[U-Boot] [PATCH] powerpc/mpc85xx: Serdes protocol "00" is supported
"0x00" is a valid serdes protocol for QorIQ parts, and can not be used to test whether the serdes is enabled or disabled.
Signed-off-by: Ebony Zhu b45385@freescale.com --- arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c index d1fc76a..8edf5bb 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c @@ -186,11 +186,6 @@ u64 serdes_init(u32 sd, u32 sd_addr, u32 sd_prctl_mask, u32 sd_prctl_shift) #endif
cfg = in_be32(&gur->rcwsr[4]) & sd_prctl_mask; - /* Is serdes enabled at all? */ - if (!cfg) { - printf("SERDES%d is not enabled\n", sd + 1); - return 0; - }
/* Erratum A-007186 * Freescale Scratch Pad Fuse Register n (SFP_FSPFR0)
Applied to u-boot-mpc85xx, awaiting upstream.
York
Ebony Zhu
York Sun
