[U-Boot] [PATCH] mc : Add support to run MC in 128 MB DDR size
ls2088, ls1088 : minimum DDR size for MC is 128 MB lx2 : minimum DDR size for MC is 256 MB
Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- drivers/net/fsl-mc/mc.c | 20 +++++++++++++++++--- include/configs/ls1088a_common.h | 2 +- include/configs/ls2080a_common.h | 2 +- include/configs/lx2160a_common.h | 2 +- 4 files changed, 20 insertions(+), 6 deletions(-)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index fa0a05d..98c57ed 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -684,7 +684,15 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) size_t mc_ram_size = mc_get_dram_block_size();
mc_ram_num_256mb_blocks = mc_ram_size / MC_RAM_SIZE_ALIGNMENT; - if (mc_ram_num_256mb_blocks < 1 || mc_ram_num_256mb_blocks > 0xff) { + + /* + * To support 128 MB DDR Size for MC + */ + if (mc_ram_num_256mb_blocks == 0) { + mc_ram_num_256mb_blocks = 0xFF; + } + + if (mc_ram_num_256mb_blocks > 0xff) { error = -EINVAL; printf("fsl-mc: ERROR: invalid MC private RAM size (%lu)\n", mc_ram_size); @@ -731,8 +739,14 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) /* * Tell MC what is the address range of the DRAM block assigned to it: */ - reg_mcfbalr = (u32)mc_ram_addr | - (mc_ram_num_256mb_blocks - 1); + if (mc_ram_num_256mb_blocks < 0xFF) { + reg_mcfbalr = (u32)mc_ram_addr | + (mc_ram_num_256mb_blocks - 1); + } else { + reg_mcfbalr = (u32)mc_ram_addr | + (mc_ram_num_256mb_blocks); + } + out_le32(&mc_ccsr_regs->reg_mcfbalr, reg_mcfbalr); out_le32(&mc_ccsr_regs->reg_mcfbahr, (u32)(mc_ram_addr >> 32)); diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 89133c2..1509292 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -154,7 +154,7 @@ unsigned long long get_qixis_addr(void); */
#if defined(CONFIG_FSL_MC_ENET) -#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) +#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (128UL * 1024 * 1024) #endif /* Command line configuration */ #define CONFIG_CMD_CACHE diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index ab38981..7c1d35b 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -159,7 +159,7 @@ unsigned long long get_qixis_addr(void); * 512MB aligned, so the min size to hide is 512MB. */ #ifdef CONFIG_FSL_MC_ENET -#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) +#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (128UL * 1024 * 1024) #endif
/* Command line configuration */ diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 0f1a621..c4bbe96 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -102,7 +102,7 @@ * 512MB aligned, so the min size to hide is 512MB. */ #ifdef CONFIG_FSL_MC_ENET -#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) +#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (256UL * 1024 * 1024) #endif
/* I2C bus multiplexer */
-----Original Message----- From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Sent: Tuesday, February 12, 2019 2:44 PM To: u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Subject: [PATCH] mc : Add support to run MC in 128 MB DDR size
Ashish: Rephrase to "Reduce MC memory size to 128M" from the above it sound like system DDR is 128MB
0xff) {
Ashish: How does the MC grow now, wrt to MC base ?. Earlier it was 2 blocks of 256 up and rest down. Considering MC base alignment is 512. 256 MB is always wasted from top of the memory, now since the minimum block is 128MB
- if (mc_ram_num_256mb_blocks == 0) {
- if (mc_ram_num_256mb_blocks > 0xff) { error = -EINVAL; printf("fsl-mc: ERROR: invalid MC private RAM size (%lu)\n", mc_ram_size);
- if (mc_ram_num_256mb_blocks < 0xFF) {
- } else {
- out_le32(&mc_ccsr_regs->reg_mcfbalr, reg_mcfbalr); out_le32(&mc_ccsr_regs->reg_mcfbahr, (u32)(mc_ram_addr >> 32));
- 512MB aligned, so the min size to hide is 512MB.
