[PATCH v4 00/14] arm: add support for SoC S5P4418
This patch adds support for SAMSUNG's/NEXELL's ARM Cortex-A9 based S5P4418 SoC, especially FriendlyARM's NanoPi2 and NanoPC-T2 boards. It is based on the following FriendlyARM's U-Boot version: https://github.com/friendlyarm/u-boot/tree/nanopi2-v2016.01.
Main changes in relation to nanopi2-v2016.01: - Cosmetic changes due to patman warnings/errors. - MMC and Video drivers changed to DM. - Configs reworked (e.g. "CONFIG_..." moved from s5p4418_nanopi2.h to s5p4418_nanopi2_defconfig) - SPL related files are not included. - MACH_TYPE_S5P4418 is not defined/used anymore. - arch/arm/mach-nexell/include/mach/boot0.h added to generate the NSIH (Nexell System Information Header), substitudes tools/nexell. - board/s5p4418/ renamed to board/friendlyarm/ - Only the NanoPi2 and NanoPC-T2 boards are supported yet because I do only have the NanoPC-T2 board to test the code (this board uses the NanoPi2 code). - USB is not supported yet. - pinctrl-driver/dt is used for mmc and i2c now instead of configuring the I/O-pins in the drivers. - '#ifdef CONFIG...' changed to 'if (IS_ENABLED(CONFIG...))' where possible (and similar). - livetree API (dev_read_...) is used instead of fdt one (fdt...).
The patch-series has been checked by buildman (all arm boards and two m68k boards = M5235EVB): buildman --step 0 -b master arm buildman --step 0 -b master M5235EVB There have been no new warnings or errors.
Changes in v4: - cosmetic changes in nx_i2c.c: if-else block simplified, defines used for constant values.
Changes in v3: - arch/arm/mach-nexell/Kconfig: "NEXELL_COMMON" removed, has not been used at all. NEXELL_ARMV7_COMMON and NEXELL_ARMV8_COMMON removed, has been used only in the Kconfig at ARCH_S5P4418 and ARCH_S5P6818. Used "select ..."-statements moved appropriately. Missing helps added. - arch/arm/mach-nexell/timer.c: '#include <log.h>' inserted because it has been removed from common.h. - '#ifdef...' changed to 'if (IS_ENABLED(CONFIG...))' where possible because of appropriate warnings of patman. - Changed to livetree API as proposed by patman: fdtdec_get_int() --> dev_read_s32_default() fdt_getprop() --> dev_read_string() - pinctrl-driver/dt is used now instead of configuring the i2c I/O-pins in the i2c-driver. - drivers/i2c/nx_i2c.c: '#include <log.h>' inserted because it has been removed from common.h. - Changed to livetree API as proposed by patman: fdtdec_get_int() --> dev_read_s32_default() - nexell_dw_mmc_dm.c renamed (back) to nexell_dw_mmc.c - pinctrl-driver/dt is used now instead of configuring the mmc I/O-pins in the mmc-driver. - nexell_dwmmc_ofdata_to_platdata() reworked, i.e. valid default values are used now (where possible) and the appropriate if-blocks have been removed. - "nexell," removed from dt-properties, e.g. "nexell,bus-width" changed to "bus-width". - new dt-property "mmcboost" is used now instead of "CONFIG_BOOST_MMC" which was not defined anywhere. - Boot error "Loading Environment from MMC... *** Warning - No block device, using default environment" after updating local repository. Bugfix in drivers/mmc/nexell_dw_mmc.c: "#include <clk.h>" changed to "#include <asm/arch/clk.h>". This Bug showed up now because of the commit "dm: clk: add stub when CONFIG_CLK is deactivated" where include/clk.h has been changed. - drivers/mmc/nexell_dw_mmc.c: '#include <log.h>' inserted because it has been removed from common.h. - Kconfig: Missing helps added. - Changed to livetree API as proposed by patman: fdt_stringlist_count() --> dev_read_string_count() fdt_stringlist_get() --> dev_read_string_index() fdtdec_get_int() --> dev_read_s32_default() - doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt added. - Handling of Configs for LCD backlight control reworked because (among others) not setting CONFIG_S5P4418_ONEWIRE and/or CONFIG_PWM_NX has caused errors when compiling board/friendlyarm/nanopi2/onewire.c. - pwm.h: () around macro argument x added to avoid precedence issues. - drivers/video/nexell/s5pxx18_dp_hdmi.c: '#include <log.h>' and '#include <linux/delay.h>' inserted because it has been removed from common.h. - drivers/video/nexell_display.c: '#include <command.h>' inserted because '#include <image.h>' (includes command.h) has been removed from common.h. - Changed to livetree API as proposed by patman: fdtdec_get_int() --> ofnode_read_s32_default() for (node = ...) --> ofnode_for_each_subnode() fdt_get_name() --> ofnode_get_name() fdt_getprop() --> dev_read_string() - nx_display_probe() removed, nx_display_dev_probe_uclass() renamed to nx_display_probe(). - dts: pinctrl is supported now, therefore s5p4418-pinctrl.dtsi added, mmc- and i2c-entries extended appropriately. New mmc-property "mmcboost" added. - Handling of Configs for LCD backlight control reworked because (among others) not setting CONFIG_S5P4418_ONEWIRE and/or CONFIG_PWM_NX has caused errors when compiling board/friendlyarm/nanopi2/onewire.c. - arch/arm/cpu/armv7/s5p4418/cpu.c: '#include <linux/delay.h>' inserted because it has been removed from common.h. - board/friendlyarm/nanopi2/board.c: Several includes inserted because some includes have been removed from common.h. - Several initialisations of static variables to 0 removed because of appropriate errors of patman. - CONFIG_SYS_RESERVE_MEM_SIZE removed, has not been used anymore - s5p4418_nanopi2_defconfig: "CONFIG_PINCTRL=y" added because pinctrl is supported now. "CONFIG_EFI_LOADER=n" removed (there have been boot errors "efi_runtime_relocate: Unknown relocation type 0" at a previous U-Boot Version without this). "CONFIG_DM_I2C_GPIO=y" removed because I2C-peripherial is used (Nexell I2C driver). Some configs moved down for cosmetic reason. - Handling of Configs for LCD backlight control reworked because (among others) not setting CONFIG_S5P4418_ONEWIRE and/or CONFIG_PWM_NX has caused errors when compiling board/friendlyarm/nanopi2/onewire.c. - CONFIG_SYS_MEMTEST_START, CONFIG_SYS_MEMTEST_END, CONFIG_CMDLINE_TAG and CONFIG_CMD_BMP moved from s5p4418_nanopi2.h to s5p4418_nanopi2_defconfig. - "#undef CONFIG_CMD_IMLS" removed in s5p4418_nanopi2.h
Changes in v2: - arch/arm/mach-nexell/serial.c removed because this is for the UARTs of the S5P6818 SoC which is not supported yet. S5P4418 UARTs are different, here the (existing) PL011-code is used. - line '... += spl/' in in arch/arm/mach-nexell/Makefile deleted, this change has already been stated in the commit message but was missing nethertheless. - commit "i2c: mmc: add nexell driver (gpio, i2c, mmc, pwm)" splitted into separate commits for gpio, i2c, mmc, pwm. - cosmetic: line "obj-$(CONFIG_NX_GPIO) += nx_gpio.o" in drivers/gpio/Makefile moved up. - several Bugfixes in nx_i2c.c. - the i2c-driver has been for s5p6818 only. Code extended approriately in order s5p4418 is also working. - "probe_chip" added to the i2c-driver. - doc/device-tree-bindings/i2c/nx_i2c.txt added. - Since drivers/pwm/pwm-nexell.c is an adapted version of s5p-common/pwm.c an appropriately changed version of s5p-common/pwm.c is used now. Therefore arch/arm/mach-s5pc1xx/include/mach/pwm.h copied to arch/arm/mach-nexell/include/mach and s5p-common/Makefile changed appropriately. - i2c: "nexell,s5pxx18-i2c"-driver is used now instead of "i2c-gpio". i2c0 and i2c1 added. I.e. dts files changed appropriately. - dts: gmac-, ehci- and dwc2otg-entries removed because the appropriate functionality is not supported yet. - s5p4418-pinctrl.dtsi removed because there is no pinctrl-driver available. - "obj-$(CONFIG_ARCH_NEXELL) += s5p-common/" added to arch/arm/cpu/armv7/Makefile since s5p-common/pwm.c is used now instead of drivers/pwm/pwm-nexell.c. - cosmetic: additional GPL license text removed, SPDX-License-Identifier is enough. Furthermore file path removed (two files). - USB related configs removed because USB is not supported yet. - CONFIG_CMD_MEMTEST moved from s5p4418_nanopi2.h to s5p4418_nanopi2_defconfig. - MAINTAINERS: "F: drivers/pwm/pwm-nexell*" deleted because arch/arm/cpu/armv7/s5p-common/pwm.c is used now. Furthermore double line "F: drivers/video/nexell/" deleted.
Stefan Bosch (14): arm: add mach-nexell (header files) arm: add mach-nexell (all files except header files) gpio: add nexell driver i2c: add nexell driver mmc: add nexell driver pinctrl: add nexell driver pwm: add driver for nexell video: add nexell video driver (soc: displaytop) video: add nexell video driver (soc: mlc, mipi) video: add nexell video driver (soc: lvds, hdmi) video: add nexell video driver (soc: dpc, makefile) video: add nexell video driver (display/video driver) arm: add support for SoC s5p4418 (cpu) / nanopi2 board arm: add (default) config for nanopi2 board
MAINTAINERS | 17 + arch/arm/Kconfig | 7 + arch/arm/Makefile | 1 + arch/arm/cpu/armv7/Makefile | 2 + arch/arm/cpu/armv7/s5p-common/Makefile | 13 +- arch/arm/cpu/armv7/s5p-common/pwm.c | 57 +- arch/arm/cpu/armv7/s5p4418/Makefile | 6 + arch/arm/cpu/armv7/s5p4418/cpu.c | 121 ++ arch/arm/dts/Makefile | 3 + arch/arm/dts/s5p4418-nanopi2.dts | 110 ++ arch/arm/dts/s5p4418-pinctrl.dtsi | 135 ++ arch/arm/dts/s5p4418.dtsi | 170 ++ arch/arm/mach-nexell/Kconfig | 58 + arch/arm/mach-nexell/Makefile | 13 + arch/arm/mach-nexell/clock.c | 869 +++++++++ arch/arm/mach-nexell/cmd_boot_linux.c | 144 ++ arch/arm/mach-nexell/config.mk | 11 + arch/arm/mach-nexell/include/mach/boot0.h | 40 + arch/arm/mach-nexell/include/mach/clk.h | 24 + arch/arm/mach-nexell/include/mach/display.h | 273 +++ arch/arm/mach-nexell/include/mach/display_dev.h | 37 + arch/arm/mach-nexell/include/mach/ehci.h | 106 ++ arch/arm/mach-nexell/include/mach/gpio.h | 17 + arch/arm/mach-nexell/include/mach/mipi_display.h | 215 +++ arch/arm/mach-nexell/include/mach/nexell.h | 352 ++++ arch/arm/mach-nexell/include/mach/nx_gpio.h | 103 ++ arch/arm/mach-nexell/include/mach/pwm.h | 54 + arch/arm/mach-nexell/include/mach/reset.h | 19 + arch/arm/mach-nexell/include/mach/sec_reg.h | 15 + arch/arm/mach-nexell/include/mach/tieoff.h | 423 +++++ arch/arm/mach-nexell/nx_gpio.c | 352 ++++ arch/arm/mach-nexell/nx_sec_reg.c | 82 + arch/arm/mach-nexell/reg-call.S | 23 + arch/arm/mach-nexell/reset.c | 33 + arch/arm/mach-nexell/tieoff.c | 107 ++ arch/arm/mach-nexell/timer.c | 299 ++++ board/friendlyarm/Kconfig | 37 + board/friendlyarm/nanopi2/Kconfig | 12 + board/friendlyarm/nanopi2/MAINTAINERS | 7 + board/friendlyarm/nanopi2/Makefile | 7 + board/friendlyarm/nanopi2/board.c | 575 ++++++ board/friendlyarm/nanopi2/hwrev.c | 108 ++ board/friendlyarm/nanopi2/hwrev.h | 15 + board/friendlyarm/nanopi2/lcds.c | 697 ++++++++ board/friendlyarm/nanopi2/nxp-fb.h | 94 + board/friendlyarm/nanopi2/onewire.c | 307 ++++ board/friendlyarm/nanopi2/onewire.h | 15 + configs/s5p4418_nanopi2_defconfig | 147 ++ doc/README.s5p4418 | 63 + doc/device-tree-bindings/i2c/nx_i2c.txt | 28 + .../pinctrl/nexell,s5pxx18-pinctrl.txt | 78 + drivers/gpio/Kconfig | 9 + drivers/gpio/Makefile | 1 + drivers/gpio/nx_gpio.c | 250 +++ drivers/i2c/Kconfig | 9 + drivers/i2c/Makefile | 1 + drivers/i2c/nx_i2c.c | 626 +++++++ drivers/mmc/Kconfig | 8 + drivers/mmc/Makefile | 1 + drivers/mmc/nexell_dw_mmc.c | 237 +++ drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/nexell/Kconfig | 18 + drivers/pinctrl/nexell/Makefile | 7 + drivers/pinctrl/nexell/pinctrl-nexell.c | 66 + drivers/pinctrl/nexell/pinctrl-nexell.h | 68 + drivers/pinctrl/nexell/pinctrl-s5pxx18.c | 220 +++ drivers/pinctrl/nexell/pinctrl-s5pxx18.h | 53 + drivers/video/Kconfig | 10 + drivers/video/Makefile | 1 + drivers/video/nexell/Kconfig | 27 + drivers/video/nexell/Makefile | 12 + drivers/video/nexell/s5pxx18_dp.c | 341 ++++ drivers/video/nexell/s5pxx18_dp_hdmi.c | 545 ++++++ drivers/video/nexell/s5pxx18_dp_lvds.c | 274 +++ drivers/video/nexell/s5pxx18_dp_mipi.c | 677 +++++++ drivers/video/nexell/s5pxx18_dp_rgb.c | 69 + drivers/video/nexell/soc/Makefile | 11 + drivers/video/nexell/soc/s5pxx18_soc_disptop.c | 185 ++ drivers/video/nexell/soc/s5pxx18_soc_disptop.h | 385 ++++ drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.c | 309 ++++ drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.h | 59 + drivers/video/nexell/soc/s5pxx18_soc_disptype.h | 23 + drivers/video/nexell/soc/s5pxx18_soc_dpc.c | 1569 +++++++++++++++++ drivers/video/nexell/soc/s5pxx18_soc_dpc.h | 444 +++++ drivers/video/nexell/soc/s5pxx18_soc_hdmi.c | 50 + drivers/video/nexell/soc/s5pxx18_soc_hdmi.h | 488 +++++ drivers/video/nexell/soc/s5pxx18_soc_lvds.c | 278 +++ drivers/video/nexell/soc/s5pxx18_soc_lvds.h | 83 + drivers/video/nexell/soc/s5pxx18_soc_mipi.c | 580 ++++++ drivers/video/nexell/soc/s5pxx18_soc_mipi.h | 291 +++ drivers/video/nexell/soc/s5pxx18_soc_mlc.c | 1861 ++++++++++++++++++++ drivers/video/nexell/soc/s5pxx18_soc_mlc.h | 429 +++++ drivers/video/nexell_display.c | 651 +++++++ include/configs/s5p4418_nanopi2.h | 257 +++ 95 files changed, 17981 insertions(+), 5 deletions(-) create mode 100644 arch/arm/cpu/armv7/s5p4418/Makefile create mode 100644 arch/arm/cpu/armv7/s5p4418/cpu.c create mode 100644 arch/arm/dts/s5p4418-nanopi2.dts create mode 100644 arch/arm/dts/s5p4418-pinctrl.dtsi create mode 100644 arch/arm/dts/s5p4418.dtsi create mode 100644 arch/arm/mach-nexell/Kconfig create mode 100644 arch/arm/mach-nexell/Makefile create mode 100644 arch/arm/mach-nexell/clock.c create mode 100644 arch/arm/mach-nexell/cmd_boot_linux.c create mode 100644 arch/arm/mach-nexell/config.mk create mode 100644 arch/arm/mach-nexell/include/mach/boot0.h create mode 100644 arch/arm/mach-nexell/include/mach/clk.h create mode 100644 arch/arm/mach-nexell/include/mach/display.h create mode 100644 arch/arm/mach-nexell/include/mach/display_dev.h create mode 100644 arch/arm/mach-nexell/include/mach/ehci.h create mode 100644 arch/arm/mach-nexell/include/mach/gpio.h create mode 100644 arch/arm/mach-nexell/include/mach/mipi_display.h create mode 100644 arch/arm/mach-nexell/include/mach/nexell.h create mode 100644 arch/arm/mach-nexell/include/mach/nx_gpio.h create mode 100644 arch/arm/mach-nexell/include/mach/pwm.h create mode 100644 arch/arm/mach-nexell/include/mach/reset.h create mode 100644 arch/arm/mach-nexell/include/mach/sec_reg.h create mode 100644 arch/arm/mach-nexell/include/mach/tieoff.h create mode 100644 arch/arm/mach-nexell/nx_gpio.c create mode 100644 arch/arm/mach-nexell/nx_sec_reg.c create mode 100644 arch/arm/mach-nexell/reg-call.S create mode 100644 arch/arm/mach-nexell/reset.c create mode 100644 arch/arm/mach-nexell/tieoff.c create mode 100644 arch/arm/mach-nexell/timer.c create mode 100644 board/friendlyarm/Kconfig create mode 100644 board/friendlyarm/nanopi2/Kconfig create mode 100644 board/friendlyarm/nanopi2/MAINTAINERS create mode 100644 board/friendlyarm/nanopi2/Makefile create mode 100644 board/friendlyarm/nanopi2/board.c create mode 100644 board/friendlyarm/nanopi2/hwrev.c create mode 100644 board/friendlyarm/nanopi2/hwrev.h create mode 100644 board/friendlyarm/nanopi2/lcds.c create mode 100644 board/friendlyarm/nanopi2/nxp-fb.h create mode 100644 board/friendlyarm/nanopi2/onewire.c create mode 100644 board/friendlyarm/nanopi2/onewire.h create mode 100644 configs/s5p4418_nanopi2_defconfig create mode 100644 doc/README.s5p4418 create mode 100644 doc/device-tree-bindings/i2c/nx_i2c.txt create mode 100644 doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt create mode 100644 drivers/gpio/nx_gpio.c create mode 100644 drivers/i2c/nx_i2c.c create mode 100644 drivers/mmc/nexell_dw_mmc.c create mode 100644 drivers/pinctrl/nexell/Kconfig create mode 100644 drivers/pinctrl/nexell/Makefile create mode 100644 drivers/pinctrl/nexell/pinctrl-nexell.c create mode 100644 drivers/pinctrl/nexell/pinctrl-nexell.h create mode 100644 drivers/pinctrl/nexell/pinctrl-s5pxx18.c create mode 100644 drivers/pinctrl/nexell/pinctrl-s5pxx18.h create mode 100644 drivers/video/nexell/Kconfig create mode 100644 drivers/video/nexell/Makefile create mode 100644 drivers/video/nexell/s5pxx18_dp.c create mode 100644 drivers/video/nexell/s5pxx18_dp_hdmi.c create mode 100644 drivers/video/nexell/s5pxx18_dp_lvds.c create mode 100644 drivers/video/nexell/s5pxx18_dp_mipi.c create mode 100644 drivers/video/nexell/s5pxx18_dp_rgb.c create mode 100644 drivers/video/nexell/soc/Makefile create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptop.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptop.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptype.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_dpc.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_dpc.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_hdmi.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_hdmi.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_lvds.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_lvds.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_mipi.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_mipi.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_mlc.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_mlc.h create mode 100644 drivers/video/nexell_display.c create mode 100644 include/configs/s5p4418_nanopi2.h
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - DM_VIDEO support (display_dev.h). - boot0.h added, handles NSIH --> tools/nexell obsolete. - gpio.h: Include-path to errno.h changed.
Signed-off-by: Stefan Bosch stefan_b@posteo.net ---
(no changes since v2)
Changes in v2: - cosmetic: additional GPL license text removed, SPDX-License-Identifier is enough.
arch/arm/mach-nexell/include/mach/boot0.h | 40 +++ arch/arm/mach-nexell/include/mach/clk.h | 24 ++ arch/arm/mach-nexell/include/mach/display.h | 273 +++++++++++++++ arch/arm/mach-nexell/include/mach/display_dev.h | 37 ++ arch/arm/mach-nexell/include/mach/ehci.h | 106 ++++++ arch/arm/mach-nexell/include/mach/gpio.h | 17 + arch/arm/mach-nexell/include/mach/mipi_display.h | 215 ++++++++++++ arch/arm/mach-nexell/include/mach/nexell.h | 352 +++++++++++++++++++ arch/arm/mach-nexell/include/mach/nx_gpio.h | 103 ++++++ arch/arm/mach-nexell/include/mach/reset.h | 19 + arch/arm/mach-nexell/include/mach/sec_reg.h | 15 + arch/arm/mach-nexell/include/mach/tieoff.h | 423 +++++++++++++++++++++++ 12 files changed, 1624 insertions(+) create mode 100644 arch/arm/mach-nexell/include/mach/boot0.h create mode 100644 arch/arm/mach-nexell/include/mach/clk.h create mode 100644 arch/arm/mach-nexell/include/mach/display.h create mode 100644 arch/arm/mach-nexell/include/mach/display_dev.h create mode 100644 arch/arm/mach-nexell/include/mach/ehci.h create mode 100644 arch/arm/mach-nexell/include/mach/gpio.h create mode 100644 arch/arm/mach-nexell/include/mach/mipi_display.h create mode 100644 arch/arm/mach-nexell/include/mach/nexell.h create mode 100644 arch/arm/mach-nexell/include/mach/nx_gpio.h create mode 100644 arch/arm/mach-nexell/include/mach/reset.h create mode 100644 arch/arm/mach-nexell/include/mach/sec_reg.h create mode 100644 arch/arm/mach-nexell/include/mach/tieoff.h
diff --git a/arch/arm/mach-nexell/include/mach/boot0.h b/arch/arm/mach-nexell/include/mach/boot0.h new file mode 100644 index 0000000..e05c07e --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/boot0.h @@ -0,0 +1,40 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * NSIH (Nexell System Information Header) for FriendlyArm nanopi2 board + * + * The NSIH (first 512 Bytes of u-boot.bin) is necessary for the + * 2nd-Bootloader to get information like load address of U-Boot. + * + * 0x400 must be added to CONFIG_SYS_TEXT_BASE to have the actual load and + * start address because 2nd-Bootloader loads with an offset of 0x400 + * (NSIH + 0x200 bytes are not loaded into RAM). + * + * It has been tested / is working with the following 2nd-Bootloader: + * "BL1 by Nexell V1.0.0-gd551e13 [Built on 2018-01-25 16:58:29]" + * + * (C) Copyright 2020 Stefan Bosch stefan_b@posteo.net + */ + +#ifndef __BOOT0_H +#define __BOOT0_H + + ARM_VECTORS + .space 0x30 + .word (_end - _start) + 20 * 1024 /* 0x50: load size + * (bin + 20k for DTB) */ + .space 0x4 + .word CONFIG_SYS_TEXT_BASE + 0x400 /* 0x58: load address */ + .word 0x00000000 + .word CONFIG_SYS_TEXT_BASE + 0x400 /* 0x60: start address */ + .space 0x198 + .byte 'N' /* 0x1FC: "NSIH" signature */ + .byte 'S' + .byte 'I' + .byte 'H' + + /* The NSIH + 0x200 bytes are omitted by the 2nd-Bootloader */ + .space 0x200 +_start: + ARM_VECTORS + +#endif /* __BOOT0_H */ diff --git a/arch/arm/mach-nexell/include/mach/clk.h b/arch/arm/mach-nexell/include/mach/clk.h new file mode 100644 index 0000000..cc5589a --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/clk.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * (C) Copyright 2016 Nexell + * Hyunseok, Jung hsjung@nexell.co.kr + */ + +#ifndef __ASM_ARM_ARCH_CLK_H_ +#define __ASM_ARM_ARCH_CLK_H_ + +struct clk { + unsigned long rate; +}; + +void clk_init(void); + +struct clk *clk_get(const char *id); +void clk_put(struct clk *clk); +unsigned long clk_get_rate(struct clk *clk); +long clk_round_rate(struct clk *clk, unsigned long rate); +int clk_set_rate(struct clk *clk, unsigned long rate); +int clk_enable(struct clk *clk); +void clk_disable(struct clk *clk); + +#endif diff --git a/arch/arm/mach-nexell/include/mach/display.h b/arch/arm/mach-nexell/include/mach/display.h new file mode 100644 index 0000000..b167e63 --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/display.h @@ -0,0 +1,273 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _NX__DISPLAY_H_ +#define _NX__DISPLAY_H_ + +#define DP_PLANS_NUM 3 + +/* the display output format. */ +#define DPC_FORMAT_RGB555 0 /* RGB555 Format */ +#define DPC_FORMAT_RGB565 1 /* RGB565 Format */ +#define DPC_FORMAT_RGB666 2 /* RGB666 Format */ +#define DPC_FORMAT_RGB888 3 /* RGB888 Format */ +#define DPC_FORMAT_MRGB555A 4 /* MRGB555A Format */ +#define DPC_FORMAT_MRGB555B 5 /* MRGB555B Format */ +#define DPC_FORMAT_MRGB565 6 /* MRGB565 Format */ +#define DPC_FORMAT_MRGB666 7 /* MRGB666 Format */ +#define DPC_FORMAT_MRGB888A 8 /* MRGB888A Format */ +#define DPC_FORMAT_MRGB888B 9 /* MRGB888B Format */ +#define DPC_FORMAT_CCIR656 10 /* ITU-R BT.656 / 601(8-bit) */ +#define DPC_FORMAT_CCIR601A 12 /* ITU-R BT.601A */ +#define DPC_FORMAT_CCIR601B 13 /* ITU-R BT.601B */ +#define DPC_FORMAT_4096COLOR 1 /* 4096 Color Format */ +#define DPC_FORMAT_16GRAY 3 /* 16 Level Gray Format */ + +/* layer pixel format. */ +#define MLC_RGBFMT_R5G6B5 0x44320000 /* {R5,G6,B5 }. */ +#define MLC_RGBFMT_B5G6R5 0xC4320000 /* {B5,G6,R5 }. */ +#define MLC_RGBFMT_X1R5G5B5 0x43420000 /* {X1,R5,G5,B5}. */ +#define MLC_RGBFMT_X1B5G5R5 0xC3420000 /* {X1,B5,G5,R5}. */ +#define MLC_RGBFMT_X4R4G4B4 0x42110000 /* {X4,R4,G4,B4}. */ +#define MLC_RGBFMT_X4B4G4R4 0xC2110000 /* {X4,B4,G4,R4}. */ +#define MLC_RGBFMT_X8R3G3B2 0x41200000 /* {X8,R3,G3,B2}. */ +#define MLC_RGBFMT_X8B3G3R2 0xC1200000 /* {X8,B3,G3,R2}. */ +#define MLC_RGBFMT_A1R5G5B5 0x33420000 /* {A1,R5,G5,B5}. */ +#define MLC_RGBFMT_A1B5G5R5 0xB3420000 /* {A1,B5,G5,R5}. */ +#define MLC_RGBFMT_A4R4G4B4 0x22110000 /* {A4,R4,G4,B4}. */ +#define MLC_RGBFMT_A4B4G4R4 0xA2110000 /* {A4,B4,G4,R4}. */ +#define MLC_RGBFMT_A8R3G3B2 0x11200000 /* {A8,R3,G3,B2}. */ +#define MLC_RGBFMT_A8B3G3R2 0x91200000 /* {A8,B3,G3,R2}. */ +#define MLC_RGBFMT_R8G8B8 0x46530000 /* {R8,G8,B8 }. */ +#define MLC_RGBFMT_B8G8R8 0xC6530000 /* {B8,G8,R8 }. */ +#define MLC_RGBFMT_X8R8G8B8 0x46530000 /* {X8,R8,G8,B8}. */ +#define MLC_RGBFMT_X8B8G8R8 0xC6530000 /* {X8,B8,G8,R8}. */ +#define MLC_RGBFMT_A8R8G8B8 0x06530000 /* {A8,R8,G8,B8}. */ +#define MLC_RGBFMT_A8B8G8R8 0x86530000 /* {A8,B8,G8,R8}. */ + +/* the data output order in case of ITU-R BT.656 / 601. */ +#define DPC_YCORDER_CBYCRY 0 +#define DPC_YCORDER_CRYCBY 1 +#define DPC_YCORDER_YCBYCR 2 +#define DPC_YCORDER_YCRYCB 3 + +/* the PAD output clock. */ +#define DPC_PADCLKSEL_VCLK 0 /* VCLK */ +#define DPC_PADCLKSEL_VCLK2 1 /* VCLK2 */ + +/* display sync info for DPC */ +struct dp_sync_info { + int interlace; + int h_active_len; + int h_sync_width; + int h_back_porch; + int h_front_porch; + int h_sync_invert; /* default active low */ + int v_active_len; + int v_sync_width; + int v_back_porch; + int v_front_porch; + int v_sync_invert; /* default active low */ + int pixel_clock_hz; /* HZ */ +}; + +/* syncgen control (DPC) */ +#define DP_SYNC_DELAY_RGB_PVD (1 << 0) +#define DP_SYNC_DELAY_HSYNC_CP1 (1 << 1) +#define DP_SYNC_DELAY_VSYNC_FRAM (1 << 2) +#define DP_SYNC_DELAY_DE_CP (1 << 3) + +struct dp_ctrl_info { + /* clock gen */ + int clk_src_lv0; + int clk_div_lv0; + int clk_src_lv1; + int clk_div_lv1; + /* scan format */ + int interlace; + /* syncgen format */ + unsigned int out_format; + int invert_field; /* 0:normal(Low odd), 1:invert (low even) */ + int swap_RB; + unsigned int yc_order; /* for CCIR output */ + /* extern sync delay */ + int delay_mask; /* if 0, set defalut delays */ + int d_rgb_pvd; /* delay for RGB/PVD, 0~16, default 0 */ + int d_hsync_cp1; /* delay for HSYNC/CP1, 0~63, default 12 */ + int d_vsync_fram; /* delay for VSYNC/FRAM, 0~63, default 12 */ + int d_de_cp2; /* delay for DE/CP2, 0~63, default 12 */ + /* sync offset */ + int vs_start_offset; /* start vsync offset, defatult 0 */ + int vs_end_offset; /* end vsync offset, default 0 */ + int ev_start_offset; /* start even vsync offset, default 0 */ + int ev_end_offset; /* end even vsync offset , default 0 */ + /* pad clock seletor */ + int vck_select; /* 0=vclk0, 1=vclk2 */ + int clk_inv_lv0; /* OUTCLKINVn */ + int clk_delay_lv0; /* OUTCLKDELAYn */ + int clk_inv_lv1; /* OUTCLKINVn */ + int clk_delay_lv1; /* OUTCLKDELAYn */ + int clk_sel_div1; /* 0=clk1_inv, 1=clk1_div_2_ns */ +}; + +/* multi layer control (MLC) */ +struct dp_plane_top { + int screen_width; + int screen_height; + int video_prior; /* 0: video>RGBn, 1: RGB0>video>RGB1, + * 2: RGB0 > RGB1 > video .. */ + int interlace; + int plane_num; + unsigned int back_color; +}; + +struct dp_plane_info { + int layer; + unsigned int fb_base; + int left; + int top; + int width; + int height; + int pixel_byte; + unsigned int format; + int alpha_on; + int alpha_depth; + int tp_on; /* transparency color enable */ + unsigned int tp_color; + unsigned int mem_lock_size; /* memory burst access (4,8,16) */ + int video_layer; + int enable; +}; + +/* + * LCD device dependency struct + * RGB, LVDS, MiPi, HDMI + */ +enum { + DP_DEVICE_RESCONV = 0, + DP_DEVICE_RGBLCD = 1, + DP_DEVICE_HDMI = 2, + DP_DEVICE_MIPI = 3, + DP_DEVICE_LVDS = 4, + DP_DEVICE_CVBS = 5, + DP_DEVICE_DP0 = 6, + DP_DEVICE_DP1 = 7, + DP_DEVICE_END, +}; + +enum { + DP_CLOCK_RESCONV = 0, + DP_CLOCK_LCDIF = 1, + DP_CLOCK_MIPI = 2, + DP_CLOCK_LVDS = 3, + DP_CLOCK_HDMI = 4, + DP_CLOCK_END, +}; + +enum dp_lvds_format { + DP_LVDS_FORMAT_VESA = 0, + DP_LVDS_FORMAT_JEIDA = 1, + DP_LVDS_FORMAT_LOC = 2, +}; + +#define DEF_VOLTAGE_LEVEL (0x20) + +struct dp_lvds_dev { + enum dp_lvds_format lvds_format; /* 0:VESA, 1:JEIDA, 2: Location */ + int pol_inv_hs; /* hsync polarity invert for VESA, JEIDA */ + int pol_inv_vs; /* bsync polarity invert for VESA, JEIDA */ + int pol_inv_de; /* de polarity invert for VESA, JEIDA */ + int pol_inv_ck; /* input clock(pixel clock) polarity invert */ + int voltage_level; + /* Location setting */ + unsigned int loc_map[9]; /* Location Setting */ + unsigned int loc_mask[2]; /* Location Setting, 0 ~ 34 */ + unsigned int loc_pol[2]; /* Location Setting, 0 ~ 34 */ +}; + +#include "mipi_display.h" + +struct dp_mipi_dev { + int lp_bitrate; /* to lcd setup, low power bitrate (150, 100, 80 Mhz) */ + int hs_bitrate; /* to lcd data, high speed bitrate (1000, ... Mhz) */ + int lpm_trans; + int command_mode; + unsigned int hs_pllpms; + unsigned int hs_bandctl; + unsigned int lp_pllpms; + unsigned int lp_bandctl; + struct mipi_dsi_device dsi; +}; + +struct dp_rgb_dev { + int lcd_mpu_type; +}; + +struct dp_hdmi_dev { + int preset; +}; + +/* platform data for the driver model */ +struct nx_display_platdata { + int module; + struct dp_sync_info sync; + struct dp_ctrl_info ctrl; + struct dp_plane_top top; + struct dp_plane_info plane[DP_PLANS_NUM]; + int dev_type; + void *device; +}; + +/* Lcd api */ +void nx_lvds_display(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_plane_top *top, + struct dp_plane_info *planes, + struct dp_lvds_dev *dev); + +void nx_rgb_display(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_plane_top *top, struct dp_plane_info *planes, + struct dp_rgb_dev *dev); + +void nx_hdmi_display(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_plane_top *top, + struct dp_plane_info *planes, + struct dp_hdmi_dev *dev); + +void nx_mipi_display(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_plane_top *top, + struct dp_plane_info *planes, + struct dp_mipi_dev *dev); + +int nx_mipi_dsi_lcd_bind(struct mipi_dsi_device *dsi); + +/* disaply api */ +void dp_control_init(int module); +int dp_control_setup(int module, struct dp_sync_info *sync, + struct dp_ctrl_info *ctrl); +void dp_control_enable(int module, int on); + +void dp_plane_init(int module); +int dp_plane_screen_setup(int module, struct dp_plane_top *top); +void dp_plane_screen_enable(int module, int on); + +int dp_plane_layer_setup(int module, struct dp_plane_info *plane); +void dp_plane_layer_enable(int module, struct dp_plane_info *plane, int on); + +int dp_plane_set_enable(int module, int layer, int on); +int dp_plane_set_address(int module, int layer, unsigned int address); +int dp_plane_wait_vsync(int module, int layer, int fps); + +#if defined CONFIG_SPL_BUILD || \ + (!defined(CONFIG_DM) && !defined(CONFIG_OF_CONTROL)) +int nx_display_probe(struct nx_display_platdata *plat); +#endif + +#endif diff --git a/arch/arm/mach-nexell/include/mach/display_dev.h b/arch/arm/mach-nexell/include/mach/display_dev.h new file mode 100644 index 0000000..77eb614 --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/display_dev.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _NX__DISPLAY_DEV_H_ +#define _NX__DISPLAY_DEV_H_ + +#if defined CONFIG_VIDEO || defined CONFIG_DM_VIDEO +#include <video_fb.h> +#elif defined CONFIG_LCD +#include <lcd.h> +#endif + +struct nx_display_dev { +#if defined CONFIG_VIDEO || defined CONFIG_DM_VIDEO + GraphicDevice graphic_device; +#elif defined CONFIG_LCD + vidinfo_t *panel_info; +#endif + unsigned long base; + int module; + struct dp_sync_info sync; + struct dp_ctrl_info ctrl; + struct dp_plane_top top; + struct dp_plane_info planes[DP_PLANS_NUM]; + int dev_type; + void *device; + struct dp_plane_info *fb_plane; + unsigned int depth; /* byte per pixel */ + unsigned int fb_addr; + unsigned int fb_size; +}; + +#endif diff --git a/arch/arm/mach-nexell/include/mach/ehci.h b/arch/arm/mach-nexell/include/mach/ehci.h new file mode 100644 index 0000000..545153b --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/ehci.h @@ -0,0 +1,106 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * NEXELL USB HOST EHCI Controller + * + * (C) Copyright 2016 Nexell + * Hyunseok, Jung hsjung@nexell.co.kr + */ + +#ifndef __ASM_ARM_ARCH_EHCI_H__ +#define __ASM_ARM_ARCH_EHCI_H__ + +/* Nexell USBHOST PHY registers */ + +/* USBHOST Configuration 0 Register */ +#define NX_HOST_CON0 0x14 +#define NX_HOST_CON0_SS_WORD_IF BIT(26) +#define NX_HOST_CON0_SS_WORD_IF_ENB BIT(25) +#define NX_HOST_CON0_SS_WORD_IF_16 ( \ + NX_HOST_CON0_SS_WORD_IF | \ + NX_HOST_CON0_SS_WORD_IF_ENB) + +#define NX_HOST_CON0_HSIC_480M_FROM_OTG_PHY BIT(24) +#define NX_HOST_CON0_HSIC_FREE_CLOCK_ENB BIT(23) +#define NX_HOST_CON0_HSIC_CLK_MASK (0x3 << 23) + +#define NX_HOST_CON0_N_HOST_HSIC_RESET_SYNC BIT(22) +#define NX_HOST_CON0_N_HOST_UTMI_RESET_SYNC BIT(21) +#define NX_HOST_CON0_N_HOST_PHY_RESET_SYNC BIT(20) +#define NX_HOST_CON0_UTMI_RESET_SYNC ( \ + NX_HOST_CON0_N_HOST_HSIC_RESET_SYNC | \ + NX_HOST_CON0_N_HOST_UTMI_RESET_SYNC | \ + NX_HOST_CON0_N_HOST_PHY_RESET_SYNC) + +#define NX_HOST_CON0_N_AUXWELL_RESET_SYNC BIT(19) +#define NX_HOST_CON0_N_OHCI_RESET_SYNC BIT(18) +#define NX_HOST_CON0_N_RESET_SYNC BIT(17) +#define NX_HOST_CON0_AHB_RESET_SYNC ( \ + NX_HOST_CON0_N_AUXWELL_RESET_SYNC | \ + NX_HOST_CON0_N_OHCI_RESET_SYNC | \ + NX_HOST_CON0_N_RESET_SYNC) + +#define NX_HOST_CON0_HSIC_EN_PORT1 (0x2 << 14) +#define NX_HOST_CON0_HSIC_EN_MASK (0x7 << 14) + +/* USBHOST Configuration 1 Register */ +#define NX_HOST_CON1 0x18 + +/* USBHOST Configuration 2 Register */ +#define NX_HOST_CON2 0x1C +#define NX_HOST_CON2_SS_ENA_INCRX_ALIGN (0x1 << 28) +#define NX_HOST_CON2_SS_ENA_INCR4 (0x1 << 27) +#define NX_HOST_CON2_SS_ENA_INCR8 (0x1 << 26) +#define NX_HOST_CON2_SS_ENA_INCR16 (0x1 << 25) +#define NX_HOST_CON2_SS_DMA_BURST_MASK \ + (NX_HOST_CON2_SS_ENA_INCR16 | NX_HOST_CON2_SS_ENA_INCR8 | \ + NX_HOST_CON2_SS_ENA_INCR4 | NX_HOST_CON2_SS_ENA_INCRX_ALIGN) + +#define NX_HOST_CON2_EHCI_SS_ENABLE_DMA_BURST \ + (NX_HOST_CON2_SS_ENA_INCR16 | NX_HOST_CON2_SS_ENA_INCR8 | \ + NX_HOST_CON2_SS_ENA_INCR4 | NX_HOST_CON2_SS_ENA_INCRX_ALIGN) + +#define NX_HOST_CON2_OHCI_SS_ENABLE_DMA_BURST \ + (NX_HOST_CON2_SS_ENA_INCR4 | NX_HOST_CON2_SS_ENA_INCRX_ALIGN) + +#define NX_HOST_CON2_SS_FLADJ_VAL_0_OFFSET (21) +#define NX_HOST_CON2_SS_FLADJ_VAL_OFFSET (3) +#define NX_HOST_CON2_SS_FLADJ_VAL_NUM (6) +#define NX_HOST_CON2_SS_FLADJ_VAL_0_SEL BIT(5) +#define NX_HOST_CON2_SS_FLADJ_VAL_MAX 0x7 + +/* USBHOST Configuration 3 Register */ +#define NX_HOST_CON3 0x20 +#define NX_HOST_CON3_POR BIT(8) +#define NX_HOST_CON3_POR_ENB BIT(7) +#define NX_HOST_CON3_POR_MASK (0x3 << 7) + +/* USBHOST Configuration 4 Register */ +#define NX_HOST_CON4 0x24 +#define NX_HOST_CON4_WORDINTERFACE BIT(9) +#define NX_HOST_CON4_WORDINTERFACE_ENB BIT(8) +#define NX_HOST_CON4_WORDINTERFACE_16 ( \ + NX_HOST_CON4_WORDINTERFACE | \ + NX_HOST_CON4_WORDINTERFACE_ENB) + +/* USBHOST Configuration 5 Register */ +#define NX_HOST_CON5 0x28 +#define NX_HOST_CON5_HSIC_POR BIT(19) +#define NX_HOST_CON5_HSIC_POR_ENB BIT(18) +#define NX_HOST_CON5_HSIC_POR_MASK (0x3 << 18) + +/* USBHOST Configuration 6 Register */ +#define NX_HOST_CON6 0x2C +#define NX_HOST_CON6_HSIC_WORDINTERFACE BIT(13) +#define NX_HOST_CON6_HSIC_WORDINTERFACE_ENB BIT(12) +#define NX_HOST_CON6_HSIC_WORDINTERFACE_16 ( \ + NX_HOST_CON6_HSIC_WORDINTERFACE | \ + NX_HOST_CON6_HSIC_WORDINTERFACE_ENB) + +/* Register map for PHY control */ +struct nx_usb_phy { + unsigned int reserved; + unsigned int others[4]; + unsigned int usbhost_con[7]; +}; + +#endif /* __ASM_ARM_ARCH_EHCI_H__ */ diff --git a/arch/arm/mach-nexell/include/mach/gpio.h b/arch/arm/mach-nexell/include/mach/gpio.h new file mode 100644 index 0000000..7167d3c --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/gpio.h @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * (C) Copyright 2016 Nexell + * DeokJin, Lee truevirtue@nexell.co.kr + */ + +#ifndef __ASM_ARCH_NEXELL_GPIO_H +#define __ASM_ARCH_NEXELL_GPIO_H + +#include <asm/io.h> +#include <linux/errno.h> + +#define PIN_BASE 0 + +#define MAX_GPIO_BANKS 5 + +#endif /* __ASM_ARCH_NEXELL_GPIO_H */ diff --git a/arch/arm/mach-nexell/include/mach/mipi_display.h b/arch/arm/mach-nexell/include/mach/mipi_display.h new file mode 100644 index 0000000..f3fdec6 --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/mipi_display.h @@ -0,0 +1,215 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Defines for Mobile Industry Processor Interface (MIPI(R)) + * Display Working Group standards: DSI, DCS, DBI, DPI + * + * Copyright (C) 2010 Guennadi Liakhovetski g.liakhovetski@gmx.de + * Copyright (C) 2006 Nokia Corporation + * Author: Imre Deak imre.deak@nokia.com + */ + +#ifndef MIPI_DISPLAY_H +#define MIPI_DISPLAY_H + +/* MIPI DSI Processor-to-Peripheral transaction types */ +enum { + MIPI_DSI_V_SYNC_START = 0x01, + MIPI_DSI_V_SYNC_END = 0x11, + MIPI_DSI_H_SYNC_START = 0x21, + MIPI_DSI_H_SYNC_END = 0x31, + + MIPI_DSI_COLOR_MODE_OFF = 0x02, + MIPI_DSI_COLOR_MODE_ON = 0x12, + MIPI_DSI_SHUTDOWN_PERIPHERAL = 0x22, + MIPI_DSI_TURN_ON_PERIPHERAL = 0x32, + + MIPI_DSI_GENERIC_SHORT_WRITE_0_PARAM = 0x03, + MIPI_DSI_GENERIC_SHORT_WRITE_1_PARAM = 0x13, + MIPI_DSI_GENERIC_SHORT_WRITE_2_PARAM = 0x23, + + MIPI_DSI_GENERIC_READ_REQUEST_0_PARAM = 0x04, + MIPI_DSI_GENERIC_READ_REQUEST_1_PARAM = 0x14, + MIPI_DSI_GENERIC_READ_REQUEST_2_PARAM = 0x24, + + MIPI_DSI_DCS_SHORT_WRITE = 0x05, + MIPI_DSI_DCS_SHORT_WRITE_PARAM = 0x15, + + MIPI_DSI_DCS_READ = 0x06, + + MIPI_DSI_SET_MAXIMUM_RETURN_PACKET_SIZE = 0x37, + + MIPI_DSI_END_OF_TRANSMISSION = 0x08, + + MIPI_DSI_NULL_PACKET = 0x09, + MIPI_DSI_BLANKING_PACKET = 0x19, + MIPI_DSI_GENERIC_LONG_WRITE = 0x29, + MIPI_DSI_DCS_LONG_WRITE = 0x39, + + MIPI_DSI_LOOSELY_PACKED_PIXEL_STREAM_YCBCR20 = 0x0c, + MIPI_DSI_PACKED_PIXEL_STREAM_YCBCR24 = 0x1c, + MIPI_DSI_PACKED_PIXEL_STREAM_YCBCR16 = 0x2c, + + MIPI_DSI_PACKED_PIXEL_STREAM_30 = 0x0d, + MIPI_DSI_PACKED_PIXEL_STREAM_36 = 0x1d, + MIPI_DSI_PACKED_PIXEL_STREAM_YCBCR12 = 0x3d, + + MIPI_DSI_PACKED_PIXEL_STREAM_16 = 0x0e, + MIPI_DSI_PACKED_PIXEL_STREAM_18 = 0x1e, + MIPI_DSI_PIXEL_STREAM_3BYTE_18 = 0x2e, + MIPI_DSI_PACKED_PIXEL_STREAM_24 = 0x3e, +}; + +/* MIPI DSI Peripheral-to-Processor transaction types */ +enum { + MIPI_DSI_RX_ACKNOWLEDGE_AND_ERROR_REPORT = 0x02, + MIPI_DSI_RX_END_OF_TRANSMISSION = 0x08, + MIPI_DSI_RX_GENERIC_SHORT_READ_RESPONSE_1BYTE = 0x11, + MIPI_DSI_RX_GENERIC_SHORT_READ_RESPONSE_2BYTE = 0x12, + MIPI_DSI_RX_GENERIC_LONG_READ_RESPONSE = 0x1a, + MIPI_DSI_RX_DCS_LONG_READ_RESPONSE = 0x1c, + MIPI_DSI_RX_DCS_SHORT_READ_RESPONSE_1BYTE = 0x21, + MIPI_DSI_RX_DCS_SHORT_READ_RESPONSE_2BYTE = 0x22, +}; + +/* MIPI DCS commands */ +enum { + MIPI_DCS_NOP = 0x00, + MIPI_DCS_SOFT_RESET = 0x01, + MIPI_DCS_GET_DISPLAY_ID = 0x04, + MIPI_DCS_GET_RED_CHANNEL = 0x06, + MIPI_DCS_GET_GREEN_CHANNEL = 0x07, + MIPI_DCS_GET_BLUE_CHANNEL = 0x08, + MIPI_DCS_GET_DISPLAY_STATUS = 0x09, + MIPI_DCS_GET_POWER_MODE = 0x0A, + MIPI_DCS_GET_ADDRESS_MODE = 0x0B, + MIPI_DCS_GET_PIXEL_FORMAT = 0x0C, + MIPI_DCS_GET_DISPLAY_MODE = 0x0D, + MIPI_DCS_GET_SIGNAL_MODE = 0x0E, + MIPI_DCS_GET_DIAGNOSTIC_RESULT = 0x0F, + MIPI_DCS_ENTER_SLEEP_MODE = 0x10, + MIPI_DCS_EXIT_SLEEP_MODE = 0x11, + MIPI_DCS_ENTER_PARTIAL_MODE = 0x12, + MIPI_DCS_ENTER_NORMAL_MODE = 0x13, + MIPI_DCS_EXIT_INVERT_MODE = 0x20, + MIPI_DCS_ENTER_INVERT_MODE = 0x21, + MIPI_DCS_SET_GAMMA_CURVE = 0x26, + MIPI_DCS_SET_DISPLAY_OFF = 0x28, + MIPI_DCS_SET_DISPLAY_ON = 0x29, + MIPI_DCS_SET_COLUMN_ADDRESS = 0x2A, + MIPI_DCS_SET_PAGE_ADDRESS = 0x2B, + MIPI_DCS_WRITE_MEMORY_START = 0x2C, + MIPI_DCS_WRITE_LUT = 0x2D, + MIPI_DCS_READ_MEMORY_START = 0x2E, + MIPI_DCS_SET_PARTIAL_AREA = 0x30, + MIPI_DCS_SET_SCROLL_AREA = 0x33, + MIPI_DCS_SET_TEAR_OFF = 0x34, + MIPI_DCS_SET_TEAR_ON = 0x35, + MIPI_DCS_SET_ADDRESS_MODE = 0x36, + MIPI_DCS_SET_SCROLL_START = 0x37, + MIPI_DCS_EXIT_IDLE_MODE = 0x38, + MIPI_DCS_ENTER_IDLE_MODE = 0x39, + MIPI_DCS_SET_PIXEL_FORMAT = 0x3A, + MIPI_DCS_WRITE_MEMORY_CONTINUE = 0x3C, + MIPI_DCS_READ_MEMORY_CONTINUE = 0x3E, + MIPI_DCS_SET_TEAR_SCANLINE = 0x44, + MIPI_DCS_GET_SCANLINE = 0x45, + MIPI_DCS_READ_DDB_START = 0xA1, + MIPI_DCS_READ_DDB_CONTINUE = 0xA8, +}; + +/* MIPI DCS pixel formats */ +#define MIPI_DCS_PIXEL_FMT_24BIT 7 +#define MIPI_DCS_PIXEL_FMT_18BIT 6 +#define MIPI_DCS_PIXEL_FMT_16BIT 5 +#define MIPI_DCS_PIXEL_FMT_12BIT 3 +#define MIPI_DCS_PIXEL_FMT_8BIT 2 +#define MIPI_DCS_PIXEL_FMT_3BIT 1 + +/* request ACK from peripheral */ +#define MIPI_DSI_MSG_REQ_ACK BIT(0) +/* use Low Power Mode to transmit message */ +#define MIPI_DSI_MSG_USE_LPM BIT(1) + +/** + * struct mipi_dsi_msg - read/write DSI buffer + * @channel: virtual channel id + * @type: payload data type + * @flags: flags controlling this message transmission + * @tx_len: length of @tx_buf + * @tx_buf: data to be written + * @rx_len: length of @rx_buf + * @rx_buf: data to be read, or NULL + */ +struct mipi_dsi_msg { + u8 channel; /* virtual channel id */ + u8 type; /* payload data type */ + u16 flags; /* flags controlling this message transmission */ + size_t tx_len; + const void *tx_buf; + size_t rx_len; + void *rx_buf; +}; + +/* DSI mode flags */ + +/* video mode */ +#define MIPI_DSI_MODE_VIDEO BIT(0) +/* video burst mode */ +#define MIPI_DSI_MODE_VIDEO_BURST BIT(1) +/* video pulse mode */ +#define MIPI_DSI_MODE_VIDEO_SYNC_PULSE BIT(2) +/* enable auto vertical count mode */ +#define MIPI_DSI_MODE_VIDEO_AUTO_VERT BIT(3) +/* enable hsync-end packets in vsync-pulse and v-porch area */ +#define MIPI_DSI_MODE_VIDEO_HSE BIT(4) +/* disable hfront-porch area */ +#define MIPI_DSI_MODE_VIDEO_HFP BIT(5) +/* disable hback-porch area */ +#define MIPI_DSI_MODE_VIDEO_HBP BIT(6) +/* disable hsync-active area */ +#define MIPI_DSI_MODE_VIDEO_HSA BIT(7) +/* flush display FIFO on vsync pulse */ +#define MIPI_DSI_MODE_VSYNC_FLUSH BIT(8) +/* disable EoT packets in HS mode */ +#define MIPI_DSI_MODE_EOT_PACKET BIT(9) +/* device supports non-continuous clock behavior (DSI spec 5.6.1) */ +#define MIPI_DSI_CLOCK_NON_CONTINUOUS BIT(10) +/* transmit data in low power */ +#define MIPI_DSI_MODE_LPM BIT(11) /* DSI mode flags */ + +enum mipi_dsi_pixel_format { + MIPI_DSI_FMT_RGB888, + MIPI_DSI_FMT_RGB666, + MIPI_DSI_FMT_RGB666_PACKED, + MIPI_DSI_FMT_RGB565, +}; + +/** + * struct mipi_dsi_device - DSI peripheral device + * @host: DSI host for this peripheral + * @dev: driver model device node for this peripheral + * @channel: virtual channel assigned to the peripheral + * @format: pixel format for video mode + * @lanes: number of active data lanes + * @mode_flags: DSI operation mode related flags + */ +struct mipi_dsi_device { + unsigned int channel; + unsigned int lanes; + enum mipi_dsi_pixel_format format; + unsigned long mode_flags; + struct mipi_panel_ops *ops; + ssize_t (*write_buffer)(struct mipi_dsi_device *dsi, + const void *data, size_t len); +}; + +struct mipi_panel_ops { + int (*init)(struct mipi_dsi_device *dsi, int width, int height); + int (*prepare)(struct mipi_dsi_device *dsi); + int (*unprepare)(struct mipi_dsi_device *dsi); + int (*enable)(struct mipi_dsi_device *dsi); + int (*disable)(struct mipi_dsi_device *dsi); + void *private_data; +}; + +#endif diff --git a/arch/arm/mach-nexell/include/mach/nexell.h b/arch/arm/mach-nexell/include/mach/nexell.h new file mode 100644 index 0000000..e42805f --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/nexell.h @@ -0,0 +1,352 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * (C) Copyright 2016 Nexell + * Hyunseok, Jung hsjung@nexell.co.kr + */ + +#ifndef __NEXELL_H__ +#define __NEXELL_H__ + +#define PHY_BASEADDR_DMA0 (0xC0000000) +#define PHY_BASEADDR_DMA1 (0xC0001000) +#if defined(CONFIG_ARCH_S5P4418) +#define PHY_BASEADDR_INTC0 (0xC0002000) +#define PHY_BASEADDR_INTC1 (0xC0003000) +#elif defined(CONFIG_ARCH_S5P6818) +#define PHY_BASEADDR_INTC (0xC0008000) +#endif +#define PHY_BASEADDR_CLKPWR (0xC0010000) +#define PHY_BASEADDR_RTC (0xC0010C00) +#define PHY_BASEADDR_ALIVE (0xC0010800) +#define PHY_BASEADDR_RSTCON (0xC0012000) +#define PHY_BASEADDR_TIEOFF (0xC0011000) +#define PHY_BASEADDR_PDM (0xC0014000) +#define PHY_BASEADDR_CRYPTO (0xC0015000) +#define PHY_BASEADDR_TIMER (0xC0017000) +#define PHY_BASEADDR_PWM (0xC0018000) +#define PHY_BASEADDR_WDT (0xC0019000) +#define PHY_BASEADDR_GPIOA (0xC001A000) +#define PHY_BASEADDR_GPIOB (0xC001B000) +#define PHY_BASEADDR_GPIOC (0xC001C000) +#define PHY_BASEADDR_GPIOD (0xC001D000) +#define PHY_BASEADDR_GPIOE (0xC001E000) +#define PHY_BASEADDR_OHCI (0xC0020000) +#define PHY_BASEADDR_EHCI (0xC0030000) +#define PHY_BASEADDR_HSOTG (0xC0040000) +#define PHY_BASEADDR_ADC (0xC0053000) +#define PHY_BASEADDR_PPM (0xC0054000) +#define PHY_BASEADDR_I2S0 (0xC0055000) +#define PHY_BASEADDR_I2S1 (0xC0056000) +#define PHY_BASEADDR_I2S2 (0xC0057000) +#define PHY_BASEADDR_AC97 (0xC0058000) +#define PHY_BASEADDR_SPDIF_TX (0xC0059000) +#define PHY_BASEADDR_SPDIF_RX (0xC005A000) +#define PHY_BASEADDR_SSP0 (0xC005B000) +#define PHY_BASEADDR_SSP1 (0xC005C000) +#define PHY_BASEADDR_SSP2 (0xC005F000) +#define PHY_BASEADDR_MPEGTSI (0xC005D000) +#define PHY_BASEADDR_GMAC (0xC0060000) +#define PHY_BASEADDR_VIP0 (0xC0063000) +#define PHY_BASEADDR_VIP1 (0xC0064000) +#if defined(CONFIG_ARCH_S5P6818) +#define PHY_BASEADDR_VIP2 (0xC0099000) +#endif +#define PHY_BASEADDR_DEINTERLACE (0xC0065000) +#define PHY_BASEADDR_SCALER (0xC0066000) +#define PHY_BASEADDR_ECID (0xC0067000) +#define PHY_BASEADDR_SDMMC0 (0xC0062000) +#define PHY_BASEADDR_SDMMC1 (0xC0068000) +#define PHY_BASEADDR_SDMMC2 (0xC0069000) +#define PHY_BASEADDR_MALI400 (0xC0070000) +#define PHY_BASEADDR_CODA_APB0 (0xC0080000) +#define PHY_BASEADDR_CODA_APB1 (0xC0081000) +#define PHY_BASEADDR_CODA_APB2 (0xC0082000) +#define PHY_BASEADDR_CODA_APB3 (0xC0083000) +/* dma (O), modem(X), UART0_MODULE */ +#define PHY_BASEADDR_UART0 (0xC00A1000) +/* dma (O), modem(O), pl01115_Uart_modem_MODULE */ +#define PHY_BASEADDR_UART1 (0xC00A0000) +/* dma (O), modem(X), UART1_MODULE */ +#define PHY_BASEADDR_UART2 (0xC00A2000) +/* dma (X), modem(X), pl01115_Uart_nodma0_MODULE */ +#define PHY_BASEADDR_UART3 (0xC00A3000) +/* dma (X), modem(X), pl01115_Uart_nodma1_MODULE */ +#define PHY_BASEADDR_UART4 (0xC006D000) +/* dma (X), modem(X), pl01115_Uart_nodma2_MODULE */ +#define PHY_BASEADDR_UART5 (0xC006F000) +#define PHY_BASEADDR_I2C0 (0xC00A4000) +#define PHY_BASEADDR_I2C1 (0xC00A5000) +#define PHY_BASEADDR_I2C2 (0xC00A6000) +#define PHY_BASEADDR_CAN0 (0xC00CE000) +#define PHY_BASEADDR_CAN1 (0xC00CF000) +#define PHY_BASEADDR_MIPI (0xC00D0000) +#define PHY_BASEADDR_DISPLAYTOP (0xC0100000) + +#define PHY_BASEADDR_CLKGEN0 (0xC00BB000) /* TIMER_1 */ +#define PHY_BASEADDR_CLKGEN1 (0xC00BC000) /* TIMER_2 */ +#define PHY_BASEADDR_CLKGEN2 (0xC00BD000) /* TIMER_3 */ +#define PHY_BASEADDR_CLKGEN3 (0xC00BE000) /* PWM_1 */ +#define PHY_BASEADDR_CLKGEN4 (0xC00BF000) /* PWM_2 */ +#define PHY_BASEADDR_CLKGEN5 (0xC00C0000) /* PWM_3 */ +#define PHY_BASEADDR_CLKGEN6 (0xC00AE000) /* I2C_0 */ +#define PHY_BASEADDR_CLKGEN7 (0xC00AF000) /* I2C_1 */ +#define PHY_BASEADDR_CLKGEN8 (0xC00B0000) /* I2C_2 */ +#define PHY_BASEADDR_CLKGEN9 (0xC00CA000) /* MIPI */ +#define PHY_BASEADDR_CLKGEN10 (0xC00C8000) /* GMAC */ +#define PHY_BASEADDR_CLKGEN11 (0xC00B8000) /* SPDIF_TX */ +#define PHY_BASEADDR_CLKGEN12 (0xC00B7000) /* MPEGTSI */ +#define PHY_BASEADDR_CLKGEN13 (0xC00BA000) /* PWM_0 */ +#define PHY_BASEADDR_CLKGEN14 (0xC00B9000) /* TIMER_0 */ +#define PHY_BASEADDR_CLKGEN15 (0xC00B2000) /* I2S_0 */ +#define PHY_BASEADDR_CLKGEN16 (0xC00B3000) /* I2S_1 */ +#define PHY_BASEADDR_CLKGEN17 (0xC00B4000) /* I2S_2 */ +#define PHY_BASEADDR_CLKGEN18 (0xC00C5000) /* SDHC_0 */ +#define PHY_BASEADDR_CLKGEN19 (0xC00CC000) /* SDHC_1 */ +#define PHY_BASEADDR_CLKGEN20 (0xC00CD000) /* SDHC_2 */ +#define PHY_BASEADDR_CLKGEN21 (0xC00C3000) /* MALI */ +#define PHY_BASEADDR_CLKGEN22 (0xC00A9000) /* UART_0 */ +#define PHY_BASEADDR_CLKGEN23 (0xC00AA000) /* UART_2 */ +#define PHY_BASEADDR_CLKGEN24 (0xC00A8000) /* UART_1 */ +#define PHY_BASEADDR_CLKGEN25 (0xC00AB000) /* UART_3 */ +#define PHY_BASEADDR_CLKGEN26 (0xC006E000) /* UART_4 */ +#define PHY_BASEADDR_CLKGEN27 (0xC00B1000) /* UART_5 */ +#define PHY_BASEADDR_CLKGEN28 (0xC00B5000) /* DEINTERLACE */ +#define PHY_BASEADDR_CLKGEN29 (0xC00C4000) /* PPM */ +#define PHY_BASEADDR_CLKGEN30 (0xC00C1000) /* VIP_0 */ +#define PHY_BASEADDR_CLKGEN31 (0xC00C2000) /* VIP_1 */ +#define PHY_BASEADDR_CLKGEN32 (0xC006B000) /* USB2HOST */ +#define PHY_BASEADDR_CLKGEN33 (0xC00C7000) /* CODA */ +#define PHY_BASEADDR_CLKGEN34 (0xC00C6000) /* CRYPTO */ +#define PHY_BASEADDR_CLKGEN35 (0xC00B6000) /* SCALER */ +#define PHY_BASEADDR_CLKGEN36 (0xC00CB000) /* PDM */ +#define PHY_BASEADDR_CLKGEN37 (0xC00AC000) /* SPI0 */ +#define PHY_BASEADDR_CLKGEN38 (0xC00AD000) /* SPI1 */ +#define PHY_BASEADDR_CLKGEN39 (0xC00A7000) /* SPI2 */ +#if defined(CONFIG_ARCH_S5P6818) +#define PHY_BASEADDR_CLKGEN40 (0xC009A000) +#endif +#define PHY_BASEADDR_DREX (0xC00E0000) + +#define PHY_BASEADDR_CS_NAND (0x2C000000) + +#define PHY_BASEADDR_SRAM (0xFFFF0000) + +/* + * Nexell clock generator + */ +#define CLK_ID_TIMER_1 0 +#define CLK_ID_TIMER_2 1 +#define CLK_ID_TIMER_3 2 +#define CLK_ID_PWM_1 3 +#define CLK_ID_PWM_2 4 +#define CLK_ID_PWM_3 5 +#define CLK_ID_I2C_0 6 +#define CLK_ID_I2C_1 7 +#define CLK_ID_I2C_2 8 +#define CLK_ID_MIPI 9 +#define CLK_ID_GMAC 10 /* External Clock 1 */ +#define CLK_ID_SPDIF_TX 11 +#define CLK_ID_MPEGTSI 12 +#define CLK_ID_PWM_0 13 +#define CLK_ID_TIMER_0 14 +#define CLK_ID_I2S_0 15 /* External Clock 1 */ +#define CLK_ID_I2S_1 16 /* External Clock 1 */ +#define CLK_ID_I2S_2 17 /* External Clock 1 */ +#define CLK_ID_SDHC_0 18 +#define CLK_ID_SDHC_1 19 +#define CLK_ID_SDHC_2 20 +#define CLK_ID_MALI 21 +#define CLK_ID_UART_0 22 /* UART0_MODULE */ +#define CLK_ID_UART_2 23 /* UART1_MODULE */ +#define CLK_ID_UART_1 24 /* pl01115_Uart_modem_MODULE */ +#define CLK_ID_UART_3 25 /* pl01115_Uart_nodma0_MODULE */ +#define CLK_ID_UART_4 26 /* pl01115_Uart_nodma1_MODULE */ +#define CLK_ID_UART_5 27 /* pl01115_Uart_nodma2_MODULE */ +#define CLK_ID_DIT 28 +#define CLK_ID_PPM 29 +#define CLK_ID_VIP_0 30 /* External Clock 1 */ +#define CLK_ID_VIP_1 31 /* External Clock 1, 2 */ +#define CLK_ID_USB2HOST 32 /* External Clock 2 */ +#define CLK_ID_CODA 33 +#define CLK_ID_CRYPTO 34 +#define CLK_ID_SCALER 35 +#define CLK_ID_PDM 36 +#define CLK_ID_SPI_0 37 +#define CLK_ID_SPI_1 38 +#define CLK_ID_SPI_2 39 +#define CLK_ID_MAX 39 + +/* + * Nexell Reset control + */ +#define RESET_ID_AC97 0 +#define RESET_ID_CPU1 1 +#define RESET_ID_CPU2 2 +#define RESET_ID_CPU3 3 +#define RESET_ID_WD1 4 +#define RESET_ID_WD2 5 +#define RESET_ID_WD3 6 +#define RESET_ID_CRYPTO 7 +#define RESET_ID_DEINTERLACE 8 +#define RESET_ID_DISP_TOP 9 +#define RESET_ID_DISPLAY 10 +#define RESET_ID_RESCONV 11 +#define RESET_ID_LCDIF 12 +#define RESET_ID_HDMI 13 +#define RESET_ID_HDMI_VIDEO 14 +#define RESET_ID_HDMI_SPDIF 15 +#define RESET_ID_HDMI_TMDS 16 +#define RESET_ID_HDMI_PHY 17 +#define RESET_ID_LVDS 18 +#define RESET_ID_ECID 19 +#define RESET_ID_I2C0 20 +#define RESET_ID_I2C1 21 +#define RESET_ID_I2C2 22 +#define RESET_ID_I2S0 23 +#define RESET_ID_I2S1 24 +#define RESET_ID_I2S2 25 +#define RESET_ID_DREX_C 26 +#define RESET_ID_DREX_A 27 +#define RESET_ID_DREX 28 +#define RESET_ID_MIPI 29 +#define RESET_ID_MIPI_DSI 30 +#define RESET_ID_MIPI_CSI 31 +#define RESET_ID_MIPI_PHY_S 32 +#define RESET_ID_MIPI_PHY_M 33 +#define RESET_ID_MPEGTSI 34 +#define RESET_ID_PDM 35 +#define RESET_ID_TIMER 36 +#define RESET_ID_PWM 37 +#define RESET_ID_SCALER 38 +#define RESET_ID_SDMMC0 39 +#define RESET_ID_SDMMC1 40 +#define RESET_ID_SDMMC2 41 +#define RESET_ID_SPDIFRX 42 +#define RESET_ID_SPDIFTX 43 +#define RESET_ID_SSP0_P 44 +#define RESET_ID_SSP0 45 +#define RESET_ID_SSP1_P 46 +#define RESET_ID_SSP1 47 +#define RESET_ID_SSP2_P 48 +#define RESET_ID_SSP2 49 +#define RESET_ID_UART0 50 /* UART1 */ +#define RESET_ID_UART1 51 /* pl01115_Uart_modem */ +#define RESET_ID_UART2 52 /* UART1 */ +#define RESET_ID_UART3 53 /* pl01115_Uart_nodma0 */ +#define RESET_ID_UART4 54 /* pl01115_Uart_nodma1 */ +#define RESET_ID_UART5 55 /* pl01115_Uart_nodma2 */ +#define RESET_ID_USB20HOST 56 +#define RESET_ID_USB20OTG 57 +#define RESET_ID_WDT 58 +#define RESET_ID_WDT_POR 59 +#define RESET_ID_ADC 60 +#define RESET_ID_CODA_A 61 +#define RESET_ID_CODA_P 62 +#define RESET_ID_CODA_C 63 +#define RESET_ID_DWC_GMAC 64 +#define RESET_ID_MALI400 65 +#define RESET_ID_PPM 66 +#define RESET_ID_VIP1 67 +#define RESET_ID_VIP0 68 +#if defined(CONFIG_ARCH_S5P6818) +#define RESET_ID_VIP2 69 +#endif + +/* + * device name + */ +#define DEV_NAME_UART "nx-uart" /* pl0115 (amba-pl011.c) */ +#define DEV_NAME_FB "nx-fb" +#define DEV_NAME_DISP "nx-disp" +#define DEV_NAME_LCD "nx-lcd" +#define DEV_NAME_LVDS "nx-lvds" +#define DEV_NAME_HDMI "nx-hdmi" +#define DEV_NAME_RESCONV "nx-resconv" +#define DEV_NAME_MIPI "nx-mipi" +#define DEV_NAME_PCM "nx-pcm" +#define DEV_NAME_I2S "nx-i2s" +#define DEV_NAME_SPDIF_TX "nx-spdif-tx" +#define DEV_NAME_SPDIF_RX "nx-spdif-rx" +#define DEV_NAME_I2C "nx-i2c" +#define DEV_NAME_NAND "nx-nand" +#define DEV_NAME_KEYPAD "nx-keypad" +#define DEV_NAME_SDHC "nx-sdhc" +#define DEV_NAME_PWM "nx-pwm" +#define DEV_NAME_TIMER "nx-timer" +#define DEV_NAME_SOC_PWM "nx-soc-pwm" +#define DEV_NAME_GPIO "nx-gpio" +#define DEV_NAME_RTC "nx-rtc" +#define DEV_NAME_GMAC "nx-gmac" +#define DEV_NAME_MPEGTSI "nx-mpegtsi" +#define DEV_NAME_MALI "nx-mali" +#define DEV_NAME_DIT "nx-deinterlace" +#define DEV_NAME_PPM "nx-ppm" +#define DEV_NAME_VIP "nx-vip" +#define DEV_NAME_CODA "nx-coda" +#define DEV_NAME_USB2HOST "nx-usb2h" +#define DEV_NAME_CRYPTO "nx-crypto" +#define DEV_NAME_SCALER "nx-scaler" +#define DEV_NAME_PDM "nx-pdm" +#define DEV_NAME_SPI "nx-spi" +#define DEV_NAME_CPUFREQ "nx-cpufreq" + +/* + * clock generator + */ +#define CORECLK_NAME_PLL0 "pll0" /* cpu clock */ +#define CORECLK_NAME_PLL1 "pll1" +#define CORECLK_NAME_PLL2 "pll2" +#define CORECLK_NAME_PLL3 "pll3" +#define CORECLK_NAME_FCLK "fclk" +#define CORECLK_NAME_MCLK "mclk" +#define CORECLK_NAME_BCLK "bclk" +#define CORECLK_NAME_PCLK "pclk" +#define CORECLK_NAME_HCLK "hclk" + +#define CORECLK_ID_PLL0 0 +#define CORECLK_ID_PLL1 1 +#define CORECLK_ID_PLL2 2 +#define CORECLK_ID_PLL3 3 +#define CORECLK_ID_FCLK 4 +#define CORECLK_ID_MCLK 5 +#define CORECLK_ID_BCLK 6 +#define CORECLK_ID_PCLK 7 +#define CORECLK_ID_HCLK 8 + +#define ALIVEPWRGATEREG (PHY_BASEADDR_ALIVE + 0x0) + +#if defined(CONFIG_ARCH_S5P4418) +#define SCR_ARM_SECOND_BOOT (0xC0010C1C) /* PWR scratch */ +#define SCR_ARM_SECOND_BOOT_REG1 (0xc0010234) /* ToDo : Check Address */ +#elif defined(CONFIG_ARCH_S5P6818) +#define SCR_ARM_SECOND_BOOT (0xc0010230) /* PWR scratch */ +#define SCR_ARM_SECOND_BOOT_REG1 (0xc0010234) /* PWR scratch */ +#define SCR_ARM_SECOND_BOOT_REG2 (0xc0010238) /* PWR scratch */ +#endif + +#define SCR_ALIVE_BASE (PHY_BASEADDR_ALIVE) +#define SCR_SIGNAGURE_RESET (SCR_ALIVE_BASE + 0x068) +#define SCR_SIGNAGURE_SET (SCR_ALIVE_BASE + 0x06C) +#define SCR_SIGNAGURE_READ (SCR_ALIVE_BASE + 0x070) + +#define SYSRSTCONFIG (0x23C) +#define DEVICEBOOTINFO (0x50) +#define BOOTMODE_MASK (0x7) +#define BOOTMODE_SDMMC 5 +#define BOOTMODE_USB 6 +#define BOOTMODE_SDMMC_PORT_VAL(x) ((((x) >> 3) & 1) | \ + (((x) >> 19 & 1) << 1)) +#define EMMC_PORT_NUM 2 +#define SD_PORT_NUM 0 +#define ID_REG_EC0 (0x54) +#define WIRE0_MASK (0x1) + +#ifndef __ASSEMBLY__ + +#define NS_IN_HZ (1000000000UL) +#define TO_PERIOD_NS(freq) (NS_IN_HZ / (freq)) +#define TO_DUTY_NS(duty, freq) (duty ? TO_PERIOD_NS(freq) / (100 / duty) : 0) + +#endif /* __ASSEMBLY__ */ + +#endif /* __NEXELL_H__ */ diff --git a/arch/arm/mach-nexell/include/mach/nx_gpio.h b/arch/arm/mach-nexell/include/mach/nx_gpio.h new file mode 100644 index 0000000..91803d2 --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/nx_gpio.h @@ -0,0 +1,103 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * (C) Copyright 2016 Nexell + * Youngbok, Park ybpark@nexell.co.kr + */ + +#include <linux/types.h> +#include <asm/io.h> + +#ifndef __nx_gpio_h__ +#define __nx_gpio_h__ + +struct nx_gpio_register_set { + u32 gpioxout; + u32 gpioxoutenb; + u32 gpioxdetmode[2]; + u32 gpioxintenb; + u32 gpioxdet; + u32 gpioxpad; + u32 gpioxpuenb; + u32 gpioxaltfn[2]; + u32 gpioxdetmodeex; + u32 __reserved[4]; + u32 gpioxdetenb; + u32 gpiox_slew; + u32 gpiox_slew_disable_default; + u32 gpiox_drv1; + u32 gpiox_drv1_disable_default; + u32 gpiox_drv0; + u32 gpiox_drv0_disable_default; + u32 gpiox_pullsel; + u32 gpiox_pullsel_disable_default; + u32 gpiox_pullenb; + u32 gpiox_pullenb_disable_default; + u32 gpiox_input_mux_select0; + u32 gpiox_input_mux_select1; + u8 __reserved1[0x1000 - 0x70]; +}; + +enum { + nx_gpio_padfunc_0 = 0ul, + nx_gpio_padfunc_1 = 1ul, + nx_gpio_padfunc_2 = 2ul, + nx_gpio_padfunc_3 = 3ul +}; + +enum { + nx_gpio_drvstrength_0 = 0ul, + nx_gpio_drvstrength_1 = 1ul, + nx_gpio_drvstrength_2 = 2ul, + nx_gpio_drvstrength_3 = 3ul +}; + +enum { + nx_gpio_pull_down = 0ul, + nx_gpio_pull_up = 1ul, + nx_gpio_pull_off = 2ul +}; + +int nx_gpio_initialize(void); +u32 nx_gpio_get_number_of_module(void); +u32 nx_gpio_get_size_of_register_set(void); +void nx_gpio_set_base_address(u32 module_index, void *base_address); +void *nx_gpio_get_base_address(u32 module_index); +int nx_gpio_open_module(u32 module_index); +int nx_gpio_close_module(u32 module_index); +int nx_gpio_check_busy(u32 module_index); +void nx_gpio_set_detect_enable(u32 module_index, u32 bit_number, + int detect_enb); +void nx_gpio_set_pad_function(u32 module_index, u32 bit_number, u32 padfunc); +void nx_gpio_set_pad_function32(u32 module_index, u32 msbvalue, u32 lsbvalue); +int nx_gpio_get_pad_function(u32 module_index, u32 bit_number); +void nx_gpio_set_output_enable(u32 module_index, u32 bit_number, + int output_enb); +int nx_gpio_get_detect_enable(u32 module_index, u32 bit_number); +u32 nx_gpio_get_detect_enable32(u32 module_index); +void nx_gpio_set_detect_enable(u32 module_index, u32 bit_number, + int detect_enb); +void nx_gpio_set_detect_enable32(u32 module_index, u32 enable_flag); +int nx_gpio_get_output_enable(u32 module_index, u32 bit_number); +void nx_gpio_set_output_enable32(u32 module_index, int output_enb); +u32 nx_gpio_get_output_enable32(u32 module_index); +void nx_gpio_set_output_value(u32 module_index, u32 bit_number, int value); +int nx_gpio_get_output_value(u32 module_index, u32 bit_number); +void nx_gpio_set_output_value32(u32 module_index, u32 value); +u32 nx_gpio_get_output_value32(u32 module_index); +int nx_gpio_get_input_value(u32 module_index, u32 bit_number); +void nx_gpio_set_pull_select(u32 module_index, u32 bit_number, int enable); +void nx_gpio_set_pull_select32(u32 module_index, u32 value); +int nx_gpio_get_pull_select(u32 module_index, u32 bit_number); +u32 nx_gpio_get_pull_select32(u32 module_index); +void nx_gpio_set_pull_mode(u32 module_index, u32 bit_number, u32 mode); +void nx_gpio_set_fast_slew(u32 module_index, u32 bit_number, int enable); +void nx_gpio_set_drive_strength_disable_default(u32 module_index, + u32 bit_number, int enable); +void nx_gpio_set_drive_strength_disable_default(u32 module_index, + u32 bit_number, int enable); +void nx_gpio_set_drive_strength(u32 module_index, u32 bit_number, + u32 drvstrength); +void nx_gpio_set_drive_strength_disable_default(u32 module_index, + u32 bit_number, int enable); +u32 nx_gpio_get_drive_strength(u32 module_index, u32 bit_number); +#endif diff --git a/arch/arm/mach-nexell/include/mach/reset.h b/arch/arm/mach-nexell/include/mach/reset.h new file mode 100644 index 0000000..e1301d4 --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/reset.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * (C) Copyright 2016 Nexell + * Youngbok, Park ybpark@nexell.co.kr + */ + +#ifndef __NEXELL_RESET__ +#define __NEXELL_RESET__ + +#define NUMBER_OF_RESET_MODULE_PIN 69 + +enum rstcon { + RSTCON_ASSERT = 0UL, + RSTCON_NEGATE = 1UL +}; + +void nx_rstcon_setrst(u32 rstindex, enum rstcon status); + +#endif /* __NEXELL_RESET__ */ diff --git a/arch/arm/mach-nexell/include/mach/sec_reg.h b/arch/arm/mach-nexell/include/mach/sec_reg.h new file mode 100644 index 0000000..e3ae5ac --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/sec_reg.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * (C) Copyright 2016 Nexell + * Youngbok, Park park@nexell.co.kr + */ + +#define NEXELL_L2C_SEC_ID 0 +#define NEXELL_MALI_SEC_ID 2 +#define NEXELL_MIPI_SEC_ID 4 +#define NEXELL_TOFF_SEC_ID 6 + +int write_sec_reg_by_id(void __iomem *reg, int val, int id); +int read_sec_reg_by_id(void __iomem *reg, int id); +int read_sec_reg(void __iomem *reg); +int write_sec_reg(void __iomem *reg, int val); diff --git a/arch/arm/mach-nexell/include/mach/tieoff.h b/arch/arm/mach-nexell/include/mach/tieoff.h new file mode 100644 index 0000000..70e9652 --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/tieoff.h @@ -0,0 +1,423 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * (C) Copyright 2016 Nexell + * Youngbok, Park park@nexell.co.kr + */ + +#ifndef _NEXELL_TIEOFF_H +#define _NEXELL_TIEOFF_H + +void nx_tieoff_set(u32 tieoff_index, u32 tieoff_value); +u32 nx_tieoff_get(u32 tieoff_index); + +#if defined(CONFIG_ARCH_S5P4418) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CLAMPCOREOUT ((1 << 16) | 0) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CLAMPCPU0 ((1 << 16) | 1) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CLAMPCPU1 ((1 << 16) | 2) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CLAMPCPU2 ((1 << 16) | 3) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CLAMPCPU3 ((1 << 16) | 4) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_COREPWRDOWN ((1 << 16) | 5) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CPU0PWRDOWN ((1 << 16) | 6) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CPU1PWRDOWN ((1 << 16) | 7) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CPU2PWRDOWN ((1 << 16) | 8) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CPU3PWRDOWN ((1 << 16) | 9) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2_CFGENDIAN ((1 << 16) | 10) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L1EMAS ((1 << 16) | 11) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2RET1N_0 ((1 << 16) | 12) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2RET1N_1 ((1 << 16) | 13) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2PGEN_0 ((1 << 16) | 14) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2PGEN_1 ((1 << 16) | 15) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CLAMPL2_0 ((1 << 16) | 16) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CLAMPL2_1 ((1 << 16) | 17) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_VINITHI ((4 << 16) | 18) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2EMA ((3 << 16) | 22) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_TEINIT ((4 << 16) | 25) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L1EMAW ((2 << 16) | 29) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2EMAW ((2 << 16) | 32) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L1EMA ((3 << 16) | 34) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_CPUCLKOFF ((4 << 16) | 37) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_PWRCTLI0 ((2 << 16) | 41) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_PWRCTLI1 ((2 << 16) | 43) +#define NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_PWRCTLI2 ((2 << 16) | 45) +#elif defined(CONFIG_ARCH_S5P6818) +#define NX_TIEOFF_MMC_8BIT ((1 << 16) | 5) +#endif +#define NX_TIEOFF_AXISRAM0_i_TIE_ra2w_EMAA ((3 << 16) | 47) +#define NX_TIEOFF_AXISRAM0_i_TIE_ra2w_EMAB ((3 << 16) | 50) +#define NX_TIEOFF_AXISRAM0_i_TIE_ra2w_EMAWA ((2 << 16) | 53) +#define NX_TIEOFF_AXISRAM0_i_TIE_ra2w_EMAWB ((2 << 16) | 55) +#define NX_TIEOFF_AXISRAM0_i_nPowerDown ((1 << 16) | 57) +#define NX_TIEOFF_AXISRAM0_i_nSleep ((1 << 16) | 58) +#define NX_TIEOFF_CAN0_i_TIE_rf1_EMA ((3 << 16) | 59) +#define NX_TIEOFF_CAN0_i_TIE_rf1_EMAW ((2 << 16) | 62) +#define NX_TIEOFF_CAN0_i_nPowerDown ((1 << 16) | 64) +#define NX_TIEOFF_CAN0_i_nSleep ((1 << 16) | 65) +#define NX_TIEOFF_CAN1_i_TIE_rf1_EMA ((3 << 16) | 66) +#define NX_TIEOFF_CAN1_i_TIE_rf1_EMAW ((2 << 16) | 69) +#define NX_TIEOFF_CAN1_i_nPowerDown ((1 << 16) | 71) +#define NX_TIEOFF_CAN1_i_nSleep ((1 << 16) | 72) +#define NX_TIEOFF_DEINTERLACE0_i_NX_RF1_EMA ((3 << 16) | 73) +#define NX_TIEOFF_DEINTERLACE0_i_NX_RF1_EMAW ((2 << 16) | 76) +#define NX_TIEOFF_DEINTERLACE0_i_NX_RF2_EMAA ((3 << 16) | 78) +#define NX_TIEOFF_DEINTERLACE0_i_NX_RF2_EMAB ((3 << 16) | 81) +#define NX_TIEOFF_DEINTERLACE0_i_NX_RF2W_EMAA ((3 << 16) | 84) +#define NX_TIEOFF_DEINTERLACE0_i_NX_RF2W_EMAB ((3 << 16) | 87) +#define NX_TIEOFF_DISPLAYTOP0_i_ResConv_nPowerDown ((1 << 16) | 90) +#define NX_TIEOFF_DISPLAYTOP0_i_ResConv_nSleep ((1 << 16) | 91) +#define NX_TIEOFF_DISPLAYTOP0_i_HDMI_nPowerDown ((2 << 16) | 92) +#define NX_TIEOFF_DISPLAYTOP0_i_HDMI_nSleep ((2 << 16) | 94) +#define NX_TIEOFF_DISPLAYTOP0_i_HDMI_PHY_REFCLK_SEL ((1 << 16) | 96) +#define NX_TIEOFF_DISPLAYTOP0_i_TIEOFF_SPSRAM_EMA ((3 << 16) | 97) +#define NX_TIEOFF_DISPLAYTOP0_i_TIEOFF_SPSRAM_EMAW ((2 << 16) | 100) +#define NX_TIEOFF_DISPLAYTOP0_i_TIEOFF_DPSRAM_1R1W_EMAA ((3 << 16) | 102) +#define NX_TIEOFF_DISPLAYTOP0_i_TIEOFF_DPSRAM_1R1W_EMAB ((3 << 16) | 105) +#define NX_TIEOFF_DISPLAYTOP0_i_TIEOFF_DPSRAM_EMAA ((3 << 16) | 108) +#define NX_TIEOFF_DISPLAYTOP0_i_TIEOFF_DPSRAM_EMAB ((3 << 16) | 111) +#define NX_TIEOFF_DISPLAYTOP0_i_TIEOFF_DPSRAM_EMAWA ((2 << 16) | 114) +#define NX_TIEOFF_DISPLAYTOP0_i_TIEOFF_DPSRAM_EMAWB ((2 << 16) | 116) +#define NX_TIEOFF_MCUSTOP0_i_vrom_EMA ((3 << 16) | 118) +#define NX_TIEOFF_DREX0_CKE_INIT ((1 << 16) | 121) +#define NX_TIEOFF_DREX0_CA_SWAP ((1 << 16) | 122) +#define NX_TIEOFF_DREX0_CSYSREQ ((1 << 16) | 123) +#define NX_TIEOFF_DREX0_PAUSE_REQ ((1 << 16) | 124) +#define NX_TIEOFF_DREX0_PEREV_TRIGGER ((1 << 16) | 125) +#define NX_TIEOFF_DREX0_CTRL_HCKE ((1 << 16) | 126) +#define NX_TIEOFF_DREX0_DFI_RESET_N_P0 ((1 << 16) | 127) +#define NX_TIEOFF_DREX0_DFI_RESET_N_P1 ((1 << 16) | 128) +#define NX_TIEOFF_MIPI0_NX_DPSRAM_1R1W_EMAA ((3 << 16) | 129) +#define NX_TIEOFF_MIPI0_NX_DPSRAM_1R1W_EMAB ((3 << 16) | 132) +#define NX_TIEOFF_MIPI0_i_NX_NPOWERDOWN ((4 << 16) | 135) +#define NX_TIEOFF_MIPI0_i_NX_NSLEEP ((4 << 16) | 139) +#define NX_TIEOFF_SCALER0_i_NX_EMA ((3 << 16) | 143) +#define NX_TIEOFF_SCALER0_i_NX_EMAW ((2 << 16) | 146) +#define NX_TIEOFF_UART0_USESMC ((1 << 16) | 148) +#define NX_TIEOFF_UART0_SMCTXENB ((1 << 16) | 149) +#define NX_TIEOFF_UART0_SMCRXENB ((1 << 16) | 150) +#define NX_TIEOFF_UART1_USESMC ((1 << 16) | 151) +#define NX_TIEOFF_UART1_SMCTXENB ((1 << 16) | 152) +#define NX_TIEOFF_UART1_SMCRXENB ((1 << 16) | 153) +#define NX_TIEOFF_UART2_USESMC ((1 << 16) | 154) +#define NX_TIEOFF_UART2_SMCTXENB ((1 << 16) | 155) +#define NX_TIEOFF_UART2_SMCRXENB ((1 << 16) | 156) +#define NX_TIEOFF_UART3_USESMC ((1 << 16) | 157) +#define NX_TIEOFF_UART3_SMCTXENB ((1 << 16) | 158) +#define NX_TIEOFF_UART3_SMCRXENB ((1 << 16) | 159) +#define NX_TIEOFF_UART4_USESMC ((1 << 16) | 160) +#define NX_TIEOFF_UART4_SMCTXENB ((1 << 16) | 161) +#define NX_TIEOFF_UART4_SMCRXENB ((1 << 16) | 162) +#define NX_TIEOFF_UART5_USESMC ((1 << 16) | 163) +#define NX_TIEOFF_UART5_SMCTXENB ((1 << 16) | 164) +#define NX_TIEOFF_UART5_SMCRXENB ((1 << 16) | 165) +#define NX_TIEOFF_USB20HOST0_i_nPowerDown ((1 << 16) | 166) +#define NX_TIEOFF_USB20HOST0_i_nSleep ((1 << 16) | 167) +#define NX_TIEOFF_USB20HOST0_i_NX_RF1_EMA ((3 << 16) | 168) +#define NX_TIEOFF_USB20HOST0_i_NX_RF1_EMAW ((2 << 16) | 171) +#define NX_TIEOFF_USB20HOST0_sys_interrupt_i ((1 << 16) | 173) +#define NX_TIEOFF_USB20HOST0_i_hsic_en ((3 << 16) | 174) +#define NX_TIEOFF_USB20HOST0_i_nResetSync ((1 << 16) | 177) +#define NX_TIEOFF_USB20HOST0_i_nResetSync_ohci ((1 << 16) | 178) +#define NX_TIEOFF_USB20HOST0_i_nAuxWellResetSync ((1 << 16) | 179) +#define NX_TIEOFF_USB20HOST0_i_nHostPhyResetSync ((1 << 16) | 180) +#define NX_TIEOFF_USB20HOST0_i_nHostUtmiResetSync ((1 << 16) | 181) +#define NX_TIEOFF_USB20HOST0_i_nHostHsicResetSync ((1 << 16) | 182) +#define NX_TIEOFF_USB20HOST0_i_HSIC_FREE_CLOCK_ENB ((1 << 16) | 183) +#define NX_TIEOFF_USB20HOST0_i_HSIC_480M_FROM_OTG_PHY ((1 << 16) | 184) +#define NX_TIEOFF_USB20HOST0_ss_word_if_enb_i ((1 << 16) | 185) +#define NX_TIEOFF_USB20HOST0_ss_word_if_i ((1 << 16) | 186) +#define NX_TIEOFF_USB20HOST0_ss_utmi_backward_enb_i ((1 << 16) | 187) +#define NX_TIEOFF_USB20HOST0_ss_resume_utmi_pls_dis_i ((1 << 16) | 188) +#define NX_TIEOFF_USB20HOST0_phy_vstatus_0_i ((3 << 16) | 189) +#define NX_TIEOFF_USB20HOST0_phy_vstatus_1_i ((3 << 16) | 192) +#define NX_TIEOFF_USB20HOST0_phy_vstatus_2_i ((3 << 16) | 195) +#define NX_TIEOFF_USB20HOST0_phy_vstatus_3_i ((3 << 16) | 198) +#define NX_TIEOFF_USB20HOST0_phy_vstatus_4_i ((3 << 16) | 201) +#define NX_TIEOFF_USB20HOST0_phy_vstatus_5_i ((3 << 16) | 204) +#define NX_TIEOFF_USB20HOST0_phy_vstatus_6_i ((3 << 16) | 207) +#define NX_TIEOFF_USB20HOST0_phy_vstatus_7_i ((3 << 16) | 210) +#define NX_TIEOFF_USB20HOST0_ss_power_state_valid_i ((1 << 16) | 213) +#define NX_TIEOFF_USB20HOST0_ss_nxt_power_state_valid_i ((1 << 16) | 214) +#define NX_TIEOFF_USB20HOST0_ss_power_state_i ((2 << 16) | 215) +#define NX_TIEOFF_USB20HOST0_ss_next_power_state_i ((2 << 16) | 217) +#define NX_TIEOFF_USB20HOST0_app_prt_ovrcur_i ((3 << 16) | 219) +#define NX_TIEOFF_USB20HOST0_ss_simulation_mode_i ((1 << 16) | 222) +#define NX_TIEOFF_USB20HOST0_ss_fladj_val_host_i ((6 << 16) | 224) +#define NX_TIEOFF_USB20HOST0_ss_fladj_val_5_i ((3 << 16) | 230) +#define NX_TIEOFF_USB20HOST0_ss_fladj_val_4_i ((3 << 16) | 233) +#define NX_TIEOFF_USB20HOST0_ss_fladj_val_3_i ((3 << 16) | 236) +#define NX_TIEOFF_USB20HOST0_ss_fladj_val_2_i ((3 << 16) | 239) +#define NX_TIEOFF_USB20HOST0_ss_fladj_val_1_i ((3 << 16) | 242) +#define NX_TIEOFF_USB20HOST0_ss_fladj_val_0_i ((3 << 16) | 245) +#define NX_TIEOFF_USB20HOST0_ss_autoppd_on_overcur_en_i ((1 << 16) | 248) +#define NX_TIEOFF_USB20HOST0_ss_ena_incr16_i ((1 << 16) | 249) +#define NX_TIEOFF_USB20HOST0_ss_ena_incr8_i ((1 << 16) | 250) +#define NX_TIEOFF_USB20HOST0_ss_ena_incr4_i ((1 << 16) | 251) +#define NX_TIEOFF_USB20HOST0_ss_ena_incrx_align_i ((1 << 16) | 252) +#define NX_TIEOFF_USB20HOST0_i_ohci_0_cntsel_n ((1 << 16) | 253) +#define NX_TIEOFF_USB20HOST0_ohci_0_app_irq1_i ((1 << 16) | 254) +#define NX_TIEOFF_USB20HOST0_ohci_0_app_irq12_i ((1 << 16) | 255) +#define NX_TIEOFF_USB20HOST0_ohci_0_app_io_hit_i ((1 << 16) | 256) +#define NX_TIEOFF_USB20HOST0_ss_hubsetup_min_i ((1 << 16) | 257) +#define NX_TIEOFF_USB20HOST0_app_start_clk_i ((1 << 16) | 258) +#define NX_TIEOFF_USB20HOST0_ohci_susp_lgcy_i ((1 << 16) | 259) +#define NX_TIEOFF_USB20HOST0_i_SIDDQ ((1 << 16) | 260) +#define NX_TIEOFF_USB20HOST0_i_VATESTENB ((2 << 16) | 261) +#define NX_TIEOFF_USB20HOST0_i_POR_ENB ((1 << 16) | 263) +#define NX_TIEOFF_USB20HOST0_i_POR ((1 << 16) | 264) +#define NX_TIEOFF_USB20HOST0_i_REFCLKSEL ((2 << 16) | 265) +#define NX_TIEOFF_USB20HOST0_i_FSEL ((3 << 16) | 267) +#define NX_TIEOFF_USB20HOST0_i_COMMONONN ((1 << 16) | 270) +#define NX_TIEOFF_USB20HOST0_i_RESREQIN ((1 << 16) | 271) +#define NX_TIEOFF_USB20HOST0_i_PORTRESET ((1 << 16) | 272) +#define NX_TIEOFF_USB20HOST0_i_OTGDISABLE ((1 << 16) | 273) +#define NX_TIEOFF_USB20HOST0_i_LOOPBACKENB ((1 << 16) | 274) +#define NX_TIEOFF_USB20HOST0_i_IDPULLUPi ((1 << 16) | 275) +#define NX_TIEOFF_USB20HOST0_i_DRVVBUS ((1 << 16) | 276) +#define NX_TIEOFF_USB20HOST0_i_ADPCHRG ((1 << 16) | 277) +#define NX_TIEOFF_USB20HOST0_i_ADPDISCHRG ((1 << 16) | 278) +#define NX_TIEOFF_USB20HOST0_i_ADPPRBENB ((1 << 16) | 279) +#define NX_TIEOFF_USB20HOST0_i_VBUSVLDEXT ((1 << 16) | 280) +#define NX_TIEOFF_USB20HOST0_i_VBUSVLDEXTSEL ((1 << 16) | 281) +#define NX_TIEOFF_USB20HOST0_i_DPPULLDOWN ((1 << 16) | 282) +#define NX_TIEOFF_USB20HOST0_i_DMPULLDOWN ((1 << 16) | 283) +#define NX_TIEOFF_USB20HOST0_i_SUSPENDM_ENB ((1 << 16) | 284) +#define NX_TIEOFF_USB20HOST0_i_SUSPENDM ((1 << 16) | 285) +#define NX_TIEOFF_USB20HOST0_i_SLEEPM_ENB ((1 << 16) | 286) +#define NX_TIEOFF_USB20HOST0_i_SLEEPM ((1 << 16) | 287) +#define NX_TIEOFF_USB20HOST0_i_OPMODE_ENB ((1 << 16) | 288) +#define NX_TIEOFF_USB20HOST0_i_OPMODE ((2 << 16) | 289) +#define NX_TIEOFF_USB20HOST0_i_TERMSEL_ENB ((1 << 16) | 291) +#define NX_TIEOFF_USB20HOST0_i_TERMSEL ((1 << 16) | 292) +#define NX_TIEOFF_USB20HOST0_i_XCVRSEL_ENB ((1 << 16) | 293) +#define NX_TIEOFF_USB20HOST0_i_XCVRSEL ((2 << 16) | 294) +#define NX_TIEOFF_USB20HOST0_i_WORDINTERFACE_ENB ((1 << 16) | 296) +#define NX_TIEOFF_USB20HOST0_i_WORDINTERFACE ((1 << 16) | 297) +#define NX_TIEOFF_USB20HOST0_i_TXBITSTUFFEN ((1 << 16) | 298) +#define NX_TIEOFF_USB20HOST0_i_TXBITSTUFFENH ((1 << 16) | 299) +#define NX_TIEOFF_USB20HOST0_i_BYPASSDPDATA ((1 << 16) | 300) +#define NX_TIEOFF_USB20HOST0_i_BYPASSDMDATA ((1 << 16) | 301) +#define NX_TIEOFF_USB20HOST0_i_BYPASSDPEN ((1 << 16) | 302) +#define NX_TIEOFF_USB20HOST0_i_BYPASSDMEN ((1 << 16) | 303) +#define NX_TIEOFF_USB20HOST0_i_BYPASSSEL ((1 << 16) | 304) +#define NX_TIEOFF_USB20HOST0_i_COMPDISTUNE ((3 << 16) | 305) +#define NX_TIEOFF_USB20HOST0_i_SQRXTUNE ((3 << 16) | 308) +#define NX_TIEOFF_USB20HOST0_i_OTGTUNE ((3 << 16) | 311) +#define NX_TIEOFF_USB20HOST0_i_TXHSXVTUNE ((2 << 16) | 314) +#define NX_TIEOFF_USB20HOST0_i_TXFSLSTUNE ((4 << 16) | 316) +#define NX_TIEOFF_USB20HOST0_i_TXVREFTUNE ((4 << 16) | 320) +#define NX_TIEOFF_USB20HOST0_i_TXRISETUNE ((2 << 16) | 324) +#define NX_TIEOFF_USB20HOST0_i_TXRESTUNE ((2 << 16) | 326) +#define NX_TIEOFF_USB20HOST0_i_TXPREEMPAMPTUNE ((2 << 16) | 328) +#define NX_TIEOFF_USB20HOST0_i_TXPREEMPPULSETUNE ((1 << 16) | 330) +#define NX_TIEOFF_USB20HOST0_i_CHRGSEL ((1 << 16) | 331) +#define NX_TIEOFF_USB20HOST0_i_VDATDETENB ((1 << 16) | 332) +#define NX_TIEOFF_USB20HOST0_i_VDATSRCENB ((1 << 16) | 333) +#define NX_TIEOFF_USB20HOST0_i_DCDENB ((1 << 16) | 334) +#define NX_TIEOFF_USB20HOST0_i_ACAENB ((1 << 16) | 335) +#define NX_TIEOFF_USB20HOST0_i_HSIC_MSTRXCVR ((1 << 16) | 336) +#define NX_TIEOFF_USB20HOST0_i_HSIC_SIDDQ ((1 << 16) | 337) +#define NX_TIEOFF_USB20HOST0_i_HSIC_POR_ENB ((1 << 16) | 338) +#define NX_TIEOFF_USB20HOST0_i_HSIC_POR ((1 << 16) | 339) +#define NX_TIEOFF_USB20HOST0_i_HSIC_REFCLKDIV ((7 << 16) | 340) +#define NX_TIEOFF_USB20HOST0_i_HSIC_REFCLKSEL ((2 << 16) | 347) +#define NX_TIEOFF_USB20HOST0_i_HSIC_COMMONONN ((1 << 16) | 349) +#define NX_TIEOFF_USB20HOST0_i_HSIC_PORTRESET ((1 << 16) | 350) +#define NX_TIEOFF_USB20HOST0_i_HSIC_LOOPBACKENB ((1 << 16) | 351) +#define NX_TIEOFF_USB20HOST0_i_HSIC_DPPULLDOWN ((1 << 16) | 352) +#define NX_TIEOFF_USB20HOST0_i_HSIC_DMPULLDOWN ((1 << 16) | 353) +#define NX_TIEOFF_USB20HOST0_i_HSIC_SUSPENDM_ENB ((1 << 16) | 354) +#define NX_TIEOFF_USB20HOST0_i_HSIC_SUSPENDM ((1 << 16) | 355) +#define NX_TIEOFF_USB20HOST0_i_HSIC_SLEEPM_ENB ((1 << 16) | 356) +#define NX_TIEOFF_USB20HOST0_i_HSIC_SLEEPM ((1 << 16) | 357) +#define NX_TIEOFF_USB20HOST0_i_HSIC_MSTRXOPU ((1 << 16) | 358) +#define NX_TIEOFF_USB20HOST0_i_HSIC_OPMODE_ENB ((1 << 16) | 359) +#define NX_TIEOFF_USB20HOST0_i_HSIC_OPMODE ((2 << 16) | 360) +#define NX_TIEOFF_USB20HOST0_i_HSIC_XCVRSELECT_ENB ((1 << 16) | 362) +#define NX_TIEOFF_USB20HOST0_i_HSIC_XCVRSELECT ((1 << 16) | 363) +#define NX_TIEOFF_USB20HOST0_i_HSIC_WORDINTERFACE_ENB ((1 << 16) | 364) +#define NX_TIEOFF_USB20HOST0_i_HSIC_WORDINTERFACE ((1 << 16) | 365) +#define NX_TIEOFF_USB20HOST0_i_HSIC_TXBITSTUFFEN ((1 << 16) | 366) +#define NX_TIEOFF_USB20HOST0_i_HSIC_TXBITSTUFFENH ((1 << 16) | 367) +#define NX_TIEOFF_USB20HOST0_i_HSIC_TXRPUTUNE ((2 << 16) | 368) +#define NX_TIEOFF_USB20HOST0_i_HSIC_TXRPDTUNE ((2 << 16) | 370) +#define NX_TIEOFF_USB20HOST0_i_HSIC_TXSRTUNE ((4 << 16) | 372) +#define NX_TIEOFF_USB20OTG0_i_nPowerDown ((1 << 16) | 376) +#define NX_TIEOFF_USB20OTG0_i_nSleep ((1 << 16) | 377) +#define NX_TIEOFF_USB20OTG0_i_NX_RF1_EMA ((3 << 16) | 378) +#define NX_TIEOFF_USB20OTG0_i_NX_RF1_EMAW ((2 << 16) | 381) +#define NX_TIEOFF_USB20OTG0_i_ss_scaledown_mode ((2 << 16) | 384) +#define NX_TIEOFF_USB20OTG0_i_gp_in ((16 << 16) | 386) +#define NX_TIEOFF_USB20OTG0_i_sof_count ((14 << 16) | 402) +#define NX_TIEOFF_USB20OTG0_i_sys_dma_done ((1 << 16) | 416) +#define NX_TIEOFF_USB20OTG0_i_if_select_hsic ((1 << 16) | 417) +#define NX_TIEOFF_USB20OTG0_i_nResetSync ((1 << 16) | 418) +#define NX_TIEOFF_USB20OTG0_i_nUtmiResetSync ((1 << 16) | 419) +#define NX_TIEOFF_USB20OTG0_i_SIDDQ ((1 << 16) | 420) +#define NX_TIEOFF_USB20OTG0_i_VATESTENB ((2 << 16) | 421) +#define NX_TIEOFF_USB20OTG0_i_POR_ENB ((1 << 16) | 423) +#define NX_TIEOFF_USB20OTG0_i_POR ((1 << 16) | 424) +#define NX_TIEOFF_USB20OTG0_i_REFCLKSEL ((2 << 16) | 425) +#define NX_TIEOFF_USB20OTG0_i_FSEL ((3 << 16) | 427) +#define NX_TIEOFF_USB20OTG0_i_COMMONONN ((1 << 16) | 430) +#define NX_TIEOFF_USB20OTG0_i_RESREQIN ((1 << 16) | 431) +#define NX_TIEOFF_USB20OTG0_i_PORTRESET ((1 << 16) | 432) +#define NX_TIEOFF_USB20OTG0_i_OTGDISABLE ((1 << 16) | 433) +#define NX_TIEOFF_USB20OTG0_i_LOOPBACKENB ((1 << 16) | 434) +#define NX_TIEOFF_USB20OTG0_i_IDPULLUP ((1 << 16) | 435) +#define NX_TIEOFF_USB20OTG0_i_DRVVBUS ((1 << 16) | 436) +#define NX_TIEOFF_USB20OTG0_i_ADPCHRG ((1 << 16) | 437) +#define NX_TIEOFF_USB20OTG0_i_ADPDISCHRG ((1 << 16) | 438) +#define NX_TIEOFF_USB20OTG0_i_ADPPRBENB ((1 << 16) | 439) +#define NX_TIEOFF_USB20OTG0_i_VBUSVLDEXT ((1 << 16) | 440) +#define NX_TIEOFF_USB20OTG0_i_VBUSVLDEXTSEL ((1 << 16) | 441) +#define NX_TIEOFF_USB20OTG0_i_DPPULLDOWN ((1 << 16) | 442) +#define NX_TIEOFF_USB20OTG0_i_DMPULLDOWN ((1 << 16) | 443) +#define NX_TIEOFF_USB20OTG0_i_SUSPENDM_ENB ((1 << 16) | 444) +#define NX_TIEOFF_USB20OTG0_i_SUSPENDM ((1 << 16) | 445) +#define NX_TIEOFF_USB20OTG0_i_SLEEPM_ENB ((1 << 16) | 446) +#define NX_TIEOFF_USB20OTG0_i_SLEEPM ((1 << 16) | 447) +#define NX_TIEOFF_USB20OTG0_i_OPMODE_ENB ((1 << 16) | 448) +#define NX_TIEOFF_USB20OTG0_i_OPMODE ((2 << 16) | 449) +#define NX_TIEOFF_USB20OTG0_i_TERMSEL_ENB ((1 << 16) | 451) +#define NX_TIEOFF_USB20OTG0_i_TERMSEL ((1 << 16) | 452) +#define NX_TIEOFF_USB20OTG0_i_XCVRSEL_ENB ((1 << 16) | 453) +#define NX_TIEOFF_USB20OTG0_i_XCVRSEL ((2 << 16) | 454) +#define NX_TIEOFF_USB20OTG0_i_WORDINTERFACE_ENB ((1 << 16) | 456) +#define NX_TIEOFF_USB20OTG0_i_WORDINTERFACE ((1 << 16) | 457) +#define NX_TIEOFF_USB20OTG0_i_TXBITSTUFFEN ((1 << 16) | 458) +#define NX_TIEOFF_USB20OTG0_i_TXBITSTUFFENH ((1 << 16) | 459) +#define NX_TIEOFF_USB20OTG0_i_BYPASSDPDATA ((1 << 16) | 460) +#define NX_TIEOFF_USB20OTG0_i_BYPASSDMDATA ((1 << 16) | 461) +#define NX_TIEOFF_USB20OTG0_i_BYPASSDPEN ((1 << 16) | 462) +#define NX_TIEOFF_USB20OTG0_i_BYPASSDMEN ((1 << 16) | 463) +#define NX_TIEOFF_USB20OTG0_i_BYPASSSEL ((1 << 16) | 464) +#define NX_TIEOFF_USB20OTG0_i_COMPDISTUNE ((3 << 16) | 465) +#define NX_TIEOFF_USB20OTG0_i_SQRXTUNE ((3 << 16) | 468) +#define NX_TIEOFF_USB20OTG0_i_OTGTUNE ((3 << 16) | 471) +#define NX_TIEOFF_USB20OTG0_i_TXHSXVTUNE ((2 << 16) | 474) +#define NX_TIEOFF_USB20OTG0_i_TXFSLSTUNE ((4 << 16) | 476) +#define NX_TIEOFF_USB20OTG0_i_TXVREFTUNE ((4 << 16) | 480) +#define NX_TIEOFF_USB20OTG0_i_TXRISETUNE ((2 << 16) | 484) +#define NX_TIEOFF_USB20OTG0_i_TXRESTUNE ((2 << 16) | 486) +#define NX_TIEOFF_USB20OTG0_i_TXPREEMPAMPTUNE ((2 << 16) | 488) +#define NX_TIEOFF_USB20OTG0_i_TXPREEMPPULSETUNE ((1 << 16) | 490) +#define NX_TIEOFF_USB20OTG0_i_CHRGSEL ((1 << 16) | 491) +#define NX_TIEOFF_USB20OTG0_i_VDATDETENB ((1 << 16) | 492) +#define NX_TIEOFF_USB20OTG0_i_VDATSRCENB ((1 << 16) | 493) +#define NX_TIEOFF_USB20OTG0_i_DCDENB ((1 << 16) | 494) +#define NX_TIEOFF_USB20OTG0_i_ACAENB ((1 << 16) | 495) +#define NX_TIEOFF_USB20OTG0_i_IDPULLUP_ENB ((1 << 16) | 496) +#define NX_TIEOFF_USB20OTG0_i_DPPULLDOWN_ENB ((1 << 16) | 497) +#define NX_TIEOFF_USB20OTG0_i_DMPULLDOWN_ENB ((1 << 16) | 498) +#define NX_TIEOFF_USB20OTG0_i_DRVVBUS_ENB ((1 << 16) | 499) +#define NX_TIEOFF_USB20OTG0_i_LPMClkMuxCntrl ((1 << 16) | 500) +#define NX_TIEOFF_USB20OTG0_i_GLITCHLESSMUXCntrl ((1 << 16) | 501) +#define NX_TIEOFF_CODA9600_i_nPWRDN00 ((4 << 16) | 502) +#define NX_TIEOFF_CODA9600_i_nSLEEP00 ((4 << 16) | 506) +#define NX_TIEOFF_CODA9600_i_nPWRDN01 ((8 << 16) | 512) +#define NX_TIEOFF_CODA9600_i_nSLEEP01 ((8 << 16) | 520) +#define NX_TIEOFF_CODA9600_i_nPWRDN02 ((10 << 16) | 528) +#define NX_TIEOFF_CODA9600_i_nSLEEP02 ((10 << 16) | 544) +#define NX_TIEOFF_CODA9600_i_nPWRDN03 ((2 << 16) | 554) +#define NX_TIEOFF_CODA9600_i_nSLEEP03 ((2 << 16) | 556) +#define NX_TIEOFF_CODA9600_i_nPWRDN04 ((8 << 16) | 558) +#define NX_TIEOFF_CODA9600_i_nSLEEP04 ((8 << 16) | 566) +#define NX_TIEOFF_CODA9600_i_nPWRDN05 ((3 << 16) | 576) +#define NX_TIEOFF_CODA9600_i_nSLEEP05 ((3 << 16) | 579) +#define NX_TIEOFF_CODA9600_i_nPWRDN06 ((7 << 16) | 582) +#define NX_TIEOFF_CODA9600_i_nSLEEP06 ((7 << 16) | 589) +#define NX_TIEOFF_CODA9600_i_nPWRDN07 ((12 << 16) | 596) +#define NX_TIEOFF_CODA9600_i_nSLEEP07 ((12 << 16) | 608) +#define NX_TIEOFF_CODA9600_i_nPWRDN08 ((1 << 16) | 620) +#define NX_TIEOFF_CODA9600_i_nSLEEP08 ((1 << 16) | 621) +#define NX_TIEOFF_CODA9600_i_nPWRDN09 ((2 << 16) | 622) +#define NX_TIEOFF_CODA9600_i_nSLEEP09 ((2 << 16) | 624) +#define NX_TIEOFF_CODA9600_i_nPWRDN10 ((10 << 16) | 626) +#define NX_TIEOFF_CODA9600_i_nSLEEP10 ((10 << 16) | 640) +#define NX_TIEOFF_CODA9600_i_nPWRDN11 ((1 << 16) | 650) +#define NX_TIEOFF_CODA9600_i_nSLEEP11 ((1 << 16) | 651) +#define NX_TIEOFF_CODA9600_i_TIE_rf2_EMAA ((3 << 16) | 652) +#define NX_TIEOFF_CODA9600_i_TIE_rf2_EMAB ((3 << 16) | 655) +#define NX_TIEOFF_CODA9600_i_TIE_rf2w_EMAA ((3 << 16) | 658) +#define NX_TIEOFF_CODA9600_i_TIE_rf2w_EMAB ((3 << 16) | 661) +#define NX_TIEOFF_CODA9600_i_TIE_ra2_EMAA ((3 << 16) | 664) +#define NX_TIEOFF_CODA9600_i_TIE_ra2_EMAB ((3 << 16) | 667) +#define NX_TIEOFF_CODA9600_i_TIE_ra2_EMAWA ((2 << 16) | 670) +#define NX_TIEOFF_CODA9600_i_TIE_ra2_EMAWB ((2 << 16) | 672) +#define NX_TIEOFF_CODA9600_i_TIE_ra2w_EMAA ((3 << 16) | 674) +#define NX_TIEOFF_CODA9600_i_TIE_ra2w_EMAB ((3 << 16) | 677) +#define NX_TIEOFF_CODA9600_i_TIE_ra2w_EMAWA ((2 << 16) | 680) +#define NX_TIEOFF_CODA9600_i_TIE_ra2w_EMAWB ((2 << 16) | 682) +#define NX_TIEOFF_CODA9600_i_TIE_rf1_EMA ((3 << 16) | 684) +#define NX_TIEOFF_CODA9600_i_TIE_rf1_EMAW ((2 << 16) | 687) +#define NX_TIEOFF_CODA9600_i_TIE_rf1w_EMA ((3 << 16) | 689) +#define NX_TIEOFF_CODA9600_i_TIE_rf1w_EMAW ((2 << 16) | 692) +#define NX_TIEOFF_DWC_GMAC0_sbd_flowctrl_i ((1 << 16) | 694) +#define NX_TIEOFF_DWC_GMAC0_phy_intf_sel_i ((3 << 16) | 695) +#define NX_TIEOFF_DWC_GMAC0_i_NX_RF2_EMAA ((3 << 16) | 698) +#define NX_TIEOFF_DWC_GMAC0_i_NX_RF2_EMAB ((3 << 16) | 701) +#define NX_TIEOFF_MALI4000_NX_DPSRAM_1R1W_EMAA ((3 << 16) | 704) +#define NX_TIEOFF_MALI4000_NX_DPSRAM_1R1W_EMAB ((3 << 16) | 707) +#define NX_TIEOFF_MALI4000_NX_SPSRAM_EMA ((3 << 16) | 710) +#define NX_TIEOFF_MALI4000_NX_SPSRAM_EMAW ((2 << 16) | 713) +#define NX_TIEOFF_MALI4000_NX_SPSRAM_BW_EMA ((3 << 16) | 715) +#define NX_TIEOFF_MALI4000_NX_SPSRAM_BW_EMAW ((2 << 16) | 718) +#define NX_TIEOFF_MALI4000_PWRDNBYPASS ((1 << 16) | 720) +#define NX_TIEOFF_MALI4000_GP_NX_NPOWERDOWN ((15 << 16) | 721) +#define NX_TIEOFF_MALI4000_GP_NX_NSLEEP ((15 << 16) | 736) +#define NX_TIEOFF_MALI4000_L2_NX_NPOWERDOWN ((3 << 16) | 751) +#define NX_TIEOFF_MALI4000_L2_NX_NSLEEP ((3 << 16) | 754) +#define NX_TIEOFF_MALI4000_PP0_NX_NPOWERDOWN ((32 << 16) | 768) +#define NX_TIEOFF_MALI4000_PP0_NX_NSLEEP ((32 << 16) | 800) +#define NX_TIEOFF_MALI4000_PP1_NX_NPOWERDOWN ((32 << 16) | 832) +#define NX_TIEOFF_MALI4000_PP1_NX_NSLEEP ((32 << 16) | 864) +#define NX_TIEOFF_MALI4000_PP2_NX_NPOWERDOWN ((32 << 16) | 896) +#define NX_TIEOFF_MALI4000_PP2_NX_NSLEEP ((32 << 16) | 928) +#define NX_TIEOFF_MALI4000_PP3_NX_NPOWERDOWN ((32 << 16) | 960) +#define NX_TIEOFF_MALI4000_PP3_NX_NSLEEP ((32 << 16) | 992) +#define NX_TIEOFF_A3BM_AXI_PERI_BUS0_SYNCMODEREQm9 ((1 << 16) | 1024) +#define NX_TIEOFF_A3BM_AXI_PERI_BUS0_SYNCMODEREQm10 ((1 << 16) | 1025) +#define NX_TIEOFF_A3BM_AXI_PERI_BUS0_SYNCMODEREQm16 ((1 << 16) | 1026) +#define NX_TIEOFF_A3BM_AXI_TOP_MASTER_BUS0_REMAP ((2 << 16) | 1027) +#if defined(CONFIG_ARCH_S5P6818) +#define NX_TIEOFF_Inst_ARMTOP_SMPEN ((4 << 16) | 2816) +#define NX_TIEOFF_Inst_ARMTOP_STANBYWFI ((4 << 16) | 2880) +#define NX_TIEOFF_Inst_ARMTOP_STANBYWFIL2 ((1 << 16) | 2884) +#define NX_TIEOFF_Inst_ARMTOP_DBGNOPWRDWN ((4 << 16) | 2889) +#define NX_TIEOFF_Inst_ARMTOP_DBGPWRUPREQ ((4 << 16) | 2893) +#define NX_TIEOFF_Inst_ARMTOP_COREPWRDOWNPRE ((1 << 16) | 2901) +#define NX_TIEOFF_Inst_ARMTOP_CPU0PWRDOWNPRE ((1 << 16) | 2902) +#define NX_TIEOFF_Inst_ARMTOP_CPU1PWRDOWNPRE ((1 << 16) | 2903) +#define NX_TIEOFF_Inst_ARMTOP_CPU2PWRDOWNPRE ((1 << 16) | 2904) +#define NX_TIEOFF_Inst_ARMTOP_CPU3PWRDOWNPRE ((1 << 16) | 2905) +#define NX_TIEOFF_Inst_ARMTOP_COREPWRDOWNALL ((1 << 16) | 2906) +#define NX_TIEOFF_Inst_ARMTOP_CPU0PWRDOWNALL ((1 << 16) | 2907) +#define NX_TIEOFF_Inst_ARMTOP_CPU1PWRDOWNALL ((1 << 16) | 2908) +#define NX_TIEOFF_Inst_ARMTOP_CPU2PWRDOWNALL ((1 << 16) | 2909) +#define NX_TIEOFF_Inst_ARMTOP_CPU3PWRDOWNALL ((1 << 16) | 2910) +#define NX_TIEOFF_Inst_ARMTOP_CLAMPL2 ((1 << 16) | 2920) +#define NX_TIEOFF_Inst_ARMTOP_L2FLUSHREQ ((1 << 16) | 3018) +#define NX_TIEOFF_Inst_ARMTOP_L2FLUSHDONE ((1 << 16) | 3019) +#define NX_TIEOFF_Inst_ARMTOP_ACINACTM ((1 << 16) | 3023) +#define NX_TIEOFF_Inst_ARMTOP_P1_SMPEN ((4 << 16) | 3360) +#define NX_TIEOFF_Inst_ARMTOP_P1_STANBYWFI ((4 << 16) | 3424) +#define NX_TIEOFF_Inst_ARMTOP_P1_STANBYWFIL2 ((1 << 16) | 3428) +#define NX_TIEOFF_Inst_ARMTOP_P1_DBGNOPWRDWN ((4 << 16) | 3442) +#define NX_TIEOFF_Inst_ARMTOP_P1_DBGPWRUPREQ ((4 << 16) | 3443) +#define NX_TIEOFF_Inst_ARMTOP_P1_DBGPWRDUP ((4 << 16) | 3444) +#define NX_TIEOFF_Inst_ARMTOP_P1_COREPWRDOWNPRE ((1 << 16) | 3445) +#define NX_TIEOFF_Inst_ARMTOP_P1_CPU0PWRDOWNPRE ((1 << 16) | 3446) +#define NX_TIEOFF_Inst_ARMTOP_P1_CPU1PWRDOWNPRE ((1 << 16) | 3447) +#define NX_TIEOFF_Inst_ARMTOP_P1_CPU2PWRDOWNPRE ((1 << 16) | 3448) +#define NX_TIEOFF_Inst_ARMTOP_P1_CPU3PWRDOWNPRE ((1 << 16) | 3449) +#define NX_TIEOFF_Inst_ARMTOP_P1_COREPWRDOWNALL ((1 << 16) | 3450) +#define NX_TIEOFF_Inst_ARMTOP_P1_CPU0PWRDOWNALL ((1 << 16) | 3451) +#define NX_TIEOFF_Inst_ARMTOP_P1_CPU1PWRDOWNALL ((1 << 16) | 3452) +#define NX_TIEOFF_Inst_ARMTOP_P1_CPU2PWRDOWNALL ((1 << 16) | 3453) +#define NX_TIEOFF_Inst_ARMTOP_P1_CPU3PWRDOWNALL ((1 << 16) | 3454) +#define NX_TIEOFF_Inst_ARMTOP_P1_CLAMPL2 ((1 << 16) | 3464) +#define NX_TIEOFF_Inst_ARMTOP_P1_L2FLUSHREQ ((1 << 16) | 3562) +#define NX_TIEOFF_Inst_ARMTOP_P1_L2FLUSHDONE ((1 << 16) | 3563) +#define NX_TIEOFF_Inst_ARMTOP_P1_ACINACTM ((1 << 16) | 3567) +#endif + +#endif /* _NEXELL_TIEOFF_H */
On Fri, Jul 10, 2020 at 07:07:25PM +0200, Stefan Bosch wrote:
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01:
- DM_VIDEO support (display_dev.h).
- boot0.h added, handles NSIH --> tools/nexell obsolete.
- gpio.h: Include-path to errno.h changed.
Signed-off-by: Stefan Bosch stefan_b@posteo.net
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - SPL not supported yet --> no spl-directory in arch/arm/mach-nexell. Appropriate line in Makefile removed. - clock.c: 'section(".data")' added to declaration of clk_periphs[] and core_hz. - Kconfig: Changes to have a structure like in mach-bcm283x/Kconfig, e.g. "config ..." entries moved from other Kconfig. - timer.c: 'section(".data")' added to declaration of timestamp and lastdec. - arch/arm/mach-nexell/serial.c removed because this is for the UARTs of the S5P6818 SoC which is not supported yet. S5P4418 UARTs are different, here the (existing) PL011-code is used. - '#ifdef CONFIG...' changed to 'if (IS_ENABLED(CONFIG...))' where possible (and similar).
Signed-off-by: Stefan Bosch stefan_b@posteo.net ---
(no changes since v3)
Changes in v3: - arch/arm/mach-nexell/Kconfig: "NEXELL_COMMON" removed, has not been used at all. NEXELL_ARMV7_COMMON and NEXELL_ARMV8_COMMON removed, has been used only in the Kconfig at ARCH_S5P4418 and ARCH_S5P6818. Used "select ..."-statements moved appropriately. Missing helps added. - arch/arm/mach-nexell/timer.c: '#include <log.h>' inserted because it has been removed from common.h. - '#ifdef...' changed to 'if (IS_ENABLED(CONFIG...))' where possible because of appropriate warnings of patman.
Changes in v2: - arch/arm/mach-nexell/serial.c removed because this is for the UARTs of the S5P6818 SoC which is not supported yet. S5P4418 UARTs are different, here the (existing) PL011-code is used. - line '... += spl/' in in arch/arm/mach-nexell/Makefile deleted, this change has already been stated in the commit message but was missing nethertheless.
arch/arm/Kconfig | 7 + arch/arm/Makefile | 1 + arch/arm/mach-nexell/Kconfig | 58 +++ arch/arm/mach-nexell/Makefile | 13 + arch/arm/mach-nexell/clock.c | 869 ++++++++++++++++++++++++++++++++++ arch/arm/mach-nexell/cmd_boot_linux.c | 144 ++++++ arch/arm/mach-nexell/config.mk | 11 + arch/arm/mach-nexell/nx_gpio.c | 352 ++++++++++++++ arch/arm/mach-nexell/nx_sec_reg.c | 82 ++++ arch/arm/mach-nexell/reg-call.S | 23 + arch/arm/mach-nexell/reset.c | 33 ++ arch/arm/mach-nexell/tieoff.c | 107 +++++ arch/arm/mach-nexell/timer.c | 299 ++++++++++++ 13 files changed, 1999 insertions(+) create mode 100644 arch/arm/mach-nexell/Kconfig create mode 100644 arch/arm/mach-nexell/Makefile create mode 100644 arch/arm/mach-nexell/clock.c create mode 100644 arch/arm/mach-nexell/cmd_boot_linux.c create mode 100644 arch/arm/mach-nexell/config.mk create mode 100644 arch/arm/mach-nexell/nx_gpio.c create mode 100644 arch/arm/mach-nexell/nx_sec_reg.c create mode 100644 arch/arm/mach-nexell/reg-call.S create mode 100644 arch/arm/mach-nexell/reset.c create mode 100644 arch/arm/mach-nexell/tieoff.c create mode 100644 arch/arm/mach-nexell/timer.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index edc9e38..17a0cb5 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -901,6 +901,11 @@ config ARCH_MX5 select CPU_V7A imply MXC_GPIO
+config ARCH_NEXELL + bool "Nexell S5P4418/S5P6818 SoC" + select ENABLE_ARM_SOC_BOOT0_HOOK + select DM + config ARCH_OWL bool "Actions Semi OWL SoCs" select DM @@ -1858,6 +1863,8 @@ source "arch/arm/cpu/armv8/Kconfig"
source "arch/arm/mach-imx/Kconfig"
+source "arch/arm/mach-nexell/Kconfig" + source "board/bosch/shc/Kconfig" source "board/bosch/guardian/Kconfig" source "board/CarMediaLab/flea3/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 94eb50b..b9cc985 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -65,6 +65,7 @@ machine-$(CONFIG_ARCH_LPC32XX) += lpc32xx machine-$(CONFIG_ARCH_MEDIATEK) += mediatek machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu +machine-$(CONFIG_ARCH_NEXELL) += nexell machine-$(CONFIG_ARCH_OMAP2PLUS) += omap2 machine-$(CONFIG_ARCH_ORION5X) += orion5x machine-$(CONFIG_ARCH_OWL) += owl diff --git a/arch/arm/mach-nexell/Kconfig b/arch/arm/mach-nexell/Kconfig new file mode 100644 index 0000000..ffa4d48 --- /dev/null +++ b/arch/arm/mach-nexell/Kconfig @@ -0,0 +1,58 @@ +if ARCH_NEXELL + +config ARCH_S5P4418 + bool "Nexell S5P4418 SoC" + select CPU_V7A + select OF_CONTROL + select OF_SEPARATE + select NX_GPIO + select PL011_SERIAL + select PL011_SERIAL_FLUSH_ON_INIT + help + Enable support for Nexell S5P4418 SoC. + +config ARCH_S5P6818 + bool "Nexell S5P6818 SoC" + select ARM64 + select ARMV8_MULTIENTRY + help + Enable support for Nexell S5P6818 SoC. + +menu "Nexell S5P4418/S5P6818" + depends on ARCH_NEXELL + +choice + prompt "Nexell S5P4418/S5P6818 board select" + optional + +config TARGET_NANOPI2 + bool "FriendlyARM NanoPi2 / NanoPC-T2 Board" + select ARCH_S5P4418 + help + Enable support for FriendlyARM NanoPi2 and NanoPC-T2 Boards. + +endchoice + +config SYS_BOARD + default "nanopi2" + +config SYS_VENDOR + default "friendlyarm" + +config SYS_SOC + default "nexell" + +config SYS_CONFIG_NAME + default "s5p4418_nanopi2" + +endmenu + +config SYS_PLLFIN + int + +config TIMER_SYS_TICK_CH + int + +source "board/friendlyarm/Kconfig" + +endif diff --git a/arch/arm/mach-nexell/Makefile b/arch/arm/mach-nexell/Makefile new file mode 100644 index 0000000..10b3963 --- /dev/null +++ b/arch/arm/mach-nexell/Makefile @@ -0,0 +1,13 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 Nexell +# Hyunseok, Jung hsjung@nexell.co.kr + +obj-y += clock.o +obj-y += timer.o +obj-y += reset.o +obj-y += nx_gpio.o +obj-y += tieoff.o +obj-$(CONFIG_ARCH_S5P4418) += reg-call.o +obj-$(CONFIG_ARCH_S5P4418) += nx_sec_reg.o +obj-$(CONFIG_CMD_BOOTL) += cmd_boot_linux.o diff --git a/arch/arm/mach-nexell/clock.c b/arch/arm/mach-nexell/clock.c new file mode 100644 index 0000000..a0ba2d8 --- /dev/null +++ b/arch/arm/mach-nexell/clock.c @@ -0,0 +1,869 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * Hyunseok, Jung hsjung@nexell.co.kr + */ + +#include <common.h> +#include <command.h> +#include <linux/err.h> +#include <asm/io.h> +#include <asm/arch/nexell.h> +#include <asm/arch/clk.h> + +/* + * clock generator macros + */ +#define I_PLL0_BIT (0) +#define I_PLL1_BIT (1) +#define I_PLL2_BIT (2) +#define I_PLL3_BIT (3) +#define I_EXT1_BIT (4) +#define I_EXT2_BIT (5) +#define I_CLKn_BIT (7) +#define I_EXT1_BIT_FORCE (8) +#define I_EXT2_BIT_FORCE (9) + +#define I_CLOCK_NUM 6 /* PLL0, PLL1, PLL2, PLL3, EXT1, EXT2 */ + +#define I_EXECEPT_CLK (0) +#define I_CLOCK_MASK (((1 << I_CLOCK_NUM) - 1) & ~I_EXECEPT_CLK) + +#define I_PLL0 (1 << I_PLL0_BIT) +#define I_PLL1 (1 << I_PLL1_BIT) +#define I_PLL2 (1 << I_PLL2_BIT) +#define I_PLL3 (1 << I_PLL3_BIT) +#define I_EXTCLK1 (1 << I_EXT1_BIT) +#define I_EXTCLK2 (1 << I_EXT2_BIT) +#define I_EXTCLK1_FORCE (1 << I_EXT1_BIT_FORCE) +#define I_EXTCLK2_FORCE (1 << I_EXT2_BIT_FORCE) + +#define I_PLL_0_1 (I_PLL0 | I_PLL1) +#define I_PLL_0_2 (I_PLL_0_1 | I_PLL2) +#define I_PLL_0_3 (I_PLL_0_2 | I_PLL3) +#define I_CLKnOUT (0) + +#define I_PCLK (1 << 16) +#define I_BCLK (1 << 17) +#define I_GATE_PCLK (1 << 20) +#define I_GATE_BCLK (1 << 21) +#define I_PCLK_MASK (I_GATE_PCLK | I_PCLK) +#define I_BCLK_MASK (I_GATE_BCLK | I_BCLK) + +struct clk_dev_peri { + const char *dev_name; + void __iomem *base; + int dev_id; + int periph_id; + int clk_step; + u32 in_mask; + u32 in_mask1; + int div_src_0; + int div_val_0; + int invert_0; + int div_src_1; + int div_val_1; + int invert_1; + int in_extclk_1; + int in_extclk_2; +}; + +struct clk_dev { + struct clk clk; + struct clk *link; + const char *name; + struct clk_dev_peri *peri; +}; + +struct clk_dev_map { + unsigned int con_enb; + unsigned int con_gen[4]; +}; + +#define CLK_PERI_1S(name, devid, id, addr, mk)[id] = \ + { .dev_name = name, .dev_id = devid, .periph_id = id, .clk_step = 1, \ + .base = (void *)addr, .in_mask = mk, } + +#define CLK_PERI_2S(name, devid, id, addr, mk, mk2)[id] = \ + { .dev_name = name, .dev_id = devid, .periph_id = id, .clk_step = 2, \ + .base = (void *)addr, .in_mask = mk, .in_mask1 = mk2, } + +static const char * const clk_core[] = { + CORECLK_NAME_PLL0, CORECLK_NAME_PLL1, CORECLK_NAME_PLL2, + CORECLK_NAME_PLL3, CORECLK_NAME_FCLK, CORECLK_NAME_MCLK, + CORECLK_NAME_BCLK, CORECLK_NAME_PCLK, CORECLK_NAME_HCLK, +}; + +/* + * Section ".data" must be used because BSS is not available before relocation, + * in board_init_f(), respectively! I.e. global variables can not be used! + */ +static struct clk_dev_peri clk_periphs[] + __attribute__((section(".data"))) = { + CLK_PERI_1S(DEV_NAME_TIMER, 0, CLK_ID_TIMER_0, + PHY_BASEADDR_CLKGEN14, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_TIMER, 1, CLK_ID_TIMER_1, + PHY_BASEADDR_CLKGEN0, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_TIMER, 2, CLK_ID_TIMER_2, + PHY_BASEADDR_CLKGEN1, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_TIMER, 3, CLK_ID_TIMER_3, + PHY_BASEADDR_CLKGEN2, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_UART, 0, CLK_ID_UART_0, + PHY_BASEADDR_CLKGEN22, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_UART, 1, CLK_ID_UART_1, + PHY_BASEADDR_CLKGEN24, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_UART, 2, CLK_ID_UART_2, + PHY_BASEADDR_CLKGEN23, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_UART, 3, CLK_ID_UART_3, + PHY_BASEADDR_CLKGEN25, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_UART, 4, CLK_ID_UART_4, + PHY_BASEADDR_CLKGEN26, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_UART, 5, CLK_ID_UART_5, + PHY_BASEADDR_CLKGEN27, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_PWM, 0, CLK_ID_PWM_0, + PHY_BASEADDR_CLKGEN13, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_PWM, 1, CLK_ID_PWM_1, + PHY_BASEADDR_CLKGEN3, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_PWM, 2, CLK_ID_PWM_2, + PHY_BASEADDR_CLKGEN4, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_PWM, 3, CLK_ID_PWM_3, + PHY_BASEADDR_CLKGEN5, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_I2C, 0, CLK_ID_I2C_0, + PHY_BASEADDR_CLKGEN6, (I_GATE_PCLK)), + CLK_PERI_1S(DEV_NAME_I2C, 1, CLK_ID_I2C_1, + PHY_BASEADDR_CLKGEN7, (I_GATE_PCLK)), + CLK_PERI_1S(DEV_NAME_I2C, 2, CLK_ID_I2C_2, + PHY_BASEADDR_CLKGEN8, (I_GATE_PCLK)), + CLK_PERI_2S(DEV_NAME_GMAC, 0, CLK_ID_GMAC, + PHY_BASEADDR_CLKGEN10, + (I_PLL_0_3 | I_EXTCLK1 | I_EXTCLK1_FORCE), + (I_CLKnOUT)), + CLK_PERI_2S(DEV_NAME_I2S, 0, CLK_ID_I2S_0, + PHY_BASEADDR_CLKGEN15, (I_PLL_0_3 | I_EXTCLK1), + (I_CLKnOUT)), + CLK_PERI_2S(DEV_NAME_I2S, 1, CLK_ID_I2S_1, + PHY_BASEADDR_CLKGEN16, (I_PLL_0_3 | I_EXTCLK1), + (I_CLKnOUT)), + CLK_PERI_2S(DEV_NAME_I2S, 2, CLK_ID_I2S_2, + PHY_BASEADDR_CLKGEN17, (I_PLL_0_3 | I_EXTCLK1), + (I_CLKnOUT)), + CLK_PERI_1S(DEV_NAME_SDHC, 0, CLK_ID_SDHC_0, + PHY_BASEADDR_CLKGEN18, (I_PLL_0_2 | I_GATE_PCLK)), + CLK_PERI_1S(DEV_NAME_SDHC, 1, CLK_ID_SDHC_1, + PHY_BASEADDR_CLKGEN19, (I_PLL_0_2 | I_GATE_PCLK)), + CLK_PERI_1S(DEV_NAME_SDHC, 2, CLK_ID_SDHC_2, + PHY_BASEADDR_CLKGEN20, (I_PLL_0_2 | I_GATE_PCLK)), + CLK_PERI_1S(DEV_NAME_SPI, 0, CLK_ID_SPI_0, + PHY_BASEADDR_CLKGEN37, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_SPI, 1, CLK_ID_SPI_1, + PHY_BASEADDR_CLKGEN38, (I_PLL_0_2)), + CLK_PERI_1S(DEV_NAME_SPI, 2, CLK_ID_SPI_2, + PHY_BASEADDR_CLKGEN39, (I_PLL_0_2)), +}; + +#define CLK_PERI_NUM ((int)ARRAY_SIZE(clk_periphs)) +#define CLK_CORE_NUM ((int)ARRAY_SIZE(clk_core)) +#define CLK_DEVS_NUM (CLK_CORE_NUM + CLK_PERI_NUM) +#define MAX_DIVIDER ((1 << 8) - 1) /* 256, align 2 */ + +static struct clk_dev st_clk_devs[CLK_DEVS_NUM] + __attribute__((section(".data"))); +#define clk_dev_get(n) ((struct clk_dev *)&st_clk_devs[n]) +#define clk_container(p) (container_of(p, struct clk_dev, clk)) + +/* + * Core frequencys + */ +struct _core_hz_ { + unsigned long pll[4]; /* PLL */ + unsigned long cpu_fclk, cpu_bclk; /* cpu */ + unsigned long mem_fclk, mem_dclk, mem_bclk, mem_pclk; /* ddr */ + unsigned long bus_bclk, bus_pclk; /* bus */ +#if defined(CONFIG_ARCH_S5P6818) + unsigned long cci4_bclk, cci4_pclk; /* cci */ +#endif + /* ip */ + unsigned long g3d_bclk; + unsigned long coda_bclk, coda_pclk; +#if defined(CONFIG_ARCH_S5P6818) + unsigned long disp_bclk, disp_pclk; + unsigned long hdmi_pclk; +#endif +}; + +/* + * Section ".data" must be used because BSS is not available before relocation, + * in board_init_f(), respectively! I.e. global variables can not be used! + */ +/* core clock */ +static struct _core_hz_ core_hz __attribute__((section(".data"))); + +#define CORE_HZ_SIZE (sizeof(core_hz) / 4) + +/* + * CLKGEN HW + */ +static inline void clk_dev_bclk(void *base, int on) +{ + struct clk_dev_map *reg = base; + unsigned int val = readl(®->con_enb) & ~(0x3); + + val |= (on ? 3 : 0) & 0x3; /* always BCLK */ + writel(val, ®->con_enb); +} + +static inline void clk_dev_pclk(void *base, int on) +{ + struct clk_dev_map *reg = base; + unsigned int val = 0; + + if (!on) + return; + + val = readl(®->con_enb) & ~(1 << 3); + val |= (1 << 3); + writel(val, ®->con_enb); +} + +static inline void clk_dev_rate(void *base, int step, int src, int div) +{ + struct clk_dev_map *reg = base; + unsigned int val = 0; + + val = readl(®->con_gen[step << 1]); + val &= ~(0x07 << 2); + val |= (src << 2); /* source */ + val &= ~(0xFF << 5); + val |= (div - 1) << 5; /* divider */ + writel(val, ®->con_gen[step << 1]); +} + +static inline void clk_dev_inv(void *base, int step, int inv) +{ + struct clk_dev_map *reg = base; + unsigned int val = readl(®->con_gen[step << 1]) & ~(1 << 1); + + val |= (inv << 1); + writel(val, ®->con_gen[step << 1]); +} + +static inline void clk_dev_enb(void *base, int on) +{ + struct clk_dev_map *reg = base; + unsigned int val = readl(®->con_enb) & ~(1 << 2); + + val |= ((on ? 1 : 0) << 2); + writel(val, ®->con_enb); +} + +/* + * CORE FREQUENCY + * + * PLL0 [P,M,S] ------- | | ----- [DIV0] --- CPU-G0 + * |M| ----- [DIV1] --- BCLK/PCLK + * PLL1 [P,M,S] ------- | | ----- [DIV2] --- DDR + * |U| ----- [DIV3] --- 3D + * PLL2 [P,M,S,K]-------| | ----- [DIV4] --- CODA + * |X| ----- [DIV5] --- DISPLAY + * PLL3 [P,M,S,K]-------| | ----- [DIV6] --- HDMI + * | | ----- [DIV7] --- CPU-G1 + * | | ----- [DIV8] --- CCI-400(FASTBUS) + * + */ + +struct nx_clkpwr_registerset { + u32 clkmodereg0; /* 0x000 : Clock Mode Register0 */ + u32 __reserved0; /* 0x004 */ + u32 pllsetreg[4]; /* 0x008 ~ 0x014 : PLL Setting Register */ + u32 __reserved1[2]; /* 0x018 ~ 0x01C */ + u32 dvoreg[9]; /* 0x020 ~ 0x040 : Divider Setting Register */ + u32 __Reserved2; /* 0x044 */ + u32 pllsetreg_sscg[6]; /* 0x048 ~ 0x05C */ + u32 __reserved3[8]; /* 0x060 ~ 0x07C */ + u8 __reserved4[0x200 - 0x80]; /* padding (0x80 ~ 0x1FF) */ + u32 gpiowakeupriseenb; /* 0x200 : GPIO Rising Edge Detect En. Reg. */ + u32 gpiowakeupfallenb; /* 0x204 : GPIO Falling Edge Detect En. Reg. */ + u32 gpiorstenb; /* 0x208 : GPIO Reset Enable Register */ + u32 gpiowakeupenb; /* 0x20C : GPIO Wakeup Source Enable */ + u32 gpiointenb; /* 0x210 : Interrupt Enable Register */ + u32 gpiointpend; /* 0x214 : Interrupt Pend Register */ + u32 resetstatus; /* 0x218 : Reset Status Register */ + u32 intenable; /* 0x21C : Interrupt Enable Register */ + u32 intpend; /* 0x220 : Interrupt Pend Register */ + u32 pwrcont; /* 0x224 : Power Control Register */ + u32 pwrmode; /* 0x228 : Power Mode Register */ + u32 __reserved5; /* 0x22C : Reserved Region */ + u32 scratch[3]; /* 0x230 ~ 0x238 : Scratch Register */ + u32 sysrstconfig; /* 0x23C : System Reset Configuration Reg. */ + u8 __reserved6[0x2A0 - 0x240]; /* padding (0x240 ~ 0x29F) */ + u32 cpupowerdownreq; /* 0x2A0 : CPU Power Down Request Register */ + u32 cpupoweronreq; /* 0x2A4 : CPU Power On Request Register */ + u32 cpuresetmode; /* 0x2A8 : CPU Reset Mode Register */ + u32 cpuwarmresetreq; /* 0x2AC : CPU Warm Reset Request Register */ + u32 __reserved7; /* 0x2B0 */ + u32 cpustatus; /* 0x2B4 : CPU Status Register */ + u8 __reserved8[0x400 - 0x2B8]; /* padding (0x2B8 ~ 0x33F) */ +}; + +static struct nx_clkpwr_registerset * const clkpwr = + (struct nx_clkpwr_registerset *)PHY_BASEADDR_CLKPWR; + +#define getquotient(v, d) ((v) / (d)) + +#define DIV_CPUG0 0 +#define DIV_BUS 1 +#define DIV_MEM 2 +#define DIV_G3D 3 +#define DIV_CODA 4 +#if defined(CONFIG_ARCH_S5P6818) +#define DIV_DISP 5 +#define DIV_HDMI 6 +#define DIV_CPUG1 7 +#define DIV_CCI4 8 +#endif + +#define DVO0 3 +#define DVO1 9 +#define DVO2 15 +#define DVO3 21 + +static unsigned int pll_rate(unsigned int plln, unsigned int xtal) +{ + unsigned int val, val1, nP, nM, nS, nK; + unsigned int temp = 0; + + val = clkpwr->pllsetreg[plln]; + val1 = clkpwr->pllsetreg_sscg[plln]; + xtal /= 1000; /* Unit Khz */ + + nP = (val >> 18) & 0x03F; + nM = (val >> 8) & 0x3FF; + nS = (val >> 0) & 0x0FF; + nK = (val1 >> 16) & 0xFFFF; + + if (plln > 1 && nK) { + temp = (unsigned int)(getquotient((getquotient((nK * 1000), + 65536) * xtal), nP) >> nS); + } + + temp = (unsigned int)((getquotient((nM * xtal), nP) >> nS) * 1000) + + temp; + return temp; +} + +static unsigned int pll_dvo(int dvo) +{ + unsigned int val; + + val = (clkpwr->dvoreg[dvo] & 0x7); + return val; +} + +static unsigned int pll_div(int dvo) +{ + unsigned int val = clkpwr->dvoreg[dvo]; + + return ((((val >> DVO3) & 0x3F) + 1) << 24) | + ((((val >> DVO2) & 0x3F) + 1) << 16) | + ((((val >> DVO1) & 0x3F) + 1) << 8) | + ((((val >> DVO0) & 0x3F) + 1) << 0); +} + +#define PLLN_RATE(n) (pll_rate(n, CONFIG_SYS_PLLFIN)) /* 0~ 3 */ +#define CPU_FCLK_RATE(n) (pll_rate(pll_dvo(n), CONFIG_SYS_PLLFIN) / \ + ((pll_div(n) >> 0) & 0x3F)) +#define CPU_BCLK_RATE(n) (pll_rate(pll_dvo(n), CONFIG_SYS_PLLFIN) / \ + ((pll_div(n) >> 0) & 0x3F) / \ + ((pll_div(n) >> 8) & 0x3F)) + +#define MEM_FCLK_RATE() (pll_rate(pll_dvo(DIV_MEM), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_MEM) >> 0) & 0x3F) / \ + ((pll_div(DIV_MEM) >> 8) & 0x3F)) + +#define MEM_DCLK_RATE() (pll_rate(pll_dvo(DIV_MEM), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_MEM) >> 0) & 0x3F)) + +#define MEM_BCLK_RATE() (pll_rate(pll_dvo(DIV_MEM), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_MEM) >> 0) & 0x3F) / \ + ((pll_div(DIV_MEM) >> 8) & 0x3F) / \ + ((pll_div(DIV_MEM) >> 16) & 0x3F)) +#define MEM_PCLK_RATE() (pll_rate(pll_dvo(DIV_MEM), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_MEM) >> 0) & 0x3F) / \ + ((pll_div(DIV_MEM) >> 8) & 0x3F) / \ + ((pll_div(DIV_MEM) >> 16) & 0x3F) / \ + ((pll_div(DIV_MEM) >> 24) & 0x3F)) + +#define BUS_BCLK_RATE() (pll_rate(pll_dvo(DIV_BUS), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_BUS) >> 0) & 0x3F)) +#define BUS_PCLK_RATE() (pll_rate(pll_dvo(DIV_BUS), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_BUS) >> 0) & 0x3F) / \ + ((pll_div(DIV_BUS) >> 8) & 0x3F)) + +#define G3D_BCLK_RATE() (pll_rate(pll_dvo(DIV_G3D), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_G3D) >> 0) & 0x3F)) + +#define MPG_BCLK_RATE() (pll_rate(pll_dvo(DIV_CODA), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_CODA) >> 0) & 0x3F)) +#define MPG_PCLK_RATE() (pll_rate(pll_dvo(DIV_CODA), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_CODA) >> 0) & 0x3F) / \ + ((pll_div(DIV_CODA) >> 8) & 0x3F)) + +#if defined(CONFIG_ARCH_S5P6818) +#define DISP_BCLK_RATE() (pll_rate(pll_dvo(DIV_DISP), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_DISP) >> 0) & 0x3F)) +#define DISP_PCLK_RATE() (pll_rate(pll_dvo(DIV_DISP), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_DISP) >> 0) & 0x3F) / \ + ((pll_div(DIV_DISP) >> 8) & 0x3F)) + +#define HDMI_PCLK_RATE() (pll_rate(pll_dvo(DIV_HDMI), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_HDMI) >> 0) & 0x3F)) + +#define CCI4_BCLK_RATE() (pll_rate(pll_dvo(DIV_CCI4), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_CCI4) >> 0) & 0x3F)) +#define CCI4_PCLK_RATE() (pll_rate(pll_dvo(DIV_CCI4), CONFIG_SYS_PLLFIN) / \ + ((pll_div(DIV_CCI4) >> 0) & 0x3F) / \ + ((pll_div(DIV_CCI4) >> 8) & 0x3F)) +#endif + +static void core_update_rate(int type) +{ + switch (type) { + case 0: + core_hz.pll[0] = PLLN_RATE(0); break; + case 1: + core_hz.pll[1] = PLLN_RATE(1); break; + case 2: + core_hz.pll[2] = PLLN_RATE(2); break; + case 3: + core_hz.pll[3] = PLLN_RATE(3); break; + case 4: + core_hz.cpu_fclk = CPU_FCLK_RATE(DIV_CPUG0); break; + case 5: + core_hz.mem_fclk = MEM_FCLK_RATE(); break; + case 6: + core_hz.bus_bclk = BUS_BCLK_RATE(); break; + case 7: + core_hz.bus_pclk = BUS_PCLK_RATE(); break; + case 8: + core_hz.cpu_bclk = CPU_BCLK_RATE(DIV_CPUG0); break; + case 9: + core_hz.mem_dclk = MEM_DCLK_RATE(); break; + case 10: + core_hz.mem_bclk = MEM_BCLK_RATE(); break; + case 11: + core_hz.mem_pclk = MEM_PCLK_RATE(); break; + case 12: + core_hz.g3d_bclk = G3D_BCLK_RATE(); break; + case 13: + core_hz.coda_bclk = MPG_BCLK_RATE(); break; + case 14: + core_hz.coda_pclk = MPG_PCLK_RATE(); break; +#if defined(CONFIG_ARCH_S5P6818) + case 15: + core_hz.disp_bclk = DISP_BCLK_RATE(); break; + case 16: + core_hz.disp_pclk = DISP_PCLK_RATE(); break; + case 17: + core_hz.hdmi_pclk = HDMI_PCLK_RATE(); break; + case 18: + core_hz.cci4_bclk = CCI4_BCLK_RATE(); break; + case 19: + core_hz.cci4_pclk = CCI4_PCLK_RATE(); break; +#endif + }; +} + +static unsigned long core_get_rate(int type) +{ + unsigned long rate = 0; + + switch (type) { + case 0: + rate = core_hz.pll[0]; break; + case 1: + rate = core_hz.pll[1]; break; + case 2: + rate = core_hz.pll[2]; break; + case 3: + rate = core_hz.pll[3]; break; + case 4: + rate = core_hz.cpu_fclk; break; + case 5: + rate = core_hz.mem_fclk; break; + case 6: + rate = core_hz.bus_bclk; break; + case 7: + rate = core_hz.bus_pclk; break; + case 8: + rate = core_hz.cpu_bclk; break; + case 9: + rate = core_hz.mem_dclk; break; + case 10: + rate = core_hz.mem_bclk; break; + case 11: + rate = core_hz.mem_pclk; break; + case 12: + rate = core_hz.g3d_bclk; break; + case 13: + rate = core_hz.coda_bclk; break; + case 14: + rate = core_hz.coda_pclk; break; +#if defined(CONFIG_ARCH_S5P6818) + case 15: + rate = core_hz.disp_bclk; break; + case 16: + rate = core_hz.disp_pclk; break; + case 17: + rate = core_hz.hdmi_pclk; break; + case 18: + rate = core_hz.cci4_bclk; break; + case 19: + rate = core_hz.cci4_pclk; break; +#endif + default: + printf("unknown core clock type %d ...\n", type); + break; + }; + return rate; +} + +static long core_set_rate(struct clk *clk, long rate) +{ + return clk->rate; +} + +static void core_rate_init(void) +{ + int i; + + for (i = 0; i < CORE_HZ_SIZE; i++) + core_update_rate(i); +} + +/* + * Clock Interfaces + */ +static inline long clk_divide(long rate, long request, + int align, int *divide) +{ + int div = (rate / request); + int max = MAX_DIVIDER & ~(align - 1); + int adv = (div & ~(align - 1)) + align; + long ret; + + if (!div) { + if (divide) + *divide = 1; + return rate; + } + + if (div != 1) + div &= ~(align - 1); + + if (div != adv && abs(request - rate / div) > abs(request - rate / adv)) + div = adv; + + div = (div > max ? max : div); + if (divide) + *divide = div; + + ret = rate / div; + return ret; +} + +void clk_put(struct clk *clk) +{ +} + +struct clk *clk_get(const char *id) +{ + struct clk_dev *cdev = clk_dev_get(0); + struct clk *clk = NULL; + const char *str = NULL, *c = NULL; + int i, devid; + + if (id) + str = id; + + for (i = 0; i < CLK_DEVS_NUM; i++, cdev++) { + if (!cdev->name) + continue; + if (!strncmp(cdev->name, str, strlen(cdev->name))) { + c = strrchr((const char *)str, (int)'.'); + if (!c || !cdev->peri) + break; + devid = simple_strtoul(++c, NULL, 10); + if (cdev->peri->dev_id == devid) + break; + } + } + if (i < CLK_DEVS_NUM) + clk = &cdev->clk; + else + clk = &(clk_dev_get(7))->clk; /* pclk */ + + return clk ? clk : ERR_PTR(-ENOENT); +} + +long clk_round_rate(struct clk *clk, unsigned long rate) +{ + struct clk_dev *pll = NULL, *cdev = clk_container(clk); + struct clk_dev_peri *peri = cdev->peri; + unsigned long request = rate, rate_hz = 0; + unsigned int mask; + int step, div[2] = { 0, }; + int i, n, clk2 = 0; + int start_src = 0, max_src = I_CLOCK_NUM; + short s1 = 0, s2 = 0, d1 = 0, d2 = 0; + + if (!peri) + return core_set_rate(clk, rate); + + step = peri->clk_step; + mask = peri->in_mask; + debug("clk: %s.%d request = %ld [input=0x%x]\n", peri->dev_name, + peri->dev_id, rate, mask); + + if (!(I_CLOCK_MASK & mask)) { + if (I_PCLK_MASK & mask) + return core_get_rate(CORECLK_ID_PCLK); + else if (I_BCLK_MASK & mask) + return core_get_rate(CORECLK_ID_BCLK); + else + return clk->rate; + } + +next: + if (peri->in_mask & I_EXTCLK1_FORCE) { + start_src = 4; max_src = 5; + } + for (n = start_src ; max_src > n; n++) { + if (!(((mask & I_CLOCK_MASK) >> n) & 0x1)) + continue; + + if (n == I_EXT1_BIT) { + rate = peri->in_extclk_1; + } else if (n == I_EXT2_BIT) { + rate = peri->in_extclk_2; + } else { + pll = clk_dev_get(n); + rate = pll->clk.rate; + } + + if (!rate) + continue; + + for (i = 0; step > i ; i++) + rate = clk_divide(rate, request, 2, &div[i]); + + if (rate_hz && (abs(rate - request) > abs(rate_hz - request))) + continue; + + debug("clk: %s.%d, pll.%d[%lu] request[%ld] calc[%ld]\n", + peri->dev_name, peri->dev_id, n, pll->clk.rate, + request, rate); + + if (clk2) { + s1 = -1, d1 = -1; /* not use */ + s2 = n, d2 = div[0]; + } else { + s1 = n, d1 = div[0]; + s2 = I_CLKn_BIT, d2 = div[1]; + } + rate_hz = rate; + } + + /* search 2th clock from input */ + if (!clk2 && abs(rate_hz - request) && + peri->in_mask1 & ((1 << I_CLOCK_NUM) - 1)) { + clk2 = 1; + mask = peri->in_mask1; + step = 1; + goto next; + } + if (peri->in_mask & I_EXTCLK1_FORCE) { + if (s1 == 0) { + s1 = 4; s2 = 7; + d1 = 1; d2 = 1; + } + } + + peri->div_src_0 = s1, peri->div_val_0 = d1; + peri->div_src_1 = s2, peri->div_val_1 = d2; + clk->rate = rate_hz; + + debug("clk: %s.%d, step[%d] src[%d,%d] %ld", peri->dev_name, + peri->dev_id, peri->clk_step, peri->div_src_0, peri->div_src_1, + rate); + debug("/(div0: %d * div1: %d) = %ld, %ld diff (%ld)\n", + peri->div_val_0, peri->div_val_1, rate_hz, request, + abs(rate_hz - request)); + + return clk->rate; +} + +unsigned long clk_get_rate(struct clk *clk) +{ + struct clk_dev *cdev = clk_container(clk); + + if (cdev->link) + clk = cdev->link; + return clk->rate; +} + +int clk_set_rate(struct clk *clk, unsigned long rate) +{ + struct clk_dev *cdev = clk_container(clk); + struct clk_dev_peri *peri = cdev->peri; + int i; + + if (!peri) + return core_set_rate(clk, rate); + + clk_round_rate(clk, rate); + + for (i = 0; peri->clk_step > i ; i++) { + int s = (i == 0 ? peri->div_src_0 : peri->div_src_1); + int d = (i == 0 ? peri->div_val_0 : peri->div_val_1); + + if (-1 == s) + continue; + + clk_dev_rate(peri->base, i, s, d); + + debug("clk: %s.%d (%p) set_rate [%d] src[%d] div[%d]\n", + peri->dev_name, peri->dev_id, peri->base, i, s, d); + } + + return clk->rate; +} + +int clk_enable(struct clk *clk) +{ + struct clk_dev *cdev = clk_container(clk); + struct clk_dev_peri *peri = cdev->peri; + int i = 0, inv = 0; + + if (!peri) + return 0; + + debug("clk: %s.%d enable (BCLK=%s, PCLK=%s)\n", peri->dev_name, + peri->dev_id, I_GATE_BCLK & peri->in_mask ? "ON" : "PASS", + I_GATE_PCLK & peri->in_mask ? "ON" : "PASS"); + + if (!(I_CLOCK_MASK & peri->in_mask)) { + /* Gated BCLK/PCLK enable */ + if (I_GATE_BCLK & peri->in_mask) + clk_dev_bclk(peri->base, 1); + + if (I_GATE_PCLK & peri->in_mask) + clk_dev_pclk(peri->base, 1); + + return 0; + } + + /* invert */ + inv = peri->invert_0; + for (; peri->clk_step > i; i++, inv = peri->invert_1) + clk_dev_inv(peri->base, i, inv); + + /* Gated BCLK/PCLK enable */ + if (I_GATE_BCLK & peri->in_mask) + clk_dev_bclk(peri->base, 1); + + if (I_GATE_PCLK & peri->in_mask) + clk_dev_pclk(peri->base, 1); + + /* restore clock rate */ + for (i = 0; peri->clk_step > i ; i++) { + int s = (i == 0 ? peri->div_src_0 : peri->div_src_1); + int d = (i == 0 ? peri->div_val_0 : peri->div_val_1); + + if (s == -1) + continue; + clk_dev_rate(peri->base, i, s, d); + } + + clk_dev_enb(peri->base, 1); + + return 0; +} + +void clk_disable(struct clk *clk) +{ + struct clk_dev *cdev = clk_container(clk); + struct clk_dev_peri *peri = cdev->peri; + + if (!peri) + return; + + debug("clk: %s.%d disable\n", peri->dev_name, peri->dev_id); + + if (!(I_CLOCK_MASK & peri->in_mask)) { + /* Gated BCLK/PCLK disable */ + if (I_GATE_BCLK & peri->in_mask) + clk_dev_bclk(peri->base, 0); + + if (I_GATE_PCLK & peri->in_mask) + clk_dev_pclk(peri->base, 0); + + return; + } + + clk_dev_rate(peri->base, 0, 7, 256); /* for power save */ + clk_dev_enb(peri->base, 0); + + /* Gated BCLK/PCLK disable */ + if (I_GATE_BCLK & peri->in_mask) + clk_dev_bclk(peri->base, 0); + + if (I_GATE_PCLK & peri->in_mask) + clk_dev_pclk(peri->base, 0); +} + +/* + * Core clocks APIs + */ +void __init clk_init(void) +{ + struct clk_dev *cdev = st_clk_devs; + struct clk_dev_peri *peri = clk_periphs; + struct clk *clk = NULL; + int i = 0; + + memset(cdev, 0, sizeof(st_clk_devs)); + core_rate_init(); + + for (i = 0; (CLK_CORE_NUM + CLK_PERI_NUM) > i; i++, cdev++) { + if (i < CLK_CORE_NUM) { + cdev->name = clk_core[i]; + clk = &cdev->clk; + clk->rate = core_get_rate(i); + continue; + } + + peri = &clk_periphs[i - CLK_CORE_NUM]; + peri->base = (void *)peri->base; + + cdev->peri = peri; + cdev->name = peri->dev_name; + + if (!(I_CLOCK_MASK & peri->in_mask)) { + if (I_BCLK_MASK & peri->in_mask) + cdev->clk.rate = core_get_rate(CORECLK_ID_BCLK); + if (I_PCLK_MASK & peri->in_mask) + cdev->clk.rate = core_get_rate(CORECLK_ID_PCLK); + } + + /* prevent uart clock disable for low step debug message */ + #ifndef CONFIG_DEBUG_NX_UART + if (peri->dev_name) { + #ifdef CONFIG_BACKLIGHT_PWM + if (!strcmp(peri->dev_name, DEV_NAME_PWM)) + continue; + #endif + } + #endif + } + debug("CPU : Clock Generator= %d EA, ", CLK_DEVS_NUM); +} diff --git a/arch/arm/mach-nexell/cmd_boot_linux.c b/arch/arm/mach-nexell/cmd_boot_linux.c new file mode 100644 index 0000000..f2dedfe --- /dev/null +++ b/arch/arm/mach-nexell/cmd_boot_linux.c @@ -0,0 +1,144 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 nexell + * jhkim jhkim@nexell.co.kr + */ + +#include <common.h> +#include <bootm.h> +#include <command.h> +#include <environment.h> +#include <errno.h> +#include <image.h> +#include <fdt_support.h> + +#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_CLI_FRAMEWORK) + +DECLARE_GLOBAL_DATA_PTR; + +static bootm_headers_t linux_images; + +static void boot_go_set_os(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[], + bootm_headers_t *images) +{ + char * const img_addr = argv[0]; + + images->os.type = IH_TYPE_KERNEL; + images->os.comp = IH_COMP_NONE; + images->os.os = IH_OS_LINUX; + images->os.load = simple_strtoul(img_addr, NULL, 16); + images->ep = images->os.load; +#if defined(CONFIG_ARM) + images->os.arch = IH_ARCH_ARM; +#elif defined(CONFIG_ARM64) + images->os.arch = IH_ARCH_ARM64; +#else + #error "Not support architecture ..." +#endif + if (!IS_ENABLED(CONFIG_OF_LIBFDT) && !IS_ENABLED(CONFIG_SPL_BUILD)) { + /* set DTB address for linux kernel */ + if (argc > 2) { + unsigned long ft_addr; + + ft_addr = simple_strtol(argv[2], NULL, 16); + images->ft_addr = (char *)ft_addr; + + /* + * if not defined IMAGE_ENABLE_OF_LIBFDT, + * must be set to fdt address + */ + if (!IMAGE_ENABLE_OF_LIBFDT) + gd->bd->bi_boot_params = ft_addr; + + debug("## set ft:%08lx and boot params:%08lx [control of:%s]" + "...\n", ft_addr, gd->bd->bi_boot_params, + IMAGE_ENABLE_OF_LIBFDT ? "on" : "off"); + } + } +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_LMB) +static void boot_start_lmb(bootm_headers_t *images) +{ + ulong mem_start; + phys_size_t mem_size; + + lmb_init(&images->lmb); + + mem_start = getenv_bootm_low(); + mem_size = getenv_bootm_size(); + + lmb_add(&images->lmb, (phys_addr_t)mem_start, mem_size); + + arch_lmb_reserve(&images->lmb); + board_lmb_reserve(&images->lmb); +} +#else +#define lmb_reserve(lmb, base, size) +static inline void boot_start_lmb(bootm_headers_t *images) { } +#endif + +int do_boot_linux(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + boot_os_fn *boot_fn; + bootm_headers_t *images = &linux_images; + int flags; + int ret; + + boot_start_lmb(images); + + flags = BOOTM_STATE_START; + + argc--; argv++; + boot_go_set_os(cmdtp, flag, argc, argv, images); + + if (IS_ENABLED(CONFIG_OF_LIBFDT)) { + /* find flattened device tree */ + ret = boot_get_fdt(flag, argc, argv, IH_ARCH_DEFAULT, images, + &images->ft_addr, &images->ft_len); + if (ret) { + puts("Could not find a valid device tree\n"); + return 1; + } + set_working_fdt_addr((ulong)images->ft_addr); + } + + if (!IS_ENABLED(CONFIG_OF_LIBFDT)) + flags |= BOOTM_STATE_OS_GO; + + boot_fn = do_bootm_linux; + ret = boot_fn(flags, argc, argv, images); + + if (ret == BOOTM_ERR_UNIMPLEMENTED) + show_boot_progress(BOOTSTAGE_ID_DECOMP_UNIMPL); + else if (ret == BOOTM_ERR_RESET) + do_reset(cmdtp, flag, argc, argv); + + return ret; +} + +U_BOOT_CMD(bootl, CONFIG_SYS_MAXARGS, 1, do_boot_linux, + "boot linux image from memory", + "[addr [arg ...]]\n - boot linux image stored in memory\n" + "\tuse a '-' for the DTB address\n" +); +#endif + +#if defined(CONFIG_CMD_BOOTD) && !defined(CONFIG_CMD_BOOTM) +int do_bootd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return run_command(env_get("bootcmd"), flag); +} + +U_BOOT_CMD(boot, 1, 1, do_bootd, + "boot default, i.e., run 'bootcmd'", + "" +); + +/* keep old command name "bootd" for backward compatibility */ +U_BOOT_CMD(bootd, 1, 1, do_bootd, + "boot default, i.e., run 'bootcmd'", + "" +); +#endif diff --git a/arch/arm/mach-nexell/config.mk b/arch/arm/mach-nexell/config.mk new file mode 100644 index 0000000..7b06626 --- /dev/null +++ b/arch/arm/mach-nexell/config.mk @@ -0,0 +1,11 @@ +# +# (C) Copyright 2016 Nexell +# junghyun kimjhkim@nexell.co.kr +# +# SPDX-License-Identifier: GPL-2.0+ +# + +SOCDIR=CPUDIR/$(VENDOR) +MACHDIR=$(patsubst %,arch/arm/mach-%,$(machine-y)) + +LDPPFLAGS += -DMACHDIR=$(MACHDIR) -DSOCDIR=$(SOCDIR) diff --git a/arch/arm/mach-nexell/nx_gpio.c b/arch/arm/mach-nexell/nx_gpio.c new file mode 100644 index 0000000..dfba3a2 --- /dev/null +++ b/arch/arm/mach-nexell/nx_gpio.c @@ -0,0 +1,352 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * Youngbok, Park ybpark@nexell.co.kr + */ + +/* + * FIXME : will be remove after support pinctrl + */ +#include <linux/types.h> +#include <asm/io.h> +#include <asm/arch/nexell.h> +#include "asm/arch/nx_gpio.h" +#define NUMBER_OF_GPIO_MODULE 5 +u32 __g_nx_gpio_valid_bit[NUMBER_OF_GPIO_MODULE] = { + 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF}; + +static struct { + struct nx_gpio_register_set *pregister; +} __g_module_variables[NUMBER_OF_GPIO_MODULE] = { + { (struct nx_gpio_register_set *)PHY_BASEADDR_GPIOA }, + { (struct nx_gpio_register_set *)PHY_BASEADDR_GPIOB }, + { (struct nx_gpio_register_set *)PHY_BASEADDR_GPIOC }, + { (struct nx_gpio_register_set *)PHY_BASEADDR_GPIOD }, + { (struct nx_gpio_register_set *)PHY_BASEADDR_GPIOE }, +}; + +enum { nx_gpio_max_bit = 32 }; + +void nx_gpio_set_bit(u32 *value, u32 bit, int enable) +{ + register u32 newvalue; + + newvalue = *value; + newvalue &= ~(1ul << bit); + newvalue |= (u32)enable << bit; + writel(newvalue, value); +} + +int nx_gpio_get_bit(u32 value, u32 bit) +{ + return (int)((value >> bit) & (1ul)); +} + +void nx_gpio_set_bit2(u32 *value, u32 bit, u32 bit_value) +{ + register u32 newvalue = *value; + + newvalue = (u32)(newvalue & ~(3ul << (bit * 2))); + newvalue = (u32)(newvalue | (bit_value << (bit * 2))); + + writel(newvalue, value); +} + +u32 nx_gpio_get_bit2(u32 value, u32 bit) +{ + return (u32)((u32)(value >> (bit * 2)) & 3ul); +} + +int nx_gpio_initialize(void) +{ + static int binit; + u32 i; + + binit = 0; + + if (binit == 0) { + for (i = 0; i < NUMBER_OF_GPIO_MODULE; i++) + __g_module_variables[i].pregister = NULL; + binit = true; + } + for (i = 0; i < NUMBER_OF_GPIO_MODULE; i++) { + __g_nx_gpio_valid_bit[i] = 0xFFFFFFFF; + }; + return true; +} + +u32 nx_gpio_get_number_of_module(void) +{ + return NUMBER_OF_GPIO_MODULE; +} + +u32 nx_gpio_get_size_of_register_set(void) +{ + return sizeof(struct nx_gpio_register_set); +} + +void nx_gpio_set_base_address(u32 module_index, void *base_address) +{ + __g_module_variables[module_index].pregister = + (struct nx_gpio_register_set *)base_address; +} + +void *nx_gpio_get_base_address(u32 module_index) +{ + return (void *)__g_module_variables[module_index].pregister; +} + +int nx_gpio_open_module(u32 module_index) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(0xFFFFFFFF, &pregister->gpiox_slew_disable_default); + writel(0xFFFFFFFF, &pregister->gpiox_drv1_disable_default); + writel(0xFFFFFFFF, &pregister->gpiox_drv0_disable_default); + writel(0xFFFFFFFF, &pregister->gpiox_pullsel_disable_default); + writel(0xFFFFFFFF, &pregister->gpiox_pullenb_disable_default); + return true; +} + +int nx_gpio_close_module(u32 module_index) { return true; } + +int nx_gpio_check_busy(u32 module_index) { return false; } + +void nx_gpio_set_pad_function(u32 module_index, u32 bit_number, + u32 padfunc) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + nx_gpio_set_bit2(&pregister->gpioxaltfn[bit_number / 16], + bit_number % 16, padfunc); +} + +void nx_gpio_set_pad_function32(u32 module_index, u32 msbvalue, u32 lsbvalue) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(lsbvalue, &pregister->gpioxaltfn[0]); + writel(msbvalue, &pregister->gpioxaltfn[1]); +} + +int nx_gpio_get_pad_function(u32 module_index, u32 bit_number) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return (int)nx_gpio_get_bit2 + (readl(&pregister->gpioxaltfn[bit_number / 16]), + bit_number % 16); +} + +void nx_gpio_set_output_enable(u32 module_index, u32 bit_number, + int output_enb) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + nx_gpio_set_bit(&pregister->gpioxoutenb, bit_number, output_enb); +} + +int nx_gpio_get_detect_enable(u32 module_index, u32 bit_number) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return nx_gpio_get_bit(readl(&pregister->gpioxdetenb), bit_number); +} + +u32 nx_gpio_get_detect_enable32(u32 module_index) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return readl(&pregister->gpioxdetenb); +} + +void nx_gpio_set_detect_enable(u32 module_index, u32 bit_number, + int detect_enb) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + nx_gpio_set_bit(&pregister->gpioxdetenb, bit_number, detect_enb); +} + +void nx_gpio_set_detect_enable32(u32 module_index, u32 enable_flag) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(enable_flag, &pregister->gpioxdetenb); +} + +int nx_gpio_get_output_enable(u32 module_index, u32 bit_number) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return nx_gpio_get_bit(readl(&pregister->gpioxoutenb), bit_number); +} + +void nx_gpio_set_output_enable32(u32 module_index, int output_enb) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (output_enb) + writel(0xFFFFFFFF, &pregister->gpioxoutenb); + else + writel(0x0, &pregister->gpioxoutenb); +} + +u32 nx_gpio_get_output_enable32(u32 module_index) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return readl(&pregister->gpioxoutenb); +} + +void nx_gpio_set_output_value(u32 module_index, u32 bit_number, int value) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + nx_gpio_set_bit(&pregister->gpioxout, bit_number, value); +} + +int nx_gpio_get_output_value(u32 module_index, u32 bit_number) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return nx_gpio_get_bit(readl(&pregister->gpioxout), bit_number); +} + +void nx_gpio_set_output_value32(u32 module_index, u32 value) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(value, &pregister->gpioxout); +} + +u32 nx_gpio_get_output_value32(u32 module_index) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return readl(&pregister->gpioxout); +} + +int nx_gpio_get_input_value(u32 module_index, u32 bit_number) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return nx_gpio_get_bit(readl(&pregister->gpioxpad), bit_number); +} + +void nx_gpio_set_pull_select(u32 module_index, u32 bit_number, int enable) +{ + nx_gpio_set_bit(&__g_module_variables[module_index] + .pregister->gpiox_pullsel_disable_default, + bit_number, true); + nx_gpio_set_bit + (&__g_module_variables[module_index].pregister->gpiox_pullsel, + bit_number, enable); +} + +void nx_gpio_set_pull_select32(u32 module_index, u32 value) +{ + writel(value, + &__g_module_variables[module_index].pregister->gpiox_pullsel); +} + +int nx_gpio_get_pull_select(u32 module_index, u32 bit_number) +{ + return nx_gpio_get_bit + (__g_module_variables[module_index].pregister->gpiox_pullsel, + bit_number); +} + +u32 nx_gpio_get_pull_select32(u32 module_index) +{ + return __g_module_variables[module_index].pregister->gpiox_pullsel; +} + +void nx_gpio_set_pull_mode(u32 module_index, u32 bit_number, u32 mode) +{ + nx_gpio_set_bit(&__g_module_variables[module_index] + .pregister->gpiox_pullsel_disable_default, + bit_number, true); + nx_gpio_set_bit(&__g_module_variables[module_index] + .pregister->gpiox_pullenb_disable_default, + bit_number, true); + if (mode == nx_gpio_pull_off) { + nx_gpio_set_bit + (&__g_module_variables[module_index].pregister->gpiox_pullenb, + bit_number, false); + nx_gpio_set_bit + (&__g_module_variables[module_index].pregister->gpiox_pullsel, + bit_number, false); + } else { + nx_gpio_set_bit + (&__g_module_variables[module_index].pregister->gpiox_pullsel, + bit_number, (mode & 1 ? true : false)); + nx_gpio_set_bit + (&__g_module_variables[module_index].pregister->gpiox_pullenb, + bit_number, true); + } +} + +void nx_gpio_set_fast_slew(u32 module_index, u32 bit_number, + int enable) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + nx_gpio_set_bit(&pregister->gpiox_slew, bit_number, + (int)(!enable)); +} + +void nx_gpio_set_drive_strength(u32 module_index, u32 bit_number, + u32 drvstrength) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + nx_gpio_set_bit(&pregister->gpiox_drv1, bit_number, + (int)(((u32)drvstrength >> 0) & 0x1)); + nx_gpio_set_bit(&pregister->gpiox_drv0, bit_number, + (int)(((u32)drvstrength >> 1) & 0x1)); +} + +void nx_gpio_set_drive_strength_disable_default(u32 module_index, + u32 bit_number, int enable) +{ + register struct nx_gpio_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + nx_gpio_set_bit(&pregister->gpiox_drv1_disable_default, bit_number, + (int)(enable)); + nx_gpio_set_bit(&pregister->gpiox_drv0_disable_default, bit_number, + (int)(enable)); +} + +u32 nx_gpio_get_drive_strength(u32 module_index, u32 bit_number) +{ + register struct nx_gpio_register_set *pregister; + register u32 retvalue; + + pregister = __g_module_variables[module_index].pregister; + retvalue = + nx_gpio_get_bit(readl(&pregister->gpiox_drv0), bit_number) << 1; + retvalue |= + nx_gpio_get_bit(readl(&pregister->gpiox_drv1), bit_number) << 0; + return retvalue; +} diff --git a/arch/arm/mach-nexell/nx_sec_reg.c b/arch/arm/mach-nexell/nx_sec_reg.c new file mode 100644 index 0000000..3d3dd9f --- /dev/null +++ b/arch/arm/mach-nexell/nx_sec_reg.c @@ -0,0 +1,82 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * Youngbok, Park park@nexell.co.kr + */ + +#include <linux/types.h> +#include <asm/io.h> +#include <asm/arch/nexell.h> +#include <asm/arch/sec_reg.h> +#include <linux/linkage.h> + +#define NEXELL_SMC_BASE 0x82000000 + +#define NEXELL_SMC_FN(n) (NEXELL_SMC_BASE + (n)) + +#define NEXELL_SMC_SEC_REG_WRITE NEXELL_SMC_FN(0x0) +#define NEXELL_SMC_SEC_REG_READ NEXELL_SMC_FN(0x1) + +#define SECURE_ID_SHIFT 8 + +#define SEC_4K_OFFSET ((4 * 1024) - 1) +#define SEC_64K_OFFSET ((64 * 1024) - 1) + +asmlinkage int __invoke_nexell_fn_smc(u32, u32, u32, u32); + +int write_sec_reg_by_id(void __iomem *reg, int val, int id) +{ + int ret = 0; + u32 off = 0; + + switch (id) { + case NEXELL_L2C_SEC_ID: + case NEXELL_MIPI_SEC_ID: + case NEXELL_TOFF_SEC_ID: + off = (u32)reg & SEC_4K_OFFSET; + break; + case NEXELL_MALI_SEC_ID: + off = (u32)reg & SEC_64K_OFFSET; + break; + } + ret = __invoke_nexell_fn_smc(NEXELL_SMC_SEC_REG_WRITE | + ((1 << SECURE_ID_SHIFT) + id), off, val, 0); + return ret; +} + +int read_sec_reg_by_id(void __iomem *reg, int id) +{ + int ret = 0; + u32 off = 0; + + switch (id) { + case NEXELL_L2C_SEC_ID: + case NEXELL_MIPI_SEC_ID: + case NEXELL_TOFF_SEC_ID: + off = (u32)reg & SEC_4K_OFFSET; + break; + case NEXELL_MALI_SEC_ID: + off = (u32)reg & SEC_64K_OFFSET; + break; + } + ret = __invoke_nexell_fn_smc(NEXELL_SMC_SEC_REG_READ | + ((1 << SECURE_ID_SHIFT) + id), off, 0, 0); + return ret; +} + +int write_sec_reg(void __iomem *reg, int val) +{ + int ret = 0; + + ret = __invoke_nexell_fn_smc(NEXELL_SMC_SEC_REG_WRITE, + (u32)reg, val, 0); + return ret; +} + +int read_sec_reg(void __iomem *reg) +{ + int ret = 0; + + ret = __invoke_nexell_fn_smc(NEXELL_SMC_SEC_REG_READ, (u32)reg, 0, 0); + return ret; +} diff --git a/arch/arm/mach-nexell/reg-call.S b/arch/arm/mach-nexell/reg-call.S new file mode 100644 index 0000000..5fdf515 --- /dev/null +++ b/arch/arm/mach-nexell/reg-call.S @@ -0,0 +1,23 @@ +#include <asm-offsets.h> +#include <config.h> +#include <linux/linkage.h> + +#define ___asm_opcode_identity32(x) ((x) & 0xFFFFFFFF) +#define __opcode_to_mem_arm(x) ___opcode_identity32(x) +#define ___asm_opcode_to_mem_arm(x) ___asm_opcode_identity32(x) + +#define ___opcode_identity32(x) ((u32)(x)) +#define ___inst_arm(x) .long x +#define __inst_arm(x) ___inst_arm(___asm_opcode_to_mem_arm(x)) + +#define __inst_arm_thumb32(arm_opcode, thumb_opcode) __inst_arm(arm_opcode) + +#define __SMC(imm4) __inst_arm_thumb32( \ + 0xE1600070 | (((imm4) & 0xF) << 0), \ + 0xF7F08000 | (((imm4) & 0xF) << 16) \ +) + +ENTRY(__invoke_nexell_fn_smc) + __SMC(0) + bx lr +ENDPROC(__invoke_nexell_fn_smc) diff --git a/arch/arm/mach-nexell/reset.c b/arch/arm/mach-nexell/reset.c new file mode 100644 index 0000000..1f732a3 --- /dev/null +++ b/arch/arm/mach-nexell/reset.c @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * Youngbok, Park park@nexell.co.kr + */ + +/* + *FIXME : Not support device tree & reset control driver. + * will remove after support device tree & reset control driver. + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/nexell.h> +#include <asm/arch/reset.h> + +struct nx_rstcon_registerset { + u32 regrst[(NUMBER_OF_RESET_MODULE_PIN + 31) >> 5]; +}; + +static struct nx_rstcon_registerset *nx_rstcon = + (struct nx_rstcon_registerset *)PHY_BASEADDR_RSTCON; + +void nx_rstcon_setrst(u32 rstindex, enum rstcon status) +{ + u32 regnum, bitpos, curstat; + + regnum = rstindex >> 5; + curstat = (u32)readl(&nx_rstcon->regrst[regnum]); + bitpos = rstindex & 0x1f; + curstat &= ~(1UL << bitpos); + curstat |= (status & 0x01) << bitpos; + writel(curstat, &nx_rstcon->regrst[regnum]); +} diff --git a/arch/arm/mach-nexell/tieoff.c b/arch/arm/mach-nexell/tieoff.c new file mode 100644 index 0000000..5a4744c --- /dev/null +++ b/arch/arm/mach-nexell/tieoff.c @@ -0,0 +1,107 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * Youngbok, Park park@nexell.co.kr + */ + +#include <common.h> +#include <asm/arch/nexell.h> +#include <asm/arch/clk.h> +#include <asm/arch/reset.h> +#include <asm/arch/nx_gpio.h> +#include <asm/arch/tieoff.h> +#include <asm/arch/sec_reg.h> + +#define NX_PIN_FN_SIZE 4 +#define TIEOFF_REG_NUM 33 + +struct nx_tieoff_registerset { + u32 tieoffreg[TIEOFF_REG_NUM]; +}; + +static struct nx_tieoff_registerset *nx_tieoff = (void *)PHY_BASEADDR_TIEOFF; + +static int tieoff_readl(void __iomem *reg) +{ + if (IS_ENABLED(CONFIG_ARCH_S5P4418)) + return read_sec_reg_by_id(reg, NEXELL_TOFF_SEC_ID); + else + return readl(reg); +} + +static int tieoff_writetl(void __iomem *reg, int val) +{ + if (IS_ENABLED(CONFIG_ARCH_S5P4418)) + return write_sec_reg_by_id(reg, val, NEXELL_TOFF_SEC_ID); + else + return writel(val, reg); +} + +void nx_tieoff_set(u32 tieoff_index, u32 tieoff_value) +{ + u32 regindex, mask; + u32 lsb, msb; + u32 regval; + + u32 position; + u32 bitwidth; + + position = tieoff_index & 0xffff; + bitwidth = (tieoff_index >> 16) & 0xffff; + + regindex = position >> 5; + + lsb = position & 0x1F; + msb = lsb + bitwidth; + + if (msb > 32) { + msb &= 0x1F; + mask = ~(0xffffffff << lsb); + regval = tieoff_readl(&nx_tieoff->tieoffreg[regindex]) & mask; + regval |= ((tieoff_value & ((1UL << bitwidth) - 1)) << lsb); + tieoff_writetl(&nx_tieoff->tieoffreg[regindex], regval); + + mask = (0xffffffff << msb); + regval = tieoff_readl(&nx_tieoff->tieoffreg[regindex]) & mask; + regval |= ((tieoff_value & ((1UL << bitwidth) - 1)) >> msb); + tieoff_writetl(&nx_tieoff->tieoffreg[regindex + 1], regval); + } else { + mask = (0xffffffff << msb) | (~(0xffffffff << lsb)); + regval = tieoff_readl(&nx_tieoff->tieoffreg[regindex]) & mask; + regval |= ((tieoff_value & ((1UL << bitwidth) - 1)) << lsb); + tieoff_writetl(&nx_tieoff->tieoffreg[regindex], regval); + } +} + +u32 nx_tieoff_get(u32 tieoff_index) +{ + u32 regindex, mask; + u32 lsb, msb; + u32 regval; + + u32 position; + u32 bitwidth; + + position = tieoff_index & 0xffff; + bitwidth = (tieoff_index >> 16) & 0xffff; + + regindex = position / 32; + lsb = position % 32; + msb = lsb + bitwidth; + + if (msb > 32) { + msb &= 0x1F; + mask = 0xffffffff << lsb; + regval = tieoff_readl(&nx_tieoff->tieoffreg[regindex]) & mask; + regval >>= lsb; + + mask = ~(0xffffffff << msb); + regval |= ((tieoff_readl(&nx_tieoff->tieoffreg[regindex + 1]) + & mask) << (32 - lsb)); + } else { + mask = ~(0xffffffff << msb) & (0xffffffff << lsb); + regval = tieoff_readl(&nx_tieoff->tieoffreg[regindex]) & mask; + regval >>= lsb; + } + return regval; +} diff --git a/arch/arm/mach-nexell/timer.c b/arch/arm/mach-nexell/timer.c new file mode 100644 index 0000000..fecee67 --- /dev/null +++ b/arch/arm/mach-nexell/timer.c @@ -0,0 +1,299 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * Hyunseok, Jung hsjung@nexell.co.kr + */ + +#include <common.h> +#include <log.h> + +#include <asm/io.h> +#include <asm/arch/nexell.h> +#include <asm/arch/clk.h> +#if defined(CONFIG_ARCH_S5P4418) +#include <asm/arch/reset.h> +#endif + +#if (CONFIG_TIMER_SYS_TICK_CH > 3) +#error Not support timer channel. Please use "0~3" channels. +#endif + +/* global variables to save timer count + * + * Section ".data" must be used because BSS is not available before relocation, + * in board_init_f(), respectively! I.e. global variables can not be used! + */ +static unsigned long timestamp __attribute__ ((section(".data"))); +static unsigned long lastdec __attribute__ ((section(".data"))); +static int timerinit __attribute__ ((section(".data"))); + +/* macro to hw timer tick config */ +static long TIMER_FREQ = 1000000; +static long TIMER_HZ = 1000000 / CONFIG_SYS_HZ; +static long TIMER_COUNT = 0xFFFFFFFF; + +#define REG_TCFG0 (0x00) +#define REG_TCFG1 (0x04) +#define REG_TCON (0x08) +#define REG_TCNTB0 (0x0C) +#define REG_TCMPB0 (0x10) +#define REG_TCNT0 (0x14) +#define REG_CSTAT (0x44) + +#define TCON_BIT_AUTO (1 << 3) +#define TCON_BIT_INVT (1 << 2) +#define TCON_BIT_UP (1 << 1) +#define TCON_BIT_RUN (1 << 0) +#define TCFG0_BIT_CH(ch) ((ch) == 0 || (ch) == 1 ? 0 : 8) +#define TCFG1_BIT_CH(ch) ((ch) * 4) +#define TCON_BIT_CH(ch) ((ch) ? (ch) * 4 + 4 : 0) +#define TINT_CH(ch) (ch) +#define TINT_CSTAT_BIT_CH(ch) ((ch) + 5) +#define TINT_CSTAT_MASK (0x1F) +#define TIMER_TCNT_OFFS (0xC) + +void reset_timer_masked(void); +unsigned long get_timer_masked(void); + +/* + * Timer HW + */ +static inline void timer_clock(void __iomem *base, int ch, int mux, int scl) +{ + u32 val = readl(base + REG_TCFG0) & ~(0xFF << TCFG0_BIT_CH(ch)); + + writel(val | ((scl - 1) << TCFG0_BIT_CH(ch)), base + REG_TCFG0); + val = readl(base + REG_TCFG1) & ~(0xF << TCFG1_BIT_CH(ch)); + writel(val | (mux << TCFG1_BIT_CH(ch)), base + REG_TCFG1); +} + +static inline void timer_count(void __iomem *base, int ch, unsigned int cnt) +{ + writel((cnt - 1), base + REG_TCNTB0 + (TIMER_TCNT_OFFS * ch)); + writel((cnt - 1), base + REG_TCMPB0 + (TIMER_TCNT_OFFS * ch)); +} + +static inline void timer_start(void __iomem *base, int ch) +{ + int on = 0; + u32 val = readl(base + REG_CSTAT) & ~(TINT_CSTAT_MASK << 5 | 0x1 << ch); + + writel(val | (0x1 << TINT_CSTAT_BIT_CH(ch) | on << ch), + base + REG_CSTAT); + val = readl(base + REG_TCON) & ~(0xE << TCON_BIT_CH(ch)); + writel(val | (TCON_BIT_UP << TCON_BIT_CH(ch)), base + REG_TCON); + + val &= ~(TCON_BIT_UP << TCON_BIT_CH(ch)); + val |= ((TCON_BIT_AUTO | TCON_BIT_RUN) << TCON_BIT_CH(ch)); + writel(val, base + REG_TCON); + dmb(); +} + +static inline void timer_stop(void __iomem *base, int ch) +{ + int on = 0; + u32 val = readl(base + REG_CSTAT) & ~(TINT_CSTAT_MASK << 5 | 0x1 << ch); + + writel(val | (0x1 << TINT_CSTAT_BIT_CH(ch) | on << ch), + base + REG_CSTAT); + val = readl(base + REG_TCON) & ~(TCON_BIT_RUN << TCON_BIT_CH(ch)); + writel(val, base + REG_TCON); +} + +static inline unsigned long timer_read(void __iomem *base, int ch) +{ + unsigned long ret; + + ret = TIMER_COUNT - readl(base + REG_TCNT0 + (TIMER_TCNT_OFFS * ch)); + return ret; +} + +int timer_init(void) +{ + struct clk *clk = NULL; + char name[16] = "pclk"; + int ch = CONFIG_TIMER_SYS_TICK_CH; + unsigned long rate, tclk = 0; + unsigned long mout, thz, cmp = -1UL; + int tcnt, tscl = 0, tmux = 0; + int mux = 0, scl = 0; + void __iomem *base = (void __iomem *)PHY_BASEADDR_TIMER; + + if (timerinit) + return 0; + + /* get with PCLK */ + clk = clk_get(name); + rate = clk_get_rate(clk); + for (mux = 0; mux < 5; mux++) { + mout = rate / (1 << mux), scl = mout / TIMER_FREQ, + thz = mout / scl; + if (!(mout % TIMER_FREQ) && 256 > scl) { + tclk = thz, tmux = mux, tscl = scl; + break; + } + if (scl > 256) + continue; + if (abs(thz - TIMER_FREQ) >= cmp) + continue; + tclk = thz, tmux = mux, tscl = scl; + cmp = abs(thz - TIMER_FREQ); + } + tcnt = tclk; /* Timer Count := 1 Mhz counting */ + + TIMER_FREQ = tcnt; /* Timer Count := 1 Mhz counting */ + TIMER_HZ = TIMER_FREQ / CONFIG_SYS_HZ; + tcnt = TIMER_COUNT == 0xFFFFFFFF ? TIMER_COUNT + 1 : tcnt; + + timer_stop(base, ch); + timer_clock(base, ch, tmux, tscl); + timer_count(base, ch, tcnt); + timer_start(base, ch); + + reset_timer_masked(); + timerinit = 1; + + return 0; +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +unsigned long get_timer(unsigned long base) +{ + long ret; + unsigned long time = get_timer_masked(); + unsigned long hz = TIMER_HZ; + + ret = time / hz - base; + return ret; +} + +void set_timer(unsigned long t) +{ + timestamp = (unsigned long)t; +} + +void reset_timer_masked(void) +{ + void __iomem *base = (void __iomem *)PHY_BASEADDR_TIMER; + int ch = CONFIG_TIMER_SYS_TICK_CH; + + /* reset time */ + /* capure current decrementer value time */ + lastdec = timer_read(base, ch); + /* start "advancing" time stamp from 0 */ + timestamp = 0; +} + +unsigned long get_timer_masked(void) +{ + void __iomem *base = (void __iomem *)PHY_BASEADDR_TIMER; + int ch = CONFIG_TIMER_SYS_TICK_CH; + + unsigned long now = timer_read(base, ch); /* current tick value */ + + if (now >= lastdec) { /* normal mode (non roll) */ + /* move stamp fordward with absolute diff ticks */ + timestamp += now - lastdec; + } else { + /* we have overflow of the count down timer */ + /* nts = ts + ld + (TLV - now) + * ts=old stamp, ld=time that passed before passing through -1 + * (TLV-now) amount of time after passing though -1 + * nts = new "advancing time stamp"... + * it could also roll and cause problems. + */ + timestamp += now + TIMER_COUNT - lastdec; + } + /* save last */ + lastdec = now; + + debug("now=%lu, last=%lu, timestamp=%lu\n", now, lastdec, timestamp); + return (unsigned long)timestamp; +} + +void __udelay(unsigned long usec) +{ + unsigned long tmo, tmp; + + debug("+udelay=%ld\n", usec); + + if (!timerinit) + timer_init(); + + /* if "big" number, spread normalization to seconds */ + if (usec >= 1000) { + /* start to normalize for usec to ticks per sec */ + tmo = usec / 1000; + /* find number of "ticks" to wait to achieve target */ + tmo *= TIMER_FREQ; + /* finish normalize. */ + tmo /= 1000; + /* else small number, don't kill it prior to HZ multiply */ + } else { + tmo = usec * TIMER_FREQ; + tmo /= (1000 * 1000); + } + + tmp = get_timer_masked(); /* get current timestamp */ + debug("A. tmo=%ld, tmp=%ld\n", tmo, tmp); + + /* if setting this fordward will roll time stamp */ + if (tmp > (tmo + tmp + 1)) + /* reset "advancing" timestamp to 0, set lastdec value */ + reset_timer_masked(); + else + /* set advancing stamp wake up time */ + tmo += tmp; + + debug("B. tmo=%ld, tmp=%ld\n", tmo, tmp); + + /* loop till event */ + do { + tmp = get_timer_masked(); + } while (tmo > tmp); + debug("-udelay=%ld\n", usec); +} + +void udelay_masked(unsigned long usec) +{ + unsigned long tmo, endtime; + signed long diff; + + /* if "big" number, spread normalization to seconds */ + if (usec >= 1000) { + /* start to normalize for usec to ticks per sec */ + tmo = usec / 1000; + /* find number of "ticks" to wait to achieve target */ + tmo *= TIMER_FREQ; + /* finish normalize. */ + tmo /= 1000; + } else { /* else small number, don't kill it prior to HZ multiply */ + tmo = usec * TIMER_FREQ; + tmo /= (1000 * 1000); + } + + endtime = get_timer_masked() + tmo; + + do { + unsigned long now = get_timer_masked(); + + diff = endtime - now; + } while (diff >= 0); +} + +unsigned long long get_ticks(void) +{ + return get_timer_masked(); +} + +#if defined(CONFIG_ARCH_S5P4418) +ulong get_tbclk(void) +{ + ulong tbclk = TIMER_FREQ; + return tbclk; +} +#endif
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - livetree API (dev_read_...) is used instead of fdt one (fdt...).
