp-hz = /bits/ 64 <240000000>; + }; + + opp-384000000 { + opp-hz = /bits/ 64 <384000000>; }; };
@@ -63,113 +181,310 @@ reg = <0x40000000 0x80000000>; };
- clocks { - /* Dummy clock for pll11 (DDR1) until actually implemented */ - pll11: pll11_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <0>; - clock-output-names = "pll11"; - }; - - ahb1_gates: clk@01c20060 { - #clock-cells = <1>; - compatible = "allwinner,sun8i-a33-ahb1-gates-clk"; - reg = <0x01c20060 0x8>; - clocks = <&ahb1>; - clock-indices = <1>, <5>, - <6>, <8>, <9>, - <10>, <13>, <14>, - <19>, <20>, - <21>, <24>, <26>, - <29>, <32>, <36>, - <40>, <44>, <46>, - <52>, <53>, - <54>, <57>, - <58>; - clock-output-names = "ahb1_mipidsi", "ahb1_ss", - "ahb1_dma","ahb1_mmc0", "ahb1_mmc1", - "ahb1_mmc2", "ahb1_nand", "ahb1_sdram", - "ahb1_hstimer", "ahb1_spi0", - "ahb1_spi1", "ahb1_otg", "ahb1_ehci", - "ahb1_ohci", "ahb1_ve", "ahb1_lcd", - "ahb1_csi", "ahb1_be", "ahb1_fe", - "ahb1_gpu", "ahb1_msgbox", - "ahb1_spinlock", "ahb1_drc", - "ahb1_sat"; - }; - - ss_clk: clk@01c2009c { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-mod0-clk"; - reg = <0x01c2009c 0x4>; - clocks = <&osc24M>, <&pll6 0>; - clock-output-names = "ss"; - }; - - mbus_clk: clk@01c2015c { - #clock-cells = <0>; - compatible = "allwinner,sun8i-a23-mbus-clk"; - reg = <0x01c2015c 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5>, <&pll11>; - clock-output-names = "mbus"; + sound: sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "sun8i-a33-audio"; + simple-audio-card,format = "i2s"; + simple-audio-card,frame-master = <&link_codec>; + simple-audio-card,bitclock-master = <&link_codec>; + simple-audio-card,mclk-fs = <512>; + simple-audio-card,aux-devs = <&codec_analog>; + simple-audio-card,routing = + "Left DAC", "AIF1 Slot 0 Left", + "Right DAC", "AIF1 Slot 0 Right"; + status = "disabled"; + + simple-audio-card,cpu { + sound-dai = <&dai>; + }; + + link_codec: simple-audio-card,codec { + sound-dai = <&codec>; }; };
soc@01c00000 { + tcon0: lcd-controller@01c0c000 { + compatible = "allwinner,sun8i-a33-tcon"; + reg = <0x01c0c000 0x1000>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_LCD>, + <&ccu CLK_LCD_CH0>; + clock-names = "ahb", + "tcon-ch0"; + clock-output-names = "tcon-pixel-clock"; + resets = <&ccu RST_BUS_LCD>; + reset-names = "lcd"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon0_in_drc0: endpoint@0 { + reg = <0>; + remote-endpoint = <&drc0_out_tcon0>; + }; + }; + + tcon0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + }; + }; + }; + crypto: crypto-engine@01c15000 { compatible = "allwinner,sun4i-a10-crypto"; reg = <0x01c15000 0x1000>; interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ahb1_gates 5>, <&ss_clk>; + clocks = <&ccu CLK_BUS_SS>, <&ccu CLK_SS>; clock-names = "ahb", "mod"; - resets = <&ahb1_rst 5>; + resets = <&ccu RST_BUS_SS>; reset-names = "ahb"; };
- usb_otg: usb@01c19000 { - compatible = "allwinner,sun8i-a33-musb"; - reg = <0x01c19000 0x0400>; - clocks = <&ahb1_gates 24>; - resets = <&ahb1_rst 24>; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "mc"; - phys = <&usbphy 0>; - phy-names = "usb"; - extcon = <&usbphy 0>; + dai: dai@01c22c00 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun6i-a31-i2s"; + reg = <0x01c22c00 0x200>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CODEC>, <&ccu CLK_AC_DIG>; + clock-names = "apb", "mod"; + resets = <&ccu RST_BUS_CODEC>; + dmas = <&dma 15>, <&dma 15>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + codec: codec@01c22e00 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-a33-codec"; + reg = <0x01c22e00 0x400>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CODEC>, <&ccu CLK_AC_DIG>; + clock-names = "bus", "mod"; status = "disabled"; };
