[PATCH v2] tools: Add script to update git subtree projects
Recently we are introducing multiple git subtree projects and it is the right time to have a universal script to update various subtrees and replace the dts/update-dts-subtree.sh.
update-subtree.sh is a wrapper of git subtree commands.
Usage: From U-Boot top directory, run $ ./tools/update-subtree.sh pull <subtree-name> <release-tag> for pulling a tag from the upstream. Or run $ ./tools/update-subtree.sh pick <subtree-name> <commit-id> for cherry-pick a commit from the upstream.
Currently <subtree-name> supports dts, mbedtls and lwip.
Signed-off-by: Raymond Mao raymond.mao@linaro.org --- Changes in v2 - Refactored the script. - Update the control doc.
doc/develop/devicetree/control.rst | 8 +-- dts/update-dts-subtree.sh | 48 ----------------- tools/update-subtree.sh | 86 ++++++++++++++++++++++++++++++ 3 files changed, 90 insertions(+), 52 deletions(-) delete mode 100755 dts/update-dts-subtree.sh create mode 100755 tools/update-subtree.sh
diff --git a/doc/develop/devicetree/control.rst b/doc/develop/devicetree/control.rst index ca4fb0b5b10..211f7e4909c 100644 --- a/doc/develop/devicetree/control.rst +++ b/doc/develop/devicetree/control.rst @@ -96,12 +96,12 @@ sync the `dts/upstream/` subtree from the devicetree-rebasing repo whenever the next branch opens (refer: :doc:`../release_cycle`) with the latest mainline Linux kernel release. To sync the `dts/upstream/` subtree, run::
- ./dts/update-dts-subtree.sh pull <devicetree-rebasing-release-tag> + ./tools/update-subtree.sh pull dts <devicetree-rebasing-release-tag>
If required it is also possible to cherry-pick fixes from the devicetree-rebasing repository prior to next sync, usage::
- ./dts/update-dts-subtree.sh pick <devicetree-rebasing-commit-id> + ./tools/update-subtree.sh pick dts <devicetree-rebasing-commit-id>
Configuration @@ -116,8 +116,8 @@ However, if `dts/upstream/` hasn't yet received devicetree source file for your newly added board support then one option is that you can add the corresponding devicetree source file as `arch/<arch>/dts/<name>.dts`. To select that add `# CONFIG_OF_UPSTREAM is not set` and set `DEFAULT_DEVICE_TREE=<name>` when -prompted by Kconfig. Another option is that you can use use the "pick" option of -`dts/update-dts-subtree.sh` mentioned above to bring in the commits that you +prompted by Kconfig. Another option is that you can use the "pick" option of +`tools/update-subtree.sh` mentioned above to bring in the commits that you need.
This should include your CPU or SoC's devicetree file. On top of that any U-Boot diff --git a/dts/update-dts-subtree.sh b/dts/update-dts-subtree.sh deleted file mode 100755 index a57b78a41d3..00000000000 --- a/dts/update-dts-subtree.sh +++ /dev/null @@ -1,48 +0,0 @@ -#!/bin/sh -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright 2024 Linaro Ltd. -# -# Usage: from the top level U-Boot source tree, run: -# $ ./dts/update-dts-subtree.sh pull <release-tag> -# $ ./dts/update-dts-subtree.sh pick <commit-id> -# -# The script will pull changes from devicetree-rebasing repo into U-Boot -# as a subtree located as <U-Boot>/dts/upstream sub-directory. It will -# automatically create a squash/merge commit listing the commits imported. - -set -e - -merge_commit_msg=$(cat << EOF -Subtree merge tag '$2' of devicetree-rebasing repo [1] into dts/upstream - -[1] https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... -EOF -) - -remote_add_and_fetch() { - if ! git remote get-url devicetree-rebasing 2>/dev/null - then - echo "Warning: Script automatically adds new git remote via:" - echo " git remote add devicetree-rebasing \" - echo " https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi..." - git remote add devicetree-rebasing \ - https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... - fi - git fetch devicetree-rebasing master -} - -if [ "$1" = "pull" ] -then - remote_add_and_fetch - git subtree pull --prefix dts/upstream devicetree-rebasing \ - "$2" --squash -m "${merge_commit_msg}" -elif [ "$1" = "pick" ] -then - remote_add_and_fetch - git cherry-pick -x --strategy=subtree -Xsubtree=dts/upstream/ "$2" -else - echo "usage: $0 <op> <ref>" - echo " <op> pull or pick" - echo " <ref> release tag [pull] or commit id [pick]" -fi diff --git a/tools/update-subtree.sh b/tools/update-subtree.sh new file mode 