Changes in v3: - Changed to livetree API as proposed by patman: fdtdec_get_int() --> dev_read_s32_default() fdt_getprop() --> dev_read_string()
Changes in v2: - commit "i2c: mmc: add nexell driver (gpio, i2c, mmc, pwm)" splitted into separate commits for gpio, i2c, mmc, pwm. - cosmetic: line "obj-$(CONFIG_NX_GPIO) += nx_gpio.o" in drivers/gpio/Makefile moved up.
drivers/gpio/Kconfig | 9 ++ drivers/gpio/Makefile | 1 + drivers/gpio/nx_gpio.c | 250 +++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 260 insertions(+) create mode 100644 drivers/gpio/nx_gpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index d87f6cc..921d1e2 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -438,4 +438,13 @@ config MT7621_GPIO help Say yes here to support MediaTek MT7621 compatible GPIOs.
+config NX_GPIO + bool "Nexell GPIO driver" + depends on DM_GPIO + help + Support GPIO access on Nexell SoCs. The GPIOs are arranged into + a number of banks (different for each SoC type) each with 32 GPIOs. + The GPIOs for a device are defined in the device tree with one node + for each bank. + endmenu diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 7638259..334c5f2 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -64,4 +64,5 @@ obj-$(CONFIG_$(SPL_)PCF8575_GPIO) += pcf8575_gpio.o obj-$(CONFIG_PM8916_GPIO) += pm8916_gpio.o obj-$(CONFIG_MT7621_GPIO) += mt7621_gpio.o obj-$(CONFIG_MSCC_SGPIO) += mscc_sgpio.o +obj-$(CONFIG_NX_GPIO) += nx_gpio.o obj-$(CONFIG_SIFIVE_GPIO) += sifive-gpio.o diff --git a/drivers/gpio/nx_gpio.c b/drivers/gpio/nx_gpio.c new file mode 100644 index 0000000..5ec73c4 --- /dev/null +++ b/drivers/gpio/nx_gpio.c @@ -0,0 +1,250 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * DeokJin, Lee truevirtue@nexell.co.kr + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct nx_gpio_regs { + u32 data; /* Data register */ + u32 outputenb; /* Output Enable register */ + u32 detmode[2]; /* Detect Mode Register */ + u32 intenb; /* Interrupt Enable Register */ + u32 det; /* Event Detect Register */ + u32 pad; /* Pad Status Register */ +}; + +struct nx_alive_gpio_regs { + u32 pwrgate; /* Power Gating Register */ + u32 reserved0[28]; /* Reserved0 */ + u32 outputenb_reset;/* Alive GPIO Output Enable Reset Register */ + u32 outputenb; /* Alive GPIO Output Enable Register */ + u32 outputenb_read; /* Alive GPIO Output Read Register */ + u32 reserved1[3]; /* Reserved1 */ + u32 pad_reset; /* Alive GPIO Output Reset Register */ + u32 data; /* Alive GPIO Output Register */ + u32 pad_read; /* Alive GPIO Pad Read Register */ + u32 reserved2[33]; /* Reserved2 */ + u32 pad; /* Alive GPIO Input Value Register */ +}; + +struct nx_gpio_platdata { + void *regs; + int gpio_count; + const char *bank_name; +}; + +static int nx_alive_gpio_is_check(struct udevice *dev) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + const char *bank_name = plat->bank_name; + + if (!strcmp(bank_name, "gpio_alv")) + return 1; + + return 0; +} + +static int nx_alive_gpio_direction_input(struct udevice *dev, unsigned int pin) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_alive_gpio_regs *const regs = plat->regs; + + setbits_le32(®s->outputenb_reset, 1 << pin); + + return 0; +} + +static int nx_alive_gpio_direction_output(struct udevice *dev, unsigned int pin, + int val) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_alive_gpio_regs *const regs = plat->regs; + + if (val) + setbits_le32(®s->data, 1 << pin); + else + setbits_le32(®s->pad_reset, 1 << pin); + + setbits_le32(®s->outputenb, 1 << pin); + + return 0; +} + +static int nx_alive_gpio_get_value(struct udevice *dev, unsigned int pin) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_alive_gpio_regs *const regs = plat->regs; + unsigned int mask = 1UL << pin; + unsigned int value; + + value = (readl(®s->pad_read) & mask) >> pin; + + return value; +} + +static int nx_alive_gpio_set_value(struct udevice *dev, unsigned int pin, + int val) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_alive_gpio_regs *const regs = plat->regs; + + if (val) + setbits_le32(®s->data, 1 << pin); + else + clrbits_le32(®s->pad_reset, 1 << pin); + + return 0; +} + +static int nx_alive_gpio_get_function(struct udevice *dev, unsigned int pin) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_alive_gpio_regs *const regs = plat->regs; + unsigned int mask = (1UL << pin); + unsigned int output; + + output = readl(®s->outputenb_read) & mask; + + if (output) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static int nx_gpio_direction_input(struct udevice *dev, unsigned int pin) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_gpio_regs *const regs = plat->regs; + + if (nx_alive_gpio_is_check(dev)) + return nx_alive_gpio_direction_input(dev, pin); + + clrbits_le32(®s->outputenb, 1 << pin); + + return 0; +} + +static int nx_gpio_direction_output(struct udevice *dev, unsigned int pin, + int val) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_gpio_regs *const regs = plat->regs; + + if (nx_alive_gpio_is_check(dev)) + return nx_alive_gpio_direction_output(dev, pin, val); + + if (val) + setbits_le32(®s->data, 1 << pin); + else + clrbits_le32(®s->data, 1 << pin); + + setbits_le32(®s->outputenb, 1 << pin); + + return 0; +} + +static int nx_gpio_get_value(struct udevice *dev, unsigned int pin) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_gpio_regs *const regs = plat->regs; + unsigned int mask = 1UL << pin; + unsigned int value; + + if (nx_alive_gpio_is_check(dev)) + return nx_alive_gpio_get_value(dev, pin); + + value = (readl(®s->pad) & mask) >> pin; + + return value; +} + +static int nx_gpio_set_value(struct udevice *dev, unsigned int pin, int val) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_gpio_regs *const regs = plat->regs; + + if (nx_alive_gpio_is_check(dev)) + return nx_alive_gpio_set_value(dev, pin, val); + + if (val) + setbits_le32(®s->data, 1 << pin); + else + clrbits_le32(®s->data, 1 << pin); + + return 0; +} + +static int nx_gpio_get_function(struct udevice *dev, unsigned int pin) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + struct nx_gpio_regs *const regs = plat->regs; + unsigned int mask = (1UL << pin); + unsigned int output; + + if (nx_alive_gpio_is_check(dev)) + return nx_alive_gpio_get_function(dev, pin); + + output = readl(®s->outputenb) & mask; + + if (output) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static int nx_gpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + + uc_priv->gpio_count = plat->gpio_count; + uc_priv->bank_name = plat->bank_name; + + return 0; +} + +static int nx_gpio_ofdata_to_platdata(struct udevice *dev) +{ + struct nx_gpio_platdata *plat = dev_get_platdata(dev); + + plat->regs = map_physmem(devfdt_get_addr(dev), + sizeof(struct nx_gpio_regs), + MAP_NOCACHE); + plat->gpio_count = dev_read_s32_default(dev, "nexell,gpio-bank-width", + 32); + plat->bank_name = dev_read_string(dev, "gpio-bank-name"); + + return 0; +} + +static const struct dm_gpio_ops nx_gpio_ops = { + .direction_input = nx_gpio_direction_input, + .direction_output = nx_gpio_direction_output, + .get_value = nx_gpio_get_value, + .set_value = nx_gpio_set_value, + .get_function = nx_gpio_get_function, +}; + +static const struct udevice_id nx_gpio_ids[] = { + { .compatible = "nexell,nexell-gpio" }, + { } +}; + +U_BOOT_DRIVER(nx_gpio) = { + .name = "nx_gpio", + .id = UCLASS_GPIO, + .of_match = nx_gpio_ids, + .ops = &nx_gpio_ops, + .ofdata_to_platdata = nx_gpio_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct nx_gpio_platdata), + .probe = nx_gpio_probe, +};
Signed-off-by: Stefan Bosch stefan_b@posteo.net
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - i2c/nx_i2c.c: Some adaptions mainly because of changes in "struct udevice". - several Bugfixes in nx_i2c.c. - the driver has been for s5p6818 only. Code extended appropriately in order s5p4418 is also working. - "probe_chip" added. - pinctrl-driver/dt is used instead of configuring the i2c I/O-pins in the i2c-driver. - '#ifdef CONFIG...' changed to 'if (IS_ENABLED(CONFIG...))' where possible (and similar). - livetree API (dev_read_...) is used instead of fdt one (fdt...).
Signed-off-by: Stefan Bosch stefan_b@posteo.net ---
Changes in v4: - cosmetic changes in nx_i2c.c: if-else block simplified, defines used for constant values.
Changes in v3: - pinctrl-driver/dt is used now instead of configuring the i2c I/O-pins in the i2c-driver. - drivers/i2c/nx_i2c.c: '#include <log.h>' inserted because it has been removed from common.h. - '#ifdef...' changed to 'if (IS_ENABLED(CONFIG...))' where possible because of appropriate warnings of patman. - Changed to livetree API as proposed by patman: fdtdec_get_int() --> dev_read_s32_default()
Changes in v2: - commit "i2c: mmc: add nexell driver (gpio, i2c, mmc, pwm)" splitted into separate commits for gpio, i2c, mmc, pwm. - several Bugfixes in nx_i2c.c. - the i2c-driver has been for s5p6818 only. Code extended approriately in order s5p4418 is also working. - "probe_chip" added to the i2c-driver. - doc/device-tree-bindings/i2c/nx_i2c.txt added.
doc/device-tree-bindings/i2c/nx_i2c.txt | 28 ++ drivers/i2c/Kconfig | 9 + drivers/i2c/Makefile | 1 + drivers/i2c/nx_i2c.c | 626 ++++++++++++++++++++++++++++++++ 4 files changed, 664 insertions(+) create mode 100644 doc/device-tree-bindings/i2c/nx_i2c.txt create mode 100644 drivers/i2c/nx_i2c.c
diff --git a/doc/device-tree-bindings/i2c/nx_i2c.txt b/doc/device-tree-bindings/i2c/nx_i2c.txt new file mode 100644 index 0000000..9f3abe7 --- /dev/null +++ b/doc/device-tree-bindings/i2c/nx_i2c.txt @@ -0,0 +1,28 @@ +I2C controller embedded in Nexell's/Samsung's SoC S5P4418 and S5P6818 + +Driver: +- drivers/i2c/nx_i2c.c + +Required properties: +- #address-cells = <1>; +- #size-cells = <0>; +- compatible = "nexell,s5pxx18-i2c"; +- reg = <i2c_base 0x100>; + Where i2c_base has to be the base address of the i2c-register set. + I2C0: 0xc00a4000 + I2C1: 0xc00a5000 + I2C2: 0xc00a6000 + +Optional properties: +- clock-frequency: Desired I2C bus frequency in Hz, default value is 100000. +- i2c-sda-delay-ns (S5P6818 only): SDA delay in ns, default value is 0. +- Child nodes conforming to i2c bus binding. + +Example: + i2c0:i2c@c00a4000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nexell,s5pxx18-i2c"; + reg = <0xc00a4000 0x100>; + clock-frequency = <400000>; + }; diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index f8b18de..b276f0b 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -325,6 +325,15 @@ config SYS_MXC_I2C8_SLAVE MXC I2C8 Slave endif
+config SYS_I2C_NEXELL + bool "Nexell I2C driver" + depends on DM_I2C + help + Add support for the Nexell I2C driver. This is used with various + Nexell parts such as S5Pxx18 series SoCs. All chips + have several I2C ports and all are provided, controlled by the + device tree. + config SYS_I2C_OMAP24XX bool "TI OMAP2+ I2C driver" depends on ARCH_OMAP2PLUS || ARCH_K3 diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 62935b7..6ebc1aa 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -27,6 +27,7 @@ obj-$(CONFIG_SYS_I2C_LPC32XX) += lpc32xx_i2c.o obj-$(CONFIG_SYS_I2C_MESON) += meson_i2c.o obj-$(CONFIG_SYS_I2C_MVTWSI) += mvtwsi.o obj-$(CONFIG_SYS_I2C_MXC) += mxc_i2c.o +obj-$(CONFIG_SYS_I2C_NEXELL) += nx_i2c.o obj-$(CONFIG_SYS_I2C_OMAP24XX) += omap24xx_i2c.o obj-$(CONFIG_SYS_I2C_RCAR_I2C) += rcar_i2c.o obj-$(CONFIG_SYS_I2C_RCAR_IIC) += rcar_iic.o diff --git a/drivers/i2c/nx_i2c.c b/drivers/i2c/nx_i2c.c new file mode 100644 index 0000000..ca14a0e --- /dev/null +++ b/drivers/i2c/nx_i2c.c @@ -0,0 +1,626 @@ +#include <common.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <log.h> +#include <asm/arch/nexell.h> +#include <asm/arch/reset.h> +#include <asm/arch/clk.h> +#include <asm/arch/nx_gpio.h> +#include <linux/delay.h> + +#define I2C_WRITE 0 +#define I2C_READ 1 + +#define I2CSTAT_MTM 0xC0 /* Master Transmit Mode */ +#define I2CSTAT_MRM 0x80 /* Master Receive Mode */ +#define I2CSTAT_BSY 0x20 /* Read: Bus Busy */ +#define I2CSTAT_SS 0x20 /* Write: START (1) / STOP (0) */ +#define I2CSTAT_RXTXEN 0x10 /* Rx/Tx enable */ +#define I2CSTAT_ABT 0x08 /* Arbitration bit */ +#define I2CSTAT_NACK 0x01 /* Nack bit */ +#define I2CCON_IRCLR 0x100 /* Interrupt Clear bit */ +#define I2CCON_ACKGEN 0x80 /* Acknowledge generation */ +#define I2CCON_TCP256 0x40 /* Tx-clock prescaler: 16 (0) / 256 (1) */ +#define I2CCON_IRENB 0x20 /* Interrupt Enable bit */ +#define I2CCON_IRPND 0x10 /* Interrupt pending bit */ +#define I2CCON_TCDMSK 0x0F /* I2C-bus transmit clock divider bit mask */ + +#ifdef CONFIG_ARCH_S5P6818 +#define SDADLY_CLKSTEP 5 /* SDA delay: Reg. val. is multiple of 5 clks */ +#define SDADLY_MAX 3 /* SDA delay: Max. reg. value is 3 */ +#define I2CLC_FILTER 0x04 /* SDA filter on */ +#else +#define STOPCON_CLR 0x01 /* Clock Line Release */ +#define STOPCON_DLR 0x02 /* Data Line Release */ +#define STOPCON_NAG 0x04 /* not-ackn. generation and data shift cont. */ +#endif + +#define I2C_TIMEOUT_MS 10 /* 10 ms */ + +#define I2C_M_NOSTOP 0x100 + +#define MAX_I2C_NUM 3 + +#define DEFAULT_SPEED 100000 /* default I2C speed [Hz] */ + +DECLARE_GLOBAL_DATA_PTR; + +struct nx_i2c_regs { + uint iiccon; + uint iicstat; + uint iicadd; + uint iicds; +#ifdef CONFIG_ARCH_S5P6818 + /* S5P6818: Offset 0x10 is Line Control Register (SDA-delay, Filter) */ + uint iiclc; +#else + /* S5P4418: Offset 0x10 is Stop Control Register */ + uint iicstopcon; +#endif +}; + +struct nx_i2c_bus { + uint bus_num; + struct nx_i2c_regs *regs; + uint speed; + uint target_speed; +#ifdef CONFIG_ARCH_S5P6818 + uint sda_delay; +#else + /* setup time for Stop condition [us] */ + uint tsu_stop; +#endif +}; + +/* s5pxx18 i2c must be reset before enabled */ +static void i2c_reset(int ch) +{ + int rst_id = RESET_ID_I2C0 + ch; + + nx_rstcon_setrst(rst_id, 0); + nx_rstcon_setrst(rst_id, 1); +} + +static uint i2c_get_clkrate(struct nx_i2c_bus *bus) +{ + struct clk *clk; + int index = bus->bus_num; + char name[50] = {0, }; + + sprintf(name, "%s.%d", DEV_NAME_I2C, index); + clk = clk_get((const char *)name); + if (!clk) + return -1; + + return clk_get_rate(clk); +} + +static uint i2c_set_clk(struct nx_i2c_bus *bus, uint enb) +{ + struct clk *clk; + char name[50]; + + sprintf(name, "%s.%d", DEV_NAME_I2C, bus->bus_num); + clk = clk_get((const char *)name); + if (!clk) { + debug("%s(): clk_get(%s) error!\n", + __func__, (const char *)name); + return -EINVAL; + } + + clk_disable(clk); + if (enb) + clk_enable(clk); + + return 0; +} + +#ifdef CONFIG_ARCH_S5P6818 +/* Set SDA line delay, not available at S5P4418 */ +static int nx_i2c_set_sda_delay(struct nx_i2c_bus *bus) +{ + struct nx_i2c_regs *i2c = bus->regs; + uint pclk = 0; + uint t_pclk = 0; + uint delay = 0; + + /* get input clock of the I2C-controller */ + pclk = i2c_get_clkrate(bus); + + if (bus->sda_delay) { + /* t_pclk = period time of one pclk [ns] */ + t_pclk = DIV_ROUND_UP(1000, pclk / 1000000); + /* delay = number of pclks required for sda_delay [ns] */ + delay = DIV_ROUND_UP(bus->sda_delay, t_pclk); + /* delay = register value (step of 5 clocks) */ + delay = DIV_ROUND_UP(delay, SDADLY_CLKSTEP); + /* max. possible register value = 3 */ + if (delay > SDADLY_MAX) { + delay = SDADLY_MAX; + debug("%s(): sda-delay des.: %dns, sat. to max.: %dns (granularity: %dns)\n", + __func__, bus->sda_delay, t_pclk * delay * SDADLY_CLKSTEP, + t_pclk * SDADLY_CLKSTEP); + } else { + debug("%s(): sda-delay des.: %dns, act.: %dns (granularity: %dns)\n", + __func__, bus->sda_delay, t_pclk * delay * SDADLY_CLKSTEP, + t_pclk * SDADLY_CLKSTEP); + } + + delay |= I2CLC_FILTER; + } else { + delay = 0; + debug("%s(): sda-delay = 0\n", __func__); + } + + delay &= 0x7; + writel(delay, &i2c->iiclc); + + return 0; +} +#endif + +static int nx_i2c_set_bus_speed(struct udevice *dev, uint speed) +{ + struct nx_i2c_bus *bus = dev_get_priv(dev); + struct nx_i2c_regs *i2c = bus->regs; + unsigned long pclk, pres = 16, div; + + if (i2c_set_clk(bus, 1)) + return -EINVAL; + + /* get input clock of the I2C-controller */ + pclk = i2c_get_clkrate(bus); + + /* calculate prescaler and divisor values */ + if ((pclk / pres / (16 + 1)) > speed) + /* prescaler value 16 is too less --> set to 256 */ + pres = 256; + + div = 0; + /* actual divider = div + 1 */ + while ((pclk / pres / (div + 1)) > speed) + div++; + + if (div > 0xF) { + debug("%s(): pres==%ld, div==0x%lx is saturated to 0xF !)\n", + __func__, pres, div); + div = 0xF; + } else { + debug("%s(): pres==%ld, div==0x%lx)\n", __func__, pres, div); + } + + /* set Tx-clock divisor and prescaler values */ + writel((div & I2CCON_TCDMSK) | ((pres == 256) ? I2CCON_TCP256 : 0), + &i2c->iiccon); + + /* init to SLAVE REVEIVE and set slaveaddr */ + writel(0, &i2c->iicstat); + writel(0x00, &i2c->iicadd); + + /* program Master Transmit (and implicit STOP) */ + writel(I2CSTAT_MTM | I2CSTAT_RXTXEN, &i2c->iicstat); + + /* calculate actual I2C speed [Hz] */ + bus->speed = pclk / ((div + 1) * pres); + debug("%s(): speed des.: %dHz, act.: %dHz\n", + __func__, speed, bus->speed); + +#ifdef CONFIG_ARCH_S5P6818 + nx_i2c_set_sda_delay(bus); +#else + /* setup time for Stop condition [us], min. 4us @ 100kHz I2C-clock */ + bus->tsu_stop = DIV_ROUND_UP(400, bus->speed / 1000); +#endif + + if (i2c_set_clk(bus, 0)) + return -EINVAL; + return 0; +} + +static void i2c_process_node(struct udevice *dev) +{ + struct nx_i2c_bus *bus = dev_get_priv(dev); + + bus->target_speed = dev_read_s32_default(dev, "clock-frequency", + DEFAULT_SPEED); +#ifdef CONFIG_ARCH_S5P6818 + bus->sda_delay = dev_read_s32_default(dev, "i2c-sda-delay-ns", 0); +#endif +} + +static int nx_i2c_probe(struct udevice *dev) +{ + struct nx_i2c_bus *bus = dev_get_priv(dev); + fdt_addr_t addr; + + /* get regs = i2c base address */ + addr = devfdt_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + bus->regs = (struct nx_i2c_regs *)addr; + + bus->bus_num = dev->seq; + + /* i2c node parsing */ + i2c_process_node(dev); + if (!bus->target_speed) + return -ENODEV; + + /* reset */ + i2c_reset(bus->bus_num); + + return 0; +} + +/* i2c bus busy check */ +static int i2c_is_busy(struct nx_i2c_regs *i2c) +{ + ulong start_time; + + start_time = get_timer(0); + while (readl(&i2c->iicstat) & I2CSTAT_BSY) { + if (get_timer(start_time) > I2C_TIMEOUT_MS) { + debug("Timeout\n"); + return -EBUSY; + } + } + return 0; +} + +/* irq enable/disable functions */ +static void i2c_enable_irq(struct nx_i2c_regs *i2c) +{ + unsigned int reg; + + reg = readl(&i2c->iiccon); + reg |= I2CCON_IRENB; + writel(reg, &i2c->iiccon); +} + +/* irq clear function */ +static void i2c_clear_irq(struct nx_i2c_regs *i2c) +{ + unsigned int reg; + + reg = readl(&i2c->iiccon); + /* reset interrupt pending flag */ + reg &= ~(I2CCON_IRPND); + /* + * Interrupt must also be cleared! + * Otherwise linux boot may hang after: + * [ 0.436000] NetLabel: unlabeled traffic allowed by default + * Next would be: + * [ 0.442000] clocksource: Switched to clocksource source timer + */ + reg |= I2CCON_IRCLR; + writel(reg, &i2c->iiccon); +} + +/* ack enable functions */ +static void i2c_enable_ack(struct nx_i2c_regs *i2c) +{ + unsigned int reg; + + reg = readl(&i2c->iiccon); + reg |= I2CCON_ACKGEN; + writel(reg, &i2c->iiccon); +} + +static void i2c_send_stop(struct nx_i2c_bus *bus) +{ + struct nx_i2c_regs *i2c = bus->regs; + + if (IS_ENABLED(CONFIG_ARCH_S5P6818)) { + unsigned int reg; + + reg = readl(&i2c->iicstat); + reg |= I2CSTAT_MRM | I2CSTAT_RXTXEN; + reg &= (~I2CSTAT_SS); + + writel(reg, &i2c->iicstat); + i2c_clear_irq(i2c); + } else { /* S5P4418 */ + writel(STOPCON_NAG, &i2c->iicstopcon); + + i2c_clear_irq(i2c); + + /* + * Clock Line Release --> SDC changes from Low to High and + * SDA from High to Low + */ + writel(STOPCON_CLR, &i2c->iicstopcon); + + /* Hold SDA Low (Setup Time for Stop condition) */ + udelay(bus->tsu_stop); + + i2c_clear_irq(i2c); + + /* Master Receive Mode Stop --> SDA becomes High */ + writel(I2CSTAT_MRM, &i2c->iicstat); + } +} + +static int wait_for_xfer(struct nx_i2c_regs *i2c) +{ + unsigned long start_time = get_timer(0); + + do { + if (readl(&i2c->iiccon) & I2CCON_IRPND) + /* return -EREMOTEIO if not Acknowledged, otherwise 0 */ + return (readl(&i2c->iicstat) & I2CSTAT_NACK) ? + -EREMOTEIO : 0; + } while (get_timer(start_time) < I2C_TIMEOUT_MS); + + return -ETIMEDOUT; +} + +static int i2c_transfer(struct nx_i2c_regs *i2c, + uchar cmd_type, + uchar chip_addr, + uchar addr[], + uchar addr_len, + uchar data[], + unsigned short data_len, + uint seq) +{ + uint status; + int i = 0, result; + + /* Note: data_len = 0 is supported for "probe_chip" */ + + i2c_enable_irq(i2c); + i2c_enable_ack(i2c); + + /* Get the slave chip address going */ + /* Enable Rx/Tx */ + writel(I2CSTAT_RXTXEN, &i2c->iicstat); + + writel(chip_addr, &i2c->iicds); + status = I2CSTAT_RXTXEN | I2CSTAT_SS; + if (cmd_type == I2C_WRITE || (addr && addr_len)) + status |= I2CSTAT_MTM; + else + status |= I2CSTAT_MRM; + + writel(status, &i2c->iicstat); + if (seq) + i2c_clear_irq(i2c); + + /* Wait for chip address to transmit. */ + result = wait_for_xfer(i2c); + if (result) { + debug("%s: transmitting chip address failed\n", __func__); + goto bailout; + } + + /* If register address needs to be transmitted - do it now. */ + if (addr && addr_len) { /* register addr */ + while ((i < addr_len) && !result) { + writel(addr[i++], &i2c->iicds); + i2c_clear_irq(i2c); + result = wait_for_xfer(i2c); + } + + i = 0; + if (result) { + debug("%s: transmitting register address failed\n", + __func__); + goto bailout; + } + } + + switch (cmd_type) { + case I2C_WRITE: + while ((i < data_len) && !result) { + writel(data[i++], &i2c->iicds); + i2c_clear_irq(i2c); + result = wait_for_xfer(i2c); + } + break; + case I2C_READ: + if (addr && addr_len) { + /* + * Register address has been sent, now send slave chip + * address again to start the actual read transaction. + */ + writel(chip_addr, &i2c->iicds); + + /* Generate a re-START. */ + writel(I2CSTAT_MRM | I2CSTAT_RXTXEN | + I2CSTAT_SS, &i2c->iicstat); + i2c_clear_irq(i2c); + result = wait_for_xfer(i2c); + if (result) { + debug("%s: I2C_READ: sending chip addr. failed\n", + __func__); + goto bailout; + } + } + + while ((i < data_len) && !result) { + /* disable ACK for final READ */ + if (i == data_len - 1) + clrbits_le32(&i2c->iiccon, I2CCON_ACKGEN); + + i2c_clear_irq(i2c); + result = wait_for_xfer(i2c); + data[i++] = readb(&i2c->iicds); + } + + if (result == -EREMOTEIO) + /* Not Acknowledged --> normal terminated read. */ + result = 0; + else if (result == -ETIMEDOUT) + debug("%s: I2C_READ: time out\n", __func__); + else + debug("%s: I2C_READ: read not terminated with NACK\n", + __func__); + break; + + default: + debug("%s: bad call\n", __func__); + result = -EINVAL; + break; + } + +bailout: + return result; +} + +static int nx_i2c_read(struct udevice *dev, uchar chip_addr, uint addr, + uint alen, uchar *buffer, uint len, uint seq) +{ + struct nx_i2c_bus *i2c; + uchar xaddr[4]; + int ret; + + i2c = dev_get_priv(dev); + if (!i2c) + return -EFAULT; + + if (alen > 4) { + debug("I2C read: addr len %d not supported\n", alen); + return -EADDRNOTAVAIL; + } + + if (alen > 0) + xaddr[0] = (addr >> 24) & 0xFF; + + if (alen > 0) { + xaddr[0] = (addr >> 24) & 0xFF; + xaddr[1] = (addr >> 16) & 0xFF; + xaddr[2] = (addr >> 8) & 0xFF; + xaddr[3] = addr & 0xFF; + } + + ret = i2c_transfer(i2c->regs, I2C_READ, chip_addr << 1, + &xaddr[4 - alen], alen, buffer, len, seq); + + if (ret) { + debug("I2C read failed %d\n", ret); + return -EIO; + } + + return 0; +} + +static int nx_i2c_write(struct udevice *dev, uchar chip_addr, uint addr, + uint alen, uchar *buffer, uint len, uint seq) +{ + struct nx_i2c_bus *i2c; + uchar xaddr[4]; + int ret; + + i2c = dev_get_priv(dev); + if (!i2c) + return -EFAULT; + + if (alen > 4) { + debug("I2C write: addr len %d not supported\n", alen); + return -EINVAL; + } + + if (alen > 0) { + xaddr[0] = (addr >> 24) & 0xFF; + xaddr[1] = (addr >> 16) & 0xFF; + xaddr[2] = (addr >> 8) & 0xFF; + xaddr[3] = addr & 0xFF; + } + + ret = i2c_transfer(i2c->regs, I2C_WRITE, chip_addr << 1, + &xaddr[4 - alen], alen, buffer, len, seq); + if (ret) { + debug("I2C write failed %d\n", ret); + return -EIO; + } + + return 0; +} + +static int nx_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) +{ + struct nx_i2c_bus *bus = dev_get_priv(dev); + struct nx_i2c_regs *i2c = bus->regs; + int ret; + int i; + + /* The power loss by the clock, only during on/off. */ + ret = i2c_set_clk(bus, 1); + + if (!ret) + /* Bus State(Busy) check */ + ret = i2c_is_busy(i2c); + if (!ret) { + for (i = 0; i < nmsgs; msg++, i++) { + if (msg->flags & I2C_M_RD) { + ret = nx_i2c_read(dev, msg->addr, 0, 0, + msg->buf, msg->len, i); + } else { + ret = nx_i2c_write(dev, msg->addr, 0, 0, + msg->buf, msg->len, i); + } + + if (ret) { + debug("i2c_xfer: error sending\n"); + ret = -EREMOTEIO; + } + } + + i2c_send_stop(bus); + if (i2c_set_clk(bus, 0)) + ret = -EINVAL; + } + + return ret; +}; + +static int nx_i2c_probe_chip(struct udevice *dev, u32 chip_addr, + u32 chip_flags) +{ + int ret; + struct nx_i2c_bus *bus = dev_get_priv(dev); + + ret = i2c_set_clk(bus, 1); + + if (!ret) { + /* + * Send Chip Address only + * --> I2C transfer with data length and address length = 0. + * If there is a Slave, i2c_transfer() returns 0 (acknowledge + * transfer). + * I2C_WRITE must be used in order Master Transmit Mode is + * selected. Otherwise (in Master Receive Mode, I2C_READ) + * sending the stop condition below is not working (SDA does + * not transit to High). + */ + ret = i2c_transfer(bus->regs, I2C_WRITE, (uchar)chip_addr << 1, + NULL, 0, NULL, 0, 0); + + i2c_send_stop(bus); + if (i2c_set_clk(bus, 0)) + ret = -EINVAL; + } + + return ret; +} + +static const struct dm_i2c_ops nx_i2c_ops = { + .xfer = nx_i2c_xfer, + .probe_chip = nx_i2c_probe_chip, + .set_bus_speed = nx_i2c_set_bus_speed, +}; + +static const struct udevice_id nx_i2c_ids[] = { + { .compatible = "nexell,s5pxx18-i2c" }, + { } +}; + +U_BOOT_DRIVER(i2c_nexell) = { + .name = "i2c_nexell", + .id = UCLASS_I2C, + .of_match = nx_i2c_ids, + .probe = nx_i2c_probe, + .priv_auto_alloc_size = sizeof(struct nx_i2c_bus), + .ops = &nx_i2c_ops, +};
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - driver changed to DM. - pinctrl-driver/dt is used now instead of configuring the mmc I/O-pins in the mmc-driver. - nexell_dwmmc_ofdata_to_platdata() reworked, i.e. valid default values are used now (where possible) and the appropriate if-blocks have been removed. - new dt-property "mmcboost" is used now instead of "CONFIG_BOOST_MMC" which was not defined anywhere.
(no changes since v3)
Changes in v3: - nexell_dw_mmc_dm.c renamed (back) to nexell_dw_mmc.c - pinctrl-driver/dt is used now instead of configuring the mmc I/O-pins in the mmc-driver. - nexell_dwmmc_ofdata_to_platdata() reworked, i.e. valid default values are used now (where possible) and the appropriate if-blocks have been removed. - "nexell," removed from dt-properties, e.g. "nexell,bus-width" changed to "bus-width". - new dt-property "mmcboost" is used now instead of "CONFIG_BOOST_MMC" which was not defined anywhere. - Boot error "Loading Environment from MMC... *** Warning - No block device, using default environment" after updating local repository. Bugfix in drivers/mmc/nexell_dw_mmc.c: "#include <clk.h>" changed to "#include <asm/arch/clk.h>". This Bug showed up now because of the commit "dm: clk: add stub when CONFIG_CLK is deactivated" where include/clk.h has been changed. - drivers/mmc/nexell_dw_mmc.c: '#include <log.h>' inserted because it has been removed from common.h.
drivers/mmc/Kconfig | 8 ++ drivers/mmc/Makefile | 1 + drivers/mmc/nexell_dw_mmc.c | 237 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 246 insertions(+) create mode 100644 drivers/mmc/nexell_dw_mmc.c
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 3c4f057..5fc47c8 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -264,6 +264,14 @@ config MMC_DW_SNPS This selects support for Synopsys DesignWare Memory Card Interface driver extensions used in various Synopsys ARC devboards.
+config NEXELL_DWMMC + bool "Nexell SD/MMC controller support" + depends on ARCH_NEXELL + depends on MMC_DW + depends on DM_MMC + depends on PINCTRL_NEXELL + default y + config MMC_MESON_GX bool "Meson GX EMMC controller support" depends on DM_MMC && BLK && ARCH_MESON diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index e84c792..d375669 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -44,6 +44,7 @@ obj-$(CONFIG_SH_MMCIF) += sh_mmcif.o obj-$(CONFIG_SH_SDHI) += sh_sdhi.o obj-$(CONFIG_STM32_SDMMC2) += stm32_sdmmc2.o obj-$(CONFIG_JZ47XX_MMC) += jz_mmc.o +obj-$(CONFIG_NEXELL_DWMMC) += nexell_dw_mmc.o
# SDHCI obj-$(CONFIG_MMC_SDHCI) += sdhci.o diff --git a/drivers/mmc/nexell_dw_mmc.c b/drivers/mmc/nexell_dw_mmc.c new file mode 100644 index 0000000..0462759 --- /dev/null +++ b/drivers/mmc/nexell_dw_mmc.c @@ -0,0 +1,237 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * Youngbok, Park park@nexell.co.kr + * + * (C) Copyright 2019 Stefan Bosch stefan_b@posteo.net + */ + +#include <common.h> +#include <dm.h> +#include <dt-structs.h> +#include <dwmmc.h> +#include <log.h> +#include <syscon.h> +#include <asm/arch/reset.h> +#include <asm/arch/clk.h> + +#define DWMCI_CLKSEL 0x09C +#define DWMCI_SHIFT_0 0x0 +#define DWMCI_SHIFT_1 0x1 +#define DWMCI_SHIFT_2 0x2 +#define DWMCI_SHIFT_3 0x3 +#define DWMCI_SET_SAMPLE_CLK(x) (x) +#define DWMCI_SET_DRV_CLK(x) ((x) << 16) +#define DWMCI_SET_DIV_RATIO(x) ((x) << 24) +#define DWMCI_CLKCTRL 0x114 +#define NX_MMC_CLK_DELAY(x, y, a, b) ((((x) & 0xFF) << 0) |\ + (((y) & 0x03) << 16) |\ + (((a) & 0xFF) << 8) |\ + (((b) & 0x03) << 24)) + +struct nexell_mmc_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + +struct nexell_dwmmc_priv { + struct clk *clk; + struct dwmci_host host; + int fifo_size; + bool fifo_mode; + int frequency; + u32 min_freq; + u32 max_freq; + int d_delay; + int d_shift; + int s_delay; + int s_shift; + bool mmcboost; +}; + +struct clk *clk_get(const char *id); + +static void nx_dw_mmc_clksel(struct dwmci_host *host) +{ + /* host->priv is pointer to "struct udevice" */ + struct nexell_dwmmc_priv *priv = dev_get_priv(host->priv); + u32 val; + + if (priv->mmcboost) + val = DWMCI_SET_SAMPLE_CLK(DWMCI_SHIFT_0) | + DWMCI_SET_DRV_CLK(DWMCI_SHIFT_0) | DWMCI_SET_DIV_RATIO(1); + else + val = DWMCI_SET_SAMPLE_CLK(DWMCI_SHIFT_0) | + DWMCI_SET_DRV_CLK(DWMCI_SHIFT_0) | DWMCI_SET_DIV_RATIO(3); + + dwmci_writel(host, DWMCI_CLKSEL, val); +} + +static void nx_dw_mmc_reset(int ch) +{ + int rst_id = RESET_ID_SDMMC0 + ch; + + nx_rstcon_setrst(rst_id, 0); + nx_rstcon_setrst(rst_id, 1); +} + +static void nx_dw_mmc_clk_delay(struct udevice *dev) +{ + unsigned int delay; + struct nexell_dwmmc_priv *priv = dev_get_priv(dev); + struct dwmci_host *host = &priv->host; + + delay = NX_MMC_CLK_DELAY(priv->d_delay, + priv->d_shift, priv->s_delay, priv->s_shift); + + writel(delay, (host->ioaddr + DWMCI_CLKCTRL)); + debug("%s: Values set: d_delay==%d, d_shift==%d, s_delay==%d, " + "s_shift==%d\n", __func__, priv->d_delay, priv->d_shift, + priv->s_delay, priv->s_shift); +} + +static unsigned int nx_dw_mmc_get_clk(struct dwmci_host *host, uint freq) +{ + struct clk *clk; + struct udevice *dev = host->priv; + struct nexell_dwmmc_priv *priv = dev_get_priv(dev); + + int index = host->dev_index; + char name[50] = { 0, }; + + clk = priv->clk; + if (!clk) { + sprintf(name, "%s.%d", DEV_NAME_SDHC, index); + clk = clk_get((const char *)name); + if (!clk) + return 0; + priv->clk = clk; + } + + return clk_get_rate(clk) / 2; +} + +static unsigned long nx_dw_mmc_set_clk(struct dwmci_host *host, + unsigned int rate) +{ + struct clk *clk; + char name[50] = { 0, }; + struct udevice *dev = host->priv; + struct nexell_dwmmc_priv *priv = dev_get_priv(dev); + + int index = host->dev_index; + + clk = priv->clk; + if (!clk) { + sprintf(name, "%s.%d", DEV_NAME_SDHC, index); + clk = clk_get((const char *)name); + if (!clk) { + debug("%s: clk_get("%s") failed!\n", __func__, name); + return 0; + } + priv->clk = clk; + } + + clk_disable(clk); + rate = clk_set_rate(clk, rate); + clk_enable(clk); + + return rate; +} + +static int nexell_dwmmc_ofdata_to_platdata(struct udevice *dev) +{ + struct nexell_dwmmc_priv *priv = dev_get_priv(dev); + struct dwmci_host *host = &priv->host; + int val = -1; + + debug("%s\n", __func__); + + host->name = dev->name; + host->ioaddr = dev_read_addr_ptr(dev); + host->buswidth = dev_read_u32_default(dev, "bus-width", 4); + host->get_mmc_clk = nx_dw_mmc_get_clk; + host->clksel = nx_dw_mmc_clksel; + host->priv = dev; + + val = dev_read_u32_default(dev, "index", -1); + if (val < 0 || val > 2) { + debug(" 'index' missing/invalid!\n"); + return -EINVAL; + } + host->dev_index = val; + + priv->fifo_size = dev_read_u32_default(dev, "fifo-size", 0x20); + priv->fifo_mode = dev_read_bool(dev, "fifo-mode"); + priv->frequency = dev_read_u32_default(dev, "frequency", 50000000); + priv->max_freq = dev_read_u32_default(dev, "max-frequency", 50000000); + priv->min_freq = 400000; /* 400 kHz */ + priv->d_delay = dev_read_u32_default(dev, "drive_dly", 0); + priv->d_shift = dev_read_u32_default(dev, "drive_shift", 3); + priv->s_delay = dev_read_u32_default(dev, "sample_dly", 0); + priv->s_shift = dev_read_u32_default(dev, "sample_shift", 2); + priv->mmcboost = dev_read_u32_default(dev, "mmcboost", 0); + + debug(" index==%d, name==%s, ioaddr==0x%08x\n", + host->dev_index, host->name, (u32)host->ioaddr); + return 0; +} + +static int nexell_dwmmc_probe(struct udevice *dev) +{ + struct nexell_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct nexell_dwmmc_priv *priv = dev_get_priv(dev); + struct dwmci_host *host = &priv->host; + struct udevice *pwr_dev __maybe_unused; + + host->fifoth_val = MSIZE(0x2) | + RX_WMARK(priv->fifo_size / 2 - 1) | + TX_WMARK(priv->fifo_size / 2); + + host->fifo_mode = priv->fifo_mode; + + dwmci_setup_cfg(&plat->cfg, host, priv->max_freq, priv->min_freq); + host->mmc = &plat->mmc; + host->mmc->priv = &priv->host; + host->mmc->dev = dev; + upriv->mmc = host->mmc; + + if (nx_dw_mmc_set_clk(host, priv->frequency * 4) != + priv->frequency * 4) { + debug("%s: nx_dw_mmc_set_clk(host, %d) failed!\n", + __func__, priv->frequency * 4); + return -EIO; + } + debug("%s: nx_dw_mmc_set_clk(host, %d) OK\n", + __func__, priv->frequency * 4); + + nx_dw_mmc_reset(host->dev_index); + nx_dw_mmc_clk_delay(dev); + + return dwmci_probe(dev); +} + +static int nexell_dwmmc_bind(struct udevice *dev) +{ + struct nexell_mmc_plat *plat = dev_get_platdata(dev); + + return dwmci_bind(dev, &plat->mmc, &plat->cfg); +} + +static const struct udevice_id nexell_dwmmc_ids[] = { + { .compatible = "nexell,nexell-dwmmc" }, + { } +}; + +U_BOOT_DRIVER(nexell_dwmmc_drv) = { + .name = "nexell_dwmmc", + .id = UCLASS_MMC, + .of_match = nexell_dwmmc_ids, + .ofdata_to_platdata = nexell_dwmmc_ofdata_to_platdata, + .ops = &dm_dwmci_ops, + .bind = nexell_dwmmc_bind, + .probe = nexell_dwmmc_probe, + .priv_auto_alloc_size = sizeof(struct nexell_dwmmc_priv), + .platdata_auto_alloc_size = sizeof(struct nexell_mmc_plat), +};
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - livetree API (dev_read_...) is used instead of fdt one (fdt...). - doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt added.
Changes in v3: - Kconfig: Missing helps added. - Changed to livetree API as proposed by patman: fdt_stringlist_count() --> dev_read_string_count() fdt_stringlist_get() --> dev_read_string_index() fdtdec_get_int() --> dev_read_s32_default() - doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt added.
.../pinctrl/nexell,s5pxx18-pinctrl.txt | 78 ++++++++ drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/nexell/Kconfig | 18 ++ drivers/pinctrl/nexell/Makefile | 7 + drivers/pinctrl/nexell/pinctrl-nexell.c | 66 +++++++ drivers/pinctrl/nexell/pinctrl-nexell.h | 68 +++++++ drivers/pinctrl/nexell/pinctrl-s5pxx18.c | 220 +++++++++++++++++++++ drivers/pinctrl/nexell/pinctrl-s5pxx18.h | 53 +++++ 9 files changed, 512 insertions(+) create mode 100644 doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt create mode 100644 drivers/pinctrl/nexell/Kconfig create mode 100644 drivers/pinctrl/nexell/Makefile create mode 100644 drivers/pinctrl/nexell/pinctrl-nexell.c create mode 100644 drivers/pinctrl/nexell/pinctrl-nexell.h create mode 100644 drivers/pinctrl/nexell/pinctrl-s5pxx18.c create mode 100644 drivers/pinctrl/nexell/pinctrl-s5pxx18.h
diff --git a/doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt b/doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt new file mode 100644 index 0000000..115ab53 --- /dev/null +++ b/doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt @@ -0,0 +1,78 @@ +Binding for Nexell s5pxx18 pin cotroller +======================================== + +Nexell's ARM bases SoC's integrates a GPIO and Pin mux/config hardware +controller. It controls the input/output settings on the available pads/pins +and also provides ability to multiplex and configure the output of various +on-chip controllers onto these pads. + +Please refer to pinctrl-bindings.txt in this directory for details of the +common pinctrl bindings used by client devices, including the meaning of the +phrase "pin configuration node". + + +Required properties: + - compatible: "nexell,s5pxx18-pinctrl" + - reg: should be register base and length as documented in the datasheet + - interrupts: interrupt specifier for the controller over gpio and alive pins + +Example: +pinctrl_0: pinctrl@c0010000 { + compatible = "nexell,s5pxx18-pinctrl"; + reg = <0xc0010000 0xf000>; + u-boot,dm-pre-reloc; +}; + +Nexell's pin configuration nodes act as a container for an arbitrary number of +subnodes. Each of these subnodes represents some desired configuration for a +pin, a group, or a list of pins or groups. This configuration can include the +mux function to select on those pin(s)/group(s), and various pin configuration +parameters. + + Child nodes must be set at least one of the following settings: + - pins = Select pins for using this function. + - pin-function = Select the function for use in a selected pin. + - pin-pull = Pull up/down configuration. + - pin-strength = Drive strength configuration. + + Valid values for nexell,pins are: + "gpioX-N" : X in {A,B,C,D,E}, N in {0-31} + Valid values for nexell,pin-function are: + "N" : N in {0-3}. + This setting means that the value is different for each pin. + Please refer to datasheet. + Valid values for nexell,pin-pull are: + "N" : 0 - Down, 1 - Up, 2 - Off + Valid values for nexell,pin-strength are: + "N" : 0,1,2,3 + + +Example: + - pin settings + mmc0_clk: mmc0-clk { + pins = "gpioa-29"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <2>; + }; + + mmc0_cmd: mmc0-cmd { + pins = "gpioa-31"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <1>; + }; + + mmc0_bus4: mmc0-bus-width4 { + pins = "gpiob-1, gpiob-3, gpiob-5, gpiob-7"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <1>; + }; + + - used by client devices + mmc0:mmc@... { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_clk>, <&mmc0_cmd>, <&mmc0_bus4>; + ... + }; diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 83e39b9..bd2061b 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -294,6 +294,7 @@ source "drivers/pinctrl/meson/Kconfig" source "drivers/pinctrl/mscc/Kconfig" source "drivers/pinctrl/mtmips/Kconfig" source "drivers/pinctrl/mvebu/Kconfig" +source "drivers/pinctrl/nexell/Kconfig" source "drivers/pinctrl/nxp/Kconfig" source "drivers/pinctrl/renesas/Kconfig" source "drivers/pinctrl/rockchip/Kconfig" diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 4f662c4..92cff1b 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -21,6 +21,7 @@ obj-$(CONFIG_PINCTRL_MESON) += meson/ obj-$(CONFIG_PINCTRL_MTK) += mediatek/ obj-$(CONFIG_PINCTRL_MSCC) += mscc/ obj-$(CONFIG_ARCH_MVEBU) += mvebu/ +obj-$(CONFIG_ARCH_NEXELL) += nexell/ obj-$(CONFIG_PINCTRL_SINGLE) += pinctrl-single.o obj-$(CONFIG_PINCTRL_STI) += pinctrl-sti.o obj-$(CONFIG_PINCTRL_STM32) += pinctrl_stm32.o diff --git a/drivers/pinctrl/nexell/Kconfig b/drivers/pinctrl/nexell/Kconfig new file mode 100644 index 0000000..8f1e472 --- /dev/null +++ b/drivers/pinctrl/nexell/Kconfig @@ -0,0 +1,18 @@ +if ARCH_NEXELL + +config PINCTRL_NEXELL + bool "Nexell pinctrl driver" + help + Support of pin multiplexing and pin configuration for Nexell + SoCs. + +config PINCTRL_NEXELL_S5PXX18 + bool "Nexell s5pxx18 SoC pinctrl driver" + default y if ARCH_S5P4418 || ARCH_S5P6818 + depends on ARCH_NEXELL && PINCTRL_FULL + select PINCTRL_NEXELL + help + Support of pin multiplexing and pin configuration for S5P4418 + and S5P6818 SoC. + +endif diff --git a/drivers/pinctrl/nexell/Makefile b/drivers/pinctrl/nexell/Makefile new file mode 100644 index 0000000..74df414 --- /dev/null +++ b/drivers/pinctrl/nexell/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 Nexell +# Bongyu, KOO freestyle@nexell.co.kr + +obj-$(CONFIG_PINCTRL_NEXELL) += pinctrl-nexell.o +obj-$(CONFIG_PINCTRL_NEXELL_S5PXX18) += pinctrl-s5pxx18.o diff --git a/drivers/pinctrl/nexell/pinctrl-nexell.c b/drivers/pinctrl/nexell/pinctrl-nexell.c new file mode 100644 index 0000000..4518c05 --- /dev/null +++ b/drivers/pinctrl/nexell/pinctrl-nexell.c @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Pinctrl driver for Nexell SoCs + * (C) Copyright 2016 Nexell + * Bongyu, KOO freestyle@nexell.co.kr + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include "pinctrl-nexell.h" +#include "pinctrl-s5pxx18.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* given a pin-name, return the address of pin config registers */ +unsigned long pin_to_bank_base(struct udevice *dev, const char *pin_name, + u32 *pin) +{ + struct nexell_pinctrl_priv *priv = dev_get_priv(dev); + const struct nexell_pin_ctrl *pin_ctrl = priv->pin_ctrl; + const struct nexell_pin_bank_data *bank_data = pin_ctrl->pin_banks; + u32 nr_banks = pin_ctrl->nr_banks, idx = 0; + char bank[10]; + + /* + * The format of the pin name is <bank name>-<pin_number>. + * Example: gpioa-4 (gpioa is the bank name and 4 is the pin number) + */ + while (pin_name[idx] != '-') { + bank[idx] = pin_name[idx]; + idx++; + } + bank[idx] = '\0'; + *pin = (u32)simple_strtoul(&pin_name[++idx], NULL, 10); + + /* lookup the pin bank data using the pin bank name */ + for (idx = 0; idx < nr_banks; idx++) + if (!strcmp(bank, bank_data[idx].name)) + break; + + return priv->base + bank_data[idx].offset; +} + +int nexell_pinctrl_probe(struct udevice *dev) +{ + struct nexell_pinctrl_priv *priv; + fdt_addr_t base; + + priv = dev_get_priv(dev); + if (!priv) + return -EINVAL; + + base = devfdt_get_addr(dev); + if (base == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->base = base; + + priv->pin_ctrl = (struct nexell_pin_ctrl *)dev_get_driver_data(dev); + + s5pxx18_pinctrl_init(dev); + + return 0; +} diff --git a/drivers/pinctrl/nexell/pinctrl-nexell.h b/drivers/pinctrl/nexell/pinctrl-nexell.h new file mode 100644 index 0000000..b21eefc --- /dev/null +++ b/drivers/pinctrl/nexell/pinctrl-nexell.h @@ -0,0 +1,68 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Pinctrl driver for Nexell SoCs + * (C) Copyright 2016 Nexell + * Bongyu, KOO freestyle@nexell.co.kr + * + */ + +#ifndef __PINCTRL_NEXELL_H_ +#define __PINCTRL_NEXELL_H_ + +/** + * struct nexell_pin_bank_data: represent a controller pin-bank data. + * @offset: starting offset of the pin-bank registers. + * @nr_pins: number of pins included in this bank. + * @name: name to be prefixed for each pin in this pin bank. + */ +struct nexell_pin_bank_data { + u32 offset; + u8 nr_pins; + const char *name; + u8 type; +}; + +#define NEXELL_PIN_BANK(pins, reg, id) \ + { \ + .offset = reg, \ + .nr_pins = pins, \ + .name = id \ + } + +/** + * struct nexell_pin_ctrl: represent a pin controller. + * @pin_banks: list of pin banks included in this controller. + * @nr_banks: number of pin banks. + */ +struct nexell_pin_ctrl { + const struct nexell_pin_bank_data *pin_banks; + u32 nr_banks; +}; + +/** + * struct nexell_pinctrl_priv: nexell pin controller driver private data + * @pin_ctrl: pin controller bank information. + * @base: base address of the pin controller instance. + */ +struct nexell_pinctrl_priv { + const struct nexell_pin_ctrl *pin_ctrl; + unsigned long base; +}; + +/** + * struct nexell_pinctrl_config_data: configuration for a peripheral. + * @offset: offset of the config registers in the controller. + * @mask: value of the register to be masked with. + * @value: new value to be programmed. + */ +struct nexell_pinctrl_config_data { + const unsigned int offset; + const unsigned int mask; + const unsigned int value; +}; + +unsigned long pin_to_bank_base(struct udevice *dev, const char *pin_name, + u32 *pin); +int nexell_pinctrl_probe(struct udevice *dev); + +#endif /* __PINCTRL_NEXELL_H_ */ diff --git a/drivers/pinctrl/nexell/pinctrl-s5pxx18.c b/drivers/pinctrl/nexell/pinctrl-s5pxx18.c new file mode 100644 index 0000000..96a2ed3 --- /dev/null +++ b/drivers/pinctrl/nexell/pinctrl-s5pxx18.c @@ -0,0 +1,220 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Pinctrl driver for Nexell SoCs + * (C) Copyright 2016 Nexell + * Bongyu, KOO freestyle@nexell.co.kr + * + * (C) Copyright 2019 Stefan Bosch stefan_b@posteo.net + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include <dm/pinctrl.h> +#include <dm/root.h> +#include "pinctrl-nexell.h" +#include "pinctrl-s5pxx18.h" + +DECLARE_GLOBAL_DATA_PTR; + +static void nx_gpio_set_bit(u32 *value, u32 bit, int enable) +{ + register u32 newvalue; + + newvalue = *value; + newvalue &= ~(1ul << bit); + newvalue |= (u32)enable << bit; + writel(newvalue, value); +} + +static void nx_gpio_set_bit2(u32 *value, u32 bit, u32 bit_value) +{ + register u32 newvalue = *value; + + newvalue = (u32)(newvalue & ~(3ul << (bit * 2))); + newvalue = (u32)(newvalue | (bit_value << (bit * 2))); + + writel(newvalue, value); +} + +static int nx_gpio_open_module(void *base) +{ + writel(0xFFFFFFFF, base + GPIOX_SLEW_DISABLE_DEFAULT); + writel(0xFFFFFFFF, base + GPIOX_DRV1_DISABLE_DEFAULT); + writel(0xFFFFFFFF, base + GPIOX_DRV0_DISABLE_DEFAULT); + writel(0xFFFFFFFF, base + GPIOX_PULLSEL_DISABLE_DEFAULT); + writel(0xFFFFFFFF, base + GPIOX_PULLENB_DISABLE_DEFAULT); + return true; +} + +static void nx_gpio_set_pad_function(void *base, u32 pin, u32 padfunc) +{ + u32 reg = (pin / 16) ? GPIOX_ALTFN1 : GPIOX_ALTFN0; + + nx_gpio_set_bit2(base + reg, pin % 16, padfunc); +} + +static void nx_gpio_set_drive_strength(void *base, u32 pin, u32 drv) +{ + nx_gpio_set_bit(base + GPIOX_DRV1, pin, (int)(((u32)drv >> 0) & 0x1)); + nx_gpio_set_bit(base + GPIOX_DRV0, pin, (int)(((u32)drv >> 1) & 0x1)); +} + +static void nx_gpio_set_pull_mode(void *base, u32 pin, u32 mode) +{ + if (mode == nx_gpio_pull_off) { + nx_gpio_set_bit(base + GPIOX_PULLENB, pin, false); + nx_gpio_set_bit(base + GPIOX_PULLSEL, pin, false); + } else { + nx_gpio_set_bit(base + GPIOX_PULLSEL, + pin, (mode & 1 ? true : false)); + nx_gpio_set_bit(base + GPIOX_PULLENB, pin, true); + } +} + +static void nx_alive_set_pullup(void *base, u32 pin, bool enable) +{ + u32 PULLUP_MASK; + + PULLUP_MASK = (1UL << pin); + if (enable) + writel(PULLUP_MASK, base + ALIVE_PADPULLUPSET); + else + writel(PULLUP_MASK, base + ALIVE_PADPULLUPRST); +} + +static int s5pxx18_pinctrl_gpio_init(struct udevice *dev) +{ + struct nexell_pinctrl_priv *priv = dev_get_priv(dev); + const struct nexell_pin_ctrl *ctrl = priv->pin_ctrl; + unsigned long reg = priv->base; + int i; + + for (i = 0; i < ctrl->nr_banks - 1; i++) /* except alive bank */ + nx_gpio_open_module((void *)(reg + ctrl->pin_banks[i].offset)); + + return 0; +} + +static int s5pxx18_pinctrl_alive_init(struct udevice *dev) +{ + struct nexell_pinctrl_priv *priv = dev_get_priv(dev); + const struct nexell_pin_ctrl *ctrl = priv->pin_ctrl; + unsigned long reg = priv->base; + + reg += ctrl->pin_banks[ctrl->nr_banks - 1].offset; + + writel(1, reg + ALIVE_PWRGATE); + return 0; +} + +int s5pxx18_pinctrl_init(struct udevice *dev) +{ + s5pxx18_pinctrl_gpio_init(dev); + s5pxx18_pinctrl_alive_init(dev); + + return 0; +} + +static int is_pin_alive(const char *name) +{ + return !strncmp(name, "alive", 5); +} + +/** + * s5pxx18_pinctrl_set_state: configure a pin state. + * dev: the pinctrl device to be configured. + * config: the state to be configured. + */ +static int s5pxx18_pinctrl_set_state(struct udevice *dev, + struct udevice *config) +{ + unsigned int count, idx, pin; + unsigned int pinfunc, pinpud, pindrv; + unsigned long reg; + const char *name; + int ret; + + /* + * refer to the following document for the pinctrl bindings + * doc/device-tree-bindings/pinctrl/nexell,s5pxx18-pinctrl.txt + */ + count = dev_read_string_count(config, "pins"); + + if (count <= 0) + return -EINVAL; + + pinfunc = dev_read_s32_default(config, "pin-function", -1); + pinpud = dev_read_s32_default(config, "pin-pull", -1); + pindrv = dev_read_s32_default(config, "pin-strength", -1); + + for (idx = 0; idx < count; idx++) { + ret = dev_read_string_index(config, "pins", idx, &name); + if (ret) + return ret; + if (!name) + continue; + reg = pin_to_bank_base(dev, name, &pin); + + if (is_pin_alive(name)) { + /* pin pull up/down */ + if (pinpud != -1) + nx_alive_set_pullup((void *)reg, pin, + pinpud & 1); + continue; + } + + /* pin function */ + if (pinfunc != -1) + nx_gpio_set_pad_function((void *)reg, pin, pinfunc); + + /* pin pull up/down/off */ + if (pinpud != -1) + nx_gpio_set_pull_mode((void *)reg, pin, pinpud); + + /* pin drive strength */ + if (pindrv != -1) + nx_gpio_set_drive_strength((void *)reg, pin, pindrv); + } + + return 0; +} + +static struct pinctrl_ops s5pxx18_pinctrl_ops = { + .set_state = s5pxx18_pinctrl_set_state, +}; + +/* pin banks of s5pxx18 pin-controller */ +static const struct nexell_pin_bank_data s5pxx18_pin_banks[] = { + NEXELL_PIN_BANK(32, 0xA000, "gpioa"), + NEXELL_PIN_BANK(32, 0xB000, "gpiob"), + NEXELL_PIN_BANK(32, 0xC000, "gpioc"), + NEXELL_PIN_BANK(32, 0xD000, "gpiod"), + NEXELL_PIN_BANK(32, 0xE000, "gpioe"), + NEXELL_PIN_BANK(6, 0x0800, "alive"), +}; + +const struct nexell_pin_ctrl s5pxx18_pin_ctrl[] = { + { + /* pin-controller data */ + .pin_banks = s5pxx18_pin_banks, + .nr_banks = ARRAY_SIZE(s5pxx18_pin_banks), + }, +}; + +static const struct udevice_id s5pxx18_pinctrl_ids[] = { + { .compatible = "nexell,s5pxx18-pinctrl", + .data = (ulong)s5pxx18_pin_ctrl }, + { } +}; + +U_BOOT_DRIVER(pinctrl_s5pxx18) = { + .name = "pinctrl_s5pxx18", + .id = UCLASS_PINCTRL, + .of_match = s5pxx18_pinctrl_ids, + .priv_auto_alloc_size = sizeof(struct nexell_pinctrl_priv), + .ops = &s5pxx18_pinctrl_ops, + .probe = nexell_pinctrl_probe, + .flags = DM_FLAG_PRE_RELOC +}; diff --git a/drivers/pinctrl/nexell/pinctrl-s5pxx18.h b/drivers/pinctrl/nexell/pinctrl-s5pxx18.h new file mode 100644 index 0000000..843a00b --- /dev/null +++ b/drivers/pinctrl/nexell/pinctrl-s5pxx18.h @@ -0,0 +1,53 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Pinctrl driver for Nexell SoCs + * (C) Copyright 2016 Nexell + * Bongyu, KOO freestyle@nexell.co.kr + */ + +#ifndef __PINCTRL_S5PXX18_H_ +#define __PINCTRL_S5PXX18_H_ + +#include <linux/types.h> +#include <asm/io.h> + +#define GPIOX_ALTFN0 0x20 +#define GPIOX_ALTFN1 0x24 +#define GPIOX_DRV1 0x48 +#define GPIOX_DRV0 0x50 +#define GPIOX_PULLSEL 0x58 +#define GPIOX_PULLENB 0x60 + +#define GPIOX_SLEW_DISABLE_DEFAULT 0x44 +#define GPIOX_DRV1_DISABLE_DEFAULT 0x4C +#define GPIOX_DRV0_DISABLE_DEFAULT 0x54 +#define GPIOX_PULLSEL_DISABLE_DEFAULT 0x5C +#define GPIOX_PULLENB_DISABLE_DEFAULT 0x64 + +#define ALIVE_PWRGATE 0x0 +#define ALIVE_PADPULLUPRST 0x80 +#define ALIVE_PADPULLUPSET 0x84 +#define ALIVE_PADPULLUPREAD 0x88 + +enum { + nx_gpio_padfunc_0 = 0ul, + nx_gpio_padfunc_1 = 1ul, + nx_gpio_padfunc_2 = 2ul, + nx_gpio_padfunc_3 = 3ul +}; + +enum { + nx_gpio_drvstrength_0 = 0ul, + nx_gpio_drvstrength_1 = 1ul, + nx_gpio_drvstrength_2 = 2ul, + nx_gpio_drvstrength_3 = 3ul +}; + +enum { + nx_gpio_pull_down = 0ul, + nx_gpio_pull_up = 1ul, + nx_gpio_pull_off = 2ul +}; + +int s5pxx18_pinctrl_init(struct udevice *dev); +#endif /* __PINCTRL_S5PXX18_H_ */
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - Since drivers/pwm/pwm-nexell.c is an adapted version of s5p-common/pwm.c an appropriately changed version of s5p-common/pwm.c is used instead. Therefore arch/arm/mach-s5pc1xx/include/mach/pwm.h copied to arch/arm/mach-nexell/include/mach and s5p-common/Makefile changed appropriately. - '#ifdef CONFIG...' changed to 'if (IS_ENABLED(CONFIG...))' where possible (and similar).
Changes in v3: - Handling of Configs for LCD backlight control reworked because (among others) not setting CONFIG_S5P4418_ONEWIRE and/or CONFIG_PWM_NX has caused errors when compiling board/friendlyarm/nanopi2/onewire.c. - pwm.h: () around macro argument x added to avoid precedence issues. - '#ifdef...' changed to 'if (IS_ENABLED(CONFIG...))' where possible because of appropriate warnings of patman.
Changes in v2: - commit "i2c: mmc: add nexell driver (gpio, i2c, mmc, pwm)" splitted into separate commits for gpio, i2c, mmc, pwm. - Since drivers/pwm/pwm-nexell.c is an adapted version of s5p-common/pwm.c an appropriately changed version of s5p-common/pwm.c is used now. Therefore arch/arm/mach-s5pc1xx/include/mach/pwm.h copied to arch/arm/mach-nexell/include/mach and s5p-common/Makefile changed appropriately.
arch/arm/cpu/armv7/s5p-common/Makefile | 13 +++++--- arch/arm/cpu/armv7/s5p-common/pwm.c | 57 ++++++++++++++++++++++++++++++++- arch/arm/mach-nexell/include/mach/pwm.h | 54 +++++++++++++++++++++++++++++++ 3 files changed, 119 insertions(+), 5 deletions(-) create mode 100644 arch/arm/mach-nexell/include/mach/pwm.h
diff --git a/arch/arm/cpu/armv7/s5p-common/Makefile b/arch/arm/cpu/armv7/s5p-common/Makefile index 12cf804..bfe0238 100644 --- a/arch/arm/cpu/armv7/s5p-common/Makefile +++ b/arch/arm/cpu/armv7/s5p-common/Makefile @@ -3,9 +3,14 @@ # Copyright (C) 2009 Samsung Electronics # Minkyu Kang mk7.kang@samsung.com
-obj-y += cpu_info.o +ifdef CONFIG_ARCH_NEXELL +obj-$(CONFIG_PWM_NX) += pwm.o +obj-$(CONFIG_S5P4418_ONEWIRE) += pwm.o +else +obj-y += cpu_info.o ifndef CONFIG_SPL_BUILD -obj-y += timer.o -obj-y += sromc.o -obj-$(CONFIG_PWM) += pwm.o +obj-y += timer.o +obj-y += sromc.o +obj-$(CONFIG_PWM) += pwm.o +endif endif diff --git a/arch/arm/cpu/armv7/s5p-common/pwm.c b/arch/arm/cpu/armv7/s5p-common/pwm.c index 6b9e865..aef2e55 100644 --- a/arch/arm/cpu/armv7/s5p-common/pwm.c +++ b/arch/arm/cpu/armv7/s5p-common/pwm.c @@ -15,7 +15,11 @@ int pwm_enable(int pwm_id) { const struct s5p_timer *pwm = +#if defined(CONFIG_ARCH_NEXELL) + (struct s5p_timer *)PHY_BASEADDR_PWM; +#else (struct s5p_timer *)samsung_get_base_timer(); +#endif unsigned long tcon;
tcon = readl(&pwm->tcon); @@ -29,7 +33,11 @@ int pwm_enable(int pwm_id) void pwm_disable(int pwm_id) { const struct s5p_timer *pwm = +#if defined(CONFIG_ARCH_NEXELL) + (struct s5p_timer *)PHY_BASEADDR_PWM; +#else (struct s5p_timer *)samsung_get_base_timer(); +#endif unsigned long tcon;
tcon = readl(&pwm->tcon); @@ -43,14 +51,43 @@ static unsigned long pwm_calc_tin(int pwm_id, unsigned long freq) unsigned long tin_parent_rate; unsigned int div;
+#if defined(CONFIG_ARCH_NEXELL) + unsigned int pre_div; + const struct s5p_timer *pwm = + (struct s5p_timer *)PHY_BASEADDR_PWM; + unsigned int val; + struct clk *clk = clk_get(CORECLK_NAME_PCLK); + + tin_parent_rate = clk_get_rate(clk); +#else tin_parent_rate = get_pwm_clk(); +#endif + +#if defined(CONFIG_ARCH_NEXELL) + writel(0, &pwm->tcfg0); + val = readl(&pwm->tcfg0); + + if (pwm_id < 2) + div = ((val >> 0) & 0xff) + 1; + else + div = ((val >> 8) & 0xff) + 1;
+ writel(0, &pwm->tcfg1); + val = readl(&pwm->tcfg1); + val = (val >> MUX_DIV_SHIFT(pwm_id)) & 0xF; + pre_div = (1UL << val); + + freq = tin_parent_rate / div / pre_div; + + return freq; +#else for (div = 2; div <= 16; div *= 2) { if ((tin_parent_rate / (div << 16)) < freq) return tin_parent_rate / div; }
return tin_parent_rate / 16; +#endif }
#define NS_IN_SEC 1000000000UL @@ -58,7 +95,11 @@ static unsigned long pwm_calc_tin(int pwm_id, unsigned long freq) int pwm_config(int pwm_id, int duty_ns, int period_ns) { const struct s5p_timer *pwm = +#if defined(CONFIG_ARCH_NEXELL) + (struct s5p_timer *)PHY_BASEADDR_PWM; +#else (struct s5p_timer *)samsung_get_base_timer(); +#endif unsigned int offset; unsigned long tin_rate; unsigned long tin_ns; @@ -84,7 +125,12 @@ int pwm_config(int pwm_id, int duty_ns, int period_ns) tin_rate = pwm_calc_tin(pwm_id, frequency);
tin_ns = NS_IN_SEC / tin_rate; - tcnt = period_ns / tin_ns; + + if (IS_ENABLED(CONFIG_ARCH_NEXELL)) + /* The counter starts at zero. */ + tcnt = (period_ns / tin_ns) - 1; + else + tcnt = period_ns / tin_ns;
/* Note, counters count down */ tcmp = duty_ns / tin_ns; @@ -115,7 +161,11 @@ int pwm_init(int pwm_id, int div, int invert) { u32 val; const struct s5p_timer *pwm = +#if defined(CONFIG_ARCH_NEXELL) + (struct s5p_timer *)PHY_BASEADDR_PWM; +#else (struct s5p_timer *)samsung_get_base_timer(); +#endif unsigned long ticks_per_period; unsigned int offset, prescaler;
@@ -148,7 +198,12 @@ int pwm_init(int pwm_id, int div, int invert) ticks_per_period = -1UL; } else { const unsigned long pwm_hz = 1000; +#if defined(CONFIG_ARCH_NEXELL) + struct clk *clk = clk_get(CORECLK_NAME_PCLK); + unsigned long timer_rate_hz = clk_get_rate(clk) / +#else unsigned long timer_rate_hz = get_pwm_clk() / +#endif ((prescaler + 1) * (1 << div));
ticks_per_period = timer_rate_hz / pwm_hz; diff --git a/arch/arm/mach-nexell/include/mach/pwm.h b/arch/arm/mach-nexell/include/mach/pwm.h new file mode 100644 index 0000000..08a287d --- /dev/null +++ b/arch/arm/mach-nexell/include/mach/pwm.h @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2009 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * Minkyu Kang mk7.kang@samsung.com + */ + +#ifndef __ASM_ARM_ARCH_PWM_H_ +#define __ASM_ARM_ARCH_PWM_H_ + +#define PRESCALER_0 (8 - 1) /* prescaler of timer 0, 1 */ +#define PRESCALER_1 (16 - 1) /* prescaler of timer 2, 3, 4 */ + +/* Divider MUX */ +#define MUX_DIV_1 0 /* 1/1 period */ +#define MUX_DIV_2 1 /* 1/2 period */ +#define MUX_DIV_4 2 /* 1/4 period */ +#define MUX_DIV_8 3 /* 1/8 period */ +#define MUX_DIV_16 4 /* 1/16 period */ + +#define MUX_DIV_SHIFT(x) ((x) * 4) + +#define TCON_OFFSET(x) (((x) + 1) * (!!(x)) << 2) + +#define TCON_START(x) (1 << TCON_OFFSET(x)) +#define TCON_UPDATE(x) (1 << (TCON_OFFSET(x) + 1)) +#define TCON_INVERTER(x) (1 << (TCON_OFFSET(x) + 2)) +#define TCON_AUTO_RELOAD(x) (1 << (TCON_OFFSET(x) + 3)) +#define TCON4_AUTO_RELOAD (1 << 22) + +#ifndef __ASSEMBLY__ +struct s5p_timer { + unsigned int tcfg0; + unsigned int tcfg1; + unsigned int tcon; + unsigned int tcntb0; + unsigned int tcmpb0; + unsigned int tcnto0; + unsigned int tcntb1; + unsigned int tcmpb1; + unsigned int tcnto1; + unsigned int tcntb2; + unsigned int tcmpb2; + unsigned int tcnto2; + unsigned int tcntb3; + unsigned int res1; + unsigned int tcnto3; + unsigned int tcntb4; + unsigned int tcnto4; + unsigned int tintcstat; +}; +#endif /* __ASSEMBLY__ */ + +#endif
Low level functions for DisplayTop (Display Topology).
