[U-Boot] [PATCH v5 0/2] Add board support for iMX8QXP AI_ML board
Hello,
This patchset adds initial board support for iMX8QXP AI_ML board from Einfochips. This board is one of the Consumer Edition and AI boards of the 96Boards family.
This initial supports contains following peripherals which are tested and known to work:
1. Debug serial via UART2 2. SD card 3. Ethernet
Below is the boot log from SPL to Linux kernel: ===============================================
MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@5a080000 Out: serial@5a080000 Err: serial@5a080000 Net: Warning: ethernet@5b040000 (eth0) using random MAC address - d2:46:66:cf:f5:61 eth0: ethernet@5b040000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 171 bytes read in 14 ms (11.7 KiB/s) 1: ai_ml-kernel Retrieving file: /Image 24689152 bytes read in 1055 ms (22.3 MiB/s) append: earlycon console=ttyLP2,115200 rw root=/dev/mmcblk0p2 rootfstype=ext4 init=/sbin/t Retrieving file: /imx8qxp-ai_ml.dtb 12529 bytes read in 13 ms (940.4 KiB/s) ## Flattened Device Tree blob at 83000000 Booting using the fdt blob at 0x83000000 Using Device Tree in place at 0000000083000000, end 00000000830060f0
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd042] [ 0.000000] Linux version 5.2.0-03138-gd75da80dce39 (mani@Mani-XPS-13-9360) (gcc versi9 [ 0.000000] Machine model: Einfochips i.MX8QXP AI_ML [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 32 MiB at 0x00000000fe000000 [ 0.000000] earlycon: lpuart32 at MMIO 0x000000005a080000 (options '') [ 0.000000] printk: bootconsole [lpuart32] enabled
Thanks, Mani
Note: This patchset depends on the below cleanup patches submitted: [U-Boot,1/2] arm: imx8: factor out uart init code [U-Boot,2/2] arm: imx8: don't duplicate build_info()
Changes in v5:
* Incorporated review comments from Lukasz.
Changes in v4:
* Incorporated review comments from Fabio.
Changes in v3:
* Incorporated review comments from Fabio. Major change is switching to distro_boot. * Added Reviewed-by tag from Peng Fan.
Changes in v2:
* Rebased the patches on top of following patches: [U-Boot,1/2] arm: imx8: factor out uart init code [U-Boot,2/2] arm: imx8: don't duplicate build_info()
Manivannan Sadhasivam (2): arm: dts: Add devicetree support for iMXQXP AI_ML board board: Add support for iMX8QXP AI_ML board
arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-imx8qxp-ai_ml-u-boot.dtsi | 117 +++++++++++ arch/arm/dts/fsl-imx8qxp-ai_ml.dts | 181 ++++++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 6 + board/einfochips/imx8qxp_ai_ml/Kconfig | 21 ++ board/einfochips/imx8qxp_ai_ml/MAINTAINERS | 6 + board/einfochips/imx8qxp_ai_ml/Makefile | 8 + board/einfochips/imx8qxp_ai_ml/README | 49 +++++ .../einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c | 79 ++++++++ board/einfochips/imx8qxp_ai_ml/imximage.cfg | 24 +++ board/einfochips/imx8qxp_ai_ml/spl.c | 39 ++++ configs/imx8qxp_ai_ml_defconfig | 83 ++++++++ include/configs/imx8qxp_ai_ml.h | 95 +++++++++ 13 files changed, 709 insertions(+) create mode 100644 arch/arm/dts/fsl-imx8qxp-ai_ml-u-boot.dtsi create mode 100644 arch/arm/dts/fsl-imx8qxp-ai_ml.dts create mode 100644 board/einfochips/imx8qxp_ai_ml/Kconfig create mode 100644 board/einfochips/imx8qxp_ai_ml/MAINTAINERS create mode 100644 board/einfochips/imx8qxp_ai_ml/Makefile create mode 100644 board/einfochips/imx8qxp_ai_ml/README create mode 100644 board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c create mode 100644 board/einfochips/imx8qxp_ai_ml/imximage.cfg create mode 100644 board/einfochips/imx8qxp_ai_ml/spl.c create mode 100644 configs/imx8qxp_ai_ml_defconfig create mode 100644 include/configs/imx8qxp_ai_ml.h
