[U-Boot] [PATCH v2] tools: mkimage: split code into core, default and FIT image specific
This is first step towards cleaning mkimage code for kwbimage support in clean way. Current mkimage code is very specific to uimg generation whereas the same framework can be used to generate other image types like Kirkwood boot image (kwbimage-TBD). For this, the architecture of mkimage code need to modified.
Here is the brief plan for the same:- a) Split mkimage code into core and image specific support b) Implement callback function for image specific functions c) Move image type specific code to respective c files Currently there are two types of file generation/list supported (i.e uimg, FIT), the code is abstracted from mkimage.c/h and put in default_image.c and fit_image.c all code in these file is static except init function call d) mkimage_register API is added to add new image type support All above is addressed in this patch e) Add kwbimage type support to this new framework (TBD)
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- Change log: v2: patch generated on mkimage branch
tools/Makefile | 9 +- tools/default_image.c | 149 ++++++++++++++ tools/fit_image.c | 212 +++++++++++++++++++ tools/mkimage.c | 539 +++++++++++++++++++++++-------------------------- tools/mkimage.h | 101 +++++++++- 5 files changed, 720 insertions(+), 290 deletions(-) create mode 100644 tools/default_image.c create mode 100644 tools/fit_image.c
diff --git a/tools/Makefile b/tools/Makefile index 6f36f23..10547e1 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -183,7 +183,8 @@ $(obj)inca-swap-bytes$(SFX): $(obj)inca-swap-bytes.o $(CC) $(CFLAGS) $(HOST_LDFLAGS) -o $@ $^ $(STRIP) $@
-$(obj)mkimage$(SFX): $(obj)crc32.o $(obj)mkimage.o $(obj)image.o $(obj)md5.o $(obj)mkimage.o \ +$(obj)mkimage$(SFX): $(obj)crc32.o $(obj)default_image.o $(obj)fit_image.o $(obj)image.o \ + $(obj)md5.o $(obj)mkimage.o \ $(obj)os_support.o $(obj)sha1.o $(LIBFDT_OBJS) $(CC) $(CFLAGS) $(HOST_LDFLAGS) -o $@ $^ $(STRIP) $@ @@ -200,6 +201,12 @@ $(obj)ubsha1$(SFX): $(obj)os_support.o $(obj)sha1.o $(obj)ubsha1.o $(CC) $(CFLAGS) -o $@ $^
# Some files complain if compiled with -pedantic, use FIT_CFLAGS +$(obj)default_image.o: $(SRCTREE)/tools/default_image.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +$(obj)fit_image.o: $(SRCTREE)/tools/fit_image.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + $(obj)image.o: $(SRCTREE)/common/image.c $(CC) -g $(FIT_CFLAGS) -c -o $@ $<
diff --git a/tools/default_image.c b/tools/default_image.c new file mode 100644 index 0000000..f5bad47 --- /dev/null +++ b/tools/default_image.c @@ -0,0 +1,149 @@ +/* + * (C) Copyright 2008 Semihalf + * + * (C) Copyright 2000-2004 + * DENX Software Engineering + * Wolfgang Denk, wd@denx.de + * + * Updated-by: Prafulla Wadaskar prafulla@marvell.com + * default_image specific code abstracted from mkimage.c + * some functions added to address abstraction + * + * All rights reserved. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include "mkimage.h" +#include <image.h> +#include <u-boot/crc.h> + +static image_header_t header; + +static int image_check_image_types (uint8_t type) +{ + if ((type > IH_TYPE_INVALID) && (type < IH_TYPE_FLATDT)) + return EXIT_SUCCESS; + else + return EXIT_FAILURE; +} + +static int image_check_params (struct mkimage_params *params) +{ + return ((params->dflag && (params->fflag || params->lflag)) || + (params->fflag && (params->dflag || params->lflag)) || + (params->lflag && (params->dflag || params->fflag))); +} + +static int image_verify_header (unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + uint32_t len; + const unsigned char *data; + uint32_t checksum; + image_header_t header; + image_header_t *hdr = &header; + + /* + * create copy of header so that we can blank out the + * checksum field for checking - this can't be done + * on the PROT_READ mapped data. + */ + memcpy (hdr, ptr, sizeof(image_header_t)); + + if (be32_to_cpu(hdr->ih_magic) != IH_MAGIC) { + fprintf (stderr, + "%s: Bad Magic Number: "%s" is no valid image\n", + params->cmdname, params->imagefile); + return -FDT_ERR_BADMAGIC; + } + + data = (const unsigned char *)hdr; + len = sizeof(image_header_t); + + checksum = be32_to_cpu(hdr->ih_hcrc); + hdr->ih_hcrc = cpu_to_be32(0); /* clear for re-calculation */ + + if (crc32 (0, data, len) != checksum) { + fprintf (stderr, + "%s: ERROR: "%s" has bad header checksum!