[U-Boot] [PATCH v2] rockchip: rk3288: Fix pinctrl for GPIO bank 0
Bank 0 is the "PMU GPIO" bank which is controlled by the PMU registers rather than the GRF registers. In the GRF the top half of the register is used as a mask so that some bits can be updated without affecting the others, but in the PMU this feature is not provided and the top half of the register is reserved.
Take the same approach as the Linux driver to update the value via read-modify-write but setting the mask for only the bits that have changed. The PMU registers ignore the top 16 bits so this works for both GRF and PMU iomux registers.
Signed-off-by: John Keeping john@metanate.com
Changes in v2: - Clear mask before setting muxval - Add comments explaining why rk_clrsetreg() can't be used
drivers/pinctrl/rockchip/pinctrl_rk3288.c | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3288.c b/drivers/pinctrl/rockchip/pinctrl_rk3288.c index 8cb3b82..0cdaac0 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3288.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3288.c @@ -589,6 +589,7 @@ static int rk3288_pinctrl_set_pins(struct udevice *dev, int banknum, int index, struct rk3288_pinctrl_priv *priv = dev_get_priv(dev); uint shift, ind = index; uint mask; + uint value; u32 *addr; int ret;
@@ -597,7 +598,18 @@ static int rk3288_pinctrl_set_pins(struct udevice *dev, int banknum, int index, &mask); if (ret) return ret; - rk_clrsetreg(addr, mask << shift, muxval << shift); + + /* + * PMU_GPIO0 registers cannot be selectively written so we cannot use + * rk_clrsetreg() here. However, the upper 16 bits are reserved and + * are ignored when written, so we can use the same code as for the + * other GPIO banks providing that we preserve the value of the other + * bits. + */ + value = readl(addr); + value &= ~(mask << shift); + value |= (mask << (shift + 16)) | (muxval << shift); + writel(value, addr);
/* Handle pullup/pulldown */ if (flags) { @@ -615,7 +627,12 @@ static int rk3288_pinctrl_set_pins(struct udevice *dev, int banknum, int index, addr = &priv->grf->gpio1_p[banknum - 1][ind]; debug("%s: addr=%p, val=%x, shift=%x\n", __func__, addr, val, shift); - rk_clrsetreg(addr, 3 << shift, val << shift); + + /* As above, rk_clrsetreg() cannot be used here. */ + value = readl(addr); + value &= ~(mask << shift); + value |= (3 << (shift + 16)) | (val << shift); + writel(value, addr); }
Hi John,
Changes in v2:
- uint value; u32 *addr; int ret;
* bits.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
On 25 July 2016 at 03:16, Kever Yang kever.yang@rock-chips.com wrote:
Hi John,
Changes in v2:
@@ -597,7 +598,18 @@ static int rk3288_pinctrl_set_pins(struct udeviceuint value; u32 *addr; int ret;
use
and
the
other
* bits.
writel(value, addr); /* Handle pullup/pulldown */ if (flags) {
writel(value, addr); } return 0;
Thanks,
- Kever
Applied to u-boot-rockchip, thanks!
John Keeping
Kever Yang
