[U-Boot] [PATCH 0/9] Use generic MMC driver on remaining OMAP platforms
Hi all,
The following series changes the remaining users of drivers/mmc/omap3_mmc.c to using the newer omap_hsmmc.c driver and then removes the legacy driver. This series depends on the patches that Vaibhav Hiremath has posted to convert am3517evm and omap3 evm over.
Thanks!
-- Tom
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc.
Signed-off-by: Tom Rini trini@ti.com --- board/cm_t35/cm_t35.c | 8 ++++++++ include/configs/cm_t35.h | 3 ++- 2 files changed, 10 insertions(+), 1 deletions(-)
diff --git a/board/cm_t35/cm_t35.c b/board/cm_t35/cm_t35.c index f82111b..420cd70 100644 --- a/board/cm_t35/cm_t35.c +++ b/board/cm_t35/cm_t35.c @@ -313,6 +313,14 @@ void set_muxconf_regs(void) cm_t3730_set_muxconf(); }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif + /* * Routine: setup_net_chip_gmpc * Description: Setting up the configuration GPMC registers specific to the diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 16a5f5b..496a904 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -108,8 +108,9 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} +#define CONFIG_GENERIC_MMC 1 #define CONFIG_MMC 1 -#define CONFIG_OMAP3_MMC 1 +#define CONFIG_OMAP_HSMMC 1 #define CONFIG_DOS_PARTITION 1
/* DDR - I use Micron DDR */
It is a good practice to CC the board maintainer. Thanks.
Tested-by: Igor Grinberg grinberg@compulab.co.il
- omap_mmc_init(0);
+} +#endif
- Routine: setup_net_chip_gmpc
- Description: Setting up the configuration GPMC registers specific to the
On Wed, Aug 24, 2011 at 5:31 AM, Igor Grinberg grinberg@compulab.co.il wrote:
Apologies, thanks!
Signed-off-by: Tom Rini trini@ti.com --- board/comelit/dig297/dig297.c | 9 +++++++++ include/configs/dig297.h | 5 +++-- 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/board/comelit/dig297/dig297.c b/board/comelit/dig297/dig297.c index 0062f12..a7071cd 100644 --- a/board/comelit/dig297/dig297.c +++ b/board/comelit/dig297/dig297.c @@ -37,6 +37,7 @@ #include <netdev.h> #include <twl4030.h> #include <asm/io.h> +#include <asm/arch/mmc_host_def.h> #include <asm/arch/omap3-regs.h> #include <asm/arch/mux.h> #include <asm/arch/mem.h> @@ -145,6 +146,14 @@ void set_muxconf_regs(void) MUX_DIG297(); }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif + #ifdef CONFIG_CMD_NET /* * Routine: setup_net_chip diff --git a/include/configs/dig297.h b/include/configs/dig297.h index b68f073..0e05df3 100644 --- a/include/configs/dig297.h +++ b/include/configs/dig297.h @@ -97,8 +97,9 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} -#define CONFIG_MMC -#define CONFIG_OMAP3_MMC +#define CONFIG_GENERIC_MMC 1 +#define CONFIG_MMC 1 +#define CONFIG_OMAP_HSMMC 1 #define CONFIG_DOS_PARTITION
Signed-off-by: Tom Rinitrini@ti.com
Again, please Cc: the board maintainers in the future, thanks.
diff --git a/board/comelit/dig297/dig297.c b/board/comelit/dig297/dig297.c index 0062f12..a7071cd 100644 --- a/board/comelit/dig297/dig297.c +++ b/board/comelit/dig297/dig297.c @@ -37,6 +37,7 @@ #include<netdev.h> #include<twl4030.h> #include<asm/io.h> +#include<asm/arch/mmc_host_def.h> #include<asm/arch/omap3-regs.h> #include<asm/arch/mux.h> #include<asm/arch/mem.h> @@ -145,6 +146,14 @@ void set_muxconf_regs(void) MUX_DIG297(); }
- omap_mmc_init(0);
+} +#endif
- #ifdef CONFIG_CMD_NET /*
IIRC the coding style says you should define the y/n constants without a value, e.g.: #define CONFIG_GENERIC_MMC not: #define CONFIG_GENERIC_MMC 1
Apart for this: Tested-by: Luca Ceresoli luca.ceresoli@comelit.it
Luca
On Wed, Aug 24, 2011 at 6:43 AM, Luca Ceresoli luca.ceresoli@comelit.it wrote:
Oh, sorry, used to other lists where people complain about too many CCs.
[snip]
OK, thanks, I'll respin this patch (all of the other boards were doing the define CONFIG_FOO 1 everywhere) shortly.
