[U-Boot] [PATCH 0/2] i2c:gpio:s5p I2C GPIO rework
Below patches are supposed to adapt S5P processor's GPIO subsystem to soft_i2c software GPIO framework.
For this purpose some renaming has been performed. Patch tested at GONI reference target.
Lukasz Majewski (2): gpio:samsung s5p_ suffix add for GPIO functions i2c:gpio:s5p: I2C GPIO Software implementation (via soft_i2c)
arch/arm/include/asm/arch-s5pc1xx/gpio.h | 18 +++++---- arch/arm/include/asm/arch-s5pc2xx/gpio.h | 16 ++++---- board/samsung/goni/goni.c | 63 +++++++++++++++++++++++++++-- board/samsung/smdkc100/smdkc100.c | 2 +- board/samsung/smdkv310/smdkv310.c | 8 ++-- drivers/gpio/s5p_gpio.c | 20 +++++----- include/configs/s5p_goni.h | 13 ++++++ 7 files changed, 104 insertions(+), 36 deletions(-)
This change is driven by need of general gpio_* functions, which as their parameter are accepting the GPIO pin number, NOT block and pin.
This makes the code alike to omap, and allows for using I2C software generic framework.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 16 ++++++++-------- arch/arm/include/asm/arch-s5pc2xx/gpio.h | 16 ++++++++-------- board/samsung/goni/goni.c | 8 ++++---- board/samsung/smdkc100/smdkc100.c | 2 +- board/samsung/smdkv310/smdkv310.c | 8 ++++---- drivers/gpio/s5p_gpio.c | 20 ++++++++++---------- 6 files changed, 35 insertions(+), 35 deletions(-)
diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index 485b9bf..903de9c 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -126,14 +126,14 @@ struct s5pc110_gpio { };
/* functions */ -void gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg); -void gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en); -void gpio_direction_input(struct s5p_gpio_bank *bank, int gpio); -void gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en); -unsigned int gpio_get_value(struct s5p_gpio_bank *bank, int gpio); -void gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); -void gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); -void gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); +void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg); +void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en); +void s5p_gpio_direction_input(struct s5p_gpio_bank *bank, int gpio); +void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en); +unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); +void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); +void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); +void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); #endif
/* Pin configurations */ diff --git a/arch/arm/include/asm/arch-s5pc2xx/gpio.h b/arch/arm/include/asm/arch-s5pc2xx/gpio.h index 38303e4..8db5895 100644 --- a/arch/arm/include/asm/arch-s5pc2xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc2xx/gpio.h @@ -80,14 +80,14 @@ struct s5pc210_gpio_part3 { };
/* Pin configurations */ diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 581935d..e24cd29 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -73,7 +73,7 @@ int board_mmc_init(bd_t *bis) int i;
/* MASSMEMORY_EN: XMSMDATA7: GPJ2[7] output high */ - gpio_direction_output(&s5pc110_gpio->j2, 7, 1); + s5p_gpio_direction_output(&s5pc110_gpio->j2, 7, 1);
/* * MMC0 GPIO @@ -86,11 +86,11 @@ int board_mmc_init(bd_t *bis) if (i == 2) continue; /* GPG0[0:6] special function 2 */ - gpio_cfg_pin(&s5pc110_gpio->g0, i, 0x2); + s5p_gpio_cfg_pin(&s5pc110_gpio->g0, i, 0x2); /* GPG0[0:6] pull disable */ - gpio_set_pull(&s5pc110_gpio->g0, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&s5pc110_gpio->g0, i, GPIO_PULL_NONE); /* GPG0[0:6] drv 4x */ - gpio_set_drv(&s5pc110_gpio->g0, i, GPIO_DRV_4X); + s5p_gpio_set_drv(&s5pc110_gpio->g0, i, GPIO_DRV_4X); }
return s5p_mmc_init(0, 4); diff --git a/board/samsung/smdkc100/smdkc100.c b/board/samsung/smdkc100/smdkc100.c index 1ad68b9..c41e610 100644 --- a/board/samsung/smdkc100/smdkc100.c +++ b/board/samsung/smdkc100/smdkc100.c @@ -41,7 +41,7 @@ static void smc9115_pre_init(void) (struct s5pc100_gpio *)samsung_get_base_gpio();
/* gpio configuration GPK0CON */ - gpio_cfg_pin(&gpio->k0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio->k0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2));
/* Ethernet needs bus width of 16 bits */ smc_bw_conf = SMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK); diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index acf9ee7..173520e 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -37,7 +37,7 @@ static void smc9115_pre_init(void) u32 smc_bw_conf, smc_bc_conf;
/* gpio configuration GPK0CON */ - gpio_cfg_pin(&gpio2->y0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio2->y0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2));
