[U-Boot] Please pull u-boot-ti/master
Hey,
The following changes since commit d2a3e911390f9fc4d8c0ee4b3c7fc75f4fd3fd19:
Merge branch 'u-boot/master' (2014-05-09 11:50:14 +0200)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to 97eeae1a0735fc17351f10b9978e966392badedc:
mtd: nand: omap_gpmc: Fix update of read_ecc in oob (2014-05-13 19:48:17 -0400)
---------------------------------------------------------------- Ash Charles (1): am335x: pepper: Add Gumstix Pepper AM335x-based machine
Belisko Marek (1): mtd: nand: omap_gpmc: Fix update of read_ecc in oob
Christian Riesch (1): arm, davinci: Use CONFIG_SPL_PAD_TO for padding the SPL in an ais image
Dmitry Lifshitz (3): ARM: OMAP5: add UART4 support ARM: OMAP5: Power: add LDO2 support for Palmas driver ARM: OMAP5: add CKO buffer control mask
Egli, Samuel (7): siemens: cosmetic: remove unused and rename defines siemens: update DDR3 parameters for dxr2 siemens: add led cmd for flexible LED control siemens: change LED indication in DFU mode siemens: cosmetic: rename project_dir siemens:cosmetic, dxr2: rename dxr2 to draco siemens, draco: add new target
Khoronzhuk, Ivan (1): config: k2hk_evm: Add generic board support
Robert Nelson (2): omap3_beagle: use omap3-beagle-xm-ab.dtb for the xM AB revision omap3_beagle: xM A/B validate new dtb exits in file system
Yegor Yefremov (1): am33xx: add SSC enable macro
Makefile | 2 +- arch/arm/include/asm/arch-am33xx/clock.h | 2 + arch/arm/include/asm/arch-omap5/clock.h | 3 + arch/arm/include/asm/arch-omap5/omap.h | 1 + board/gumstix/pepper/Makefile | 13 ++ board/gumstix/pepper/board.c | 226 ++++++++++++++++++++++++++++++ board/gumstix/pepper/board.h | 19 +++ board/gumstix/pepper/mux.c | 78 +++++++++++ board/siemens/common/board.c | 46 +++++- board/siemens/{dxr2 => draco}/Makefile | 0 board/siemens/{dxr2 => draco}/board.c | 112 ++++++++------- board/siemens/{dxr2 => draco}/board.h | 26 ++-- board/siemens/{dxr2 => draco}/mux.c | 2 +- board/siemens/pxm2/board.c | 10 +- board/siemens/rut/board.c | 2 +- boards.cfg | 4 +- drivers/mtd/nand/omap_gpmc.c | 2 +- include/configs/da850evm.h | 1 + include/configs/draco.h | 92 ++++++++++++ include/configs/dxr2.h | 4 +- include/configs/k2hk_evm.h | 1 + include/configs/omap3_beagle.h | 10 +- include/configs/pepper.h | 99 +++++++++++++ include/configs/pxm2.h | 2 +- include/configs/siemens-am33x-common.h | 8 +- include/palmas.h | 4 + 26 files changed, 686 insertions(+), 83 deletions(-) create mode 100644 board/gumstix/pepper/Makefile create mode 100644 board/gumstix/pepper/board.c create mode 100644 board/gumstix/pepper/board.h create mode 100644 board/gumstix/pepper/mux.c rename board/siemens/{dxr2 => draco}/Makefile (100%) rename board/siemens/{dxr2 => draco}/board.c (63%) rename board/siemens/{dxr2 => draco}/board.h (71%) rename board/siemens/{dxr2 => draco}/mux.c (99%) create mode 100644 include/configs/draco.h create mode 100644 include/configs/pepper.h
Thanks!
Hi Tom,
On Tue, 13 May 2014 21:36:51 -0400, Tom Rini trini@ti.com wrote:
Hey,
Thanks!
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
