[PATCH] mtd: spi-nor-ids: add xtxtech part#
adding xtxtech part numbers
Signed-off-by: Bruce Suen bruce_suen@163.com --- drivers/mtd/spi/spi-nor-ids.c | 38 +++++++++++++++++++++++++++++++++-- 1 file changed, 36 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 3f8b796789..9a079c851d 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -528,8 +528,42 @@ const struct flash_info spi_nor_ids[] = { { INFO("XM25QH128A", 0x207018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, #endif #ifdef CONFIG_SPI_FLASH_XTX - /* XTX Technology (Shenzhen) Limited */ - { INFO("xt25f128b", 0x0b4018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + /* XTX Technology Limited */ + /* adding these 3V QSPI flash parts */ + { INFO("xt25f08", 0x0b4014, 0, 64 * 1024, 16, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25f16", 0x0b4015, 0, 64 * 1024, 32, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25f32", 0x0b4016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25f64", 0x0b4017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25f128", 0x0b4018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25f256", 0x0b4019, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + /* adding these 1.8V QSPI flash parts */ + { INFO("xt25q08", 0x0b6014, 0, 64 * 1024, 16, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25q16", 0x0b6015, 0, 64 * 1024, 32, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25q32", 0x0b6016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25q64", 0x0b6017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25q128", 0x0b6018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("xt25q256", 0x0b6019, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("xt25q512", 0x0b601A, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("xt25q01g", 0x0b601B, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + /* adding these wide voltage QSPI flash parts */ + { INFO("xt25w512", 0x0b651A, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("xt25w01g", 0x0b651B, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, #endif { }, };
Rework on commit head, it is unclear.
Why were these existing id's removed?
Jagan
Thanks for your comment,I will rework on commit head in V2 like this:
Adding the following XTX part numbers to the list:
xt25f08: 3V QSPI, 8Mbit
xt25f16: 3V QSPI, 16Mbit
xt25f32: 3V QSPI, 32Mbit
xt25f64: 3V QSPI, 64Mbit
xt25f128: 3V QSPI, 128Mbit
xt25f256: 3V QSPI, 256Mbit
xt25q08: 1.8V QSPI, 8Mbit
xt25q16: 1.8V QSPI, 16Mbit
xt25q32: 1.8V QSPI, 32Mbit
xt25q64: 1.8V QSPI, 64Mbit
xt25q128: 1.8V QSPI, 128Mbit
xt25q256: 1.8V QSPI, 256Mbit
xt25q512: 1.8V QSPI, 512Mbit
xt25q01g: 1.8V QSPI, 1Gbit
xt25w512: wide voltage, QSPI, 512Mbit
xt25w01g: wide voltage, QSPI, 1Gbit
Jagan
For 3.3v 32Mbit,There are two part numbers: xt25f128b(65nm) and xt25f128f(55nm).They have same id,so I removed xt25f128b and add xt25f128
add following XTX part numbers to the list:
xt25f08: 3V QSPI, 8Mbit xt25f16: 3V QSPI, 16Mbit xt25f32: 3V QSPI, 32Mbit xt25f64: 3V QSPI, 64Mbit xt25f128: 3V QSPI, 128Mbit xt25f256: 3V QSPI, 256Mbit xt25q08: 1.8V QSPI, 8Mbit xt25q16: 1.8V QSPI, 16Mbit xt25q32: 1.8V QSPI, 32Mbit xt25q64: 1.8V QSPI, 64Mbit xt25q128: 1.8V QSPI, 128Mbit xt25q256: 1.8V QSPI, 256Mbit xt25q512: 1.8V QSPI, 512Mbit xt25q01g: 1.8V QSPI, 1Gbit xt25w512: wide voltage, QSPI, 512Mbit xt25w01g: wide voltage, QSPI, 1Gbit
remove xt25f128b and add xt25f128,because xt25f128b andxt25f128f share same jdec id,we use xt25f128 instead.
Signed-off-by: Bruce Suen bruce_suen@163.com --- V2: modify commit head,add detailed part numbers --- drivers/mtd/spi/spi-nor-ids.c | 38 +++++++++++++++++++++++++++++++++-- 1 file changed, 36 insertions(+), 2 deletions(-)
Why "(Shenzhen)" dropped?
Jagan.
Hi Jagan,
XTX changed name from "XTX Technology (Shenzhen) Limited" to "XTX Technology Limited" since 2020,
so I removed "(Shenzhen)" .
Jagan.
On Mon, Jun 19, 2023 at 12:25 PM Bruce Suen bruce_suen@163.com wrote:
Hi Jagan,
Please reply in-line. and add a separate patch for it with a proper commit message as proof.
Thanks, Jagan.
Hi Jagan,
Thanks, Jagan.
Sorry,my last mail not reply in-line; Do you mean that I can sent version V3 with two patchs(1/2,2/2),one
of which is to add part numbers and the other is to change comment from "XTX Technology (Shenzhen) Limited"
Thanks, Bruce Suen.
Hi Jagan,
Thanks, Jagan.
patch 1: change the company name patch 2: add new parts.
Thanks, Jagan.
Bruce Suen
Jagan Teki
