[U-Boot] [PATCH] ARM: dts: Sync Amlogic G12A with Linux 5.3-rc1
Sync the Amlogic Meson G12A DT and Bindings file with the Linux 5.3-rc1 from the commit 5f9e832c1370 ("Linus 5.3-rc1").
Also remove the meson-g12a-u-boot.dtsi and meson-g12a-u200-u-boot.dtsi, now conflicting with the main DT content.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-g12a-u-boot.dtsi | 216 --- arch/arm/dts/meson-g12a-u200-u-boot.dtsi | 63 - arch/arm/dts/meson-g12a-u200.dts | 122 +- arch/arm/dts/meson-g12a.dtsi | 1825 +++++++++++++++++++- include/dt-bindings/clock/axg-aoclkc.h | 7 +- include/dt-bindings/clock/axg-audio-clkc.h | 30 +- include/dt-bindings/clock/g12a-clkc.h | 3 +- 7 files changed, 1928 insertions(+), 338 deletions(-) delete mode 100644 arch/arm/dts/meson-g12a-u-boot.dtsi delete mode 100644 arch/arm/dts/meson-g12a-u200-u-boot.dtsi
diff --git a/arch/arm/dts/meson-g12a-u-boot.dtsi b/arch/arm/dts/meson-g12a-u-boot.dtsi deleted file mode 100644 index 8e0c81f199..0000000000 --- a/arch/arm/dts/meson-g12a-u-boot.dtsi +++ /dev/null @@ -1,216 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -/ { - soc { - ethmac: ethernet@ff3f0000 { - compatible = "amlogic,meson-axg-dwmac", "snps,dwmac-3.710", - "snps,dwmac"; - reg = <0x0 0xff3f0000 0x0 0x10000 - 0x0 0xff634540 0x0 0x8>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq"; - clocks = <&clkc CLKID_ETH>, - <&clkc CLKID_FCLK_DIV2>, - <&clkc CLKID_MPLL2>; - clock-names = "stmmaceth", "clkin0", "clkin1"; - status = "disabled"; - - mdio0: mdio { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - }; - }; - - sd_emmc_a: sd@ffe03000 { - compatible = "amlogic,meson-axg-mmc"; - reg = <0x0 0xffe03000 0x0 0x800>; - interrupts = <GIC_SPI 189 IRQ_TYPE_EDGE_RISING>; - status = "disabled"; - clocks = <&clkc CLKID_SD_EMMC_A>, - <&clkc CLKID_SD_EMMC_A_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_A>; - }; - - sd_emmc_b: sd@ffe05000 { - compatible = "amlogic,meson-axg-mmc"; - reg = <0x0 0xffe05000 0x0 0x800>; - interrupts = <GIC_SPI 190 IRQ_TYPE_EDGE_RISING>; - status = "disabled"; - clocks = <&clkc CLKID_SD_EMMC_B>, - <&clkc CLKID_SD_EMMC_B_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_B>; - }; - - sd_emmc_c: mmc@ffe07000 { - compatible = "amlogic,meson-axg-mmc"; - reg = <0x0 0xffe07000 0x0 0x800>; - interrupts = <GIC_SPI 191 IRQ_TYPE_EDGE_RISING>; - status = "disabled"; - clocks = <&clkc CLKID_SD_EMMC_C>, - <&clkc CLKID_SD_EMMC_C_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_C>; - }; - }; -}; - -&periphs_pinctrl { - emmc_pins: emmc { - mux { - groups = "emmc_nand_d0", - "emmc_nand_d1", - "emmc_nand_d2", - "emmc_nand_d3", - "emmc_nand_d4", - "emmc_nand_d5", - "emmc_nand_d6", - "emmc_nand_d7", - "emmc_clk", - "emmc_cmd"; - function = "emmc"; - bias-pull-up; - }; - }; - - emmc_ds_pins: emmc-ds { - mux { - groups = "emmc_nand_ds"; - function = "emmc"; - bias-pull-down; - }; - }; - - emmc_clk_gate_pins: emmc_clk_gate { - mux { - groups = "BOOT_8"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; - - eth_leds_pins: eth-leds { - mux { - groups = "eth_link_led", - "eth_act_led"; - function = "eth"; - bias-disable; - }; - }; - - eth_rmii_pins: eth-rmii { - mux { - groups = "eth_mdio", - "eth_mdc", - "eth_rgmii_rx_clk", - "eth_rx_dv", - "eth_rxd0", - "eth_rxd1", - "eth_txen", - "eth_txd0", - "eth_txd1"; - function = "eth"; - bias-disable; - }; - }; - - eth_rgmii_pins: eth-rgmii { - mux { - groups = "eth_rxd2_rgmii", - "eth_rxd3_rgmii", - "eth_rgmii_tx_clk", - "eth_txd2_rgmii", - "eth_txd3_rgmii"; - function = "eth"; - bias-disable; - }; - }; - - sdcard_c_pins: sdcard_c { - mux { - groups = "sdcard_d0_c", - "sdcard_d1_c", - "sdcard_d2_c", - "sdcard_d3_c", - "sdcard_cmd_c", - "sdcard_clk_c"; - function = "sdcard"; - bias-pull-up; - }; - }; - - sdcard_clk_gate_c_pins: sdcard_clk_gate_c { - mux { - groups = "GPIOC_4"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; - - sdcard_z_pins: sdcard_z { - mux { - groups = "sdcard_d0_z", - "sdcard_d1_z", - "sdcard_d2_z", - "sdcard_d3_z", - "sdcard_cmd_z", - "sdcard_clk_z"; - function = "sdcard"; - bias-pull-up; - }; - }; - - sdcard_clk_gate_z_pins: sdcard_clk_gate_z { - mux { - groups = "GPIOZ_6"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; -}; - -&periphs { - eth_phy: mdio-multiplexer@4c000 { - compatible = "amlogic,g12a-mdio-mux"; - reg = <0x0 0x4c000 0x0 0xa4>; - clocks = <&clkc CLKID_ETH_PHY>, - <&xtal>, - <&clkc CLKID_MPLL_5OM>; - clock-names = "pclk", "clkin0", "clkin1"; - mdio-parent-bus = <&mdio0>; - #address-cells = <1>; - #size-cells = <0>; - - ext_mdio: mdio@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - }; - - int_mdio: mdio@1 { - reg = <1>; - #address-cells = <1>; - #size-cells = <0>; - - internal_ephy: ethernet_phy@8 { - compatible = "ethernet-phy-id0180.3300", - "ethernet-phy-ieee802.3-c22"; - reg = <8>; - max-speed = <100>; - - /* FIXME: Add irq support */ - }; - }; - }; -}; - - diff --git a/arch/arm/dts/meson-g12a-u200-u-boot.dtsi b/arch/arm/dts/meson-g12a-u200-u-boot.dtsi deleted file mode 100644 index 9486ab0c47..0000000000 --- a/arch/arm/dts/meson-g12a-u200-u-boot.dtsi +++ /dev/null @@ -1,63 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -#include "meson-g12a-u-boot.dtsi" - - / { - aliases { - ethernet0 = ðmac; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; - }; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_leds_pins>; - pinctrl-names = "default"; - phy-handle = <&internal_ephy>; - phy-mode = "rmii"; -}; - - -/* SD card */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_c_pins>; - pinctrl-1 = <&sdcard_clk_gate_c_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - disable-wp; - - cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vddao_3v3>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - max-frequency = <200000000>; - disable-wp; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&flash_1v8>; -}; diff --git a/arch/arm/dts/meson-g12a-u200.dts b/arch/arm/dts/meson-g12a-u200.dts index 0e8045b8a9..8551fbd4a4 100644 --- a/arch/arm/dts/meson-g12a-u200.dts +++ b/arch/arm/dts/meson-g12a-u200.dts @@ -15,14 +15,12 @@
aliases { serial0 = &uart_AO; + ethernet0 = ðmac; }; + chosen { stdout-path = "serial0:115200n8"; }; - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x40000000>; - };
