[U-Boot] Marvell Kirkwood Guruplug Server Standard upgrade uboot and standalone app issue
I have a Guruplug server standard that I would like to upgrade with a newer version of u-boot. Serial output during boot currently shows the following:
----------------cut----------------
U-Boot 2009.11-rc1-00602-g8e6db3d (Dec 24 2009 - 03:11:17) Marvell-Plug2
SoC: Kirkwood 88F6281_A0 DRAM: 512 MB NAND: 512 MiB In: serial Out: serial Err: serial Net: egiga0 88E1121 Initialized on egiga0 Hit any key to stop autoboot: 0 Marvell>>
I cloned git://git.denx.de/u-boot-marvell.git and built u-boot off master branch:
make mrproper make guruplug_config make CROSS_COMPILE=arm-none-eabi- u-boot.kwb
I wanted to verify that my uboot works properly on my device before committing to flash since I don't have a JTAG available at the moment. However, when I tftp the new u-boot.bin image to the device and issue a "go 0x......" command it never starts (no output after "Starting application at ...".
Also, to do a sanity check I tried to get the standalone hello_world.bin to run in the current u-boot and I am unable to get this to work. I loaded the hellow_world.bin to 0x0c100000 (tftp 0x0c100000 hello_world.bin" and then I issue "go 0x0c100000" and again nothing is printed after the "Starting application at ..." is printed by u-boot.
So my questions are what am I doing wrong and am I using the right repo, branch, and configuration?
Appreciate any pointers.
No one have any idea? Can someone tell me whether this is the right repo/branch for the guruplug server standard and this uboot should work with it?
Any ideas what can be wrong?
Thanks!
Hi
branch:
Sorry I can't answer your specific questions but if you want to avoid flashing a board take a look at the kwboot tool. I've used it quite successfully on boards with similar Marvell processors test out new images and to unbrick boards.
On 05/06/2017 01:18 AM, Chris Packham wrote:
Hi
On 6/05/2017 3:57 PM, "Kernel Hacker" <kernel.hacker8@gmail.com mailto:kernel.hacker8@gmail.com> wrote:
On 04/25/2017 09:04 PM, Kernel Hacker wrote: I have a Guruplug server standard that I would like to upgrade with a newer version of u-boot. Serial output during boot currently shows the following:
Great, that worked! Thanks!
Chris Packham
Kernel Hacker