1.9.1
-----Original Message----- From: Ashish Kumar Sent: Tuesday, February 12, 2019 10:12 AM To: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; u- boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Subject: RE: [PATCH] mc : Add support to run MC in 128 MB DDR size
0xff) {
No changes done in this respect, it is same as before depending on MC size. For 128 MB, we are reserving only 128 M up and rest down.
We are reserving only DDR memory according to the size of MC, so if it is 128 M, then we are reserving only 128 M (surely, base address is 512 MB aligned). Rest DDR memory is available for uboot to use and is marked as free.
- } else {
(512UL *
(128UL *
(512UL *
(128UL *
1024 * 1024) #endif
#endif
1.9.1
"memmap" command prints uefi-specific memory map information. => efi memmap Type Start End Attributes ================ ================ ================ ========== CONVENTIONAL 0000000040000000-000000007de27000 WB RUNTIME DATA 000000007de27000-000000007de28000 WB|RT RESERVED 000000007de28000-000000007de2a000 WB RUNTIME DATA 000000007de2a000-000000007de2b000 WB|RT RESERVED 000000007de2b000-000000007de2c000 WB RUNTIME DATA 000000007de2c000-000000007de2d000 WB|RT LOADER DATA 000000007de2d000-000000007ff37000 WB RUNTIME CODE 000000007ff37000-000000007ff38000 WB|RT LOADER DATA 000000007ff38000-0000000080000000 WB
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/efidebug.c | 127 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 126 insertions(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index e3a2d09..5072a7b 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -335,6 +335,127 @@ static int do_efi_show_images(cmd_tbl_t *cmdtp, int flag, return CMD_RET_SUCCESS; }
+static const char * const efi_mem_type_string[] = { + [EFI_RESERVED_MEMORY_TYPE] = "RESERVED", + [EFI_LOADER_CODE] = "LOADER CODE", + [EFI_LOADER_DATA] = "LOADER DATA", + [EFI_BOOT_SERVICES_CODE] = "BOOT CODE", + [EFI_BOOT_SERVICES_DATA] = "BOOT DATA", + [EFI_RUNTIME_SERVICES_CODE] = "RUNTIME CODE", + [EFI_RUNTIME_SERVICES_DATA] = "RUNTIME DATA", + [EFI_CONVENTIONAL_MEMORY] = "CONVENTIONAL", + [EFI_UNUSABLE_MEMORY] = "UNUSABLE MEM", + [EFI_ACPI_RECLAIM_MEMORY] = "ACPI RECLAIM MEM", + [EFI_ACPI_MEMORY_NVS] = "ACPI NVS", + [EFI_MMAP_IO] = "IO", + [EFI_MMAP_IO_PORT] = "IO PORT", + [EFI_PAL_CODE] = "PAL", +}; + +static const struct efi_mem_attrs { + const u64 bit; + const char *text; +} efi_mem_attrs[] = { + {EFI_MEMORY_UC, "UC"}, + {EFI_MEMORY_UC, "UC"}, + {EFI_MEMORY_WC, "WC"}, + {EFI_MEMORY_WT, "WT"}, + {EFI_MEMORY_WB, "WB"}, + {EFI_MEMORY_UCE, "UCE"}, + {EFI_MEMORY_WP, "WP"}, + {EFI_MEMORY_RP, "RP"}, + {EFI_MEMORY_XP, "WP"}, + {EFI_MEMORY_NV, "NV"}, + {EFI_MEMORY_MORE_RELIABLE, "REL"}, + {EFI_MEMORY_RO, "RO"}, + {EFI_MEMORY_RUNTIME, "RT"}, +}; + +/** + * print_memory_attributes() - print