[U-Boot] [PATCH] kconfig: fix typo 'parition'
%s/parition/partition
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
common/spl/Kconfig | 2 +- drivers/i2c/muxes/Kconfig | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0ad1e049a9..b44b7412fd 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -409,7 +409,7 @@ config SPL_LIBCOMMON_SUPPORT an SPL build.
config SPL_LIBDISK_SUPPORT - bool "Support disk paritions" + bool "Support disk partitions" help Enable support for disk partitions within SPL. 'Disk' is something of a misnomer as it includes non-spinning media such as flash (as diff --git a/drivers/i2c/muxes/Kconfig b/drivers/i2c/muxes/Kconfig index 156380c1cc..b0da67ce2c 100644 --- a/drivers/i2c/muxes/Kconfig +++ b/drivers/i2c/muxes/Kconfig @@ -31,7 +31,7 @@ config I2C_MUX_PCA954x help If you say yes here you get support for the TI PCA954x I2C mux/switch devices. It is x width I2C multiplexer which enables to - paritioning I2C bus and connect multiple devices with the same address + partitioning I2C bus and connect multiple devices with the same address to the same I2C controller where driver handles proper routing to target i2c device. PCA9544 and PCA9548 are supported.
On 13 Aug 2018, at 11:34, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Make this a whole sentence to make it easier to read.
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
On Mon, Aug 13, 2018 at 12:46 PM Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Sure I can. I was only following example of other such patches...
Simon
Replaced misspelled words "parition"/"paritioning" (missing 't') in two Kconfig files by correct words "partition"/"partitioning"
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
Changes in v2: - Improve commit message
On 16 Aug 2018, at 09:44, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Dr. Philipp Tomsich
Simon Goldschmidt