- usbphy: phy@01c19400 { - compatible = "allwinner,sun8i-a33-usb-phy"; - reg = <0x01c19400 0x14>, - <0x01c1a800 0x4>; - reg-names = "phy_ctrl", - "pmu1"; - clocks = <&usb_clk 8>, - <&usb_clk 9>; - clock-names = "usb0_phy", - "usb1_phy"; - resets = <&usb_clk 0>, - <&usb_clk 1>; - reset-names = "usb0_reset", - "usb1_reset"; + ths: ths@01c25000 { + compatible = "allwinner,sun8i-a33-ths"; + reg = <0x01c25000 0x100>; + #thermal-sensor-cells = <0>; + #io-channel-cells = <0>; + }; + + fe0: display-frontend@01e00000 { + compatible = "allwinner,sun8i-a33-display-frontend"; + reg = <0x01e00000 0x20000>; + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>, + <&ccu CLK_DRAM_DE_FE>; + clock-names = "ahb", "mod", + "ram"; + resets = <&ccu RST_BUS_DE_FE>; status = "disabled"; - #phy-cells = <1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + fe0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + fe0_out_be0: endpoint@0 { + reg = <0>; + remote-endpoint = <&be0_in_fe0>; + }; + }; + }; + }; + + be0: display-backend@01e60000 { + compatible = "allwinner,sun8i-a33-display-backend"; + reg = <0x01e60000 0x10000>, <0x01e80000 0x1000>; + reg-names = "be", "sat"; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>, + <&ccu CLK_DRAM_DE_BE>, <&ccu CLK_BUS_SAT>; + clock-names = "ahb", "mod", + "ram", "sat"; + resets = <&ccu RST_BUS_DE_BE>, <&ccu RST_BUS_SAT>; + reset-names = "be", "sat"; + assigned-clocks = <&ccu CLK_DE_BE>; + assigned-clock-rates = <300000000>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + be0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + be0_in_fe0: endpoint@0 { + reg = <0>; + remote-endpoint = <&fe0_out_be0>; + }; + }; + + be0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + be0_out_drc0: endpoint@0 { + reg = <0>; + remote-endpoint = <&drc0_in_be0>; + }; + }; + }; + }; + + drc0: drc@01e70000 { + compatible = "allwinner,sun8i-a33-drc"; + reg = <0x01e70000 0x10000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DRC>, <&ccu CLK_DRC>, + <&ccu CLK_DRAM_DRC>; + clock-names = "ahb", "mod", "ram"; + resets = <&ccu RST_BUS_DRC>; + + assigned-clocks = <&ccu CLK_DRC>; + assigned-clock-rates = <300000000>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + drc0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + drc0_in_be0: endpoint@0 { + reg = <0>; + remote-endpoint = <&be0_out_drc0>; + }; + }; + + drc0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + drc0_out_tcon0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon0_in_drc0>; + }; + }; + }; + }; + }; + + thermal-zones { + cpu_thermal { + /* milliseconds */ + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&ths>; + + cooling-maps { + map0 { + trip = <&cpu_alert0>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu_alert1>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + + map2 { + trip = <&gpu_alert0>; + cooling-device = <&mali 1 THERMAL_NO_LIMIT>; + }; + + map3 { + trip = <&gpu_alert1>; + cooling-device = <&mali 2 THERMAL_NO_LIMIT>; + }; + }; + + trips { + cpu_alert0: cpu_alert0 { + /* milliCelsius */ + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + + gpu_alert0: gpu_alert0 { + /* milliCelsius */ + temperature = <85000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu_alert1: cpu_alert1 { + /* milliCelsius */ + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + + gpu_alert1: gpu_alert1 { + /* milliCelsius */ + temperature = <95000>; + hysteresis = <2000>; + type = "hot"; + }; + + cpu_crit: cpu_crit { + /* milliCelsius */ + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; }; }; };