\n", + params->cmdname, params->imagefile); + return -FDT_ERR_BADSTATE; + } + + data = (const unsigned char *)ptr + sizeof(image_header_t); + len = image_size - sizeof(image_header_t) ; + + checksum = be32_to_cpu(hdr->ih_dcrc); + if (crc32 (0, data, len) != checksum) { + fprintf (stderr, + "%s: ERROR: "%s" has corrupted data!\n", + params->cmdname, params->imagefile); + return -FDT_ERR_BADSTRUCTURE; + } + return 0; +} + +static void image_set_header (void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + uint32_t checksum; + + image_header_t * hdr = (image_header_t *)ptr; + + checksum = crc32 (0, + (const unsigned char *)(ptr + + sizeof(image_header_t)), + sbuf->st_size - sizeof(image_header_t)); + + /* Build new header */ + image_set_magic (hdr, IH_MAGIC); + image_set_time (hdr, sbuf->st_mtime); + image_set_size (hdr, sbuf->st_size - sizeof(image_header_t)); + image_set_load (hdr, params->addr); + image_set_ep (hdr, params->ep); + image_set_dcrc (hdr, checksum); + image_set_os (hdr, params->os); + image_set_arch (hdr, params->arch); + image_set_type (hdr, params->type); + image_set_comp (hdr, params->comp); + + image_set_name (hdr, params->imagename); + + checksum = crc32 (0, (const unsigned char *)hdr, + sizeof(image_header_t)); + + image_set_hcrc (hdr, checksum); +} + +/* + * Default image type parameters definition + */ +static struct image_type_params defimage_params = { + .name = "Default Image support", + .header_size = sizeof(image_header_t), + .hdr = (void*)&header, + .check_image_type = image_check_image_types, + .verify_header = image_verify_header, + .print_header = image_print_contents, + .set_header = image_set_header, + .check_params = image_check_params, +}; + +void init_default_image_type (void) +{ + mkimage_register (&defimage_params); +} diff --git a/tools/fit_image.c b/tools/fit_image.c new file mode 100644 index 0000000..6f5c8c6 --- /dev/null +++ b/tools/fit_image.c @@ -0,0 +1,212 @@ +/* + * (C) Copyright 2008 Semihalf + * + * (C) Copyright 2000-2004 + * DENX Software Engineering + * Wolfgang Denk, wd@denx.de + * + * Updated-by: Prafulla Wadaskar prafulla@marvell.com + * fir image specific code abstracted from mkimage.c + * some functions added to address abstraction + * + * All rights reserved. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include "mkimage.h" +#include <image.h> +#include <u-boot/crc.h> + +static image_header_t header; + +static int fit_verify_header (unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + return fdt_check_header ((void *)ptr); +} + +static int fit_check_image_types (uint8_t type) +{ + if (type == IH_TYPE_FLATDT) + return EXIT_SUCCESS; + else + return EXIT_FAILURE; +} + +/** + * fit_handle_file - main FIT file processing function + * + * fit_handle_file() runs dtc to convert .its to .itb, includes + * binary data, updates timestamp property and calculates hashes. + * + * datafile - .its file + * imagefile - .itb file + * + * returns: + * only on success, otherwise calls exit (EXIT_FAILURE); + */ +static int fit_handle_file (struct mkimage_params *params) +{ + char tmpfile[MKIMAGE_MAX_TMPFILE_LEN]; + char cmd[MKIMAGE_MAX_DTC_CMDLINE_LEN]; + int tfd; + struct stat sbuf; + unsigned char *ptr; + + /* Flattened Image Tree (FIT) format handling */ + debug ("FIT format handling\n"); + + /* call dtc to include binary properties into the tmp file */ + if (strlen (params->imagefile) + + strlen (MKIMAGE_TMPFILE_SUFFIX) + 1 > sizeof (tmpfile)) { + fprintf (stderr, "%s: Image file name (%s) too long, " + "can't create tmpfile", + params->imagefile, params->cmdname); + return (EXIT_FAILURE); + } + sprintf (tmpfile, "%s%s", params->imagefile, MKIMAGE_TMPFILE_SUFFIX); + + /* dtc -I dts -O -p 200 datafile > tmpfile */ + sprintf (cmd, "%s %s %s > %s", + MKIMAGE_DTC, params->dtc, params->datafile, tmpfile); + debug ("Trying to execute "%s"\n", cmd); + if (system (cmd) == -1) { + fprintf (stderr, "%s: system(%s) failed: %s\n", + params->cmdname, cmd, strerror(errno)); + unlink (tmpfile); + return (EXIT_FAILURE); + } + + /* load FIT blob into memory */ + tfd = open (tmpfile, O_RDWR|O_BINARY); + + if (tfd < 0) { + fprintf (stderr, "%s: Can't open %s: %s\n", + params->cmdname, tmpfile, strerror(errno)); + unlink (tmpfile); + return (EXIT_FAILURE); + } + + if (fstat (tfd, &sbuf) < 0) { + fprintf (stderr, "%s: Can't stat %s: %s\n", + params->cmdname, tmpfile, strerror(errno)); + unlink (tmpfile); + return (EXIT_FAILURE); + } + + ptr = mmap (0, sbuf.st_size, PROT_READ|PROT_WRITE, MAP_SHARED, + tfd, 0); + if (ptr == MAP_FAILED) { + fprintf (stderr, "%s: Can't read %s: %s\n", + params->cmdname, tmpfile, strerror(errno)); + unlink (tmpfile); + return (EXIT_FAILURE); + } + + /* check if ptr has a valid blob */ + if (fdt_check_header (ptr)) { + fprintf (stderr, "%s: Invalid FIT blob\n", params->cmdname); + unlink (tmpfile); + return (EXIT_FAILURE); + } + + /* set hashes for images in the blob */ + if (fit_set_hashes (ptr)) { + fprintf (stderr, "%s Can't add hashes to FIT blob", + params->cmdname); + unlink (tmpfile); + return (EXIT_FAILURE); + } + + /* add a timestamp at offset 0 i.e., root */ + if (fit_set_timestamp (ptr, 0, sbuf.st_mtime)) { + fprintf (stderr, "%s: Can't add image timestamp\n", + params->cmdname); + unlink (tmpfile); + return (EXIT_FAILURE); + } + debug ("Added timestamp successfully\n"); + + munmap ((void *)ptr, sbuf.st_size); + close (tfd); + + if (rename (tmpfile, params->imagefile) == -1) { + fprintf (stderr, "%s: Can't rename %s to %s: %s\n", + params->cmdname, tmpfile, params->imagefile, + strerror (errno)); + unlink (tmpfile); + unlink (params->imagefile); + return (EXIT_FAILURE); + } + return (EXIT_SUCCESS); +} + +static void fit_set_header (void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + uint32_t checksum; + + image_header_t * hdr = (image_header_t *)ptr; + + checksum = crc32 (0, + (const unsigned char *)(ptr + + sizeof(image_header_t)), + sbuf->st_size - sizeof(image_header_t)); + + /* Build new header */ + image_set_magic (hdr, IH_MAGIC); + image_set_time (hdr, sbuf->st_mtime); + image_set_size (hdr, sbuf->st_size - sizeof(image_header_t)); + image_set_load (hdr, params->addr); + image_set_ep (hdr, params->ep); + image_set_dcrc (hdr, checksum); + image_set_os (hdr, params->os); + image_set_arch (hdr, params->arch); + image_set_type (hdr, params->type); + image_set_comp (hdr, params->comp); + + image_set_name (hdr, params->imagename); + + checksum = crc32 (0, (const unsigned char *)hdr, + sizeof(image_header_t)); + + image_set_hcrc (hdr, checksum); +} + +static int fit_check_params (struct mkimage_params *params) +{ + return ((params->dflag && (params->fflag || params->lflag)) || + (params->fflag && (params->dflag || params->lflag)) || + (params->lflag && (params->dflag || params->fflag))); +} + +static struct image_type_params fitimage_params = { + .name = "FIT Image support", + .header_size = sizeof(image_header_t), + .hdr = (void*)&header, + .verify_header = fit_verify_header, + .print_header = fit_print_contents, + .check_image_type = fit_check_image_types, + .fflag_handle = fit_handle_file, + .set_header = fit_set_header, + .check_params = fit_check_params, +}; + +void init_fit_image_type (void) +{ + mkimage_register (&fitimage_params); +} diff --git a/tools/mkimage.c b/tools/mkimage.c index 19ae733..66ebb70 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -24,126 +24,223 @@
#include "mkimage.h" #include <image.h> -#include <u-boot/crc.h> - -static void copy_file (int, const char *, int); -static void usage (void); -static int image_verify_header (char *, int); -static void fit_handle_file (void); - -char *datafile; -char *imagefile; -char *cmdname; - -int dflag = 0; -int eflag = 0; -int fflag = 0; -int lflag = 0; -int vflag = 0; -int xflag = 0; -int opt_os = IH_OS_LINUX; -int opt_arch = IH_ARCH_PPC; -int opt_type = IH_TYPE_KERNEL; -int opt_comp = IH_COMP_GZIP; -char *opt_dtc = MKIMAGE_DEFAULT_DTC_OPTIONS; - -image_header_t header; -image_header_t *hdr = &header; + +static void copy_file(int, const char *, int); +static void usage(void); + +/* image_type_params link list to maintain registered image type supports */ +struct image_type_params *mkimage_tparams = NULL; + +/* parameters initialized by core will be used by the image type code */ +struct mkimage_params params = { + .os = IH_OS_LINUX, + .arch = IH_ARCH_PPC, + .type = IH_TYPE_KERNEL, + .comp = IH_COMP_GZIP, + .dtc = MKIMAGE_DEFAULT_DTC_OPTIONS, +}; + +/* + * mkimage_register - + * + * It is used to register respective image generation/list support to the + * mkimage core + * + * the input struct image_type_params is checked and appended to the link + * list, if the input structure is already registered, error + */ +void mkimage_register (struct image_type_params *tparams) +{ + struct image_type_params **tp; + + if (!tparams) { + fprintf (stderr, "%s: %s: Null input\n", + params.cmdname, __FUNCTION__); + exit (EXIT_FAILURE); + } + + /* scan