Tested-by: Luca Ceresoli luca.ceresoli@comelit.it Signed-off-by: Tom Rini trini@ti.com
V2 changes: Follow board config format, just use #define CONFIG_GENERIC_MMC, etc) --- board/comelit/dig297/dig297.c | 9 +++++++++ include/configs/dig297.h | 3 ++- 2 files changed, 11 insertions(+), 1 deletions(-)
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif + #ifdef CONFIG_CMD_NET /* * Routine: setup_net_chip diff --git a/include/configs/dig297.h b/include/configs/dig297.h index b68f073..4186ab6 100644 --- a/include/configs/dig297.h +++ b/include/configs/dig297.h @@ -97,8 +97,9 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} +#define CONFIG_GENERIC_MMC #define CONFIG_MMC -#define CONFIG_OMAP3_MMC +#define CONFIG_OMAP_HSMMC #define CONFIG_DOS_PARTITION
Signed-off-by: Tom Rini trini@ti.com --- board/logicpd/zoom1/zoom1.c | 9 +++++++++ include/configs/omap3_zoom1.h | 10 ++++++---- 2 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/board/logicpd/zoom1/zoom1.c b/board/logicpd/zoom1/zoom1.c index 7ef13cc..dec0b26 100644 --- a/board/logicpd/zoom1/zoom1.c +++ b/board/logicpd/zoom1/zoom1.c @@ -34,6 +34,7 @@ #include <netdev.h> #include <twl4030.h> #include <asm/io.h> +#include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> #include <asm/mach-types.h> @@ -88,6 +89,14 @@ void set_muxconf_regs(void) MUX_ZOOM1_MDK(); }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif + #ifdef CONFIG_CMD_NET int board_eth_init(bd_t *bis) { diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index aeac7c7..4b095a1 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -95,8 +95,9 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} +#define CONFIG_GENERIC_MMC 1 #define CONFIG_MMC 1 -#define CONFIG_OMAP3_MMC 1 +#define CONFIG_OMAP_HSMMC 1 #define CONFIG_DOS_PARTITION 1
/* DDR - I use Micron DDR */ @@ -178,6 +179,7 @@ "loadaddr=0x82000000\0" \ "usbtty=cdc_acm\0" \ "console=ttyS2,115200n8\0" \ + "mmcdev=0\0" \ "videomode=1024x768@60,vxres=1024,vyres=768\0" \ "videospec=omapfb:vram:2M,vram:4M\0" \ "mmcargs=setenv bootargs console=${console} " \ @@ -188,10 +190,10 @@ "video=${videospec},mode:${videomode} " \ "root=/dev/mtdblock4 rw " \ "rootfstype=jffs2\0" \ - "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ "source ${loadaddr}\0" \ - "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ "bootm ${loadaddr}\0" \ @@ -201,7 +203,7 @@ "bootm ${loadaddr}\0" \
#define CONFIG_BOOTCOMMAND \ - "if mmc init; then " \ + "if mmc rescan ${mmcdev}; then " \ "if run loadbootscript; then " \ "run bootscript; " \ "else " \
Signed-off-by: Tom Rini trini@ti.com --- board/logicpd/zoom2/zoom2.c | 9 +++++++++ include/configs/omap3_zoom2.h | 3 ++- 2 files changed, 11 insertions(+), 1 deletions(-)
diff --git a/board/logicpd/zoom2/zoom2.c b/board/logicpd/zoom2/zoom2.c index 76793e4..800113a 100644 --- a/board/logicpd/zoom2/zoom2.c +++ b/board/logicpd/zoom2/zoom2.c @@ -35,6 +35,7 @@ #endif #include <twl4030.h> #include <asm/io.h> +#include <asm/arch/mmc_host_def.h> #include <asm/arch/gpio.h> #include <asm/arch/mem.h> #include <asm/arch/mux.h> @@ -180,6 +181,14 @@ void set_muxconf_regs (void) MUX_ZOOM2 (); }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif + #ifdef CONFIG_CMD_NET int board_eth_init(bd_t *bis) { diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index 2a56182..57b42da 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -95,8 +95,9 @@ /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
Signed-off-by: Tom Rini trini@ti.com --- board/pandora/pandora.c | 9 +++++++++ include/configs/omap3_pandora.h | 5 +++-- 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/board/pandora/pandora.c b/board/pandora/pandora.c index 0df4570..58a676d 100644 --- a/board/pandora/pandora.c +++ b/board/pandora/pandora.c @@ -32,6 +32,7 @@ #include <common.h> #include <twl4030.h> #include <asm/io.h> +#include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> #include <asm/arch/gpio.h> #include <asm/arch/sys_proto.h> @@ -103,3 +104,11 @@ void set_muxconf_regs(void) { MUX_PANDORA(); } + +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index bd55abc..320cf64 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -100,8 +100,9 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, \ 115200} +#define CONFIG_GENERIC_MMC 1 #define CONFIG_MMC 1 -#define CONFIG_OMAP3_MMC 1 +#define CONFIG_OMAP_HSMMC 1 #define CONFIG_DOS_PARTITION 1
/* DDR - I use Micron DDR */ @@ -182,7 +183,7 @@ "mtdparts=" MTDPARTS_DEFAULT "\0" \
#define CONFIG_BOOTCOMMAND \ - "if mmc init && fatload mmc1 0 ${loadaddr} autoboot.scr || " \ + "if mmc rescan && fatload mmc1 0 ${loadaddr} autoboot.scr || " \ "ext2load mmc1 0 ${loadaddr} autoboot.scr; then " \ "source ${loadaddr}; " \ "fi; " \