memory map attributes + * @attributes: Attribute value + * + * Print memory map attributes + */ +static void print_memory_attributes(u64 attributes) +{ + int sep, i; + + for (sep = 0, i = 0; i < ARRAY_SIZE(efi_mem_attrs); i++) + if (attributes & efi_mem_attrs[i].bit) { + if (sep) { + putc('|'); + } else { + putc(' '); + sep = 1; + } + puts(efi_mem_attrs[i].text); + } +} + +#define EFI_PHYS_ADDR_WIDTH (int)(sizeof(efi_physical_addr_t) * 2) + +/** + * do_efi_show_memmap() - show UEFI memory map + * + * @cmdtp: Command table + * @flag: Command flag + * @argc: Number of arguments + * @argv: Argument array + * Return: CMD_RET_SUCCESS on success, CMD_RET_RET_FAILURE on failure + * + * Implement efidebug "memmap" sub-command. + * Show UEFI memory map. + */ +static int do_efi_show_memmap(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + struct efi_mem_desc *memmap = NULL, *map; + efi_uintn_t map_size = 0; + const char *type; + int i; + efi_status_t ret; + + ret = EFI_CALL(BS->get_memory_map(&map_size, memmap, NULL, NULL, NULL)); + if (ret == EFI_BUFFER_TOO_SMALL) { + map_size += sizeof(struct efi_mem_desc); /* for my own */ + ret = EFI_CALL(BS->allocate_pool(EFI_LOADER_DATA, + map_size, (void *)&memmap)); + if (ret != EFI_SUCCESS) + return CMD_RET_FAILURE; + ret = EFI_CALL(BS->get_memory_map(&map_size, memmap, + NULL, NULL, NULL)); + } + if (ret != EFI_SUCCESS) { + EFI_CALL(BS->free_pool(memmap)); + return CMD_RET_FAILURE; + } + + printf("Type Start%.*s End%.*s Attributes\n", + EFI_PHYS_ADDR_WIDTH - 5, spc, EFI_PHYS_ADDR_WIDTH - 3, spc); + printf("================ %.*s %.*s ==========\n", + EFI_PHYS_ADDR_WIDTH, sep, EFI_PHYS_ADDR_WIDTH, sep); + for (i = 0, map = memmap; i < map_size / sizeof(*map); map++, i++) { + if (map->type < EFI_MAX_MEMORY_TYPE) + type = efi_mem_type_string[map->type]; + else + type = "(unknown)"; + + printf("%-16s %.*llx-%.*llx", type, + EFI_PHYS_ADDR_WIDTH, + map->physical_start, + EFI_PHYS_ADDR_WIDTH, + map->physical_start + map->num_pages * EFI_PAGE_SIZE); + + print_memory_attributes(map->attribute); + putc('\n'); + } + + EFI_CALL(BS->free_pool(memmap)); + + return CMD_RET_SUCCESS; +} + /** * do_efi_boot_add() - set UEFI load option * @@ -845,6 +966,8 @@ static cmd_tbl_t cmd_efidebug_sub[] = { "", ""), U_BOOT_CMD_MKENT(images, CONFIG_SYS_MAXARGS, 1, do_efi_show_images, "", ""), + U_BOOT_CMD_MKENT(memmap, CONFIG_SYS_MAXARGS, 1, do_efi_show_memmap, + "", ""), };
/** @@ -911,7 +1034,9 @@ static char efidebug_help_text[] = "efidebug dh\n" " - show uefi handles\n" "efidebug images\n" - " - show loaded images\n"; + " - show loaded images\n" + "efidebug memmap\n" + " - show uefi memory map\n"; #endif
U_BOOT_CMD(
Please ignore, it is sent by mistake.
