Hey All,
We are working on a Freescale Development Board (the MPC8315E-RDB). We have used this board in the past with u-boot and it worked perfectly. However now that we are trying to use it again - we seem to be having some trouble getting the network working. We have tried the following with a number of u-boot.bin files (version 1.3.0 the latest 2009.03 version from the git repository, and a couple of more from Freescale). However we are having no luck.
We erased the flash on the board and every since then cannot get a ping reply from any deivce on our network, and we cannot ping the board itself.
Our set up is very simple we have: • Hub connecting all the devices • Server plugged in with light on (192.168.0.31) • TFTP server plugged in with the light on (192.168.0.22) • MY laptop plugged in with light on (192.168.0.202) • The Freescale board with light on (192.168.0.109) - thus it can detect the pressense of the board on the hub
When we try and ping with no cable plugged in we get the following:
=> ping 192.168.0.31 eTSEC1: No link. eTSEC0: No Link. Using eTSEC0 device ping failed; host 192.168.0.31 is not alive
When we try and ping with a cable plugged in we get the following:
=> ping 192.168.0.31 Speed: 100, full duplex Using eTSEC0 device ping failed; host 192.168.0.31 is not alive
Since all the lights on the hub are on we once again know that it is able to detect the presence of the cable on the board. Also since the board can detect the pressense of a cable it seems to be working, at least on the physical layer. Is there anything one must do to ensure that u-boot has network support? We have built editted versions as well us just extracting u-boot, building it and programming it. Nothing seems to be working.
Regards,
Louis
Another quick question. Since the Ethernet devices seem to both be working on the physical layer (we can detect the cable plugged in) it must be a software related problem. How does u-boot use the Ethernet chips, i.e. s to awhere does it get driver to actually perform ping and tftp commands? I know tsec.c there is phy_info data. Is this basically what u-boot uses as the dirvers?
Regards
Louis
On Wed, Mar 18, 2009 at 12:02 PM, Louis Ruch louisruch@gmail.com wrote:
Hey All,
Regards,
Louis
Dear Louis Ruch,
In message 85a17cd50903180302x62c0f6c1u11e4876452608130@mail.gmail.com you wrote:
Did you check your environment settings, especially the MAC addresses? Did you use valid MAC addresses?
Hey Wolfgang,
Here is the printenv of my u-boot, it seems that the MAC addresses on the development boards are set to a standard which does not change, since I got a printenv from freescale where they have the ping working and they have the same ethaddr as I do on my dev board:
Here is my printenv:
=> printenv
bootcmd=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr -$fdtaddrramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddrnfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr\
bootdelay=6
baudrate=115200
loads_echo=1
ethaddr=04:00:00:00:00:0A
eth1addr=04:00:00:00:00:0B
loadaddr=200000
netdev=eth0
consoledev=ttyS0
ramdiskaddr=1000000
ramdiskfile=ramfs.83xx
fdtaddr=400000
fdtfile=mpc8315erdb.dtb
stdin=serial
stdout=serial
stderr=serial
ethact=eTSEC0
ipaddr=192.168.0.109
serverip=192.168.0.22
gatewayip=192.168.0.31
Environment size: 1043/8188 bytes
Using eTSEC0 device
Here is the printenv from Freescale where they are able to successfully ping another device on their network:
=> printenv ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr bootdelay=6 baudrate=115200 loads_echo=1 ethaddr=04:00:00:00:00:0A eth1addr=04:00:00:00:00:0B loadaddr=200000 netdev=eth0 consoledev=ttyS0 ramdiskaddr=1000000 ramdiskfile=ramfs.83xx fdtaddr=400000 bootcmd=setenv bootargs root=/dev/nfs rw nfsroot=10.192.208.120: rootpath=/tftpboot/10.192.208.246 bootcmd=setenv bootargs root=/dev/nfs rw nfsroot=10.192.208.120:/tftpboot/ 10.192.208.246 fdtfile=/tftpboot/mpc8315.dtb bootfile=/tftpboot/uImage stdin=serial stdout=serial stderr=serial gatewayip=10.192.208.254 serverip=10.192.208.120 ipaddr=10.192.208.246 ethact=eTSEC0
Environment size: 1019/8188 bytes => ping 10.192.208.120 Speed: 100, full duplex Using eTSEC0 device host 10.192.208.120 is alive =>
On Wed, Mar 18, 2009 at 1:23 PM, Wolfgang Denk wd@denx.de wrote:
Dear Louis Ruch,
itself. ...
to
extracting
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de All repairs tend to destroy the structure, to increase the entropy and disorder of the system. Less and less effort is spent on fixing original design flaws; more and more is spent on fixing flaws intro- duced by earlier fixes. - Fred Brooks, "The Mythical Man Month"
Louis Ruch