Signed-off-by: Tom Rini trini@ti.com --- board/ti/am3517crane/am3517crane.c | 9 +++++++++ include/configs/am3517_crane.h | 10 ++++++---- 2 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/board/ti/am3517crane/am3517crane.c b/board/ti/am3517crane/am3517crane.c index d007044..cd5683d 100644 --- a/board/ti/am3517crane/am3517crane.c +++ b/board/ti/am3517crane/am3517crane.c @@ -24,6 +24,7 @@
#include <common.h> #include <asm/io.h> +#include <asm/arch/mmc_host_def.h> #include <asm/arch/mem.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> @@ -73,3 +74,11 @@ void set_muxconf_regs(void) { MUX_AM3517CRANE(); } + +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 743768e..e23ca45 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -93,8 +93,9 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} +#define CONFIG_GENERIC_MMC 1 #define CONFIG_MMC 1 -#define CONFIG_OMAP3_MMC 1 +#define CONFIG_OMAP_HSMMC 1 #define CONFIG_DOS_PARTITION 1
/* @@ -191,16 +192,17 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x82000000\0" \ "console=ttyS2,115200n8\0" \ + "mmcdev=0\0" \ "mmcargs=setenv bootargs console=${console} " \ "root=/dev/mmcblk0p2 rw " \ "rootfstype=ext3 rootwait\0" \ "nandargs=setenv bootargs console=${console} " \ "root=/dev/mtdblock4 rw " \ "rootfstype=jffs2\0" \ - "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ "source ${loadaddr}\0" \ - "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ "bootm ${loadaddr}\0" \ @@ -210,7 +212,7 @@ "bootm ${loadaddr}\0" \
Signed-off-by: Tom Rini trini@ti.com --- board/ti/sdp3430/sdp.c | 9 +++++++++ include/configs/omap3_sdp3430.h | 3 ++- 2 files changed, 11 insertions(+), 1 deletions(-)
diff --git a/board/ti/sdp3430/sdp.c b/board/ti/sdp3430/sdp.c index 72f0984..d73f501 100644 --- a/board/ti/sdp3430/sdp.c +++ b/board/ti/sdp3430/sdp.c @@ -25,6 +25,7 @@ #include <netdev.h> #include <twl4030.h> #include <asm/io.h> +#include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> @@ -204,3 +205,11 @@ void set_muxconf_regs(void) /* platform specific muxes */ MUX_SDP3430(); } + +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif diff --git a/include/configs/omap3_sdp3430.h b/include/configs/omap3_sdp3430.h index e1d8c78..17286d4 100644 --- a/include/configs/omap3_sdp3430.h +++ b/include/configs/omap3_sdp3430.h @@ -189,8 +189,9 @@ */
#if defined(CONFIG_CMD_MMC) +#define CONFIG_GENERIC_MMC 1 #define CONFIG_MMC 1 -#define CONFIG_OMAP3_MMC 1 +#define CONFIG_OMAP_HSMMC 1 #define CONFIG_DOS_PARTITION 1 #endif
Signed-off-by: Tom Rini trini@ti.com --- board/timll/devkit8000/devkit8000.c | 9 +++++++++ include/configs/devkit8000.h | 10 ++++++---- 2 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 95afaaa..533af5a 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -35,6 +35,7 @@ #include <common.h> #include <twl4030.h> #include <asm/io.h> +#include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h> @@ -119,6 +120,14 @@ void set_muxconf_regs(void) MUX_DEVKIT8000(); }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + return 0; +} +#endif + #ifdef CONFIG_DRIVER_DM9000 /* * Routine: board_eth_init diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index cf77606..710092d 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -98,8 +98,9 @@ 115200}
/* MMC */ +#define CONFIG_GENERIC_MMC 1 #define CONFIG_MMC 1 -#define CONFIG_OMAP3_MMC 1 +#define CONFIG_OMAP_HSMMC 1 #define CONFIG_DOS_PARTITION 1
/* I2C */ @@ -181,6 +182,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x82000000\0" \ "console=ttyS2,115200n8\0" \ + "mmcdev=0\0" \ "vram=12M\0" \ "dvimode=1024x768MR-16@60\0" \ "defaultdisplay=dvi\0" \ @@ -213,10 +215,10 @@ "${kernelopts} " \ "dnsip1=${dnsip} " \ "dnsip2=${dnsip2}\0" \ - "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ "source ${loadaddr}\0" \ - "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage\0" \ "eraseenv=nand unlock 0x260000 0x20000; nand erase 0x260000 0x20000\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ @@ -229,7 +231,7 @@ "dhcp ${loadaddr}; " \ "run netargs; " \ "bootm ${loadaddr}\0" \ - "autoboot=if mmc init 0; then " \ + "autoboot=if mmc rescan ${mmcdev}; then " \ "if run loadbootscript; then " \ "run bootscript; " \ "else " \
Now that all platforms have been migrated to the new MMC driver, remove the old one.
Signed-off-by: Tom Rini trini@ti.com --- drivers/mmc/Makefile | 1 - drivers/mmc/omap3_mmc.c | 570 ----------------------------------------------- drivers/mmc/omap3_mmc.h | 233 ------------------- 3 files changed, 0 insertions(+), 804 deletions(-) delete mode 100644 drivers/mmc/omap3_mmc.c delete mode 100644 drivers/mmc/omap3_mmc.h