Add devicetree support for iMXQXP AI_ML board from Einfochips.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Lukasz Majewski lukma@denx.de --- arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-imx8qxp-ai_ml-u-boot.dtsi | 117 +++++++++++++ arch/arm/dts/fsl-imx8qxp-ai_ml.dts | 181 +++++++++++++++++++++ 3 files changed, 299 insertions(+) create mode 100644 arch/arm/dts/fsl-imx8qxp-ai_ml-u-boot.dtsi create mode 100644 arch/arm/dts/fsl-imx8qxp-ai_ml.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e6680e5e98..7834a158da 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -614,6 +614,7 @@ dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qm-apalis.dtb \ fsl-imx8qm-mek.dtb \ + fsl-imx8qxp-ai_ml.dtb \ fsl-imx8qxp-colibri.dtb \ fsl-imx8qxp-mek.dtb
diff --git a/arch/arm/dts/fsl-imx8qxp-ai_ml-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-ai_ml-u-boot.dtsi new file mode 100644 index 0000000000..3ca53bb945 --- /dev/null +++ b/arch/arm/dts/fsl-imx8qxp-ai_ml-u-boot.dtsi @@ -0,0 +1,117 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 Linaro Ltd. + */ + +&{/imx8qx-pm} { + + u-boot,dm-spl; +}; + +&mu { + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&pd_lsio { + u-boot,dm-spl; +}; + +&pd_lsio_gpio0 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio1 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio2 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio3 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio4 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio5 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio6 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio7 { + u-boot,dm-spl; +}; + +&pd_conn { + u-boot,dm-spl; +}; + +&pd_conn_sdch0 { + u-boot,dm-spl; +}; + +&pd_conn_sdch1 { + u-boot,dm-spl; +}; + +&pd_conn_sdch2 { + u-boot,dm-spl; +}; + +&gpio0 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&gpio6 { + u-boot,dm-spl; +}; + +&gpio7 { + u-boot,dm-spl; +}; + +&lpuart2 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/fsl-imx8qxp-ai_ml.dts b/arch/arm/dts/fsl-imx8qxp-ai_ml.dts new file mode 100644 index 0000000000..aa85caaff5 --- /dev/null +++ b/arch/arm/dts/fsl-imx8qxp-ai_ml.dts @@ -0,0 +1,181 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Einfochips + * Copyright 2019 Linaro Ltd. + */ + +/dts-v1/; + +#include "fsl-imx8qxp.dtsi" +#include "fsl-imx8qxp-ai_ml-u-boot.dtsi" + +/ { + model = "Einfochips i.MX8QXP AI_ML"; + compatible = "einfochips,imx8qxp-ai_ml", "fsl,imx8qxp"; + + chosen { + bootargs = "console=ttyLP2,115200 earlycon=lpuart32,0x5a080000,115200"; + stdout-path = &lpuart2; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x00000000 0x80000000 0 0x80000000>; + }; +}; + +&lpuart0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart0>; + status = "okay"; +}; + +&lpuart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart1>; + status = "okay"; +}; + +&lpuart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart2>; + status = "okay"; +}; + +&lpuart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart3>; + status = "okay"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii"; + phy-handle = <ðphy0>; + fsl,ar8031-phy-fixup; + fsl,magic-packet; + phy-reset-gpios = <&gpio4 14 GPIO_ACTIVE_LOW>; + phy-reset-duration = <10>; + phy-reset-post-delay = <150>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; + }; +}; + +/* LS-I2C1 */ +&i2c1 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpi2c1>; + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + bus-width = <4>; + no-sd; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + bus-width = <4>; + cd-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&iomuxc { + pinctrl_fec1: fec1grp { + fsl,pins = < + SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB0_PAD 0x000014a0 + SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB1_PAD 0x000014a0 + SC_P_ENET0_MDC_CONN_ENET0_MDC 0x06000020 + SC_P_ENET0_MDIO_CONN_ENET0_MDIO 0x06000020 + SC_P_ENET0_RGMII_TX_CTL_CONN_ENET0_RGMII_TX_CTL 0x06000020 + SC_P_ENET0_RGMII_TXC_CONN_ENET0_RGMII_TXC 0x06000020 + SC_P_ENET0_RGMII_TXD0_CONN_ENET0_RGMII_TXD0 0x06000020 + SC_P_ENET0_RGMII_TXD1_CONN_ENET0_RGMII_TXD1 0x06000020 + SC_P_ENET0_RGMII_TXD2_CONN_ENET0_RGMII_TXD2 0x06000020 + SC_P_ENET0_RGMII_TXD3_CONN_ENET0_RGMII_TXD3 0x06000020 + SC_P_ENET0_RGMII_RXC_CONN_ENET0_RGMII_RXC 0x06000020 + SC_P_ENET0_RGMII_RX_CTL_CONN_ENET0_RGMII_RX_CTL 0x06000020 + SC_P_ENET0_RGMII_RXD0_CONN_ENET0_RGMII_RXD0 0x06000020 + SC_P_ENET0_RGMII_RXD1_CONN_ENET0_RGMII_RXD1 0x06000020 + SC_P_ENET0_RGMII_RXD2_CONN_ENET0_RGMII_RXD2 0x06000020 + SC_P_ENET0_RGMII_RXD3_CONN_ENET0_RGMII_RXD3 0x06000020 + >; + }; + + pinctrl_lpi2c1: lpi2c1grp { + fsl,pins = < + SC_P_USB_SS3_TC1_ADMA_I2C1_SCL 0x06000021 + SC_P_USB_SS3_TC3_ADMA_I2C1_SDA 0x06000021 + >; + }; + + pinctrl_lpuart0: lpuart0grp { + fsl,pins = < + SC_P_UART0_RX_ADMA_UART0_RX 0X06000020 + SC_P_UART0_TX_ADMA_UART0_TX 0X06000020 + >; + }; + + pinctrl_lpuart1: lpuart1grp { + fsl,pins = < + SC_P_UART1_RX_ADMA_UART1_RX 0X06000020 + SC_P_UART1_TX_ADMA_UART1_TX 0X06000020 + >; + }; + + pinctrl_lpuart2: lpuart2grp { + fsl,pins = < + SC_P_UART2_RX_ADMA_UART2_RX 0X06000020 + SC_P_UART2_TX_ADMA_UART2_TX 0X06000020 + >; + }; + + pinctrl_lpuart3: lpuart3grp { + fsl,pins = < + SC_P_FLEXCAN2_RX_ADMA_UART3_RX 0X06000020 + SC_P_FLEXCAN2_TX_ADMA_UART3_TX 0X06000020 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000021 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000021 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000021 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000021 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000021 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000021 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000021 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000021 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000021 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000021 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000021 + >; + }; +};
Add devicetree support for iMXQXP AI_ML board from Einfochips. Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Lukasz Majewski lukma@denx.de
Best regards, Stefano Babic
This commit adds initial board support for iMX8QXP AI_ML board from Einfochips. This board is one of the 96Boards Consumer Edition and AI boards of the 96Boards family based on i.MX8QXP SoC from NXP/Freescale.