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Meenakshi Aggarwal Sent: Wednesday, February 27, 2019 2:41 PM To: u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [U-Boot] [PATCH 1/2] cmd: efidebug: add memmap command
- [EFI_RESERVED_MEMORY_TYPE] = "RESERVED",
- [EFI_LOADER_CODE] = "LOADER CODE",
- [EFI_LOADER_DATA] = "LOADER DATA",
- [EFI_BOOT_SERVICES_CODE] = "BOOT CODE",
- [EFI_BOOT_SERVICES_DATA] = "BOOT DATA",
- [EFI_RUNTIME_SERVICES_CODE] = "RUNTIME CODE",
- [EFI_RUNTIME_SERVICES_DATA] = "RUNTIME DATA",
- [EFI_CONVENTIONAL_MEMORY] = "CONVENTIONAL",
- [EFI_UNUSABLE_MEMORY] = "UNUSABLE MEM",
- [EFI_ACPI_RECLAIM_MEMORY] = "ACPI RECLAIM MEM",
- [EFI_ACPI_MEMORY_NVS] = "ACPI NVS",
- [EFI_MMAP_IO] = "IO",
- [EFI_MMAP_IO_PORT] = "IO PORT",
- [EFI_PAL_CODE] = "PAL",
- const u64 bit;
- const char *text;
- {EFI_MEMORY_UC, "UC"},
- {EFI_MEMORY_WC, "WC"},
- {EFI_MEMORY_WT, "WT"},
- {EFI_MEMORY_WB, "WB"},
- {EFI_MEMORY_UCE, "UCE"},
- {EFI_MEMORY_WP, "WP"},
- {EFI_MEMORY_RP, "RP"},
- {EFI_MEMORY_XP, "WP"},
- {EFI_MEMORY_NV, "NV"},
- {EFI_MEMORY_MORE_RELIABLE, "REL"},
- {EFI_MEMORY_RO, "RO"},
- {EFI_MEMORY_RUNTIME, "RT"},
- print_memory_attributes() - print memory map attributes
- @attributes: Attribute value
- Print memory map attributes
+static void print_memory_attributes(u64 attributes) {
- int sep, i;
- for (sep = 0, i = 0; i < ARRAY_SIZE(efi_mem_attrs); i++)
if (sep) {
putc('|');
} else {
putc(' ');
sep = 1;
- do_efi_show_memmap() - show UEFI memory map
- @cmdtp: Command table
- @flag: Command flag
- @argc: Number of arguments
- @argv: Argument array
- Return: CMD_RET_SUCCESS on success, CMD_RET_RET_FAILURE on
failure
- Implement efidebug "memmap" sub-command.
- Show UEFI memory map.
int argc, char * const argv[]) {
- struct efi_mem_desc *memmap = NULL, *map;
- efi_uintn_t map_size = 0;
- const char *type;
- int i;
- efi_status_t ret;
- ret = EFI_CALL(BS->get_memory_map(&map_size, memmap, NULL,
NULL, NULL));
- if (ret == EFI_BUFFER_TOO_SMALL) {
map_size, (void
*)&memmap));
NULL, NULL, NULL));
- if (ret != EFI_SUCCESS) {
- printf("Type Start%.*s End%.*s Attributes\n",
- printf("================ %.*s %.*s ==========\n",
- for (i = 0, map = memmap; i < map_size / sizeof(*map); map++, i++) {
else
type = "(unknown)";
putc('\n');
- EFI_CALL(BS->free_pool(memmap));
- return CMD_RET_SUCCESS;
- do_efi_boot_add() - set UEFI load option
- U_BOOT_CMD_MKENT(memmap, CONFIG_SYS_MAXARGS, 1,
do_efi_show_memmap,
- "efidebug memmap\n"
- " - show uefi memory map\n";
#endif
U_BOOT_CMD(
1.9.1
U-Boot mailing list U-Boot@lists.denx.de https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.de nx.de%2Flistinfo%2Fu- boot&data=02%7C01%7Cmeenakshi.aggarwal%40nxp.com%7Cf6d2c8270 9004cdb237708d69c634a7f%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C 0%7C636868347604262106&sdata=5uxeibcyDGCCEu1yYYp3gXqz8huNvnoc GqFVj5lumd8%3D&reserved=0
ls2088, ls1088 : minimum MC Memory size is 128 MB lx2 : minimum MC memory size is 256 MB
Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- drivers/net/fsl-mc/mc.c | 23 +++++++++++++++++++---- include/configs/ls1088a_common.h | 2 +- include/configs/ls2080a_common.h | 2 +- include/configs/lx2160a_common.h | 2 +- 4 files changed, 22 insertions(+), 7 deletions(-)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index a51b8a4..a56edc3 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -28,6 +28,7 @@ #define MC_MEM_SIZE_ENV_VAR "mcmemsize" #define MC_BOOT_TIMEOUT_ENV_VAR "mcboottimeout" #define MC_BOOT_ENV_VAR "mcinitcmd" +#define MC_DRAM_BLOCK_DEFAULT_SIZE (512UL * 1024 * 1024)
DECLARE_GLOBAL_DATA_PTR; static int mc_memset_resv_ram; @@ -680,7 +681,8 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) size_t mc_ram_size = mc_get_dram_block_size();