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 3968c14..e5ca121 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -35,7 +35,6 @@ COBJS-$(CONFIG_MMC_SPI) += mmc_spi.o COBJS-$(CONFIG_ARM_PL180_MMCI) += arm_pl180_mmci.o COBJS-$(CONFIG_MV_SDHCI) += mv_sdhci.o COBJS-$(CONFIG_MXC_MMC) += mxcmmc.o -COBJS-$(CONFIG_OMAP3_MMC) += omap3_mmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o diff --git a/drivers/mmc/omap3_mmc.c b/drivers/mmc/omap3_mmc.c deleted file mode 100644 index 15d41e5..0000000 --- a/drivers/mmc/omap3_mmc.c +++ /dev/null @@ -1,570 +0,0 @@ -/* - * (C) Copyright 2008 - * Texas Instruments, <www.ti.com> - * Syed Mohammed Khasim khasim@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation's version 2 of - * the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <fat.h> -#include <mmc.h> -#include <part.h> -#include <i2c.h> -#include <twl4030.h> -#include <asm/io.h> - -#include "omap3_mmc.h" - -static const unsigned short mmc_transspeed_val[15][4] = { - {CLKD(10, 1), CLKD(10, 10), CLKD(10, 100), CLKD(10, 1000)}, - {CLKD(12, 1), CLKD(12, 10), CLKD(12, 100), CLKD(12, 1000)}, - {CLKD(13, 1), CLKD(13, 10), CLKD(13, 100), CLKD(13, 1000)}, - {CLKD(15, 1), CLKD(15, 10), CLKD(15, 100), CLKD(15, 1000)}, - {CLKD(20, 1), CLKD(20, 10), CLKD(20, 100), CLKD(20, 1000)}, - {CLKD(26, 1), CLKD(26, 10), CLKD(26, 100), CLKD(26, 1000)}, - {CLKD(30, 1), CLKD(30, 10), CLKD(30, 100), CLKD(30, 1000)}, - {CLKD(35, 1), CLKD(35, 10), CLKD(35, 100), CLKD(35, 1000)}, - {CLKD(40, 1), CLKD(40, 10), CLKD(40, 100), CLKD(40, 1000)}, - {CLKD(45, 1), CLKD(45, 10), CLKD(45, 100), CLKD(45, 1000)}, - {CLKD(52, 1), CLKD(52, 10), CLKD(52, 100), CLKD(52, 1000)}, - {CLKD(55, 1), CLKD(55, 10), CLKD(55, 100), CLKD(55, 1000)}, - {CLKD(60, 1), CLKD(60, 10), CLKD(60, 100), CLKD(60, 1000)}, - {CLKD(70, 1), CLKD(70, 10), CLKD(70, 100), CLKD(70, 1000)}, - {CLKD(80, 1), CLKD(80, 10), CLKD(80, 100), CLKD(80, 1000)} -}; - -static mmc_card_data cur_card_data; -static block_dev_desc_t mmc_blk_dev; -static hsmmc_t *mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; - -int mmc_set_dev(int dev_num) -{ - switch (dev_num) { - case 1: - mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; - break; - case 2: - mmc_base = (hsmmc_t *)OMAP_HSMMC2_BASE; - break; - case 3: - mmc_base = (hsmmc_t *)OMAP_HSMMC3_BASE; - break; - default: - mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; - return 1; - } - - return 0; -} - -block_dev_desc_t *mmc_get_dev(int dev) -{ - return (block_dev_desc_t *) &mmc_blk_dev; -} - -static unsigned char mmc_board_init(void) -{ -#if defined(CONFIG_TWL4030_POWER) - twl4030_power_mmc_init(); -#endif - -#if defined(CONFIG_OMAP34XX) - t2_t *t2_base = (t2_t *)T2_BASE; - struct prcm *prcm_base = (struct prcm *)PRCM_BASE; - - writel(readl(&t2_base->pbias_lite) | PBIASLITEPWRDNZ1 | - PBIASSPEEDCTRL0 | PBIASLITEPWRDNZ0, - &t2_base->pbias_lite); - - writel(readl(&t2_base->devconf0) | MMCSDIO1ADPCLKISEL, - &t2_base->devconf0); - - writel(readl(&t2_base->devconf1) | MMCSDIO2ADPCLKISEL, - &t2_base->devconf1); - - writel(readl(&prcm_base->fclken1_core) | - EN_MMC1 | EN_MMC2 | EN_MMC3, - &prcm_base->fclken1_core); - - writel(readl(&prcm_base->iclken1_core) | - EN_MMC1 | EN_MMC2 | EN_MMC3, - &prcm_base->iclken1_core); -#endif - -/* TODO add appropriate OMAP4 init */ - - return 1; -} - -static void mmc_init_stream(void) -{ - writel(readl(&mmc_base->con) | INIT_INITSTREAM, &mmc_base->con); - - writel(MMC_CMD0, &mmc_base->cmd); - while (!(readl(&mmc_base->stat) & CC_MASK)); - - writel(CC_MASK, &mmc_base->stat); - - writel(MMC_CMD0, &mmc_base->cmd); - while (!(readl(&mmc_base->stat) & CC_MASK)); - - writel(readl(&mmc_base->con) & ~INIT_INITSTREAM, &mmc_base->con); -} - -static unsigned char mmc_clock_config(unsigned int iclk, unsigned short clk_div) -{ - unsigned int val; - - mmc_reg_out(&mmc_base->sysctl, (ICE_MASK | DTO_MASK | CEN_MASK), - (ICE_STOP | DTO_15THDTO | CEN_DISABLE)); - - switch (iclk) { - case CLK_INITSEQ: - val = MMC_INIT_SEQ_CLK / 2; - break; - case CLK_400KHZ: - val = MMC_400kHz_CLK; - break; - case CLK_MISC: - val = clk_div; - break; - default: - return 0; - } - mmc_reg_out(&mmc_base->sysctl, ICE_MASK | CLKD_MASK, - (val << CLKD_OFFSET) | ICE_OSCILLATE); - - while ((readl(&mmc_base->sysctl) & ICS_MASK) == ICS_NOTREADY); - - writel(readl(&mmc_base->sysctl) | CEN_ENABLE, &mmc_base->sysctl); - return 1; -} - -static unsigned char mmc_init_setup(void) -{ - unsigned int reg_val; - - mmc_board_init(); - - writel(readl(&mmc_base->sysconfig) | MMC_SOFTRESET, - &mmc_base->sysconfig); - while ((readl(&mmc_base->sysstatus) & RESETDONE) == 0); - - writel(readl(&mmc_base->sysctl) | SOFTRESETALL, &mmc_base->sysctl); - while ((readl(&mmc_base->sysctl) & SOFTRESETALL) != 0x0); - - writel(DTW_1_BITMODE | SDBP_PWROFF | SDVS_3V0, &mmc_base->hctl); - writel(readl(&mmc_base->capa) | VS30_3V0SUP | VS18_1V8SUP, - &mmc_base->capa); - - reg_val = readl(&mmc_base->con) & RESERVED_MASK; - - writel(CTPL_MMC_SD | reg_val | WPP_ACTIVEHIGH | CDP_ACTIVEHIGH | - MIT_CTO | DW8_1_4BITMODE | MODE_FUNC | STR_BLOCK | - HR_NOHOSTRESP | INIT_NOINIT | NOOPENDRAIN, &mmc_base->con); - - mmc_clock_config(CLK_INITSEQ, 0); - writel(readl(&mmc_base->hctl) | SDBP_PWRON, &mmc_base->hctl); - - writel(IE_BADA | IE_CERR | IE_DEB | IE_DCRC | IE_DTO | IE_CIE | - IE_CEB | IE_CCRC | IE_CTO | IE_BRR | IE_BWR | IE_TC | IE_CC, - &mmc_base->ie); - - mmc_init_stream(); - return 1; -} - -static unsigned char mmc_send_cmd(unsigned int cmd, unsigned int arg, - unsigned int *response) -{ - unsigned int mmc_stat; - - while ((readl(&mmc_base->pstate) & DATI_MASK) == DATI_CMDDIS); - - writel(BLEN_512BYTESLEN | NBLK_STPCNT, &mmc_base->blk); - writel(0xFFFFFFFF, &mmc_base->stat); - writel(arg, &mmc_base->arg); - writel(cmd | CMD_TYPE_NORMAL | CICE_NOCHECK | CCCE_NOCHECK | - MSBS_SGLEBLK | ACEN_DISABLE | BCE_DISABLE | DE_DISABLE, - &mmc_base->cmd); - - while (1) { - do { - mmc_stat = readl(&mmc_base->stat); - } while (mmc_stat == 0); - - if ((mmc_stat & ERRI_MASK) != 0) - return (unsigned char) mmc_stat; - - if (mmc_stat & CC_MASK) { - writel(CC_MASK, &mmc_base->stat); - response[0] = readl(&mmc_base->rsp10); - if ((cmd & RSP_TYPE_MASK) == RSP_TYPE_LGHT136) { - response[1] = readl(&mmc_base->rsp32); - response[2] = readl(&mmc_base->rsp54); - response[3] = readl(&mmc_base->rsp76); - } - break; - } - } - return 1; -} - -static unsigned char mmc_read_data(unsigned int *output_buf) -{ - unsigned int mmc_stat; - unsigned int read_count = 0; - - /* - * Start Polled Read - */ - while (1) { - do { - mmc_stat = readl(&mmc_base->stat); - } while (mmc_stat == 0); - - if ((mmc_stat & ERRI_MASK) != 0) - return (unsigned char) mmc_stat; - - if (mmc_stat & BRR_MASK) { - unsigned int k; - - writel(readl(&mmc_base->stat) | BRR_MASK, - &mmc_base->stat); - for (k = 0; k < MMCSD_SECTOR_SIZE / 4; k++) { - *output_buf = readl(&mmc_base->data); - output_buf++; - read_count += 4; - } - } - - if (mmc_stat & BWR_MASK) - writel(readl(&mmc_base->stat) | BWR_MASK, - &mmc_base->stat); - - if (mmc_stat & TC_MASK) { - writel(readl(&mmc_base->stat) | TC_MASK, - &mmc_base->stat); - break; - } - } - return 1; -} - -static unsigned char mmc_detect_card(mmc_card_data *mmc_card_cur) -{ - unsigned char err; - unsigned int argument = 0; - unsigned int ocr_value, ocr_recvd, ret_cmd41, hcs_val; - unsigned short retry_cnt = 2000; - mmc_resp_t mmc_resp; - - /* Set to Initialization Clock */ - err = mmc_clock_config(CLK_400KHZ, 0); - if (err != 1) - return err; - - mmc_card_cur->RCA = MMC_RELATIVE_CARD_ADDRESS; - argument = 0x00000000; - - ocr_value = (0x1FF << 15); - err = mmc_send_cmd(MMC_CMD0, argument, mmc_resp.resp); - if (err != 1) - return err; - - argument = SD_CMD8_CHECK_PATTERN | SD_CMD8_2_7_3_6_V_RANGE; - err = mmc_send_cmd(MMC_SDCMD8, argument, mmc_resp.resp); - hcs_val = (err == 1) ? - MMC_OCR_REG_HOST_CAPACITY_SUPPORT_SECTOR : - MMC_OCR_REG_HOST_CAPACITY_SUPPORT_BYTE; - - argument = 0x0000 << 16; - err = mmc_send_cmd(MMC_CMD55, argument, mmc_resp.resp); - if (err == 1) { - mmc_card_cur->card_type = SD_CARD; - ocr_value |= hcs_val; - ret_cmd41 = MMC_ACMD41; - } else { - mmc_card_cur->card_type = MMC_CARD; - ocr_value |= MMC_OCR_REG_ACCESS_MODE_SECTOR; - ret_cmd41 = MMC_CMD1; - writel(readl(&mmc_base->con) & ~OD, &mmc_base->con); - writel(readl(&mmc_base->con) | OPENDRAIN, &mmc_base->con); - } - - argument = ocr_value; - err = mmc_send_cmd(ret_cmd41, argument, mmc_resp.resp); - if (err != 1) - return err; - - ocr_recvd = mmc_resp.r3.ocr; - - while (!(ocr_recvd & (0x1 << 31)) && (retry_cnt > 0)) { - retry_cnt--; - if (mmc_card_cur->card_type == SD_CARD) { - argument = 0x0000 << 16; - err = mmc_send_cmd(MMC_CMD55, argument, mmc_resp.resp); - } - - argument = ocr_value; - err = mmc_send_cmd(ret_cmd41, argument, mmc_resp.resp); - if (err != 1) - return err; - ocr_recvd = mmc_resp.r3.ocr; - } - - if (!(ocr_recvd & (0x1 << 31))) - return 0; - - if (mmc_card_cur->card_type == MMC_CARD) { - if ((ocr_recvd & MMC_OCR_REG_ACCESS_MODE_MASK) == - MMC_OCR_REG_ACCESS_MODE_SECTOR) { - mmc_card_cur->mode = SECTOR_MODE; - } else { - mmc_card_cur->mode = BYTE_MODE; - } - - ocr_recvd &= ~MMC_OCR_REG_ACCESS_MODE_MASK; - } else { - if ((ocr_recvd & MMC_OCR_REG_HOST_CAPACITY_SUPPORT_MASK) - == MMC_OCR_REG_HOST_CAPACITY_SUPPORT_SECTOR) { - mmc_card_cur->mode = SECTOR_MODE; - } else { - mmc_card_cur->mode = BYTE_MODE; - } - ocr_recvd &= ~MMC_OCR_REG_HOST_CAPACITY_SUPPORT_MASK; - } - - ocr_recvd &= ~(0x1 << 31); - if (!