+&ccu { + compatible = "allwinner,sun8i-a33-ccu"; +}; + +&mali { + operating-points-v2 = <&mali_opp_table>; +}; + &pio { compatible = "allwinner,sun8i-a33-pinctrl"; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
uart0_pins_b: uart0@1 { - allwinner,pins = "PB0", "PB1"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + pins = "PB0", "PB1"; + function = "uart0"; };
}; + +&usb_otg { + compatible = "allwinner,sun8i-a33-musb"; +}; + +&usbphy { + compatible = "allwinner,sun8i-a33-usb-phy"; + reg = <0x01c19400 0x14>, <0x01c1a800 0x4>; + reg-names = "phy_ctrl", "pmu1"; +}; diff --git a/include/dt-bindings/clock/sun8i-a23-a33-ccu.h b/include/dt-bindings/clock/sun8i-a23-a33-ccu.h new file mode 100644 index 000000000000..f8222b6b2cc3 --- /dev/null +++ b/include/dt-bindings/clock/sun8i-a23-a33-ccu.h @@ -0,0 +1,127 @@ +/* + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN8I_A23_A33_H_ +#define _DT_BINDINGS_CLK_SUN8I_A23_A33_H_ + +#define CLK_CPUX 18 + +#define CLK_BUS_MIPI_DSI 23 +#define CLK_BUS_SS 24 +#define CLK_BUS_DMA 25 +#define CLK_BUS_MMC0 26 +#define CLK_BUS_MMC1 27 +#define CLK_BUS_MMC2 28 +#define CLK_BUS_NAND 29 +#define CLK_BUS_DRAM 30 +#define CLK_BUS_HSTIMER 31 +#define CLK_BUS_SPI0 32 +#define CLK_BUS_SPI1 33 +#define CLK_BUS_OTG 34 +#define CLK_BUS_EHCI 35 +#define CLK_BUS_OHCI 36 +#define CLK_BUS_VE 37 +#define CLK_BUS_LCD 38 +#define CLK_BUS_CSI 39 +#define CLK_BUS_DE_BE 40 +#define CLK_BUS_DE_FE 41 +#define CLK_BUS_GPU 42 +#define CLK_BUS_MSGBOX 43 +#define CLK_BUS_SPINLOCK 44 +#define CLK_BUS_DRC 45 +#define CLK_BUS_SAT 46 +#define CLK_BUS_CODEC 47 +#define CLK_BUS_PIO 48 +#define CLK_BUS_I2S0 49 +#define CLK_BUS_I2S1 50 +#define CLK_BUS_I2C0 51 +#define CLK_BUS_I2C1 52 +#define CLK_BUS_I2C2 53 +#define CLK_BUS_UART0 54 +#define CLK_BUS_UART1 55 +#define CLK_BUS_UART2 56 +#define CLK_BUS_UART3 57 +#define CLK_BUS_UART4 58 +#define CLK_NAND 59 +#define CLK_MMC0 60 +#define CLK_MMC0_SAMPLE 61 +#define CLK_MMC0_OUTPUT 62 +#define CLK_MMC1 63 +#define CLK_MMC1_SAMPLE 64 +#define CLK_MMC1_OUTPUT 65 +#define CLK_MMC2 66 +#define CLK_MMC2_SAMPLE 67 +#define CLK_MMC2_OUTPUT 68 +#define CLK_SS 69 +#define CLK_SPI0 70 +#define CLK_SPI1 71 +#define CLK_I2S0 72 +#define CLK_I2S1 73 +#define CLK_USB_PHY0 74 +#define CLK_USB_PHY1 75 +#define CLK_USB_HSIC 76 +#define CLK_USB_HSIC_12M 77 +#define CLK_USB_OHCI 78 + +#define CLK_DRAM_VE 80 +#define CLK_DRAM_CSI 81 +#define CLK_DRAM_DRC 82 +#define CLK_DRAM_DE_FE 83 +#define CLK_DRAM_DE_BE 84 +#define CLK_DE_BE 85 +#define CLK_DE_FE 86 +#define CLK_LCD_CH0 87 +#define CLK_LCD_CH1 88 +#define CLK_CSI_SCLK 89 +#define CLK_CSI_MCLK 90 +#define CLK_VE 91 +#define CLK_AC_DIG 92 +#define CLK_AC_DIG_4X 93 +#define CLK_AVS 94 + +#define CLK_DSI_SCLK 96 +#define CLK_DSI_DPHY 97 +#define CLK_DRC 98 +#define CLK_GPU 99 +#define CLK_ATS 100 + +#endif /* _DT_BINDINGS_CLK_SUN8I_A23_A33_H_ */ diff --git