[PATCH] board: ti: Kconfig: Correct invalid Kconfig syntax
Kconfig does not support using 'select' to select a 'choice'. A choice can be configured by either setting the choice symbol to 'y' in a configuration file or by setting a 'default' of the choice.
In board/ti/*/Kconfig the SOC_K3_* choice is already set to 'y' in their corresponding configs/*_defconfig file. So remove selecting it.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am62ax/Kconfig | 2 -- board/ti/am62x/Kconfig | 2 -- board/ti/am64x/Kconfig | 2 -- board/ti/am65x/Kconfig | 2 -- board/ti/j721e/Kconfig | 4 ---- board/ti/j721s2/Kconfig | 2 -- 6 files changed, 14 deletions(-)
diff --git a/board/ti/am62ax/Kconfig b/board/ti/am62ax/Kconfig index 2c18cd49b5..9b868e4553 100644 --- a/board/ti/am62ax/Kconfig +++ b/board/ti/am62ax/Kconfig @@ -10,7 +10,6 @@ choice config TARGET_AM62A7_A53_EVM bool "TI K3 based AM62A7 EVM running on A53" select ARM64 - select SOC_K3_AM62A7 imply BOARD imply SPL_BOARD imply TI_I2C_BOARD_DETECT @@ -20,7 +19,6 @@ config TARGET_AM62A7_R5_EVM select CPU_V7R select SYS_THUMB_BUILD select K3_LOAD_SYSFW - select SOC_K3_AM62A7 select RAM select SPL_RAM select K3_DDRSS diff --git a/board/ti/am62x/Kconfig b/board/ti/am62x/Kconfig index 87fed44df1..5e8dfa3cc4 100644 --- a/board/ti/am62x/Kconfig +++ b/board/ti/am62x/Kconfig @@ -10,14 +10,12 @@ choice config TARGET_AM625_A53_EVM bool "TI K3 based AM625 EVM running on A53" select ARM64 - select SOC_K3_AM625
config TARGET_AM625_R5_EVM bool "TI K3 based AM625 EVM running on R5" select CPU_V7R select SYS_THUMB_BUILD select K3_LOAD_SYSFW - select SOC_K3_AM625 select RAM select SPL_RAM select K3_DDRSS diff --git a/board/ti/am64x/Kconfig b/board/ti/am64x/Kconfig index 8036947e34..afb54f8cda 100644 --- a/board/ti/am64x/Kconfig +++ b/board/ti/am64x/Kconfig @@ -9,7 +9,6 @@ choice config TARGET_AM642_A53_EVM bool "TI K3 based AM642 EVM running on A53" select ARM64 - select SOC_K3_AM642 imply BOARD imply SPL_BOARD imply TI_I2C_BOARD_DETECT @@ -19,7 +18,6 @@ config TARGET_AM642_R5_EVM select CPU_V7R select SYS_THUMB_BUILD select K3_LOAD_SYSFW - select SOC_K3_AM642 select RAM select SPL_RAM select K3_DDRSS diff --git a/board/ti/am65x/Kconfig b/board/ti/am65x/Kconfig index 4765b13ba0..220dd0234c 100644 --- a/board/ti/am65x/Kconfig +++ b/board/ti/am65x/Kconfig @@ -10,7 +10,6 @@ choice config TARGET_AM654_A53_EVM bool "TI K3 based AM654 EVM running on A53" select ARM64 - select SOC_K3_AM654 select SYS_DISABLE_DCACHE_OPS select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT @@ -19,7 +18,6 @@ config TARGET_AM654_R5_EVM bool "TI K3 based AM654 EVM running on R5" select CPU_V7R select SYS_THUMB_BUILD - select SOC_K3_AM654 select K3_LOAD_SYSFW select K3_AM654_DDRSS imply SYS_K3_SPL_ATF diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index d19d30d59e..ca8273954a 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -10,7 +10,6 @@ choice config TARGET_J721E_A72_EVM bool "TI K3 based J721E EVM running on A72" select ARM64 - select SOC_K3_J721E select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS @@ -19,7 +18,6 @@ config TARGET_J721E_R5_EVM bool "TI K3 based J721E EVM running on R5" select CPU_V7R select SYS_THUMB_BUILD - select SOC_K3_J721E select K3_LOAD_SYSFW select RAM select SPL_RAM @@ -30,7 +28,6 @@ config TARGET_J721E_R5_EVM config TARGET_J7200_A72_EVM bool "TI K3 based J7200 EVM running on A72" select ARM64 - select SOC_K3_J721E select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS @@ -39,7 +36,6 @@ config TARGET_J7200_R5_EVM bool "TI K3 based J7200 EVM running on R5" select CPU_V7R select SYS_THUMB_BUILD - select SOC_K3_J721E select K3_LOAD_SYSFW select RAM select SPL_RAM diff --git a/board/ti/j721s2/Kconfig b/board/ti/j721s2/Kconfig index 6141798333..067c56a470 100644 --- a/board/ti/j721s2/Kconfig +++ b/board/ti/j721s2/Kconfig @@ -10,7 +10,6 @@ choice config TARGET_J721S2_A72_EVM bool "TI K3 based J721S2 EVM running on A72" select ARM64 - select SOC_K3_J721S2 select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS @@ -19,7 +18,6 @@ config TARGET_J721S2_R5_EVM bool "TI K3 based J721S2 EVM running on R5" select CPU_V7R select SYS_THUMB_BUILD - select SOC_K3_J721S2 select K3_LOAD_SYSFW select RAM select SPL_RAM
Neha Malcom Francis