More information about this board can be found in arrow website: https://www.arrow.com/en/products/imx8-ai-ml/arrow-development-tools
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8/Kconfig | 6 ++ board/einfochips/imx8qxp_ai_ml/Kconfig | 21 ++++ board/einfochips/imx8qxp_ai_ml/MAINTAINERS | 6 ++ board/einfochips/imx8qxp_ai_ml/Makefile | 8 ++ board/einfochips/imx8qxp_ai_ml/README | 49 ++++++++++ .../einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c | 79 +++++++++++++++ board/einfochips/imx8qxp_ai_ml/imximage.cfg | 24 +++++ board/einfochips/imx8qxp_ai_ml/spl.c | 39 ++++++++ configs/imx8qxp_ai_ml_defconfig | 83 ++++++++++++++++ include/configs/imx8qxp_ai_ml.h | 95 +++++++++++++++++++ 10 files changed, 410 insertions(+) create mode 100644 board/einfochips/imx8qxp_ai_ml/Kconfig create mode 100644 board/einfochips/imx8qxp_ai_ml/MAINTAINERS create mode 100644 board/einfochips/imx8qxp_ai_ml/Makefile create mode 100644 board/einfochips/imx8qxp_ai_ml/README create mode 100644 board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c create mode 100644 board/einfochips/imx8qxp_ai_ml/imximage.cfg create mode 100644 board/einfochips/imx8qxp_ai_ml/spl.c create mode 100644 configs/imx8qxp_ai_ml_defconfig create mode 100644 include/configs/imx8qxp_ai_ml.h
diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index bbe323d5ca..bb877055f8 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -37,6 +37,11 @@ config TARGET_COLIBRI_IMX8X select BOARD_LATE_INIT select IMX8QXP
+config TARGET_IMX8QXP_AI_ML + bool "Support i.MX8QXP AI_ML board" + select BOARD_EARLY_INIT_F + select IMX8QXP + config TARGET_IMX8QM_MEK bool "Support i.MX8QM MEK board" select BOARD_LATE_INIT @@ -49,6 +54,7 @@ config TARGET_IMX8QXP_MEK
endchoice
+source "board/einfochips/imx8qxp_ai_ml/Kconfig" source "board/freescale/imx8qm_mek/Kconfig" source "board/freescale/imx8qxp_mek/Kconfig" source "board/toradex/apalis-imx8/Kconfig" diff --git a/board/einfochips/imx8qxp_ai_ml/Kconfig b/board/einfochips/imx8qxp_ai_ml/Kconfig new file mode 100644 index 0000000000..b6806b8859 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/Kconfig @@ -0,0 +1,21 @@ +if TARGET_IMX8QXP_AI_ML + +config SYS_BOARD + default "imx8qxp_ai_ml" + +config SYS_VENDOR + default "einfochips" + +config SYS_CONFIG_NAME + default "imx8qxp_ai_ml" + +config SYS_MALLOC_LEN + default 0x2400000 + +config ENV_SIZE + default 0x1000 + +config ENV_OFFSET + default 0x400000 + +endif diff --git a/board/einfochips/imx8qxp_ai_ml/MAINTAINERS b/board/einfochips/imx8qxp_ai_ml/MAINTAINERS new file mode 100644 index 0000000000..add0bd9431 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/MAINTAINERS @@ -0,0 +1,6 @@ +i.MX8QXP AI_ML BOARD +M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +S: Maintained +F: board/einfochips/imx8qxp_ai_ml/ +F: include/configs/imx8qxp_ai_ml.h +F: configs/imx8qxp_ai_ml_defconfig diff --git a/board/einfochips/imx8qxp_ai_ml/Makefile b/board/einfochips/imx8qxp_ai_ml/Makefile new file mode 100644 index 0000000000..e08774dc6e --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/Makefile @@ -0,0 +1,8 @@ +# +# Copyright 2019 Linaro Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx8qxp_ai_ml.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/board/einfochips/imx8qxp_ai_ml/README b/board/einfochips/imx8qxp_ai_ml/README new file mode 100644 index 0000000000..488920580f --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/README @@ -0,0 +1,49 @@ +U-Boot for the Einfochips i.MX8QXP AI_ML board + +Quick Start +=========== + +- Get and Build the ARM Trusted firmware +- Get scfw_tcm.bin and ahab-container.img +- Build U-Boot +- Flash the binary into the SD card +- Boot + +Get and Build the ARM Trusted firmware +====================================== + +$ git clone https://source.codeaurora.org/external/imx/imx-atf +$ cd imx-atf/ +$ git checkout origin/imx_4.9.88_imx8qxp_beta2 -b imx_4.9.88_imx8qxp_beta2 +$ make