the linked list, check for registry and point the last one */ + for (tp = &mkimage_tparams; *tp != NULL; tp = &(*tp)->next) { + if (!strcmp((*tp)->name, tparams->name)) { + fprintf (stderr, "%s: %s already registered\n", + params.cmdname, tparams->name); + return; + } + } + + /* add input struct entry at the end of link list */ + *tp = tparams; + /* mark input entry as last entry in the link list */ + tparams->next = NULL; + + debug ("Registered %s\n", tparams->name); +} + +/* + * mkimage_get_type - + * + * It scans all registers image type supports + * checks the input type_id for each supported image type + * + * if successful, + * returns respective image_type_params pointer if success + * if input type_id is not supported by any of image_type_support + * returns NULL + */ +struct image_type_params *mkimage_get_type(int type) +{ + struct image_type_params *curr; + + for (curr = mkimage_tparams; curr != NULL; curr = curr->next) { + if (curr->check_image_type) { + if (!curr->check_image_type (type)) + return curr; + } + } + return NULL; +} + +/* + * mkimage_verify_print_header - + * + * It scans mkimage_tparams link list, + * verifies image_header for each supported image type + * if verification is successful, prints respective header + * + * returns negative if input image format does not match with any of + * supported image types + */ +int mkimage_verify_print_header (void *ptr, struct stat *sbuf) +{ + int retval = -1; + struct image_type_params *curr; + + for (curr = mkimage_tparams; curr != NULL; curr = curr->next ) { + if (curr->verify_header) { + retval = curr->verify_header ( + (unsigned char *)ptr, sbuf->st_size, + ¶ms); + + if (retval == 0) { + /* + * Print the image information + * if verify is successful + */ + if (curr->print_header) + curr->print_header (ptr); + else { + fprintf (stderr, + "%s: print_header undefined for %s\n", + params.cmdname, curr->name); + } + break; + } + } + } + return retval; +}
int main (int argc, char **argv) { int ifd = -1; - uint32_t checksum; - uint32_t addr; - uint32_t ep; struct stat sbuf; unsigned char *ptr; - char *name = ""; int retval = 0; + struct image_type_params *tparams = NULL;
- cmdname = *argv; + /* Init FIT image generation/list support */ + init_fit_image_type (); + /* Init Default image generation/list support */ + init_default_image_type ();
- addr = ep = 0; + params.cmdname = *argv; + params.addr = params.ep = 0;
while (--argc > 0 && **++argv == '-') { while (*++*argv) { switch (**argv) { case 'l': - lflag = 1; + params.lflag = 1; break; case 'A': if ((--argc <= 0) || - (opt_arch = genimg_get_arch_id (*++argv)) < 0) + (params.arch = + genimg_get_arch_id (*++argv)) < 0) usage (); goto NXTARG; case 'C': if ((--argc <= 0) || - (opt_comp = genimg_get_comp_id (*++argv)) < 0) + (params.comp = + genimg_get_comp_id (*++argv)) < 0) usage (); goto NXTARG; case 'D': if (--argc <= 0) usage (); - opt_dtc = *++argv; + params.dtc = *++argv; goto NXTARG;
case 'O': if ((--argc <= 0) || - (opt_os = genimg_get_os_id (*++argv)) < 0) + (params.os = + genimg_get_os_id (*++argv)) < 0) usage (); goto NXTARG; case 'T': if ((--argc <= 0) || - (opt_type = genimg_get_type_id (*++argv)) < 0) + (params.type = + genimg_get_type_id (*++argv)) < 0) usage (); goto NXTARG;
case 'a': if (--argc <= 0) usage (); - addr = strtoul (*++argv, (char **)&ptr, 16); + params.addr = strtoul (*++argv, + (char **)&ptr, 16); if (*ptr) { fprintf (stderr, "%s: invalid load address %s\n", - cmdname, *argv); + params.cmdname, *argv); exit (EXIT_FAILURE); } goto NXTARG; case 'd': if (--argc <= 0) usage (); - datafile = *++argv; - dflag = 1; + params.datafile = *++argv; + params.dflag = 1; goto NXTARG; case 'e': if (--argc <= 0) usage (); - ep = strtoul (*++argv, (char **)&ptr, 16); + params.ep = strtoul (*++argv, + (char **)&ptr, 16); if (*ptr) { fprintf (stderr, "%s: invalid entry point %s\n", - cmdname, *argv); + params.cmdname, *argv); exit (EXIT_FAILURE); } - eflag = 1; + params.eflag = 1; goto NXTARG; case 'f': if (--argc <= 0) usage (); - datafile = *++argv; - fflag = 1; + params.datafile = *++argv; + params.fflag = 1; goto NXTARG; case 'n': if (--argc <= 0) usage (); - name = *++argv; + params.imagename = *++argv; goto NXTARG; case 'v': - vflag++; + params.vflag++; break; case 'x': - xflag++; + params.xflag++; break; default: usage (); @@ -152,91 +249,112 @@ main (int argc, char **argv) NXTARG: ; }