a/include/dt-bindings/reset/sun8i-a23-a33-ccu.h b/include/dt-bindings/reset/sun8i-a23-a33-ccu.h new file mode 100644 index 000000000000..6121f2b0cd0a --- /dev/null +++ b/include/dt-bindings/reset/sun8i-a23-a33-ccu.h @@ -0,0 +1,87 @@ +/* + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_RST_SUN8I_A23_A33_H_ +#define _DT_BINDINGS_RST_SUN8I_A23_A33_H_ + +#define RST_USB_PHY0 0 +#define RST_USB_PHY1 1 +#define RST_USB_HSIC 2 +#define RST_MBUS 3 +#define RST_BUS_MIPI_DSI 4 +#define RST_BUS_SS 5 +#define RST_BUS_DMA 6 +#define RST_BUS_MMC0 7 +#define RST_BUS_MMC1 8 +#define RST_BUS_MMC2 9 +#define RST_BUS_NAND 10 +#define RST_BUS_DRAM 11 +#define RST_BUS_HSTIMER 12 +#define RST_BUS_SPI0 13 +#define RST_BUS_SPI1 14 +#define RST_BUS_OTG 15 +#define RST_BUS_EHCI 16 +#define RST_BUS_OHCI 17 +#define RST_BUS_VE 18 +#define RST_BUS_LCD 19 +#define RST_BUS_CSI 20 +#define RST_BUS_DE_BE 21 +#define RST_BUS_DE_FE 22 +#define RST_BUS_GPU 23 +#define RST_BUS_MSGBOX 24 +#define RST_BUS_SPINLOCK 25 +#define RST_BUS_DRC 26 +#define RST_BUS_SAT 27 +#define RST_BUS_LVDS 28 +#define RST_BUS_CODEC 29 +#define RST_BUS_I2S0 30 +#define RST_BUS_I2S1 31 +#define RST_BUS_I2C0 32 +#define RST_BUS_I2C1 33 +#define RST_BUS_I2C2 34 +#define RST_BUS_UART0 35 +#define RST_BUS_UART1 36 +#define RST_BUS_UART2 37 +#define RST_BUS_UART3 38 +#define RST_BUS_UART4 39 + +#endif /* _DT_BINDINGS_RST_SUN8I_A23_A33_H_ */
- Copyright 2016 Free Electrons
- Quentin Schulz quentin.schulz@free-electrons.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- AXP223 Integrated Power Management Chip
- The AXP223 shares most of its logic with the AXP221 but it has some
- differences, for the VBUS driver for example.
- compatible = "x-powers,axp223-usb-power-supply";
- ac_power_supply: ac-power-supply {
- battery_power_supply: battery-power-supply {
- regulators { /* Default work frequency for buck regulators */ x-powers,dcdc-freq = <3000>;
clocks = <&pll6 0>;
}; };<&ccu CLK_DRAM_DE_BE>, <&ccu CLK_DRC>; status = "disabled";
cpu@0 {
};clock-accuracy = <50000>; clock-output-names = "osc24M";
#clock-cells = <0>;
clocks = <&osc24M>;
pll5: pll5_clk {
#clock-cells = <0>;
#clock-cells = <1>;
clocks = <&osc24M>;
#clock-cells = <0>;
* Allwinner.
#clock-cells = <0>;
clocks = <&cpu>;
#clock-cells = <0>;
#clock-cells = <0>;
clocks = <&ahb1>;
#clock-cells = <1>;
clocks = <&apb1>;
<12>, <13>;
#clock-cells = <0>;
#clock-cells = <1>;
clocks = <&apb2>;
<2>, <16>,
<17>, <18>,
<19>, <20>;
#clock-cells = <1>;
"mmc0_output",
"mmc0_sample";
#clock-cells = <1>;
"mmc1_output",
"mmc1_sample";
#clock-cells = <1>;
"mmc2_output",
"mmc2_sample";
#clock-cells = <1>;
#reset-cells = <1>;
clocks = <&osc24M>;
}; };clock-output-names = "ext-osc32k";
<&mmc0_clk 0>,
<&mmc0_clk 1>,
<&mmc0_clk 2>;
<&ccu CLK_MMC0>,
<&mmc1_clk 0>,
<&mmc1_clk 1>,
<&mmc1_clk 2>;
<&ccu CLK_MMC1>,
<&mmc2_clk 0>,
<&mmc2_clk 1>,
<&mmc2_clk 2>;
<&ccu CLK_MMC2>,
#size-cells = <0>;
phys = <&usbphy 0>;
phy-names = "usb";
"usb1_phy";
"usb1_reset";
#phy-cells = <1>;
- ehci0: usb@01c1a000 { compatible = "allwinner,sun8i-a23-ehci", "generic-ehci"; reg = <0x01c1a000 0x100>; interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
#clock-cells = <1>;
#reset-cells = <1>;
clock-names = "apb", "hosc", "losc"; gpio-controller; interrupt-controller; #interrupt-cells = <3>; #gpio-cells = <3>; uart0_pins_a: uart0@0 {
function = "uart0";
function = "uart1";
