[U-Boot] tps6586x: staticize funtions
Make funtions static which are locally used in file.
Signed-off-by: Manish Badarkhe badarkhe.manish@gmail.com --- :100644 100644 704c243... d29d969... M drivers/power/tps6586x.c drivers/power/tps6586x.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/tps6586x.c b/drivers/power/tps6586x.c index 704c243..d29d969 100644 --- a/drivers/power/tps6586x.c +++ b/drivers/power/tps6586x.c @@ -32,7 +32,7 @@ enum { };
#define MAX_I2C_RETRY 3 -int tps6586x_read(int reg) +static int tps6586x_read(int reg) { int i; uchar data; @@ -61,7 +61,7 @@ exit: return retval; }
-int tps6586x_write(int reg, uchar *data, uint len) +static int tps6586x_write(int reg, uchar *data, uint len) { int i; int retval = -1;
Hi Tom,
On Thu, Apr 24, 2014 at 8:55 AM, Manish Badarkhe badarkhe.manish@gmail.com wrote:
-int tps6586x_write(int reg, uchar *data, uint len) +static int tps6586x_write(int reg, uchar *data, uint len) { int i; int retval = -1; -- 1.7.10.4
Please provide your comments on this patch.
Thanks Manish Badarkhe
Manish Badarkhe