/* Ethernet needs bus width of 16 bits */ smc_bw_conf = SROMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK); @@ -116,10 +116,10 @@ int board_mmc_init(bd_t *bis) */ for (i = 0; i < 7; i++) { /* GPK2[0:6] special function 2 */ - gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2));
/* GPK2[0:6] drv 4x */ - gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); + s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X);
/* GPK2[0:1] pull disable */ if (i == 0 || i == 1) { @@ -128,7 +128,7 @@ int board_mmc_init(bd_t *bis) }
/* GPK2[2:6] pull up */ - gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); + s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); } err = s5p_mmc_init(2, 4); return err; diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index a1bcddc..2043859 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -36,7 +36,7 @@ #define RATE_MASK(x) (0x1 << (x + 16)) #define RATE_SET(x) (0x1 << (x + 16))
-void gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) +void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) { unsigned int value;
@@ -46,11 +46,11 @@ void gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) writel(value, &bank->con); }
-void gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en) +void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en) { unsigned int value;
- gpio_cfg_pin(bank, gpio, GPIO_OUTPUT); + s5p_gpio_cfg_pin(bank, gpio, GPIO_OUTPUT);
value = readl(&bank->dat); value &= ~DAT_MASK(gpio); @@ -59,12 +59,12 @@ void gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en) writel(value, &bank->dat); }
-void gpio_direction_input(struct s5p_gpio_bank *bank, int gpio) +void s5p_gpio_direction_input(struct s5p_gpio_bank *bank, int gpio) { - gpio_cfg_pin(bank, gpio, GPIO_INPUT); + s5p_gpio_cfg_pin(bank, gpio, GPIO_INPUT); }
-void gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) +void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) { unsigned int value;
@@ -75,7 +75,7 @@ void gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) writel(value, &bank->dat); }
-unsigned int gpio_get_value(struct s5p_gpio_bank *bank, int gpio) +unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio) { unsigned int value;
@@ -83,7 +83,7 @@ unsigned int gpio_get_value(struct s5p_gpio_bank *bank, int gpio) return !!(value & DAT_MASK(gpio)); }
-void gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) +void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) { unsigned int value;
@@ -102,7 +102,7 @@ void gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) writel(value, &bank->pull); }
-void gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode) +void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode) { unsigned int value;
@@ -123,7 +123,7 @@ void gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode) writel(value, &bank->drv); }
-void gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) +void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) { unsigned int value;
Dear Lukasz Majewski,
Please make it single patch. separate from i2c patch.
Thanks Minkyu Kang
This makes the code alike to omap, and allows for using more generic frameworks (e.g. software I2C).
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 16 ++++++++-------- arch/arm/include/asm/arch-s5pc2xx/gpio.h | 16 ++++++++-------- board/samsung/goni/goni.c | 8 ++++---- board/samsung/smdkc100/smdkc100.c | 2 +- board/samsung/smdkv310/smdkv310.c | 8 ++++---- drivers/gpio/s5p_gpio.c | 20 ++++++++++---------- 6 files changed, 35 insertions(+), 35 deletions(-)
Acked-by: Mike Frysinger vapier@gentoo.org -mike
applied to u-boot-samsung
Thanks Minkyu Kang
This is a cosmetic patch, which is changing the gpio_ prefix to s5p_gpio_.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- board/samsung/universal_c210/universal.c | 28 ++++++++++++++-------------- 1 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index b65bc6e..1b27e8b 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -160,7 +160,7 @@ int board_mmc_init(bd_t *bis) * you should set it HIGH since it removes the inverter */ /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ - gpio_direction_output(&gpio1->e3, 6, 0); + s5p_gpio_direction_output(&gpio1->e3, 6, 0); break; default: /* @@ -168,7 +168,7 @@ int board_mmc_init(bd_t *bis) * But set it as HIGH to ensure */ /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ - gpio_direction_output(&gpio1->e1, 3, 1); + s5p_gpio_direction_output(&gpio1->e1, 3, 1); break; }