- if ((argc != 1) || - (dflag && (fflag || lflag)) || - (fflag && (dflag || lflag)) || - (lflag && (dflag || fflag))) - usage(); + if (argc != 1) + usage (); + + /* set tparams as per input type_id */ + tparams = mkimage_get_type(params.type); + if (tparams == NULL) { + fprintf (stderr, "%s: unsupported type %s\n", + params.cmdname, genimg_get_type_name(params.type)); + exit (EXIT_FAILURE); + }
- if (!eflag) { - ep = addr; + /* + * check the passed arguments parameters meets the requirements + * as per image type to be generated/listed + */ + if (tparams->check_params) + if (tparams->check_params (¶ms)) + usage (); + + if (!params.eflag) { + params.ep = params.addr; /* If XIP, entry point must be after the U-Boot header */ - if (xflag) - ep += image_get_header_size (); + if (params.xflag) + params.ep += tparams->header_size; }
/* * If XIP, ensure the entry point is equal to the load address plus * the size of the U-Boot header. */ - if (xflag) { - if (ep != addr + image_get_header_size ()) { + if (params.xflag) { + if (params.ep != params.addr + tparams->header_size) { fprintf (stderr, "%s: For XIP, the entry point must be the load addr + %lu\n", - cmdname, - (unsigned long)image_get_header_size ()); + params.cmdname, + (unsigned long)tparams->header_size); exit (EXIT_FAILURE); } }
- imagefile = *argv; + params.imagefile = *argv;
- if (!fflag){ - if (lflag) { - ifd = open (imagefile, O_RDONLY|O_BINARY); + if (!params.fflag){ + if (params.lflag) { + ifd = open (params.imagefile, O_RDONLY|O_BINARY); } else { - ifd = open (imagefile, + ifd = open (params.imagefile, O_RDWR|O_CREAT|O_TRUNC|O_BINARY, 0666); }
if (ifd < 0) { fprintf (stderr, "%s: Can't open %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, + strerror(errno)); exit (EXIT_FAILURE); } }
- if (lflag) { + if (params.lflag) { /* * list header information of existing image */ if (fstat(ifd, &sbuf) < 0) { fprintf (stderr, "%s: Can't stat %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, + strerror(errno)); exit (EXIT_FAILURE); }
- if ((unsigned)sbuf.st_size < image_get_header_size ()) { + if ((unsigned)sbuf.st_size < tparams->header_size) { fprintf (stderr, - "%s: Bad size: "%s" is no valid image\n", - cmdname, imagefile); + "%s: Bad size: "%s" is not valid image\n", + params.cmdname, params.imagefile); exit (EXIT_FAILURE); }
ptr = mmap(0, sbuf.st_size, PROT_READ, MAP_SHARED, ifd, 0); if (ptr == MAP_FAILED) { fprintf (stderr, "%s: Can't read %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, + strerror(errno)); exit (EXIT_FAILURE); }
- if (!(retval = fdt_check_header (ptr))) { - /* FIT image */ - fit_print_contents (ptr); - } else if (!(retval = image_verify_header ((char *)ptr, - sbuf.st_size))) { - /* old-style image */ - image_print_contents ((image_header_t *)ptr); - } + /* + * scan through mkimage registry for all supported image types + * and verify the input image file header for match + * Print the image information for matched image type + * Returns the error code if not matched + */ + retval = mkimage_verify_print_header (ptr, &sbuf);
(void) munmap((void *)ptr, sbuf.st_size); (void) close (ifd);
exit (retval); - } else if (fflag) { - /* Flattened Image Tree (FIT) format handling */ - debug ("FIT format handling\n"); - fit_handle_file (); + } else if (params.fflag) { + if (tparams->fflag_handle) + /* + * in some cases, some additional processing needs + * to be done if fflag is defined + * + * For ex. fit_handle_file for Fit file support + */ + retval = tparams->fflag_handle(¶ms); + exit (retval); }
@@ -245,16 +363,17 @@ NXTARG: ; * * write dummy header, to be fixed later */ - memset (hdr, 0, image_get_header_size ()); + memset (tparams->hdr, 0, tparams->header_size);
- if (write(ifd, hdr, image_get_header_size ()) != image_get_header_size ()) { + if (write(ifd, tparams->hdr, tparams->header_size) + != tparams->header_size) { fprintf (stderr, "%s: Write error on %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, strerror(errno)); exit (EXIT_FAILURE); }
- if (opt_type == IH_TYPE_MULTI || opt_type == IH_TYPE_SCRIPT) { - char *file = datafile; + if (params.type == IH_TYPE_MULTI || params.type == IH_TYPE_SCRIPT) { + char *file = params.datafile; uint32_t size;
for (;;) { @@ -267,7 +386,7 @@ NXTARG: ;
if (stat (file, &sbuf) < 0) { fprintf (stderr, "%s: Can't stat %s: %s\n", - cmdname, file, strerror(errno)); + params.cmdname, file, strerror(errno)); exit (EXIT_FAILURE); } size = cpu_to_uimage (sbuf.st_size); @@ -277,7 +396,8 @@ NXTARG: ;