function = "uart1"; }; mmc0_pins_a: mmc0@0 {
function = "mmc0";
bias-pull-up; }; mmc1_pins_a: mmc1@0 {
function = "mmc1";
bias-pull-up; }; mmc2_8bit_pins: mmc2_8bit {
"PC15", "PC16";
"PC15", "PC16";
function = "mmc2";
bias-pull-up; }; pwm0_pins: pwm0 {
pins = "PH0";
function = "pwm0"; }; i2c0_pins_a: i2c0@0 {
function = "i2c0"; }; i2c1_pins_a: i2c1@0 {
function = "i2c1"; }; i2c2_pins_a: i2c2@0 {
#reset-cells = <1>;
#reset-cells = <1>;
#reset-cells = <1>;
function = "lcd0";
timer@01c20c00 {
mali: gpu@1c40000 {
"gpmmu",
"pp0",
"ppmmu0",
"pp1",
"ppmmu1",
"pmu";
};#clock-cells = <1>;
};reg = <0x01f00c00 0x400>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
cpucfg@01f01c00 {
r_rsb_pins: r_rsb {
function = "s_rsb";
bias-pull-up; }; r_uart_pins_a: r_uart@0 {
};function = "s_uart"; };
- panel {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
reg = <0>;
+&de {
- status = "okay";
+&cpu0 {
&ehci0 {
+&tcon0 {
- pinctrl-names = "default";
- pinctrl-0 = <&lcd_rgb666_pins>;
- status = "okay";
+&tcon0_out {
- tcon0_out_panel: endpoint@0 {
reg = <0>;
- &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_b>; status = "okay"; };
+&usb_otg {
- dr_mode = "peripheral";
- status = "okay";
- &usbphy { status = "okay"; usb1_vbus-supply = <®_vcc5v0>; /* USB1 VBUS is always on */
opp-shared;
opp-120000000 {
opp-240000000 {
opp-312000000 {
opp-408000000 {
opp-480000000 {
opp-504000000 {
opp-600000000 {
opp-648000000 {
opp-720000000 {
opp-816000000 {
opp-912000000 {
opp-1008000000 {
cpus {
cpu@0 {
cpu@1 {
iio-hwmon {
opp-144000000 {
opp-240000000 {
opp-384000000 {
- clocks {
pll11: pll11_clk {
#clock-cells = <0>;
#clock-cells = <1>;
clocks = <&ahb1>;
<6>, <8>, <9>,
<10>, <13>, <14>,
<19>, <20>,
<21>, <24>, <26>,
<29>, <32>, <36>,
<40>, <44>, <46>,
<52>, <53>,
<54>, <57>,
<58>;
"ahb1_sat";
#clock-cells = <0>;
#clock-cells = <0>;
sound: sound {
sound-dai = <&dai>;
soc@01c00000 {
<&ccu CLK_LCD_CH0>;
"tcon-ch0";
ports {
#size-cells = <0>;
tcon0_in: port@0 {
#size-cells = <0>;
reg = <0>;
reg = <0>;
tcon0_out: port@1 {
#size-cells = <0>;
reg = <1>;
};resets = <&ccu RST_BUS_SS>; reset-names = "ahb";
phys = <&usbphy 0>;
phy-names = "usb";
dai: dai@01c22c00 {
};clock-names = "bus", "mod"; status = "disabled";
<0x01c1a800 0x4>;
"pmu1";
<&usb_clk 9>;
"usb1_phy";
<&usb_clk 1>;
"usb1_reset";
ths: ths@01c25000 {
"ram";
#phy-cells = <1>;
ports {
#size-cells = <0>;
fe0_out: port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
"ram", "sat";
ports {
#size-cells = <0>;
be0_in: port@0 {
#size-cells = <0>;
reg = <0>;
reg = <0>;
be0_out: port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
ports {
#size-cells = <0>;
drc0_in: port@0 {
#size-cells = <0>;
reg = <0>;
reg = <0>;
drc0_out: port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
- thermal-zones {
cpu_thermal {
/* milliseconds */
cooling-maps {
map0 {
map1 {
map2 {
map3 {
trips {
/* milliCelsius */
type = "passive";
/* milliCelsius */
type = "passive";
/* milliCelsius */
type = "hot";
/* milliCelsius */
type = "hot";
/* milliCelsius */
type = "critical";
+&ccu {
- compatible = "allwinner,sun8i-a33-ccu";
+&mali {
- operating-points-v2 = <&mali_opp_table>;
function = "uart0";
+&usb_otg {
+&usbphy {
- reg = <0x01c19400 0x14>, <0x01c1a800 0x4>;
- reg-names = "phy_ctrl", "pmu1";
- Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com
- whole.
conditions:
- whole.
conditions:
Shouldn't we use the SPDX license header?