(ocr_recvd & ocr_value)) - return 0; - - err = mmc_send_cmd(MMC_CMD2, argument, mmc_resp.resp); - if (err != 1) - return err; - - if (mmc_card_cur->card_type == MMC_CARD) { - argument = mmc_card_cur->RCA << 16; - err = mmc_send_cmd(MMC_CMD3, argument, mmc_resp.resp); - if (err != 1) - return err; - } else { - argument = 0x00000000; - err = mmc_send_cmd(MMC_SDCMD3, argument, mmc_resp.resp); - if (err != 1) - return err; - - mmc_card_cur->RCA = mmc_resp.r6.newpublishedrca; - } - - writel(readl(&mmc_base->con) & ~OD, &mmc_base->con); - writel(readl(&mmc_base->con) | NOOPENDRAIN, &mmc_base->con); - return 1; -} - -static unsigned char mmc_read_cardsize(mmc_card_data *mmc_dev_data, - mmc_csd_reg_t *cur_csd) -{ - mmc_extended_csd_reg_t ext_csd; - unsigned int size, count, blk_len, blk_no, card_size, argument; - unsigned char err; - unsigned int resp[4]; - - if (mmc_dev_data->mode == SECTOR_MODE) { - if (mmc_dev_data->card_type == SD_CARD) { - card_size = - (((mmc_sd2_csd_reg_t *) cur_csd)-> - c_size_lsb & MMC_SD2_CSD_C_SIZE_LSB_MASK) | - ((((mmc_sd2_csd_reg_t *) cur_csd)-> - c_size_msb & MMC_SD2_CSD_C_SIZE_MSB_MASK) - << MMC_SD2_CSD_C_SIZE_MSB_OFFSET); - mmc_dev_data->size = card_size * 1024; - if (mmc_dev_data->size == 0) - return 0; - } else { - argument = 0x00000000; - err = mmc_send_cmd(MMC_CMD8, argument, resp); - if (err != 1) - return err; - err = mmc_read_data((unsigned int *) &ext_csd); - if (err != 1) - return err; - mmc_dev_data->size = ext_csd.sectorcount; - - if (mmc_dev_data->size == 0) - mmc_dev_data->size = 8388608; - } - } else { - if (cur_csd->c_size_mult >= 8) - return 0; - - if (cur_csd->read_bl_len >= 12) - return 0; - - /* Compute size */ - count = 1 << (cur_csd->c_size_mult + 2); - card_size = (cur_csd->c_size_lsb & MMC_CSD_C_SIZE_LSB_MASK) | - ((cur_csd->c_size_msb & MMC_CSD_C_SIZE_MSB_MASK) - << MMC_CSD_C_SIZE_MSB_OFFSET); - blk_no = (card_size + 1) * count; - blk_len = 1 << cur_csd->read_bl_len; - size = blk_no * blk_len; - mmc_dev_data->size = size / MMCSD_SECTOR_SIZE; - if (mmc_dev_data->size == 0) - return 0; - } - return 1; -} - -static unsigned long mmc_bread(int dev_num, unsigned long blknr, - lbaint_t blkcnt, void *dst) -{ - unsigned char err; - unsigned int argument; - unsigned int resp[4]; - unsigned int *output_buf = dst; - unsigned int sec_inc_val; - lbaint_t i; - - if (blkcnt == 0) - return 0; - - if (cur_card_data.mode == SECTOR_MODE) { - argument = blknr; - sec_inc_val = 1; - } else { - argument = blknr * MMCSD_SECTOR_SIZE; - sec_inc_val = MMCSD_SECTOR_SIZE; - } - - for (i = 0; i < blkcnt; i++) { - err = mmc_send_cmd(MMC_CMD17, argument, resp); - if (err != 1) { - printf("mmc: CMD17 failed, status = %08x\n", err); - break; - } - - err = mmc_read_data(output_buf); - if (err != 1) { - printf("mmc: read failed, status = %08x\n", err); - break; - } - - output_buf += (MMCSD_SECTOR_SIZE / 4); - argument += sec_inc_val; - } - - return i; -} - -static unsigned char configure_mmc(mmc_card_data *mmc_card_cur) -{ - unsigned char ret_val; - unsigned int argument; - unsigned int trans_clk, trans_fact, trans_unit, retries = 2; - unsigned char trans_speed; - mmc_resp_t mmc_resp; - - ret_val = mmc_init_setup(); - - if (ret_val != 1) - return ret_val; - - do { - ret_val = mmc_detect_card(mmc_card_cur); - retries--; - } while ((retries > 0) && (ret_val != 1)); - - argument = mmc_card_cur->RCA << 16; - ret_val = mmc_send_cmd(MMC_CMD9, argument, mmc_resp.resp); - if (ret_val != 1) - return ret_val; - - if (mmc_card_cur->card_type == MMC_CARD) - mmc_card_cur->version = mmc_resp.Card_CSD.spec_vers; - - trans_speed = mmc_resp.Card_CSD.tran_speed; - - ret_val = mmc_send_cmd(MMC_CMD4, MMC_DSR_DEFAULT << 16, mmc_resp.resp); - if (ret_val != 1) - return ret_val; - - trans_unit = trans_speed & MMC_CSD_TRAN_SPEED_UNIT_MASK; - trans_fact = trans_speed & MMC_CSD_TRAN_SPEED_FACTOR_MASK; - - if (trans_unit > MMC_CSD_TRAN_SPEED_UNIT_100MHZ) - return 0; - - if ((trans_fact < MMC_CSD_TRAN_SPEED_FACTOR_1_0) || - (trans_fact > MMC_CSD_TRAN_SPEED_FACTOR_8_0)) - return 0; - - trans_unit >>= 0; - trans_fact >>= 3; - - trans_clk = mmc_transspeed_val[trans_fact - 1][trans_unit] * 2; - ret_val = mmc_clock_config(CLK_MISC, trans_clk); - - if (ret_val != 1) - return ret_val; - - argument = mmc_card_cur->RCA << 16; - ret_val = mmc_send_cmd(MMC_CMD7_SELECT, argument, mmc_resp.resp); - if (ret_val != 1) - return ret_val; - - /* Configure the block length to 512 bytes */ - argument = MMCSD_SECTOR_SIZE; - ret_val = mmc_send_cmd(MMC_CMD16, argument, mmc_resp.resp); - if (ret_val != 1) - return ret_val; - - /* get the card size in sectors */ - ret_val = mmc_read_cardsize(mmc_card_cur, &mmc_resp.Card_CSD); - if (ret_val != 1) - return ret_val; - - return 