if (write(ifd, (char *)&size, sizeof(size)) != sizeof(size)) { fprintf (stderr, "%s: Write error on %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, + strerror(errno)); exit (EXIT_FAILURE); }
@@ -293,7 +413,7 @@ NXTARG: ; } }
- file = datafile; + file = params.datafile;
for (;;) { char *sep = strchr(file, ':'); @@ -308,7 +428,7 @@ NXTARG: ; } } } else { - copy_file (ifd, datafile, 0); + copy_file (ifd, params.datafile, 0); }
/* We're a bit of paranoid */ @@ -320,45 +440,34 @@ NXTARG: ;
if (fstat(ifd, &sbuf) < 0) { fprintf (stderr, "%s: Can't stat %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, strerror(errno)); exit (EXIT_FAILURE); }
ptr = mmap(0, sbuf.st_size, PROT_READ|PROT_WRITE, MAP_SHARED, ifd, 0); if (ptr == MAP_FAILED) { fprintf (stderr, "%s: Can't map %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, strerror(errno)); exit (EXIT_FAILURE); }
- hdr = (image_header_t *)ptr; - - checksum = crc32 (0, - (const unsigned char *)(ptr + - image_get_header_size ()), - sbuf.st_size - image_get_header_size () - ); - - /* Build new header */ - image_set_magic (hdr, IH_MAGIC); - image_set_time (hdr, sbuf.st_mtime); - image_set_size (hdr, sbuf.st_size - image_get_header_size ()); - image_set_load (hdr, addr); - image_set_ep (hdr, ep); - image_set_dcrc (hdr, checksum); - image_set_os (hdr, opt_os); - image_set_arch (hdr, opt_arch); - image_set_type (hdr, opt_type); - image_set_comp (hdr, opt_comp); - - image_set_name (hdr, name); - - checksum = crc32 (0, (const unsigned char *)hdr, - image_get_header_size ()); - - image_set_hcrc (hdr, checksum); + /* Setup the image header as per input image type*/ + if (tparams->set_header) + tparams->set_header (ptr, &sbuf, ifd, ¶ms); + else { + fprintf (stderr, "%s: Can't set header for %s: %s\n", + params.cmdname, tparams->name, strerror(errno)); + exit (EXIT_FAILURE); + }
- image_print_contents (hdr); + /* Print the image information by processing image header */ + if (tparams->print_header) + tparams->print_header (ptr); + else { + fprintf (stderr, "%s: Can't print header for %s: %s\n", + params.cmdname, tparams->name, strerror(errno)); + exit (EXIT_FAILURE); + }
@@ -371,7 +480,7 @@ NXTARG: ;
if (close(ifd)) { fprintf (stderr, "%s: Write error on %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, strerror(errno)); exit (EXIT_FAILURE); }
@@ -388,31 +497,32 @@ copy_file (int ifd, const char *datafile, int pad) int zero = 0; int offset = 0; int size; + struct image_type_params *tparams = mkimage_get_type (params.type);
- if (vflag) { + if (params.vflag) { fprintf (stderr, "Adding Image %s\n", datafile); }
if ((dfd = open(datafile, O_RDONLY|O_BINARY)) < 0) { fprintf (stderr, "%s: Can't open %s: %s\n", - cmdname, datafile, strerror(errno)); + params.cmdname, datafile, strerror(errno)); exit (EXIT_FAILURE); }
if (fstat(dfd, &sbuf) < 0) { fprintf (stderr, "%s: Can't stat %s: %s\n", - cmdname, datafile, strerror(errno)); + params.cmdname, datafile, strerror(errno)); exit (EXIT_FAILURE); }
ptr = mmap(0, sbuf.st_size, PROT_READ, MAP_SHARED, dfd, 0); if (ptr == MAP_FAILED) { fprintf (stderr, "%s: Can't read %s: %s\n", - cmdname, datafile, strerror(errno)); + params.cmdname, datafile, strerror(errno)); exit (EXIT_FAILURE); }
- if (xflag) { + if (params.xflag) { unsigned char *p = NULL; /* * XIP: do not append the image_header_t at the @@ -420,29 +530,29 @@ copy_file (int ifd, const char *datafile, int pad) * reserved for it. */
- if ((unsigned)sbuf.st_size < image_get_header_size ()) { + if ((unsigned)sbuf.st_size < tparams->header_size) { fprintf (stderr, "%s: Bad size: "%s" is too small for XIP\n", - cmdname, datafile); + params.cmdname, datafile); exit (EXIT_FAILURE); }
- for (p = ptr; p < ptr + image_get_header_size (); p++) { + for (p = ptr; p < ptr + tparams->header_size; p++) { if ( *p != 0xff ) { fprintf (stderr, "%s: Bad file: "%s" has invalid buffer for XIP\n", - cmdname, datafile); + params.cmdname, datafile); exit (EXIT_FAILURE); } }
- offset = image_get_header_size (); + offset = tparams->header_size; }
size = sbuf.st_size - offset; if (write(ifd, ptr + offset, size) != size) { fprintf (stderr, "%s: Write error on %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, strerror(errno)); exit (EXIT_FAILURE); }
@@ -450,7 +560,8 @@ copy_file (int ifd, const char *datafile, int pad)