Tom what is the policy for importing dts[i] files from Linux kernel?
Reviewed-by: Łukasz Majewski lukma@denx.de
Hi Maxime,
This serie aims at fixing an issue we had to carry out of tree patches for for a few years.
The issue is this: a significant number of Allwinner boards don't have an Ethernet connection, while an Ethernet connection is pretty useful for example during development to do some PXE/NFS boot.
However, we needed to have DM_ETH enabled for the boards that use our Ethernet controller drivers that rely on it. It meant having to use the newly introduced DM_ETH support in the usb_ether gadget, but our musb peripheral wasn't converted to the device model, and therefore not usable with it.
The other alternative was to use the old-style usb_ether driver, which worked fine but were disabling the Ethernet controller driver.
Thus, none were good, upstreamable solution.
Fix this properly by adding support for the musb in peripheral mode in the device model. While we're doing so, I also took the occasion to move a number of configuration options to Kconfig, and rework the dependencies between them to ease the selection of related options while trying to avoid as much as possible the combinations that are not valid.
This was tested on a Sinlinx SinA33 that is wired as a peripheral-only mUSB.
Let me know what you think,
Thanks for your effort. I've ack'ed gadget relevant commits, so I think that this series should go through the sunxi tree.
Best regards, Łukasz
Maxime
Changes from v1:
- Rebased on v2017.09
- Added some help on a number of options introduced
- Added the various tags collected
Maxime Ripard (14): usb: gadget: Move USBNET_DEVADDR option out of g_dnl usb: gadget: Document USBNET_DEVADDR usb: gadget: Move USBNET_HOST_ADDR to Kconfig usb: gadget: Convert USB_ETHER to Kconfig usb: gadget: usb_ether: Move the interfaces to Kconfig usb: gadget: Make g_dnl USB settings common usb: gadget: usb_ether: Move settings to common sunxi: provide default USB gadget setup sunxi: imply USB_GADGET cmd: fastboot: Rework fastboot dependency musb: sunxi: switch to the device model sunxi: Register usb_ether sunxi: Imply USB_ETHER sunxi: sina33: Sync the device tree with the kernel
arch/arm/Kconfig | 4 +- arch/arm/dts/axp223.dtsi | 58 ++- arch/arm/dts/axp22x.dtsi | 10 +- arch/arm/dts/sun8i-a23-a33.dtsi | 446 ++++++--------- arch/arm/dts/sun8i-a33-sinlinx-sina33.dts | 43 +- arch/arm/dts/sun8i-a33.dtsi | 477 +++++++++++++--- arch/arm/include/asm/arch-sunxi/usb_phy.h | 7 +- board/samsung/common/gadget.c | 4 +- board/siemens/common/factoryset.c | 4 +- board/sunxi/board.c | 3 +- cmd/fastboot/Kconfig | 4 +- configs/A13-OLinuXino_defconfig | 5 +- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 5 +- configs/A20-OLinuXino-Lime2_defconfig | 5 +- configs/CHIP_defconfig | 5 +- configs/CHIP_pro_defconfig | 5 +- configs/Cubietruck_defconfig | 5 +- configs/Nintendo_NES_Classic_Edition_defconfig | 5 +- configs/Sinlinx_SinA33_defconfig | 5 +- configs/am335x_baltos_defconfig | 8 +- configs/am335x_boneblack_defconfig | 10 +- configs/am335x_boneblack_vboot_defconfig | 9 +- configs/am335x_evm_defconfig | 9 +- configs/am335x_evm_nor_defconfig | 9 +- configs/am335x_evm_norboot_defconfig | 10 +- configs/am335x_evm_spiboot_defconfig | 9 +- configs/am335x_evm_usbspl_defconfig | 9 +- configs/am335x_hs_evm_defconfig | 7 +- configs/am43xx_evm_defconfig | 6 +- configs/am43xx_evm_ethboot_defconfig | 6 +- configs/am43xx_evm_qspiboot_defconfig | 6 +- configs/am43xx_evm_usbhost_boot_defconfig | 6 +- configs/am43xx_hs_evm_defconfig | 6 +- configs/am57xx_evm_defconfig | 8 +- configs/am57xx_evm_nodt_defconfig | 9 +- configs/am57xx_hs_evm_defconfig | 8 +- configs/apalis-tk1_defconfig | 6 +- configs/apalis_imx6_defconfig | 6 +- configs/apalis_imx6_nospl_com_defconfig | 6 +- configs/apalis_imx6_nospl_it_defconfig | 6 +- configs/apalis_t30_defconfig | 6 +- configs/bcm11130_defconfig | 6 +- configs/bcm11130_nand_defconfig | 6 +- configs/bcm23550_w1d_defconfig | 9 +- configs/bcm28155_ap_defconfig | 9 +- configs/bcm28155_w1d_defconfig | 6 +- configs/beaver_defconfig | 6 +- configs/birdland_bav335a_defconfig | 9 +- configs/birdland_bav335b_defconfig | 9 +- configs/cei-tk1-som_defconfig | 6 +- configs/cgtqmx6eval_defconfig | 9 +- configs/chromebit_mickey_defconfig | 7 +- configs/chromebook_jerry_defconfig | 7 +- configs/chromebook_minnie_defconfig | 7 +- configs/colibri_imx6_defconfig | 6 +- configs/colibri_imx6_nospl_defconfig | 6 +- configs/colibri_imx7_defconfig | 6 +- configs/colibri_t20_defconfig | 6 +- configs/colibri_t30_defconfig | 6 +- configs/colibri_vf_defconfig | 6 +- configs/corvus_defconfig | 6 +- configs/dalmore_defconfig | 6 +- configs/dms-ba16-1g_defconfig | 6 +- configs/dms-ba16_defconfig | 6 +- configs/dra7xx_evm_defconfig | 8 +- configs/dra7xx_hs_evm_defconfig | 8 +- configs/draco_defconfig | 7 +- configs/e2220-1170_defconfig | 6 +- configs/edison_defconfig | 6 +- configs/etamin_defconfig | 7 +- configs/evb-rk3036_defconfig | 7 +- configs/evb-rk3229_defconfig | 7 +- configs/evb-rk3288_defconfig | 7 +- configs/evb-rk3328_defconfig | 6 +- configs/fennec-rk3288_defconfig | 7 +- configs/firefly-rk3288_defconfig | 7 +- configs/gwventana_emmc_defconfig | 8 +- configs/gwventana_gw5904_defconfig | 8 +- configs/gwventana_nand_defconfig | 8 +- configs/jetson-tk1_defconfig | 6 +- configs/kc1_defconfig | 9 +- configs/kylin-rk3036_defconfig | 7 +- configs/ma5d4evk_defconfig | 7 +- configs/miqi-rk3288_defconfig | 7 +- configs/mx6qsabrelite_defconfig | 11 +- configs/mx6sabreauto_defconfig | 6 +- configs/mx6sabresd_defconfig | 6 +- configs/mx7dsabresd_defconfig | 6 +- configs/mx7dsabresd_secure_defconfig | 6 +- configs/nitrogen6dl2g_defconfig | 11 +- configs/nitrogen6dl_defconfig | 11 +- configs/nitrogen6q2g_defconfig | 11 +- configs/nitrogen6q_defconfig | 11 +- configs/nitrogen6s1g_defconfig | 11 +- configs/nitrogen6s_defconfig | 11 +- configs/novena_defconfig | 2 +- configs/nyan-big_defconfig | 6 +- configs/odroid-xu3_defconfig | 6 +- configs/odroid_defconfig | 6 +- configs/omap3_beagle_defconfig | 10 +- configs/omap3_evm_defconfig | 7 +- configs/omap3_logic_defconfig | 9 +- configs/omap5_uevm_defconfig | 6 +- configs/opos6uldev_defconfig | 6 +- configs/origen_defconfig | 6 +- configs/p2371-0000_defconfig | 6 +- configs/p2371-2180_defconfig | 6 +- configs/p2571_defconfig | 6 +- configs/parrot_r16_defconfig | 5 +- configs/pcm051_rev1_defconfig | 1 +- configs/pcm051_rev3_defconfig | 1 +- configs/phycore-rk3288_defconfig | 7 +- configs/pico-imx6ul_defconfig | 6 +- configs/pico-imx7d_defconfig | 6 +- configs/popmetal-rk3288_defconfig | 7 +- configs/pxm2_defconfig | 8 +- configs/rastaban_defconfig | 8 +- configs/rock2_defconfig | 7 +- configs/rut_defconfig | 7 +- configs/s5p_goni_defconfig | 6 +- configs/s5pc210_universal_defconfig | 6 +- configs/sama5d2_ptc_nandflash_defconfig | 2 +- configs/sama5d2_ptc_spiflash_defconfig | 2 +- configs/sansa_fuze_plus_defconfig | 2 +- configs/smartweb_defconfig | 6 +- configs/sniper_defconfig | 9 +- configs/socfpga_arria5_defconfig | 6 +- configs/socfpga_cyclone5_defconfig | 6 +- configs/socfpga_de0_nano_soc_defconfig | 6 +- configs/socfpga_de10_nano_defconfig | 6 +- configs/socfpga_mcvevk_defconfig | 6 +- configs/socfpga_sockit_defconfig | 6 +- configs/socfpga_socrates_defconfig | 6 +- configs/socfpga_vining_fpga_defconfig | 6 +- configs/taurus_defconfig | 6 +- configs/tbs2910_defconfig | 6 +- configs/thuban_defconfig | 7 +- configs/tinker-rk3288_defconfig | 7 +- configs/topic_miami_defconfig | 6 +- configs/topic_miamilite_defconfig | 6 +- configs/topic_miamiplus_defconfig | 6 +- configs/trats2_defconfig | 6 +- configs/trats_defconfig | 6 +- configs/venice2_defconfig | 6 +- configs/vinco_defconfig | 2 +- configs/warp7_defconfig | 9 +- configs/warp7_secure_defconfig | 9 +- configs/warp_defconfig | 6 +- configs/xfi3_defconfig | 2 +- configs/xilinx_zynqmp_ep_defconfig | 6 +- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 6 +- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 6 +- configs/xilinx_zynqmp_zcu102_revA_defconfig | 6 +- configs/xilinx_zynqmp_zcu102_revB_defconfig | 6 +- configs/zynq_microzed_defconfig | 6 +- configs/zynq_picozed_defconfig | 6 +- configs/zynq_z_turn_defconfig | 6 +- configs/zynq_zc702_defconfig | 6 +- configs/zynq_zc706_defconfig | 6 +- configs/zynq_zed_defconfig | 6 +- configs/zynq_zybo_defconfig | 6 +- doc/README.android-fastboot | 8 +- drivers/usb/gadget/Kconfig | 78 ++- drivers/usb/gadget/ether.c | 16 +- drivers/usb/gadget/g_dnl.c | 12 +- drivers/usb/musb-new/sunxi.c | 56 +-- include/configs/am335x_evm.h | 6 +- include/configs/am3517_evm.h | 5 +- include/configs/am43xx_evm.h | 6 +- include/configs/baltos.h | 6 +- include/configs/gw_ventana.h | 2 +- include/configs/h2200.h | 2 +- include/configs/ma5d4evk.h | 3 +- include/configs/nitrogen6x.h | 2 +- include/configs/novena.h | 2 +- include/configs/odroid_xu3.h | 2 +- include/configs/omap3_beagle.h | 1 +- include/configs/omap3_evm.h | 1 +- include/configs/omap3_logic.h | 1 +- include/configs/pcm051.h | 5 +- include/configs/sama5d2_ptc.h | 3 +- include/configs/sansa_fuze_plus.h | 2 +- include/configs/siemens-am33x-common.h | 6 +- include/configs/tao3530.h | 2 +- include/configs/vinco.h | 3 +- include/configs/warp7.h | 4 +- include/configs/xfi3.h | 2 +- include/dt-bindings/clock/sun8i-a23-a33-ccu.h | 127 ++++- include/dt-bindings/reset/sun8i-a23-a33-ccu.h | 87 +++- scripts/config_whitelist.txt | 5 +- 190 files changed, 1509 insertions(+), 999 deletions(-) create mode 100644 arch/arm/dts/axp223.dtsi create mode 100644 include/dt-bindings/clock/sun8i-a23-a33-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-a23-a33-ccu.h
base-commit: c98ac3487e413c71e5d36322ef3324b21c6f60f9
Hi Łukasz,
On Wed, Sep 13, 2017 at 12:53:25PM +0200, Łukasz Majewski wrote:
Hi Maxime,
I just applied them to the sunxi/master branch, with both Simon's and your tags added.
(Jagan, if it's not the right branch, please tell me. I'm still getting used to the u-boot way of managing branches).
Thanks! Maxime
Chen-Yu Tsai
Maxime Ripard
Łukasz Majewski
