[U-Boot] [PATCH v4 0/4] spi-flash: switch to "jedec, spi-nor" binding
There is no reason not to use the Linux "jedec,spi-nor" binding in u-boot. This patchset : - switches all DTS/DTSI files to "jedec,spi-nor" - remove the "spi-flash" compatible from sf-probe - switch GENERIC_SPI_FLASH to jedec,spi-nor in fdtdec - switches dt bindings examples files to "jedec,spi-nor"
Changes since v3: - collected tags - dropped patch 1 - updated for new boards
Changes since v2: - collected tags - extracted x86 dts changed and merged it with the fdtdec change - updated for new boards
Neil Armstrong (4): dts: switch spi-flash to jedec, spi-nor compatible x86: dts: switch spi-flash to jedec, spi-nor compatible mtd: sf_probe: remove spi-flash compatible doc: device-tree-bindings: switch from spi-flash to jedec, spi-nor
arch/arc/dts/axs10x_mb.dtsi | 2 +- arch/arc/dts/hsdk.dts | 2 +- arch/arm/dts/am335x-brppt1-spi.dts | 2 +- arch/arm/dts/am437x-idk-evm.dts | 2 +- arch/arm/dts/am437x-sk-evm.dts | 2 +- arch/arm/dts/armada-3720-db.dts | 2 +- arch/arm/dts/armada-3720-espressobin.dts | 2 +- arch/arm/dts/armada-3720-turris-mox.dts | 2 +- arch/arm/dts/armada-385-amc.dts | 2 +- arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 2 +- arch/arm/dts/armada-38x-controlcenterdc.dts | 4 ++-- arch/arm/dts/armada-38x-solidrun-microsom.dtsi | 2 +- arch/arm/dts/armada-8040-clearfog-gt-8k.dts | 2 +- arch/arm/dts/armada-xp-theadorable.dts | 2 +- arch/arm/dts/at91-sama5d2_xplained.dts | 2 +- arch/arm/dts/at91-sama5d4_xplained.dts | 2 +- arch/arm/dts/at91-sama5d4ek.dts | 2 +- arch/arm/dts/at91sam9n12ek.dts | 2 +- arch/arm/dts/at91sam9x5ek.dtsi | 2 +- arch/arm/dts/bk4r1.dts | 4 ++-- arch/arm/dts/da850-evm-u-boot.dtsi | 2 +- arch/arm/dts/exynos5250-snow.dts | 2 +- arch/arm/dts/exynos5250-spring.dts | 2 +- arch/arm/dts/exynos5420-peach-pit.dts | 2 +- arch/arm/dts/fsl-ls1012a-2g5rdb.dts | 2 +- arch/arm/dts/fsl-ls1012a-frdm.dtsi | 2 +- arch/arm/dts/fsl-ls1012a-frwy.dts | 2 +- arch/arm/dts/fsl-ls1012a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1012a-rdb.dtsi | 2 +- arch/arm/dts/fsl-ls1043a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1043a-rdb.dts | 2 +- arch/arm/dts/fsl-ls1046a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1046a-rdb.dts | 4 ++-- arch/arm/dts/fsl-ls1088a-qds.dts | 10 +++++----- arch/arm/dts/fsl-ls1088a-rdb.dts | 4 ++-- arch/arm/dts/fsl-ls2080a-qds.dts | 8 ++++---- arch/arm/dts/fsl-ls2080a-rdb.dts | 2 +- arch/arm/dts/fsl-ls2081a-rdb.dts | 6 +++--- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 6 +++--- arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi | 4 ++-- arch/arm/dts/imx6sx-sdb-u-boot.dtsi | 4 ++-- arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx6ul-9x9-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx6ull-14x14-evk.dts | 2 +- arch/arm/dts/imx7d-sdb-qspi-u-boot.dtsi | 2 +- arch/arm/dts/keystone-k2e-evm.dts | 2 +- arch/arm/dts/keystone-k2g-evm.dts | 4 ++-- arch/arm/dts/keystone-k2g-ice.dts | 2 +- arch/arm/dts/keystone-k2hk-evm.dts | 2 +- arch/arm/dts/keystone-k2l-evm.dts | 2 +- arch/arm/dts/kirkwood-atl-sbx81lifkw.dts | 2 +- arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts | 2 +- arch/arm/dts/kirkwood-dreamplug.dts | 2 +- arch/arm/dts/kirkwood-lsxl.dtsi | 2 +- arch/arm/dts/kirkwood-netxbig.dtsi | 2 +- arch/arm/dts/kirkwood-ns2-common.dtsi | 2 +- arch/arm/dts/kirkwood-synology.dtsi | 2 +- arch/arm/dts/ls1021a-iot.dtsi | 4 ++-- arch/arm/dts/ls1021a-qds.dtsi | 2 +- arch/arm/dts/ls1021a-twr.dtsi | 4 ++-- arch/arm/dts/mt7629-rfb.dts | 2 +- arch/arm/dts/omap5-u-boot.dtsi | 2 +- arch/arm/dts/r8a77970-eagle-u-boot.dts | 2 +- arch/arm/dts/rk3288-veyron.dtsi | 2 +- arch/arm/dts/rk3368-lion.dts | 2 +- arch/arm/dts/rk3399-gru.dtsi | 2 +- arch/arm/dts/rk3399-puma.dtsi | 2 +- arch/arm/dts/rv1108-evb.dts | 2 +- arch/arm/dts/sama5d27_som1.dtsi | 2 +- arch/arm/dts/sama5d3xmb.dtsi | 2 +- arch/arm/dts/sama5d3xmb_cmp.dtsi | 2 +- arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_is1.dts | 2 +- arch/arm/dts/socfpga_cyclone5_socdk-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_sockit-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_socrates-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_sr1500.dts | 2 +- arch/arm/dts/socfpga_cyclone5_vining_fpga-u-boot.dtsi | 4 ++-- arch/arm/dts/stm32f746-disco.dts | 2 +- arch/arm/dts/stm32f769-disco.dts | 2 +- arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 4 ++-- arch/arm/dts/stv0991.dts | 2 +- arch/arm/dts/zynq-zed.dts | 2 +- arch/arm/dts/zynqmp-zc1232-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1254-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1275-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1275-revB.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 2 +- arch/arm/dts/zynqmp-zcu102-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revC.dts | 2 +- arch/arm/dts/zynqmp-zcu106-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu111-revA.dts | 2 +- arch/mips/dts/ap121.dts | 2 +- arch/mips/dts/ap143.dts | 2 +- arch/mips/dts/comtrend,ar-5315u.dts | 2 +- arch/mips/dts/comtrend,ar-5387un.dts | 2 +- arch/mips/dts/gardena-smart-gateway-mt7688.dts | 2 +- arch/mips/dts/jr2_pcb110.dts | 2 +- arch/mips/dts/jr2_pcb111.dts | 2 +- arch/mips/dts/linkit-smart-7688.dts | 2 +- arch/mips/dts/luton_pcb090.dts | 2 +- arch/mips/dts/luton_pcb091.dts | 2 +- arch/mips/dts/mscc,ocelot_pcb.dtsi | 2 +- arch/mips/dts/netgear,cg3100d.dts | 2 +- arch/mips/dts/sagem,f@st1704.dts | 2 +- arch/mips/dts/serval2_pcb112.dts | 2 +- arch/mips/dts/serval_pcb105.dts | 2 +- arch/mips/dts/serval_pcb106.dts | 2 +- arch/mips/dts/servalt_pcb116.dts | 2 +- arch/mips/dts/tplink_wdr4300.dts | 2 +- arch/nds32/dts/ae3xx.dts | 2 +- arch/riscv/dts/ae350_32.dts | 2 +- arch/riscv/dts/ae350_64.dts | 2 +- arch/sandbox/dts/test.dts | 2 +- arch/x86/dts/bayleybay.dts | 2 +- arch/x86/dts/baytrail_som-db5800-som-6867.dts | 2 +- arch/x86/dts/cherryhill.dts | 2 +- arch/x86/dts/chromebook_link.dts | 2 +- arch/x86/dts/chromebook_samus.dts | 2 +- arch/x86/dts/chromebox_panther.dts | 2 +- arch/x86/dts/conga-qeval20-qa3-e3845.dts | 2 +- arch/x86/dts/cougarcanyon2.dts | 2 +- arch/x86/dts/crownbay.dts | 2 +- arch/x86/dts/dfi-bt700.dtsi | 2 +- arch/x86/dts/galileo.dts | 2 +- arch/x86/dts/minnowmax.dts | 2 +- doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt | 2 +- doc/device-tree-bindings/spi/spi-atcspi200.txt | 2 +- doc/device-tree-bindings/spi/spi-stm32-qspi.txt | 2 +- drivers/mtd/spi/sf_probe.c | 1 - lib/fdtdec.c | 2 +- 133 files changed, 163 insertions(+), 164 deletions(-)
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it.
This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present.