if (write(ifd, (char *)&zero, 4-tail) != 4-tail) { fprintf (stderr, "%s: Write error on %s: %s\n", - cmdname, imagefile, strerror(errno)); + params.cmdname, params.imagefile, + strerror(errno)); exit (EXIT_FAILURE); } } @@ -464,7 +575,7 @@ usage () { fprintf (stderr, "Usage: %s -l image\n" " -l ==> list image header information\n", - cmdname); + params.cmdname); fprintf (stderr, " %s [-x] -A arch -O os -T type -C comp " "-a addr -e ep -n name -d data_file[:data_file...] image\n" " -A ==> set architecture to 'arch'\n" @@ -476,157 +587,9 @@ usage () " -n ==> set image name to 'name'\n" " -d ==> use image data from 'datafile'\n" " -x ==> set XIP (execute in place)\n", - cmdname); + params.cmdname); fprintf (stderr, " %s [-D dtc_options] -f fit-image.its fit-image\n", - cmdname); + params.cmdname);
exit (EXIT_FAILURE); } - -static int -image_verify_header (char *ptr, int image_size) -{ - int len; - const unsigned char *data; - uint32_t checksum; - image_header_t header; - image_header_t *hdr = &header; - - /* - * create copy of header so that we can blank out the - * checksum field for checking - this can't be done - * on the PROT_READ mapped data. - */ - memcpy (hdr, ptr, sizeof(image_header_t)); - - if (be32_to_cpu(hdr->ih_magic) != IH_MAGIC) { - fprintf (stderr, - "%s: Bad Magic Number: "%s" is no valid image\n", - cmdname, imagefile); - return -FDT_ERR_BADMAGIC; - } - - data = (const unsigned char *)hdr; - len = sizeof(image_header_t); - - checksum = be32_to_cpu(hdr->ih_hcrc); - hdr->ih_hcrc = cpu_to_be32(0); /* clear for re-calculation */ - - if (crc32 (0, data, len) != checksum) { - fprintf (stderr, - "%s: ERROR: "%s" has bad header checksum!\n", - cmdname, imagefile); - return -FDT_ERR_BADSTATE; - } - - data = (const unsigned char *)ptr + sizeof(image_header_t); - len = image_size - sizeof(image_header_t) ; - - if (crc32 (0, data, len) != be32_to_cpu(hdr->ih_dcrc)) { - fprintf (stderr, - "%s: ERROR: "%s" has corrupted data!\n", - cmdname, imagefile); - return -FDT_ERR_BADSTRUCTURE; - } - return 0; -} - -/** - * fit_handle_file - main FIT file processing function - * - * fit_handle_file() runs dtc to convert .its to .itb, includes - * binary data, updates timestamp property and calculates hashes. - * - * datafile - .its file - * imagefile - .itb file - * - * returns: - * only on success, otherwise calls exit (EXIT_FAILURE); - */ -static void fit_handle_file (void) -{ - char tmpfile[MKIMAGE_MAX_TMPFILE_LEN]; - char cmd[MKIMAGE_MAX_DTC_CMDLINE_LEN]; - int tfd; - struct stat sbuf; - unsigned char *ptr; - - /* call dtc to include binary properties into the tmp file */ - if (strlen (imagefile) + strlen (MKIMAGE_TMPFILE_SUFFIX) + 1 > - sizeof (tmpfile)) { - fprintf (stderr, "%s: Image file name (%s) too long, " - "can't create tmpfile", - imagefile, cmdname); - exit (EXIT_FAILURE); - } - sprintf (tmpfile, "%s%s", imagefile, MKIMAGE_TMPFILE_SUFFIX); - - /* dtc -I dts -O -p 200 datafile > tmpfile */ - sprintf (cmd, "%s %s %s > %s", - MKIMAGE_DTC, opt_dtc, datafile, tmpfile); - debug ("Trying to execute "%s"\n", cmd); - if (system (cmd) == -1) { - fprintf (stderr, "%s: system(%s) failed: %s\n", - cmdname, cmd, strerror(errno)); - unlink (tmpfile); - exit (EXIT_FAILURE); - } - - /* load FIT blob into memory */ - tfd = open (tmpfile, O_RDWR|O_BINARY); - - if (tfd < 0) { - fprintf (stderr, "%s: Can't open %s: %s\n", - cmdname, tmpfile, strerror(errno)); - unlink (tmpfile); - exit (EXIT_FAILURE); - } - - if (fstat (tfd, &sbuf) < 0) { - fprintf (stderr, "%s: Can't stat %s: %s\n", - cmdname, tmpfile, strerror(errno)); - unlink (tmpfile); - exit (EXIT_FAILURE); - } - - ptr = mmap (0, sbuf.st_size, PROT_READ|PROT_WRITE, MAP_SHARED, tfd, 0); - if (ptr == MAP_FAILED) { - fprintf (stderr, "%s: Can't read %s: %s\n", - cmdname, tmpfile, strerror(errno)); - unlink (tmpfile); - exit (EXIT_FAILURE); - } - - /* check if ptr has a valid blob */ - if (fdt_check_header (ptr)) { - fprintf (stderr, "%s: Invalid FIT blob\n", cmdname); - unlink (tmpfile); - exit (EXIT_FAILURE); - } - - /* set hashes for images in the blob */ - if (fit_set_hashes (ptr)) { - fprintf (stderr, "%s Can't add hashes to FIT blob", cmdname); - unlink (tmpfile); - exit (EXIT_FAILURE); - } - - /* add a timestamp at offset 0 i.e., root */ - if (fit_set_timestamp (ptr, 0, sbuf.st_mtime)) { - fprintf (stderr, "%s: Can't add image timestamp\n", cmdname); - unlink (tmpfile); - exit (EXIT_FAILURE); - } - debug ("Added timestamp successfully\n"); - - munmap ((void *)ptr, sbuf.st_size); - close (tfd); - - if (rename (tmpfile, imagefile) == -1) { - fprintf (stderr, "%s: Can't rename %s to %s: %s\n", - cmdname, tmpfile, imagefile, strerror (errno)); - unlink (tmpfile); - unlink (imagefile); - exit (EXIT_FAILURE); - } -} diff --git a/tools/mkimage.h b/tools/mkimage.h index 70c53ad..a9295b6 100644 --- a/tools/mkimage.h +++ b/tools/mkimage.h @@ -20,6 +20,9 @@ * MA 02111-1307 USA */