@@ -192,25 +192,25 @@ int board_mmc_init(bd_t *bis) if (i == 2) continue; /* GPK0[0:6] special function 2 */ - gpio_cfg_pin(&gpio2->k0, i, 0x2); + s5p_gpio_cfg_pin(&gpio2->k0, i, 0x2); /* GPK0[0:6] pull disable */ - gpio_set_pull(&gpio2->k0, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio2->k0, i, GPIO_PULL_NONE); /* GPK0[0:6] drv 4x */ - gpio_set_drv(&gpio2->k0, i, GPIO_DRV_4X); + s5p_gpio_set_drv(&gpio2->k0, i, GPIO_DRV_4X); }
for (i = 3; i < 7; i++) { /* GPK1[3:6] special function 3 */ - gpio_cfg_pin(&gpio2->k1, i, 0x3); + s5p_gpio_cfg_pin(&gpio2->k1, i, 0x3); /* GPK1[3:6] pull disable */ - gpio_set_pull(&gpio2->k1, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio2->k1, i, GPIO_PULL_NONE); /* GPK1[3:6] drv 4x */ - gpio_set_drv(&gpio2->k1, i, GPIO_DRV_4X); + s5p_gpio_set_drv(&gpio2->k1, i, GPIO_DRV_4X); }
/* T-flash detect */ - gpio_cfg_pin(&gpio2->x3, 4, 0xf); - gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); + s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); + s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP);
/* * MMC device init @@ -223,7 +223,7 @@ int board_mmc_init(bd_t *bis) * Check the T-flash detect pin * GPX3[4] T-flash detect pin */ - if (!gpio_get_value(&gpio2->x3, 4)) { + if (!s5p_gpio_get_value(&gpio2->x3, 4)) { /* * SD card GPIO: * GPK2[0] SD_2_CLK(2) @@ -235,11 +235,11 @@ int board_mmc_init(bd_t *bis) if (i == 2) continue; /* GPK2[0:6] special function 2 */ - gpio_cfg_pin(&gpio2->k2, i, 0x2); + s5p_gpio_cfg_pin(&gpio2->k2, i, 0x2); /* GPK2[0:6] pull disable */ - gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); /* GPK2[0:6] drv 4x */ - gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); + s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); } err = s5p_mmc_init(2, 4); }
Dear Lukasz,
Thanks Minkyu Kang
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 2 + board/samsung/goni/goni.c | 55 +++++++++++++++++++++++++++++- include/configs/s5p_goni.h | 13 +++++++ 3 files changed, 69 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index 903de9c..108fb64 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -155,4 +155,6 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); #define GPIO_DRV_FAST 0x0 #define GPIO_DRV_SLOW 0x1
+/* GPIO pins per bank */ +#define GPIO_PER_BANK 8 #endif diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index e24cd29..dbbd7ed 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -1,7 +1,8 @@ /* - * Copyright (C) 2008-2009 Samsung Electronics + * Copyright (C) 2008-2011 Samsung Electronics * Minkyu Kang mk7.kang@samsung.com * Kyungmin Park kyungmin.park@samsung.com + * Lukasz Majewski l.majewski@samsung.com * * See file CREDITS for list of people who contributed to this * project. @@ -96,3 +97,55 @@ int board_mmc_init(bd_t *bis) return s5p_mmc_init(0, 4); } #endif + +#ifdef CONFIG_SOFT_I2C + +enum { I2C_PMIC, I2C_NUM, }; + +void i2c_init_board(void) {} + +int s5p_gpio_get_nr(void *gp_ptr, int gpio) +{ + unsigned int offset = gp_ptr - (void *) s5pc110_gpio; + offset /= sizeof(struct s5p_gpio_bank); + + return (offset * GPIO_PER_BANK) + gpio; +} + +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr) +{ + int bank = nr / GPIO_PER_BANK; + bank *= sizeof(struct s5p_gpio_bank); + + return (struct s5p_gpio_bank *) ((void *) s5pc110_gpio + bank); +} + +inline int s5p_gpio_get_pin(int nr) +{ + return nr % GPIO_PER_BANK; +} + +inline int gpio_direction_input(int nr) +{ + s5p_gpio_direction_input(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); +} + +inline int gpio_direction_output(int nr, int value) +{ + s5p_gpio_direction_output(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); +} + +inline int gpio_get_value(int nr) +{ + return (int) s5p_gpio_get_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); +} + +inline void gpio_set_value(int nr, int value) +{ + s5p_gpio_set_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); +} +#endif diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 010428b..ee87927 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -224,4 +224,17 @@
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
+#include <asm/arch/gpio.h> +/* + * I2C Settings + */ +#define S5PC110_GPIO_J3 (S5PC110_GPIO_BASE + 0x2C0) +#define CONFIG_SOFT_I2C_GPIO_SCL s5p_gpio_get_nr(S5PC110_GPIO_J3, 3) +#define CONFIG_SOFT_I2C_GPIO_SDA s5p_gpio_get_nr(S5PC110_GPIO_J3, 0) + +#define CONFIG_SOFT_I2C 1 +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_SYS_I2C_SPEED 50000 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS 7 #endif /* __CONFIG_H */
You missing commit message.
- Copyright (C) 2008-2009 Samsung Electronics
- Copyright (C) 2008-2011 Samsung Electronics
- Lukasz Majewski l.majewski@samsung.com
What purpose of these enum? Where these used?
