[U-Boot] Pull request: u-boot-sunxi/master
Hi Tom,
Please pull this PR.
thanks, Jagan.
The following changes since commit b8aa55cb6414e512cce30bb7db3268eea934466d:
common: move init_helpers.h prototypes in init.h (2018-03-16 14:56:59 -0400)
git://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to 0354f4bef0f1ff1e160673794577ca00b23f3f1a:
sunxi: Add DRAM_SUN8I_A83T kconfig entry (2018-03-19 16:46:47 +0530)
---------------------------------------------------------------- Jagan Teki (11): sunxi: Add SUN6I_PRCM kconfig entry sunxi: Add SUN6I_P2WI kconfig entry sunxi: Use SUN6I_PRCM if used sunxi: Add SUN8I_RSB kconfig entry sunxi: Add AXP_PMIC_BUS kconfig entry sunxi: add DRAM_SUN6I kconfig sunxi: Add DRAM_SUN4I kconfig entry sunxi: Add DRAM_SUN9I kconfig entry sunxi: Add DRAM_SUN8I_A23 kconfig entry sunxi: Add DRAM_SUN8I_A33 kconfig entry sunxi: Add DRAM_SUN8I_A83T kconfig entry
arch/arm/mach-sunxi/Kconfig | 81 ++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-sunxi/Makefile | 30 ++++++---------- drivers/power/Kconfig | 5 +++ 3 files changed, 96 insertions(+), 20 deletions(-)
On Tue, Mar 20, 2018 at 01:30:02AM +0530, Jagan Teki wrote:
Hi Tom,
thanks, Jagan.
Jagan Teki