PLAT=imx8qxp bl31 + +Get scfw_tcm.bin and ahab-container.img +======================================= + +$ wget https://raw.githubusercontent.com/96boards-ai-ml/binaries/master/mx8qx-aiml-... +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.1.bin +$ chmod +x firmware-imx-8.1.bin +$ ./firmware-imx-8.1.bin + +Copy the following binaries to U-Boot folder: + +$ cp imx-atf/build/imx8qxp/release/bl31.bin . +$ cp firmware-imx-8.1/firmware/seco/mx8qx-ahab-container.img . + +Build U-Boot +============ + +$ make imx8qxp_ai_ml_defconfig +$ make u-boot-dtb.imx + +Flash the binary into the SD card +================================= + +Burn the u-boot-dtb.imx binary to SD card offset 32KB: + +$ sudo dd if=u-boot-dtb.imx of=/dev/sd[x] bs=1024 seek=32 + +Boot +==== + +Set Boot switch SW2: 1100. diff --git a/board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c b/board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c new file mode 100644 index 0000000000..e7dbcca16d --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c @@ -0,0 +1,79 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * Copyright 2019 Linaro Ltd. + */ + +#include <common.h> +#include <errno.h> +#include <linux/libfdt.h> +#include <environment.h> +#include <fsl_esdhc.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/imx8-pins.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + sc_pm_clock_rate_t rate = SC_80MHZ; + int ret; + + /* Set UART2 clock root to 80 MHz */ + ret = sc_pm_setup_uart(SC_R_UART_2, rate); + if (ret) + return ret; + + return 0; +} + +#if IS_ENABLED(CONFIG_FEC_MXC) +#include <miiphy.h> + +int board_phy_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif + +int checkboard(void) +{ + puts("Board: iMX8QXP AI_ML\n"); + + build_info(); + print_bootinfo(); + + return 0; +} + +int board_init(void) +{ + return 0; +} + +/* Board specific reset that is system reset */ + +void reset_cpu(ulong addr) +{ + /* TODO */ +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + return 0; +} +#endif diff --git a/board/einfochips/imx8qxp_ai_ml/imximage.cfg b/board/einfochips/imx8qxp_ai_ml/imximage.cfg new file mode 100644 index 0000000000..4fc5ade313 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/imximage.cfg @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + * + * Refer doc/README.imx8image for more details about how-to configure + * and create imx8image boot image + */ + +#define __ASSEMBLY__ + +/* Boot from SD, sector size 0x400 */ +BOOT_FROM SD 0x400 +/* SoC type IMX8QX */ +SOC_TYPE IMX8QX +/* Append seco container image */ +APPEND mx8qx-ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ +IMAGE SCU mx8qx-aiml-scfw-tcm.bin +/* Add ATF image with exec attribute */ +IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ +DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/board/einfochips/imx8qxp_ai_ml/spl.c b/board/einfochips/imx8qxp_ai_ml/spl.c new file mode 100644 index 0000000000..2e6e0741e5 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/spl.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * Copyright 2019 Linaro Ltd. + * + */ + +#include <common.h> +#include <dm.h> +#include <spl.h> +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> +#include <dm/lists.h> + +DECLARE_GLOBAL_DATA_PTR; + +void spl_board_init(void) +{ + arch_cpu_init(); + + timer_init(); + + preloader_console_init(); + + puts("Normal Boot\n"); +} + +void board_init_f(ulong dummy) +{ + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8qxp_ai_ml_defconfig b/configs/imx8qxp_ai_ml_defconfig new file mode 100644 index 0000000000..e20a0c783e --- /dev/null +++ b/configs/imx8qxp_ai_ml_defconfig @@ -0,0 +1,83 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_TARGET_IMX8QXP_AI_ML=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=4 +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/einfochips/imx8qxp_ai_ml/imximage.