cvbs-connector { compatible = "composite-video-connector"; @@ -34,13 +32,9 @@ }; };
- flash_1v8: regulator-flash_1v8 { - compatible = "regulator-fixed"; - regulator-name = "FLASH_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_3v3>; - regulator-always-on; + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; };
hdmi-connector { @@ -54,6 +48,20 @@ }; };
+ memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x40000000>; + }; + + flash_1v8: regulator-flash_1v8 { + compatible = "regulator-fixed"; + regulator-name = "FLASH_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + main_12v: regulator-main_12v { compatible = "regulator-fixed"; regulator-name = "12V"; @@ -62,6 +70,17 @@ regulator-always-on; };
+ usb_pwr_en: regulator-usb_pwr_en { + compatible = "regulator-fixed"; + regulator-name = "USB_PWR_EN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_5v>; + + gpio = <&gpio GPIOH_6 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + vcc_1v8: regulator-vcc_1v8 { compatible = "regulator-fixed"; regulator-name = "VCC_1V8"; @@ -92,17 +111,6 @@ enable-active-high; };
- usb_pwr_en: regulator-usb_pwr_en { - compatible = "regulator-fixed"; - regulator-name = "USB_PWR_EN"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc_5v>; - - gpio = <&gpio GPIOH_6 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - vddao_1v8: regulator-vddao_1v8 { compatible = "regulator-fixed"; regulator-name = "VDDAO_1V8"; @@ -143,6 +151,12 @@ }; };
+ðmac { + status = "okay"; + phy-handle = <&internal_ephy>; + phy-mode = "rmii"; +}; + &hdmi_tx { status = "okay"; pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; @@ -156,6 +170,70 @@ }; };
+&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; +}; + +/* i2c Touch */ +&i2c0 { + status = "okay"; + pinctrl-0 = <&i2c0_sda_z0_pins>, <&i2c0_sck_z1_pins>; + pinctrl-names = "default"; +}; + +/* i2c CM */ +&i2c2 { + status = "okay"; + pinctrl-0 = <&i2c2_sda_z_pins>, <&i2c2_sck_z_pins>; + pinctrl-names = "default"; +}; + +/* i2c Audio */ +&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; +}; + +/* SD card */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_c_pins>; + pinctrl-1 = <&sdcard_clk_gate_c_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <50000000>; + disable-wp; + + cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; + vmmc-supply = <&vddao_3v3>; + vqmmc-supply = <&vddao_3v3>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + non-removable; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&flash_1v8>; +}; + &uart_AO { status = "okay"; pinctrl-0 = <&uart_ao_a_pins>; diff --git a/arch/arm/dts/meson-g12a.dtsi b/arch/arm/dts/meson-g12a.dtsi index 9f72396ba7..f8d43e3dcf 100644 --- a/arch/arm/dts/meson-g12a.dtsi +++ b/arch/arm/dts/meson-g12a.dtsi @@ -5,10 +5,12 @@
#include <dt-bindings/phy/phy.h> #include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/axg-audio-clkc.h> #include <dt-bindings/clock/g12a-clkc.h> #include <dt-bindings/clock/g12a-aoclkc.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> #include <dt-bindings/reset/amlogic,meson-g12a-reset.h>
/ { @@ -18,6 +20,39 @@ #address-cells = <2>; #size-cells = <2>;
+ tdmif_a: audio-controller-0 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_A"; + clocks = <&clkc_audio AUD_CLKID_MST_A_MCLK>, + <&clkc_audio AUD_CLKID_MST_A_SCLK>, + <&clkc_audio AUD_CLKID_MST_A_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_b: audio-controller-1 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_B"; + clocks = <&clkc_audio AUD_CLKID_MST_B_MCLK>, + <&clkc_audio AUD_CLKID_MST_B_SCLK>, + <&clkc_audio AUD_CLKID_MST_B_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_c: audio-controller-2 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_C"; + clocks = <&clkc_audio AUD_CLKID_MST_C_MCLK>, + <&clkc_audio AUD_CLKID_MST_C_SCLK>, + <&clkc_audio AUD_CLKID_MST_C_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + cpus { #address-cells = <0x2>; #size-cells = <0x0>; @@ -102,6 +137,27 @@ #size-cells = <2>; ranges;
+ ethmac: ethernet@ff3f0000 { + compatible = "amlogic,meson-axg-dwmac", + "snps,dwmac-3.70a", + "snps,dwmac"; + reg = <0x0 0xff3f0000 0x0 0x10000 + 0x0 0xff634540 0x0 0x8>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + clocks = <&clkc CLKID_ETH>, + <&clkc CLKID_FCLK_DIV2>, + <&clkc CLKID_MPLL2>; + clock-names = "stmmaceth", "clkin0", "clkin1"; + status = "disabled"; + + mdio0: mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + }; + }; + apb: bus@ff600000 { compatible = "simple-bus"; reg = <0x0 0xff600000 0x0 0x200000>; @@ -123,6 +179,7 @@ clock-names = "isfr", "iahb", "venci"; #address-cells = <1>; #size-cells = <0>; + #sound-dai-cells = <0>; status = "disabled";
/* VPU VENC Input */ @@ -140,6 +197,19 @@ }; };
+ apb_efuse: bus@30000 { + compatible = "simple-bus"; + reg = <0x0 0x30000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x30000 0x0 0x2000>; + + hwrng: rng@218 { + compatible = "amlogic,meson-rng"; + reg = <0x0 0x218 0x0 0x4>; + }; + }; + periphs: bus@34400 { compatible = "simple-bus"; reg = <0x0 0x34400 0x0 0x400>; @@ -169,35 +239,1112 @@ gpio-ranges = <&periphs_pinctrl 0 0 86>; };
- cec_ao_a_h_pins: cec_ao_a_h { + cec_ao_a_h_pins: cec_ao_a_h { + mux { + groups = "cec_ao_a_h"; + function = "cec_ao_a_h"; + bias-disable; + }; + }; + + cec_ao_b_h_pins: cec_ao_b_h { + mux { + groups = "cec_ao_b_h"; + function = "cec_ao_b_h"; + bias-disable; + }; + }; + + emmc_pins: emmc { + mux-0 { + groups = "emmc_nand_d0", + "emmc_nand_d1", + "emmc_nand_d2", + "emmc_nand_d3", + "emmc_nand_d4", + "emmc_nand_d5", + "emmc_nand_d6", + "emmc_nand_d7", + "emmc_cmd"; + function = "emmc"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "emmc_clk"; + function = "emmc"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + emmc_ds_pins: emmc-ds { + mux { + groups = "emmc_nand_ds"; + function = "emmc"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + emmc_clk_gate_pins: emmc_clk_gate { + mux { + groups = "BOOT_8"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + hdmitx_ddc_pins: hdmitx_ddc { + mux { + groups = "hdmitx_sda", + "hdmitx_sck"; + function = "hdmitx"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + hdmitx_hpd_pins: hdmitx_hpd { + mux { + groups = "hdmitx_hpd_in"; + function = "hdmitx"; + bias-disable; + }; + }; + + + i2c0_sda_c_pins: i2c0-sda-c { + mux { + groups = "i2c0_sda_c"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + + }; + }; + + i2c0_sck_c_pins: i2c0-sck-c { + mux { + groups = "i2c0_sck_c"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z0_pins: i2c0-sda-z0 { + mux { + groups = "i2c0_sda_z0"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sck_z1_pins: i2c0-sck-z1 { + mux { + groups = "i2c0_sck_z1"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z7_pins: i2c0-sda-z7 { + mux { + groups = "i2c0_sda_z7"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z8_pins: i2c0-sda-z8 { + mux { + groups = "i2c0_sda_z8"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_x_pins: i2c1-sda-x { + mux { + groups = "i2c1_sda_x"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_x_pins: i2c1-sck-x { + mux { + groups = "i2c1_sck_x"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_h2_pins: i2c1-sda-h2 { + mux { + groups = "i2c1_sda_h2"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_h3_pins: i2c1-sck-h3 { + mux { + groups = "i2c1_sck_h3"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_h6_pins: i2c1-sda-h6 { + mux { + groups = "i2c1_sda_h6"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_h7_pins: i2c1-sck-h7 { + mux { + groups = "i2c1_sck_h7"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sda_x_pins: i2c2-sda-x { + mux { + groups = "i2c2_sda_x"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sck_x_pins: i2c2-sck-x { + mux { + groups = "i2c2_sck_x"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sda_z_pins: i2c2-sda-z { + mux { + groups = "i2c2_sda_z"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sck_z_pins: i2c2-sck-z { + mux { + groups = "i2c2_sck_z"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sda_h_pins: i2c3-sda-h { + mux { + groups = "i2c3_sda_h"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sck_h_pins: i2c3-sck-h { + mux { + groups = "i2c3_sck_h"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sda_a_pins: i2c3-sda-a { + mux { + groups = "i2c3_sda_a"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sck_a_pins: i2c3-sck-a { + mux { + groups = "i2c3_sck_a"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk0_a_pins: mclk0-a { + mux { + groups = "mclk0_a"; + function = "mclk0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_a_pins: mclk1-a { + mux { + groups = "mclk1_a"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_x_pins: mclk1-x { + mux { + groups = "mclk1_x"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_z_pins: mclk1-z { + mux { + groups = "mclk1_z"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + pdm_din0_a_pins: pdm-din0-a { + mux { + groups = "pdm_din0_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_c_pins: pdm-din0-c { + mux { + groups = "pdm_din0_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_x_pins: pdm-din0-x { + mux { + groups = "pdm_din0_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_z_pins: pdm-din0-z { + mux { + groups = "pdm_din0_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_a_pins: pdm-din1-a { + mux { + groups = "pdm_din1_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_c_pins: pdm-din1-c { + mux { + groups = "pdm_din1_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_x_pins: pdm-din1-x { + mux { + groups = "pdm_din1_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_z_pins: pdm-din1-z { + mux { + groups = "pdm_din1_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_a_pins: pdm-din2-a { + mux { + groups = "pdm_din2_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_c_pins: pdm-din2-c { + mux { + groups = "pdm_din2_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_x_pins: pdm-din2-x { + mux { + groups = "pdm_din2_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_z_pins: pdm-din2-z { + mux { + groups = "pdm_din2_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_a_pins: pdm-din3-a { + mux { + groups = "pdm_din3_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_c_pins: pdm-din3-c { + mux { + groups = "pdm_din3_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_x_pins: pdm-din3-x { + mux { + groups = "pdm_din3_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_z_pins: pdm-din3-z { + mux { + groups = "pdm_din3_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_dclk_a_pins: pdm-dclk-a { + mux { + groups = "pdm_dclk_a"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_c_pins: pdm-dclk-c { + mux { + groups = "pdm_dclk_c"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_x_pins: pdm-dclk-x { + mux { + groups = "pdm_dclk_x"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_z_pins: pdm-dclk-z { + mux { + groups = "pdm_dclk_z"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pwm_a_pins: pwm-a { + mux { + groups = "pwm_a"; + function = "pwm_a"; + bias-disable; + }; + }; + + pwm_b_x7_pins: pwm-b-x7 { + mux { + groups = "pwm_b_x7"; + function = "pwm_b"; + bias-disable; + }; + }; + + pwm_b_x19_pins: pwm-b-x19 { + mux { + groups = "pwm_b_x19"; + function = "pwm_b"; + bias-disable; + }; + }; + + pwm_c_c_pins: pwm-c-c { + mux { + groups = "pwm_c_c"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_c_x5_pins: pwm-c-x5 { + mux { + groups = "pwm_c_x5"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_c_x8_pins: pwm-c-x8 { + mux { + groups = "pwm_c_x8"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_d_x3_pins: pwm-d-x3 { + mux { + groups = "pwm_d_x3"; + function = "pwm_d"; + bias-disable; + }; + }; + + pwm_d_x6_pins: pwm-d-x6 { + mux { + groups = "pwm_d_x6"; + function = "pwm_d"; + bias-disable; + }; + }; + + pwm_e_pins: pwm-e { + mux { + groups = "pwm_e"; + function = "pwm_e"; + bias-disable; + }; + }; + + pwm_f_x_pins: pwm-f-x { + mux { + groups = "pwm_f_x"; + function = "pwm_f"; + bias-disable; + }; + }; + + pwm_f_h_pins: pwm-f-h { + mux { + groups = "pwm_f_h"; + function = "pwm_f"; + bias-disable; + }; + }; + + sdcard_c_pins: sdcard_c { + mux-0 { + groups = "sdcard_d0_c", + "sdcard_d1_c", + "sdcard_d2_c", + "sdcard_d3_c", + "sdcard_cmd_c"; + function = "sdcard"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "sdcard_clk_c"; + function = "sdcard"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_clk_gate_c_pins: sdcard_clk_gate_c { + mux { + groups = "GPIOC_4"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_z_pins: sdcard_z { + mux-0 { + groups = "sdcard_d0_z", + "sdcard_d1_z", + "sdcard_d2_z", + "sdcard_d3_z", + "sdcard_cmd_z"; + function = "sdcard"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "sdcard_clk_z"; + function = "sdcard"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_clk_gate_z_pins: sdcard_clk_gate_z { + mux { + groups = "GPIOZ_6"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + sdio_pins: sdio { + mux { + groups = "sdio_d0", + "sdio_d1", + "sdio_d2", + "sdio_d3", + "sdio_clk", + "sdio_cmd"; + function = "sdio"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdio_clk_gate_pins: sdio_clk_gate { + mux { + groups = "GPIOX_4"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + spdif_in_a10_pins: spdif-in-a10 { + mux { + groups = "spdif_in_a10"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_in_a12_pins: spdif-in-a12 { + mux { + groups = "spdif_in_a12"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_in_h_pins: spdif-in-h { + mux { + groups = "spdif_in_h"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_out_h_pins: spdif-out-h { + mux { + groups = "spdif_out_h"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + spdif_out_a11_pins: spdif-out-a11 { + mux { + groups = "spdif_out_a11"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + spdif_out_a13_pins: spdif-out-a13 { + mux { + groups = "spdif_out_a13"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + tdm_a_din0_pins: tdm-a-din0 { + mux { + groups = "tdm_a_din0"; + function = "tdm_a"; + bias-disable; + }; + }; + + + tdm_a_din1_pins: tdm-a-din1 { + mux { + groups = "tdm_a_din1"; + function = "tdm_a"; + bias-disable; + }; + }; + + tdm_a_dout0_pins: tdm-a-dout0 { + mux { + groups = "tdm_a_dout0"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_dout1_pins: tdm-a-dout1 { + mux { + groups = "tdm_a_dout1"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_fs_pins: tdm-a-fs { + mux { + groups = "tdm_a_fs"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_sclk_pins: tdm-a-sclk { + mux { + groups = "tdm_a_sclk"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_slv_fs_pins: tdm-a-slv-fs { + mux { + groups = "tdm_a_slv_fs"; + function = "tdm_a"; + bias-disable; + }; + }; + + + tdm_a_slv_sclk_pins: tdm-a-slv-sclk { + mux { + groups = "tdm_a_slv_sclk"; + function = "tdm_a"; + bias-disable; + }; + }; + + tdm_b_din0_pins: tdm-b-din0 { + mux { + groups = "tdm_b_din0"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din1_pins: tdm-b-din1 { + mux { + groups = "tdm_b_din1"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din2_pins: tdm-b-din2 { + mux { + groups = "tdm_b_din2"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din3_a_pins: tdm-b-din3-a { + mux { + groups = "tdm_b_din3_a"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din3_h_pins: tdm-b-din3-h { + mux { + groups = "tdm_b_din3_h"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_dout0_pins: tdm-b-dout0 { + mux { + groups = "tdm_b_dout0"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout1_pins: tdm-b-dout1 { + mux { + groups = "tdm_b_dout1"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout2_pins: tdm-b-dout2 { + mux { + groups = "tdm_b_dout2"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout3_a_pins: tdm-b-dout3-a { + mux { + groups = "tdm_b_dout3_a"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout3_h_pins: tdm-b-dout3-h { + mux { + groups = "tdm_b_dout3_h"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_fs_pins: tdm-b-fs { + mux { + groups = "tdm_b_fs"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_sclk_pins: tdm-b-sclk { + mux { + groups = "tdm_b_sclk"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_slv_fs_pins: tdm-b-slv-fs { + mux { + groups = "tdm_b_slv_fs"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_slv_sclk_pins: tdm-b-slv-sclk { + mux { + groups = "tdm_b_slv_sclk"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_c_din0_a_pins: tdm-c-din0-a { + mux { + groups = "tdm_c_din0_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din0_z_pins: tdm-c-din0-z { + mux { + groups = "tdm_c_din0_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din1_a_pins: tdm-c-din1-a { + mux { + groups = "tdm_c_din1_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din1_z_pins: tdm-c-din1-z { + mux { + groups = "tdm_c_din1_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din2_a_pins: tdm-c-din2-a { + mux { + groups = "tdm_c_din2_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + eth_leds_pins: eth-leds { + mux { + groups = "eth_link_led", + "eth_act_led"; + function = "eth"; + bias-disable; + }; + }; + + eth_pins: eth { + mux { + groups = "eth_mdio", + "eth_mdc", + "eth_rgmii_rx_clk", + "eth_rx_dv", + "eth_rxd0", + "eth_rxd1", + "eth_txen", + "eth_txd0", + "eth_txd1"; + function = "eth"; + drive-strength-microamp = <4000>; + bias-disable; + }; + }; + + eth_rgmii_pins: eth-rgmii { + mux { + groups = "eth_rxd2_rgmii", + "eth_rxd3_rgmii", + "eth_rgmii_tx_clk", + "eth_txd2_rgmii", + "eth_txd3_rgmii"; + function = "eth"; + drive-strength-microamp = <4000>; + bias-disable; + }; + }; + + tdm_c_din2_z_pins: tdm-c-din2-z { + mux { + groups = "tdm_c_din2_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din3_a_pins: tdm-c-din3-a { + mux { + groups = "tdm_c_din3_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din3_z_pins: tdm-c-din3-z { + mux { + groups = "tdm_c_din3_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_dout0_a_pins: tdm-c-dout0-a { + mux { + groups = "tdm_c_dout0_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout0_z_pins: tdm-c-dout0-z { + mux { + groups = "tdm_c_dout0_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout1_a_pins: tdm-c-dout1-a { + mux { + groups = "tdm_c_dout1_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout1_z_pins: tdm-c-dout1-z { + mux { + groups = "tdm_c_dout1_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout2_a_pins: tdm-c-dout2-a { + mux { + groups = "tdm_c_dout2_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout2_z_pins: tdm-c-dout2-z { + mux { + groups = "tdm_c_dout2_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout3_a_pins: tdm-c-dout3-a { + mux { + groups = "tdm_c_dout3_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout3_z_pins: tdm-c-dout3-z { + mux { + groups = "tdm_c_dout3_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_fs_a_pins: tdm-c-fs-a { + mux { + groups = "tdm_c_fs_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_fs_z_pins: tdm-c-fs-z { + mux { + groups = "tdm_c_fs_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_sclk_a_pins: tdm-c-sclk-a { mux { - groups = "cec_ao_a_h"; - function = "cec_ao_a_h"; + groups = "tdm_c_sclk_a"; + function = "tdm_c"; bias-disable; + drive-strength-microamp = <3000>; }; };