The x86 dts are switched in a separate commit since it depends on a change in fdtdec.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com Acked-by: Stefan Roese sr@denx.de Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Evgeniy Paltsev paltsev@synopsys.com Reviewed-by: Rick Chen rick@andestech.com Reviewed-by: Patrick Delaunay Patrick.delaunay@st.com --- arch/arc/dts/axs10x_mb.dtsi | 2 +- arch/arc/dts/hsdk.dts | 2 +- arch/arm/dts/am335x-brppt1-spi.dts | 2 +- arch/arm/dts/am437x-idk-evm.dts | 2 +- arch/arm/dts/am437x-sk-evm.dts | 2 +- arch/arm/dts/armada-3720-db.dts | 2 +- arch/arm/dts/armada-3720-espressobin.dts | 2 +- arch/arm/dts/armada-3720-turris-mox.dts | 2 +- arch/arm/dts/armada-385-amc.dts | 2 +- arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 2 +- arch/arm/dts/armada-38x-controlcenterdc.dts | 4 ++-- arch/arm/dts/armada-38x-solidrun-microsom.dtsi | 2 +- arch/arm/dts/armada-8040-clearfog-gt-8k.dts | 2 +- arch/arm/dts/armada-xp-theadorable.dts | 2 +- arch/arm/dts/at91-sama5d2_xplained.dts | 2 +- arch/arm/dts/at91-sama5d4_xplained.dts | 2 +- arch/arm/dts/at91-sama5d4ek.dts | 2 +- arch/arm/dts/at91sam9n12ek.dts | 2 +- arch/arm/dts/at91sam9x5ek.dtsi | 2 +- arch/arm/dts/bk4r1.dts | 4 ++-- arch/arm/dts/da850-evm-u-boot.dtsi | 2 +- arch/arm/dts/exynos5250-snow.dts | 2 +- arch/arm/dts/exynos5250-spring.dts | 2 +- arch/arm/dts/exynos5420-peach-pit.dts | 2 +- arch/arm/dts/fsl-ls1012a-2g5rdb.dts | 2 +- arch/arm/dts/fsl-ls1012a-frdm.dtsi | 2 +- arch/arm/dts/fsl-ls1012a-frwy.dts | 2 +- arch/arm/dts/fsl-ls1012a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1012a-rdb.dtsi | 2 +- arch/arm/dts/fsl-ls1043a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1043a-rdb.dts | 2 +- arch/arm/dts/fsl-ls1046a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1046a-rdb.dts | 4 ++-- arch/arm/dts/fsl-ls1088a-qds.dts | 10 +++++----- arch/arm/dts/fsl-ls1088a-rdb.dts | 4 ++-- arch/arm/dts/fsl-ls2080a-qds.dts | 8 ++++---- arch/arm/dts/fsl-ls2080a-rdb.dts | 2 +- arch/arm/dts/fsl-ls2081a-rdb.dts | 6 +++--- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 6 +++--- arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi | 4 ++-- arch/arm/dts/imx6sx-sdb-u-boot.dtsi | 4 ++-- arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx6ul-9x9-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx6ull-14x14-evk.dts | 2 +- arch/arm/dts/imx7d-sdb-qspi-u-boot.dtsi | 2 +- arch/arm/dts/keystone-k2e-evm.dts | 2 +- arch/arm/dts/keystone-k2g-evm.dts | 4 ++-- arch/arm/dts/keystone-k2g-ice.dts | 2 +- arch/arm/dts/keystone-k2hk-evm.dts | 2 +- arch/arm/dts/keystone-k2l-evm.dts | 2 +- arch/arm/dts/kirkwood-atl-sbx81lifkw.dts | 2 +- arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts | 2 +- arch/arm/dts/kirkwood-dreamplug.dts | 2 +- arch/arm/dts/kirkwood-lsxl.dtsi | 2 +- arch/arm/dts/kirkwood-netxbig.dtsi | 2 +- arch/arm/dts/kirkwood-ns2-common.dtsi | 2 +- arch/arm/dts/kirkwood-synology.dtsi | 2 +- arch/arm/dts/ls1021a-iot.dtsi | 4 ++-- arch/arm/dts/ls1021a-qds.dtsi | 2 +- arch/arm/dts/ls1021a-twr.dtsi | 4 ++-- arch/arm/dts/mt7629-rfb.dts | 2 +- arch/arm/dts/omap5-u-boot.dtsi | 2 +- arch/arm/dts/r8a77970-eagle-u-boot.dts | 2 +- arch/arm/dts/rk3288-veyron.dtsi | 2 +- arch/arm/dts/rk3368-lion.dts | 2 +- arch/arm/dts/rk3399-gru.dtsi | 2 +- arch/arm/dts/rk3399-puma.dtsi | 2 +- arch/arm/dts/rv1108-evb.dts | 2 +- arch/arm/dts/sama5d27_som1.dtsi | 2 +- arch/arm/dts/sama5d3xmb.dtsi | 2 +- arch/arm/dts/sama5d3xmb_cmp.dtsi | 2 +- arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_is1.dts | 2 +- arch/arm/dts/socfpga_cyclone5_socdk-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_sockit-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_socrates-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_sr1500.dts | 2 +- arch/arm/dts/socfpga_cyclone5_vining_fpga-u-boot.dtsi | 4 ++-- arch/arm/dts/stm32f746-disco.dts | 2 +- arch/arm/dts/stm32f769-disco.dts | 2 +- arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 4 ++-- arch/arm/dts/stv0991.dts | 2 +- arch/arm/dts/zynq-zed.dts | 2 +- arch/arm/dts/zynqmp-zc1232-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1254-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1275-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1275-revB.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 2 +- arch/arm/dts/zynqmp-zcu102-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revC.dts | 2 +- arch/arm/dts/zynqmp-zcu106-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu111-revA.dts | 2 +- arch/mips/dts/ap121.dts | 2 +- arch/mips/dts/ap143.dts | 2 +- arch/mips/dts/comtrend,ar-5315u.dts | 2 +- arch/mips/dts/comtrend,ar-5387un.dts | 2 +- arch/mips/dts/gardena-smart-gateway-mt7688.dts | 2 +- arch/mips/dts/jr2_pcb110.dts | 2 +- arch/mips/dts/jr2_pcb111.dts | 2 +- arch/mips/dts/linkit-smart-7688.dts | 2 +- arch/mips/dts/luton_pcb090.dts | 2 +- arch/mips/dts/luton_pcb091.dts | 2 +- arch/mips/dts/mscc,ocelot_pcb.dtsi | 2 +- arch/mips/dts/netgear,cg3100d.dts | 2 +- arch/mips/dts/sagem,f@st1704.dts | 2 +- arch/mips/dts/serval2_pcb112.dts | 2 +- arch/mips/dts/serval_pcb105.dts | 2 +- arch/mips/dts/serval_pcb106.dts | 2 +- arch/mips/dts/servalt_pcb116.dts | 2 +- arch/mips/dts/tplink_wdr4300.dts | 2 +- arch/nds32/dts/ae3xx.dts | 2 +- arch/riscv/dts/ae350_32.dts | 2 +- arch/riscv/dts/ae350_64.dts | 2 +- arch/sandbox/dts/test.dts | 2 +- 116 files changed, 147 insertions(+), 147 deletions(-)
diff --git a/arch/arc/dts/axs10x_mb.dtsi b/arch/arc/dts/axs10x_mb.dtsi index dfc0381..b5aacd5 100644 --- a/arch/arc/dts/axs10x_mb.dtsi +++ b/arch/arc/dts/axs10x_mb.dtsi @@ -71,7 +71,7 @@ clock-names = "spi_clk"; cs-gpio = <&cs_gpio 0>; spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <4000000>; }; diff --git a/arch/arc/dts/hsdk.dts b/arch/arc/dts/hsdk.dts index f024b96..5e9ba05 100644 --- a/arch/arc/dts/hsdk.dts +++ b/arch/arc/dts/hsdk.dts @@ -96,7 +96,7 @@ clock-names = "spi_clk"; cs-gpio = <&cs_gpio 0>; spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <4000000>; }; diff --git a/arch/arm/dts/am335x-brppt1-spi.dts b/arch/arm/dts/am335x-brppt1-spi.dts index 522ed50..01ab74b 100644 --- a/arch/arm/dts/am335x-brppt1-spi.dts +++ b/arch/arm/dts/am335x-brppt1-spi.dts @@ -169,7 +169,7 @@ spi_flash: spiflash@0 { u-boot,dm-spl; u-boot,dm-pre-reloc; - compatible = "spidev", "spi-flash"; + compatible = "spidev", "jedec,spi-nor"; spi-max-frequency = <24000000>; reg = <0>; }; diff --git a/arch/arm/dts/am437x-idk-evm.dts b/arch/arm/dts/am437x-idk-evm.dts index 28e3e1b..19d1462 100644 --- a/arch/arm/dts/am437x-idk-evm.dts +++ b/arch/arm/dts/am437x-idk-evm.dts @@ -339,7 +339,7 @@
spi-max-frequency = <48000000>; m25p80@0 { - compatible = "mx66l51235l", "spi-flash"; + compatible = "mx66l51235l", "jedec,spi-nor"; spi-max-frequency = <48000000>; reg = <0>; spi-cpol; diff --git a/arch/arm/dts/am437x-sk-evm.dts b/arch/arm/dts/am437x-sk-evm.dts index 927d8d3..dc8fcde 100644 --- a/arch/arm/dts/am437x-sk-evm.dts +++ b/arch/arm/dts/am437x-sk-evm.dts @@ -568,7 +568,7 @@
spi-max-frequency = <48000000>; m25p80@0 { - compatible = "mx66l51235l","spi-flash"; + compatible = "mx66l51235l","jedec,spi-nor"; spi-max-frequency = <48000000>; reg = <0>; spi-cpol; diff --git a/arch/arm/dts/armada-3720-db.dts b/arch/arm/dts/armada-3720-db.dts index 770c08a..1b219c4 100644 --- a/arch/arm/dts/armada-3720-db.dts +++ b/arch/arm/dts/armada-3720-db.dts @@ -131,7 +131,7 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "st,m25p128", "spi-flash"; + compatible = "st,m25p128", "jedec,spi-nor"; reg = <0>; /* Chip select 0 */ spi-max-frequency = <50000000>; m25p,fast-read; diff --git a/arch/arm/dts/armada-3720-espressobin.dts b/arch/arm/dts/armada-3720-espressobin.dts index 7bfccb0..84e2c2a 100644 --- a/arch/arm/dts/armada-3720-espressobin.dts +++ b/arch/arm/dts/armada-3720-espressobin.dts @@ -118,7 +118,7 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "st,m25p128", "spi-flash"; + compatible = "st,m25p128", "jedec,spi-nor"; reg = <0>; /* Chip select 0 */ spi-max-frequency = <50000000>; m25p,fast-read; diff --git a/arch/arm/dts/armada-3720-turris-mox.dts b/arch/arm/dts/armada-3720-turris-mox.dts index 14bec09..c36a5b8 100644 --- a/arch/arm/dts/armada-3720-turris-mox.dts +++ b/arch/arm/dts/armada-3720-turris-mox.dts @@ -115,7 +115,7 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "st,s25fl064l", "spi-flash"; + compatible = "st,s25fl064l", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <20000000>; m25p,fast-read; diff --git a/arch/arm/dts/armada-385-amc.dts b/arch/arm/dts/armada-385-amc.dts index d4d127f..93c80e3 100644 --- a/arch/arm/dts/armada-385-amc.dts +++ b/arch/arm/dts/armada-385-amc.dts @@ -154,7 +154,7 @@ u-boot,dm-pre-reloc; #address-cells = <1>; #size-cells = <1>; - compatible = "st,m25p128", "jedec,spi-nor", "spi-flash"; + compatible = "st,m25p128", "jedec,spi-nor"; reg = <0>; /* Chip select 0 */ spi-max-frequency = <50000000>; m25p,fast-read; diff --git a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi index 904429b..1b46797 100644 --- a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi +++ b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi @@ -42,7 +42,7 @@ u-boot,dm-pre-reloc;
spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <40000000>; u-boot,dm-pre-reloc; diff --git a/arch/arm/dts/armada-38x-controlcenterdc.dts b/arch/arm/dts/armada-38x-controlcenterdc.dts index ffbd0dc..00f74b9 100644 --- a/arch/arm/dts/armada-38x-controlcenterdc.dts +++ b/arch/arm/dts/armada-38x-controlcenterdc.dts @@ -573,14 +573,14 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "n25q016a", "spi-flash"; + compatible = "n25q016a", "jedec,spi-nor"; reg = <0>; /* Chip select 0 */ spi-max-frequency = <108000000>; }; spi-flash@1 { #address-cells = <1>; #size-cells = <1>; - compatible = "n25q128a11", "spi-flash"; + compatible = "n25q128a11", "jedec,spi-nor"; reg = <1>; /* Chip select 1 */ spi-max-frequency = <108000000>; u-boot,dm-pre-reloc; diff --git a/arch/arm/dts/armada-38x-solidrun-microsom.dtsi b/arch/arm/dts/armada-38x-solidrun-microsom.dtsi index 74f58de..a262722 100644 --- a/arch/arm/dts/armada-38x-solidrun-microsom.dtsi +++ b/arch/arm/dts/armada-38x-solidrun-microsom.dtsi @@ -86,7 +86,7 @@ w25q32: spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "w25q32", "jedec,spi-nor", "spi-flash"; + compatible = "w25q32", "jedec,spi-nor"; reg = <0>; /* Chip select 0 */ spi-max-frequency = <3000000>; status = "disabled"; diff --git a/arch/arm/dts/armada-8040-clearfog-gt-8k.dts b/arch/arm/dts/armada-8040-clearfog-gt-8k.dts index 498105f..659a9c9 100644 --- a/arch/arm/dts/armada-8040-clearfog-gt-8k.dts +++ b/arch/arm/dts/armada-8040-clearfog-gt-8k.dts @@ -232,7 +232,7 @@ status = "okay";
spi-flash@0 { - compatible = "jedec,spi-nor", "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <10000000>;
diff --git a/arch/arm/dts/armada-xp-theadorable.dts b/arch/arm/dts/armada-xp-theadorable.dts index 5695e9b..b0f6c2b 100644 --- a/arch/arm/dts/armada-xp-theadorable.dts +++ b/arch/arm/dts/armada-xp-theadorable.dts @@ -134,7 +134,7 @@ u-boot,dm-pre-reloc; #address-cells = <1>; #size-cells = <1>; - compatible = "n25q128a13", "jedec,spi-nor", "spi-flash"; + compatible = "n25q128a13", "jedec,spi-nor"; reg = <0>; /* Chip select 0 */ spi-max-frequency = <27777777>; }; diff --git a/arch/arm/dts/at91-sama5d2_xplained.dts b/arch/arm/dts/at91-sama5d2_xplained.dts index 33064b3..c0708fe 100644 --- a/arch/arm/dts/at91-sama5d2_xplained.dts +++ b/arch/arm/dts/at91-sama5d2_xplained.dts @@ -110,7 +110,7 @@ u-boot,dm-pre-reloc;
spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <50000000>; u-boot,dm-pre-reloc; diff --git a/arch/arm/dts/at91-sama5d4_xplained.dts b/arch/arm/dts/at91-sama5d4_xplained.dts index 58a0e60..7da5086 100644 --- a/arch/arm/dts/at91-sama5d4_xplained.dts +++ b/arch/arm/dts/at91-sama5d4_xplained.dts @@ -117,7 +117,7 @@ status = "okay"; spi_flash@0 { u-boot,dm-pre-reloc; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; diff --git a/arch/arm/dts/at91-sama5d4ek.dts b/arch/arm/dts/at91-sama5d4ek.dts index a5d7545..c1d6578 100644 --- a/arch/arm/dts/at91-sama5d4ek.dts +++ b/arch/arm/dts/at91-sama5d4ek.dts @@ -137,7 +137,7 @@ status = "okay"; spi_flash@0 { u-boot,dm-pre-reloc; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; diff --git a/arch/arm/dts/at91sam9n12ek.dts b/arch/arm/dts/at91sam9n12ek.dts index 888bda1..64a7abf 100644 --- a/arch/arm/dts/at91sam9n12ek.dts +++ b/arch/arm/dts/at91sam9n12ek.dts @@ -112,7 +112,7 @@ status = "okay"; cs-gpios = <&pioA 14 0>, <0>, <0>, <0>; spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; diff --git a/arch/arm/dts/at91sam9x5ek.dtsi b/arch/arm/dts/at91sam9x5ek.dtsi index f2a532d..1f7f37b 100644 --- a/arch/arm/dts/at91sam9x5ek.dtsi +++ b/arch/arm/dts/at91sam9x5ek.dtsi @@ -121,7 +121,7 @@ status = "okay"; cs-gpios = <&pioA 14 0>, <0>, <0>, <0>; spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; diff --git a/arch/arm/dts/bk4r1.dts b/arch/arm/dts/bk4r1.dts index 866b80e..16c6026 100644 --- a/arch/arm/dts/bk4r1.dts +++ b/arch/arm/dts/bk4r1.dts @@ -32,7 +32,7 @@ qflash0: spi_flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <108000000>; reg = <0>; }; @@ -40,7 +40,7 @@ qflash1: spi_flash@1 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <66000000>; reg = <1>; }; diff --git a/arch/arm/dts/da850-evm-u-boot.dtsi b/arch/arm/dts/da850-evm-u-boot.dtsi index ab1de77..360e79e 100644 --- a/arch/arm/dts/da850-evm-u-boot.dtsi +++ b/arch/arm/dts/da850-evm-u-boot.dtsi @@ -7,5 +7,5 @@ */
&flash { - compatible = "m25p64", "spi-flash"; + compatible = "m25p64", "jedec,spi-nor"; }; diff --git a/arch/arm/dts/exynos5250-snow.dts b/arch/arm/dts/exynos5250-snow.dts index 7587dc0..e41f2d3 100644 --- a/arch/arm/dts/exynos5250-snow.dts +++ b/arch/arm/dts/exynos5250-snow.dts @@ -232,7 +232,7 @@ spi@12d30000 { spi-max-frequency = <50000000>; firmware_storage_spi: flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; }; }; diff --git a/arch/arm/dts/exynos5250-spring.dts b/arch/arm/dts/exynos5250-spring.dts index 191e12a..ae142a6 100644 --- a/arch/arm/dts/exynos5250-spring.dts +++ b/arch/arm/dts/exynos5250-spring.dts @@ -96,7 +96,7 @@ spi@12d30000 { spi-max-frequency = <50000000>; firmware_storage_spi: flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; }; }; diff --git a/arch/arm/dts/exynos5420-peach-pit.dts b/arch/arm/dts/exynos5420-peach-pit.dts index 4a96a18..a68c3b5 100644 --- a/arch/arm/dts/exynos5420-peach-pit.dts +++ b/arch/arm/dts/exynos5420-peach-pit.dts @@ -257,7 +257,7 @@ spi@12d30000 { /* spi1 */ spi-max-frequency = <50000000>; firmware_storage_spi: flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>;
/* diff --git a/arch/arm/dts/fsl-ls1012a-2g5rdb.dts b/arch/arm/dts/fsl-ls1012a-2g5rdb.dts index cdd4ce4..fecef88 100644 --- a/arch/arm/dts/fsl-ls1012a-2g5rdb.dts +++ b/arch/arm/dts/fsl-ls1012a-2g5rdb.dts @@ -27,7 +27,7 @@ qflash0: s25fl128s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls1012a-frdm.dtsi b/arch/arm/dts/fsl-ls1012a-frdm.dtsi index 9cb3de1..a357793 100644 --- a/arch/arm/dts/fsl-ls1012a-frdm.dtsi +++ b/arch/arm/dts/fsl-ls1012a-frdm.dtsi @@ -21,7 +21,7 @@ qflash0: s25fl128s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls1012a-frwy.dts b/arch/arm/dts/fsl-ls1012a-frwy.dts index a56909a..7242af5 100644 --- a/arch/arm/dts/fsl-ls1012a-frwy.dts +++ b/arch/arm/dts/fsl-ls1012a-frwy.dts @@ -28,7 +28,7 @@ qflash0: w25q16dw@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls1012a-qds.dtsi b/arch/arm/dts/fsl-ls1012a-qds.dtsi index 661af0e..a330597 100644 --- a/arch/arm/dts/fsl-ls1012a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1012a-qds.dtsi @@ -20,7 +20,7 @@ dflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <1000000>; /* input clock */ }; @@ -28,7 +28,7 @@ dflash1: sst25wf040b { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3500000>; reg = <1>; }; @@ -36,7 +36,7 @@ dflash2: en25s64 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3500000>; reg = <2>; }; @@ -49,7 +49,7 @@ qflash0: s25fl128s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls1012a-rdb.dtsi b/arch/arm/dts/fsl-ls1012a-rdb.dtsi index 757e2eb..f053e78 100644 --- a/arch/arm/dts/fsl-ls1012a-rdb.dtsi +++ b/arch/arm/dts/fsl-ls1012a-rdb.dtsi @@ -21,7 +21,7 @@ qflash0: s25fl128s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls1043a-qds.dtsi b/arch/arm/dts/fsl-ls1043a-qds.dtsi index 3841aee..70e1a6a 100644 --- a/arch/arm/dts/fsl-ls1043a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1043a-qds.dtsi @@ -24,7 +24,7 @@ dflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <1000000>; /* input clock */ spi-cpol; spi-cpha; @@ -34,7 +34,7 @@ dflash1: sst25wf040b { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3500000>; spi-cpol; spi-cpha; @@ -44,7 +44,7 @@ dflash2: en25s64 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3500000>; spi-cpol; spi-cpha; @@ -59,7 +59,7 @@ qflash0: s25fl128s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls1043a-rdb.dts b/arch/arm/dts/fsl-ls1043a-rdb.dts index c42cad7..721b158 100644 --- a/arch/arm/dts/fsl-ls1043a-rdb.dts +++ b/arch/arm/dts/fsl-ls1043a-rdb.dts @@ -26,7 +26,7 @@ dspiflash: n25q12a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <1000000>; /* input clock */ }; diff --git a/arch/arm/dts/fsl-ls1046a-qds.dtsi b/arch/arm/dts/fsl-ls1046a-qds.dtsi index ada8a85..c95f44f 100644 --- a/arch/arm/dts/fsl-ls1046a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1046a-qds.dtsi @@ -24,7 +24,7 @@ dflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <1000000>; /* input clock */ spi-cpol; spi-cpha; @@ -34,7 +34,7 @@ dflash1: sst25wf040b { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3500000>; spi-cpol; spi-cpha; @@ -44,7 +44,7 @@ dflash2: en25s64 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3500000>; spi-cpol; spi-cpha; @@ -59,7 +59,7 @@ qflash0: s25fl128s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls1046a-rdb.dts b/arch/arm/dts/fsl-ls1046a-rdb.dts index ba30fd2..a05c9e9 100644 --- a/arch/arm/dts/fsl-ls1046a-rdb.dts +++ b/arch/arm/dts/fsl-ls1046a-rdb.dts @@ -26,7 +26,7 @@ qflash0: s25fs512s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; @@ -34,7 +34,7 @@ qflash1: s25fs512s@1 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <1>; }; diff --git a/arch/arm/dts/fsl-ls1088a-qds.dts b/arch/arm/dts/fsl-ls1088a-qds.dts index 4ea451c..8fbb52f 100644 --- a/arch/arm/dts/fsl-ls1088a-qds.dts +++ b/arch/arm/dts/fsl-ls1088a-qds.dts @@ -62,7 +62,7 @@ dflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <1000000>; /* input clock */ }; @@ -70,7 +70,7 @@ dflash1: sst25wf040b { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3500000>; reg = <1>; }; @@ -78,7 +78,7 @@ dflash2: en25s64 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3500000>; reg = <2>; }; @@ -91,7 +91,7 @@ qflash0: s25fs512s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; @@ -99,7 +99,7 @@ qflash1: s25fs512s@1 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <1>; }; diff --git a/arch/arm/dts/fsl-ls1088a-rdb.dts b/arch/arm/dts/fsl-ls1088a-rdb.dts index f30bbb7..765d1e3 100644 --- a/arch/arm/dts/fsl-ls1088a-rdb.dts +++ b/arch/arm/dts/fsl-ls1088a-rdb.dts @@ -24,7 +24,7 @@ qflash0: s25fs512s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; @@ -32,7 +32,7 @@ qflash1: s25fs512s@1 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <1>; }; diff --git a/arch/arm/dts/fsl-ls2080a-qds.dts b/arch/arm/dts/fsl-ls2080a-qds.dts index 39fbc1b..2a0a528 100644 --- a/arch/arm/dts/fsl-ls2080a-qds.dts +++ b/arch/arm/dts/fsl-ls2080a-qds.dts @@ -26,7 +26,7 @@ dflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3000000>; spi-cpol; spi-cpha; @@ -35,7 +35,7 @@ dflash1: sst25wf040b { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3000000>; spi-cpol; spi-cpha; @@ -44,7 +44,7 @@ dflash2: en25s64 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3000000>; spi-cpol; spi-cpha; @@ -59,7 +59,7 @@ qflash0: s25fs256s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls2080a-rdb.dts b/arch/arm/dts/fsl-ls2080a-rdb.dts index e7567cf..0a87cae 100644 --- a/arch/arm/dts/fsl-ls2080a-rdb.dts +++ b/arch/arm/dts/fsl-ls2080a-rdb.dts @@ -25,7 +25,7 @@ dflash0: n25q512a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3000000>; spi-cpol; spi-cpha; diff --git a/arch/arm/dts/fsl-ls2081a-rdb.dts b/arch/arm/dts/fsl-ls2081a-rdb.dts index 73e2683..b0b7ef0 100644 --- a/arch/arm/dts/fsl-ls2081a-rdb.dts +++ b/arch/arm/dts/fsl-ls2081a-rdb.dts @@ -28,7 +28,7 @@ dflash0: n25q512a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3000000>; spi-cpol; spi-cpha; @@ -43,7 +43,7 @@ qflash0: s25fs512s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; @@ -51,7 +51,7 @@ qflash1: s25fs512s@1 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <1>; }; diff --git a/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts b/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts index b6d4f0f..bf97d13 100644 --- a/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts +++ b/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts @@ -28,7 +28,7 @@ dflash0: n25q512a { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <3000000>; spi-cpol; spi-cpha; @@ -43,7 +43,7 @@ qflash0: s25fs512s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; @@ -51,7 +51,7 @@ qflash1: s25fs512s@1 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <1>; }; diff --git a/arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi b/arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi index f5c68d7..549461d 100644 --- a/arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi +++ b/arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi @@ -7,10 +7,10 @@ num-cs = <2>;
flash0: n25q256a@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; };
flash1: n25q256a@1 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; }; }; diff --git a/arch/arm/dts/imx6sx-sdb-u-boot.dtsi b/arch/arm/dts/imx6sx-sdb-u-boot.dtsi index 8e592cd..8f9236d 100644 --- a/arch/arm/dts/imx6sx-sdb-u-boot.dtsi +++ b/arch/arm/dts/imx6sx-sdb-u-boot.dtsi @@ -7,10 +7,10 @@ num-cs = <2>;
flash1: n25q256a@1 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; }; }; diff --git a/arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi b/arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi index db640d6..77cb461 100644 --- a/arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi +++ b/arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi @@ -5,6 +5,6 @@
&qspi { flash0: n25q256a@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; }; }; \ No newline at end of file diff --git a/arch/arm/dts/imx6ul-9x9-evk-u-boot.dtsi b/arch/arm/dts/imx6ul-9x9-evk-u-boot.dtsi index db640d6..77cb461 100644 --- a/arch/arm/dts/imx6ul-9x9-evk-u-boot.dtsi +++ b/arch/arm/dts/imx6ul-9x9-evk-u-boot.dtsi @@ -5,6 +5,6 @@
&qspi { flash0: n25q256a@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; }; }; \ No newline at end of file diff --git a/arch/arm/dts/imx6ull-14x14-evk.dts b/arch/arm/dts/imx6ull-14x14-evk.dts index 8a1b67d..9ebcfe1 100644 --- a/arch/arm/dts/imx6ull-14x14-evk.dts +++ b/arch/arm/dts/imx6ull-14x14-evk.dts @@ -455,7 +455,7 @@ #address-cells = <1>; #size-cells = <1>; /* compatible = "micron,n25q256a"; */ - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <29000000>; spi-nor,ddr-quad-read-dummy = <6>; reg = <0>; diff --git a/arch/arm/dts/imx7d-sdb-qspi-u-boot.dtsi b/arch/arm/dts/imx7d-sdb-qspi-u-boot.dtsi index 2ce6961..585af6d 100644 --- a/arch/arm/dts/imx7d-sdb-qspi-u-boot.dtsi +++ b/arch/arm/dts/imx7d-sdb-qspi-u-boot.dtsi @@ -5,6 +5,6 @@
&qspi1 { flash0: mx25l51245g@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; }; }; diff --git a/arch/arm/dts/keystone-k2e-evm.dts b/arch/arm/dts/keystone-k2e-evm.dts index 3be8b53..9288df2 100644 --- a/arch/arm/dts/keystone-k2e-evm.dts +++ b/arch/arm/dts/keystone-k2e-evm.dts @@ -123,7 +123,7 @@ nor_flash: n25q128a11@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "Micron,n25q128a11", "spi-flash"; + compatible = "Micron,n25q128a11", "jedec,spi-nor"; spi-max-frequency = <54000000>; m25p,fast-read; reg = <0>; diff --git a/arch/arm/dts/keystone-k2g-evm.dts b/arch/arm/dts/keystone-k2g-evm.dts index 6c9de25..d91869f 100644 --- a/arch/arm/dts/keystone-k2g-evm.dts +++ b/arch/arm/dts/keystone-k2g-evm.dts @@ -75,7 +75,7 @@ spi_nor: flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; m25p,fast-read; reg = <0>; @@ -97,7 +97,7 @@ status = "okay";
flash0: m25p80@0 { - compatible = "s25fl512s","spi-flash"; + compatible = "s25fl512s","jedec,spi-nor"; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; diff --git a/arch/arm/dts/keystone-k2g-ice.dts b/arch/arm/dts/keystone-k2g-ice.dts index 698338b..680dfee 100644 --- a/arch/arm/dts/keystone-k2g-ice.dts +++ b/arch/arm/dts/keystone-k2g-ice.dts @@ -38,7 +38,7 @@ status = "okay";
flash0: m25p80@0 { - compatible = "s25fl256s1", "spi-flash"; + compatible = "s25fl256s1", "jedec,spi-nor"; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; diff --git a/arch/arm/dts/keystone-k2hk-evm.dts b/arch/arm/dts/keystone-k2hk-evm.dts index 76a675f..84c58d7 100644 --- a/arch/arm/dts/keystone-k2hk-evm.dts +++ b/arch/arm/dts/keystone-k2hk-evm.dts @@ -151,7 +151,7 @@ nor_flash: n25q128a11@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "Micron,n25q128a11", "spi-flash"; + compatible = "Micron,n25q128a11", "jedec,spi-nor"; spi-max-frequency = <54000000>; m25p,fast-read; reg = <0>; diff --git a/arch/arm/dts/keystone-k2l-evm.dts b/arch/arm/dts/keystone-k2l-evm.dts index b5c5617..91cefdf 100644 --- a/arch/arm/dts/keystone-k2l-evm.dts +++ b/arch/arm/dts/keystone-k2l-evm.dts @@ -100,7 +100,7 @@ nor_flash: n25q128a11@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "Micron,n25q128a11", "spi-flash"; + compatible = "Micron,n25q128a11", "jedec,spi-nor"; spi-max-frequency = <54000000>; m25p,fast-read; reg = <0>; diff --git a/arch/arm/dts/kirkwood-atl-sbx81lifkw.dts b/arch/arm/dts/kirkwood-atl-sbx81lifkw.dts index e5b1efa..4ae74f4 100644 --- a/arch/arm/dts/kirkwood-atl-sbx81lifkw.dts +++ b/arch/arm/dts/kirkwood-atl-sbx81lifkw.dts @@ -78,7 +78,7 @@ flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "st,m25p128", "jedec,spi-nor", "spi-flash"; + compatible = "st,m25p128", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <50000000>; mode = <0>; diff --git a/arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts b/arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts index c234449..6e3418f 100644 --- a/arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts +++ b/arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts @@ -92,7 +92,7 @@ flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "st,m25p128", "jedec,spi-nor", "spi-flash"; + compatible = "st,m25p128", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <50000000>; mode = <0>; diff --git a/arch/arm/dts/kirkwood-dreamplug.dts b/arch/arm/dts/kirkwood-dreamplug.dts index a647a65..7f326e2 100644 --- a/arch/arm/dts/kirkwood-dreamplug.dts +++ b/arch/arm/dts/kirkwood-dreamplug.dts @@ -43,7 +43,7 @@ m25p40@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "mxicy,mx25l1606e", "jedec,spi-nor", "spi-flash"; + compatible = "mxicy,mx25l1606e", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <50000000>; mode = <0>; diff --git a/arch/arm/dts/kirkwood-lsxl.dtsi b/arch/arm/dts/kirkwood-lsxl.dtsi index 479a750..c99c0da 100644 --- a/arch/arm/dts/kirkwood-lsxl.dtsi +++ b/arch/arm/dts/kirkwood-lsxl.dtsi @@ -79,7 +79,7 @@ m25p40@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "m25p40", "jedec,spi-nor", "spi-flash"; + compatible = "m25p40", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <25000000>; mode = <0>; diff --git a/arch/arm/dts/kirkwood-netxbig.dtsi b/arch/arm/dts/kirkwood-netxbig.dtsi index 135ac80..b573702 100644 --- a/arch/arm/dts/kirkwood-netxbig.dtsi +++ b/arch/arm/dts/kirkwood-netxbig.dtsi @@ -32,7 +32,7 @@ flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "mxicy,mx25l4005a", "jedec,spi-nor", "spi-flash"; + compatible = "mxicy,mx25l4005a", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <20000000>; mode = <0>; diff --git a/arch/arm/dts/kirkwood-ns2-common.dtsi b/arch/arm/dts/kirkwood-ns2-common.dtsi index f997bb4..51530ea 