- unsigned int offset = gp_ptr - (void *) s5pc110_gpio;
- offset /= sizeof(struct s5p_gpio_bank);
- return (offset * GPIO_PER_BANK) + gpio;
- int bank = nr / GPIO_PER_BANK;
- bank *= sizeof(struct s5p_gpio_bank);
- return (struct s5p_gpio_bank *) ((void *) s5pc110_gpio + bank);
- return nr % GPIO_PER_BANK;
- s5p_gpio_direction_input(s5p_gpio_get_bank(nr),
- s5p_gpio_get_pin(nr));
- s5p_gpio_direction_output(s5p_gpio_get_bank(nr),
- s5p_gpio_get_pin(nr), value);
- return (int) s5p_gpio_get_value(s5p_gpio_get_bank(nr),
- s5p_gpio_set_value(s5p_gpio_get_bank(nr),
+} +#endif
I think It's not a board specific. Please make common file for I2C gpio for s5p.
- I2C Settings
I have one question. How we can handle multiple bus? I mean.. how we can change SCL and SDA?
+#define CONFIG_SOFT_I2C 1 +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_SYS_I2C_SPEED 50000 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS 7 #endif /* __CONFIG_H */ -- 1.7.2.3
Thanks Minkyu Kang
Hi Minkyu,
For now goni reference target is going to use only one I2C bus (implemented as soft_i2c GPIO). Therefore this enum will be erased for v2. In the future, however this might be needed.
I've asked this question to Heiko Schocher already. Please refer to this reply:
http://lists.denx.de/pipermail/u-boot/2011-July/095610.html
This patch adds support for software I2C for GONI reference target. It adds support for access to GPIOs by number, not as it is present, by bank and offset.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com Cc: Heiko Schocher hs@denx.de
--- Changes for v2: - Generic GPIO code added to arch/arm/gpio.h - Platform dependent GPIO code added to board/samsung/goni.c - Code cleanup --- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 36 ++++++++++++++++++++++++++++++ board/samsung/goni/goni.c | 30 +++++++++++++++++++++++- include/configs/s5p_goni.h | 13 ++++++++++ 3 files changed, 77 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index 903de9c..8d2e2e9 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -134,6 +134,40 @@ unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr); +int s5p_gpio_get_pin(int nr); + +static inline int gpio_request(int gpio, const char *label) +{ + return 0; +} + +static inline int gpio_direction_input(int nr) +{ + s5p_gpio_direction_input(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); + return 0; +} + +static inline int gpio_direction_output(int nr, int value) +{ + s5p_gpio_direction_output(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); + return 0; +} + +static inline int gpio_get_value(int nr) +{ + return (int) s5p_gpio_get_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); +} + +static inline void gpio_set_value(int nr, int value) +{ + s5p_gpio_set_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); +} + #endif
/* Pin configurations */ @@ -155,4 +189,6 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); #define GPIO_DRV_FAST 0x0 #define GPIO_DRV_SLOW 0x1
+/* GPIO pins per bank */ +#define GPIO_PER_BANK 8 #endif diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index e24cd29..d1ff956 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -1,7 +1,8 @@ /* - * Copyright (C) 2008-2009 Samsung Electronics + * Copyright (C) 2008-2011 Samsung Electronics * Minkyu Kang mk7.kang@samsung.com * Kyungmin Park kyungmin.park@samsung.com + * Lukasz Majewski l.majewski@samsung.com * * See file CREDITS for list of people who contributed to this * project. @@ -28,7 +29,7 @@
DECLARE_GLOBAL_DATA_PTR;
-static struct s5pc110_gpio *s5pc110_gpio; +struct s5pc110_gpio *s5pc110_gpio;
int board_init(void) { @@ -96,3 +97,28 @@ int board_mmc_init(bd_t *bis) return s5p_mmc_init(0, 4); } #endif + +#ifdef CONFIG_SOFT_I2C +void i2c_init_board(void) {} +/* Platform dependent functions for extracting GPIO number */ +int s5p_gpio_get_nr(void *gp_ptr, int gpio) +{ + unsigned int offset = gp_ptr - (void *) s5pc110_gpio; + offset /= sizeof(struct s5p_gpio_bank); + + return (offset * GPIO_PER_BANK) + gpio; +} + +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr) +{ + int bank = nr / GPIO_PER_BANK; + bank *= sizeof(struct s5p_gpio_bank); + + return (struct s5p_gpio_bank *) ((void *) s5pc110_gpio + bank); +} + +int s5p_gpio_get_pin(int nr) +{ + return nr % GPIO_PER_BANK; +} +#endif diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 010428b..7af1b5f 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -224,4 +224,17 @@
+#include <asm/arch/gpio.h> +/* + * I2C Settings + */ +#define S5PC110_GPIO_J3 (S5PC110_GPIO_BASE + 0x2C0) +#define CONFIG_SOFT_I2C_GPIO_SCL s5p_gpio_get_nr(S5PC110_GPIO_J3, 3) +#define CONFIG_SOFT_I2C_GPIO_SDA s5p_gpio_get_nr(S5PC110_GPIO_J3, 0) + +#define CONFIG_SOFT_I2C 1 +#define CONFIG_SYS_I2C_SPEED 50000 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS 7 + #endif /* __CONFIG_H */
please add s5pc2xx also.