100755 index 00000000000..5946aa1a9e2 --- /dev/null +++ b/tools/update-subtree.sh @@ -0,0 +1,86 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2024 Linaro Limited +# Author: Raymond Mao raymond.mao@linaro.org +# +# Usage: from the top level U-Boot source tree, run: +# $ ./tools/update-subtree.sh pull <subtree-name> <release-tag> +# Or: +# $ ./tools/update-subtree.sh pick <subtree-name> <commit-id> +# +# The script will pull changes from subtree repo into U-Boot. +# It will automatically create a squash/merge commit listing the commits +# imported. + +set -e + +print_usage() { + echo "usage: $0 <op> <subtree-name> <ref>" + echo " <op> pull or pick" + echo " <subtree-name> mbedtls or dts or lwip" + echo " <ref> release tag [pull] or commit id [pick]" +} + +if [ $# -ne 3 ]; then + print_usage + exit 1 +fi + +op=$1 +subtree_name=$2 +ref=$3 + +set_params() { + case "$subtree_name" in + mbedtls) + path=lib/mbedtls/external/mbedtls + repo_url=https://github.com/Mbed-TLS/mbedtls.git + remote_name="mbedtls_upstream" + ;; + dts) + path=dts/upstream + repo_url=https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... + remote_name="devicetree-rebasing" + ;; + lwip) + path=lib/lwip/lwip + repo_url=https://git.savannah.gnu.org/git/lwip.git + remote_name="lwip_upstream" + ;; + *) + echo "Invalid subtree name: $subtree_name" + print_usage + exit 1 + esac +} + +set_params + +merge_commit_msg=$(cat << EOF +Subtree merge tag '$ref' of $subtree_name repo [1] into $path + +[1] $repo_url +EOF +) + +remote_add_and_fetch() { + if [ -z "$(git remote get-url $remote_name 2>/dev/null)" ]; then + echo "Warning: Script automatically adds new git remote via:" + echo " git remote add $remote_name \" + echo " $repo_url" + git remote add $remote_name $repo_url + fi + git fetch $remote_name master +} + +if [ "$op" = "pull" ]; then + remote_add_and_fetch + git subtree pull --prefix $path $remote_name "$ref" --squash -m "$merge_commit_msg" +elif [ "$op" = "pick" ]; then + remote_add_and_fetch + git cherry-pick -x --strategy=subtree -Xsubtree=$path/ "$ref" +else + print_usage + exit 1 +fi
Changes in v2
Acked-by: Jerome Forissier jerome.forissier@linaro.org
Changes in v2
- ./tools/update-subtree.sh pull dts <devicetree-rebasing-release-tag>
- ./tools/update-subtree.sh pick dts <devicetree-rebasing-commit-id>
-set -e
- then
echo " git remote add devicetree-rebasing \\"
echo " https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git"
- fi
-else
+set -e
+print_usage() {
- echo "usage: $0 <op> <subtree-name> <ref>"
- echo " <subtree-name> mbedtls or dts or lwip"
- print_usage
- exit 1
+fi
+set_params() {
- case "$subtree_name" in
mbedtls)
dts)
path=dts/upstream
repo_url=https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git
lwip)
path=lib/lwip/lwip
print_usage
exit 1
- esac
+set_params
- if [ -z "$(git remote get-url $remote_name 2>/dev/null)" ]; then
echo " git remote add $remote_name \\"
echo " $repo_url"
- fi
- git fetch $remote_name master
- git subtree pull --prefix $path $remote_name "$ref" --squash -m "$merge_commit_msg"
- git cherry-pick -x --strategy=subtree -Xsubtree=$path/ "$ref"
+else
- print_usage
- exit 1
+fi
2.25.1
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Hi Raymond,
Changes in v2
Configuration
-set -e
- then
- fi
-else
We have scripts/ and tools/ directories, this being a shell script I would have intuitively added it to scripts/. So my question is, what's the difference between those two directories :) ?
+set -e
+print_usage() {
I think pulls are supposed to be done and sent to the ML by maintainers only? At least that's what we're supposed to do for the dts/upstream/ directory AFAIR. Is it the same for mbedtls and lwip? If so, maybe explicit this in the usage that only maintainers are supposed to run this script with that option? And if you need to do it, ask the maintainers to do it for you? Does this make sense?
- print_usage
- exit 1
+fi
+set_params() {
mbedtls)
dts)
path=dts/upstream
lwip)
path=lib/lwip/lwip
print_usage
exit 1
- esac
+set_params
I would recommend adding at the very least the path of the tools used to generate this merge commit (so ./tools/update-subtree.sh or maybe just $0?) or maybe even the full command line that was used to do this merge?
echo " $repo_url"
- fi
Should we add -s there too? (or --signoff)
Those are just questions, no blocker for me.