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_LOG=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_FAT_WRITE=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-imx8qxp-ai_ml" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPL_TINY_MEMSET=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/imx8qxp_ai_ml.h b/include/configs/imx8qxp_ai_ml.h new file mode 100644 index 0000000000..bdac710103 --- /dev/null +++ b/include/configs/imx8qxp_ai_ml.h @@ -0,0 +1,95 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + * Copyright 2019 Linaro Ltd. + */ + +#ifndef __IMX8QXP_AI_ML_H +#define __IMX8QXP_AI_ML_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_MAX_SIZE (124 * SZ_1K) +#define CONFIG_SYS_MONITOR_LEN (SZ_1K * SZ_1K) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x250 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 0 + +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x013E000 +#define CONFIG_SPL_BSS_START_ADDR 0x00128000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_4K /* 4 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x00120000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x3000 /* 12 KB */ +#define CONFIG_SERIAL_LPUART_BASE 0x5a080000 +#define CONFIG_MALLOC_F_ADDR 0x00120000 + +#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE + +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#define CONFIG_OF_SEPARATE +#endif + +#define CONFIG_REMAKE_ELF + +/* Flat Device Tree Definitions */ +#define CONFIG_OF_BOARD_SETUP + +#define CONFIG_FSL_USDHC + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=ttyLP2 earlycon\0" \ + "fdt_addr_r=0x83000000\0" \ + "kernel_addr_r=0x81000000\0" \ + "ramdisk_addr_r=0x94400000\0" \ + "scriptaddr=0x89000000\0" \ + "fdtfile=imx8qxp-ai_ml.dtb\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "image=Image\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp" \ + "\0" \ + "nfsboot=run netargs; dhcp ${loadaddr} ${image}; tftp ${fdt_addr} " \ + "imx8qxp-ai_ml/${fdt_file}; booti ${loadaddr} - ${fdt_addr}\0" \ + BOOTENV + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x80280000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_SP_ADDR 0x80200000 + +/* USDHC2 is the SD card interface */ +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_2 0x880000000 +#define PHYS_SDRAM_1_SIZE SZ_2G /* 2 GB */ +#define PHYS_SDRAM_2_SIZE 0x00000000 /* 0 GB */ + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 8000000 /* 8MHz */ + +/* Networking */ +#define CONFIG_FEC_XCV_TYPE RGMII +#define FEC_QUIRK_ENET_MAC + +#endif /* __IMX8QXP_AI_ML_H */
On Thu, Aug 15, 2019 at 01:57:23PM +0530, Manivannan Sadhasivam wrote:
Hello,
- Debug serial via UART2
- SD card
- Ethernet
Starting kernel ...
Thanks, Mani
Any update on this patchset?
Thanks, Mani
Changes in v5:
- Incorporated review comments from Lukasz.
Changes in v4:
- Incorporated review comments from Fabio.
Changes in v3:
- Incorporated review comments from Fabio. Major change is switching to distro_boot.
- Added Reviewed-by tag from Peng Fan.
Changes in v2:
- Rebased the patches on top of following patches: [U-Boot,1/2] arm: imx8: factor out uart init code [U-Boot,2/2] arm: imx8: don't duplicate build_info()
-- 2.17.1
Hello,
- SD card
- Ethernet
Starting kernel ...
Thanks, Mani
Sorry for delay. Anyway, I have applied the patch, but due to changes in other subsystems (environment, etc.) it is not built clean. Could you rebase and resend ? Thanks
Thanks, Mani
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
-- 2.17.1
Hello,
- SD card
- Ethernet
Starting kernel ...
Thanks, Mani
So you want me to just resend the board support patch? (Saw that you applied DT patch)
Thanks, Mani
Thanks, Mani
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
-- 2.17.1
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Hello,
- SD card
- Ethernet
Starting kernel ...
Thanks, Mani
Yes.
Regards, Stefano
Thanks, Mani
Thanks, Mani
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
-- 2.17.1
sbabic@denx.de
Stefano Babic