(no changes since v1)
drivers/video/nexell/soc/s5pxx18_soc_disptop.c | 185 ++++++++++ drivers/video/nexell/soc/s5pxx18_soc_disptop.h | 385 +++++++++++++++++++++ drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.c | 309 +++++++++++++++++ drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.h | 59 ++++ drivers/video/nexell/soc/s5pxx18_soc_disptype.h | 23 ++ 5 files changed, 961 insertions(+) create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptop.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptop.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_disptype.h
diff --git a/drivers/video/nexell/soc/s5pxx18_soc_disptop.c b/drivers/video/nexell/soc/s5pxx18_soc_disptop.c new file mode 100644 index 0000000..626e53a --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_disptop.c @@ -0,0 +1,185 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <linux/types.h> +#include <linux/io.h> + +#include "s5pxx18_soc_disptop.h" + +static struct { + struct nx_disp_top_register_set *pregister; +} __g_module_variables = { NULL, }; + +int nx_disp_top_initialize(void) +{ + static int binit; + u32 i; + + if (binit == 0) { + for (i = 0; i < NUMBER_OF_DISPTOP_MODULE; i++) + __g_module_variables.pregister = NULL; + binit = 1; + } + return 1; +} + +u32 nx_disp_top_get_number_of_module(void) +{ + return NUMBER_OF_DISPTOP_MODULE; +} + +u32 nx_disp_top_get_physical_address(void) +{ + static const u32 physical_addr[] = PHY_BASEADDR_DISPTOP_LIST; + + return (u32)(physical_addr[0] + PHY_BASEADDR_DISPLAYTOP_MODULE_OFFSET); +} + +u32 nx_disp_top_get_size_of_register_set(void) +{ + return sizeof(struct nx_disp_top_register_set); +} + +void nx_disp_top_set_base_address(void *base_address) +{ + __g_module_variables.pregister = + (struct nx_disp_top_register_set *)base_address; +} + +void *nx_disp_top_get_base_address(void) +{ + return (void *)__g_module_variables.pregister; +} + +void nx_disp_top_set_resconvmux(int benb, u32 sel) +{ + register struct nx_disp_top_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables.pregister; + regvalue = (benb << 31) | (sel << 0); + writel((u32)regvalue, &pregister->resconv_mux_ctrl); +} + +void nx_disp_top_set_hdmimux(int benb, u32 sel) +{ + register struct nx_disp_top_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables.pregister; + regvalue = (benb << 31) | (sel << 0); + writel((u32)regvalue, &pregister->interconv_mux_ctrl); +} + +void nx_disp_top_set_mipimux(int benb, u32 sel) +{ + register struct nx_disp_top_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables.pregister; + regvalue = (benb << 31) | (sel << 0); + writel((u32)regvalue, &pregister->mipi_mux_ctrl); +} + +void nx_disp_top_set_lvdsmux(int benb, u32 sel) +{ + register struct nx_disp_top_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables.pregister; + regvalue = (benb << 31) | (sel << 0); + writel((u32)regvalue, &pregister->lvds_mux_ctrl); +} + +void nx_disp_top_set_primary_mux(u32 sel) +{ + register struct nx_disp_top_register_set *pregister; + + pregister = __g_module_variables.pregister; + writel((u32)sel, &pregister->tftmpu_mux); +} + +void nx_disp_top_hdmi_set_vsync_start(u32 sel) +{ + register struct nx_disp_top_register_set *pregister; + + pregister = __g_module_variables.pregister; + writel((u32)sel, &pregister->hdmisyncctrl0); +} + +void nx_disp_top_hdmi_set_vsync_hsstart_end(u32 start, u32 end) +{ + register struct nx_disp_top_register_set *pregister; + + pregister = __g_module_variables.pregister; + writel((u32)(end << 16) | (start << 0), &pregister->hdmisyncctrl3); +} + +void nx_disp_top_hdmi_set_hactive_start(u32 sel) +{ + register struct nx_disp_top_register_set *pregister; + + pregister = __g_module_variables.pregister; + writel((u32)sel, &pregister->hdmisyncctrl1); +} + +void nx_disp_top_hdmi_set_hactive_end(u32 sel) +{ + register struct nx_disp_top_register_set *pregister; + + pregister = __g_module_variables.pregister; + writel((u32)sel, &pregister->hdmisyncctrl2); +} + +void nx_disp_top_set_hdmifield(u32 enable, u32 init_val, u32 vsynctoggle, + u32 hsynctoggle, u32 vsyncclr, u32 hsyncclr, + u32 field_use, u32 muxsel) +{ + register struct nx_disp_top_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables.pregister; + regvalue = ((enable & 0x01) << 0) | ((init_val & 0x01) << 1) | + ((vsynctoggle & 0x3fff) << 2) | + ((hsynctoggle & 0x3fff) << 17); + writel(regvalue, &pregister->hdmifieldctrl); + regvalue = ((field_use & 0x01) << 31) | ((muxsel & 0x01) << 30) | + ((hsyncclr) << 15) | ((vsyncclr) << 0); + writel(regvalue, &pregister->greg0); +} + +void nx_disp_top_set_padclock(u32 mux_index, u32 padclk_cfg) +{ + register struct nx_disp_top_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables.pregister; + regvalue = readl(&pregister->greg1); + if (padmux_secondary_mlc == mux_index) { + regvalue = regvalue & (~(0x7 << 3)); + regvalue = regvalue | (padclk_cfg << 3); + } else if (padmux_resolution_conv == mux_index) { + regvalue = regvalue & (~(0x7 << 6)); + regvalue = regvalue | (padclk_cfg << 6); + } else { + regvalue = regvalue & (~(0x7 << 0)); + regvalue = regvalue | (padclk_cfg << 0); + } + writel(regvalue, &pregister->greg1); +} + +void nx_disp_top_set_lcdif_enb(int enb) +{ + register struct nx_disp_top_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables.pregister; + regvalue = readl(&pregister->greg1); + regvalue = regvalue & (~(0x1 << 9)); + regvalue = regvalue | ((enb & 0x1) << 9); + writel(regvalue, &pregister->greg1); +} diff --git a/drivers/video/nexell/soc/s5pxx18_soc_disptop.h b/drivers/video/nexell/soc/s5pxx18_soc_disptop.h new file mode 100644 index 0000000..c7bf504 --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_disptop.h @@ -0,0 +1,385 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _S5PXX18_SOC_DISPTOP_H_ +#define _S5PXX18_SOC_DISPTOP_H_ + +#include "s5pxx18_soc_disptype.h" + +#define NUMBER_OF_DISPTOP_MODULE 1 +#define PHY_BASEADDR_DISPLAYTOP_MODULE 0xC0100000 +#define PHY_BASEADDR_DISPTOP_LIST \ + { PHY_BASEADDR_DISPLAYTOP_MODULE } + +#define HDMI_ADDR_OFFSET \ + (((PHY_BASEADDR_DISPLAYTOP_MODULE / 0x00100000) % 2) ? 0x100000 \ + : 0x000000) +#define OTHER_ADDR_OFFSET \ + (((PHY_BASEADDR_DISPLAYTOP_MODULE / 0x00100000) % 2) ? 0x000000 \ + : 0x100000) +#define PHY_BASEADDR_DISPLAYTOP_MODULE_OFFSET (OTHER_ADDR_OFFSET + 0x001000) +#define PHY_BASEADDR_DUALDISPLAY_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x002000) +#define PHY_BASEADDR_RESCONV_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x003000) +#define PHY_BASEADDR_LCDINTERFACE_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x004000) +#define PHY_BASEADDR_HDMI_MODULE (PHY_BASEADDR_DISPLAYTOP_MODULE + 0x000000) +#define PHY_BASEADDR_LVDS_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x00a000) + +#define NUMBER_OF_DUALDISPLAY_MODULE 1 +#define INTNUM_OF_DUALDISPLAY_MODULE_PRIMIRQ \ + INTNUM_OF_DISPLAYTOP_MODULE_DUALDISPLAY_PRIMIRQ +#define INTNUM_OF_DUALDISPLAY_MODULE_SECONDIRQ \ + INTNUM_OF_DISPLAYTOP_MODULE_DUALDISPLAY_SECONDIRQ +#define RESETINDEX_OF_DUALDISPLAY_MODULE_I_NRST \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_DUALDISPLAY_NRST +#define PADINDEX_OF_DUALDISPLAY_O_NCS \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PADPRIMVCLK +#define PADINDEX_OF_DUALDISPLAY_O_NRD \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADN_HSYNC +#define PADINDEX_OF_DUALDISPLAY_O_RS \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADN_VSYNC +#define PADINDEX_OF_DUALDISPLAY_O_NWR \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADDE +#define PADINDEX_OF_DUALDISPLAY_PADPRIMVCLK \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PADPRIMVCLK +#define PADINDEX_OF_DUALDISPLAY_O_PRIM_PADN_HSYNC \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADN_HSYNC +#define PADINDEX_OF_DUALDISPLAY_O_PRIM_PADN_VSYNC \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADN_VSYNC +#define PADINDEX_OF_DUALDISPLAY_O_PRIM_PADDE \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADDE +#define PADINDEX_OF_DUALDISPLAY_PRIM_0_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_0_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_1_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_1_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_2_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_2_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_3_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_3_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_4_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_4_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_5_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_5_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_6_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_6_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_7_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_7_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_8_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_8_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_9_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_9_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_10_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_10_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_11_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_11_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_12_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_12_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_13_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_13_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_14_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_14_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_15_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_15_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_16_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_16_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_17_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_17_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_18_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_18_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_19_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_19_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_20_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_20_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_21_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_21_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_22_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_22_ +#define PADINDEX_OF_DUALDISPLAY_PRIM_23_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_23_ +#define PADINDEX_OF_DUALDISPLAY_PADSECONDVCLK \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PADPRIMVCLK +#define PADINDEX_OF_DUALDISPLAY_O_SECOND_PADN_HSYNC \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADN_HSYNC +#define PADINDEX_OF_DUALDISPLAY_O_SECOND_PADN_VSYNC \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADN_VSYNC +#define PADINDEX_OF_DUALDISPLAY_O_SECOND_PADDE \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADDE +#define PADINDEX_OF_DUALDISPLAY_SECOND_0_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_0_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_1_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_1_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_2_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_2_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_3_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_3_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_4_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_4_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_5_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_5_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_6_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_6_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_7_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_7_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_8_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_8_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_9_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_9_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_10_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_10_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_11_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_11_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_12_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_12_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_13_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_13_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_14_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_14_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_15_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_15_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_16_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_16_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_17_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_17_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_18_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_18_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_19_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_19_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_20_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_20_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_21_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_21_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_22_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_22_ +#define PADINDEX_OF_DUALDISPLAY_SECOND_23_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_23_ + +#define NUMBER_OF_RESCONV_MODULE 1 +#define INTNUM_OF_RESCONV_MODULE INTNUM_OF_DISPLAYTOP_MODULE_RESCONV_IRQ +#define RESETINDEX_OF_RESCONV_MODULE_I_NRST \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_RESCONV_NRST +#define RESETINDEX_OF_RESCONV_MODULE RESETINDEX_OF_RESCONV_MODULE_I_NRST +#define NUMBER_OF_LCDINTERFACE_MODULE 1 +#define RESETINDEX_OF_LCDINTERFACE_MODULE_I_NRST \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_LCDIF_NRST +#define PADINDEX_OF_LCDINTERFACE_O_VCLK \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PADPRIMVCLK +#define PADINDEX_OF_LCDINTERFACE_O_NHSYNC \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADN_HSYNC +#define PADINDEX_OF_LCDINTERFACE_O_NVSYNC \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADN_VSYNC +#define PADINDEX_OF_LCDINTERFACE_O_DE \ + PADINDEX_OF_DISPLAYTOP_O_DUAL_DISPLAY_PRIM_PADDE +#define PADINDEX_OF_LCDINTERFACE_RGB24_0_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_0_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_1_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_1_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_2_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_2_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_3_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_3_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_4_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_4_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_5_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_5_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_6_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_6_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_7_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_7_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_8_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_8_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_9_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_9_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_10_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_10_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_11_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_11_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_12_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_12_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_13_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_13_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_14_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_14_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_15_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_15_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_16_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_16_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_17_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_17_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_18_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_18_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_19_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_19_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_20_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_20_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_21_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_21_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_22_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_22_ +#define PADINDEX_OF_LCDINTERFACE_RGB24_23_ \ + PADINDEX_OF_DISPLAYTOP_DUAL_DISPLAY_PRIM_23_ + +#define NUMBER_OF_HDMI_MODULE 1 +#define INTNUM_OF_HDMI_MODULE INTNUM_OF_DISPLAYTOP_MODULE_HDMI_IRQ +#define RESETINDEX_OF_HDMI_MODULE_I_NRST \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_HDMI_NRST +#define RESETINDEX_OF_HDMI_MODULE_I_NRST_VIDEO \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_HDMI_VIDEO_NRST +#define RESETINDEX_OF_HDMI_MODULE_I_NRST_SPDIF \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_HDMI_SPDIF_NRST +#define RESETINDEX_OF_HDMI_MODULE_I_NRST_TMDS \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_HDMI_TMDS_NRST +#define RESETINDEX_OF_HDMI_MODULE_I_NRST_PHY \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_HDMI_PHY_NRST +#define PADINDEX_OF_HDMI_I_PHY_CLKI PADINDEX_OF_DISPLAYTOP_I_HDMI_CLKI +#define PADINDEX_OF_HDMI_O_PHY_CLKO PADINDEX_OF_DISPLAYTOP_O_HDMI_CLKO +#define PADINDEX_OF_HDMI_IO_PHY_REXT PADINDEX_OF_DISPLAYTOP_IO_HDMI_REXT +#define PADINDEX_OF_HDMI_O_PHY_TX0P PADINDEX_OF_DISPLAYTOP_O_HDMI_TX0P +#define PADINDEX_OF_HDMI_O_PHY_TX0N PADINDEX_OF_DISPLAYTOP_O_HDMI_TX0N +#define PADINDEX_OF_HDMI_O_PHY_TX1P PADINDEX_OF_DISPLAYTOP_O_HDMI_TX1P +#define PADINDEX_OF_HDMI_O_PHY_TX1N PADINDEX_OF_DISPLAYTOP_O_HDMI_TX1N +#define PADINDEX_OF_HDMI_O_PHY_TX2P PADINDEX_OF_DISPLAYTOP_O_HDMI_TX2P +#define PADINDEX_OF_HDMI_O_PHY_TX2N PADINDEX_OF_DISPLAYTOP_O_HDMI_TX2N +#define PADINDEX_OF_HDMI_O_PHY_TXCP PADINDEX_OF_DISPLAYTOP_O_HDMI_TXCP +#define PADINDEX_OF_HDMI_O_PHY_TXCN PADINDEX_OF_DISPLAYTOP_O_HDMI_TXCN +#define PADINDEX_OF_HDMI_I_HOTPLUG PADINDEX_OF_DISPLAYTOP_I_HDMI_HOTPLUG_5V +#define PADINDEX_OF_HDMI_IO_PAD_CEC PADINDEX_OF_DISPLAYTOP_IO_HDMI_CEC +#define NUMBER_OF_LVDS_MODULE 1 + +#define RESETINDEX_OF_LVDS_MODULE_I_RESETN \ + RESETINDEX_OF_DISPLAYTOP_MODULE_I_LVDS_NRST +#define RESETINDEX_OF_LVDS_MODULE RESETINDEX_OF_LVDS_MODULE_I_RESETN + +#define PADINDEX_OF_LVDS_TAP PADINDEX_OF_DISPLAYTOP_LVDS_TXP_A +#define PADINDEX_OF_LVDS_TAN PADINDEX_OF_DISPLAYTOP_LVDS_TXN_A +#define PADINDEX_OF_LVDS_TBP PADINDEX_OF_DISPLAYTOP_LVDS_TXP_B +#define PADINDEX_OF_LVDS_TBN PADINDEX_OF_DISPLAYTOP_LVDS_TXN_B +#define PADINDEX_OF_LVDS_TCP PADINDEX_OF_DISPLAYTOP_LVDS_TXP_C +#define PADINDEX_OF_LVDS_TCN PADINDEX_OF_DISPLAYTOP_LVDS_TXN_C +#define PADINDEX_OF_LVDS_TDP PADINDEX_OF_DISPLAYTOP_LVDS_TXP_D +#define PADINDEX_OF_LVDS_TDN PADINDEX_OF_DISPLAYTOP_LVDS_TXN_D +#define PADINDEX_OF_LVDS_TCLKP PADINDEX_OF_DISPLAYTOP_LVDS_TXP_CLK +#define PADINDEX_OF_LVDS_TCLKN PADINDEX_OF_DISPLAYTOP_LVDS_TXN_CLK +#define PADINDEX_OF_LVDS_ROUT PADINDEX_OF_DISPLAYTOP_LVDS_ROUT +#define PADINDEX_OF_LVDS_TEP PADINDEX_OF_DISPLAYTOP_LVDS_TXN_E +#define PADINDEX_OF_LVDS_TEN PADINDEX_OF_DISPLAYTOP_LVDS_TXN_E +#define NUMBER_OF_DISPTOP_CLKGEN_MODULE 5 + +enum disptop_clkgen_module_index { + res_conv_clkgen = 0, + lcdif_clkgen = 1, + to_mipi_clkgen = 2, + to_lvds_clkgen = 3, + hdmi_clkgen = 4, +}; + +enum disptop_res_conv_iclk_cclk { + res_conv_iclk = 0, + res_conv_cclk = 1, +}; + +enum disptop_res_conv_oclk { + res_conv_oclk = 1, +}; + +enum disptop_lcdif_clk { + lcdif_pixel_clkx_n = 0, + lcdif_pixel_clk = 1, +}; + +#define HDMI_SPDIF_CLKGEN 2 +#define HDMI_SPDIF_CLKOUT 0 +#define HDMI_I_VCLK_CLKOUT 0 +#define PHY_BASEADDR_DISPTOP_CLKGEN0_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x006000) +#define PHY_BASEADDR_DISPTOP_CLKGEN1_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x007000) +#define PHY_BASEADDR_DISPTOP_CLKGEN2_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x005000) +#define PHY_BASEADDR_DISPTOP_CLKGEN3_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x008000) +#define PHY_BASEADDR_DISPTOP_CLKGEN4_MODULE \ + (PHY_BASEADDR_DISPLAYTOP_MODULE + OTHER_ADDR_OFFSET + 0x009000) + +struct nx_disp_top_register_set { + u32 resconv_mux_ctrl; + u32 interconv_mux_ctrl; + u32 mipi_mux_ctrl; + u32 lvds_mux_ctrl; + u32 hdmifixctrl0; + u32 hdmisyncctrl0; + u32 hdmisyncctrl1; + u32 hdmisyncctrl2; + u32 hdmisyncctrl3; + u32 tftmpu_mux; + u32 hdmifieldctrl; + u32 greg0; + u32 greg1; + u32 greg2; + u32 greg3; + u32 greg4; + u32 greg5; +}; + +int nx_disp_top_initialize(void); +u32 nx_disp_top_get_number_of_module(void); + +u32 nx_disp_top_get_physical_address(void); +u32 nx_disp_top_get_size_of_register_set(void); +void nx_disp_top_set_base_address(void *base_address); +void *nx_disp_top_get_base_address(void); +int nx_disp_top_open_module(void); +int nx_disp_top_close_module(void); +int nx_disp_top_check_busy(void); + +enum mux_index { + primary_mlc = 0, + secondary_mlc = 1, + resolution_conv = 2, +}; + +enum prim_pad_mux_index { + padmux_primary_mlc = 0, + padmux_primary_mpu = 1, + padmux_secondary_mlc = 2, + padmux_resolution_conv = 3, +}; + +void nx_disp_top_set_resconvmux(int benb, u32 sel); +void nx_disp_top_set_hdmimux(int benb, u32 sel); +void nx_disp_top_set_mipimux(int benb, u32 sel); +void nx_disp_top_set_lvdsmux(int benb, u32 sel); +void nx_disp_top_set_primary_mux(u32 sel); +void nx_disp_top_hdmi_set_vsync_start(u32 sel); +void nx_disp_top_hdmi_set_vsync_hsstart_end(u32 start, u32 end); +void nx_disp_top_hdmi_set_hactive_start(u32 sel); +void nx_disp_top_hdmi_set_hactive_end(u32 sel); + +void nx_disp_top_set_hdmifield(u32 enable, u32 init_val, u32 vsynctoggle, + u32 hsynctoggle, u32 vsyncclr, u32 hsyncclr, + u32 field_use, u32 muxsel); + +enum padclk_config { + padclk_clk = 0, + padclk_inv_clk = 1, + padclk_reserved_clk = 2, + padclk_reserved_inv_clk = 3, + padclk_clk_div2_0 = 4, + padclk_clk_div2_90 = 5, + padclk_clk_div2_180 = 6, + padclk_clk_div2_270 = 7, +}; + +void nx_disp_top_set_padclock(u32 mux_index, u32 padclk_cfg); +void nx_disp_top_set_lcdif_enb(int enb); +void nx_disp_top_set_hdmifield(u32 enable, u32 init_val, u32 vsynctoggle, + u32 hsynctoggle, u32 vsyncclr, u32 hsyncclr, + u32 field_use, u32 muxsel); + +#endif diff --git a/drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.c b/drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.c new file mode 100644 index 0000000..02361ba --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.c @@ -0,0 +1,309 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <linux/types.h> +#include <linux/io.h> + +#include "s5pxx18_soc_disptop_clk.h" +#include "s5pxx18_soc_disptop.h" + +static struct { + struct nx_disptop_clkgen_register_set *__g_pregister; +} __g_module_variables[NUMBER_OF_DISPTOP_CLKGEN_MODULE] = { + { NULL,}, +}; + +int nx_disp_top_clkgen_initialize(void) +{ + static int binit; + u32 i; + + if (binit == 0) { + for (i = 0; i < NUMBER_OF_DISPTOP_CLKGEN_MODULE; i++) + __g_module_variables[i].__g_pregister = NULL; + binit = 1; + } + return 1; +} + +u32 nx_disp_top_clkgen_get_number_of_module(void) +{ + return NUMBER_OF_DISPTOP_CLKGEN_MODULE; +} + +u32 nx_disp_top_clkgen_get_physical_address(u32 module_index) +{ + static const u32 physical_addr[] = + PHY_BASEADDR_DISPTOP_CLKGEN_LIST; + + return (u32)physical_addr[module_index]; +} + +u32 nx_disp_top_clkgen_get_size_of_register_set(void) +{ + return sizeof(struct nx_disptop_clkgen_register_set); +} + +void nx_disp_top_clkgen_set_base_address(u32 module_index, void *base_address) +{ + __g_module_variables[module_index].__g_pregister = + (struct nx_disptop_clkgen_register_set *)base_address; +} + +void *nx_disp_top_clkgen_get_base_address(u32 module_index) +{ + return (void *)__g_module_variables[module_index].__g_pregister; +} + +void nx_disp_top_clkgen_set_clock_bclk_mode(u32 module_index, + enum nx_bclkmode mode) +{ + register struct nx_disptop_clkgen_register_set *pregister; + register u32 regvalue; + u32 clkmode = 0; + + pregister = __g_module_variables[module_index].__g_pregister; + switch (mode) { + case nx_bclkmode_disable: + clkmode = 0; + case nx_bclkmode_dynamic: + clkmode = 2; + break; + case nx_bclkmode_always: + clkmode = 3; + break; + default: + break; + } + + regvalue = pregister->clkenb; + regvalue &= ~3ul; + regvalue |= (clkmode & 0x03); + + writel(regvalue, &pregister->clkenb); +} + +enum nx_bclkmode nx_disp_top_clkgen_get_clock_bclk_mode(u32 module_index) +{ + register struct nx_disptop_clkgen_register_set *pregister; + u32 mode = 0; + + pregister = __g_module_variables[module_index].__g_pregister; + mode = (pregister->clkenb & 3ul); + + switch (mode) { + case 0: + return nx_bclkmode_disable; + case 2: + return nx_bclkmode_dynamic; + case 3: + return nx_bclkmode_always; + default: + break; + } + return nx_bclkmode_disable; +} + +void nx_disp_top_clkgen_set_clock_pclk_mode(u32 module_index, + enum nx_pclkmode mode) +{ + register struct nx_disptop_clkgen_register_set *pregister; + register u32 regvalue; + const u32 pclkmode_pos = 3; + u32 clkmode = 0; + + pregister = __g_module_variables[module_index].__g_pregister; + switch (mode) { + case nx_pclkmode_dynamic: + clkmode = 0; + break; + case nx_pclkmode_always: + clkmode = 1; + break; + default: + break; + } + + regvalue = pregister->clkenb; + regvalue &= ~(1ul << pclkmode_pos); + regvalue |= (clkmode & 0x01) << pclkmode_pos; + + writel(regvalue, &pregister->clkenb); +} + +enum nx_pclkmode nx_disp_top_clkgen_get_clock_pclk_mode(u32 module_index) +{ + register struct nx_disptop_clkgen_register_set *pregister; + const u32 pclkmode_pos = 3; + + pregister = __g_module_variables[module_index].__g_pregister; + + if (pregister->clkenb & (1ul << pclkmode_pos)) + return nx_pclkmode_always; + + return nx_pclkmode_dynamic; +} + +void nx_disp_top_clkgen_set_clock_source(u32 module_index, u32 index, + u32 clk_src) +{ + register struct nx_disptop_clkgen_register_set *pregister; + register u32 read_value; + + const u32 clksrcsel_pos = 2; + const u32 clksrcsel_mask = 0x07 << clksrcsel_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + read_value = pregister->CLKGEN[index << 1]; + read_value &= ~clksrcsel_mask; + read_value |= clk_src << clksrcsel_pos; + + writel(read_value, &pregister->CLKGEN[index << 1]); +} + +u32 nx_disp_top_clkgen_get_clock_source(u32 module_index, u32 index) +{ + register struct nx_disptop_clkgen_register_set *pregister; + const u32 clksrcsel_pos = 2; + const u32 clksrcsel_mask = 0x07 << clksrcsel_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + return (pregister->CLKGEN[index << 1] & + clksrcsel_mask) >> clksrcsel_pos; +} + +void nx_disp_top_clkgen_set_clock_divisor(u32 module_index, u32 index, + u32 divisor) +{ + register struct nx_disptop_clkgen_register_set *pregister; + const u32 clkdiv_pos = 5; + const u32 clkdiv_mask = 0xff << clkdiv_pos; + register u32 read_value; + + pregister = __g_module_variables[module_index].__g_pregister; + + read_value = pregister->CLKGEN[index << 1]; + read_value &= ~clkdiv_mask; + read_value |= (divisor - 1) << clkdiv_pos; + writel(read_value, &pregister->CLKGEN[index << 1]); +} + +u32 nx_disp_top_clkgen_get_clock_divisor(u32 module_index, u32 index) +{ + register struct nx_disptop_clkgen_register_set *pregister; + const u32 clkdiv_pos = 5; + const u32 clkdiv_mask = 0xff << clkdiv_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + return ((pregister->CLKGEN[index << 1] & + clkdiv_mask) >> clkdiv_pos) + 1; +} + +void nx_disp_top_clkgen_set_clock_divisor_enable(u32 module_index, int enable) +{ + register struct nx_disptop_clkgen_register_set *pregister; + register u32 read_value; + const u32 clkgenenb_pos = 2; + const u32 clkgenenb_mask = 1ul << clkgenenb_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + read_value = pregister->clkenb; + read_value &= ~clkgenenb_mask; + read_value |= (u32)enable << clkgenenb_pos; + + writel(read_value, &pregister->clkenb); +} + +int nx_disp_top_clkgen_get_clock_divisor_enable(u32 module_index) +{ + register struct nx_disptop_clkgen_register_set *pregister; + const u32 clkgenenb_pos = 2; + const u32 clkgenenb_mask = 1ul << clkgenenb_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + return (int)((pregister->clkenb & + clkgenenb_mask) >> clkgenenb_pos); +} + +void nx_disp_top_clkgen_set_clock_out_inv(u32 module_index, u32 index, + int out_clk_inv) +{ + register struct nx_disptop_clkgen_register_set *pregister; + register u32 read_value; + const u32 outclkinv_pos = 1; + const u32 outclkinv_mask = 1ul << outclkinv_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + read_value = pregister->CLKGEN[index << 1]; + read_value &= ~outclkinv_mask; + read_value |= out_clk_inv << outclkinv_pos; + + writel(read_value, &pregister->CLKGEN[index << 1]); +} + +int nx_disp_top_clkgen_get_clock_out_inv(u32 module_index, u32 index) +{ + register struct nx_disptop_clkgen_register_set *pregister; + const u32 outclkinv_pos = 1; + const u32 outclkinv_mask = 1ul << outclkinv_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + return (int)((pregister->CLKGEN[index << 1] & + outclkinv_mask) >> outclkinv_pos); +} + +int nx_disp_top_clkgen_set_input_inv(u32 module_index, + u32 index, int in_clk_inv) +{ + register struct nx_disptop_clkgen_register_set *pregister; + register u32 read_value; + const u32 inclkinv_pos = 4 + index; + const u32 inclkinv_mask = 1ul << inclkinv_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + read_value = pregister->clkenb; + read_value &= ~inclkinv_mask; + read_value |= in_clk_inv << inclkinv_pos; + + writel(read_value, &pregister->clkenb); + return true; +} + +int nx_disp_top_clkgen_get_input_inv(u32 module_index, u32 index) +{ + register struct nx_disptop_clkgen_register_set *pregister; + const u32 inclkinv_pos = 4 + index; + const u32 inclkinv_mask = 1ul << inclkinv_pos; + + pregister = __g_module_variables[module_index].__g_pregister; + + return (int)((pregister->clkenb & + inclkinv_mask) >> inclkinv_pos); +} + +void nx_disp_top_clkgen_set_clock_out_select(u32 module_index, u32 index, + int bbypass) +{ + register struct nx_disptop_clkgen_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].__g_pregister; + + read_value = pregister->CLKGEN[index << 1]; + read_value = read_value & (~0x01); + read_value = read_value | bbypass; + + writel(read_value, &pregister->CLKGEN[index << 1]); +} diff --git a/drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.h b/drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.h new file mode 100644 index 0000000..d55fef7 --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_disptop_clk.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _S5PXX18_SOC_DISPTOP_CLK_H_ +#define _S5PXX18_SOC_DISPTOP_CLK_H_ + +#include "s5pxx18_soc_disptype.h" + +#define PHY_BASEADDR_DISPTOP_CLKGEN_LIST \ + { PHY_BASEADDR_DISPTOP_CLKGEN0_MODULE, \ + PHY_BASEADDR_DISPTOP_CLKGEN1_MODULE, \ + PHY_BASEADDR_DISPTOP_CLKGEN2_MODULE, \ + PHY_BASEADDR_DISPTOP_CLKGEN3_MODULE, \ + PHY_BASEADDR_DISPTOP_CLKGEN4_MODULE, \ + } + +struct nx_disptop_clkgen_register_set { + u32 clkenb; + u32 CLKGEN[4]; +}; + +int nx_disp_top_clkgen_initialize(void); +u32 nx_disp_top_clkgen_get_number_of_module(void); +u32 nx_disp_top_clkgen_get_physical_address(u32 module_index); +u32 nx_disp_top_clkgen_get_size_of_register_set(void); +void nx_disp_top_clkgen_set_base_address(u32 module_index, + void *base_address); +void *nx_disp_top_clkgen_get_base_address(u32 module_index); +void nx_disp_top_clkgen_set_clock_pclk_mode(u32 module_index, + enum nx_pclkmode mode); +enum nx_pclkmode nx_disp_top_clkgen_get_clock_pclk_mode(u32 module_index); +void nx_disp_top_clkgen_set_clock_source(u32 module_index, u32 index, + u32 clk_src); +u32 nx_disp_top_clkgen_get_clock_source(u32 module_index, u32 index); +void nx_disp_top_clkgen_set_clock_divisor(u32 module_index, u32 index, + u32 divisor); +u32 nx_disp_top_clkgen_get_clock_divisor(u32 module_index, u32 index); +void nx_disp_top_clkgen_set_clock_divisor_enable(u32 module_index, + int enable); +int nx_disp_top_clkgen_get_clock_divisor_enable(u32 module_index); +void nx_disp_top_clkgen_set_clock_bclk_mode(u32 module_index, + enum nx_bclkmode mode); +enum nx_bclkmode nx_disp_top_clkgen_get_clock_bclk_mode(u32 module_index); + +void nx_disp_top_clkgen_set_clock_out_inv(u32 module_index, u32 index, + int out_clk_inv); +int nx_disp_top_clkgen_get_clock_out_inv(u32 module_index, u32 index); +int nx_disp_top_clkgen_set_input_inv(u32 module_index, u32 index, + int out_clk_inv); +int nx_disp_top_clkgen_get_input_inv(u32 module_index, u32 index); + +void nx_disp_top_clkgen_set_clock_out_select(u32 module_index, u32 index, + int bbypass); + +#endif diff --git a/drivers/video/nexell/soc/s5pxx18_soc_disptype.h b/drivers/video/nexell/soc/s5pxx18_soc_disptype.h new file mode 100644 index 0000000..b5df7a7 --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_disptype.h @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _S5PXX18_SOC_DISP_TYPE_H_ +#define _S5PXX18_SOC_DISP_TYPE_H_ + +/* clock control types */ +enum nx_pclkmode { + nx_pclkmode_dynamic = 0UL, + nx_pclkmode_always = 1UL +}; + +enum nx_bclkmode { + nx_bclkmode_disable = 0UL, + nx_bclkmode_dynamic = 2UL, + nx_bclkmode_always = 3UL +}; + +#endif
Signed-off-by: Stefan Bosch stefan_b@posteo.net
Low level functions for MLC (Multi Layer Control) and MIPI (Mobile Industry Processor Interface).
Signed-off-by: Stefan Bosch stefan_b@posteo.net ---
drivers/video/nexell/soc/s5pxx18_soc_mipi.c | 580 +++++++++ drivers/video/nexell/soc/s5pxx18_soc_mipi.h | 291 +++++ drivers/video/nexell/soc/s5pxx18_soc_mlc.c | 1861 +++++++++++++++++++++++++++ drivers/video/nexell/soc/s5pxx18_soc_mlc.h | 429 ++++++ 4 files changed, 3161 insertions(+) create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_mipi.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_mipi.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_mlc.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_mlc.h
diff --git a/drivers/video/nexell/soc/s5pxx18_soc_mipi.c b/drivers/video/nexell/soc/s5pxx18_soc_mipi.c new file mode 100644 index 0000000..1000ddb --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_mipi.c @@ -0,0 +1,580 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <linux/types.h> +#include <linux/io.h> + +#include "s5pxx18_soc_disptop.h" +#include "s5pxx18_soc_mipi.h" + +static struct nx_mipi_register_set *__g_pregister[NUMBER_OF_MIPI_MODULE]; + +int nx_mipi_smoke_test(u32 module_index) +{ + register struct nx_mipi_register_set *pregister; + + pregister = __g_pregister[module_index]; + + if (pregister->csis_config_ch0 != 0x000000FC) + return false; + + if (pregister->dsim_intmsk != 0xB337FFFF) + return false; + + writel(0xDEADC0DE, &pregister->csis_dphyctrl); + writel(0xFFFFFFFF, &pregister->csis_ctrl2); + writel(0xDEADC0DE, &pregister->dsim_msync); + + if (pregister->csis_dphyctrl != 0xDE80001E) + return false; + + if ((pregister->csis_ctrl2 & (~1)) != 0xEEE00010) + return false; + + if (pregister->dsim_msync != 0xDE80C0DE) + return false; + + return true; +} + +void nx_mipi_set_base_address(u32 module_index, void *base_address) +{ + __g_pregister[module_index] = + (struct nx_mipi_register_set *)base_address; +} + +void *nx_mipi_get_base_address(u32 module_index) +{ + return (void *)__g_pregister[module_index]; +} + +u32 nx_mipi_get_physical_address(u32 module_index) +{ + const u32 physical_addr[] = PHY_BASEADDR_MIPI_LIST; + + return physical_addr[module_index]; +} + +#define __nx_mipi_valid_dsi_intmask__ \ + (~((1 << 26) | (1 << 23) | (1 << 22) | (1 << 19))) + +void nx_mipi_set_interrupt_enable(u32 module_index, u32 int_num, int enable) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + + pregister = __g_pregister[module_index]; + if (int_num < 32) { + regvalue = pregister->csis_intmsk; + regvalue &= ~(1ul << int_num); + regvalue |= (u32)enable << int_num; + writel(regvalue, &pregister->csis_intmsk); + } else { + regvalue = pregister->dsim_intmsk; + regvalue &= ~(1ul << (int_num - 32)); + regvalue |= (u32)enable << (int_num - 32); + writel(regvalue, &pregister->dsim_intmsk); + } +} + +int nx_mipi_get_interrupt_enable(u32 module_index, u32 int_num) +{ + if (int_num < 32) + return (int)((__g_pregister[module_index]->csis_intmsk >> + int_num) & 0x01); + else + return (int)((__g_pregister[module_index]->dsim_intmsk >> + (int_num - 32)) & 0x01); +} + +int nx_mipi_get_interrupt_pending(u32 module_index, u32 int_num) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + int ret; + + pregister = __g_pregister[module_index]; + if (int_num < 32) { + regvalue = pregister->csis_intmsk; + regvalue &= pregister->csis_intsrc; + ret = (int)((regvalue >> int_num) & 0x01); + } else { + regvalue = pregister->dsim_intmsk; + regvalue &= pregister->dsim_intsrc; + ret = (int)((regvalue >> (int_num - 32)) & 0x01); + } + + return ret; +} + +void nx_mipi_clear_interrupt_pending(u32 module_index, u32 int_num) +{ + register struct nx_mipi_register_set *pregister; + + pregister = __g_pregister[module_index]; + if (int_num < 32) + writel(1ul << int_num, &pregister->csis_intsrc); + else + writel(1ul << (int_num - 32), &pregister->dsim_intsrc); +} + +void nx_mipi_set_interrupt_enable_all(u32 module_index, int enable) +{ + register struct nx_mipi_register_set *pregister; + + pregister = __g_pregister[module_index]; + if (enable) + writel(__nx_mipi_valid_dsi_intmask__, &pregister->dsim_intmsk); + else + writel(0, &pregister->dsim_intmsk); +} + +int nx_mipi_get_interrupt_enable_all(u32 module_index) +{ + if (__g_pregister[module_index]->csis_intmsk) + return true; + + if (__g_pregister[module_index]->dsim_intmsk) + return true; + + return false; +} + +int nx_mipi_get_interrupt_pending_all(u32 module_index) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + + pregister = __g_pregister[module_index]; + regvalue = pregister->csis_intmsk; + regvalue &= pregister->csis_intsrc; + + if (regvalue) + return true; + + regvalue = pregister->dsim_intmsk; + regvalue &= pregister->dsim_intsrc; + + if (regvalue) + return true; + + return false; +} + +void nx_mipi_clear_interrupt_pending_all(u32 module_index) +{ + register struct nx_mipi_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(__nx_mipi_valid_dsi_intmask__, &pregister->dsim_intsrc); +} + +int32_t nx_mipi_get_interrupt_pending_number(u32 module_index) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + int i; + + pregister = __g_pregister[module_index]; + regvalue = pregister->csis_intmsk; + regvalue &= pregister->csis_intsrc; + if (regvalue != 0) { + for (i = 0; i < 32; i++) { + if (regvalue & 1ul) + return i; + regvalue >>= 1; + } + } + + regvalue = pregister->dsim_intmsk; + regvalue &= pregister->dsim_intsrc; + if (regvalue != 0) { + for (i = 0; i < 32; i++) { + if (regvalue & 1ul) + return i + 32; + regvalue >>= 1; + } + } + return -1; +} + +#define writereg(regname, mask, value) \ + regvalue = pregister->(regname); \ + regvalue = (regvalue & (~(mask))) | (value); \ + writel(regvalue, &pregister->(regname)) + +void nx_mipi_dsi_get_status(u32 module_index, u32 *pulps, u32 *pstop, + u32 *pispllstable, u32 *pisinreset, + u32 *pisbackward, u32 *pishsclockready) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + + pregister = __g_pregister[module_index]; + regvalue = pregister->dsim_status; + if (pulps) { + *pulps = 0; + if (regvalue & (1 << 4)) + *pulps |= (1 << 0); + if (regvalue & (1 << 5)) + *pulps |= (1 << 1); + if (regvalue & (1 << 6)) + *pulps |= (1 << 2); + if (regvalue & (1 << 7)) + *pulps |= (1 << 3); + if (regvalue & (1 << 9)) + *pulps |= (1 << 4); + } + + if (pstop) { + *pstop = 0; + if (regvalue & (1 << 0)) + *pstop |= (1 << 0); + if (regvalue & (1 << 1)) + *pstop |= (1 << 1); + if (regvalue & (1 << 2)) + *pstop |= (1 << 2); + if (regvalue & (1 << 3)) + *pstop |= (1 << 3); + if (regvalue & (1 << 8)) + *pstop |= (1 << 4); + } + + if (pispllstable) + *pispllstable = (regvalue >> 31) & 1; + + if (pisinreset) + *pisinreset = ((regvalue >> 20) & 1) ? 0 : 1; + + if (pisbackward) + *pisbackward = (regvalue >> 16) & 1; + + if (pishsclockready) + *pishsclockready = (regvalue >> 10) & 1; +} + +void nx_mipi_dsi_software_reset(u32 module_index) +{ + register struct nx_mipi_register_set *pregister; + + pregister = __g_pregister[module_index]; + + writel(0x00010001, &pregister->dsim_swrst); + + while (0 != (readl(&pregister->dsim_status) & (1 << 20))) + ; + + writel(0x00000000, &pregister->dsim_swrst); +} + +void nx_mipi_dsi_set_clock(u32 module_index, int enable_txhsclock, + int use_external_clock, int enable_byte_clock, + int enable_escclock_clock_lane, + int enable_escclock_data_lane0, + int enable_escclock_data_lane1, + int enable_escclock_data_lane2, + int enable_escclock_data_lane3, + int enable_escprescaler, u32 escprescalervalue) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + + pregister = __g_pregister[module_index]; + regvalue = 0; + regvalue |= (enable_txhsclock << 31); + regvalue |= (use_external_clock << 27); + regvalue |= (enable_byte_clock << 24); + regvalue |= (enable_escclock_clock_lane << 19); + regvalue |= (enable_escclock_data_lane0 << 20); + regvalue |= (enable_escclock_data_lane1 << 21); + regvalue |= (enable_escclock_data_lane2 << 22); + regvalue |= (enable_escclock_data_lane3 << 23); + regvalue |= (enable_escprescaler << 28); + regvalue |= escprescalervalue; + + writel(regvalue, &pregister->dsim_clkctrl); +} + +void nx_mipi_dsi_set_timeout(u32 module_index, u32 bta_tout, u32 lpdrtout) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + + pregister = __g_pregister[module_index]; + regvalue = 0; + regvalue |= (bta_tout << 16); + regvalue |= (lpdrtout << 0); + + writel(regvalue, &pregister->dsim_timeout); +} + +void nx_mipi_dsi_set_config_video_mode(u32 module_index, + int enable_auto_flush_main_display_fifo, + int enable_auto_vertical_count, + int enable_burst, + enum nx_mipi_dsi_syncmode sync_mode, + int enable_eo_tpacket, + int enable_hsync_end_packet, + int enable_hfp, int enable_hbp, + int enable_hsa, + u32 number_of_virtual_channel, + enum nx_mipi_dsi_format format, + u32 number_of_words_in_hfp, + u32 number_of_words_in_hbp, + u32 number_of_words_in_hsync, + u32 number_of_lines_in_vfp, + u32 number_of_lines_in_vbp, + u32 number_of_lines_in_vsync, + u32 number_of_lines_in_command_allow) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + u32 newvalue; + + pregister = __g_pregister[module_index]; + newvalue = (1 << 25); + newvalue |= ((1 - enable_auto_flush_main_display_fifo) << 29); + newvalue |= (enable_auto_vertical_count << 24); + newvalue |= (enable_burst << 26); + newvalue |= (sync_mode << 27); + newvalue |= ((1 - enable_eo_tpacket) << 28); + newvalue |= (enable_hsync_end_packet << 23); + newvalue |= ((1 - enable_hfp) << 22); + newvalue |= ((1 - enable_hbp) << 21); + newvalue |= ((1 - enable_hsa) << 20); + newvalue |= (number_of_virtual_channel << 18); + newvalue |= (format << 12); + + writereg(dsim_config, 0xFFFFFF00, newvalue); + + newvalue = (number_of_lines_in_command_allow << 28); + newvalue |= (number_of_lines_in_vfp << 16); + newvalue |= (number_of_lines_in_vbp << 0); + + writel(newvalue, &pregister->dsim_mvporch); + + newvalue = (number_of_words_in_hfp << 16); + newvalue |= (number_of_words_in_hbp << 0); + + writel(newvalue, &pregister->dsim_mhporch); + + newvalue = (number_of_words_in_hsync << 0); + newvalue |= (number_of_lines_in_vsync << 22); + + writel(newvalue, &pregister->dsim_msync); +} + +void nx_mipi_dsi_set_config_command_mode(u32 module_index, + int + enable_auto_flush_main_display_fifo, + int enable_eo_tpacket, + u32 number_of_virtual_channel, + enum nx_mipi_dsi_format format) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + u32 newvalue; + + pregister = __g_pregister[module_index]; + newvalue = (0 << 25); + newvalue |= (enable_auto_flush_main_display_fifo << 29); + newvalue |= (enable_eo_tpacket << 28); + newvalue |= (number_of_virtual_channel << 18); + newvalue |= (format << 12); + writereg(dsim_config, 0xFFFFFF00, newvalue); +} + +void nx_mipi_dsi_set_escape_mode(u32 module_index, u32 stop_state_count, + int force_stop_state, int force_bta, + enum nx_mipi_dsi_lpmode cmdin_lp, + enum nx_mipi_dsi_lpmode txinlp) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + u32 newvalue; + + pregister = __g_pregister[module_index]; + newvalue = (stop_state_count << 21); + newvalue |= (force_stop_state << 20); + newvalue |= (force_bta << 16); + newvalue |= (cmdin_lp << 7); + newvalue |= (txinlp << 6); + writereg(dsim_escmode, 0xFFFFFFC0, newvalue); +} + +void nx_mipi_dsi_set_escape_lp(u32 module_index, + enum nx_mipi_dsi_lpmode cmdin_lp, + enum nx_mipi_dsi_lpmode txinlp) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + u32 newvalue = 0; + + pregister = __g_pregister[module_index]; + newvalue |= (cmdin_lp << 7); + newvalue |= (txinlp << 6); + writereg(dsim_escmode, 0xC0, newvalue); +} + +void nx_mipi_dsi_remote_reset_trigger(u32 module_index) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + u32 newvalue; + + pregister = __g_pregister[module_index]; + newvalue = (1 << 4); + writereg(dsim_escmode, (1 << 4), newvalue); + + while (readl(&pregister->dsim_escmode) & (1 << 4)) + ; +} + +void nx_mipi_dsi_set_ulps(u32 module_index, int ulpsclocklane, int ulpsdatalane) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + + pregister = __g_pregister[module_index]; + regvalue = pregister->dsim_escmode; + + if (ulpsclocklane) { + regvalue &= ~(1 << 0); + regvalue |= (1 << 1); + } else { + regvalue |= (1 << 0); + } + + if (ulpsdatalane) { + regvalue &= ~(1 << 2); + regvalue |= (1 << 3); + } else { + regvalue |= (1 << 2); + } + + writel(regvalue, &pregister->dsim_escmode); + + if (ulpsclocklane) + while ((1 << 9) == + (readl(&pregister->dsim_status) & (1 << 9))) + ; + else + while (0 != (readl(&pregister->dsim_status) & (1 << 9))) + ; + + if (ulpsdatalane) + while ((15 << 4) == + (readl(&pregister->dsim_status) & (15 << 4))) + ; + else + while (0 != (readl(&pregister->dsim_status) & (15 << 4))) + ; + + if (!ulpsclocklane) + regvalue &= (3 << 0); + + if (!ulpsdatalane) + regvalue |= (3 << 2); + + writel(regvalue, &pregister->dsim_escmode); +} + +void nx_mipi_dsi_set_size(u32 module_index, u32 width, u32 height) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + u32 newvalue; + + pregister = __g_pregister[module_index]; + newvalue = (height << 16); + newvalue |= (width << 0); + writereg(dsim_mdresol, 0x0FFFFFFF, newvalue); +} + +void nx_mipi_dsi_set_enable(u32 module_index, int enable) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + + pregister = __g_pregister[module_index]; + writereg(dsim_mdresol, (1 << 31), (enable << 31)); +} + +void nx_mipi_dsi_set_phy(u32 module_index, u32 number_of_data_lanes, + int enable_clock_lane, int enable_data_lane0, + int enable_data_lane1, int enable_data_lane2, + int enable_data_lane3, int swap_clock_lane, + int swap_data_lane) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + u32 newvalue; + + pregister = __g_pregister[module_index]; + newvalue = (number_of_data_lanes << 5); + newvalue |= (enable_clock_lane << 0); + newvalue |= (enable_data_lane0 << 1); + newvalue |= (enable_data_lane1 << 2); + newvalue |= (enable_data_lane2 << 3); + newvalue |= (enable_data_lane3 << 4); + writereg(dsim_config, 0xFF, newvalue); + newvalue = (swap_clock_lane << 1); + newvalue |= (swap_data_lane << 0); + writereg(dsim_phyacchr1, 0x3, newvalue); +} + +void nx_mipi_dsi_set_pll(u32 module_index, int enable, u32 pllstabletimer, + u32 m_pllpms, u32 m_bandctl, u32 m_dphyctl, + u32 b_dphyctl) +{ + register struct nx_mipi_register_set *pregister; + register u32 regvalue; + u32 newvalue; + + pregister = __g_pregister[module_index]; + if (!enable) { + newvalue = (enable << 23); + newvalue |= (m_pllpms << 1); + newvalue |= (m_bandctl << 24); + writereg(dsim_pllctrl, 0x0FFFFFFF, newvalue); + } + + writel(m_dphyctl, &pregister->dsim_phyacchr); + writel(pllstabletimer, &pregister->dsim_plltmr); + writel((b_dphyctl << 9), &pregister->dsim_phyacchr1); + + if (enable) { + newvalue = (enable << 23); + newvalue |= (m_pllpms << 1); + newvalue |= (m_bandctl << 24); + writereg(dsim_pllctrl, 0x0FFFFFFF, newvalue); + } +} + +void nx_mipi_dsi_write_pkheader(u32 module_index, u32 data) +{ + register struct nx_mipi_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(data, &pregister->dsim_pkthdr); +} + +void nx_mipi_dsi_write_payload(u32 module_index, u32 data) +{ + register struct nx_mipi_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(data, &pregister->dsim_payload); +} + +u32 nx_mipi_dsi_read_fifo_status(u32 module_index) +{ + register struct nx_mipi_register_set *pregister; + + pregister = __g_pregister[module_index]; + return readl(&pregister->dsim_fifoctrl); +} diff --git a/drivers/video/nexell/soc/s5pxx18_soc_mipi.h b/drivers/video/nexell/soc/s5pxx18_soc_mipi.h new file mode 100644 index 0000000..63751ca --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_mipi.h @@ -0,0 +1,291 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _S5PXX18_SOC_MIPI_H_ +#define _S5PXX18_SOC_MIPI_H_ + +#define NUMBER_OF_MIPI_MODULE 1 +#define PHY_BASEADDR_MIPI_MODULE 0xC00D0000 +#define PHY_BASEADDR_MIPI_LIST \ + { PHY_BASEADDR_MIPI_MODULE } + +#define nx_mipi_numberof_csi_channels 2 + +struct nx_mipi_register_set { + u32 csis_control; + u32 csis_dphyctrl; + u32 csis_config_ch0; + u32 csis_dphysts; + u32 csis_intmsk; + u32 csis_intsrc; + u32 csis_ctrl2; + u32 csis_version; + u32 csis_dphyctrl_0; + u32 csis_dphyctrl_1; + u32 __reserved0; + u32 csis_resol_ch0; + u32 __reserved1; + u32 __reserved2; + u32 sdw_config_ch0; + u32 sdw_resol_ch0; + u32 csis_config_ch1; + u32 csis_resol_ch1; + u32 sdw_config_ch1; + u32 sdw_resol_ch1; + u32 csis_config_ch2; + u32 csis_resol_ch2; + u32 sdw_config_ch2; + u32 sdw_resol_ch2; + u32 csis_config_ch3; + u32 csis_resol_ch3; + u32 sdw_config_ch3; + u32 sdw_resol_3; + u32 __reserved3[(16 + 128) / 4]; + + u32 dsim_status; + u32 dsim_swrst; + u32 dsim_clkctrl; + u32 dsim_timeout; + u32 dsim_config; + u32 dsim_escmode; + u32 dsim_mdresol; + u32 dsim_mvporch; + u32 dsim_mhporch; + u32 dsim_msync; + u32 dsim_sdresol; + u32 dsim_intsrc; + u32 dsim_intmsk; + u32 dsim_pkthdr; + u32 dsim_payload; + u32 dsim_rxfifo; + u32 dsim_fifothld; + u32 dsim_fifoctrl; + u32 dsim_memacchr; + u32 dsim_pllctrl; + u32 dsim_plltmr; + u32 dsim_phyacchr; + u32 dsim_phyacchr1; + + u32 __reserved4[(0x2000 - 0x015C) / 4]; + u32 mipi_csis_pktdata[0x2000 / 4]; +}; + +enum nx_mipi_dsi_syncmode { + nx_mipi_dsi_syncmode_event = 0, + nx_mipi_dsi_syncmode_pulse = 1, +}; + +enum nx_mipi_dsi_format { + nx_mipi_dsi_format_command3 = 0, + nx_mipi_dsi_format_command8 = 1, + nx_mipi_dsi_format_command12 = 2, + nx_mipi_dsi_format_command16 = 3, + nx_mipi_dsi_format_rgb565 = 4, + nx_mipi_dsi_format_rgb666_packed = 5, + nx_mipi_dsi_format_rgb666 = 6, + nx_mipi_dsi_format_rgb888 = 7 +}; + +enum nx_mipi_dsi_lpmode { + nx_mipi_dsi_lpmode_hs = 0, + nx_mipi_dsi_lpmode_lp = 1 +}; + +enum nx_mipi_phy_b_dphyctl { + nx_mipi_phy_b_dphyctl_m_txclkesc_20_mhz = 0x1F4, + nx_mipi_phy_b_dphyctl_m_txclkesc_19_mhz = 0x1DB, + nx_mipi_phy_b_dphyctl_m_txclkesc_18_mhz = 0x1C2, + nx_mipi_phy_b_dphyctl_m_txclkesc_17_mhz = 0x1A9, + nx_mipi_phy_b_dphyctl_m_txclkesc_16_mhz = 0x190, + nx_mipi_phy_b_dphyctl_m_txclkesc_15_mhz = 0x177, + nx_mipi_phy_b_dphyctl_m_txclkesc_14_mhz = 0x15E, + nx_mipi_phy_b_dphyctl_m_txclkesc_13_mhz = 0x145, + nx_mipi_phy_b_dphyctl_m_txclkesc_12_mhz = 0x12C, + nx_mipi_phy_b_dphyctl_m_txclkesc_11_mhz = 0x113, + nx_mipi_phy_b_dphyctl_m_txclkesc_10_mhz = 0x0FA, + nx_mipi_phy_b_dphyctl_m_txclkesc_9_mhz = 0x0E1, + nx_mipi_phy_b_dphyctl_m_txclkesc_8_mhz = 0x0C8, + nx_mipi_phy_b_dphyctl_m_txclkesc_7_mhz = 0x0AF, + nx_mipi_phy_b_dphyctl_m_txclkesc_6_mhz = 0x096, + nx_mipi_phy_b_dphyctl_m_txclkesc_5_mhz = 0x07D, + nx_mipi_phy_b_dphyctl_m_txclkesc_4_mhz = 0x064, + nx_mipi_phy_b_dphyctl_m_txclkesc_3_mhz = 0x04B, + nx_mipi_phy_b_dphyctl_m_txclkesc_2_mhz = 0x032, + nx_mipi_phy_b_dphyctl_m_txclkesc_1_mhz = 0x019, + nx_mipi_phy_b_dphyctl_m_txclkesc_0_10_mhz = 0x003, + nx_mipi_phy_b_dphyctl_m_txclkesc_0_01_mhz = 0x000 +}; + +enum { + nx_mipi_rst = 0, + nx_mipi_rst_dsi_i, + nx_mipi_rst_csi_i, + nx_mipi_rst_phy_s, + nx_mipi_rst_phy_m +}; + +enum nx_mipi_int { + nx_mipi_int_csi_even_before = 31, + nx_mipi_int_csi_even_after = 30, + nx_mipi_int_csi_odd_before = 29, + nx_mipi_int_csi_odd_after = 28, + nx_mipi_int_csi_frame_start_ch3 = 27, + nx_mipi_int_csi_frame_start_ch2 = 26, + nx_mipi_int_csi_frame_start_ch1 = 25, + nx_mipi_int_csi_frame_start_ch0 = 24, + nx_mipi_int_csi_frame_end_ch3 = 23, + nx_mipi_int_csi_frame_end_ch2 = 22, + nx_mipi_int_csi_frame_end_ch1 = 21, + nx_mipi_int_csi_frame_end_ch0 = 20, + nx_mipi_int_csi_err_sot_hs_ch3 = 19, + nx_mipi_int_csi_err_sot_hs_ch2 = 18, + nx_mipi_int_csi_err_sot_hs_ch1 = 17, + nx_mipi_int_csi_err_sot_hs_ch0 = 16, + nx_mipi_int_csi_err_lost_fs_ch3 = 15, + nx_mipi_int_csi_err_lost_fs_ch2 = 14, + nx_mipi_int_csi_err_lost_fs_ch1 = 13, + nx_mipi_int_csi_err_lost_fs_ch0 = 12, + nx_mipi_int_csi_err_lost_fe_ch3 = 11, + nx_mipi_int_csi_err_lost_fe_ch2 = 10, + nx_mipi_int_csi_err_lost_fe_ch1 = 9, + nx_mipi_int_csi_err_lost_fe_ch0 = 8, + nx_mipi_int_csi_err_over_ch3 = 7, + nx_mipi_int_csi_err_over_ch2 = 6, + nx_mipi_int_csi_err_over_ch1 = 5, + nx_mipi_int_csi_err_over_ch0 = 4, + + nx_mipi_int_csi_err_ecc = 2, + nx_mipi_int_csi_err_crc = 1, + nx_mipi_int_csi_err_id = 0, + nx_mipi_int_dsi_pll_stable = 32 + 31, + nx_mipi_int_dsi_sw_rst_release = 32 + 30, + nx_mipi_int_dsi_sfrplfifoempty = 32 + 29, + nx_mipi_int_dsi_sfrphfifoempty = 32 + 28, + nx_mipi_int_dsi_sync_override = 32 + 27, + + nx_mipi_int_dsi_bus_turn_over = 32 + 25, + nx_mipi_int_dsi_frame_done = 32 + 24, + + nx_mipi_int_dsi_lpdr_tout = 32 + 21, + nx_mipi_int_dsi_ta_tout = 32 + 20, + + nx_mipi_int_dsi_rx_dat_done = 32 + 18, + nx_mipi_int_dsi_rx_te = 32 + 17, + nx_mipi_int_dsi_rx_ack = 32 + 16, + nx_mipi_int_dsi_err_rx_ecc = 32 + 15, + nx_mipi_int_dsi_err_rx_crc = 32 + 14, + nx_mipi_int_dsi_err_esc3 = 32 + 13, + nx_mipi_int_dsi_err_esc2 = 32 + 12, + nx_mipi_int_dsi_err_esc1 = 32 + 11, + nx_mipi_int_dsi_err_esc0 = 32 + 10, + nx_mipi_int_dsi_err_sync3 = 32 + 9, + nx_mipi_int_dsi_err_sync2 = 32 + 8, + nx_mipi_int_dsi_err_sync1 = 32 + 7, + nx_mipi_int_dsi_err_sync0 = 32 + 6, + nx_mipi_int_dsi_err_control3 = 32 + 5, + nx_mipi_int_dsi_err_control2 = 32 + 4, + nx_mipi_int_dsi_err_control1 = 32 + 3, + nx_mipi_int_dsi_err_control0 = 32 + 2, + nx_mipi_int_dsi_err_content_lp0 = 32 + 1, + nx_mipi_int_dsi_err_content_lp1 = 32 + 0, +}; + +#define DSI_TX_FIFO_SIZE 2048 +#define DSI_RX_FIFO_SIZE 256 +#define DSI_RX_FIFO_EMPTY 0x30800002 + +void nx_mipi_dsi_get_status(u32 module_index, u32 *pulps, u32 *pstop, + u32 *pispllstable, u32 *pisinreset, + u32 *pisbackward, u32 *pishsclockready); + +void nx_mipi_dsi_software_reset(u32 module_index); + +void nx_mipi_dsi_set_clock(u32 module_index, int enable_txhsclock, + int use_external_clock, int enable_byte_clock, + int enable_escclock_clock_lane, + int enable_escclock_data_lane0, + int enable_escclock_data_lane1, + int enable_escclock_data_lane2, + int enable_escclock_data_lane3, + int enable_escprescaler, + u32 escprescalervalue); + +void nx_mipi_dsi_set_timeout(u32 module_index, u32 bta_tout, + u32 lpdrtout); + +void nx_mipi_dsi_set_config_video_mode(u32 module_index, + int enable_auto_flush_main_display_fifo, + int enable_auto_vertical_count, + int enable_burst, + enum nx_mipi_dsi_syncmode + sync_mode, int enable_eo_tpacket, + int enable_hsync_end_packet, + int enable_hfp, int enable_hbp, + int enable_hsa, + u32 number_of_virtual_channel, + enum nx_mipi_dsi_format format, + u32 number_of_words_in_hfp, + u32 number_of_words_in_hbp, + u32 number_of_words_in_hsync, + u32 number_of_lines_in_vfp, + u32 number_of_lines_in_vbp, + u32 number_of_lines_in_vsync, + u32 number_of_lines_in_command_allow); + +void nx_mipi_dsi_set_config_command_mode(u32 module_index, + int enable_auto_flush_main_display_fifo, + int enable_eo_tpacket, + u32 number_of_virtual_channel, + enum nx_mipi_dsi_format format); + +void nx_mipi_dsi_set_escape_mode(u32 module_index, u32 stop_state_count, + int force_stop_state, int force_bta, + enum nx_mipi_dsi_lpmode cmdin_lp, + enum nx_mipi_dsi_lpmode txinlp); +void nx_mipi_dsi_set_escape_lp(u32 module_index, + enum nx_mipi_dsi_lpmode cmdin_lp, + enum nx_mipi_dsi_lpmode txinlp); + +void nx_mipi_dsi_remote_reset_trigger(u32 module_index); +void nx_mipi_dsi_set_ulps(u32 module_index, int ulpsclocklane, + int ulpsdatalane); +void nx_mipi_dsi_set_size(u32 module_index, u32 width, u32 height); +void nx_mipi_dsi_set_enable(u32 module_index, int enable); +void nx_mipi_dsi_set_phy(u32 module_index, u32 number_of_data_lanes, + int enable_clock_lane, int enable_data_lane0, + int enable_data_lane1, int enable_data_lane2, + int enable_data_lane3, int swap_clock_lane, + int swap_data_lane); + +void nx_mipi_dsi_set_pll(u32 module_index, int enable, + u32 pllstabletimer, u32 m_pllpms, u32 m_bandctl, + u32 m_dphyctl, u32 b_dphyctl); + +void nx_mipi_dsi_write_pkheader(u32 module_index, u32 data); +void nx_mipi_dsi_write_payload(u32 module_index, u32 data); +u32 nx_mipi_dsi_read_fifo(u32 module_index); +u32 nx_mipi_dsi_read_fifo_status(u32 module_index); + +int nx_mipi_smoke_test(u32 module_index); +void nx_mipi_set_base_address(u32 module_index, void *base_address); +void *nx_mipi_get_base_address(u32 module_index); +u32 nx_mipi_get_physical_address(u32 module_index); + +void nx_mipi_dsi_set_interrupt_enable_all(u32 module_index, int enable); +void nx_mipi_dsi_set_interrupt_enable(u32 module_index, + u32 int_num, int enable); +int nx_mipi_dsi_get_interrupt_enable(u32 module_index, u32 int_num); +int nx_mipi_dsi_get_interrupt_enable_all(u32 module_index); + +int nx_mipi_dsi_get_interrupt_pending(u32 module_index, u32 int_num); +int nx_mipi_dsi_get_interrupt_pending_all(u32 module_index); +int32_t nx_mipi_dsi_get_interrupt_pending_number(u32 module_index); + +void nx_mipi_dsi_clear_interrupt_pending(u32 module_index, u32 int_num); +void nx_mipi_dsi_clear_interrupt_pending_all(u32 module_index); + +#endif diff --git a/drivers/video/nexell/soc/s5pxx18_soc_mlc.c b/drivers/video/nexell/soc/s5pxx18_soc_mlc.c new file mode 100644 index 0000000..c8cf833 --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_mlc.c @@ -0,0 +1,1861 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <linux/types.h> +#include <linux/io.h> + +#include "s5pxx18_soc_mlc.h" + +static struct { + struct nx_mlc_register_set *pregister; +} __g_module_variables[NUMBER_OF_MLC_MODULE] = { { NULL, },}; + +int nx_mlc_initialize(void) +{ + static int binit; + u32 i; + + if (binit == 0) { + for (i = 0; i < NUMBER_OF_MLC_MODULE; i++) + __g_module_variables[i].pregister = NULL; + binit = 1; + } + return 1; +} + +u32 nx_mlc_get_physical_address(u32 module_index) +{ + const u32 physical_addr[] = PHY_BASEADDR_MLC_LIST; + + return physical_addr[module_index]; +} + +void nx_mlc_set_base_address(u32 module_index, void *base_address) +{ + __g_module_variables[module_index].pregister = + (struct nx_mlc_register_set *)base_address; +} + +void *nx_mlc_get_base_address(u32 module_index) +{ + return (void *)__g_module_variables[module_index].pregister; +} + +void nx_mlc_set_clock_pclk_mode(u32 module_index, enum nx_pclkmode mode) +{ + const u32 pclkmode_pos = 3; + u32 clkmode = 0; + + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + switch (mode) { + case nx_pclkmode_dynamic: + clkmode = 0; + break; + case nx_pclkmode_always: + clkmode = 1; + break; + default: + break; + } + regvalue = pregister->mlcclkenb; + regvalue &= ~(1ul << pclkmode_pos); + regvalue |= (clkmode & 0x01) << pclkmode_pos; + + writel(regvalue, &pregister->mlcclkenb); +} + +enum nx_pclkmode nx_mlc_get_clock_pclk_mode(u32 module_index) +{ + const u32 pclkmode_pos = 3; + + if (__g_module_variables[module_index].pregister->mlcclkenb & + (1ul << pclkmode_pos)) { + return nx_pclkmode_always; + } + return nx_pclkmode_dynamic; +} + +void nx_mlc_set_clock_bclk_mode(u32 module_index, enum nx_bclkmode mode) +{ + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + u32 clkmode = 0; + + pregister = __g_module_variables[module_index].pregister; + switch (mode) { + case nx_bclkmode_disable: + clkmode = 0; + break; + case nx_bclkmode_dynamic: + clkmode = 2; + break; + case nx_bclkmode_always: + clkmode = 3; + break; + default: + break; + } + regvalue = pregister->mlcclkenb; + regvalue &= ~(0x3); + regvalue |= clkmode & 0x3; + + writel(regvalue, &pregister->mlcclkenb); +} + +enum nx_bclkmode nx_mlc_get_clock_bclk_mode(u32 module_index) +{ + const u32 bclkmode = 3ul << 0; + + switch (__g_module_variables[module_index].pregister->mlcclkenb & + bclkmode) { + case 0: + return nx_bclkmode_disable; + case 2: + return nx_bclkmode_dynamic; + case 3: + return nx_bclkmode_always; + } + return nx_bclkmode_disable; +} + +void nx_mlc_set_top_power_mode(u32 module_index, int bpower) +{ + const u32 pixelbuffer_pwd_pos = 11; + const u32 pixelbuffer_pwd_mask = 1ul << pixelbuffer_pwd_pos; + const u32 dittyflag_mask = 1ul << 3; + register struct nx_mlc_register_set *pregister; + register u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->mlccontrolt; + regvalue &= ~(pixelbuffer_pwd_mask | dittyflag_mask); + regvalue |= (bpower << pixelbuffer_pwd_pos); + + writel(regvalue, &pregister->mlccontrolt); +} + +int nx_mlc_get_top_power_mode(u32 module_index) +{ + const u32 pixelbuffer_pwd_pos = 11; + const u32 pixelbuffer_pwd_mask = 1ul << pixelbuffer_pwd_pos; + + return (int)((__g_module_variables[module_index].pregister->mlccontrolt + & pixelbuffer_pwd_mask) >> + pixelbuffer_pwd_pos); +} + +void nx_mlc_set_top_sleep_mode(u32 module_index, int bsleep) +{ + const u32 pixelbuffer_sld_pos = 10; + const u32 pixelbuffer_sld_mask = 1ul << pixelbuffer_sld_pos; + const u32 dittyflag_mask = 1ul << 3; + register struct nx_mlc_register_set *pregister; + register u32 regvalue; + + bsleep = (int)((u32)bsleep ^ 1); + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->mlccontrolt; + regvalue &= ~(pixelbuffer_sld_mask | dittyflag_mask); + regvalue |= (bsleep << pixelbuffer_sld_pos); + + writel(regvalue, &pregister->mlccontrolt); +} + +int nx_mlc_get_top_sleep_mode(u32 module_index) +{ + const u32 pixelbuffer_sld_pos = 11; + const u32 pixelbuffer_sld_mask = 1ul << pixelbuffer_sld_pos; + + return (int)(((__g_module_variables[module_index].pregister->mlccontrolt + & pixelbuffer_sld_mask) >> + pixelbuffer_sld_pos) ^ 0x01); +} + +void nx_mlc_set_top_dirty_flag(u32 module_index) +{ + const u32 dirtyflag = 1ul << 3; + register struct nx_mlc_register_set *pregister; + register u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->mlccontrolt; + regvalue |= dirtyflag; + + writel(regvalue, &pregister->mlccontrolt); +} + +int nx_mlc_get_top_dirty_flag(u32 module_index) +{ + const u32 dirtyflag_pos = 3; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + + return (int)((readl(&__g_module_variables[module_index] + .pregister->mlccontrolt) & + dirtyflag_mask) >> dirtyflag_pos); +} + +void nx_mlc_set_mlc_enable(u32 module_index, int benb) +{ + const u32 mlcenb_pos = 1; + const u32 mlcenb_mask = 1ul << mlcenb_pos; + const u32 dirtyflag_pos = 3; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->mlccontrolt; + regvalue &= ~(mlcenb_mask | dirtyflag_mask); + regvalue |= (benb << mlcenb_pos); + + writel(regvalue, &pregister->mlccontrolt); +} + +int nx_mlc_get_mlc_enable(u32 module_index) +{ + const u32 mlcenb_pos = 1; + const u32 mlcenb_mask = 1ul << mlcenb_pos; + + return (int)((__g_module_variables[module_index].pregister->mlccontrolt + & mlcenb_mask) >> mlcenb_pos); +} + +void nx_mlc_set_field_enable(u32 module_index, int benb) +{ + const u32 fieldenb_pos = 0; + const u32 fieldenb_mask = 1ul << fieldenb_pos; + const u32 dirtyflag_pos = 3; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->mlccontrolt; + regvalue &= ~(fieldenb_mask | dirtyflag_mask); + regvalue |= (benb << fieldenb_pos); + + writel(regvalue, &pregister->mlccontrolt); +} + +int nx_mlc_get_field_enable(u32 module_index) +{ + const u32 fieldenb_pos = 0; + const u32 fieldenb_mask = 1ul << fieldenb_pos; + + return (int)(__g_module_variables[module_index].pregister->mlccontrolt & + fieldenb_mask); +} + +void nx_mlc_set_layer_priority(u32 module_index, enum nx_mlc_priority priority) +{ + const u32 priority_pos = 8; + const u32 priority_mask = 0x03 << priority_pos; + const u32 dirtyflag_pos = 3; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + register struct nx_mlc_register_set *pregister; + register u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->mlccontrolt; + regvalue &= ~(priority_mask | dirtyflag_mask); + regvalue |= (priority << priority_pos); + + writel(regvalue, &pregister->mlccontrolt); +} + +void nx_mlc_set_screen_size(u32 module_index, u32 width, u32 height) +{ + register struct nx_mlc_register_set *pregister; + register u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + regvalue = ((height - 1) << 16) | (width - 1); + + writel(regvalue, &pregister->mlcscreensize); +} + +void nx_mlc_get_screen_size(u32 module_index, u32 *pwidth, u32 *pheight) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + if (pwidth) + *pwidth = (pregister->mlcscreensize & 0x0fff) + 1; + + if (pheight) + *pheight = ((pregister->mlcscreensize >> 16) & 0x0fff) + 1; +} + +void nx_mlc_set_background(u32 module_index, u32 color) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(color, &pregister->mlcbgcolor); +} + +void nx_mlc_set_dirty_flag(u32 module_index, u32 layer) +{ + register struct nx_mlc_register_set *pregister; + register u32 regvalue; + const u32 dirtyflg_mask = 1ul << 4; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + regvalue = pregister->mlcrgblayer[layer].mlccontrol; + regvalue |= dirtyflg_mask; + + writel(regvalue, &pregister->mlcrgblayer[layer].mlccontrol); + } else if (layer == 3) { + regvalue = pregister->mlcvideolayer.mlccontrol; + regvalue |= dirtyflg_mask; + + writel(regvalue, &pregister->mlcvideolayer.mlccontrol); + } +} + +int nx_mlc_get_dirty_flag(u32 module_index, u32 layer) +{ + const u32 dirtyflg_pos = 4; + const u32 dirtyflg_mask = 1ul << dirtyflg_pos; + + if (layer == 0 || layer == 1) { + return (int)((__g_module_variables[module_index] + .pregister->mlcrgblayer[layer] + .mlccontrol & dirtyflg_mask) >> dirtyflg_pos); + } else if (layer == 2) { + return (int)((__g_module_variables[module_index] + .pregister->mlcrgblayer2.mlccontrol & + dirtyflg_mask) >> dirtyflg_pos); + } else if (layer == 3) { + return (int)((__g_module_variables[module_index] + .pregister->mlcvideolayer.mlccontrol & + dirtyflg_mask) >> dirtyflg_pos); + } + return 0; +} + +void nx_mlc_set_layer_enable(u32 module_index, u32 layer, int benb) +{ + const u32 layerenb_pos = 5; + const u32 layerenb_mask = 0x01 << layerenb_pos; + const u32 dirtyflag_pos = 4; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + regvalue = pregister->mlcrgblayer[layer].mlccontrol; + regvalue &= ~(layerenb_mask | dirtyflag_mask); + regvalue |= (benb << layerenb_pos); + + writel(regvalue, &pregister->mlcrgblayer[layer].mlccontrol); + } else if (layer == 3) { + regvalue = pregister->mlcvideolayer.mlccontrol; + regvalue &= ~(layerenb_mask | dirtyflag_mask); + regvalue |= (benb << layerenb_pos); + + writel(regvalue, &pregister->mlcvideolayer.mlccontrol); + } +} + +int nx_mlc_get_layer_enable(u32 module_index, u32 layer) +{ + const u32 layerenb_pos = 5; + const u32 layerenb_mask = 0x01 << layerenb_pos; + + if (layer == 0 || layer == 1) { + return (int)((__g_module_variables[module_index] + .pregister->mlcrgblayer[layer] + .mlccontrol & layerenb_mask) >> layerenb_pos); + } else if (layer == 3) { + return (int)((__g_module_variables[module_index] + .pregister->mlcvideolayer.mlccontrol & + layerenb_mask) >> layerenb_pos); + } + return 0; +} + +void nx_mlc_set_lock_size(u32 module_index, u32 layer, u32 locksize) +{ + const u32 locksize_mask = 3ul << 12; + const u32 dirtyflag_pos = 4; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + register struct nx_mlc_register_set *pregister; + register u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + locksize >>= 3; + if (layer == 0 || layer == 1) { + regvalue = pregister->mlcrgblayer[layer].mlccontrol; + regvalue &= ~(locksize_mask | dirtyflag_mask); + regvalue |= (locksize << 12); + + writel(regvalue, &pregister->mlcrgblayer[layer].mlccontrol); + } +} + +void nx_mlc_set_alpha_blending(u32 module_index, u32 layer, int benb, u32 alpha) +{ + const u32 blendenb_pos = 2; + const u32 blendenb_mask = 0x01 << blendenb_pos; + const u32 dirtyflag_pos = 4; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + const u32 alpha_pos = 28; + const u32 alpha_mask = 0xf << alpha_pos; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + regvalue = pregister->mlcrgblayer[layer].mlccontrol; + regvalue &= ~(blendenb_mask | dirtyflag_mask); + regvalue |= (benb << blendenb_pos); + + writel(regvalue, &pregister->mlcrgblayer[layer].mlccontrol); + regvalue = pregister->mlcrgblayer[layer].mlctpcolor; + regvalue &= ~alpha_mask; + regvalue |= alpha << alpha_pos; + + writel(regvalue, &pregister->mlcrgblayer[layer].mlctpcolor); + } else if (layer == 3) { + regvalue = pregister->mlcvideolayer.mlccontrol; + regvalue &= ~(blendenb_mask | dirtyflag_mask); + regvalue |= (benb << blendenb_pos); + + writel(regvalue, &pregister->mlcvideolayer.mlccontrol); + + writel(alpha << alpha_pos, + &pregister->mlcvideolayer.mlctpcolor); + } +} + +void nx_mlc_set_transparency(u32 module_index, u32 layer, int benb, u32 color) +{ + const u32 tpenb_pos = 0; + const u32 tpenb_mask = 0x01 << tpenb_pos; + const u32 dirtyflag_pos = 4; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + const u32 tpcolor_pos = 0; + const u32 tpcolor_mask = ((1 << 24) - 1) << tpcolor_pos; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + regvalue = pregister->mlcrgblayer[layer].mlccontrol; + regvalue &= ~(tpenb_mask | dirtyflag_mask); + regvalue |= (benb << tpenb_pos); + + writel(regvalue, &pregister->mlcrgblayer[layer].mlccontrol); + regvalue = pregister->mlcrgblayer[layer].mlctpcolor; + regvalue &= ~tpcolor_mask; + regvalue |= (color & tpcolor_mask); + + writel(regvalue, &pregister->mlcrgblayer[layer].mlctpcolor); + } +} + +void nx_mlc_set_color_inversion(u32 module_index, u32 layer, int benb, + u32 color) +{ + const u32 invenb_pos = 1; + const u32 invenb_mask = 0x01 << invenb_pos; + const u32 dirtyflag_pos = 4; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + const u32 invcolor_pos = 0; + const u32 invcolor_mask = ((1 << 24) - 1) << invcolor_pos; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + regvalue = pregister->mlcrgblayer[layer].mlccontrol; + regvalue &= ~(invenb_mask | dirtyflag_mask); + regvalue |= (benb << invenb_pos); + + writel(regvalue, &pregister->mlcrgblayer[layer].mlccontrol); + regvalue = pregister->mlcrgblayer[layer].mlcinvcolor; + regvalue &= ~invcolor_mask; + regvalue |= (color & invcolor_mask); + + writel(regvalue, &pregister->mlcrgblayer[layer].mlcinvcolor); + } +} + +u32 nx_mlc_get_extended_color(u32 module_index, u32 color, + enum nx_mlc_rgbfmt format) +{ + u32 rgb[3] = { + 0, + }; + u32 bw[3] = { + 0, + }; + u32 bp[3] = { + 0, + }; + u32 blank = 0; + u32 fill = 0; + u32 i = 0; + + switch (format) { + case nx_mlc_rgbfmt_r5g6b5: + bw[0] = 5; + bw[1] = 6; + bw[2] = 5; + bp[0] = 11; + bp[1] = 5; + bp[2] = 0; + break; + case nx_mlc_rgbfmt_b5g6r5: + bw[0] = 5; + bw[1] = 6; + bw[2] = 5; + bp[0] = 0; + bp[1] = 5; + bp[2] = 11; + break; + case nx_mlc_rgbfmt_x1r5g5b5: + case nx_mlc_rgbfmt_a1r5g5b5: + bw[0] = 5; + bw[1] = 5; + bw[2] = 5; + bp[0] = 10; + bp[1] = 5; + bp[2] = 0; + break; + case nx_mlc_rgbfmt_x1b5g5r5: + case nx_mlc_rgbfmt_a1b5g5r5: + bw[0] = 5; + bw[1] = 5; + bw[2] = 5; + bp[0] = 0; + bp[1] = 5; + bp[2] = 10; + break; + case nx_mlc_rgbfmt_x4r4g4b4: + case nx_mlc_rgbfmt_a4r4g4b4: + bw[0] = 4; + bw[1] = 4; + bw[2] = 4; + bp[0] = 8; + bp[1] = 4; + bp[2] = 0; + break; + case nx_mlc_rgbfmt_x4b4g4r4: + case nx_mlc_rgbfmt_a4b4g4r4: + bw[0] = 4; + bw[1] = 4; + bw[2] = 4; + bp[0] = 0; + bp[1] = 4; + bp[2] = 8; + break; + case nx_mlc_rgbfmt_x8r3g3b2: + case nx_mlc_rgbfmt_a8r3g3b2: + bw[0] = 3; + bw[1] = 3; + bw[2] = 2; + bp[0] = 5; + bp[1] = 2; + bp[2] = 0; + break; + case nx_mlc_rgbfmt_x8b3g3r2: + case nx_mlc_rgbfmt_a8b3g3r2: + bw[0] = 2; + bw[1] = 3; + bw[2] = 3; + bp[0] = 0; + bp[1] = 2; + bp[2] = 5; + break; + case nx_mlc_rgbfmt_r8g8b8: + case nx_mlc_rgbfmt_a8r8g8b8: + bw[0] = 8; + bw[1] = 8; + bw[2] = 8; + bp[0] = 16; + bp[1] = 8; + bp[2] = 0; + break; + case nx_mlc_rgbfmt_b8g8r8: + case nx_mlc_rgbfmt_a8b8g8r8: + bw[0] = 8; + bw[1] = 8; + bw[2] = 8; + bp[0] = 0; + bp[1] = 8; + bp[2] = 16; + break; + default: + break; + } + for (i = 0; i < 3; i++) { + rgb[i] = (color >> bp[i]) & ((u32)(1 << bw[i]) - 1); + fill = bw[i]; + blank = 8 - fill; + rgb[i] <<= blank; + while (blank > 0) { + rgb[i] |= (rgb[i] >> fill); + blank -= fill; + fill += fill; + } + } + + return (rgb[0] << 16) | (rgb[1] << 8) | (rgb[2] << 0); +} + +void nx_mlc_set_format_rgb(u32 module_index, u32 layer, + enum nx_mlc_rgbfmt format) +{ + const u32 dirtyflag_pos = 4; + const u32 dirtyflag_mask = 1ul << dirtyflag_pos; + const u32 format_mask = 0xffff0000ul; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + regvalue = pregister->mlcrgblayer[layer].mlccontrol; + regvalue &= ~(format_mask | dirtyflag_mask); + regvalue |= (u32)format; + + writel(regvalue, &pregister->mlcrgblayer[layer].mlccontrol); + } +} + +void nx_mlc_set_format_yuv(u32 module_index, enum nx_mlc_yuvfmt format) +{ + const u32 format_mask = 0xffff0000ul; + register u32 temp; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + temp = pregister->mlcvideolayer.mlccontrol; + temp &= ~format_mask; + temp |= (u32)format; + + writel(temp, &pregister->mlcvideolayer.mlccontrol); +} + +void nx_mlc_set_position(u32 module_index, u32 layer, s32 sx, s32 sy, + s32 ex, s32 ey) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + writel((((u32)sx & 0xffful) << 16) | ((u32)ex & 0xffful), + &pregister->mlcrgblayer[layer].mlcleftright); + + writel((((u32)sy & 0xffful) << 16) | ((u32)ey & 0xffful), + &pregister->mlcrgblayer[layer].mlctopbottom); + } else if (layer == 2) { + writel((((u32)sx & 0xffful) << 16) | ((u32)ex & 0xffful), + &pregister->mlcrgblayer2.mlcleftright); + + writel((((u32)sy & 0xffful) << 16) | ((u32)ey & 0xffful), + &pregister->mlcrgblayer2.mlctopbottom); + } else if (layer == 3) { + writel((((u32)sx & 0xffful) << 16) | ((u32)ex & 0xffful), + &pregister->mlcvideolayer.mlcleftright); + + writel((((u32)sy & 0xffful) << 16) | ((u32)ey & 0xffful), + &pregister->mlcvideolayer.mlctopbottom); + } +} + +void nx_mlc_set_dither_enable_when_using_gamma(u32 module_index, int benable) +{ + const u32 ditherenb_bitpos = 0; + const u32 ditherenb_mask = 1 << ditherenb_bitpos; + register struct nx_mlc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + read_value &= ~ditherenb_mask; + read_value |= ((u32)benable << ditherenb_bitpos); + + writel(read_value, &pregister->mlcgammacont); +} + +int nx_mlc_get_dither_enable_when_using_gamma(u32 module_index) +{ + const u32 ditherenb_bitpos = 0; + const u32 ditherenb_mask = 1 << ditherenb_bitpos; + + return (int)(__g_module_variables[module_index].pregister->mlcgammacont + & ditherenb_mask); +} + +void nx_mlc_set_gamma_priority(u32 module_index, int bvideolayer) +{ + const u32 alphaselect_bitpos = 5; + const u32 alphaselect_mask = 1 << alphaselect_bitpos; + register struct nx_mlc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + read_value &= ~alphaselect_mask; + read_value |= ((u32)bvideolayer << alphaselect_bitpos); + + writel(read_value, &pregister->mlcgammacont); +} + +int nx_mlc_get_gamma_priority(u32 module_index) +{ + const u32 alphaselect_bitpos = 5; + const u32 alphaselect_mask = 1 << alphaselect_bitpos; + + return (int)((__g_module_variables[module_index].pregister->mlcgammacont + & alphaselect_mask) >> alphaselect_bitpos); +} + +void nx_mlc_set_rgblayer_invalid_position(u32 module_index, u32 layer, + u32 region, s32 sx, s32 sy, + s32 ex, s32 ey, int benb) +{ + const u32 invalidenb_pos = 28; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + if (region == 0) { + writel(((benb << invalidenb_pos) | + ((sx & 0x7ff) << 16) | (ex & 0x7ff)), + &pregister->mlcrgblayer[layer] + .mlcinvalidleftright0); + + writel((((sy & 0x7ff) << 16) | (ey & 0x7ff)), + &pregister->mlcrgblayer[layer] + .mlcinvalidtopbottom0); + } else { + writel(((benb << invalidenb_pos) | + ((sx & 0x7ff) << 16) | (ex & 0x7ff)), + &pregister->mlcrgblayer[layer] + .mlcinvalidleftright1); + + writel((((sy & 0x7ff) << 16) | (ey & 0x7ff)), + &pregister->mlcrgblayer[layer] + .mlcinvalidtopbottom1); + } + } +} + +void nx_mlc_set_rgblayer_stride(u32 module_index, u32 layer, s32 hstride, + s32 vstride) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) { + writel(hstride, &pregister->mlcrgblayer[layer].mlchstride); + writel(vstride, &pregister->mlcrgblayer[layer].mlcvstride); + } else if (layer == 2) { + writel(hstride, &pregister->mlcrgblayer2.mlchstride); + writel(vstride, &pregister->mlcrgblayer2.mlcvstride); + } +} + +void nx_mlc_set_rgblayer_address(u32 module_index, u32 layer, u32 addr) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0 || layer == 1) + writel(addr, &pregister->mlcrgblayer[layer].mlcaddress); + else if (layer == 2) + writel(addr, &pregister->mlcrgblayer2.mlcaddress); +} + +void nx_mlc_set_rgblayer_gama_table_power_mode(u32 module_index, int bred, + int bgreen, int bblue) +{ + const u32 bgammatable_pwd_bitpos = 11; + const u32 ggammatable_pwd_bitpos = 9; + const u32 rgammatable_pwd_bitpos = 3; + const u32 bgammatable_pwd_mask = (1 << bgammatable_pwd_bitpos); + const u32 ggammatable_pwd_mask = (1 << ggammatable_pwd_bitpos); + const u32 rgammatable_pwd_mask = (1 << rgammatable_pwd_bitpos); + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + read_value &= ~(bgammatable_pwd_mask | ggammatable_pwd_mask | + rgammatable_pwd_mask); + read_value |= (((u32)bred << rgammatable_pwd_bitpos) | + ((u32)bgreen << ggammatable_pwd_bitpos) | + ((u32)bblue << bgammatable_pwd_bitpos)); + + writel(read_value, &pregister->mlcgammacont); +} + +void nx_mlc_get_rgblayer_gama_table_power_mode(u32 module_index, int *pbred, + int *pbgreen, int *pbblue) +{ + const u32 bgammatable_pwd_bitpos = 11; + const u32 ggammatable_pwd_bitpos = 9; + const u32 rgammatable_pwd_bitpos = 3; + const u32 bgammatable_pwd_mask = (1 << bgammatable_pwd_bitpos); + const u32 ggammatable_pwd_mask = (1 << ggammatable_pwd_bitpos); + const u32 rgammatable_pwd_mask = (1 << rgammatable_pwd_bitpos); + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + if (pbred) + *pbred = (read_value & rgammatable_pwd_mask) ? 1 : 0; + + if (pbgreen) + *pbgreen = (read_value & ggammatable_pwd_mask) ? 1 : 0; + + if (pbblue) + *pbblue = (read_value & bgammatable_pwd_mask) ? 1 : 0; +} + +void nx_mlc_set_rgblayer_gama_table_sleep_mode(u32 module_index, int bred, + int bgreen, int bblue) +{ + const u32 bgammatable_sld_bitpos = 10; + const u32 ggammatable_sld_bitpos = 8; + const u32 rgammatable_sld_bitpos = 2; + const u32 bgammatable_sld_mask = (1 << bgammatable_sld_bitpos); + const u32 ggammatable_sld_mask = (1 << ggammatable_sld_bitpos); + const u32 rgammatable_sld_mask = (1 << rgammatable_sld_bitpos); + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + if (bred) + read_value &= ~rgammatable_sld_mask; + else + read_value |= rgammatable_sld_mask; + + if (bgreen) + read_value &= ~ggammatable_sld_mask; + else + read_value |= ggammatable_sld_mask; + + if (bblue) + read_value &= ~bgammatable_sld_mask; + else + read_value |= bgammatable_sld_mask; + + writel(read_value, &pregister->mlcgammacont); +} + +void nx_mlc_get_rgblayer_gama_table_sleep_mode(u32 module_index, int *pbred, + int *pbgreen, int *pbblue) +{ + const u32 bgammatable_sld_bitpos = 10; + const u32 ggammatable_sld_bitpos = 8; + const u32 rgammatable_sld_bitpos = 2; + const u32 bgammatable_sld_mask = (1 << bgammatable_sld_bitpos); + const u32 ggammatable_sld_mask = (1 << ggammatable_sld_bitpos); + const u32 rgammatable_sld_mask = (1 << rgammatable_sld_bitpos); + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + + if (pbred) + *pbred = (read_value & rgammatable_sld_mask) ? 