100644 --- a/arch/arm/dts/kirkwood-ns2-common.dtsi +++ b/arch/arm/dts/kirkwood-ns2-common.dtsi @@ -30,7 +30,7 @@ flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "mxicy,mx25l4005a", "jedec,spi-nor", "spi-flash"; + compatible = "mxicy,mx25l4005a", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <20000000>; mode = <0>; diff --git a/arch/arm/dts/kirkwood-synology.dtsi b/arch/arm/dts/kirkwood-synology.dtsi index b80d8ee..c97ed29 100644 --- a/arch/arm/dts/kirkwood-synology.dtsi +++ b/arch/arm/dts/kirkwood-synology.dtsi @@ -201,7 +201,7 @@ m25p80@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "st,m25p80", "jedec,spi-nor", "spi-flash"; + compatible = "st,m25p80", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <20000000>; mode = <0>; diff --git a/arch/arm/dts/ls1021a-iot.dtsi b/arch/arm/dts/ls1021a-iot.dtsi index d27b601..44dd9b6 100644 --- a/arch/arm/dts/ls1021a-iot.dtsi +++ b/arch/arm/dts/ls1021a-iot.dtsi @@ -27,7 +27,7 @@ qflash0: n25q128a13@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; @@ -40,7 +40,7 @@ dspiflash: at26df081a@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <16000000>; spi-cpol; spi-cpha; diff --git a/arch/arm/dts/ls1021a-qds.dtsi b/arch/arm/dts/ls1021a-qds.dtsi index f7783e5..b12102a 100644 --- a/arch/arm/dts/ls1021a-qds.dtsi +++ b/arch/arm/dts/ls1021a-qds.dtsi @@ -43,7 +43,7 @@ qflash0: s25fl128s@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; diff --git a/arch/arm/dts/ls1021a-twr.dtsi b/arch/arm/dts/ls1021a-twr.dtsi index 928e100..5d3275c 100644 --- a/arch/arm/dts/ls1021a-twr.dtsi +++ b/arch/arm/dts/ls1021a-twr.dtsi @@ -30,7 +30,7 @@ qflash0: n25q128a13@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <20000000>; reg = <0>; }; @@ -43,7 +43,7 @@ dspiflash: at26df081a@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <16000000>; spi-cpol; spi-cpha; diff --git a/arch/arm/dts/mt7629-rfb.dts b/arch/arm/dts/mt7629-rfb.dts index 95d10aa..4612218 100644 --- a/arch/arm/dts/mt7629-rfb.dts +++ b/arch/arm/dts/mt7629-rfb.dts @@ -62,7 +62,7 @@ status = "okay";
spi-flash@0{ - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/omap5-u-boot.dtsi b/arch/arm/dts/omap5-u-boot.dtsi index 54a7285..1b1d765 100644 --- a/arch/arm/dts/omap5-u-boot.dtsi +++ b/arch/arm/dts/omap5-u-boot.dtsi @@ -68,7 +68,7 @@ u-boot,dm-spl;
m25p80@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; u-boot,dm-spl; }; }; diff --git a/arch/arm/dts/r8a77970-eagle-u-boot.dts b/arch/arm/dts/r8a77970-eagle-u-boot.dts index 5b17f1d..eb868ed 100644 --- a/arch/arm/dts/r8a77970-eagle-u-boot.dts +++ b/arch/arm/dts/r8a77970-eagle-u-boot.dts @@ -44,7 +44,7 @@ flash0: spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "s25fs512s", "spi-flash", "jedec,spi-nor"; + compatible = "s25fs512s", "jedec,spi-nor"; spi-max-frequency = <50000000>; spi-tx-bus-width = <1>; spi-rx-bus-width = <1>; diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 49ba3f3..916dd48 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -307,7 +307,7 @@
spi_flash: spiflash@0 { u-boot,dm-pre-reloc; - compatible = "spidev", "spi-flash"; + compatible = "spidev", "jedec,spi-nor"; spi-max-frequency = <20000000>; /* Reduce for Dediprog em100 pro */ reg = <0>; }; diff --git a/arch/arm/dts/rk3368-lion.dts b/arch/arm/dts/rk3368-lion.dts index 5e578b1..2814542 100644 --- a/arch/arm/dts/rk3368-lion.dts +++ b/arch/arm/dts/rk3368-lion.dts @@ -185,7 +185,7 @@ #size-cells = <0>;
spiflash: w25q32dw@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <49500000>; spi-cpol; diff --git a/arch/arm/dts/rk3399-gru.dtsi b/arch/arm/dts/rk3399-gru.dtsi index df19263..4cdb432 100644 --- a/arch/arm/dts/rk3399-gru.dtsi +++ b/arch/arm/dts/rk3399-gru.dtsi @@ -552,7 +552,7 @@ ap_i2c_audio: &i2c8 {
spi_flash: spiflash@0 { u-boot,dm-pre-reloc; - compatible = "jedec,spi-nor", "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>;
/* May run faster once verified. */ diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 8304f67..aec13a2 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -658,7 +658,7 @@ spiflash: w25q32dw@0 { u-boot,dm-pre-reloc;
- compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <49500000>; spi-cpol; diff --git a/arch/arm/dts/rv1108-evb.dts b/arch/arm/dts/rv1108-evb.dts index ccb9969..c91776b 100644 --- a/arch/arm/dts/rv1108-evb.dts +++ b/arch/arm/dts/rv1108-evb.dts @@ -45,7 +45,7 @@ &sfc { status = "okay"; flash@0 { - compatible = "gd25q256","spi-flash"; + compatible = "gd25q256","jedec,spi-nor"; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <1>; diff --git a/arch/arm/dts/sama5d27_som1.dtsi b/arch/arm/dts/sama5d27_som1.dtsi index 9efcf63..ea7540b 100644 --- a/arch/arm/dts/sama5d27_som1.dtsi +++ b/arch/arm/dts/sama5d27_som1.dtsi @@ -66,7 +66,7 @@ u-boot,dm-pre-reloc;
spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <50000000>; spi-rx-bus-width = <4>; diff --git a/arch/arm/dts/sama5d3xmb.dtsi b/arch/arm/dts/sama5d3xmb.dtsi index f9ef905..c75b76a 100644 --- a/arch/arm/dts/sama5d3xmb.dtsi +++ b/arch/arm/dts/sama5d3xmb.dtsi @@ -35,7 +35,7 @@ u-boot,dm-pre-reloc;
spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; u-boot,dm-pre-reloc; diff --git a/arch/arm/dts/sama5d3xmb_cmp.dtsi b/arch/arm/dts/sama5d3xmb_cmp.dtsi index 9792b2a..5566fde 100644 --- a/arch/arm/dts/sama5d3xmb_cmp.dtsi +++ b/arch/arm/dts/sama5d3xmb_cmp.dtsi @@ -32,7 +32,7 @@ dmas = <0>, <0>; /* Do not use DMA for spi0 */
spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; diff --git a/arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi index c44d1ee..e75f290 100644 --- a/arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi +++ b/arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi @@ -30,7 +30,7 @@ };
&flash { - compatible = "n25q00", "spi-flash"; + compatible = "n25q00", "jedec,spi-nor"; u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/socfpga_cyclone5_is1.dts b/arch/arm/dts/socfpga_cyclone5_is1.dts index b7054bf..93e4d45 100644 --- a/arch/arm/dts/socfpga_cyclone5_is1.dts +++ b/arch/arm/dts/socfpga_cyclone5_is1.dts @@ -91,7 +91,7 @@ u-boot,dm-pre-reloc; #address-cells = <1>; #size-cells = <1>; - compatible = "n25q00", "spi-flash"; + compatible = "n25q00", "jedec,spi-nor"; reg = <0>; /* chip select */ spi-max-frequency = <100000000>; m25p,fast-read; diff --git a/arch/arm/dts/socfpga_cyclone5_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_cyclone5_socdk-u-boot.dtsi index 9436e0f..2fafd7e 100644 --- a/arch/arm/dts/socfpga_cyclone5_socdk-u-boot.dtsi +++ b/arch/arm/dts/socfpga_cyclone5_socdk-u-boot.dtsi @@ -34,7 +34,7 @@ };
&flash0 { - compatible = "n25q00", "spi-flash"; + compatible = "n25q00", "jedec,spi-nor"; u-boot,dm-pre-reloc;
partition@qspi-boot { diff --git a/arch/arm/dts/socfpga_cyclone5_sockit-u-boot.dtsi b/arch/arm/dts/socfpga_cyclone5_sockit-u-boot.dtsi index 648f1bd..7ef3053 100644 --- a/arch/arm/dts/socfpga_cyclone5_sockit-u-boot.dtsi +++ b/arch/arm/dts/socfpga_cyclone5_sockit-u-boot.dtsi @@ -30,7 +30,7 @@ };
diff --git a/arch/arm/dts/socfpga_cyclone5_socrates-u-boot.dtsi b/arch/arm/dts/socfpga_cyclone5_socrates-u-boot.dtsi index 31bd1db..1003115 100644 --- a/arch/arm/dts/socfpga_cyclone5_socrates-u-boot.dtsi +++ b/arch/arm/dts/socfpga_cyclone5_socrates-u-boot.dtsi @@ -30,7 +30,7 @@ };
&flash { - compatible = "n25q256a", "spi-flash"; + compatible = "n25q256a", "jedec,spi-nor"; u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/socfpga_cyclone5_sr1500.dts b/arch/arm/dts/socfpga_cyclone5_sr1500.dts index 6a6c29b..1a18c4f 100644 --- a/arch/arm/dts/socfpga_cyclone5_sr1500.dts +++ b/arch/arm/dts/socfpga_cyclone5_sr1500.dts @@ -99,7 +99,7 @@ u-boot,dm-pre-reloc; #address-cells = <1>; #size-cells = <1>; - compatible = "n25q00", "spi-flash"; + compatible = "n25q00", "jedec,spi-nor"; reg = <0>; /* chip select */ spi-max-frequency = <100000000>; m25p,fast-read; diff --git a/arch/arm/dts/socfpga_cyclone5_vining_fpga-u-boot.dtsi b/arch/arm/dts/socfpga_cyclone5_vining_fpga-u-boot.dtsi index 360b946..e05ca82 100644 --- a/arch/arm/dts/socfpga_cyclone5_vining_fpga-u-boot.dtsi +++ b/arch/arm/dts/socfpga_cyclone5_vining_fpga-u-boot.dtsi @@ -29,11 +29,11 @@ u-boot,dm-pre-reloc;
n25q128@0 { - compatible = "n25q128", "spi-flash"; + compatible = "n25q128", "jedec,spi-nor"; u-boot,dm-pre-reloc; }; n25q00@1 { - compatible = "n25q00", "spi-flash"; + compatible = "n25q00", "jedec,spi-nor"; u-boot,dm-pre-reloc; }; }; diff --git a/arch/arm/dts/stm32f746-disco.dts b/arch/arm/dts/stm32f746-disco.dts index 7ef33d6..babd37f 100644 --- a/arch/arm/dts/stm32f746-disco.dts +++ b/arch/arm/dts/stm32f746-disco.dts @@ -297,7 +297,7 @@ qflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "micron,n25q128a13", "spi-flash"; + compatible = "micron,n25q128a13", "jedec,spi-nor"; spi-max-frequency = <108000000>; spi-tx-bus-width = <1>; spi-rx-bus-width = <1>; diff --git a/arch/arm/dts/stm32f769-disco.dts b/arch/arm/dts/stm32f769-disco.dts index 1e8ef74..a23d02d 100644 --- a/arch/arm/dts/stm32f769-disco.dts +++ b/arch/arm/dts/stm32f769-disco.dts @@ -246,7 +246,7 @@ qflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "micron,n25q128a13", "spi-flash"; + compatible = "micron,n25q128a13", "jedec,spi-nor"; spi-max-frequency = <108000000>; spi-tx-bus-width = <1>; spi-rx-bus-width = <1>; diff --git a/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi index 30b1734..409f983 100644 --- a/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi @@ -14,11 +14,11 @@ };