1; -} - -int mmc_legacy_init(int dev) -{ - if (mmc_set_dev(dev) != 0) - return 1; - - if (configure_mmc(&cur_card_data) != 1) - return 1; - - mmc_blk_dev.if_type = IF_TYPE_MMC; - mmc_blk_dev.part_type = PART_TYPE_DOS; - mmc_blk_dev.dev = 0; - mmc_blk_dev.lun = 0; - mmc_blk_dev.type = 0; - - /* FIXME fill in the correct size (is set to 32MByte) */ - mmc_blk_dev.blksz = MMCSD_SECTOR_SIZE; - mmc_blk_dev.lba = 0x10000; - mmc_blk_dev.removable = 0; - mmc_blk_dev.block_read = mmc_bread; - - fat_register_device(&mmc_blk_dev, 1); - return 0; -} diff --git a/drivers/mmc/omap3_mmc.h b/drivers/mmc/omap3_mmc.h deleted file mode 100644 index e4d263c..0000000 --- a/drivers/mmc/omap3_mmc.h +++ /dev/null @@ -1,233 +0,0 @@ -/* - * (C) Copyright 2008 - * Texas Instruments, <www.ti.com> - * Syed Mohammed Khasim khasim@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation's version 2 of - * the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef MMC_H -#define MMC_H - -#include <asm/arch/mmc_host_def.h> - -/* Responses */ -#define RSP_TYPE_NONE (RSP_TYPE_NORSP | CCCE_NOCHECK | CICE_NOCHECK) -#define RSP_TYPE_R1 (RSP_TYPE_LGHT48 | CCCE_CHECK | CICE_CHECK) -#define RSP_TYPE_R1B (RSP_TYPE_LGHT48B | CCCE_CHECK | CICE_CHECK) -#define RSP_TYPE_R2 (RSP_TYPE_LGHT136 | CCCE_CHECK | CICE_NOCHECK) -#define RSP_TYPE_R3 (RSP_TYPE_LGHT48 | CCCE_NOCHECK | CICE_NOCHECK) -#define RSP_TYPE_R4 (RSP_TYPE_LGHT48 | CCCE_NOCHECK | CICE_NOCHECK) -#define RSP_TYPE_R5 (RSP_TYPE_LGHT48 | CCCE_CHECK | CICE_CHECK) -#define RSP_TYPE_R6 (RSP_TYPE_LGHT48 | CCCE_CHECK | CICE_CHECK) -#define RSP_TYPE_R7 (RSP_TYPE_LGHT48 | CCCE_CHECK | CICE_CHECK) - -/* All supported commands */ -#define MMC_CMD0 (INDEX(0) | RSP_TYPE_NONE | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD1 (INDEX(1) | RSP_TYPE_R3 | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD2 (INDEX(2) | RSP_TYPE_R2 | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD3 (INDEX(3) | RSP_TYPE_R1 | DP_NO_DATA | DDIR_WRITE) -#define MMC_SDCMD3 (INDEX(3) | RSP_TYPE_R6 | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD4 (INDEX(4) | RSP_TYPE_NONE | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD6 (INDEX(6) | RSP_TYPE_R1B | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD7_SELECT (INDEX(7) | RSP_TYPE_R1B | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD7_DESELECT (INDEX(7)| RSP_TYPE_NONE | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD8 (INDEX(8) | RSP_TYPE_R1 | DP_DATA | DDIR_READ) -#define MMC_SDCMD8 (INDEX(8) | RSP_TYPE_R7 | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD9 (INDEX(9) | RSP_TYPE_R2 | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD12 (INDEX(12) | RSP_TYPE_R1B | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD13 (INDEX(13) | RSP_TYPE_R1 | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD15 (INDEX(15) | RSP_TYPE_NONE | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD16 (INDEX(16) | RSP_TYPE_R1 | DP_NO_DATA | DDIR_WRITE) -#define MMC_CMD17 (INDEX(17) | RSP_TYPE_R1 | DP_DATA | DDIR_READ) -#define MMC_CMD24 (INDEX(24) | RSP_TYPE_R1 | DP_DATA | DDIR_WRITE) -#define MMC_ACMD6 (INDEX(6) | RSP_TYPE_R1 | DP_NO_DATA | DDIR_WRITE) -#define MMC_ACMD41 (INDEX(41) | RSP_TYPE_R3 | DP_NO_DATA | DDIR_WRITE) -#define MMC_ACMD51 (INDEX(51) | RSP_TYPE_R1 | DP_DATA | DDIR_READ) -#define MMC_CMD55 (INDEX(55) | RSP_TYPE_R1 | DP_NO_DATA | DDIR_WRITE) - -#define MMC_AC_CMD_RCA_MASK (unsigned int)(0xFFFF << 16) -#define MMC_BC_CMD_DSR_MASK (unsigned int)(0xFFFF << 16) -#define MMC_DSR_DEFAULT 0x0404 -#define SD_CMD8_CHECK_PATTERN 0xAA -#define SD_CMD8_2_7_3_6_V_RANGE (0x01 << 8) - -/* Clock Configurations and Macros */ - -#define MMC_CLOCK_REFERENCE 96 -#define MMC_RELATIVE_CARD_ADDRESS 0x1234 -#define MMC_INIT_SEQ_CLK (MMC_CLOCK_REFERENCE * 1000 / 80) -#define MMC_400kHz_CLK (MMC_CLOCK_REFERENCE * 1000 / 400) -#define CLKDR(r, f, u) ((((r)*100) / ((f)*(u))) + 1) -#define CLKD(f, u) (CLKDR(MMC_CLOCK_REFERENCE, f, u)) - -#define MMC_OCR_REG_ACCESS_MODE_MASK (0x3 << 29) -#define MMC_OCR_REG_ACCESS_MODE_BYTE (0x0 << 29) -#define MMC_OCR_REG_ACCESS_MODE_SECTOR (0x2 << 29) - -#define MMC_OCR_REG_HOST_CAPACITY_SUPPORT_MASK (0x1 << 30) -#define MMC_OCR_REG_HOST_CAPACITY_SUPPORT_BYTE (0x0 << 30) -#define MMC_OCR_REG_HOST_CAPACITY_SUPPORT_SECTOR (0x1 << 30) - -#define MMC_SD2_CSD_C_SIZE_LSB_MASK 0xFFFF -#define MMC_SD2_CSD_C_SIZE_MSB_MASK 0x003F -#define MMC_SD2_CSD_C_SIZE_MSB_OFFSET 16 -#define MMC_CSD_C_SIZE_LSB_MASK 0x0003 -#define MMC_CSD_C_SIZE_MSB_MASK 0x03FF -#define MMC_CSD_C_SIZE_MSB_OFFSET 2 - -#define MMC_CSD_TRAN_SPEED_UNIT_MASK (0x07 << 0) -#define MMC_CSD_TRAN_SPEED_FACTOR_MASK (0x0F << 3) -#define MMC_CSD_TRAN_SPEED_UNIT_100MHZ (0x3 << 0) -#define