[PATCH V2 1/2] ARM: dts: rmobile: beacon-renesom: Enable USB and ethernet ref clocks
There are two versaclock programmable clock chips used to provide reference clocks for both USB and Ethernet. Enable the driver in the configs to run these clocks.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Move from defconfig to kconfig
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index a6dcce180b..c90ea06692 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -76,18 +76,24 @@ config TARGET_BEACON_RZG2H select R8A774E1 select RZ_G2 select PINCTRL_PFC_R8A774E1 + select CLK_CCF + select CLK_VERSACLOCK
config TARGET_BEACON_RZG2M bool "Beacon EmbeddedWorks RZ/G2M Dev Kit" select R8A774A1 select RZ_G2 select PINCTRL_PFC_R8A774A1 + select CLK_CCF + select CLK_VERSACLOCK
config TARGET_BEACON_RZG2N bool "Beacon EmbeddedWorks RZ/G2N Dev Kit" select R8A774B1 select RZ_G2 select PINCTRL_PFC_R8A774B1 + select CLK_CCF + select CLK_VERSACLOCK
config TARGET_CONDOR bool "Condor board"
Now that the versaclock driver is available, point the ethernet node at these clocks and configure the RGMII to enable Ethernet.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Fix subject heading
diff --git a/arch/arm/dts/beacon-renesom-som.dtsi b/arch/arm/dts/beacon-renesom-som.dtsi index d30bab3c8b..9fe541b607 100644 --- a/arch/arm/dts/beacon-renesom-som.dtsi +++ b/arch/arm/dts/beacon-renesom-som.dtsi @@ -60,8 +60,11 @@ pinctrl-0 = <&avb_pins>; pinctrl-names = "default"; phy-handle = <&phy0>; + phy-mode = "rgmii-txid"; rx-internal-delay-ps = <1800>; tx-internal-delay-ps = <2000>; + clocks = <&cpg CPG_MOD 812>, <&versaclock5 4>; + clock-names = "fck", "refclk"; status = "okay";
phy0: ethernet-phy@0 {
Go ahead and drop this now. I have FIT working with multiple DTB's from one config file. I'll push a new series to unify M/N/H boards into one defconfig, then add new the functions to the one remaining board. That should eliminate a lot of duplicated entries.
adam
select CLK_CCF
select CLK_CCF
select CLK_CCF
config TARGET_CONDOR bool "Condor board" -- 2.25.1
Adam Ford