Cheers, Quentin
Hi Quentin,
On Tue, 23 Jul 2024 at 03:16, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Raymond,
Changes in v2
mainline
Configuration
corresponding
add `#
when
option of
that you
option of
you
need.
any U-Boot
imported.
-set -e
-[1]
-EOF -)
- then
echo "
https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... "
- fi
-else
Good question. Personally I think 'scripts' are for those scripts needed
by other components and 'tools' are for the general purpose utilities (not limited to scripts). That is the reason I prefer 'tools'.
@@ -0,0 +1,86 @@
+set -e
+print_usage() {
The rules of running this script are the same as the original one
'dts/update-dts-subtree.sh'. We have the documentation for dts now, and will have similar ones for MbedTLS and LWIP soon. I didn't add this part yet since both MbedTLS and LWIP patch series are still under review.
- print_usage
- exit 1
+fi
+set_params() {
mbedtls)
dts)
path=dts/upstream
repo_url=
lwip)
path=lib/lwip/lwip
print_usage
exit 1
- esac
+set_params
Sorry but in any case would we need this commit message only without
knowing the variables?
echo " $repo_url"
- fi
"$merge_commit_msg"
As I search for all 'merge' commits in history, they have not
signed-off tags. This patch is to extend the original script to support more git upstream repos. So I intended to keep the commit message format as the original one unless we have reasons to improve it.
Regards, Raymond
Hi Raymond,
On 7/23/24 4:05 PM, Raymond Mao wrote:
Hi Quentin,
Hi Raymond,
Changes in v2
mainline
Configuration
corresponding
add `#
when
option of
that you
option of
you
need.
any U-Boot
imported.
-set -e
-[1]
-EOF -)
- then
echo "
- fi
-else
@@ -0,0 +1,86 @@
+set -e
+print_usage() {
I'm suggesting we could "improve" this, not that it needs to be done as part of this patch :)
- print_usage
- exit 1
+fi
+set_params() {
mbedtls)
dts)
path=dts/upstream
repo_url=
lwip)
path=lib/lwip/lwip
print_usage
exit 1
- esac
+set_params
Less magic for people not aware of those pulls and how they are made.
echo " $repo_url"
- fi
"$merge_commit_msg"
signed-off tags.
Yes, and I think that's a mistake. Though.... I'm not entirely sure if we can add this Signed-off-by tag to the merge commit as well? (with what I'm suggesting, we would only fix one of the ways to bring patches into dts/upstream or the two other subtrees).
Yup, was just suggesting "improving" this, not necessarily as part of this one patch though.
Forgot to say in my earlier mail: Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
Thanks! Quentin
Hi Raymond,
Thanks for doing this.
Changes in v2
-set -e
- then
- fi
-else
+set -e
+print_usage() {
- print_usage
- exit 1
+fi
+set_params() {
mbedtls)
Although I am in favour of making this script generic, this subdir path doesn't exist yet. Wouldn't it make more sense to add mbedtls here alongside the corresponding patch-set? Otherwise the script will just fail.
dts)
path=dts/upstream
lwip)
path=lib/lwip/lwip
Ditto here.
-Sumit
print_usage
exit 1
- esac
+set_params
echo " $repo_url"
- fi
+else
- print_usage
- exit 1
+fi
2.25.1
Hi Sumit,
On Wed, 24 Jul 2024 at 03:08, Sumit Garg sumit.garg@linaro.org wrote:
Hi Raymond,
Changes in v2
mainline
corresponding
add `#
option of
that you
option of
you
need.
any U-Boot
imported.
-set -e
-[1]
-EOF -)
- then
echo "
- fi
-else
+set -e
+print_usage() {
- print_usage
- exit 1
+fi
+set_params() {
mbedtls)
Actually this patch is split from the MbedTLS series which is under review.
I think this should be fine before merging the MbedTLS/LWIP series, since it is supposed to be run by maintainers only. And the failing message explains that the sub-project dir does not exist which should be sufficient at the moment.
Regards, Raymond
On Wed, 24 Jul 2024 at 19:40, Raymond Mao raymond.mao@linaro.org wrote:
Hi Sumit,
Hi Raymond,
Changes in v2
-set -e
- then
- fi
-else
Something I forgot earlier, if you are going to add explicit authorship then you should retain the prior author too from where this script is derived.
+set -e
+print_usage() {
- print_usage
- exit 1
+fi
+set_params() {
mbedtls)
Actually this patch is split from the MbedTLS series which is under review. I think this should be fine before merging the MbedTLS/LWIP series, since it is supposed to be run by maintainers only.
Developers also use this script to cherry-pick DTS patches from upstream to enable certain features in U-Boot.
Sure, I am only afraid that if this patch lands in a prior U-Boot release than the actual MbedTLS/LWIP series then we are just giving users a somewhat broken tool. If your worry is about merge conflicts then I suppose that should be taken care off while merging corresponding patch series.