+#ifndef _MKIIMAGE_H_ +#define _MKIIMAGE_H_ + #include "os_support.h" #include <errno.h> #include <fcntl.h> @@ -32,7 +35,7 @@ #include <sha1.h> #include "fdt_host.h"
-#define MKIMAGE_DEBUG +#undef MKIMAGE_DEBUG
#ifdef MKIMAGE_DEBUG #define debug(fmt,args...) printf (fmt ,##args) @@ -45,3 +48,99 @@ #define MKIMAGE_DEFAULT_DTC_OPTIONS "-I dts -O dtb -p 500" #define MKIMAGE_MAX_DTC_CMDLINE_LEN 512 #define MKIMAGE_DTC "dtc" /* assume dtc is in $PATH */ + +/* + * This structure defines all such variables those are initialized by + * mkimage main core and need to be referred by image type specific + * functions + */ +struct mkimage_params { + int dflag; + int eflag; + int fflag; + int lflag; + int vflag; + int xflag; + int os; + int arch; + int type; + int comp; + char *dtc; + unsigned int addr; + unsigned int ep; + char *imagename; + char *datafile; + char *imagefile; + char *cmdname; +}; + +/* + * image type specific variables and callback functions + */ +struct image_type_params { + /* name is an identification tag string for added support */ + char *name; + /* + * header size is local to the specific image type to be supported, + * mkimage core treats this as number of bytes + */ + uint32_t header_size; + /* Image type header pointer */ + void *hdr; + /* + * There are several arguments that are passed on the command line + * and are registered as flags in mkimage_params structure. + * This callback function can be used to check the passed arguments + * are in-lined with the image type to be supported + * + * Returns 1 if parameter check is successful + */ + int (*check_params) (struct mkimage_params *); + /* + * This function is used by list command (i.e. mkimage -l <filename>) + * image type verification code must be put here + * + * Returns 0 if image header verification is successful + * otherwise, returns respective negative error codes + */ + int (*verify_header) (unsigned char *, int, struct mkimage_params *); + /* Prints image information abstracting from image header */ + void (*print_header) (void *); + /* + * The header or image contents need to be set as per image type to + * be generated using this callback function. + * further output file post processing (for ex. checksum calculation, + * padding bytes etc..) can also be done in this callback function. + */ + void (*set_header) (void *, struct stat *, int, + struct mkimage_params *); + /* + * Some image generation support for ex (default image type) supports + * more than one type_ids, this callback function is used to check + * whether input (-T <image_type>) is supported by registered image + * generation/list low level code + */ + int (*check_image_type) (uint8_t); + /* This callback function will be executed if fflag is defined */ + int (*fflag_handle) (struct mkimage_params *); + /* pointer to the next registered entry in linked list */ + struct image_type_params *next; +}; + +/* + * Exported functions + */ +void mkimage_register (struct image_type_params *tparams); + +/* + * There is a c file associated with supported image type low level code + * for ex. default_image.c, fit_image.c + * init is the only function referred by mkimage core. + * to avoid a single lined header file, you can define them here + * + * Supported image types init functions + */ +void init_default_image_type (void); +void init_fit_image_type (void); + +#endif /* _MKIIMAGE_H_ */
Dear Prafulla Wadaskar,
Thanks, applied.
I edited the commit message a bit.
I had to clean up some compile warnings: tools/default_image.c:141: warning: initialization from incompatible pointer type tools/fit_image.c:202: warning: initialization from incompatible pointer type I added some "const" attributes while doing this. See patch posted.
Please see the current "mkimage" branch.
This line was still too long, I split it.
- (C) Copyright 2008 Semihalf
- (C) Copyright 2000-2004
- DENX Software Engineering
- Wolfgang Denk, wd@denx.de
- Updated-by: Prafulla Wadaskar prafulla@marvell.com
I fixed the "fir" typo.
In general, just add your (C) Copyright, please. We have the git commit message to document such changes.
Prafulla Wadaskar