Why?
+} +#endif
I think these codes are not board specific. Please make common file for I2C gpio for s5p.
Thanks Minkyu Kang
--- Changes for v2: - Generic GPIO code added to arch/arm/gpio.h - Platform dependent GPIO code added to board/samsung/goni.c - Code cleanup Changes for v3: - I2C GPIO common code added to drivers/gpio/s5p_gpio.c - i2c_init_board() function added(required by soft_i2c) --- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 38 ++++++++++++++++++++++++++++++ board/samsung/goni/goni.c | 16 ++++++++---- drivers/gpio/s5p_gpio.c | 24 +++++++++++++++++++ include/configs/s5p_goni.h | 14 +++++++++++ 4 files changed, 86 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index 903de9c..619ba6f 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -134,6 +134,41 @@ unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr); +int s5p_gpio_get_pin(int nr); + +static inline int gpio_request(int gpio, const char *label) +{ + return 0; +} + +static inline int gpio_direction_input(int nr) +{ + s5p_gpio_direction_input(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); + return 0; +} + +static inline int gpio_direction_output(int nr, int value) +{ + s5p_gpio_direction_output(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); + return 0; +} + +static inline int gpio_get_value(int nr) +{ + return (int) s5p_gpio_get_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); +} + +static inline void gpio_set_value(int nr, int value) +{ + s5p_gpio_set_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); +} + +extern struct s5pc110_gpio *s5p_gpio; #endif
/* Pin configurations */ @@ -155,4 +190,7 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); #define GPIO_DRV_FAST 0x0 #define GPIO_DRV_SLOW 0x1
+/* GPIO pins per bank */ +#define GPIO_PER_BANK 8 + #endif diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index e24cd29..354f5ad 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -28,12 +28,12 @@
-static struct s5pc110_gpio *s5pc110_gpio; +struct s5pc110_gpio *s5p_gpio;
int board_init(void) { /* Set Initial global variables */ - s5pc110_gpio = (struct s5pc110_gpio *)S5PC110_GPIO_BASE; + s5p_gpio = (struct s5pc110_gpio *)S5PC110_GPIO_BASE;
gd->bd->bi_arch_number = MACH_TYPE_GONI; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; @@ -67,13 +67,17 @@ int checkboard(void) } #endif
+#ifdef CONFIG_SOFT_I2C +void i2c_init_board(void) {} +#endif + #ifdef CONFIG_GENERIC_MMC int board_mmc_init(bd_t *bis) { int i;
/* MASSMEMORY_EN: XMSMDATA7: GPJ2[7] output high */ - s5p_gpio_direction_output(&s5pc110_gpio->j2, 7, 1); + s5p_gpio_direction_output(&s5p_gpio->j2, 7, 1);
/* * MMC0 GPIO @@ -86,11 +90,11 @@ int board_mmc_init(bd_t *bis) if (i == 2) continue; /* GPG0[0:6] special function 2 */ - s5p_gpio_cfg_pin(&s5pc110_gpio->g0, i, 0x2); + s5p_gpio_cfg_pin(&s5p_gpio->g0, i, 0x2); /* GPG0[0:6] pull disable */ - s5p_gpio_set_pull(&s5pc110_gpio->g0, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&s5p_gpio->g0, i, GPIO_PULL_NONE); /* GPG0[0:6] drv 4x */ - s5p_gpio_set_drv(&s5pc110_gpio->g0, i, GPIO_DRV_4X); + s5p_gpio_set_drv(&s5p_gpio->g0, i, GPIO_DRV_4X); }
return s5p_mmc_init(0, 4); diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 2043859..e247b6f 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -141,3 +141,27 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode)
writel(value, &bank->drv); } + +#ifdef CONFIG_SOFT_I2C +/* Platform dependent functions for extracting GPIO number */ +int s5p_gpio_get_nr(void *gp_ptr, int gpio) +{ + unsigned int offset = gp_ptr - (void *) s5p_gpio; + offset /= sizeof(struct s5p_gpio_bank); + + return (offset * GPIO_PER_BANK) + gpio; +} + +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr) +{ + int bank = nr / GPIO_PER_BANK; + bank *= sizeof(struct s5p_gpio_bank); + + return (struct s5p_gpio_bank *) ((void *) s5p_gpio + bank); +} + +int s5p_gpio_get_pin(int nr) +{ + return nr % GPIO_PER_BANK; +} +#endif diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 381bb39..620dca7 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -223,4 +223,18 @@
+#include <asm/arch/gpio.h> +/* + * I2C Settings + */ +#define S5PC110_GPIO_J3 (S5PC110_GPIO_BASE + 0x2C0) +#define CONFIG_SOFT_I2C_GPIO_SCL s5p_gpio_get_nr(S5PC110_GPIO_J3, 3) +#define CONFIG_SOFT_I2C_GPIO_SDA s5p_gpio_get_nr(S5PC110_GPIO_J3, 0) + +#define CONFIG_SOFT_I2C 1 +#define CONFIG_SYS_I2C_SPEED 50000 +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS 7 + #endif /* __CONFIG_H */
Please adds s5pc2xx also.