- cec_ao_b_h_pins: cec_ao_b_h { + tdm_c_sclk_z_pins: tdm-c-sclk-z { mux { - groups = "cec_ao_b_h"; - function = "cec_ao_b_h"; + groups = "tdm_c_sclk_z"; + function = "tdm_c"; bias-disable; + drive-strength-microamp = <3000>; }; };
- hdmitx_ddc_pins: hdmitx_ddc { + tdm_c_slv_fs_a_pins: tdm-c-slv-fs-a { mux { - groups = "hdmitx_sda", - "hdmitx_sck"; - function = "hdmitx"; + groups = "tdm_c_slv_fs_a"; + function = "tdm_c"; bias-disable; }; };
- hdmitx_hpd_pins: hdmitx_hpd { + tdm_c_slv_fs_z_pins: tdm-c-slv-fs-z { mux { - groups = "hdmitx_hpd_in"; - function = "hdmitx"; + groups = "tdm_c_slv_fs_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_slv_sclk_a_pins: tdm-c-slv-sclk-a { + mux { + groups = "tdm_c_slv_sclk_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_slv_sclk_z_pins: tdm-c-slv-sclk-z { + mux { + groups = "tdm_c_slv_sclk_z"; + function = "tdm_c"; bias-disable; }; }; @@ -303,6 +1450,282 @@ }; };
+ pdm: audio-controller@40000 { + compatible = "amlogic,g12a-pdm", + "amlogic,axg-pdm"; + reg = <0x0 0x40000 0x0 0x34>; + #sound-dai-cells = <0>; + sound-name-prefix = "PDM"; + clocks = <&clkc_audio AUD_CLKID_PDM>, + <&clkc_audio AUD_CLKID_PDM_DCLK>, + <&clkc_audio AUD_CLKID_PDM_SYSCLK>; + clock-names = "pclk", "dclk", "sysclk"; + status = "disabled"; + }; + + audio: bus@42000 { + compatible = "simple-bus"; + reg = <0x0 0x42000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x42000 0x0 0x2000>; + + clkc_audio: clock-controller@0 { + status = "disabled"; + compatible = "amlogic,g12a-audio-clkc"; + reg = <0x0 0x0 0x0 0xb4>; + #clock-cells = <1>; + + clocks = <&clkc CLKID_AUDIO>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL3>, + <&clkc CLKID_HIFI_PLL>, + <&clkc CLKID_FCLK_DIV3>, + <&clkc CLKID_FCLK_DIV4>, + <&clkc CLKID_GP0_PLL>; + clock-names = "pclk", + "mst_in0", + "mst_in1", + "mst_in2", + "mst_in3", + "mst_in4", + "mst_in5", + "mst_in6", + "mst_in7"; + + resets = <&reset RESET_AUDIO>; + }; + + toddr_a: audio-controller@100 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x100 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_A"; + interrupts = <GIC_SPI 148 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_A>; + resets = <&arb AXG_ARB_TODDR_A>; + status = "disabled"; + }; + + toddr_b: audio-controller@140 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x140 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_B"; + interrupts = <GIC_SPI 149 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_B>; + resets = <&arb AXG_ARB_TODDR_B>; + status = "disabled"; + }; + + toddr_c: audio-controller@180 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x180 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_C"; + interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_C>; + resets = <&arb AXG_ARB_TODDR_C>; + status = "disabled"; + }; + + frddr_a: audio-controller@1c0 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x1c0 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_A"; + interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_A>; + resets = <&arb AXG_ARB_FRDDR_A>; + status = "disabled"; + }; + + frddr_b: audio-controller@200 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x200 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_B"; + interrupts = <GIC_SPI 153 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_B>; + resets = <&arb AXG_ARB_FRDDR_B>; + status = "disabled"; + }; + + frddr_c: audio-controller@240 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x240 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_C"; + interrupts = <GIC_SPI 154 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_C>; + resets = <&arb AXG_ARB_FRDDR_C>; + status = "disabled"; + }; + + arb: reset-controller@280 { + status = "disabled"; + compatible = "amlogic,meson-axg-audio-arb"; + reg = <0x0 0x280 0x0 0x4>; + #reset-cells = <1>; + clocks = <&clkc_audio AUD_CLKID_DDR_ARB>; + }; + + tdmin_a: audio-controller@300 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x300 0x0 0x40>; + sound-name-prefix = "TDMIN_A"; + clocks = <&clkc_audio AUD_CLKID_TDMIN_A>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_b: audio-controller@340 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x340 0x0 0x40>; + sound-name-prefix = "TDMIN_B"; + clocks = <&clkc_audio AUD_CLKID_TDMIN_B>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_c: audio-controller@380 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x380 0x0 0x40>; + sound-name-prefix = "TDMIN_C"; + clocks = <&clkc_audio AUD_CLKID_TDMIN_C>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_lb: audio-controller@3c0 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x3c0 0x0 0x40>; + sound-name-prefix = "TDMIN_LB"; + clocks = <&clkc_audio AUD_CLKID_TDMIN_LB>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + spdifin: audio-controller@400 { + compatible = "amlogic,g12a-spdifin", + "amlogic,axg-spdifin"; + reg = <0x0 0x400 0x0 0x30>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFIN"; + interrupts = <GIC_SPI 151 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_SPDIFIN>, + <&clkc_audio AUD_CLKID_SPDIFIN_CLK>; + clock-names = "pclk", "refclk"; + status = "disabled"; + }; + + spdifout: audio-controller@480 { + compatible = "amlogic,g12a-spdifout", + "amlogic,axg-spdifout"; + reg = <0x0 0x480 0x0 0x50>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFOUT"; + clocks = <&clkc_audio AUD_CLKID_SPDIFOUT>, + <&clkc_audio AUD_CLKID_SPDIFOUT_CLK>; + clock-names = "pclk", "mclk"; + status = "disabled"; + }; + + tdmout_a: audio-controller@500 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x500 0x0 0x40>; + sound-name-prefix = "TDMOUT_A"; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_A>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_b: audio-controller@540 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x540 0x0 0x40>; + sound-name-prefix = "TDMOUT_B"; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_B>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_c: audio-controller@580 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x580 0x0 0x40>; + sound-name-prefix = "TDMOUT_C"; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_C>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + spdifout_b: audio-controller@680 { + compatible = "amlogic,g12a-spdifout", + "amlogic,axg-spdifout"; + reg = <0x0 0x680 0x0 0x50>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFOUT_B"; + clocks = <&clkc_audio AUD_CLKID_SPDIFOUT_B>, + <&clkc_audio AUD_CLKID_SPDIFOUT_B_CLK>; + clock-names = "pclk", "mclk"; + status = "disabled"; + }; + + tohdmitx: audio-controller@744 { + compatible = "amlogic,g12a-tohdmitx"; + reg = <0x0 0x744 0x0 0x4>; + #sound-dai-cells = <1>; + sound-name-prefix = "TOHDMITX"; + status = "disabled"; + }; + }; + usb3_pcie_phy: phy@46000 { compatible = "amlogic,g12a-usb3-pcie-phy"; reg = <0x0 0x46000 0x0 0x2000>; @@ -314,6 +1737,38 @@ assigned-clock-rates = <100000000>; #phy-cells = <1>; }; + + eth_phy: mdio-multiplexer@4c000 { + compatible = "amlogic,g12a-mdio-mux"; + reg = <0x0 0x4c000 0x0 0xa4>; + clocks = <&clkc CLKID_ETH_PHY>, + <&xtal>, + <&clkc CLKID_MPLL_50M>; + clock-names = "pclk", "clkin0", "clkin1"; + mdio-parent-bus = <&mdio0>; + #address-cells = <1>; + #size-cells = <0>; + + ext_mdio: mdio@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + int_mdio: mdio@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + internal_ephy: ethernet_phy@8 { + compatible = "ethernet-phy-id0180.3301", + "ethernet-phy-ieee802.3-c22"; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + reg = <8>; + max-speed = <100>; + }; + }; + }; };
aobus: bus@ff800000 { @@ -401,6 +1856,145 @@ gpio-ranges = <&ao_pinctrl 0 0 15>; };
+ i2c_ao_sck_pins: i2c_ao_sck_pins { + mux { + groups = "i2c_ao_sck"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sda_pins: i2c_ao_sda { + mux { + groups = "i2c_ao_sda"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sck_e_pins: i2c_ao_sck_e { + mux { + groups = "i2c_ao_sck_e"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sda_e_pins: i2c_ao_sda_e { + mux { + groups = "i2c_ao_sda_e"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk0_ao_pins: mclk0-ao { + mux { + groups = "mclk0_ao"; + function = "mclk0_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_din0_pins: tdm-ao-b-din0 { + mux { + groups = "tdm_ao_b_din0"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + spdif_ao_out_pins: spdif-ao-out { + mux { + groups = "spdif_ao_out"; + function = "spdif_ao_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + tdm_ao_b_din1_pins: tdm-ao-b-din1 { + mux { + groups = "tdm_ao_b_din1"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_din2_pins: tdm-ao-b-din2 { + mux { + groups = "tdm_ao_b_din2"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_dout0_pins: tdm-ao-b-dout0 { + mux { + groups = "tdm_ao_b_dout0"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_dout1_pins: tdm-ao-b-dout1 { + mux { + groups = "tdm_ao_b_dout1"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_dout2_pins: tdm-ao-b-dout2 { + mux { + groups = "tdm_ao_b_dout2"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_fs_pins: tdm-ao-b-fs { + mux { + groups = "tdm_ao_b_fs"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_sclk_pins: tdm-ao-b-sclk { + mux { + groups = "tdm_ao_b_sclk"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_slv_fs_pins: tdm-ao-b-slv-fs { + mux { + groups = "tdm_ao_b_slv_fs"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_slv_sclk_pins: tdm-ao-b-slv-sclk { + mux { + groups = "tdm_ao_b_slv_sclk"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + uart_ao_a_pins: uart-a-ao { mux { groups = "uart_ao_a_tx", @@ -418,6 +2012,69 @@ bias-disable; }; }; + + pwm_ao_a_pins: pwm-ao-a { + mux { + groups = "pwm_ao_a"; + function = "pwm_ao_a"; + bias-disable; + }; + }; + + pwm_ao_b_pins: pwm-ao-b { + mux { + groups = "pwm_ao_b"; + function = "pwm_ao_b"; + bias-disable; + }; + }; + + pwm_ao_c_4_pins: pwm-ao-c-4 { + mux { + groups = "pwm_ao_c_4"; + function = "pwm_ao_c"; + bias-disable; + }; + }; + + pwm_ao_c_6_pins: pwm-ao-c-6 { + mux { + groups = "pwm_ao_c_6"; + function = "pwm_ao_c"; + bias-disable; + }; + }; + + pwm_ao_d_5_pins: pwm-ao-d-5 { + mux { + groups = "pwm_ao_d_5"; + function = "pwm_ao_d"; + bias-disable; + }; + }; + + pwm_ao_d_10_pins: pwm-ao-d-10 { + mux { + groups = "pwm_ao_d_10"; + function = "pwm_ao_d"; + bias-disable; + }; + }; + + pwm_ao_d_e_pins: pwm-ao-d-e { + mux { + groups = "pwm_ao_d_e"; + function = "pwm_ao_d"; + }; + }; + + remote_input_ao_pins: remote-input-ao { + mux { + groups = "remote_ao_input"; + function = "remote_ao_input"; + bias-disable; + }; + }; }; };
@@ -445,12 +2102,19 @@ status = "disabled"; };
+ pwm_AO_cd: pwm@2000 { + compatible = "amlogic,meson-g12a-ao-pwm-cd"; + reg = <0x0 0x2000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + uart_AO: serial@3000 { compatible = "amlogic,meson-gx-uart", "amlogic,meson-ao-uart"; reg = <0x0 0x3000 0x0 0x18>; interrupts = <GIC_SPI 193 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>, <&xtal>, <&xtal>; + clocks = <&xtal>, <&clkc_AO CLKID_AO_UART>, <&xtal>; clock-names = "xtal", "pclk", "baud"; status = "disabled"; }; @@ -460,11 +2124,35 @@ "amlogic,meson-ao-uart"; reg = <0x0 0x4000 0x0 0x18>; interrupts = <GIC_SPI 197 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>, <&xtal>, <&xtal>; + clocks = <&xtal>, <&clkc_AO CLKID_AO_UART2>, <&xtal>; clock-names = "xtal", "pclk", "baud"; status = "disabled"; };