0 : 1; + + if (pbgreen) + *pbgreen = (read_value & ggammatable_sld_mask) ? 0 : 1; + + if (pbblue) + *pbblue = (read_value & bgammatable_sld_mask) ? 0 : 1; +} + +void nx_mlc_set_rgblayer_rgamma_table(u32 module_index, u32 dwaddress, + u32 dwdata) +{ + register struct nx_mlc_register_set *pregister; + const u32 tableaddr_bitpos = 24; + + pregister = __g_module_variables[module_index].pregister; + writel(((dwaddress << tableaddr_bitpos) | dwdata), + &pregister->mlcrgammatablewrite); +} + +void nx_mlc_set_rgblayer_ggamma_table(u32 module_index, u32 dwaddress, + u32 dwdata) +{ + register struct nx_mlc_register_set *pregister; + const u32 tableaddr_bitpos = 24; + + pregister = __g_module_variables[module_index].pregister; + writel(((dwaddress << tableaddr_bitpos) | dwdata), + &pregister->mlcggammatablewrite); +} + +void nx_mlc_set_rgblayer_bgamma_table(u32 module_index, u32 dwaddress, + u32 dwdata) +{ + register struct nx_mlc_register_set *pregister; + const u32 tableaddr_bitpos = 24; + + pregister = __g_module_variables[module_index].pregister; + writel(((dwaddress << tableaddr_bitpos) | dwdata), + &pregister->mlcbgammatablewrite); +} + +void nx_mlc_set_rgblayer_gamma_enable(u32 module_index, int benable) +{ + const u32 rgbgammaemb_bitpos = 1; + const u32 rgbgammaemb_mask = 1 << rgbgammaemb_bitpos; + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + read_value &= ~rgbgammaemb_mask; + read_value |= (u32)benable << rgbgammaemb_bitpos; + + writel(read_value, &pregister->mlcgammacont); +} + +int nx_mlc_get_rgblayer_gamma_enable(u32 module_index) +{ + const u32 rgbgammaemb_bitpos = 1; + const u32 rgbgammaemb_mask = 1 << rgbgammaemb_bitpos; + + return (int)((__g_module_variables[module_index].pregister->mlcgammacont + & rgbgammaemb_mask) >> rgbgammaemb_bitpos); +} + +void nx_mlc_set_video_layer_stride(u32 module_index, s32 lu_stride, + s32 cb_stride, s32 cr_stride) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + writel(lu_stride, &pregister->mlcvideolayer.mlcvstride); + writel(cb_stride, &pregister->mlcvideolayer.mlcvstridecb); + writel(cr_stride, &pregister->mlcvideolayer.mlcvstridecr); +} + +void nx_mlc_set_video_layer_address(u32 module_index, u32 lu_addr, u32 cb_addr, + u32 cr_addr) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(lu_addr, &pregister->mlcvideolayer.mlcaddress); + writel(cb_addr, &pregister->mlcvideolayer.mlcaddresscb); + writel(cr_addr, &pregister->mlcvideolayer.mlcaddresscr); +} + +void nx_mlc_set_video_layer_address_yuyv(u32 module_index, u32 addr, + s32 stride) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(addr, &pregister->mlcvideolayer.mlcaddress); + writel(stride, &pregister->mlcvideolayer.mlcvstride); +} + +void nx_mlc_set_video_layer_scale_factor(u32 module_index, u32 hscale, + u32 vscale, int bhlumaenb, + int bhchromaenb, int bvlumaenb, + int bvchromaenb) +{ + const u32 filter_luma_pos = 28; + const u32 filter_choma_pos = 29; + const u32 scale_mask = ((1 << 23) - 1); + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + writel(((bhlumaenb << filter_luma_pos) | + (bhchromaenb << filter_choma_pos) | (hscale & scale_mask)), + &pregister->mlcvideolayer.mlchscale); + + writel(((bvlumaenb << filter_luma_pos) | + (bvchromaenb << filter_choma_pos) | (vscale & scale_mask)), + &pregister->mlcvideolayer.mlcvscale); +} + +void nx_mlc_set_video_layer_scale_filter(u32 module_index, int bhlumaenb, + int bhchromaenb, int bvlumaenb, + int bvchromaenb) +{ + const u32 filter_luma_pos = 28; + const u32 filter_choma_pos = 29; + const u32 scale_mask = ((1 << 23) - 1); + register struct nx_mlc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcvideolayer.mlchscale; + read_value &= scale_mask; + read_value |= + (bhlumaenb << filter_luma_pos) | (bhchromaenb << filter_choma_pos); + + writel(read_value, &pregister->mlcvideolayer.mlchscale); + read_value = pregister->mlcvideolayer.mlcvscale; + read_value &= scale_mask; + read_value |= + (bvlumaenb << filter_luma_pos) | (bvchromaenb << filter_choma_pos); + + writel(read_value, &pregister->mlcvideolayer.mlcvscale); +} + +void nx_mlc_get_video_layer_scale_filter(u32 module_index, int *bhlumaenb, + int *bhchromaenb, int *bvlumaenb, + int *bvchromaenb) +{ + const u32 filter_luma_pos = 28; + const u32 filter_choma_pos = 29; + const u32 filter_mask = 1ul; + register struct nx_mlc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcvideolayer.mlchscale; + *bhlumaenb = (read_value >> filter_luma_pos) & filter_mask; + *bhchromaenb = (read_value >> filter_choma_pos) & filter_mask; + read_value = pregister->mlcvideolayer.mlcvscale; + *bvlumaenb = (read_value >> filter_luma_pos) & filter_mask; + *bvchromaenb = (read_value >> filter_choma_pos) & filter_mask; +} + +void nx_mlc_set_video_layer_scale(u32 module_index, u32 sw, u32 sh, u32 dw, + u32 dh, int bhlumaenb, int bhchromaenb, + int bvlumaenb, int bvchromaenb) +{ + const u32 filter_luma_pos = 28; + const u32 filter_choma_pos = 29; + const u32 scale_mask = ((1 << 23) - 1); + register u32 hscale, vscale, cal_sh; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + if ((bhlumaenb || bhchromaenb) && dw > sw) { + sw--; + dw--; + } + hscale = (sw << 11) / dw; + + if ((bvlumaenb || bvchromaenb) && dh > sh) { + sh--; + dh--; + vscale = (sh << 11) / dh; + + cal_sh = ((vscale * dh) >> 11); + if (sh <= cal_sh) + vscale--; + + } else { + vscale = (sh << 11) / dh; + } + + writel(((bhlumaenb << filter_luma_pos) | + (bhchromaenb << filter_choma_pos) | (hscale & scale_mask)), + &pregister->mlcvideolayer.mlchscale); + + writel(((bvlumaenb << filter_luma_pos) | + (bvchromaenb << filter_choma_pos) | (vscale & scale_mask)), + &pregister->mlcvideolayer.mlcvscale); +} + +void nx_mlc_set_video_layer_luma_enhance(u32 module_index, u32 contrast, + s32 brightness) +{ + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + writel((((u32)brightness & 0xfful) << 8) | contrast, + &pregister->mlcvideolayer.mlcluenh); +} + +void nx_mlc_set_video_layer_chroma_enhance(u32 module_index, u32 quadrant, + s32 cb_a, s32 cb_b, + s32 cr_a, s32 cr_b) +{ + register struct nx_mlc_register_set *pregister; + register u32 temp; + + pregister = __g_module_variables[module_index].pregister; + temp = (((u32)cr_b & 0xfful) << 24) | (((u32)cr_a & 0xfful) << 16) | + (((u32)cb_b & 0xfful) << 8) | (((u32)cb_a & 0xfful) << 0); + if (quadrant > 0) { + writel(temp, &pregister->mlcvideolayer.mlcchenh[quadrant - 1]); + } else { + writel(temp, &pregister->mlcvideolayer.mlcchenh[0]); + writel(temp, &pregister->mlcvideolayer.mlcchenh[1]); + writel(temp, &pregister->mlcvideolayer.mlcchenh[2]); + writel(temp, &pregister->mlcvideolayer.mlcchenh[3]); + } +} + +void nx_mlc_set_video_layer_line_buffer_power_mode(u32 module_index, + int benable) +{ + const u32 linebuff_pwd_pos = 15; + const u32 linebuff_pwd_mask = 1ul << linebuff_pwd_pos; + const u32 dirtyflag_mask = 1ul << 4; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->mlcvideolayer.mlccontrol; + regvalue &= ~(linebuff_pwd_mask | dirtyflag_mask); + regvalue |= ((u32)benable << linebuff_pwd_pos); + + writel(regvalue, &pregister->mlcvideolayer.mlccontrol); +} + +int nx_mlc_get_video_layer_line_buffer_power_mode(u32 module_index) +{ + const u32 linebuff_pwd_pos = 15; + const u32 linebuff_pwd_mask = 1ul << linebuff_pwd_pos; + + return (int)((__g_module_variables[module_index] + .pregister->mlcvideolayer.mlccontrol & + linebuff_pwd_mask) >> linebuff_pwd_pos); +} + +void nx_mlc_set_video_layer_line_buffer_sleep_mode(u32 module_index, + int benable) +{ + const u32 linebuff_slmd_pos = 14; + const u32 linebuff_slmd_mask = 1ul << linebuff_slmd_pos; + const u32 dirtyflag_mask = 1ul << 4; + register u32 regvalue; + register struct nx_mlc_register_set *pregister; + + benable = (int)((u32)benable ^ 1); + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->mlcvideolayer.mlccontrol; + regvalue &= ~(linebuff_slmd_mask | dirtyflag_mask); + regvalue |= (benable << linebuff_slmd_pos); + + writel(regvalue, &pregister->mlcvideolayer.mlccontrol); +} + +int nx_mlc_get_video_layer_line_buffer_sleep_mode(u32 module_index) +{ + const u32 linebuff_slmd_pos = 14; + const u32 linebuff_slmd_mask = 1ul << linebuff_slmd_pos; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (linebuff_slmd_mask & pregister->mlcvideolayer.mlccontrol) + return 0; + else + return 1; +} + +void nx_mlc_set_video_layer_gama_table_power_mode(u32 module_index, int by, + int bu, int bv) +{ + const u32 vgammatable_pwd_bitpos = 17; + const u32 ugammatable_pwd_bitpos = 15; + const u32 ygammatable_pwd_bitpos = 13; + const u32 vgammatable_pwd_mask = (1 << vgammatable_pwd_bitpos); + const u32 ugammatable_pwd_mask = (1 << ugammatable_pwd_bitpos); + const u32 ygammatable_pwd_mask = (1 << ygammatable_pwd_bitpos); + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + read_value &= ~(ygammatable_pwd_mask | ugammatable_pwd_mask | + vgammatable_pwd_mask); + read_value |= (((u32)by << ygammatable_pwd_bitpos) | + ((u32)bu << ugammatable_pwd_bitpos) | + ((u32)bv << vgammatable_pwd_bitpos)); + + writel(read_value, &pregister->mlcgammacont); +} + +void nx_mlc_get_video_layer_gama_table_power_mode(u32 module_index, int *pby, + int *pbu, int *pbv) +{ + const u32 vgammatable_pwd_bitpos = 17; + const u32 ugammatable_pwd_bitpos = 15; + const u32 ygammatable_pwd_bitpos = 13; + const u32 vgammatable_pwd_mask = (1 << vgammatable_pwd_bitpos); + const u32 ugammatable_pwd_mask = (1 << ugammatable_pwd_bitpos); + const u32 ygammatable_pwd_mask = (1 << ygammatable_pwd_bitpos); + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + if (pby) + *pby = (read_value & ygammatable_pwd_mask) ? 1 : 0; + + if (pbu) + *pbu = (read_value & ugammatable_pwd_mask) ? 1 : 0; + + if (pbv) + *pbv = (read_value & vgammatable_pwd_mask) ? 1 : 0; +} + +void nx_mlc_set_video_layer_gama_table_sleep_mode(u32 module_index, int by, + int bu, int bv) +{ + const u32 vgammatable_sld_bitpos = 16; + const u32 ugammatable_sld_bitpos = 14; + const u32 ygammatable_sld_bitpos = 12; + const u32 vgammatable_sld_mask = (1 << vgammatable_sld_bitpos); + const u32 ugammatable_sld_mask = (1 << ugammatable_sld_bitpos); + const u32 ygammatable_sld_mask = (1 << ygammatable_sld_bitpos); + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + if (by) + read_value &= ~ygammatable_sld_mask; + else + read_value |= ygammatable_sld_mask; + + if (bu) + read_value &= ~ugammatable_sld_mask; + else + read_value |= ugammatable_sld_mask; + + if (bv) + read_value &= ~vgammatable_sld_mask; + else + read_value |= vgammatable_sld_mask; + + writel(read_value, &pregister->mlcgammacont); +} + +void nx_mlc_get_video_layer_gama_table_sleep_mode(u32 module_index, int *pby, + int *pbu, int *pbv) +{ + const u32 vgammatable_sld_bitpos = 16; + const u32 ugammatable_sld_bitpos = 14; + const u32 ygammatable_sld_bitpos = 12; + const u32 vgammatable_sld_mask = (1 << vgammatable_sld_bitpos); + const u32 ugammatable_sld_mask = (1 << ugammatable_sld_bitpos); + const u32 ygammatable_sld_mask = (1 << ygammatable_sld_bitpos); + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + + if (pby) + *pby = (read_value & vgammatable_sld_mask) ? 0 : 1; + + if (pbu) + *pbu = (read_value & ugammatable_sld_mask) ? 0 : 1; + + if (pbv) + *pbv = (read_value & ygammatable_sld_mask) ? 0 : 1; +} + +void nx_mlc_set_video_layer_gamma_enable(u32 module_index, int benable) +{ + const u32 yuvgammaemb_bitpos = 4; + const u32 yuvgammaemb_mask = 1 << yuvgammaemb_bitpos; + register u32 read_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->mlcgammacont; + read_value &= ~yuvgammaemb_mask; + read_value |= (u32)benable << yuvgammaemb_bitpos; + + writel(read_value, &pregister->mlcgammacont); +} + +int nx_mlc_get_video_layer_gamma_enable(u32 module_index) +{ + const u32 yuvgammaemb_bitpos = 4; + const u32 yuvgammaemb_mask = 1 << yuvgammaemb_bitpos; + + return (int)((__g_module_variables[module_index].pregister->mlcgammacont + & yuvgammaemb_mask) >> yuvgammaemb_bitpos); +} + +void nx_mlc_set_gamma_table_poweroff(u32 module_index, int enb) +{ + register struct nx_mlc_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + if (enb == 1) { + regvalue = pregister->mlcgammacont; + regvalue = regvalue & 0xf3; + writel(regvalue, &pregister->mlcgammacont); + } +} + +void nx_mlc_set_mlctop_control_parameter(u32 module_index, int field_enable, + int mlcenable, u8 priority, + enum g3daddrchangeallowed + g3daddr_change_allowed) +{ + register u32 mlctopcontrolreg; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + mlctopcontrolreg = (readl(&pregister->mlccontrolt)) & 0xfffffcfc; + mlctopcontrolreg = (u32)(mlctopcontrolreg | + ((priority << 8) | ((mlcenable == 1) << 1) | + (1 == + field_enable)) | (g3daddr_change_allowed << + 12)); + writel(mlctopcontrolreg, &pregister->mlccontrolt); +} + +void nx_mlc_set_rgb0layer_control_parameter(u32 module_index, int layer_enable, + int grp3denable, int tp_enable, + u32 transparency_color, + int inv_enable, u32 inverse_color, + int blend_enable, u8 alpha_value, + enum mlc_rgbfmt rbgformat, + enum locksizesel lock_size_select) +{ + u32 layer_format; + u32 control_enb; + u32 alpha_argument; + u32 lock_size = (u32)(lock_size_select & 0x3); + u32 rgb0controlreg; + u32 regvalue; + register struct nx_mlc_register_set *pregister; + + layer_format = nx_mlc_get_rgbformat(rbgformat); + pregister = __g_module_variables[module_index].pregister; + control_enb = + (u32)((grp3denable << 8) | (layer_enable << 5) | + (blend_enable << 2) | (inv_enable << 1) | tp_enable) & 0x127; + alpha_argument = (u32)(alpha_value & 0xf); + + rgb0controlreg = readl(&pregister->mlcrgblayer[0].mlccontrol) & 0x10; + regvalue = + (u32)(((layer_format << 16) | control_enb | (lock_size << 12)) | + rgb0controlreg); + writel(regvalue, &pregister->mlcrgblayer[0].mlccontrol); + + regvalue = (u32)((alpha_argument << 28) | transparency_color); + writel(regvalue, &pregister->mlcrgblayer[0].mlctpcolor); + regvalue = inverse_color; + writel(regvalue, &pregister->mlcrgblayer[0].mlcinvcolor); +} + +u32 nx_mlc_get_rgbformat(enum mlc_rgbfmt rbgformat) +{ + u32 rgbformatvalue; + const u32 format_table[] = { + 0x4432ul, 0x4342ul, 0x4211ul, 0x4120ul, 0x4003ul, 0x4554ul, + 0x3342ul, 0x2211ul, 0x1120ul, 0x1003ul, 0x4653ul, 0x4653ul, + 0x0653ul, 0x4ed3ul, 0x4f84ul, 0xc432ul, 0xc342ul, 0xc211ul, + 0xc120ul, 0xb342ul, 0xa211ul, 0x9120ul, 0xc653ul, 0xc653ul, + 0x8653ul, 0xced3ul, 0xcf84ul, 0x443aul + }; + + return rgbformatvalue = format_table[rbgformat]; +} + +void nx_mlc_set_rgb1layer_control_parameter(u32 module_index, int layer_enable, + int grp3denable, int tp_enable, + u32 transparency_color, + int inv_enable, u32 inverse_color, + int blend_enable, u8 alpha_value, + enum mlc_rgbfmt rbgformat, + enum locksizesel lock_size_select) +{ + u32 layer_format; + u32 control_enb; + u32 alpha_argument; + u32 lock_size = (u32)(lock_size_select & 0x3); + u32 rgb0controlreg; + u32 regvalue; + register struct nx_mlc_register_set *pregister; + + layer_format = nx_mlc_get_rgbformat(rbgformat); + pregister = __g_module_variables[module_index].pregister; + + rgb0controlreg = readl(&pregister->mlcrgblayer[1].mlccontrol) & 0x10; + control_enb = + (u32)((grp3denable << 8) | (layer_enable << 5) | + (blend_enable << 2) | (inv_enable << 1) | tp_enable) & 0x127; + alpha_argument = (u32)(alpha_value & 0xf); + regvalue = + (u32)(((layer_format << 16) | control_enb | (lock_size << 12)) | + rgb0controlreg); + writel(regvalue, &pregister->mlcrgblayer[1].mlccontrol); + regvalue = (u32)((alpha_argument << 28) | transparency_color); + writel(regvalue, &pregister->mlcrgblayer[1].mlctpcolor); + regvalue = inverse_color; + writel(regvalue, &pregister->mlcrgblayer[1].mlcinvcolor); +} + +void nx_mlc_set_rgb2layer_control_parameter(u32 module_index, int layer_enable, + int grp3denable, int tp_enable, + u32 transparency_color, + int inv_enable, u32 inverse_color, + int blend_enable, u8 alpha_value, + enum mlc_rgbfmt rbgformat, + enum locksizesel lock_size_select) +{ + u32 layer_format; + u32 control_enb; + u32 alpha_argument; + u32 lock_size = (u32)(lock_size_select & 0x3); + u32 rgb0controlreg; + u32 regvalue; + register struct nx_mlc_register_set *pregister; + + layer_format = nx_mlc_get_rgbformat(rbgformat); + pregister = __g_module_variables[module_index].pregister; + + rgb0controlreg = readl(&pregister->mlcrgblayer2.mlccontrol) & 0x10; + control_enb = + (u32)((grp3denable << 8) | (layer_enable << 5) | + (blend_enable << 2) | (inv_enable << 1) | tp_enable) & 0x127; + alpha_argument = (u32)(alpha_value & 0xf); + regvalue = + (u32)(((layer_format << 16) | control_enb | (lock_size << 12)) | + rgb0controlreg); + writel(regvalue, &pregister->mlcrgblayer2.mlccontrol); + regvalue = (u32)((alpha_argument << 28) | transparency_color); + writel(regvalue, &pregister->mlcrgblayer2.mlctpcolor); + regvalue = inverse_color; + writel(regvalue, &pregister->mlcrgblayer2.mlcinvcolor); +} + +void nx_mlc_set_video_layer_control_parameter(u32 module_index, + int layer_enable, int tp_enable, + u32 transparency_color, + int inv_enable, u32 inverse_color, + int blend_enable, u8 alpha_value, + enum nx_mlc_yuvfmt yuvformat) +{ + u32 control_enb; + u32 alpha_argument; + u32 regvalue; + register struct nx_mlc_register_set *pregister; + u32 video_control_reg; + + pregister = __g_module_variables[module_index].pregister; + + video_control_reg = readl(&pregister->mlcvideolayer.mlccontrol); + control_enb = + (u32)((yuvformat) | (layer_enable << 5) | (blend_enable << 2) | + (inv_enable << 1) | tp_enable) & 0x30027; + alpha_argument = (u32)(alpha_value & 0xf); + regvalue = (u32)(control_enb | video_control_reg); + writel(regvalue, &pregister->mlcvideolayer.mlccontrol); + regvalue = (u32)((alpha_argument << 28) | transparency_color); + writel(regvalue, &pregister->mlcvideolayer.mlctpcolor); + regvalue = (u32)((alpha_argument << 28) | transparency_color); + writel(regvalue, &pregister->mlcvideolayer.mlcinvcolor); +} + +void nx_mlc_set_srammode(u32 module_index, enum latyername layer_name, + enum srammode sram_mode) +{ + u32 control_reg_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + switch (layer_name) { + case topmlc: + control_reg_value = readl(&pregister->mlccontrolt); + writel((u32)(control_reg_value | (sram_mode << 10)), + &pregister->mlccontrolt); + control_reg_value = 0; + break; + case rgb0: + control_reg_value = + readl(&pregister->mlcrgblayer[0].mlccontrol); + writel((u32)(control_reg_value | (sram_mode << 14)), + &pregister->mlcrgblayer[0].mlccontrol); + control_reg_value = 0; + break; + case rgb1: + control_reg_value = + readl(&pregister->mlcrgblayer[1].mlccontrol); + writel((u32)(control_reg_value | (sram_mode << 14)), + &pregister->mlcrgblayer[1].mlccontrol); + control_reg_value = 0; + break; + case rgb2: + control_reg_value = readl(&pregister->mlcrgblayer2.mlccontrol); + writel((u32)(control_reg_value | (sram_mode << 14)), + &pregister->mlcrgblayer2.mlccontrol); + control_reg_value = 0; + break; + case video: + control_reg_value = readl(&pregister->mlcvideolayer.mlccontrol); + writel((u32)(control_reg_value | (sram_mode << 14)), + &pregister->mlcvideolayer.mlccontrol); + control_reg_value = 0; + break; + default: + break; + } +} + +void nx_mlc_set_layer_reg_finish(u32 module_index, enum latyername layer_name) +{ + u32 control_reg_value; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + switch (layer_name) { + case topmlc: + control_reg_value = readl(&pregister->mlccontrolt); + writel((u32)(control_reg_value | (1ul << 3)), + &pregister->mlccontrolt); + control_reg_value = 0; + break; + case rgb0: + control_reg_value = + readl(&pregister->mlcrgblayer[0].mlccontrol); + writel((u32)(control_reg_value | (1ul << 4)), + &pregister->mlcrgblayer[0].mlccontrol); + control_reg_value = 0; + break; + case rgb1: + control_reg_value = + readl(&pregister->mlcrgblayer[1].mlccontrol); + writel((u32)(control_reg_value | (1ul << 4)), + &pregister->mlcrgblayer[1].mlccontrol); + control_reg_value = 0; + break; + case rgb2: + control_reg_value = readl(&pregister->mlcrgblayer2.mlccontrol); + writel((u32)(control_reg_value | (1ul << 4)), + &pregister->mlcrgblayer2.mlccontrol); + control_reg_value = 0; + break; + case video: + control_reg_value = readl(&pregister->mlcvideolayer.mlccontrol); + writel((u32)(control_reg_value | (1ul << 4)), + &pregister->mlcvideolayer.mlccontrol); + control_reg_value = 0; + break; + default: + break; + } +} + +void nx_mlc_set_video_layer_coordinate(u32 module_index, int vfilterenable, + int hfilterenable, int vfilterenable_c, + int hfilterenable_c, + u16 video_layer_with, + u16 video_layer_height, s16 left, + s16 right, s16 top, + s16 bottom) +{ + s32 source_width, source_height; + s32 destination_width; + s32 destination_height; + s32 hscale, vscale; + s32 hfilterenb, vfilterenb; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((s32)(((left & 0x0fff) << 16) | (right & 0x0fff)), + &pregister->mlcvideolayer.mlcleftright); + writel((s32)(((top & 0x0fff) << 16) | (bottom & 0x0fff)), + &pregister->mlcvideolayer.mlctopbottom); + source_width = (s32)(video_layer_with - 1); + source_height = (s32)(video_layer_height - 1); + destination_width = (s32)(right - left); + destination_height = (s32)(bottom - top); + + hscale = + (s32)((source_width * (1ul << 11) + (destination_width / 2)) / + destination_width); + vscale = + (s32)((source_height * (1ul << 11) + + (destination_height / 2)) / destination_height); + + hfilterenb = (u32)(((hfilterenable_c << 29) | (hfilterenable) << 28)) & + 0x30000000; + vfilterenb = (u32)(((vfilterenable_c << 29) | (vfilterenable) << 28)) & + 0x30000000; + writel((u32)(hfilterenb | (hscale & 0x00ffffff)), + &pregister->mlcvideolayer.mlchscale); + writel((u32)(vfilterenb | (vscale & 0x00ffffff)), + &pregister->mlcvideolayer.mlcvscale); +} + +void nx_mlc_set_video_layer_filter_scale(u32 module_index, u32 hscale, + u32 vscale) +{ + register struct nx_mlc_register_set *pregister; + u32 mlchscale = 0; + u32 mlcvscale = 0; + + pregister = __g_module_variables[module_index].pregister; + mlchscale = readl(&pregister->mlcvideolayer.mlchscale) & (~0x00ffffff); + mlcvscale = readl(&pregister->mlcvideolayer.mlcvscale) & (~0x00ffffff); + + writel((u32)(mlchscale | (hscale & 0x00ffffff)), + &pregister->mlcvideolayer.mlchscale); + writel((u32)(mlcvscale | (vscale & 0x00ffffff)), + &pregister->mlcvideolayer.mlcvscale); +} + +void nx_mlc_set_gamma_control_parameter(u32 module_index, int rgbgammaenb, + int yuvgammaenb, int yuvalphaarray, + int dither_enb) +{ + u32 register_data; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + register_data = readl(&pregister->mlcgammacont); + register_data = (register_data & 0xf0c) | + ((yuvalphaarray << 5) | (yuvgammaenb << 4) | + (rgbgammaenb << 1) | (dither_enb << 0)); + writel(register_data, &pregister->mlcgammacont); +} + +void nx_mlc_set_layer_alpha256(u32 module_index, u32 layer, u32 alpha) +{ + u32 register_data; + register struct nx_mlc_register_set *pregister; + + if (alpha < 0) + alpha = 0; + if (alpha > 255) + alpha = 255; + + pregister = __g_module_variables[module_index].pregister; + if (layer == 0) { + register_data = + readl(&pregister->mlcrgblayer[0].mlctpcolor) & 0x00ffffff; + register_data = register_data | (alpha << 24); + writel(register_data, &pregister->mlcrgblayer[0].mlctpcolor); + } else if (layer == 1) { + register_data = + readl(&pregister->mlcrgblayer[1].mlctpcolor) & 0x00ffffff; + register_data = register_data | (alpha << 24); + writel(register_data, &pregister->mlcrgblayer[1].mlctpcolor); + } else if (layer == 2) { + register_data = + readl(&pregister->mlcrgblayer[1].mlctpcolor) & 0x00ffffff; + register_data = register_data | (alpha << 24); + writel(register_data, &pregister->mlcrgblayer2.mlctpcolor); + } else { + register_data = + readl(&pregister->mlcvideolayer.mlctpcolor) & 0x00ffffff; + register_data = register_data | (alpha << 24); + writel(register_data, &pregister->mlcvideolayer.mlctpcolor); + } +} + +int nx_mlc_is_under_flow(u32 module_index) +{ + const u32 underflow_pend_pos = 31; + const u32 underflow_pend_mask = 1ul << underflow_pend_pos; + + return (int)((__g_module_variables[module_index].pregister->mlccontrolt + & underflow_pend_mask) >> underflow_pend_pos); +} + +void nx_mlc_set_gamma_table(u32 module_index, int enb, + struct nx_mlc_gamma_table_parameter *p_gammatable) +{ + register struct nx_mlc_register_set *pregister; + u32 i, regval = 0; + + pregister = __g_module_variables[module_index].pregister; + if (enb == 1) { + regval = readl(&pregister->mlcgammacont); + + regval = (1 << 11) | (1 << 9) | (1 << 3); + writel(regval, &pregister->mlcgammacont); + + regval = regval | (1 << 10) | (1 << 8) | (1 << 2); + writel(regval, &pregister->mlcgammacont); + + for (i = 0; i < 256; i++) { + nx_mlc_set_rgblayer_rgamma_table(module_index, i, + p_gammatable->r_table[i]); + nx_mlc_set_rgblayer_ggamma_table(module_index, i, + p_gammatable->g_table[i]); + nx_mlc_set_rgblayer_bgamma_table(module_index, i, + p_gammatable->b_table[i]); + } + + regval = regval | (p_gammatable->alphaselect << 5) | + (p_gammatable->yuvgammaenb << 4 | + p_gammatable->allgammaenb << 4) | + (p_gammatable->rgbgammaenb << 1 | + p_gammatable->allgammaenb << 1) | + (p_gammatable->ditherenb << 1); + writel(regval, &pregister->mlcgammacont); + } else { + regval = regval & ~(1 << 10) & ~(1 << 8) & ~(1 << 2); + writel(regval, &pregister->mlcgammacont); + + regval = regval & ~(1 << 11) & ~(1 << 9) & ~(1 << 3); + writel(regval, &pregister->mlcgammacont); + } +} + +void nx_mlc_get_rgblayer_stride(u32 module_index, u32 layer, s32 *hstride, + s32 *vstride) +{ + unsigned int hs, vs; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + hs = readl(&pregister->mlcrgblayer[layer].mlchstride); + vs = readl(&pregister->mlcrgblayer[layer].mlcvstride); + + if (hstride) + *(s32 *)hstride = hs; + + if (vstride) + *(s32 *)vstride = vs; +} + +void nx_mlc_get_rgblayer_address(u32 module_index, u32 layer, + u32 *phys_address) +{ + u32 pa; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + pa = readl(&pregister->mlcrgblayer[layer].mlcaddress); + + if (phys_address) + *(u32 *)phys_address = pa; +} + +void nx_mlc_get_position(u32 module_index, u32 layer, int *left, int *top, + int *right, int *bottom) +{ + int lr, tb; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + lr = readl(&pregister->mlcrgblayer[layer].mlcleftright); + tb = readl(&pregister->mlcrgblayer[layer].mlctopbottom); + + if (left) + *(int *)left = ((lr >> 16) & 0xFFUL); + + if (top) + *(int *)top = ((tb >> 16) & 0xFFUL); + + if (right) + *(int *)right = ((lr >> 0) & 0xFFUL); + + if (bottom) + *(int *)bottom = ((tb >> 0) & 0xFFUL); +} + +void nx_mlc_get_video_layer_address_yuyv(u32 module_index, u32 *address, + u32 *stride) +{ + u32 a, s; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + a = readl(&pregister->mlcvideolayer.mlcaddress); + s = readl(&pregister->mlcvideolayer.mlcvstride); + + if (address) + *(u32 *)address = a; + + if (stride) + *(u32 *)stride = s; +} + +void nx_mlc_get_video_layer_address(u32 module_index, u32 *lu_address, + u32 *cb_address, u32 *cr_address) +{ + u32 lua, cba, cra; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + lua = readl(&pregister->mlcvideolayer.mlcaddress); + cba = readl(&pregister->mlcvideolayer.mlcaddresscb); + cra = readl(&pregister->mlcvideolayer.mlcaddresscr); + + if (lu_address) + *(u32 *)lu_address = lua; + + if (cb_address) + *(u32 *)cb_address = cba; + + if (cr_address) + *(u32 *)cr_address = cra; +} + +void nx_mlc_get_video_layer_stride(u32 module_index, u32 *lu_stride, + u32 *cb_stride, u32 *cr_stride) +{ + u32 lus, cbs, crs; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + lus = readl(&pregister->mlcvideolayer.mlcvstride); + cbs = readl(&pregister->mlcvideolayer.mlcvstridecb); + crs = readl(&pregister->mlcvideolayer.mlcvstridecr); + + if (lu_stride) + *(u32 *)lu_stride = lus; + + if (cb_stride) + *(u32 *)cb_stride = cbs; + + if (cr_stride) + *(u32 *)cr_stride = crs; +} + +void nx_mlc_get_video_position(u32 module_index, int *left, int *top, + int *right, int *bottom) +{ + int lr, tb; + register struct nx_mlc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + lr = readl(&pregister->mlcvideolayer.mlcleftright); + tb = readl(&pregister->mlcvideolayer.mlctopbottom); + + if (left) + *(int *)left = ((lr >> 16) & 0xFFUL); + + if (top) + *(int *)top = ((tb >> 16) & 0xFFUL); + + if (right) + *(int *)right = ((lr >> 0) & 0xFFUL); + + if (bottom) + *(int *)bottom = ((tb >> 0) & 0xFFUL); +} diff --git a/drivers/video/nexell/soc/s5pxx18_soc_mlc.h b/drivers/video/nexell/soc/s5pxx18_soc_mlc.h new file mode 100644 index 0000000..77ceca6 --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_mlc.h @@ -0,0 +1,429 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _S5PXX18_SOC_MLC_H_ +#define _S5PXX18_SOC_MLC_H_ + +#include "s5pxx18_soc_disptype.h" + +#define NUMBER_OF_MLC_MODULE 2 +#define PHY_BASEADDR_MLC0 0xC0102000 +#define PHY_BASEADDR_MLC1 0xC0102400 + +#define PHY_BASEADDR_MLC_LIST \ + { PHY_BASEADDR_MLC0, PHY_BASEADDR_MLC1 } + +struct nx_mlc_register_set { + u32 mlccontrolt; + u32 mlcscreensize; + u32 mlcbgcolor; + struct { + u32 mlcleftright; + u32 mlctopbottom; + u32 mlcinvalidleftright0; + u32 mlcinvalidtopbottom0; + u32 mlcinvalidleftright1; + u32 mlcinvalidtopbottom1; + u32 mlccontrol; + s32 mlchstride; + s32 mlcvstride; + u32 mlctpcolor; + u32 mlcinvcolor; + u32 mlcaddress; + u32 __reserved0; + } mlcrgblayer[2]; + struct { + u32 mlcleftright; + u32 mlctopbottom; + u32 mlccontrol; + u32 mlcvstride; + u32 mlctpcolor; + + u32 mlcinvcolor; + u32 mlcaddress; + u32 mlcaddresscb; + u32 mlcaddresscr; + s32 mlcvstridecb; + s32 mlcvstridecr; + u32 mlchscale; + u32 mlcvscale; + u32 mlcluenh; + u32 mlcchenh[4]; + } mlcvideolayer; + struct { + u32 mlcleftright; + u32 mlctopbottom; + u32 mlcinvalidleftright0; + u32 mlcinvalidtopbottom0; + u32 mlcinvalidleftright1; + u32 mlcinvalidtopbottom1; + u32 mlccontrol; + s32 mlchstride; + s32 mlcvstride; + u32 mlctpcolor; + u32 mlcinvcolor; + u32 mlcaddress; + } mlcrgblayer2; + u32 mlcpaletetable2; + u32 mlcgammacont; + u32 mlcrgammatablewrite; + u32 mlcggammatablewrite; + u32 mlcbgammatablewrite; + u32 yuvlayergammatable_red; + u32 yuvlayergammatable_green; + u32 yuvlayergammatable_blue; + + u32 dimctrl; + u32 dimlut0; + u32 dimlut1; + u32 dimbusyflag; + u32 dimprdarrr0; + u32 dimprdarrr1; + u32 dimram0rddata; + u32 dimram1rddata; + u32 __reserved2[(0x3c0 - 0x12c) / 4]; + u32 mlcclkenb; +}; + +enum nx_mlc_priority { + nx_mlc_priority_videofirst = 0ul, + nx_mlc_priority_videosecond = 1ul, + nx_mlc_priority_videothird = 2ul, + nx_mlc_priority_videofourth = 3ul +}; + +enum nx_mlc_rgbfmt { + nx_mlc_rgbfmt_r5g6b5 = 0x44320000ul, + nx_mlc_rgbfmt_b5g6r5 = 0xc4320000ul, + nx_mlc_rgbfmt_x1r5g5b5 = 0x43420000ul, + nx_mlc_rgbfmt_x1b5g5r5 = 0xc3420000ul, + nx_mlc_rgbfmt_x4r4g4b4 = 0x42110000ul, + nx_mlc_rgbfmt_x4b4g4r4 = 0xc2110000ul, + nx_mlc_rgbfmt_x8r3g3b2 = 0x41200000ul, + nx_mlc_rgbfmt_x8b3g3r2 = 0xc1200000ul, + nx_mlc_rgbfmt_a1r5g5b5 = 0x33420000ul, + nx_mlc_rgbfmt_a1b5g5r5 = 0xb3420000ul, + nx_mlc_rgbfmt_a4r4g4b4 = 0x22110000ul, + nx_mlc_rgbfmt_a4b4g4r4 = 0xa2110000ul, + nx_mlc_rgbfmt_a8r3g3b2 = 0x11200000ul, + nx_mlc_rgbfmt_a8b3g3r2 = 0x91200000ul, + nx_mlc_rgbfmt_r8g8b8 = 0x46530000ul, + nx_mlc_rgbfmt_b8g8r8 = 0xc6530000ul, + nx_mlc_rgbfmt_x8r8g8b8 = 0x46530000ul, + nx_mlc_rgbfmt_x8b8g8r8 = 0xc6530000ul, + nx_mlc_rgbfmt_a8r8g8b8 = 0x06530000ul, + nx_mlc_rgbfmt_a8b8g8r8 = 0x86530000ul +}; + +enum nx_mlc_yuvfmt { + nx_mlc_yuvfmt_420 = 0ul << 16, + nx_mlc_yuvfmt_422 = 1ul << 16, + nx_mlc_yuvfmt_444 = 3ul << 16, + nx_mlc_yuvfmt_yuyv = 2ul << 16, + nx_mlc_yuvfmt_422_cbcr = 4ul << 16, + nx_mlc_yuvfmt_420_cbcr = 5ul << 16, +}; + +#ifdef __arm +#pragma diag_default 66 +#endif + +int nx_mlc_initialize(void); +u32 nx_mlc_get_number_of_module(void); +u32 nx_mlc_get_physical_address(u32 module_index); +u32 nx_mlc_get_size_of_register_set(void); +void nx_mlc_set_base_address(u32 module_index, void *base_address); +void *nx_mlc_get_base_address(u32 module_index); +int nx_mlc_open_module(u32 module_index); +int nx_mlc_close_module(u32 module_index); +int nx_mlc_check_busy(u32 module_index); +int nx_mlc_can_power_down(u32 module_index); +void nx_mlc_set_clock_pclk_mode(u32 module_index, enum nx_pclkmode mode); +enum nx_pclkmode nx_mlc_get_clock_pclk_mode(u32 module_index); +void nx_mlc_set_clock_bclk_mode(u32 module_index, enum nx_bclkmode mode); +enum nx_bclkmode nx_mlc_get_clock_bclk_mode(u32 module_index); + +void nx_mlc_set_top_power_mode(u32 module_index, int bpower); +int nx_mlc_get_top_power_mode(u32 module_index); +void nx_mlc_set_top_sleep_mode(u32 module_index, int bsleep); +int nx_mlc_get_top_sleep_mode(u32 module_index); +void nx_mlc_set_top_dirty_flag(u32 module_index); +int nx_mlc_get_top_dirty_flag(u32 module_index); +void nx_mlc_set_mlc_enable(u32 module_index, int benb); +int nx_mlc_get_mlc_enable(u32 module_index); +void nx_mlc_set_field_enable(u32 module_index, int benb); +int nx_mlc_get_field_enable(u32 module_index); +void nx_mlc_set_layer_priority(u32 module_index, + enum nx_mlc_priority priority); +void nx_mlc_set_screen_size(u32 module_index, u32 width, u32 height); +void nx_mlc_get_screen_size(u32 module_index, u32 *pwidth, + u32 *pheight); +void nx_mlc_set_background(u32 module_index, u32 color); + +void nx_mlc_set_dirty_flag(u32 module_index, u32 layer); +int nx_mlc_get_dirty_flag(u32 module_index, u32 layer); +void nx_mlc_set_layer_enable(u32 module_index, u32 layer, int benb); +int nx_mlc_get_layer_enable(u32 module_index, u32 layer); +void nx_mlc_set_lock_size(u32 module_index, u32 layer, u32 locksize); +void nx_mlc_set_alpha_blending(u32 module_index, u32 layer, int benb, + u32 alpha); +void nx_mlc_set_transparency(u32 module_index, u32 layer, int benb, + u32 color); +void nx_mlc_set_color_inversion(u32 module_index, u32 layer, int benb, + u32 color); +u32 nx_mlc_get_extended_color(u32 module_index, u32 color, + enum nx_mlc_rgbfmt format); +void nx_mlc_set_format_rgb(u32 module_index, u32 layer, + enum nx_mlc_rgbfmt format); +void nx_mlc_set_format_yuv(u32 module_index, enum nx_mlc_yuvfmt format); +void nx_mlc_set_position(u32 module_index, u32 layer, s32 sx, + s32 sy, s32 ex, s32 ey); +void nx_mlc_set_dither_enable_when_using_gamma(u32 module_index, + int benable); +int nx_mlc_get_dither_enable_when_using_gamma(u32 module_index); +void nx_mlc_set_gamma_priority(u32 module_index, int bvideolayer); +int nx_mlc_get_gamma_priority(u32 module_index); + +void nx_mlc_set_rgblayer_invalid_position(u32 module_index, u32 layer, + u32 region, s32 sx, + s32 sy, s32 ex, + s32 ey, int benb); +void nx_mlc_set_rgblayer_stride(u32 module_index, u32 layer, + s32 hstride, s32 vstride); +void nx_mlc_set_rgblayer_address(u32 module_index, u32 layer, u32 addr); +void nx_mlc_set_rgblayer_gama_table_power_mode(u32 module_index, + int bred, int bgreen, + int bblue); +void nx_mlc_get_rgblayer_gama_table_power_mode(u32 module_index, + int *pbred, int *pbgreen, + int *pbblue); +void nx_mlc_set_rgblayer_gama_table_sleep_mode(u32 module_index, + int bred, int bgreen, + int bblue); +void nx_mlc_get_rgblayer_gama_table_sleep_mode(u32 module_index, + int *pbred, int *pbgreen, + int *pbblue); +void nx_mlc_set_rgblayer_rgamma_table(u32 module_index, u32 dwaddress, + u32 dwdata); +void nx_mlc_set_rgblayer_ggamma_table(u32 module_index, u32 dwaddress, + u32 dwdata); +void nx_mlc_set_rgblayer_bgamma_table(u32 module_index, u32 dwaddress, + u32 dwdata); +void nx_mlc_set_rgblayer_gamma_enable(u32 module_index, int benable); +int nx_mlc_get_rgblayer_gamma_enable(u32 module_index); + +void nx_mlc_set_video_layer_stride(u32 module_index, s32 lu_stride, + s32 cb_stride, s32 cr_stride); +void nx_mlc_set_video_layer_address(u32 module_index, u32 lu_addr, + u32 cb_addr, u32 cr_addr); +void nx_mlc_set_video_layer_address_yuyv(u32 module_index, u32 addr, + s32 stride); +void nx_mlc_set_video_layer_scale_factor(u32 module_index, u32 hscale, + u32 vscale, int bhlumaenb, + int bhchromaenb, int bvlumaenb, + int bvchromaenb); +void nx_mlc_set_video_layer_scale_filter(u32 module_index, int bhlumaenb, + int bhchromaenb, int bvlumaenb, + int bvchromaenb); +void nx_mlc_get_video_layer_scale_filter(u32 module_index, + int *bhlumaenb, + int *bhchromaenb, + int *bvlumaenb, + int *bvchromaenb); +void nx_mlc_set_video_layer_scale(u32 module_index, u32 sw, u32 sh, + u32 dw, u32 dh, int bhlumaenb, + int bhchromaenb, int bvlumaenb, + int bvchromaenb); +void nx_mlc_set_video_layer_luma_enhance(u32 module_index, u32 contrast, + s32 brightness); +void nx_mlc_set_video_layer_chroma_enhance(u32 module_index, + u32 quadrant, s32 cb_a, + s32 cb_b, s32 cr_a, + s32 cr_b); +void nx_mlc_set_video_layer_line_buffer_power_mode(u32 module_index, + int benable); +int nx_mlc_get_video_layer_line_buffer_power_mode(u32 module_index); +void nx_mlc_set_video_layer_line_buffer_sleep_mode(u32 module_index, + int benable); +int nx_mlc_get_video_layer_line_buffer_sleep_mode(u32 module_index); +void nx_mlc_set_video_layer_gamma_enable(u32 module_index, int benable); +int nx_mlc_get_video_layer_gamma_enable(u32 module_index); + +void nx_mlc_set_gamma_table_poweroff(u32 module_index, int enb); + +enum mlc_rgbfmt { + rgbfmt_r5g6b5 = 0, + rgbfmt_x1r5g5b5 = 1, + rgbfmt_x4r4g4b4 = 2, + rgbfmt_x8r3g3b2 = 3, + rgbfmt_x8l8 = 4, + rgbfmt_l16 = 5, + rgbfmt_a1r5g5b5 = 6, + rgbfmt_a4r4g4b4 = 7, + rgbfmt_a8r3g3b2 = 8, + rgbfmt_a8l8 = 9, + rgbfmt_r8g8b8 = 10, + rgbfmt_x8r8g8b8 = 11, + rgbfmt_a8r8g8b8 = 12, + rgbfmt_g8r8_g8b8 = 13, + rgbfmt_r8g8_b8g8 = 14, + rgbfmt_b5g6r5 = 15, + rgbfmt_x1b5g5r5 = 16, + rgbfmt_x4b4g4r4 = 17, + rgbfmt_x8b3g3r2 = 18, + rgbfmt_a1b5g5r5 = 19, + rgbfmt_a4b4g4r4 = 20, + rgbfmt_a8b3g3r2 = 21, + rgbfmt_b8g8r8 = 22, + rgbfmt_x8b8g8r8 = 23, + rgbfmt_a8b8g8r8 = 24, + rgbfmt_g8b8_g8r8 = 25, + rgbfmt_b8g8_r8g8 = 26, + rgbfmt_pataletb = 27 +}; + +enum latyername { + topmlc = 0, + rgb0 = 1, + rgb1 = 2, + rgb2 = 3, + video = 4 +}; + +enum srammode { + poweroff = 0, + sleepmode = 2, + run = 3 +}; + +enum locksizesel { + locksize_4 = 0, + locksize_8 = 1, + locksize_16 = 2 +}; + +enum g3daddrchangeallowed { + prim = 0, + secon = 1, + primorsecon = 2, + primandsecon = 3 +}; + +void nx_mlc_set_mlctop_control_parameter(u32 module_index, + int field_enable, int mlcenable, + u8 priority, + enum g3daddrchangeallowed + g3daddr_change_allowed); +void nx_mlc_set_rgb0layer_control_parameter(u32 module_index, + int layer_enable, + int grp3denable, + int tp_enable, + u32 transparency_color, + int inv_enable, + u32 inverse_color, + int blend_enable, + u8 alpha_value, + enum mlc_rgbfmt rbgformat, + enum locksizesel + lock_size_select); + +u32 nx_mlc_get_rgbformat(enum mlc_rgbfmt rbgformat); +void nx_mlc_set_rgb1layer_control_parameter(u32 module_index, + int layer_enable, + int grp3denable, + int tp_enable, + u32 transparency_color, + int inv_enable, + u32 inverse_color, + int blend_enable, + u8 alpha_value, + enum mlc_rgbfmt rbgformat, + enum locksizesel + lock_size_select); + +void nx_mlc_set_rgb2layer_control_parameter(u32 module_index, + int layer_enable, + int grp3denable, + int tp_enable, + u32 transparency_color, + int inv_enable, + u32 inverse_color, + int blend_enable, + u8 alpha_value, + enum mlc_rgbfmt rbgformat, + enum locksizesel + lock_size_select); + +void nx_mlc_set_video_layer_control_parameter(u32 module_index, + int layer_enable, + int tp_enable, + u32 transparency_color, + int inv_enable, + u32 inverse_color, + int blend_enable, + u8 alpha_value, + enum nx_mlc_yuvfmt + yuvformat); + +void nx_mlc_set_srammode(u32 module_index, enum latyername layer_name, + enum srammode sram_mode); + +void nx_mlc_set_layer_reg_finish(u32 module_index, + enum latyername layer_name); + +void nx_mlc_set_video_layer_coordinate(u32 module_index, + int vfilterenable, + int hfilterenable, + int vfilterenable_c, + int hfilterenable_c, + u16 video_layer_with, + u16 video_layer_height, + s16 left, s16 right, + s16 top, s16 bottom); + +void nx_mlc_set_video_layer_filter_scale(u32 module_index, u32 hscale, + u32 vscale); +void nx_mlcsetgammasrammode(u32 module_index, enum srammode sram_mode); +void nx_mlc_set_gamma_control_parameter(u32 module_index, + int rgbgammaenb, int yuvgammaenb, + int yuvalphaarray, + int dither_enb); + +void nx_mlc_set_layer_alpha256(u32 module_index, u32 layer, u32 alpha); +int nx_mlc_is_under_flow(u32 module_index); + +struct nx_mlc_gamma_table_parameter { + u32 r_table[256]; + u32 g_table[256]; + u32 b_table[256]; + u32 ditherenb; + u32 alphaselect; + u32 yuvgammaenb; + u32 rgbgammaenb; + u32 allgammaenb; +}; + +void nx_mlc_set_gamma_table(u32 module_index, int enb, + struct nx_mlc_gamma_table_parameter *p_gammatable); +void nx_mlc_get_rgblayer_stride(u32 module_index, u32 layer, + s32 *hstride, s32 *vstride); +void nx_mlc_get_rgblayer_address(u32 module_index, u32 layer, + u32 *phys_address); +void nx_mlc_get_position(u32 module_index, u32 layer, int *left, + int *top, int *right, int *bottom); +void nx_mlc_get_video_layer_address_yuyv(u32 module_index, u32 *address, + u32 *stride); +void nx_mlc_get_video_layer_address(u32 module_index, u32 *lu_address, + u32 *cb_address, u32 *cr_address); +void nx_mlc_get_video_layer_stride(u32 module_index, u32 *lu_stride, + u32 *cb_stride, u32 *cr_stride); +void nx_mlc_get_video_layer_stride(u32 module_index, u32 *lu_stride, + u32 *cb_stride, u32 *cr_stride); +void nx_mlc_get_video_position(u32 module_index, int *left, int *top, + int *right, int *bottom); + +#endif
On Fri, Jul 10, 2020 at 07:07:33PM +0200, Stefan Bosch wrote:
Low level functions for MLC (Multi Layer Control) and MIPI (Mobile Industry Processor Interface).
Signed-off-by: Stefan Bosch stefan_b@posteo.net
Low level functions for LVDS and HDMI display interfaces.
Signed-off-by: Stefan Bosch stefan_b@posteo.net ---
(no changes since v1)
drivers/video/nexell/soc/s5pxx18_soc_hdmi.c | 50 +++ drivers/video/nexell/soc/s5pxx18_soc_hdmi.h | 488 ++++++++++++++++++++++++++++ drivers/video/nexell/soc/s5pxx18_soc_lvds.c | 278 ++++++++++++++++ drivers/video/nexell/soc/s5pxx18_soc_lvds.h | 83 +++++ 4 files changed, 899 insertions(+) create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_hdmi.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_hdmi.h create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_lvds.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_lvds.h
diff --git a/drivers/video/nexell/soc/s5pxx18_soc_hdmi.c b/drivers/video/nexell/soc/s5pxx18_soc_hdmi.c new file mode 100644 index 0000000..7b8be7e --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_hdmi.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <linux/types.h> +#include <linux/io.h> + +#include "s5pxx18_soc_hdmi.h" + +static u32 *hdmi_base_addr; + +u32 nx_hdmi_get_reg(u32 module_index, u32 offset) +{ + u32 *reg_addr; + u32 regvalue; + + reg_addr = hdmi_base_addr + (offset / sizeof(u32)); + regvalue = readl((u32 *)reg_addr); + + return regvalue; +} + +void nx_hdmi_set_reg(u32 module_index, u32 offset, u32 regvalue) +{ + s64 offset_new = (s64)((int32_t)offset); + u32 *reg_addr; + + reg_addr = hdmi_base_addr + (offset_new / sizeof(u32)); + writel(regvalue, (u32 *)reg_addr); +} + +void nx_hdmi_set_base_address(u32 module_index, void *base_address) +{ + hdmi_base_addr = (u32 *)base_address; +} + +void *nx_hdmi_get_base_address(u32 module_index) +{ + return (u32 *)hdmi_base_addr; +} + +u32 nx_hdmi_get_physical_address(u32 module_index) +{ + const u32 physical_addr[] = PHY_BASEADDR_HDMI_LIST; + + return physical_addr[module_index]; +} diff --git a/drivers/video/nexell/soc/s5pxx18_soc_hdmi.h b/drivers/video/nexell/soc/s5pxx18_soc_hdmi.h new file mode 100644 index 0000000..a4c5ab5 --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_hdmi.h @@ -0,0 +1,488 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _S5PXX18_SOC_HDMI_H_ +#define _S5PXX18_SOC_HDMI_H_ + +#include "s5pxx18_soc_disptop.h" + +#define PHY_BASEADDR_HDMI_PHY_MODULE 0xc00f0000 +#define PHY_BASEADDR_HDMI_LIST \ + { PHY_BASEADDR_HDMI_MODULE } + +#define HDMI_LINK_INTC_CON_0 (HDMI_ADDR_OFFSET + 0x00000000) +#define HDMI_LINK_INTC_FLAG_0 (HDMI_ADDR_OFFSET + 0x00000004) +#define HDMI_LINK_AESKEY_VALID (HDMI_ADDR_OFFSET + 0x00000008) +#define HDMI_LINK_HPD (HDMI_ADDR_OFFSET + 0x0000000C) +#define HDMI_LINK_INTC_CON_1 (HDMI_ADDR_OFFSET + 0x00000010) +#define HDMI_LINK_INTC_FLAG_1 (HDMI_ADDR_OFFSET + 0x00000014) +#define HDMI_LINK_PHY_STATUS_0 (HDMI_ADDR_OFFSET + 0x00000020) +#define HDMI_LINK_PHY_STATUS_CMU (HDMI_ADDR_OFFSET + 0x00000024) +#define HDMI_LINK_PHY_STATUS_PLL (HDMI_ADDR_OFFSET + 0x00000028) +#define HDMI_LINK_PHY_CON_0 (HDMI_ADDR_OFFSET + 0x00000030) +#define HDMI_LINK_HPD_CTRL (HDMI_ADDR_OFFSET + 0x00000040) +#define HDMI_LINK_HPD_STATUS (HDMI_ADDR_OFFSET + 0x00000044) +#define HDMI_LINK_HPD_TH_x (HDMI_ADDR_OFFSET + 0x00000050) + +#define HDMI_LINK_HDMI_CON_0 (HDMI_ADDR_OFFSET + 0x00010000) +#define HDMI_LINK_HDMI_CON_1 (HDMI_ADDR_OFFSET + 0x00010004) +#define HDMI_LINK_HDMI_CON_2 (HDMI_ADDR_OFFSET + 0x00010008) +#define HDMI_LINK_STATUS (HDMI_ADDR_OFFSET + 0x00010010) +#define HDMI_LINK_STATUS_EN (HDMI_ADDR_OFFSET + 0x00010020) + +#define HDMI_LINK_HDCP_SHA1_REN0 (HDMI_ADDR_OFFSET + 0x00010024) +#define HDMI_LINK_HDCP_SHA1_REN1 (HDMI_ADDR_OFFSET + 0x00010028) + +#define HDMI_LINK_MODE_SEL (HDMI_ADDR_OFFSET + 0x00010040) +#define HDMI_LINK_ENC_EN (HDMI_ADDR_OFFSET + 0x00010044) +#define HDMI_LINK_HDMI_YMAX (HDMI_ADDR_OFFSET + 0x00010060) +#define HDMI_LINK_HDMI_YMIN (HDMI_ADDR_OFFSET + 0x00010064) +#define HDMI_LINK_HDMI_CMAX (HDMI_ADDR_OFFSET + 0x00010068) +#define HDMI_LINK_HDMI_CMIN (HDMI_ADDR_OFFSET + 0x0001006C) +#define HDMI_LINK_H_BLANK_0 (HDMI_ADDR_OFFSET + 0x000100A0) +#define HDMI_LINK_H_BLANK_1 (HDMI_ADDR_OFFSET + 0x000100A4) +#define HDMI_LINK_V2_BLANK_0 (HDMI_ADDR_OFFSET + 0x000100B0) +#define HDMI_LINK_V2_BLANK_1 (HDMI_ADDR_OFFSET + 0x000100B4) +#define HDMI_LINK_V1_BLANK_0 (HDMI_ADDR_OFFSET + 0x000100B8) +#define HDMI_LINK_V1_BLANK_1 (HDMI_ADDR_OFFSET + 0x000100BC) +#define HDMI_LINK_V_LINE_0 (HDMI_ADDR_OFFSET + 0x000100C0) +#define HDMI_LINK_V_LINE_1 (HDMI_ADDR_OFFSET + 0x000100C4) +#define HDMI_LINK_H_LINE_0 (HDMI_ADDR_OFFSET + 0x000100C8) +#define HDMI_LINK_H_LINE_1 (HDMI_ADDR_OFFSET + 0x000100CC) +#define HDMI_LINK_HSYNC_POL (HDMI_ADDR_OFFSET + 0x000100E0) +#define HDMI_LINK_VSYNC_POL (HDMI_ADDR_OFFSET + 0x000100E4) +#define HDMI_LINK_INT_PRO_MODE (HDMI_ADDR_OFFSET + 0x000100E8) +#define HDMI_LINK_SEND_START_0 (HDMI_ADDR_OFFSET + 0x000100F0) +#define HDMI_LINK_SEND_START_1 (HDMI_ADDR_OFFSET + 0x000100F4) +#define HDMI_LINK_SEND_END_0 (HDMI_ADDR_OFFSET + 0x00010100) +#define HDMI_LINK_SEND_END_1 (HDMI_ADDR_OFFSET + 0x00010104) +#define HDMI_LINK_SEND_END_2 (HDMI_ADDR_OFFSET + 0x00010108) +#define HDMI_LINK_V_BLANK_F0_0 (HDMI_ADDR_OFFSET + 0x00010110) +#define HDMI_LINK_V_BLANK_F0_1 (HDMI_ADDR_OFFSET + 0x00010114) +#define HDMI_LINK_V_BLANK_F1_0 (HDMI_ADDR_OFFSET + 0x00010118) +#define HDMI_LINK_V_BLANK_F1_1 (HDMI_ADDR_OFFSET + 0x0001011C) +#define HDMI_LINK_H_SYNC_START_0 (HDMI_ADDR_OFFSET + 0x00010120) +#define HDMI_LINK_H_SYNC_START_1 (HDMI_ADDR_OFFSET + 0x00010124) +#define HDMI_LINK_H_SYNC_END_0 (HDMI_ADDR_OFFSET + 0x00010128) +#define HDMI_LINK_H_SYNC_END_1 (HDMI_ADDR_OFFSET + 0x0001012C) +#define HDMI_LINK_V_SYNC_LINE_BEF_2_0 (HDMI_ADDR_OFFSET + 0x00010130) +#define HDMI_LINK_V_SYNC_LINE_BEF_2_1 (HDMI_ADDR_OFFSET + 0x00010134) +#define HDMI_LINK_V_SYNC_LINE_BEF_1_0 (HDMI_ADDR_OFFSET + 0x00010138) +#define HDMI_LINK_V_SYNC_LINE_BEF_1_1 (HDMI_ADDR_OFFSET + 0x0001013C) +#define HDMI_LINK_V_SYNC_LINE_AFT_2_0 (HDMI_ADDR_OFFSET + 0x00010140) +#define HDMI_LINK_V_SYNC_LINE_AFT_2_1 (HDMI_ADDR_OFFSET + 0x00010144) +#define HDMI_LINK_V_SYNC_LINE_AFT_1_0 (HDMI_ADDR_OFFSET + 0x00010148) +#define HDMI_LINK_V_SYNC_LINE_AFT_1_1 (HDMI_ADDR_OFFSET + 0x0001014C) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_2_0 (HDMI_ADDR_OFFSET + 0x00010150) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_2_1 (HDMI_ADDR_OFFSET + 0x00010154) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_1_0 (HDMI_ADDR_OFFSET + 0x00010158) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_1_1 (HDMI_ADDR_OFFSET + 0x0001015C) +#define HDMI_LINK_V_BLANK_F2_0 (HDMI_ADDR_OFFSET + 0x00010160) +#define HDMI_LINK_V_BLANK_F2_1 (HDMI_ADDR_OFFSET + 0x00010164) +#define HDMI_LINK_V_BLANK_F3_0 (HDMI_ADDR_OFFSET + 0x00010168) +#define HDMI_LINK_V_BLANK_F3_1 (HDMI_ADDR_OFFSET + 0x0001016C) +#define HDMI_LINK_V_BLANK_F4_0 (HDMI_ADDR_OFFSET + 0x00010170) +#define HDMI_LINK_V_BLANK_F4_1 (HDMI_ADDR_OFFSET + 0x00010174) +#define HDMI_LINK_V_BLANK_F5_0 (HDMI_ADDR_OFFSET + 0x00010178) +#define HDMI_LINK_V_BLANK_F5_1 (HDMI_ADDR_OFFSET + 0x0001017C) +#define HDMI_LINK_V_SYNC_LINE_AFT_3_0 (HDMI_ADDR_OFFSET + 0x00010180) +#define HDMI_LINK_V_SYNC_LINE_AFT_3_1 (HDMI_ADDR_OFFSET + 0x00010184) +#define HDMI_LINK_V_SYNC_LINE_AFT_4_0 (HDMI_ADDR_OFFSET + 0x00010188) +#define HDMI_LINK_V_SYNC_LINE_AFT_4_1 (HDMI_ADDR_OFFSET + 0x0001018C) +#define HDMI_LINK_V_SYNC_LINE_AFT_5_0 (HDMI_ADDR_OFFSET + 0x00010190) +#define HDMI_LINK_V_SYNC_LINE_AFT_5_1 (HDMI_ADDR_OFFSET + 0x00010194) +#define HDMI_LINK_V_SYNC_LINE_AFT_6_0 (HDMI_ADDR_OFFSET + 0x00010198) +#define HDMI_LINK_V_SYNC_LINE_AFT_6_1 (HDMI_ADDR_OFFSET + 0x0001019C) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_3_0 (HDMI_ADDR_OFFSET + 0x000101A0) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_3_1 (HDMI_ADDR_OFFSET + 0x000101A4) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_4_0 (HDMI_ADDR_OFFSET + 0x000101A8) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_4_1 (HDMI_ADDR_OFFSET + 0x000101AC) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_5_0 (HDMI_ADDR_OFFSET + 0x000101B0) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_5_1 (HDMI_ADDR_OFFSET + 0x000101B4) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_6_0 (HDMI_ADDR_OFFSET + 0x000101B8) +#define HDMI_LINK_V_SYNC_LINE_AFT_PXL_6_1 (HDMI_ADDR_OFFSET + 0x000101BC) +#define HDMI_LINK_VACT_SPACE1_0 (HDMI_ADDR_OFFSET + 0x000101C0) +#define HDMI_LINK_VACT_SPACE1_1 (HDMI_ADDR_OFFSET + 0x000101C4) +#define HDMI_LINK_VACT_SPACE2_0 (HDMI_ADDR_OFFSET + 0x000101C8) +#define HDMI_LINK_VACT_SPACE2_1 (HDMI_ADDR_OFFSET + 0x000101CC) +#define HDMI_LINK_VACT_SPACE3_0 (HDMI_ADDR_OFFSET + 0x000101D0) +#define HDMI_LINK_VACT_SPACE3_1 (HDMI_ADDR_OFFSET + 0x000101D4) +#define HDMI_LINK_VACT_SPACE4_0 (HDMI_ADDR_OFFSET + 0x000101D8) +#define HDMI_LINK_VACT_SPACE4_1 (HDMI_ADDR_OFFSET + 0x000101DC) +#define HDMI_LINK_VACT_SPACE5_0 (HDMI_ADDR_OFFSET + 0x000101E0) +#define HDMI_LINK_VACT_SPACE5_1 (HDMI_ADDR_OFFSET + 0x000101E4) +#define HDMI_LINK_VACT_SPACE6_0 (HDMI_ADDR_OFFSET + 0x000101E8) +#define HDMI_LINK_VACT_SPACE6_1 (HDMI_ADDR_OFFSET + 0x000101EC) + +#define HDMI_LINK_CSC_MUX (HDMI_ADDR_OFFSET + 0x000101F0) +#define HDMI_LINK_SYNC_GEN_MUX (HDMI_ADDR_OFFSET + 0x000101F4) + +#define HDMI_LINK_GCP_CON (HDMI_ADDR_OFFSET + 0x00010200) +#define HDMI_LINK_GCP_BYTE1 (HDMI_ADDR_OFFSET + 0x00010210) +#define HDMI_LINK_GCP_BYTE2 (HDMI_ADDR_OFFSET + 0x00010214) +#define HDMI_LINK_GCP_BYTE3 (HDMI_ADDR_OFFSET + 0x00010218) +#define HDMI_LINK_ASP_CON (HDMI_ADDR_OFFSET + 0x00010300) +#define HDMI_LINK_ASP_SP_FLAT (HDMI_ADDR_OFFSET + 0x00010304) +#define HDMI_LINK_ASP_CHCFG0 (HDMI_ADDR_OFFSET + 0x00010310) +#define HDMI_LINK_ASP_CHCFG1 (HDMI_ADDR_OFFSET + 0x00010314) +#define HDMI_LINK_ASP_CHCFG2 (HDMI_ADDR_OFFSET + 0x00010318) +#define HDMI_LINK_ASP_CHCFG3 (HDMI_ADDR_OFFSET + 0x0001031C) +#define HDMI_LINK_ACR_CON (HDMI_ADDR_OFFSET + 0x00010400) +#define HDMI_LINK_ACR_MCTS0 (HDMI_ADDR_OFFSET + 0x00010410) +#define HDMI_LINK_ACR_MCTS1 (HDMI_ADDR_OFFSET + 0x00010414) +#define HDMI_LINK_ACR_MCTS2 (HDMI_ADDR_OFFSET + 0x00010418) +#define HDMI_LINK_ACR_N0 (HDMI_ADDR_OFFSET + 0x00010430) +#define HDMI_LINK_ACR_N1 (HDMI_ADDR_OFFSET + 0x00010434) +#define HDMI_LINK_ACR_N2 (HDMI_ADDR_OFFSET + 0x00010438) +#define HDMI_LINK_ACP_CON (HDMI_ADDR_OFFSET + 0x00010500) +#define HDMI_LINK_ACP_TYPE (HDMI_ADDR_OFFSET + 0x00010514) +#define HDMI_LINK_ACP_DATAX (HDMI_ADDR_OFFSET + 0x00010520) +#define HDMI_LINK_ISRC_CON (HDMI_ADDR_OFFSET + 0x00010600) +#define HDMI_LINK_ISRC1_HEADER1 (HDMI_ADDR_OFFSET + 0x00010614) +#define HDMI_LINK_ISRC1_DATAX (HDMI_ADDR_OFFSET + 0x00010620) +#define HDMI_LINK_ISRC2_DATAX (HDMI_ADDR_OFFSET + 0x000106A0) +#define HDMI_LINK_AVI_CON (HDMI_ADDR_OFFSET + 0x00010700) +#define HDMI_LINK_AVI_HEADER0 (HDMI_ADDR_OFFSET + 0x00010710) +#define HDMI_LINK_AVI_HEADER1 (HDMI_ADDR_OFFSET + 0x00010714) +#define HDMI_LINK_AVI_HEADER2 (HDMI_ADDR_OFFSET + 0x00010718) +#define HDMI_LINK_AVI_CHECK_SUM (HDMI_ADDR_OFFSET + 0x0001071C) +#define HDMI_LINK_AVI_BYTEX (HDMI_ADDR_OFFSET + 0x00010720) +#define HDMI_LINK_AVI_BYTE00 (HDMI_ADDR_OFFSET + 0x00010720) +#define HDMI_LINK_AVI_BYTE01 (HDMI_ADDR_OFFSET + 0x00010724) +#define HDMI_LINK_AVI_BYTE02 (HDMI_ADDR_OFFSET + 0x00010728) +#define HDMI_LINK_AVI_BYTE03 (HDMI_ADDR_OFFSET + 0x0001073C) +#define HDMI_LINK_AVI_BYTE04 (HDMI_ADDR_OFFSET + 0x00010730) +#define HDMI_LINK_AVI_BYTE05 (HDMI_ADDR_OFFSET + 0x00010734) +#define HDMI_LINK_AVI_BYTE06 (HDMI_ADDR_OFFSET + 0x00010738) +#define HDMI_LINK_AVI_BYTE07 (HDMI_ADDR_OFFSET + 0x0001074C) +#define HDMI_LINK_AVI_BYTE08 (HDMI_ADDR_OFFSET + 0x00010740) +#define HDMI_LINK_AVI_BYTE09 (HDMI_ADDR_OFFSET + 0x00010744) +#define HDMI_LINK_AVI_BYTE10 (HDMI_ADDR_OFFSET + 0x00010748) +#define HDMI_LINK_AVI_BYTE11 (HDMI_ADDR_OFFSET + 0x0001074C) +#define HDMI_LINK_AVI_BYTE12 (HDMI_ADDR_OFFSET + 0x00010750) +#define HDMI_LINK_AUI_CON (HDMI_ADDR_OFFSET + 0x00010800) +#define HDMI_LINK_AUI_HEADER0 (HDMI_ADDR_OFFSET + 0x00010810) +#define HDMI_LINK_AUI_HEADER1 (HDMI_ADDR_OFFSET + 0x00010814) +#define HDMI_LINK_AUI_HEADER2 (HDMI_ADDR_OFFSET + 0x00010818) +#define HDMI_LINK_AUI_CHECK_SUM (HDMI_ADDR_OFFSET + 0x0001081C) +#define HDMI_LINK_AUI_BYTEX (HDMI_ADDR_OFFSET + 0x00010820) +#define HDMI_LINK_MPG_CON (HDMI_ADDR_OFFSET + 0x00010900) +#define HDMI_LINK_MPG_CHECK_SUM (HDMI_ADDR_OFFSET + 0x0001091C) +#define HDMI_LINK_MPG_DATAX (HDMI_ADDR_OFFSET + 0x00010920) +#define HDMI_LINK_SPD_CON (HDMI_ADDR_OFFSET + 0x00010A00) +#define HDMI_LINK_SPD_HEADER0 (HDMI_ADDR_OFFSET + 0x00010A10) +#define HDMI_LINK_SPD_HEADER1 (HDMI_ADDR_OFFSET + 0x00010A14) +#define HDMI_LINK_SPD_HEADER2 (HDMI_ADDR_OFFSET + 0x00010A18) +#define HDMI_LINK_SPD_DATAX (HDMI_ADDR_OFFSET + 0x00010A20) +#define HDMI_LINK_GAMUT_CON (HDMI_ADDR_OFFSET + 0x00010B00) +#define HDMI_LINK_GAMUT_HEADER0 (HDMI_ADDR_OFFSET + 0x00010B10) +#define HDMI_LINK_GAMUT_HEADER1 (HDMI_ADDR_OFFSET + 0x00010B14) +#define HDMI_LINK_GAMUT_HEADER2 (HDMI_ADDR_OFFSET + 0x00010B18) +#define HDMI_LINK_GAMUT_METADATAX (HDMI_ADDR_OFFSET + 0x00010B20) +#define HDMI_LINK_VSI_CON (HDMI_ADDR_OFFSET + 0x00010C00) +#define HDMI_LINK_VSI_HEADER0 (HDMI_ADDR_OFFSET + 0x00010C10) +#define HDMI_LINK_VSI_HEADER1 (HDMI_ADDR_OFFSET + 0x00010C14) +#define HDMI_LINK_VSI_HEADER2 (HDMI_ADDR_OFFSET + 0x00010C18) +#define HDMI_LINK_VSI_DATAX (HDMI_ADDR_OFFSET + 0x00010C20) +#define HDMI_LINK_VSI_DATA00 (HDMI_ADDR_OFFSET + 0x00010C20) +#define HDMI_LINK_VSI_DATA01 (HDMI_ADDR_OFFSET + 0x00010C24) +#define HDMI_LINK_VSI_DATA02 (HDMI_ADDR_OFFSET + 0x00010C28) +#define HDMI_LINK_VSI_DATA03 (HDMI_ADDR_OFFSET + 0x00010C2C) +#define HDMI_LINK_VSI_DATA04 (HDMI_ADDR_OFFSET + 0x00010C30) +#define HDMI_LINK_VSI_DATA05 (HDMI_ADDR_OFFSET + 0x00010C34) +#define HDMI_LINK_VSI_DATA06 (HDMI_ADDR_OFFSET + 0x00010C38) +#define HDMI_LINK_VSI_DATA07 (HDMI_ADDR_OFFSET + 0x00010C3C) +#define HDMI_LINK_VSI_DATA08 (HDMI_ADDR_OFFSET + 0x00010C40) +#define HDMI_LINK_VSI_DATA09 (HDMI_ADDR_OFFSET + 0x00010C44) +#define HDMI_LINK_VSI_DATA10 (HDMI_ADDR_OFFSET + 0x00010C48) +#define HDMI_LINK_VSI_DATA11 (HDMI_ADDR_OFFSET + 0x00010c4c) +#define HDMI_LINK_VSI_DATA12 (HDMI_ADDR_OFFSET + 0x00010C50) +#define HDMI_LINK_VSI_DATA13 (HDMI_ADDR_OFFSET + 0x00010C54) +#define HDMI_LINK_VSI_DATA14 (HDMI_ADDR_OFFSET + 0x00010C58) +#define HDMI_LINK_VSI_DATA15 (HDMI_ADDR_OFFSET + 0x00010C5c) +#define HDMI_LINK_VSI_DATA16 (HDMI_ADDR_OFFSET + 0x00010C60) +#define HDMI_LINK_VSI_DATA17 (HDMI_ADDR_OFFSET + 0x00010C64) +#define HDMI_LINK_VSI_DATA18 (HDMI_ADDR_OFFSET + 0x00010C68) +#define HDMI_LINK_VSI_DATA19 (HDMI_ADDR_OFFSET + 0x00010C6c) +#define HDMI_LINK_VSI_DATA20 (HDMI_ADDR_OFFSET + 0x00010C70) +#define HDMI_LINK_VSI_DATA21 (HDMI_ADDR_OFFSET + 0x00010c74) +#define HDMI_LINK_VSI_DATA22 (HDMI_ADDR_OFFSET + 0x00010C78) +#define HDMI_LINK_VSI_DATA23 (HDMI_ADDR_OFFSET + 0x00010C7c) +#define HDMI_LINK_VSI_DATA24 (HDMI_ADDR_OFFSET + 0x00010C80) +#define HDMI_LINK_VSI_DATA25 (HDMI_ADDR_OFFSET + 0x00010C84) +#define HDMI_LINK_VSI_DATA26 (HDMI_ADDR_OFFSET + 0x00010C88) +#define HDMI_LINK_VSI_DATA27 (HDMI_ADDR_OFFSET + 0x00010C8C) +#define HDMI_LINK_DC_CONTROL (HDMI_ADDR_OFFSET + 0x00010D00) +#define HDMI_LINK_VIDEO_PATTERN_GEN (HDMI_ADDR_OFFSET + 0x00010D04) +#define HDMI_LINK_AN_SEED_SEL (HDMI_ADDR_OFFSET + 0x00010E48) +#define HDMI_LINK_AN_SEED_0 (HDMI_ADDR_OFFSET + 0x00010E58) +#define HDMI_LINK_AN_SEED_1 (HDMI_ADDR_OFFSET + 0x00010E5C) +#define HDMI_LINK_AN_SEED_2 (HDMI_ADDR_OFFSET + 0x00010E60) +#define HDMI_LINK_AN_SEED_3 (HDMI_ADDR_OFFSET + 0x00010E64) +#define HDMI_LINK_HDCP_SHA1_X (HDMI_ADDR_OFFSET + 0x00017000) + +#define HDMI_LINK_HDCP_SHA1_0_0 (HDMI_LINK_HDCP_SHA1_x + 0x00) +#define HDMI_LINK_HDCP_SHA1_0_1 (HDMI_LINK_HDCP_SHA1_0_0 + 0x04) +#define HDMI_LINK_HDCP_SHA1_0_2 (HDMI_LINK_HDCP_SHA1_0_0 + 0x08) +#define HDMI_LINK_HDCP_SHA1_0_3 (HDMI_LINK_HDCP_SHA1_0_0 + 0x0C) +#define HDMI_LINK_HDCP_SHA1_1_0 (HDMI_LINK_HDCP_SHA1_x + 0x10) +#define HDMI_LINK_HDCP_SHA1_1_1 (HDMI_LINK_HDCP_SHA1_1_0 + 0x04) +#define HDMI_LINK_HDCP_SHA1_1_2 (HDMI_LINK_HDCP_SHA1_1_0 + 0x08) +#define HDMI_LINK_HDCP_SHA1_1_3 (HDMI_LINK_HDCP_SHA1_1_0 + 0x0C) +#define HDMI_LINK_HDCP_SHA1_2_0 (HDMI_LINK_HDCP_SHA1_x + 0x20) +#define HDMI_LINK_HDCP_SHA1_2_1 (HDMI_LINK_HDCP_SHA1_2_0 + 0x04) +#define HDMI_LINK_HDCP_SHA1_2_2 (HDMI_LINK_HDCP_SHA1_2_0 + 0x08) +#define HDMI_LINK_HDCP_SHA1_2_3 (HDMI_LINK_HDCP_SHA1_2_0 + 0x0C) +#define HDMI_LINK_HDCP_SHA1_3_0 (HDMI_LINK_HDCP_SHA1_x + 0x30) +#define HDMI_LINK_HDCP_SHA1_3_1 (HDMI_LINK_HDCP_SHA1_3_0 + 0x04) +#define HDMI_LINK_HDCP_SHA1_3_2 (HDMI_LINK_HDCP_SHA1_3_0 + 0x08) +#define HDMI_LINK_HDCP_SHA1_3_3 (HDMI_LINK_HDCP_SHA1_3_0 + 0x0C) +#define HDMI_LINK_HDCP_SHA1_4_0 (HDMI_LINK_HDCP_SHA1_x + 0x40) +#define HDMI_LINK_HDCP_SHA1_4_1 (HDMI_LINK_HDCP_SHA1_4_0 + 0x04) +#define HDMI_LINK_HDCP_SHA1_4_2 (HDMI_LINK_HDCP_SHA1_4_0 + 0x08) +#define HDMI_LINK_HDCP_SHA1_4_3 (HDMI_LINK_HDCP_SHA1_4_0 + 0x0C) + +#define HDMI_LINK_HDCP_KSV_LIST_X (HDMI_ADDR_OFFSET + 0x00017050) + +#define HDMI_LINK_HDCP_KSV_0_0 (HDMI_LINK_HDCP_KSV_LIST_X + 0x00) +#define HDMI_LINK_HDCP_KSV_0_1 (HDMI_LINK_HDCP_KSV_LIST_X + 0x04) +#define HDMI_LINK_HDCP_KSV_0_2 (HDMI_LINK_HDCP_KSV_LIST_X + 0x08) +#define HDMI_LINK_HDCP_KSV_0_3 (HDMI_LINK_HDCP_KSV_LIST_X + 0x0C) +#define HDMI_LINK_HDCP_KSV_1_0 (HDMI_LINK_HDCP_KSV_LIST_X + 0x10) +#define HDMI_LINK_HDCP_KSV_1_1 (HDMI_LINK_HDCP_KSV_LIST_X + 0x14) + +#define HDMI_LINK_HDCP_KSV_LIST_0_0 (HDMI_LINK_HDCP_KSV_LIST_X + 0x00) +#define HDMI_LINK_HDCP_KSV_LIST_0_1 (HDMI_LINK_HDCP_KSV_LIST_X + 0x04) +#define HDMI_LINK_HDCP_KSV_LIST_0_2 (HDMI_LINK_HDCP_KSV_LIST_X + 0x08) +#define HDMI_LINK_HDCP_KSV_LIST_0_3 (HDMI_LINK_HDCP_KSV_LIST_X + 0x0C) +#define HDMI_LINK_HDCP_KSV_LIST_1_0 (HDMI_LINK_HDCP_KSV_LIST_X + 0x10) +#define HDMI_LINK_HDCP_KSV_LIST_1_1 (HDMI_LINK_HDCP_KSV_LIST_X + 0x14) + +#define HDMI_LINK_HDCP_KSV_LIST_CON (HDMI_ADDR_OFFSET + 0x00017064) +#define HDMI_LINK_HDCP_SHA_RESULT (HDMI_ADDR_OFFSET + 0x00017070) +#define HDMI_LINK_HDCP_CTRL1 (HDMI_ADDR_OFFSET + 0x00017080) +#define HDMI_LINK_HDCP_CTRL2 (HDMI_ADDR_OFFSET + 0x00017084) +#define HDMI_LINK_HDCP_CHECK_RESULT (HDMI_ADDR_OFFSET + 0x00017090) +#define HDMI_LINK_HDCP_BKSV_X (HDMI_ADDR_OFFSET + 0x000170A0) + +#define HDMI_LINK_HDCP_BKSV0_0 (HDMI_ADDR_OFFSET + 0x000170A0) +#define HDMI_LINK_HDCP_BKSV0_1 (HDMI_ADDR_OFFSET + 0x000170A4) +#define HDMI_LINK_HDCP_BKSV0_2 (HDMI_ADDR_OFFSET + 0x000170A8) +#define HDMI_LINK_HDCP_BKSV0_3 (HDMI_ADDR_OFFSET + 0x000170AC) +#define HDMI_LINK_HDCP_BKSV1 (HDMI_ADDR_OFFSET + 0x000170B0) + +#define HDMI_LINK_HDCP_AKSV_X (HDMI_ADDR_OFFSET + 0x000170C0) +#define HDMI_LINK_HDCP_AN_X (HDMI_ADDR_OFFSET + 0x000170E0) +#define HDMI_LINK_HDCP_BCAPS (HDMI_ADDR_OFFSET + 0x00017100) +#define HDMI_LINK_HDCP_BSTATUS_0 (HDMI_ADDR_OFFSET + 0x00017110) +#define HDMI_LINK_HDCP_BSTATUS_1 (HDMI_ADDR_OFFSET + 0x00017114) +#define HDMI_LINK_HDCP_RI_0 (HDMI_ADDR_OFFSET + 0x00017140) +#define HDMI_LINK_HDCP_RI_1 (HDMI_ADDR_OFFSET + 0x00017144) + +#define HDMI_LINK_HDCP_OFFSET_TX_0 (HDMI_ADDR_OFFSET + 0x00017160) +#define HDMI_LINK_HDCP_OFFSET_TX_1 (HDMI_ADDR_OFFSET + 0x00017164) +#define HDMI_LINK_HDCP_OFFSET_TX_2 (HDMI_ADDR_OFFSET + 0x00017168) +#define HDMI_LINK_HDCP_OFFSET_TX_3 (HDMI_ADDR_OFFSET + 0x0001716C) +#define HDMI_LINK_HDCP_CYCLE_AA (HDMI_ADDR_OFFSET + 0x00017170) + +#define HDMI_LINK_HDCP_I2C_INT (HDMI_ADDR_OFFSET + 0x00017180) +#define HDMI_LINK_HDCP_AN_INT (HDMI_ADDR_OFFSET + 0x00017190) +#define HDMI_LINK_HDCP_WATCHDOG_INT (HDMI_ADDR_OFFSET + 0x000171A0) +#define HDMI_LINK_HDCP_RI_INT (HDMI_ADDR_OFFSET + 0x000171B0) +#define HDMI_LINK_HDCP_RI_COMPARE_0 (HDMI_ADDR_OFFSET + 0x000171D0) +#define HDMI_LINK_HDCP_RI_COMPARE_1 (HDMI_ADDR_OFFSET + 0x000171D4) + +#define HDMI_LINK_HDCP_RI_INT (HDMI_ADDR_OFFSET + 0x000171B0) +#define HDMI_LINK_HDCP_RI_COMPARE_0 (HDMI_ADDR_OFFSET + 0x000171D0) +#define HDMI_LINK_HDCP_RI_COMPARE_1 (HDMI_ADDR_OFFSET + 0x000171D4) + +#define HDMI_LINK_HDCP_FRAME_COUNT (HDMI_ADDR_OFFSET + 0x000171E0) +#define HDMI_LINK_RGB_ROUND_EN (HDMI_ADDR_OFFSET + 0x0001D500) +#define HDMI_LINK_VACT_SPACE_R_0 (HDMI_ADDR_OFFSET + 0x0001D504) +#define HDMI_LINK_VACT_SPACE_R_1 (HDMI_ADDR_OFFSET + 0x0001D508) +#define HDMI_LINK_VACT_SPACE_G_0 (HDMI_ADDR_OFFSET + 0x0001D50C) +#define HDMI_LINK_VACT_SPACE_G_1 (HDMI_ADDR_OFFSET + 0x0001D510) +#define HDMI_LINK_VACT_SPACE_B_0 (HDMI_ADDR_OFFSET + 0x0001D514) +#define HDMI_LINK_VACT_SPACE_B_1 (HDMI_ADDR_OFFSET + 0x0001D518) +#define HDMI_LINK_BLUE_SCREEN_R_0 (HDMI_ADDR_OFFSET + 0x0001D520) +#define HDMI_LINK_BLUE_SCREEN_R_1 (HDMI_ADDR_OFFSET + 0x0001D524) +#define HDMI_LINK_BLUE_SCREEN_G_0 (HDMI_ADDR_OFFSET + 0x0001D528) +#define HDMI_LINK_BLUE_SCREEN_G_1 (HDMI_ADDR_OFFSET + 0x0001D52C) +#define HDMI_LINK_BLUE_SCREEN_B_0 (HDMI_ADDR_OFFSET + 0x0001D530) +#define HDMI_LINK_BLUE_SCREEN_B_1 (HDMI_ADDR_OFFSET + 0x0001D534) +#define HDMI_LINK_AES_START (HDMI_ADDR_OFFSET + 0x00020000) +#define HDMI_LINK_AES_DATA_SIZE_L (HDMI_ADDR_OFFSET + 0x00020020) +#define HDMI_LINK_AES_DATA_SIZE_H (HDMI_ADDR_OFFSET + 0x00020024) +#define HDMI_LINK_AES_DATA (HDMI_ADDR_OFFSET + 0x00020040) +#define HDMI_LINK_SPDIFIN_CLK_CTRL (HDMI_ADDR_OFFSET + 0x00030000) +#define HDMI_LINK_SPDIFIN_OP_CTRL (HDMI_ADDR_OFFSET + 0x00030004) +#define HDMI_LINK_SPDIFIN_IRQ_MASK (HDMI_ADDR_OFFSET + 0x00030008) +#define HDMI_LINK_SPDIFIN_IRQ_STATUS (HDMI_ADDR_OFFSET + 0x0003000C) +#define HDMI_LINK_SPDIFIN_CONFIG_1 (HDMI_ADDR_OFFSET + 0x00030010) +#define HDMI_LINK_SPDIFIN_CONFIG_2 (HDMI_ADDR_OFFSET + 0x00030014) +#define HDMI_LINK_SPDIFIN_USER_VALUE_1 (HDMI_ADDR_OFFSET + 0x00030020) +#define HDMI_LINK_SPDIFIN_USER_VALUE_2 (HDMI_ADDR_OFFSET + 0x00030024) +#define HDMI_LINK_SPDIFIN_USER_VALUE_3 (HDMI_ADDR_OFFSET + 0x00030028) +#define HDMI_LINK_SPDIFIN_USER_VALUE_4 (HDMI_ADDR_OFFSET + 0x0003002C) +#define HDMI_LINK_SPDIFIN_CH_STATUS_0_1 (HDMI_ADDR_OFFSET + 0x00030030) +#define HDMI_LINK_SPDIFIN_CH_STATUS_0_2 (HDMI_ADDR_OFFSET + 0x00030034) +#define HDMI_LINK_SPDIFIN_CH_STATUS_0_3 (HDMI_ADDR_OFFSET + 0x00030038) +#define HDMI_LINK_SPDIFIN_CH_STATUS_0_4 (HDMI_ADDR_OFFSET + 0x0003003C) +#define HDMI_LINK_SPDIFIN_CH_STATUS_1 (HDMI_ADDR_OFFSET + 0x00030040) +#define HDMI_LINK_SPDIFIN_FRAME_PERIOD_1 (HDMI_ADDR_OFFSET + 0x00030048) +#define HDMI_LINK_SPDIFIN_FRAME_PERIOD_2 (HDMI_ADDR_OFFSET + 0x0003004C) +#define HDMI_LINK_SPDIFIN_PC_INFO_1 (HDMI_ADDR_OFFSET + 0x00030050) +#define HDMI_LINK_SPDIFIN_PC_INFO_2 (HDMI_ADDR_OFFSET + 0x00030054) +#define HDMI_LINK_SPDIFIN_PD_INFO_1 (HDMI_ADDR_OFFSET + 0x00030058) +#define HDMI_LINK_SPDIFIN_PD_INFO_2 (HDMI_ADDR_OFFSET + 0x0003005C) +#define HDMI_LINK_SPDIFIN_DATA_BUF_0_1 (HDMI_ADDR_OFFSET + 0x00030060) +#define HDMI_LINK_SPDIFIN_DATA_BUF_0_2 (HDMI_ADDR_OFFSET + 0x00030064) +#define HDMI_LINK_SPDIFIN_DATA_BUF_0_3 (HDMI_ADDR_OFFSET + 0x00030068) +#define HDMI_LINK_SPDIFIN_USER_BUF_0 (HDMI_ADDR_OFFSET + 0x0003006C) +#define HDMI_LINK_SPDIFIN_DATA_BUF_1_1 (HDMI_ADDR_OFFSET + 0x00030070) +#define HDMI_LINK_SPDIFIN_DATA_BUF_1_2 (HDMI_ADDR_OFFSET + 0x00030074) +#define HDMI_LINK_SPDIFIN_DATA_BUF_1_3 (HDMI_ADDR_OFFSET + 0x00030078) +#define HDMI_LINK_SPDIFIN_USER_BUF_1 (HDMI_ADDR_OFFSET + 0x0003007C) +#define HDMI_LINK_I2S_CLK_CON (HDMI_ADDR_OFFSET + 0x00040000) +#define HDMI_LINK_I2S_CON_1 (HDMI_ADDR_OFFSET + 0x00040004) +#define HDMI_LINK_I2S_CON_2 (HDMI_ADDR_OFFSET + 0x00040008) +#define HDMI_LINK_I2S_PIN_SEL_0 (HDMI_ADDR_OFFSET + 0x0004000C) +#define HDMI_LINK_I2S_PIN_SEL_1 (HDMI_ADDR_OFFSET + 0x00040010) +#define HDMI_LINK_I2S_PIN_SEL_2 (HDMI_ADDR_OFFSET + 0x00040014) +#define HDMI_LINK_I2S_PIN_SEL_3 (HDMI_ADDR_OFFSET + 0x00040018) +#define HDMI_LINK_I2S_DSD_CON (HDMI_ADDR_OFFSET + 0x0004001C) +#define HDMI_LINK_I2S_MUX_CON (HDMI_ADDR_OFFSET + 0x00040020) +#define HDMI_LINK_I2S_CH_ST_CON (HDMI_ADDR_OFFSET + 0x00040024) +#define HDMI_LINK_I2S_CH_ST_0 (HDMI_ADDR_OFFSET + 0x00040028) +#define HDMI_LINK_I2S_CH_ST_1 (HDMI_ADDR_OFFSET + 0x0004002C) +#define HDMI_LINK_I2S_CH_ST_2 (HDMI_ADDR_OFFSET + 0x00040030) +#define HDMI_LINK_I2S_CH_ST_3 (HDMI_ADDR_OFFSET + 0x00040034) +#define HDMI_LINK_I2S_CH_ST_4 (HDMI_ADDR_OFFSET + 0x00040038) +#define HDMI_LINK_I2S_CH_ST_SH_0 (HDMI_ADDR_OFFSET + 0x0004003C) +#define HDMI_LINK_I2S_CH_ST_SH_1 (HDMI_ADDR_OFFSET + 0x00040040) +#define HDMI_LINK_I2S_CH_ST_SH_2 (HDMI_ADDR_OFFSET + 0x00040044) +#define HDMI_LINK_I2S_CH_ST_SH_3 (HDMI_ADDR_OFFSET + 0x00040048) +#define HDMI_LINK_I2S_CH_ST_SH_4 (HDMI_ADDR_OFFSET + 0x0004004C) +#define HDMI_LINK_I2S_VD_DATA (HDMI_ADDR_OFFSET + 0x00040050) +#define HDMI_LINK_I2S_MUX_CH (HDMI_ADDR_OFFSET + 0x00040054) +#define HDMI_LINK_I2S_MUX_CUV (HDMI_ADDR_OFFSET + 0x00040058) +#define HDMI_LINK_I2S_CH0_L_0 (HDMI_ADDR_OFFSET + 0x00040064) +#define HDMI_LINK_I2S_CH0_L_1 (HDMI_ADDR_OFFSET + 0x00040068) +#define HDMI_LINK_I2S_CH0_L_2 (HDMI_ADDR_OFFSET + 0x0004006C) +#define HDMI_LINK_I2S_CH0_R_0 (HDMI_ADDR_OFFSET + 0x00040074) +#define HDMI_LINK_I2S_CH0_R_1 (HDMI_ADDR_OFFSET + 0x00040078) +#define HDMI_LINK_I2S_CH0_R_2 (HDMI_ADDR_OFFSET + 0x0004007C) +#define HDMI_LINK_I2S_CH0_R_3 (HDMI_ADDR_OFFSET + 0x00040080) +#define HDMI_LINK_I2S_CH1_L_0 (HDMI_ADDR_OFFSET + 0x00040084) +#define HDMI_LINK_I2S_CH1_L_1 (HDMI_ADDR_OFFSET + 0x00040088) +#define HDMI_LINK_I2S_CH1_L_2 (HDMI_ADDR_OFFSET + 0x0004008C) +#define HDMI_LINK_I2S_CH1_L_3 (HDMI_ADDR_OFFSET + 0x00040090) +#define HDMI_LINK_I2S_CH1_R_0 (HDMI_ADDR_OFFSET + 0x00040094) +#define HDMI_LINK_I2S_CH1_R_1 (HDMI_ADDR_OFFSET + 0x00040098) +#define HDMI_LINK_I2S_CH1_R_2 (HDMI_ADDR_OFFSET + 0x0004009C) +#define HDMI_LINK_I2S_CH1_R_3 (HDMI_ADDR_OFFSET + 0x000400A0) +#define HDMI_LINK_I2S_CH2_L_0 (HDMI_ADDR_OFFSET + 0x000400A4) +#define HDMI_LINK_I2S_CH2_L_1 (HDMI_ADDR_OFFSET + 0x000400A8) +#define HDMI_LINK_I2S_CH2_L_2 (HDMI_ADDR_OFFSET + 0x000400AC) +#define HDMI_LINK_I2S_CH2_L_3 (HDMI_ADDR_OFFSET + 0x000400B0) +#define HDMI_LINK_I2S_CH2_R_0 (HDMI_ADDR_OFFSET + 0x000400B4) +#define HDMI_LINK_I2S_CH2_R_1 (HDMI_ADDR_OFFSET + 0x000400B8) +#define HDMI_LINK_I2S_CH2_R_2 (HDMI_ADDR_OFFSET + 0x000400BC) +#define HDMI_LINK_I2S_CH2_R_3 (HDMI_ADDR_OFFSET + 0x000400C0) +#define HDMI_LINK_I2S_CH3_L_0 (HDMI_ADDR_OFFSET + 0x000400C4) +#define HDMI_LINK_I2S_CH3_L_1 (HDMI_ADDR_OFFSET + 0x000400C8) +#define HDMI_LINK_I2S_CH3_L_2 (HDMI_ADDR_OFFSET + 0x000400CC) +#define HDMI_LINK_I2S_CH3_R_0 (HDMI_ADDR_OFFSET + 0x000400D0) +#define HDMI_LINK_I2S_CH3_R_1 (HDMI_ADDR_OFFSET + 0x000400D4) +#define HDMI_LINK_I2S_CH3_R_2 (HDMI_ADDR_OFFSET + 0x000400D8) +#define HDMI_LINK_I2S_CUV_L_R (HDMI_ADDR_OFFSET + 0x000400DC) + +#define HDMI_CEC_TX_STATUS_0 (OTHER_ADDR_OFFSET + 0x00000000) +#define HDMI_CEC_TX_STATUS_1 (OTHER_ADDR_OFFSET + 0x00000004) +#define HDMI_CEC_RX_STATUS_0 (OTHER_ADDR_OFFSET + 0x00000008) +#define HDMI_CEC_RX_STATUS_1 (OTHER_ADDR_OFFSET + 0x0000000C) +#define HDMI_CEC_INTR_MASK (OTHER_ADDR_OFFSET + 0x00000010) +#define HDMI_CEC_INTR_CLEAR (OTHER_ADDR_OFFSET + 0x00000014) +#define HDMI_CEC_LOGIC_ADDR (OTHER_ADDR_OFFSET + 0x00000020) +#define HDMI_CEC_DIVISOR_0 (OTHER_ADDR_OFFSET + 0x00000030) +#define HDMI_CEC_DIVISOR_1 (OTHER_ADDR_OFFSET + 0x00000034) +#define HDMI_CEC_DIVISOR_2 (OTHER_ADDR_OFFSET + 0x00000038) +#define HDMI_CEC_DIVISOR_3 (OTHER_ADDR_OFFSET + 0x0000003C) +#define HDMI_CEC_TX_CTRL (OTHER_ADDR_OFFSET + 0x00000040) +#define HDMI_CEC_TX_BYTE_NUM (OTHER_ADDR_OFFSET + 0x00000044) +#define HDMI_CEC_TX_STATUS_2 (OTHER_ADDR_OFFSET + 0x00000060) +#define HDMI_CEC_TX_STATUS_3 (OTHER_ADDR_OFFSET + 0x00000064) +#define HDMI_CEC_TX_BUFFER_x (OTHER_ADDR_OFFSET + 0x00000080) +#define HDMI_CEC_TX_BUFFER00 (OTHER_ADDR_OFFSET + 0x00000080) +#define HDMI_CEC_RX_CTRL (OTHER_ADDR_OFFSET + 0x000000C0) +#define HDMI_CEC_RX_STATUS_2 (OTHER_ADDR_OFFSET + 0x000000E0) +#define HDMI_CEC_RX_STATUS_3 (OTHER_ADDR_OFFSET + 0x000000E4) +#define HDMI_CEC_RX_BUFFER_x (OTHER_ADDR_OFFSET + 0x00000100) +#define HDMI_CEC_FILTER_CTRL (OTHER_ADDR_OFFSET + 0x00000180) +#define HDMI_CEC_FILTER_TH (OTHER_ADDR_OFFSET + 0x00000184) + +#ifdef CONFIG_MACH_S5P6818 +#define HDMI_PHY_OFFSET \ + (PHY_BASEADDR_HDMI_PHY_MODULE - PHY_BASEADDR_HDMI_MODULE) +#else +#define HDMI_PHY_OFFSET 0x400 +#endif + +#define HDMI_PHY_REG00 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000000) +#define HDMI_PHY_REG04 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000004) +#define HDMI_PHY_REG08 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000008) +#define HDMI_PHY_REG0C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000000C) +#define HDMI_PHY_REG10 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000010) +#define HDMI_PHY_REG14 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000014) +#define HDMI_PHY_REG18 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000018) +#define HDMI_PHY_REG1C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000001C) +#define HDMI_PHY_REG20 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000020) +#define HDMI_PHY_REG24 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000024) +#define HDMI_PHY_REG28 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000028) +#define HDMI_PHY_REG2C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000002C) +#define HDMI_PHY_REG30 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000030) +#define HDMI_PHY_REG34 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000034) +#define HDMI_PHY_REG38 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000038) +#define HDMI_PHY_REG3C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000003C) +#define HDMI_PHY_REG40 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000040) +#define HDMI_PHY_REG44 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000044) +#define HDMI_PHY_REG48 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000048) +#define HDMI_PHY_REG4C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000004C) +#define HDMI_PHY_REG50 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000050) +#define HDMI_PHY_REG54 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000054) +#define HDMI_PHY_REG58 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000058) +#define HDMI_PHY_REG5C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000005C) +#define HDMI_PHY_REG60 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000060) +#define HDMI_PHY_REG64 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000064) +#define HDMI_PHY_REG68 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000068) +#define HDMI_PHY_REG6C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000006C) +#define HDMI_PHY_REG70 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000070) +#define HDMI_PHY_REG74 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000074) +#define HDMI_PHY_REG78 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000078) +#define HDMI_PHY_REG7C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000007C) +#define HDMI_PHY_REG80 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000080) +#define HDMI_PHY_REG84 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000084) +#define HDMI_PHY_REG88 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000088) +#define HDMI_PHY_REG8C (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x0000008C) +#define HDMI_PHY_REG90 (OTHER_ADDR_OFFSET + HDMI_PHY_OFFSET + 0x00000090) + +enum hdmi_reset { + i_nRST = 0, + i_nRST_VIDEO = 1, + i_nRST_SPDIF = 2, + i_nRST_TMDS = 3, + i_nRST_PHY = 4, +}; + +u32 nx_hdmi_get_reg(u32 module_index, u32 offset); +void nx_hdmi_set_reg(u32 module_index, u32 offset, u32 regvalue); + +void nx_hdmi_set_base_address(u32 module_index, void *base_address); +void *nx_hdmi_get_base_address(u32 module_index); +u32 nx_hdmi_get_physical_address(u32 module_index); + +#endif diff --git a/drivers/video/nexell/soc/s5pxx18_soc_lvds.c b/drivers/video/nexell/soc/s5pxx18_soc_lvds.c new file mode 100644 index 0000000..18c101b --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_lvds.c @@ -0,0 +1,278 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <linux/types.h> +#include <linux/io.h> + +#include "s5pxx18_soc_disptop.h" +#include "s5pxx18_soc_lvds.h" + +#ifndef pow +static inline unsigned int pow(int a, int b) +{ + if (b == 0) + return 1; + else + return a * pow(a, b - 1); +} +#endif + +static struct nx_lvds_register_set *__g_pregister[NUMBER_OF_LVDS_MODULE]; + +int nx_lvds_initialize(void) +{ + static int binit; + u32 i; + + if (binit == 0) { + for (i = 0; i < NUMBER_OF_LVDS_MODULE; i++) + __g_pregister[i] = NULL; + binit = 1; + } + + return 1; +} + +u32 nx_lvds_get_number_of_module(void) +{ + return NUMBER_OF_LVDS_MODULE; +} + +u32 nx_lvds_get_size_of_register_set(void) +{ + return sizeof(struct nx_lvds_register_set); +} + +void nx_lvds_set_base_address(u32 module_index, void *base_address) +{ + __g_pregister[module_index] = + (struct nx_lvds_register_set *)base_address; +} + +void *nx_lvds_get_base_address(u32 module_index) +{ + return (void *)__g_pregister[module_index]; +} + +u32 nx_lvds_get_physical_address(u32 module_index) +{ + const u32 physical_addr[] = PHY_BASEADDR_LVDS_LIST; + + return physical_addr[module_index]; +} + +int nx_lvds_open_module(u32 module_index) +{ + return true; +} + +int nx_lvds_close_module(u32 module_index) +{ + return true; +} + +int nx_lvds_check_busy(u32 module_index) +{ + return false; +} + +void nx_lvds_set_lvdsctrl0(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsctrl0); +} + +void nx_lvds_set_lvdsctrl1(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsctrl1); +} + +void nx_lvds_set_lvdsctrl2(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsctrl2); +} + +void nx_lvds_set_lvdsctrl3(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsctrl3); +} + +void nx_lvds_set_lvdsctrl4(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsctrl4); +} + +void nx_lvds_set_lvdstmode0(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdstmode0); +} + +void nx_lvds_set_lvdsloc0(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsloc0); +} + +void nx_lvds_set_lvdsloc1(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsloc1); +} + +void nx_lvds_set_lvdsloc2(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsloc2); +} + +void nx_lvds_set_lvdsloc3(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsloc3); +} + +void nx_lvds_set_lvdsloc4(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsloc4); +} + +void nx_lvds_set_lvdsloc5(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsloc5); +} + +void nx_lvds_set_lvdsloc6(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdsloc6); +} + +void nx_lvds_set_lvdslocmask0(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdslocmask0); +} + +void nx_lvds_set_lvdslocmask1(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdslocmask1); +} + +void nx_lvds_set_lvdslocpol0(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdslocpol0); +} + +void nx_lvds_set_lvdslocpol1(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + writel(regvalue, &pregister->lvdslocpol1); +} + +void nx_lvds_set_lvdsdummy(u32 module_index, u32 regvalue) +{ + register struct nx_lvds_register_set *pregister; + u32 oldvalue; + + pregister = __g_pregister[module_index]; + oldvalue = readl(&pregister->lvdsctrl1) & 0x00ffffff; + writel(oldvalue | ((regvalue & 0xff) << 24), &pregister->lvdsctrl1); +} + +u32 nx_lvds_get_lvdsdummy(u32 module_index) +{ + register struct nx_lvds_register_set *pregister; + u32 oldvalue; + + pregister = __g_pregister[module_index]; + oldvalue = readl(&pregister->lvdsctrl1); + oldvalue = oldvalue >> 24; + return oldvalue; +} + +u32 nx_lvds_get_lvdsctrl0(u32 module_index) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + return (u32)readl(&pregister->lvdsctrl0); +} + +u32 nx_lvds_get_lvdsctrl1(u32 module_index) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + return (u32)readl(&pregister->lvdsctrl1); +} + +u32 nx_lvds_get_lvdsctrl2(u32 module_index) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + return (u32)readl(&pregister->lvdsctrl2); +} + +u32 nx_lvds_get_lvdsctrl3(u32 module_index) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + return (u32)readl(&pregister->lvdsctrl3); +} + +u32 nx_lvds_get_lvdsctrl4(u32 module_index) +{ + register struct nx_lvds_register_set *pregister; + + pregister = __g_pregister[module_index]; + return (u32)readl(&pregister->lvdsctrl4); +} diff --git a/drivers/video/nexell/soc/s5pxx18_soc_lvds.h b/drivers/video/nexell/soc/s5pxx18_soc_lvds.h new file mode 100644 index 0000000..08f8e5c --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_lvds.h @@ -0,0 +1,83 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _S5PXX18_SOC_LVDS_H_ +#define _S5PXX18_SOC_LVDS_H_ + +/* + * refter to s5pxx18_soc_disptop.h + * + * #define NUMBER_OF_LVDS_MODULE 1 + * #define PHY_BASEADDR_LVDS_MODULE 0xC010A000 + */ +#define PHY_BASEADDR_LVDS_LIST \ + { PHY_BASEADDR_LVDS_MODULE } + +struct nx_lvds_register_set { + u32 lvdsctrl0; + u32 lvdsctrl1; + u32 lvdsctrl2; + u32 lvdsctrl3; + u32 lvdsctrl4; + u32 _reserved0[3]; + u32 lvdsloc0; + u32 lvdsloc1; + u32 lvdsloc2; + u32 lvdsloc3; + u32 lvdsloc4; + u32 lvdsloc5; + u32 lvdsloc6; + u32 _reserved1; + u32 lvdslocmask0; + u32 lvdslocmask1; + u32 lvdslocpol0; + u32 lvdslocpol1; + u32 lvdstmode0; + u32 lvdstmode1; + u32 _reserved2[2]; +}; + +int nx_lvds_initialize(void); +u32 nx_lvds_get_number_of_module(void); +u32 nx_lvds_get_size_of_register_set(void); +void nx_lvds_set_base_address(u32 module_index, void *base_address); +void *nx_lvds_get_base_address(u32 module_index); +u32 nx_lvds_get_physical_address(u32 module_index); +int nx_lvds_open_module(u32 module_index); +int nx_lvds_close_module(u32 module_index); +int nx_lvds_check_busy(u32 module_index); + +void nx_lvds_set_lvdsctrl0(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsctrl1(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsctrl2(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsctrl3(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsctrl4(u32 module_index, u32 regvalue); +u32 nx_lvds_get_lvdsctrl0(u32 module_index); +u32 nx_lvds_get_lvdsctrl1(u32 module_index); +u32 nx_lvds_get_lvdsctrl2(u32 module_index); +u32 nx_lvds_get_lvdsctrl3(u32 module_index); +u32 nx_lvds_get_lvdsctrl4(u32 module_index); + +void nx_lvds_set_lvdstmode0(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsloc0(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsloc1(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsloc2(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsloc3(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsloc4(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsloc5(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdsloc6(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdslocmask0(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdslocmask1(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdslocpol0(u32 module_index, u32 regvalue); +void nx_lvds_set_lvdslocpol1(u32 module_index, u32 regvalue); + +void nx_lvds_set_lvdslocpol1(u32 module_index, u32 regvalue); + +void nx_lvds_set_lvdsdummy(u32 module_index, u32 regvalue); +u32 nx_lvds_get_lvdsdummy(u32 module_index); + +#endif
Low level functions for DPC (Display Controller) and Makefile for all nexell video low level functions.