&flash0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; };
&flash1 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; };
&v3v3 { diff --git a/arch/arm/dts/stv0991.dts b/arch/arm/dts/stv0991.dts index 98bd5df..b04e899 100644 --- a/arch/arm/dts/stv0991.dts +++ b/arch/arm/dts/stv0991.dts @@ -40,7 +40,7 @@ flash0: n25q32@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; /* chip select */ spi-max-frequency = <50000000>; m25p,fast-read; diff --git a/arch/arm/dts/zynq-zed.dts b/arch/arm/dts/zynq-zed.dts index 9c505fb..8b1cf54 100644 --- a/arch/arm/dts/zynq-zed.dts +++ b/arch/arm/dts/zynq-zed.dts @@ -53,7 +53,7 @@ status = "okay"; num-cs = <1>; flash@0 { - compatible = "spansion,s25fl256s", "spi-flash"; + compatible = "spansion,s25fl256s", "jedec,spi-nor"; reg = <0>; spi-max-frequency = <30000000>; m25p,fast-read; diff --git a/arch/arm/dts/zynqmp-zc1232-revA.dts b/arch/arm/dts/zynqmp-zc1232-revA.dts index 5c212ba..6117f83 100644 --- a/arch/arm/dts/zynqmp-zc1232-revA.dts +++ b/arch/arm/dts/zynqmp-zc1232-revA.dts @@ -41,7 +41,7 @@ &qspi { status = "okay"; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB FIXME */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB FIXME */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zc1254-revA.dts b/arch/arm/dts/zynqmp-zc1254-revA.dts index 881aacc..6ac8346 100644 --- a/arch/arm/dts/zynqmp-zc1254-revA.dts +++ b/arch/arm/dts/zynqmp-zc1254-revA.dts @@ -41,7 +41,7 @@ &qspi { status = "okay"; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zc1275-revA.dts b/arch/arm/dts/zynqmp-zc1275-revA.dts index 7403f15..82c30a3 100644 --- a/arch/arm/dts/zynqmp-zc1275-revA.dts +++ b/arch/arm/dts/zynqmp-zc1275-revA.dts @@ -41,7 +41,7 @@ &qspi { status = "okay"; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zc1275-revB.dts b/arch/arm/dts/zynqmp-zc1275-revB.dts index e84b2da..c6348ff 100644 --- a/arch/arm/dts/zynqmp-zc1275-revB.dts +++ b/arch/arm/dts/zynqmp-zc1275-revB.dts @@ -42,7 +42,7 @@ &qspi { status = "okay"; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts index 9768dfe..8824f5c 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts @@ -101,7 +101,7 @@ &qspi { status = "okay"; flash@0 { - compatible = "m25p80", "spi-flash"; /* Micron MT25QU512ABB8ESF */ + compatible = "m25p80", "jedec,spi-nor"; /* Micron MT25QU512ABB8ESF */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts b/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts index 9afbbb6..84c2904 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts @@ -180,7 +180,7 @@ &qspi { status = "okay"; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index 05be919..d209355 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -536,7 +536,7 @@ status = "okay"; is-dual = <1>; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zcu104-revA.dts b/arch/arm/dts/zynqmp-zcu104-revA.dts index 431dff5..c7a3cdc 100644 --- a/arch/arm/dts/zynqmp-zcu104-revA.dts +++ b/arch/arm/dts/zynqmp-zcu104-revA.dts @@ -169,7 +169,7 @@ &qspi { status = "okay"; flash@0 { - compatible = "m25p80", "spi-flash"; /* n25q512a 128MiB */ + compatible = "m25p80", "jedec,spi-nor"; /* n25q512a 128MiB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zcu104-revC.dts b/arch/arm/dts/zynqmp-zcu104-revC.dts index becc6a0..2d9d195 100644 --- a/arch/arm/dts/zynqmp-zcu104-revC.dts +++ b/arch/arm/dts/zynqmp-zcu104-revC.dts @@ -175,7 +175,7 @@ &qspi { status = "okay"; flash@0 { - compatible = "m25p80", "spi-flash"; /* n25q512a 128MiB */ + compatible = "m25p80", "jedec,spi-nor"; /* n25q512a 128MiB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index 7735e9d..2358c24 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -514,7 +514,7 @@ status = "okay"; is-dual = <1>; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index 172e6cc..7653e11 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -451,7 +451,7 @@ status = "okay"; is-dual = <1>; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>; diff --git a/arch/mips/dts/ap121.dts b/arch/mips/dts/ap121.dts index 4ca1c70..f30af50 100644 --- a/arch/mips/dts/ap121.dts +++ b/arch/mips/dts/ap121.dts @@ -34,7 +34,7 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; memory-map = <0x9f000000 0x00800000>; spi-max-frequency = <25000000>; reg = <0>; diff --git a/arch/mips/dts/ap143.dts b/arch/mips/dts/ap143.dts index 6aedd87..82bf637 100644 --- a/arch/mips/dts/ap143.dts +++ b/arch/mips/dts/ap143.dts @@ -34,7 +34,7 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; memory-map = <0x9f000000 0x00800000>; spi-max-frequency = <25000000>; reg = <0>; diff --git a/arch/mips/dts/comtrend,ar-5315u.dts b/arch/mips/dts/comtrend,ar-5315u.dts index eb60aaa..28443b3 100644 --- a/arch/mips/dts/comtrend,ar-5315u.dts +++ b/arch/mips/dts/comtrend,ar-5315u.dts @@ -110,7 +110,7 @@ status = "okay";
spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; #address-cells = <1>; #size-cells = <1>; diff --git a/arch/mips/dts/comtrend,ar-5387un.dts b/arch/mips/dts/comtrend,ar-5387un.dts index 03e3851..12ace64 100644 --- a/arch/mips/dts/comtrend,ar-5387un.dts +++ b/arch/mips/dts/comtrend,ar-5387un.dts @@ -94,7 +94,7 @@ status = "okay";
spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; #address-cells = <1>; #size-cells = <1>; diff --git a/arch/mips/dts/gardena-smart-gateway-mt7688.dts b/arch/mips/dts/gardena-smart-gateway-mt7688.dts index 75f6037..2f2cfdd 100644 --- a/arch/mips/dts/gardena-smart-gateway-mt7688.dts +++ b/arch/mips/dts/gardena-smart-gateway-mt7688.dts @@ -97,7 +97,7 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash", "jedec,spi-nor"; + compatible = "jedec,spi-nor"; spi-max-frequency = <40000000>; reg = <0>; }; diff --git a/arch/mips/dts/jr2_pcb110.dts b/arch/mips/dts/jr2_pcb110.dts index ddc30ff..1e12397 100644 --- a/arch/mips/dts/jr2_pcb110.dts +++ b/arch/mips/dts/jr2_pcb110.dts @@ -43,7 +43,7 @@ &spi0 { status = "okay"; spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ }; diff --git a/arch/mips/dts/jr2_pcb111.dts b/arch/mips/dts/jr2_pcb111.dts index 4d411b6..fcd8455 100644 --- a/arch/mips/dts/jr2_pcb111.dts +++ b/arch/mips/dts/jr2_pcb111.dts @@ -43,7 +43,7 @@ &spi0 { status = "okay"; spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ }; diff --git a/arch/mips/dts/linkit-smart-7688.dts b/arch/mips/dts/linkit-smart-7688.dts index c9db136..bb10402 100644 --- a/arch/mips/dts/linkit-smart-7688.dts +++ b/arch/mips/dts/linkit-smart-7688.dts @@ -38,7 +38,7 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash", "jedec,spi-nor"; + compatible = "jedec,spi-nor"; spi-max-frequency = <25000000>; reg = <0>; }; diff --git a/arch/mips/dts/luton_pcb090.dts b/arch/mips/dts/luton_pcb090.dts index 315172b..fe457ba 100644 --- a/arch/mips/dts/luton_pcb090.dts +++ b/arch/mips/dts/luton_pcb090.dts @@ -48,7 +48,7 @@ &spi0 { status = "okay"; spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ spi-cs-high; diff --git a/arch/mips/dts/luton_pcb091.dts b/arch/mips/dts/luton_pcb091.dts index 9b4d628..f684cc8 100644 --- a/arch/mips/dts/luton_pcb091.dts +++ b/arch/mips/dts/luton_pcb091.dts @@ -54,7 +54,7 @@ &spi0 { status = "okay"; spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ spi-cs-high; diff --git a/arch/mips/dts/mscc,ocelot_pcb.dtsi b/arch/mips/dts/mscc,ocelot_pcb.dtsi index 90725d3..885b564 100644 --- a/arch/mips/dts/mscc,ocelot_pcb.dtsi +++ b/arch/mips/dts/mscc,ocelot_pcb.dtsi @@ -29,7 +29,7 @@ pinctrl-names = "default";
spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ }; diff --git a/arch/mips/dts/netgear,cg3100d.dts b/arch/mips/dts/netgear,cg3100d.dts index a3d4cd5..a42a0da 100644 --- a/arch/mips/dts/netgear,cg3100d.dts +++ b/arch/mips/dts/netgear,cg3100d.dts @@ -93,7 +93,7 @@ status = "okay";
spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; #address-cells = <1>; #size-cells = <1>; diff --git a/arch/mips/dts/sagem,f@st1704.dts b/arch/mips/dts/sagem,f@st1704.dts index ec6846d..98ed353 100644 --- a/arch/mips/dts/sagem,f@st1704.dts +++ b/arch/mips/dts/sagem,f@st1704.dts @@ -59,7 +59,7 @@ status = "okay";
spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; #address-cells = <1>; #size-cells = <1>; diff --git a/arch/mips/dts/serval2_pcb112.dts b/arch/mips/dts/serval2_pcb112.dts index fe025f4..2921c44 100644 --- a/arch/mips/dts/serval2_pcb112.dts +++ b/arch/mips/dts/serval2_pcb112.dts @@ -43,7 +43,7 @@ &spi0 { status = "okay"; spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ }; diff --git a/arch/mips/dts/serval_pcb105.dts b/arch/mips/dts/serval_pcb105.dts index d0d6fac..1598669 100644 --- a/arch/mips/dts/serval_pcb105.dts +++ b/arch/mips/dts/serval_pcb105.dts @@ -43,7 +43,7 @@ &spi0 { status = "okay"; spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ spi-cs-high; diff --git a/arch/mips/dts/serval_pcb106.dts b/arch/mips/dts/serval_pcb106.dts index 1198249..fb3524b 100644 --- a/arch/mips/dts/serval_pcb106.dts +++ b/arch/mips/dts/serval_pcb106.dts @@ -43,7 +43,7 @@ &spi0 { status = "okay"; spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ spi-cs-high; diff --git a/arch/mips/dts/servalt_pcb116.dts b/arch/mips/dts/servalt_pcb116.dts index fb33312..4de3e25 100644 --- a/arch/mips/dts/servalt_pcb116.dts +++ b/arch/mips/dts/servalt_pcb116.dts @@ -43,7 +43,7 @@ &spi0 { status = "okay"; spi-flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <18000000>; /* input clock */ reg = <0>; /* CS0 */ spi-cs-high; diff --git a/arch/mips/dts/tplink_wdr4300.dts b/arch/mips/dts/tplink_wdr4300.dts index 96cf0da..2bcad6d 100644 --- a/arch/mips/dts/tplink_wdr4300.dts +++ b/arch/mips/dts/tplink_wdr4300.dts @@ -35,7 +35,7 @@ spi-flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; memory-map = <0x1e000000 0x00800000>; spi-max-frequency = <25000000>; reg = <0>; diff --git a/arch/nds32/dts/ae3xx.dts b/arch/nds32/dts/ae3xx.dts index 272eb33..7bba2a2 100644 --- a/arch/nds32/dts/ae3xx.dts +++ b/arch/nds32/dts/ae3xx.dts @@ -93,7 +93,7 @@ clocks = <&spiclk>; interrupts = <3 4>; flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; spi-cpol; diff --git a/arch/riscv/dts/ae350_32.dts b/arch/riscv/dts/ae350_32.dts index 0679827..15bff2b 100644 --- a/arch/riscv/dts/ae350_32.dts +++ b/arch/riscv/dts/ae350_32.dts @@ -219,7 +219,7 @@ interrupts = <4 4>; interrupt-parent = <&plic0>; flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; spi-cpol; diff --git a/arch/riscv/dts/ae350_64.dts b/arch/riscv/dts/ae350_64.dts index e48c298..7aec9a4 100644 --- a/arch/riscv/dts/ae350_64.dts +++ b/arch/riscv/dts/ae350_64.dts @@ -219,7 +219,7 @@ interrupts = <4 4>; interrupt-parent = <&plic0>; flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; spi-cpol; diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 1d011de..7afbb2a 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -565,7 +565,7 @@ cs-gpios = <0>, <&gpio_a 0>; spi.bin@0 { reg = <0>; - compatible = "spansion,m25p16", "spi-flash"; + compatible = "spansion,m25p16", "jedec,spi-nor"; spi-max-frequency = <40000000>; sandbox,filename = "spi.bin"; };
The x86 code and DT uses "spi-flash" to detect a flash node, switch to "jedec,spi-nor" in the DTS files and in fdtdec by switching the GENERIC_SPI_FLASH value to to jedec,spi-nor.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- arch/x86/dts/bayleybay.dts | 2 +- arch/x86/dts/baytrail_som-db5800-som-6867.dts | 2 +- arch/x86/dts/cherryhill.dts | 2 +- arch/x86/dts/chromebook_link.dts | 2 +- arch/x86/dts/chromebook_samus.dts | 2 +- arch/x86/dts/chromebox_panther.dts | 2 +- arch/x86/dts/conga-qeval20-qa3-e3845.dts | 2 +- arch/x86/dts/cougarcanyon2.dts | 2 +- arch/x86/dts/crownbay.dts | 2 +- arch/x86/dts/dfi-bt700.dtsi | 2 +- arch/x86/dts/galileo.dts | 2 +- arch/x86/dts/minnowmax.dts | 2 +- lib/fdtdec.c | 2 +- 13 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/arch/x86/dts/bayleybay.dts b/arch/x86/dts/bayleybay.dts index 291dc07..d0168e8 100644 --- a/arch/x86/dts/bayleybay.dts +++ b/arch/x86/dts/bayleybay.dts @@ -175,7 +175,7 @@ #size-cells = <1>; reg = <0>; compatible = "winbond,w25q64dw", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/baytrail_som-db5800-som-6867.dts b/arch/x86/dts/baytrail_som-db5800-som-6867.dts index 4e8a761..5abbc66 100644 --- a/arch/x86/dts/baytrail_som-db5800-som-6867.dts +++ b/arch/x86/dts/baytrail_som-db5800-som-6867.dts @@ -199,7 +199,7 @@ #size-cells = <1>; reg = <0>; compatible = "macronix,mx25l6405d", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/cherryhill.dts b/arch/x86/dts/cherryhill.dts index 39e2d2f..37146fd 100644 --- a/arch/x86/dts/cherryhill.dts +++ b/arch/x86/dts/cherryhill.dts @@ -147,7 +147,7 @@ #address-cells = <1>; #size-cells = <1>; reg = <0>; - compatible = "macronix,mx25u6435f", "spi-flash"; + compatible = "macronix,mx25u6435f", "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/chromebook_link.dts b/arch/x86/dts/chromebook_link.dts index f9f0979..fc9d156 100644 --- a/arch/x86/dts/chromebook_link.dts +++ b/arch/x86/dts/chromebook_link.dts @@ -401,7 +401,7 @@ u-boot,dm-pre-reloc; reg = <0>; compatible = "winbond,w25q64", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/chromebook_samus.dts b/arch/x86/dts/chromebook_samus.dts index b58936b..0866a72 100644 --- a/arch/x86/dts/chromebook_samus.dts +++ b/arch/x86/dts/chromebook_samus.dts @@ -538,7 +538,7 @@ #address-cells = <1>; reg = <0>; compatible = "winbond,w25q64", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/chromebox_panther.dts b/arch/x86/dts/chromebox_panther.dts index f56e482..bcd4c4d 100644 --- a/arch/x86/dts/chromebox_panther.dts +++ b/arch/x86/dts/chromebox_panther.dts @@ -47,7 +47,7 @@ #address-cells = <1>; reg = <0>; compatible = "winbond,w25q64", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/conga-qeval20-qa3-e3845.dts b/arch/x86/dts/conga-qeval20-qa3-e3845.dts index 5884dbc..70b8c04 100644 --- a/arch/x86/dts/conga-qeval20-qa3-e3845.dts +++ b/arch/x86/dts/conga-qeval20-qa3-e3845.dts @@ -186,7 +186,7 @@ #size-cells = <1>; reg = <0>; compatible = "stmicro,n25q064a", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/cougarcanyon2.dts b/arch/x86/dts/cougarcanyon2.dts index 9801790..c6ba811 100644 --- a/arch/x86/dts/cougarcanyon2.dts +++ b/arch/x86/dts/cougarcanyon2.dts @@ -154,7 +154,7 @@
spi-flash@0 { reg = <0>; - compatible = "winbond,w25q64bv", "spi-flash"; + compatible = "winbond,w25q64bv", "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; }; }; diff --git a/arch/x86/dts/crownbay.dts b/arch/x86/dts/crownbay.dts index 2ffcc5f..f5b1ac6 100644 --- a/arch/x86/dts/crownbay.dts +++ b/arch/x86/dts/crownbay.dts @@ -223,7 +223,7 @@ spi-flash@0 { reg = <0>; compatible = "sst,25vf016b", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xffe00000 0x00200000>; }; }; diff --git a/arch/x86/dts/dfi-bt700.dtsi b/arch/x86/dts/dfi-bt700.dtsi index 51d33e7..e9930cb 100644 --- a/arch/x86/dts/dfi-bt700.dtsi +++ b/arch/x86/dts/dfi-bt700.dtsi @@ -197,7 +197,7 @@ #size-cells = <1>; reg = <0>; compatible = "stmicro,n25q064a", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/galileo.dts b/arch/x86/dts/galileo.dts index 3a5d168..5de4568 100644 --- a/arch/x86/dts/galileo.dts +++ b/arch/x86/dts/galileo.dts @@ -139,7 +139,7 @@ #address-cells = <1>; reg = <0>; compatible = "winbond,w25q64", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index 6c65fb9..f4cdb2c 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -199,7 +199,7 @@ #size-cells = <1>; reg = <0>; compatible = "stmicro,n25q064a", - "spi-flash"; + "jedec,spi-nor"; memory-map = <0xff800000 0x00800000>; rw-mrc-cache { label = "rw-mrc-cache"; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 18663ce..b2f898f 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -49,7 +49,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS_DWMMC, "samsung,exynos-dwmmc"), COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), - COMPAT(GENERIC_SPI_FLASH, "spi-flash"), + COMPAT(GENERIC_SPI_FLASH, "jedec,spi-nor"), COMPAT(MAXIM_98095_CODEC, "maxim,max98095-codec"), COMPAT(SAMSUNG_EXYNOS5_I2C, "samsung,exynos5-hsi2c"), COMPAT(SAMSUNG_EXYNOS_SYSMMU, "samsung,sysmmu-v3.3"),
Now the "spi-flash" compatible has been removed in the DTS files, remove this compatible from sf_probe to finally use the Linux "jedec,spi-nor" compatible.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- drivers/mtd/spi/sf_probe.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 7f1378f..73297e1 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -166,7 +166,6 @@ static const struct dm_spi_flash_ops spi_flash_std_ops = { };
static const struct udevice_id spi_flash_std_ids[] = { - { .compatible = "spi-flash" }, { .compatible = "jedec,spi-nor" }, { } };
Since all DTS files has been switched to "jedec,spi-nor", remove the "spi-flash" compatible from the bindings examples.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Rick Chen rick@andestech.com Reviewed-by: Patrick Delaunay Patrick.delaunay@st.com --- doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt | 2 +- doc/device-tree-bindings/spi/spi-atcspi200.txt | 2 +- doc/device-tree-bindings/spi/spi-stm32-qspi.txt | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt b/doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt index a1b5596..a376c6f 100644 --- a/doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt +++ b/doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt @@ -42,7 +42,7 @@ Example: status = "okay";
spi_flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <50000000>; }; diff --git a/doc/device-tree-bindings/spi/spi-atcspi200.txt b/doc/device-tree-bindings/spi/spi-atcspi200.txt index 9c0630b..e67b342 100644 --- a/doc/device-tree-bindings/spi/spi-atcspi200.txt +++ b/doc/device-tree-bindings/spi/spi-atcspi200.txt @@ -28,7 +28,7 @@ Example: clocks = <&spiclk>; interrupts = <3 4>; flash@0 { - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; spi-cpol; diff --git a/doc/device-tree-bindings/spi/spi-stm32-qspi.txt b/doc/device-tree-bindings/spi/spi-stm32-qspi.txt index 6c7da1d..cec3e12 100644 --- a/doc/device-tree-bindings/spi/spi-stm32-qspi.txt +++ b/doc/device-tree-bindings/spi/spi-stm32-qspi.txt @@ -29,7 +29,7 @@ Example: qflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "micron,n25q128a13", "spi-flash"; + compatible = "micron,n25q128a13", "jedec,spi-nor"; spi-max-frequency = <108000000>; spi-tx-bus-width = <4>; spi-rx-bus-width = <4>;
Hi Neil,
There is no reason not to use the Linux "jedec,spi-nor" binding in u-boot. This patchset :
- switches all DTS/DTSI files to "jedec,spi-nor"
- remove the "spi-flash" compatible from sf-probe
A number of boards, or even all boards for a SoC type just resync the dts files from the Linux kernel every so often, or even every cycle, do we know all the boards have the appropriate "jedec,spi-nor" or something more specific so those boards won't break on resync?