mc_ram_num_256mb_blocks = mc_ram_size / MC_RAM_SIZE_ALIGNMENT; - if (mc_ram_num_256mb_blocks < 1 || mc_ram_num_256mb_blocks > 0xff) { + + if (mc_ram_num_256mb_blocks >= 0xff) { error = -EINVAL; printf("fsl-mc: ERROR: invalid MC private RAM size (%lu)\n", mc_ram_size); @@ -688,6 +690,13 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) }
/* + * To support 128 MB DDR Size for MC + */ + if (mc_ram_num_256mb_blocks == 0) { + mc_ram_num_256mb_blocks = 0xFF; + } + + /* * Management Complex cores should be held at reset out of POR. * U-Boot should be the first software to touch MC. To be safe, * we reset all cores again by setting GCR1 to 0. It doesn't do @@ -727,8 +736,14 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) /* * Tell MC what is the address range of the DRAM block assigned to it: */ - reg_mcfbalr = (u32)mc_ram_addr | - (mc_ram_num_256mb_blocks - 1); + if (mc_ram_num_256mb_blocks < 0xFF) { + reg_mcfbalr = (u32)mc_ram_addr | + (mc_ram_num_256mb_blocks - 1); + } else { + reg_mcfbalr = (u32)mc_ram_addr | + (mc_ram_num_256mb_blocks); + } + out_le32(&mc_ccsr_regs->reg_mcfbalr, reg_mcfbalr); out_le32(&mc_ccsr_regs->reg_mcfbahr, (u32)(mc_ram_addr >> 32)); @@ -878,7 +893,7 @@ unsigned long mc_get_dram_block_size(void) "' environment variable: %lu\n", dram_block_size);
- dram_block_size = CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE; + dram_block_size = MC_DRAM_BLOCK_DEFAULT_SIZE; } }
diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index b663937..fa9c8c8 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -151,7 +151,7 @@ unsigned long long get_qixis_addr(void); */
#if defined(CONFIG_FSL_MC_ENET) -#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) +#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (128UL * 1024 * 1024) #endif /* Command line configuration */ #define CONFIG_CMD_CACHE diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 0a6c90d..682f068 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -155,7 +155,7 @@ unsigned long long get_qixis_addr(void); * 512MB aligned, so the min size to hide is 512MB. */ #ifdef CONFIG_FSL_MC_ENET -#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) +#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (128UL * 1024 * 1024) #endif
/* Command line configuration */ diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 4b5608b..637619c 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -100,7 +100,7 @@ * 512MB aligned, so the min size to hide is 512MB. */ #ifdef CONFIG_FSL_MC_ENET -#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) +#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (256UL * 1024 * 1024) #endif
Hello Joe,
in patchwork I have reassigned the patch https://patchwork.ozlabs.org/patch/1048656/ to you.
The first patch of the series received a comment by the author: "Please ignore, it is sent by mistake." So I set it to superseeded.
Best regards
Heinrich
On Fri, Mar 1, 2019 at 2:48 PM Heinrich Schuchardt xypron.debian@gmx.de wrote:
Hello Joe,
Thanks for the heads up! -Joe
Best regards
Heinrich _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
On Tue, Feb 26, 2019 at 9:26 PM Meenakshi Aggarwal meenakshi.aggarwal@nxp.com wrote:
-----Original Message----- From: Joe Hershberger joe.hershberger@gmail.com Sent: Saturday, March 2, 2019 2:56 AM To: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Cc: u-boot u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: Re: [U-Boot] [PATCH 2/2] mc : Reduce MC memory size to 128M
Applied u-boot-fsl-qoriq, awaiting upstream
--pk
Hi Meenakshi,
https://patchwork.ozlabs.org/patch/1048656/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
participants (6)
Ashish Kumar
Joe Hershberger
Joe Hershberger
Meenakshi Aggarwal
Prabhakar Kushwaha