Why you removed the "static"? And.. why you change s5pc110_gpio to s5p_gpio? It is unrelated changes with this patch.
- s5p_gpio = (struct s5pc110_gpio *)S5PC110_GPIO_BASE;
Empty function? then please undef CONFIG_SYS_I2C_INIT_BOARD.
- s5p_gpio_direction_output(&s5p_gpio->j2, 7, 1);
unrelated change.
- s5p_gpio_cfg_pin(&s5p_gpio->g0, i, 0x2);
ditto.
- s5p_gpio_set_pull(&s5p_gpio->g0, i, GPIO_PULL_NONE);
ditto.
- s5p_gpio_set_drv(&s5p_gpio->g0, i, GPIO_DRV_4X);
ditto.
I think, we don't have to use ifdef here. These are looks common functions of GPIO.
- unsigned int offset = gp_ptr - (void *) s5p_gpio;
- return (struct s5p_gpio_bank *) ((void *) s5p_gpio + bank);
- I2C Settings
I think, you can divide into 2 patches. One is for GPIO. Another is for enabling soft i2c.
Thanks Minkyu Kang
This patches adds support for I2C GPIO S5PC1xx and S5PC2xx targets. Moreover the I2C GPIO on the S5PC110 GONI reference target is enabled.
Lukasz Majewski (2): i2c:gpio:s5p: I2C GPIO Software implementation (via soft_i2c) i2c:gpio:s5p: Enable I2C GPIO on the GONI target
arch/arm/include/asm/arch-s5pc1xx/gpio.h | 38 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-s5pc2xx/gpio.h | 39 ++++++++++++++++++++++++++++++ board/samsung/goni/goni.c | 2 + board/samsung/universal_c210/universal.c | 2 + drivers/gpio/s5p_gpio.c | 21 ++++++++++++++++ include/configs/s5p_goni.h | 13 ++++++++++ 6 files changed, 115 insertions(+), 0 deletions(-)
--- Changes for v2: - Generic GPIO code added to arch/arm/gpio.h - Platform dependent GPIO code added to board/samsung/goni.c - Code cleanup Changes for v3: - I2C GPIO common code added to drivers/gpio/s5p_gpio.c - i2c_init_board() function added(required by soft_i2c) Changes for v4: - i2x_init_board() removed - s5pc210 support added - GPIO code and I2C enable code split to separate patches --- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 38 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-s5pc2xx/gpio.h | 39 ++++++++++++++++++++++++++++++ board/samsung/goni/goni.c | 2 + board/samsung/universal_c210/universal.c | 2 + drivers/gpio/s5p_gpio.c | 21 ++++++++++++++++ 5 files changed, 102 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index 903de9c..4a5ca87 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -134,6 +134,41 @@ unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr); +int s5p_gpio_get_pin(int nr); + +static inline int gpio_request(int gpio, const char *label) +{ + return 0; +} + +static inline int gpio_direction_input(int nr) +{ + s5p_gpio_direction_input(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); + return 0; +} + +static inline int gpio_direction_output(int nr, int value) +{ + s5p_gpio_direction_output(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); + return 0; +} + +static inline int gpio_get_value(int nr) +{ + return (int) s5p_gpio_get_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); +} + +static inline void gpio_set_value(int nr, int value) +{ + s5p_gpio_set_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); +} + +extern void *s5p_gpio; #endif
+/* GPIO pins per bank */ +#define GPIO_PER_BANK 8 + #endif diff --git a/arch/arm/include/asm/arch-s5pc2xx/gpio.h b/arch/arm/include/asm/arch-s5pc2xx/gpio.h index 8db5895..82aaab5 100644 --- a/arch/arm/include/asm/arch-s5pc2xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc2xx/gpio.h @@ -88,6 +88,41 @@ unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr); +int s5p_gpio_get_pin(int nr); + +static inline int gpio_request(int gpio, const char *label) +{ + return 0; +} + +static inline int gpio_direction_input(int nr) +{ + s5p_gpio_direction_input(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); + return 0; +} + +static inline int gpio_direction_output(int nr, int value) +{ + s5p_gpio_direction_output(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); + return 0; +} + +static inline int gpio_get_value(int nr) +{ + return (int) s5p_gpio_get_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); +} + +static inline void gpio_set_value(int nr, int value) +{ + s5p_gpio_set_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); +} + +extern void *s5p_gpio; #endif