drivers/video/nexell/soc/Makefile | 11 + drivers/video/nexell/soc/s5pxx18_soc_dpc.c | 1569 ++++++++++++++++++++++++++++ drivers/video/nexell/soc/s5pxx18_soc_dpc.h | 444 ++++++++ 3 files changed, 2024 insertions(+) create mode 100644 drivers/video/nexell/soc/Makefile create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_dpc.c create mode 100644 drivers/video/nexell/soc/s5pxx18_soc_dpc.h
diff --git a/drivers/video/nexell/soc/Makefile b/drivers/video/nexell/soc/Makefile new file mode 100644 index 0000000..a3036e5 --- /dev/null +++ b/drivers/video/nexell/soc/Makefile @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 Nexell +# Junghyun, kimjhkim@nexell.co.kr + +obj-$(CONFIG_VIDEO_NX) += s5pxx18_soc_dpc.o s5pxx18_soc_mlc.o \ + s5pxx18_soc_disptop.o s5pxx18_soc_disptop_clk.o + +obj-$(CONFIG_VIDEO_NX_LVDS) += s5pxx18_soc_lvds.o +obj-$(CONFIG_VIDEO_NX_MIPI) += s5pxx18_soc_mipi.o +obj-$(CONFIG_VIDEO_NX_HDMI) += s5pxx18_soc_hdmi.o diff --git a/drivers/video/nexell/soc/s5pxx18_soc_dpc.c b/drivers/video/nexell/soc/s5pxx18_soc_dpc.c new file mode 100644 index 0000000..fc15d6b --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_dpc.c @@ -0,0 +1,1569 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <linux/types.h> +#include <linux/io.h> + +#include "s5pxx18_soc_dpc.h" + +static struct { + struct nx_dpc_register_set *pregister; +} __g_module_variables[NUMBER_OF_DPC_MODULE] = { { NULL,},}; + +int nx_dpc_initialize(void) +{ + static int binit; + u32 i; + + if (binit == 0) { + for (i = 0; i < NUMBER_OF_DPC_MODULE; i++) + __g_module_variables[i].pregister = NULL; + binit = 1; + } + return 1; +} + +u32 nx_dpc_get_number_of_module(void) +{ + return NUMBER_OF_DPC_MODULE; +} + +u32 nx_dpc_get_physical_address(u32 module_index) +{ + const u32 physical_addr[] = PHY_BASEADDR_DPC_LIST; + + return physical_addr[module_index]; +} + +void nx_dpc_set_base_address(u32 module_index, void *base_address) +{ + __g_module_variables[module_index].pregister = + (struct nx_dpc_register_set *)base_address; +} + +void *nx_dpc_get_base_address(u32 module_index) +{ + return (void *)__g_module_variables[module_index].pregister; +} + +void nx_dpc_set_interrupt_enable(u32 module_index, int32_t int_num, int enable) +{ + const u32 intenb_pos = 11; + const u32 intenb_mask = 1ul << intenb_pos; + const u32 intpend_pos = 10; + const u32 intpend_mask = 1ul << intpend_pos; + + register u32 regvalue; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->dpcctrl0; + regvalue &= ~(intenb_mask | intpend_mask); + regvalue |= (u32)enable << intenb_pos; + + writel(regvalue, &pregister->dpcctrl0); +} + +int nx_dpc_get_interrupt_enable(u32 module_index, int32_t int_num) +{ + const u32 intenb_pos = 11; + const u32 intenb_mask = 1ul << intenb_pos; + + return (int)((__g_module_variables[module_index].pregister->dpcctrl0 & + intenb_mask) >> intenb_pos); +} + +void nx_dpc_set_interrupt_enable32(u32 module_index, u32 enable_flag) +{ + const u32 intenb_pos = 11; + const u32 intenb_mask = 1 << intenb_pos; + const u32 intpend_pos = 10; + const u32 intpend_mask = 1 << intpend_pos; + + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcctrl0 & ~(intpend_mask | intenb_mask); + + writel((u32)(read_value | (enable_flag & 0x01) << intenb_pos), + &pregister->dpcctrl0); +} + +u32 nx_dpc_get_interrupt_enable32(u32 module_index) +{ + const u32 intenb_pos = 11; + const u32 intenb_mask = 1 << intenb_pos; + + return (u32)((__g_module_variables[module_index].pregister->dpcctrl0 & + intenb_mask) >> intenb_pos); +} + +int nx_dpc_get_interrupt_pending(u32 module_index, int32_t int_num) +{ + const u32 intpend_pos = 10; + const u32 intpend_mask = 1ul << intpend_pos; + + return (int)((__g_module_variables[module_index].pregister->dpcctrl0 & + intpend_mask) >> intpend_pos); +} + +u32 nx_dpc_get_interrupt_pending32(u32 module_index) +{ + const u32 intpend_pos = 10; + const u32 intpend_mask = 1 << intpend_pos; + + return (u32)((__g_module_variables[module_index].pregister->dpcctrl0 & + intpend_mask) >> intpend_pos); +} + +void nx_dpc_clear_interrupt_pending(u32 module_index, int32_t int_num) +{ + const u32 intpend_pos = 10; + register struct nx_dpc_register_set *pregister; + register u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->dpcctrl0; + regvalue |= 1ul << intpend_pos; + + writel(regvalue, &pregister->dpcctrl0); +} + +void nx_dpc_clear_interrupt_pending32(u32 module_index, u32 pending_flag) +{ + const u32 intpend_pos = 10; + const u32 intpend_mask = 1 << intpend_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcctrl0 & ~intpend_mask; + + writel((u32)(read_value | ((pending_flag & 0x01) << intpend_pos)), + &pregister->dpcctrl0); +} + +void nx_dpc_set_interrupt_enable_all(u32 module_index, int enable) +{ + const u32 intenb_pos = 11; + const u32 intenb_mask = 1ul << intenb_pos; + const u32 intpend_pos = 10; + const u32 intpend_mask = 1ul << intpend_pos; + register u32 regvalue; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->dpcctrl0; + regvalue &= ~(intenb_mask | intpend_mask); + regvalue |= (u32)enable << intenb_pos; + + writel(regvalue, &pregister->dpcctrl0); +} + +int nx_dpc_get_interrupt_enable_all(u32 module_index) +{ + const u32 intenb_pos = 11; + const u32 intenb_mask = 1ul << intenb_pos; + + return (int)((__g_module_variables[module_index].pregister->dpcctrl0 & + intenb_mask) >> intenb_pos); +} + +int nx_dpc_get_interrupt_pending_all(u32 module_index) +{ + const u32 intpend_pos = 10; + const u32 intpend_mask = 1ul << intpend_pos; + + return (int)((__g_module_variables[module_index].pregister->dpcctrl0 & + intpend_mask) >> intpend_pos); +} + +void nx_dpc_clear_interrupt_pending_all(u32 module_index) +{ + const u32 intpend_pos = 10; + register struct nx_dpc_register_set *pregister; + register u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + regvalue = pregister->dpcctrl0; + regvalue |= 1ul << intpend_pos; + + writel(regvalue, &pregister->dpcctrl0); +} + +int32_t nx_dpc_get_interrupt_pending_number(u32 module_index) +{ + const u32 intenb_pos = 11; + const u32 intpend_pos = 10; + register struct nx_dpc_register_set *pregister; + register u32 pend; + + pregister = __g_module_variables[module_index].pregister; + pend = ((pregister->dpcctrl0 >> intenb_pos) && + (pregister->dpcctrl0 >> intpend_pos)); + + if (pend & 0x01) + return 0; + + return -1; +} + +void nx_dpc_set_clock_pclk_mode(u32 module_index, enum nx_pclkmode mode) +{ + const u32 pclkmode_pos = 3; + register u32 regvalue; + register struct nx_dpc_register_set *pregister; + u32 clkmode = 0; + + pregister = __g_module_variables[module_index].pregister; + switch (mode) { + case nx_pclkmode_dynamic: + clkmode = 0; + break; + case nx_pclkmode_always: + clkmode = 1; + break; + default: + break; + } + regvalue = pregister->dpcclkenb; + regvalue &= ~(1ul << pclkmode_pos); + regvalue |= (clkmode & 0x01) << pclkmode_pos; + + writel(regvalue, &pregister->dpcclkenb); +} + +enum nx_pclkmode nx_dpc_get_clock_pclk_mode(u32 module_index) +{ + const u32 pclkmode_pos = 3; + + if (__g_module_variables[module_index].pregister->dpcclkenb & + (1ul << pclkmode_pos)) { + return nx_pclkmode_always; + } + return nx_pclkmode_dynamic; +} + +void nx_dpc_set_clock_source(u32 module_index, u32 index, u32 clk_src) +{ + const u32 clksrcsel_pos = 2; + const u32 clksrcsel_mask = 0x07 << clksrcsel_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcclkgen[index][0]; + read_value &= ~clksrcsel_mask; + read_value |= clk_src << clksrcsel_pos; + + writel(read_value, &pregister->dpcclkgen[index][0]); +} + +u32 nx_dpc_get_clock_source(u32 module_index, u32 index) +{ + const u32 clksrcsel_pos = 2; + const u32 clksrcsel_mask = 0x07 << clksrcsel_pos; + + return (__g_module_variables[module_index] + .pregister->dpcclkgen[index][0] & + clksrcsel_mask) >> clksrcsel_pos; +} + +void nx_dpc_set_clock_divisor(u32 module_index, u32 index, u32 divisor) +{ + const u32 clkdiv_pos = 5; + const u32 clkdiv_mask = ((1 << 8) - 1) << clkdiv_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcclkgen[index][0]; + read_value &= ~clkdiv_mask; + read_value |= (divisor - 1) << clkdiv_pos; + + writel(read_value, &pregister->dpcclkgen[index][0]); +} + +u32 nx_dpc_get_clock_divisor(u32 module_index, u32 index) +{ + const u32 clkdiv_pos = 5; + const u32 clkdiv_mask = ((1 << 8) - 1) << clkdiv_pos; + + return ((__g_module_variables[module_index] + .pregister->dpcclkgen[index][0] & + clkdiv_mask) >> clkdiv_pos) + 1; +} + +void nx_dpc_set_clock_out_inv(u32 module_index, u32 index, int out_clk_inv) +{ + const u32 outclkinv_pos = 1; + const u32 outclkinv_mask = 1ul << outclkinv_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcclkgen[index][0]; + read_value &= ~outclkinv_mask; + read_value |= out_clk_inv << outclkinv_pos; + + writel(read_value, &pregister->dpcclkgen[index][0]); +} + +int nx_dpc_get_clock_out_inv(u32 module_index, u32 index) +{ + const u32 outclkinv_pos = 1; + const u32 outclkinv_mask = 1ul << outclkinv_pos; + + return (int)((__g_module_variables[module_index] + .pregister->dpcclkgen[index][0] & + outclkinv_mask) >> outclkinv_pos); +} + +void nx_dpc_set_clock_out_select(u32 module_index, u32 index, int bbypass) +{ + const u32 outclksel_pos = 0; + const u32 outclksel_mask = 1ul << outclksel_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcclkgen[index][0]; + read_value &= ~outclksel_mask; + if (bbypass == 0) + read_value |= outclksel_mask; + + writel(read_value, &pregister->dpcclkgen[index][0]); +} + +int nx_dpc_get_clock_out_select(u32 module_index, u32 index) +{ + const u32 outclksel_pos = 0; + const u32 outclksel_mask = 1ul << outclksel_pos; + + if (__g_module_variables[module_index].pregister->dpcclkgen[index][0] & + outclksel_mask) { + return 0; + } else { + return 1; + } +} + +void nx_dpc_set_clock_polarity(u32 module_index, int bpolarity) +{ + const u32 clkpol_pos = 2; + const u32 clkpol_mask = 1ul << clkpol_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcctrl1; + read_value &= ~clkpol_mask; + if (bpolarity == 1) + read_value |= clkpol_mask; + + writel(read_value, &pregister->dpcctrl1); +} + +int nx_dpc_get_clock_polarity(u32 module_index) +{ + const u32 clkpol_pos = 2; + const u32 clkpol_mask = 1ul << clkpol_pos; + + if (__g_module_variables[module_index].pregister->dpcctrl1 & + clkpol_mask) { + return 1; + } else { + return 0; + } +} + +void nx_dpc_set_clock_out_enb(u32 module_index, u32 index, int out_clk_enb) +{ + const u32 outclkenb_pos = 15; + const u32 outclkenb_mask = 1ul << outclkenb_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcclkgen[index][0]; + read_value &= ~outclkenb_mask; + + if (out_clk_enb == 1) + read_value |= outclkenb_mask; + + writel(read_value, &pregister->dpcclkgen[index][0]); +} + +int nx_dpc_get_clock_out_enb(u32 module_index, u32 index) +{ + const u32 outclkenb_pos = 15; + const u32 outclkenb_mask = 1ul << outclkenb_pos; + + if (__g_module_variables[module_index].pregister->dpcclkgen[index][0] & + outclkenb_mask) { + return 1; + } else { + return 0; + } +} + +void nx_dpc_set_clock_out_delay(u32 module_index, u32 index, u32 delay) +{ + const u32 outclkdelay_pos = 0; + const u32 outclkdelay_mask = 0x1f << outclkdelay_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcclkgen[index][1]; + read_value &= ~outclkdelay_mask; + read_value |= (u32)delay << outclkdelay_pos; + + writel(read_value, &pregister->dpcclkgen[index][1]); +} + +u32 nx_dpc_get_clock_out_delay(u32 module_index, u32 index) +{ + register struct nx_dpc_register_set *pregister; + const u32 outclkdelay_pos = 0; + const u32 outclkdelay_mask = 0x1f << outclkdelay_pos; + + pregister = __g_module_variables[module_index].pregister; + + return (u32)((pregister->dpcclkgen[index][1] & outclkdelay_mask) >> + outclkdelay_pos); +} + +void nx_dpc_set_clock_divisor_enable(u32 module_index, int enable) +{ + const u32 clkgenenb_pos = 2; + const u32 clkgenenb_mask = 1ul << clkgenenb_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcclkenb; + read_value &= ~clkgenenb_mask; + read_value |= (u32)enable << clkgenenb_pos; + + writel(read_value, &pregister->dpcclkenb); +} + +int nx_dpc_get_clock_divisor_enable(u32 module_index) +{ + const u32 clkgenenb_pos = 2; + const u32 clkgenenb_mask = 1ul << clkgenenb_pos; + + return (int)((__g_module_variables[module_index].pregister->dpcclkenb & + clkgenenb_mask) >> clkgenenb_pos); +} + +void nx_dpc_set_dpc_enable(u32 module_index, int benb) +{ + const u32 intpend_pos = 10; + const u32 intpend_mask = 1ul << intpend_pos; + const u32 dpcenb_pos = 15; + const u32 dpcenb_mask = 1ul << dpcenb_pos; + register struct nx_dpc_register_set *pregister; + register u32 read_value; + + pregister = __g_module_variables[module_index].pregister; + read_value = pregister->dpcctrl0; + read_value &= ~(intpend_mask | dpcenb_mask); + read_value |= (u32)benb << dpcenb_pos; + + writel(read_value, &pregister->dpcctrl0); +} + +int nx_dpc_get_dpc_enable(u32 module_index) +{ + const u32 dpcenb_pos = 15; + const u32 dpcenb_mask = 1ul << dpcenb_pos; + + return (int)((__g_module_variables[module_index].pregister->dpcctrl0 & + dpcenb_mask) >> dpcenb_pos); +} + +void nx_dpc_set_delay(u32 module_index, u32 delay_rgb_pvd, u32 delay_hs_cp1, + u32 delay_vs_fram, u32 delay_de_cp2) +{ + const u32 intpend_mask = 1u << 10; + const u32 delayrgb_pos = 4; + const u32 delayrgb_mask = 0xfu << delayrgb_pos; + register u32 temp; + const u32 delayde_pos = 0; + const u32 delayvs_pos = 8; + const u32 delayhs_pos = 0; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + temp = pregister->dpcctrl0; + temp &= (u32)~(intpend_mask | delayrgb_mask); + temp = (u32)(temp | (delay_rgb_pvd << delayrgb_pos)); + + writel(temp, &pregister->dpcctrl0); + + writel((u32)((delay_vs_fram << delayvs_pos) | + (delay_hs_cp1 << delayhs_pos)), &pregister->dpcdelay0); + + writel((u32)(delay_de_cp2 << delayde_pos), &pregister->dpcdelay1); +} + +void nx_dpc_get_delay(u32 module_index, u32 *pdelayrgb_pvd, u32 *pdelayhs_cp1, + u32 *pdelayvs_fram, u32 *pdelayde_cp2) +{ + const u32 delayrgb_pos = 4; + const u32 delayrgb_mask = 0xfu << delayrgb_pos; + const u32 delayde_pos = 0; + const u32 delayde_mask = 0x3fu << delayde_pos; + const u32 delayvs_pos = 8; + const u32 delayvs_mask = 0x3fu << delayvs_pos; + const u32 delayhs_pos = 0; + const u32 delayhs_mask = 0x3fu << delayhs_pos; + register u32 temp; + + temp = __g_module_variables[module_index].pregister->dpcctrl0; + if (pdelayrgb_pvd) + *pdelayrgb_pvd = (u32)((temp & delayrgb_mask) >> delayrgb_pos); + temp = __g_module_variables[module_index].pregister->dpcdelay0; + if (pdelayhs_cp1) + *pdelayhs_cp1 = (u32)((temp & delayhs_mask) >> delayhs_pos); + if (pdelayvs_fram) + *pdelayvs_fram = (u32)((temp & delayvs_mask) >> delayvs_pos); + temp = __g_module_variables[module_index].pregister->dpcdelay1; + if (pdelayde_cp2) + *pdelayde_cp2 = (u32)((temp & delayde_mask) >> delayde_pos); +} + +void nx_dpc_set_dither(u32 module_index, enum nx_dpc_dither dither_r, + enum nx_dpc_dither dither_g, enum nx_dpc_dither dither_b) +{ + const u32 dither_mask = 0x3fu; + const u32 rdither_pos = 0; + const u32 gdither_pos = 2; + const u32 bdither_pos = 4; + register u32 temp; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + temp = pregister->dpcctrl1; + temp &= (u32)~dither_mask; + temp = (u32)(temp | + ((dither_b << bdither_pos) | (dither_g << gdither_pos) | + (dither_r << rdither_pos))); + + writel(temp, &pregister->dpcctrl1); +} + +void nx_dpc_get_dither(u32 module_index, enum nx_dpc_dither *pditherr, + enum nx_dpc_dither *pditherg, + enum nx_dpc_dither *pditherb) +{ + const u32 rdither_pos = 0; + const u32 rdither_mask = 0x3u << rdither_pos; + const u32 gdither_pos = 2; + const u32 gdither_mask = 0x3u << gdither_pos; + const u32 bdither_pos = 4; + const u32 bdither_mask = 0x3u << bdither_pos; + register u32 temp; + + temp = __g_module_variables[module_index].pregister->dpcctrl1; + if (pditherr) + *pditherr = + (enum nx_dpc_dither)((temp & rdither_mask) >> rdither_pos); + if (pditherg) + *pditherg = + (enum nx_dpc_dither)((temp & gdither_mask) >> gdither_pos); + if (pditherb) + *pditherb = + (enum nx_dpc_dither)((temp & bdither_mask) >> bdither_pos); +} + +void nx_dpc_set_mode(u32 module_index, enum nx_dpc_format format, + int binterlace, int binvertfield, int brgbmode, + int bswaprb, enum nx_dpc_ycorder ycorder, int bclipyc, + int bembeddedsync, enum nx_dpc_padclk clock, + int binvertclock, int bdualview) +{ + const u32 polfield_pos = 2; + const u32 seavenb_pos = 8; + const u32 scanmode_pos = 9; + const u32 intpend_pos = 10; + const u32 rgbmode_pos = 12; + + const u32 dither_mask = 0x3f; + const u32 ycorder_pos = 6; + const u32 format_pos = 8; + const u32 ycrange_pos = 13; + const u32 swaprb_pos = 15; + + const u32 padclksel_pos = 0; + const u32 padclksel_mask = 3u << padclksel_pos; + const u32 lcdtype_pos = 7; + const u32 lcdtype_mask = 3u << lcdtype_pos; + register struct nx_dpc_register_set *pregister; + register u32 temp; + + pregister = __g_module_variables[module_index].pregister; + temp = pregister->dpcctrl0; + temp &= (u32)~(1u << intpend_pos); + if (binterlace) + temp |= (u32)(1u << scanmode_pos); + else + temp &= (u32)~(1u << scanmode_pos); + if (binvertfield) + temp |= (u32)(1u << polfield_pos); + else + temp &= (u32)~(1u << polfield_pos); + if (brgbmode) + temp |= (u32)(1u << rgbmode_pos); + else + temp &= (u32)~(1u << rgbmode_pos); + if (bembeddedsync) + temp |= (u32)(1u << seavenb_pos); + else + temp &= (u32)~(1u << seavenb_pos); + + writel(temp, &pregister->dpcctrl0); + temp = pregister->dpcctrl1; + temp &= (u32)dither_mask; + temp = (u32)(temp | (ycorder << ycorder_pos)); + if (format >= 16) { + register u32 temp1; + + temp1 = pregister->dpcctrl2; + temp1 = temp1 | (1 << 4); + writel(temp1, &pregister->dpcctrl2); + } else { + register u32 temp1; + + temp1 = pregister->dpcctrl2; + temp1 = temp1 & ~(1 << 4); + writel(temp1, &pregister->dpcctrl2); + } + temp = (u32)(temp | ((format & 0xf) << format_pos)); + if (!bclipyc) + temp |= (u32)(1u << ycrange_pos); + if (bswaprb) + temp |= (u32)(1u << swaprb_pos); + + writel(temp, &pregister->dpcctrl1); + temp = pregister->dpcctrl2; + temp &= (u32)~(padclksel_mask | lcdtype_mask); + temp = (u32)(temp | (clock << padclksel_pos)); + + writel(temp, &pregister->dpcctrl2); + + nx_dpc_set_clock_out_inv(module_index, 0, binvertclock); + nx_dpc_set_clock_out_inv(module_index, 1, binvertclock); +} + +void nx_dpc_get_mode(u32 module_index, enum nx_dpc_format *pformat, + int *pbinterlace, int *pbinvertfield, int *pbrgbmode, + int *pbswaprb, enum nx_dpc_ycorder *pycorder, + int *pbclipyc, int *pbembeddedsync, + enum nx_dpc_padclk *pclock, int *pbinvertclock, + int *pbdualview) +{ + const u32 polfield = 1u << 2; + const u32 seavenb = 1u << 8; + const u32 scanmode = 1u << 9; + const u32 rgbmode = 1u << 12; + + const u32 ycorder_pos = 6; + const u32 ycorder_mask = 0x3u << ycorder_pos; + const u32 format_pos = 8; + const u32 format_mask = 0xfu << format_pos; + const u32 ycrange = 1u << 13; + const u32 swaprb = 1u << 15; + + const u32 padclksel_pos = 0; + const u32 padclksel_mask = 3u << padclksel_pos; + const u32 lcdtype_pos = 7; + const u32 lcdtype_mask = 3u << lcdtype_pos; + register u32 temp; + + temp = __g_module_variables[module_index].pregister->dpcctrl0; + if (pbinterlace) + *pbinterlace = (temp & scanmode) ? 1 : 0; + + if (pbinvertfield) + *pbinvertfield = (temp & polfield) ? 1 : 0; + + if (pbrgbmode) + *pbrgbmode = (temp & rgbmode) ? 1 : 0; + + if (pbembeddedsync) + *pbembeddedsync = (temp & seavenb) ? 1 : 0; + + temp = __g_module_variables[module_index].pregister->dpcctrl1; + + if (pycorder) + *pycorder = + (enum nx_dpc_ycorder)((temp & ycorder_mask) >> ycorder_pos); + + if (pformat) + *pformat = + (enum nx_dpc_format)((temp & format_mask) >> format_pos); + if (pbclipyc) + *pbclipyc = (temp & ycrange) ? 0 : 1; + if (pbswaprb) + *pbswaprb = (temp & swaprb) ? 1 : 0; + + temp = __g_module_variables[module_index].pregister->dpcctrl2; + + if (pclock) + *pclock = + (enum nx_dpc_padclk)((temp & padclksel_mask) >> + padclksel_pos); + + if (pbdualview) + *pbdualview = (2 == ((temp & lcdtype_mask) >> lcdtype_pos)) + ? 1 : 0; + + if (pbinvertclock) + *pbinvertclock = nx_dpc_get_clock_out_inv(module_index, 1); +} + +void nx_dpc_set_hsync(u32 module_index, u32 avwidth, u32 hsw, u32 hfp, u32 hbp, + int binvhsync) +{ + const u32 intpend = 1u << 10; + const u32 polhsync = 1u << 0; + register u32 temp; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + writel((u32)(hsw + hbp + avwidth + hfp - 1), &pregister->dpchtotal); + + writel((u32)(hsw - 1), &pregister->dpchswidth); + + writel((u32)(hsw + hbp - 1), &pregister->dpchastart); + + writel((u32)(hsw + hbp + avwidth - 1), &pregister->dpchaend); + temp = pregister->dpcctrl0; + temp &= ~intpend; + if (binvhsync) + temp |= (u32)polhsync; + else + temp &= (u32)~polhsync; + + writel(temp, &pregister->dpcctrl0); +} + +void nx_dpc_get_hsync(u32 module_index, u32 *pavwidth, u32 *phsw, u32 *phfp, + u32 *phbp, int *pbinvhsync) +{ + const u32 polhsync = 1u << 0; + u32 htotal, hsw, hab, hae; + u32 avw, hfp, hbp; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + htotal = (u32)pregister->dpchtotal + 1; + hsw = (u32)pregister->dpchswidth + 1; + hab = (u32)pregister->dpchastart + 1; + hae = (u32)pregister->dpchaend + 1; + hbp = hab - hsw; + avw = hae - hab; + hfp = htotal - hae; + if (pavwidth) + *pavwidth = avw; + if (phsw) + *phsw = hsw; + if (phfp) + *phfp = hfp; + if (phbp) + *phbp = hbp; + if (pbinvhsync) + *pbinvhsync = (pregister->dpcctrl0 & polhsync) ? 1 : 0; +} + +void nx_dpc_set_vsync(u32 module_index, u32 avheight, u32 vsw, u32 vfp, u32 vbp, + int binvvsync, u32 eavheight, u32 evsw, u32 evfp, + u32 evbp) +{ + const u32 intpend = 1u << 10; + const u32 polvsync = 1u << 1; + register u32 temp; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + writel((u32)(vsw + vbp + avheight + vfp - 1), &pregister->dpcvtotal); + + writel((u32)(vsw - 1), &pregister->dpcvswidth); + + writel((u32)(vsw + vbp - 1), &pregister->dpcvastart); + + writel((u32)(vsw + vbp + avheight - 1), &pregister->dpcvaend); + + writel((u32)(evsw + evbp + eavheight + evfp - 1), + &pregister->dpcevtotal); + + writel((u32)(evsw - 1), &pregister->dpcevswidth); + + writel((u32)(evsw + evbp - 1), &pregister->dpcevastart); + + writel((u32)(evsw + evbp + eavheight - 1), &pregister->dpcevaend); + temp = pregister->dpcctrl0; + temp &= ~intpend; + if (binvvsync) + temp |= (u32)polvsync; + else + temp &= (u32)~polvsync; + + writel(temp, &pregister->dpcctrl0); +} + +void nx_dpc_get_vsync(u32 module_index, u32 *pavheight, u32 *pvsw, u32 *pvfp, + u32 *pvbp, int *pbinvvsync, u32 *peavheight, + u32 *pevsw, u32 *pevfp, u32 *pevbp) +{ + const u32 polvsync = 1u << 1; + u32 vtotal, vsw, vab, vae; + u32 avh, vfp, vbp; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + vtotal = (u32)pregister->dpcvtotal + 1; + vsw = (u32)pregister->dpcvswidth + 1; + vab = (u32)pregister->dpcvastart + 1; + vae = (u32)pregister->dpcvaend + 1; + vbp = vab - vsw; + avh = vae - vab; + vfp = vtotal - vae; + if (pavheight) + *pavheight = avh; + if (pvsw) + *pvsw = vsw; + if (pvfp) + *pvfp = vfp; + if (pvbp) + *pvbp = vbp; + vtotal = (u32)pregister->dpcevtotal + 1; + vsw = (u32)pregister->dpcevswidth + 1; + vab = (u32)pregister->dpcevastart + 1; + vae = (u32)pregister->dpcevaend + 1; + vbp = vab - vsw; + avh = vae - vab; + vfp = vtotal - vae; + if (peavheight) + *peavheight = avh; + if (pevsw) + *pevsw = vsw; + if (pevfp) + *pevfp = vfp; + if (pevbp) + *pevbp = vbp; + if (pbinvvsync) + *pbinvvsync = (pregister->dpcctrl0 & polvsync) ? 1 : 0; +} + +void nx_dpc_set_vsync_offset(u32 module_index, u32 vssoffset, u32 vseoffset, + u32 evssoffset, u32 evseoffset) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + writel((u32)vseoffset, &pregister->dpcvseoffset); + + writel((u32)vssoffset, &pregister->dpcvssoffset); + + writel((u32)evseoffset, &pregister->dpcevseoffset); + + writel((u32)evssoffset, &pregister->dpcevssoffset); +} + +void nx_dpc_get_vsync_offset(u32 module_index, u32 *pvssoffset, + u32 *pvseoffset, u32 *pevssoffset, + u32 *pevseoffset) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + if (pvseoffset) + *pvseoffset = (u32)pregister->dpcvseoffset; + + if (pvssoffset) + *pvssoffset = (u32)pregister->dpcvssoffset; + + if (pevseoffset) + *pevseoffset = (u32)pregister->dpcevseoffset; + + if (pevssoffset) + *pevssoffset = (u32)pregister->dpcevssoffset; +} + +void nx_dpc_set_horizontal_up_scaler(u32 module_index, int benb, + u32 sourcewidth, u32 destwidth) +{ + const u32 upscalel_pos = 8; + const u32 upscaleh_pos = 0; + const u32 upscaleh_mask = ((1 << 15) - 1) << upscaleh_pos; + const u32 upscalerenb_pos = 0; + register struct nx_dpc_register_set *pregister; + register u32 regvalue; + register u32 up_scale; + + pregister = __g_module_variables[module_index].pregister; + up_scale = ((sourcewidth - 1) * (1 << 11)) / (destwidth - 1); + regvalue = 0; + regvalue |= (((u32)benb << upscalerenb_pos) | + (up_scale & 0xff) << upscalel_pos); + + writel(regvalue, &pregister->dpcupscalecon0); + + writel((up_scale >> 0x08) & upscaleh_mask, &pregister->dpcupscalecon1); + + writel(sourcewidth - 1, &pregister->dpcupscalecon2); +} + +void nx_dpc_get_horizontal_up_scaler(u32 module_index, int *pbenb, + u32 *psourcewidth, u32 *pdestwidth) +{ + const u32 upscalerenb_pos = 0; + const u32 upscalerenb_mask = 1u << upscalerenb_pos; + register struct nx_dpc_register_set *pregister; + + u32 up_scale; + u32 destwidth, srcwidth; + + pregister = __g_module_variables[module_index].pregister; + up_scale = ((u32)(pregister->dpcupscalecon1 & 0x7fff) << 8) | + ((u32)(pregister->dpcupscalecon0 >> 8) & 0xff); + srcwidth = pregister->dpcupscalecon2; + destwidth = (srcwidth * (1 << 11)) / up_scale; + if (pbenb) + *pbenb = (pregister->dpcupscalecon0 & upscalerenb_mask); + if (psourcewidth) + *psourcewidth = srcwidth + 1; + if (pdestwidth) + *pdestwidth = destwidth + 1; +} + +void nx_dpc_set_sync(u32 module_index, enum syncgenmode sync_gen_mode, + u32 avwidth, u32 avheight, u32 hsw, u32 hfp, u32 hbp, + u32 vsw, u32 vfp, u32 vbp, enum polarity field_polarity, + enum polarity hsyncpolarity, enum polarity vsyncpolarity, + u32 even_vsw, u32 even_vfp, u32 even_vbp, u32 vsetpixel, + u32 vsclrpixel, u32 evenvsetpixel, u32 evenvsclrpixel) +{ + register struct nx_dpc_register_set *pregister; + u32 regvalue = 0; + + pregister = __g_module_variables[module_index].pregister; + + writel((u32)(hfp + hsw + hbp + avwidth - 1), &pregister->dpchtotal); + writel((u32)(hsw - 1), &pregister->dpchswidth); + writel((u32)(hsw + hbp - 1), &pregister->dpchastart); + writel((u32)(hsw + hbp + avwidth - 1), &pregister->dpchaend); + writel((u32)(vfp + vsw + vbp + avheight - 1), &pregister->dpcvtotal); + writel((u32)(vsw - 1), &pregister->dpcvswidth); + writel((u32)(vsw + vbp - 1), &pregister->dpcvastart); + writel((u32)(vsw + vbp + avheight - 1), &pregister->dpcvaend); + writel((u32)vsetpixel, &pregister->dpcvseoffset); + writel((u32)(hfp + hsw + hbp + avwidth - vsclrpixel - 1), + &pregister->dpcvssoffset); + writel((u32)evenvsetpixel, &pregister->dpcevseoffset); + writel((u32)(hfp + hsw + hbp + avwidth - evenvsclrpixel - 1), + &pregister->dpcevssoffset); + if (sync_gen_mode == 1) { + writel((u32)(even_vfp + even_vsw + even_vbp + avheight - 1), + &pregister->dpcevtotal); + writel((u32)(even_vsw - 1), &pregister->dpcevswidth); + writel((u32)(even_vsw + even_vbp - 1), + &pregister->dpcevastart); + writel((u32)(even_vsw + even_vbp + avheight - 1), + &pregister->dpcevaend); + } + regvalue = readl(&pregister->dpcctrl0) & 0xfff0ul; + regvalue |= (((u32)field_polarity << 2) | ((u32)vsyncpolarity << 1) | + ((u32)hsyncpolarity << 0)); + writel((u32)regvalue, &pregister->dpcctrl0); +} + +void nx_dpc_set_output_format(u32 module_index, enum outputformat output_format, + u8 output_video_config) +{ + const u32 format_table[] = { + (0 << 0), (1 << 0), (2 << 0), (3 << 0), (4 << 0), (5 << 0), + (6 << 0), (7 << 0), (8 << 0), (9 << 0), (0 << 0) | (1 << 7), + (1 << 0) | (1 << 7), (2 << 0) | (1 << 7), (3 << 0) | (1 << 7), + (4 << 0) | (1 << 7), (5 << 0) | (1 << 7), (6 << 0) | (1 << 7), + (7 << 0) | (1 << 7), (8 << 0) | (1 << 7), (9 << 0) | (1 << 7), + (10 << 0), (11 << 0), (12 << 0), (13 << 0), (14 << 0), (15 << 0) + }; + u32 regvalue; + u32 regvalue0; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + regvalue = readl(&pregister->dpcctrl1) & 0x30fful; + + regvalue |= (format_table[output_format] << 8); + writel((u32)regvalue, &pregister->dpcctrl1); + regvalue0 = (u32)(readl(&pregister->dpcctrl1) & 0xff3f); + regvalue0 = (u32)((output_video_config << 6) | regvalue0); + writel((u32)regvalue0, &pregister->dpcctrl1); +} + +void nx_dpc_set_quantization_mode(u32 module_index, enum qmode rgb2yc, + enum qmode yc2rgb) +{ + register struct nx_dpc_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + regvalue = readl(&pregister->dpcctrl1) & 0x8ffful; + regvalue |= ((u32)rgb2yc << 13) | ((u32)yc2rgb << 12); + writel((u32)regvalue, &pregister->dpcctrl1); +} + +void nx_dpc_set_enable(u32 module_index, int enable, int rgbmode, + int use_ntscsync, int use_analog_output, int seavenable) +{ + u32 regvalue; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + regvalue = readl(&pregister->dpcctrl0) & 0x0efful; + regvalue |= ((u32)enable << 15) | ((u32)use_ntscsync << 14) | + ((u32)seavenable << 8) | ((u32)use_analog_output << 13) | + ((u32)rgbmode << 12); + writel((u32)regvalue, &pregister->dpcctrl0); +} + +void nx_dpc_set_out_video_clk_select(u32 module_index, + enum outpadclksel out_pad_vclk_sel) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + writel((u32)((readl(&pregister->dpcctrl2)) | (out_pad_vclk_sel & 0x3)), + &pregister->dpcctrl2); +} + +void nx_dpc_set_reg_flush(u32 module_index) +{ + u32 reg; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + reg = readl(&pregister->dpcdataflush); + writel((u32)(reg | (1ul << 4)), &pregister->dpcdataflush); +} + +void nx_dpc_set_sramon(u32 module_index) +{ + u32 reg; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + reg = (u32)(readl(&pregister->dpcctrl2) & 0xf3ff); + writel((u32)(reg | (1ul << 10)), &pregister->dpcctrl2); + reg = (u32)(readl(&pregister->dpcctrl2) & 0xf7ff); + writel((u32)(reg | (1ul << 11)), &pregister->dpcctrl2); +} + +void nx_dpc_set_sync_lcdtype(u32 module_index, int stnlcd, int dual_view_enb, + int bit_widh, u8 cpcycle) +{ + u32 reg; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + + reg = (u32)(readl(&pregister->dpcctrl2) & 0xc0f); + writel((u32)(reg | (cpcycle << 12) | (bit_widh << 9) | + (dual_view_enb << 8) | (stnlcd << 7)), + &pregister->dpcctrl2); +} + +void nx_dpc_set_up_scale_control(u32 module_index, int up_scale_enb, + int filter_enb, u32 hscale, u16 source_width) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u32)((hscale << 8) | ((u32)filter_enb << 1) | (up_scale_enb)), + &pregister->dpcupscalecon0); + writel((u32)(hscale >> 8), &pregister->dpcupscalecon1); + writel(source_width, &pregister->dpcupscalecon2); +} + +void nx_dpc_set_mputime(u32 module_index, u8 setup, u8 hold, u8 acc) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u32)((setup << 8) | (hold & 0xff)), &pregister->dpcmputime0); + writel((u32)(acc), &pregister->dpcmputime1); +} + +void nx_dpc_set_index(u32 module_index, u32 index) +{ + u32 regvalue; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u32)(index & 0xffff), &pregister->dpcmpuwrdatal); + writel((u32)((index >> 16) & 0xff), &pregister->dpcmpuindex); + if (index == 0x22) { + regvalue = readl(&pregister->dpcctrl2); + writel((regvalue | 0x10), &pregister->dpcctrl2); + } +} + +void nx_dpc_set_data(u32 module_index, u32 data) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u32)(data & 0xffff), &pregister->dpcmpuwrdatal); + writel((u32)((data >> 16) & 0xff), &pregister->dpcmpudatah); +} + +void nx_dpc_set_cmd_buffer_flush(u32 module_index) +{ + u32 reg; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + reg = readl(&pregister->dpcdataflush); + writel((u32)(reg | (1 << 1)), &pregister->dpcdataflush); +} + +void nx_dpc_set_cmd_buffer_clear(u32 module_index) +{ + u32 reg; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + reg = readl(&pregister->dpcdataflush); + writel((u32)(reg | (1 << 0)), &pregister->dpcdataflush); +} + +void nx_dpc_set_cmd_buffer_write(u32 module_index, u32 cmd_data) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u32)(cmd_data & 0xffff), &pregister->dpccmdbufferdatal); + writel((u32)(cmd_data >> 16), &pregister->dpccmdbufferdatah); +} + +void nx_dpc_set(u32 module_index) +{ + u32 reg; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + reg = readl(&pregister->dpcpolctrl); + writel((u32)(reg | 0x1), &pregister->dpcpolctrl); +} + +u32 nx_dpc_get_data(u32 module_index) +{ + u32 reg = 0; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + reg = readl(&pregister->dpcmpudatah); + reg = (reg << 16) | readl(&pregister->dpcmpurdatal); + return reg; +} + +u32 nx_dpc_get_status(u32 module_index) +{ + u32 reg = 0; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + reg = readl(&pregister->dpcmpustatus); + reg = (reg << 16) | readl(&pregister->dpcmpurdatal); + return reg; +} + +void nx_dpc_rgbmask(u32 module_index, u32 rgbmask) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((rgbmask >> 0) & 0xffff, &pregister->dpcrgbmask[0]); + writel((rgbmask >> 16) & 0x00ff, &pregister->dpcrgbmask[1]); +} + +void nx_dpc_set_pad_location(u32 module_index, u32 index, u32 regvalue) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(regvalue, &pregister->dpcpadposition[index]); +} + +u32 nx_dpc_get_field_flag(u32 module_index) +{ + register struct nx_dpc_register_set *pregister; + u32 regvalue; + + pregister = __g_module_variables[module_index].pregister; + regvalue = readl(&pregister->dpcrgbshift); + + return (u32)((regvalue >> 5) & 0x01); +} + +void nx_dpc_set_enable_with_interlace(u32 module_index, int enable, int rgbmode, + int use_ntscsync, int use_analog_output, + int seavenable) +{ + u32 regvalue; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + regvalue = readl(&pregister->dpcctrl0) & 0x0eff; + regvalue = readl(&pregister->dpcctrl0) & 0x0eff; + regvalue |= ((u32)enable << 15) | ((u32)use_ntscsync << 14) | + ((u32)seavenable << 8) | ((u32)use_analog_output << 13) | + ((u32)rgbmode << 12); + + regvalue |= (1 << 9); + writel((u16)regvalue, &pregister->dpcctrl0); +} + +void nx_dpc_set_encoder_control_reg(u32 module_index, u32 param_a, u32 param_b, + u32 param_c) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(param_a, &pregister->ntsc_ecmda); + writel(param_b, &pregister->ntsc_ecmdb); + writel(param_c, &pregister->ntsc_ecmdc); +} + +void nx_dpc_set_encoder_shcphase_control(u32 module_index, u32 chroma_param) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(chroma_param, &pregister->ntsc_sch); +} + +void nx_dpc_set_encoder_timing_config_reg(u32 module_index, u32 icntl) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(icntl, &pregister->ntsc_icntl); +} + +void nx_dpc_set_encoder_dacoutput_select(u32 module_index, u8 dacsel0, + u8 dacsel1, u8 dacsel2, u8 dacsel3, + u8 dacsel4, u8 dacsel5) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(((dacsel1 & 0xf) << 4) | (dacsel0 & 0xf), + &pregister->ntsc_dacsel10); + writel(((dacsel3 & 0xf) << 4) | (dacsel2 & 0xf), + &pregister->ntsc_dacsel32); + writel(((dacsel5 & 0xf) << 4) | (dacsel4 & 0xf), + &pregister->ntsc_dacsel54); +} + +void nx_dpc_set_encoder_sync_location(u32 module_index, u16 hsoe, u16 hsob, + u16 vsob, u16 vsoe, u8 vsost, int novrst) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u16)((((vsob & 0x100) >> 2) | ((hsob & 0x700) >> 5) | + (hsoe & 0x700) >> 8)), &pregister->ntsc_hsvso); + writel((u16)(hsoe & 0xff), &pregister->ntsc_hsoe); + writel((u16)(hsob & 0xff), &pregister->ntsc_hsob); + writel((u16)(vsob & 0xff), &pregister->ntsc_vsob); + writel((u16)(((vsost & 0x3) << 6) | (novrst << 5) | (vsoe & 0x1f)), + &pregister->ntsc_vsoe); +} + +void nx_dpc_set_encoder_dacpower_enable(u32 module_index, u8 dacpd) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(dacpd, &pregister->ntsc_dacpd); +} + +void nx_dpc_set_ycorder(u32 module_index, enum nx_dpc_ycorder ycorder) +{ + const u16 ycorder_pos = 6; + register struct nx_dpc_register_set *pregister; + u32 temp; + + pregister = __g_module_variables[module_index].pregister; + temp = pregister->dpcctrl1 & (~(0xf << ycorder_pos)); + temp = (u16)(temp | (ycorder << ycorder_pos)); + writel(temp, &pregister->dpcctrl1); +} + +void nx_dpc_set_luma_gain(u32 module_index, u32 luma_gain) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel(luma_gain, &pregister->ntsc_cont); +} + +void nx_dpc_set_encenable(u32 module_index, int benb) +{ + const u16 encmode = 1u << 14; + const u16 encrst = 1u << 13; + const u16 intpend = 1u << 10; + register struct nx_dpc_register_set *pregister; + register u16 temp; + + pregister = __g_module_variables[module_index].pregister; + temp = readl(&pregister->dpcctrl0); + temp &= (u16)~intpend; + if (benb) + temp |= (u16)encrst; + else + temp &= (u16)~encrst; + writel((temp | encmode), &pregister->dpcctrl0); + writel(7, &pregister->ntsc_icntl); +} + +int nx_dpc_get_encenable(u32 module_index) +{ + const u16 encrst = 1u << 13; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return (readl(&pregister->dpcctrl0) & encrst) ? 1 : 0; +} + +void nx_dpc_set_video_encoder_power_down(u32 module_index, int benb) +{ + const u16 pwdenc = 1u << 7; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (benb) { + writel(readl(&pregister->ntsc_ecmda) | (u16)pwdenc, + &pregister->ntsc_ecmda); + writel(0, &pregister->ntsc_dacsel10); + } else { + writel(1, &pregister->ntsc_dacsel10); + writel(readl(&pregister->ntsc_ecmda) & (u16)~pwdenc, + &pregister->ntsc_ecmda); + } +} + +int nx_dpc_get_video_encoder_power_down(u32 module_index) +{ + const u16 pwdenc = 1u << 7; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return (readl(&pregister->ntsc_ecmda) & pwdenc) ? 1 : 0; +} + +void nx_dpc_set_video_encoder_mode(u32 module_index, enum nx_dpc_vbs vbs, + int bpedestal) +{ + register struct nx_dpc_register_set *pregister; + +#define phalt (1u << 0) +#define ifmt (1u << 1) +#define ped (1u << 3) +#define fscsel_ntsc (0u << 4) +#define fscsel_pal (1u << 4) +#define fscsel_palm (2u << 4) +#define fscsel_paln (3u << 4) +#define fdrst (1u << 6) +#define pwdenc (1u << 7) + register u16 temp; + static const u8 ntsc_ecmda_table[] = { + (u8)(fscsel_ntsc | fdrst), (u8)(ifmt | fscsel_ntsc), + (u8)(fscsel_pal), (u8)(fscsel_palm | phalt), + (u8)(ifmt | fscsel_paln | phalt), + (u8)(ifmt | fscsel_pal | phalt | fdrst), + (u8)(fscsel_pal | phalt), + (u8)(ifmt | fscsel_ntsc) + }; + pregister = __g_module_variables[module_index].pregister; + temp = readl(&pregister->ntsc_ecmda); + temp &= (u16)pwdenc; + temp = (u16)(temp | (u16)ntsc_ecmda_table[vbs]); + if (bpedestal) + temp |= (u16)ped; + writel(temp, &pregister->ntsc_ecmda); +#undef phalt +#undef ifmt +#undef ped +#undef fscsel_ntsc +#undef fscsel_pal +#undef fscsel_palm +#undef fscsel_paln +#undef fdrst +#undef pwdenc +} + +void nx_dpc_set_video_encoder_schlock_control(u32 module_index, int bfreerun) +{ + const u16 fdrst = 1u << 6; + register struct nx_dpc_register_set *pregister; + register u16 temp; + + pregister = __g_module_variables[module_index].pregister; + temp = readl(&pregister->ntsc_ecmda); + if (bfreerun) + temp |= (u16)fdrst; + else + temp &= (u16)~fdrst; + writel(temp, &pregister->ntsc_ecmda); +} + +int nx_dpc_get_video_encoder_schlock_control(u32 module_index) +{ + const u16 fdrst = 1u << 6; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + return (readl(&pregister->ntsc_ecmda) & fdrst) ? 1 : 0; +} + +void nx_dpc_set_video_encoder_bandwidth(u32 module_index, + enum nx_dpc_bandwidth luma, + enum nx_dpc_bandwidth chroma) +{ + const u16 ybw_pos = 0; + const u16 cbw_pos = 2; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u16)((chroma << cbw_pos) | (luma << ybw_pos)), + &pregister->ntsc_ecmdb); +} + +void nx_dpc_get_video_encoder_bandwidth(u32 module_index, + enum nx_dpc_bandwidth *pluma, + enum nx_dpc_bandwidth *pchroma) +{ + const u16 ybw_pos = 0; + const u16 ybw_mask = 3u << ybw_pos; + const u16 cbw_pos = 2; + const u16 cbw_mask = 3u << cbw_pos; + register struct nx_dpc_register_set *pregister; + register u16 temp; + + pregister = __g_module_variables[module_index].pregister; + temp = readl(&pregister->ntsc_ecmdb); + if (pluma) + *pluma = (enum nx_dpc_bandwidth)((temp & ybw_mask) >> ybw_pos); + if (pchroma) + *pchroma = + (enum nx_dpc_bandwidth)((temp & cbw_mask) >> cbw_pos); +} + +void nx_dpc_set_video_encoder_color_control(u32 module_index, s8 sch, + s8 hue, s8 sat, s8 crt, + s8 brt) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u16)sch, &pregister->ntsc_sch); + writel((u16)hue, &pregister->ntsc_hue); + writel((u16)sat, &pregister->ntsc_sat); + writel((u16)crt, &pregister->ntsc_cont); + writel((u16)brt, &pregister->ntsc_bright); +} + +void nx_dpc_get_video_encoder_color_control(u32 module_index, s8 *psch, + s8 *phue, s8 *psat, + s8 *pcrt, s8 *pbrt) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + if (psch) + *psch = (s8)readl(&pregister->ntsc_sch); + if (phue) + *phue = (s8)readl(&pregister->ntsc_hue); + if (psat) + *psat = (s8)readl(&pregister->ntsc_sat); + if (pcrt) + *pcrt = (s8)readl(&pregister->ntsc_cont); + if (pbrt) + *pbrt = (s8)readl(&pregister->ntsc_bright); +} + +void nx_dpc_set_video_encoder_fscadjust(u32 module_index, int16_t adjust) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + writel((u16)(adjust >> 8), &pregister->ntsc_fsc_adjh); + writel((u16)(adjust & 0xff), &pregister->ntsc_fsc_adjl); +} + +u16 nx_dpc_get_video_encoder_fscadjust(u32 module_index) +{ + register u32 temp; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + temp = (u32)readl(&pregister->ntsc_fsc_adjh); + temp <<= 8; + temp |= (((u32)readl(&pregister->ntsc_fsc_adjl)) & 0xff); + return (u16)temp; +} + +void nx_dpc_set_video_encoder_timing(u32 module_index, u32 hsos, u32 hsoe, + u32 vsos, u32 vsoe) +{ + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + hsos -= 1; + hsoe -= 1; + writel((u16)((((vsos >> 8) & 1u) << 6) | (((hsos >> 8) & 7u) << 3) | + (((hsoe >> 8) & 7u) << 0)), &pregister->ntsc_hsvso); + writel((u16)(hsos & 0xffu), &pregister->ntsc_hsob); + writel((u16)(hsoe & 0xffu), &pregister->ntsc_hsoe); + writel((u16)(vsos & 0xffu), &pregister->ntsc_vsob); + writel((u16)(vsoe & 0x1fu), &pregister->ntsc_vsoe); +} + +void nx_dpc_get_video_encoder_timing(u32 module_index, u32 *phsos, u32 *phsoe, + u32 *pvsos, u32 *pvsoe) +{ + register u16 hsvso; + register struct nx_dpc_register_set *pregister; + + pregister = __g_module_variables[module_index].pregister; + hsvso = readl(&pregister->ntsc_hsvso); + if (phsos) + *phsos = (u32)((((hsvso >> 3) & 7u) << 8) | + (readl(&pregister->ntsc_hsob) & 0xffu)) + 1; + if (phsoe) + *phsoe = (u32)((((hsvso >> 0) & 7u) << 8) | + (readl(&pregister->ntsc_hsoe) & 0xffu)) + 1; + if (pvsos) + *pvsos = (u32)((((hsvso >> 6) & 1u) << 8) | + (readl(&pregister->ntsc_vsob) & 0xffu)); + if (pvsoe) + *pvsoe = (u32)(readl(&pregister->ntsc_vsoe) & 0x1fu); +} diff --git a/drivers/video/nexell/soc/s5pxx18_soc_dpc.h b/drivers/video/nexell/soc/s5pxx18_soc_dpc.h new file mode 100644 index 0000000..cfa53c3 --- /dev/null +++ b/drivers/video/nexell/soc/s5pxx18_soc_dpc.h @@ -0,0 +1,444 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#ifndef _S5PXX18_SOC_DPC_H_ +#define _S5PXX18_SOC_DPC_H_ + +#include "s5pxx18_soc_disptype.h" + +#define IRQ_OFFSET 32 +#define IRQ_DPC_P (IRQ_OFFSET + 33) +#define IRQ_DPC_S (IRQ_OFFSET + 34) + +#define NUMBER_OF_DPC_MODULE 2 +#define PHY_BASEADDR_DPC0 0xC0102800 +#define PHY_BASEADDR_DPC1 0xC0102C00 + +#define PHY_BASEADDR_DPC_LIST \ + { PHY_BASEADDR_DPC0, PHY_BASEADDR_DPC1 } + +struct nx_dpc_register_set { + u32 ntsc_stata; + u32 ntsc_ecmda; + u32 ntsc_ecmdb; + u32 ntsc_glk; + u32 ntsc_sch; + u32 ntsc_hue; + u32 ntsc_sat; + u32 ntsc_cont; + u32 ntsc_bright; + u32 ntsc_fsc_adjh; + u32 ntsc_fsc_adjl; + u32 ntsc_ecmdc; + u32 ntsc_csdly; + u32 __ntsc_reserved_0_[3]; + u32 ntsc_dacsel10; + u32 ntsc_dacsel32; + u32 ntsc_dacsel54; + u32 ntsc_daclp; + u32 ntsc_dacpd; + u32 __ntsc_reserved_1_[(0x20 - 0x15)]; + u32 ntsc_icntl; + u32 ntsc_hvoffst; + u32 ntsc_hoffst; + u32 ntsc_voffset; + u32 ntsc_hsvso; + u32 ntsc_hsob; + u32 ntsc_hsoe; + u32 ntsc_vsob; + u32 ntsc_vsoe; + u32 __reserved[(0xf8 / 4) - 0x29]; + u32 dpchtotal; + u32 dpchswidth; + u32 dpchastart; + u32 dpchaend; + u32 dpcvtotal; + u32 dpcvswidth; + u32 dpcvastart; + u32 dpcvaend; + u32 dpcctrl0; + u32 dpcctrl1; + u32 dpcevtotal; + u32 dpcevswidth; + u32 dpcevastart; + u32 dpcevaend; + u32 dpcctrl2; + u32 dpcvseoffset; + u32 dpcvssoffset; + u32 dpcevseoffset; + u32 dpcevssoffset; + u32 dpcdelay0; + u32 dpcupscalecon0; + u32 dpcupscalecon1; + u32 dpcupscalecon2; + + u32 dpcrnumgencon0; + u32 dpcrnumgencon1; + u32 dpcrnumgencon2; + u32 dpcrndconformula_l; + u32 dpcrndconformula_h; + u32 dpcfdtaddr; + u32 dpcfrdithervalue; + u32 dpcfgdithervalue; + u32 dpcfbdithervalue; + u32 dpcdelay1; + u32 dpcmputime0; + u32 dpcmputime1; + u32 dpcmpuwrdatal; + u32 dpcmpuindex; + u32 dpcmpustatus; + u32 dpcmpudatah; + u32 dpcmpurdatal; + u32 dpcdummy12; + u32 dpccmdbufferdatal; + u32 dpccmdbufferdatah; + u32 dpcpolctrl; + u32 dpcpadposition[8]; + u32 dpcrgbmask[2]; + u32 dpcrgbshift; + u32 dpcdataflush; + u32 __reserved06[((0x3c0) - (2 * 0x0ec)) / 4]; + + u32 dpcclkenb; + u32 dpcclkgen[2][2]; +}; + +enum { + nx_dpc_int_vsync = 0 +}; + +enum nx_dpc_format { + nx_dpc_format_rgb555 = 0ul, + nx_dpc_format_rgb565 = 1ul, + nx_dpc_format_rgb666 = 2ul, + nx_dpc_format_rgb666b = 18ul, + nx_dpc_format_rgb888 = 3ul, + nx_dpc_format_mrgb555a = 4ul, + nx_dpc_format_mrgb555b = 5ul, + nx_dpc_format_mrgb565 = 6ul, + nx_dpc_format_mrgb666 = 7ul, + nx_dpc_format_mrgb888a = 8ul, + nx_dpc_format_mrgb888b = 9ul, + nx_dpc_format_ccir656 = 10ul, + nx_dpc_format_ccir601a = 12ul, + nx_dpc_format_ccir601b = 13ul, + nx_dpc_format_srgb888 = 14ul, + nx_dpc_format_srgbd8888 = 15ul, + nx_dpc_format_4096color = 1ul, + nx_dpc_format_16gray = 3ul +}; + +enum nx_dpc_ycorder { + nx_dpc_ycorder_cb_ycr_y = 0ul, + nx_dpc_ycorder_cr_ycb_y = 1ul, + nx_dpc_ycorder_ycbycr = 2ul, + nx_dpc_ycorder_ycrycb = 3ul +}; + +enum nx_dpc_padclk { + nx_dpc_padclk_vclk = 0ul, + nx_dpc_padclk_vclk2 = 1ul, + nx_dpc_padclk_vclk3 = 2ul +}; + +enum nx_dpc_dither { + nx_dpc_dither_bypass = 0ul, + nx_dpc_dither_4bit = 1ul, + nx_dpc_dither_5bit = 2ul, + nx_dpc_dither_6bit = 3ul +}; + +enum nx_dpc_vbs { + nx_dpc_vbs_ntsc_m = 0ul, + nx_dpc_vbs_ntsc_n = 1ul, + nx_dpc_vbs_ntsc_443 = 2ul, + nx_dpc_vbs_pal_m = 3ul, + nx_dpc_vbs_pal_n = 4ul, + nx_dpc_vbs_pal_bghi = 5ul, + nx_dpc_vbs_pseudo_pal = 6ul, + nx_dpc_vbs_pseudo_ntsc = 7ul +}; + +enum nx_dpc_bandwidth { + nx_dpc_bandwidth_low = 0ul, + nx_dpc_bandwidth_medium = 1ul, + nx_dpc_bandwidth_high = 2ul +}; + +int nx_dpc_initialize(void); +u32 nx_dpc_get_number_of_module(void); +u32 nx_dpc_get_physical_address(u32 module_index); +u32 nx_dpc_get_size_of_register_set(void); +void nx_dpc_set_base_address(u32 module_index, void *base_address); +void *nx_dpc_get_base_address(u32 module_index); +int nx_dpc_open_module(u32 module_index); +int nx_dpc_close_module(u32 module_index); +int nx_dpc_check_busy(u32 module_index); +int nx_dpc_can_power_down(u32 module_index); +int32_t nx_dpc_get_interrupt_number(u32 module_index); +void nx_dpc_set_interrupt_enable(u32 module_index, int32_t int_num, + int enable); +int nx_dpc_get_interrupt_enable(u32 module_index, int32_t int_num); +int nx_dpc_get_interrupt_pending(u32 module_index, int32_t int_num); +void nx_dpc_clear_interrupt_pending(u32 module_index, int32_t int_num); +void nx_dpc_set_interrupt_enable_all(u32 module_index, int enable); +int nx_dpc_get_interrupt_enable_all(u32 module_index); +int nx_dpc_get_interrupt_pending_all(u32 module_index); +void nx_dpc_clear_interrupt_pending_all(u32 module_index); +void nx_dpc_set_interrupt_enable32(u32 module_index, u32 enable_flag); +u32 nx_dpc_get_interrupt_enable32(u32 module_index); +u32 nx_dpc_get_interrupt_pending32(u32 module_index); +void nx_dpc_clear_interrupt_pending32(u32 module_index, + u32 pending_flag); +int32_t nx_dpc_get_interrupt_pending_number(u32 module_index); +void nx_dpc_set_clock_pclk_mode(u32 module_index, enum nx_pclkmode mode); +enum nx_pclkmode nx_dpc_get_clock_pclk_mode(u32 module_index); +void nx_dpc_set_clock_source(u32 module_index, u32 index, u32 clk_src); +u32 nx_dpc_get_clock_source(u32 module_index, u32 index); +void nx_dpc_set_clock_divisor(u32 module_index, u32 index, u32 divisor); +u32 nx_dpc_get_clock_divisor(u32 module_index, u32 index); +void nx_dpc_set_clock_out_inv(u32 module_index, u32 index, + int out_clk_inv); +int nx_dpc_get_clock_out_inv(u32 module_index, u32 index); +void nx_dpc_set_clock_out_select(u32 module_index, u32 index, + int bbypass); +int nx_dpc_get_clock_out_select(u32 module_index, u32 index); +void nx_dpc_set_clock_polarity(u32 module_index, int bpolarity); +int nx_dpc_get_clock_polarity(u32 module_index); +void nx_dpc_set_clock_out_enb(u32 module_index, u32 index, + int out_clk_enb); +int nx_dpc_get_clock_out_enb(u32 module_index, u32 index); +void nx_dpc_set_clock_out_delay(u32 module_index, u32 index, u32 delay); +u32 nx_dpc_get_clock_out_delay(u32 module_index, u32 index); +void nx_dpc_set_clock_divisor_enable(u32 module_index, int enable); +int nx_dpc_get_clock_divisor_enable(u32 module_index); + +void nx_dpc_set_dpc_enable(u32 module_index, int benb); +int nx_dpc_get_dpc_enable(u32 module_index); +void nx_dpc_set_delay(u32 module_index, u32 delay_rgb_pvd, + u32 delay_hs_cp1, u32 delay_vs_fram, + u32 delay_de_cp2); +void nx_dpc_get_delay(u32 module_index, u32 *pdelayrgb_pvd, + u32 *pdelayhs_cp1, u32 *pdelayvs_fram, + u32 *pdelayde_cp2); +void nx_dpc_set_dither(u32 module_index, enum nx_dpc_dither dither_r, + enum nx_dpc_dither dither_g, + enum nx_dpc_dither dither_b); +void nx_dpc_get_dither(u32 module_index, enum nx_dpc_dither *pditherr, + enum nx_dpc_dither *pditherg, + enum nx_dpc_dither *pditherb); +void nx_dpc_set_horizontal_up_scaler(u32 module_index, int benb, + u32 sourcewidth, u32 destwidth); +void nx_dpc_get_horizontal_up_scaler(u32 module_index, int *pbenb, + u32 *psourcewidth, + u32 *pdestwidth); + +void nx_dpc_set_mode(u32 module_index, enum nx_dpc_format format, + int binterlace, int binvertfield, int brgbmode, + int bswaprb, enum nx_dpc_ycorder ycorder, + int bclipyc, int bembeddedsync, + enum nx_dpc_padclk clock, int binvertclock, + int bdualview); +void nx_dpc_get_mode(u32 module_index, enum nx_dpc_format *pformat, + int *pbinterlace, int *pbinvertfield, + int *pbrgbmode, int *pbswaprb, + enum nx_dpc_ycorder *pycorder, int *pbclipyc, + int *pbembeddedsync, enum nx_dpc_padclk *pclock, + int *pbinvertclock, int *pbdualview); +void nx_dpc_set_hsync(u32 module_index, u32 avwidth, u32 hsw, u32 hfp, + u32 hbp, int binvhsync); +void nx_dpc_get_hsync(u32 module_index, u32 *pavwidth, u32 *phsw, + u32 *phfp, u32 *phbp, int *pbinvhsync); +void nx_dpc_set_vsync(u32 module_index, u32 avheight, u32 vsw, u32 vfp, + u32 vbp, int binvvsync, u32 eavheight, u32 evsw, + u32 evfp, u32 evbp); +void nx_dpc_get_vsync(u32 module_index, u32 *pavheight, u32 *pvsw, + u32 *pvfp, u32 *pvbp, int *pbinvvsync, + u32 *peavheight, u32 *pevsw, u32 *pevfp, + u32 *pevbp); +void nx_dpc_set_vsync_offset(u32 module_index, u32 vssoffset, + u32 vseoffset, u32 evssoffset, + u32 evseoffset); +void nx_dpc_get_vsync_offset(u32 module_index, u32 *pvssoffset, + u32 *pvseoffset, u32 *pevssoffset, + u32 *pevseoffset); + +u32 nx_dpc_enable_pad_tft(u32 module_index, u32 mode_index); +u32 nx_dpc_enable_pad_i80(u32 module_index, u32 mode_index); + +enum syncgenmode { + progressive = 0, + interlace = 1 +}; + +enum polarity { + polarity_activehigh = 0, + polarity_activelow = 1 +}; + +enum outputformat { + outputformat_rgb555 = 0, + outputformat_rgb565 = 1, + outputformat_rgb666 = 2, + outputformat_rgb888 = 3, + outputformat_mrgb555a = 4, + outputformat_mrgb555b = 5, + outputformat_mrgb565 = 6, + outputformat_mrgb666 = 7, + outputformat_mrgb888a = 8, + outputformat_mrgb888b = 9, + outputformat_bgr555 = 10, + outputformat_bgr565 = 11, + outputformat_bgr666 = 12, + outputformat_bgr888 = 13, + outputformat_mbgr555a = 14, + outputformat_mbgr555b = 15, + outputformat_mbgr565 = 16, + outputformat_mbgr666 = 17, + outputformat_mbgr888a = 18, + outputformat_mbgr888b = 19, + outputformat_ccir656 = 20, + outputformat_ccir601_8 = 21, + outputformat_ccir601_16a = 22, + outputformat_ccir601_16b = 23, + outputformat_srgb888 = 24, + outputformat_srgbd8888 = 25 +}; + +enum outpadclksel { + padvclk = 0, + padvclk2 = 1, + padvclk3 = 2 +}; + +enum qmode { + qmode_220 = 0, + qmode_256 = 1 +}; + +void nx_dpc_set_sync(u32 module_index, enum syncgenmode sync_gen_mode, + u32 avwidth, u32 avheight, u32 hsw, u32 hfp, + u32 hbp, u32 vsw, u32 vfp, u32 vbp, + enum polarity field_polarity, + enum polarity hsyncpolarity, + enum polarity vsyncpolarity, u32 even_vsw, + u32 even_vfp, u32 even_vbp, u32 vsetpixel, + u32 vsclrpixel, u32 evenvsetpixel, + u32 evenvsclrpixel); +void nx_dpc_set_output_format(u32 module_index, + enum outputformat output_format, + u8 output_video_config); +void nx_dpc_set_quantization_mode(u32 module_index, enum qmode rgb2yc, + enum qmode yc2rgb); +void nx_dpc_set_enable(u32 module_index, int enable, int rgbmode, + int use_ntscsync, int use_analog_output, + int seavenable); +void nx_dpc_set_enable_with_interlace(u32 module_index, int enable, + int rgbmode, int use_ntscsync, + int use_analog_output, + int seavenable); +void nx_dpc_set_enable_with_interlace(u32 module_index, int enable, + int rgbmode, int use_ntscsync, + int use_analog_output, + int seavenable); +void nx_dpc_set_out_video_clk_select(u32 module_index, + enum outpadclksel out_pad_vclk_sel); +void nx_dpc_set_reg_flush(u32 module_index); +void nx_dpc_set_sramon(u32 module_index); +void nx_dpc_set_sync_lcdtype(u32 module_index, int stnlcd, + int dual_view_enb, int bit_widh, + u8 cpcycle); +void nx_dpc_set_up_scale_control(u32 module_index, int up_scale_enb, + int filter_enb, u32 hscale, + u16 source_width); + +void nx_dpc_set_mputime(u32 module_index, u8 setup, u8 hold, u8 acc); +void nx_dpc_set_index(u32 module_index, u32 index); +void nx_dpc_set_data(u32 module_index, u32 data); +void nx_dpc_set_cmd_buffer_flush(u32 module_index); +void nx_dpc_set_cmd_buffer_clear(u32 module_index); +void nx_dpc_set_cmd_buffer_write(u32 module_index, u32 cmd_data); +void nx_dpc_set(u32 module_index); +u32 nx_dpc_get_data(u32 module_index); +u32 nx_dpc_get_status(u32 module_index); +void nx_dpc_rgbmask(u32 module_index, u32 rgbmask); +void nx_dpc_set_pad_location(u32 module_index, u32 index, u32 regvalue); +u32 nx_dpc_get_field_flag(u32 module_index); + +void nx_dpc_set_sync_v(u32 module_index, u32 avheight, u32 vsw, u32 vfp, + u32 vbp); + +int nx_dpc_init_reg_test(u32 module_index); +void nx_dpc_set_encoder_control_reg(u32 module_index, u32 param_a, + u32 param_b, u32 param_c); +void nx_dpc_set_encoder_shcphase_control(u32 module_index, + u32 chroma_param); +void nx_dpc_set_encoder_timing_config_reg(u32 module_index, u32 inctl); +void nx_dpc_set_encoder_dacoutput_select(u32 module_index, u8 dacsel0, + u8 dacsel1, u8 dacsel2, + u8 dacsel3, u8 dacsel4, + u8 dacsel5); +void nx_dpc_set_encoder_sync_location(u32 module_index, u16 hsoe, + u16 hsob, u16 vsob, u16 vsoe, + u8 vsost, int novrst); +void nx_dpc_set_encoder_dacpower_enable(u32 module_index, u8 dacpd); +void nx_dpc_set_ycorder(u32 module_index, enum nx_dpc_ycorder ycorder); +void nx_dpc_set_luma_gain(u32 module_index, u32 luma_gain); + +void nx_dpc_set_secondary_dpcsync(u32 module_index, int benb); +int nx_dpc_get_secondary_dpcsync(u32 module_index); +void nx_dpc_set_encenable(u32 module_index, int benb); +int nx_dpc_get_encenable(u32 module_index); +void nx_dpc_set_video_encoder_power_down(u32 module_index, int benb); +int nx_dpc_get_video_encoder_power_down(u32 module_index); +void nx_dpc_set_video_encoder_mode(u32 module_index, enum nx_dpc_vbs vbs, + int bpedestal); +void nx_dpc_set_video_encoder_schlock_control(u32 module_index, + int bfreerun); +int nx_dpc_get_video_encoder_schlock_control(u32 module_index); +void nx_dpc_set_video_encoder_bandwidth(u32 module_index, + enum nx_dpc_bandwidth luma, + enum nx_dpc_bandwidth chroma); +void nx_dpc_get_video_encoder_bandwidth(u32 module_index, + enum nx_dpc_bandwidth *pluma, + enum nx_dpc_bandwidth *pchroma); +void nx_dpc_set_video_encoder_color_control(u32 module_index, s8 sch, + s8 hue, s8 sat, + s8 crt, s8 brt); +void nx_dpc_get_video_encoder_color_control(u32 module_index, + s8 *psch, s8 *phue, + s8 *psat, s8 *pcrt, + s8 *pbrt); +void nx_dpc_set_video_encoder_fscadjust(u32 module_index, + int16_t adjust); +u16 nx_dpc_get_video_encoder_fscadjust(u32 module_index); +void nx_dpc_set_video_encoder_timing(u32 module_index, u32 hsos, + u32 hsoe, u32 vsos, u32 vsoe); +void nx_dpc_get_video_encoder_timing(u32 module_index, u32 *phsos, + u32 *phsoe, u32 *pvsos, + u32 *pvsoe); +void nx_dpc_set_sync_v(u32 module_index, u32 avheight, u32 vsw, u32 vfp, + u32 vbp); + +int nx_dpc_init_reg_test(u32 module_index); +void nx_dpc_set_encoder_control_reg(u32 module_index, u32 param_a, + u32 param_b, u32 param_c); +void nx_dpc_set_encoder_shcphase_control(u32 module_index, + u32 chroma_param); +void nx_dpc_set_encoder_timing_config_reg(u32 module_index, u32 inctl); +void nx_dpc_set_encoder_dacoutput_select(u32 module_index, u8 dacsel0, + u8 dacsel1, u8 dacsel2, + u8 dacsel3, u8 dacsel4, + u8 dacsel5); +void nx_dpc_set_encoder_sync_location(u32 module_index, u16 hsoe, + u16 hsob, u16 vsob, u16 vsoe, + u8 vsost, int novrst); +void nx_dpc_set_encoder_dacpower_enable(u32 module_index, u8 dacpd); +void nx_dpc_set_ycorder(u32 module_index, enum nx_dpc_ycorder ycorder); +void nx_dpc_set_luma_gain(u32 module_index, u32 luma_gain); + +#endif
On Fri, Jul 10, 2020 at 07:07:35PM +0200, Stefan Bosch wrote:
Low level functions for DPC (Display Controller) and Makefile for all nexell video low level functions.
Signed-off-by: Stefan Bosch stefan_b@posteo.net
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - nexell_display.c: Changed to DM, CONFIG_FB_ADDR can not be used anymore because framebuffer is allocated by video_reserve() in video-uclass.c. Therefore code changed appropriately. - '#ifdef CONFIG...' changed to 'if (IS_ENABLED(CONFIG...))' where possible (and similar). - livetree API (dev_read_...) is used instead of fdt one (fdt...).