Peter
- switch GENERIC_SPI_FLASH to jedec,spi-nor in fdtdec
- switches dt bindings examples files to "jedec,spi-nor"
Changes since v3:
- collected tags
- dropped patch 1
- updated for new boards
Changes since v2:
- collected tags
- extracted x86 dts changed and merged it with the fdtdec change
Neil Armstrong (4): dts: switch spi-flash to jedec, spi-nor compatible x86: dts: switch spi-flash to jedec, spi-nor compatible mtd: sf_probe: remove spi-flash compatible doc: device-tree-bindings: switch from spi-flash to jedec, spi-nor
arch/arc/dts/axs10x_mb.dtsi | 2 +- arch/arc/dts/hsdk.dts | 2 +- arch/arm/dts/am335x-brppt1-spi.dts | 2 +- arch/arm/dts/am437x-idk-evm.dts | 2 +- arch/arm/dts/am437x-sk-evm.dts | 2 +- arch/arm/dts/armada-3720-db.dts | 2 +- arch/arm/dts/armada-3720-espressobin.dts | 2 +- arch/arm/dts/armada-3720-turris-mox.dts | 2 +- arch/arm/dts/armada-385-amc.dts | 2 +- arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 2 +- arch/arm/dts/armada-38x-controlcenterdc.dts | 4 ++-- arch/arm/dts/armada-38x-solidrun-microsom.dtsi | 2 +- arch/arm/dts/armada-8040-clearfog-gt-8k.dts | 2 +- arch/arm/dts/armada-xp-theadorable.dts | 2 +- arch/arm/dts/at91-sama5d2_xplained.dts | 2 +- arch/arm/dts/at91-sama5d4_xplained.dts | 2 +- arch/arm/dts/at91-sama5d4ek.dts | 2 +- arch/arm/dts/at91sam9n12ek.dts | 2 +- arch/arm/dts/at91sam9x5ek.dtsi | 2 +- arch/arm/dts/bk4r1.dts | 4 ++-- arch/arm/dts/da850-evm-u-boot.dtsi | 2 +- arch/arm/dts/exynos5250-snow.dts | 2 +- arch/arm/dts/exynos5250-spring.dts | 2 +- arch/arm/dts/exynos5420-peach-pit.dts | 2 +- arch/arm/dts/fsl-ls1012a-2g5rdb.dts | 2 +- arch/arm/dts/fsl-ls1012a-frdm.dtsi | 2 +- arch/arm/dts/fsl-ls1012a-frwy.dts | 2 +- arch/arm/dts/fsl-ls1012a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1012a-rdb.dtsi | 2 +- arch/arm/dts/fsl-ls1043a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1043a-rdb.dts | 2 +- arch/arm/dts/fsl-ls1046a-qds.dtsi | 8 ++++---- arch/arm/dts/fsl-ls1046a-rdb.dts | 4 ++-- arch/arm/dts/fsl-ls1088a-qds.dts | 10 +++++----- arch/arm/dts/fsl-ls1088a-rdb.dts | 4 ++-- arch/arm/dts/fsl-ls2080a-qds.dts | 8 ++++---- arch/arm/dts/fsl-ls2080a-rdb.dts | 2 +- arch/arm/dts/fsl-ls2081a-rdb.dts | 6 +++--- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 6 +++--- arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi | 4 ++-- arch/arm/dts/imx6sx-sdb-u-boot.dtsi | 4 ++-- arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx6ul-9x9-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx6ull-14x14-evk.dts | 2 +- arch/arm/dts/imx7d-sdb-qspi-u-boot.dtsi | 2 +- arch/arm/dts/keystone-k2e-evm.dts | 2 +- arch/arm/dts/keystone-k2g-evm.dts | 4 ++-- arch/arm/dts/keystone-k2g-ice.dts | 2 +- arch/arm/dts/keystone-k2hk-evm.dts | 2 +- arch/arm/dts/keystone-k2l-evm.dts | 2 +- arch/arm/dts/kirkwood-atl-sbx81lifkw.dts | 2 +- arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts | 2 +- arch/arm/dts/kirkwood-dreamplug.dts | 2 +- arch/arm/dts/kirkwood-lsxl.dtsi | 2 +- arch/arm/dts/kirkwood-netxbig.dtsi | 2 +- arch/arm/dts/kirkwood-ns2-common.dtsi | 2 +- arch/arm/dts/kirkwood-synology.dtsi | 2 +- arch/arm/dts/ls1021a-iot.dtsi | 4 ++-- arch/arm/dts/ls1021a-qds.dtsi | 2 +- arch/arm/dts/ls1021a-twr.dtsi | 4 ++-- arch/arm/dts/mt7629-rfb.dts | 2 +- arch/arm/dts/omap5-u-boot.dtsi | 2 +- arch/arm/dts/r8a77970-eagle-u-boot.dts | 2 +- arch/arm/dts/rk3288-veyron.dtsi | 2 +- arch/arm/dts/rk3368-lion.dts | 2 +- arch/arm/dts/rk3399-gru.dtsi | 2 +- arch/arm/dts/rk3399-puma.dtsi | 2 +- arch/arm/dts/rv1108-evb.dts | 2 +- arch/arm/dts/sama5d27_som1.dtsi | 2 +- arch/arm/dts/sama5d3xmb.dtsi | 2 +- arch/arm/dts/sama5d3xmb_cmp.dtsi | 2 +- arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_is1.dts | 2 +- arch/arm/dts/socfpga_cyclone5_socdk-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_sockit-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_socrates-u-boot.dtsi | 2 +- arch/arm/dts/socfpga_cyclone5_sr1500.dts | 2 +- arch/arm/dts/socfpga_cyclone5_vining_fpga-u-boot.dtsi | 4 ++-- arch/arm/dts/stm32f746-disco.dts | 2 +- arch/arm/dts/stm32f769-disco.dts | 2 +- arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 4 ++-- arch/arm/dts/stv0991.dts | 2 +- arch/arm/dts/zynq-zed.dts | 2 +- arch/arm/dts/zynqmp-zc1232-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1254-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1275-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1275-revB.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 2 +- arch/arm/dts/zynqmp-zcu102-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revC.dts | 2 +- arch/arm/dts/zynqmp-zcu106-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu111-revA.dts | 2 +- arch/mips/dts/ap121.dts | 2 +- arch/mips/dts/ap143.dts | 2 +- arch/mips/dts/comtrend,ar-5315u.dts | 2 +- arch/mips/dts/comtrend,ar-5387un.dts | 2 +- arch/mips/dts/gardena-smart-gateway-mt7688.dts | 2 +- arch/mips/dts/jr2_pcb110.dts | 2 +- arch/mips/dts/jr2_pcb111.dts | 2 +- arch/mips/dts/linkit-smart-7688.dts | 2 +- arch/mips/dts/luton_pcb090.dts | 2 +- arch/mips/dts/luton_pcb091.dts | 2 +- arch/mips/dts/mscc,ocelot_pcb.dtsi | 2 +- arch/mips/dts/netgear,cg3100d.dts | 2 +- arch/mips/dts/sagem,f@st1704.dts | 2 +- arch/mips/dts/serval2_pcb112.dts | 2 +- arch/mips/dts/serval_pcb105.dts | 2 +- arch/mips/dts/serval_pcb106.dts | 2 +- arch/mips/dts/servalt_pcb116.dts | 2 +- arch/mips/dts/tplink_wdr4300.dts | 2 +- arch/nds32/dts/ae3xx.dts | 2 +- arch/riscv/dts/ae350_32.dts | 2 +- arch/riscv/dts/ae350_64.dts | 2 +- arch/sandbox/dts/test.dts | 2 +- arch/x86/dts/bayleybay.dts | 2 +- arch/x86/dts/baytrail_som-db5800-som-6867.dts | 2 +- arch/x86/dts/cherryhill.dts | 2 +- arch/x86/dts/chromebook_link.dts | 2 +- arch/x86/dts/chromebook_samus.dts | 2 +- arch/x86/dts/chromebox_panther.dts | 2 +- arch/x86/dts/conga-qeval20-qa3-e3845.dts | 2 +- arch/x86/dts/cougarcanyon2.dts | 2 +- arch/x86/dts/crownbay.dts | 2 +- arch/x86/dts/dfi-bt700.dtsi | 2 +- arch/x86/dts/galileo.dts | 2 +- arch/x86/dts/minnowmax.dts | 2 +- doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt | 2 +- doc/device-tree-bindings/spi/spi-atcspi200.txt | 2 +- doc/device-tree-bindings/spi/spi-stm32-qspi.txt | 2 +- drivers/mtd/spi/sf_probe.c | 1 - lib/fdtdec.c | 2 +- 133 files changed, 163 insertions(+), 164 deletions(-)
-- 2.7.4
Hi Peter,
Le 10/02/2019 11:25, Peter Robinson a écrit :
Hi Neil,
"spi-flash" is U-Boot specific, Linux dts files should not contain it at all
linux$ find ./ -name "*.dts*" -exec grep "spi-flash" {} ; | wc -l 0
Neil
Peter
Changes since v3:
- collected tags
- dropped patch 1
Changes since v2:
- collected tags
-- 2.7.4
On Sun, Feb 10, 2019 at 3:46 PM Neil Armstrong narmstrong@baylibre.com wrote:
Changes since v3:
- collected tags
- dropped patch 1
Changes since v2:
- collected tags
Reviewed-by: Jagan Teki jagan@openedev.com
Applied to u-boot-spi/next
Jagan Teki
Neil Armstrong
Peter Robinson