/* Pin configurations */ @@ -108,4 +143,8 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); #define GPIO_DRV_4X 0x3 #define GPIO_DRV_FAST 0x0 #define GPIO_DRV_SLOW 0x1 + +/* GPIO pins per bank */ +#define GPIO_PER_BANK 8 + #endif diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index e24cd29..adc1e0e 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -29,11 +29,13 @@ DECLARE_GLOBAL_DATA_PTR;
static struct s5pc110_gpio *s5pc110_gpio; +void *s5p_gpio;
int board_init(void) { /* Set Initial global variables */ s5pc110_gpio = (struct s5pc110_gpio *)S5PC110_GPIO_BASE; + s5p_gpio = (void *) s5pc110_gpio;
gd->bd->bi_arch_number = MACH_TYPE_GONI; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 1b27e8b..b4a7f86 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -32,6 +32,7 @@ DECLARE_GLOBAL_DATA_PTR;
struct s5pc210_gpio_part1 *gpio1; struct s5pc210_gpio_part2 *gpio2; +void *s5p_gpio; unsigned int board_rev;
u32 get_board_rev(void) @@ -50,6 +51,7 @@ int board_init(void) { gpio1 = (struct s5pc210_gpio_part1 *) S5PC210_GPIO_PART1_BASE; gpio2 = (struct s5pc210_gpio_part2 *) S5PC210_GPIO_PART2_BASE; + s5p_gpio = (void *) gpio1; /* ptr used with I2C SW implementation */
gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 2043859..49c43c7 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -141,3 +141,24 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode)
writel(value, &bank->drv); } + +int s5p_gpio_get_nr(void *gp_ptr, int gpio) +{ + unsigned int offset = gp_ptr - (void *) s5p_gpio; + offset /= sizeof(struct s5p_gpio_bank); + + return (offset * GPIO_PER_BANK) + gpio; +} + +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr) +{ + int bank = nr / GPIO_PER_BANK; + bank *= sizeof(struct s5p_gpio_bank); + + return (struct s5p_gpio_bank *) ((void *) s5p_gpio + bank); +} + +int s5p_gpio_get_pin(int nr) +{ + return nr % GPIO_PER_BANK; +}
arch/arm/include/asm/arch-s5pc1xx/gpio.h | 38 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-s5pc2xx/gpio.h | 39 ++++++++++++++++++++++++++++++ board/samsung/goni/goni.c | 2 + board/samsung/universal_c210/universal.c | 2 + drivers/gpio/s5p_gpio.c | 21 ++++++++++++++++ 5 files changed, 102 insertions(+), 0 deletions(-) diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index e24cd29..adc1e0e 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -29,11 +29,13 @@ DECLARE_GLOBAL_DATA_PTR;
- s5p_gpio = (void *) s5pc110_gpio;
I can't understand it. Why is it need? If you want to get gpio base address, then use the define value directly. s5p_gpio pointer is unnecessary.
- s5p_gpio = (void *) gpio1; /* ptr used with I2C SW implementation */
How can use gpio part2??
As I said.. the purpose of s5p_gpio is to get base address, then please use define value.
And you should solve how can use gpio part2.
Thanks Minkyu Kang.
This patch enables the software I2C for GONI reference target.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com Cc: Heiko Schocher hs@denx.de --- include/configs/s5p_goni.h | 13 +++++++++++++ 1 files changed, 13 insertions(+), 0 deletions(-)
diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 381bb39..79f45b3 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -223,4 +223,17 @@
arch/arm/include/asm/arch-s5pc1xx/gpio.h | 13 +++++++++ arch/arm/include/asm/arch-s5pc2xx/gpio.h | 29 +++++++++++++++++++ drivers/gpio/s5p_gpio.c | 44 ++++++++++++++++++++++++++++++ include/configs/s5p_goni.h | 12 ++++++++ 4 files changed, 98 insertions(+), 0 deletions(-)
--- Changes for v2: - Macros for calculating the pin number from block pointer - Removal of the s5p_gpio generic pointer
This patch adds support for software I2C for GONI and Universal C210 reference targets. It adds support for access to GPIOs by number, not as it is present, by bank and offset.