Signed-off-by: Stefan Bosch stefan_b@posteo.net ---
(no changes since v3)
Changes in v3: - drivers/video/nexell/s5pxx18_dp_hdmi.c: '#include <log.h>' and '#include <linux/delay.h>' inserted because it has been removed from common.h. - drivers/video/nexell_display.c: '#include <command.h>' inserted because '#include <image.h>' (includes command.h) has been removed from common.h. - '#ifdef...' changed to 'if (IS_ENABLED(CONFIG...))' where possible because of appropriate warnings of patman. - Changed to livetree API as proposed by patman: fdtdec_get_int() --> ofnode_read_s32_default() for (node = ...) --> ofnode_for_each_subnode() fdt_get_name() --> ofnode_get_name() fdt_getprop() --> dev_read_string() - nx_display_probe() removed, nx_display_dev_probe_uclass() renamed to nx_display_probe().
drivers/video/Kconfig | 10 + drivers/video/Makefile | 1 + drivers/video/nexell/Kconfig | 27 ++ drivers/video/nexell/Makefile | 12 + drivers/video/nexell/s5pxx18_dp.c | 341 +++++++++++++++++ drivers/video/nexell/s5pxx18_dp_hdmi.c | 545 ++++++++++++++++++++++++++ drivers/video/nexell/s5pxx18_dp_lvds.c | 274 +++++++++++++ drivers/video/nexell/s5pxx18_dp_mipi.c | 677 +++++++++++++++++++++++++++++++++ drivers/video/nexell/s5pxx18_dp_rgb.c | 69 ++++ drivers/video/nexell_display.c | 651 +++++++++++++++++++++++++++++++ 10 files changed, 2607 insertions(+) create mode 100644 drivers/video/nexell/Kconfig create mode 100644 drivers/video/nexell/Makefile create mode 100644 drivers/video/nexell/s5pxx18_dp.c create mode 100644 drivers/video/nexell/s5pxx18_dp_hdmi.c create mode 100644 drivers/video/nexell/s5pxx18_dp_lvds.c create mode 100644 drivers/video/nexell/s5pxx18_dp_mipi.c create mode 100644 drivers/video/nexell/s5pxx18_dp_rgb.c create mode 100644 drivers/video/nexell_display.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 3812354..fb145e5 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -572,6 +572,16 @@ source "drivers/video/bridge/Kconfig"
source "drivers/video/imx/Kconfig"
+config VIDEO_NX + bool "Enable video support on Nexell SoC" + depends on ARCH_S5P6818 || ARCH_S5P4418 + help + Nexell SoC supports many video output options including eDP and + HDMI. This option enables this support which can be used on devices + which have an eDP display connected. + +source "drivers/video/nexell/Kconfig" + config VIDEO bool "Enable legacy video support" depends on !DM_VIDEO diff --git a/drivers/video/Makefile b/drivers/video/Makefile index df7119d..3bacc64 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -61,6 +61,7 @@ obj-${CONFIG_VIDEO_MIPI_DSI} += mipi_dsi.o obj-$(CONFIG_VIDEO_MVEBU) += mvebu_lcd.o obj-$(CONFIG_VIDEO_MX3) += mx3fb.o videomodes.o obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o +obj-$(CONFIG_VIDEO_NX) += nexell_display.o videomodes.o nexell/ obj-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o obj-$(CONFIG_VIDEO_DSI_HOST_SANDBOX) += sandbox_dsi_host.o obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o diff --git a/drivers/video/nexell/Kconfig b/drivers/video/nexell/Kconfig new file mode 100644 index 0000000..54b8ccb --- /dev/null +++ b/drivers/video/nexell/Kconfig @@ -0,0 +1,27 @@ +if VIDEO_NX + +menu "LCD select" + +config VIDEO_NX_RGB + bool "RGB LCD" + help + Support for RGB lcd output. + +config VIDEO_NX_LVDS + bool "LVDS LCD" + help + Support for LVDS lcd output. + +config VIDEO_NX_MIPI + bool "MiPi" + help + Support for MiPi lcd output. + +config VIDEO_NX_HDMI + bool "HDMI" + help + Support for hdmi output. + +endmenu + +endif diff --git a/drivers/video/nexell/Makefile b/drivers/video/nexell/Makefile new file mode 100644 index 0000000..111ab45 --- /dev/null +++ b/drivers/video/nexell/Makefile @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 Nexell +# Junghyun, kimjhkim@nexell.co.kr + +obj-$(CONFIG_VIDEO_NX) += s5pxx18_dp.o +obj-$(CONFIG_VIDEO_NX) += soc/ + +obj-$(CONFIG_VIDEO_NX_RGB) += s5pxx18_dp_rgb.o +obj-$(CONFIG_VIDEO_NX_LVDS) += s5pxx18_dp_lvds.o +obj-$(CONFIG_VIDEO_NX_MIPI) += s5pxx18_dp_mipi.o +obj-$(CONFIG_VIDEO_NX_HDMI) += s5pxx18_dp_hdmi.o diff --git a/drivers/video/nexell/s5pxx18_dp.c b/drivers/video/nexell/s5pxx18_dp.c new file mode 100644 index 0000000..2248f47 --- /dev/null +++ b/drivers/video/nexell/s5pxx18_dp.c @@ -0,0 +1,341 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <config.h> +#include <common.h> +#include <errno.h> +#include <log.h> +#include <asm/arch/reset.h> +#include <asm/arch/nexell.h> +#include <asm/arch/display.h> + +#include "soc/s5pxx18_soc_disptop.h" +#include "soc/s5pxx18_soc_dpc.h" +#include "soc/s5pxx18_soc_mlc.h" + +#define MLC_LAYER_RGB_0 0 /* number of RGB layer 0 */ +#define MLC_LAYER_RGB_1 1 /* number of RGB layer 1 */ +#define MLC_LAYER_VIDEO 3 /* number of Video layer: 3 = VIDEO */ + +#define __io_address(a) (void *)(uintptr_t)(a) + +void dp_control_init(int module) +{ + void *base; + + /* top */ + base = __io_address(nx_disp_top_get_physical_address()); + nx_disp_top_set_base_address(base); + + /* control */ + base = __io_address(nx_dpc_get_physical_address(module)); + nx_dpc_set_base_address(module, base); + + /* top controller */ + nx_rstcon_setrst(RESET_ID_DISP_TOP, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_DISP_TOP, RSTCON_NEGATE); + + /* display controller */ + nx_rstcon_setrst(RESET_ID_DISPLAY, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_DISPLAY, RSTCON_NEGATE); + + nx_dpc_set_clock_pclk_mode(module, nx_pclkmode_always); +} + +int dp_control_setup(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl) +{ + unsigned int out_format; + unsigned int delay_mask; + int rgb_pvd = 0, hsync_cp1 = 7, vsync_fram = 7, de_cp2 = 7; + int v_vso = 1, v_veo = 1, e_vso = 1, e_veo = 1; + + int interlace = 0; + int invert_field; + int swap_rb; + unsigned int yc_order; + int vck_select; + int vclk_invert; + int emb_sync; + + enum nx_dpc_dither r_dither, g_dither, b_dither; + int rgb_mode = 0; + + if (NULL == sync || NULL == ctrl) { + debug("error, dp.%d not set sync or pad clock info !!!\n", + module); + return -EINVAL; + } + + out_format = ctrl->out_format; + delay_mask = ctrl->delay_mask; + interlace = sync->interlace; + invert_field = ctrl->invert_field; + swap_rb = ctrl->swap_RB; + yc_order = ctrl->yc_order; + vck_select = ctrl->vck_select; + vclk_invert = ctrl->clk_inv_lv0 | ctrl->clk_inv_lv1; + emb_sync = (out_format == DPC_FORMAT_CCIR656 ? 1 : 0); + + /* set delay mask */ + if (delay_mask & DP_SYNC_DELAY_RGB_PVD) + rgb_pvd = ctrl->d_rgb_pvd; + if (delay_mask & DP_SYNC_DELAY_HSYNC_CP1) + hsync_cp1 = ctrl->d_hsync_cp1; + if (delay_mask & DP_SYNC_DELAY_VSYNC_FRAM) + vsync_fram = ctrl->d_vsync_fram; + if (delay_mask & DP_SYNC_DELAY_DE_CP) + de_cp2 = ctrl->d_de_cp2; + + if (ctrl->vs_start_offset != 0 || + ctrl->vs_end_offset != 0 || + ctrl->ev_start_offset != 0 || ctrl->ev_end_offset != 0) { + v_vso = ctrl->vs_start_offset; + v_veo = ctrl->vs_end_offset; + e_vso = ctrl->ev_start_offset; + e_veo = ctrl->ev_end_offset; + } + + if (nx_dpc_format_rgb555 == out_format || + nx_dpc_format_mrgb555a == out_format || + nx_dpc_format_mrgb555b == out_format) { + r_dither = nx_dpc_dither_5bit; + g_dither = nx_dpc_dither_5bit; + b_dither = nx_dpc_dither_5bit; + rgb_mode = 1; + } else if (nx_dpc_format_rgb565 == out_format || + nx_dpc_format_mrgb565 == out_format) { + r_dither = nx_dpc_dither_5bit; + b_dither = nx_dpc_dither_5bit; + g_dither = nx_dpc_dither_6bit, rgb_mode = 1; + } else if ((nx_dpc_format_rgb666 == out_format) || + (nx_dpc_format_mrgb666 == out_format)) { + r_dither = nx_dpc_dither_6bit; + g_dither = nx_dpc_dither_6bit; + b_dither = nx_dpc_dither_6bit; + rgb_mode = 1; + } else { + r_dither = nx_dpc_dither_bypass; + g_dither = nx_dpc_dither_bypass; + b_dither = nx_dpc_dither_bypass; + rgb_mode = 1; + } + + /* CLKGEN0/1 */ + nx_dpc_set_clock_source(module, 0, ctrl->clk_src_lv0 == 3 ? + 6 : ctrl->clk_src_lv0); + nx_dpc_set_clock_divisor(module, 0, ctrl->clk_div_lv0); + nx_dpc_set_clock_source(module, 1, ctrl->clk_src_lv1); + nx_dpc_set_clock_divisor(module, 1, ctrl->clk_div_lv1); + nx_dpc_set_clock_out_delay(module, 0, ctrl->clk_delay_lv0); + nx_dpc_set_clock_out_delay(module, 1, ctrl->clk_delay_lv1); + + /* LCD out */ + nx_dpc_set_mode(module, out_format, interlace, invert_field, + rgb_mode, swap_rb, yc_order, emb_sync, emb_sync, + vck_select, vclk_invert, 0); + nx_dpc_set_hsync(module, sync->h_active_len, sync->h_sync_width, + sync->h_front_porch, sync->h_back_porch, + sync->h_sync_invert); + nx_dpc_set_vsync(module, sync->v_active_len, sync->v_sync_width, + sync->v_front_porch, sync->v_back_porch, + sync->v_sync_invert, sync->v_active_len, + sync->v_sync_width, sync->v_front_porch, + sync->v_back_porch); + nx_dpc_set_vsync_offset(module, v_vso, v_veo, e_vso, e_veo); + nx_dpc_set_delay(module, rgb_pvd, hsync_cp1, vsync_fram, de_cp2); + nx_dpc_set_dither(module, r_dither, g_dither, b_dither); + + if (IS_ENABLED(CONFIG_MACH_S5P6818)) { + /* Set TFT_CLKCTRL (offset : 1030h) + * Field name : DPC0_CLKCTRL, DPC1_CLKCRL + * Default value : clk_inv_lv0/1 = 0 : PADCLK_InvCLK + * Invert case : clk_inv_lv0/1 = 1 : PADCLK_CLK + */ + if (module == 0 && ctrl->clk_inv_lv0) + nx_disp_top_set_padclock(padmux_primary_mlc, + padclk_clk); + if (module == 1 && ctrl->clk_inv_lv1) + nx_disp_top_set_padclock(padmux_secondary_mlc, + padclk_clk); + } + + debug("%s: dp.%d x:%4d, hf:%3d, hb:%3d, hs:%3d, hi=%d\n", + __func__, module, sync->h_active_len, sync->h_front_porch, + sync->h_back_porch, sync->h_sync_width, sync->h_sync_invert); + debug("%s: dp.%d y:%4d, vf:%3d, vb:%3d, vs:%3d, vi=%d\n", + __func__, module, sync->v_active_len, sync->v_front_porch, + sync->v_back_porch, sync->v_sync_width, sync->h_sync_invert); + debug("%s: dp.%d ck.0:%d:%d:%d, ck.1:%d:%d:%d\n", + __func__, module, + ctrl->clk_src_lv0, ctrl->clk_div_lv0, ctrl->clk_inv_lv0, + ctrl->clk_src_lv1, ctrl->clk_div_lv1, ctrl->clk_inv_lv1); + debug("%s: dp.%d vs:%d, ve:%d, es:%d, ee:%d\n", + __func__, module, v_vso, v_veo, e_vso, e_veo); + debug("%s: dp.%d delay RGB:%d, hs:%d, vs:%d, de:%d, fmt:0x%x\n", + __func__, module, rgb_pvd, hsync_cp1, vsync_fram, de_cp2, + out_format); + + return 0; +} + +void dp_control_enable(int module, int on) +{ + debug("%s: dp.%d top %s\n", __func__, module, on ? "ON" : "OFF"); + + nx_dpc_set_dpc_enable(module, on); + nx_dpc_set_clock_divisor_enable(module, on); +} + +void dp_plane_init(int module) +{ + void *base = __io_address(nx_mlc_get_physical_address(module)); + + nx_mlc_set_base_address(module, base); + nx_mlc_set_clock_pclk_mode(module, nx_pclkmode_always); + nx_mlc_set_clock_bclk_mode(module, nx_bclkmode_always); +} + +int dp_plane_screen_setup(int module, struct dp_plane_top *top) +{ + int width = top->screen_width; + int height = top->screen_height; + int interlace = top->interlace; + int video_prior = top->video_prior; + unsigned int bg_color = top->back_color; + + /* MLC TOP layer */ + nx_mlc_set_screen_size(module, width, height); + nx_mlc_set_layer_priority(module, video_prior); + nx_mlc_set_background(module, bg_color); + nx_mlc_set_field_enable(module, interlace); + nx_mlc_set_rgblayer_gama_table_power_mode(module, 0, 0, 0); + nx_mlc_set_rgblayer_gama_table_sleep_mode(module, 1, 1, 1); + nx_mlc_set_rgblayer_gamma_enable(module, 0); + nx_mlc_set_dither_enable_when_using_gamma(module, 0); + nx_mlc_set_gamma_priority(module, 0); + nx_mlc_set_top_power_mode(module, 1); + nx_mlc_set_top_sleep_mode(module, 0); + + debug("%s: dp.%d screen %dx%d, %s, priority:%d, bg:0x%x\n", + __func__, module, width, height, + interlace ? "Interlace" : "Progressive", + video_prior, bg_color); + + return 0; +} + +void dp_plane_screen_enable(int module, int on) +{ + /* enable top screen */ + nx_mlc_set_mlc_enable(module, on); + nx_mlc_set_top_dirty_flag(module); + debug("%s: dp.%d top %s\n", __func__, module, on ? "ON" : "OFF"); +} + +int dp_plane_layer_setup(int module, struct dp_plane_info *plane) +{ + int sx = plane->left; + int sy = plane->top; + int ex = sx + plane->width - 1; + int ey = sy + plane->height - 1; + int pixel_byte = plane->pixel_byte; + int mem_lock_size = 16; /* fix mem lock size */ + int layer = plane->layer; + unsigned int format = plane->format; + + if (!plane->enable) + return -EINVAL; + + /* MLC layer */ + nx_mlc_set_lock_size(module, layer, mem_lock_size); + nx_mlc_set_alpha_blending(module, layer, 0, 15); + nx_mlc_set_transparency(module, layer, 0, 0); + nx_mlc_set_color_inversion(module, layer, 0, 0); + nx_mlc_set_rgblayer_invalid_position(module, layer, 0, 0, 0, 0, 0, 0); + nx_mlc_set_rgblayer_invalid_position(module, layer, 1, 0, 0, 0, 0, 0); + nx_mlc_set_format_rgb(module, layer, format); + nx_mlc_set_position(module, layer, sx, sy, ex, ey); + nx_mlc_set_rgblayer_stride(module, layer, pixel_byte, + plane->width * pixel_byte); + nx_mlc_set_rgblayer_address(module, layer, plane->fb_base); + + debug("%s: dp.%d.%d %d * %d, %dbpp, fmt:0x%x\n", + __func__, module, layer, plane->width, plane->height, + pixel_byte * 8, format); + debug("%s: b:0x%x, l:%d, t:%d, r:%d, b:%d, hs:%d, vs:%d\n", + __func__, plane->fb_base, sx, sy, ex, ey, + plane->width * pixel_byte, pixel_byte); + + return 0; +} + +int dp_plane_set_enable(int module, int layer, int on) +{ + int hl, hc; + int vl, vc; + + debug("%s: dp.%d.%d %s:%s\n", + __func__, module, layer, + layer == MLC_LAYER_VIDEO ? "Video" : "RGB", + on ? "ON" : "OFF"); + + if (layer != MLC_LAYER_VIDEO) { + nx_mlc_set_layer_enable(module, layer, on); + nx_mlc_set_dirty_flag(module, layer); + return 0; + } + + /* video layer */ + if (on) { + nx_mlc_set_video_layer_line_buffer_power_mode(module, 1); + nx_mlc_set_video_layer_line_buffer_sleep_mode(module, 0); + nx_mlc_set_layer_enable(module, layer, 1); + nx_mlc_set_dirty_flag(module, layer); + } else { + nx_mlc_set_layer_enable(module, layer, 0); + nx_mlc_set_dirty_flag(module, layer); + nx_mlc_get_video_layer_scale_filter(module, + &hl, &hc, &vl, &vc); + if (hl || hc || vl || vc) + nx_mlc_set_video_layer_scale_filter(module, 0, 0, 0, 0); + nx_mlc_set_video_layer_line_buffer_power_mode(module, 0); + nx_mlc_set_video_layer_line_buffer_sleep_mode(module, 1); + nx_mlc_set_dirty_flag(module, layer); + } + + return 0; +} + +void dp_plane_layer_enable(int module, + struct dp_plane_info *plane, int on) +{ + dp_plane_set_enable(module, plane->layer, on); +} + +int dp_plane_set_address(int module, int layer, unsigned int address) +{ + nx_mlc_set_rgblayer_address(module, layer, address); + nx_mlc_set_dirty_flag(module, layer); + + return 0; +} + +int dp_plane_wait_vsync(int module, int layer, int fps) +{ + int cnt = 0; + + if (fps == 0) + return (int)nx_mlc_get_dirty_flag(module, layer); + + while (fps > cnt++) { + while (nx_mlc_get_dirty_flag(module, layer)) + ; + nx_mlc_set_dirty_flag(module, layer); + } + return 0; +} diff --git a/drivers/video/nexell/s5pxx18_dp_hdmi.c b/drivers/video/nexell/s5pxx18_dp_hdmi.c new file mode 100644 index 0000000..3f1fb8a --- /dev/null +++ b/drivers/video/nexell/s5pxx18_dp_hdmi.c @@ -0,0 +1,545 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <config.h> +#include <common.h> +#include <errno.h> +#include <log.h> + +#include <asm/arch/nexell.h> +#include <asm/arch/tieoff.h> +#include <asm/arch/reset.h> +#include <asm/arch/display.h> + +#include <linux/delay.h> + +#include "soc/s5pxx18_soc_dpc.h" +#include "soc/s5pxx18_soc_hdmi.h" +#include "soc/s5pxx18_soc_disptop.h" +#include "soc/s5pxx18_soc_disptop_clk.h" + +#define __io_address(a) (void *)(uintptr_t)(a) + +static const u8 hdmiphy_preset74_25[32] = { + 0xd1, 0x1f, 0x10, 0x40, 0x40, 0xf8, 0xc8, 0x81, + 0xe8, 0xba, 0xd8, 0x45, 0xa0, 0xac, 0x80, 0x0a, + 0x80, 0x09, 0x84, 0x05, 0x22, 0x24, 0x86, 0x54, + 0xa5, 0x24, 0x01, 0x00, 0x00, 0x01, 0x10, 0x80, +}; + +static const u8 hdmiphy_preset148_5[32] = { + 0xd1, 0x1f, 0x00, 0x40, 0x40, 0xf8, 0xc8, 0x81, + 0xe8, 0xba, 0xd8, 0x45, 0xa0, 0xac, 0x80, 0x0a, + 0x80, 0x09, 0x84, 0x05, 0x22, 0x24, 0x86, 0x54, + 0x4b, 0x25, 0x03, 0x00, 0x00, 0x01, 0x80, +}; + +#define HDMIPHY_PRESET_TABLE_SIZE (32) + +enum NXP_HDMI_PRESET { + NXP_HDMI_PRESET_720P = 0, /* 1280 x 720 */ + NXP_HDMI_PRESET_1080P, /* 1920 x 1080 */ + NXP_HDMI_PRESET_MAX +}; + +static void hdmi_reset(void) +{ + nx_rstcon_setrst(RESET_ID_HDMI_VIDEO, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_HDMI_SPDIF, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_HDMI_TMDS, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_HDMI_VIDEO, RSTCON_NEGATE); + nx_rstcon_setrst(RESET_ID_HDMI_SPDIF, RSTCON_NEGATE); + nx_rstcon_setrst(RESET_ID_HDMI_TMDS, RSTCON_NEGATE); +} + +static int hdmi_phy_enable(int preset, int enable) +{ + const u8 *table = NULL; + int size = 0; + u32 addr, i = 0; + + if (!enable) + return 0; + + switch (preset) { + case NXP_HDMI_PRESET_720P: + table = hdmiphy_preset74_25; + size = 32; + break; + case NXP_HDMI_PRESET_1080P: + table = hdmiphy_preset148_5; + size = 31; + break; + default: + printf("hdmi: phy not support preset %d\n", preset); + return -EINVAL; + } + + nx_hdmi_set_reg(0, HDMI_PHY_REG7C, (0 << 7)); + nx_hdmi_set_reg(0, HDMI_PHY_REG7C, (0 << 7)); + nx_hdmi_set_reg(0, HDMI_PHY_REG04, (0 << 4)); + nx_hdmi_set_reg(0, HDMI_PHY_REG04, (0 << 4)); + nx_hdmi_set_reg(0, HDMI_PHY_REG24, (1 << 7)); + nx_hdmi_set_reg(0, HDMI_PHY_REG24, (1 << 7)); + + for (i = 0, addr = HDMI_PHY_REG04; size > i; i++, addr += 4) { + nx_hdmi_set_reg(0, addr, table[i]); + nx_hdmi_set_reg(0, addr, table[i]); + } + + nx_hdmi_set_reg(0, HDMI_PHY_REG7C, 0x80); + nx_hdmi_set_reg(0, HDMI_PHY_REG7C, 0x80); + nx_hdmi_set_reg(0, HDMI_PHY_REG7C, (1 << 7)); + nx_hdmi_set_reg(0, HDMI_PHY_REG7C, (1 << 7)); + debug("%s: preset = %d\n", __func__, preset); + + return 0; +} + +static inline int hdmi_wait_phy_ready(void) +{ + int count = 500; + + do { + u32 val = nx_hdmi_get_reg(0, HDMI_LINK_PHY_STATUS_0); + + if (val & 0x01) { + printf("HDMI: phy ready...\n"); + return 1; + } + mdelay(10); + } while (count--); + + return 0; +} + +static inline int hdmi_get_vsync(int preset, + struct dp_sync_info *sync, + struct dp_ctrl_info *ctrl) +{ + switch (preset) { + case NXP_HDMI_PRESET_720P: /* 720p: 1280x720 */ + sync->h_active_len = 1280; + sync->h_sync_width = 40; + sync->h_back_porch = 220; + sync->h_front_porch = 110; + sync->h_sync_invert = 0; + sync->v_active_len = 720; + sync->v_sync_width = 5; + sync->v_back_porch = 20; + sync->v_front_porch = 5; + sync->v_sync_invert = 0; + break; + + case NXP_HDMI_PRESET_1080P: /* 1080p: 1920x1080 */ + sync->h_active_len = 1920; + sync->h_sync_width = 44; + sync->h_back_porch = 148; + sync->h_front_porch = 88; + sync->h_sync_invert = 0; + sync->v_active_len = 1080; + sync->v_sync_width = 5; + sync->v_back_porch = 36; + sync->v_front_porch = 4; + sync->v_sync_invert = 0; + break; + default: + printf("HDMI: not support preset sync %d\n", preset); + return -EINVAL; + } + + ctrl->clk_src_lv0 = 4; + ctrl->clk_div_lv0 = 1; + ctrl->clk_src_lv1 = 7; + ctrl->clk_div_lv1 = 1; + + ctrl->out_format = outputformat_rgb888; + ctrl->delay_mask = (DP_SYNC_DELAY_RGB_PVD | DP_SYNC_DELAY_HSYNC_CP1 | + DP_SYNC_DELAY_VSYNC_FRAM | DP_SYNC_DELAY_DE_CP); + ctrl->d_rgb_pvd = 0; + ctrl->d_hsync_cp1 = 0; + ctrl->d_vsync_fram = 0; + ctrl->d_de_cp2 = 7; + + /* HFP + HSW + HBP + AVWidth-VSCLRPIXEL- 1; */ + ctrl->vs_start_offset = (sync->h_front_porch + sync->h_sync_width + + sync->h_back_porch + sync->h_active_len - 1); + ctrl->vs_end_offset = 0; + + /* HFP + HSW + HBP + AVWidth-EVENVSCLRPIXEL- 1 */ + ctrl->ev_start_offset = (sync->h_front_porch + sync->h_sync_width + + sync->h_back_porch + sync->h_active_len - 1); + ctrl->ev_end_offset = 0; + debug("%s: preset: %d\n", __func__, preset); + + return 0; +} + +static void hdmi_clock(void) +{ + void *base = + __io_address(nx_disp_top_clkgen_get_physical_address + (to_mipi_clkgen)); + + nx_disp_top_clkgen_set_base_address(to_mipi_clkgen, base); + nx_disp_top_clkgen_set_clock_divisor_enable(to_mipi_clkgen, 0); + nx_disp_top_clkgen_set_clock_pclk_mode(to_mipi_clkgen, + nx_pclkmode_always); + nx_disp_top_clkgen_set_clock_source(to_mipi_clkgen, HDMI_SPDIF_CLKOUT, + 2); + nx_disp_top_clkgen_set_clock_divisor(to_mipi_clkgen, HDMI_SPDIF_CLKOUT, + 2); + nx_disp_top_clkgen_set_clock_source(to_mipi_clkgen, 1, 7); + nx_disp_top_clkgen_set_clock_divisor_enable(to_mipi_clkgen, 1); + + /* must initialize this !!! */ + nx_disp_top_hdmi_set_vsync_hsstart_end(0, 0); + nx_disp_top_hdmi_set_vsync_start(0); + nx_disp_top_hdmi_set_hactive_start(0); + nx_disp_top_hdmi_set_hactive_end(0); +} + +static void hdmi_vsync(struct dp_sync_info *sync) +{ + int width = sync->h_active_len; + int hsw = sync->h_sync_width; + int hbp = sync->h_back_porch; + int height = sync->v_active_len; + int vsw = sync->v_sync_width; + int vbp = sync->v_back_porch; + + int v_sync_s = vsw + vbp + height - 1; + int h_active_s = hsw + hbp; + int h_active_e = width + hsw + hbp; + int v_sync_hs_se0 = hsw + hbp + 1; + int v_sync_hs_se1 = hsw + hbp + 2; + + nx_disp_top_hdmi_set_vsync_start(v_sync_s); + nx_disp_top_hdmi_set_hactive_start(h_active_s); + nx_disp_top_hdmi_set_hactive_end(h_active_e); + nx_disp_top_hdmi_set_vsync_hsstart_end(v_sync_hs_se0, v_sync_hs_se1); +} + +static int hdmi_prepare(struct dp_sync_info *sync) +{ + int width = sync->h_active_len; + int hsw = sync->h_sync_width; + int hfp = sync->h_front_porch; + int hbp = sync->h_back_porch; + int height = sync->v_active_len; + int vsw = sync->v_sync_width; + int vfp = sync->v_front_porch; + int vbp = sync->v_back_porch; + + u32 h_blank, h_line, h_sync_start, h_sync_end; + u32 v_blank, v2_blank, v_line; + u32 v_sync_line_bef_1, v_sync_line_bef_2; + + u32 fixed_ffff = 0xffff; + + /* calculate sync variables */ + h_blank = hfp + hsw + hbp; + v_blank = vfp + vsw + vbp; + v2_blank = height + vfp + vsw + vbp; + v_line = height + vfp + vsw + vbp; /* total v */ + h_line = width + hfp + hsw + hbp; /* total h */ + h_sync_start = hfp; + h_sync_end = hfp + hsw; + v_sync_line_bef_1 = vfp; + v_sync_line_bef_2 = vfp + vsw; + + /* no blue screen mode, encoding order as it is */ + nx_hdmi_set_reg(0, HDMI_LINK_HDMI_CON_0, (0 << 5) | (1 << 4)); + + /* set HDMI_LINK_BLUE_SCREEN_* to 0x0 */ + nx_hdmi_set_reg(0, HDMI_LINK_BLUE_SCREEN_R_0, 0x5555); + nx_hdmi_set_reg(0, HDMI_LINK_BLUE_SCREEN_R_1, 0x5555); + nx_hdmi_set_reg(0, HDMI_LINK_BLUE_SCREEN_G_0, 0x5555); + nx_hdmi_set_reg(0, HDMI_LINK_BLUE_SCREEN_G_1, 0x5555); + nx_hdmi_set_reg(0, HDMI_LINK_BLUE_SCREEN_B_0, 0x5555); + nx_hdmi_set_reg(0, HDMI_LINK_BLUE_SCREEN_B_1, 0x5555); + + /* set HDMI_CON_1 to 0x0 */ + nx_hdmi_set_reg(0, HDMI_LINK_HDMI_CON_1, 0x0); + nx_hdmi_set_reg(0, HDMI_LINK_HDMI_CON_2, 0x0); + + /* set interrupt : enable hpd_plug, hpd_unplug */ + nx_hdmi_set_reg(0, HDMI_LINK_INTC_CON_0, + (1 << 6) | (1 << 3) | (1 << 2)); + + /* set STATUS_EN to 0x17 */ + nx_hdmi_set_reg(0, HDMI_LINK_STATUS_EN, 0x17); + + /* TODO set HDP to 0x0 : later check hpd */ + nx_hdmi_set_reg(0, HDMI_LINK_HPD, 0x0); + + /* set MODE_SEL to 0x02 */ + nx_hdmi_set_reg(0, HDMI_LINK_MODE_SEL, 0x2); + + /* set H_BLANK_*, V1_BLANK_*, V2_BLANK_*, V_LINE_*, + * H_LINE_*, H_SYNC_START_*, H_SYNC_END_ * + * V_SYNC_LINE_BEF_1_*, V_SYNC_LINE_BEF_2_* + */ + nx_hdmi_set_reg(0, HDMI_LINK_H_BLANK_0, h_blank % 256); + nx_hdmi_set_reg(0, HDMI_LINK_H_BLANK_1, h_blank >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V1_BLANK_0, v_blank % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V1_BLANK_1, v_blank >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V2_BLANK_0, v2_blank % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V2_BLANK_1, v2_blank >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_LINE_0, v_line % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_LINE_1, v_line >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_H_LINE_0, h_line % 256); + nx_hdmi_set_reg(0, HDMI_LINK_H_LINE_1, h_line >> 8); + + if (width == 1280) { + nx_hdmi_set_reg(0, HDMI_LINK_HSYNC_POL, 0x1); + nx_hdmi_set_reg(0, HDMI_LINK_VSYNC_POL, 0x1); + } else { + nx_hdmi_set_reg(0, HDMI_LINK_HSYNC_POL, 0x0); + nx_hdmi_set_reg(0, HDMI_LINK_VSYNC_POL, 0x0); + } + + nx_hdmi_set_reg(0, HDMI_LINK_INT_PRO_MODE, 0x0); + + nx_hdmi_set_reg(0, HDMI_LINK_H_SYNC_START_0, (h_sync_start % 256) - 2); + nx_hdmi_set_reg(0, HDMI_LINK_H_SYNC_START_1, h_sync_start >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_H_SYNC_END_0, (h_sync_end % 256) - 2); + nx_hdmi_set_reg(0, HDMI_LINK_H_SYNC_END_1, h_sync_end >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_BEF_1_0, + v_sync_line_bef_1 % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_BEF_1_1, + v_sync_line_bef_1 >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_BEF_2_0, + v_sync_line_bef_2 % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_BEF_2_1, + v_sync_line_bef_2 >> 8); + + /* Set V_SYNC_LINE_AFT*, V_SYNC_LINE_AFT_PXL*, VACT_SPACE* */ + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_1_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_1_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_2_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_2_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_3_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_3_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_4_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_4_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_5_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_5_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_6_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_6_1, fixed_ffff >> 8); + + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_1_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_1_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_2_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_2_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_3_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_3_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_4_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_4_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_5_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_5_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_6_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_V_SYNC_LINE_AFT_PXL_6_1, fixed_ffff >> 8); + + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE1_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE1_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE2_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE2_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE3_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE3_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE4_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE4_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE5_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE5_1, fixed_ffff >> 8); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE6_0, fixed_ffff % 256); + nx_hdmi_set_reg(0, HDMI_LINK_VACT_SPACE6_1, fixed_ffff >> 8); + + nx_hdmi_set_reg(0, HDMI_LINK_CSC_MUX, 0x0); + nx_hdmi_set_reg(0, HDMI_LINK_SYNC_GEN_MUX, 0x0); + + nx_hdmi_set_reg(0, HDMI_LINK_SEND_START_0, 0xfd); + nx_hdmi_set_reg(0, HDMI_LINK_SEND_START_1, 0x01); + nx_hdmi_set_reg(0, HDMI_LINK_SEND_END_0, 0x0d); + nx_hdmi_set_reg(0, HDMI_LINK_SEND_END_1, 0x3a); + nx_hdmi_set_reg(0, HDMI_LINK_SEND_END_2, 0x08); + + /* Set DC_CONTROL to 0x00 */ + nx_hdmi_set_reg(0, HDMI_LINK_DC_CONTROL, 0x0); + + if (IS_ENABLED(CONFIG_HDMI_PATTERN)) + nx_hdmi_set_reg(0, HDMI_LINK_VIDEO_PATTERN_GEN, 0x1); + else + nx_hdmi_set_reg(0, HDMI_LINK_VIDEO_PATTERN_GEN, 0x0); + + nx_hdmi_set_reg(0, HDMI_LINK_GCP_CON, 0x0a); + return 0; +} + +static void hdmi_init(void) +{ + void *base; + /** + * [SEQ 2] set the HDMI CLKGEN's PCLKMODE to always enabled + */ + base = + __io_address(nx_disp_top_clkgen_get_physical_address(hdmi_clkgen)); + nx_disp_top_clkgen_set_base_address(hdmi_clkgen, base); + nx_disp_top_clkgen_set_clock_pclk_mode(hdmi_clkgen, nx_pclkmode_always); + + base = __io_address(nx_hdmi_get_physical_address(0)); + nx_hdmi_set_base_address(0, base); + + /** + * [SEQ 3] set the 0xC001100C[0] to 1 + */ + nx_tieoff_set(NX_TIEOFF_DISPLAYTOP0_i_HDMI_PHY_REFCLK_SEL, 1); + + /** + * [SEQ 4] release the resets of HDMI.i_PHY_nRST and HDMI.i_nRST + */ + nx_rstcon_setrst(RESET_ID_HDMI_PHY, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_HDMI, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_HDMI_PHY, RSTCON_NEGATE); + nx_rstcon_setrst(RESET_ID_HDMI, RSTCON_NEGATE); +} + +void hdmi_enable(int input, int preset, struct dp_sync_info *sync, int enable) +{ + if (enable) { + nx_hdmi_set_reg(0, HDMI_LINK_HDMI_CON_0, + (nx_hdmi_get_reg(0, HDMI_LINK_HDMI_CON_0) | + 0x1)); + hdmi_vsync(sync); + } else { + hdmi_phy_enable(preset, 0); + } +} + +static int hdmi_setup(int input, int preset, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl) +{ + u32 HDMI_SEL = 0; + int ret; + + switch (input) { + case DP_DEVICE_DP0: + HDMI_SEL = primary_mlc; + break; + case DP_DEVICE_DP1: + HDMI_SEL = secondary_mlc; + break; + case DP_DEVICE_RESCONV: + HDMI_SEL = resolution_conv; + break; + default: + printf("HDMI: not support source device %d\n", input); + return -EINVAL; + } + + /** + * [SEQ 5] set up the HDMI PHY to specific video clock. + */ + ret = hdmi_phy_enable(preset, 1); + if (ret < 0) + return ret; + + /** + * [SEQ 6] I2S (or SPDIFTX) configuration for the source audio data + * this is done in another user app - ex> Android Audio HAL + */ + + /** + * [SEQ 7] Wait for ECID ready + */ + + /** + * [SEQ 8] release the resets of HDMI.i_VIDEO_nRST and HDMI.i_SPDIF_nRST + * and HDMI.i_TMDS_nRST + */ + hdmi_reset(); + + /** + * [SEQ 9] Wait for HDMI PHY ready (wait until 0xC0200020.[0], 1) + */ + if (hdmi_wait_phy_ready() == 0) { + printf("%s: failed to wait for hdmiphy ready\n", __func__); + hdmi_phy_enable(preset, 0); + return -EIO; + } + /* set mux */ + nx_disp_top_set_hdmimux(1, HDMI_SEL); + + /** + * [SEC 10] Set the DPC CLKGEN's Source Clock to HDMI_CLK & + * Set Sync Parameter + */ + hdmi_clock(); + /* set hdmi link clk to clkgen vs default is hdmi phy clk */ + + /** + * [SEQ 11] Set up the HDMI Converter parameters + */ + hdmi_get_vsync(preset, sync, ctrl); + hdmi_prepare(sync); + + return 0; +} + +void nx_hdmi_display(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_plane_top *top, struct dp_plane_info *planes, + struct dp_hdmi_dev *dev) +{ + struct dp_plane_info *plane = planes; + int input = module == 0 ? DP_DEVICE_DP0 : DP_DEVICE_DP1; + int count = top->plane_num; + int preset = dev->preset; + int i = 0; + + debug("HDMI: display.%d\n", module); + + switch (preset) { + case 0: + top->screen_width = 1280; + top->screen_height = 720; + sync->h_active_len = 1280; + sync->v_active_len = 720; + break; + case 1: + top->screen_width = 1920; + top->screen_height = 1080; + sync->h_active_len = 1920; + sync->v_active_len = 1080; + break; + default: + printf("hdmi not support preset %d\n", preset); + return; + } + + printf("HDMI: display.%d, preset %d (%4d * %4d)\n", + module, preset, top->screen_width, top->screen_height); + + dp_control_init(module); + dp_plane_init(module); + + hdmi_init(); + hdmi_setup(input, preset, sync, ctrl); + + dp_plane_screen_setup(module, top); + for (i = 0; count > i; i++, plane++) { + if (!plane->enable) + continue; + dp_plane_layer_setup(module, plane); + dp_plane_layer_enable(module, plane, 1); + } + dp_plane_screen_enable(module, 1); + + dp_control_setup(module, sync, ctrl); + dp_control_enable(module, 1); + + hdmi_enable(input, preset, sync, 1); +} diff --git a/drivers/video/nexell/s5pxx18_dp_lvds.c b/drivers/video/nexell/s5pxx18_dp_lvds.c new file mode 100644 index 0000000..f8ea63f --- /dev/null +++ b/drivers/video/nexell/s5pxx18_dp_lvds.c @@ -0,0 +1,274 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <config.h> +#include <common.h> +#include <errno.h> + +#include <asm/arch/nexell.h> +#include <asm/arch/reset.h> +#include <asm/arch/display.h> + +#include "soc/s5pxx18_soc_lvds.h" +#include "soc/s5pxx18_soc_disptop.h" +#include "soc/s5pxx18_soc_disptop_clk.h" + +#define __io_address(a) (void *)(uintptr_t)(a) + +static void lvds_phy_reset(void) +{ + nx_rstcon_setrst(RESET_ID_LVDS, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_LVDS, RSTCON_NEGATE); +} + +static void lvds_init(void) +{ + int clkid = DP_CLOCK_LVDS; + int index = 0; + void *base; + + base = __io_address(nx_disp_top_clkgen_get_physical_address(clkid)); + nx_disp_top_clkgen_set_base_address(clkid, base); + + nx_lvds_initialize(); + + for (index = 0; nx_lvds_get_number_of_module() > index; index++) + nx_lvds_set_base_address(index, + (void *)__io_address(nx_lvds_get_physical_address(index))); + + nx_disp_top_clkgen_set_clock_pclk_mode(clkid, nx_pclkmode_always); +} + +static void lvds_enable(int enable) +{ + int clkid = DP_CLOCK_LVDS; + int on = (enable ? 1 : 0); + + nx_disp_top_clkgen_set_clock_divisor_enable(clkid, on); +} + +static int lvds_setup(int module, int input, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_lvds_dev *dev) +{ + unsigned int val; + int clkid = DP_CLOCK_LVDS; + enum dp_lvds_format format = DP_LVDS_FORMAT_JEIDA; + u32 voltage = DEF_VOLTAGE_LEVEL; + + if (dev) { + format = dev->lvds_format; + voltage = dev->voltage_level; + } + + printf("LVDS: "); + printf("%s, ", format == DP_LVDS_FORMAT_VESA ? "VESA" : + format == DP_LVDS_FORMAT_JEIDA ? "JEIDA" : "LOC"); + printf("voltage LV:0x%x\n", voltage); + + /* + *-------- predefined type. + * only change iTA to iTE in VESA mode + * wire [34:0] loc_VideoIn = + * {4'hf, 4'h0, i_VDEN, i_VSYNC, i_HSYNC, i_VD[23:0] }; + */ + u32 VSYNC = 25; + u32 HSYNC = 24; + u32 VDEN = 26; /* bit position */ + u32 ONE = 34; + u32 ZERO = 27; + + /*==================================================== + * current not use location mode + *==================================================== + */ + u32 LOC_A[7] = {ONE, ONE, ONE, ONE, ONE, ONE, ONE}; + u32 LOC_B[7] = {ONE, ONE, ONE, ONE, ONE, ONE, ONE}; + u32 LOC_C[7] = {VDEN, VSYNC, HSYNC, ONE, HSYNC, VSYNC, VDEN}; + u32 LOC_D[7] = {ZERO, ZERO, ZERO, ZERO, ZERO, ZERO, ZERO}; + u32 LOC_E[7] = {ZERO, ZERO, ZERO, ZERO, ZERO, ZERO, ZERO}; + + switch (input) { + case DP_DEVICE_DP0: + input = 0; + break; + case DP_DEVICE_DP1: + input = 1; + break; + case DP_DEVICE_RESCONV: + input = 2; + break; + default: + return -EINVAL; + } + + /* + * select TOP MUX + */ + nx_disp_top_clkgen_set_clock_divisor_enable(clkid, 0); + nx_disp_top_clkgen_set_clock_source(clkid, 0, ctrl->clk_src_lv0); + nx_disp_top_clkgen_set_clock_divisor(clkid, 0, ctrl->clk_div_lv0); + nx_disp_top_clkgen_set_clock_source(clkid, 1, ctrl->clk_src_lv1); + nx_disp_top_clkgen_set_clock_divisor(clkid, 1, ctrl->clk_div_lv1); + + /* + * LVDS Control Pin Setting + */ + val = (0 << 30) | /* CPU_I_VBLK_FLAG_SEL */ + (0 << 29) | /* CPU_I_BVLK_FLAG */ + (1 << 28) | /* SKINI_BST */ + (1 << 27) | /* DLYS_BST */ + (0 << 26) | /* I_AUTO_SEL */ + (format << 19) | /* JEiDA data packing */ + (0x1B << 13) | /* I_LOCK_PPM_SET, PPM setting for PLL lock */ + (0x638 << 1); /* I_DESKEW_CNT_SEL, period of de-skew region */ + nx_lvds_set_lvdsctrl0(0, val); + + val = (0 << 28) | /* I_ATE_MODE, function mode */ + (0 << 27) | /* I_TEST_CON_MODE, DA (test ctrl mode) */ + (0 << 24) | /* I_TX4010X_DUMMY */ + (0 << 15) | /* SKCCK 0 */ + (0 << 12) | /* SKC4 (TX output skew control pin at ODD ch4) */ + (0 << 9) | /* SKC3 (TX output skew control pin at ODD ch3) */ + (0 << 6) | /* SKC2 (TX output skew control pin at ODD ch2) */ + (0 << 3) | /* SKC1 (TX output skew control pin at ODD ch1) */ + (0 << 0); /* SKC0 (TX output skew control pin at ODD ch0) */ + nx_lvds_set_lvdsctrl1(0, val); + + val = (0 << 15) | /* CK_POL_SEL, Input clock, bypass */ + (0 << 14) | /* VSEL, VCO Freq. range. 0: Low(40MHz~90MHz), + * 1: High(90MHz~160MHz) */ + (0x1 << 12) | /* S (Post-scaler) */ + (0xA << 6) | /* M (Main divider) */ + (0xA << 0); /* P (Pre-divider) */ + + nx_lvds_set_lvdsctrl2(0, val); + val = (0x03 << 6) | /* SK_BIAS, Bias current ctrl pin */ + (0 << 5) | /* SKEWINI, skew selection pin, 0: bypass, + * 1: skew enable */ + (0 << 4) | /* SKEW_EN_H, skew block power down, 0: power down, + * 1: operating */ + (1 << 3) | /* CNTB_TDLY, delay control pin */ + (0 << 2) | /* SEL_DATABF, input clock 1/2 division cont. pin */ + (0x3 << 0); /* SKEW_REG_CUR, regulator bias current selection + * in SKEW block */ + + nx_lvds_set_lvdsctrl3(0, val); + val = (0 << 28) | /* FLT_CNT, filter control pin for PLL */ + (0 << 27) | /* VOD_ONLY_CNT, the pre-emphasis's pre-diriver + * control pin (VOD only) */ + (0 << 26) | /* CNNCT_MODE_SEL, connectivity mode selection, + * 0:TX operating, 1:con check */ + (0 << 24) | /* CNNCT_CNT, connectivity ctrl pin, + * 0: tx operating, 1: con check */ + (0 << 23) | /* VOD_HIGH_S, VOD control pin, 1: Vod only */ + (0 << 22) | /* SRC_TRH, source termination resistor sel. pin */ + (voltage << 14) | + (0x01 << 6) | /* CNT_PEN_H, TX driver pre-emphasis level cont. */ + (0x4 << 3) | /* FC_CODE, vos control pin */ + (0 << 2) | /* OUTCON, TX Driver state selectioin pin, 0:Hi-z, + * 1:Low */ + (0 << 1) | /* LOCK_CNT, Lock signal selection pin, enable */ + (0 << 0); /* AUTO_DSK_SEL, auto deskew sel. pin, normal */ + nx_lvds_set_lvdsctrl4(0, val); + + val = (0 << 24) | /* I_BIST_RESETB */ + (0 << 23) | /* I_BIST_EN */ + (0 << 21) | /* I_BIST_PAT_SEL */ + (0 << 14) | /* I_BIST_USER_PATTERN */ + (0 << 13) | /* I_BIST_FORCE_ERROR */ + (0 << 7) | /* I_BIST_SKEW_CTRL */ + (0 << 5) | /* I_BIST_CLK_INV */ + (0 << 3) | /* I_BIST_DATA_INV */ + (0 << 0); /* I_BIST_CH_SEL */ + nx_lvds_set_lvdstmode0(0, val); + + /* user do not need to modify this codes. */ + val = (LOC_A[4] << 24) | (LOC_A[3] << 18) | (LOC_A[2] << 12) | + (LOC_A[1] << 6) | (LOC_A[0] << 0); + nx_lvds_set_lvdsloc0(0, val); + + val = (LOC_B[2] << 24) | (LOC_B[1] << 18) | (LOC_B[0] << 12) | + (LOC_A[6] << 6) | (LOC_A[5] << 0); + nx_lvds_set_lvdsloc1(0, val); + + val = (LOC_C[0] << 24) | (LOC_B[6] << 18) | (LOC_B[5] << 12) | + (LOC_B[4] << 6) | (LOC_B[3] << 0); + nx_lvds_set_lvdsloc2(0, val); + + val = (LOC_C[5] << 24) | (LOC_C[4] << 18) | (LOC_C[3] << 12) | + (LOC_C[2] << 6) | (LOC_C[1] << 0); + nx_lvds_set_lvdsloc3(0, val); + + val = (LOC_D[3] << 24) | (LOC_D[2] << 18) | (LOC_D[1] << 12) | + (LOC_D[0] << 6) | (LOC_C[6] << 0); + nx_lvds_set_lvdsloc4(0, val); + + val = (LOC_E[1] << 24) | (LOC_E[0] << 18) | (LOC_D[6] << 12) | + (LOC_D[5] << 6) | (LOC_D[4] << 0); + nx_lvds_set_lvdsloc5(0, val); + + val = (LOC_E[6] << 24) | (LOC_E[5] << 18) | (LOC_E[4] << 12) | + (LOC_E[3] << 6) | (LOC_E[2] << 0); + nx_lvds_set_lvdsloc6(0, val); + + nx_lvds_set_lvdslocmask0(0, 0xffffffff); + nx_lvds_set_lvdslocmask1(0, 0xffffffff); + + nx_lvds_set_lvdslocpol0(0, (0 << 19) | (0 << 18)); + + /* + * select TOP MUX + */ + nx_disp_top_set_lvdsmux(1, input); + + /* + * LVDS PHY Reset, make sure last. + */ + lvds_phy_reset(); + + return 0; +} + +void nx_lvds_display(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_plane_top *top, struct dp_plane_info *planes, + struct dp_lvds_dev *dev) +{ + struct dp_plane_info *plane = planes; + int input = module == 0 ? DP_DEVICE_DP0 : DP_DEVICE_DP1; + int count = top->plane_num; + int i = 0; + + printf("LVDS: dp.%d\n", module); + + dp_control_init(module); + dp_plane_init(module); + + lvds_init(); + + /* set plane */ + dp_plane_screen_setup(module, top); + + for (i = 0; count > i; i++, plane++) { + if (!plane->enable) + continue; + dp_plane_layer_setup(module, plane); + dp_plane_layer_enable(module, plane, 1); + } + + dp_plane_screen_enable(module, 1); + + /* set lvds */ + lvds_setup(module, input, sync, ctrl, dev); + + lvds_enable(1); + + /* set dp control */ + dp_control_setup(module, sync, ctrl); + dp_control_enable(module, 1); +} diff --git a/drivers/video/nexell/s5pxx18_dp_mipi.c b/drivers/video/nexell/s5pxx18_dp_mipi.c new file mode 100644 index 0000000..670272b --- /dev/null +++ b/drivers/video/nexell/s5pxx18_dp_mipi.c @@ -0,0 +1,677 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <config.h> +#include <common.h> +#include <errno.h> + +#include <asm/arch/nexell.h> +#include <asm/arch/tieoff.h> +#include <asm/arch/reset.h> +#include <asm/arch/display.h> + +#include "soc/s5pxx18_soc_mipi.h" +#include "soc/s5pxx18_soc_disptop.h" +#include "soc/s5pxx18_soc_disptop_clk.h" + +#define PLLPMS_1000MHZ 0x33E8 +#define BANDCTL_1000MHZ 0xF +#define PLLPMS_960MHZ 0x2280 +#define BANDCTL_960MHZ 0xF +#define PLLPMS_900MHZ 0x2258 +#define BANDCTL_900MHZ 0xE +#define PLLPMS_840MHZ 0x2230 +#define BANDCTL_840MHZ 0xD +#define PLLPMS_750MHZ 0x43E8 +#define BANDCTL_750MHZ 0xC +#define PLLPMS_660MHZ 0x21B8 +#define BANDCTL_660MHZ 0xB +#define PLLPMS_600MHZ 0x2190 +#define BANDCTL_600MHZ 0xA +#define PLLPMS_540MHZ 0x2168 +#define BANDCTL_540MHZ 0x9 +#define PLLPMS_512MHZ 0x03200 +#define BANDCTL_512MHZ 0x9 +#define PLLPMS_480MHZ 0x2281 +#define BANDCTL_480MHZ 0x8 +#define PLLPMS_420MHZ 0x2231 +#define BANDCTL_420MHZ 0x7 +#define PLLPMS_402MHZ 0x2219 +#define BANDCTL_402MHZ 0x7 +#define PLLPMS_330MHZ 0x21B9 +#define BANDCTL_330MHZ 0x6 +#define PLLPMS_300MHZ 0x2191 +#define BANDCTL_300MHZ 0x5 +#define PLLPMS_210MHZ 0x2232 +#define BANDCTL_210MHZ 0x4 +#define PLLPMS_180MHZ 0x21E2 +#define BANDCTL_180MHZ 0x3 +#define PLLPMS_150MHZ 0x2192 +#define BANDCTL_150MHZ 0x2 +#define PLLPMS_100MHZ 0x3323 +#define BANDCTL_100MHZ 0x1 +#define PLLPMS_80MHZ 0x3283 +#define BANDCTL_80MHZ 0x0 + +#define MIPI_INDEX 0 +#define MIPI_EXC_PRE_VALUE 1 +#define MIPI_DSI_IRQ_MASK 29 + +#define __io_address(a) (void *)(uintptr_t)(a) + +struct mipi_xfer_msg { + u8 id, data[2]; + u16 flags; + const u8 *tx_buf; + u16 tx_len; + u8 *rx_buf; + u16 rx_len; +}; + +static void mipi_reset(void) +{ + /* tieoff */ + nx_tieoff_set(NX_TIEOFF_MIPI0_NX_DPSRAM_1R1W_EMAA, 3); + nx_tieoff_set(NX_TIEOFF_MIPI0_NX_DPSRAM_1R1W_EMAB, 3); + + /* reset */ + nx_rstcon_setrst(RESET_ID_MIPI, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_MIPI_DSI, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_MIPI_CSI, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_MIPI_PHY_S, RSTCON_ASSERT); + nx_rstcon_setrst(RESET_ID_MIPI_PHY_M, RSTCON_ASSERT); + + nx_rstcon_setrst(RESET_ID_MIPI, RSTCON_NEGATE); + nx_rstcon_setrst(RESET_ID_MIPI_DSI, RSTCON_NEGATE); + nx_rstcon_setrst(RESET_ID_MIPI_PHY_S, RSTCON_NEGATE); + nx_rstcon_setrst(RESET_ID_MIPI_PHY_M, RSTCON_NEGATE); +} + +static void mipi_init(void) +{ + int clkid = DP_CLOCK_MIPI; + void *base; + + /* + * neet to reset before open + */ + mipi_reset(); + + base = __io_address(nx_disp_top_clkgen_get_physical_address(clkid)); + nx_disp_top_clkgen_set_base_address(clkid, base); + nx_disp_top_clkgen_set_clock_pclk_mode(clkid, nx_pclkmode_always); + + base = __io_address(nx_mipi_get_physical_address(0)); + nx_mipi_set_base_address(0, base); +} + +static int mipi_get_phy_pll(int bitrate, unsigned int *pllpms, + unsigned int *bandctl) +{ + unsigned int pms, ctl; + + switch (bitrate) { + case 1000: + pms = PLLPMS_1000MHZ; + ctl = BANDCTL_1000MHZ; + break; + case 960: + pms = PLLPMS_960MHZ; + ctl = BANDCTL_960MHZ; + break; + case 900: + pms = PLLPMS_900MHZ; + ctl = BANDCTL_900MHZ; + break; + case 840: + pms = PLLPMS_840MHZ; + ctl = BANDCTL_840MHZ; + break; + case 750: + pms = PLLPMS_750MHZ; + ctl = BANDCTL_750MHZ; + break; + case 660: + pms = PLLPMS_660MHZ; + ctl = BANDCTL_660MHZ; + break; + case 600: + pms = PLLPMS_600MHZ; + ctl = BANDCTL_600MHZ; + break; + case 540: + pms = PLLPMS_540MHZ; + ctl = BANDCTL_540MHZ; + break; + case 512: + pms = PLLPMS_512MHZ; + ctl = BANDCTL_512MHZ; + break; + case 480: + pms = PLLPMS_480MHZ; + ctl = BANDCTL_480MHZ; + break; + case 420: + pms = PLLPMS_420MHZ; + ctl = BANDCTL_420MHZ; + break; + case 402: + pms = PLLPMS_402MHZ; + ctl = BANDCTL_402MHZ; + break; + case 330: + pms = PLLPMS_330MHZ; + ctl = BANDCTL_330MHZ; + break; + case 300: + pms = PLLPMS_300MHZ; + ctl = BANDCTL_300MHZ; + break; + case 210: + pms = PLLPMS_210MHZ; + ctl = BANDCTL_210MHZ; + break; + case 180: + pms = PLLPMS_180MHZ; + ctl = BANDCTL_180MHZ; + break; + case 150: + pms = PLLPMS_150MHZ; + ctl = BANDCTL_150MHZ; + break; + case 100: + pms = PLLPMS_100MHZ; + ctl = BANDCTL_100MHZ; + break; + case 80: + pms = PLLPMS_80MHZ; + ctl = BANDCTL_80MHZ; + break; + default: + return -EINVAL; + } + + *pllpms = pms; + *bandctl = ctl; + + return 0; +} + +static int mipi_prepare(int module, int input, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_mipi_dev *mipi) +{ + int index = MIPI_INDEX; + u32 esc_pre_value = MIPI_EXC_PRE_VALUE; + int lpm = mipi->lpm_trans; + int ret = 0; + + ret = mipi_get_phy_pll(mipi->hs_bitrate, + &mipi->hs_pllpms, &mipi->hs_bandctl); + if (ret < 0) + return ret; + + ret = mipi_get_phy_pll(mipi->lp_bitrate, + &mipi->lp_pllpms, &mipi->lp_bandctl); + if (ret < 0) + return ret; + + debug("%s: mipi lp:%dmhz:0x%x:0x%x, hs:%dmhz:0x%x:0x%x, %s trans\n", + __func__, mipi->lp_bitrate, mipi->lp_pllpms, mipi->lp_bandctl, + mipi->hs_bitrate, mipi->hs_pllpms, mipi->hs_bandctl, + lpm ? "low" : "high"); + + if (lpm) + nx_mipi_dsi_set_pll(index, 1, 0xFFFFFFFF, + mipi->lp_pllpms, mipi->lp_bandctl, 0, 0); + else + nx_mipi_dsi_set_pll(index, 1, 0xFFFFFFFF, + mipi->hs_pllpms, mipi->hs_bandctl, 0, 0); + +#ifdef CONFIG_ARCH_S5P4418 + /* + * disable the escape clock generating prescaler + * before soft reset. + */ + nx_mipi_dsi_set_clock(index, 0, 0, 1, 1, 1, 0, 0, 0, 0, 10); + mdelay(1); +#endif + + nx_mipi_dsi_software_reset(index); + nx_mipi_dsi_set_clock(index, 0, 0, 1, 1, 1, 0, 0, 0, 1, esc_pre_value); + nx_mipi_dsi_set_phy(index, 0, 1, 1, 0, 0, 0, 0, 0); + + if (lpm) + nx_mipi_dsi_set_escape_lp(index, nx_mipi_dsi_lpmode_lp, + nx_mipi_dsi_lpmode_lp); + else + nx_mipi_dsi_set_escape_lp(index, nx_mipi_dsi_lpmode_hs, + nx_mipi_dsi_lpmode_hs); + mdelay(20); + + return 0; +} + +static int mipi_enable(int module, int input, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_mipi_dev *mipi) +{ + struct mipi_dsi_device *dsi = &mipi->dsi; + int clkid = DP_CLOCK_MIPI; + int index = MIPI_INDEX; + int width = sync->h_active_len; + int height = sync->v_active_len; + int HFP = sync->h_front_porch; + int HBP = sync->h_back_porch; + int HS = sync->h_sync_width; + int VFP = sync->v_front_porch; + int VBP = sync->v_back_porch; + int VS = sync->v_sync_width; + int en_prescaler = 1; + u32 esc_pre_value = MIPI_EXC_PRE_VALUE; + + int txhsclock = 1; + int lpm = mipi->lpm_trans; + bool command_mode = mipi->command_mode; + + enum nx_mipi_dsi_format dsi_format; + int data_len = dsi->lanes - 1; + bool burst = dsi->mode_flags & MIPI_DSI_MODE_VIDEO_BURST ? true : false; + bool eot_enable = dsi->mode_flags & MIPI_DSI_MODE_EOT_PACKET ? + false : true; + + /* + * disable the escape clock generating prescaler + * before soft reset. + */ +#ifdef CONFIG_ARCH_S5P4418 + en_prescaler = 0; +#endif + + debug("%s: mode:%s, lanes.%d\n", __func__, + command_mode ? "command" : "video", data_len + 1); + + if (lpm) + nx_mipi_dsi_set_escape_lp(index, + nx_mipi_dsi_lpmode_hs, + nx_mipi_dsi_lpmode_hs); + + nx_mipi_dsi_set_pll(index, 1, 0xFFFFFFFF, + mipi->hs_pllpms, mipi->hs_bandctl, 0, 0); + mdelay(1); + + nx_mipi_dsi_set_clock(index, 0, 0, 1, 1, 1, 0, 0, 0, en_prescaler, 10); + mdelay(1); + + nx_mipi_dsi_software_reset(index); + nx_mipi_dsi_set_clock(index, txhsclock, 0, 1, + 1, 1, 0, 0, 0, 1, esc_pre_value); + + switch (data_len) { + case 0: /* 1 lane */ + nx_mipi_dsi_set_phy(index, data_len, 1, 1, 0, 0, 0, 0, 0); + break; + case 1: /* 2 lane */ + nx_mipi_dsi_set_phy(index, data_len, 1, 1, 1, 0, 0, 0, 0); + break; + case 2: /* 3 lane */ + nx_mipi_dsi_set_phy(index, data_len, 1, 1, 1, 1, 0, 0, 0); + break; + case 3: /* 3 lane */ + nx_mipi_dsi_set_phy(index, data_len, 1, 1, 1, 1, 1, 0, 0); + break; + default: + printf("%s: not support data lanes %d\n", + __func__, data_len + 1); + return -EINVAL; + } + + switch (dsi->format) { + case MIPI_DSI_FMT_RGB565: + dsi_format = nx_mipi_dsi_format_rgb565; + break; + case MIPI_DSI_FMT_RGB666: + dsi_format = nx_mipi_dsi_format_rgb666; + break; + case MIPI_DSI_FMT_RGB666_PACKED: + dsi_format = nx_mipi_dsi_format_rgb666_packed; + break; + case MIPI_DSI_FMT_RGB888: + dsi_format = nx_mipi_dsi_format_rgb888; + break; + default: + printf("%s: not support format %d\n", __func__, dsi->format); + return -EINVAL; + } + + nx_mipi_dsi_set_config_video_mode(index, 1, 0, burst, + nx_mipi_dsi_syncmode_event, + eot_enable, 1, 1, 1, 1, 0, dsi_format, + HFP, HBP, HS, VFP, VBP, VS, 0); + + nx_mipi_dsi_set_size(index, width, height); + + /* set mux */ + nx_disp_top_set_mipimux(1, module); + + /* 0 is spdif, 1 is mipi vclk */ + nx_disp_top_clkgen_set_clock_source(clkid, 1, ctrl->clk_src_lv0); + nx_disp_top_clkgen_set_clock_divisor(clkid, 1, + ctrl->clk_div_lv1 * + ctrl->clk_div_lv0); + + /* SPDIF and MIPI */ + nx_disp_top_clkgen_set_clock_divisor_enable(clkid, 1); + + /* START: CLKGEN, MIPI is started in setup function */ + nx_disp_top_clkgen_set_clock_divisor_enable(clkid, true); + nx_mipi_dsi_set_enable(index, true); + + return 0; +} + +static int nx_mipi_transfer_tx(struct mipi_dsi_device *dsi, + struct mipi_xfer_msg *xfer) +{ + const u8 *txb; + int size, index = 0; + u32 data; + + if (xfer->tx_len > DSI_TX_FIFO_SIZE) + printf("warn: tx %d size over fifo %d\n", + (int)xfer->tx_len, DSI_TX_FIFO_SIZE); + + /* write payload */ + size = xfer->tx_len; + txb = xfer->tx_buf; + + while (size >= 4) { + data = (txb[3] << 24) | (txb[2] << 16) | + (txb[1] << 8) | (txb[0]); + nx_mipi_dsi_write_payload(index, data); + txb += 4, size -= 4; + data = 0; + } + + switch (size) { + case 3: + data |= txb[2] << 16; + case 2: + data |= txb[1] << 8; + case 1: + data |= txb[0]; + nx_mipi_dsi_write_payload(index, data); + break; + case 0: + break; /* no payload */ + } + + /* write packet hdr */ + data = (xfer->data[1] << 16) | (xfer->data[0] << 8) | xfer->id; + + nx_mipi_dsi_write_pkheader(index, data); + + return 0; +} + +static int nx_mipi_transfer_done(struct mipi_dsi_device *dsi) +{ + int index = 0, count = 100; + u32 value; + + do { + mdelay(1); + value = nx_mipi_dsi_read_fifo_status(index); + if (((1 << 22) & value)) + break; + } while (count-- > 0); + + if (count < 0) + return -EINVAL; + + return 0; +} + +static int nx_mipi_transfer_rx(struct mipi_dsi_device *dsi, + struct mipi_xfer_msg *xfer) +{ + u8 *rxb = xfer->rx_buf; + int index = 0, rx_len = 0; + u32 data, count = 0; + u16 size; + int err = -EINVAL; + + nx_mipi_dsi_clear_interrupt_pending(index, 18); + + while (1) { + /* Completes receiving data. */ + if (nx_mipi_dsi_get_interrupt_pending(index, 18)) + break; + + mdelay(1); + + if (count > 500) { + printf("%s: error recevice data\n", __func__); + err = -EINVAL; + goto clear_fifo; + } else { + count++; + } + } + + data = nx_mipi_dsi_read_fifo(index); + + switch (data & 0x3f) { + case MIPI_DSI_RX_GENERIC_SHORT_READ_RESPONSE_2BYTE: + case MIPI_DSI_RX_DCS_SHORT_READ_RESPONSE_2BYTE: + if (xfer->rx_len >= 2) { + rxb[1] = data >> 16; + rx_len++; + } + + /* Fall through */ + case MIPI_DSI_RX_GENERIC_SHORT_READ_RESPONSE_1BYTE: + case MIPI_DSI_RX_DCS_SHORT_READ_RESPONSE_1BYTE: + rxb[0] = data >> 8; + rx_len++; + xfer->rx_len = rx_len; + err = rx_len; + goto clear_fifo; + + case MIPI_DSI_RX_ACKNOWLEDGE_AND_ERROR_REPORT: + printf("DSI Error Report: 0x%04x\n", (data >> 8) & 0xffff); + err = rx_len; + goto clear_fifo; + } + + size = (data >> 8) & 0xffff; + + if (size > xfer->rx_len) + size = xfer->rx_len; + else if (size < xfer->rx_len) + xfer->rx_len = size; + + size = xfer->rx_len - rx_len; + rx_len += size; + + /* Receive payload */ + while (size >= 4) { + data = nx_mipi_dsi_read_fifo(index); + rxb[0] = (data >> 0) & 0xff; + rxb[1] = (data >> 8) & 0xff; + rxb[2] = (data >> 16) & 0xff; + rxb[3] = (data >> 24) & 0xff; + rxb += 4, size -= 4; + } + + if (size) { + data = nx_mipi_dsi_read_fifo(index); + switch (size) { + case 3: + rxb[2] = (data >> 16) & 0xff; + case 2: + rxb[1] = (data >> 8) & 0xff; + case 1: + rxb[0] = data & 0xff; + } + } + + if (rx_len == xfer->rx_len) + err = rx_len; + +clear_fifo: + size = DSI_RX_FIFO_SIZE / 4; + do { + data = nx_mipi_dsi_read_fifo(index); + if (data == DSI_RX_FIFO_EMPTY) + break; + } while (--size); + + return err; +} + +#define IS_SHORT(t) (9 > ((t) & 0x0f)) + +static int nx_mipi_transfer(struct mipi_dsi_device *dsi, + const struct mipi_dsi_msg *msg) +{ + struct mipi_xfer_msg xfer; + int err; + + if (!msg->tx_len) + return -EINVAL; + + /* set id */ + xfer.id = msg->type | (msg->channel << 6); + + /* short type msg */ + if (IS_SHORT(msg->type)) { + const char *txb = msg->tx_buf; + + if (msg->tx_len > 2) + return -EINVAL; + + xfer.tx_len = 0; /* no payload */ + xfer.data[0] = txb[0]; + xfer.data[1] = (msg->tx_len == 2) ? txb[1] : 0; + xfer.tx_buf = NULL; + } else { + xfer.tx_len = msg->tx_len; + xfer.data[0] = msg->tx_len & 0xff; + xfer.data[1] = msg->tx_len >> 8; + xfer.tx_buf = msg->tx_buf; + } + + xfer.rx_len = msg->rx_len; + xfer.rx_buf = msg->rx_buf; + xfer.flags = msg->flags; + + err = nx_mipi_transfer_tx(dsi, &xfer); + + if (xfer.rx_len) + err = nx_mipi_transfer_rx(dsi, &xfer); + + nx_mipi_transfer_done(dsi); + + return err; +} + +static ssize_t nx_mipi_write_buffer(struct mipi_dsi_device *dsi, + const void *data, size_t len) +{ + struct mipi_dsi_msg msg = { + .channel = dsi->channel, + .tx_buf = data, + .tx_len = len + }; + + switch (len) { + case 0: + return -EINVAL; + case 1: + msg.type = MIPI_DSI_DCS_SHORT_WRITE; + break; + case 2: + msg.type = MIPI_DSI_DCS_SHORT_WRITE_PARAM; + break; + default: + msg.type = MIPI_DSI_DCS_LONG_WRITE; + break; + } + + if (dsi->mode_flags & MIPI_DSI_MODE_LPM) + msg.flags |= MIPI_DSI_MSG_USE_LPM; + + return nx_mipi_transfer(dsi, &msg); +} + +__weak int nx_mipi_dsi_lcd_bind(struct mipi_dsi_device *dsi) +{ + return 0; +} + +/* + * disply + * MIPI DSI Setting + * (1) Initiallize MIPI(DSIM,DPHY,PLL) + * (2) Initiallize LCD + * (3) ReInitiallize MIPI(DSIM only) + * (4) Turn on display(MLC,DPC,...) + */ +void nx_mipi_display(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_plane_top *top, struct dp_plane_info *planes, + struct dp_mipi_dev *dev) +{ + struct dp_plane_info *plane = planes; + struct mipi_dsi_device *dsi = &dev->dsi; + int input = module == 0 ? DP_DEVICE_DP0 : DP_DEVICE_DP1; + int count = top->plane_num; + int i = 0, ret; + + printf("MIPI: dp.%d\n", module); + + /* map mipi-dsi write callback func */ + dsi->write_buffer = nx_mipi_write_buffer; + + ret = nx_mipi_dsi_lcd_bind(dsi); + if (ret) { + printf("Error: bind mipi-dsi lcd driver !\n"); + return; + } + + dp_control_init(module); + dp_plane_init(module); + + mipi_init(); + + /* set plane */ + dp_plane_screen_setup(module, top); + + for (i = 0; count > i; i++, plane++) { + if (!plane->enable) + continue; + dp_plane_layer_setup(module, plane); + dp_plane_layer_enable(module, plane, 1); + } + dp_plane_screen_enable(module, 1); + + /* set mipi */ + mipi_prepare(module, input, sync, ctrl, dev); + + if (dsi->ops && dsi->ops->prepare) + dsi->ops->prepare(dsi); + + if (dsi->ops && dsi->ops->enable) + dsi->ops->enable(dsi); + + mipi_enable(module, input, sync, ctrl, dev); + + /* set dp control */ + dp_control_setup(module, sync, ctrl); + dp_control_enable(module, 1); +} diff --git a/drivers/video/nexell/s5pxx18_dp_rgb.c b/drivers/video/nexell/s5pxx18_dp_rgb.c new file mode 100644 index 0000000..44e8edb --- /dev/null +++ b/drivers/video/nexell/s5pxx18_dp_rgb.c @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + */ + +#include <config.h> +#include <common.h> +#include <errno.h> + +#include <asm/arch/display.h> + +#include "soc/s5pxx18_soc_disptop.h" + +static int rgb_switch(int module, int input, struct dp_sync_info *sync, + struct dp_rgb_dev *dev) +{ + int mpu = dev->lcd_mpu_type; + int rsc = 0, sel = 0; + + switch (module) { + case 0: + sel = mpu ? 1 : 0; + break; + case 1: + sel = rsc ? 3 : 2; + break; + default: + printf("Fail, %s nuknown module %d\n", __func__, module); + return -1; + } + + nx_disp_top_set_primary_mux(sel); + return 0; +} + +void nx_rgb_display(int module, + struct dp_sync_info *sync, struct dp_ctrl_info *ctrl, + struct dp_plane_top *top, struct dp_plane_info *planes, + struct dp_rgb_dev *dev) +{ + struct dp_plane_info *plane = planes; + int input = module == 0 ? DP_DEVICE_DP0 : DP_DEVICE_DP1; + int count = top->plane_num; + int i = 0; + + printf("RGB: dp.%d\n", module); + + dp_control_init(module); + dp_plane_init(module); + + /* set plane */ + dp_plane_screen_setup(module, top); + + for (i = 0; count > i; i++, plane++) { + if (!plane->enable) + continue; + dp_plane_layer_setup(module, plane); + dp_plane_layer_enable(module, plane, 1); + } + + dp_plane_screen_enable(module, 1); + + rgb_switch(module, input, sync, dev); + + dp_control_setup(module, sync, ctrl); + dp_control_enable(module, 1); +} diff --git a/drivers/video/nexell_display.c b/drivers/video/nexell_display.c new file mode 100644 index 0000000..4101e09 --- /dev/null +++ b/drivers/video/nexell_display.c @@ -0,0 +1,651 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Nexell Co., Ltd. + * + * Author: junghyun, kim jhkim@nexell.co.kr + * + * Copyright (C) 2020 Stefan Bosch stefan_b@posteo.net + */ + +#include <config.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <mapmem.h> +#include <malloc.h> +#include <linux/compat.h> +#include <linux/err.h> +#include <video.h> /* For struct video_uc_platdata */ +#include <video_fb.h> +#include <lcd.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/display.h> +#include <asm/arch/display_dev.h> +#include "videomodes.h" + +DECLARE_GLOBAL_DATA_PTR; + +#if !defined(CONFIG_DM) && !defined(CONFIG_OF_CONTROL) +static struct nx_display_dev *dp_dev; +#endif + +static char *const dp_dev_str[] = { + [DP_DEVICE_RESCONV] = "RESCONV", + [DP_DEVICE_RGBLCD] = "LCD", + [DP_DEVICE_HDMI] = "HDMI", + [DP_DEVICE_MIPI] = "MiPi", + [DP_DEVICE_LVDS] = "LVDS", + [DP_DEVICE_CVBS] = "TVOUT", + [DP_DEVICE_DP0] = "DP0", + [DP_DEVICE_DP1] = "DP1", +}; + +#if CONFIG_IS_ENABLED(OF_CONTROL) +static void nx_display_parse_dp_sync(ofnode node, struct dp_sync_info *sync) +{ + sync->h_active_len = ofnode_read_s32_default(node, "h_active_len", 0); + sync->h_sync_width = ofnode_read_s32_default(node, "h_sync_width", 0); + sync->h_back_porch = ofnode_read_s32_default(node, "h_back_porch", 0); + sync->h_front_porch = ofnode_read_s32_default(node, "h_front_porch", 0); + sync->h_sync_invert = ofnode_read_s32_default(node, "h_sync_invert", 0); + sync->v_active_len = ofnode_read_s32_default(node, "v_active_len", 0); + sync->v_sync_width = ofnode_read_s32_default(node, "v_sync_width", 0); + sync->v_back_porch = ofnode_read_s32_default(node, "v_back_porch", 0); + sync->v_front_porch = ofnode_read_s32_default(node, "v_front_porch", 0); + sync->v_sync_invert = ofnode_read_s32_default(node, "v_sync_invert", 0); + sync->pixel_clock_hz = ofnode_read_s32_default(node, "pixel_clock_hz", 0); + + debug("DP: sync ->\n"); + debug("ha:%d, hs:%d, hb:%d, hf:%d, hi:%d\n", + sync->h_active_len, sync->h_sync_width, + sync->h_back_porch, sync->h_front_porch, sync->h_sync_invert); + debug("va:%d, vs:%d, vb:%d, vf:%d, vi:%d\n", + sync->v_active_len, sync->v_sync_width, + sync->v_back_porch, sync->v_front_porch, sync->v_sync_invert); +} + +static void nx_display_parse_dp_ctrl(ofnode node, struct dp_ctrl_info *ctrl) +{ + /* clock gen */ + ctrl->clk_src_lv0 = ofnode_read_s32_default(node, "clk_src_lv0", 0); + ctrl->clk_div_lv0 = ofnode_read_s32_default(node, "clk_div_lv0", 0); + ctrl->clk_src_lv1 = ofnode_read_s32_default(node, "clk_src_lv1", 0); + ctrl->clk_div_lv1 = ofnode_read_s32_default(node, "clk_div_lv1", 0); + + /* scan format */ + ctrl->interlace = ofnode_read_s32_default(node, "interlace", 0); + + /* syncgen format */ + ctrl->out_format = ofnode_read_s32_default(node, "out_format", 0); + ctrl->invert_field = ofnode_read_s32_default(node, "invert_field", 0); + ctrl->swap_RB = ofnode_read_s32_default(node, "swap_RB", 0); + ctrl->yc_order = ofnode_read_s32_default(node, "yc_order", 0); + + /* extern sync delay */ + ctrl->delay_mask = ofnode_read_s32_default(node, "delay_mask", 0); + ctrl->d_rgb_pvd = ofnode_read_s32_default(node, "d_rgb_pvd", 0); + ctrl->d_hsync_cp1 = ofnode_read_s32_default(node, "d_hsync_cp1", 0); + ctrl->d_vsync_fram = ofnode_read_s32_default(node, "d_vsync_fram", 0); + ctrl->d_de_cp2 = ofnode_read_s32_default(node, "d_de_cp2", 0); + + /* extern sync delay */ + ctrl->vs_start_offset = + ofnode_read_s32_default(node, "vs_start_offset", 0); + ctrl->vs_end_offset = ofnode_read_s32_default(node, "vs_end_offset", 0); + ctrl->ev_start_offset = + ofnode_read_s32_default(node, "ev_start_offset", 0); + ctrl->ev_end_offset = ofnode_read_s32_default(node, "ev_end_offset", 0); + + /* pad clock seletor */ + ctrl->vck_select = ofnode_read_s32_default(node, "vck_select", 0); + ctrl->clk_inv_lv0 = ofnode_read_s32_default(node, "clk_inv_lv0", 0); + ctrl->clk_delay_lv0 = ofnode_read_s32_default(node, "clk_delay_lv0", 0); + ctrl->clk_inv_lv1 = ofnode_read_s32_default(node, "clk_inv_lv1", 0); + ctrl->clk_delay_lv1 = ofnode_read_s32_default(node, "clk_delay_lv1", 0); + ctrl->clk_sel_div1 = ofnode_read_s32_default(node, "clk_sel_div1", 0); + + debug("DP: ctrl [%s] ->\n", + ctrl->interlace ? "Interlace" : " Progressive"); + debug("cs0:%d, cd0:%d, cs1:%d, cd1:%d\n", + ctrl->clk_src_lv0, ctrl->clk_div_lv0, + ctrl->clk_src_lv1, ctrl->clk_div_lv1); + debug("fmt:0x%x, inv:%d, swap:%d, yb:0x%x\n", + ctrl->out_format, ctrl->invert_field, + ctrl->swap_RB, ctrl->yc_order); + debug("dm:0x%x, drp:%d, dhs:%d, dvs:%d, dde:0x%x\n", + ctrl->delay_mask, ctrl->d_rgb_pvd, + ctrl->d_hsync_cp1, ctrl->d_vsync_fram, ctrl->d_de_cp2); + debug("vss:%d, vse:%d, evs:%d, eve:%d\n", + ctrl->vs_start_offset, ctrl->vs_end_offset, + ctrl->ev_start_offset, ctrl->ev_end_offset); + debug("sel:%d, i0:%d, d0:%d, i1:%d, d1:%d, s1:%d\n", + ctrl->vck_select, ctrl->clk_inv_lv0, ctrl->clk_delay_lv0, + ctrl->clk_inv_lv1, ctrl->clk_delay_lv1, ctrl->clk_sel_div1); +} + +static void nx_display_parse_dp_top_layer(ofnode node, struct dp_plane_top *top) +{ + top->screen_width = ofnode_read_s32_default(node, "screen_width", 0); + top->screen_height = ofnode_read_s32_default(node, "screen_height", 0); + top->video_prior = ofnode_read_s32_default(node, "video_prior", 0); + top->interlace = ofnode_read_s32_default(node, "interlace", 0); + top->back_color = ofnode_read_s32_default(node, "back_color", 0); + top->plane_num = DP_PLANS_NUM; + + debug("DP: top [%s] ->\n", + top->interlace ? "Interlace" : " Progressive"); + debug("w:%d, h:%d, prior:%d, bg:0x%x\n", + top->screen_width, top->screen_height, + top->video_prior, top->back_color); +} + +static void nx_display_parse_dp_layer(ofnode node, struct dp_plane_info *plane) +{ + plane->left = ofnode_read_s32_default(node, "left", 0); + plane->width = ofnode_read_s32_default(node, "width", 0); + plane->top = ofnode_read_s32_default(node, "top", 0); + plane->height = ofnode_read_s32_default(node, "height", 0); + plane->pixel_byte = ofnode_read_s32_default(node, "pixel_byte", 0); + plane->format = ofnode_read_s32_default(node, "format", 0); + plane->alpha_on = ofnode_read_s32_default(node, "alpha_on", 0); + plane->alpha_depth = ofnode_read_s32_default(node, "alpha", 0); + plane->tp_on = ofnode_read_s32_default(node, "tp_on", 0); + plane->tp_color = ofnode_read_s32_default(node, "tp_color", 0); + + /* enable layer */ + if (plane->fb_base) + plane->enable = 1; + else + plane->enable = 0; + + if (plane->fb_base == 0) { + printf("fail : dp plane.%d invalid fb base [0x%x] ->\n", + plane->layer, plane->fb_base); + return; + } + + debug("DP: plane.%d [0x%x] ->\n", plane->layer, plane->fb_base); + debug("f:0x%x, l:%d, t:%d, %d * %d, bpp:%d, a:%d(%d), t:%d(0x%x)\n", + plane->format, plane->left, plane->top, plane->width, + plane->height, plane->pixel_byte, plane->alpha_on, + plane->alpha_depth, plane->tp_on, plane->tp_color); +} + +static void nx_display_parse_dp_planes(ofnode node, + struct nx_display_dev *dp, + struct video_uc_platdata *plat) +{ + const char *name; + ofnode subnode; + + ofnode_for_each_subnode(subnode, node) { + name = ofnode_get_name(subnode); + + if (strcmp(name, "layer_top") == 0) + nx_display_parse_dp_top_layer(subnode, &dp->top); + + /* + * TODO: Is it sure that only one layer is used? Otherwise + * fb_base must be different? + */ + if (strcmp(name, "layer_0") == 0) { + dp->planes[0].fb_base = + (uint)map_sysmem(plat->base, plat->size); + debug("%s(): dp->planes[0].fb_base == 0x%x\n", __func__, + (uint)dp->planes[0].fb_base); + nx_display_parse_dp_layer(subnode, &dp->planes[0]); + } + + if (strcmp(name, "layer_1") == 0) { + dp->planes[1].fb_base = + (uint)map_sysmem(plat->base, plat->size); + debug("%s(): dp->planes[1].fb_base == 0x%x\n", __func__, + (uint)dp->planes[1].fb_base); + nx_display_parse_dp_layer(subnode, &dp->planes[1]); + } + + if (strcmp(name, "layer_2") == 0) { + dp->planes[2].fb_base = + (uint)map_sysmem(plat->base, plat->size); + debug("%s(): dp->planes[2].fb_base == 0x%x\n", __func__, + (uint)dp->planes[2].fb_base); + nx_display_parse_dp_layer(subnode, &dp->planes[2]); + } + } +} + +static int nx_display_parse_dp_lvds(ofnode node, struct nx_display_dev *dp) +{ + struct dp_lvds_dev *dev = kzalloc(sizeof(*dev), GFP_KERNEL); + + if (!dev) { + printf("failed to allocate display LVDS object.\n"); + return -ENOMEM; + } + + dp->device = dev; + + dev->lvds_format = ofnode_read_s32_default(node, "format", 0); + dev->pol_inv_hs = ofnode_read_s32_default(node, "pol_inv_hs", 0); + dev->pol_inv_vs = ofnode_read_s32_default(node, "pol_inv_vs", 0); + dev->pol_inv_de = ofnode_read_s32_default(node, "pol_inv_de", 0); + dev->pol_inv_ck = ofnode_read_s32_default(node, "pol_inv_ck", 0); + dev->voltage_level = ofnode_read_s32_default(node, "voltage_level", 0); + + if (!dev->voltage_level) + dev->voltage_level = DEF_VOLTAGE_LEVEL; + + debug("DP: LVDS -> %s, voltage LV:0x%x\n", + dev->lvds_format == DP_LVDS_FORMAT_VESA ? "VESA" : + dev->lvds_format == DP_LVDS_FORMAT_JEIDA ? "JEIDA" : "LOC", + dev->voltage_level); + debug("pol inv hs:%d, vs:%d, de:%d, ck:%d\n", + dev->pol_inv_hs, dev->pol_inv_vs, + dev->pol_inv_de, dev->pol_inv_ck); + + return 0; +} + +static int nx_display_parse_dp_rgb(ofnode node, struct nx_display_dev *dp) +{ + struct dp_rgb_dev *dev = kzalloc(sizeof(*dev), GFP_KERNEL); + + if (!dev) { + printf("failed to allocate display RGB LCD object.\n"); + return -ENOMEM; + } + dp->device = dev; + + dev->lcd_mpu_type = ofnode_read_s32_default(node, "lcd_mpu_type", 0); + + debug("DP: RGB -> MPU[%s]\n", dev->lcd_mpu_type ? "O" : "X"); + return 0; +} + +static int nx_display_parse_dp_mipi(ofnode node, struct nx_display_dev *dp) +{ + struct dp_mipi_dev *dev = kzalloc(sizeof(*dev), GFP_KERNEL); + + if (!dev) { + printf("failed to allocate display MiPi object.\n"); + return -ENOMEM; + } + dp->device = dev; + + dev->lp_bitrate = ofnode_read_s32_default(node, "lp_bitrate", 0); + dev->hs_bitrate = ofnode_read_s32_default(node, "hs_bitrate", 0); + dev->lpm_trans = 1; + dev->command_mode = 0; + + debug("DP: MIPI ->\n"); + debug("lp:%dmhz, hs:%dmhz\n", dev->lp_bitrate, dev->hs_bitrate); + + return 0; +} + +static int nx_display_parse_dp_hdmi(ofnode node, struct nx_display_dev *dp) +{ + struct dp_hdmi_dev *dev = kzalloc(sizeof(*dev), GFP_KERNEL); + + if (!dev) { + printf("failed to allocate display HDMI object.\n"); + return -ENOMEM; + } + dp->device = dev; + + dev->preset = ofnode_read_s32_default(node, "preset", 0); + + debug("DP: HDMI -> %d\n", dev->preset); + + return 0; +} + +static int nx_display_parse_dp_lcds(ofnode node, const char *type, + struct nx_display_dev *dp) +{ + if (strcmp(type, "lvds") == 0) { + dp->dev_type = DP_DEVICE_LVDS; + return nx_display_parse_dp_lvds(node, dp); + } else if (strcmp(type, "rgb") == 0) { + dp->dev_type = DP_DEVICE_RGBLCD; + return nx_display_parse_dp_rgb(node, dp); + } else if (strcmp(type, "mipi") == 0) { + dp->dev_type = DP_DEVICE_MIPI; + return nx_display_parse_dp_mipi(node, dp); + } else if (strcmp(type, "hdmi") == 0) { + dp->dev_type = DP_DEVICE_HDMI; + return nx_display_parse_dp_hdmi(node, dp); + } + + printf("%s: node %s unknown display type\n", __func__, + ofnode_get_name(node)); + return -EINVAL; + + return 0; +} + +#define DT_SYNC (1 << 0) +#define DT_CTRL (1 << 1) +#define DT_PLANES (1 << 2) +#define DT_DEVICE (1 << 3) + +static int nx_display_parse_dt(struct udevice *dev, + struct nx_display_dev *dp, + struct video_uc_platdata *plat) +{ + const char *name, *dtype; + int ret = 0; + unsigned int dt_status = 0; + ofnode subnode; + + if (!dev) + return -ENODEV; + + dp->module = dev_read_s32_default(dev, "module", -1); + if (dp->module == -1) + dp->module = dev_read_s32_default(dev, "index", 0); + + dtype = dev_read_string(dev, "lcd-type"); + + ofnode_for_each_subnode(subnode, dev_ofnode(dev)) { + name = ofnode_get_name(subnode); + + if (strcmp("dp-sync", name) == 0) { + dt_status |= DT_SYNC; + nx_display_parse_dp_sync(subnode, &dp->sync); + } + + if (strcmp("dp-ctrl", name) == 0) { + dt_status |= DT_CTRL; + nx_display_parse_dp_ctrl(subnode, &dp->ctrl); + } + + if (strcmp("dp-planes", name) == 0) { + dt_status |= DT_PLANES; + nx_display_parse_dp_planes(subnode, dp, plat); + } + + if (strcmp("dp-device", name) == 0) { + dt_status |= DT_DEVICE; + ret = nx_display_parse_dp_lcds(subnode, dtype, dp); + } + } + + if (dt_status != (DT_SYNC | DT_CTRL | DT_PLANES | DT_DEVICE)) { + printf("Not enough DT config for display [0x%x]\n", dt_status); + return -ENODEV; + } + + return ret; +} +#endif + +__weak int nx_display_fixup_dp(struct nx_display_dev *dp) +{ + return 0; +} + +static struct nx_display_dev *nx_display_setup(void) +{ + struct nx_display_dev *dp; + int i, ret; + int node = 0; + struct video_uc_platdata *plat = NULL; + + struct udevice *dev; + + /* call driver probe */ + debug("DT: uclass device call...\n"); + + ret = uclass_get_device(UCLASS_VIDEO, 0, &dev); + if (ret) { + debug("%s(): uclass_get_device(UCLASS_VIDEO, 0, &dev) != 0 --> return NULL\n", + __func__); + return NULL; + } + plat = dev_get_uclass_platdata(dev); + if (!dev) { + debug("%s(): dev_get_uclass_platdata(dev) == NULL --> return NULL\n", + __func__); + return NULL; + } + dp = dev_get_priv(dev); + if (!dp) { + debug("%s(): dev_get_priv(dev) == NULL --> return NULL\n", + __func__); + return NULL; + } + node = dev->node.of_offset; + + if (CONFIG_IS_ENABLED(OF_CONTROL)) { + ret = nx_display_parse_dt(dev, dp, plat); + if (ret) + goto err_setup; + } + + nx_display_fixup_dp(dp); + + for (i = 0; dp->top.plane_num > i; i++) { + dp->planes[i].layer = i; + if (dp->planes[i].enable && !dp->fb_plane) { + dp->fb_plane = &dp->planes[i]; + dp->fb_addr = dp->fb_plane->fb_base; + dp->depth = dp->fb_plane->pixel_byte; + } + } + + switch (dp->dev_type) { +#ifdef CONFIG_VIDEO_NX_RGB + case DP_DEVICE_RGBLCD: + nx_rgb_display(dp->module, + &dp->sync, &dp->ctrl, &dp->top, + dp->planes, (struct dp_rgb_dev *)dp->device); + break; +#endif +#ifdef CONFIG_VIDEO_NX_LVDS + case DP_DEVICE_LVDS: + nx_lvds_display(dp->module, + &dp->sync, &dp->ctrl, &dp->top, + dp->planes, (struct dp_lvds_dev *)dp->device); + break; +#endif +#ifdef CONFIG_VIDEO_NX_MIPI + case DP_DEVICE_MIPI: + nx_mipi_display(dp->module, + &dp->sync, &dp->ctrl, &dp->top, + dp->planes, (struct dp_mipi_dev *)dp->device); + break; +#endif +#ifdef CONFIG_VIDEO_NX_HDMI + case DP_DEVICE_HDMI: + nx_hdmi_display(dp->module, + &dp->sync, &dp->ctrl, &dp->top, + dp->planes, (struct dp_hdmi_dev *)dp->device); + break; +#endif + default: + printf("fail : not support lcd type %d !!!\n", dp->dev_type); + goto err_setup; + }; + + printf("LCD: [%s] dp.%d.%d %dx%d %dbpp FB:0x%08x\n", + dp_dev_str[dp->dev_type], dp->module, dp->fb_plane->layer, + dp->fb_plane->width, dp->fb_plane->height, dp->depth * 8, + dp->fb_addr); + + return dp; + +err_setup: + kfree(dp); + + return NULL; +} + +#if defined CONFIG_LCD + +/* default lcd */ +struct vidinfo panel_info = { + .vl_col = 320, .vl_row = 240, .vl_bpix = 32, +}; + +void lcd_ctrl_init(void *lcdbase) +{ + vidinfo_t *pi = &panel_info; + struct nx_display_dev *dp; + int bpix; + + dp = nx_display_setup(); + if (!dp) + return NULL; + + switch (dp->depth) { + case 2: + bpix = LCD_COLOR16; + break; + case 3: + case 4: + bpix = LCD_COLOR32; + break; + default: + printf("fail : not support LCD bit per pixel %d\n", + dp->depth * 8); + return NULL; + } + + dp->panel_info = pi; + + /* set resolution with config */ + pi->vl_bpix = bpix; + pi->vl_col = dp->fb_plane->width; + pi->vl_row = dp->fb_plane->height; + pi->priv = dp; + gd->fb_base = dp->fb_addr; +} + +void lcd_setcolreg(ushort regno, ushort red, ushort green, ushort blue) +{ +} + +__weak void lcd_enable(void) +{ +} +#endif + +static int nx_display_probe(struct udevice *dev) +{ + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct nx_display_platdata *plat = dev_get_platdata(dev); + static GraphicDevice *graphic_device; + char addr[64]; + + debug("%s()\n", __func__); + + if (!dev) + return -EINVAL; + + if (!uc_plat) { + debug("%s(): video_uc_platdata *plat == NULL --> return -EINVAL\n", + __func__); + return -EINVAL; + } + + if (!uc_priv) { + debug("%s(): video_priv *uc_priv == NULL --> return -EINVAL\n", + __func__); + return -EINVAL; + } + + if (!plat) { + debug("%s(): nx_display_platdata *plat == NULL --> return -EINVAL\n", + __func__); + return -EINVAL; + } + + struct nx_display_dev *dp; + unsigned int pp_index = 0; + + dp = nx_display_setup(); + if (!dp) { + debug("%s(): nx_display_setup() == 0 --> return -EINVAL\n", + __func__); + return -EINVAL; + } + + switch (dp->depth) { + case 2: + pp_index = GDF_16BIT_565RGB; + uc_priv->bpix = VIDEO_BPP16; + break; + case 3: + /* There is no VIDEO_BPP24 because these values are of + * type video_log2_bpp + */ + case 4: + pp_index = GDF_32BIT_X888RGB; + uc_priv->bpix = VIDEO_BPP32; + break; + default: + printf("fail : not support LCD bit per pixel %d\n", + dp->depth * 8); + return -EINVAL; + } + + uc_priv->xsize = dp->fb_plane->width; + uc_priv->ysize = dp->fb_plane->height; + uc_priv->rot = 0; + + graphic_device = &dp->graphic_device; + graphic_device->frameAdrs = dp->fb_addr; + graphic_device->gdfIndex = pp_index; + graphic_device->gdfBytesPP = dp->depth; + graphic_device->winSizeX = dp->fb_plane->width; + graphic_device->winSizeY = dp->fb_plane->height; + graphic_device->plnSizeX = + graphic_device->winSizeX * graphic_device->gdfBytesPP; + + /* + * set environment variable "fb_addr" (frame buffer address), required + * for splash image. Because drv_video_init() in common/stdio.c is only + * called when CONFIG_VIDEO is set (and not if CONFIG_DM_VIDEO is set). + */ + sprintf(addr, "0x%x", dp->fb_addr); + debug("%s(): env_set("fb_addr", %s) ...\n", __func__, addr); + env_set("fb_addr", addr); + + return 0; +} + +static int nx_display_bind(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + + debug("%s()\n", __func__); + + /* Datasheet S5p4418: + * Resolution up to 2048 x 1280, up to 12 Bit per color (HDMI) + * Actual (max.) size is 0x1000000 because in U-Boot nanopi2-2016.01 + * "#define CONFIG_FB_ADDR 0x77000000" and next address is + * "#define BMP_LOAD_ADDR 0x78000000" + */ + plat->size = 0x1000000; + + return 0; +} + +static const struct udevice_id nx_display_ids[] = { + {.compatible = "nexell,nexell-display", }, + {} +}; + +U_BOOT_DRIVER(nexell_display) = { + .name = "nexell-display", + .id = UCLASS_VIDEO, + .of_match = nx_display_ids, + .platdata_auto_alloc_size = + sizeof(struct nx_display_platdata), + .bind = nx_display_bind, + .probe = nx_display_probe, + .priv_auto_alloc_size = sizeof(struct nx_display_dev), +};
On Fri, Jul 10, 2020 at 07:07:36PM +0200, Stefan Bosch wrote:
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01:
- nexell_display.c: Changed to DM, CONFIG_FB_ADDR can not be used anymore because framebuffer is allocated by video_reserve() in video-uclass.c. Therefore code changed appropriately.
