[U-Boot] [PATCH] common: board_f: Dont relocate FDT incase of CONFIG_OF_EMBED
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Done relocate fdt incase of CONFIG_OF EMBED as the fdt is already embedded with u-boot image. Also update the fdt_blob correctly in this case
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
common/board_f.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index b035c90ff3b7..91bf8beea1c6 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -508,7 +508,7 @@ static int reserve_global_data(void) return 0; }
-static int reserve_fdt(void) +static int __maybe_unused reserve_fdt(void) { /* * If the device tree is sitting immediately above our image then we @@ -658,7 +658,7 @@ static int setup_dram_config(void) return 0; }
-static int reloc_fdt(void) +static int __maybe_unused reloc_fdt(void) { if (gd->flags & GD_FLG_SKIP_RELOC) return 0; @@ -687,6 +687,9 @@ static int setup_reloc(void) gd->reloc_off = gd->relocaddr - (CONFIG_SYS_TEXT_BASE + 0x400); #endif #endif +#ifdef CONFIG_OF_EMBED + gd->fdt_blob += gd->reloc_off; +#endif memcpy(gd->new_gd, (char *)gd, sizeof(gd_t));
debug("Relocation Offset is: %08lx\n", gd->reloc_off); @@ -938,7 +941,9 @@ static init_fnc_t init_sequence_f[] = { #endif setup_machine, reserve_global_data, +#ifndef CONFIG_OF_EMBED reserve_fdt, +#endif reserve_arch, reserve_stacks, setup_dram_config, @@ -955,7 +960,9 @@ static init_fnc_t init_sequence_f[] = { setup_board_extra, #endif INIT_FUNC_WATCHDOG_RESET +#ifndef CONFIG_OF_EMBED reloc_fdt, +#endif setup_reloc, #if defined(CONFIG_X86) || defined(CONFIG_ARC) copy_uboot_to_ram,
Hi Michal,
Probably it was meant to be something like: ------------------->8------------------- __Don't__ relocate fdt in__case of CONFIG_OF EMBED as the fdt is ------------------->8-------------------
Otherwise, Reviewed-by: Alexey Brodkin abrodkin@synopsys.com
-Alexey
On 26.11.2015 12:18, Alexey Brodkin wrote:
Hi Michal,
Ah yeah. Will fix it in v2.
Thanks, Michal
Alexey Brodkin
Michal Simek