+ i2c_AO: i2c@5000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x05000 0x0 0x20>; + interrupts = <GIC_SPI 195 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + pwm_AO_ab: pwm@7000 { + compatible = "amlogic,meson-g12a-ao-pwm-ab"; + reg = <0x0 0x7000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + ir: ir@8000 { + compatible = "amlogic,meson-gxbb-ir"; + reg = <0x0 0x8000 0x0 0x20>; + interrupts = <GIC_SPI 196 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + }; + saradc: adc@9000 { compatible = "amlogic,meson-g12a-saradc", "amlogic,meson-saradc"; @@ -533,6 +2221,76 @@ #reset-cells = <1>; };
+ gpio_intc: interrupt-controller@f080 { + compatible = "amlogic,meson-g12a-gpio-intc", + "amlogic,meson-gpio-intc"; + reg = <0x0 0xf080 0x0 0x10>; + interrupt-controller; + #interrupt-cells = <2>; + amlogic,channel-interrupts = <64 65 66 67 68 69 70 71>; + }; + + pwm_ef: pwm@19000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x19000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + pwm_cd: pwm@1a000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x1a000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + pwm_ab: pwm@1b000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x1b000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + i2c3: i2c@1c000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1c000 0x0 0x20>; + interrupts = <GIC_SPI 39 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c2: i2c@1d000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1d000 0x0 0x20>; + interrupts = <GIC_SPI 215 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c1: i2c@1e000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1e000 0x0 0x20>; + interrupts = <GIC_SPI 214 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c0: i2c@1f000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1f000 0x0 0x20>; + interrupts = <GIC_SPI 21 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + clk_msr: clock-measure@18000 { compatible = "amlogic,meson-g12a-clk-measure"; reg = <0x0 0x18000 0x0 0x10>; @@ -566,6 +2324,43 @@ }; };
+ sd_emmc_a: sd@ffe03000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe03000 0x0 0x800>; + interrupts = <GIC_SPI 189 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_A>, + <&clkc CLKID_SD_EMMC_A_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_A>; + amlogic,dram-access-quirk; + }; + + sd_emmc_b: sd@ffe05000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe05000 0x0 0x800>; + interrupts = <GIC_SPI 190 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_B>, + <&clkc CLKID_SD_EMMC_B_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_B>; + }; + + sd_emmc_c: mmc@ffe07000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe07000 0x0 0x800>; + interrupts = <GIC_SPI 191 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_C>, + <&clkc CLKID_SD_EMMC_C_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_C>; + }; + usb: usb@ffe09000 { status = "disabled"; compatible = "amlogic,meson-g12a-usb-ctrl"; diff --git a/include/dt-bindings/clock/axg-aoclkc.h b/include/dt-bindings/clock/axg-aoclkc.h index 61955016a5..8ec4a269c7 100644 --- a/include/dt-bindings/clock/axg-aoclkc.h +++ b/include/dt-bindings/clock/axg-aoclkc.h @@ -21,6 +21,11 @@ #define CLKID_AO_SAR_ADC_SEL 8 #define CLKID_AO_SAR_ADC_DIV 9 #define CLKID_AO_SAR_ADC_CLK 10 -#define CLKID_AO_ALT_XTAL 11 +#define CLKID_AO_CTS_OSCIN 11 +#define CLKID_AO_32K_PRE 12 +#define CLKID_AO_32K_DIV 13 +#define CLKID_AO_32K_SEL 14 +#define CLKID_AO_32K 15 +#define CLKID_AO_CTS_RTC_OSCIN 16
#endif diff --git a/include/dt-bindings/clock/axg-audio-clkc.h b/include/dt-bindings/clock/axg-audio-clkc.h index fd9c362099..75901c6368 100644 --- a/include/dt-bindings/clock/axg-audio-clkc.h +++ b/include/dt-bindings/clock/axg-audio-clkc.h @@ -7,26 +7,6 @@ #ifndef __AXG_AUDIO_CLKC_BINDINGS_H #define __AXG_AUDIO_CLKC_BINDINGS_H
-#define AUD_CLKID_SLV_SCLK0 9 -#define AUD_CLKID_SLV_SCLK1 10 -#define AUD_CLKID_SLV_SCLK2 11 -#define AUD_CLKID_SLV_SCLK3 12 -#define AUD_CLKID_SLV_SCLK4 13 -#define AUD_CLKID_SLV_SCLK5 14 -#define AUD_CLKID_SLV_SCLK6 15 -#define AUD_CLKID_SLV_SCLK7 16 -#define AUD_CLKID_SLV_SCLK8 17 -#define AUD_CLKID_SLV_SCLK9 18 -#define AUD_CLKID_SLV_LRCLK0 19 -#define AUD_CLKID_SLV_LRCLK1 20 -#define AUD_CLKID_SLV_LRCLK2 21 -#define AUD_CLKID_SLV_LRCLK3 22 -#define AUD_CLKID_SLV_LRCLK4 23 -#define AUD_CLKID_SLV_LRCLK5 24 -#define AUD_CLKID_SLV_LRCLK6 25 -#define AUD_CLKID_SLV_LRCLK7 26 -#define AUD_CLKID_SLV_LRCLK8 27 -#define AUD_CLKID_SLV_LRCLK9 28 #define AUD_CLKID_DDR_ARB 29 #define AUD_CLKID_PDM 30 #define AUD_CLKID_TDMIN_A 31 @@ -90,5 +70,15 @@ #define AUD_CLKID_TDMOUT_A_LRCLK 134 #define AUD_CLKID_TDMOUT_B_LRCLK 135 #define AUD_CLKID_TDMOUT_C_LRCLK 136 +#define AUD_CLKID_SPDIFOUT_B 151 +#define AUD_CLKID_SPDIFOUT_B_CLK 152 +#define AUD_CLKID_TDM_MCLK_PAD0 155 +#define AUD_CLKID_TDM_MCLK_PAD1 156 +#define AUD_CLKID_TDM_LRCLK_PAD0 157 +#define AUD_CLKID_TDM_LRCLK_PAD1 158 +#define AUD_CLKID_TDM_LRCLK_PAD2 159 +#define AUD_CLKID_TDM_SCLK_PAD0 160 +#define AUD_CLKID_TDM_SCLK_PAD1 161 +#define AUD_CLKID_TDM_SCLK_PAD2 162
#endif /* __AXG_AUDIO_CLKC_BINDINGS_H */ diff --git a/include/dt-bindings/clock/g12a-clkc.h b/include/dt-bindings/clock/g12a-clkc.h index 82c9e0c020..b6b127e456 100644 --- a/include/dt-bindings/clock/g12a-clkc.h +++ b/include/dt-bindings/clock/g12a-clkc.h @@ -130,11 +130,12 @@ #define CLKID_MALI_1_SEL 172 #define CLKID_MALI_1 174 #define CLKID_MALI 175 -#define CLKID_MPLL_5OM 177 +#define CLKID_MPLL_50M 177 #define CLKID_CPU_CLK 187 #define CLKID_PCIE_PLL 201 #define CLKID_VDEC_1 204 #define CLKID_VDEC_HEVC 207 #define CLKID_VDEC_HEVCF 210 +#define CLKID_TS 212
#endif /* __G12A_CLKC_H */
- Copyright (c) 2019 BayLibre, SAS.
- Author: Neil Armstrong narmstrong@baylibre.com
- soc {
"snps,dwmac";
mdio0: mdio {
#size-cells = <0>;
-&periphs_pinctrl {
- emmc_pins: emmc {
mux {
"emmc_nand_d1",
"emmc_nand_d2",
"emmc_nand_d3",
"emmc_nand_d4",
"emmc_nand_d5",
"emmc_nand_d6",
"emmc_nand_d7",
"emmc_clk",
"emmc_cmd";
function = "emmc";
bias-pull-up;
mux {
function = "emmc";
bias-pull-down;
mux {
groups = "BOOT_8";
bias-pull-down;
mux {
"eth_act_led";
function = "eth";
bias-disable;
mux {
"eth_mdc",
"eth_rgmii_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_txen",
"eth_txd0",
"eth_txd1";
function = "eth";
bias-disable;
mux {
"eth_rxd3_rgmii",
"eth_rgmii_tx_clk",
"eth_txd2_rgmii",
"eth_txd3_rgmii";
function = "eth";