--- Changes for v2: - Generic GPIO code added to arch/arm/gpio.h - Platform dependent GPIO code added to board/samsung/goni.c - Code cleanup Changes for v3: - I2C GPIO common code added to drivers/gpio/s5p_gpio.c - i2c_init_board() function added(required by soft_i2c) Changes for v4: - i2x_init_board() removed - s5pc210 support added - GPIO code and I2C enable code split to separate patches Changes for v5: - s5p_gpio pointer removed and replaced with generic s5p_gpio_base function - removed duplicated code Changes for v6: - s5pc[1|2]10_gpio_get_nr macro added. More redable code for I2C gpio pins definition --- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 13 +++++++++ arch/arm/include/asm/arch-s5pc2xx/gpio.h | 29 +++++++++++++++++++ drivers/gpio/s5p_gpio.c | 44 ++++++++++++++++++++++++++++++ 3 files changed, 86 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index 903de9c..76b901b 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -134,6 +134,19 @@ unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); + +/* GPIO pins per bank */ +#define GPIO_PER_BANK 8 + +static inline unsigned int s5p_gpio_base(int nr) +{ + return S5PC110_GPIO_BASE; +} + +#define s5pc110_gpio_get_nr(bank, pin) \ + ((((((unsigned int)&(((struct s5pc110_gpio *)S5PC110_GPIO_BASE)->bank))\ + - S5PC110_GPIO_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) #endif
/* Pin configurations */ diff --git a/arch/arm/include/asm/arch-s5pc2xx/gpio.h b/arch/arm/include/asm/arch-s5pc2xx/gpio.h index 8db5895..8be620c 100644 --- a/arch/arm/include/asm/arch-s5pc2xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc2xx/gpio.h @@ -88,6 +88,35 @@ unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); + +/* GPIO pins per bank */ +#define GPIO_PER_BANK 8 + +#define s5pc210_gpio_part1_get_nr(bank, pin) \ + ((((((unsigned int) &(((struct s5pc210_gpio_part1 *) \ + S5PC210_GPIO_PART1_BASE)->bank)) \ + - S5PC210_GPIO_PART1_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + +#define GPIO_PART1_MAX ((sizeof(struct s5pc210_gpio_part1) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define s5pc210_gpio_part2_get_nr(bank, pin) \ + (((((((unsigned int) &(((struct s5pc210_gpio_part2 *) \ + S5PC210_GPIO_PART2_BASE)->bank)) \ + - S5PC210_GPIO_PART2_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + GPIO_PART1_MAX) + +static inline unsigned int s5p_gpio_base(int nr) +{ + if (nr < GPIO_PART1_MAX) + return S5PC210_GPIO_PART1_BASE; + else + return S5PC210_GPIO_PART2_BASE; + + return 0; +} + #endif
/* Pin configurations */ diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 2043859..1edf9a2 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -141,3 +141,47 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode)
writel(value, &bank->drv); } + +struct s5p_gpio_bank *s5p_gpio_get_bank(int nr) +{ + int bank = nr / GPIO_PER_BANK; + bank *= sizeof(struct s5p_gpio_bank); + + return (struct s5p_gpio_bank *) (s5p_gpio_base(nr) + bank); +} + +int s5p_gpio_get_pin(int nr) +{ + return nr % GPIO_PER_BANK; +} + +int gpio_request(int gpio, const char *label) +{ + return 0; +} + +int gpio_direction_input(int nr) +{ + s5p_gpio_direction_input(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); + return 0; +} + +int gpio_direction_output(int nr, int value) +{ + s5p_gpio_direction_output(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); + return 0; +} + +int gpio_get_value(int nr) +{ + return (int) s5p_gpio_get_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr)); +} + +void gpio_set_value(int nr, int value) +{ + s5p_gpio_set_value(s5p_gpio_get_bank(nr), + s5p_gpio_get_pin(nr), value); +}
Thanks Minkyu Kang
--- Changes for v2: - Replace explicit GPIO definition with more readable one --- include/configs/s5p_goni.h | 12 ++++++++++++ 1 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 381bb39..886c8be 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -223,4 +223,16 @@
+#include <asm/arch/gpio.h> +/* + * I2C Settings + */ +#define CONFIG_SOFT_I2C_GPIO_SCL s5pc110_gpio_get_nr(j4, 3) +#define CONFIG_SOFT_I2C_GPIO_SDA s5pc110_gpio_get_nr(j4, 0) + +#define CONFIG_SOFT_I2C 1 +#define CONFIG_SYS_I2C_SPEED 50000 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS 7 + #endif /* __CONFIG_H */
Thanks Minkyu Kang
Lukasz Majewski
Mike Frysinger
Minkyu Kang