-Sumit
Regards, Raymond
Hi Sumit,
Hi Raymond,
Changes in v2
-set -e
- then
- fi
-else
+set -e
+print_usage() {
- print_usage
- exit 1
+fi
+set_params() {
mbedtls)
I can certainly take care of adding the lwIP chunk in the lwIP series if that helps.
Thanks,
Hi Sumit,
Hi Sumit,
Hi Raymond,
Changes in v2
latest mainline
<devicetree-rebasing-release-tag> >> > + ./tools/update-subtree.sh pull dts <devicetree-rebasing-release-tag> >> > >> > If required it is also possible to cherry-pick fixes from the >> > devicetree-rebasing repository prior to next sync, usage:: >> > >> > - ./dts/update-dts-subtree.sh pick <devicetree-rebasing-commit-id> >> > + ./tools/update-subtree.sh pick dts <devicetree-rebasing-commit-id> >> > >> > >> > Configuration >> > @@ -116,8 +116,8 @@ However, if `dts/upstream/` hasn't yet received devicetree source file for your >> > newly added board support then one option is that you can add the corresponding >> > devicetree source file as `arch/<arch>/dts/<name>.dts`. To select that add `# >> > CONFIG_OF_UPSTREAM is not set` and set `DEFAULT_DEVICE_TREE=<name>` when >> > -prompted by Kconfig. Another option is that you can use use the "pick" option of >> > -`dts/update-dts-subtree.sh` mentioned above to bring in the commits that you >> > +prompted by Kconfig. Another option is that you can use the "pick" option of >> > +`tools/update-subtree.sh` mentioned above to bring in the commits that you >> > need. >> > >> > This should include your CPU or SoC's devicetree file. On top of that any U-Boot >> > diff --git a/dts/update-dts-subtree.sh b/dts/update-dts-subtree.sh >> > deleted file mode 100755 >> > index a57b78a41d3..00000000000 >> > --- a/dts/update-dts-subtree.sh >> > +++ /dev/null >> > @@ -1,48 +0,0 @@ >> > -#!/bin/sh >> > -# SPDX-License-Identifier: GPL-2.0+ >> > -# >> > -# Copyright 2024 Linaro Ltd. >> > -# >> > -# Usage: from the top level U-Boot source tree, run: >> > -# $ ./dts/update-dts-subtree.sh pull <release-tag> >> > -# $ ./dts/update-dts-subtree.sh pick <commit-id> >> > -# >> > -# The script will pull changes from devicetree-rebasing repo into U-Boot >> > -# as a subtree located as <U-Boot>/dts/upstream sub-directory. It will >> > -# automatically create a squash/merge commit listing the commits imported. >> > - >> > -set -e >> > - >> > -merge_commit_msg=$(cat << EOF >> > -Subtree merge tag '$2' of devicetree-rebasing repo [1] into dts/upstream >> > - >> > -[1] https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git/ >> > -EOF >> > -) >> > - >> > -remote_add_and_fetch() { >> > - if ! git remote get-url devicetree-rebasing 2>/dev/null >> > - then >> > - echo "Warning: Script automatically adds new git remote via:" >> > - echo " git remote add devicetree-rebasing \\" >> > - echo " https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git " >> > - git remote add devicetree-rebasing \ >> > - https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git >> > - fi >> > - git fetch devicetree-rebasing master >> > -} >> > - >> > -if [ "$1" = "pull" ] >> > -then >> > - remote_add_and_fetch >> > - git subtree pull --prefix dts/upstream devicetree-rebasing \ >> > - "$2" --squash -m "${merge_commit_msg}" >> > -elif [ "$1" = "pick" ] >> > -then >> > - remote_add_and_fetch >> > - git cherry-pick -x --strategy=subtree -Xsubtree=dts/upstream/ "$2" >> > -else >> > - echo "usage: $0 <op> <ref>" >> > - echo " <op> pull or pick" >> > - echo " <ref> release tag [pull] or commit id [pick]" >> > -fi >> > diff --git a/tools/update-subtree.sh b/tools/update-subtree.sh >> > new file mode 100755 >> > index 00000000000..5946aa1a9e2 >> > --- /dev/null >> > +++ b/tools/update-subtree.sh >> > @@ -0,0 +1,86 @@ >> > +#!/bin/sh >> > +# SPDX-License-Identifier: GPL-2.0+ >> > +# >> > +# Copyright (c) 2024 Linaro Limited >> > +# Author: Raymond Mao <raymond.mao@linaro.org>
Sorry about it, I will update the file header.
Raymond
participants (6)
Ilias Apalodimas
Jerome Forissier
Quentin Schulz
Raymond Mao
Sumit Garg