bias-disable;
mux {
"sdcard_d1_c",
"sdcard_d2_c",
"sdcard_d3_c",
"sdcard_cmd_c",
"sdcard_clk_c";
bias-pull-up;
mux {
groups = "GPIOC_4";
bias-pull-down;
mux {
"sdcard_d1_z",
"sdcard_d2_z",
"sdcard_d3_z",
"sdcard_cmd_z",
"sdcard_clk_z";
bias-pull-up;
mux {
groups = "GPIOZ_6";
bias-pull-down;
-&periphs {
<&xtal>,
#size-cells = <0>;
ext_mdio: mdio@0 {
reg = <0>;
#size-cells = <0>;
int_mdio: mdio@1 {
reg = <1>;
#size-cells = <0>;
reg = <8>;
max-speed = <100>;
- aliases {
ethernet0 = ðmac;
-ðmac {
- status = "okay";
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- status = "okay";
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- disable-wp;
};ethernet0 = ðmac;
- chosen { stdout-path = "serial0:115200n8"; };
memory@0 {
hdmi-connector {
- memory@0 {
- main_12v: regulator-main_12v { compatible = "regulator-fixed"; regulator-name = "12V";
enable-active-high;
- vcc_1v8: regulator-vcc_1v8 { compatible = "regulator-fixed"; regulator-name = "VCC_1V8";
enable-active-high;
+ðmac {
- status = "okay";
+&ir {
- status = "okay";
- pinctrl-0 = <&remote_input_ao_pins>;
- status = "okay";
- pinctrl-0 = <&i2c0_sda_z0_pins>, <&i2c0_sck_z1_pins>;
- status = "okay";
- pinctrl-0 = <&i2c2_sda_z_pins>, <&i2c2_sck_z_pins>;
- status = "okay";
- pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>;
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- status = "okay";
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- non-removable;
- disable-wp;
- tdmif_a: audio-controller-0 {
- tdmif_b: audio-controller-1 {
- tdmif_c: audio-controller-2 {
- cpus { #address-cells = <0x2>; #size-cells = <0x0>;
"snps,dwmac-3.70a",
"snps,dwmac";
mdio0: mdio {
#size-cells = <0>;
- apb: bus@ff600000 { compatible = "simple-bus"; reg = <0x0 0xff600000 0x0 0x200000>;
#sound-dai-cells = <0>; status = "disabled"; /* VPU VENC Input */
#size-cells = <2>;
hwrng: rng@218 {
mux {
bias-disable;
mux {
bias-disable;
emmc_pins: emmc {
mux-0 {
"emmc_nand_d1",
"emmc_nand_d2",
"emmc_nand_d3",
"emmc_nand_d4",
"emmc_nand_d5",
"emmc_nand_d6",
"emmc_nand_d7",
"emmc_cmd";
function = "emmc";
bias-pull-up;
mux-1 {
function = "emmc";
bias-disable;
mux {
function = "emmc";
bias-pull-down;
mux {
groups = "BOOT_8";
bias-pull-down;
mux {
"hdmitx_sck";
bias-disable;
mux {
bias-disable;
mux {
function = "i2c0";
bias-disable;
mux {
function = "i2c0";
bias-disable;
mux {
function = "i2c0";
bias-disable;
mux {
function = "i2c0";
bias-disable;
mux {
function = "i2c0";
bias-disable;
mux {
function = "i2c0";
bias-disable;
mux {
function = "i2c1";
bias-disable;
mux {
function = "i2c1";
bias-disable;
mux {
function = "i2c1";
bias-disable;
mux {
function = "i2c1";
bias-disable;
mux {
function = "i2c1";
bias-disable;
mux {
function = "i2c1";
bias-disable;
mux {
function = "i2c2";
bias-disable;
mux {
function = "i2c2";
bias-disable;
mux {
function = "i2c2";
bias-disable;
mux {
function = "i2c2";
bias-disable;
mux {
function = "i2c3";
bias-disable;
mux {
function = "i2c3";
bias-disable;
mux {
function = "i2c3";
bias-disable;
mux {
function = "i2c3";
bias-disable;
mux {
groups = "mclk0_a";
function = "mclk0";
bias-disable;
mux {
groups = "mclk1_a";
function = "mclk1";
bias-disable;
mux {
groups = "mclk1_x";
function = "mclk1";
bias-disable;
mux {
groups = "mclk1_z";
function = "mclk1";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
mux {
function = "pdm";
bias-disable;
pwm_a_pins: pwm-a {
mux {
groups = "pwm_a";
function = "pwm_a";
bias-disable;
mux {
function = "pwm_b";
bias-disable;
mux {
function = "pwm_b";
bias-disable;
mux {
groups = "pwm_c_c";
function = "pwm_c";
bias-disable;
mux {
function = "pwm_c";
bias-disable;
mux {
function = "pwm_c";
bias-disable;
mux {
function = "pwm_d";
bias-disable;
mux {
function = "pwm_d";
bias-disable;
pwm_e_pins: pwm-e {
mux {
groups = "pwm_e";
function = "pwm_e";
bias-disable;
mux {
groups = "pwm_f_x";
function = "pwm_f";
bias-disable;
mux {
groups = "pwm_f_h";
function = "pwm_f";
bias-disable;
mux-0 {
"sdcard_d1_c",
"sdcard_d2_c",
"sdcard_d3_c",
"sdcard_cmd_c";
bias-pull-up;
mux-1 {
bias-disable;
mux {
groups = "GPIOC_4";
bias-pull-down;
mux-0 {
"sdcard_d1_z",
"sdcard_d2_z",
"sdcard_d3_z",
"sdcard_cmd_z";
bias-pull-up;
mux-1 {
bias-disable;
mux {
groups = "GPIOZ_6";
bias-pull-down;
sdio_pins: sdio {
mux {
groups = "sdio_d0",
"sdio_d1",
"sdio_d2",
"sdio_d3",
"sdio_clk",
"sdio_cmd";
function = "sdio";
bias-disable;
mux {
groups = "GPIOX_4";
bias-pull-down;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
function = "tdm_a";
bias-disable;
mux {
function = "tdm_a";
bias-disable;
mux {
function = "tdm_a";
bias-disable;
mux {
function = "tdm_a";
bias-disable;
mux {
function = "tdm_a";
bias-disable;
mux {
function = "tdm_a";
bias-disable;
mux {
function = "tdm_a";
bias-disable;
mux {
function = "tdm_a";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_b";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
"eth_act_led";
function = "eth";
bias-disable;
eth_pins: eth {
mux {
"eth_mdc",
"eth_rgmii_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_txen",
"eth_txd0",
"eth_txd1";
function = "eth";
bias-disable;
mux {
"eth_rxd3_rgmii",
"eth_rgmii_tx_clk",
"eth_txd2_rgmii",
"eth_txd3_rgmii";
function = "eth";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
"hdmitx_sck";
function = "tdm_c";
bias-disable;
mux {
function = "tdm_c";
bias-disable;
mux {
"amlogic,axg-pdm";
audio: bus@42000 {
#size-cells = <2>;
#clock-cells = <1>;
"mst_in0",
"mst_in1",
"mst_in2",
"mst_in3",
"mst_in4",
"mst_in5",
"mst_in6",
"mst_in7";
#reset-cells = <1>;
<&xtal>,
#size-cells = <0>;
ext_mdio: mdio@0 {
reg = <0>;
#size-cells = <0>;
int_mdio: mdio@1 {
reg = <1>;
#size-cells = <0>;
reg = <8>;
max-speed = <100>;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
mux {
bias-disable;
#pwm-cells = <3>;
i2c_AO: i2c@5000 {
#size-cells = <0>;
#pwm-cells = <3>;
ir: ir@8000 {
pwm_ef: pwm@19000 {
#pwm-cells = <3>;
pwm_cd: pwm@1a000 {
#pwm-cells = <3>;
pwm_ab: pwm@1b000 {
#pwm-cells = <3>;
i2c3: i2c@1c000 {
#size-cells = <0>;
i2c2: i2c@1d000 {
#size-cells = <0>;
i2c1: i2c@1e000 {
#size-cells = <0>;
i2c0: i2c@1f000 {
#size-cells = <0>;
- usb: usb@ffe09000 { status = "disabled"; compatible = "amlogic,meson-g12a-usb-ctrl";
Applied to u-boot-amlogic
Neil
Neil Armstrong