MMC_CSD_TRAN_SPEED_FACTOR_1_0 (0x01 << 3) -#define MMC_CSD_TRAN_SPEED_FACTOR_8_0 (0x0F << 3) - -typedef struct { - unsigned not_used:1; - unsigned crc:7; - unsigned ecc:2; - unsigned file_format:2; - unsigned tmp_write_protect:1; - unsigned perm_write_protect:1; - unsigned copy:1; - unsigned file_format_grp:1; - unsigned content_prot_app:1; - unsigned reserved_1:4; - unsigned write_bl_partial:1; - unsigned write_bl_len:4; - unsigned r2w_factor:3; - unsigned default_ecc:2; - unsigned wp_grp_enable:1; - unsigned wp_grp_size:5; - unsigned erase_grp_mult:5; - unsigned erase_grp_size:5; - unsigned c_size_mult:3; - unsigned vdd_w_curr_max:3; - unsigned vdd_w_curr_min:3; - unsigned vdd_r_curr_max:3; - unsigned vdd_r_curr_min:3; - unsigned c_size_lsb:2; - unsigned c_size_msb:10; - unsigned reserved_2:2; - unsigned dsr_imp:1; - unsigned read_blk_misalign:1; - unsigned write_blk_misalign:1; - unsigned read_bl_partial:1; - unsigned read_bl_len:4; - unsigned ccc:12; - unsigned tran_speed:8; - unsigned nsac:8; - unsigned taac:8; - unsigned reserved_3:2; - unsigned spec_vers:4; - unsigned csd_structure:2; -} mmc_csd_reg_t; - -/* csd for sd2.0 */ -typedef struct { - unsigned not_used:1; - unsigned crc:7; - unsigned reserved_1:2; - unsigned file_format:2; - unsigned tmp_write_protect:1; - unsigned perm_write_protect:1; - unsigned copy:1; - unsigned file_format_grp:1; - unsigned reserved_2:5; - unsigned write_bl_partial:1; - unsigned write_bl_len:4; - unsigned r2w_factor:3; - unsigned reserved_3:2; - unsigned wp_grp_enable:1; - unsigned wp_grp_size:7; - unsigned sector_size:7; - unsigned erase_blk_len:1; - unsigned reserved_4:1; - unsigned c_size_lsb:16; - unsigned c_size_msb:6; - unsigned reserved_5:6; - unsigned dsr_imp:1; - unsigned read_blk_misalign:1; - unsigned write_blk_misalign:1; - unsigned read_bl_partial:1; - unsigned read_bl_len:4; - unsigned ccc:12; - unsigned tran_speed:8; - unsigned nsac:8; - unsigned taac:8; - unsigned reserved_6:6; - unsigned csd_structure:2; -} mmc_sd2_csd_reg_t; - -/* extended csd - 512 bytes long */ -typedef struct { - unsigned char reserved_1[181]; - unsigned char erasedmemorycontent; - unsigned char reserved_2; - unsigned char buswidthmode; - unsigned char reserved_3; - unsigned char highspeedinterfacetiming; - unsigned char reserved_4; - unsigned char powerclass; - unsigned char reserved_5; - unsigned char commandsetrevision; - unsigned char reserved_6; - unsigned char commandset; - unsigned char extendedcsdrevision; - unsigned char reserved_7; - unsigned char csdstructureversion; - unsigned char reserved_8; - unsigned char cardtype; - unsigned char reserved_9[3]; - unsigned char powerclass_52mhz_1_95v; - unsigned char powerclass_26mhz_1_95v; - unsigned char powerclass_52mhz_3_6v; - unsigned char powerclass_26mhz_3_6v; - unsigned char reserved_10; - unsigned char minreadperf_4b_26mhz; - unsigned char minwriteperf_4b_26mhz; - unsigned char minreadperf_8b_26mhz_4b_52mhz; - unsigned char minwriteperf_8b_26mhz_4b_52mhz; - unsigned char minreadperf_8b_52mhz; - unsigned char minwriteperf_8b_52mhz; - unsigned char reserved_11; - unsigned int sectorcount; - unsigned char reserved_12[288]; - unsigned char supportedcommandsets; - unsigned char reserved_13[7]; -} mmc_extended_csd_reg_t; - -/* mmc sd responce */ -typedef struct { - unsigned int ocr; -} mmc_resp_r3; - -typedef struct { - unsigned short cardstatus; - unsigned short newpublishedrca; -} mmc_resp_r6; - -typedef union { - unsigned int resp[4]; - mmc_resp_r3 r3; - mmc_resp_r6 r6; - mmc_csd_reg_t Card_CSD; -} mmc_resp_t; - -#endif /* MMC_H */
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Rini, Tom Sent: Tuesday, August 23, 2011 3:44 AM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH 9/9] OMAP3: Remove legacy mmc driver
Similar patch was posted earlier in the month: http://marc.info/?l=u-boot&m=131220851719468&w=2
You may still want to keep the "legacy" mmc driver. Should help the new boards during early development.
~sanjeev
How? Really, protecting legacy stuff won't help anyone ... and if those people want it, they can pull it from git history.
Cheers
~sanjeev _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Agreed. I'd be happy to apply this once the patches changing the drivers over have been committed. I can do that, if the many board maintainers don't object. Otherwise, I'll just wait. :)
Andy
<Playing some post-vacation catch-up>
I just want to address this point real quick. Take a look at the board conversion patches, it's not a big deal to hook in to this, it's just a matter of calling the init function, on top of any "normal" hook up work you had to do.
participants (8)
Andy Fleming
Igor Grinberg
Luca Ceresoli
Premi, Sanjeev
Rini, Tom