- '#ifdef CONFIG...' changed to 'if (IS_ENABLED(CONFIG...))' where possible (and similar).
- livetree API (dev_read_...) is used instead of fdt one (fdt...).
Signed-off-by: Stefan Bosch stefan_b@posteo.net
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - SPL not supported yet --> no spl-dir in arch/arm/cpu/armv7/s5p4418/. Appropriate line in Makefile removed. - cpu.c: '#include <cpu_func.h>' added. - arch/arm/cpu/armv7/s5p4418/u-boot.lds removed, is not required anylonger. - "obj-$(CONFIG_ARCH_NEXELL) += s5p-common/" added to arch/arm/cpu/armv7/Makefile since s5p-common/pwm.c is used instead of drivers/pwm/pwm-nexell.c. - s5p4418.dtsi: '#include "../../../include/generated/autoconf.h"' removed, is not necessary, error at out-of-tree building. '#ifdef CONFIG_CPU_NXP4330'-blocks (2x) removed. Some minor changes regarding mmc. 'u-boot,dm-pre-reloc' added to dp0 because of added DM_VIDEO support. - board/s5p4418/ renamed to board/friendlyarm/ - All s5p4418-boards except nanopi2 removed because there is no possibility to test the other boards. - Kconfig: Changes to have a structure like mach-bcm283x (RaspberryPi), e.g. "config ..." entries moved from/to other Kconfig. - "CONFIG_" removed from several s5p4418/nanopi2 specific defines because the appropriate values do not need to be configurable. - nanopi2/board.c: All getenv(), getenv_ulong(), setenv() and saveenv() renamed to env_get(), env_get_ulong(), env_set() and env_save(), respectively. MACH_TYPE_S5P4418 is not defined anymore, therefore appropriate code removed (not necessary for DT-kernels). - nanopi2/onewire.c: All crc8() renamed to crc8_ow() because crc8() is already defined in lib/crc8.c (with different parameters). - dts: "nexell,s5pxx18-i2c" used instead of "i2c-gpio", i2c0 and i2c1 added. gmac-, ehci- and dwc2otg-entries removed because the appropriate functionality is not supported yet. New mmc-property "mmcboost" added. s5p4418-pinctrl.dtsi: gmac-entries removed, mmc- and i2c-entries added. - '#ifdef CONFIG...' changed to 'if (IS_ENABLED(CONFIG...))' where possible (and similar).
Signed-off-by: Stefan Bosch stefan_b@posteo.net ---
(no changes since v3)
Changes in v3: - dts: pinctrl is supported now, therefore s5p4418-pinctrl.dtsi added, mmc- and i2c-entries extended appropriately. New mmc-property "mmcboost" added. - Handling of Configs for LCD backlight control reworked because (among others) not setting CONFIG_S5P4418_ONEWIRE and/or CONFIG_PWM_NX has caused errors when compiling board/friendlyarm/nanopi2/onewire.c. - arch/arm/cpu/armv7/s5p4418/cpu.c: '#include <linux/delay.h>' inserted because it has been removed from common.h. - board/friendlyarm/nanopi2/board.c: Several includes inserted because some includes have been removed from common.h. - '#ifdef...' changed to 'if (IS_ENABLED(CONFIG...))' where possible because of appropriate warnings of patman. - Several initialisations of static variables to 0 removed because of appropriate errors of patman.
Changes in v2: - i2c: "nexell,s5pxx18-i2c"-driver is used now instead of "i2c-gpio". i2c0 and i2c1 added. I.e. dts files changed appropriately. - dts: gmac-, ehci- and dwc2otg-entries removed because the appropriate functionality is not supported yet. - s5p4418-pinctrl.dtsi removed because there is no pinctrl-driver available. - "obj-$(CONFIG_ARCH_NEXELL) += s5p-common/" added to arch/arm/cpu/armv7/Makefile since s5p-common/pwm.c is used now instead of drivers/pwm/pwm-nexell.c. - cosmetic: additional GPL license text removed, SPDX-License-Identifier is enough. Furthermore file path removed (two files).
arch/arm/cpu/armv7/Makefile | 2 + arch/arm/cpu/armv7/s5p4418/Makefile | 6 + arch/arm/cpu/armv7/s5p4418/cpu.c | 121 ++++++ arch/arm/dts/Makefile | 3 + arch/arm/dts/s5p4418-nanopi2.dts | 110 ++++++ arch/arm/dts/s5p4418-pinctrl.dtsi | 135 +++++++ arch/arm/dts/s5p4418.dtsi | 170 +++++++++ board/friendlyarm/Kconfig | 37 ++ board/friendlyarm/nanopi2/Kconfig | 12 + board/friendlyarm/nanopi2/MAINTAINERS | 7 + board/friendlyarm/nanopi2/Makefile | 7 + board/friendlyarm/nanopi2/board.c | 575 ++++++++++++++++++++++++++++ board/friendlyarm/nanopi2/hwrev.c | 108 ++++++ board/friendlyarm/nanopi2/hwrev.h | 15 + board/friendlyarm/nanopi2/lcds.c | 697 ++++++++++++++++++++++++++++++++++ board/friendlyarm/nanopi2/nxp-fb.h | 94 +++++ board/friendlyarm/nanopi2/onewire.c | 307 +++++++++++++++ board/friendlyarm/nanopi2/onewire.h | 15 + 18 files changed, 2421 insertions(+) create mode 100644 arch/arm/cpu/armv7/s5p4418/Makefile create mode 100644 arch/arm/cpu/armv7/s5p4418/cpu.c create mode 100644 arch/arm/dts/s5p4418-nanopi2.dts create mode 100644 arch/arm/dts/s5p4418-pinctrl.dtsi create mode 100644 arch/arm/dts/s5p4418.dtsi create mode 100644 board/friendlyarm/Kconfig create mode 100644 board/friendlyarm/nanopi2/Kconfig create mode 100644 board/friendlyarm/nanopi2/MAINTAINERS create mode 100644 board/friendlyarm/nanopi2/Makefile create mode 100644 board/friendlyarm/nanopi2/board.c create mode 100644 board/friendlyarm/nanopi2/hwrev.c create mode 100644 board/friendlyarm/nanopi2/hwrev.h create mode 100644 board/friendlyarm/nanopi2/lcds.c create mode 100644 board/friendlyarm/nanopi2/nxp-fb.h create mode 100644 board/friendlyarm/nanopi2/onewire.c create mode 100644 board/friendlyarm/nanopi2/onewire.h
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 8c955d0..0e83e39 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -42,3 +42,5 @@ obj-$(CONFIG_RMOBILE) += rmobile/ obj-$(if $(filter stv0991,$(SOC)),y) += stv0991/ obj-$(CONFIG_ARCH_SUNXI) += sunxi/ obj-$(CONFIG_VF610) += vf610/ +obj-$(CONFIG_ARCH_S5P4418) += s5p4418/ +obj-$(CONFIG_ARCH_NEXELL) += s5p-common/ diff --git a/arch/arm/cpu/armv7/s5p4418/Makefile b/arch/arm/cpu/armv7/s5p4418/Makefile new file mode 100644 index 0000000..321b257 --- /dev/null +++ b/arch/arm/cpu/armv7/s5p4418/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 Nexell +# Hyunseok, Jung hsjung@nexell.co.kr + +obj-y += cpu.o diff --git a/arch/arm/cpu/armv7/s5p4418/cpu.c b/arch/arm/cpu/armv7/s5p4418/cpu.c new file mode 100644 index 0000000..8add947 --- /dev/null +++ b/arch/arm/cpu/armv7/s5p4418/cpu.c @@ -0,0 +1,121 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Nexell + * Hyunseok, Jung hsjung@nexell.co.kr + */ + +#include <common.h> +#include <command.h> +#include <asm/system.h> +#include <asm/cache.h> +#include <asm/sections.h> +#include <asm/io.h> +#include <asm/arch/nexell.h> +#include <asm/arch/clk.h> +#include <asm/arch/reset.h> +#include <asm/arch/tieoff.h> +#include <cpu_func.h> +#include <linux/delay.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_ARCH_CPU_INIT +#error must be define the macro "CONFIG_ARCH_CPU_INIT" +#endif + +void s_init(void) +{ +} + +static void cpu_soc_init(void) +{ + /* + * NOTE> ALIVE Power Gate must enable for Alive register access. + * must be clear wfi jump address + */ + writel(1, ALIVEPWRGATEREG); + writel(0xFFFFFFFF, SCR_ARM_SECOND_BOOT); + + /* write 0xf0 on alive scratchpad reg for boot success check */ + writel(readl(SCR_SIGNAGURE_READ) | 0xF0, (SCR_SIGNAGURE_SET)); + + /* set l2 cache tieoff */ + nx_tieoff_set(NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2RET1N_0, 1); + nx_tieoff_set(NX_TIEOFF_CORTEXA9MP_TOP_QUADL2C_L2RET1N_1, 1); +} + +#ifdef CONFIG_PL011_SERIAL +static void serial_device_init(void) +{ + char dev[10]; + int id; + + sprintf(dev, "nx-uart.%d", CONFIG_CONS_INDEX); + id = RESET_ID_UART0 + CONFIG_CONS_INDEX; + + struct clk *clk = clk_get((const char *)dev); + + /* reset control: Low active ___|--- */ + nx_rstcon_setrst(id, RSTCON_ASSERT); + udelay(10); + nx_rstcon_setrst(id, RSTCON_NEGATE); + udelay(10); + + /* set clock */ + clk_disable(clk); + clk_set_rate(clk, CONFIG_PL011_CLOCK); + clk_enable(clk); +} +#endif + +int arch_cpu_init(void) +{ + flush_dcache_all(); + cpu_soc_init(); + clk_init(); + + if (IS_ENABLED(CONFIG_PL011_SERIAL)) + serial_device_init(); + + return 0; +} + +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + return 0; +} +#endif + +void reset_cpu(ulong ignored) +{ + void *clkpwr_reg = (void *)PHY_BASEADDR_CLKPWR; + const u32 sw_rst_enb_bitpos = 3; + const u32 sw_rst_enb_mask = 1 << sw_rst_enb_bitpos; + const u32 sw_rst_bitpos = 12; + const u32 sw_rst_mask = 1 << sw_rst_bitpos; + int pwrcont = 0x224; + int pwrmode = 0x228; + u32 read_value; + + read_value = readl((void *)(clkpwr_reg + pwrcont)); + + read_value &= ~sw_rst_enb_mask; + read_value |= 1 << sw_rst_enb_bitpos; + + writel(read_value, (void *)(clkpwr_reg + pwrcont)); + writel(sw_rst_mask, (void *)(clkpwr_reg + pwrmode)); +} + +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} + +#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{ + return 0; +} +#endif /* CONFIG_ARCH_MISC_INIT */ diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9900b44..fbabcc0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -142,6 +142,9 @@ dtb-$(CONFIG_ROCKCHIP_RV1108) += \ rv1108-elgin-r1.dtb \ rv1108-evb.dtb
+dtb-$(CONFIG_ARCH_S5P4418) += \ + s5p4418-nanopi2.dtb + dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-nanopi-k2.dtb \ meson-gxbb-odroidc2.dtb \ diff --git a/arch/arm/dts/s5p4418-nanopi2.dts b/arch/arm/dts/s5p4418-nanopi2.dts new file mode 100644 index 0000000..4deaf10 --- /dev/null +++ b/arch/arm/dts/s5p4418-nanopi2.dts @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2020 Stefan Bosch stefan_b@posteo.net + * + * (C) Copyright 2017 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * (C) Copyright 2016 Nexell + * Youngbok, Park park@nexell.co.kr + */ + +/dts-v1/; +#include "s5p4418.dtsi" + +/ { + model = "FriendlyElec boards based on Nexell s5p4418"; + cpu-model = "S5p4418"; + + compatible = "friendlyelec,nanopi2", + "nexell,s5p4418"; + + aliases { + mmc0 = "/mmc@c0069000"; + mmc1 = "/mmc@c0062000"; + i2c0 = "/i2c@c00a4000"; + i2c1 = "/i2c@c00a5000"; + i2c2 = "/i2c@c00a6000"; + }; + + mmc0:mmc@c0062000 { + frequency = <50000000>; + drive_dly = <0x0>; + drive_shift = <0x03>; + sample_dly = <0x00>; + sample_shift = <0x02>; + mmcboost = <0>; + status = "okay"; + }; + + mmc2:mmc@c0069000 { + frequency = <50000000>; + drive_dly = <0x0>; + drive_shift = <0x03>; + sample_dly = <0x00>; + sample_shift = <0x02>; + mmcboost = <0>; + status = "okay"; + }; + + /* NanoPi2: Header "CON2", NanoPC-T2: EEPROM (MAC-Addr.) and Audio */ + i2c0:i2c@c00a4000 { + status ="okay"; + }; + + /* NanoPi2: Header "CON2" and HDMI, NanoPC-T2: HDMI */ + i2c1:i2c@c00a5000 { + status ="okay"; + }; + + /* NanoPi2: LCD interface, NanoPC-T2: LCD, LVDS and MIPI interfaces */ + i2c2:i2c@c00a6000 { + status ="okay"; + }; + + dp0:dp@c0102800 { + status = "okay"; + module = <0>; + lcd-type = "lvds"; + + dp-device { + format = <0>; /* 0:VESA, 1:JEIDA */ + }; + + dp-sync { + h_active_len = <1024>; + h_front_porch = <84>; + h_back_porch = <84>; + h_sync_width = <88>; + h_sync_invert = <0>; + v_active_len = <600>; + v_front_porch = <10>; + v_back_porch = <10>; + v_sync_width = <20>; + v_sync_invert = <0>; + }; + + dp-ctrl { + clk_src_lv0 = <3>; + clk_div_lv0 = <16>; + clk_src_lv1 = <7>; + clk_div_lv1 = <1>; + out_format = <2>; + }; + + dp-planes { + layer_top { + screen_width = <1024>; + screen_height = <600>; + back_color = <0x0>; + }; + + layer_1 { /* RGB 1 */ + width = <1024>; + height = <600>; + format = <0x06530000>; + pixel_byte = <4>; + }; + }; + }; +}; diff --git a/arch/arm/dts/s5p4418-pinctrl.dtsi b/arch/arm/dts/s5p4418-pinctrl.dtsi new file mode 100644 index 0000000..a7e1c2c --- /dev/null +++ b/arch/arm/dts/s5p4418-pinctrl.dtsi @@ -0,0 +1,135 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Nexell's s5p6818 SoC pin-mux and pin-config device tree source + * + * (C) Copyright 2020 Stefan Bosch stefan_b@posteo.net + * + * Copyright (C) 2016 Nexell Co., Ltd. + * http://www.nexell.co.kr + * + * Nexell's s5p6818 SoC pin-mux and pin-config options are listed as + * device tree nodes in this file. + */ + +pinctrl@C0010000 { + /* + * values for "pin-pull": + * pulldown resistor = 0 + * pullup = 1 + * no pullup/down = 2 + */ + + /* MMC */ + mmc0_clk: mmc0-clk { + pins = "gpioa-29"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <2>; + }; + + mmc0_cmd: mmc0-cmd { + pins = "gpioa-31"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <1>; + }; + + mmc0_bus4: mmc0-bus-width4 { + pins = "gpiob-1, gpiob-3, gpiob-5, gpiob-7"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <1>; + }; + + mmc1_clk: mmc1-clk { + pins = "gpiod-22"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <2>; + }; + + mmc1_cmd: mmc1-cmd { + pins = "gpiod-23"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <1>; + }; + + mmc1_bus4: mmc1-bus-width4 { + pins = "gpiod-24, gpiod-25, gpiod-26, gpiod-27"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <1>; + }; + + mmc2_clk: mmc2-clk { + pins = "gpioc-18"; + pin-function = <2>; + pin-pull = <2>; + pin-strength = <2>; + }; + + mmc2_cmd: mmc2-cmd { + pins = "gpioc-19"; + pin-function = <2>; + pin-pull = <2>; + pin-strength = <1>; + }; + + mmc2_bus4: mmc2-bus-width4 { + pins = "gpioc-20, gpioc-21, gpioc-22, gpioc-23"; + pin-function = <2>; + pin-pull = <2>; + pin-strength = <1>; + }; + + mmc2_bus8: mmc2-bus-width8 { + nexell,pins = "gpioe-21", "gpioe-22", "gpioe-23", "gpioe-24"; + pin-function = <2>; + pin-pull = <2>; + pin-strength = <1>; + }; + + /* I2C */ + i2c0_sda:i2c0-sda { + pins = "gpiod-3"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <0>; + }; + + i2c0_scl:i2c0-scl { + pins = "gpiod-2"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <0>; + }; + + i2c1_sda:i2c1-sda { + pins = "gpiod-5"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <0>; + }; + + i2c1_scl:i2c1-scl { + pins = "gpiod-4"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <0>; + }; + + i2c2_sda:i2c2-sda { + pins = "gpiod-7"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <0>; + }; + + i2c2_scl:i2c2-scl { + pins = "gpiod-6"; + pin-function = <1>; + pin-pull = <2>; + pin-strength = <0>; + }; +}; diff --git a/arch/arm/dts/s5p4418.dtsi b/arch/arm/dts/s5p4418.dtsi new file mode 100644 index 0000000..a4d1a1b --- /dev/null +++ b/arch/arm/dts/s5p4418.dtsi @@ -0,0 +1,170 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2020 Stefan Bosch stefan_b@posteo.net + * + * (C) Copyright 2016 Nexell + * Youngbok, Park park@nexell.co.kr + * + */ + +#include "skeleton.dtsi" + +/ { + #include "s5p4418-pinctrl.dtsi" + + aliases { + mmc0 = &mmc0; + mmc1 = &mmc1; + mmc2 = &mmc2; + gmac = "/ethernet@c0060000"; + }; + + mmc2:mmc@c0069000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nexell,nexell-dwmmc"; + reg = <0xc0069000 0x1000>; + bus-width = <4>; + index = <2>; + max-frequency = <50000000>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_clk>, <&mmc2_cmd>, <&mmc2_bus4>; + status = "disabled"; + }; + + mmc1:mmc@c0068000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nexell,nexell-dwmmc"; + reg = <0xc0068000 0x1000>; + bus-width = <4>; + index = <1>; + max-frequency = <50000000>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_clk>, <&mmc1_cmd>, <&mmc1_bus4>; + status = "disabled"; + }; + + mmc0:mmc@c0062000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nexell,nexell-dwmmc"; + reg = <0xc0062000 0x1000>; + bus-width = <4>; + index = <0>; + max-frequency = <50000000>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_clk>, <&mmc0_cmd>, <&mmc0_bus4>; + status = "disabled"; + }; + + i2c0:i2c@c00a4000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nexell,s5pxx18-i2c"; + reg = <0xc00a4000 0x100>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_sda>, <&i2c0_scl>; + status ="disabled"; + }; + + i2c1:i2c@c00a5000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nexell,s5pxx18-i2c"; + reg = <0xc00a5000 0x100>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_sda>, <&i2c1_scl>; + status ="disabled"; + }; + + i2c2:i2c@c00a6000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nexell,s5pxx18-i2c"; + reg = <0xc00a6000 0x100>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_sda>, <&i2c2_scl>; + status ="disabled"; + }; + + dp0:dp@c0102800 { + compatible = "nexell,nexell-display"; + reg = <0xc0102800 0x100>; + index = <0>; + u-boot,dm-pre-reloc; + status = "disabled"; + }; + + dp1:dp@c0102c00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nexell,nexell-display"; + reg = <0xc0102c00 0x100>; + index = <1>; + status = "disabled"; + }; + + gpio_a:gpio@c001a000 { + compatible = "nexell,nexell-gpio"; + reg = <0xc001a000 0x00000010>; + altr,gpio-bank-width = <32>; + gpio-bank-name = "gpio_a"; + gpio-controller; + #gpio-cells = <2>; + }; + + gpio_b:gpio@c001b000 { + compatible = "nexell,nexell-gpio"; + reg = <0xc001b000 0x00000010>; + altr,gpio-bank-width = <32>; + gpio-bank-name = "gpio_b"; + gpio-controller; + #gpio-cells = <2>; + }; + + gpio_c:gpio@c001c000 { + compatible = "nexell,nexell-gpio"; + reg = <0xc001c000 0x00000010>; + nexell,gpio-bank-width = <32>; + gpio-bank-name = "gpio_c"; + gpio-controller; + #gpio-cells = <2>; + }; + + gpio_d:gpio@c001d000 { + compatible = "nexell,nexell-gpio"; + reg = <0xc001d000 0x00000010>; + nexell,gpio-bank-width = <32>; + gpio-bank-name = "gpio_d"; + gpio-controller; + #gpio-cells = <2>; + }; + + gpio_e:gpio@c001e000 { + compatible = "nexell,nexell-gpio"; + reg = <0xc001e000 0x00000010>; + nexell,gpio-bank-width = <32>; + gpio-bank-name = "gpio_e"; + gpio-controller; + #gpio-cells = <2>; + }; + + gpio_alv:gpio@c0010800 { + compatible = "nexell,nexell-gpio"; + reg = <0xc0010800 0x00000010>; + nexell,gpio-bank-width = <32>; + gpio-bank-name = "gpio_alv"; + gpio-controller; + #gpio-cells = <2>; + }; + + pinctrl@C0010000 { + compatible = "nexell,s5pxx18-pinctrl"; + reg = <0xc0010000 0xf000>; + u-boot,dm-pre-reloc; + }; +}; diff --git a/board/friendlyarm/Kconfig b/board/friendlyarm/Kconfig new file mode 100644 index 0000000..f8f9cfd --- /dev/null +++ b/board/friendlyarm/Kconfig @@ -0,0 +1,37 @@ +choice + prompt "LCD backlight control" + optional + default S5P4418_ONEWIRE + +config S5P4418_ONEWIRE + bool "I2C / 1-Wire" + help + This enables LCD-Backlight control for FriendlyARM LCD-panels. + I2C is used if available, otherwise 1-Wire is used. + +config PWM_NX + bool "PWM" + help + This enables LCD-Backlight control via PWM. +endchoice + +config ROOT_DEV + int "ROOT_DEV" + help + Environment variable rootdev is set to this value if env. var. firstboot + does not exist. Otherwise rootdev is set to the MMC boot device. rootdev + determines (together with env. var. bootpart) where the OS (linux) is + booted from. + +config BOOT_PART + int "BOOT_PART" + help + Environment variable bootpart is set to this value. bootpart determines + (together with env. var. rootdev) where the OS (linux) is booted from. + +config ROOT_PART + int "ROOT_PART" + help + Environment variable rootpart is set to this value. + +source "board/friendlyarm/nanopi2/Kconfig" diff --git a/board/friendlyarm/nanopi2/Kconfig b/board/friendlyarm/nanopi2/Kconfig new file mode 100644 index 0000000..0f68422 --- /dev/null +++ b/board/friendlyarm/nanopi2/Kconfig @@ -0,0 +1,12 @@ +if TARGET_NANOPI2 + +config SYS_BOARD + default "nanopi2" + +config SYS_VENDOR + default "friendlyarm" + +config SYS_CONFIG_NAME + default "s5p4418_nanopi2" + +endif diff --git a/board/friendlyarm/nanopi2/MAINTAINERS b/board/friendlyarm/nanopi2/MAINTAINERS new file mode 100644 index 0000000..c8e2ce7 --- /dev/null +++ b/board/friendlyarm/nanopi2/MAINTAINERS @@ -0,0 +1,7 @@ +NANOPI2 BOARD +NANOPC-T2 BOARD +M: Stefan Bosch stefan_b@posteo.net +S: Maintained +F: board/s5p4418/nanopi2/ +F: include/configs/s5p4418_nanopi2.h +F: configs/s5p4418_nanopi2_defconfig diff --git a/board/friendlyarm/nanopi2/Makefile b/board/friendlyarm/nanopi2/Makefile new file mode 100644 index 0000000..5c8b3b7 --- /dev/null +++ b/board/friendlyarm/nanopi2/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 Nexell +# Hyunseok, Jung hsjung@nexell.co.kr + +obj-y := board.o hwrev.o lcds.o +obj-$(CONFIG_S5P4418_ONEWIRE) += onewire.o diff --git a/board/friendlyarm/nanopi2/board.c b/board/friendlyarm/nanopi2/board.c new file mode 100644 index 0000000..4710f7e --- /dev/null +++ b/board/friendlyarm/nanopi2/board.c @@ -0,0 +1,575 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) Guangzhou FriendlyARM Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + */ + +#include <config.h> +#include <common.h> +#include <command.h> +#include <fdt_support.h> +#include <log.h> +#ifdef CONFIG_PWM_NX +#include <pwm.h> +#endif +#include <asm/io.h> + +#include <asm/arch/nexell.h> +#include <asm/arch/nx_gpio.h> +#include <asm/arch/display.h> +#include <asm/arch/display_dev.h> + +#include <u-boot/md5.h> + +#include <linux/stringify.h> + +#include "hwrev.h" +#include "onewire.h" +#include "nxp-fb.h" + +#include <env_internal.h> /* for env_save() */ +#include <asm/mach-types.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum gpio_group { + gpio_a, gpio_b, gpio_c, gpio_d, gpio_e, +}; + +#ifdef CONFIG_PWM_NX +struct pwm_device { + int grp; + int bit; + int io_fn; +}; + +static inline void bd_pwm_config_gpio(int ch) +{ + struct pwm_device pwm_dev[] = { + [0] = { .grp = gpio_d, .bit = 1, .io_fn = 0 }, + [1] = { .grp = gpio_c, .bit = 13, .io_fn = 1 }, + [2] = { .grp = gpio_c, .bit = 14, .io_fn = 1 }, + [3] = { .grp = gpio_d, .bit = 0, .io_fn = 0 }, + }; + + int gp = pwm_dev[ch].grp; + int io = pwm_dev[ch].bit; + + /* pwm backlight OFF: HIGH, ON: LOW */ + nx_gpio_set_pad_function(gp, io, pwm_dev[ch].io_fn); + nx_gpio_set_output_value(gp, io, 1); + nx_gpio_set_output_enable(gp, io, 1); +} +#endif + +static void bd_backlight_off(void) +{ +#ifdef CONFIG_S5P4418_ONEWIRE + onewire_set_backlight(0); + +#elif defined(BACKLIGHT_CH) + bd_pwm_config_gpio(BACKLIGHT_CH); +#endif +} + +static void bd_backlight_on(void) +{ +#ifdef CONFIG_S5P4418_ONEWIRE + onewire_set_backlight(127); + +#elif defined(BACKLIGHT_CH) + /* pwm backlight ON: HIGH, ON: LOW */ + pwm_init(BACKLIGHT_CH, + BACKLIGHT_DIV, BACKLIGHT_INV); + pwm_config(BACKLIGHT_CH, + TO_DUTY_NS(BACKLIGHT_DUTY, BACKLIGHT_HZ), + TO_PERIOD_NS(BACKLIGHT_HZ)); +#endif +} + +static void bd_lcd_config_gpio(void) +{ + int i; + + for (i = 0; i < 28; i++) { + nx_gpio_set_pad_function(gpio_a, i, 1); + nx_gpio_set_drive_strength(gpio_a, i, 0); + nx_gpio_set_pull_mode(gpio_a, i, 2); + } + + nx_gpio_set_drive_strength(gpio_a, 0, 1); +} + +/* DEFAULT mmc dev for eMMC boot (dwmmc.2) */ +static int mmc_boot_dev; + +int board_mmc_bootdev(void) +{ + return mmc_boot_dev; +} + +/* call from common/env_mmc.c */ +int mmc_get_env_dev(void) +{ + return mmc_boot_dev; +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + printf("Board: %s\n", get_board_name()); + + return 0; +} +#endif + +int nx_display_fixup_dp(struct nx_display_dev *dp) +{ + struct nxp_lcd *lcd = bd_get_lcd(); + enum lcd_format fmt = bd_get_lcd_format(); + struct nxp_lcd_timing *timing = &lcd->timing; + struct dp_sync_info *sync = &dp->sync; + struct dp_plane_info *plane = &dp->planes[0]; + int i; + u32 clk = 800000000; + u32 div; + + sync->h_active_len = lcd->width; + sync->h_sync_width = timing->h_sw; + sync->h_back_porch = timing->h_bp; + sync->h_front_porch = timing->h_fp; + sync->h_sync_invert = !lcd->polarity.inv_hsync; + + sync->v_active_len = lcd->height; + sync->v_sync_width = timing->v_sw; + sync->v_back_porch = timing->v_bp; + sync->v_front_porch = timing->v_fp; + sync->v_sync_invert = !lcd->polarity.inv_vsync; + + /* calculates pixel clock */ + div = timing->h_sw + timing->h_bp + timing->h_fp + lcd->width; + div *= timing->v_sw + timing->v_bp + timing->v_fp + lcd->height; + div *= lcd->freq ? : 60; + clk /= div; + + dp->ctrl.clk_div_lv0 = clk; + dp->ctrl.clk_inv_lv0 = lcd->polarity.rise_vclk; + + dp->top.screen_width = lcd->width; + dp->top.screen_height = lcd->height; + + for (i = 0; i < dp->top.plane_num; i++, plane++) { + if (plane->enable) { + plane->width = lcd->width; + plane->height = lcd->height; + } + } + + /* initialize display device type */ + if (fmt == LCD_RGB) { + dp->dev_type = DP_DEVICE_RGBLCD; + + } else if (fmt == LCD_HDMI) { + struct dp_hdmi_dev *dev = (struct dp_hdmi_dev *)dp->device; + + dp->dev_type = DP_DEVICE_HDMI; + if (lcd->width == 1920 && lcd->height == 1080) + dev->preset = 1; + else + dev->preset = 0; + + } else { + struct dp_lvds_dev *dev = (struct dp_lvds_dev *)dp->device; + + dp->dev_type = DP_DEVICE_LVDS; + dev->lvds_format = (fmt & 0x3); + } + + return 0; +} + +/* -------------------------------------------------------------------------- + * initialize board status. + */ + +#define MMC_BOOT_CH0 (0) +#define MMC_BOOT_CH1 (1 << 3) +#define MMC_BOOT_CH2 (1 << 19) + +static void bd_bootdev_init(void) +{ + unsigned int rst = readl(PHY_BASEADDR_CLKPWR + SYSRSTCONFIG); + + rst &= (1 << 19) | (1 << 3); + if (rst == MMC_BOOT_CH0) { + /* mmc dev 1 for SD boot */ + mmc_boot_dev = 1; + } +} + +#ifdef CONFIG_S5P4418_ONEWIRE +static void bd_onewire_init(void) +{ + unsigned char lcd; + unsigned short fw_ver; + + onewire_init(); + onewire_get_info(&lcd, &fw_ver); +} +#endif + +static void bd_lcd_init(void) +{ + struct nxp_lcd *cfg; + int id = -1; + int ret; + +#ifdef CONFIG_S5P4418_ONEWIRE + id = onewire_get_lcd_id(); + /* -1: onwire probe failed + * 0: bad + * >0: identified + */ +#endif + ret = bd_setup_lcd_by_id(id); + if (id <= 0 || ret != id) { + printf("Panel: N/A (%d)\n", id); + bd_setup_lcd_by_name("HDMI720P60"); + + } else { + printf("Panel: %s\n", bd_get_lcd_name()); + + cfg = bd_get_lcd(); + if (cfg->gpio_init) + cfg->gpio_init(); + } +} + +static int mac_read_from_generic_eeprom(u8 *addr) +{ + return -1; +} + +static void make_ether_addr(u8 *addr) +{ + u32 hash[20]; + +#define ETHER_MAC_TAG "ethmac" + memset(hash, 0, sizeof(hash)); + memcpy(hash + 12, ETHER_MAC_TAG, sizeof(ETHER_MAC_TAG)); + + hash[4] = readl(PHY_BASEADDR_ECID + 0x00); + hash[5] = readl(PHY_BASEADDR_ECID + 0x04); + hash[6] = readl(PHY_BASEADDR_ECID + 0x08); + hash[7] = readl(PHY_BASEADDR_ECID + 0x0c); + + md5((unsigned char *)&hash[4], 64, (unsigned char *)hash); + + hash[0] ^= hash[2]; + hash[1] ^= hash[3]; + + memcpy(addr, (char *)hash, 6); + addr[0] &= 0xfe; /* clear multicast bit */ + addr[0] |= 0x02; +} + +static void set_ether_addr(void) +{ + unsigned char mac[6]; + char ethaddr[20]; + int ret; + + if (env_get("ethaddr")) + return; + + ret = mac_read_from_generic_eeprom(mac); + if (ret < 0) + make_ether_addr(mac); + + sprintf(ethaddr, "%02x:%02x:%02x:%02x:%02x:%02x", + mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]); + if (!ret) + printf("MAC: [%s]\n", ethaddr); + + env_set("ethaddr", ethaddr); +} + +#ifdef CONFIG_REVISION_TAG +static void set_board_rev(void) +{ + char info[64] = {0, }; + + snprintf(info, ARRAY_SIZE(info), "%02x", get_board_rev()); + env_set("board_rev", info); +} +#endif + +static void set_dtb_name(void) +{ + char info[64] = {0, }; + + snprintf(info, ARRAY_SIZE(info), + "s5p4418-nanopi2-rev%02x.dtb", get_board_rev()); + env_set("dtb_name", info); +} + +static void bd_update_env(void) +{ + char *lcdtype = env_get("lcdtype"); + char *lcddpi = env_get("lcddpi"); + char *bootargs = env_get("bootargs"); + const char *name; + char *p = NULL; + int rootdev = board_mmc_bootdev(); + int need_save = 0; + +#define CMDLINE_LCD " lcd=" + char cmdline[CONFIG_SYS_CBSIZE]; + int n = 1; + + if (rootdev != CONFIG_ROOT_DEV && !env_get("firstboot")) { + env_set_ulong("rootdev", rootdev); + env_set("firstboot", "0"); + need_save = 1; + } + + if (lcdtype) { + /* Setup again as user specified LCD in env */ + bd_setup_lcd_by_name(lcdtype); + } + + name = bd_get_lcd_name(); + + if (bootargs) + n = strlen(bootargs); /* isn't 0 for NULL */ + else + cmdline[0] = '\0'; + + if ((n + strlen(name) + sizeof(CMDLINE_LCD)) > sizeof(cmdline)) { + printf("Error: `bootargs' is too large (%d)\n", n); + goto __exit; + } + + if (bootargs) { + p = strstr(bootargs, CMDLINE_LCD); + if (p) { + n = (p - bootargs); + p += strlen(CMDLINE_LCD); + } + strncpy(cmdline, bootargs, n); + } + + /* add `lcd=NAME,NUMdpi' */ + strncpy(cmdline + n, CMDLINE_LCD, strlen(CMDLINE_LCD)); + n += strlen(CMDLINE_LCD); + + strcpy(cmdline + n, name); + n += strlen(name); + + if (lcddpi) { + n += sprintf(cmdline + n, ",%sdpi", lcddpi); + } else { + int dpi = bd_get_lcd_density(); + + if (dpi > 0 && dpi < 600) + n += sprintf(cmdline + n, ",%ddpi", dpi); + } + + /* copy remaining of bootargs */ + if (p) { + p = strstr(p, " "); + if (p) { + strcpy(cmdline + n, p); + n += strlen(p); + } + } + + /* append `bootdev=2' */ +#define CMDLINE_BDEV " bootdev=" + if (rootdev > 0 && !strstr(cmdline, CMDLINE_BDEV)) + n += sprintf(cmdline + n, "%s2", CMDLINE_BDEV); + + /* finally, let's update uboot env & save it */ + if (bootargs && strncmp(cmdline, bootargs, sizeof(cmdline))) { + env_set("bootargs", cmdline); + need_save = 1; + } + +__exit: + if (need_save) + env_save(); +} + +/* -------------------------------------------------------------------------- + * call from u-boot + */ + +int board_early_init_f(void) +{ + return 0; +} + +int board_init(void) +{ + bd_hwrev_init(); + bd_base_rev_init(); + + bd_bootdev_init(); +#ifdef CONFIG_S5P4418_ONEWIRE + bd_onewire_init(); +#endif + + bd_backlight_off(); + + bd_lcd_config_gpio(); + bd_lcd_init(); + + if (IS_ENABLED(CONFIG_SILENT_CONSOLE)) + gd->flags |= GD_FLG_SILENT; + + return 0; +} + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + bd_update_env(); + +#ifdef CONFIG_REVISION_TAG + set_board_rev(); +#endif + set_dtb_name(); + + set_ether_addr(); + + if (IS_ENABLED(CONFIG_SILENT_CONSOLE)) + gd->flags &= ~GD_FLG_SILENT; + + bd_backlight_on(); + printf("\n"); + + return 0; +} +#endif + +#ifdef CONFIG_SPLASH_SOURCE +#include <splash.h> +static struct splash_location splash_locations[] = { + { + .name = "mmc_fs", + .storage = SPLASH_STORAGE_MMC, + .flags = SPLASH_STORAGE_FS, + .devpart = __stringify(CONFIG_ROOT_DEV) ":" + __stringify(CONFIG_BOOT_PART), + }, +}; + +int splash_screen_prepare(void) +{ + int err; + char *env_cmd = env_get("load_splash"); + + debug("%s()\n", __func__); + + if (env_cmd) { + err = run_command(env_cmd, 0); + + } else { + char devpart[64] = { 0, }; + int bootpart = env_get_ulong("bootpart", 0, CONFIG_BOOT_PART); + int rootdev; + + if (env_get("firstboot")) + rootdev = env_get_ulong("rootdev", 0, CONFIG_ROOT_DEV); + else + rootdev = board_mmc_bootdev(); + + snprintf(devpart, ARRAY_SIZE(devpart), "%d:%d", rootdev, + bootpart); + splash_locations[0].devpart = devpart; + + err = splash_source_load(splash_locations, + ARRAY_SIZE(splash_locations)); + } + + if (!err) { + char addr[64]; + + sprintf(addr, "0x%lx", gd->fb_base); + env_set("fb_addr", addr); + } + + return err; +} +#endif + +/* u-boot dram initialize */ +int dram_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + return 0; +} + +/* u-boot dram board specific */ +int dram_init_banksize(void) +{ +#define SCR_USER_SIG6_READ (SCR_ALIVE_BASE + 0x0F0) + unsigned int reg_val = readl(SCR_USER_SIG6_READ); + + /* set global data memory */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x00000100; + + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = CONFIG_SYS_SDRAM_SIZE; + + /* Number of Row: 14 bits */ + if ((reg_val >> 28) == 14) + gd->bd->bi_dram[0].size -= 0x20000000; + + /* Number of Memory Chips */ + if ((reg_val & 0x3) > 1) { + gd->bd->bi_dram[1].start = 0x80000000; + gd->bd->bi_dram[1].size = 0x40000000; + } + return 0; +} + +#if defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + int nodeoff; + unsigned int rootdev; + unsigned int fb_addr; + + if (board_mmc_bootdev() > 0) { + rootdev = fdt_getprop_u32_default(blob, "/board", "sdidx", 2); + if (rootdev) { + /* find or create "/chosen" node. */ + nodeoff = fdt_find_or_add_subnode(blob, 0, "chosen"); + if (nodeoff >= 0) + fdt_setprop_u32(blob, nodeoff, "linux,rootdev", + rootdev); + } + } + + fb_addr = env_get_ulong("fb_addr", 0, 0); + if (fb_addr) { + nodeoff = fdt_path_offset(blob, "/reserved-memory"); + if (nodeoff < 0) + return nodeoff; + + nodeoff = fdt_add_subnode(blob, nodeoff, "display_reserved"); + if (nodeoff >= 0) { + fdt32_t cells[2]; + + cells[0] = cpu_to_fdt32(fb_addr); + cells[1] = cpu_to_fdt32(0x800000); + + fdt_setprop(blob, nodeoff, "reg", cells, + sizeof(cells[0]) * 2); + } + } + + return 0; +} +#endif diff --git a/board/friendlyarm/nanopi2/hwrev.c b/board/friendlyarm/nanopi2/hwrev.c new file mode 100644 index 0000000..b1e23a4 --- /dev/null +++ b/board/friendlyarm/nanopi2/hwrev.c @@ -0,0 +1,108 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) Guangzhou FriendlyARM Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + */ + +#include <config.h> +#include <common.h> +#include <i2c.h> +#include <asm/io.h> + +#include <asm/arch/nexell.h> +#include <asm/arch/nx_gpio.h> + +/* Board revision list: <PCB3 | PCB2 | PCB1> + * 0b000 - NanoPi 2 + * 0b001 - NanoPC-T2 + * 0b010 - NanoPi S2 + * 0b011 - Smart4418 + * 0b100 - NanoPi Fire 2A + * 0b111 - NanoPi M2A + * + * Extented revision: + * 0b001 - Smart4418-SDK + */ +#define __IO_GRP 2 /* GPIO_C */ +#define __IO_PCB1 26 +#define __IO_PCB2 27 +#define __IO_PCB3 25 + +static int pcb_rev = -1; +static int base_rev; + +static void bd_hwrev_config_gpio(void) +{ + int gpios[3][2] = { + { __IO_PCB1, 1 }, + { __IO_PCB2, 1 }, + { __IO_PCB3, 1 }, + }; + int i; + + /* gpio input mode, pull-down */ + for (i = 0; i < 3; i++) { + nx_gpio_set_pad_function(__IO_GRP, gpios[i][0], gpios[i][1]); + nx_gpio_set_output_enable(__IO_GRP, gpios[i][0], 0); + nx_gpio_set_pull_mode(__IO_GRP, gpios[i][0], 0); + } +} + +void bd_hwrev_init(void) +{ + if (pcb_rev >= 0) + return; + + bd_hwrev_config_gpio(); + + pcb_rev = nx_gpio_get_input_value(__IO_GRP, __IO_PCB1); + pcb_rev |= nx_gpio_get_input_value(__IO_GRP, __IO_PCB2) << 1; + pcb_rev |= nx_gpio_get_input_value(__IO_GRP, __IO_PCB3) << 2; +} + +/* Get extended revision for SmartXX18 */ +void bd_base_rev_init(void) +{ + struct udevice *dev; + u8 val = 0; + + if (pcb_rev != 0x3) + return; + +#define PCA9536_I2C_BUS 2 +#define PCA9636_I2C_ADDR 0x41 + if (i2c_get_chip_for_busnum + (PCA9536_I2C_BUS, PCA9636_I2C_ADDR, 1, &dev)) + return; + + if (!dm_i2c_read(dev, 0, &val, 1)) + base_rev = (val & 0xf); +} + +/* To override __weak symbols */ +u32 get_board_rev(void) +{ + return (base_rev << 8) | pcb_rev; +} + +const char *get_board_name(void) +{ + bd_hwrev_init(); + + switch (pcb_rev) { + case 0: + return "NanoPi 2"; + case 1: + return "NanoPC-T2"; + case 2: + return "NanoPi S2"; + case 3: + return "Smart4418"; + case 4: + return "NanoPi Fire 2A"; + case 7: + return "NanoPi M2A"; + default: + return "s5p4418-X"; + } +} diff --git a/board/friendlyarm/nanopi2/hwrev.h b/board/friendlyarm/nanopi2/hwrev.h new file mode 100644 index 0000000..1b1a828 --- /dev/null +++ b/board/friendlyarm/nanopi2/hwrev.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) Guangzhou FriendlyARM Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + */ + +#ifndef __BD_HW_REV_H__ +#define __BD_HW_REV_H__ + +extern void bd_hwrev_init(void); +extern void bd_base_rev_init(void); +extern u32 get_board_rev(void); +extern const char *get_board_name(void); + +#endif /* __BD_HW_REV_H__ */ diff --git a/board/friendlyarm/nanopi2/lcds.c b/board/friendlyarm/nanopi2/lcds.c new file mode 100644 index 0000000..7303e53 --- /dev/null +++ b/board/friendlyarm/nanopi2/lcds.c @@ -0,0 +1,697 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2017 FriendlyARM (www.arm9.net) + */ + +#include <config.h> +#include <common.h> +#include <errno.h> +#include <fdtdec.h> +#include <fdt_support.h> +#include <asm/io.h> + +#include <asm/arch/nexell.h> +#include <asm/arch/display.h> +#include <asm/arch/nx_gpio.h> + +#include "nxp-fb.h" + +/* + * param @module_index for nx_gpio APIs and will be removed + * after support pinctrl + */ +#ifndef PAD_GPIO_A +#define PAD_GPIO_A 0 +#endif + +static inline void common_gpio_init(void) +{ + /* PVCLK */ + nx_gpio_set_fast_slew(PAD_GPIO_A, 0, 1); +} + +static void s70_gpio_init(void) +{ + int i; + + /* PVCLK */ + nx_gpio_set_drive_strength(PAD_GPIO_A, 0, 1); + + /* RGB24 */ + for (i = 1; i < 25; i++) + nx_gpio_set_drive_strength(PAD_GPIO_A, i, 2); + + /* HS/VS/DE */ + for (; i < 28; i++) + nx_gpio_set_drive_strength(PAD_GPIO_A, i, 1); +} + +static void s702_gpio_init(void) +{ + int i; + + common_gpio_init(); + + nx_gpio_set_drive_strength(PAD_GPIO_A, 0, 2); + + for (i = 1; i < 25; i++) + nx_gpio_set_drive_strength(PAD_GPIO_A, i, 0); + + for (; i < 28; i++) + nx_gpio_set_drive_strength(PAD_GPIO_A, i, 1); +} + +static void s430_gpio_init(void) +{ + int i; + + for (i = 0; i < 28; i++) + nx_gpio_set_drive_strength(PAD_GPIO_A, i, 1); +} + +static void hd101_gpio_init(void) +{ + int i; + + common_gpio_init(); + + nx_gpio_set_drive_strength(PAD_GPIO_A, 0, 2); + + for (i = 1; i < 25; i++) + nx_gpio_set_drive_strength(PAD_GPIO_A, i, 1); + + nx_gpio_set_drive_strength(PAD_GPIO_A, 27, 1); +} + +static void hd700_gpio_init(void) +{ + hd101_gpio_init(); +} + +/* NXP display configs for supported LCD */ + +static struct nxp_lcd wxga_hd700 = { + .width = 800, + .height = 1280, + .p_width = 94, + .p_height = 151, + .bpp = 24, + .freq = 60, + + .timing = { + .h_fp = 20, + .h_bp = 20, + .h_sw = 24, + .v_fp = 4, + .v_fpe = 1, + .v_bp = 4, + .v_bpe = 1, + .v_sw = 8, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 0, + .inv_vsync = 0, + .inv_vden = 0, + }, + .gpio_init = hd700_gpio_init, +}; + +static struct nxp_lcd wvga_s70 = { + .width = 800, + .height = 480, + .p_width = 155, + .p_height = 93, + .bpp = 24, + .freq = 61, + + .timing = { + .h_fp = 48, + .h_bp = 36, + .h_sw = 10, + .v_fp = 22, + .v_fpe = 1, + .v_bp = 15, + .v_bpe = 1, + .v_sw = 8, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, + .gpio_init = s70_gpio_init, +}; + +static struct nxp_lcd wvga_s702 = { + .width = 800, + .height = 480, + .p_width = 155, + .p_height = 93, + .bpp = 24, + .freq = 61, + + .timing = { + .h_fp = 44, + .h_bp = 26, + .h_sw = 20, + .v_fp = 22, + .v_fpe = 1, + .v_bp = 15, + .v_bpe = 1, + .v_sw = 8, + }, + .polarity = { + .rise_vclk = 1, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, + .gpio_init = s702_gpio_init, +}; + +static struct nxp_lcd wvga_s70d = { + .width = 800, + .height = 480, + .p_width = 155, + .p_height = 93, + .bpp = 24, + .freq = 61, + + .timing = { + .h_fp = 80, + .h_bp = 78, + .h_sw = 10, + .v_fp = 22, + .v_fpe = 1, + .v_bp = 24, + .v_bpe = 1, + .v_sw = 8, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, + .gpio_init = s702_gpio_init, +}; + +static struct nxp_lcd wvga_w50 = { + .width = 800, + .height = 480, + .p_width = 108, + .p_height = 64, + .bpp = 24, + .freq = 61, + + .timing = { + .h_fp = 40, + .h_bp = 40, + .h_sw = 48, + .v_fp = 20, + .v_fpe = 1, + .v_bp = 20, + .v_bpe = 1, + .v_sw = 12, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, + .gpio_init = s70_gpio_init, +}; + +static struct nxp_lcd wvga_s430 = { + .width = 480, + .height = 800, + .p_width = 108, + .p_height = 64, + .bpp = 24, + .freq = 60, + + .timing = { + .h_fp = 64, + .h_bp = 0, + .h_sw = 16, + .v_fp = 32, + .v_fpe = 1, + .v_bp = 0, + .v_bpe = 1, + .v_sw = 16, + }, + .polarity = { + .rise_vclk = 1, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, + .gpio_init = s430_gpio_init, +}; + +static struct nxp_lcd wsvga_w101 = { + .width = 1024, + .height = 600, + .p_width = 204, + .p_height = 120, + .bpp = 24, + .freq = 60, + + .timing = { + .h_fp = 40, + .h_bp = 40, + .h_sw = 200, + .v_fp = 8, + .v_fpe = 1, + .v_bp = 8, + .v_bpe = 1, + .v_sw = 16, + }, + .polarity = { + .rise_vclk = 1, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, +}; + +static struct nxp_lcd wsvga_x710 = { + .width = 1024, + .height = 600, + .p_width = 154, + .p_height = 90, + .bpp = 24, + .freq = 61, + + .timing = { + .h_fp = 84, + .h_bp = 84, + .h_sw = 88, + .v_fp = 10, + .v_fpe = 1, + .v_bp = 10, + .v_bpe = 1, + .v_sw = 20, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, + .gpio_init = hd101_gpio_init, +}; + +static struct nxp_lcd xga_a97 = { + .width = 1024, + .height = 768, + .p_width = 200, + .p_height = 150, + .bpp = 24, + .freq = 61, + + .timing = { + .h_fp = 12, + .h_bp = 12, + .h_sw = 4, + .v_fp = 8, + .v_fpe = 1, + .v_bp = 8, + .v_bpe = 1, + .v_sw = 4, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, +}; + +static struct nxp_lcd xga_lq150 = { + .width = 1024, + .height = 768, + .p_width = 304, + .p_height = 228, + .bpp = 24, + .freq = 60, + + .timing = { + .h_fp = 12, + .h_bp = 12, + .h_sw = 40, + .v_fp = 8, + .v_fpe = 1, + .v_bp = 8, + .v_bpe = 1, + .v_sw = 40, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, +}; + +static struct nxp_lcd vga_l80 = { + .width = 640, + .height = 480, + .p_width = 160, + .p_height = 120, + .bpp = 32, + .freq = 60, + + .timing = { + .h_fp = 35, + .h_bp = 53, + .h_sw = 73, + .v_fp = 3, + .v_fpe = 1, + .v_bp = 29, + .v_bpe = 1, + .v_sw = 6, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, +}; + +static struct nxp_lcd wxga_bp101 = { + .width = 1280, + .height = 800, + .p_width = 218, + .p_height = 136, + .bpp = 24, + .freq = 60, + + .timing = { + .h_fp = 20, + .h_bp = 20, + .h_sw = 24, + .v_fp = 4, + .v_fpe = 1, + .v_bp = 4, + .v_bpe = 1, + .v_sw = 8, + }, + .polarity = { + .rise_vclk = 1, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, +}; + +static struct nxp_lcd wxga_hd101 = { + .width = 1280, + .height = 800, + .p_width = 218, + .p_height = 136, + .bpp = 24, + .freq = 60, + + .timing = { + .h_fp = 16, + .h_bp = 16, + .h_sw = 30, + .v_fp = 8, + .v_fpe = 1, + .v_bp = 8, + .v_bpe = 1, + .v_sw = 12, + }, + .polarity = { + .rise_vclk = 1, + .inv_hsync = 0, + .inv_vsync = 0, + .inv_vden = 0, + }, + .gpio_init = hd101_gpio_init, +}; + +static struct nxp_lcd hvga_h43 = { + .width = 480, + .height = 272, + .p_width = 96, + .p_height = 54, + .bpp = 32, + .freq = 65, + + .timing = { + .h_fp = 5, + .h_bp = 40, + .h_sw = 2, + .v_fp = 8, + .v_fpe = 1, + .v_bp = 8, + .v_bpe = 1, + .v_sw = 2, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, +}; + +static struct nxp_lcd hvga_p43 = { + .width = 480, + .height = 272, + .p_width = 96, + .p_height = 54, + .bpp = 32, + .freq = 65, + + .timing = { + .h_fp = 5, + .h_bp = 40, + .h_sw = 2, + .v_fp = 8, + .v_fpe = 1, + .v_bp = 9, + .v_bpe = 1, + .v_sw = 2, + }, + .polarity = { + .rise_vclk = 1, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, +}; + +static struct nxp_lcd qvga_w35 = { + .width = 320, + .height = 240, + .p_width = 70, + .p_height = 52, + .bpp = 16, + .freq = 65, + + .timing = { + .h_fp = 4, + .h_bp = 70, + .h_sw = 4, + .v_fp = 4, + .v_fpe = 1, + .v_bp = 12, + .v_bpe = 1, + .v_sw = 4, + }, + .polarity = { + .rise_vclk = 1, + .inv_hsync = 0, + .inv_vsync = 0, + .inv_vden = 0, + }, +}; + +/* HDMI */ +static struct nxp_lcd hdmi_def = { + .width = 1920, + .height = 1080, + .p_width = 480, + .p_height = 320, + .bpp = 24, + .freq = 60, + + .timing = { + .h_fp = 12, + .h_bp = 12, + .h_sw = 4, + .v_fp = 8, + .v_fpe = 1, + .v_bp = 8, + .v_bpe = 1, + .v_sw = 4, + }, + .polarity = { + .rise_vclk = 0, + .inv_hsync = 1, + .inv_vsync = 1, + .inv_vden = 0, + }, +}; + +static struct hdmi_config { + char *name; + int width; + int height; +} bd_hdmi_config[] = { + { "HDMI1080P60", 1920, 1080 }, + { "HDMI1080I60", 1920, 1080 }, + { "HDMI1080P30", 1920, 1080 }, + { "HDMI1080P50", 1920, 1080 }, + { "HDMI1080I50", 1920, 1080 }, + + { "HDMI1080P60D", 960, 536 }, + { "HDMI1080I60D", 960, 536 }, + { "HDMI1080P30D", 960, 536 }, + { "HDMI1080P50D", 960, 536 }, + { "HDMI1080I50D", 960, 536 }, + + { "HDMI720P60", 1280, 720 }, + { "HDMI720P60D", 640, 360 }, + { "HDMI720P50", 1280, 720 }, + { "HDMI720P50D", 640, 360 }, + + { "HDMI576P16X9", 720, 576 }, + { "HDMI576P16X9D", 720, 576 }, + { "HDMI576P4X3", 720, 576 }, + { "HDMI576P4X3D", 720, 576 }, + + { "HDMI480P16X9", 720, 480 }, + { "HDMI480P16X9D", 720, 480 }, + { "HDMI480P4X3", 720, 480 }, + { "HDMI480P4X3D", 720, 480 }, +}; + +/* Try to guess LCD panel by kernel command line, or + * using *HD101* as default + */ +static struct { + int id; + char *name; + struct nxp_lcd *lcd; + int dpi; + int ctp; + enum lcd_format fmt; +} bd_lcd_config[] = { + { 25, "HD101", &wxga_hd101, 0, 1, LCD_RGB }, + { 32, "HD101B", &wxga_hd101, 0, 1, LCD_RGB }, + { 18, "HD700", &wxga_hd700, 213, 1, LCD_RGB }, + { 30, "HD702", &wxga_hd700, 213, 1, LCD_RGB }, + { 33, "H70", &wxga_hd700, 213, 0, LCD_VESA }, + { 3, "S70", &wvga_s70, 128, 1, LCD_RGB }, + { 36, "S701", &wvga_s70, 128, 1, LCD_RGB }, + { 24, "S702", &wvga_s702, 128, 3, LCD_RGB }, + { 26, "S70D", &wvga_s70d, 128, 0, LCD_RGB }, + { 14, "H43", &hvga_h43, 0, 0, LCD_RGB }, + { 19, "P43", &hvga_p43, 0, 0, LCD_RGB }, + { 8, "W35", &qvga_w35, 0, 0, LCD_RGB }, + { 28, "X710", &wsvga_x710, 0, 1, LCD_RGB }, + { 31, "S430", &wvga_s430, 180, 1, LCD_RGB }, + { 4, "W50", &wvga_w50, 0, 0, LCD_RGB }, + + /* TODO: Testing */ + { 15, "W101", &wsvga_w101, 0, 1, LCD_RGB }, + { 5, "L80", &vga_l80, 0, 1, LCD_RGB }, + { -1, "A97", &xga_a97, 0, 0, LCD_RGB }, + { -1, "LQ150", &xga_lq150, 0, 1, LCD_RGB }, + { -1, "BP101", &wxga_bp101, 0, 1, LCD_RGB }, + /* Pls keep it at last */ + { 128, "HDMI", &hdmi_def, 0, 0, LCD_HDMI }, +}; + +static int lcd_idx; + +int bd_setup_lcd_by_id(int id) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(bd_lcd_config); i++) { + if (bd_lcd_config[i].id == id) { + lcd_idx = i; + break; + } + } + + if (i >= ARRAY_SIZE(bd_lcd_config)) { + /* NOT found */ + return -19; + } + + return bd_lcd_config[i].id; +} + +int bd_setup_lcd_by_name(char *str) +{ + char *delim; + int i; + + delim = strchr(str, ','); + if (delim) + *delim++ = '\0'; + + if (!strncasecmp("HDMI", str, 4)) { + struct hdmi_config *cfg = &bd_hdmi_config[0]; + struct nxp_lcd *lcd; + + lcd_idx = ARRAY_SIZE(bd_lcd_config) - 1; + lcd = bd_lcd_config[lcd_idx].lcd; + + for (i = 0; i < ARRAY_SIZE(bd_hdmi_config); i++, cfg++) { + if (!strcasecmp(cfg->name, str)) { + lcd->width = cfg->width; + lcd->height = cfg->height; + bd_lcd_config[lcd_idx].name = cfg->name; + goto __ret; + } + } + } + + for (i = 0; i < ARRAY_SIZE(bd_lcd_config); i++) { + if (!strcasecmp(bd_lcd_config[i].name, str)) { + lcd_idx = i; + break; + } + } + +__ret: + return 0; +} + +struct nxp_lcd *bd_get_lcd(void) +{ + return bd_lcd_config[lcd_idx].lcd; +} + +const char *bd_get_lcd_name(void) +{ + return bd_lcd_config[lcd_idx].name; +} + +enum lcd_format bd_get_lcd_format(void) +{ + return bd_lcd_config[lcd_idx].fmt; +} + +int bd_get_lcd_density(void) +{ + return bd_lcd_config[lcd_idx].dpi; +} + +#if CONFIG_IS_ENABLED(OF_CONTROL) +int bd_fixup_lcd_fdt(void *blob, struct nxp_lcd *lcd) +{ + return 0; +} +#endif diff --git a/board/friendlyarm/nanopi2/nxp-fb.h b/board/friendlyarm/nanopi2/nxp-fb.h new file mode 100644 index 0000000..d31a03d --- /dev/null +++ b/board/friendlyarm/nanopi2/nxp-fb.h @@ -0,0 +1,94 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (c) 2017 FriendlyARM (www.arm9.net) + * + * Copyright (c) 2010 Samsung Electronics Co., Ltd. + * http://www.samsung.com/ + * + * Header file for NXP Display Driver + */ + +#ifndef __MACH_NXP_FB_H__ +#define __MACH_NXP_FB_H__ + +/* + * struct nxp_lcd_polarity + * @rise_vclk: if 1, video data is fetched at rising edge + * @inv_hsync: if HSYNC polarity is inversed + * @inv_vsync: if VSYNC polarity is inversed + * @inv_vden: if VDEN polarity is inversed + */ +struct nxp_lcd_polarity { + int rise_vclk; + int inv_hsync; + int inv_vsync; + int inv_vden; +}; + +/* + * struct nxp_lcd_timing + * @h_fp: horizontal front porch + * @h_bp: horizontal back porch + * @h_sw: horizontal sync width + * @v_fp: vertical front porch + * @v_fpe: vertical front porch for even field + * @v_bp: vertical back porch + * @v_bpe: vertical back porch for even field + */ +struct nxp_lcd_timing { + int h_fp; + int h_bp; + int h_sw; + int v_fp; + int v_fpe; + int v_bp; + int v_bpe; + int v_sw; +}; + +/* + * struct nxp_lcd + * @width: horizontal resolution + * @height: vertical resolution + * @p_width: width of lcd in mm + * @p_height: height of lcd in mm + * @bpp: bits per pixel + * @freq: vframe frequency + * @timing: timing values + * @polarity: polarity settings + * @gpio_init: pointer to GPIO init function + * + */ +struct nxp_lcd { + int width; + int height; + int p_width; + int p_height; + int bpp; + int freq; + struct nxp_lcd_timing timing; + struct nxp_lcd_polarity polarity; + void (*gpio_init)(void); +}; + +/** + * Public interfaces + */ +enum lcd_format { + LCD_VESA = 0, + LCD_JEIDA = 1, + LCD_LOC = 2, + + LCD_RGB = 4, + LCD_HDMI = 5, +}; + +extern int bd_setup_lcd_by_id(int id); +extern int bd_setup_lcd_by_name(char *name); +extern struct nxp_lcd *bd_get_lcd(void); +extern const char *bd_get_lcd_name(void); +extern int bd_get_lcd_density(void); +extern enum lcd_format bd_get_lcd_format(void); +extern int bd_fixup_lcd_fdt(void *blob, struct nxp_lcd *cfg); + +#endif /* __MACH_NXP_FB_H__ */ diff --git a/board/friendlyarm/nanopi2/onewire.c b/board/friendlyarm/nanopi2/onewire.c new file mode 100644 index 0000000..994befb --- /dev/null +++ b/board/friendlyarm/nanopi2/onewire.c @@ -0,0 +1,307 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) Guangzhou FriendlyARM Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + */ + +#include <config.h> +#include <common.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/clk.h> +#include <i2c.h> +#include <pwm.h> + +#include <irq_func.h> + +#include <asm/arch/nexell.h> +#include <asm/arch/nx_gpio.h> + +#ifndef NSEC_PER_SEC +#define NSEC_PER_SEC 1000000000L +#endif + +#define SAMPLE_BPS 9600 +#define SAMPLE_IN_US 101 /* (1000000 / BPS) */ + +#define REQ_INFO 0x60U +#define REQ_BL 0x80U + +#define BUS_I2C 0x18 +#define ONEWIRE_I2C_BUS 2 +#define ONEWIRE_I2C_ADDR 0x2f + +static int bus_type = -1; +static int lcd_id = -1; +static unsigned short lcd_fwrev; +static int current_brightness = -1; +#ifdef CONFIG_DM_I2C +static struct udevice *i2c_dev; +#endif + +/* debug */ +#if (0) +#define DBGOUT(msg...) do { printf("onewire: " msg); } while (0) +#else +#define DBGOUT(msg...) do {} while (0) +#endif + +/* based on web page from http://lfh1986.blogspot.com */ +static unsigned char crc8_ow(unsigned int v, unsigned int len) +{ + unsigned char crc = 0xACU; + + while (len--) { + if ((crc & 0x80U) != 0) { + crc <<= 1; + crc ^= 0x7U; + } else { + crc <<= 1; + } + if ((v & (1U << 31)) != 0) + crc ^= 0x7U; + v <<= 1; + } + return crc; +} + +/* GPIO helpers */ +#define __IO_GRP 2 /* GPIOC15 */ +#define __IO_IDX 15 + +static inline void set_pin_as_input(void) +{ + nx_gpio_set_output_enable(__IO_GRP, __IO_IDX, 0); +} + +static inline void set_pin_as_output(void) +{ + nx_gpio_set_output_enable(__IO_GRP, __IO_IDX, 1); +} + +static inline void set_pin_value(int v) +{ + nx_gpio_set_output_value(__IO_GRP, __IO_IDX, !!v); +} + +static inline int get_pin_value(void) +{ + return nx_gpio_get_input_value(__IO_GRP, __IO_IDX); +} + +/* Timer helpers */ +#define PWM_CH 3 +#define PWM_TCON (PHY_BASEADDR_PWM + 0x08) +#define PWM_TCON_START (1 << 16) +#define PWM_TINT_CSTAT (PHY_BASEADDR_PWM + 0x44) + +static int onewire_init_timer(void) +{ + int period_ns = NSEC_PER_SEC / SAMPLE_BPS; + + /* range: 1080~1970 */ + period_ns -= 1525; + + return pwm_config(PWM_CH, period_ns >> 1, period_ns); +} + +static void wait_one_tick(void) +{ + unsigned int tcon; + + tcon = readl(PWM_TCON); + tcon |= PWM_TCON_START; + writel(tcon, PWM_TCON); + + while (1) { + if (readl(PWM_TINT_CSTAT) & (1 << (5 + PWM_CH))) + break; + } + + writel((1 << (5 + PWM_CH)), PWM_TINT_CSTAT); + + tcon &= ~PWM_TCON_START; + writel(tcon, PWM_TCON); +} + +/* Session handler */ +static int onewire_session(unsigned char req, unsigned char res[]) +{ + unsigned int Req; + unsigned int *Res; + int ints = disable_interrupts(); + int i; + int ret; + + Req = (req << 24) | (crc8_ow(req << 24, 8) << 16); + Res = (unsigned int *)res; + + set_pin_value(1); + set_pin_as_output(); + for (i = 0; i < 60; i++) + wait_one_tick(); + + set_pin_value(0); + for (i = 0; i < 2; i++) + wait_one_tick(); + + for (i = 0; i < 16; i++) { + int v = !!(Req & (1U << 31)); + + Req <<= 1; + set_pin_value(v); + wait_one_tick(); + } + + wait_one_tick(); + set_pin_as_input(); + wait_one_tick(); + for (i = 0; i < 32; i++) { + (*Res) <<= 1; + (*Res) |= get_pin_value(); + wait_one_tick(); + } + set_pin_value(1); + set_pin_as_output(); + + if (ints) + enable_interrupts(); + + ret = crc8_ow(*Res, 24) == res[0]; + DBGOUT("req = %02X, res = %02X%02X%02X%02X, ret = %d\n", + req, res[3], res[2], res[1], res[0], ret); + + return ret; +} + +static int onewire_i2c_do_request(unsigned char req, unsigned char *buf) +{ + unsigned char tx[4]; + int ret; + + tx[0] = req; + tx[1] = crc8_ow(req << 24, 8); + +#ifdef CONFIG_DM_I2C + if (dm_i2c_write(i2c_dev, 0, tx, 2)) + return -EIO; + + if (!buf) + return 0; + + if (dm_i2c_read(i2c_dev, 0, buf, 4)) + return -EIO; +#else + if (i2c_write(ONEWIRE_I2C_ADDR, 0, 0, tx, 2)) + return -EIO; + + if (!buf) /* NO READ */ + return 0; + + if (i2c_read(ONEWIRE_I2C_ADDR, 0, 0, buf, 4)) + return -EIO; +#endif + + ret = crc8_ow((buf[0] << 24) | (buf[1] << 16) | (buf[2] << 8), 24); + DBGOUT("req = %02X, res = %02X%02X%02X%02X, ret = %02x\n", + req, buf[0], buf[1], buf[2], buf[3], ret); + + return (ret == buf[3]) ? 0 : -EIO; +} + +static void onewire_i2c_init(void) +{ + unsigned char buf[4]; + int ret; + +#ifdef CONFIG_DM_I2C + ret = i2c_get_chip_for_busnum(ONEWIRE_I2C_BUS, + ONEWIRE_I2C_ADDR, 0, &i2c_dev); +#else + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + i2c_set_bus_num(ONEWIRE_I2C_BUS); + + ret = i2c_probe(ONEWIRE_I2C_ADDR); +#endif + if (ret) + return; + + ret = onewire_i2c_do_request(REQ_INFO, buf); + if (!ret) { + lcd_id = buf[0]; + lcd_fwrev = buf[1] * 0x100 + buf[2]; + bus_type = BUS_I2C; + } +} + +void onewire_init(void) +{ + /* GPIO, Pull-off */ + nx_gpio_set_pad_function(__IO_GRP, __IO_IDX, 1); + nx_gpio_set_pull_mode(__IO_GRP, __IO_IDX, 2); + + onewire_init_timer(); + onewire_i2c_init(); +} + +int onewire_get_info(unsigned char *lcd, unsigned short *fw_ver) +{ + unsigned char res[4]; + int i; + + if (bus_type == BUS_I2C && lcd_id > 0) { + *lcd = lcd_id; + *fw_ver = lcd_fwrev; + return 0; + } + + for (i = 0; i < 3; i++) { + if (onewire_session(REQ_INFO, res)) { + *lcd = res[3]; + *fw_ver = res[2] * 0x100 + res[1]; + lcd_id = *lcd; + DBGOUT("lcd = %d, fw_ver = %x\n", *lcd, *fw_ver); + return 0; + } + } + + /* LCD unknown or not connected */ + *lcd = 0; + *fw_ver = -1; + + return -1; +} + +int onewire_get_lcd_id(void) +{ + return lcd_id; +} + +int onewire_set_backlight(int brightness) +{ + unsigned char res[4]; + int i; + + if (brightness == current_brightness) + return 0; + + if (brightness > 127) + brightness = 127; + else if (brightness < 0) + brightness = 0; + + if (bus_type == BUS_I2C) { + onewire_i2c_do_request((REQ_BL | brightness), NULL); + current_brightness = brightness; + return 0; + } + + for (i = 0; i < 3; i++) { + if (onewire_session((REQ_BL | brightness), res)) { + current_brightness = brightness; + return 0; + } + } + + return -1; +} diff --git a/board/friendlyarm/nanopi2/onewire.h b/board/friendlyarm/nanopi2/onewire.h new file mode 100644 index 0000000..9f6d7cf --- /dev/null +++ b/board/friendlyarm/nanopi2/onewire.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) Guangzhou FriendlyARM Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + */ + +#ifndef __ONE_WIRE_H__ +#define __ONE_WIRE_H__ + +extern void onewire_init(void); +extern int onewire_get_info(unsigned char *lcd, unsigned short *fw_ver); +extern int onewire_get_lcd_id(void); +extern int onewire_set_backlight(int brightness); + +#endif /* __ONE_WIRE_H__ */
Changes in relation to FriendlyARM's U-Boot nanopi2-v2016.01: - Configuration changed, mainly several "CONFIG_..." moved from s5p4418_nanopi2.h to s5p4418_nanopi2_defconfig and USB related configs removed because USB is not supported yet. - s5p4418_nanopi2.h: "CONFIG_" removed from several s5p4418/nanopi2 specific defines because the appropriate values do not need to be configurable. - pinctrl is supported now, therefore "CONFIG_PINCTRL=y" added to s5p4418_nanopi2_defconfig.
Changes in v3: - CONFIG_SYS_RESERVE_MEM_SIZE removed, has not been used anymore - s5p4418_nanopi2_defconfig: "CONFIG_PINCTRL=y" added because pinctrl is supported now. "CONFIG_EFI_LOADER=n" removed (there have been boot errors "efi_runtime_relocate: Unknown relocation type 0" at a previous U-Boot Version without this). "CONFIG_DM_I2C_GPIO=y" removed because I2C-peripherial is used (Nexell I2C driver). Some configs moved down for cosmetic reason. - Handling of Configs for LCD backlight control reworked because (among others) not setting CONFIG_S5P4418_ONEWIRE and/or CONFIG_PWM_NX has caused errors when compiling board/friendlyarm/nanopi2/onewire.c. - CONFIG_SYS_MEMTEST_START, CONFIG_SYS_MEMTEST_END, CONFIG_CMDLINE_TAG and CONFIG_CMD_BMP moved from s5p4418_nanopi2.h to s5p4418_nanopi2_defconfig. - "#undef CONFIG_CMD_IMLS" removed in s5p4418_nanopi2.h
Changes in v2: - USB related configs removed because USB is not supported yet. - CONFIG_CMD_MEMTEST moved from s5p4418_nanopi2.h to s5p4418_nanopi2_defconfig. - MAINTAINERS: "F: drivers/pwm/pwm-nexell*" deleted because arch/arm/cpu/armv7/s5p-common/pwm.c is used now. Furthermore double line "F: drivers/video/nexell/" deleted.
MAINTAINERS | 17 +++ configs/s5p4418_nanopi2_defconfig | 147 ++++++++++++++++++++++ doc/README.s5p4418 | 63 ++++++++++ include/configs/s5p4418_nanopi2.h | 257 ++++++++++++++++++++++++++++++++++++++ 4 files changed, 484 insertions(+) create mode 100644 configs/s5p4418_nanopi2_defconfig create mode 100644 doc/README.s5p4418 create mode 100644 include/configs/s5p4418_nanopi2.h
diff --git a/MAINTAINERS b/MAINTAINERS index 1fd975c..314162c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -270,6 +270,23 @@ F: arch/arm/mach-at91/ F: board/atmel/ F: drivers/misc/microchip_flexcom.c
+ARM NEXELL S5P4418 +M: Stefan Bosch stefan_b@posteo.net +S: Maintained +F: arch/arm/cpu/armv7/s5p4418/ +F: arch/arm/dts/s5p4418* +F: arch/arm/mach-nexell/ +F: board/friendlyarm/ +F: configs/s5p4418_nanopi2_defconfig +F: doc/README.s5p4418 +F: drivers/gpio/nx_gpio.c +F: drivers/i2c/nx_i2c.c +F: drivers/mmc/nexell_dw_mmc_dm.c +F: drivers/pinctrl/nexell/ +F: drivers/video/nexell/ +F: drivers/video/nexell_display.c +F: include/configs/s5p4418_nanopi2.h + ARM OWL M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org S: Maintained diff --git a/configs/s5p4418_nanopi2_defconfig b/configs/s5p4418_nanopi2_defconfig new file mode 100644 index 0000000..c1cd08a --- /dev/null +++ b/configs/s5p4418_nanopi2_defconfig @@ -0,0 +1,147 @@ +CONFIG_ARM=y +CONFIG_ARCH_NEXELL=y +CONFIG_ARCH_S5P4418=y +CONFIG_TARGET_NANOPI2=y +CONFIG_DEFAULT_DEVICE_TREE="s5p4418-nanopi2" +CONFIG_FIT=y + +CONFIG_SYS_MEMTEST_START=0x71000000 +CONFIG_SYS_MEMTEST_END=0xb0000000 + +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set + +# Default is CONFIG_NET=y, in this case: +# Loading Environment from MMC... ## Warning: Unknown environment variable type 'm' +# OK +# CONFIG_CMD_NET=y must be set to avoid this Warning. But then: +# Net: Net Initialization Skipped +# No ethernet found. +# If CONFIG_NET=n is set additionally warning at "make s5p4418_nanopi2_defconfig": +# arch/../configs/s5p4418_nanopi2_defconfig:24:warning: override: reassigning to symbol CMD_NET +# +# --> CONFIG_NET=n set only +CONFIG_NET=n + +# CONFIG_CMD_NFS is not set +CONFIG_CMD_FDISK=y +CONFIG_CMD_EXT4_IMG_WRITE=y +CONFIG_CMD_SD_RECOVERY=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y + +CONFIG_PINCTRL=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_NEXELL=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_AXP228=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_AXP228=y +CONFIG_DM_PWM=n + +CONFIG_DISPLAY=y +CONFIG_DM_VIDEO=y +CONFIG_SYS_CONSOLE_BG_COL=0xff +CONFIG_SYS_CONSOLE_FG_COL=0x00 +CONFIG_VIDEO_NX=y +CONFIG_VIDEO_NX_RGB=y +CONFIG_VIDEO_NX_LVDS=y +CONFIG_VIDEO_NX_HDMI=y +CONFIG_CMD_BMP=y + +## LCD backlight control +CONFIG_S5P4418_ONEWIRE=y +CONFIG_PWM_NX is not set + +CONFIG_REGEX=y +CONFIG_ERRNO_STR=y + +CONFIG_SYS_TEXT_BASE=0x74C00000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SYS_CACHELINE_SIZE=64 + +## System initialize options (board_init_f) +# board_init_f->init_sequence, call board_early_init_f +CONFIG_BOARD_LATE_INIT=y +# board_init_f->init_sequence, call print_cpuinfo +CONFIG_DISPLAY_CPUINFO=y +# board_init_f->init_sequence, call show_board_info +CONFIG_DISPLAY_BOARDINFO=y +# board_init_f, CONFIG_SYS_ICACHE_OFF +CONFIG_SYS_DCACHE_OFF=y +# board_init_r, call arch_misc_init +CONFIG_ARCH_MISC_INIT=y + +CONFIG_BOOTDELAY=1 +CONFIG_ZERO_BOOTDELAY_CHECK=y + +## U-Boot Environments +## refer to common/env_common.c + +# CONFIG_ENV_IS_IN_MMC must be set here and not in s5p4418_nanopi2.h +# otherwise CONFIG_ENV_IS_NOWHERE is set by env/Kconfig and environment +# (bootargs) are not loaded +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_OFFSET=0x2E0200 +CONFIG_ENV_SIZE=0x4000 +CONFIG_CMD_SAVEENV=y + +## Etc Command definition +# image info +CONFIG_CMD_IMI=y +# add command line history +CONFIG_CMDLINE_EDITING=y +CONFIG_CMDLINE_TAG=y +CONFIG_INITRD_TAG=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_REVISION_TAG=y +CONFIG_CMD_BOOTZ=y + +## serial console configuration +CONFIG_CONS_INDEX=0 +CONFIG_BAUDRATE=115200 + +## SD/MMC +CONFIG_BOUNCE_BUFFER=y +CONFIG_GENERIC_MMC=y +CONFIG_MMC=y +CONFIG_MMC_DW=y +CONFIG_NEXELL_DWMMC=y +CONFIG_CMD_MMC=y +CONFIG_DM_MMC=y + +CONFIG_DOS_PARTITION=y +CONFIG_CMD_FAT=y +CONFIG_FS_FAT=y +CONFIG_FAT_WRITE=y + +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_FS_EXT4=y +CONFIG_EXT4_WRITE=y + +## OF_CONTROL +CONFIG_FIT_BEST_MATCH=y +CONFIG_OF_LIBFDT=y +CONFIG_OF_BOARD_SETUP=y + +## BOOTCOMMAND +CONFIG_ROOT_DEV=1 +CONFIG_BOOT_PART=1 +CONFIG_ROOT_PART=2 + +# necessary for if-cmd +CONFIG_HUSH_PARSER=y + +# set to 'n' to save memory +CONFIG_SYS_LONGHELP=y + +# For debugging (trace) of MMC-CMDs +CONFIG_MMC_TRACE=n diff --git a/doc/README.s5p4418 b/doc/README.s5p4418 new file mode 100644 index 0000000..ac724d0 --- /dev/null +++ b/doc/README.s5p4418 @@ -0,0 +1,63 @@ + +Summary +======= + +This README is about U-Boot support for SAMSUNG's/NEXELL's ARM Cortex-A9 based +S5P4418 SoC. It is based on FriendlyARM's U-Boot v2016.01 for the NanoPi2 +(and other) boards [1]. + +Currently the following boards are supported: + +* FriendlyArm NanoPi2 [2] +* FriendlyArm NanoPC-T2 [3] + + +Build +===== + +* NanoPi2 and NanoPC-T2 + +make s5p4418_nanopi2_defconfig +make + + +Installation +============ + +- Download Official-ROMs-SDCard-20190718.7z from [4] (images files for android, + friendlyCore and LUbuntu) +- Use s5p4418-sd-lubuntu-desktop-xenial-4.4-armhf-20190718.img to make a SD-card +- Use dd in the directory where U-Boot has been built to update U-Boot: + (replace <SD-card> with the device used for the SD-card, e.g. sdc) + sudo dd seek=3841 if=u-boot.bin of=/dev/<SD-card> +- Boot the board from this SD-card + +The source code for (the used?) LUbuntu 16.04 can be found at [5]. + + +Links +===== + +[1] FriendlyArm U-boot v2016.01: + +https://github.com/friendlyarm/u-boot/tree/nanopi2-v2016.01 + + +[2] NanoPi2: + +http://wiki.friendlyarm.com/wiki/index.php/NanoPi_2 + + +[3] NanoPC-T2: + +http://wiki.friendlyarm.com/wiki/index.php/NanoPC-T2 + + +[4] FriendlyArm image files for NanoPi2: + +http://download.friendlyarm.com//NanoPi2 + + +[5] FriendlyArm LUbuntu 16.04 Source Code for NanoPi2: + +https://github.com/friendlyarm/linux/tree/nanopi2-v4.4.y diff --git a/include/configs/s5p4418_nanopi2.h b/include/configs/s5p4418_nanopi2.h new file mode 100644 index 0000000..da5b29a --- /dev/null +++ b/include/configs/s5p4418_nanopi2.h @@ -0,0 +1,257 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (C) Guangzhou FriendlyARM Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * (C) Copyright 2016 Nexell + * Hyejung Kwon cjscld15@nexell.co.kr + * + * Copyright (C) 2019 Stefan Bosch stefan_b@posteo.net + */ + +#ifndef __CONFIG_H__ +#define __CONFIG_H__ + +#include <linux/sizes.h> +#include <asm/arch/nexell.h> + +/*----------------------------------------------------------------------- + * System memory Configuration + */ +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_MEM_SIZE 0x40000000 +#define CONFIG_SYS_SDRAM_BASE 0x71000000 + +/* + * "(CONFIG_SYS_MEM_SIZE - CONFIG_SYS_RESERVE_MEM_SIZE)" has been used in + * u-boot nanopi2-v2016.01. + * This is not working anymore because boot_fdt_add_mem_rsv_regions() in + * common/image-fdt.c has been extended: + * Also reserved-memory sections are marked as unusable. + * + * In friendlyArm Ubuntu 16.04 source arch/arm/boot/dts/s5p4418.dtsi: + * reserved-memory { + * #address-cells = <1>; + * #size-cells = <1>; + * ranges; + * + * secure_memory@b0000000 { + * reg = <0xB0000000 0x1000000>; + * nop-map; + * }; + * }; + * + * arch_lmb_reserve() of arch/arm/lib/bootm.c: + * "Allocate space for command line and board info - ... below the current + * stack pointer." + * --> Memory allocated would overlap with "secure_memory@b0000000" + * --> lmb_add_region(rgn, base==0xb0000000, size==0x1000000) fails, + * boot output: + * ... + * Kernel image @ 0x71080000 [ 0x000000 - 0x60e628 ] + * ## Flattened Device Tree blob at 7a000000 + * Booting using the fdt blob at 0x7a000000 + * ERROR: reserving fdt memory region failed (addr=b0000000 size=1000000) + * Using Device Tree in place at 7a000000, end 7a00fbf0 + * + * Starting kernel ... + * ... + */ +#define CONFIG_SYS_SDRAM_SIZE (0xb0000000 - CONFIG_SYS_SDRAM_BASE) + +#define CONFIG_SYS_MALLOC_LEN (32 * 1024 * 1024) + +#define BMP_LOAD_ADDR 0x78000000 + +/* kernel load address */ +#define CONFIG_SYS_LOAD_ADDR 0x71080000 +#define INITRD_START 0x79000000 +#define KERNEL_DTB_ADDR 0x7A000000 + +/*----------------------------------------------------------------------- + * High Level System Configuration + */ +/* Not used: not need IRQ/FIQ stuff */ +#undef CONFIG_USE_IRQ +/* decrementer freq: 1ms ticks */ +#define CONFIG_SYS_HZ 1000 + +/*----------------------------------------------------------------------- + * System initialize options (board_init_f) + */ +/* board_init_f->init_sequence, call arch_cpu_init */ +#define CONFIG_ARCH_CPU_INIT + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + */ +#ifdef CONFIG_SYS_PROMPT +#undef CONFIG_SYS_PROMPT +/* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "nanopi2# " +#endif + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 1024 +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/*----------------------------------------------------------------------- + * allow to overwrite serial and ethaddr + */ +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +/*----------------------------------------------------------------------- + * Etc Command definition + */ +#undef CONFIG_BOOTM_NETBSD +#undef CONFIG_BOOTM_RTEMS + +/*----------------------------------------------------------------------- + * serial console configuration + */ +#define CONFIG_PL011_CLOCK 50000000 +#define CONFIG_PL01x_PORTS {(void *)PHY_BASEADDR_UART0, \ + (void *)PHY_BASEADDR_UART1, \ + (void *)PHY_BASEADDR_UART2, \ + (void *)PHY_BASEADDR_UART3} +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*----------------------------------------------------------------------- + * PLL + */ +#define CONFIG_SYS_PLLFIN 24000000UL + +/*----------------------------------------------------------------------- + * Timer + */ +#define CONFIG_TIMER_SYS_TICK_CH 0 + +/*----------------------------------------------------------------------- + * BACKLIGHT + */ +#ifndef CONFIG_S5P4418_ONEWIRE +#ifdef CONFIG_PWM_NX +/* fallback to pwm */ +#define BACKLIGHT_CH 0 +#define BACKLIGHT_DIV 0 +#define BACKLIGHT_INV 0 +#define BACKLIGHT_DUTY 50 +#define BACKLIGHT_HZ 1000 +#endif +#endif + +/*----------------------------------------------------------------------- + * SD/MMC + */ +#if defined(CONFIG_MMC) +/* eMMC = 0, SD-card = 2 */ +#define CONFIG_SYS_MMC_DEV 2 +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_SYS_MMC_DEV +#endif + +/*----------------------------------------------------------------------- + * Default environment organization + */ +#if !defined(CONFIG_ENV_IS_IN_MMC) && !defined(CONFIG_ENV_IS_IN_NAND) && \ + !defined(CONFIG_ENV_IS_IN_FLASH) && !defined(CONFIG_ENV_IS_IN_EEPROM) + /* default: CONFIG_ENV_IS_NOWHERE */ + #define CONFIG_ENV_IS_NOWHERE + #define CONFIG_ENV_OFFSET 1024 + #define CONFIG_ENV_SIZE (4 * 1024) /* env size */ +#endif + +/*----------------------------------------------------------------------- + * VIDEO + */ + +#define CONFIG_VIDEO_LOGO + +#define CONFIG_SPLASH_SCREEN + +#ifdef CONFIG_VIDEO_LOGO + +#ifdef CONFIG_DM_VIDEO +#define CONFIG_BMP_24BPP +#endif + +#ifdef CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SOURCE 1 +#define CONFIG_SPLASH_SCREEN_ALIGN 1 +#define SPLASH_FILE logo.bmp +#endif + +#endif + +/*----------------------------------------------------------------------- + * ENV + */ +#define BLOADER_MMC \ + "ext4load mmc ${rootdev}:${bootpart} " + +#ifdef CONFIG_OF_BOARD_SETUP +#define EXTRA_ENV_DTB_RESERVE \ + "dtb_reserve=" \ + "if test -n "$dtb_addr"; then fdt addr $dtb_addr; fi\0" +#else +#define EXTRA_ENV_DTB_RESERVE \ + "dtb_reserve=" \ + "if test -n "$fb_addr"; then " \ + "fdt addr $dtb_addr;" \ + "fdt resize;" \ + "fdt mk /reserved-memory display_reserved;" \ + "fdt set /reserved-memory/display_reserved " \ + "reg <$fb_addr 0x800000>;" \ + "fi;\0" +#endif + +#ifdef CONFIG_SPLASH_SCREEN +#define EXTRA_ENV_BOOT_LOGO \ + "splashimage=" __stringify(BMP_LOAD_ADDR)"\0" \ + "splashfile=" __stringify(SPLASH_FILE)"\0" \ + "splashpos=m,m\0" \ + "fb_addr=\0" \ + EXTRA_ENV_DTB_RESERVE +#else + #define EXTRA_ENV_BOOT_LOGO EXTRA_ENV_DTB_RESERVE +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "rootdev=" __stringify(CONFIG_ROOT_DEV) "\0" \ + "rootpart=" __stringify(CONFIG_ROOT_PART) "\0" \ + "bootpart=" __stringify(CONFIG_BOOT_PART) "\0" \ + "kernel=zImage\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "dtb_name=s5p4418-nanopi2-rev01.dtb\0" \ + "dtb_addr=" __stringify(KERNEL_DTB_ADDR) "\0" \ + "initrd_name=ramdisk.img\0" \ + "initrd_addr=" __stringify(INITRD_START) "\0" \ + "initrd_size=0x600000\0" \ + "load_dtb=" \ + BLOADER_MMC "${dtb_addr} ${dtb_name}; " \ + "run dtb_reserve\0" \ + "load_kernel=" \ + BLOADER_MMC "${loadaddr} ${kernel}\0" \ + "load_initrd=" \ + BLOADER_MMC "${initrd_addr} ${initrd_name}; " \ + "setenv initrd_size 0x${filesize}\0" \ + "mmcboot=" \ + "run load_kernel; run load_initrd; run load_dtb; " \ + "bootz ${loadaddr} ${initrd_addr}:${initrd_size} " \ + "${dtb_addr}\0" \ + "bootcmd=run mmcboot\0" \ + EXTRA_ENV_BOOT_LOGO + +#endif /* __CONFIG_H__ */
Signed-off-by: Stefan Bosch stefan_b@posteo.net
Stefan Bosch
